- 14-WLAN Configuration Guide (Fat AP)
- 01-Compatibility of hardware and AP functionality
- 02-Radio management configuration
- 03-Band navigation configuration
- 04-WLAN access configuration
- 05-WLAN security configuration
- 06-WLAN authentication configuration
- 07-WLAN QoS configuration
- 08-Cloud connection configuration
- 09-WLAN multicast optimization configuration
- 10-WLAN load balancing configuration
| 00-Preface | 81.06 KB |
Preface
This configuration guide describes the fundamentals and configuration procedures for WLAN features.
· Audience.
· Conventions.
Audience
· Network planners.
· Network administrators.
Conventions
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Documentation feedback
We appreciate your comments.
