02-Layer 2 Configuration Guide
HomeSupportWirelessWX3000E Series Wireless SwitchesConfigure & DeployConfiguration GuidesH3C WX3000E Series Wireless Switches Switching Engine Configuration Guides(R3507P26)-6W10202-Layer 2 Configuration Guide
00-Preface
00-Preface 85.13 KB
Preface
The H3C WX3000E documentation set includes eight configuration guides, which describe the software features for the H3C WX3000E Series Wireless Switches Switching Engine and guide you through the software configuration procedures. These configuration guides also provide configuration examples to help you apply software features to different network scenarios.
The Layer 2 Configuration Guide describes the fundamentals and configuration of Layer 2 interfaces, MAC address table, Ethernet link aggregation, port isolation, MSTP, VLAN, GVRP, QinQ, and LLDP.
This preface includes:
·          Audience
·          Conventions
·          Documentation feedback
Audience
·          Network planners
·          Field technical support and servicing engineers
·          Network administrators working with the WX series
Conventions
This section describes the conventions used in this documentation set.
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one.
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK.
Symbols
Convention
WARNING WARNING
CAUTION CAUTION
IMPORTANT IMPORTANT
NOTE
TIP TIP
Network topology icons
Represents an access controller, an access controller module, or a switching engine on a wireless switch.
Represents an access point.
Port numbering in examples
The port numbers in this document are for illustration only and might be unavailable on your device.
We appreciate your comments.
