11-High Availability Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-R757X-GL-6W10011-High Availability Command Reference
10-BFD commands
10-BFD commands 99.33 KB
BFD commands
Basic BFD commands
bfd authentication-mode
Use bfd authentication-mode to configure the BFD authentication mode for single-hop BFD control packets.
Use undo bfd authentication-mode to restore the default.
bfd authentication-mode { m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
Single-hop BFD control packets are not authenticated.
Interface view
m-md5: Specifies the Meticulous MD5 algorithm.
m-sha1: Specifies the Meticulous SHA1 algorithm.
md5: Specifies the MD5 algorithm.
sha1: Specifies the SHA1 algorithm.
simple: Specifies the simple authentication mode.
key-id: Sets the authentication key ID in the range of 1 to 255.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
Use this command to enhance BFD session security.
BFD version 0 does not support this command. The configuration does not take effect.
# Configure VLAN-interface 11 to perform simple authentication for single-hop BFD control packets, setting the authentication key ID to 1 and plaintext key to 123456.
[Sysname-Vlan-interface11] bfd authentication-mode simple 1 plain 123456
bfd dampening
Use bfd dampening to configure BFD session flapping suppression.
Use undo bfd dampening to disable BFD session flapping suppression.
bfd dampening [ maximum maximum-interval initial initial-interval secondary secondary-interval ]
undo bfd dampening
BFD sessions are not suppressed.
maximum-interval: Specifies the maximum amount of time a BFD session is suppressed, in the range of 1 to 3600 seconds. The default is 20 seconds.
initial-interval: Specifies the amount of time a BFD session is suppressed for the first time. The value range for the initial-interval argument is 1 to 3600 seconds. The default is 6 seconds.
secondary-interval: Specifies the amount of time a BFD session is suppressed for the second time. The value range for the secondary-interval argument is 1 to 3600 seconds. The default is 10 seconds.
When BFD detects a link failure, it tears down the BFD session and notifies the upper-layer protocol of the failure. When the upper-layer protocol re-establishes a neighbor relationship, the BFD session comes up again. BFD session flaps occur when a link fails and recovers repeatedly, which consumes significant system resources and causes network instability.
This command allows you to suppress BFD session flapping by using the initial-interval, secondary-interval, and maximum-interval arguments.
·     A BFD session is suppressed within the specified interval. The suppression time does not exceed the maximum-interval.
·     After a BFD session goes down for the second time, it cannot be re-established within the initial-interval.
·     After a BFD session goes down for the third time, it cannot be re-established within the secondary-interval.
·     After a BFD session goes down for the fourth time and at any later time, the following rules apply:
¡     If secondary-interval × 2n-3 is smaller than or equal to the maximum-interval, the BFD session cannot be re-established within the secondary-interval × 2n-3.
¡     If secondary-interval × 2n-3 is greater than the maximum-interval, the BFD session cannot be re-established within the maximum-interval.
The letter n, starting from 4, is the number of times the BFD session flaps.
# Enable BFD session flapping suppression, and set the maximum-interval, initial-interval, and secondary-interval to 12 seconds, 4 seconds, and 8 seconds, respectively.
[Sysname] bfd dampening maximum 12 initial 4 secondary 8
bfd demand enable
Use bfd demand enable to enable the Demand BFD session mode.
Use undo bfd demand enable to restore the default.
bfd demand enable
The BFD session is in Asynchronous mode.
Interface view
In Demand mode, the device periodically sends BFD control packets. If the peer end is operating in Asynchronous mode (default), the peer end stops sending BFD control packets. If the peer end is operating in Demand mode, both ends stop sending BFD control packets. When the connectivity to another system needs to be verified explicitly, a system sends several BFD control packets with the Poll (P) bit set at the negotiated transmit interval. If no response is received within the detection interval, the session is considered down. If the connectivity is found to be up, no more BFD control packets are sent until the next command is issued.
In Asynchronous mode, the device periodically sends BFD control packets. The device considers that the session is down if it does not receive any BFD control packets within a specific interval.
# Enable the Demand BFD session mode on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd demand enable
bfd detect-interface
Use bfd detect-interface source-ip to create a BFD session for detecting the local interface state.
Use undo bfd detect-interface to remove the BFD session.
bfd detect-interface source-ip ip-address [ discriminator local local-value remote remote-value ]
No BFD session is created for detecting the local interface state.
Interface view
ip-address: Specifies the source IP address for BFD control packets.
discriminator: Specifies BFD session discriminators. If you do not specify discriminators, the device obtains BFD session discriminators through autonegotiation.
local local-value: Specifies the local discriminator. The value range for the local-value argument varies by MDC ID. Enter discriminator local ? to view relevant information.
remote remote-value: Specifies the remote discriminator in the range of 1 to 4294967295.
This command implements fast collaboration between interface state and BFD session state. When BFD detects a link fault, it sets the link layer protocol state to DOWN(BFD). This behavior helps applications relying on the link layer protocol state achieve fast convergence.
The member ports in Layer 3 aggregation groups do not have IP addresses, and they do not support fast detection mechanisms. You can use this command to detect link faults and locate faulty member ports of Layer 3 aggregate interfaces. This command also applies to member ports of Layer 3 aggregate interfaces, Layer 3 Ethernet interfaces, member ports of Layer 2 aggregate interfaces, and Layer 2 Ethernet interfaces.
Before you configure this command, you must enable the BFD control packet mode on both ends of the BFD session. The destination IP address for BFD control packets is 224.0.0.184, and it cannot be configured. As a best practice, configure the IP address of the interface as the source IP address. If the interface does not have an IP address configured, configure a unicast address other than 0.0.0.0.
If you configure both the bfd detect-interface and bfd echo enable commands for an interface, only the bfd detect-interface command takes effect.
If the peer device does not support obtaining BFD session discriminators through autonegotiation, you must specify the discriminators on both the local and peer devices. Without the discriminators, the BFD session cannot come up.
The BFD session discriminators must match on the local and peer devices. For example, if you configure bfd detect-interface source-ip 20.1.1.1 discriminator local 3073 remote 3074 on the local device, you must configure bfd detect-interface source-ip 20.1.1.2 discriminator local 3074 remote 3073 on the peer device.
The local discriminators of BFD sessions for interfaces on the same device must be different.
# Create a BFD session to detect the state of GigabitEthernet 1/0/1, and specify the source IP address as 20.1.1.1.
[Sysname-GigabitEthernet1/0/1] bfd detect-interface source-ip 20.1.1.1
bfd detect-multiplier
Use bfd detect-multiplier to set the single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode.
Use undo bfd detect-multiplier to restore the default.
bfd detect-multiplier value
The single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode are both 5.
Interface view
value: Specifies a detection time multiplier. The value range for this argument is 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD packets (including control packets and echo packets) that can be discarded.
Table 1 Detection interval calculation method
Mode
Detection interval
Echo packet mode
Detection time multiplier of the sender × actual packet sending interval of the sender
Control packet mode BFD session in asynchronous mode
Detection time multiplier of the receiver × actual packet sending interval of the receiver
Control packet mode BFD session in demand mode
# Set the single-hop detection time multiplier for control packet mode and the detection time multiplier for echo packet mode to 6 on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd detect-multiplier 6
bfd echo enable
Use bfd echo enable to enable the echo packet mode.
Use undo bfd echo enable to disable the echo packet mode.
undo bfd echo [ receive | send ] enable
The echo packet mode is disabled.
Interface view
receive: Specifies the echo packet receiving capability.
send: Specifies the echo packet sending capability.
If you enable the echo packet mode for a BFD session in which control packets are sent and the session comes up, BFD performs the following operations:
·     Periodically sends echo packets to detect link connectivity.
·     Decreases the control packet receiving rate at the same time.
To enable only the echo packet receiving capability, use the bfd echo receive enable command.
To enable only the echo packet sending capability, use the bfd echo send enable command.
If you do not specify the receive or send keyword, the command enables both the echo packet receiving and sending capabilities.
# Enable the echo packet mode on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd echo enable
bfd echo-source-ip
Use bfd echo-source-ip to configure the source IP address of BFD echo packets.
Use undo bfd echo-source-ip to remove the configured source IP address of BFD echo packets.
bfd echo-source-ip ip-address
No source IP address is configured for BFD echo packets.
ip-address: Specifies the source IP address of BFD echo packets.
The source IP address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IP address of BFD echo packets as 8.8.8.8.
[Sysname] bfd echo-source-ip 8.8.8.8
bfd echo-source-ipv6
Use bfd echo-source-ipv6 to configure the source IPv6 address of BFD echo packets.
Use undo bfd echo-source-ipv6 to remove the configured source IPv6 address of BFD echo packets.
No source IPv6 address is configured for BFD echo packets.
ipv6-address: Specifies the source IPv6 address for BFD echo packets.
The source IPv6 address of echo packets can only be a global unicast address.
The source IPv6 address cannot be on the same network segment as any local interface's IP address. Otherwise, a large number of ICMP redirect packets might be sent from the peer, resulting in link congestion.
# Configure the source IPv6 address of BFD echo packets as 80::2.
[Sysname] bfd echo-source-ipv6 80::2
bfd min-echo-receive-interval
Use bfd min-echo-receive-interval to set the minimum interval for receiving BFD echo packets.
Use undo bfd min-echo-receive-interval to restore the default.
On an S7503E-M switch, the default setting is 400 milliseconds for the LSQM1CTGS24QSFD0 MPU and is 1000 milliseconds for other MPUs.
On a switch other than S7503E-M, the default setting is 400 milliseconds.
Interface view
interval: Specifies the minimum interval for receiving BFD echo packets, in milliseconds. The value takes 0 or is in the range of 10 to 1000. The values 10 through 99 are not supported in the current software version.
This command sets the BFD echo packet receiving interval, which is the actual BFD echo packet sending interval.
The local end stops sending echo packets after autonegotiation with the remote end if the following conditions are met:
·     The echo packet mode is enabled on the local end.
·     The minimum interval for receiving BFD echo packets is set to 0 milliseconds on the remote end.
# Set the minimum interval for receiving BFD echo packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-echo-receive-interval 500
bfd min-receive-interval
Use bfd min-receive-interval to set the minimum interval for receiving single-hop BFD control packets.
Use undo bfd min-receive-interval to restore the default.
Interface view
interval: Specifies the minimum interval for receiving single-hop BFD control packets, in milliseconds. The value range for this argument is 10 to 1000. The values 10 through 99 are not supported in the current software version.
Use this command to prevent the control packet sending rate of the peer end from exceeding the control packet receiving rate of the local end.
The actual control packet sending interval of the peer end takes the greater value between the following values:
·     Minimum interval for transmitting BFD control packets on the peer end.
·     Minimum interval for receiving BFD control packets on the local end.
# Set the minimum interval for receiving single-hop BFD control packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-receive-interval 500
bfd min-transmit-interval
Use bfd min-transmit-interval to set the minimum interval for transmitting single-hop BFD control packets.
Use undo bfd min-transmit-interval to restore the default.
Interface view
interval: Specifies the minimum interval for transmitting single-hop BFD control packets, in milliseconds. The value range for this argument is 10 to 1000. The values 10 through 99 are not supported in the current software version.
Use this command to prevent the BFD packet sending rate from exceeding the device capability.
The actual BFD control packet transmitting interval on the local end is the greater value between the following values:
·     Minimum interval for transmitting BFD control packets on the local end.
·     Minimum interval for receiving BFD control packets on the peer end.
# Set the minimum interval for transmitting single-hop BFD control packets to 500 milliseconds on VLAN-interface 11.
[Sysname-Vlan-interface11] bfd min-transmit-interval 500
bfd multi-hop authentication-mode
Use bfd multi-hop authentication-mode to configure the authentication mode for multihop BFD control packets.
Use undo bfd multi-hop authentication-mode to restore the default.
bfd multi-hop authentication-mode { m-md5 | m-sha1 | md5 | sha1 | simple } key-id { cipher | plain } string
No authentication is performed.
# Configure the simple authentication mode for multihop BFD control packets, setting the authentication key ID to 1 and key to 123456.
[Sysname] bfd multi-hop authentication-mode simple 1 plain 123456
bfd multi-hop destination-port
Use bfd multi-hop destination-port to configure the destination port number for multihop BFD control packets.
Use undo bfd multi-hop destination-port to restore the default.
The destination port number for multihop BFD control packets is 4784.
port-number: Specifies the destination port number of multihop BFD control packets, 3784 or 4784.
# Specify the destination port number for multihop BFD control packets as 3784.
[Sysname] bfd multi-hop destination-port 3784
bfd multi-hop detect-multiplier
Use bfd multi-hop detect-multiplier to set the multihop detection time multiplier for control packet mode.
Use undo bfd multi-hop detect-multiplier to restore the default.
The multihop detection time multiplier for control packet mode is 5.
value: Specifies the multihop detection time multiplier in the range of 3 to 50.
The detection time multiplier determines the maximum number of concurrent BFD control packets that can be discarded.
Table 2 Detection interval calculation method
Mode
Detection interval
# Set the multihop detection time multiplier to 6.
[Sysname] bfd multi-hop detect-multiplier 6
bfd multi-hop min-receive-interval
Use bfd multi-hop min-receive-interval to set the minimum interval for receiving multihop BFD control packets.
Use undo bfd multi-hop min-receive-interval to restore the default.
interval: Specifies the minimum interval for receiving multihop BFD control packets, in milliseconds. The value range for this argument is 10 to 1000. The values 10 through 99 are not supported in the current software version.
Use this command to prevent the packet sending rate of the peer end from exceeding the packet receiving capability (minimum control packet receiving interval) of the local end. If the receiving capability is exceeded, the peer end dynamically adjusts the BFD control packet sending interval to the minimum control packet receiving interval of the local end.
# Set the minimum interval for receiving multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-receive-interval 500
bfd multi-hop min-transmit-interval
Use bfd multi-hop min-transmit-interval to set the minimum interval for transmitting multihop BFD control packets.
Use undo bfd multi-hop min-transmit-interval to restore the default.
interval: Specifies the minimum interval for transmitting multihop BFD control packets, in milliseconds. The value range for this argument is 10 to 1000. The values 10 through 99 are not supported in the current software version.
# Set the minimum interval for transmitting multihop BFD control packets to 500 milliseconds.
[Sysname] bfd multi-hop min-transmit-interval 500
bfd session init-mode
Use bfd session init-mode to configure the mode for establishing a BFD session.
Use undo bfd session init-mode to restore the default.
BFD uses the active mode.
active: Specifies the active mode. In active mode, BFD actively transmits BFD control packets to the remote device, regardless of whether it receives a BFD control packet from the remote device.
passive: Specifies the passive mode. In passive mode, BFD does not actively transmit a BFD control packet to the remote end; it transmits a BFD control packet only after receiving a BFD control packet from the remote end.
A minimum of one end must operate in active mode for a BFD session to be established.
BFD MAD always uses the active mode to establish sessions. For information about BFD MAD, see Virtual Technologies Configuration Guide.
# Configure the session establishment mode as passive.
[Sysname] bfd session init-mode passive
display bfd session
Use display bfd session to display BFD session information.
display bfd session [ discriminator value | verbose ]
discriminator value: Specifies a local ID in the range of 1 to 4294967295. If this option is not specified, the command displays brief information about all BFD sessions.
verbose: Displays detailed BFD session information. If this keyword is not specified, the command displays brief BFD session information.
# Display brief information about all IPv4 BFD sessions.
<Sysname> display bfd session
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 513/513        1.1.1.1         1.1.1.2         Up       2297ms      Vlan100
# Display detailed IPv4 BFD session information.
<Sysname> display bfd session verbose
       Local Discr: 513                  Remote Discr: 513
         Source IP: 1.1.1.1            Destination IP: 1.1.1.2
     Session State: Up                      Interface: Vlan-interface100
      Min Tx Inter: 500ms                Act Tx Inter: 500ms
      Min Rx Inter: 500ms                Detect Inter: 2500ms
          Rx Count: 42                       Tx Count: 43
      Connect Type: Direct             Running Up for: 00:00:20
         Hold Time: 2078ms                  Auth mode: None
       Detect Mode: Async                        Slot: 0
          Protocol: OSPF
          Version:1
         Diag Info: No Diagnostic
# Display brief information about all IPv6 BFD sessions.
 IPv6 session working in control packet mode:
         Source IP: FE80::20C:29FF:FED4:7171
    Destination IP: FE80::20C:29FF:FE72:AC4D
     Session State: Up                      Interface: Vlan100
         Hold Time: 2142ms
# Display detailed IPv6 BFD session information.
          Rx Count: 38                       Tx Count: 38
      Connect Type: Direct             Running Up for: 00:00:15
         Hold Time: 2211ms                  Auth mode: None
          Protocol: OSPFv3
          Version:1
Total Session Num
Total number of BFD sessions.
Up Session Num
Total number of active BFD sessions.
Init Mode
BFD operating mode: Active or passive.
BFD session type and operating mode:
·     IPv4 session working in control packet mode.
·     IPv4 session working in echo mode.
·     IPv6 session working in control packet mode.
·     IPv6 session working in echo mode.
Local Discr/LD
Local discriminator of the session.
Remote Discr/RD
Remote discriminator of the session.
Source IP/SourceAddr
Source IP address of the session.
Destination IP/DestAddr
Destination IP address of the session.
Session State/State
Session state: Down, Init, or Up.
Name of the interface of the session.
Min Tx Inter
Minimum BFD packet transmission interval.
Min Rx Inter
Minimum BFD packet receiving interval.
Act Tx Inter
Actual BFD packet transmission interval.
Detect Inter
Actual session detection timer.
Rx Count
Number of packets received.
Tx Count
Number of packets sent.
Hold Time/Holdtime
Length of time before the session detection timer expires, in milliseconds.
For a BFD session in Down state, this field displays 0ms.
Auth mode
Session authentication mode.
Connect Type
Connection type of the interface: Direct or indirect.
Running up for
Time period for which the session has been up.
Detect Mode
Detection mode:
·     Async—Asynchronous mode.
·     Demand—Demand mode.
·     Async/Echo—Asynchronous mode with echo detection enabled.
·     Demand/Echo—Demand mode with echo detection enabled.
Slot
Slot number.
Diag Info
Diagnostic information about the session:
·     No Diagnostic.
·     Control Detection Time Expired—A control packet mode BFD session goes down because local detection times out.
·     Echo Function Failed—An echo packet mode BFD session goes down, because local detection times out or the source IP address of echo packets is deleted.
·     Neighbor Signaled Session Down—The remote end notifies the local end of BFD session down.
·     Administratively Down—The local system prevents a BFD session from being established.
reset bfd session statistics
Use reset bfd session statistics to clear the BFD session statistics.
# Clear the BFD session statistics.
<Sysname> reset bfd session statistics
snmp-agent trap enable bfd
Use snmp-agent trap enable bfd to enable SNMP notifications for BFD.
Use undo snmp-agent trap enable bfd to disable SNMP notifications for BFD.
All SNMP notifications are enabled for BFD.
To report critical BFD events to an NMS, enable SNMP notifications for BFD. For BFD event notifications to be sent correctly, you must also configure SNMP as described in the network management and monitoring configuration guide for the device.
# Disable SNMP notifications for BFD.
[Sysname] undo snmp-agent trap enable bfd
