HomeSupportSwitchesS7500E-X SeriesConfigure & DeployConfiguration GuidesH3C S7500E-X Configuration Guides-R7523P01-6W10001-Fundamentals Configuration Guide
15-License management
15-License management 63.92 KB
Managing licenses
Overview
License-based features, such as MDC, EVI, FCoE, TRILL, and EVB, require a license to run on your device. To use a license-based feature, you must purchase a license or obtain a free trial license.
This chapter describes how to license a feature, transfer a license between devices, remove a license, and manage the license storage space.
License-based feature packages
The following are feature packages available for the device:
·           CAMPUS—Includes the MDC feature.
·           DATACENTER—Includes the EVI, FCoE, EVB, TRILL, and MDC features.
To use features in these packages, you must register and install the feature package licenses.
For more information about these features, see EVI Configuration Guide, FCoE Configuration Guide, EVB Configuration Guide, TRILL Configuration Guide, and Virtual Technologies Configuration Guide.
License types
The following types of licenses are available depending on validity period:
·           Permanent—A permanent license is always valid and never expires.
·           Days restricted—A license valid for a limited period in days, for example, 30 days.
Trial licenses are typically days restricted.
Locking methods
The following locking methods are available:
·           Device locked—A license can be installed only on the DID-specific device. The license takes effect on any MPU in the device even after an MPU replacement. The device supports this locking method.
·           MPU locked—A license can be installed only on the DID-specific MPU. The license takes effect on the MPU even after the MPU is moved to a different device.
General restrictions and guidelines
When you manage licenses, follow the general restrictions and guidelines:
·           Make sure no one else is performing license management tasks on the device you are working with.
·           Manage licenses on the default MDC, and the licensed features will be licensed to the non-default MDCs automatically. Non-default MDCs do not support the license management. For information about MDCs, see Virtual Technologies Configuration Guide.
·           Trial licenses and expired formal licenses cannot be uninstalled. Expired licenses remain in the license storage area unless you compress the license storage area.
·           Licenses cannot be installed if the license storage area is not sufficient. Before registering licenses, use the display license feature command to identify the number of available licenses. Do not register licenses more than the available number.
·           When installing a license, the system also searches the storage media for a matching feature package. When it finds a matching package, it stops searching and installs the package.
·           When uninstalling a license, the system checks whether the feature package for the license is running. If it is running, the system uninstalls the package automatically.
·           After a license is activated, it takes 5 minutes for fiber ports that are bound to an IRF port to function correctly.
·           If you cannot obtain or re-register the activation file due to problems such as operating system and browser errors, contact H3C Support.
License file safety
When you manage licenses, follow these restrictions and guidelines for license file safety:
·           Save and back up the obtained activation file in case of loss.
·           If you use FTP to transfer the activation file, use the Binary mode.
·           Do not open and edit the activation file to avoid file corruption.
·           Do not modify the name of the activation file to avoid licensing error.
·           Do not delete or move files in the flash:/license directory on a device. The license management feature uses this directory for license management. An incorrect file operation can cause problems. For example, if you delete an activation file that is usable or in use, the related feature will not function correctly. If a file is missing or corrupted, use the copy command to copy its backup file to the directory to recover the license. If the state of the recovered license is In use but not all licensed features can function, reboot the device. To verify the license state, use the display license command.
Licenses for different device types
To run a license-based feature on a device in standalone mode, install the registered license. The device will copy the activation file to other MPUs on the device during installation.
When you register and install licenses in an IRF fabric, follow these restrictions and guidelines:
·           Install one license for the feature on each member in the fabric. Make sure the SN and DID used for registering the feature license matches the current SN and DID of the specified member device.
·           Make sure the licenses installed on the members are the same.
·           A registered license takes effect on the member device where it is installed, and it is effective even after the member device joins another IRF fabric.
Compressing the license storage
CAUTION
CAUTION:
·       Compressing the license storage deletes expired licenses, uninstalled licenses, and Uninstall files. Back up the Uninstall files before you compress the license storage.
·       The DID changes each time the license storage is compressed. Before performing a compression, make sure all activation files generated based on the old DID have been installed. They cannot be installed after the compression.
When the value for the Total field equals that of the Usage field from the output of the display license feature command, the license storage area is full. To ensure sufficient storage space for installing new licenses, compress the license storage area.
To compress the license storage:
Step
1.      Enter system view.
2.      Compress the license storage.
In standalone mode:
license compress
in IRF mode:
license compress chassis chassis-number
Registering and activating a license
Make sure you have purchased a license for the first registration or an upgrade license for add-on nodes, add-on features, or time extensions.
To register and activate a license:
Step
1.      Identify the number of available license storage entries.
2.      (Optional.) Compress the license storage if the free license storage is not sufficient for licenses to be activated.
See "Compressing the license storage."
3.      Obtain the SN and DID on the device.
display license device-id
4.      Identity the license key on your license.
N/A
5.      Access http://www.h3c.com/portal/Technical_Support___Documents/Product_Licensing/, and select Register the First Time or Register Upgrade Licenses from the navigation tree.
N/A
6.      Select the product category and use the license key, SN, and DID to register the license.
N/A
7.      Download the activation file to the device.
N/A
8.      Enter system view.
9.      Install the activation file.
In standalone mode:
license activation-file install [ file-name ]
In IRF mode:
license activation-file install [ file-name ] chassis chassis-number
Transferring a license
You can transfer a license from one device to another if its activation file has not expired. If the activation file has expired, the license is not transferrable. Trial licenses are not transferrable either.
To transfer a license:
Step
Remarks
1.      Enter system view on the source device.
N/A
2.      Uninstall the activation file.
In standalone mode:
license activation-file uninstall [ file-name ]
In IRF mode:
license activation-file uninstall [ file-name ] chassis chassis-number
When an activation file is uninstalled, the system creates an Uninstall file. This file is required when you register the license for the target device.
The uninstallation action does not delete license data from the license storage area. To free storage space, you must compress the license storage (see "Compressing the license storage").
3.      Obtain the Uninstall key of the source device.
display license
N/A
4.      Access the target device and display SN and DID information.
N/A
5.      Access http://www.h3c.com/portal/Technical_Support___Documents/Product_Licensing/, and use the target device's SN and DID information and the source device's Uninstall key to generate a new activation file.
N/A
N/A
6.      Download the new activation file to the target device.
N/A
N/A
7.      Install the activation file on the target device.
N/A
See "Registering and activating a license."
Displaying and maintaining licenses
(In standalone mode.) Display the SN and DID of the device.
(In IRF mode.) Display the SN and DID of an IRF member device.
display license device-id chassis chassis-number
(In standalone mode.) Display detailed license information.
display license [ activation-file ]
(In IRF mode.) Display detailed license information.
display license [ activation-file ] [ chassis chassis-number ]
Display brief feature license information.
