- 15-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PoE commands
- 05-SNMP commands
- 06-RMON commands
- 07-Event MIB commands
- 08-CWMP commands
- 09-EAA commands
- 10-NETCONF commands
- 11-Process monitoring and maintenance commands
- 12-Sampler commands
- 13-Mirroring commands
- 14-NetStream commands
- 15-IPv6 NetStream commands
- 16-sFlow commands
- 17-Information center commands
- 18-Flow log commands
- 19-SmartMC commands
- 20-Packet capture commands
| 20-Packet capture commands | 45.22 KB |
display packet-capture status
Use display packet-capture status to display local or remote packet capture status information.
# Display local or remote packet capture status information.
<Sysname> display packet-capture status
Status : Capturing
File Name : flash:/a.pcap
User Name : N/A
Password : N/A
Status |
Packet capture status. Only the Capturing status is supported in the current software version. |
Username |
Username for logging in to the remote FTP server. |
Password |
Password for logging in to the remote FTP server. Both passwords in encrypted form and in plaintext form are displayed as ******. If no password is required or configured, this filed displays N/A. |
packet-capture local interface
Use packet-capture local interface to capture incoming packets on an interface and save the captured packets to a local file or to a remote file on an FTP server.
packet-capture local interface interface-type interface-number [ capture-filter capt-expression | limit-frame-size bytes | autostop filesize kilobytes | autostop duration seconds ] * write { filepath | url url [ username username [ password { cipher | simple } string ] ] }
interface-type interface-number: Specifies an Ethernet interface by its type and number.
capture-filter capt-expression: Specifies an expression to match packets to be captured, a case-sensitive string of 1 to 256 characters. If you do not specify a capture filter expression, the device captures all incoming packets on an interface.
limit-frame-size bytes: Sets the maximum number of bytes to capture for a packet. The value range is 64 to 8000 bytes, and the default value is 8000 bytes.
autostop filesize kilobytes: Stops capturing packets if the maximum packet file size is exceeded when file rotation is disabled. The kilobytes argument sets the maximum packet file size. The value range is 1 to 65536 kilobytes. If you do not set a limit, the packet file size is unlimited.
autostop duration seconds: Stops capturing packets when the capturing duration expires. The seconds argument sets the capturing duration. The value range is 1 to 2147483647 seconds. If you do not set a limit, the capturing duration is unlimited.
write: Stores the captured packet data.
filepath: Specifies the full path of a local packet file to store captured packet data. The path must be a case-sensitive string of up to 64 characters. The filename extension must be .pcap. For more information about setting a file path, see file system management in Fundamentals Configuration Guide.
url url: Specifies the URL of a remote packet file on an FTP server to store captured packet data. The URL must be a case-sensitive string of 1 to 255 characters. The URL string must not contain at signs (@), and the specified username and password. If you do not specify a URL, the captured packet data is not saved.
username username: Specifies a username for logging in to the FTP server. The username is a case-sensitive string of 1 to 32 characters.
password: Specifies a password for logging in to the FTP server.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters.
To stop the capture while it is capturing packets, use the packet-capture stop command.
If you configure both the autostop filesize option and autostop duration option, the packet capture stops when any one of the limits for the stop options is reached.
Follow these restrictions and guidelines to specify the URL, username, and password:
· The URL format is ftp://ftp/ server address:port number/file name, where the port number is optional, for example, ftp://192.168.1.1/test.cfg and ftp://192.168.1.1/test.cfg. If the server is configured with a port number, you must enter the port number in the URL.
· If the server address is an IPv6 address, enclose the address in a pair of brackets, for example, ftp://[2001::1]/test.cfg and ftp://[2001::1]:21/test.cfg.
· You can also specify the DNS domain name for the server address field, for example, ftp://sdp:21/test.cfg.
· The username and password must be the same as those configured on the FTP server. If the server authenticates only the username, the password can be omitted.
Do not set a short capturing duration in the autostop duration seconds option. If the duration is too short, the capture might stop when a user has not logged in to the FTP server. The captured packets cannot be saved because a packet file has not been created.
# Capture incoming packets and store the data in the database.pcap file on the FTP server at 10.1.1.1. The username and password for logging in to the FTP server are 1 and 1, respectively.
<Sysname> packet-capture local interface gigabitethernet 1/0/1 write url ftp://10.1.1.1/database.pcap username 1 password simple 1
packet-capture stop
packet-capture remote interface
Use packet-capture remote interface to capture incoming packets on an interface.
packet-capture remote interface interface-type interface-number [ port port ]
port port: Specifies the RPCAP service port by its number. If you do not specify a RPCAP service port, RPCAP service port 2002 is used.
To stop the ongoing capture, use the packet-capture stop command.
# Capture incoming packets on GigabitEthernet 1/0/1 and specify the RPCAP service port number as 2014.
<Sysname> packet-capture remote interface gigabitethernet 1/0/1 port 2014
packet-capture stop
packet-capture stop
Use packet-capture stop to stop the local or remote packet capture.
packet-capture stop
# Stop the local or remote packet capture.
<Sysname> packet-capture stop
