06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS7500E-X SeriesReference GuidesCommand ReferencesH3C S7500E-X Command References-R7523P01-6W10006-Layer 3 - IP Routing Command Reference
08-IPv6 static routing commands
08-IPv6 static routing commands 55.28 KB
delete ipv6 static-routes all
Use delete ipv6 static-routes all to delete all IPv6 static routes.
delete ipv6 [ vpn-instance vpn-instance-name ] static-routes all
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command deletes all IPv6 static routes for the public network.
When you use this command, the system will prompt you to confirm the operation before deleting all the IPv6 static routes.
# Delete all IPv6 static routes.
[Sysname] delete ipv6 static-routes all
This will erase all IPv6 static routes and their configurations, you must reconfigure all static routes.
Are you sure?[Y/N]:y
ipv6 route-static
display ipv6 route-static nib
Use display ipv6 route-static nib to display IPv6 static route next hop information.
display ipv6 route-static nib [ nib-id ] [ verbose ]
nib-id: Specifies a NIB by its ID, a hexadecimal string in the range of 1 to ffffffff.
verbose: Displays detailed IPv6 static route next hop information. If you do not specify this keyword, the command displays brief IPv6 static route next hop information.
# Display brief IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib
Total number of nexthop(s): 35
      NibID: 0x21000000        Sequence: 0
       Type: 0x41               Flushed: Yes
   UserKey0: 0x0                VrfNthp: 0
   UserKey1: 0x0                Nexthop: 2::3
    IFIndex: 0x0              LocalAddr: ::
   TopoNthp: Invalid
      NibID: 0x21000001        Sequence: 1
   UserKey1: 0x0                Nexthop: 3::4
   TopoNthp: Invalid
NibID
ID of the NIB.
Sequence
Sequence number of the NIB.
Type of the NIB.
Flushed
Indicates whether the route with the NIB has been flushed to the FIB.
UserKey0
Reserved data 1.
UserKey1
Reserved data 2.
VrfNthp
Index of the VPN instance to which the next hop belongs. This field displays 0 if the next hop is on an IPv6 network.
Nexthop
Next hop address.
IFIndex
Interface index
LocalAddr
Local interface address.
# Display detailed IPv6 static route next hop information.
<Sysname> display ipv6 route-static nib verbose
   TopoNthp: Invalid
     RefCnt: 1              FlushRefCnt: 0
       Flag: 0x12               Version: 1
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 2::3
  RelyDepth: 2              RealNexthop: ::
  Interface: NULL0            LocalAddr: ::
  TunnelCnt: 0                      Vrf: default-vrf
   TunnelID: N/A               Topology:
     Weight: 0
   TopoNthp: Invalid
 1 nexthop(s):
PrefixIndex: 0              OrigNexthop: 3::4
  RelyDepth: 1              RealNexthop: ::
  Interface: Vlan11           LocalAddr: ::
     Weight: 0
x nexthop(s)
Number of next hops.
PrefixIndex
Prefix index of the next hop for an ECMP route.
Vrf
VPN instance name. For an IPv6 network, this field displays default-vrf.
OrigNexthop
Original next hop.
RealNexthop
Real next hop.
Output interface.
localAddr
RelyDepth
Recursion depth.
TunnelCnt
Number of tunnels after route recursion.
TunnelID
ID of the tunnel after route recursion.
Weight
ECMP route weight. This field displays 0 for non-ECMP routes.
RefCnt
Reference count of the next hop.
FlushRefCnt
Reference count of the next hop that is flushed to the FIB.
Flag
Flag of the next hop.
Version
Version of the next hop.
display ipv6 route-static routing-table
Use display ipv6 route-static routing-table to display IPv6 static routing table information.
display ipv6 route-static routing-table [ vpn-instance vpn-instance-name ] [ ipv6-address prefix-length ]
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VPN instance, the command displays IPv6 static routing table information for the public network.
ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies the prefix length in the range of 0 to 128.
# Display IPv6 static routing table information.
<Sysname> display ipv6 route-static routing-table
Total number of routes: 5
Status: * - valid
*Destination: 1::1/128
       NibID: 0x21000000        NextHop: 2::2
   MainNibID: N/A             BkNextHop: N/A
     BkNibID: N/A             Interface: Vlan-interface11
     TableID: 0xa           BkInterface: N/A
        Flag: 0x80d0a          BfdSrcIp: N/A
     DbIndex: 0x3            BfdIfIndex: 0x0
        Type: Normal        BfdVrfIndex: 0
  TrackIndex: 0xffffffff          Label: NULL
  Preference: 60            vrfIndexDst: 0
     BfdMode: N/A            vrfIndexNH: 0
   Permanent: 0                     Tag: 0
*Destination: 1::1234/128
     BkNibID: N/A             Interface: NULL0
     DbIndex: 0x1            BfdIfIndex: 0x0
   Permanent: 0                     Tag: 0
Destination
Destination address/prefix.
NibID
ID of the NIB.
MainNibID
ID of the primary next hop for static route FRR.
BkNibID
ID of the backup next hop for static route FRR.
NextHop
Next hop address.
BkNextHop
Backup next hop address.
Output interface of the route.
BkInterface
Backup output interface.
TableID
ID of the table to which the route belongs.
DbIndex
Index of the database to which the route belongs.
Route type:
·     Normal.
·     DHCP.
BfdSrcIp
Source IPv6 address of the indirect BFD session.
BfdIfIndex
Index of the interface where BFD is enabled.
BfdVrfIndex
Index of the VPN instance where BFD is enabled. This field displays 0 if BFD is enabled for an IPv6 network.
BfdMode
BFD session mode:
·     N/A—No BFD session is configured.
·     Ctrl—Control packet mode.
·     Echo—Echo packet mode.
TrackIndex
NQA Track index.
vrfIndexDst
Index of the VPN instance to which the destination belongs. For an IPv6 network, this field displays 0.
vrfIndexNH
Index of the VPN instance to which the next hop belongs. For an IPv6 network, this field displays 0.
Permanent
Permanent static route flag. 1 indicates a permanent static route.
ipv6 route-static
Use ipv6 route-static to configure an IPv6 static route.
Use undo ipv6 route-static to remove an IPv6 static route.
ipv6 route-static ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] [ bfd { control-packet | echo-packet } [ bfd-source ipv6-address ] | permanent ] | [ vpn-instance d-vpn-instance-name ] next-hop-address [ bfd control-packet bfd-source ipv6-address | permanent ] } [ preference preference ] [ tag tag-value ] [ description text ]
undo ipv6 route-static ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | [ vpn-instance d-vpn-instance-name ] next-hop-address ] [ preference preference ]
ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length { interface-type interface-number [ next-hop-address ] [ bfd { control-packet | echo-packet } [ bfd-source ipv6-address ] | permanent ] | next-hop-address [ public ] [ bfd control-packet bfd-source ipv6-address | permanent ] | vpn-instance d-vpn-instance-name next-hop-address [ bfd control-packet bfd-source ipv6-address | permanent ] } [ preference preference ] [ tag tag-value ] [ description text ]
undo ipv6 route-static vpn-instance s-vpn-instance-name ipv6-address prefix-length [ interface-type interface-number [ next-hop-address ] | next-hop-address [ public ] | vpn-instance d-vpn-instance-name next-hop-address ] [ preference preference ]
No IPv6 static route is configured.
ipv6-address prefix-length: Specifies the IPv6 address and prefix length.
interface-type interface-number: Specifies an output interface by its type and number. If the output interface is an NBMA interface or broadcast interface and not a point-to-point (P2P) interface, the next hop address must be specified.
next-hop-address: Specifies the next hop IPv6 address.
bfd: Enables BFD to detect reachability of the static route's next hop.
control-packet: Specifies the BFD control mode.
bfd-source ipv6-address: Specifies the source IPv6 address of BFD packets.
echo-packet: Specifies the BFD echo mode.
permanent: Specifies the IPv6 route as a permanent IPv6 static route. If the output interface is down, the permanent IPv6 static route is still active.
public: Indicates the next hop is on the public network.
vpn-instance d-vpn-instance-name: Specifies a destination MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If a destination VPN is specified, packets will search for the output interface based on the specified next hop (IPv6 address) for the static route.
preference preference: Specifies a preference for IPv6 static routes, in the range of 1 to 255. The default is 60.
tag tag-value: Sets a tag for marking the static route, in the range of 1 to 4294967295. The default is 0. Tags of routes are used for route control in routing policies. For more information about routing policies, see Layer 3—IP Routing Configuration Guide.
description text: Configures a description for the IPv6 static route, which consists of 1 to 60 characters, including special characters such as the space, but excluding the question mark (?).
vpn-instance s-vpn-instance-name: Specifies a source MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Each VPN has its own routing table, and the configured static route is installed in the routing tables of the specified VPNs.
An IPv6 static route that has the destination address configured as ::/0 (a prefix length of 0) is the default IPv6 route. If the destination address of an IPv6 packet does not match any entry in the routing table, this default route is used to forward the packet.
Follow these guidelines to configure the output interface, next hop address, or both for a static route:
·     If the output interface is a broadcast interface or an NBMA interface, the next hop address must be specified.
·     If the output interface is a P2P interface, you can specify only the output interface. You do not need to change the configuration of the route even if the peer address is changed.
Follow these guidelines when you configure BFD for IPv6 static routes:
·     If you specify the source IPv6 address of BFD packets, you must specify the IPv6 address as the next hop IPv6 address on the peer device.
·     If you specify a non-P2P output interface and a direct next hop, specify the bfd-source ipv6-address option as a best practice. Make sure the source IPv6 address of BFD packets meets the following requirements:
¡     The address is the same as the IPv6 address of the output interface.
¡     The address is on the same network segment as the next hop IPv6 address of the same type.
For example, if the next hop IPv6 address is a link-local address, the source IPv6 address of BFD packets must also be a link-local address.
Follow these guidelines when you configure a static route:
·     Enabling BFD for a flapping route could worsen the route flapping situation. Therefore, use it with caution. For more information about BFD, see High Availability Configuration Guide.
·     The next hop IPv6 address of echo packets must be a global unicast address.
·     Do not specify the permanent keyword together with the bfd keyword.
# Configure an IPv6 static route, with the destination address 1:1:2::/64 and next hop 1:1:3::1.
[Sysname] ipv6 route-static 1:1:2:: 64 1:1:3::1
display ipv6 routing-table protocol
ipv6 route-static default-preference
Use ipv6 route-static default-preference to set a default preference for IPv6 static routes.
Use undo ipv6 route-static default-preference to restore the default.
ipv6 route-static default-preference default-preference
The default preference of IPv6 static routes is 60.
default-preference: Specifies a default preference for IPv6 static routes, in the range of 1 to 255.
If no preference is specified for an IPv6 static route, the default preference applies.
When the default preference is reconfigured, it applies only to newly added IPv6 static routes.
# Set a default preference of 120 for IPv6 static routes.
[Sysname] ipv6 route-static default-preference 120
