- 12-Network Management and Monitoring Command Reference
- 02-NQA commands
- 03-NTP commands
- 04-PoE commands
- 05-SNMP commands
- 06-RMON commands
- 07-NETCONF commands
- 08-EAA commands
- 09-Process monitoring and maintenance commands
- 10-Sampler commands
- 11-Mirroring commands
- 12-NetStream commands
- 13-IPv6 NetStream commands
- 14-sFlow commands
- 15-Information center commands
- 16-GOLD commands
- 17-Packet capture commands
- 18-VCF fabric commands
| 18-VCF fabric commands | 38.04 KB |
VCF fabric commands
display vcf-fabric topology
Use display vcf-fabric topology to display VCF fabric topology information.
You can execute this command only on the master spine node.
Before you display VCF fabric topology information, make sure VCF fabric topology discovery and automated underlay network provisioning are enabled.
# Display VCF fabric topology information.
<Sysname> display vcf-fabric topology
Topology Information
* indicates the master spine role among all spines
SpineIP Interface Link LeafIP Status
*10.11.113.51 Ten-GigabitEthernet1/0/1 Up 10.11.113.52 Running
Ten-GigabitEthernet1/0/2 Down -- --
Ten-GigabitEthernet1/0/3 Down -- --
SpineIP |
IPv4 address of the management Ethernet interface on the spine node. This field displays an asterisk (*) before the IP address if the device is the master spine node. |
Interface through which the spine node connects to a leaf node. If the device is a master spine node, all interfaces on the device are displayed. |
Link |
Physical link state of the interface. |
LeafIP |
IPv4 address of the interface through which a leaf node connects to the spine node. |
Status |
Status of automated underlay network provisioning on the leaf node. This field displays two hyphens (--) if automated underlay network provisioning is not started. This field displays Deploying if automated underlay network provisioning is in progress. |
vcf-fabric underlay autoconfigure
vcf-fabric topology enable
display vcf-fabric underlay autoconfigure
Use display vcf-fabric underlay autoconfigure to display information about automated underlay network provisioning.
Before you execute this command, make sure automated underlay network provisioning is enabled.
# Display information about automated underlay network provisioning.
<Sysname> display vcf-fabric underlay autoconfigure
Successfully configured commands:
clock timezone beijing add 08:00:00
lldp global enable
sysname spine
irf mac-address persistent always
ospf 1
graceful-restart ietf
area 0.0.0.0
interface LoopBack0
l2vpn enable
interface M-GigabitEthernet0/0/0
undo lldp enable
ntp-service enable
ntp-service unicast-peer 10.11.113.143
restful https enable
netconf soap https enable
ip https enable
telnet server enable
local-user aaa
password simple aaa
service-type telnet https
line vty 0 63
authentication-mode scheme
bgp 100
vcf topo enable
neutron
rabbit user openstack
rabbit password plain 12345678
rabbit host ip 10.11.113.143
username aaa password plain aaa
network-type vxlan-central
l2agent enable
l3agent enable
IRF configuration:
Bridge MAC: 72bd-bf0e-0100
IRF status: No
Member ID list: ['2']
Loopback address assignment:
IP address list: None
BGP peers:
No peers
AggrID: 1023
interface: Ten-GigabitEthernet1/0/1
interface: Ten-GigabitEthernet1/0/2
Successfully configured commands |
Commands that have been successfully executed during automated underlay network provisioning. |
IRF configuration |
IRF configurations, including IRF bridge MAC address of the IRF fabric, IRF status, and the IRF member ID of the device. |
Loopback address assignment |
IP address assigned to the loopback interfaces. |
BGP peers |
Information about BGP peers of the device. |
AggrID |
Information about Layer 2 aggregation groups. |
vcf-fabric role
Use vcf-fabric role to specify the role of the device.
Use undo vcf-fabric role to restore the default.
vcf-fabric role { access | leaf | spine }
No role is specified for the device.
Neutron view
access: Specifies the access node.
leaf: Specifies the leaf node.
spine: Specifies the spine node.
If you change the role of the device, the new role takes effect after the device restarts up.
# Specify the device as a spine node.
[Sysname] vcf-fabric role spine
vcf-fabric spine-role master
Use vcf-fabric spine-role master to specify the device as a master spine node.
Use undo vcf-fabric spine-role master to restore the default.
The device is not a master spine node.
You must execute this command on a spine node.
When multiple spines nodes exist in a VCF fabric, you must specify a device as the master spine node to collect the topology for the entire VCF fabric.
# Specify the device as a master spine.
[Sysname] vcf-fabric spine-role master
vcf-fabric role
Use vcf-fabric topology enable to enable VCF fabric topology discovery.
Use undo vcf-fabric topology enable to disable VCF fabric topology discovery.
VCF fabric topology discovery is disabled.
# Enable VCF fabric topology discovery.
[Sysname] vcf-fabric topology enable
Use vcf-fabric underlay autoconfigure to specify the template file for automated underlay network provisioning.
Use undo vcf-fabric underlay autoconfigure to restore the default.
vcf-fabric underlay autoconfigure template
No template file is specified for automated underlay network provisioning.
template: Specifies a template file by its name, a case-insensitive string of 1 to 127 characters. A template file is a file that ends with the .template file extension.
After this command is executed, the device uses the specified template file to deploy the underlay network.
# Specify template file vxlan_spine.template for automated underlay network provisioning.
[Sysname] vcf-fabric underlay autoconfigure vxlan_spine.template
vcf-fabric underlay pause
Use vcf-fabric underlay pause to pause automated underlay network provisioning.
Use undo vcf-fabric underlay pause to continue automated underlay network provisioning.
Automated underlay network provisioning is not paused.
You can use this command to pause automated underlay network provisioning if the device is in the process of automated underlay network provisioning.
# Pause automated underlay network provisioning.
<sysname> system-view
[sysname] vcf-fabric underlay pause
