01-Fundamentals Command Reference
HomeSupportSwitchesS5130 SeriesReference GuidesCommand ReferencesH3C S5130-HI Command References-R1118P02[R1122]-6W10201-Fundamentals Command Reference
00-Preface
00-Preface 81.76 KB
Preface
This command reference describes commands that help you get started with the device, including:
·     CLI.
·     RBAC, switch login, and switch access control.
·     Management of the switch, file system, and configuration files.
·     FTP and TFTP.
·     Tcl and Python.
·     Common software upgrade and ISSU.
·     Audience.
·     Conventions
·     Documentation feedback
Audience
·     Network planners.
·     Network administrators working with the S5130-HI switch series.
Conventions
Command conventions
Convention
Boldface
Italic
{ x | y | ... }
[ x | y | ... ]
{ x | y | ... } *
[ x | y | ... ] *
&<1-n>
GUI conventions
Convention
Boldface
Symbols
Convention
WARNING WARNING!
CAUTION CAUTION:
IMPORTANT IMPORTANT:
TIP TIP:
Network topology icons
Convention
Represents an access point.
Wireless terminator unit.
Wireless terminator.
We appreciate your comments.
