| 01-EVB commands | 138.37 KB |
EVB commands
EVB requires a license to run on the device. For information about obtaining a license, see Fundamentals Configuration Guide.
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
The expected bandwidth of an interface is the default maximum bandwidth of the physical port to which the interface belongs.
S-channel interface view
S-channel aggregate interface view
VSI interface view
VSI aggregate interface view
# Set the expected bandwidth to 2000000 kbps for S-Channel 1/0/1:10.
[Sysname] interface s-channel 1/0/1:10
[Sysname–S-Channel1/0/1:10] bandwidth 2000000
# Set the expected bandwidth to 2000000 kbps for Schannel-Aggregation1:10.
[Sysname] interface schannel-aggregation 1:10
[Sysname–Schannel-Aggregation1:10] bandwidth 2000000
# Set the expected bandwidth to 2000000 kbps for S-Channel 1/0/1:10.1.
[Sysname] interface s-channel 1/0/1:10.1
[Sysname–S-Channel1/0/1:10.1] bandwidth 2000000
# Set the expected bandwidth to 2000000 kbps for Schannel-Aggregation1:10.1.
[Sysname] interface schannel-aggregation 1:10.1
[Sysname–Schannel-Aggregation1:10.1] bandwidth 2000000
default
Use default to restore the default settings for an interface.
default
VSI interface view
CAUTION: The default command might interrupt ongoing network services. Make sure you are fully aware of the impacts of this command when you execute it on a live network. |
This command might fail to restore the default settings for some commands for reasons such as command dependencies and system restrictions. Use the display this command in interface view to identify these commands. Then use their undo forms or follow the command reference to individually restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for S-Channel 1/0/1:10.
[Sysname–S-Channel1/0/1:10] default
# Restore the default settings for Schannel-Aggregation1:10.
[Sysname–Schannel-Aggregation1:10] default
# Restore the default settings for S-Channel 1/0/1:10.1.
[Sysname–S-Channel1/0/1:10.1] default
# Restore the default settings for Schannel-Aggregation1:10.1.
[Sysname–Schannel-Aggregation1:10.1] default
description
The default description for an interface is "interface name Interface." The following table shows examples of interfaces and their default descriptions:
S-channel interface S-Channel 1/0/1:10 |
S-Channel 1/0/1:10 Interface |
S-channel aggregate interface Schannel-Aggregation 1:10 |
Schannel-Aggregation 1:10 Interface |
VSI interface S-Channel 1/0/1:10.1 |
S-Channel 1/0/1:10.1 Interface |
VSI aggregate interface Schannel-Aggregation 1:10.1 |
Schannel-Aggregation 1:10.1 Interface |
VSI interface view
text: Specifies a description for the interface, a case-sensitive string of 1 to 255 characters.
# Set the description to S-Channel to lab for S-Channel 1/0/1:10.
[Sysname–S-Channel1/0/1:10] description S-Channel to lab
# Set the description to Schannel-Aggregation to lab for Schannel-Aggregation 1:10.
[Sysname–Schannel-Aggregation1:10] description Schannel-Aggregation to lab
# Set the description to VSI to lab for S-Channel 1/0/1:10.1.
[Sysname–S-Channel1/0/1:10.1] description VSI to lab
# Set the description to VSI-Aggregation to lab for Schannel-Aggregation 1:10.1.
[Sysname–Schannel-Aggregation1:10.1] description VSI-Aggregation to lab
display evb cdcp
Use display evb cdcp to display CDCP negotiation information.
display evb cdcp [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface (Layer 2 Ethernet interface or Layer 2 aggregate interface) by its type and number. If you do not specify an interface, this command displays CDCP negotiation information for all interfaces with EVB enabled.
# Display CDCP negotiation information for all interfaces with EVB enabled.
<Sysname> display evb cdcp
---------------------------Bridge-Aggregation1---------------------
S-component capability : Local-supported/Remote-not supported
Supported S-Channel numbers per-port : Local-167/Remote-0
SVID range : 2-4094
SCID requested from remote :
SCID/SVID pair list allocated :
<1, 1>
---------------------------Ten-GigabitEthernet1/0/1---------------------
S-component capability : Local-supported/Remote-supported
Supported S-Channel numbers per-port : Local-167/Remote-167
SVID range : 2-4094
1, 2, 3, 4, 6, 10, 11, 12, 34, 35, 67
<1, 1>, <2, 3>, <3, 2>, <4, 5>, <6, 4>,
<10, 9>, <11, 6>, <12, 7>, <34, 23>, <35, 35>,
<67, 67>
S-component capability |
Port-mapping S-VLAN component capability on the EVB bridge and the EVB station: supported or not supported. |
Supported S-channel numbers per-port |
Number of S-channels supported by the EVB bridge and the EVB station. |
SVID range |
SVID range on the EVB bridge. |
SCID requested from remote |
SCIDs requested by the EVB station in ascending order. |
SCID/SVID pair list allocated |
List of (SCID, SVID) pairs allocated by the EVB bridge. |
display evb evb-tlv
Use display evb evb-tlv to display S-channel EVB TLV negotiation information.
display evb evb-tlv [ interface interface-type { interface-number | interface-number:channel-id } ]
interface: Specifies an interface. If you do not specify an interface, this command displays EVB TLV negotiation information for all interfaces with EVB enabled.
interface-type { interface-number | interface-number:channel-id }: Specifies a Layer 2 Ethernet interface, Layer 2 aggregate interface, S-channel interface, or an S-channel aggregate interface by its type and number. The interface-number argument specifies a Layer 2 Ethernet interface or Layer 2 aggregate interface. The interface-number:channel-id argument specifies an S-channel interface or S-channel aggregate interface.
# Display EVB TLV negotiation information for Ten-GigabitEthernet 1/0/1.
<Sysname> display evb evb-tlv interface ten-gigabitethernet 1/0/1
S-Channel1/0/1:1
EVB mode : Local-bridge/Remote-station
BGID status : Supported
Local RR capability : Supported
Local RR status : Disabled
Remote SGID status : Not supported
Remote RR request status : Not requested
Remote RR status : Unknown
Max ECP retry time : Local-3/Remote-NA/Operative-3
ULPDU retransmission exponent : Local-16/Remote-NA/Operative-16
Resource wait-delay exponent : Local-20/Remote-NA/Operative-20
Reinit Keep-alive exponent : Local-25/Remote-NA/Operative-25
S-Channel1/0/1:100
Reinit keep-alive exponent : Local-25/Remote-NA/Operative-25
EVB mode |
EVB mode: · bridge—EVB bridge. · station—EVB station. |
BGID status |
Support for Group ID on the EVB bridge: Supported or Not supported. |
Local RR capability |
Support for the RR mode on the EVB bridge: Supported or Not supported. |
Local RR status |
RR status on the EVB bridge after EVB TLV negotiation. |
Remote SGID status |
Support for Group ID on the EVB station: Supported or Not supported. |
Remote RR request status |
Whether or not the EVB station has requested the RR mode: Requested or Not requested. |
Remote RR status |
Whether or not the EVB station has enabled the RR mode after EVB TLV negotiation: Enabled, Disabled, or Unknown. |
Max ECP retry time |
Maximum ECP retransmission times in this format: Local negotiation value/Remote negotiation value/Operative value. NA means no value is set on the remote EVB station. |
ULPDU retransmission exponent |
ECP retransmission exponent in this format: Local negotiation value/Remote negotiation value/Operative value. NA means no value is set on the remote EVB station. |
Resource wait-delay exponent |
VDP resource-wait-delay exponent in this format: Local negotiation value/Remote negotiation value/Operative value. NA means no value is set on the remote EVB station. |
Reinit keep-alive exponent |
VDP keepalive exponent in this format: Local negotiation value/Remote negotiation value/Operative value. NA means no value is set on the remote EVB station. |
display evb s-channel
Use display evb s-channel to display S-channel information.
display evb s-channel [ interface interface-type interface-number ]
interface interface-type interface-number: Specifies an interface (Layer 2 Ethernet interface or Layer 2 aggregate interface) by its type and number. If you do not specify an interface, this command displays S-channel information for all interfaces with EVB enabled.
# Display S-channel information for Ten-GigabitEthernet 1/0/1.
<Sysname> display evb s-channel interface ten-gigabitethernet 1/0/1
RR status: D -- Disabled, E -- Enabled
MAC learning: A -- Allowed, F -- Forbidden
S-Channel SVID Uptime RR MAC VSI
interface yyyy/mm/dd hh:mm:ss status learning number
S-Ch1/0/1:1 1 2012/12/17 03:43:13 D A 0
S-Ch1/0/1:100 100 2012/12/17 03:43:14 D A 2
S-Channel interface |
S-channel interface name. |
Uptime |
Time when the S-channel was created. |
VSI number |
Number of VSI interfaces created on the S-channel. |
display evb summary
Use display evb summary to display brief EVB information.
display evb summary
# Display brief EVB information.
Default manager ID: 192.168.1.1
Port number: 80
Interface S-Channel number VSI number
XGE1/0/1 2 2
Default manager ID |
Address or name of the default VSI manager. |
Port number |
Port number of the default VSI manager. |
Name of the interface with EVB enabled. |
S-channel number |
Number of S-channels. |
VSI number |
Number of VSI interfaces. |
display evb vsi
Use display evb vsi to display VSI interface information.
display evb vsi [ verbose ] [ interface interface-type { interface-number | interface-number:channel-id | interface-number:channel-id.vsi-local-id } ]
verbose: Displays detailed VSI interface information. If you do not specify this keyword, the command displays brief VSI interface information.
interface: Specifies an interface. If you do not specify an interface, this command displays VSI interface information for all interfaces with EVB enabled.
vsi-local-id }: Specifies a Layer 2 Ethernet
interface , Layer 2 aggregate interface, S-channel interface, S-channel
aggregate interface, VSI interface, or a VSI aggregate interface by its type
and number.
· The interface-number argument specifies a Layer 2 Ethernet interface or Layer 2 aggregate interface.
· The interface-number:channel-id argument specifies an S-channel interface or S-channel aggregate interface.
· The interface-number:channel-id.vsi-local-id argument specifies a VSI interface or VSI aggregate interface.
# Display brief VSI interface information for Ten-GigabitEthernet 1/0/1.
<Sysname> display evb vsi interface ten-gigabitethernet 1/0/1
Status: A -- Association, P -- Pre-association
VSI VTID Type Instance Status
interface version ID
S-Ch1/0/1:100.0 NA NA NA P
S-Ch1/0/1:100.1 NA NA NA A
# Display detailed VSI interface information for Ten-GigabitEthernet 1/0/1.
<Sysname> display evb vsi verbose interface ten-gigabitethernet 1/0/1
S-Channel1/0/1:100
S-Channel1/0/1:100.0
VSI local-ID: 0 VSI type ID: NA VSI type version: NA
VSI instance ID: NA
VSI manager ID: NA
Current VDP status: Pre-association
Filter type: VID
Filter info:
<100>
S-Channel1/0/1:100.1
VSI local-ID: 1 VSI type ID: 100 VSI type version: 0
VSI instance ID: 11:2233:4455:6677:8899:1234:5678:9010
VSI manager ID: NA
Current VDP status: Association
Filter type: MAC/VID
Filter info:
<0011-2233-4455, 1000>
VSI interface |
Name of the VSI interface. |
VTID/VSI type ID |
VSI type ID. NA indicates no ID is specified. |
Type version/VSI type version |
VSI type version number. NA indicates no version is specified. |
Instance ID/VSI instance ID |
VSI instance ID. NA indicates no instance ID is specified. |
Status |
Current status of the VSI interface: · A—Association property. · P—Pre-association property. |
VSI manager ID |
Address of the VSI manager. NA indicates no VSI manager is specified. |
Current VDP status |
Current status of the VSI interface: · Association—Association property. · Pre-association—Pre-association property. |
Filter type |
VSI filter type: · GroupID/VID—Group ID values and VID values. · GroupID/MAC/VID—Group ID values, MAC addresses, and VID values. · VID—VLAN ID. · MAC/VID—MAC addresses and VID values. |
Filter info |
VSI filters. |
display interface
Use display interface to display information about an S-channel interface, an S-channel aggregate interface, a VSI interface, or a VSI aggregate interface.
display interface [ { s-channel | schannel-aggregation } [ interface-number:channel-id | interface-number:channel-id.vsi-local-id ] ] [ brief [ description | down ] ]
s-channel: Specifies an S-channel interface or a VSI interface.
schannel-aggregation: Specifies an S-channel aggregate interface or a VSI aggregate interface.
interface-number:channel-id: Specifies an S-channel interface or S-channel aggregate interface. The interface-number argument specifies the interface where the S-channel resides. The channel-id argument specifies the ID of the S-channel.
interface-number:channel-id.vsi-local-id: Specifies a VSI interface or VSI aggregate interface. The interface-number argument specifies the interface where the S-channel resides. The channel-id argument specifies the ID of the S-channel. The vsi-local-id argument specifies the local ID of the VSI.
brief: Displays brief information. If you do not specify this keyword, the command displays detailed information.
description: Displays complete interface descriptions. If you do not specify this keyword, the command displays only the first 27 characters of interface descriptions.
down: Displays information about interfaces in DOWN state and the causes. If you do not specify this keyword, the command displays information about interfaces in all states.
If you do not specify an interface type, this command displays information about all interfaces.
If you specify an interface type but do not specify an interface number, this command displays information about all created S-channel interfaces and VSI interfaces.
# Display detailed information about S-Channel 1/0/1:10.
<Sysname> display interface s-channel 1/0/1:10
S-Channel1/0/1:10
Current state: DOWN
IP packet frame type: Ethernet II, hardware address: 0cda-415e-2386
Description: S-Channel1/0/1:10 Interface
Bandwidth: 10000000 kbps
PVID: 1
Port link-type: Trunk
VLAN Passing: 1(default vlan)
VLAN permitted: 1(default vlan)
Trunk port encapsulation: IEEE 802.1q
Input (total): 0 packets, 0 bytes
# Display brief information about S-Channel 1/0/1:10.
<Sysname> display interface s-channel 1/0/1:10 brief
Speed: (a) - auto
Interface Link Speed Duplex Type PVID Description
S-Ch1/0/1:10 DOWN 10G(a) F(a) T 1
# Display detailed information about S-Channel 1/0/1:10.1.
<Sysname> display interface s-channel 1/0/1:10.1
S-Channel1/0/1:10.1
Current state: DOWN
Description: S-Channel1/0/1:10.1 Interface
Table 6 Command output
Current state |
Physical link state of the interface: · Administratively DOWN—The interface has been shut down by using the shutdown command. · DOWN—The interface is administratively up, but its physical state is down (possibly because no physical link exists or the link has failed). · UP—The interface is both administratively and physically up. |
IP packet frame type |
IPv4 packet framing format. |
hardware address |
MAC address of the interface. |
Unknown-speed mode |
The speed of the interface is unknown because the speed negotiation fails or the interface is physically disconnected. |
unknown-duplex mode |
The duplex mode of the interface is unknown because the duplex mode negotiation fails or the interface is physically disconnected. |
Link speed type is autonegotiation, link duplex type is autonegotiation |
The interface is configured with the speed auto and duplex auto commands. |
PVID |
Port VLAN ID (PVID) of the interface. |
VLAN Passing |
VLANs whose packets can be forwarded by the port. The VLANs must have been created. |
VLAN permitted |
VLANs whose packets are permitted by the port. |
Trunk port encapsulation |
Encapsulation protocol type for the trunk port. |
Last clearing of counters |
Time when the reset counters interface command was last used to clear the interface statistics. This field displays Never if the reset counters interface command has never been used on the interface since device startup. |
Input (total): 0 packets, 0 bytes |
Inbound traffic statistics (in packets and bytes) for the interface. |
Output (total): 0 packets, 0 bytes |
Outbound traffic statistics (in packets and bytes) for the interface. |
# Display brief information about S-Channel 1/0/1:10.1.
<Sysname> display interface s-channel 1/0/1:10.1 brief
Speed: (a) - auto
S-Ch1/0/1:10.1 UP -- -- -- --
# Display brief information about all S-channel interfaces and VSI interfaces in DOWN state.
<Sysname> display interface s-channel brief down
Interface Link Cause
S-Ch1/0/1:11 DOWN Not connected
S-Ch1/0/1:11.1 DOWN Not connected
Table 7 Command output
Brief information on interfaces in bridge mode |
Brief information about Layer 2 interfaces. |
Abbreviated interface name. |
Link |
Physical link state of the interface: · UP—The interface is physically up. · DOWN—The interface is physically down. · ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command. |
Speed |
Speed of the interface, in bps. This field displays the (a) flag next to the speed if the speed is automatically negotiated. This field displays auto if the interface is configured to autonegotiate its speed but the autonegotiation has not started. |
Duplex |
Duplex mode of the interface: · A—Autonegotiation. The interface is configured to autonegotiate its duplex mode but the autonegotiation has not started. · F—Full duplex. · F(a)—Autonegotiated full duplex. · H—Half duplex. · H(a)—Autonegotiated half duplex. |
Type |
Link type of the interface: · A—Access. · H—Hybrid. · T—Trunk. |
PVID |
Port VLAN ID. |
Cause |
Cause for the physical link state of an interface to be DOWN: · Administratively—The interface has been manually shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command. · Not connected—No physical connection exists (possibly because the network cable is disconnected or faulty). |
evb default-manager
Use evb default-manager to specify the default VSI manager.
Use undo evb default-manager to restore the default.
evb default-manager { { ip ipv4-address | ipv6 ipv6-address | name name } [ port port-number ] | local-server }
The default VSI manager is not specified.
ip ipv4-address: Specifies the IPv4 address of the default VSI manager.
ipv6 ipv6-address: Specifies the IPv6 address of the default VSI manager.
name name: Specifies the name of the default VSI manager, a case-insensitive string of 1 to 127 characters.
port port-number: Specifies the port number of the default VSI manager, in the range of 0 to 65535. The default port number is 8080.
local-server: Specifies the device as the default VSI manager.
When the bridge receives a VDP packet (except for a De-Associate packet) from a station, it contacts the VSI manager specified in the VDP packet to get VSI interface resources and policies for the station.
The VSI manager ID TLV in a VDP packet carries the VSI manager's IP address. If the value for the TLV is 0, the bridge communicates with the default VSI manager specified by this command.
# Set the IPv4 address to 192.168.100.20 for the default VSI manager.
[Sysname] evb default-manager ip 192.168.100.20
evb enable
Use evb enable to enable EVB on an interface.
Use undo evb enable to disable EVB on an interface.
evb enable
undo evb enable
EVB is disabled on an interface.
Do not enable EVB on a member port of an aggregation group, or add a member port with EVB enabled into an aggregation group.
Do not enable both EVB and QinQ on the same interface.
Do not create a service instance for an interface enabled with EVB, and vice versa.
Restore all default settings for an interface by using the default command before enabling EVB on the interface.
A default S-channel is created on an interface after EVB is enabled on the interface, with both SCID and SVID as 1. After an S-channel is created, an S-channel interface or S-channel aggregate interface is created and operates in access mode.
Do not configure VLAN settings or enable any other Layer 2 protocols except LLDP on an interface with EVB enabled.
Delete all non-default S-channels on an interface before disabling EVB on the interface. The default S-channel is deleted after EVB is disabled.
# Enable EVB on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] evb enable
# Enable EVB on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] evb enable
evb s-channel
qinq enable (Layer 2—LAN Switching Command Reference)
service-instance (MPLS Command Reference)
evb mac-learning forbidden
Use evb mac-learning forbidden to disable MAC address learning for an S-channel.
Use undo evb mac-learning forbidden to enable MAC address learning for an S-channel.
MAC address learning for an S-channel is enabled.
For the EVB bridge to successfully forward traffic from VMs on the EVB station, do not disable MAC address learning for an S-channel with the RR mode disabled.
After you disable MAC address learning for an S-channel, packets with an unknown source MAC address are discarded.
The undo evb mac-learning forbidden command and the mac-address mac-learning enable command must be configured together to avoid communication interruption.
# Disable MAC address learning on S-Channel 1/0/1:10.
[Sysname-S-Channel1/0/1:10] evb mac-learning forbidden
# Disable MAC address learning on Schannel-Aggregation 1:10.
[Sysname–Schannel-Aggregation1:10] evb mac-learning forbidden
evb reflective-relay
mac-address mac-learning enable (Layer 2—LAN Switching Command Reference)
Use evb reflective-relay to enable the RR mode for an S-channel.
Use undo evb reflective-relay to disable the RR mode for an S-channel.
The RR mode for an S-channel is disabled.
EVB TLVs exchanged through LLDP allow an EVB station and EVB bridge to negotiate the use of reflective relay (RR). If the EVB bridge supports the RR mode, when the EVB station requests the use of the RR mode, the bridge performs the following operations:
· Automatically enables the RR mode for the S-channel.
· Adds the corresponding command line to the configuration file.
# Enable the RR mode on S-Channel 1/0/1:10.
[Sysname-S-Channel1/0/1:10] evb reflective-relay
# Enable the RR mode on Schannel-Aggregation 1:10.
[Sysname–Schannel-Aggregation1:10] evb reflective-relay
evb s-channel
Use evb s-channel to create an S-channel on an interface.
Use undo evb s-channel to remove an S-channel on an interface.
evb s-channel channel-id [ service-vlan svlan-id ]
undo evb s-channel channel-id
Only an automatically created default S-channel (with both SCID and SVID as 1) exists on an interface with EVB enabled.
channel-id: Specifies an S-channel ID (SCID) in the range of 2 to 167. 0 is the reserved SCID, and 1 is the default SCID.
svlan-id: Specifies an S-VLAN ID (SVID) in the range of 2 to 4094. 1 is the SVID for the default S-channel. If you do not specify this argument, the system automatically assigns the minimum SVID that is not used by other S-channels.
An S-channel is automatically created through CDCP, and the command line corresponding to the action is added to the configuration file on the bridge. You can also manually create an S-channel by using this command. If you create an S-channel that has the same number as an automatically created S-channel, the (SCID, SVID) pair configuration for the automatically created S-channel takes precedence over the (SCID, SVID) pair configuration for the manually created S-channel.
Creating an S-channel also creates an S-channel interface or S-channel aggregate interface. Removing an S-channel also removes the S-channel interface or S-channel aggregate interface. The S-channel interface or S-channel aggregate interface associated with a manually created S-channel operates in access mode. The S-channel interface or S-channel aggregate interface associated with an automatically created S-channel operates in trunk mode.
An S-channel interface is associated with the S-channel that is created on a Layer 2 Ethernet interface. An S-channel aggregate interface is associated with the S-channel that is created on a Layer 2 aggregate interface.
When you create an S-channel, follow these restrictions and guidelines:
· Create an S-channel on an interface with EVB enabled.
· When you manually create an S-channel, do not use the SCID or SVID being used by any other S-channels.
· To manually create or remove an S-channel, disable CDCP that automatically performs these operations.
# Create an S-channel on Ten-GigabitEthernet 1/0/1, with the SCID 10 and SVID 5.
[Sysname-Ten-GigabitEthernet1/0/1] evb s-channel 10 service-vlan 5
# Create an S-channel on Bridge-Aggregation 1, with the SCID 10 and SVID 5.
[Sysname-Bridge-Aggregation1] evb s-channel 10 service-vlan 5
evb enable
interface
evb vdp timer keepalive exponent
Use evb vdp timer keepalive exponent to set a VDP keepalive exponent.
Use undo evb vdp timer keepalive exponent to restore the default.
evb vdp timer keepalive exponent value
The VDP keepalive exponent is 20.
value: Specifies a VDP keepalive exponent in the range of 14 to 31.
The value for VDP keepalive time is expressed by the following equation:
VDP keepalive time (seconds) = 1.5 × [ 2VDP keepalive + (2 × ECP maximum retransmission time + 1) × 2ECP retransmission ] × 10—5
For detailed values, see Table 8.
Table 8 uses 3 and 14 (the defaults) as the ECP maximum retransmission time and the ECP retransmission exponent to calculate the VDP keepalive time. These two variables use the larger values proposed by the station and bridge through EVB TLV.
The network environment and configurations on the EVB bridge and station determine whether to use the defaults or the actual proposed values for the following ECP values:
· ECP maximum retransmission time.
· ECP retransmission exponent.
Table 8 Values for VDP keepalive time
VDP keepalive exponent |
Calculated value (seconds) |
Result value (seconds) |
14 |
1.96608 |
2 |
15 |
2.21184 |
3 |
16 |
2.70336 |
3 |
17 |
3.68640 |
4 |
18 |
5.65248 |
6 |
19 |
9.58464 |
10 |
20 |
17.44896 |
18 |
21 |
33.17760 |
34 |
22 |
64.63488 |
65 |
23 |
127.54944 |
128 |
24 |
253.37856 |
254 |
25 |
505.03680 |
506 |
26 |
1008.35328 |
1009 |
27 |
2014.98624 |
2015 |
28 |
4028.25216 |
4029 |
29 |
8054.78400 |
8055 |
30 |
16107.84768 |
16108 |
31 |
32213.97504 |
32214 |
# Set the VDP keepalive exponent to 23 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] evb vdp timer keepalive exponent 23
# Set the VDP keepalive exponent to 23 on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] evb vdp timer keepalive exponent 23
evb vdp timer resource-wait-delay exponent
Use evb vdp timer resource-wait-delay exponent to set a VDP resource-wait-delay exponent.
Use undo evb vdp timer resource-wait-delay exponent to restore the default.
evb vdp timer resource-wait-delay exponent value
The VDP resource-wait-delay exponent is 20.
value: Specifies a VDP resource-wait-delay exponent in the range of 15 to 31.
The value for VDP response-wait-delay time is expressed by the following equation:
VDP response-wait-delay time (seconds) = 2VDP resource-wait-delay × 10—5
For detailed values, see Table 9.
Table 9 Values for VDP response-wait-delay time
VDP resource-wait-delay exponent |
15 |
0.32768 |
1 |
16 |
0.65536 |
1 |
17 |
1.31072 |
2 |
18 |
2.62144 |
3 |
19 |
5.24288 |
6 |
20 |
10.48576 |
11 |
21 |
20.97152 |
21 |
22 |
41.94304 |
42 |
23 |
83.88608 |
84 |
24 |
167.77216 |
168 |
25 |
335.54432 |
336 |
26 |
671.08864 |
672 |
27 |
1342.17728 |
1343 |
28 |
2684.35456 |
2685 |
29 |
5368.70912 |
5369 |
30 |
10737.41824 |
10738 |
31 |
21474.83648 |
21475 |
# Set the VDP resource-wait-delay exponent to 23 on Ten-GigabitEthernet 1/0/1.
[Sysname-Ten-GigabitEthernet1/0/1] evb vdp timer resource-wait-delay exponent 23
# Set the VDP resource-wait-delay exponent to 23 on Bridge-Aggregation 1.
[Sysname-Bridge-Aggregation1] evb vdp timer resource-wait-delay exponent 23
evb vsi
Use evb vsi to create a VSI interface or VSI aggregate interface.
Use undo evb vsi to remove a VSI interface or VSI aggregate interface.
evb vsi vsi-local-id { association | pre-association }
undo evb vsi vsi-local-id
No VSI interface or VSI aggregate interfaces exist on an S-channel.
vsi-local-id: Specifies a VSI local ID in the range of 0 to 1023.
association: Specifies the association property. On a VSI interface with the association property, all filters immediately take effect.
pre-association: Specifies the pre-association property. On a VSI interface with the pre-association property, VLAN filters take effect immediately, but <VLAN, MAC> filters are not effective until the interface uses the association property.
A VSI interface is a subinterface of an S-channel interface, and a VSI aggregate interface is a subinterface of an S-channel aggregate interface.
A VSI interface or VSI aggregate interface is usually created or deleted by a VSI manager. You can also manually create or delete a VSI interface, or modify its pre-association or association property by executing this command.
Removing an S-channel also removes all its VSI interfaces and VSI aggregate interfaces.
If MAC address information is contained in the traffic sent by a VM when you change association to pre-association for a VSI interface or VSI aggregate interface, the following events occur:
· The MAC address is removed from the drive on the EVB bridge.
· The traffic from the VM cannot be forwarded.
When you change pre-association to association for a VSI interface, the EVB bridge sets the VM's MAC address.
After creating a VSI interface or VSI aggregate interface, you can enter VSI interface view or VSI aggregate interface view by using the interface command.
# Create a VSI interface on S-Channel 1/0/1:10, with VSI local ID 1 and the association property.
[Sysname-S-Channel1/0/1:10] evb vsi 1 association
# Create a VSI aggregate interface on Schannel-Aggregation 1:10, with VSI local ID 1 and the association property.
[Sysname–Schannel-Aggregation1:10] evb vsi 1 association
evb s-channel
evb vsi filter
interface
evb vsi active
Use evb vsi active to activate a VSI interface or VSI aggregate interface.
Use undo evb vsi active to deactivate a VSI interface or VSI aggregate interface.
evb vsi active
undo evb vsi active
A VSI interface or VSI aggregate interface is not activated.
VSI interface view
Traffic policing configuration on a VSI interface or VSI aggregate interface takes effect only when the VSI interface or VSI aggregate interface is activated. When a VSI interface or VSI aggregate interface is not activated, do not configure any settings other than filters on either interface. For more information about traffic policing, see ACL and QoS Configuration Guide.
Activate a VSI interface or VSI aggregate interface after configuring a VSI filter, and deactivate a VSI interface or VSI aggregate interface before removing a VSI filter.
# Activate S-Channel 1/0/1:10.1.
[Sysname–S-Channel1/0/1:10.1] evb vsi active
# Activate Schannel-Aggregation 1:10.1.
[Sysname–Schannel-Aggregation1:10.1] evb vsi active
evb vsi filter
evb vsi filter
Use evb vsi filter to create a VSI filter.
Use undo evb vsi filter to remove a VSI filter.
evb vsi filter [ group group-id ] vlan vlan-id [ mac mac-address ]
undo evb vsi filter [ group group-id ] [ vlan vlan-id [ mac mac-address ] ]
No VSI filters exist.
VSI interface view
group group-id: Specifies a group ID that classifies VLAN IDs, in the range of 1 to 4094. When the number of VLANs exceeds 4094, a group ID and a VLAN ID together identify a VLAN.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094. The VLAN must exist.
mac mac-address: Specifies a MAC address, which must be a valid unicast MAC address.
The EVB bridge uses VSI filters to identify VSI traffic. Typically a VSI manager assigns filters. You can use this command to manually create or remove a VSI filter.
A VSI filter contains a set of VID values, MAC addresses, and group ID values. EVB supports the following filter info formats:
· VLAN ID.
· VLAN ID + MAC.
· Group ID + VLAN ID.
· Group ID + VLAN ID + MAC.
Before configuring a VSI filter, make sure the S-channel interface or the S-channel aggregate interface to which the VSI interface or VSI aggregate interface belongs operates in trunk mode.
When you configure a VSI filter on a VSI interface, follow these restrictions and guidelines:
· When you create a VSI filter, the following interfaces automatically permit the VLAN contained in the VSI filter:
? The S-channel interface to which the VSI interface belongs.
? The Layer 2 Ethernet interface where the S-channel that is associated with the S-channel interface is created.
· When you delete a VSI filter, the following interfaces automatically deny the VLAN in the filter if the VSI filters on the other VSI interfaces created on the same S-channel interface do not contain the VLAN:
· Do not create a VSI filter that contains the same VLAN on the same VSI interface or on other VSI interfaces that belong to the same S-channel interface. If you do so, the system displays an error message.
· Disabling MAC address learning for an S-channel prevents the traffic from the VSI from being forwarded if the VSI filter contains the VLAN to which the traffic belongs.
When you configure a VSI filter on a VSI aggregate interface, follow these restrictions and guidelines:
? The S-channel aggregate interface to which the VSI aggregate interface belongs.
? The Layer 2 aggregate interface where the S-channel that is associated with the S-channel aggregate interface is created.
· When you delete a VSI filter, the following interfaces automatically deny the VLAN in the filter if the VSI filters on the other VSI aggregate interfaces created on the same S-channel aggregate interface do not contain the VLAN:
· Do not create a VSI filter that contains the same VLAN on the same VSI aggregate interface or on other VSI aggregate interfaces that belong to the same S-channel aggregate interface. If you do so, the system displays an error message.
# Create a VSI filter for VLAN 1 on S-Channel 1/0/1:10.1.
[Sysname–S-Channel1/0/1:10.1] evb vsi filter vlan 1
# Create a VSI filter for VLAN 1 on Schannel-Aggregation 1:10.1.
[Sysname–Schannel-Aggregation1:10.1] evb vsi filter vlan 1
evb vsi active
interface
Use interface to enter S-channel interface view, S-channel aggregate interface view, VSI interface view, or VSI aggregate interface view.
interface { s-channel | schannel-aggregation } { interface-number:channel-id | interface-number:channel-id.vsi-local-id }
# Enter the view of S-Channel 1/0/1:10.
# Enter the view of Schannel-Aggregation 1:10.
# Enter the view of S-Channel 1/0/1:10.1.
# Enter the view of Schannel-Aggregation 1:10.1.
Use reset counters interface to clear statistics for an S-channel interface, an S-channel aggregate interface, a VSI interface, or a VSI aggregate interface.
reset counters interface [ { s-channel | schannel-aggregation } [ interface-number:channel-id | interface-number:channel-id.vsi-local-id ] ]
Use this command to clear history statistics before you collect traffic statistics for the following interfaces:
· S-channel interfaces.
· S-channel aggregate interfaces.
· VSI interfaces.
· VSI aggregate interfaces.
If you do not specify an interface type, this command clears statistics for all interfaces.
If you specify an interface type but do not specify an interface number, this command clears statistics for all created S-channel interfaces, S-channel aggregate interfaces, VSI interfaces, and VSI aggregate interfaces.
# Clear statistics for S-Channel 1/0/1:10.
<Sysname> reset counters interface s-channel 1/0/1:10
# Clear statistics for Schannel-Aggregation 1:10.
<Sysname> reset counters interface schannel-aggregation 1:10
# Clear statistics for S-Channel 1/0/1:10.1.
<Sysname> reset counters interface s-channel 1/0/1:10.1
# Clear statistics for Schannel-Aggregation 1:10.1.
<Sysname> reset counters interface schannel-aggregation 1:10.1
display interface
shutdown
Use shutdown to shut down an interface.
Use undo shutdown to bring up an interface.
shutdown
An interface is up.
# Shut down S-Channel 1/0/1:10.
[Sysname–S-Channel1/0/1:10] shutdown
# Shut down Schannel-Aggregation 1:10.
[Sysname–Schannel-Aggregation1:10] shutdown
