H3C WX Series Access Controllers License Registration and Activation Guide-6W102
HomeSupportConfigure & DeployUser ManualsH3C WX Series Access Controllers License Registration and Activation Guide-6W102
01-Text
01-Text 377.84 KB
Overview
License-based features require a license to run on your device. The features include increase of online AP number, Wireless Intrusion Prevention System (WIPS), Intelligent Application Aware (IAA), and Radio Frequency Prevention (RFP). To use a license-based feature, you must obtain a license.
The following types of licenses are available depending on validity period:
·          Official—An official license never expires.
·          Trial—A trial license has a trial period, and the feature becomes unusable when the trial period expires. You must purchase an official license for the feature.
The following types of licenses are available depending on the requirement for license activation:
·          StandardTo activate a standard license, you must provide the license key and activation key.
·          EnhancedTo activate an enhanced license, you only need to provide the activation key.
This document describes how to license a feature for the H3C WX series. The WX series includes access controllers, unified wired-WLAN modules, and switching engines on unified wired-WLAN switches.
Licensing procedure
Tasks at a glance
Remarks
Registering licenses:
·         Registering licenses for the first time—Registers a license for a device that has never been activated.
·         Registering upgrade licenses—Registers a license for add-on nodes, add-on features, or time extension.
H3C website provides the license registration function.
Activating licenses
N/A
Figure 1 shows the generic licensing procedure.
Figure 1 Licensing procedure
1.        Visit the H3C website at www.h3c.com.hk. Select Technical Support > Product Licensing > Register the First Time.
Figure 2 Registering a license for the first time
2.        Select WLAN_H3C WLAN Access Controller from the Product category dropdown list, and click Submit.
Figure 3 Selecting a product category
3.        Enter the license, device, and contact information, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
Figure 4 Entering the information
Table 1 Field description
Item
Remarks
License key
Enter the license key provided on New H3C Technologies Co., Ltd. Software License Certificate.
Required.
H3C device S/N
Enter the device serial number, a string of 20 characters.
You can obtain the number by using one of the following methods:
·         Check the number on the chassis.
·         Check the bar code provided on the warranty card.
·         Select Overview > Device from the navigation tree at the Web interface of the device. The number is displayed on the left of the page.
·         Use the display device serial-number command at the CLI.
Required.
CHECK_SUM
Enter the 8-byte checksum for the device serial number.
You can use the display device serial-number command at the CLI to display the checksum.
Required.
Customer company/organization
Enter the name of the company or organization that uses the device.
Required.
Company/Organization
Enter your company or organization name.
Required.
First name
Enter your first name.
Required.
Last name
Enter your last name.
Optional.
Phone number
Enter your phone number.
Required.
Email address
Enter your email address.
H3C will send a copy of the activation key to your email box in addition to providing it on the registration result page.
Required.
Zip code
Enter the zip code of your region.
Optional.
Address
Enter your address.
Optional.
Project name
Enter the name of the project that uses the device.
Optional.
Verify code
Enter the code literally as is displayed on the image to the right of the text box.
Required.
4.        On the dialog box that appears, confirm to register the license.
5.        When the operation success page appears, save the activation key.
Follow the procedure described in "Activating licenses" to activate the licenses on your device.
Figure 5 Registration success
1.        Visit the H3C website at www.h3c.com.hk, and select Technical Support > Product Licensing > Register Upgrade Licenses.
Figure 6 Registering an upgrade license
Figure 7 Selecting a product category
3.        Enter the device information and click Submit.
Figure 8 Entering the device information
4.        On the page that appears, enter the license and contact information, select I accept all terms of H3C Legal Statement, and click Get activation key or file.
Figure 9 Entering the information for license upgrade
5.        On the dialog box that appears, confirm to register the license.
6.        When the operation success page appears, save the activation key.
Follow the procedure described in "Activating licenses" to activate the license on your device.
Figure 10 Registration success
Activating licenses
This chapter describes the license activation procedure for the WX5004 through the Web interface. Activation procedures for other access controllers are similar.
Building the network environment
1.        Connect the Ethernet port of the AC to a PC by using a crossover Ethernet cable.
Figure 11 Connecting PC and AC
2.        Assign an IP address (except for 192.168.0.100) to the PC. Ensure that the PC and the AC can reach each other.
The default IP address of the AC's management Ethernet interface is 192.168.0.100. For example, assign 192.168.0.2 to the PC.
3.        Launch the browser and enter http://192.168.0.100 in the address bar.
The Web User Login page appears.
4.        Enter admin for User Name and admin for Password, select English from the Language dropdown list, and click Login.
Figure 12 Login page of the Web interface
Standard and enhanced licenses are activated on different Web interfaces. Before activating your license, check your activation key to determine whether you are activating a standard or an enhanced license:
·          If the activation key is a string of 20 characters, such as 0E60F01DD07102DE532C, you are activating a standard license.
·          If the activation key is a string of hyphenated characters, for example 3130A0J3-1-PQustbsE-&gJTxaKd-9e&&HcbW, you are activating an enhanced license.
1.        From the navigation tree, select Device > License.
The License page appears for you to activate a standard license. To activate an enhanced license, go to step 3.
2.        To activate a standard license:
a.    On the License page, enter the license key and the activation key.
b.    Click Add.
Figure 13 Adding a standard license
Table 2 Field description
Item
License Key
Activation Key
Enter the activation key. For information about obtaining an activation key, see "Registering licenses."
3.        To activate an enhanced license:
a.    Click the Enhanced License tab.
b.    Select the feature name, enter the activation key, and click Add.
Figure 14 Adding an enhanced license
Table 3 Field description
Item
Feature Name
Select the name of the feature to be registered.
·         WAPI—Supports WAPI.
·         AP—Increases the number of online APs.
·         IAA—Supports IAA.
·         RFP—Supports RFP.
Activation Key
4.        Reboot the AC for the license to take effect.
