02-Reth interface and redundancy group commands
Chapters Download (121.43 KB)
Use bandwidth to set the expected bandwidth for a Reth interface or subinterface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth is 10000 kbps for a Reth interface or subinterface.
Reth interface view
Reth subinterface view
context-admin
# Set the expected bandwidth to 50 kbps for Reth 1.
[Sysname] interface reth 1
[Sysname-Reth1] bandwidth 50
Use default to restore the default settings for a Reth interface or subinterface.
default
Reth interface view
context-admin
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions.
To resolve this problem:
1. Use the display this command in interface view to identify these commands.
2. Use their undo forms or follow the command reference to restore their default settings.
3. If the restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for Reth 1.
[Sysname-Reth1] default
Use description to configure the description of an interface or subinterface.
The description of a Reth interface or subinterface is interface-name plus Interface (for example, Reth1 Interface).
Reth interface view
context-admin
# Configure the description of Reth 1 as master-interface.
[Sysname-Reth1] description master-interface
Use display counters interface reth to display Reth interface traffic statistics.
display counters { inbound | outbound } interface [ reth [ interface-number ] ]
context-admin
context-operator
inbound: Displays inbound traffic statistics.
outbound: Displays outbound traffic statistics.
reth: Specifies Reth interfaces. If you do not specify this keyword, the command displays traffic statistics for all interfaces that have traffic counters.
interface-number: Specifies a Reth interface by its number. If you do not specify this argument, the command displays traffic statistics for all Reth interfaces.
This command displays traffic statistics within a statistics polling interval. You can use the flow-interval command to set the statistics polling interval.
To clear Reth interface traffic statistics, use the reset counters interface reth command.
# Display inbound traffic statistics for Reth 1.
<Sysname> display counters inbound interface reth 1
Interface Total (pkts) Broadcast (pkts) Multicast (pkts) Err (pkts)
Reth1 100 100 0 0
Overflow: More than 14 digits (7 digits for column "Err").
--: Not supported.
Abbreviated interface name. |
Total (pkts) |
Total number of packets received or sent through the interface. |
Broadcast (pkts) |
Total number of broadcast packets received or sent through the interface. On an RPR physical port, all broadcast and multicast packets received or sent are displayed as multicast packets. |
Multicast (pkts) |
Total number of multicast packets received or sent through the interface. On an RPR physical port, all broadcast and multicast packets received or sent are displayed as multicast packets. |
Err (pkts) |
Total number of error packets received or sent through the interface. |
Overflow: More than 14 digits (7 digits for column "Err"). |
This Overflow field is displayed when any of the following conditions exist: · The data length of the Err field exceeds 7 decimal digits. · The data length of a non-Err field exceeds 14 decimal digits. |
--: Not supported. |
If a statistical item is not supported, two hyphens (--) are displayed for the item. |
flow-interval (Interface Command Reference)
Use display counters rate interface reth to display traffic rate statistics for Reth interfaces in up state during the most recent statistics polling interval.
display counters rate { inbound | outbound } interface [ reth [ interface-number ] ]
context-admin
context-operator
inbound: Displays inbound traffic rate statistics.
outbound: Displays outbound traffic rate statistics.
reth: Specifies Reth interfaces. If you do not specify this keyword, the command displays traffic rate statistics for all up interfaces that have traffic counters during the most recent statistics polling interval.
interface-number: Specifies a Reth interface by its number. If you do not specify this argument, the command displays traffic rate statistics for all up Reth interfaces during the most recent statistics polling interval.
This command displays traffic rate statistics within a statistics polling interval. You can use the flow-interval command to set the statistics polling interval.
To clear Reth interface traffic rate statistics, use the reset counters interface reth command.
# Display inbound traffic rate statistics for Reth1.
<Sysname> display counters rate inbound interface reth 1
Usage: Bandwidth utilization in percentage
Interface Usage (%) Total (pps) Broadcast (pps) Multicast (pps)
Reth1 3 200 100 100
Overflow: More than 14 digits.
--: Not supported.
Usage (%) |
Bandwidth usage (in percentage) of the interface during the most recent statistics polling interval. |
Total (pps) |
Average receiving or sending rate (in pps) for all packets during the most recent statistics polling interval. |
Broadcast (pps) |
Average receiving or sending rate (in pps) for broadcast packets during the most recent statistics polling interval. On an RPR physical port, all broadcast and multicast packets received or sent are counted as multicast packets. |
Multicast (pps) |
Average receiving or sending rate (in pps) for multicast packets during the most recent statistics polling interval. On an RPR physical port, all broadcast and multicast packets received or sent are counted as multicast packets. |
Overflow: More than 14 digits. |
The Overflow field is displayed if the data length of a statistical item exceeds 14 decimal digits. |
Use display interface reth to display Reth interface or subinterface information.
display interface [ reth [ interface-number | interface-number.subnumber ] ] [ brief [ description | down ] ]
context-admin
context-operator
reth: Specifies Reth interfaces or subinterfaces.
interface-number: Specifies an existing Reth interface by its number.
interface-number.subnumber: Specifies a subinterface of a Reth interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.).
down: Displays information about interfaces in down state and the causes for the down state. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify the reth keyword, the command displays information about all interfaces except for VA interfaces. For more information about VA interfaces, see PPPoE configuration in PPP and PPPoE Configuration Guide.
If you specify the reth keyword but do not specify an interface or subinterface, the command displays information about all Reth interfaces and subinterfaces.
If you specify the reth interface-number option or the reth interface-number.subnumber option, the command displays information about the specified Reth interface or subinterface.
# Display detailed information about Reth 1.
<Sysname> display interface reth 1
Reth1
Current state: UP
Line protocol state: UP
Description: Reth1 Interface
Bandwidth: 10000kbps
IP packet frame type: Ethernet II, hardware address: 0cda-41b5-cf30
IPv6 packet frame type: Ethernet II, hardware address: 0cda-41b5-cf30
Physical: Reth, baudrate: 10000000 bps
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. A Reth interface is both administratively and physically up when a minimum of one member interface is administratively and physically up. |
Line protocol state |
Data link layer state of the interface. The state is determined through automatic parameter negotiation at the data link layer. · UP—The data link layer protocol is up. · DOWN—The data link layer protocol is down. |
Description of the interface. |
Bandwidth |
Expected bandwidth of the interface. |
Maximum transmission unit |
MTU of the interface. |
Internet protocol processing: Disabled |
The interface is not assigned an IP address and cannot process IP packets. |
Internet Address |
IP address of the interface. The primary attribute indicates that the address is the primary IP address. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address of the interface. |
IPv6 packet frame type |
IPv6 packet framing format. |
Physical |
Interface type. |
Last clearing of counters |
Last time when the reset counters interface command was used to clear the interface statistics. If the reset counters interface command has never been used on the interface since the device startup, this field displays Never. |
Last 300 seconds input rate |
Average input rate (in Bps and pps) over the last 300 seconds. This field is displayed for a Reth subinterface only after you execute the sub-interface rate-statistic command. |
Last 300 seconds output rate |
Average output rate (in Bps and pps) over the last 300 seconds. This field is displayed for a Reth subinterface only after you execute the sub-interface rate-statistic command. |
Input |
Incoming traffic statistics on the interface: · Number of packets. · Number of bytes. · Number of dropped packets due to insufficient receive buffer. |
Output |
Outgoing traffic statistics on the interface: · Number of packets. · Number of bytes. · Number of dropped packets due to insufficient send buffer. |
Brief information on interfaces in route mode |
Brief information about Layer 3 interfaces. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. |
Primary IP |
Primary IP address of the interface. This field displays two hyphens (--) if the interface does not have an IP address. |
Partial or complete interface description configured by using the description command: · If you specify the description keyword in the display interface brief command, this field displays only the first 27 characters of the interface description. · If you do not specify the description keyword in the display interface brief command, this field displays the complete interface description. |
# Display brief information about Reth 1.
<Sysname> display interface reth 1 brief
Protocol: (s) - spoofing
Reth1 DOWN DOWN --
# Display the causes for the down state of Reth 1.
<Sysname> display interface reth 1 brief down
Interface Link Cause
Reth1 DOWN Not connected
Brief information on interfaces in route mode: |
Interface name. |
Link |
Protocol |
Data link layer protocol state of the interface: · UP—The data link layer protocol of the interface is up. · DOWN—The data link layer protocol of the interface is down. · UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag. This value is typical of null interfaces and loopback interfaces. |
Primary IP |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty). |
Use display reth interface to display information about the member interfaces of a Reth interface.
display reth interface reth interface-number
context-admin
context-operator
reth interface-number: Specifies a Reth interface by its number. The Reth interface must exist.
# Display information about the member interfaces of Reth 1.
<Sysname> display reth interface reth 1
Reth1 :
Redundancy group : aaa
Member Physical status Forwarding status Presence status
GE1/2/5/1 UP Active Normal
GE1/2/5/2 UP Inactive Normal
Table 5 Command output
Redundancy group |
The redundancy group to which the Reth interface belongs. If the Reth interface is not in any redundancy group, this field displays N/A. |
Member |
Name of the member interface. |
Physical status |
Physical status of the member interface: · Down (redundancy down)—The interface has been shut down by the Reth module. · Down—The interface is administratively up but physically down possibly because no physical link is present or the link has failed. · UP—The interface is both administratively and physically up. |
Forwarding status |
Forwarding status of the member interface: · Active—The member interface can forward packets. · Inactive—The member interface cannot forward packets. |
Presence status |
Status of the member interface: · Normal—The member interface exists. · Absent—The member interface does not exist. |
Use interface reth to create a Reth interface or subinterface and enter its view, or enter the view of an existing Reth interface or subinterface.
Use undo interface reth to delete a Reth interface or subinterface.
interface reth { interface-number | interface-number.subnumber }
undo interface reth { interface-number | interface-number.subnumber }
No Reth interfaces or subinterfaces exist.
context-admin
interface-number: Specifies a Reth interface by its number. The value range for this argument is 1 to 255.
interface-number.subnumber: Specifies a subinterface of a Reth interface. The interface-number argument specifies the main interface number. The subnumber argument specifies the subinterface number and is separated from the main interface number by a dot (.). The value range for the subnumber argument is 1 to 4094.
A Reth interface is a virtual Layer 3 interface that uses two member interfaces to ensure link availability.
To create a Reth subinterface, create the Reth interface first.
You cannot create subinterfaces for a Reth interface in any of the following situations:
· The members of the Reth interface are Layer 3 Ethernet subinterfaces or Layer 3 aggregate subinterfaces.
· A minimum of one subinterface is created on the member interfaces of the Reth interface.
You cannot delete a Reth interface if it has member interfaces.
# Create Reth 1 and enter its view.
[Sysname-Reth1]
# Create Reth 1.1 and enter its view.
[Sysname] interface reth 1.1
[Sysname-Reth1.1]
Use member interface to assign a member interface to a Reth interface.
Use undo member interface to remove a member interface from a Reth interface.
member interface interface-type interface-number priority priority
undo member interface interface-type interface-number
A Reth interface does not have member interfaces.
Reth interface view
context-admin
The interface can be any of the following interfaces and their subinterfaces:
· Layer 3 Ethernet interfaces.
· Layer 3 aggregate interfaces.
priority: Specifies an interface priority in the range of 1 to 255. The higher the value, the higher the interface priority.
You can assign a maximum of two member interfaces to a Reth interface. An interface can belong to only one Reth interface.
As a best practice, assign interfaces of the same type and same speed to a Reth interface.
If both member interfaces of a Reth interface are subinterfaces, make sure they are on different main interfaces and terminate the same VLAN ID. For more information about VLAN termination, see Layer 2—LAN Switching Configuration Guide.
When the two member interfaces of a Reth interface are up, the system chooses the interface with the higher priority as the active interface to forward packet. The interface with the lower priority is inactive and cannot forward packets.
You cannot assign subinterfaces or interfaces that have subinterfaces to a Reth interface if the Reth interface has Reth subinterfaces.
Do not specify a Reth interface as the outgoing interface in IPv6 static neighbor entries if its member interfaces contain subinterfaces. For more information about IPv6 static neighbor entries, see Layer 3—IP Services Configuration Guide.
# Assign GigabitEthernet 1/2/5/1 and GigabitEthernet 1/2/5/2 to Reth 1, and set their priority to 100 and 50, respectively.
[Sysname-Reth1] member interface gigabitethernet 1/2/5/1 priority 100
[Sysname-Reth1] member interface gigabitethernet 1/2/5/2 priority 50
Use mtu to set the MTU of a Reth interface or subinterface.
mtu size
undo mtu
The MTU is 1500 bytes for a Reth interface or subinterface.
Reth interface view
context-admin
size: Specifies the MTU in bytes. The value range for this argument is 46 to 8192.
The MTU size of a Reth interface or subinterface affects the fragmentation and reassembly of IP packets on the interface or subinterface.
For the configured MTU size to take effect, execute the shutdown command, and then the undo shutdown command on the interface.
# Set the MTU to 200 bytes for Reth 1.
[Sysname-Reth1] mtu 200
Use reset counters interface reth to clear statistics for Reth interfaces or subinterfaces.
reset counters interface [ reth [ interface-number | interface-number.subnumber ] ]
context-admin
Use this command to clear history statistics before you collect traffic statistics for a time period.
If you do not specify the reth keyword, the command clears statistics for all interfaces except for VA interfaces.
If you specify the reth keyword but do not specify an interface or subinterface, the command clears statistics for all Reth interfaces and subinterfaces.
If you specify the reth interface-number option or the reth interface-number.subnumber option, the command clears statistics for the specified Reth interface or subinterface.
# Clear statistics for Reth 1.
<Sysname> reset counters interface reth 1
Use shutdown to shut down a Reth interface or subinterface.
Use undo shutdown to bring up a Reth interface or subinterface.
shutdown
A Reth interface or subinterface is not manually shut down.
Reth interface view
context-admin
# Shut down Reth 1.
[Sysname-Reth1] shutdown
Use sub-interface rate-statistic to enable subinterface rate statistics collection on a Reth interface.
Use undo sub-interface rate-statistic to disable subinterface rate statistics collection on a Reth interface.
Subinterface rate statistics collection is disabled on a Reth interface.
Reth interface view
context-admin
CAUTION: This command is resource intensive. When you use this command, make sure you fully understand its impact on system performance. |
After you execute this command, the device periodically refreshes subinterface rate statistics for the Reth interface. The statistics is displayed in the Last 300 seconds input rate and Last 300 seconds output rate fields of the command output from the display interface reth command.
# Enable subinterface rate statistics collection on Reth 1.
[Sysname-Reth1] sub-interface rate-statistic
Use bind chassis to bind a redundancy group node to an IRF member device.
Use undo bind chassis to remove the binding between a redundancy group node and an IRF member device.
bind chassis chassis-number
undo bind chassis
A redundancy group node is not bound to an IRF member device.
Redundancy group node view
context-admin
chassis-number: Specifies an IRF member device by its member ID.
You can create only one-to-one bindings between redundancy group nodes and IRF member devices.
The node in a binding can use interfaces of the bound IRF member device as members. Member interfaces on one node of a redundancy group back up the member interfaces on the other node.
You cannot change the binding for a node if the node has member interfaces.
# Bind node 1 in redundancy group aaa to IRF member device 3.
[Sysname] redundancy group aaa
[Sysname-redundancy-group-aaa] node 1
[Sysname-redundancy-group-aaa-node1] bind chassis 3
Use display redundancy group to display redundancy group information.
display redundancy group [ group-name ]
context-admin
context-operator
group-name: Specifies a redundancy group by its name, a case-sensitive string of 1 to 15 characters. If you do not specify a redundancy group, this command displays information about all redundancy groups.
# Display information about the redundancy group aaa.
<Sysname> display redundancy group aaa
Redundancy group aaa (ID 1):
Node ID Chassis Priority Status Track weight
1 Chassis1 100 Secondary -255
2 Chassis2 99 Primary 255
Preempt delay time remained : 0 min
Preempt delay timer setting : 1 min
Remaining hold-down time : 0 sec
Hold-down timer setting : 300 sec
Manual switchover request : No
Member interfaces:
Reth1 Reth2
Member failover groups:
groupa
groupabc
Node 1:
Node member Physical status
GE1/2/5/2 DOWN
GE1/2/5/4 DOWN(redundancy down)
Track info:
Track Status Reduced weight Interface
1 Negative(Faulty) 255 GE1/2/5/2
2 Negative 255 GE1/2/5/4
Node 2:
GE2/2/5/2 UP
GE2/2/5/4 UP
Track info:
3 Positive 55 GE2/2/5/2
4 Positive 55 GE2/2/5/4
Table 6 Command output
Priority |
Priority of the node. |
Status |
Node status: · Primary—The primary node. It can forward packets. · Secondary—The secondary node. When the high-priority node acts as the secondary node, all its member interfaces are shut down by the Reth module and cannot forward packets. When the low-priority node acts as the secondary node, all its member interfaces can forward packets. |
Track weight |
Weight of the node. |
Preempt delay time remained |
Remaining preemption delay time in minutes. |
Preempt delay timer setting |
Configured preemption delay timer in minutes. |
Remaining hold-down time |
Remaining hold-down time in seconds. |
Hold-down timer setting |
Configured hold-down timer in seconds. |
Manual switchover request |
Manual switchover request: · Yes—A request is issued. · No—No request is issued. |
Member interfaces |
Reth interfaces in the redundancy group. |
Member failover groups |
Failover groups in the redundancy group. |
Node 1 |
Detailed information about the redundancy group node. |
Node member |
Member interfaces on the redundancy group node. |
Physical status |
Physical status of the member interfaces on the node: · Down (redundancy down)—The interface is shut down by the Reth module. · Down—The interface is administratively up but physically down possibly because no physical link is present or the link has failed. · UP—The interface is both administratively and physically up. |
Track info |
Information about the track entries associated with the node. |
Track |
Track entry number. |
Status |
Track entry status. For the high-priority node, the first track entry that changed to NotReady or Negative state is identified as Faulty. |
Reduced weight |
Weight decrement rate of the node. |
The interface excluded from the shutdown action by the Reth module. Absent indicates that the interface does not exist. |
Use hold-down-interval to set the hold-down timer for a redundancy group.
Use undo hold-down-interval to restore the default.
hold-down-interval second
The hold-down timer is 1 second for a redundancy group.
Redundancy group view
context-admin
second: Specifies the hold-down timer in the range of 0 to 1800 seconds.
Set the hold-down timer to prevent frequent switchovers. The hold-down timer specifies the minimum interval between two switchovers. This timer starts when a switchover is finished. The redundancy group can perform another switchover only after the hold-down timer expires.
# Set the hold-down timer to 300 seconds for redundancy group aaa.
[Sysname-redundancy-group-aaa] hold-down-interval 300
Use member failover group to assign a failover group to a redundancy group.
Use undo member failover group to remove a failover group from a redundancy group.
member failover group group-name
undo member failover group group-name
A redundancy group does not contain failover groups.
context-admin
group-name: Specifies an existing failover group by its name, a case-sensitive string of 1 to 63 characters.
You can assign a failover group to only one redundancy group.
A redundancy group can contain a maximum of 32 failover groups.
# Assign failover group bb to redundancy group aaa.
[Sysname-redundancy-group-aaa] member failover group bb
Use member interface to assign a Reth interface to a redundancy group.
Use undo member interface to remove a Reth interface from a redundancy group.
member interface reth interface-number [ quick-fallback ]
undo member interface reth interface-number
A redundancy group does not contain Reth interfaces.
context-admin
reth interface-number: Specifies an existing Reth interface by its number. The Reth interface must exist.
quick-fallback: Enables quick fallback for the Reth interface. If quick fallback is enabled on a Reth interface, only the protocol state of the higher-priority member interface is set to down when it becomes inactive. The high-priority member interface is still physically up. When this feature is disabled on a Reth interface, both the physical state and protocol state of the inactive member interface are set to down. As a best practice, enable this feature if the preemption delay timer is set in seconds.
You can assign a Reth interface to only one redundancy group.
A redundancy group can contain a maximum of 32 Reth interfaces.
# Assign Reth 1 to redundancy group aaa.
[Sysname-redundancy-group-aaa] member interface reth 1
Use node to create a redundancy group node and enter its view, or enter the view of an existing redundancy group node.
Use undo node to remove a redundancy group node.
node node-id
undo node node-id
No redundancy group nodes exist.
context-admin
node-id: Specifies a redundancy group node ID in the range of 1 to 2.
You can create a maximum of two nodes for a redundancy group. One is the primary node, and the other is the secondary node.
Before you delete a redundancy group node, you must remove the binding between the node and its IRF member device.
# Create node 1 for redundancy group aaa.
bind chassis
Use node-member interface to assign a physical Ethernet interface to a redundancy group node.
Use undo node-member interface to remove a physical Ethernet interface from a redundancy group node.
node-member interface interface-type interface-number
undo node-member interface interface-type interface-number
A redundancy group node does not have member interfaces.
context-admin
interface-type interface-number: Specifies a physical interface by its type and number. The interface must belong to the IRF member device that is bound to the node.
Before you assign physical Ethernet interfaces to a redundancy group node, you must use the bind chassis command to bind the node to an IRF member device.
The physical Ethernet interfaces cannot be members of Reth interfaces.
An interface can be assigned to only one redundancy group node.
# Assign GigabitEthernet 1/2/5/1 to node 1 of redundancy group aaa.
[Sysname-redundancy-group-aaa-node1]node-member interface gigabitethernet 1/2/5/1
bind chassis
Use preempt-delay to set the preemption delay timer for a redundancy group.
Use undo preempt-delay to restore the default.
preempt-delay min
undo preempt-delay
The preemption delay timer is 1 minute (60 seconds) for a redundancy group.
context-admin
min: Specifies the preemption delay timer in the range of 0 to 12 minutes. If you set this timer to 0 minutes, both automatic and manual switchovers to the high-priority node are disabled.
The preemption delay timer specifies the delay before a switchover to the high-priority node occurs after the switchover is triggered. The delay allows the system to process events (such as interface state changes) required for the switchover.
If the low-priority node is the primary node, after you set this timer from 0 to a non-zero value, you must manually request a switchover back to the high-priority node. If you do not manually request a switchover, the automatic switchover feature cannot work correctly.
# Set the preemption delay timer to 2 minutes for redundancy group aaa.
[Sysname-redundancy-group-aaa] preempt-delay 2
# Set the preemption delay timer to 120 seconds for redundancy group aaa.
[Sysname-redundancy-group-aaa] preempt-delay seconds 120
Use priority to set the priority of a redundancy group node.
Use undo priority to restore the default.
priority priority
undo priority
The priority of a redundancy group node is 1.
context-admin
priority: Specifies the priority in the range of 1 to 255. The higher the value, the higher the priority.
By default, the high-priority node is the primary node, and the low-priority node is the secondary node. If both nodes have the same priority, the lower-numbered node is the primary node.
# Set the priority to 3 for node 1 of redundancy group aaa.
[Sysname-redundancy-group-aaa-node1] priority 3
Use redundancy group to create a redundancy group and enter its view, or enter the view of an existing redundancy group.
Use undo redundancy group to remove a redundancy group.
redundancy group group-name
undo redundancy group group-name
No redundancy groups exist.
context-admin
group-name: Specifies a redundancy group name, a case-sensitive string of 1 to 15 characters.
You can create a maximum of 255 redundancy groups.
Before you delete a redundancy group, make sure all its Reth interfaces, nodes, and failover groups are removed.
# Create redundancy group aaa and enter its view.
Use snmp-agent trap enable rddc to enable SNMP notifications for redundancy groups.
Use undo snmp-agent trap enable rddc to disable SNMP notifications for redundancy groups.
SNMP notifications are enabled for redundancy groups.
context-admin
This command enables SNMP notifications for the following events:
· A manual switchover is performed.
· An interface goes down.
· A faulty interface is recovered.
For redundancy group event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
# Enable SNMP notifications for redundancy groups.
[Sysname] snmp-agent trap enable rddc
Use switchover request to request a switchover to the low-priority node.
switchover request
context-admin
Use this command to request a switchover to the low-priority node when both of the redundancy group nodes are operating correctly. This command can be used in scenarios where component replacement is required for the high-priority node.
# Request a switchover to the low-priority node for redundancy group aaa.
[Sysname-redundancy-group-aaa] switchover request
switchover reset
Use switchover reset to request a switchover to the high-priority node.
switchover reset
context-admin
Use this command to request a switchover to the high-priority node when both of the redundancy group nodes are operating correctly.
If the preemption delay timer is set to 0 seconds, you cannot perform a manual switchover to the high-priority node.
# Request a switchover to the high-priority node for redundancy group aaa.
[Sysname-redundancy-group-aaa] switchover reset
preempt-delay
switchover request
Use track to associate a track entry with a redundancy group node.
Use undo track to remove the association between a track entry and a redundancy group node.
track track-entry-number [ reduced weight-reduced ] [ interface interface-type interface-number ]
undo track track-entry-number
A redundancy group node is not associated with track entries.
context-admin
track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
reduced weight-reduced: Specifies the weight decrement rate in the range of 1 to 255. The default is 255.
interface interface-type interface-number: Specifies an interface by its type and number. The interface will be excluded from the shutdown action by the Reth module. If you do not specify this option, no interface is excluded from the shutdown action by the Reth module. You must specify the tracked interface for this option if the interface has one of the following roles:
· Member of the redundancy group.
· Member of a Reth interface in the redundancy group.
You can associate a maximum of 64 track entries with a redundancy group node.
As a best practice, associate a redundancy group node with an existing track entry. If the track entry does not exist, a switchover might occur.
Do not exclude a subinterface from the shutdown action if both the subinterface and its main interface have one of the following roles on the high-priority node:
When the Reth module shuts down the main interface, the subinterface is also shut down. The shutdown subinterface cannot recover automatically to trigger an automatic switchover.
# Associate track entries 1 and 2 with redundancy group node 1. Exclude GigabitEthernet 1/2/5/1 and GigabitEthernet 2/2/5/1 from the shutdown action by the Reth module.
[Sysname] track 1 interface gigabitethernet 1/2/5/1
[Sysname] track 2 interface gigabitethernet 2/2/5/1
[Sysname-redundancy-group-aaa-node1] track 1 reduced 50 interface gigabitethernet 1/2/5/1
[Sysname-redundancy-group-aaa-node1] track 2 reduced 50 interface gigabitethernet 2/2/5/1
