| 07-3G and 4G modem management commands | 202.10 KB |
3G/4G modem management commands
reset counters controller cellular
3G modem-specific management commands
Common management commands
controller cellular
Use controller cellular to enter cellular interface view.
controller cellular cellular-number
cellular-number: Specifies a cellular interface by its number.
# Enter Cellular 2/4/0 interface view.
[Sysname] controller cellular 2/4/0
[Sysname-Cellular 2/4/0]
description
The description for a cellular interface is in the interface name Interface format, for example, Cellular 2/4/0 Interface.
Cellular interface view
text: Sets an interface description, a case-sensitive string of 1 to 255 characters.
# Set the description to Cellular-intf for Cellular 2/4/0.
[Sysname-Cellular2/4/0] description Cellular-intf
display cellular
Use display cellular to display call connection information for a 3G/4G modem.
display cellular [ interface-number ]
cellular [ interface-number ]: Specifies a cellular interface by its number. If you do not specify a cellular interface, this command displays call connection information for all cellular interfaces with 3G/4G modems installed.
The command output might vary by modem manufacturers.
# Display call connection information for the 3G modem. (WCDMA network).
<Sysname> display cellular 2/4/0
Cellular2/4/0:
Hardware Information:
Model: E176G
Modem Firmware Version: 11.604.09.00.00
Hardware Version: CD25TCPU
International Mobile Subscriber Identity (IMSI): 460029010431055
International Mobile Equipment Identity (IMEI): 353871020138548
Factory Serial Number (FSN): DK9RAA1871500602
Modem Status: Online
Profile Information:
Profile 1: Active
PDP Type: IPv4, Header Compression: Off
Data Compression: Off
Access Point Name (APN): 001
Packet Session Status: Inactive
Modem Setup Information:
Diagnostics Monitor: Close
Network Information:
Current Service Status: Service available
Current Service: Combined
Packet Service: Attached
Current Roaming Status: Roaming
Network Selection Mode: Manual
Network Connection Mode: WCDMA precedence
Current Network Connection: HSDPA and HSUPA
Mobile Country Code (MCC): 460
Mobile Network Code (MNC): 00
Location Area Code (LAC): 4318
Cell ID: 25381
Radio Information:
Current Band: ANY
Current RSSI: -51 dBm
Modem Security Information:
PIN Verification: Disabled
PIN Status: Ready
Number of Retries remaining: 3
SIM Status: OK
Model |
Modem name. |
International Mobile Subscriber Identity (IMSI) |
IMSI string of the SIM card. |
International Mobile Equipment Identity (IMEI) |
IMEI serial number of the modem. |
Factory Serial Number (FSN) |
FSN of the modem. |
Modem Status |
Status of the modem: · Online—The modem is powered on. · Offline—The modem is powered off or in low power mode. The cellular interface is not available. |
Profile Information |
Profile settings for the modem. |
Profile 1 |
PDP status of the modem: · Active—The profile is already configured. · Undefined—The profile is not configured. |
PDP Type |
PDP type, displayed only when Profile 1 is Active: · IPv4. · IPv6. · PPP (transparent transmission). |
Header Compression |
PDP header compression status: · On. · Off. |
Data Compression |
PDP data compression status: · On. · Off. |
Packet Session Status |
PDP status: · Active—The modem is transmitting data through PPP. · Inactive—The modem is physically down. |
Diagnostics Monitor |
Diagnostic and monitoring (DM) status: · Open—DM is enabled. · Close—DM is disabled. |
Current Service Status |
Service status of the modem: · Service available—The modem is providing services correctly. · Emergency—The modem is providing limited services. The cellular interface is not available. · No service—The modem cannot provide services. The cellular interface is not available. · Low power—The modem is in low power mode. The cellular interface is not available. |
Current Service |
Current service type: · Circuit-switched—For the CS domain only. · Packet-switched—For the PS domain only. · Combined—For both the CS and PS domains. · Invalid—Invalid service. |
Packet Service |
PS domain attach/detach status of the modem: · Detached—The cellular interface is not available. · Attached—The cellular interface is available. |
Current Roaming Status |
Roaming status: · Roaming. · Home. |
Network Selection Mode |
Network selection mode: · Manual. · Automatic. |
Network Connection Mode |
Network connection mode: · WCDMA only—Connected to the WCDMA network only. · WCDMA precedence—Connected to the WCDMA network with preference. · GSM only—Connected to the GSM network only. · GSM precedence—Connected to the GSM network with preference. |
Current Network Connection |
Current network: · No Service. · GSM. · GPRS. · EDGE. · WCDMA. · HSDPA. · HSUPA. · HSDPA and HSUPA. · HSPA+. · Unknown. |
Mobile Country Code (MCC) |
The MCC is displayed if the modem has found a mobile network. |
Mobile Network Code (MNC) |
The MNC is displayed if the modem is successfully registered with a mobile network. |
Location Area Code (LAC) |
The LAC is displayed if the modem is successfully registered with a mobile network. |
Cell ID |
The Cell ID is displayed if the modem is successfully registered with a mobile network. |
Current Band |
Current band selection mode: · GSM. · WCDMA. · ANY. · AUTO. |
Current RSSI |
Current RSSI: · An RSSI value in the range of –110 dBm to –51 dBm. · Unknown—No signal. The cellular interface is unavailable. |
PIN Verification |
PIN authentication status: · Disabled. · Enabled. |
PIN Status |
PIN status: · Ready—The SIM card is ready. · PIN Requirement—Requires you to execute the pin verify command to enter the PIN for PIN verification. · PUK Requirement—Requires you to execute the pin unlock command to unlock the SIM or UIM card. |
Number of Retries remaining |
Remaining retries available for entering the PIN or PUK. |
SIM Status |
SIM card status: · OK—The SIM card is normal. · Network Reject—The SIM card is denied access to the network. The cellular interface is not available. · Not Insert—The SIM card is absent. The cellular interface is not available. |
# Display call connection information for the 3G modem (TD-SCDMA network).
Cellular2/4/0:
Model: ET128
Modem Firmware Version: 11.101.01.08.00
Hardware Version: CS31TCPU
International Mobile Subscriber Identity (IMSI): 460079011105842
International Mobile Equipment Identity (IMEI): 860039002369111
Factory Serial Number (FSN): GQ4CAB1942911350
Profile 1: Active
PDP Type: IPv4
Access Point Name (APN): cmnet
Packet Session Status: Active
Network Selection Mode: Automatic
Network Connection Mode: TD-SCDMA precedence
Mobile Network Name: CHINA MOBILE
Downstream Bandwidth: 2800000 bps
Radio Information:
Current RSSI: -75 dBm
PIN Status: Ready
SIM Status: OK
Model |
Modem name. |
FSN of the modem. |
Modem Status |
Profile 1 |
PDP Type |
Data Compression |
Current network: · No Service. · GSM. · GPRS. · EDGE. · TD-SCDMA. · HSDPA. · Unknown. |
Downstream Bandwidth |
Downstream bandwidth, in bps. |
Radio Information |
Radio communication information. |
Current RSSI |
Current RSSI: · An RSSI value in the range of –110 dBm and –51 dBm. · Unknown—No signal. The cellular interface is unavailable. |
PIN Verification |
PIN Status |
SIM Status |
# Display call connection information for the 3G modem (CDMA network).
Cellular2/4/0:
Model: EC169
Manufacturer: HUAWEI TECHNOLOGIES CO.
Modem Firmware Version: 11.002.03.01.45
Hardware Version: CE62TCPUVer A
Electronic Serial Number (ESN): c1836f2d
Preferred Roaming List (PRL) Version: 0
International Mobile Subscriber Identity (IMSI): 460036101433925
Current Roaming Status: Home
Network Connection Mode: Manual
Current Network Connection: 1xRTT/EVDO HYBRID
Downstream Bandwidth: 3100000 bps
Radio Information:
Current RSSI(1xRTT): -93 dBm
Current RSSI(EVDO): -75 dBm
Current Voltage: 3336 mV
PIN Status: Ready
UIM Status: OK
Model |
Modem name. |
IMSI string of the UIM card. |
Modem Status |
Network selection mode · Manual. · Automatic. |
Current network: · No Service. · 1xRTT/EVDO HYBRID. · EVDO. · 1xRTT. · Unknown. |
Radio Information |
Current RSSI (1xRTT) |
Current RSSI of 1xRTT: · An RSSI value in the range of –125 dBm to –75 dBm. · Unknown—No signal. |
Current RSSI (EVDO) |
Current RSSI of EVDO: · An RSSI value in the ranges of –120 dBm to –60 dBm. · Unknown—No signal. |
Current Voltage |
Current voltage of the UIM card, in mV. |
PIN Verification |
PIN Status |
PIN status: · Ready—The UIM card is ready. · PIN Requirement—Requires you to execute the pin verify command to enter the PIN for PIN verification. · PUK Requirement—Requires you to execute the pin unlock command to unlock the SIM or UIM card. |
UIM Status |
UIM card status: · OK—The UIM card is normal. · Network Reject—The UIM card is denied access to the network. The cellular interface is not available. · Not Insert—The UIM card is absent. The cellular interface is not available. |
# Display the call connection information for the 4G modem (LTE network).
<Sysname> display cellular 0/0
Cellular0/0:
Model: MC7750
Manufacturer: Sierra Wireless, Incorporated
Modem Firmware Version: SWI9600M_03.05.10.06
Hardware Version: 10
International Mobile Equipment Identity (IMEI): 990000560327506
Profile index: 1
PDP Type: IPv4
Access Point Name (APN): vzwinternet
Current Data Bearer Technology: Unknown
Cell ID: 25381
Radio Information:
Technology Preference: LTE only
Technology Selected: LTE
LTE related info:
Current RSSI: -79 dBm
Current RSRQ: -9 dB
Current RSRP: -106 dBm
Current SNR: 5 dB
Tx Power: -3276 dBm
PIN Status: Ready
SIM Status: OK
ICCID: 89860113811003195000
Model |
Modem name. |
Modem Status |
Status of the modem: · Online—The modem is powered on. · Offline—The modem is powered off or in lower power mode. The cellular interface is unavailable. |
Profile settings for the 4G modem. |
Profile index |
Index of the profile for modem. |
PDP Type |
PDP header compression status · On. · Off. |
Data Compression |
Service status of the modem: · Limited—The modem is not in the coverage of the selected network. The cellular interface is not available. · Service available—The modem is providing services correctly. · Emergency—The modem is providing limited services. The cellular interface is not available. · No service—The modem cannot provide services. The cellular interface is not available. · Low power—The modem is in low power mode. The cellular interface is not available. |
Current Data Bearer Technology |
Current data carrier technology: · CDMA2000 1X. · CDMA2000 HRPD (1xEV-DO). · GSM. · UMTS. · CDMA2000 HRPD (1xEV-DO RevA). · EDGE. · HSDPA and WCDMA. · WCDMA and HSUPA. · HSDPA and HSUPA. · LTE. · CDMA2000 EHRPD. · HSDPA+ and WCDMA. · HSDPA+ and HSUPA. · DC_HSDPA+ and WCDMA. · DC_HSDPA+ and HSUPA. · HSDPA+ and 64QAM. · HSDPA+, 64QAM and HSUPA. · TDSCDMA. · TDSCDMA and HSDPA. · Unknown. |
The MCC is displayed if the modem has found the network. |
Cell ID |
Radio Information |
Technology Preference |
Network connecting preference: · AUTO—Connects to a network automatically. · GSM only—Connects to a GSM network only. · GSM precedence—Connects to a GSM network with preference. · WCDMA only—Connects to a WCDMA network only. · WCDMA precedence—Connects to a WCDMA network with preference. · TD-SCDMA only—Connects to a TD-SCDMA network only. · TD-SCDMA precedence—Connects to a TD-SCDMA network with preference. · EVDO—Connects to a CDMA-EVDO network only. · 1x RTT—Connects to a CDMA-1x RTT network only. · 1xRTT/EVDO HYBRID—Connects to the CDMA-EVDO and CDMA-1x RTT hybrid networks only. · LTE only—Connects to an LTE network only. |
Technology Selected |
Current network: · GSM—Has connected to a GSM network. · WCDMA—Has connected to a WCDMA network. · TD-SCDMA—Has connected to a TD-SCDMA network. · EVDO—Has connected to a CDMA-EVDO network. · 1Xrtt—Has connected to a CDMA-1x RTT network. · 1xRTT/EVDO HYBRID—Has connected to the CDMA-EVDO and CDMA-1x RTT networks. · LTE—Has connected to an LTE network. |
LTE related info |
Information about the LTE network. |
Current RSSI |
Current RSRQ |
Reference Signal Received Quality. |
Current RSRP |
Reference Signal Receiving Power. |
Current SNR |
Signal to noise ratio. |
Tx Power |
Transmitting power. |
Modem Security Information |
Information about modem security. |
PIN Verification |
PIN authentication status: · Disabled. · Enabled. · Unknown. |
PIN Status |
SIM Status |
SIM card status: · OK—The SIM card is normal. · Network Reject—The SIM card is denied access to the network. The cellular interface is not available. · Not Insert—The SIM card is absent. The cellular interface is not available. · Not Initialized—The SIM card status cannot be identified. |
ICCID |
ID of the SIM card, displayed only when the SIM card status is OK. |
mode
pin modify
pin unlock
pin verification enable
pin verify
plmn select
profile create
display controller cellular
Use display controller cellular to display information about cellular interfaces.
display controller [ cellular [ interface-number ] ]
cellular [ interface-number ]: Specifies cellular interfaces or a cellular interface by its number. If you do not specify the cellular keyword, this command displays information about all interfaces. If you specify the cellular keyword but not the interface-number argument, this command displays information about all cellular interfaces.
Hot swapping a USB 3G/4G modem clears the cellular interface statistics.
# Display information about Cellular 2/4/0.
<Sysname> display controller cellular 2/4/0
Cellular2/4/0
Current state: UP
Description: Cellular2/4/0 Interface
Modem status: Present
DM port status: Disabled
Capability:
1 Control channel, 1 PPP channel
Control channel 0 traffic statistics:
TX: 0 packets, 0 errors
RX: 0 packets, 0 errors
PPP channel 0 traffic statistics:
Table 5 Command output
Cellular2/4/0 Current state |
Status of the interface: · DOWN(Administratively)—The interface has been administratively shut down by using the shutdown command. · DOWN—The interface is administratively up but its physical state is down, possibly because of a connection or link failure. · UP—The administrative and physical states of the interface are both up. |
Description of the interface. |
Modem status |
Status of the USB 3G/4G modem: · Present—The modem is present. · Absent—The modem is absent. |
DM port status |
DM status: · Enabled. · Disabled. |
Capability: 1 Control channel, 1 PPP channel |
Type and number of channels the cellular interface supports: · 1 Control channel—Supports one control channel. · 1 PPP channel—Supports one asynchronous serial subchannel. · 1 ETH channel—Supports one Ethernet subchannel. |
Control channel 0 traffic statistics: TX: 0 packets, 0 errors RX: 0 packets, 0 errors |
Control channel statistics: · TX: 0 packets, 0 errors—Number of packets and number of error packets sent through the control channel. · RX: 0 packets, 0 errors—Number of packets and number of error packets received through the control channel. |
PPP channel 0 traffic statistics TX: 0 packets, 0 errors RX: 0 packets, 0 errors |
PPP channel statistics: · TX: 0 packets, 0 errors—Number of packets and number of error packets sent through the PPP channel. · RX: 0 packets, 0 errors—Number of packets and number of error packets received through the PPP channel. |
ETH channel 0 traffic statistics TX: 0 packets, 0 errors RX: 0 packets, 0 errors |
Ethernet channel statistics: · TX: 0 packets, 0 errors—Number of packets and number of error packets sent through the Ethernet channel. · RX: 0 packets, 0 errors—Number of packets and number of error packets received through the Ethernet channel. |
dm-port open
Use dm-port open to enable diagnostic and monitoring (DM) on a 3G/4G modem.
Use undo dm-port open to disable DM on a 3G/4G modem.
dm-port open
undo dm-port open
The default setting for this command depends on the modem model.
Enabling DM on a 3G/4G modem allows third-party debugging tools to diagnose and monitor the 3G/4G modem through cellular interface debugging output.
# Enable DM on a 3G/4G modem.
[Sysname-Cellular2/4/0] dm-port open
mode
Use mode to specify network services for a 3G/4G modem.
mode { 1xrtt | auto | evdo | gsm | gsm-precedence | hybrid | lte | td | td-precedence | wcdma | wcdma-precedence }
1xrtt: Connects to a CDMA-1x RTT network only.
auto: Connects to a network automatically.
evdo: Connects to a CDMA-EVDO network only.
gsm: Connects to a GSM network only.
gsm-preference: Connects to a GSM network with preference.
hybrid: Connects to the CDMA-EVDO and CDMA-1xRTT networks only.
lte: Connects to an LTE network only.
td: Connects to a TD-SCDMA network only.
td-preference: Connects to a TD-SCDMA network with preference.
wcdma: Connects to a WCDMA network only.
wcdma-preference: Connects to a WCDMA network with preference.
The available parameters depend on the modem model.
# Specify the LTE service for the 4G modem.
[Sysname-Cellular2/4/0] mode lte
modem reboot
Use modem reboot to reboot a 3G/4G modem.
modem reboot
A 3G/4G modem module can automatically detect running errors and reboot. If the 3G/4G modem fails to reboot by itself, you can use this command to reboot it.
# Manually reboot the 3G/4G modem.
[Sysname-Cellular2/4/0] modem reboot
modem response
Use modem response to set a 3G/4G modem response timer and a consecutive response failure threshold for auto recovery.
Use undo modem response to restore the default.
modem response timer time auto-recovery threshold
undo modem response
The response timer is 10 seconds and the consecutive response failure threshold is 3.
timer time: Sets the response timer, in the range of 1 to 300, in seconds.
auto-recovery threshold: Specifies the consecutive response failure threshold for auto recovery. The value range for the threshold argument is 0 to 10. To disable auto recovery, set the value to 0.
A 3G/4G modem might malfunction in an unstable 3G/4G network or when the application environment changes. During a malfunction, the modem cannot respond to the device's requests or configuration commands. If the device does not receive any responses from the 3G/4G modem within the timer, a response failure occurs. When the number of consecutive response failures reaches the threshold, the device restarts the 3G/4G modem automatically. This releases the user from manually rebooting the modem.
The device does not restart the 3G/4G modem when the 3G/4G modem has not made a successful dialup since the last restart. This restriction avoids repeated restarts of the 3G/4G modem when there are configuration errors.
# Set the response timer to 20 seconds and the consecutive response failure threshold for auto recovery to 4.
[Sysname-Cellular2/4/0] modem response timer 20 auto-recovery 4
pin modify
Use pin modify to modify the PIN of a SIM/UIM card.
pin modify current-pin new-pin
current-pin: Specifies the current PIN of the SIM/UIM card, a string of 4 to 8 digits.
new-pin: Specifies the new PIN, a string of 4 to 8 digits.
The new PIN is saved on the SIM/UIM card.
If PIN verification is enabled, execute the pin verify command to save the new PIN on the device after the PIN is modified.
Failure to modify the PIN in a maximum number of attempts locks the SIM/UIM card. The maximum number of attempts depend on the 3G/4G modem model. To unlock the card, execute the pin unlock command.
For some 3G/4G modems, you can modify their PINs only when the 3G/4G modems pass the PIN authentication.
# Modify the PIN of a SIM/UIM card.
[Sysname-Cellular2/4/0] pin modify 1234 4321
PIN will be changed to “4321”. Continue? [Y/N]:y
PIN has been changed successfully.
pin unlock
pin verify
pin unlock
Use pin unlock to specify the Personal Unlock Code (PUK) to unlock a SIM/UIM card.
pin unlock puk new-pin
puk: Specifies the PUK of the SIM/UIM card, a string of 4 to 8 digits. The PUK code of a SIM/UIM card is provided by the network service provider.
A SIM/UIM card will be locked in the following circumstances:
· Consecutive PIN modification failures.
· Consecutive failures for enabling or disabling PIN authentication.
· Consecutive PIN authentication failures.
If the SIM/UIM card is locked, the 3G modem cannot be used. To unlock the card, you can use the pin unlock command. The new PIN is saved on the SIM/UIM card.
If PIN verification is enabled, use the pin verify command to save the new PIN on the device after the SIM/UIM card is unlocked.
If you consecutively fail to unlock a card by using the PUK, the card will be locked permanently. To unlock a permanently locked card, contact the service provider of the card.
# Use the PUK to unlock a SIM/UIM card.
[Sysname-Cellular2/4/0] pin unlock 87654321 1234
PIN will be unlocked and changed to “1234”. Continue? [Y/N]:y
PIN has been unlocked and changed successfully.
pin modify
Use pin verification enable to enable PIN verification for a 3G/4G modem.
Use undo pin verification enable to disable PIN verification for a 3G/4G modem.
pin verification enable [ pin ]
undo pin verification enable [ pin ]
pin: Specifies the PIN of the SIM/UIM card, a string of 4 to 8 digits.
If PIN verification is enabled, PIN verification is performed after you perform any of the following tasks:
· Install a 3G/4G modem.
· Reboot the device.
· Execute the modem reboot command to reboot a 3G/4G modem.
· Hot swap a USB 3G/4G modem.
· Cold boot the device where a SIC-3G/4G modem is installed.
To perform PIN verification, you also need to execute the pin verify command to save the PIN of the SIM/UIM card on the device. After the PIN is saved on the device, the PIN is used for verification automatically when required.
You might be required to provide the current PIN when you enable or disable PIN verification. Consecutive failures for enabling or disabling PIN verification lock a SIM/UIM card. To unlock the card, execute the pin unlock command.
For some 3G/4G modems, you can disable PIN verification only when the 3G/4G modems pass PIN authentication.
# Enable PIN authentication.
[Sysname-Cellular2/4/0] pin verification enable 1234
pin unlock
pin verify
pin verify
Use pin verify to specify the PIN of a SIM/UIM card on a 3G/4G modem.
Use undo pin verify to restore the default.
pin verify { cipher | simple } string
undo pin verify
No PIN is specified for a SIM/UIM card.
cipher ciphered-pin: Specifies a PIN in encrypted form.
simple pin: Specifies a PIN in plaintext form. For security purposes, the PIN specified in plaintext form will be stored in encrypted form.
string: Specifies the PIN. Its plaintext form is 4 to 8 digits long. Its encrypted from is a string of 37 to 41 characters.
This command saves the PIN of the SIM/UIM card on the device. The PIN is used for verifying the 3G/4G modem when PIN verification is performed. You can execute this command before or after you enable PIN verification.
Consecutive PIN verification failures might lock a SIM/UIM card. To unlock the card, execute the pin unlock command.
# Specify the plaintext form PIN 1234 for the SIM/UIM card.
[Sysname-Cellular2/4/0] pin verify simple 1234
pin unlock
plmn search
Use plmn search to search for available mobile networks.
plmn search
Before you use a 3G/4G modem to access a mobile network, use the plmn search command to search a PLMN for available mobile networks. The search takes a few minutes. After the search is complete, the CLI displays the available mobile networks. Some 3G/4G modems automatically access an available network. You can also specify a mobile network for the 3G/4G modem from the available mobile networks.
# Search for mobile networks on Cellular 2/4/0.
[Sysname-Cellular2/4/0] plmn search
PLMN search done.
Available PLMNs:
PLMN No. MCC MNC Status Type
01 460 00 Current GSM
02 460 00 Available UTRAN
03 460 01 Forbidden GSM
Table 6 Command output
PLMN No |
PLMN number. |
MCC |
Mobile Country Code. |
MNC |
Mobile Network Code: · 00, 02, and 07—China Mobile. · 01—China Unicom. · 03—China Telecom. |
Status |
Status of the mobile network: · Current. · Available. · Forbidden. |
Type |
Type of the mobile network. |
display cellular
plmn select
plmn select
Use plmn select to configure the mobile network selection mode.
plmn select { auto | manual mcc mnc }
auto: Specifies the auto selection mode. The 3G modem automatically selects a mobile network.
manual: Specifies the manual selection mode.
mcc: Specifies the mobile country code (MCC) in the range of 0 to 65535.
mnc: Specifies the mobile network code (MNC) in the range of 0 to 65535.
For manual selection, you can first use the plmn search command to obtain the MCC and MNC of a mobile network.
# Manually specify a mobile network.
[Sysname-Cellular2/4/0] plmn select manual 65524 65524
display cellular
plmn search
Use reset counters controller cellular to clear statistics on cellular interfaces.
reset counters controller cellular [ interface-number ]
cellular [ interface-number ]: Specifies cellular interfaces or a cellular interface by its number. If you do not specify the interface-number argument, this command clears statistics on all cellular interfaces. If you specify the interface-number argument, this command clears statistics on the specified cellular interface.
To collect traffic statistics on an interface during a period of time, first use the reset counters controller cellular command to clear the existing statistics on the interface.
# Clear statistics on Cellular 2/4/0.
<Sysname> reset counters controller cellular 2/4/0
rssi
Use rssi to set the RSSI thresholds for a 3G/4G modem.
Use undo rssi to restore the default.
rssi { 1xrtt | evdo | gsm | lte } { low lowthreshold | medium mediumthreshold } *
undo rssi { 1xrtt | evdo | gsm | lte } [ low | medium ]
The lower and upper RSSI thresholds for a 3G/4G modem are –150 dBm and 0 dBm, respectively.
1xrtt: Specifies the 1xRTT mode.
evdo: Specifies the EVDO mode.
gsm: Specifies the GSM mode.
lte: Specifies the LTE mode.
low lowthreshold: Specifies the lower RSSI threshold value in the range of 0 to 150, which represents a lower RSSI threshold in the range of –150 dBm to 0 dBm. The value of lowthreshold cannot be smaller than the value of mediumthreshold because the system automatically adds a negative sign to the RSSI thresholds.
medium mediumthreshold: Specifies the upper RSSI threshold value in the range of 0 to 150, which represents an upper RSSI threshold in the range of –150 dBm to 0 dBm.
The device performs the following operations based on the actual RSSI of the 3G/4G modem:
· Sends a trap that indicates high RSSI when the RSSI exceeds the upper threshold.
· Sends a trap that indicates normal RSSI when the RSSI is between the lower threshold and upper threshold (included).
· Sends a trap that indicates low RSSI when the RSSI drops to or below the lower threshold.
· Sends a trap that indicates low RSSI every 10 minutes when the RSSI remains equal to or smaller than the lower threshold.
To view the RSSI change information for a 3G/4G modem, use the display cellular command.
# Set the lower threshold for a 3G/4G modem in GSM mode to –110 dBm.
[Sysname] controller cellular 0/0
[Sysname-Cellular0/0] rssi gsm low 110
sendat
Use sendat to issue a configuration directive to a 3G/4G modem.
sendat at-string
at-string: Specifies a configuration directive string, a string of 1 to 300 characters. This argument can be an AT directive (containing +++, A/, or be any string beginning with AT) or a CNS directive. For more information about AT directives, see the sendat command in Layer 2—WAN Access Command Reference. Table 7 describes the CNS directive samples.
Table 7 CNS directive description
Directive |
CNSn |
Controls the CNS heartbeat debugging switch. · n = 00000500000000000000—Enables CNS heartbeat debugging. · n = 00000800000000000000—Disables CNS heartbeat debugging. |
The sendat command does not verify the configuration directive. Each time it issues one configuration directive to the 3G/4G modem, lowercase characters are automatically converted to uppercase characters.
One sendat command issues one configuration directive. To issue multiple configuration directives to a modem, you must repeat the sendat command.
Configuration directives might cause malfunction of a 3G/4G modem. When you issue a configuration directive to the modem, make sure you understand the impact on the 3G/4G modem.
# Issue the ATD169 directive to the 3G/4G modem to call number 169.
[Sysname-Cellular2/4/0] sendat ATD169
# Issue the cns00000500000000000000 directive to the 3G/4G modem to enable CNS heartbeat debugging.
[Sysname-Cellular2/4/0] sendat cns00000500000000000000
shutdown
Use shutdown to shut down a cellular interface.
Use undo shutdown to bring up a cellular interface.
shutdown
The cellular interface is up.
# Shut down Cellular 2/4/0.
[Sysname] interface cellular 2/4/0
[Sysname-Cellular2/4/0] shutdown
trust-imsi
Use trust-imsi to configure a trusted IMSI.
Use undo trust-imsi to remove a trusted IMSI.
trust-imsi string-imsi
undo trust-imsi [ string-imsi ]
No trusted IMSI is configured.
string-imsi: Specifies an IMSI. The string-imsi argument is a case-insensitive string of 1 to 31 characters.
For a successful dialup, configure the IMSI of the SIM card as a trusted IMSI.
You can configure a maximum of 16 trusted IMSIs.
# Configure trusted IMSI hccc123456789 for Cellular 0/0.
[Sysname-Cellular0/0] trust-imsi hccc123456789
gsm band
Use gsm band to specify a GSM frequency band.
Use undo gsm band to restore the default.
gsm band { egsm900 | gsm450 | gsm480 | gsm750 | gsm850 | gsm1800 | gsm1900 | pgsm900 | rsgm900 }
undo gsm band
No GSM band is specified.
egsm900: Specifies the E-GSM 900 MHz band.
gsm450: Specifies the GSM 450 MHz band.
gsm480: Specifies the GSM 480 MHz band
gsm750: Specifies the GSM 750 MHz band.
gsm850: Specifies the GSM 850 MHz band.
gsm1800: Specifies the GSM 1800 MHz band.
gsm1900: Specifies the GSM 1900 MHz band.
pgsm900: Specifies the P-GSM 900 MHz band.
rgsm900: Specifies the GSM-R 900 MHz band.
This command is supported only by Sierra MC7354 (ATT version) and MC7304 4G modules.
Multiple frequency bands are available for accessing the GSM network. When the network environment changes, the 3G/4G modem might change the working band automatically to adapt to the change. To avoid link instability caused by frequency changes, you can specify a GSM band for the 3G/4G modem.
# Specify the GSM 1800 MHz band for the 3G/4G modem.
[Sysname-Cellular0/0] gsm band gsm1800
lte band
wcdma band
profile create
Use profile create to create a profile for the 3G modem.
profile create profile-number { dynamic | static apn } authentication-mode { none | { chap | pap } user username [ password password ] }
profile-number: Specifies a profile number.
dynamic: Uses an access point automatically assigned by the service provider.
static apn: Specifies the access point provided by the service provider. It is a string of 1 to 100 characters. Whether the string is case-sensitive varies by service providers.
authentication-mode: Specifies the authentication mode, which can be none, pap, or chap.
none: Performs no authentication.
chap: Specifies CHAP authentication.
pap: Specifies PAP authentication.
user username: Specifies the username provided by the service provider. It is a case-sensitive string of 1 to 32 characters.
password password: Specifies the authentication password provided by the service provider. It is a case-sensitive string of 1 to 32 characters.
If you specify chap or pap, make sure the authentication settings are identical to those assigned by the service provider.
# Create a profile for Cellular 2/4/0. Specify the profile number as 1 and the access point name as cmnet, and specify the PAP authentication mode.
[Sysname-Cellular2/4/0] profile create 1 static cmnet authentication-mode pap user abc password abc
display cellular
profile delete
profile delete
Use profile delete to delete a profile for the 3G modem.
profile delete profile-number
profile-number: Specifies a profile by its number.
# Delete profile 1 for Cellular 2/4/0.
[Sysname-Cellular2/4/0] profile delete 1
display cellular
profile create
profile main
Use profile main to specify the primary and backup profiles for 3G modem dialup.
Use undo profile main to restore the default.
profile main profile-M-number backup profile-B-number
undo profile main
Profile 1 is used for 3G modem dialup.
main profile-M-number: Specifies the primary profile by its number.
backup profile-B-number: Specifies the backup profile by its number.
The primary profile always has priority over the backup profile. For each dialup connection establishment, the 3G modem uses the backup profile only when it has failed to dial up using the primary profile.
You must configure the same user name and password for the primary and backup profiles.
This command takes effect only on dialup connections initiated after the command is configured. It does not take effect on a dialup connection that has been established.
# Specify the profiles numbered 1 and 2 as the primary and backup profiles, respectively.
<sysname>system-view
[sysname]interface Cellular 2/4/0
[sysname-Cellular2/4/0]profile main 1 backup 2
serial-set
Use serial-set to channelize a cellular interface into a synchronous/asynchronous serial interface.
Use undo serial-set to delete a synchronous/asynchronous serial interface channelized from a cellular interface.
serial-set set-number
undo serial-set set-number
set-number: Specifies the serial interface number.
The command names the serial interface as serial cellular-number:set-number.
# Channelize Cellular 2/4/0 into a serial interface.
[Sysname-Cellular2/4/0] serial-set 0
wcdma band
Use wcdma band to specify a WCDMA band.
Use undo wcdma band to restore the default.
wcdma band { wcdma800 | wcdma850 | wcdma900 | wcdma1700ip | wcdma1700us | wcdma1800 | wcdma1900 | wcdma2100 | wcdma2600 }
undo wcdma band
No WCDMA band is specified.
wcdma800: Specifies the WCDMA 800 MHz band.
wcdma850: Specifies the WCDMA 850 MHz band.
wcdma900: Specifies the WCDMA 900 MHz band.
wcdma1700jp: Specifies the Japan WCDMA 1700 MHz band.
wcdma1700us: Specifies the US WCDMA 1700 MHz band.
wcdma1800: Specifies the WCDMA 1800 MHz band.
wcdma1900: Specifies the WCDMA 1900 MHz band.
wcdma2100: Specifies the WCDMA 2100 MHz band.
wcdma2600: Specifies the WCDMA 2600 MHz band.
Multiple frequency bands are available for accessing the WCDMA network. When the network environment changes, the 3G/4G modem might change the working band automatically to adapt to the change. To avoid link instability caused by frequency changes, you can specify a WCDMA band for the 3G/4G modem.
# Specify the WCDMA 1700 MHz band for the 3G/4G modem.
[Sysname-Cellular0/0] wcdma band wcdma1700
gsm band
lte band
4G modem-specific management commands
apn
Use apn to specify an access point name (APN) for a 4G modem.
Use undo apn to remove an APN.
apn { dynamic | static apn }
undo apn
No APN is specified for a 4G modem.
4G modem profile view
dynamic: Uses an APN automatically assigned by the service provider.
static apn: Specifies the APN provided by the service provider. The apn argument is a string of 1 to 100 characters. Whether the string is case-sensitive depends on the service provider.
# Specify APN apn1 for 4G modem profile test.
[Sysname] apn-profile test
[Sysname-apn-profile-test] apn static apn1
apn-profile
apn-profile
Use apn-profile to create a 4G modem profile.
Use undo apn-profile to remove a 4G modem profile.
apn-profile profile-name
undo apn-profile profile-name
No 4G modem profile exists.
profile-name: Specifies a 4G modem profile name.
A 4G modem profile takes effect only after you apply the profile to a 4G interface. To remove a 4G modem profile, you must first remove the association between the profile and the 4G interface.
# Create 4G modem profile test.
apn-profile apply
apn-profile apply
Use apn-profile apply to specify 4G modem profiles for an interface.
Use undo apn-profile apply to restore the default.
apn-profile apply profile-name [ backup profile-name ]
No 4G modem profiles are specified for an interface.
Eth-channel interface view
profile-name: Specifies a primary 4G modem profile name.
backup profile-name: Specifies a backup 4G modem profile name.
After you specify a 4G modem profile for a 4G modem, the 4G modem uses the settings in the profile to negotiate with the service provider's device.
A primary profile always has priority over a backup profile. For each dialup connection establishment, the 4G modem uses the backup profile only when it has failed to dial up using the primary profile.
# Specify primary 4G modem profile test and backup 4G modem profile bktest for Eth-channel interface 2/4/0:0.
[Sysname] interface eth-channel 2/4/0:0
[Sysname-Eth-channel2/4/0:0] apn-profile apply test backup bktest
apn-profile
attach-format imsi-sn split
Use attach-format imsi-sn split to specify a delimiter for the IMSI/SN binding authentication information.
Use undo attach-format imsi-sn split to restore the default.
attach-format imsi-sn split splitchart
No delimiter is specified for the IMSI/SN binding authentication information.
split splitchart: Specifies a delimiter. It can be a letter, a digit, or a sign such as a percent sign (%) or a pound sign (#).
If IMSI/SN binding authentication is enabled, the IMSI/SN information is included in the authentication information in addition to the username. You need to configure a delimiter to separate different types of information. For example, if you specify the delimiter as #, the authentication information will be sent in the imsiinfo#sninfo#username format.
# Configure the pound sign (#) as the delimiter for the IMSI/SN binding authentication information.
[Sysname-apn-profile-test] attach-format imsi-sn split #
apn-profile
authentication-mode
Use authentication-mode to specify an authentication mode for accessing a 4G network.
Use undo authentication-mode to restore the default.
authentication-mode { pap | chap| pap-chap } user user-name password { cipher | simple } string
No authentication mode is specified for accessing a 4G network.
pap-chap: Specifies CHAP or PAP authentication.
user username: Specifies the username for authentication, a case-sensitive string of 1 to 32 characters.
string: Specifies the password. Its plaintext form is a case-sensitive string of 1 to 32 characters. Its encrypted form is a case-sensitive string of 1 to 73 characters
# Specify the CHAP authentication mode for 4G modem profile test. Specify the username as user1 and the password as 123456.
[Sysname-apn-profile-test] authentication-mode chap user user1 password simple 123456
apn-profile
bandwidth
Use bandwidth to configure the expected bandwidth for an Eth-channel interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth for an interface affects the link costs in OSPF, OSPFv3, and IS-IS. For more information, see Layer 3—IP Routing Configuration Guide.
# Set the expected bandwidth for Eth-channel 2/4/0:0 to 1000 kbps.
[Sysname-Eth-channel2/4/0:0] bandwidth 1000
default
Use default to restore the default settings for an interface.
default
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command before using it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands. Then, use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Eth-channel 2/4/0:0.
[Sysname-Eth-channel2/4/0:0] default
description
The description for an interface is in the interface name Interface format, for example, Echannel 2/4/0:0 Interface.
Configure the description of an interface for easy identification and management purposes.
You can use the display interface command to view the description for an interface.
# Configure the description for Eth-channel 2/4/0:0 as Echannel-interface.
[Sysname-Eth-channel2/4/0:0] description Echannel-interface
display interface eth-channel
Use display interface eth-channel to display information about the specified or all Eth-channel interfaces.
display interface [ eth-channel [ channel-id ] ] [ brief [ description | down ] ]
eth-channel [ channel-id ]: Specifies Eth-channel interfaces or an Eth-channel interface by its number. If you do not specify the eth-channel keyword, the command displays information about all interfaces. If you specify the eth-channel keyword but not the channel-id argument, this command displays information about all Eth-channel interfaces.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in down state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
# Display detailed information about Eth-channel 2/4/0:0, including its operating status.
<Sysname> display interface eth-channel 2/4/0:0
Echannel2/4/0:0
Current state: DOWN
Line protocol state: DOWN
Description: Echannel2/4/0:0 Interface
Bandwidth: 100000kbps
Maximum Transmit Unit: 1500
Internet protocol processing: disabled
IP Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 000c-2963-b75d
IPv6 Packet Frame Type:PKTFMT_ETHNT_2, Hardware Address: 000c-2963-b75d
Last link flapping: Never
Last 300 seconds input rate 0.00 bytes/sec, 0.00 packets/sec
Last 300 seconds output rate 0.00 bytes/sec, 0.00 packets/sec
Input: 0 packets, 0 bytes, 0 buffers
Output:0 packets, 0 bytes
# Display brief information about Eth-channel 2/4/0:0.
<Sysname> display interface eth-channel 2/4/0:0 brief
Brief information on interface(s) under route mode:
Protocol: (s) - spoofing
Interface Link Protocol Main IP Description
Echannel2/4/0:0 UP UP(s) 192.168.80.239
# Display information about all Eth-channel interfaces in down state and the causes.
<Sysname> display interface eth-channel brief down
Interface Link Cause
Echannel2/4/0:0 ADM Administratively
Table 8 Command output
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · UP (spoofing)—The data link layer protocol is up, but the link is an on-demand link or does not exist. This attribute is typical of null interfaces and loopback interfaces. · DOWN—The data link layer protocol is down. |
Description for the interface. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum Transmit Unit |
MTU of the interface. |
Internet address: ip-address/mask-length (Type) |
IP address of the interface and type of the address in parentheses. Possible IP address types include: · Primary—Manually configured primary IP address. · Sub—Manually configured secondary IP address. If the interface has both primary and secondary IP addresses, the primary IP address is displayed. If the interface has only secondary IP addresses, the lowest secondary IP address is displayed. · DHCP-Allocated—DHCP allocated IP address. For more information, see DHCP client configuration in Layer 3—IP Services Configuration Guide. · BOOTP-Allocated—BOOTP allocated IP address. For more information, see BOOTP client configuration in Layer 3—IP Services Configuration Guide. · PPP-Negotiated—IP address assigned by a PPP server during PPP negotiation. For more information, see PPP configuration in Layer 2—WAN Access Configuration Guide. · Unnumbered—IP address borrowed from another interface. · Cellular-Allocated—IP address allocated through the modem-manufacturer's proprietary protocol. For more information, see 3G/4G modem management in Layer 2—WAN Access Configuration Guide. · MAD—IP address assigned to an IRF member device for MAD on the interface. For more information, see IRF configuration in Virtual Technologies Configuration Guide. · MTunnel—IP address of the multicast tunnel interface (MTI), which is the same as the IP address of the MVPN source interface. For more information, see multicast VPN configuration in IP Multicast Configuration Guide. |
Internet protocol processing: disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet Address is 192.168.1.200/24 Primary |
IP address of the interface. The primary attribute indicates that the address is the primary IP address.. |
IP Packet Frame Type |
IPv4 packet framing format. |
Hardware Address |
MAC address of the interface. |
IPv6 Packet Frame Type |
IPv6 packet framing format. |
Output queue - Urgent queuing: Size/Length/Discards |
Packet statistics for urgent queuing in the output queue of the interface: · Size—Current number of packets in the queue. · Length—Maximum number of packets that can stay in the queue. · Discards—Number of dropped packets. |
Output queue - Protocol queuing: Size/Length/Discards |
Packet statistics for protocol queuing in the output queue of the interface: · Size—Current number of packets in the queue. · Length—Maximum number of packets that can stay in the queue. · Discards—Number of dropped packets. |
Output queue - FIFO queuing: Size/Length/Discards |
Packet statistics for FIFO queuing in the output queue of the interface: · Size—Current number of packets in the queue. · Length—Maximum number of packets that can stay in the queue. · Discards—Number of dropped packets. |
Last link flapping |
The amount of time that has elapsed since the most recent physical state change of the interface. This field displays Never if the interface has been physically down since device startup. |
Last clearing of counters |
Time when statistics on the logical interface were last cleared by using the reset counters interface command. If the statistics of the interface have never been cleared by using the reset counters interface command since the device started, this field displays Never. |
Last 300 seconds input rate |
Average input rate during the last 300 seconds: · bytes/sec—Average number of received bytes per second. · bits/sec—Average number of received bits per second. · packets/sec—Average number of received packets per second. |
Last 300 seconds output rate |
Average output rate over the last 300 seconds: · bytes/sec—Average number of sent bytes per second. · bits/sec—Average number of sent bits per second. · packets/sec—Average number of sent packets per second. |
Input: 0 packets, 0 bytes, 0 buffers |
Incoming packet statistics: · 0 packets—Packet number. · 0 bytes—Packet size in bytes. · 0 buffers—Number of buffered units. |
Output: 0 packets, 0 bytes |
Outgoing packet statistics: · 0 packets—Packet number. · 0 bytes—Packet size in bytes. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Main IP |
Main IP address of the interface. |
Cause |
Cause for the physical link state of the interface to be DOWN. Administratively represents that the interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. |
eth-channel
Use eth-channel to channelize a cellular interface into an Eth-channel interface.
Use undo eth-channel to remove the Eth-channel interface channelized from a cellular interface.
eth-channel channel-number
undo eth-channel channel-number
channel-number: Specifies an Eth-channel interface by its number.
This command names the Eth-channel interface channelized from a cellular interface as eth-channel cellular-number:channel-number.
# Channelize Cellular 2/4/0 into an Eth-channel interface.
[Sysname-Cellular2/4/0] eth-channel 0
Use interface eth-channel to enter Eth-channel interface view.
interface eth-channel interface-number
interface-number: Specifies an Eth-channel interface by its number.
# Enter Eth-channel 2/4/0:0 interface view.
ip address cellular-alloc
Use ip address cellular-alloc to enable an Eth-channel interface to obtain an IP address by using the modem-manufacturer's proprietary protocol.
Use undo ip address cellular-alloc to restore the default.
An Eth-channel interface does not obtain an IP address by using the modem-manufacturer's proprietary protocol.
To enable an interface to obtain an IP address from the modem by using the modem-manufacturer's proprietary protocol, use the ip address cellular-alloc command.
To enable an interface to obtain an IP address from the modem by using DHCP, use the ip address dhcp-alloc command.
The IP address of the modem is automatically allocated by the service provider.
# Channelize Cellular 2/4/0 into an Eth-channel interface. Enable the Eth-channel interface to obtain an IP address by using the modem-manufacturer's proprietary protocol.
[Sysname-Cellular2/4/0] quit
[Sysname-Eth-channel2/4/0:0] ip address cellular-alloc
ipv6 address cellular-alloc
Use ipv6 address cellular-alloc to enable an interface to obtain an IPv6 address by using the modem-manufacturer's proprietary protocol.
Use undo ipv6 address cellular-alloc to restore the default.
An interface does not obtain an IPv6 address by using the modem-manufacturer's proprietary protocol.
To enable an interface to obtain an IPv6 address by using the modem-manufacturer's proprietary protocol, use the ipv6 address cellular-alloc command.
To enable an interface to obtain an IP address by using DHCP, use the ipv6 address dhcp-alloc command.
The IPv6 address of the modem is automatically allocated by the service provider.
# Channelize Cellular 2/4/0 into an Eth-channel interface. Enable the Eth-channel interface to obtain an IPv6 address by using the modem-manufacturer's proprietary protocol.
[Sysname-Eth-channel2/4/0:0] ipv6 address cellular-alloc
lte band
Use lte band to specify a band for a 4G modem.
Use undo lte band to restore the default.
lte band band-number
undo lte band
The default setting for this command varies by 4G modem model.
band-number: Specifies a band for a 4G modem. The available bands vary by modem model.
This command is supported by the following 4G modems:
· Sierra MC7354 and MC7304.
· Long Sung U8300C, U8300W, and U8300.
· WNC DM11-2.
# Specify band 3 for Cellular 2/4/0.
[Sysname-Controller-Cellular2/4/0] lte band 3
mtu
Use mtu to set the maximum transmission unit (MTU) for an interface.
mtu size
undo mtu
The MTU of an interface is 1500 bytes.
size: Sets the MTU in bytes.
# Set the MTU for Eth-channel 2/4/0:0 to 1430 bytes.
[Sysname-Eth-channel2/4/0:0] mtu 1430
pdp-type
Use pdp-type to specify the PDP data carrying protocol.
Use undo pdp-type to restore the default.
pdp-type { ipv4 | ipv6 | ipv4v6 }
undo pdp-type
The PDP data carrying protocol is IPv4 and IPv6.
Apn-profile view
ipv4: Specifies the IPv4 protocol.
ipv6: Specifies the IPv6 protocol.
ipv4v6: Specifies the IPv4 and IPv6 protocols.
# Specify the PDP data carrying protocol as IPv4.
[Sysname] apn-profile 1
[Sysname-apn-profile-1] pdp-type ipv4
Use reset counters interface to clear the statistics on the specified or all Eth-channel interfaces.
reset counters interface [ eth-channel [ channel-id ] ]
eth-channel [ channel-id ]: Specifies Eth-channel interfaces or an Eth-channel interface by its number. If you do not the eth-channel keyword, the command clears statistics on all interfaces. If you specify the eth-channel keyword but not the channel-id argument, this command clears statistics on all Eth-channel interfaces. If you specify both the eth-channel keyword and the channel-id argument, this command clears statistics on the specified Eth-channel interface.
Use this command to clear history statistics if you want to collect traffic statistics for a specific period.
# Clear the statistics on Eth-channel 2/4/0:0.
<Sysname> reset counters interface eth-channel 2/4/0:0
shutdown
Use shutdown to shut down an Eth-channel interface.
Use undo shutdown to bring up an Eth-channel interface.
shutdown
An Eth-channel interface is up.
# Shut down Eth-channel 2/4/0:0.
[Sysname-Eth-channel2/4/0:0] shutdown
