10-Network Management and Monitoring Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10210-Network Management and Monitoring Command Reference
12-PoE commands
12-PoE commands 118.13 KB
PoE commands
apply poe-profile
Use apply poe-profile to apply a PoE profile to a power interface (PI).
Use undo apply poe-profile to remove application of a PoE profile from a PI.
apply poe-profile { index index | name profile-name }
undo apply poe-profile { index index | name profile-name }
No PoE profile is applied to PIs.
PI view
index index: Specifies a PoE profile by its index number in the range of 1 to 100.
name profile-name: Specifies a PoE profile by its name, a case-sensitive string of 1 to 15 characters.
# Apply the PoE profile named forIPphone to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] apply poe-profile name forIPphone
·     apply poe-profile interface
·     display poe-profile
Use apply poe-profile interface to apply a PoE profile to PIs.
Use undo apply poe-profile interface to remove the application of a PoE profile from PIs.
apply poe-profile { index index | name profile-name } interface interface-range
undo apply poe-profile { index index | name profile-name } interface interface-range
No PoE profile is applied to a PI.
interface-range: Specifies a range of Ethernet interfaces in the form of interface-type interface-number [ to interface-type interface-number ], where interface-type interface-number represents the interface type and interface number. The start interface number must be smaller than the end interface number. If an interface in the specified range does not support PoE, it is ignored when the PoE profile is applied.
[Sysname] apply poe-profile name forIPphone interface gigabitethernet 1/0/1
# Apply the PoE profile with index number 1 to PIs GigabitEthernet 1/0/2 to GigabitEthernet 1/0/8.
[Sysname] apply poe-profile index 1 interface gigabitethernet 1/0/2 to gigabitethernet 1/0/8
·     apply poe-profile
·     display poe-profile interface
display poe device
Use display poe device to display brief PSE information, including the ID, slot number, and status of PSEs.
display poe device [ slot slot-number ]
slot slot-number: Specifies an IRF member device by its member ID. If you do not specify a member device, the command displays information about all PSEs in the IRF fabric.
# Display PSE information.
<Sysname> display poe device
 Slot  1:
 PSE ID    Slot No.  SSlot No. PortNum   MaxPower(W)    State   Model
 4          1          0           48         370.0            On      LSP7POEB
Slot
ID of the member device.
PSE ID
ID of the PSE.
Slot No.
Slot number of the PSE.
SSlot No.
Sub-slot number of the PSE.
PortNum
Number of PIs on the PSE.
MaxPower(W)
Maximum power of the PSE.
PSE status:
·     On—The PSE is supplying power.
·     Off—The PSE is not supplying power.
·     Faulty—The PSE has failed.
Model
PSE model.
display poe interface
Use display poe interface to display power supplying information for PIs.
display poe interface [ interface-type interface-number ]
If you do not specify an interface, this command displays power supplying information for all PIs.
# Display power supplying information for GigabitEthernet 1/0/1.
<Sysname> display poe interface gigabitethernet 1/0/1
 PoE Status                  : Enabled
 Power Priority             : Low
 Oper                         : Off
 IEEE Class                  : 0
 Detection Status           : Searching
 Power Mode                  : Signal
 Current Power              : 0        mW
 Average Power              : 0        mW
 Peak Power                  : 0        mW
 Max Power                   : 30000    mW
 Electric Current           : 0        mA
 Voltage                     : 0.0      V
 PD Description
PoE status
PoE status:
·     Enabled.
·     Disabled.
Power Priority
Power supply priority of the PI:
·     Critical (highest).
·     High.
·     Low.
Oper
Operating status of a PI:
·     Off—PoE is disabled.
·     On—Power is being supplied to the PI correctly.
·     Power-lack—Remaining guaranteed power is insufficient for a critical PI.
·     Power-deny—The PSE refuses to supply power. The power required by the PD is higher than the configured power.
·     Power-itself—The PD is using another power supply.
·     Power-limit—The PSE is supplying power to the PD based on the configured power though the PD requires more power than the configured power.
IEEE Class
PD power class: 0, 1, 2, 3, or 4.
If the PSE does not support PD classification, this field displays a hyphen (-).
Detection Status
Power detection status of a PI:
·     Disabled—The PoE function is disabled.
·     Searching—The PI is searching for the PD.
·     Delivering power—The PI is supplying power to the PD.
·     Fault—A fault occurred during the test.
·     Test—The PI is undergoing a test.
·     Other fault—A fault has caused the PSE to enter the idle status.
·     PD disconnected—The PD is disconnected.
Power Mode
Power transmission mode of a PI.
The switch transmits power over signal cables.
Current Power
Current power of a PI, including PD consumption power and transmission loss.
Typical transmission loss is within 1 watt.
Average Power
Average power of a PI.
Peak Power
Peak power of a PI.
Max Power
Maximum power of a PI.
Electric Current
Current of a PI.
Voltage
Voltage of a PI.
PD Description
Type and location description for the PD connected to the PI.
# Display power supplying information for all PIs.
 Interface    PoE       Priority  CurPower  Oper      IEEE  Detection
                                     (W)                    Class Status
 GE1/0/1      Enabled   Low       0.0       Off       0     Searching
 GE1/0/2      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/3      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/4      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/5      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/6      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/7      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/8      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/9      Disabled  Low       0.0       Off       0     Disabled
 GE1/0/10     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/11     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/12     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/13     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/14     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/15     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/16     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/17     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/18     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/19     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/20     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/21     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/22     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/23     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/24     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/25     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/26     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/27     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/28     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/29     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/30     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/31     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/32     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/33     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/34     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/35     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/36     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/37     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/38     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/39     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/40     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/41     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/42     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/43     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/44     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/45     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/46     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/47     Disabled  Low       0.0       Off       0     Disabled
 GE1/0/48     Disabled  Low       0.0       Off       0     Disabled
   ---  On State Ports: 0; Used: 0.0(W); Remaining: 500.0(W)  ---
Interface name of a PI.
PoE
PoE status:
·     Enabled.
·     Disabled.
Priority
Power priority of a PI:
·     High.
·     Low.
CurPower
Current power of a PI.
Oper
IEEE Class
Detection Status
·     Disabled—PoE function is disabled.
·     Delivering Power—The PI is supplying power for the PD.
On State Ports
Number of PIs that are supplying power.
Used
Power consumed by the current PI.
Remaining
Total remaining power of the system.
display poe interface power
Use display poe interface power to display power information for PIs.
display poe interface power [ interface-type interface-number ]
If you do not specify an interface, this command displays power information for all PIs.
# Display power information for GigabitEthernet 1/0/1.
<Sysname> display poe interface power gigabitethernet 1/0/1
 Interface    Current   Peak      Max       PD Description
               (W)        (W)       (W)
 GE1/0/1      0.0        0.0       30.0
# Display power information for all PIs.
               (W)       (W)       (W)
 GE1/0/2      0.0       0.0       30.0
 GE1/0/3      0.0       0.0       30.0
 GE1/0/4      0.0       0.0       30.0
 GE1/0/5      0.0       0.0       30.0
 GE1/0/6      0.0       0.0       30.0
 GE1/0/7      0.0       0.0       30.0
 GE1/0/8      0.0       0.0       30.0
 GE1/0/9      0.0       0.0       30.0
 GE1/0/10     0.0       0.0       30.0
 GE1/0/11     0.0       0.0       30.0
 GE1/0/12     0.0       0.0       30.0
 GE1/0/13     0.0       0.0       30.0
 GE1/0/14     0.0       0.0       30.0
 GE1/0/15     0.0       0.0       30.0
 GE1/0/16     0.0       0.0       30.0
 GE1/0/17     0.0       0.0       30.0
 GE1/0/18     0.0       0.0       30.0
 GE1/0/19     0.0       0.0       30.0
 GE1/0/20     0.0       0.0       30.0
 GE1/0/21     0.0       0.0       30.0
 GE1/0/22     0.0       0.0       30.0
 GE1/0/23     0.0       0.0       30.0
 GE1/0/24     0.0       0.0       30.0
 GE1/0/25     0.0       0.0       30.0
 GE1/0/26     0.0       0.0       30.0
 GE1/0/27     0.0       0.0       30.0
 GE1/0/28     0.0       0.0       30.0
 GE1/0/29     0.0       0.0       30.0
 GE1/0/30     0.0       0.0       30.0
 GE1/0/31     0.0       0.0       30.0
 GE1/0/32     0.0       0.0       30.0
 GE1/0/33     0.0       0.0       30.0
 GE1/0/34     0.0       0.0       30.0
 GE1/0/35     0.0       0.0       30.0
 GE1/0/36     0.0       0.0       30.0
 GE1/0/37     0.0       0.0       30.0
 GE1/0/38     0.0       0.0       30.0
 GE1/0/39     0.0       0.0       30.0
 GE1/0/40     0.0       0.0       30.0
 GE1/0/41     0.0       0.0       30.0
 GE1/0/42     0.0       0.0       30.0
 GE1/0/43     0.0       0.0       30.0
 GE1/0/44     0.0       0.0       30.0
 GE1/0/45     0.0       0.0       30.0
 GE1/0/46     0.0       0.0       30.0
 GE1/0/47     0.0       0.0       30.0
 GE1/0/48     0.0       0.0       30.0
CurPower
PeakPower
Peak power of a PI.
MaxPower
PD Description
Type and location description for the PD connected to a PI.
Ports On
Used
Power consumed by all PIs.
Remaining
display poe pse
Use display poe pse to display PSE information.
display poe pse [ pse-id ]
pse-id: Specifies a PSE by its ID.
If you do not specify a PSE, this command displays information about all PSEs.
# Display detailed information about PSE 7.
<Sysname> display poe pse 7
 PSE ID                               : 7
 Slot No.                            : 1
 SSlot No.                           : 0
 PSE Model                           : LSP7POEB
 PSE Status                          : Enabled
 Current Power                       : 0.0      W
 Average Power                       : 0.0      W
 Peak Power                          : 0.0      W
 Max Power                           : 500.0    W
 Remaining Guaranteed Power       : 500.0    W
 PSE CPLD Version                   : -
 PSE Software Version              : 130
 PSE Hardware Version              : 57633
 Legacy PD Detection               : Disabled
 Power Utilization Threshold      : 80
 PD Power Policy                    : Disabled
 PD Disconnect-Detection Mode     : AC
Table 5 Command output
PSE ID
ID of the PSE.
Slot No.
SSlot No.
Subslot number of the PSE.
PSE Status
PoE status of the PSE:
·     Enabled.
·     Disabled.
Power Priority
Power priority of the PSE.
Current Power
Current power of the PSE.
Average Power
Average power of the PSE.
Peak Power
Peak power of the PSE.
Max Power
Remaining guaranteed power of the PSE = Maximum guaranteed power of the PSE – Total maximum power of all critical PIs of the PSE.
PSE CPLD Version
PSE CPLD version number.
PSE software version number.
PSE hardware version number.
Legacy PD Detection
Nonstandard PD detection status:
·     Enabled.
·     Disabled.
PSE power alarm threshold.
PD Power Policy
PD power management policy mode.
PD Disconnect Detection Mode
PD disconnection detection mode.
display poe pse interface
Use display poe pse interface to display the PoE status of all PIs on a PSE.
display poe pse pse-id interface
pse pse-id: Specifies a PSE ID.
To display PSE ID and slot mappings, use the display poe device command.
# Display the status of all PIs on PSE 7.
<Sysname> display poe pse 7 interface
                                     (W)                    Class Status
Table 6 Command output
PoE
PoE status of a PI:
·     Enabled.
·     Disabled.
Priority
Priority of a PI:
·     High.
·     Low.
CurPower
Oper
IEEE Class
Detection Status
·     Delivering Power—The PI is supplying power to the PD.
·     Other Fault—A fault has caused the PSE to enter the idle status.
·     PD Disconnected—The PD is disconnected.
On State Ports
Used
Power consumed by PIs on the PSE.
Remaining
Remaining power on the PSE.
display poe pse interface power
Use display poe pse interface power to display power information for PIs on a PSE.
display poe pse pse-id interface power
pse pse-id: Specifies a PSE by its ID.
# Display power information for PIs on PSE 7.
<Sysname> display poe pse 7 interface power
               (W)       (W)       (W)
Table 7 Command output
Current
Peak
Peak power of a PI.
Max
PD Description
Type and location description for the PD connected with a PI.
Ports On
Used
Remaining
display poe-profile
Use display poe-profile to display PoE profile information .
display poe-profile [ index index | name profile-name ]
If you do not specify a profile, the command displays information about all PoE profiles.
# Display information about all PoE profiles.
<Sysname> display poe-profile
 PoE Profile     Index   ApplyNum  Interfaces     Configuration
 forIPphone      1        6           GE1/0/5            poe enable
                                        GE1/0/6           poe priority critical
                                        GE1/0/7
                                        GE1/0/8
                                        GE1/0/9
                                        GE1/0/10
 forAP            2        2          GE1/0/11          poe enable
                                        GE1/0/12          poe max-power 14000
   ---  Total PoE profiles: 3, total ports: 0  ---
# Display information about the PoE profile with index number 1.
<Sysname> display poe-profile index 1
                                       GE1/0/7
                                       GE1/0/8
                                       GE1/0/9
                                       GE1/0/1
   ---  Total ports: 0  ---
Table 8 Command output
PoE Profile
Name of the PoE profile.
Index
Index number of the PoE profile.
ApplyNum
Number of PIs to which the PoE profile is applied.
Interfaces
Interface name of the PI to which the PoE configuration is applied.
Configuration
Configurations of the PoE profile.
Total PoE profiles
Number of PoE profiles.
Total ports
Number of PIs to which all PoE profiles are applied.
Use display poe-profile interface to display information about the PoE profile on a PI.
display poe-profile interface interface-type interface-number
# Display information about the PoE profile on GigabitEthernet 1/0/1.
<Sysname> display poe-profile interface gigabitethernet 1/0/1
 PoEProfile     Index   ApplyNum  Interface   Effective configuration
 forIPphone      1        6          GE1/0/1       poe enable
The Effective configuration field displays the configurations that have taken effect. For the descriptions of other fields, see Table 8.
poe enable
Use poe enable to enable PoE on a PI.
Use undo poe enable to disable PoE on a PI.
poe enable
undo poe enable
PoE is disabled on a PI.
PI view
PoE profile view
If a PoE profile has been applied to a PI, remove the application before configuring the PI in PoE profile view.
If a PI has been configured, remove the configuration before configuring the PI in PI view.
# Enable PoE on a PI in PI view.
[Sysname-GigabitEthernet1/0/1] poe enable
# Enable PoE on a PI in PoE profile view.
[Sysname] poe-profile abc
[Sysname-poe-profile-abc-1] poe enable
·     display poe interface
·     poe-profile
poe enable pse
Use poe enable pse to enable PoE for a PSE.
Use undo poe enable pse to disable PoE for the PSE.
poe enable pse pse-id
undo poe enable pse pse-id
PoE is disabled on PSEs.
# Enable PoE for PSE 7.
[Sysname] poe enable pse 7
display poe pse
poe legacy enable
Use poe legacy enable to enable a PSE to detect nonstandard PDs.
Use undo poe legacy enable to disable the PSE from detecting nonstandard PDs.
poe legacy enable pse pse-id
undo poe legacy enable pse pse-id
Nonstandard PD detection is disabled.
# Enable PSE 7 to detect nonstandard PDs.
[Sysname] poe legacy enable pse 7
display poe pse
poe max-power
Use poe max-power to configure the maximum power for a PI.
Use undo poe max-power to restore the default.
poe max-power max-power
undo poe max-power
The maximum power of a PI is 30000 milliwatts.
PI view
PoE profile view
max-power: Sets the maximum power in the range of 1000 milliwatts to 30000 milliwatts.
# Set the maximum power of a PI to 12000 milliwatts in PI view.
[Sysname-GigabitEthernet1/0/1] poe max-power 12000
# Set the maximum power of a PI to 12000 milliwatts in PoE profile view.
[Sysname-poe-profile-abc-1] poe max-power 12000
poe pd-description
Use poe pd-description to configure a description for the PD that connects to a PI.
Use undo poe pd-description to restore the default.
poe pd-description text
No description is available for the PD that connects to a PI.
PI view
text: Configures a description for the PD connected to the PI, a case-sensitive string of 1 to 80 characters.
# Configure the description for the PD as IP Phone for Room 101.
[Sysname] interface gigabitEthernet 1/0/1
[Sysname-GigabitEthernet1/0/1] poe pd-description IP Phone For Room 101
poe pd-policy priority
Use poe pd-policy priority to enable PI power management.
Use undo poe pd-policy priority to restore the default.
PI power management is disabled.
If PI power management is enabled, when a PSE is overloaded, the PSE allocates power to new PDs based on the priority of their PIs. Otherwise, the PSE does not supply power to new PDs.
# Enable PI power management.
[Sysname] poe pd-policy priority
poe priority
poe priority
Use poe priority to configure a power supply priority for a PI.
Use undo poe priority to restore the default.
poe priority { critical | high | low }
undo poe priority
The power priority of a PI is low.
PI view
PoE profile view
critical: Sets the power supply priority to critical. The PI with critical power priority operates in guaranteed mode. Power is first supplied to the PD connected to the critical PI.
high: Sets the power supply priority to high.
low: Sets the power supply priority to low.
When the PoE power is insufficient, power is first supplied to PIs with higher priority.
For PIs with same power supply priority, the PI with the smallest ID is allocated with power first.
# Set the power supply priority of the PI to critical in PI view.
[Sysname-GigabitEthernet1/0/1] poe priority critical
# Set the power supply priority of the PI to critical in PoE profile view.
[Sysname-poe-profile-abc-1] poe priority critical
[Sysname-poe-profile-abc-1] quit
[Sysname-GigabitEthernet1/0/1] apply poe-profile name abc
poe update
Use poe update to upgrade a PSE firmware when the device is operating.
poe update { full | refresh } filename [ pse pse-id ]
full: Upgrades the PSE firmware in full mode.
refresh: Upgrades the PSE firmware in refresh mode.
filename: Specifies the name of the upgrade file, a case-sensitive string of 1 to 64 characters. The specified file must be in the root directory of the file system of the device.
pse pse-id: Specifies a PSE by its ID. If you do not specify a PSE, PSEs of all member devices of the IRF fabric are upgraded.
Typically, you can upgrade the firmware in refresh mode. Upgrade the firmware in full mode only in the following cases:
·     You fail to upgrade the software in refresh mode.
·     The current firmware is unavailable, and execution of all PoE commands fail.
# Upgrade the firmware of PSE 7 in service.
[Sysname] poe update refres poeupdate.bin pse 7
poe-profile
Use poe-profile to create a PoE profile and enter PoE profile view.
Use undo poe-profile to delete the specified PoE profile.
poe-profile profile-name [ index ]
undo poe-profile { index index | name profile-name }
No PoE profile is created.
profile-name: Specifies a PoE profile name, a case-sensitive string of 1 to 15 characters. A PoE configuration file name begins with a letter and must not contain reserved keywords including undo, all, name, interface, user, poe, disable, max-power, mode, priority, or enable.
index: Specifies the index number of a PoE profile, in the range of 1 to 100.
If you do not specify a profile index, the system automatically assigns an index (starting from 1) to the PoE profile.
If a PoE profile is applied, use the undo apply poe-profile command to remove the application before deleting the PoE profile.
# Create a PoE profile, name it abc, and specify the index number as 3.
[Sysname] poe-profile abc 3
[Sysname-poe-profile-abc-3]
# Create a PoE profile and name it def. Do not specify the index number.
[Sysname] poe-profile def
[Sysname-poe-profile-def-1]
·     apply poe-profile
·     poe enable
·     poe max-power
·     poe priority
poe utilization-threshold
Use poe utilization-threshold to configure a power alarm threshold for a PSE.
Use undo poe utilization-threshold to restore the default power alarm threshold of a PSE.
poe utilization-threshold value pse pse-id
undo poe utilization-threshold pse pse-id
The power alarm threshold for the PSE is 80%.
value: Specifies alarm threshold as a percentage of 1 to 99.
If PSE power utilization crosses the threshold multiple times in succession, the system sends notification messages only for the first crossing. For more information, see "Configuring SNMP."
# Set the power alarm threshold of PSE 7 to 90%.
[Sysname] poe utilization-threshold 90 pse 7
