| 00-Preface | 63.08 KB |
Preface
The H3C access controllers documentation set describes the software features for the H3C access controllers and guide you through the software configuration procedures. These guides also provide configuration examples to help you apply software features to different network scenarios.
The Layer 3—IP Services Configuration Guide describes the configurations of ARP, IP addressing, DHCP, DNS, NAT, IP performance optimization, IPv6 basics, DHCPv6, and GRE.
· Hardware and software compatibility matrix
· Audience
Table 1 Hardware and software compatibility matrix
Model |
Product version |
WX1800H series |
· WX1804H · WX1810H · WX1820H |
· WX1804H-CMW710-E5208P03 · WX1810H-CMW710-E5215P01 · WX1820H-CMW710-E5208P03 |
WX2500H series |
· WX2510H · WX2540H · WX2560H |
· WX2510H-CMW710-R5215P01 · WX2540H-CMW710-R5215P01 · WX2560H-CMW710-R5215P01 |
WX3000H series |
· WX3010H · WX3010H-L · WX3010H-X · WX3024H · WX3024H-L |
· WX3010H-CMW710-R5215P01 · WX3010HL-CMW710-R5215P01 · WX3010HX-CMW710-R5215P01 · WX3024H-CMW710-R5215P01 · WX3024HL-CMW710-R5215P01 |
WX3500H series |
· WX3508H · WX3510H · WX3520H · WX3540H |
· WX3508H-CMW710-R5215P01 · WX3520H-CMW710-R5215P01 · WX3540H-CMW710-R5215P01 |
WX5500E series |
· WX5510E · WX5540E |
· WX5510E-CMW710-R5215P01 · WX5540E-CMW710-R5215P01 |
WX5500H series |
· WX5540H · WX5560H · WX5580H |
· WX5540H-CMW710-R5215P01 · WX5560H-CMW710-R5215P01 · WX5580H-CMW710-R5215P01 |
Access controller modules |
· EWPXM1MAC0F · EWPXM1WCME0 · EWPXM2WCMD0F · LSQM1WCMX20 · LSQM1WCMX40 · LSUM1WCME0 · LSUM1WCMX20RT · LSUM1WCMX40RT |
· WCMX40-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 · WCMX20-CMW710-R5215P01 · WCMX20-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 · WCMX20-CMW710-R5215P01 · WCMX40-CMW710-R5215P01 |
Audience
· Network planners.
· Network administrators working with the H3C access controllers.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Documentation feedback
We appreciate your comments.
