04-Layer 2 - LAN Switching Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R7523P01-6W10004-Layer 2 - LAN Switching Command Reference
04-VLAN commands
04-VLAN commands 250.03 KB
VLAN commands· 1
Basic VLAN commands· 1
bandwidth· 1
default 1
description· 2
display interface vlan-interface· 3
display vlan· 5
display vlan brief 7
interface vlan-interface· 8
mtu· 9
name· 9
reset counters interface vlan-interface· 10
service· 10
shutdown· 11
vlan· 12
Port-based VLAN commands· 13
display port 13
port 14
port access vlan· 14
port hybrid pvid· 15
port hybrid vlan· 16
port link-type· 17
port trunk permit vlan· 18
port trunk pvid· 18
MAC-based VLAN commands· 19
display mac-vlan· 19
display mac-vlan interface· 20
mac-vlan enable· 21
mac-vlan mac-address· 21
mac-vlan trigger enable· 23
port pvid forbidden· 23
vlan precedence· 24
IP subnet-based VLAN commands· 25
display ip-subnet-vlan interface· 25
display ip-subnet-vlan vlan· 26
ip-subnet-vlan· 27
port hybrid ip-subnet-vlan· 27
Protocol-based VLAN commands· 29
display protocol-vlan interface· 29
display protocol-vlan vlan· 30
port hybrid protocol-vlan· 30
protocol-vlan· 32
VLAN group commands· 33
display vlan-group· 33
vlan-group· 34
vlan-list 35
Super VLAN commands· 36
display supervlan· 36
subvlan· 38
supervlan· 39
Private VLAN commands· 40
display private-vlan· 40
port private-vlan host 42
port private-vlan promiscuous· 44
port private-vlan trunk promiscuous· 46
port private-vlan trunk secondary· 48
private-vlan (VLAN interface view) 51
private-vlan (VLAN view) 53
private-vlan community· 54
private-vlan isolated· 55
private-vlan primary· 57
Voice VLAN commands· 58
display voice-vlan mac-address· 58
display voice-vlan state· 58
voice-vlan aging· 59
voice-vlan enable· 60
voice-vlan mac-address· 61
voice-vlan mode auto· 62
voice-vlan qos· 63
voice-vlan qos trust 63
voice-vlan security enable· 64
voice-vlan track lldp· 65
VLAN commands
Basic VLAN commands
bandwidth
Use bandwidth to set the expected bandwidth of an interface.
bandwidth bandwidth-value
undo bandwidth
VLAN interface view
# Set the expected bandwidth to 10000 kbps for VLAN-interface 1.
[Sysname-Vlan-interface1] bandwidth 10000
default
Use default to restore the default settings for a VLAN interface.
default
VLAN interface view
CAUTION
CAUTION:
The default command might interrupt ongoing network services. Make sure you are fully aware of the impact of this command when you use it on a live network.
This command might fail to restore the default settings for some commands for reasons such as command dependencies or system restrictions. Use the display this command in interface view to identify these commands, and then use their undo forms or follow the command reference to restore their default settings. If your restoration attempt still fails, follow the error message instructions to resolve the problem.
# Restore the default settings for VLAN-interface 1.
[Sysname-Vlan-interface1] default
description
Use description to configure the description of a VLAN or VLAN interface.
For a VLAN, the description is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has fewer than four digits, leading zeros are added. For example, the default description of VLAN 100 is VLAN 0100.
For a VLAN interface, the description is the name of the interface. For example, Vlan-interface1 Interface.
VLAN view
VLAN interface view
To manage VLANs and VLAN interfaces efficiently, configure descriptions for them based on their functions or connections.
# Configure the description of VLAN 2 as sales-private.
[Sysname] vlan 2
[Sysname-vlan2] description sales-private
# Configure the description of VLAN-interface 2 as linktoPC56.
[Sysname] vlan 2
[Sysname-vlan2] quit
[Sysname-Vlan-interface2] description linktoPC56
display vlan
Use display interface vlan-interface to display VLAN interface information.
display interface vlan-interface [ interface-number ] [ brief [ description | down ] ]
vlan-interface interface-number: Specifies a VLAN interface number. If you do not specify this argument, the command displays information about all VLAN interfaces.
down: Displays VLAN interfaces in down state and their down causes. If you do not specify this keyword, the command displays information about VLAN interfaces in all states.
# Display information about VLAN-interface 2.
<Sysname> display interface vlan-interface 2
Vlan-interface2
Current state: DOWN
Line protocol state: DOWN
Description: Vlan-interface2 Interface
Bandwidth: 100000 kbps
Internet protocol processing : Disabled
IP packet frame type: Ethernet II, hardware address: 000f-e249-8050
IPv6 packet frame type: Ethernet II, hardware address: 000f-e249-8050
# Display brief information about VLAN-interface 2.
<Sysname> display interface vlan-interface 2 brief
Protocol: (s) - spoofing
Interface            Link Protocol Primary IP         Description
Vlan2                DOWN DOWN     --
Vlan-interface2
VLAN interface name.
Current state
Physical link state of the VLAN interface:
·     Administratively DOWN—The interface has been shut down by using the shutdown command.
·     DOWN—The interface is administratively up, but its physical state is down. The VLAN of this VLAN interface does not contain any physical ports in up state. The ports might not be connected correctly or the links might have failed.
·     UP—The interface is both administratively and physically up.
Line protocol state
Data link layer state of the VLAN interface:
·     DOWN—The link layer protocol state of the interface is down.
·     UP—The link layer protocol state of the interface is up.
Description of the VLAN interface.
Bandwidth
Expected bandwidth of the VLAN interface.
MTU of the VLAN interface.
The VLAN interface is not assigned an IP address and cannot process IP packets.
Internet Address
IP address of the VLAN interface. The primary attribute indicates that the address is the primary IP address.
IPv4 packet framing format.
hardware address
MAC address of the VLAN interface.
IPv6 packet framing format.
Information about the urgent, protocol, and FIFO output queues:
·     Size—Number of packets in the queue.
·     Length—Maximum number of packets that the queue can contain.
·     Discards—Number of dropped packets.
The most recent time that the reset counters interface vlan-interface command was executed. This field displays Never if you have never executed this command.
Average rates of input packets and output packets in the last 300 seconds (in Bps, bps, and pps).
Total number and size (in bytes) of the received packets of the interface and the number of the dropped packets.
Total number and size (in bytes) of the sent packets of the interface and the number of the dropped packets.
Brief information about Layer 3 interfaces.
Abbreviated interface name.
Link
Physical link state of the interface:
·     UP—The interface is physically up.
·     DOWN—The interface is physically down.
·     ADM—The interface has been shut down by using the shutdown command. To restore the physical state of the interface, use the undo shutdown command.
·     Stby—The interface is a backup interface in standby state. To see the primary interface, use the display interface-backup state command.
Protocol
Data link layer protocol state of the interface:
·     UP—The data link layer protocol state of the interface is up.
·     DOWN—The data link layer protocol state of the interface is down.
·     UP(s)—The data link layer protocol of the interface is up, but the link is an on-demand link or does not exist. The (s) attribute represents the spoofing flag.
Primary IP
Primary IP address of the interface.
display vlan
Use display vlan to display VLAN information.
display vlan [ vlan-id1 [ to vlan-id2 ] | all | dynamic | reserved | static ]
vlan-id1: Specifies a VLAN by its ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN ID range. Both the vlan-id1 and the vlan-id2 arguments are in the range of 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
all: Specifies all VLANs except the reserved VLANs.
dynamic: Specifies dynamic VLANs. If you specify this keyword, the command displays the total number of dynamic VLANs and each dynamic VLAN ID. Dynamic VLANs are generated through MVRP or assigned by a RADIUS server.
reserved: Specifies reserved VLANs. Protocol modules determine which VLANs are reserved according to function implementation. The reserved VLANs provide services for protocol modules. You cannot configure reserved VLANs.
static: Specifies static VLANs. If you specify this keyword, the command displays the total number of static VLANs and each static VLAN ID. Static VLANs are manually created.
# Display information about VLAN 2.
<Sysname> display vlan 2
 VLAN ID: 2
 VLAN type: Static
 Description: VLAN 0002
 Tagged ports:   None
 Untagged ports:
    Ten-GigabitEthernet1/1/1  Ten-GigabitEthernet1/1/2  Ten-GigabitEthernet1/1/3
# Display information about VLAN 3.
<Sysname> display vlan 3
 VLAN ID: 3
 VLAN type: static
 Route interface: Configured
 IPv4 address: 1.1.1.1
 IPv4 subnet mask: 255.255.255.0
 Description: VLAN 0003
 Tagged ports:   None
 Untagged ports: None
VLAN type
VLAN type, static or dynamic.
Route interface
Whether the VLAN interface is configured for the VLAN.
·     Not configured.
·     Configured.
Description of the VLAN.
Name
VLAN name.
IP address
Primary IPv4 address of the VLAN interface. This field is displayed only when an IPv4 address is configured for the VLAN interface.
When the VLAN interface is also configured with secondary IPv4 addresses, you can view them by using one of the following commands:
·     display interface vlan-interface.
·     display this (VLAN interface view).
Subnet mask
Subnet mask of the primary IP address. This field is available only when an IP address is configured for the VLAN interface.
Tagged ports
Tagged members of the VLAN.
Untagged ports
Untagged members of the VLAN.
vlan
display vlan brief
Use display vlan brief to display brief VLAN information.
display vlan brief
# Display brief VLAN information.
<Sysname> display vlan brief
Brief information about all VLANs:
Supported Minimum VLAN ID: 1
Supported Maximum VLAN ID: 4094
Default VLAN ID: 1
VLAN ID   Name                             Port
1         VLAN 0001                        XGE1/1/1  XGE1/1/2  XGE1/1/3  XGE1/1/4
                                           XGE1/1/5  XGE1/1/6  XGE1/1/7  XGE1/1/8
                                           XGE1/1/9  XGE1/1/10  XGE1/1/11
                                           XGE1/1/12  XGE1/1/13  XGE1/1/14
                                           XGE1/1/15  XGE1/1/16  XGE1/1/17
                                           XGE1/1/18  XGE1/1/19  XGE1/1/20
                                           XGE1/1/21  XGE1/1/22  XGE1/1/23
2         VLAN 0002
3         VLAN 0003
Default VLAN ID
System default VLAN ID.
Name
VLAN name.
Port
Ports that allow packets from the VLAN to pass through.
Use interface vlan-interface to create a VLAN interface and enter its view, or enter the view of an existing VLAN interface.
Use undo interface vlan-interface to delete a VLAN interface.
undo interface vlan-interface interface-number
No VLAN interfaces exist.
interface-number: Specifies a VLAN interface number in the range of 1 to 4094.
Create the VLAN before you create the VLAN interface for a VLAN.
You cannot create VLAN interfaces for sub-VLANs.
You cannot create VLAN interfaces for secondary VLANs that meet the following requirements:
·     Associated with the same primary VLAN.
·     Enabled with Layer 3 communication in VLAN interface view of the primary VLAN interface.
# Create VLAN-interface 2, and enter its view.
[Sysname] vlan 2
mtu
Use mtu to set the MTU for a VLAN interface.
mtu size
undo mtu
The MTU of a VLAN interface is 1500 bytes.
VLAN interface view
size: Sets the MTU in bytes. The value range for this argument is 46 to 9198.
If you configure both the mtu and ip mtu commands on a VLAN interface, the MTU set by the ip mtu command is used for fragmentation. For more information about the ip mtu command, see Layer 3—IP Services Command Reference.
# Set the MTU to 1492 bytes for VLAN-interface 1.
[Sysname-Vlan-interface1] mtu 1492
name
Use name to assign a name to a VLAN.
Use undo name to restore the default.
name text
undo name
The name of a VLAN is VLAN vlan-id. The vlan-id argument specifies the VLAN ID in a four-digit format. If the VLAN ID has fewer than four digits, leading zeros are added. For example, the name of VLAN 100 is VLAN 0100.
VLAN view
text: Specifies a VLAN name, a case-sensitive string of 1 to 32 characters.
For 802.1X or MAC authentication, you can specify authorization VLANs by their names or IDs. If a large number of VLANs are configured, use VLAN names to identify them.
# Assign the name test vlan to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] name test vlan
display vlan
Use reset counters interface vlan-interface to clear statistics on a VLAN interface.
reset counters interface vlan-interface [ interface-number ]
vlan-interface interface-number: Specifies a VLAN interface by its number. If you do not specify the interface-number argument, this command clears statistics on all VLAN interfaces.
Use this command to clear the history statistics before you collect statistics within a time period.
# Clear statistics on VLAN-interface 2.
<Sysname> reset counters interface vlan-interface 2
service
Use service to specify a traffic processing slot for a VLAN interface.
Use undo service to restore the default.
service slot slot-number
undo service slot
No traffic processing slot is specified for a VLAN interface. Traffic on a VLAN interface is processed on the slot at which the traffic arrives.
VLAN interface view
slot slot-number: Specifies an IRF member device by its member ID or specifies a PEX by its virtual slot number.
Specify a traffic processing slot for a VLAN interface if all traffic on the VLAN interface must be processed on the same slot.
Make sure the specified traffic processing slot is available. If the specified traffic processing slot is not available, traffic on the VLAN interface cannot be forwarded. Traffic on the VLAN interface will not be forwarded until the traffic processing slot becomes available or until you respecify an available traffic processing slot.
# Specify slot 2 to process traffic for VLAN-interface 2.
[Sysname] vlan 2
[Sysname-Vlan-interface2] service slot 2
shutdown
Use shutdown to shut down a VLAN interface.
Use undo shutdown to bring up a VLAN interface.
shutdown
A VLAN interface is not manually shut down.
VLAN interface view
When a VLAN interface is not manually shut down, the following guidelines apply to the interface state:
·     The VLAN interface is down if all ports in the VLAN are down.
·     The VLAN interface is up if one or more ports in the VLAN are up.
When you use this command to shut down a VLAN interface, the VLAN interface remains in DOWN (Administratively) state. In this case, the VLAN interface state is not affected by the state of the ports in the VLAN.
Before you configure parameters for a VLAN interface, use this command to shut it down to prevent the configuration from affecting the network. After you complete the VLAN interface configuration, use the undo shutdown command to make the settings take effect.
To troubleshoot a failed VLAN interface, you can use the shutdown command and then the undo shutdown command on the interface to see whether it recovers.
In a VLAN, the state of each Ethernet port is independent of the state of the VLAN interface.
# Shut down VLAN-interface 2, and then bring it up.
[Sysname-Vlan-interface2] shutdown
[Sysname-Vlan-interface2] undo shutdown
vlan
Use vlan vlan-id to create a VLAN and enter its view, or enter the view of an existing VLAN.
Use vlan vlan-id1 to vlan-id2 to create VLANs vlan-id1 through vlan-id2, except reserved VLANs.
Use vlan all to create VLANs 1 through 4094.
Use undo vlan to delete the specified VLANs.
vlan { vlan-id1 [ to vlan-id2 ] | all }
undo vlan { vlan-id1 [ to vlan-id2 ] | all }
VLAN 1 (system default VLAN) exists.
vlan-id1: Specifies a VLAN ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies a VLAN range. The vlan-id1 and vlan-id2 arguments specify VLAN IDs. The value range for each of the two arguments is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
all: Specifies all VLANs except reserved VLANs. The keyword is not supported when the maximum number of VLANs that can be created on a device is less than 4094.
You cannot create or delete the system default VLAN (VLAN 1) or reserved VLANs.
Before you delete a dynamic VLAN or a VLAN locked by an application, you must first remove the configuration from the VLAN.
# Create VLAN 2 and enter its view.
[Sysname] vlan 2
[Sysname-vlan2]
# Create VLANs 4 through 100.
[Sysname] vlan 4 to 100
display vlan
display port
Use display port to display information about hybrid or trunk ports.
hybrid: Specifies hybrid ports.
trunk: Specifies trunk ports.
# Display information about hybrid ports.
<Sysname> display port hybrid
Interface            PVID  VLAN Passing
XGE1/1/1             100   Tagged:  1000, 1002, 1500, 1600-1611, 2000,
                                    2555-2558, 3000, 4000
                           Untagged:1, 10, 15, 18, 20-30, 44, 55, 67, 100,
                                    150-160, 200, 255, 286, 300-302
# Display information about trunk ports.
<Sysname> display port trunk
XGE1/1/2             2     1-4, 6-100, 145, 177, 189-200, 244, 289, 400,
                           555, 600-611, 1000, 2006-2008
Interface name.
PVID
Port VLAN ID.
VLAN Passing
Existing VLANs allowed on the port.
Tagged
VLANs from which the port sends packets without removing VLAN tags.
Untagged
VLANs from which the port sends packets after removing VLAN tags.
port
Use port to assign the specified access ports to a VLAN.
Use undo port to remove the specified access ports from a VLAN.
port interface-list
undo port interface-list
All ports are in VLAN 1.
VLAN view
interface-list: Specifies a space-separated list of up to 10 Ethernet interface items. Each item specifies an Ethernet interface or a range of Ethernet interfaces in the form of interface-type interface-number1 to interface-type interface-number2. The value for the interface-number2 argument must be equal to or greater than the value for the interface-number1 argument.
This command is applicable only to access ports.
By default, all ports are access ports. You can manually configure the port link type. For more information, see "port link-type."
# Assign Ten-GigabitEthernet 1/1/1 through Ten-GigabitEthernet 1/1/3 to VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] port ten-gigabitethernet 1/1/1 to ten-gigabitethernet 1/1/3
display vlan
port access vlan
Use port access vlan to assign an access port to the specified VLAN.
Use undo port access vlan to restore the default.
port access vlan vlan-id
All access ports belong to VLAN 1.
S-channel interface/S-channel aggregate interface view
vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
Before assigning an access port to a VLAN, make sure the VLAN has been created.
# Assign Ten-GigabitEthernet 1/1/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] quit
[Sysname] interface ten-gigabitethernet 1/1/1
[Sysname-Ten-GigabitEthernet1/1/1] port access vlan 3
port hybrid pvid
Use port hybrid pvid to set the PVID of a hybrid port.
Use undo port hybrid pvid to set the PVID of a hybrid port to 1.
port hybrid pvid vlan vlan-id
The PVID of a hybrid port is the ID of the VLAN to which the port belongs when its link type is access.
You can use a nonexistent VLAN as the PVID of a hybrid port. When you delete the PVID of a hybrid port by using the undo vlan command, the PVID setting of the port does not change.
For correct packet transmission, set the same PVID for a local hybrid port and its peer.
To enable a hybrid port to transmit packets from its PVID, you must assign the hybrid port to the PVID by using the port hybrid vlan command.
# Configure Ten-GigabitEthernet 1/1/1 as a hybrid port, set its PVID to VLAN 100, and assign it to VLAN 100 as an untagged member.
[Sysname] vlan 100
[Sysname-vlan100] quit
[Sysname-Ten-GigabitEthernet1/1/1] port link-type hybrid
[Sysname-Ten-GigabitEthernet1/1/1] port hybrid pvid vlan 100
[Sysname-Ten-GigabitEthernet1/1/1] port hybrid vlan 100 untagged
port hybrid vlan
port link-type
port hybrid vlan
Use port hybrid vlan to assign a hybrid port to the specified VLANs.
Use undo port hybrid vlan to remove a hybrid port from the specified VLANs.
undo port hybrid vlan vlan-id-list
A hybrid port is an untagged member of the VLAN to which the port belongs when its link type is access.
vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN ID or a range of VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument. The specified VLANs must already exist on the device.
tagged: Configures the port as a tagged member of the specified VLANs. A tagged member of a VLAN sends packets from the VLAN without removing VLAN tags.
untagged: Configures the port as an untagged member of the specified VLANs. An untagged member of a VLAN sends packets from the VLAN after removing VLAN tags.
A hybrid port can allow multiple VLANs. If you execute this command multiple times on a hybrid port, the hybrid port allows all the specified VLANs.
# Configure Ten-GigabitEthernet 1/1/1 as a hybrid port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100 as a tagged member.
[Sysname-Ten-GigabitEthernet1/1/1] port hybrid vlan 2 4 50 to 100 tagged
port link-type
port link-type
Use port link-type to set the link type of a port.
Use undo port link-type to restore the default link type of a port.
undo port link-type
Each port is an access port.
access: Sets the port link type to access.
hybrid: Sets the port link type to hybrid.
trunk: Sets the port link type to trunk.
To change the link type of a port from trunk to hybrid or vice versa, first set the link type to access.
# Configure Ten-GigabitEthernet 1/1/1 as a trunk port.
[Sysname-Ten-GigabitEthernet1/1/1] port link-type trunk
Use port trunk permit vlan to assign a trunk port to the specified VLANs.
Use undo port trunk permit vlan to remove a trunk port from the specified VLANs.
undo port trunk permit vlan { vlan-id-list | all }
A trunk port allows packets only from VLAN 1 to pass through.
all: Specifies all VLANs. To prevent unauthorized VLAN users from accessing restricted resources through the port, use the port trunk permit vlan all command with caution.
A trunk port can allow multiple VLANs. If you execute this command multiple times on a trunk port, the trunk port allows all the specified VLANs.
On a trunk port, packets only from the PVID can pass through untagged.
# Configure Ten-GigabitEthernet 1/1/1 as a trunk port, and assign it to VLAN 2, VLAN 4, and VLAN 50 through VLAN 100.
[Sysname-Ten-GigabitEthernet1/1/1] port trunk permit vlan 2 4 50 to 100
port link-type
port trunk pvid
Use port trunk pvid to set the PVID for a trunk port.
Use undo port trunk pvid to restore the default.
port trunk pvid vlan vlan-id
The PVID of a trunk port is VLAN 1.
You can use a nonexistent VLAN as the PVID for a trunk port. When you delete the PVID of a trunk port by using the undo vlan command, the PVID setting of the port does not change.
For correct packet transmission, set the same PVID for a local trunk port and its peer.
To enable a trunk port to transmit packets from its PVID, you must assign the trunk port to the PVID by using the port trunk permit vlan command.
# Configure Ten-GigabitEthernet 1/1/1 as a trunk, set its PVID to VLAN 100, and assign it to VLAN 100.
[Sysname-Ten-GigabitEthernet1/1/1] port trunk pvid vlan 100
[Sysname-Ten-GigabitEthernet1/1/1] port trunk permit vlan 100
port link-type
display mac-vlan
Use display mac-vlan to display MAC-to-VLAN entries.
display mac-vlan { all | dynamic | mac-address mac-address [ mask mac-mask ] | static | vlan vlan-id }
all: Specifies all MAC-to-VLAN entries.
dynamic: Specifies dynamically configured MAC-to-VLAN entries.
mac-address mac-address: Specifies the MAC address in the MAC-to-VLAN entry. The format of the mac-address argument is H-H-H.
mask mac-mask: Specifies the mask for matching MAC addresses in MAC-to-VLAN entries. For the mac-mask argument, the high-order bits must be consecutive 1s in binary notation or consecutive Fs in hexadecimal notation. The default value is ffff-ffff-ffff.
static: Specifies statically configured MAC-to-VLAN entries.
vlan vlan-id: Specifies the VLAN in MAC-to-VLAN entries. The value range for the vlan-id argument is 1 to 4094.
# Display all MAC-to-VLAN entries.
<Sysname> display mac-vlan all
The following MAC VLAN entries exist:
State: S - Static, D - Dynamic
MAC address        Mask                VLAN ID   Dot1q      State
0008-0001-0000     ffff-ff00-0000      5         3          S
0002-0001-0000     ffff-ffff-ffff      5         3          S&D
Total MAC VLAN entries count: 2
Table 5 Command output
S - Static
Statically configured MAC-to-VLAN entries.
D - Dynamic
Dynamically configured MAC-to-VLAN entries.
MAC address
MAC address of the MAC-to-VLAN entry.
Mask
MAC address mask of the MAC-to-VLAN entry.
VLAN ID
VLAN ID of the MAC-to-VLAN entry.
Dot1q
802.1p priority of the VLAN in the MAC-to-VLAN entry.
State of a MAC-to-VLAN entry:
·     S—The MAC-to-VLAN entry is configured statically.
·     D—The MAC-to-VLAN entry is dynamically issued by the authentication server.
·     S&D—The MAC-to-VLAN entry is configured both statically and dynamically.
Use display mac-vlan interface to display all ports that are enabled with the MAC-based VLAN feature.
# Display all ports that are enabled with the MAC-based VLAN feature.
<Sysname> display mac-vlan interface
MAC VLAN is enabled on following ports:
mac-vlan enable
mac-vlan enable
Use mac-vlan enable to enable the MAC-based VLAN feature on a port.
Use undo mac-vlan enable to disable the MAC-based VLAN feature on a port.
mac-vlan enable
The MAC-based VLAN feature is disabled on a port.
# Enable the MAC-based VLAN feature on Ten-GigabitEthernet 1/1/1.
[Sysname–Ten-GigabitEthernet1/1/1] mac-vlan enable
Use mac-vlan mac-address to configure a MAC-to-VLAN entry.
Use undo mac-vlan to delete the specified MAC-to-VLAN entries.
mac-vlan mac-address mac-address [ mask mac-mask ] vlan vlan-id [ dot1q priority ]
undo mac-vlan { all | mac-address mac-address [ mask mac-mask ] | vlan vlan-id }
No MAC-to-VLAN entries exist.
mac-address mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be a multicast MAC address or all 0s. When you configure a MAC address, leading zeros in each H section can be omitted. For example, to configure a MAC address 000f-00e2-0001, you can enter only f-e2-1.
mask mac-mask: Specifies the MAC address mask. For the mac-mask argument, the high-order bits must be consecutive 1s in binary notation or consecutive Fs in hexadecimal notation. The default value is ffff-ffff-ffff.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
dot1q priority: Specifies the 802.1p priority of the VLAN specific to the MAC-to-VLAN entry. The value range for the priority argument is 0 to 7, and the default value is 0. The higher the value, the higher the 802.1p priority.
all: Specifies all static MAC-to-VLAN entries.
For successful dynamic MAC-based VLAN assignment, use static VLANs when you create MAC-to-VLAN entries.
Different types of MAC-to-VLAN entries are created depending on whether you specify the mask keyword.
·     When you specify this keyword, the created MAC-to-VLAN entry describes the relationship among a group of MAC addresses, a VLAN, and the 802.1p priority for the VLAN.
·     When you do not specify this keyword, the created MAC-to-VLAN entry describes the relationship among a MAC address, a VLAN, and the 802.1p priority for the VLAN.
These different types of MAC-to-VLAN entries are stored separately in two tables. The system updates the two tables according to the configuration.
# Associate the MAC address 0000-0001-0001 with VLAN 100, and set the 802.1p priority to 7 for VLAN 100 in this entry.
[Sysname] mac-vlan mac-address 0-1-1 vlan 100 dot1q 7
# Associate VLAN 100 with MAC addresses whose six high-order bits are 121122, and set the 802.1p priority to 4 for VLAN 100 in this entry.
[Sysname] mac-vlan mac-address 1211-2222-3333 mask ffff-ff00-0000 vlan 100 dot1q 4
display mac-vlan
Use mac-vlan trigger enable to enable dynamic MAC-based VLAN assignment on a port.
Use undo mac-vlan trigger enable to disable dynamic MAC-based VLAN assignment on a port.
Dynamic MAC-based VLAN assignment is disabled on a port.
VLAN assignment for a port is triggered only when the source MAC address of its received packet exactly matches the MAC address in a MAC-to-VLAN entry.
# Enable dynamic MAC-based VLAN assignment on Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] mac-vlan trigger enable
port pvid forbidden
port pvid forbidden
Use port pvid forbidden to disable a port from forwarding packets that fail the exact MAC address match in its PVID.
Use undo port pvid forbidden to restore the default.
port pvid forbidden
When a port receives packets whose source MAC addresses fail the exact MAC address match, the port forwards them in its PVID.
Use this feature only with dynamic MAC-based VLAN assignment.
# Disable Ten-GigabitEthernet 1/1/1 from forwarding packets that fail the exact MAC address match in its PVID.
[Sysname-Ten-GigabitEthernet1/1/1] port pvid forbidden
vlan precedence
Use vlan precedence to set the VLAN matching order.
Use undo vlan precedence to restore the default.
vlan precedence { mac-vlan | ip-subnet-vlan }
A port matches VLANs based on MAC addresses preferentially.
mac-vlan: Matches VLANs based on MAC addresses preferentially.
ip-subnet-vlan: Matches VLANs based on IP subnets preferentially.
This command takes effect only on MAC-based VLANs and IP subnet-based VLANs.
When you enable dynamic MAC-based VLAN assignment, configure the vlan precedence mac-vlan command as a best practice to ensure the priority of MAC-based VLAN matching. If you execute the vlan precedence ip-subnet-vlan command, the command does not take effect.
# Configure Ten-GigabitEthernet 1/1/1 to match VLANs based on MAC addresses preferentially.
[Sysname-Ten-GigabitEthernet1/1/1] vlan precedence mac-vlan
Use display ip-subnet-vlan interface to display IP subnet-based VLANs that are associated with the specified ports.
display ip-subnet-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
interface-type interface-number1 to interface-type interface-number2: Specifies an interface range. Both the interface-type interface-number1 argument and the interface-type interface-number2 argument represent the interface type and interface number. The value for the interface-number2 argument must be greater than or equal to the value for the interface-number1 argument.
all: Specifies all ports.
# Display IP subnet-based VLANs on Ten-GigabitEthernet 1/1/1.
<Sysname> display ip-subnet-vlan interface ten-gigabitethernet 1/1/1
 Interface: Ten-GigabitEthernet1/1/1
  VLAN ID   Subnet index    IP address       Subnet mask       Status
  3         0               192.168.1.0      255.255.255.0     Active
  4         N/A             N/A              N/A               Inactive
  4094      65535           172.16.1.1       255.255.0.0       Inactive
Table 6 Command output
VLAN ID
ID of the IP subnet-based VLAN.
Subnet index
Index of the IP subnet.
This field displays N/A if no IP subnet-based VLAN is configured.
IP address
IP address of the subnet. It can be an IP address or a subnet address.
This field displays N/A if no IP subnet address is configured for the VLAN.
Subnet mask
Mask of the IP subnet.
This field displays N/A if no subnet mask is configured for the VLAN.
Status
Whether the IP subnet-based VLAN has taken effect on the port:
·     Active—The IP subnet-based VLAN has taken effect.
·     Inactive—The IP subnet-based VLAN has not taken effect. For example, this field displays Inactive in one of the following conditions:
¡     The configuration of the IP subnet-based VLAN is not complete.
¡     The port does not allow the IP subnet-based VLAN.
ip-subnet-vlan
Use display ip-subnet-vlan vlan to display information about IP subnet-based VLANs.
display ip-subnet-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
vlan-id1: Specifies an IP subnet-based VLAN by its VLAN ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies an IP subnet-based VLAN ID range. Both the vlan-id1 and the vlan-id2 arguments are in the range of 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
all: Specifies all IP subnet-based VLANs.
# Display information about all IP subnet-based VLANs.
<Sysname> display ip-subnet-vlan vlan all
 VLAN ID: 3
Table 7 Command output
VLAN ID
Subnet index
IP address
Subnet mask
ip-subnet-vlan
ip-subnet-vlan
Use ip-subnet-vlan to associate a VLAN with the specified IP subnet or IP address.
Use undo ip-subnet-vlan to disassociate a VLAN from the specified IP subnet or IP address.
ip-subnet-vlan [ ip-subnet-index ] ip ip-address [ mask ]
undo ip-subnet-vlan { ip-subnet-index [ to ip-subnet-end ] | all }
A VLAN is not associated with an IP subnet or IP address.
VLAN view
ip-subnet-index: Specifies a beginning IP subnet index in the range of 0 to 65535. The value can be configured by users. It can also be automatically numbered by the system based on the order in which the IP subnets or IP addresses are associated with the VLAN.
ip ip-address [ mask ]: Specifies the source IP address or network address that is associated with the VLAN. The ip-address argument specifies the source IP address or network address in dotted decimal notation. The mask argument is the subnet mask of the source IP address or network address, in dotted decimal notation with a default value of 255.255.255.0.
to ip-subnet-end: Specifies an end IP subnet index of an IP subnet index range, in the range of 0 to 65535. The value for the ip-subnet-end argument must be greater than or equal to the beginning IP subnet index.
all: Specifies all IP subnets or IP addresses that are associated with the VLAN.
The IP subnet or IP address cannot be a multicast network segment or a multicast address.
# Configure VLAN 3 as an IP subnet-based VLAN and associate it with the subnet 192.168.1.0/24.
[Sysname] vlan 3
[Sysname-vlan3] ip-subnet-vlan ip 192.168.1.0 255.255.255.0
Use port hybrid ip-subnet-vlan to associate a port with the specified IP subnet-based VLAN.
Use undo port hybrid ip-subnet-vlan to disassociate a port from the specified IP subnet-based VLAN.
port hybrid ip-subnet-vlan vlan vlan-id
undo port hybrid ip-subnet-vlan { vlan vlan-id | all }
A port is not associated with an IP subnet-based VLAN.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
For this command to take effect, perform the following tasks:
1.     Create a VLAN and associate it with the specified IP subnet or IP address.
2.     Set the port link type to hybrid.
3.     Configure the port to allow the IP subnet-based VLAN to pass through.
# Associate Ten-GigabitEthernet 1/1/1 with IP subnet-based VLAN 3.
[Sysname] vlan 3
[Sysname-Ten-GigabitEthernet1/1/1] port hybrid vlan 3 untagged
[Sysname-Ten-GigabitEthernet1/1/1] port hybrid ip-subnet-vlan vlan 3
# Associate Layer 2 aggregate interface Bridge-Aggregation 1 with IP subnet-based VLAN 3.
[Sysname] vlan 3
[Sysname-Bridge-Aggregation1] port link-type hybrid
[Sysname-Bridge-Aggregation1] port hybrid vlan 3 untagged
[Sysname-Bridge-Aggregation1] port hybrid ip-subnet-vlan vlan 3
ip-subnet-vlan
Use display protocol-vlan interface to display protocol-based VLANs that are associated with the specified ports.
display protocol-vlan interface { interface-type interface-number1 [ to interface-type interface-number2 ] | all }
# Display protocol-based VLAN information on Ten-GigabitEthernet 1/1/1.
<Sysname> display protocol-vlan interface ten-gigabitethernet 1/1/1
  VLAN ID  Protocol index  Protocol type             Status
  2        0               IPv6                      Active
  2        1               N/A                       Inactive
  4094     65535           IPv4                      Inactive
Table 8 Command output
VLAN ID
ID of the protocol-based VLAN.
Protocol index
Protocol template index.
Protocol type
Protocol type specified by the protocol template.
This field displays N/A if the protocol type is not specified.
Status
Whether the protocol-based VLAN has taken effect:
·     Active—The protocol-based VLAN has taken effect.
·     Inactive—The protocol-based VLAN has not taken effect.
protocol-vlan
Use display protocol-vlan vlan to display information about protocol-based VLANs.
display protocol-vlan vlan { vlan-id1 [ to vlan-id2 ] | all }
vlan-id1: Specifies a protocol-based VLAN ID in the range of 1 to 4094.
vlan-id1 to vlan-id2: Specifies a protocol-based VLAN ID range. Both the vlan-id1 and the vlan-id2 arguments are in the range of 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
all: Specifies all protocol-based VLANs.
# Displays information about all protocol-based VLANs.
<Sysname> display protocol-vlan vlan all
 VLAN ID: 2
  0               IPv4
  65535           IPv6
 VLAN ID: 3
  0               IPv4
  65535           LLC DSAP 0x11 SSAP 0x22
Table 9 Command output
VLAN ID
Protocol index
Protocol type
Protocol type or encapsulation format specified by the protocol template.
protocol-vlan
Use port hybrid protocol-vlan to associate a port with the specified protocol-based VLAN.
Use undo port hybrid protocol-vlan to disassociate a port from the specified protocol-based VLAN.
port hybrid protocol-vlan vlan vlan-id { protocol-index [ to protocol-end ] | all }
undo hybrid protocol-vlan { vlan vlan-id { protocol-index [ to protocol-end ] | all } | all }
A port is not associated with a protocol-based VLAN.
protocol-index: Specifies a beginning protocol template index in the range of 0 to 65535.
to protocol-end: Specifies an end protocol template index of a protocol template range, in the range of 0 to 65535. The value for this argument must be greater than or equal to the beginning protocol template index.
all: Specifies all protocol templates.
1.     Create a VLAN and associate it with the specified protocol templates.
3.     Configure the port to allow the protocol-based VLAN to pass through.
When you execute the undo port hybrid protocol-vlan command on a port, follow these guidelines:
·     If you specify both the vlan-id argument and the all keyword, this command disassociates the port from all protocol templates of the specified VLAN.
·     If you specify only the all keyword, this command disassociates the port from all protocol templates of all VLANs.
# Configure Ten-GigabitEthernet 1/1/1 as a hybrid port, assign it to VLAN 2 as an untagged member, and associated it with protocol template 1 in VLAN 2.
[Sysname] vlan 2
[Sysname-vlan2] protocol-vlan 1 ipv4
[Sysname-Ten-GigabitEthernet1/1/1] port hybrid vlan 2 untagged
[Sysname-Ten-GigabitEthernet1/1/1] port hybrid protocol-vlan vlan 2 1
# Configure Layer 2 aggregate interface Bridge-Aggregation 1 as a hybrid port, assign it to VLAN 2 as an untagged member, and associated it with protocol template 1 in VLAN 2.
[Sysname] vlan 2
[Sysname-Bridge-Aggregation1] port hybrid vlan 2 untagged
[Sysname-Bridge-Aggregation1] port hybrid protocol-vlan vlan 2 1
protocol-vlan
Use protocol-vlan to associate a VLAN with the specified protocol template.
Use undo protocol-vlan to disassociate a VLAN from the specified protocol template.
protocol-vlan [ protocol-index ] { at | ipv4 | ipv6 | ipx { ethernetii | llc | raw | snap } | mode { ethernetii etype etype-id | llc { dsap dsap-id [ ssap ssap-id ] | ssap ssap-id } | snap etype etype-id } }
undo protocol-vlan { protocol-index [ to protocol-end ] | all }
A VLAN is not associated with a protocol template.
VLAN view
at: Specifies the AppleTalk-based VLAN.
ipv4: Specifies the IPv4-based VLAN.
ipv6: Specifies the IPv6-based VLAN.
ipx: Specifies the IPX-based VLAN. The keywords ethernetii, llc, raw, and snap specify IPX encapsulation formats.
mode: Configures a user-defined protocol template for the VLAN. The keywords ethernetii, llc, and snap specify the available encapsulation formats.
ethernetii etype etype-id: Matches the Ethernet II encapsulation format and the specified protocol type ID. The etype-id argument specifies the protocol type ID of inbound packets, in the range of 600 to ffff in hexadecimal notation, excluding 800, 86dd, 809b, and 8137.
llc: Matches the LLC encapsulation format.
dsap dsap-id: Specifies the destination service access point in hexadecimal notation, in the range of 0 to ff.
ssap ssap-id: Specifies the source service access point in hexadecimal notation, in the range of 0 to ff.
snap etype etype-id: Matches the SNAP encapsulation format and the specified protocol type value. The etype-id argument specifies the Ethernet type of inbound packets, in the range of 600 to ffff in hexadecimal notation, excluding 8137.
protocol-index: Specifies a protocol template index that is associated with the VLAN. The value range for this argument is 0 to 65535. The system will automatically assign an index if you do not specify this argument.
to protocol-end: Specifies an end protocol template index of a protocol template range, in the range of 0 to 65535. The value for the protocol-end argument must be greater than or equal to the value for the protocol-index argument.
all: Specifies all protocols associated with the VLAN.
CAUTION
CAUTION:
IP uses ARP for address resolution in Ethernet. To prevent communication failures, configure the IP and ARP templates in the same VLAN and associate them with the same port.
When you use the mode keyword to configure a protocol template, follow these restrictions and guidelines:
·     Do not set the etype-id argument in the ethernetii etype etype-id option to the following hexadecimal values:
¡     800—Specifies the IPv4 protocol in Ethernet II encapsulation.
¡     809b—Specifies the AppleTalk protocol in Ethernet II encapsulation.
¡     8137—Specifies the IPX protocol in Ethernet II encapsulation.
¡     86dd—Specifies the IPv6 protocol in Ethernet II encapsulation.
·     Do not set both the dsap-id and ssap-id arguments to any of the following hexadecimal values:
¡     e0—Specifies the 802.2 LLC encapsulation format for IPX packets.
¡     ff—Specifies the 802.3 raw encapsulation format for IPX packets.
¡     aa—Specifies the 802.2 SNAP encapsulation format.
When either of the dsap-id and ssap-id arguments is configured, the system assigns the hexadecimal value aa to the other argument.
·     Do not set the etype-id argument in the snap etype etype-id option to the hexadecimal value 8137. Otherwise, the template format will be the same as that of the IPX protocol. You can set the etype-id argument to the hexadecimal value 800, 809b, or 86dd. The hexadecimal values 800, 809b, and 86dd correspond to IPv4, AppleTalk, and IPv6, respectively.
# Assign ARP packets in Ethernet II encapsulation and IPv4 packets to VLAN 3 for transmission. (The protocol type ID for ARP is 0806 in hexadecimal notation.)
[Sysname] vlan 3
[Sysname-vlan3] protocol-vlan 1 ipv4
[Sysname-vlan3] protocol-vlan 2 mode ethernetii etype 0806
port protocol-vlan
VLAN group commands
display vlan-group
Use display vlan-group to display VLAN group information.
display vlan-group [ group-name ]
group-name: Specifies a VLAN group by its name, a case-sensitive string of 1 to 31 characters. The first character must be an alphabetical character. If you do not specify this argument, the command displays information about all VLAN groups.
# Display information about VLAN group test001.
<Sysname> display vlan-group test001
VLAN group: test001
     VLAN list: 2-4 100 200
# Display information about all VLAN groups.
VLAN group: test001
VLAN group: rnd
     VLAN list: Null
Table 10 Command output
VLAN group
Name of the VLAN group.
VLAN list
VLAN list in the VLAN group.
vlan-group
vlan-list
vlan-group
Use vlan-group to create a VLAN group and enter its view, or enter the view of an existing VLAN group.
Use undo vlan-group to delete a VLAN group.
vlan-group group-name
undo vlan-group group-name
No VLAN groups exist.
A VLAN group includes a set of VLANs. You can add multiple VLAN lists to a VLAN group.
# Create a VLAN group named test001 and enter VLAN group view.
[Sysname] vlan-group test001
[Sysname-vlan-group-test001]
vlan-list
vlan-list
Use vlan-list to add VLANs to a VLAN group.
Use undo vlan-list to remove VLANs from a VLAN group.
vlan-list vlan-id-list
undo vlan-list vlan-id-list
No VLANs exist in a VLAN group.
VLAN group view
# Add VLAN 2 through VLAN 4, VLAN 100, and VLAN 200 to VLAN group test001.
[Sysname-vlan-group-test001] vlan-list 2 to 4 100 200
vlan-group
Super VLAN commands
display supervlan
Use display supervlan to display information about super VLANs and their associated sub-VLANs.
display supervlan [ supervlan-id ]
supervlan-id: Specifies a super VLAN ID in the range of 1 to 4094. If you do not specify a super VLAN ID, this command displays information about all super VLANs and their associated sub-VLANs.
# Display information about super VLAN 2 and its associated sub-VLANs.
<Sysname> display supervlan 2
 Super VLAN ID: 2
 Sub-VLAN ID: 3-5
 VLAN ID: 2
 VLAN type: Static
 It is a super VLAN.
 IPv4 address: 10.153.17.41
 IPv4 subnet mask: 255.255.252.0
 IPv6 global unicast addresses:
   2001::1, subnet is 2001::/64 [TENTATIVE]
 Tagged ports:   None
 VLAN ID: 3
 VLAN type: Static
 It is a sub VLAN.
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 4
 VLAN type: Static
 It is a sub VLAN.
 Description: VLAN 0004
 Tagged ports:   None
 Untagged ports:
    Ten-GigabitEthernet1/1/4
Table 11 Command output
VLAN type
VLAN type, dynamic or static.
Route interface
Whether a VLAN interface is configured for the VLAN.
IPv4 address
IPv4 subnet mask
Subnet mask for the primary IPv4 address of the VLAN interface. This field is displayed only when an IPv4 address is configured for the VLAN interface.
Global unicast IPv6 address of the VLAN interface. This field is not displayed when no IPv6 address is configured for the VLAN interface.
The IPv6 address states are as follows:
·     TENTATIVE—Initial state. DAD is being performed or is to be performed on the address. An address in this state cannot be used as the source address or destination address of packets.
·     DUPLICATE—DAD has been completed for the address. The address is not unique on the link and cannot be used.
·     PREFERRED—The address is preferred and can be used as the source or destination address of a packet. If an address is in this state, the command does not display the address state.
·     DEPRECATED—The address is beyond the preferred lifetime but within the valid lifetime. It is valid, but it cannot be used as the source address for a new connection. Packets destined to the address are processed correctly.
VLAN description.
Name
VLAN name.
Tagged ports
Untagged ports
subvlan
supervlan
subvlan
Use subvlan to associate a super VLAN with the specified sub-VLANs.
Use undo subvlan to dissociate sub-VLANs from a super VLAN.
subvlan vlan-id-list
undo subvlan [ vlan-id-list ]
A super VLAN is not associated with any sub-VLANs.
VLAN view
vlan-id-list: Specifies a space-separated list of up to 10 sub-VLAN items. Each item specifies a sub-VLAN ID or a range of sub-VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for sub-VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument.
Make sure sub-VLANs already exist before you associate them with a super VLAN.
You can add ports to and remove ports from a sub-VLAN that is already associated with a super VLAN.
When you use the undo subvlan command, follow these guidelines:
·     If you do not specify the vlan-id-list argument, this command dissociates all sub-VLANs from the current super VLAN.
·     If you specify the vlan-id-list argument, this command dissociates the specified sub-VLANs from the current super VLAN.
# Associate super VLAN 10 with sub-VLANs 3, 4, and 5.
[Sysname] vlan 3 to 5
[Sysname] vlan 10
[Sysname-vlan10] supervlan
[Sysname-vlan10] subvlan 3 to 5
display supervlan
supervlan
supervlan
Use supervlan to configure a VLAN as a super VLAN.
Use undo supervlan to restore the default.
supervlan
undo supervlan
A VLAN is not a super VLAN.
VLAN view
You cannot configure a VLAN as both a super VLAN and a guest VLAN, Auth-Fail VLAN, or critical VLAN. For more information about guest VLANs, Auth-Fail VLANs, and critical VLANs, see Security Configuration Guide.
As a best practice, do not configure VRRP for a super VLAN interface, because the configuration affects network performance.
Layer 2 multicast configuration for super VLANs does not take effect because they do not have physical ports.
# Configure VLAN 2 as a super VLAN.
[Sysname] vlan 2
[Sysname-vlan2] supervlan
display supervlan
subvlan
Use display private-vlan to display information about primary VLANs and their associated secondary VLANs.
display private-vlan [ primary-vlan-id ]
primary-vlan-id: Specifies a primary VLAN ID in the range of 1 to 4094. If you do not specify a primary VLAN ID, this command displays information about all primary VLANs and their associated secondary VLANs.
# Display information about primary VLANs and their associated secondary VLANs.
<Sysname> display private-vlan
 Primary VLAN ID: 2
 Secondary VLAN ID: 3-4
 VLAN ID: 2
 VLAN type: Static
 Private VLAN type: Primary
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 3
 VLAN type: Static
 Private VLAN type: Secondary
 Tagged ports:   None
 Untagged ports:
 VLAN ID: 4
 VLAN type: Static
 Tagged ports:   None
 Untagged ports:
Table 12 Command output
VLAN type
Private VLAN type
Private VLAN type:
·     Primary—Primary VLAN.
·     Secondary—Secondary VLAN.
·     Isolated secondary—Secondary VLAN configured with port isolation at Layer 2.
Route interface
Whether a VLAN interface is created for the VLAN:
·     Configured.
·     Not configured.
IPv4 address
IPv4 subnet mask
VLAN description.
Name
VLAN name.
Tagged ports
Untagged ports
Use port private-vlan host to configure a port as a host port.
Use undo port private-vlan to restore the default.
A port is not a host port.
If the port has been assigned to a secondary VLAN, the command assigns the port to the primary VLAN associated with the secondary VLAN. Also, the following events occur:
·     For an access port, the device performs the following operations:
¡     Changes the port link type to hybrid.
¡     Configures the secondary VLAN as the PVID.
¡     Assigns the port to the primary VLAN as an untagged member.
·     For a trunk port, the device does not change the port link type or PVID.
·     For a hybrid port, the device does not change the port link type or PVID.
¡     If the hybrid port has been a tagged or untagged member of the primary VLAN, this member attribute remains in the primary VLAN.
¡     If the hybrid port does not allow the primary VLAN, the device assigns the port to the primary VLAN as an untagged member.
You can assign the port to a secondary VLAN before or after you execute this command.
The undo port private-vlan command does not change the VLAN attributes (allowed VLANs, port link type, and PVID) of the port.
The port private-vlan host command is mutually exclusive with the port private-vlan trunk promiscuous and port private-vlan trunk secondary commands.
In this example, VLAN 20 is a secondary VLAN and is associated with primary VLAN 2.
# Configure Ten-GigabitEthernet 1/1/1 as a host port, and then verify the configuration.
[Sysname-Ten-GigabitEthernet1/1/1] port private-vlan host
[Sysname-Ten-GigabitEthernet1/1/1] display this
interface Ten-GigabitEthernet1/1/1
 port link-mode bridge
return
The output show that Ten-GigabitEthernet 1/1/1 is operating in bridge mode and is a host port.
# Assign Ten-GigabitEthernet 1/1/1 to VLAN 20, and then verify the configuration.
[Sysname-Ten-GigabitEthernet1/1/1] port access vlan 20
 undo port hybrid vlan 1
 port hybrid vlan 2 20 untagged
 port hybrid pvid vlan 20
return
The output shows that:
·     Ten-GigabitEthernet 1/1/1 is an untagged member of secondary VLAN 20 and primary VLAN 2.
·     The port link type of Ten-GigabitEthernet 1/1/1 is hybrid and its PVID is VLAN 20.
Use port private-vlan promiscuous to configure a port as a promiscuous port of the specified VLAN and assign the port to the VLAN.
port private-vlan vlan-id promiscuous
A port is not a promiscuous port of any VLANs.
vlan-id: Specifies a VLAN ID in the range of 1 to 4094. Though VLAN 1 is in the valid value range, it cannot be configured in the command.
If the specified VLAN is a primary VLAN that has been associated with secondary VLANs, the command assigns the port to the associated secondary VLANs. Also, the following events occur:
¡     Configures the primary VLAN as the PVID.
¡     Assigns the port to the primary VLAN and its associated secondary VLANs as an untagged member.
¡     If the hybrid port has been a tagged or untagged member of the primary VLAN and part of its associated secondary VLANs, this member attribute remains in these VLANs. The device assigns the hybrid port to the rest of the associated secondary VLANs as an untagged member.
¡     If the hybrid port does not allow any of the primary VLAN and its associated secondary VLANs, the command assigns the port to these VLANs as an untagged member.
If you execute this command on a promiscuous port multiple times, the most recent configuration takes effect.
The undo port private-vlan command does not change the VLAN attributes (allowed secondary VLANs, link type, and PVID) of the port. When you execute the undo port private-vlan command on a promiscuous port of a VLAN, the command removes the port from the VLAN.
You can configure the VLAN as a primary VLAN before or after you execute the port private-vlan promiscuous command.
This command is mutually exclusive with the port private-vlan trunk promiscuous and port private-vlan trunk secondary commands.
In this example, VLAN 2 is a primary VLAN, and it is associated with secondary VLAN 20.
# Display information about Ten-GigabitEthernet 1/1/1.
return
# Configure Ten-GigabitEthernet 1/1/1 as a promiscuous port of VLAN 2, and then verify the configuration.
[Sysname-Ten-GigabitEthernet1/1/1] port private-vlan 2 promiscuous
return
·     Ten-GigabitEthernet 1/1/1 is a promiscuous port of VLAN 2.
·     Ten-GigabitEthernet 1/1/1 is an untagged member of primary VLAN 2 and secondary VLAN 20.
·     The port link type of Ten-GigabitEthernet 1/1/1 is hybrid and its PVID is VLAN 2.
# Execute the undo port private-vlan command on Ten-GigabitEthernet 1/1/1, and then verify the configuration.
[Sysname-Ten-GigabitEthernet1/1/1] undo port private-vlan
 port hybrid vlan 20 untagged
return
·     Ten-GigabitEthernet 1/1/1 is removed from primary VLAN 2.
·     Ten-GigabitEthernet 1/1/1 is an untagged member of VLAN 20.
·     The link type and PVID of Ten-GigabitEthernet 1/1/1 do not change.
Use port private-vlan trunk promiscuous to configure a port as a trunk promiscuous port of the specified VLANs and assign the port to these VLANs.
Use undo port private-vlan trunk promiscuous to cancel the trunk promiscuous attribute of a port in the specified VLANs.
port private-vlan vlan-id-list trunk promiscuous
undo port private-vlan vlan-id-list trunk promiscuous
A port is not a trunk promiscuous port of any VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 primary VLAN items. Each item specifies a primary VLAN ID or a range of primary VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for primary VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument. Though the system default VLAN (VLAN 1) is in the valid value range, it cannot be configured in the command.
If the specified VLANs are primary VLANs that have been associated with secondary VLANs, the command assigns the port to the associated secondary VLANs. Also, the following events occur:
¡     Changes the port link type to hybrid. The PVID of the port does not change.
¡     Assigns the port to the primary VLANs and the associated secondary VLANs as a tagged member.
¡     If the hybrid port has been a tagged or untagged member of part of the primary VLANs and their associated secondary VLANs, this member attribute remains in these VLANs. The device assigns the hybrid port to the rest of the primary VLANs and their associated secondary VLANs as a tagged member.
¡     If the hybrid port does not allow any of the primary VLANs and their associated secondary VLANs, the device assigns the port to these VLANs as a tagged member.
The undo form of this command does not change the VLAN attributes (allowed secondary VLANs, port link type, and PVID) of the port.
If you execute the undo form of this command on a trunk promiscuous port, the command removes the port from the VLANs specified by the vlan-id-list argument.
You can configure the specified VLANs as primary VLANs before or after you execute this command.
This command is mutually exclusive with the port private-vlan host, port private-vlan promiscuous and port private-vlan trunk secondary commands.
For an uplink port to permit multiple primary VLANs, use the port private-vlan trunk promiscuous command to assign the port to these VLANs. The port can then transmit packets from these primary VLANs with VLAN tags. For an uplink port to permit only one primary VLAN, use the port private-vlan promiscuous command to assign the port to the VLAN. The port can then transmit packets from the primary VLAN without VLAN tags.
In this example, VLANs 2 and 3 are primary VLANs. VLAN 2 is associated with secondary VLAN 20. VLAN 3 is associated with secondary VLAN 30.
return
# Configure Ten-GigabitEthernet 1/1/1 as a trunk promiscuous port of VLANs 2 and 3, and then verify the configuration.
[Sysname-Ten-GigabitEthernet1/1/1] port private-vlan 2 3 trunk promiscuous
 port hybrid vlan 2 3 20 30 tagged
 port hybrid vlan 1 untagged
return
·     Ten-GigabitEthernet 1/1/1 is a trunk promiscuous port of VLANs 2 and 3.
·     Ten-GigabitEthernet1/1/1 is a tagged member of VLANs 2, 3, 20, and 30.
·     The port link type of Ten-GigabitEthernet 1/1/1 is hybrid.
# Execute the undo port private-vlan trunk promiscuous command on Ten-GigabitEthernet 1/1/1, and then verify the configuration.
[Sysname-Ten-GigabitEthernet1/1/1] undo port private-vlan 2 3 trunk promiscuous
 port hybrid vlan 20 30 tagged
return
·     Ten-GigabitEthernet 1/1/1 is removed from VLANs 2 and 3.
·     Ten-GigabitEthernet 1/1/1 is a tagged member of VLANs 20 and 30.
·     The port link type and PVID of Ten-GigabitEthernet 1/1/1 do not change.
private-vlan (VLAN view)
private-vlan primary
Use port private-vlan trunk secondary to configure a port as a trunk secondary port of the specified VLANs and assign the port to these VLANs.
Use undo port private-vlan trunk secondary to cancel the trunk secondary attribute of a port in the specified VLANs.
port private-vlan vlan-id-list trunk secondary
undo port private-vlan vlan-id-list trunk secondary
A port is not a trunk secondary port of any VLANs.
vlan-id-list: Specifies a space-separated list of up to 10 secondary VLAN items. Each item specifies a secondary VLAN ID or a range of secondary VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for secondary VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument. Though the system default VLAN (VLAN 1) is in the valid value range, it cannot be configured in the command.
If the specified VLANs are secondary VLANs that have been associated with primary VLANs, the command also assigns the port to the associated primary VLANs. Also, the following events occur:
¡     Assigns the port to the secondary VLANs and the associated primary VLANs as a tagged member.
¡     If the port has been an untagged or tagged member of part of the secondary VLANs and their associated primary VLANs, this member attribute remains in these VLANs. The device assigns the port to the rest of the secondary VLANs and their associated primary VLANs as a tagged member.
¡     If the hybrid port does not allow any of the secondary VLANs and their associated primary VLANs, the device assigns the port to these VLANs as a tagged member.
A trunk secondary port can join only one secondary VLAN among all secondary VLANs associated with a primary VLAN. However, it can join multiple secondary VLANs that are associated with different primary VLANs.
The undo form of this command does not change the VLAN attributes (allowed primary VLANs, port link type, and PVID) of the port.
When you execute the undo form of this command on a trunk secondary port of the VLANs specified by the vlan-id-list argument, one of the following events occurs:
·     If the port is an access port, the device does not change the VLAN configuration of the port.
·     If the port is a trunk or hybrid port, the device removes the port from the specified VLANs.
You can associate the specified VLANs with their respective primary VLANs before or after you execute this command.
This command does not take effect on the specified VLAN if any of the following conditions applies:
·     The specified VLAN does not exist.
·     The specified VLAN is not a secondary VLAN and is used for other purposes.
·     The specified VLAN shares the same primary VLAN with other secondary VLANs, and the current port has been configured as a trunk secondary port in one of the other secondary VLANs.
This command is mutually exclusive with the port private-vlan host, port private-vlan promiscuous and port private-vlan trunk promiscuous commands.
For a downlink port to permit multiple secondary VLANs associated with different primary VLANs, use the port private-vlan trunk secondary command to assign the port to these secondary VLANs. The port can then transmit packets from these secondary VLANs with VLAN tags. For a downlink port to permit only one secondary VLAN, use the port private-vlan host command to assign the port to the secondary VLAN. The port can then transmit packets from the secondary VLAN without VLAN tags.
·     In this example, VLANs 2 and 3 are primary VLANs. VLAN 2 is associated with secondary VLAN 20. VLAN 3 is associated with secondary VLAN 30.
return
# Configure Ten-GigabitEthernet 1/1/1 as a trunk secondary port of VLANs 20 and 30, and then verify the configuration.
[Sysname-Ten-GigabitEthernet1/1/1] port private-vlan 20 30 trunk secondary
return
¡     Ten-GigabitEthernet 1/1/1 is a trunk secondary port of VLANs 20 and 30.
¡     Ten-GigabitEthernet 1/1/1 is a tagged member of VLANs 2, 3, 20, and 30.
¡     The port link type of Ten-GigabitEthernet 1/1/1 is hybrid.
# Execute the undo port private-vlan trunk secondary command on Ten-GigabitEthernet 1/1/1, and then verify the configuration.
[Sysname-Ten-GigabitEthernet1/1/1] undo port private-vlan 20 30 trunk secondary
 port hybrid vlan 2 3 tagged
return
¡     Ten-GigabitEthernet 1/1/1 is removed from VLANs 20 and 30.
¡     Ten-GigabitEthernet 1/1/1 is a tagged member of VLANs 2 and 3.
¡     The port link type and PVID of Ten-GigabitEthernet 1/1/1 do not change.
·     In this example, VLAN 10 is not a secondary VLAN.
return
# Configure Ten-GigabitEthernet 1/1/1 as a trunk secondary port of VLAN 10, and then verify the configuration.
[Sysname-Ten-GigabitEthernet1/1/1] port private-vlan 10 trunk secondary
 port hybrid vlan 10 tagged
return
¡     Ten-GigabitEthernet 1/1/1 is a trunk secondary port of VLAN 10.
¡     Ten-GigabitEthernet 1/1/1 is a tagged member of VLAN 10.
# Execute the undo port private-vlan trunk secondary command on Ten-GigabitEthernet1/1/1, and then verify the configuration.
[Sysname-Ten-GigabitEthernet1/1/1] undo port private-vlan 10 trunk secondary
return
¡     Ten-GigabitEthernet 1/1/1 is removed from VLAN 10.
private-vlan isolated
private-vlan (VLAN interface view)
Use private-vlan secondary to enable Layer 3 communication between secondary VLANs that are associated with a primary VLAN.
Use undo private-vlan to cancel the Layer 3 communication configuration for secondary VLANs that are associated with a primary VLAN.
private-vlan secondary vlan-id-list
undo private-vlan [ secondary vlan-id-list ]
Secondary VLANs are isolated at Layer 3.
VLAN interface view
This command takes effect only when the following conditions exist:
·     This command is executed in VLAN interface view of the primary VLAN interface.
·     Secondary VLANs are associated with the primary VLAN.
·     No VLAN interfaces are created for secondary VLANs.
·     An IP address is assigned to the primary VLAN interface.
·     Local proxy ARP or ND is enabled on the primary VLAN interface.
You can create VLAN interfaces for secondary VLANs that are not enabled with Layer 3 communication. If secondary VLANs are enabled with Layer 3 communication, do not create VLAN interfaces for them.
When you execute this command in the same primary VLAN interface view multiple times, all the specified secondary VLANs are interoperable at Layer 3.
When you execute the undo private-vlan command, follow these guidelines:
·     If you specify the secondary vlan-id-list option, this command cancels the Layer 3 communication configuration only for the specified secondary VLANs.
·     If you do not specify the secondary vlan-id-list option, this command cancels the Layer 3 communication configuration for all secondary VLANs of the primary VLAN.
This example shows how to meet the following requirements:
·     VLAN 4 is a secondary VLAN, and it is associated with primary VLAN 2.
·     The uplink port (Ten-GigabitEthernet 1/1/2) is a promiscuous port of VLAN 2.
·     Downlink ports Ten-GigabitEthernet 1/1/3 and Ten-GigabitEthernet 1/1/4 are host ports of VLANs 3 and 4, respectively.
·     Secondary VLANs 3 and 4 can communicate at Layer 3.
# Configure VLAN 2 as a primary VLAN and associate it with secondary VLANs 3 and 4.
[Sysname] vlan 3 to 4
[Sysname] vlan 2
[Sysname-vlan2] private-vlan primary
[Sysname-vlan2] private-vlan secondary 3 to 4
[Sysname-vlan2] quit
# Configure the uplink port (Ten-GigabitEthernet 1/1/2) as a promiscuous port of VLAN 2.
[Sysname] interface ten-gigabitethernet 1/1/2
[Sysname-Ten-GigabitEthernet1/1/2] port private-vlan 2 promiscuous
[Sysname-Ten-GigabitEthernet1/1/2] quit
# Assign downlink port Ten-GigabitEthernet 1/1/3 to VLAN 3 and configure the port as a host port.
[Sysname] interface ten-gigabitethernet 1/1/3
[Sysname-Ten-GigabitEthernet1/1/3] port access vlan 3
[Sysname-Ten-GigabitEthernet1/1/3] port private-vlan host
[Sysname-Ten-GigabitEthernet1/1/3] quit
# Assign downlink port Ten-GigabitEthernet 1/1/4 to VLAN 4 and configure the port as a host port.
[Sysname] interface ten-gigabitethernet 1/1/4
[Sysname-Ten-GigabitEthernet1/1/4] port access vlan 4
[Sysname-Ten-GigabitEthernet1/1/4] port private-vlan host
[Sysname-Ten-GigabitEthernet1/1/4] quit
# Create VLAN-interface 2 and enable Layer 3 communication between secondary VLANs 3 and 4.
[Sysname-Vlan-interface2] private-vlan secondary 3 to 4
# Assign an IP address to VLAN-interface 2.
[Sysname-Vlan-interface2] ip address 192.168.1.1 255.255.255.0
# Enable local proxy ARP on VLAN-interface 2.
[Sysname-Vlan-interface2] local-proxy-arp enable
Use private-vlan to associate a primary VLAN with the specified secondary VLANs.
Use undo private-vlan to dissociate a primary VLAN from the specified secondary VLANs.
A primary VLAN is not associated with any secondary VLANs.
VLAN view
secondary vlan-id-list: Specifies a space-separated list of up to 10 secondary VLAN items. Each item specifies a secondary VLAN ID or a range of secondary VLAN IDs in the form of vlan-id1 to vlan-id2. The value range for secondary VLAN IDs is 1 to 4094. The value for the vlan-id2 argument must be equal to or greater than the value for the vlan-id1 argument. Though the system default VLAN (VLAN 1) is in the valid value range, it cannot be configured in the command.
A primary VLAN can be associated with multiple secondary VLANs. When you execute this command in the same VLAN view multiple times, all the specified secondary VLANs are associated with the primary VLAN.
The configuration synchronization is triggered based on the interface configuration when the following conditions exist:
·     This command is configured for a primary VLAN.
·     Ports on the device are promiscuous, trunk promiscuous, or host ports.
·     If you specify the secondary vlan-id-list option, this command dissociates the primary VLAN from the specified secondary VLANs.
·     If you do not specify the secondary vlan-id-list option, this command dissociates the primary VLAN from all secondary VLANs.
# Associate primary VLAN 2 with secondary VLANs 3 and 4.
[Sysname] vlan 2
primary-vlan primary
private-vlan community
Use private-vlan community to enable Layer 2 communication between ports in a secondary VLAN.
Ports in the same secondary VLAN can communicate with each other at Layer 2.
VLAN view
This command and the undo private-vlan isolated command have the same function.
When you use the save command to save the configuration, the private-vlan community command is not saved into the configuration file.
·     Ten-GigabitEthernet 1/1/2 and Ten-GigabitEthernet 1/1/3 are host ports.
·     Ten-GigabitEthernet 1/1/2 and Ten-GigabitEthernet 1/1/3 can communicate at Layer 2 in secondary VLAN 4.
# Configure VLAN 2 as a primary VLAN and associate it with secondary VLAN 4.
[Sysname] vlan 4
[Sysname-vlan4] quit
[Sysname] vlan 2
[Sysname-vlan2] private-vlan secondary 4
# Configure Ten-GigabitEthernet 1/1/1 as a promiscuous port of VLAN 2.
[Sysname-Ten-GigabitEthernet1/1/1] quit
# Assign Ten-GigabitEthernet 1/1/2 to VLAN 4 and configure the port as a host port.
[Sysname-Ten-GigabitEthernet1/1/2] port access vlan 4
[Sysname-Ten-GigabitEthernet1/1/2] port private-vlan host
# Assign Ten-GigabitEthernet 1/1/3 to VLAN 4 and configure the port as a host port.
[Sysname-Ten-GigabitEthernet1/1/3] port access vlan 4
# Enable Layer 2 communication in secondary VLAN 4.
[Sysname] vlan 4
[Sysname-vlan4] private-vlan community
Use private-vlan isolated to isolate ports in a secondary VLAN at Layer 2.
Use undo private-vlan isolated to restore the default.
VLAN view
This command takes effect when the following conditions exist:
·     The secondary VLAN is associated with a primary VLAN.
·     The ports are configured as host ports or trunk secondary ports of the secondary VLAN.
This command is mutually exclusive with the primary VLAN, super VLAN, and sub-VLAN configuration commands.
·     Ten-GigabitEthernet 1/1/2 and Ten-GigabitEthernet 1/1/3 are isolated at Layer 2 in secondary VLAN 4.
[Sysname] vlan 4
[Sysname] vlan 2
# Configure port isolation at Layer 2 in secondary VLAN 4.
[Sysname] vlan 4
[Sysname-vlan4] private-vlan isolated
Use private-vlan primary to configure a VLAN as a primary VLAN.
Use undo private-vlan primary to restore the default.
A VLAN is not a primary VLAN.
VLAN view
·     This command is configured for a VLAN that has been associated with secondary VLANs.
·     Ports on the device are promiscuous, trunk promiscuous, host, or trunk secondary ports.
# Configure VLAN 5 as a primary VLAN.
[Sysname] vlan 5
[Sysname-vlan5] private-vlan primary
Voice VLAN commands
display voice-vlan mac-address
Use display voice-vlan mac-address to display the OUI addresses supported on the device.
# Display the OUI addresses supported on the device.
<Sysname> display voice-vlan mac-address
OUI Address     Mask            Description
0001-e300-0000  ffff-ff00-0000  Siemens phone
0003-6b00-0000  ffff-ff00-0000  Cisco phone
0004-0d00-0000  ffff-ff00-0000  Avaya phone
000f-e200-0000  ffff-ff00-0000  H3C Aolynk phone
0060-b900-0000  ffff-ff00-0000  Philips/NEC phone
00d0-1e00-0000  ffff-ff00-0000  Pingtel phone
00e0-7500-0000  ffff-ff00-0000  Polycom phone
00e0-bb00-0000  ffff-ff00-0000  3Com phone
Table 13 Command output
OUI Address
OUI address allowed on the device.
Mask
Mask of the OUI address.
Description of the OUI address.
display voice-vlan state
Use display voice-vlan state to display voice VLAN information.
# Display voice VLAN information.
<Sysname> display voice-vlan state
 Current voice VLANs: 1
 Voice VLAN security mode: Security
 Voice VLAN aging time: 1440 minutes
 Voice VLAN enabled ports and their modes:
 Port                        VLAN        Mode        CoS        DSCP
 XGE1/1/1                    111         Auto        6          46
Table 14 Command output
Current Voice VLANs
Number of existing voice VLANs.
Voice VLAN mode:
·     Security.
·     Normal.
Voice VLAN-enabled ports and their voice VLAN assignment modes.
Port
Name of the voice VLAN-enabled port.
VLAN
ID of the voice VLAN enabled on the port.
Mode
Voice VLAN assignment mode of the port:
·     Manual.
·     Automatic.
voice-vlan aging
voice-vlan enable
voice-vlan mode auto
voice-vlan security enable
voice-vlan aging
Use voice-vlan aging to set the voice VLAN aging timer.
Use undo voice-vlan aging to restore the default.
voice-vlan aging minutes
The voice VLAN aging timer is 1440 minutes (24 hours).
minutes: Sets the voice VLAN aging timer in the range of 5 to 43200 minutes.
In automatic voice VLAN assignment mode, the device starts an aging timer for a voice VLAN when assigning a port to the voice VLAN. If no voice packets are received on the port before the timer expires, the device removes the port from the voice VLAN.
Set the voice VLAN aging timer only when the voice VLAN assignment mode is automatic.
# Set the voice VLAN aging timer to 100 minutes.
[Sysname] voice-vlan aging 100
voice-vlan enable
Use voice-vlan enable to enable the voice VLAN feature on a port.
Use undo voice-vlan enable to disable the voice VLAN feature on a port.
voice-vlan vlan-id enable
undo voice-vlan [ vlan-id ] enable
The voice VLAN feature is disabled on ports.
vlan-id: Specifies a voice VLAN ID in the range of 2 to 4094.
Use this command only on a hybrid or trunk port operating in automatic voice VLAN assignment mode.
Before you execute this command, make sure the specified VLAN already exists.
# Enable the voice VLAN feature on Ten-GigabitEthernet 1/1/1.
[Sysname-Ten-GigabitEthernet1/1/1] voice-vlan 2 enable
Use voice-vlan mac-address to configure the OUI address information for voice packet identification.
Use undo voice-vlan mac-address to delete an OUI address.
voice-vlan mac-address mac-address mask oui-mask [ description text ]
undo voice-vlan mac-address oui
System default OUI addresses exist.
Table 15 System default OUI addresses
Number
OUI address
Vendor
1
0001-e300-0000
Siemens phone
2
0003-6b00-0000
Cisco phone
3
0004-0d00-0000
Avaya phone
4
000f-e200-0000
H3C Aolynk phone
5
0060-b900-0000
Philips/NEC phone
6
00d0-1e00-0000
Pingtel phone
7
00e0-7500-0000
Polycom phone
8
00e0-bb00-0000
3Com phone
mac-address: Specifies a source MAC address of voice traffic, in the format of H-H-H. For example, 1234-1234-1234.
mask oui-mask: Specifies the valid length of the OUI address by using a mask in the format of H-H-H. The mask contains consecutive 1s and 0s. For example, ffff-0000-0000. To match the voice devices of a vendor, set the mask to ffff-ff00-0000.
description text: Specifies the OUI address description, a case-sensitive string of 1 to 30 characters.
oui: Specifies an OUI address to delete, in the format of H-H-H. For example, 1234-1200-0000. An OUI address is the logical AND result of the mac-address and oui-mask arguments. It cannot be a broadcast address, a multicast address, or an all-zero address.
You can manually delete or add the system default OUI addresses.
The maximum number of configurable OUI addresses depends on the device model.
# Add OUI address 1234-1200-0000 by specifying the MAC address as 1234-1234-1234 and the mask as fff-ff00-0000. Configure the OUI address description as PhoneA.
[Sysname] voice-vlan mac-address 1234-1234-1234 mask ffff-ff00-0000 description PhoneA
Use voice-vlan mode auto to configure a port to operate in automatic voice VLAN assignment mode.
Use undo voice-vlan mode auto to configure a port to operate in manual voice VLAN assignment mode.
A port operates in automatic voice VLAN assignment mode.
S-channel interface/S-channel aggregate interface view
To make a voice VLAN take effect on a port operating in manual mode, you must manually assign the port to the voice VLAN.
# Configure Ten-GigabitEthernet 1/1/1 to operate in manual voice VLAN assignment mode.
[Sysname] interface ten-gigabitethernet 1/1/1
[Sysname-Ten-GigabitEthernet1/1/1] undo voice-vlan mode auto
voice-vlan qos
Use voice-vlan qos to configure a port to modify the CoS and DSCP values for incoming voice VLAN packets.
Use undo voice-vlan qos to restore the default.
voice-vlan qos cos-value dscp-value
undo voice-vlan qos
A port modifies the CoS and DSCP values for incoming voice VLAN packets to 6 and 46, respectively.
cos-value: Specifies a CoS value in the range of 0 to 7. A bigger CoS value represents a higher priority.
dscp-value: Specifies a DSCP value in the range of 0 to 63. A bigger DSCP value represents a higher priority.
You cannot execute this command on a voice VLAN-enabled port. Before you execute this command on a port, you must disable the voice VLAN feature on it.
If you execute both the voice-vlan qos and voice-vlan qos trust commands multiple times, the most recent configuration takes effect.
# Configure Ten-GigabitEthernet 1/1/1 to modify the CoS and DSCP values for voice VLAN packets to 5 and 45, respectively.
[Sysname-Ten-GigabitEthernet1/1/1] voice-vlan qos 5 45
Use voice-vlan qos trust to configure a port to trust the priority settings in incoming voice VLAN packets.
undo voice-vlan qos
When a port trusts the QoS priority settings in incoming voice VLAN packets, the port does not modify their CoS and DSCP values.
# Configure Ten-GigabitEthernet 1/1/1 to trust the priority settings in incoming voice VLAN traffic.
[Sysname-Ten-GigabitEthernet1/1/1] voice-vlan qos trust
voice-vlan qos
Use voice-vlan security enable to enable the voice VLAN security mode.
Use undo voice-vlan security enable to disable the voice VLAN security mode.
The voice VLAN security mode is enabled.
In security mode, a voice VLAN transmits only voice packets whose source MAC addresses match the OUI addresses of the device.
In normal mode, a voice VLAN transmits voice packets and non-voice packets.
# Disable the voice VLAN security mode.
[Sysname] undo voice-vlan security enable
voice-vlan track lldp
Use voice-vlan track lldp to enable LLDP for automatic IP phone discovery.
Use undo voice-vlan track lldp to disable LLDP for automatic IP phone discovery.
LLDP for automatic IP phone discovery is disabled.
# Enable LLDP for automatic IP phone discovery.
[Sysname] voice-vlan track lldp
