- 12-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-PoE configuration
- 05-SNMP configuration
- 06-RMON configuration
- 07-NETCONF configuration
- 08-EAA configuration
- 09-Process monitoring and maintenance configuration
- 10-Sampler configuration
- 11-Mirroring configuration
- 12-sFlow configuration
- 13-Information center configuration
- 14-GOLD configuration
- 15-Packet capture configuration
- 16-VCF fabric configuration
- 17-CWMP configuration
- 18-SmartMC configuration
| 13-Information center configuration | 165.06 KB |
Configuring the information center
Default output rules for diagnostic logs·
Default output rules for security logs
Default output rules for hidden logs
Default output rules for trace logs
Information center configuration task list
Outputting logs to the console
Outputting logs to the monitor terminal
Outputting logs to the log buffer
Saving security logs to the security log file
Managing the security log file
Saving diagnostic logs to the diagnostic log file
Configuring the maximum size of the trace log file
Setting the minimum storage period for log files and logs in the log buffer
Enabling synchronous information output
Enabling duplicate log suppression
Configuring log suppression for a module
Disabling an interface from generating link up or link down logs
Enabling SNMP notifications for system logs
Displaying and maintaining information center
Information center configuration examples
Configuration example for outputting logs to the console
Configuration example for outputting logs to a UNIX log host
Configuration example for outputting logs to a Linux log host
The information center on a device classifies and manages logs for all modules so that network administrators can monitor network performance and troubleshoot network problems.
Overview
The information center receives logs generated by source modules and outputs logs to different destinations according to user-defined output rules. You can classify, filter, and output logs based on source modules. To view the supported source modules, use info-center source ?.
Figure 1 Information center diagram
By default, the information center is enabled. It affects system performance to some degree while processing large amounts of information. If the system resources are insufficient, disable the information center to save resources.
Log types
Logs are classified into the following types:
· Standard system logs—Record common system information. Unless otherwise specified, the term "logs" in this document refers to standard system logs.
· Diagnostic logs—Record debug messages.
· Security logs—Record security information, such as authentication and authorization information.
· Hidden logs—Record log information not displayed on the terminal, such as input commands.
· Trace logs—Record system tracing and debug messages, which can be viewed only after the devkit package is installed.
Log levels
Logs are classified into eight severity levels from 0 through 7 in descending order. The information center outputs logs with a severity level that is higher than or equal to the specified level. For example, if you specify a severity level of 6 (informational), logs that have a severity level from 0 to 6 are output.
Severity value |
Level |
0 |
Emergency |
The system is unusable. For example, the system authorization has expired. |
1 |
Alert |
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit. |
2 |
Critical |
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails. |
3 |
Error |
Error condition. For example, the link state changes. |
4 |
Warning |
Warning condition. For example, an interface is disconnected, or the memory resources are used up. |
5 |
Notification |
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots. |
6 |
Informational |
Informational message. For example, a command or a ping operation is executed. |
7 |
Debugging |
Debug message. |
Log destinations
The system outputs logs to the following destinations: console, monitor terminal, log buffer, log host, and log file. Log output destinations are independent and you can configure them after enabling the information center.
Default output rules for logs
A log output rule specifies the source modules and severity level of logs that can be output to a destination. Logs matching the output rule are output to the destination. Table 2 shows the default log output rules.
Destination |
Log source modules |
Output switch |
Severity |
Console |
All supported modules |
Enabled |
Debug |
Monitor terminal |
Disabled |
Debug |
Log host |
Enabled |
Informational |
Log buffer |
Enabled |
Informational |
Log file |
Enabled |
Informational |
Diagnostic logs can only be output to the diagnostic log file, and cannot be filtered by source modules and severity levels. Table 3 shows the default output rule for diagnostic logs.
Table 3 Default output rule for diagnostic logs
Destination |
Output switch |
Severity |
Diagnostic log file |
Enabled |
Debug |
Security logs can only be output to the security log file, and cannot be filtered by source modules and severity levels. Table 4 shows the default output rule for security logs.
Table 4 Default output rule for security logs
Destination |
Output switch |
Severity |
Security log file |
Disabled |
Debug |
Hidden logs can be output to the log host, the log buffer, and the log file. Table 5 shows the default output rules for hidden logs.
Table 5 Default output rules for hidden logs
Destination |
Output switch |
Severity |
Log host |
Enabled |
Informational |
Log buffer |
Enabled |
Informational |
Log file |
Enabled |
Informational |
Trace logs can only be output to the trace log file, and cannot be filtered by source modules and severity levels. Table 6 shows the default output rules for trace logs.
Table 6 Default output rules for trace logs
Destination |
Output switch |
Severity |
Trace log file |
Enabled |
Debugging |
Log formats
The format of logs varies by output destinations, as shown in Table 7.
Output destination |
Format |
Example |
Console, monitor terminal, log buffer, or log file |
Prefix Timestamp Sysname Module/Level/Mnemonic: Content |
%Nov 24 14:21:43:502 2010 Sysname SHELL/5/SHELL_LOGIN: VTY logged in from 192.168.1.26 |
Log host |
· Standard format: · unicom format: · cmcc format: |
Table 8 describes the fields in a log message.
Prefix (information type) |
A log to a destination other than the log host has an identifier in front of the timestamp: · An identifier of percent sign (%) indicates a log with a level equal to or higher than informational. · An identifier of asterisk (*) indicates a debug log or a trace log. · An identifier of caret (^) indicates a diagnostic log. |
PRI (priority) |
A log destined to the log host has a priority identifier in front of the timestamp. The priority is calculated by using this formula: facility*8+level, where: · facility is the facility name. Facility names local0 through local7 correspond to values 16 through 23. The facility name can be configured using the info-center loghost command. It is used to identify log sources on the log host, and to query and filter the logs from specific log sources. · level is in the range of 0 to 7. See Table 1 for more information about severity levels. |
Timestamp |
Records the time when the log was generated. Logs sent to the log host and those sent to the other destinations have different timestamp precisions, and their timestamp formats are configured with different commands. For more information, see Table 9 and Table 10. |
Hostip |
Source IP address of the log. If the info-center loghost source command is configured, this field displays the IP address of the specified source interface. Otherwise, this field displays the sysname. This field exists only in logs in unicom format that are sent to the log host. |
Serial number |
Serial number of the device that generated the log. This field exists only in logs in unicom format that are sent to the log host. |
Sysname (host name or host IP address) |
The sysname is the host name or IP address of the device that generated the log. You can use the sysname command to modify the name of the device. |
%% (vendor ID) |
Indicates that the information was generated by an H3C device. This field exists only in logs sent to the log host. |
vv (version information) |
Identifies the version of the log, and has a value of 10. This field exists only in logs that are sent to the log host. |
Module |
Specifies the name of the module that generated the log. You can enter the info-center source ? command in system view to view the module list. |
Level |
Identifies the level of the log. See Table 1 for more information about severity levels. |
Mnemonic |
Describes the content of the log. It contains a string of up to 32 characters. |
Source |
(In standalone mode.) Optional field that identifies the source of the log. The value contains a card slot number and the IP address of the log sender. (In IRF mode.) Optional field that identifies the source of the log. The value contains an IRF member device ID, a card slot number, and the IP address of the log sender. |
Content |
Provides the content of the log. |
Table 9 Timestamp precisions and configuration commands
Item |
Destined to the log host |
Destined to the console, monitor terminal, log buffer, and log file |
Precision |
Seconds |
Milliseconds |
Command used to set the timestamp format |
info-center timestamp loghost |
info-center timestamp |
Table 10 Description of the timestamp parameters
Timestamp parameters |
Example |
boot |
Time that has elapsed since system startup, in the format of xxx.yyy. xxx represents the higher 32 bits, and yyy represents the lower 32 bits, of milliseconds elapsed. Logs that are sent to all destinations other than a log host support this parameter. |
%0.109391473 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully. 0.109391473 is a timestamp in the boot format. |
date |
Current date and time, in the format of mmm dd hh:mm:ss yyy for logs that are output to a log host, or MMM DD hh:mm:ss:xxx YYYY for logs that are output to other destinations. All logs support this parameter. |
%May 30 05:36:29:579 2003 Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully. May 30 05:36:29:579 2003 is a timestamp in the date format. |
iso |
Timestamp format stipulated in ISO 8601. Only logs that are sent to a log host support this parameter. |
<189>2003-05-30T06:42:44 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully. 2003-05-30T06:42:44 is a timestamp in the iso format. |
none |
No timestamp is included. All logs support this parameter. |
% Sysname FTPD/5/FTPD_LOGIN: User ftp (192.168.1.23) has logged in successfully. No timestamp is included. |
no-year-date |
Current date and time without year information, in the format of MMM DD hh:mm:ss:xxx. Only logs that are sent to a log host support this parameter. |
<189>May 30 06:44:22 Sysname %%10FTPD/5/FTPD_LOGIN(l): User ftp (192.168.1.23) has logged in successfully. May 30 06:44:22 is a timestamp in the no-year-date format. |
FIPS compliance
Tasks at a glance |
Perform at least one of the following tasks: · Outputting logs to the console · Outputting logs to the monitor terminal · Outputting logs to log hosts |
(Optional.) Managing security logs |
(Optional.) Saving diagnostic logs to the diagnostic log file |
(Optional.) Configuring the maximum size of the trace log file |
(Optional.) Setting the minimum storage period for log files and logs in the log buffer |
(Optional.) Enabling synchronous information output |
(Optional.) Enabling duplicate log suppression |
(Optional.) Configuring log suppression for a module |
(Optional.) Disabling an interface from generating link up or link down logs |
(Optional.) Enabling SNMP notifications for system logs |
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable the information center. |
info-center enable |
By default, the information center is enabled. |
3. Configure an output rule for the console. |
info-center source { module-name | default } { console | monitor | logbuffer | logfile | loghost } { deny | level severity } |
For information about default output rules, see "Default output rules for logs." |
4. (Optional.) Configure the timestamp format. |
info-center timestamp { boot | date | none } |
By default, the timestamp format is date. |
5. Return to user view. |
quit |
N/A |
6. (Optional.) Enable log output to the console. |
terminal monitor |
The default setting is enabled. |
7. Enable the display of debug information on the current terminal. |
terminal debugging |
By default, the display of debug information is disabled on the current terminal. |
8. (Optional.) Set the lowest severity level of logs that can be output to the console. |
terminal logging level severity |
The default setting is 6 (informational). |
Monitor terminals refer to terminals that log in to the device through the VTY line.
To output logs to the monitor terminal:
Step |
Command |
Remarks |
system-view |
N/A |
3. Configure an output rule for the monitor terminal. |
The default timestamp format is date. |
quit |
N/A |
6. Enable log output to the monitor terminal. |
terminal monitor |
By default, log output to the monitor terminal is enabled. |
8. (Optional.) Set the lowest level of logs that can be output to the monitor terminal. |
Step |
Command |
Remarks |
system-view |
N/A |
3. Configure a log output rule or log output filter for sending logs to log hosts. |
· Configure a log output rule: · Configure a log output filter: |
Use either command. For information about default output rules, see "Default output rules for logs." |
4. (Optional.) Specify the source IP address for output logs. |
info-center loghost source interface-type interface-number |
By default, the source IP address of output logs is the primary IP address of their outgoing interfaces. |
5. (Optional.) Specify the format for logs to be output to log hosts. |
info-center format { unicom | cmcc } |
By default, logs are output to log hosts in standard format. |
6. (Optional.) Configure the timestamp format. |
info-center timestamp loghost { date | iso [ with-timezone ] | no-year-date | none } |
7. Specify a log host and configure related parameters. |
info-center loghost [ vpn-instance vpn-instance-name ] { hostname | ipv4-address | ipv6 ipv6-address } [ port port-number ] [ dscp dscp-value ] [ facility local-number ] [ filter filter-name ] |
By default, no log hosts or related parameters are specified. The value for the port-number argument must be the same as the value configured on the log host. Otherwise, the log host cannot receive logs. The device supports a maximum of 20 log hosts. |
Step |
Command |
Remarks |
N/A |
3. Enable log output to the log buffer. |
info-center logbuffer |
By default, log output to the log buffer is enabled. |
4. (Optional.) Set the maximum number of logs that can be stored in the log buffer. |
info-center logbuffer size buffersize |
By default, the log buffer can store 512 logs. |
5. Configure an output rule for the log buffer. |
Saving logs to the log file
By default, the log file feature saves logs from the log file buffer to the log file every 24 hours. You can adjust the saving interval or manually save logs to the log file. After saving logs to the log file, the system clears the log file buffer.
The device supports multiple log files. Each log file has a maximum capacity. The log files are named as logfile1.log, logfile2.log, and so on.
When logfile1.log is full, the system compresses logfile1.log as logfile1.log.gz and creates a new log file named logfile2.log. The process repeats until the last log file is full.
After the last log file is full, the device repeats the following process:
1. The device locates the oldest compressed log file logfileX.log.gz and creates a new file using the same name (logfileX.log).
2. When logfileX.log is full, the device compresses the log file as logfileX.log.gz to replace the existing file logfileX.log.gz.
As a best practice, back up the log files regularly to avoid loss of important logs.
You can enable log file overwrite-protection to stop the device from saving new logs when the last log file is full or the storage device runs out of space.
To save logs to the log file:
Step |
Command |
Remarks |
system-view |
N/A |
3. Enable the log file feature. |
info-center logfile enable |
By default, the log file feature is enabled. |
4. (Optional.) Enable log file overwrite-protection. |
info-center logfile overwrite-protection [ all-port-powerdown ] |
By default, log file overwrite-protection is disabled. This feature is supported only in FIPS mode. |
5. (Optional.) Set the maximum size for the log file. |
info-center logfile size-quota size |
The default setting is 5 MB. To ensure normal operation, set the size argument to a value between 1 MB and 10 MB. |
6. (Optional.) Specify the directory to save the log file. |
info-center logfile directory dir-name |
The default log file directory is flash:/logfile. (In standalone mode.) This command cannot survive a reboot or an active/standby switchover. (In IRF mode.) This command cannot survive an IRF reboot or a global active/standby switchover in an IRF fabric. |
7. Save the logs in the log file buffer to the log file. |
· Configure the interval to perform the
save operation: · Manually save the logs in the log file buffer
to the log file: |
The default saving interval is 86400 seconds. The logfile save command is available in any view. |
Security logs are very important for locating and troubleshooting network problems. Generally, security logs are output together with other logs. It is difficult to identify security logs among all logs.
To solve this problem, you can save security logs to the security log file without affecting the current log output rules.
After you enable the saving of the security logs to the security log file:
· The system first outputs security logs to the security log file buffer.
· The system saves logs from the security log file buffer to the security log file at the specified interval (a user authorized the security-audit role can also manually save security logs to the security log file).
· After the security logs are saved, the buffer is cleared immediately.
The device supports only one security log file. To avoid security log loss, you can set an alarm threshold for the security log file usage. When the alarm threshold is reached, the system outputs a message to inform the administrator. The administrator can log in to the device with the security-audit user role and back up the security log file to prevent the loss of important data.
To save security logs to the security log file:
Step |
Command |
Remarks |
system-view |
N/A |
3. Enable the saving of the security logs to the security log file. |
info-center security-logfile enable |
By default, saving security logs to the security log file is disabled. |
4. Set the interval at which the system saves security logs. |
info-center security-logfile frequency freq-sec |
The default saving interval is 86400 seconds. |
5. (Optional.) Set the maximum size for the security log file. |
info-center security-logfile size-quota size |
The default setting is 10 MB. |
6. (Optional.) Set the alarm threshold of the security log file usage. |
info-center security-logfile alarm-threshold usage |
By default, the alarm threshold of the security log file usage is 80. When the usage of the security log file reaches 80%, the system will inform the user. |
To use the security log file management commands in this section, a local user must be authorized the security-audit user role. For information about configuring the security-audit user role, see Security Command Reference.
To manage the security log file:
Task |
Command |
Remarks |
Display a summary of the security log file. |
display security-logfile summary |
Available in user view. |
Change the directory of the security log file. |
a system-view b info-center security-logfile directory dir-name |
By default, the security log file is saved in the seclog directory in the root directory of the storage device. (In standalone mode.) This command cannot survive a reboot or an active/standby switchover. (In IRF mode.) This command cannot survive an IRF reboot or a global active/standby switchover in an IRF fabric. |
Manually save all the contents in the security log file buffer to the security log file. |
security-logfile save |
Available in any view. |
By default, the device saves diagnostic logs from the diagnostic log file buffer to the diagnostic log file every 24 hours. You can adjust the saving interval or manually save diagnostic logs to the diagnostic log file. After saving diagnostic logs to the diagnostic log file, the system clears the diagnostic log file buffer.
The device supports multiple diagnostic log files. Each diagnostic log file has a maximum capacity. The diagnostic log files are named as diagfile1.log, diagfile2.log, and so on. When diagfile1.log is full, the system compresses diagfile1.log as diagfile1.log.gz and creates a new diagnostic log file named diagfile2.log. The process repeats until the last diagnostic log file is full.
After the last diagnostic log file is full, the device repeats the following process:
1. The device locates the oldest compressed diagnostic log file diagfileX.log.gz and creates a new file using the same name (diagfileX.log).
2. When diagfileX.log is full, the device compresses the log file as diagfileX.log.gz to replace the existing file diagfileX.log.gz.
To avoid loss of important logs, back up the diagnostic log files regularly.
To enable saving diagnostic logs to the diagnostic log file:
Step |
Command |
Remarks |
system-view |
N/A |
3. Enable saving diagnostic logs to the diagnostic log file. |
info-center diagnostic-logfile enable |
By default, saving diagnostic logs to the diagnostic log file is enabled. |
4. (Optional.) Set the maximum size for the diagnostic log file. |
info-center diagnostic-logfile quota size |
5. (Optional.) Specify the directory to save the diagnostic log file. |
info-center diagnostic-logfile directory dir-name |
By default, the diagnostic log file is saved in the diagfile directory under the root directory of the storage device. (In standalone mode.) This command cannot survive a reboot or an active/standby switchover. (In IRF mode.) This command cannot survive an IRF reboot or a global active/standby switchover in an IRF fabric. |
6. Save diagnostic logs in the diagnostic log file buffer to the diagnostic log file. |
saving operation: · Manually save diagnostic logs in the buffer to
the diagnostic log file: |
The default saving interval is 86400 seconds. The diagnostic-logfile save command is available in any view. |
The device has only one trace log file. When the trace log file is full, the device overwrites the oldest trace logs with new ones.
To set the maximum size for the trace log file:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the maximum size for the trace log file. |
info-center trace-logfile quota size |
By default, the maximum size of the trace log file is 10 MB. |
Use this feature to set the minimum storage period for log files and logs in the log buffer.
Logs in the log buffer
By default, when the log buffer is full, new logs will automatically overwrite the oldest logs. After the minimum storage period is set, the system identifies the storage period of a log to determine whether to delete the log. The system current time minus a log's generation time is the log's storage period.
· If the storage period of a log is shorter than or equal to the minimum storage period, the system does not delete the log. The new log will not be saved.
· If the storage period of a log is longer than the minimum storage period, the system deletes the log to save the new log.
Log files
By default, when the last log file is full, the device locates the oldest compressed log file logfileX.log.gz and creates a new file using the same name (logfileX.log).
After the minimum storage period is set, the system identifies the storage period of the compressed log file before creating a new log file with the same name. The system current time minus the log file's last modification time is the log file's storage period.
· If the storage period of the compressed log file is shorter than or equal to the minimum storage period, the system stops saving new logs.
· If the storage period of the compressed log file is longer than the minimum storage period, the system creates a new file to save new logs.
For more information about log saving, see "Saving logs to the log file."
Configuration procedure
To set the minimum storage period for log files and logs in the log buffer:
Step |
Command |
Remarks |
system-view |
N/A |
2. Set the log minimum storage period. |
info-center syslog min-age min-age |
By default, the log minimum storage period is not set. |
System log output interrupts ongoing configuration operations, obscuring previously entered commands. Synchronous information output shows the obscured commands. It also provides a command prompt in command editing mode, or a [Y/N] string in interaction mode so you can continue your operation from where you were stopped.
To enable synchronous information output:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable synchronous information output. |
info-center synchronous |
By default, synchronous information output is disabled. |
Output of consecutive duplicate logs (logs that have the same module name, level, mnemonic, location, and text) wastes system and network resources.
With duplicate log suppression enabled, the system starts a suppression period upon outputting a log:
· If only duplicate logs are received during the suppression period, the information center does not output the duplicate logs. When the suppression period expires, the information center outputs the suppressed log and the number of times the log is suppressed.
· If a different log is received during the suppression period, the information center performs the following operations:
¡ Outputs the suppressed log and the number of times the log is suppressed.
¡ Outputs the different log and starts a suppression period for that log.
To enable duplicate log suppression:
Step |
Command |
Remarks |
system-view |
N/A |
info-center logging suppress duplicates |
By default, duplicate log suppression is disabled. |
Perform this task to configure a log suppression rule to suppress output of all logs or logs with a specific mnemonic value for a module.
To configure a log suppression rule for a module:
Step |
Command |
Remarks |
system-view |
N/A |
2. Configure a log suppression rule for a module. |
info-center logging suppress module module-name mnemonic { all | mnemonic-content } |
By default, the device does not suppress output of any logs from any modules. |
By default, all interfaces generate link up or link down log information when the interface state changes. In some cases, you might want to disable certain interfaces from generating this information. For example:
· You are concerned only about the states of some interfaces. In this case, you can use this function to disable other interfaces from generating link up and link down log information.
· An interface is unstable and continuously outputs log information. In this case, you can disable the interface from generating link up and link down log information.
Use the default setting in normal cases to avoid affecting interface status monitoring.
To disable an interface from generating link up or link down logs:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter interface view. |
N/A |
3. Disable the interface from generating link up or link down logs. |
undo enable log updown |
By default, all interfaces generate link up and link down logs when the interface state changes. |
This feature enables the device to send an SNMP notification for each log message it outputs. The device encapsulates the logs in SNMP notifications and then sends them to the SNMP module and the log trap buffer.
You can configure the SNMP module to send received SNMP notifications in SNMP traps or informs to remote hosts. For more information, see "Configuring SNMP."
To view the traps in the log trap buffer, access the MIB corresponding to the log trap buffer.
To enable SNMP notifications for system logs:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enable SNMP notifications for system logs. |
snmp-agent trap enable syslog |
By default, the device does not send SNMP notifications for system logs. |
3. Set the maximum number of traps that can be stored in the log trap buffer. |
info-center syslog trap buffersize buffersize |
By default, the log trap buffer can store a maximum of 1024 traps. |
Task |
Command |
Display the diagnostic log file configuration. |
display diagnostic-logfile summary |
Display the information of each output destination. |
display info-center |
Display log output filter information. |
display info-center filter [ filtername ] |
Display the content of the log file buffer. |
display logfile buffer |
(In standalone mode.) Display the state and the log information of the log buffer. |
display logbuffer [ reverse ] [ level severity | size buffersize | slot slot-number ] * |
(In IRF mode.) Display the state and the log information of the log buffer. |
display logbuffer [ reverse ] [ level severity | size buffersize | chassis chassis-number slot slot-number ] * |
(In standalone mode.) Display a summary of the log buffer. |
display logbuffer summary [ level severity | slot slot-number ] * |
(In IRF mode.) Display a summary of the log buffer. |
display logbuffer summary [ level severity | chassis chassis-number slot slot-number ] * |
Display the log file configuration. |
display logfile summary |
Display the content of the security log file buffer. |
display security-logfile buffer |
Clear the log buffer. |
reset logbuffer |
Network requirements
Configure the device to output to the console FTP logs that have a severity level of at least warning.
Figure 2 Network diagram
# Enable the information center.
[Device] info-center enable
# Disable log output to the console.
[Device] info-center source default console deny
To avoid output of unnecessary information, disable all modules from outputting log information to the specified destination (console in this example) before you configure the output rule.
# Configure an output rule to output to the console FTP logs that have a severity level of at least warning.
[Device] info-center source ftp console level warning
[Device] quit
# Enable the display of logs on the console. (This function is enabled by default.)
<Device> terminal logging level 6
<Device> terminal monitor
Now, if the FTP module generates logs, the information center automatically sends the logs to the console, and the console displays the logs.
Configure the device to output to the UNIX log host FTP logs that have a severity level of at least informational.
Figure 3 Network diagram
Before the configuration, make sure the device and the log host can reach each other. (Details not shown.)
1. Configure the device:
# Specify the log host 1.2.0.1/16 and specify local4 as the logging facility.
[Device] info-center loghost 1.2.0.1 facility local4
# Disable log output to the log host.
To avoid output of unnecessary information, disable all modules from outputting logs to the specified destination (loghost in this example) before you configure an output rule.
# Configure an output rule to output to the log host FTP logs that have a severity level of at least informational.
[Device] info-center source ftp loghost level informational
2. Configure the log host:
The following configurations were performed on Solaris. Other UNIX operating systems have similar configurations.
a. Log in to the log host as a root user.
b. Create a subdirectory named Device in directory /var/log/, and then create file info.log in the Device directory to save logs from Device.
# mkdir /var/log/Device
c. Edit the file syslog.conf in directory /etc/ and add the following contents.
In this configuration, local4 is the name of the logging facility that the log host uses to receive logs. info is the informational level. The UNIX system records the log information that has a severity level of at least informational to the file /var/log/Device/info.log.
NOTE: Follow these guidelines while editing the file /etc/syslog.conf: · Comments must be on a separate line and must begin with a pound sign (#). · No redundant spaces are allowed after the file name. · The logging facility name and the severity level specified in the /etc/syslog.conf file must be identical to those configured on the device by using the info-center loghost and info-center source commands. Otherwise, the log information might not be output to the log host correctly. |
d. Display the process ID of syslogd, kill the syslogd process, and then restart syslogd using the –r option to make the new configuration take effect.
# ps -ae | grep syslogd
147
# kill -HUP 147
# syslogd -r &
Now, the device can output FTP logs to the log host, which stores the logs to the specified file.
Configure the device to output to the Linux log host 1.2.0.1/16 FTP logs that have a severity level of at least informational.
Figure 4 Network diagram
# Specify the log host 1.2.0.1/16, and specify local5 as the logging facility.
[Device] info-center loghost 1.2.0.1 facility local5
To avoid outputting unnecessary information, disable all modules from outputting log information to the specified destination (loghost in this example) before you configure an output rule.
# Configure an output rule to enable output to the log host FTP logs that have a severity level of at least informational.
b. Create a subdirectory named Device in the directory /var/log/, and create file info.log in the Device directory to save logs of Device.
local5.info /var/log/Device/info.log
In the above configuration, local5 is the name of the logging facility used by the log host to receive logs. info is the informational level. The Linux system will store the log information with a severity level equal to or higher than informational to the file /var/log/Device/info.log.
d. Display the process ID of syslogd, kill the syslogd process, and then restart syslogd by using the -r option to apply the new configuration.
Make sure the syslogd process is started with the -r option on a Linux log host.
147
# kill -9 147
# syslogd -r &
Now, the system can record log information to the specified file.
