04-Layer 3 - IP Services Configuration Examples
HomeSupportSwitchesS7500E-X SeriesConfigure & DeployConfiguration ExamplesH3C S7500E-X Switch Series Configuration Examples-Release7536P05-6W10004-Layer 3 - IP Services Configuration Examples
02-H3C_GRE_with_OSPF_Configuration_Examples
02-H3C_GRE_with_OSPF_Configuration_Examples 81.05 KB
H3C GRE with OSPF Configuration Examples
H3C_彩色.emf
Introduction
This document provides GRE with OSPF configuration examples.
This document assumes that you have basic knowledge of GRE and OSPF.
Example: Configuring GRE with OSPF
As shown in Figure 1, Device A is the gateway of the headquarters. Device B and Device C are the gateways of Branch 1 and Branch 2, respectively. The gateways have obtained public IP addresses from an ISP and can communicate with one another. Configure GRE with OSPF to meet the following requirements:
·     The headquarters and the branches communicate with one another through the GRE tunnels established between the headquarters and the branches.
·     The gateways learn the routes reaching the destination networks through the tunnel interfaces.
Figure 1 Network diagram
Device
IP address
Device
IP address
Device A
Vlan-int 10
191.2.1.1/24
Device B
Vlan-int 10
191.3.1.1/24
Vlan-int 20
10.1.1.1/24
Vlan-int 20
10.7.1.1/24
Tunnel 1
10.5.1.1/24
Tunnel 1
10.5.1.2/24
Tunnel 2
10.6.1.1/24
Device C
Vlan-int 10
191.4.1.1/24
Vlan-int 20
10.8.1.1/24
Tunnel 2
10.6.1.2/24
Software versions used
This configuration example was created and verified on S7500E-X-CMW710-R7536P05.
Encapsulated packets cannot be forwarded on Layer 3 according to the destination IP addresses and routing tables. You must create a service loopback group of the tunnel service type to loop encapsulated packets back to the forwarding module for Layer 3 forwarding.
Procedures
# Configure an IPv4 routing protocol on the gateways so that the gateways can reach one another. (Details not shown.)
Configuring Device A
# Configure an IP address for VLAN-interface 10.
[DeviceA] vlan 10
[DeviceA-vlan10] port gigabitethernet 3/0/1
[DeviceA-vlan10] quit
[DeviceA-Vlan-interface10] ip address 191.2.1.1 255.255.255.0
# Configure other interfaces in the same way VLAN-interface 10 is configured. (Details not shown.)
# Create tunnel interface Tunnel 1, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 1 mode gre
# Configure an IP address for tunnel interface Tunnel 1.
[DeviceA-Tunnel1] ip address 10.5.1.1 24
# Configure the source interface of Tunnel 1 as VLAN-interface 10.
[DeviceA-Tunnel1] source vlan-interface 10
# Configure the destination address of Tunnel 1 as the IP address of VLAN-interface 10 on Device B.
[DeviceA-Tunnel1] destination 191.3.1.1
[DeviceA-Tunnel1] quit
# Create tunnel interface Tunnel 2, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 2 mode gre
# Configure an IP address for tunnel interface Tunnel 2.
[DeviceA-Tunnel2] ip address 10.6.1.1 24
# Configure the source interface of Tunnel 2 as VLAN-interface 10.
[DeviceA-Tunnel2] source vlan-interface 10
# Configure the destination address of Tunnel 2 as the IP address of VLAN-interface 10 on Device C.
[DeviceA-Tunnel2] destination 191.4.1.1
[DeviceA-Tunnel2] quit
# Create service loopback group 1, and specify its service type as Tunnel.
[DeviceA] service-loopback group 1 type tunnel
# Add GigabitEthernet 3/0/3 to service loopback group 1.
[DeviceA] interface gigabitethernet 3/0/3
[DeviceA-GigabitEthernet3/0/3] port service-loopback group 1
[DeviceA-GigabitEthernet3/0/3] quit
# Configure the OSPF router ID as 10.6.1.1.
[DeviceA] router-id 10.6.1.1
# Enable OSPF process 1.
[DeviceA] ospf 1
# Create OSPF area 0.
[DeviceA-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.1.1.0/24, 10.5.1.0/24, or 10.6.1.0/24 in area 0.
[DeviceA-ospf-1-area-0.0.0.0] network 10.1.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
[DeviceA-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
Configuring Device B
[DeviceB] vlan 10
[DeviceB-vlan10] port gigabitethernet 3/0/1
[DeviceB-vlan10] quit
[DeviceB] interface vlan-interface 10
[DeviceB-Vlan-interface10] ip address 191.3.1.1 255.255.255.0
[DeviceB-Vlan-interface10] quit
[DeviceB] interface tunnel 1 mode gre
[DeviceB-Tunnel1] ip address 10.5.1.2 24
[DeviceB-Tunnel1] source vlan-interface 10
# Configure the destination address of Tunnel 1 as the IP address of VLAN-interface 10 on Device A.
[DeviceB-Tunnel1] destination 191.2.1.1
[DeviceB-Tunnel1] quit
[DeviceB] service-loopback group 1 type tunnel
[DeviceB] interface gigabitethernet 3/0/3
[DeviceB-GigabitEthernet3/0/3] port service-loopback group 1
[DeviceB-GigabitEthernet3/0/3] quit
# Configure the OSPF router ID as 10.7.1.1.
[DeviceB] router-id 10.7.1.1
[DeviceB] ospf 1
[DeviceB-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.7.1.0/24 or 10.5.1.0/24 in area 0.
[DeviceB-ospf-1-area-0.0.0.0] network 10.7.1.0 0.0.0.255
[DeviceB-ospf-1-area-0.0.0.0] network 10.5.1.0 0.0.0.255
Configuring Device C
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan10] port gigabitethernet 3/0/1
[DeviceC-vlan10] quit
[DeviceC] interface vlan-interface 10
[DeviceC-Vlan-interface10] ip address 191.4.1.1 255.255.255.0
[DeviceC-Vlan-interface10] quit
[DeviceC] interface tunnel 2 mode gre
[DeviceC-Tunnel2] ip address 10.6.1.2 24
[DeviceC-Tunnel2] source vlan-interface 10
# Configure the destination address of Tunnel 2 as the IP address of VLAN-interface 10 on Device A.
[DeviceC-Tunnel2] destination 191.2.1.1
[DeviceC-Tunnel2] quit
[DeviceC] service-loopback group 1 type tunnel
[DeviceC] interface gigabitethernet 3/0/3
[DeviceC-GigabitEthernet3/0/3] port service-loopback group 1
[DeviceC-GigabitEthernet3/0/3] quit
# Configure the OSPF router ID as 10.8.1.1.
[DeviceC] router-id 10.8.1.1
[DeviceC] ospf 1
[DeviceC-ospf-1] area 0
# Enable OSPF on interfaces whose primary IP addresses are on network 10.8.1.0/24 or 10.6.1.0/24 in area 0.
[DeviceC-ospf-1-area-0.0.0.0] network 10.8.1.0 0.0.0.255
[DeviceC-ospf-1-area-0.0.0.0] network 10.6.1.0 0.0.0.255
# Verify that Host A can ping Host B successfully.
C:\> ping 10.7.1.2
Pinging 10.7.1.2 with 32 bytes of data:
Reply from 10.7.1.2: bytes=32 time=19ms TTL=253
Reply from 10.7.1.2: bytes=32 time<1ms TTL=253
Ping statistics for 10.7.1.2:
    Minimum = 0ms, Maximum = 19ms, Average = 4ms
# Verify that Host A can ping Host C successfully.
C:\> ping 10.8.1.2
Pinging 10.8.1.2 with 32 bytes of data:
Reply from 10.8.1.2: bytes=32 time=18ms TTL=253
Reply from 10.8.1.2: bytes=32 time<1ms TTL=253
Ping statistics for 10.8.1.2:
# Verify that Host B can ping Host C successfully.
C:\> ping 10.8.1.2
Reply from 10.8.1.2: bytes=32 time=20ms TTL=251
Reply from 10.8.1.2: bytes=32 time<1ms TTL=251
Configuration files
·     Device A:
vlan 10
vlan 20
interface GigabitEthernet3/0/1
 port link-mode bridge
 port access vlan 10
interface GigabitEthernet3/0/2
 port access vlan 20
interface GigabitEthernet3/0/3
interface Vlan-interface10
interface Vlan-interface 20
interface Tunnel1 mode gre
 source Vlan-interface10
 ip address 10.5.1.1 255.255.255.0
interface Tunnel2 mode gre
 ip address 10.6.1.1 255.255.255.0
ospf 1
 area 0.0.0.0
·     Device B:
vlan 10
vlan 20
 port access vlan 10
 port access vlan 20
interface Vlan-interface 10
 ip address 10.7.1.1 255.255.255.0
 ip address 10.5.1.2 255.255.255.0
ospf 1
 area 0.0.0.0
·     Device C:
vlan 10
vlan 20
 port access vlan 10
 port access vlan 20
 ip address 10.8.1.1 255.255.255.0
 ip address 10.6.1.2 255.255.255.0
ospf 1
 area 0.0.0.0
Related documentation
·     H3C S7500E-X Switch Series Layer 3—IP Routing Command Reference-R7536P05
·     H3C S7500E-X Switch Series Layer 3—IP Routing Configuration Guide-R7536P05
·     H3C S7500E-X Switch Series Layer 3—IP Services Command Reference-R7536P05
·     H3C S7500E-X Switch Series Layer 3—IP Services Configuration Guide-R7536P05
