09-High Availability Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10209-High Availability Command Reference
08-BFD commands
08-BFD commands 105.31 KB
BFD commands
The term "interface" in this chapter refers to Layer 2 aggregate interfaces and Layer 3 interfaces, including VLAN interfaces and Layer 3 Ethernet interfaces. You can set an Ethernet port as a Layer 3 interface by using the port link-mode route command (see Layer 2—LAN Switching Configuration Guide).
The following commands can be configured in Layer 2 aggregate interface view:
·     bfd authentication-mode
·     bfd detect-multiplier
·     bfd min-receive-interval
·     bfd min-transmit-interval
For more information about configuring BFD on Layer 2 aggregate interfaces, see Layer 2—LAN Switching Configuration Guide.
Use bfd authentication-mode to configure the BFD authentication mode for single-hop BFD control packets.
Use undo bfd authentication-mode to restore the default.
bfd authentication-mode { m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
Single-hop BFD control packets are not authenticated.
Interface view, BFD template view
m-md5: Specifies the Meticulous MD5 algorithm.
m-sha1: Specifies the Meticulous SHA1 algorithm.
md5: Specifies the MD5 algorithm.
sha1: Specifies the SHA1 algorithm.
simple: Specifies the simple authentication mode.
key-id: Sets the authentication key ID in the range of 1 to 255.
cipher: Sets a ciphertext password.
cipher-string: Ciphertext password, which is a case-sensitive string of 33 to 53 characters.
plain: Sets a ciphertext password.
plain-string: Plaintext password, which is a case-sensitive string of 1 to 16 characters.
Use this command to enhance BFD session security.
For security purposes, all authentication passwords, including passwords configured in plain text, are saved in cipher text.
# Configure VLAN-interface 11 to perform simple authentication for single-hop BFD control packets, setting the authentication key ID to 1 and password to 123456.
[Sysname-Vlan-interface11] bfd authentication-mode simple 1 plain 123456
bfd demand enable
Use bfd demand enable to enable the Demand BFD session mode.
Use undo bfd demand enable to restore the default.
bfd demand enable
The BFD session is in Asynchronous mode.
Interface view
In Demand mode, the device periodically sends BFD control packets. If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets. If the peer end is operating in Demand mode, both ends stop sending BFD control packets. When the connectivity to another system needs to be verified explicitly, a system sends several BFD control packets that have the Poll (P) bit set at the negotiated transmit interval. If no response is received within the detection interval, the session is considered down. If the connectivity is found to be up, no more BFD control packets are sent until the next command is issued.
In Asynchronous mode, the device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within a specific interval.
# Enable the Demand BFD session mode on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd demand enable
Use bfd detect-multiplier to set the single-hop detection time multiplier.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The single-hop detection time multiplier is 5.
value: Specifies a single-hop detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD packets (including control packets and echo packets) that can be discarded.
Table 1 Detection interval calculation method
Mode
Detection interval
Echo packet mode
Detection time multiplier of the sender × actual packet sending interval of the sender
Control packet mode BFD session in asynchronous mode
Detection time multiplier of the receiver × actual packet sending interval of the receiver
Control packet mode BFD session in demand mode
# Set the single-hop detection time multiplier to 6 on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd detect-multiplier 6
bfd echo enable
Use bfd echo enable to enable the echo packet mode.
Use undo bfd echo enable to restore the default.
bfd echo enable
The echo packet mode is disabled.
Interface view
If you enable the echo packet mode for a BFD session in which control packets are sent and the session comes up, BFD does the following:
·     Periodically sends echo packets to detect link connectivity.
·     Decreases the control packet receiving rate at the same time.
# Enable the echo packet mode on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd echo enable
bfd echo-source-ip
Use bfd echo-source-ip to configure the source IP address of BFD echo packets.
Use undo bfd echo-source-ip to remove the configured source IP address of BFD echo packets.
bfd echo-source-ip ip-address
No source IP address is configured for BFD echo packets.
ip-address: Specifies the source IP address of BFD echo packets.
The source IP address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IP address of BFD echo packets as 8.8.8.8.
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6
Use bfd echo-source-ipv6 to configure the source IPv6 address of BFD echo packets.
Use undo bfd echo-source-ipv6 to remove the configured source IPv6 address of BFD echo packets.
No source IPv6 address is configured for BFD echo packets.
ipv6-address: Specifies the source IPv6 address for BFD echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
The source IPv6 address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IPv6 address of BFD echo packets as 80::2.
[Sysname] bfd echo-source-ipv6 80::2
bfd min-echo-receive-interval
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets.
Use undo bfd min-echo-receive-interval to restore the default.
bfd min-echo-receive-interval value
The minimum interval for receiving BFD echo packets is 400 milliseconds.
Interface view
value: Specifies a minimum interval for receiving BFD echo packets, in milliseconds. The value takes 0 or is in the range of 100 to 1000.
This command sets the BFD echo packet receiving interval, which is the actual BFD echo packet sending interval.
The local end stops sending echo packets after autonegotiation with the remote end if the following conditions are met:
·     The echo packet mode is enabled on the local end.
·     The minimum interval for receiving BFD echo packets is set to 0 milliseconds on the remote end.
# Set the minimum interval for receiving BFD echo packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-echo-receive-interval 500
Use bfd min-receive-interval to set the minimum interval for receiving single-hop BFD control packets.
Use undo bfd min-receive-interval to restore the default.
bfd min-receive-interval value
The minimum interval for receiving single-hop BFD control packets is 400 milliseconds.
value: Specifies the minimum interval for receiving single-hop BFD control packets, in the range of 100 to 1000 milliseconds.
Configure this command to prevent the control packet sending rate of the peer end from exceeding the control packet receiving rate of the local end.
The actual control packet sending interval of the peer end takes the greater value between the minimum interval for transmitting BFD control packets on the peer end and the minimum interval for receiving BFD control packets on the local end.
# Set the minimum interval for receiving single-hop BFD control packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-receive-interval 500
Use bfd min-transmit-interval to set the minimum interval for transmitting single-hop BFD control packets.
Use undo bfd min-transmit-interval to restore the default.
bfd min-transmit-interval value
The minimum interval for transmitting single-hop BFD control packets is 400 milliseconds.
value: Specifies the minimum interval for transmitting single-hop BFD control packets, in the range of 100 to 1000 milliseconds.
Use this command to make sure that the BFD packet sending rate does not exceed the device capability. The actual BFD control packet transmitting interval on the local end is the greater value between the minimum interval for transmitting BFD control packets on the local end and the minimum interval for receiving BFD control packets on the peer end.
# Set the minimum interval for transmitting single-hop BFD control packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-transmit-interval 500
bfd multi-hop authentication-mode
Use bfd multi-hop authentication-mode to configure the authentication mode for multihop BFD control packets.
Use undo bfd multi-hop authentication-mode to restore the default.
bfd multi-hop authentication-mode { m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher cipher-string | plain plain-string }
No authentication is performed.
cipher-string: Sets the ciphertext password, which is a case-sensitive string of 33 to 53 characters.
plain: Sets a plaintext password.
plain-string: Sets the plaintext password, which is a case-sensitive string of 1 to 16 characters.
# Configure the simple authentication mode for multihop BFD control packets, setting the authentication key ID to 1 and password to 123456.
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
bfd multi-hop destination-port
Use bfd multi-hop destination-port to configure the destination port number for multihop BFD control packets.
Use undo bfd multi-hop destination-port to restore the default.
The destination port number for multihop BFD control packets is 4784.
port-number: Specifies the destination port number of multihop BFD control packets, 3784 or 4784.
# Specify the destination port number for multihop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
bfd multi-hop detect-multiplier
Use bfd multi-hop detect-multiplier to set the multihop detection time multiplier.
Use undo bfd multi-hop detect-multiplier to restore the default.
The multihop detection time multiplier is 5.
value: Specifies the multihop detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD control packets that can be discarded.
Table 2 Detection interval calculation method
Mode
Detection interval
# Set the multihop detection time multiplier to 6.
[Sysname] bfd multi-hop detect-multiplier 6
bfd multi-hop min-receive-interval
Use bfd multi-hop min-receive-interval to set the minimum interval for receiving multihop BFD control packets.
Use undo bfd multi-hop min-receive-interval to restore the default.
bfd multi-hop min-receive-interval value
The minimum interval for receiving multihop BFD control packets is 400 milliseconds.
value: Specifies the minimum interval for receiving multihop BFD control packets, in the range of 100 to 1000 milliseconds.
When the packet sending rate of the peer end exceeds the packet receiving capability (minimum control packet receiving interval) of the local end, the peer end dynamically adjusts the BFD control packet sending interval to the minimum control packet receiving interval of the local end.
# Set the minimum interval for receiving multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-receive-interval 500
bfd multi-hop min-transmit-interval
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting multihop BFD control packets.
Use undo bfd multi-hop min-transmit-interval to restore the default.
bfd multi-hop min-transmit-interval value
The minimum interval for transmitting multihop BFD control packets is 400 milliseconds.
value: Specifies the minimum interval for transmitting multihop BFD control packets, in the range of 100 to 1000 milliseconds.
# Set the minimum interval for transmitting multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-transmit-interval 500
bfd session init-mode
Use bfd session init-mode to configure the mode for establishing a BFD session.
Use undo bfd session init-mode to restore the default.
BFD uses the active mode.
active: Uses the active mode. In active mode, BFD actively transmits BFD control packets to the remote device, regardless of whether it receives a BFD control packet from the remote device.
passive: Uses the passive mode. In passive mode, BFD does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
At least one end must operate in active mode for a BFD session to be established.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
bfd template
Use bfd template to create a BFD template and enter BFD template view.
Use undo bfd template to delete the BFD template.
bfd template template-name
undo bfd template template-name
No BFD template is created.
template-name: Specifies the template name, a case-sensitive string of 1 to 63 characters.
# Create BFD template bfd1 and enter BFD template view.
[Sysname] bfd template bfd1
[Sysname-bfd-template-bfd1]
display bfd session
Use display bfd session to display BFD session information.
display bfd session [ discriminator value | verbose ]
discriminator value: Specifies a local ID in the range of 1 to 4294967295. If this option is not specified, the command displays brief information about all BFD sessions.
verbose: Displays detailed BFD session information. If this keyword is not specified, the command displays brief BFD session information.
# Display all IPv4 BFD session information.
<Sysname> display bfd session
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 513/513        1.1.1.1         1.1.1.2         Up       2297ms      GE1/0/1
# Display all IPv6 BFD session information.
 IPv6 Session Working Under Ctrl Mode:
       Local Discr: 513                  Remote Discr: 513
         Source IP: FE80::20C:29FF:FED4:7171
    Destination IP: FE80::20C:29FF:FE72:AC4D
     Session State: Up                      Interface: GE1/0/2
# Display detailed IPv4 BFD session information.
<Sysname> display bfd session verbose
         Source IP: 1.1.1.1            Destination IP: 1.1.1.2
     Session State: Up                      Interface: GigabitEthernet 1/0/1
      Min Tx Inter: 500ms                Act Tx Inter: 500ms
      Min Rx Inter: 500ms                Detect Inter: 2500ms
          Rx Count: 42                       Tx Count: 43
      Connect Type: Direct             Running Up for: 00:00:20
         Hold Time: 2078ms                  Auth mode: None
       Detect Mode: Async                        Slot: 1
          Protocol: OSPF
         Diag Info: No Diagnostic
     Template name: abc
# Display detailed IPv6 BFD session information.
     Session State: Up                      Interface: GigabitEthernet 1/0/2
          Rx Count: 38                       Tx Count: 38
      Connect Type: Direct             Running Up for: 00:00:15
         Hold Time: 2211ms                  Auth mode: None
          Protocol: OSPFv3
     Template name: abc
Total Session Num
Total number of BFD sessions.
Up Session Num
Total number of active BFD sessions.
Init Mode
BFD operating mode, active or passive.
IPv4/IPv6 BFD session mode:
·     Ctrl—Control packet mode.
·     Echo—Echo packet mode.
Local Discr/LD
Local ID of the session.
Remote Discr/RD
Remote ID of the session.
Source IP/SourceAddr
Source IP address of the session.
Destination IP/DestAddr
Destination IP address of the session.
Session State/State
Session state: up or down.
Name of the interface of the session.
Min Tx Inter
Minimum transmit interval.
Min Rx Inter
Minimum receive interval.
Act Tx Inter
Actual transmit interval.
Detect Inter
Actual session detection timer.
Rx Count
Number of packets received.
Tx Count
Number of packets sent.
Hold Time/Holdtime
Length of time before session detection timer expires.
Auth mode
Session authentication mode (only simple is supported).
Connect Type
Connection type of the interface, direct or indirect.
Running up for
Time interval for which the session has been up.
Detect Mode
Detection mode:
·     Async—Asynchronous mode.
·     Demand—Demand mode.
Slot
IRF member ID.
Diag Info
Diagnostic information about the session.
Template name
BFD template name.
reset bfd session statistics
Use reset bfd session statistics to clear the BFD session statistics.
# Clear the BFD session statistics.
<Sysname> reset bfd session statistics
