04-Layer 3-IP Services Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10204-Layer 3-IP Services Command Reference
05-IP forwarding basics commands
05-IP forwarding basics commands 43.84 KB
Basic IP forwarding commands
display fib
Use display fib to display FIB entries.
display fib [ ip-address [ mask | mask-length ] ]
ip-address: Displays the FIB entry that matches the specified destination IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address, the number of consecutive ones in the mask. The value range is 0 to 32.
Each FIB entry contains a destination IP address/mask, next hop, and output interface.
If you specify an IP address without a mask or mask length, this command displays the longest matching FIB entry.
If you specify an IP address and a mask or mask length, this command displays the exactly matching FIB entry.
# Display all FIB entries of the public network.
<Sysname> display fib
Destination count: 9 FIB entry count: 9
Flag:
  U:Useable   G:Gateway   H:Host   B:Blackhole   D:Dynamic   S:Static
  R:Relay     F:FRR
0.0.0.0/32         127.0.0.1       UH       InLoop0                  Null
127.0.0.0/8        127.0.0.1       U        InLoop0                  Null
127.0.0.0/32       127.0.0.1       UH       InLoop0                  Null
127.0.0.1/32       127.0.0.1       UH       InLoop0                  Null
127.255.255.255/32 127.0.0.1       UH       InLoop0                  Null
192.168.0.0/24     192.168.0.63    U        M-GE0/0/0                Null
192.168.0.0/32     192.168.0.63    UBH      M-GE0/0/0                Null
192.168.0.2/32     192.168.0.2     UH       M-GE0/0/0                Null
192.168.0.3/32     192.168.0.3     UH       M-GE0/0/0                Null
Destination count
Total number of destination addresses.
FIB entry count
Total number of FIB entries.
Destination/Mask
Destination address/mask length.
Nexthop
Next hop address.
Flag
Flags of routes:
·     U—Usable route.
·     G—Gateway route.
·     H—Host route.
·     B—Blackhole route.
·     D—Dynamic route.
·     S—Static route.
·     R—Relay route.
·     F—Fast reroute.
OutInterface/Token
Output interface/LSP index number.
Label
Inner label.
Load sharing commands
ip load-sharing local-first enable
Use ip load-sharing local-first enable to enable local-first load sharing.
Use undo ip load-sharing local-first enable to disable local-first load sharing.
Local-first load sharing is enabled.
Local-first load sharing takes effect only in an IRF fabric.
# Disable local-first load sharing.
[Sysname] undo ip load-sharing local-first enable
ip load-sharing mode per-flow
Use ip load-sharing mode per-flow to configure per-flow load sharing.
Use undo ip load-sharing mode per-flow to restore the default.
ip load-sharing mode per-flow [ algorithm algorithm-number | [ dest-ip | dest-port | ingress-port | ip-pro | src-ip | src-port ] * ] [ slot slot-number ]
undo ip load-sharing mode [ slot slot-number ]
The device performs per-flow load sharing based on the source IP address, destination IP address, source port, destination port, IP protocol number, ingress port, and VLAN.
algorithm algorithm-number: Enables flow-based load sharing algorithm switching. The algorithm-number argument specifies the algorithm to be switched, and is in the range of 0 to 8. Value 0 indicates the default algorithm.
dest-ip: Identifies flows by destination IP address.
dest-port: Identifies flows by destination port.
ingress-port: Identifies flows by ingress port.
ip-pro: Identifies flows by protocol ID.
src-ip: Identifies flows by source IP address.
src-port: Identifies flows by source port.
slot slot-number: Specifies an IRF member device by its member ID.
# Configure per-flow load sharing on IRF member device 2.
[Sysname] ip load-sharing mode per-flow slot 2
