HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Switch Series Configuration Guides-Release7178-6W10001-Fundamentals Configuration Guide
06-Configuration file management configuration
06-Configuration file management configuration 103.80 KB
Managing configuration files
Overview
You can use the CLI or the BootWare menus to manage configuration files. This chapter explains how to manage configuration files from the CLI.
A configuration file saves a set of commands for configuring software features on the device. You can save any configuration to a configuration file so the configuration can survive a reboot. You can also back up configuration files to a host for future use.
Configuration types
The device has the following types of configurations: factory defaults, startup configuration, and running configuration.
Factory defaults
The device is shipped with some basic settings called factory defaults. These default settings ensure that the device can start up and run correctly when it does not have any startup configuration file or when the configuration file is corrupt.
Factory defaults might differ from the default settings of commands.
To display factory defaults, use the display default-configuration command.
Startup configuration
The device uses startup configuration to configure software features during startup. After the device starts up, you can specify a different configuration file to be loaded at the next startup. This configuration file is called the next-startup configuration file. The configuration file that has been loaded is called the current startup configuration file.
If no next-startup configuration file exists, the device starts up with the factory defaults.
You can display the startup configuration by using one of the following methods:
·           Execute the display startup command. To display detailed file contents, use the more command.
·           After the device reboots, execute the display current-configuration command before making any configuration changes.
Running configuration
The running configuration includes unchanged startup settings and new settings. The running configuration is stored in the memory and is cleared at a device reboot or power off. To use the running configuration after a power cycling or reboot, save it to a configuration file.
To display the running configuration, use the display current-configuration command.
Next-startup configuration file redundancy
You can specify one main next-startup configuration file and one backup next-startup configuration file for redundancy.
At startup, the device tries to start up with the main configuration file. If the main configuration file is corrupt or unavailable, the device tries the backup configuration file. If the backup configuration file is corrupt or unavailable, the device starts up with the factory defaults.
For high availability, do not specify one configuration file as both the main and backup configuration files.
Configuration file formats
Configuration files you specify for saving configuration must use the .cfg extension. A .cfg configuration file is a human-readable text file. When you save configuration to a .cfg file, the device automatically saves the configuration to an .mdb user-inaccessible binary file that has the same name as the .cfg file. The device loads an .mdb file faster than loading a .cfg file.
Startup configuration file selection
At startup, the device uses the following procedure to identify the configuration file to load:
1.      The device searches for a valid .cfg next-startup configuration file.
2.      If one is found, the device searches for an .mdb file that has the same name and content as the .cfg file.
3.      If an .mdb file has the same name and content as the .cfg file, the device starts up with the .mdb file. If none is found, the device starts up with the .cfg file.
Unless otherwise stated, the term "configuration file" in this document refers to a .cfg configuration file.
Configuration file content organization and format
IMPORTANT:
To run on the device, a configuration file must meet the content and format requirements. To ensure a successful configuration load at startup, use a configuration file created on the device. If you edit the configuration file, make sure all edits are compliant with the requirements.
A configuration file must meet the following requirements:
·           All commands are saved in their complete form.
·           Commands are sorted in sections by different command views, including system view, interface view, protocol view, and user line view.
·           Two adjacent sections are separated by a comment line that starts with a pound sign (#).
·           The configuration file ends with the word return.
The following is a sample configuration file excerpt:
local-user root class manage
 password hash $h$6$Twd73mLrN8O2vvD5$Cz1vgdpR4KoTiRQNE9pg33gU14Br2p1VguczLSVyJLO2huV5Syx/LfDIf8ROLtVErJ/C31oq2rFtmNuyZf4STw==
interface Ten-GigabitEthernet1/1/1
 port link-mode route
 ip address 1.1.1.1 255.255.255.0
FIPS compliance
General configuration restrictions and guidelines
When you manage the next-startup configuration files, follow these restrictions and guidelines:
·           Save the next-startup configuration files to the root directory of the default storage medium. The device loads startup configuration files only from the default storage medium. You can access the BootWare menus to specify the built-in flash memory or the USB disk as the default storage medium.
·           In an IRF fabric, make sure all member devices use the same type of storage medium as the default storage medium.
Enabling configuration encryption
Configuration encryption enables the device to encrypt a startup configuration file automatically when it saves the running configuration. All H3C devices running Comware 7 software use the same private key or public key to encrypt configuration files.
Only H3C devices running Comware 7 software can decrypt the encrypted configuration files.
To enable configuration encryption:
Step
Remarks
1.      Enter system view.
N/A
2.      Enable configuration encryption.
configuration encrypt { private-key | public-key }
By default, configuration encryption is disabled. Configuration is saved unencrypted.
Displaying configuration differences
You can use the commands in this section to display the configuration differences between two configuration files or between a configuration file and the running configuration.
If you specify the next-startup configuration file for comparison, the system searches for the next-startup configuration file in the following order:
1.      The main next-startup configuration file.
2.      The backup next-startup configuration file if the main next-startup configuration file is unavailable or corrupt.
If both the main and backup next-startup configuration files are unavailable or corrupt, the system displays a message indicating that the next-startup configuration file does not exist.
To display the configuration differences in any view:
Display the configuration differences between two specified configuration files.
display diff configfile file-name-s configfile file-name-d
Display the configuration differences between the specified configuration file and the running configuration.
·          Method 1:
display diff configfile file-name-s current-configuration
·          Method 2:
display diff current-configuration configfile file-name-d
Display the configuration differences between the specified configuration file and the next-startup configuration file.
·          Method 1:
display diff configfile file-name-s startup-configuration
·          Method 2:
display diff startup-configuration configfile file-name-d
Display the configuration differences between the next-startup configuration file and the running configuration.
·          Method 1:
display diff current-configuration startup-configuration
·          Method 2:
display current-configuration diff
·          Method 3:
display diff startup-configuration current-configuration
Saving the running configuration
On an IRF fabric, use the display irf command to verify that the IRF topology is correct before you save the running configuration. After a member device leaves because of an IRF split, the member device's settings are still retained in the running configuration and the next-startup configuration file. However, saving the running configuration before recovering the IRF fabric will remove the member device's settings from the next-startup configuration file.
If you have saved the running configuration to the next-startup configuration file after an IRF split occurs, use the following method to restore the next-startup configuration file:
1.      Fix the split problem.
2.      Reboot the member device after the device rejoins the fabric.
3.      Execute the display current-configuration command to verify that the member device's settings are retained in the running configuration on the IRF fabric.
¡  If the settings are retained, you can directly save the running configuration to the next-startup configuration file on the IRF fabric.
¡  If the settings are lost, you must reconfigure the member device on the IRF fabric and then save the running configuration to the next-startup configuration file.
Using different methods to save the running configuration
When saving the running configuration to a configuration file, you can specify the file as the next-startup configuration file.
If you are specifying the file as the next-startup configuration file, use one of the following methods to save the configuration:
·           Fast mode—Use the save command without the safely keyword. In this mode, the device directly overwrites the target next-startup configuration file. If a reboot or power failure occurs during this process, the next-startup configuration file is lost. You must specify a new startup configuration file after the device reboots (see "Specifying a next-startup configuration file").
·           Safe mode—Use the save command with the safely keyword. Safe mode is slower than fast mode, but more secure. In safe mode, the system saves configuration in a temporary file and starts overwriting the target next-startup configuration file after the save operation is complete. If a reboot or power failure occurs during the save operation, the next-startup configuration file is still retained.
Use the safe mode if the power source is not reliable or you are remotely configuring the device.
To save the running configuration, perform either of the following tasks in any view:
Remarks
Save the running configuration to a configuration file without specifying the file as the next-startup configuration file.
N/A
Save the running configuration to a configuration file and specify the file as a next-startup configuration file.
save [ safely ] [ backup | main ] [ force ]
This command saves the configuration to a file in the root directory of each member device's default storage medium.
As a best practice, specify the safely keyword for reliable configuration saving.
If you specify only the safely keyword, the command saves the configuration to the main startup configuration file.
If the force keyword is specified, the command saves the configuration to the existing configuration file.
If the force keyword is not specified, the command allows you to specify a new next-startup configuration file.
Configuring configuration rollback
To replace the running configuration with the configuration in a configuration file without rebooting the device, use the configuration rollback function. This function helps you revert to a previous configuration state or adapt the running configuration to different network environments.
The configuration rollback function compares the running configuration against the specified replacement configuration file and handles configuration differences as follows:
·           If a command in the running configuration is not in the replacement file, the rollback function executes the undo form of the command.
·           If a command in the replacement file is not in the running configuration, the rollback function adds the command to the running configuration.
·           If a command has different settings in the running configuration and the configuration file, the rollback function replaces the running command setting with the setting in the configuration file.
To facilitate configuration rollback, the configuration archive function was developed. This function enables the system to save the running configuration automatically at regular intervals as checkpoint references.
Configuration task list
Tasks at a glance
(Required.) Configuring configuration archive parameters
(Required.) Perform either task:
·          Enabling automatic configuration archiving
·          Manually archiving the running configuration
(Required.) Rolling back configuration
Before archiving the running configuration, either manually or automatically, you must configure a file directory and file name prefix for configuration archives.
Configuration archives are saved with the file name format prefix_serial number.cfg, for example, 20080620archive_1.cfg and 20080620archive_2.cfg. The serial number is automatically assigned from 1 to 1000, increasing by 1. After the serial number reaches 1000, it restarts from 1.
After you change the file directory or file name prefix, or reboot the device, all of the following events occur:
·           The old configuration archives are regarded as common configuration files.
·           The configuration archive counter is reset.
·           The display archive configuration command no longer displays the old configuration archives.
·           The serial number for new configuration archives starts at 1.
After the maximum number of configuration archives is reached, the system deletes the oldest archive to make room for the new archive.
Configuration guidelines
The function saves the running configuration only on the master device.
To make sure the system can archive the running configuration after a master/subordinate switchover, create the configuration archive directory on all IRF member devices.
Configuration procedure
To configure configuration archive parameters:
Step
Remarks
N/A
2.      Configure the directory and file name prefix for archiving the running configuration.
archive configuration location directory filename-prefix filename-prefix
Do not include slot information in the directory name.
By default, no path or file name prefix is set for configuration archives, and the system does not regularly save configuration.
IMPORTANT IMPORTANT:
The undo form of this command performs the following operations:
·          Disables both manual and automatic configuration archiving.
·          Restores the default settings for the archive configuration interval and archive configuration max commands.
·          Clears the configuration archive information displayed by using the display archive configuration command.
3.      (Optional.) Set the maximum number of configuration archives.
archive configuration max file-number
The default number is 5.
Change the setting depending on the amount of storage available on the device.
Make sure you have set an archive path and file name prefix before performing this task.
To enable automatic configuration archiving:
Step
Remarks
N/A
2.      Enable automatic configuration archiving and set the archiving interval.
archive configuration interval minutes
By default, this function is disabled.
To display configuration archive names and their archiving time, use the display archive configuration command.
To save system resources, disable automatic configuration archiving and manually archive the configuration if the configuration will not be changed very often. You can also manually archive configuration before performing complicated configuration tasks. Then, you can use the archive for configuration recovery if the configuration attempt fails.
Perform the following task in user view:
Manually archive the running configuration.
To avoid a rollback failure, follow these guidelines:
·           Make sure the replacement configuration file is created by using the configuration archive function or the save command on the local device.
·           If the configuration file is not created on the local device, make sure the command lines in the configuration file are fully compatible with the local device.
·           The replacement configuration file is not encrypted.
To perform a configuration rollback:
Step
Remarks
N/A
2.      Roll the running configuration back to the configuration defined by a configuration file.
The specified configuration file must not be encrypted.
The configuration rollback function might fail to reconfigure some commands in the running configuration for one of the following reasons:
·           A command cannot be undone because prefixing the undo keyword to the command does not result in a valid undo command. For example, if the undo form designed for the A [B] C command is undo A C, the configuration rollback function cannot undo the A B C command. This is because the system does not recognize the undo A B C command.
·           A command (for example, a hardware-dependent command) cannot be deleted, overwritten, or undone due to system restrictions.
·           The commands in different views are dependent on each other.
·           Commands or command settings that the device does not support cannot be added to the running configuration.
Configuring configuration commit delay
This feature allows you to perform the following operations:
1.      Use the configuration commit delay command to set the allowed delay time for a manual commit to keep the settings configured after the command was executed.
2.      Use the configuration commit command to commit the settings. If no manual commit is performed within the allowed delay time, the device rolls back the configuration to the settings before the configuration commit delay command was executed.
Once the rollback begins, the device outputs logs to notify the user of the rollback operation. The user cannot perform other operations before the rollback is finished.
As a best practice, set the allowed delay time in the following situations:
·           The user configures the device remotely. The user might be disconnected from the device because of a setting. If the configuration commit delay command is configured and the setting is not committed, the user can reconnect to the device after the delay time expires.
·           The user is not familiar with the device configuration. If any parameters are configured incorrectly, the rollback mechanism can remove the incorrect settings after the delay time expires.
To configure the configuration commit delay feature:
Step
Remarks
N/A
2.      Set the allowed delay time for a manual commit to keep the settings configured subsequently in effect.
configuration commit delay delay-time
Configure this command in a single-user environment.
3.      (Optional.) Commit the settings configured after the configuration commit delay command was executed.
N/A
CAUTION:
Use the undo startup saved-configuration command with caution. This command can cause an IRF split after the IRF fabric or an IRF member reboots.
You can execute the save [ safely ] [ backup | main ] [ force ] command to save the running configuration to a .cfg configuration file. The .cfg configuration file can be specified as both the main and backup next-startup configuration files.
Alternatively, you can execute the startup saved-configuration cfgfile [ backup | main ] command to specify a .cfg configuration file as the main or backup next-startup configuration file. Make sure the specified configuration file is valid and saved to the root directory of each IRF member device's default storage medium.
To specify a next-startup configuration file, perform the following task in user view:
Remarks
Specify the next-startup configuration file.
By default, no next-startup configuration file is specified.
Use the display startup command and the display saved-configuration command in any view to verify the configuration.
If you specify neither the backup keyword nor the main keyword, this command sets the configuration file as the main next-startup configuration file.
Even though the main and backup next-startup configuration files can be the same one, specify them as separate files for high availability.
The undo startup saved-configuration command changes the attribute of the main or backup next-startup configuration file to NULL instead of deleting the file.
Backing up the main next-startup configuration file to a TFTP server
Before performing this task, make sure the following requirements are met:
·           The server is reachable.
·           The server is enabled with TFTP service.
·           You have read and write permissions to the server.
To back up the main next-startup configuration file to a TFTP server:
Step
Remarks
1.      (Optional.) Verify that a next-startup configuration file has been specified in user view.
display startup
If no next-startup configuration file has been specified, the backup operation will fail.
2.      Back up the next-startup configuration file to a TFTP server in user view.
backup startup-configuration to dest-addr [dest-filename ]
This command is not supported in FIPS mode.
Restoring the main next-startup configuration file from a TFTP server
To restore the main next-startup configuration file from a TFTP server, the device performs the following operations:
·           Downloads a configuration file from a TFTP server to the root directory of the default storage medium on each IRF member device.
·           Specifies the file as the main next-startup configuration file.
Before restoring the next-startup configuration file, make sure the following requirements are met:
To restore the main next-startup configuration file from a TFTP server:
Step
Remarks
1.      Restore the main next-startup configuration file from a TFTP server in user view.
restore startup-configuration from src-addr src-filename
2.      (Optional.) Verify that the specified configuration file has been set as the main next-startup configuration file.
display startup
N/A
Deleting a next-startup configuration file
CAUTION:
This task permanently deletes the next-startup configuration file from each IRF member device. Before performing this task, back up the file as needed.
You can perform this task to delete a next-startup configuration file. If both the main and backup next-startup configuration files are deleted, the device uses factory defaults at the next startup.
To delete a file that is set as both main and backup next-startup configuration files, you must execute both the reset saved-configuration backup command and the reset saved-configuration main command. Using only one of the commands removes the specified file attribute instead of deleting the file.
For example, if the reset saved-configuration backup command is executed, the backup next-startup configuration file attribute is set to NULL. However, the file is still used as the main file. To delete the file, you must also execute the reset saved-configuration main command.
Remarks
Delete a next-startup configuration file.
If you do not specify either backup or main, this command deletes the main next-startup configuration file.
Displaying and maintaining configuration files
Display information about configuration rollback.
Display the running configuration.
display current-configuration [ configuration [ module-name ] | interface [ interface-type [ interface-number ] ] ]
Display the factory defaults.
Display the contents of the configuration file for the next system startup.
Display the names of the configuration files for this startup and the next startup.
display startup
Display the valid configuration in the current view.
display this
