01-IRF commands | 157.27 KB |
IRF commands
display irf
Use display irf to display IRF fabric information.
display irf
# Display IRF fabric information.
<Sysname> display irf
MemberID Role Priority CPU-Mac Description
1 Loading 1 00e0-fcbe-3102 F1Num001
*+2 Master 1 00e0-fcb1-ade2 F1Num002
The Bridge MAC of the IRF is: 00e0-fc00-1000
Auto upgrade : yes
Mac persistent : always
Domain ID : 30
IRF mode : normal
MemberID |
IRF member ID: · ID of the master is prefixed with an asterisk (*) sign. · ID of the device where you are logged in is prefixed with a plus (+) sign. |
Role |
Role of the member device in the IRF fabric: · Standby—Subordinate device. · Master—Master device. · Loading—The device is loading software images. |
Priority |
IRF member priority. |
CPU-MAC |
MAC address of the CPU in the device. |
Description you have configured for the member device. · If no description is configured, this field displays a dashed line (-----). · If the description exceeds the maximum number of characters that can be displayed, an ellipsis (…) is displayed in place of the exceeding text. To display the complete description, use the display current-configuration command. |
Auto upgrade |
Status of the software auto-update feature: · yes—Enabled. · no—Disabled. |
MAC persistent |
IRF bridge MAC persistence setting: · 6 min—Bridge MAC address of the IRF fabric remains unchanged for 6 minutes after the address owner leaves. · always—Bridge MAC address of the IRF fabric does not change after the address owner leaves. · no—Bridge MAC address of the current master replaces the original bridge MAC address as soon as the owner of the original address leaves. |
Domain ID |
Domain ID of the IRF fabric. The domain ID you assign to an IRF fabric must uniquely identify the fabric in a multi-IRF fabric network. |
IRF mode |
IRF mode: · enhanced. · normal. |
display irf configuration
display irf topology
Use display irf configuration to display basic IRF settings for each member device.
# Display basic IRF settings for all members.
<Sysname> display irf configuration
MemberID NewID IRF-Port1 IRF-Port2
2 2 Ten-GigabitEthernet2/1/5 Ten-GigabitEthernet2/1/6
5 5 Ten-GigabitEthernet5/1/5 Ten-GigabitEthernet5/1/6
Ten-GigabitEthernet5/1/7
Ten-GigabitEthernet5/1/8
10 10 Ten-GigabitEthernet10/1/5 Ten-GigabitEthernet10/1/6
Ten-GigabitEthernet10/1/7
Ten-GigabitEthernet10/1/8
MemberID |
Current member ID of the device. |
NewID |
Member ID assigned to the device. This member ID takes effect at reboot. |
IRF-Port1 |
Physical interfaces bound to IRF-port 1. This field displays disable if no physical interfaces are bound to the IRF port. |
IRF-Port2 |
Physical interfaces bound to IRF-port 2. This field displays disable if no physical interfaces are bound to the IRF port. |
display irf
display irf link
Use display irf link to display IRF link information.
display irf link
# Display IRF link information.
<Sysname> display irf link
Member 1
IRF Port Interface Status
1 disable --
2 Ten-GigabitEthernet1/1/1 UP
Ten-GigabitEthernet1/1/2 ADM
Ten-GigabitEthernet1/1/3 DOWN
Member 2
1 Ten-GigabitEthernet2/1/1 UP
Ten-GigabitEthernet2/1/2 DOWN
Ten-GigabitEthernet2/1/3 ADM
2 disable --
Member ID |
IRF member ID. |
IRF Port |
IRF port number: · 1—IRF-port 1. · 2—IRF-port 2. |
Physical interfaces bound to the IRF port. This field displays disable if no physical interfaces have been bound to the IRF port. |
Status |
Link state of the IRF physical interface: · UP—The link is up. · DOWN—The link is down. · ADM—The interface has been manually shut down by using the shutdown command. · ABSENT—Expansion interface card that hosts the interface is not present. |
Use display irf topology to display IRF fabric topology information.
# Display the IRF fabric topology.
<Sysname> display irf topology
Topology Info
IRF-Port1 IRF-Port2
MemberID Link neighbor Link neighbor Belong To
1 DOWN --- UP 2 000f-cbb8-1a82
2 UP 1 DIS --- 000f-cbb8-1a82
IRF-Port1 |
Information about IRF-port 1, including its link state and neighbor. |
IRF-Port2 |
Information about IRF-port 2, including its link state and neighbor. |
MemberID |
IRF member ID. |
Link |
Link state of the IRF port: · UP—The IRF link is up. · DOWN—The IRF link is down because the port has no physical link or has not been activated by the irf-port-configuration active command. · DIS—No physical interfaces have been bound to the IRF port. · TIMEOUT—IRF hello interval has timed out. · ISOLATE—The device is isolated from the IRF fabric. This issue might be caused by the following reasons: ? The IRF fabric does not support the device model. ? The maximum number of member devices has exceeded the upper limit. |
neighbor |
IRF member ID of the device connected to the IRF port. This field displays three hyphens (---) if no device is connected to the port. |
Belong To |
IRF fabric that has the device, represented by the CPU MAC address of the master in the IRF fabric. |
display irf
display irf-port load-sharing mode
Use display irf-port load-sharing mode to display IRF link load sharing mode.
display irf-port load-sharing mode [ irf-port [ member-id/irf-port-number ] ]
irf-port: Displays IRF port-specific load sharing modes. If you do not specify this keyword, the command displays the global load sharing mode for IRF links.
member-id/irf-port-number: Specifies an IRF port number. The member-id argument represents an IRF member ID. The irf-port-number argument represents the index number (1 or 2) of the IRF port on the member device. If you do not specify the member-id and irf-port-number arguments, this command displays the load sharing mode used on each IRF port in the IRF fabric. If no IRF ports are in up state, this command displays No IRF link exists.
# Display the global load sharing mode for IRF links. In this example, because no user-defined global load sharing mode has been configured, the default global load sharing mode applies.
<Sysname> display irf-port load-sharing mode
irf-port Load-Sharing Mode:
Layer 2 traffic: packet type-based sharing
Layer 3 traffic: packet type-based sharing
Layer 4 traffic: packet type-based sharing
# Display the global load sharing mode for IRF links. In this example, because a global load sharing mode has been configured, the configured mode applies.
destination-mac address source-mac address
# Display the load sharing mode of IRF-port 1/1. In this example, because neither port-specific load sharing mode nor user-defined global load sharing mode has been configured, the default global load sharing mode applies.
<Sysname> display irf-port load-sharing mode irf-port 1/1
irf-port1/1 Load-Sharing Mode:
# Display the load sharing mode of IRF-port 1/1 after a load sharing mode is configured on the port.
# Display the load sharing mode used on each IRF port.
destination-ip address source-ip address
irf-port1/2 Load-Sharing Mode:
Layer 2 traffic: destination-mac address source-mac address
Layer 3 traffic: destination-ip address source-ip address
Layer 4 traffic: destination-port source-port
Table 5 Command output
irf-port Load-Sharing Mode |
Global load sharing mode for IRF links: · If no global IRF link load sharing mode has been configured, the default global load sharing mode applies. · If a user-defined global load sharing mode has been configured, the configured mode applies. |
irf-port1/1 Load-Sharing Mode |
Link load sharing mode of IRF-port 1/1: · If you have not configured a port-specific load sharing mode, the global IRF link load sharing mode applies. · If you have configured a port-specific load sharing mode, the configured mode applies. |
Layer 2 traffic: packet type-based sharing |
Default load sharing mode for traffic that has no IP header. By default, this type of traffic is distributed based on packet types. |
Layer 3 traffic: packet type-based sharing |
Default load sharing mode for non-TCP/-UDP IP packets. By default, this type of traffic is distributed based on packet types. |
Layer 4 traffic: packet type-based sharing |
Default load sharing mode for TCP/UDP packets. By default, this type of traffic is distributed based on packet types. |
display mad
Use display mad to display MAD status and settings.
display mad [ verbose ]
verbose: Displays detailed MAD information. If you do not specify this keyword, the command only displays whether a MAD mechanism is enabled or disabled.
# Display brief MAD information.
<Sysname> display mad
MAD ARP enabled.
MAD ND enabled.
MAD LACP disabled.
MAD BFD disabled.
# Display detailed MAD information.
<Sysname> display mad verbose
Multi-active recovery state: No
Excluded ports(user-configured):
Vlan-interface999
Excluded ports(system-configured):
Ten-GigabitEthernet1/1/5
Ten-GigabitEthernet1/1/6
Ten-GigabitEthernet1/1/7
Ten-GigabitEthernet1/1/8
Ten-GigabitEthernet2/1/7
Ten-GigabitEthernet2/1/8
MAD ARP enabled interface:
Vlan-interface2
MAD ND enabled interface:
Vlan-interface2
MAD LACP enabled interface: Bridge-Aggregation 1
MAD status : Normal
Member ID Port MAD status
1 Ten-GigabitEthernet1/1/1 Normal
2 Ten-GigabitEthernet2/1/1 Normal
MAD BFD enabled interface: VLAN-interface 3
MAD status : Normal
Member ID MAD IP address Neighbor MAD status
1 192.168.1.1/24 2 Normal
1 192.168.1.1/24 3 Normal
2 192.168.1.2/24 1 Normal
2 192.168.1.2/24 3 Normal
3 192.168.1.3/24 1 Normal
3 192.168.1.3/24 2 Normal
Table 6 Command output
MAD ARP enabled. |
Status of ARP MAD. This field displays MAD ARP disabled if ARP MAD is disabled. |
MAD ND enabled. |
Status of ND MAD. This field displays MAD ND disabled if ND MAD is disabled. |
MAD LACP enabled. |
Status of LACP MAD. This field displays MAD LACP disabled if LACP MAD is disabled. |
MAD BFD enabled. |
Status of BFD MAD. This field displays MAD BFD disabled if BFD MAD is disabled. |
Multi-active recovery state |
Whether the IRF fabric is in Recovery state: · Yes—The IRF fabric is in Recovery state. When MAD detects that an IRF fabric has split into multiple IRF fabrics, it allows one fabric to forward traffic. All the other IRF fabrics are set to the Recovery state. In Recovery state, MAD shuts down all network ports and interfaces in the fabric except for the following ports and interfaces: ? IRF physical interfaces. ? Ports and interfaces configured to not shut down. · No—The IRF fabric is not in Recovery state. It is active and can forward traffic. |
Excluded ports(user-configured) |
Ports and interfaces manually configured to not shut down when the IRF fabric transits to the Recovery state. |
Excluded ports(system-configured) |
Ports and interfaces set to not shut down by default when the IRF fabric transits to the Recovery state. These ports and interfaces are not user configurable. |
MAD status |
MAD operating status: · Normal—The MAD mechanism is operating correctly. · Faulty—The MAD mechanism is not operating correctly. Check the interface or port for connectivity or configuration problems. For example, verify that all member devices have member ports used for LACP MAD. · N/A—MAD link status cannot be detected. This field always displays N/A if BFD MAD is enabled on a management Ethernet port. |
Member ID |
IRF member ID of the local device. |
Port |
Member ports of the aggregate interface used for LACP MAD. |
Neighbor |
IRF member ID of the neighbor member device. |
easy-irf
Use easy-irf to bulk-configure basic IRF settings for an IRF member device.
easy-irf [ member member-id [ renumber new-member-id ] domain domain-id [ priority priority ] [ irf-port1 interface-list1 ] [ irf-port2 interface-list2 ] ]
member member-id: Specifies the member ID of a member device. The value range for the member ID is 1 to 10.
renumber new-member-id: Specifies a new member ID for the device. The value range for the member ID is 1 to 10. The member device automatically reboots for the new member ID to take effect. If you do not specify this option, the command does not change the member ID.
domain domain-id: Specifies an IRF domain ID in the range of 0 to 4294967295. Assign the same domain ID to all devices you are adding to the same IRF fabric.
priority priority: Specifies an IRF priority in the range of 1 to 32. The greater the priority value, the higher the priority. A member with higher priority is more likely to be the master.
irf-port1 interface-list1: Specifies a space-separated list of up to 16 interface items. Each interface item specifies one interface in the interface-type interface-number form. The interfaces are bound to IRF-port 1.
irf-port2 interface-list2: Specifies a space-separated list of up to 16 interface items. Each interface item specifies one interface in the interface-type interface-number form. The interfaces are bound to IRF-port 2. A physical interface can be bound to only one IRF port.
This command bulk-configures basic IRF settings for a member device, including the member ID, domain ID, priority, and IRF port bindings.
The easy IRF feature provides the following configuration methods:
· Interactive method—Enter the easy-irf command without parameters. The system will guide you to set the parameters step by step.
· Non-interactive method—Enter the easy-irf command with parameters.
As a best practice, use the interactive method if you are new to IRF.
If you execute this command multiple times, the following settings take effect:
· The most recent settings for the member ID, domain ID, and priority.
· IRF port bindings added through executions of the command. You can bind a maximum of 16 physical interfaces to an IRF port.
When you specify physical interfaces for an IRF port, you must follow the IRF port binding requirements in Virtual Technologies Configuration Guide.
If you specify physical interfaces by using the interactive method, you must also follow these restrictions and guidelines:
· Do not enter spaces between the interface type and interface number.
· Use a comma (,) to separate two physical interfaces. No spaces are allowed between interfaces.
To remove an IRF physical interface from an IRF port, you must use the undo port group interface command in IRF port view.
# Bulk-configure basic IRF settings by using the non-interactive method. Change the member ID from 2 to 3, set the domain ID to 10, configure the member priority as 10, and bind Ten-GigabitEthernet 2/1/1 through Ten-GigabitEthernet 2/1/4 to IRF-port 1.
[Sysname] easy-irf member 2 renumber 3 domain 10 priority 10 irf-port1 ten-gigabitethernet 2/1/1 ten-gigabitethernet 2/1/2 ten-gigabitethernet 2/1/3 ten-gigabitethernet 2/1/4
Configuration summary for member 2
IRF new member ID: 3
IRF domain ID : 10
IRF priority : 10
IRF-port 1 : Ten-GigabitEthernet2/1/1, Ten-GigabitEthernet2/1/2
Ten-GigabitEthernet2/1/3, Ten-GigabitEthernet2/1/4
IRF-port 2 : Disabled
Are you sure to use these settings to set up IRF? [Y/N] y
Starting to configure IRF...
Configuration succeeded.
The device will reboot for the new member ID to take effect. Continue? [Y/N] y
# Bulk-configure basic IRF settings by using the interactive method. Change the member ID from 3 to 5, set the domain ID to 10, configure the member priority as 10, and bind Ten-GigabitEthernet 3/1/1 through Ten-GigabitEthernet 3/1/4 to IRF-port 1.
[Sysname] easy-irf
Welcome to use easy IRF.
To skip the current step, enter a dot sign (.).
To return to the previous step, enter a minus sign (-).
To use the default value (enclosed in []) for each parameter, press Enter withou
t entering a value.
To quit the setup procedure, press CTRL+C.
Select a member by its ID <3> [3]:3
Specify a new member ID <1~10> [1]: 5
Specify a domain ID <0~4294967295> [0]: 10
Specify a priority <1~32> [1]: 10
Specify IRF-port 1 bindings (a physical interface or a comma-separated physical
interface list)[Disabled]: ten-gigabitethernet3/1/1,ten-gigabitethernet3/1/2,ten-gigabitethernet3/1/3,ten-gigabitethernet3/1/4
Specify IRF-port 2 bindings (a physical interface or a comma-separated physical
Configuration summary for member 3
IRF new member ID: 5
IRF domain ID : 10
IRF priority : 10
IRF-port 1 : Ten-GigabitEthernet3/1/1, Ten-GigabitEthernet3/1/2
Ten-GigabitEthernet3/1/3, Ten-GigabitEthernet3/1/4
irf auto-update enable
Use irf auto-update enable to enable the software auto-update feature.
Use undo irf auto-update enable to disable the software auto-update feature.
Software auto-update is enabled.
This command automatically propagates the current software images of the master device in the IRF fabric to any devices you are adding to the IRF fabric.
To ensure a successful software update, verify that the new device you are adding to the IRF fabric has sufficient storage space for the new software images. If sufficient storage space is not available, the device automatically deletes the current software images. If the reclaimed space is still insufficient, the device cannot complete the auto-update. You must reboot the device, and then access the BootWare menus to delete files.
# Enable the software auto-update feature.
[Sysname] irf auto-update enable
irf domain
Use irf domain to assign a domain ID to the IRF fabric.
Use undo irf domain to restore the default.
irf domain domain-id
undo irf domain
The IRF domain ID is 0.
domain-id: Specifies a domain ID for the IRF fabric. The value range is 0 to 4294967295.
One IRF fabric forms one IRF domain. IRF uses IRF domain IDs to uniquely identify IRF fabrics and prevent IRF fabrics from interfering with one another.
If one IRF fabric uses another IRF fabric as the intermediate device for LACP MAD, ARP MAD, or ND MAD, you must assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
An IRF fabric has only one IRF domain ID. You can change the IRF domain ID by using the following commands: irf domain, mad enable, mad arp enable, or mad nd enable. The IRF domain IDs configured by using these commands overwrite each other.
# Set the IRF domain ID to 10.
[Sysname] irf domain 10
irf link-delay
Use irf link-delay to set a delay for the IRF ports to report a link down event.
Use undo irf link-delay to restore the default.
irf link-delay interval
undo irf link-delay
The delay time is 1 second.
interval: Sets the IRF link down report delay in the range of 0 to 10000 milliseconds. If the interval is set to 0, link down events are reported without any delay.
Make sure the IRF link down report delay is shorter than the maximum CCM lifetime and BFD session lifetime. For more information about CFD and BFD, see High Availability Configuration Guide.
As a best practice, set the delay to 0 seconds in the following situations:
· The IRF fabric requires a fast master/subordinate or IRF link switchover.
· The BFD, BFD MAD, GR, or RRPP feature is used.
# Set the IRF link down report delay to 300 milliseconds.
[Sysname] irf link-delay 300
irf mac-address
Use irf mac-address to specify a MAC address as the IRF bridge MAC address.
Use undo irf mac-address to restore the default.
irf mac-address mac-address
An IRF fabric uses the bridge MAC address of the master device as the IRF bridge MAC address.
mac-address: Specifies a MAC address in the format of H-H-H. The MAC address cannot be the all-zero or all-F MAC address, or a multicast MAC address. You can omit the consecutive zeros at the beginning of each segment. For example, you can enter f-e2-1 for 000f-00e2-0001.
CAUTION: IRF bridge MAC address change causes transient traffic disruption. |
You can specify the bridge MAC address of an existing IRF fabric for a new IRF fabric to replace the existing IRF fabric with transient packet loss.
On a switched LAN, the IRF bridge MAC address must be unique.
After you specify an IRF bridge MAC address, the IRF fabric always uses the specified address as the IRF bridge MAC address.
When IRF fabrics merge, IRF ignores the IRF bridge MAC address and only checks the bridge MAC address of each member device in the IRF fabrics. IRF merge fails if any two member devices have the same bridge MAC address.
After IRF fabrics merge, the merged IRF fabric uses the bridge MAC address of the merging IRF fabric that won the master election as the IRF bridge MAC address.
If an IRF fabric splits after you configure the IRF bridge MAC address, both the split IRF fabrics use the configured bridge MAC address as the IRF bridge MAC address.
# Configure the IRF fabric to use c4ca-d9e0-8c3c as the IRF bridge MAC address.
[Sysname] irf mac-address c4ca-d9e0-8c3c
irf mac-address persistent
Use irf mac-address persistent to configure IRF bridge MAC persistence.
Use undo irf mac-address persistent to enable the IRF fabric to change its bridge MAC address as soon as the address owner leaves.
irf mac-address persistent { always | timer }
The IRF bridge MAC address does not change after the address owner leaves.
always: Enables the IRF bridge MAC address to be permanent. The IRF bridge MAC address does not change after the address owner leaves the fabric.
timer: Enables the IRF bridge MAC address to remain unchanged for 6 minutes after the address owner leaves. If the owner rejoins the IRF fabric with the time limit, the IRF bridge MAC address does not change. If the owner does not rejoin the IRF fabric within the time limit, the IRF fabric uses the bridge MAC address of the current master as the bridge MAC address.
If the undo form of this command is configured, bridge MAC address of the current master replaces the original IRF bridge MAC as soon as the original address owner leaves.
If ARP MAD or ND MAD is used with the spanning tree feature, you must configure IRF bridge MAC persistence by using the undo irf mac-address persistent command. Do not specify a MAC address as the IRF bridge MAC address.
If TRILL is used, configure IRF bridge MAC persistence by using the irf mac-address persistent always command or specify a MAC address as the IRF bridge MAC address. The setting avoids unnecessary traffic disruption caused by IRF bridge MAC address changes on the TRILL network.
If the IRF fabric has cross-member aggregate links, do not use the undo irf mac-address persistent command to avoid unnecessary traffic disruption.
By default, an IRF fabric uses the bridge MAC address of the master device as its bridge MAC address.
On a switched LAN, the IRF bridge MAC address must be unique for correct traffic transmission.
# Enable the IRF bridge MAC address to persist forever.
[Sysname] irf mac-address persistent always
irf member description
Use irf member description to configure a description for an IRF member device.
Use undo irf member description to restore the default.
irf member member-id description text
undo irf member member-id description
No description is configured for an IRF member device.
member-id: Specifies the ID of an IRF member.
text: Specifies a description, a string of 1 to 127 characters.
# Configure the description as F1Num001 for IRF member 1.
[Sysname] irf member 1 description F1Num001
irf member priority
Use irf member priority to change the priority of an IRF member device.
Use undo irf member priority to restore the default.
irf member member-id priority priority
undo irf member member-id priority
The IRF member priority is 1.
member-id: Specifies an IRF member ID. The value range for IRF member IDs is 1 to 10.
priority: Sets priority in the range of 1 to 32. The greater the priority value, the higher the priority. A member with higher priority is more likely to be the master.
The new priority setting takes effect at the next master election, but it does not trigger a master election.
# Set the priority of IRF member 2 to 32.
[Sysname] irf member 2 priority 32
irf member renumber
Use irf member renumber to change the member ID of an IRF member device.
Use undo irf member renumber to restore the previous IRF member ID of the device.
irf member member-id renumber new-member-id
undo irf member member-id renumber
The IRF member ID is 1.
member-id: Specifies the ID of an IRF member. The value range for IRF member IDs is 1 to 10.
new-member-id: Assigns a new ID to the IRF member. The value range for IRF member IDs is 1 to 10.
CAUTION: IRF member ID change can invalidate member ID-related settings, including interface and file path settings, and cause data loss. Make sure you fully understand its impact on your live network. |
To have the new ID take effect, you must reboot the IRF member. To cancel the member ID change before you reboot the member device, use the undo irf member renumber command. In the command, set the new member ID to be the same as the old member ID.
When adding a device into an IRF fabric, you must assign a unique IRF member ID to the device. If its IRF member ID has been used in the IRF fabric, the device cannot join the IRF fabric.
Interchanging member IDs between IRF member devices might cause undesirable configuration changes and data loss. For example, the IRF member IDs of Device A and Device B are 2 and 3, respectively. After you interchange their member IDs, their port settings also interchange.
# Change the ID of an IRF member device from 1 to 2.
[Sysname] irf member 1 renumber 2
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]Y
# Before rebooting the device, cancel the change in the preceding example.
[Sysname] undo irf member 1 renumber
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]y
If you reboot the device after executing the irf member 1 renumber 2 command, the device member ID changes to 2 at system reboot. Using undo irf member 1 renumber cannot restore the member ID to 1. You must use the irf member 2 renumber 1 command to reconfigure the member ID.
irf-port
Use irf-port to enter IRF port view.
Use undo irf-port to remove all port bindings on an IRF port.
irf-port member-id/irf-port-number
undo irf-port member-id/irf-port-number
member-id: Specifies an IRF member device by its member ID.
irf-port-number: Specifies an IRF port on the member device. The irf-port-number argument represents the IRF port index and must be 1 or 2.
To bind physical interfaces to an IRF port, you must enter IRF port view.
# Enter IRF-port 2/1 view.
[Sysname] irf-port 2/1
[Sysname-irf-port2/1]
irf-port global load-sharing mode
Use irf-port global load-sharing mode to set the global load sharing mode for IRF links.
Use undo irf-port global load-sharing mode to restore the default.
irf-port global load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
The following are criteria for distributing different types of packets across IRF links:
· TCP/UDP packets—Source and destination TCP/UDP port numbers.
· Non-TCP/-UDP IP packets—Source and destination IP addresses.
· Non-IP packets (packets without an IP header)—Source and destination MAC addresses.
destination-ip: Distributes traffic across IRF member links based on destination IP address.
destination-mac: Distributes packets across IRF member links based on destination MAC address.
ingress-port: Distributes packets across IRF member links based on incoming port.
source-ip: Distributes packets across IRF member links based on source IP address.
source-mac: Distributes packets across IRF member links based on source MAC address.
The global IRF link load sharing mode applies to all IRF ports in the IRF fabric. You can configure the sharing mode to include a combination of multiple criteria for making traffic distribution decisions. If your device does not support a criterion combination, the system displays an error message.
If you configure the global load sharing mode multiple times, the most recent configuration takes effect.
You can also configure a port-specific load sharing mode for an IRF port in IRF port view by using the irf-port load-sharing mode command.
An IRF port preferentially uses the port-specific load sharing mode. If no port-specific load sharing mode is available, the port uses the global load sharing mode.
# Configure the global IRF link load sharing mode to distribute traffic based on destination MAC address.
[Sysname] irf-port global load-sharing mode destination-mac
Use irf-port load-sharing mode to configure a port-specific load sharing mode for an IRF port to distribute traffic across its physical links.
Use undo irf-port load-sharing mode to restore the default.
irf-port load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
IRF port view
To successfully configure a port-specific load sharing mode for an IRF port, make sure you have bound a minimum of one physical interface to the IRF port.
You can configure an IRF port-specific load sharing mode to include a combination of multiple criteria for making traffic distribution decisions. If your device does not support a criterion combination, the system displays an error message.
If you configure the port-specific load sharing mode multiple times on an IRF port, the most recent configuration takes effect.
# Configure a port-specific load sharing mode for IRF-port 1/1 to distribute traffic based on destination MAC address.
[Sysname] irf-port 1/1
[Sysname-irf-port1/1] irf-port load-sharing mode destination-mac
Use irf-port-configuration active to activate IRF ports.
After connecting the physical interfaces between two devices and binding them to the correct IRF ports, you must use this command to activate the settings on the IRF ports. This command merges the two devices into one IRF fabric.
The system activates the IRF port settings automatically in the following situations:
· The configuration file that the device starts with contains IRF port bindings.
· You are binding physical interfaces to an IRF port after an IRF fabric is formed.
To configure and activate IRF-port 1/2 when the port is in DIS state:
# Bind Ten-GigabitEthernet 1/1/1 to IRF-port 1/2.
[Sysname] interface ten-gigabitethernet 1/1/1
[Sysname-Ten-GigabitEthernet1/1/1] shutdown
[Sysname-Ten-GigabitEthernet1/1/1] quit
[Sysname] irf-port 1/2
[Sysname-irf-port1/2] port group interface Ten-GigabitEthernet 1/1/1
You must perform the following tasks for a successful IRF setup:
Save the configuration after completing IRF configuration.
Execute the "irf-port-configuration active" command to activate the IRF ports.
[Sysname-irf-port1/2] quit
[Sysname-Ten-GigabitEthernet1/1/1] undo shutdown
# Save the configuration so the IRF port settings can take effect after the device reboots.
[Sysname] save
Validating file. Please wait............................
Slot 1:
Save next configuration file successfully.
Configuration is saved to device successfully.
# Activate the IRF port.
[Sysname] irf-port-configuration active
mad arp enable
Use mad arp enable to enable ARP MAD.
Use undo mad arp enable to disable ARP MAD.
mad arp enable
undo mad arp enable
Management Ethernet interface view
VLAN interface view
Do not configure ARP MAD together with LACP MAD, because they handle collisions differently.
Do not configure ARP MAD together with BFD MAD. ARP MAD requires the spanning tree feature, but BFD MAD is mutually exclusive with the spanning tree feature. At the same time, ARP MAD handles collisions differently than BFD MAD.
When you configure ARP MAD that uses common Ethernet ports, follow these restrictions and guidelines:
Category |
Restrictions and guidelines |
ARP MAD VLAN |
· Do not enable ARP MAD on VLAN-interface 1. · If you are using an intermediate device, perform the following tasks on both the IRF fabric and the intermediate device: ? Create a VLAN and VLAN interface for ARP MAD. ? Assign the ports of ARP MAD links to the ARP MAD VLAN. · As a best practice, do not use the ARP MAD VLAN for any other purposes. |
ARP MAD and feature configuration |
If an intermediate device is used, make sure the following requirements are met: · Run the spanning tree feature between the IRF fabric and the intermediate device to ensure that there is only one ARP MAD link in forwarding state. For more information about the spanning tree feature and its configuration, see Layer 2—LAN Switching Configuration Guide. · Enable the IRF fabric to change its bridge MAC address as soon as the address owner leaves. · If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection. |
When you configure ARP MAD that uses management Ethernet ports, follow these restrictions and guidelines:
Category |
Management Ethernet ports for ARP MAD |
Connect the management Ethernet port on each member device to the common Ethernet ports on the intermediate device. |
ARP MAD VLAN |
On the intermediate device, create a VLAN for ARP MAD, and assign the ports used for ARP MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN. |
When you use the mad arp enable command, the system prompts you to enter a domain ID. If you do not want to change the current domain ID, press enter at the prompt.
# Enable ARP MAD on VLAN-interface 3.
[Sysname] interface vlan-interface 3
[Sysname-Vlan-interface3] mad arp enable
[Current domain is: 0]: 1
The assigned domain ID is: 1
irf domain
mad bfd enable
Use mad bfd enable to enable BFD MAD.
Use undo mad bfd enable to disable BFD MAD.
mad bfd enable
undo mad bfd enable
VLAN interface view
Do not configure BFD MAD together with ARP MAD or ND MAD. BFD MAD is mutually exclusive with the spanning tree feature, but ARP MAD and ND MAD require the spanning tree feature. At the same time, BFD MAD handles collisions differently than ARP MAD and ND MAD.
When you configure BFD MAD that uses common Ethernet ports, follow these guidelines:
Category |
BFD MAD VLAN |
· Do not enable BFD MAD on VLAN-interface 1. · If you are using an intermediate device, perform the following tasks on both the IRF fabric and the intermediate device: ? Create a VLAN and VLAN interface for BFD MAD. ? Assign the ports of BFD MAD links to the BFD MAD VLAN. · Make sure the IRF fabrics on the network use different BFD MAD VLANs. · Make sure the BFD MAD VLAN contains only ports on the BFD MAD links. Exclude a port from the BFD MAD VLAN if the port is not on the BFD MAD link. For example, if you have assigned the port to all VLANs by using the port trunk permit vlan all command, use the undo port trunk permit command to exclude the port from the BFD MAD VLAN. |
BFD MAD VLAN and feature compatibility |
Do not use the BFD MAD VLAN for any purposes other than configuring BFD MAD. · Configure only the mad bfd enable and mad ip address commands on the BFD MAD-enabled VLAN interface. If you configure other features, both BFD MAD and other features on the interface might run incorrectly. · Disable the spanning tree feature on any Layer 2 Ethernet ports in the BFD MAD VLAN. The MAD feature is mutually exclusive with the spanning tree feature. |
MAD IP address |
· To avoid problems, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled VLAN interface. Do not configure an IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled VLAN interface. · Make sure all the MAD IP addresses are on the same subnet. |
When you configure BFD MAD that uses management Ethernet ports, follow these restrictions and guidelines:
Category |
Management Ethernet ports for BFD MAD |
BFD MAD VLAN |
· On the intermediate device, create a VLAN for BFD MAD, and assign the ports used for BFD MAD to the VLAN. On the IRF fabric, you do not need to assign the management Ethernet ports to the VLAN. · Make sure the IRF fabrics on the network use different BFD MAD VLANs. · Make sure the BFD MAD VLAN on the intermediate device contains only ports on the BFD MAD links. |
MAD IP address |
· Use the mad ip address command instead of the ip address command to configure MAD IP addresses on the BFD MAD-enabled management Ethernet ports. · Make sure all the MAD IP addresses are on the same subnet. |
# Enable BFD MAD on VLAN-interface 3.
[Sysname-Vlan-interface3] mad bfd enable
mad enable
Use mad enable to enable LACP MAD.
Use undo mad enable to disable LACP MAD.
mad enable
undo mad enable
Aggregate interface view
LACP MAD handles collisions differently than ARP MAD and ND MAD. To avoid conflicts, do not enable LACP MAD together with ARP MAD and ND MAD on an IRF fabric.
LACP MAD requires an H3C device that supports extended LACPDUs to act as the intermediate device. You must set up a dynamic link aggregation group that spans all IRF member devices between the IRF fabric and the intermediate device. To enable dynamic link aggregation, configure the link-aggregation mode dynamic command on the aggregate interface.
If one IRF fabric uses another IRF fabric as the intermediate device for LACP MAD, you must assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
When you use the mad enable command, the system prompts you to enter a domain ID. If you do not want to change the current domain ID, press enter at the prompt.
# Enable LACP MAD on Bridge-Aggregation 1, a Layer 2 dynamic aggregate interface.
[Sysname-Bridge-Aggregation1] mad enable
MAD LACP only enable on dynamic aggregation interface.
# Enable LACP MAD on Route-Aggregation 1, a Layer 3 dynamic aggregate interface.
[Sysname-Route-Aggregation1] link-aggregation mode dynamic
[Sysname-Route-Aggregation1] mad enable
irf domain
mad exclude interface
Use mad exclude interface to exclude a network port or interface from being shut down when the IRF fabric transits to the Recovery state upon detection of a multi-active collision.
Use undo mad exclude interface to configure the IRF fabric to shut down a network port or interface when it transits to the Recovery state upon detection of a multi-active collision.
mad exclude interface interface-type interface-number
undo mad exclude interface interface-type interface-number
All network ports and interfaces except the IRF physical interfaces and console ports shut down when the IRF fabric transits to the Recovery state.
interface-type interface-number: Specifies a port or interface by its type and number.
If a port or interface must be kept in up state for special purposes such as Telnet connection, exclude the port or interface from the shutdown action. As a best practice to avoid incorrect traffic forwarding, do not exclude any ports or interfaces except for the ports used for Telnet.
Do not exclude the following ports and interfaces from the shutdown action:
· Aggregate interfaces used for MAD and their member ports.
· VLAN interfaces used for MAD and the Ethernet ports in the VLANs.
· Management Ethernet ports used for MAD.
The ports and interfaces that have been shut down by MAD come up when the member devices reboot to join the recovered IRF fabric. If auto recovery fails because the current master fails or any other exception occurs, use the mad restore command to manually recover the member devices and bring up the ports and interfaces.
# Exclude Ten-GigabitEthernet 1/1/1 from being shut down when the MAD status transits to Recovery.
[Sysname] mad exclude interface ten-gigabitethernet 1/1/1
mad restore
mad ip address
Use mad ip address to assign a MAD IP address to an IRF member device for BFD MAD.
Use undo mad ip address to delete the MAD IP address for an IRF member device.
mad ip address ip-address { mask | mask-length } member member-id
undo mad ip address ip-address { mask | mask-length } member member-id
No MAD IP address is configured for an IRF member device.
VLAN interface view
ip-address: Specifies an IP address in dotted decimal notation.
mask: Specifies a subnet mask in decimal dotted notation.
mask-length: Specifies a subnet mask in length, in the range of 0 to 32.
member member-id: Specifies the ID of an IRF member.
To use BFD MAD, configure a MAD IP address for each IRF member. Make sure all the MAD IP addresses are on the same subnet.
Do not configure a MAD IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled port or interface.
The master attempts to establish BFD sessions with other member devices by using its MAD IP address as the source IP address.
· If the IRF fabric is integrated, only the MAD IP address of the master takes effect. The master cannot establish a BFD session with any other member. If you execute the display bfd session command, the state of the BFD sessions is Down.
· When the IRF fabric splits, the IP addresses of the masters in the partitioned IRF fabrics take effect. The masters can establish a BFD session. If you execute the display bfd session command, the state of the BFD session between the two devices is Up.
# Assign a MAD IP address to IRF member 1 on VLAN-interface 3.
[Sysname-Vlan-interface3] mad ip address 192.168.0.1 255.255.255.0 member 1
# Assign a MAD IP address to IRF member 2 on VLAN-interface 3.
[Sysname-Vlan-interface3] mad ip address 192.168.0.2 255.255.255.0 member 2
mad bfd enable
mad nd enable
Use mad nd enable to enable ND MAD.
Use undo mad nd enable to disable ND MAD.
mad nd enable
undo mad nd enable
ND MAD is disabled.
VLAN interface view
Do not configure ND MAD together with LACP MAD, because they handle collisions differently.
Do not configure ND MAD together with BFD MAD. ND MAD requires the spanning tree feature, but BFD MAD is mutually exclusive with the spanning tree feature. At the same time, ND MAD handles collisions differently than BFD MAD.
Do not configure ND MAD on VLAN-interface 1.
If one IRF fabric uses another IRF fabric as the intermediate device for ND MAD, you must assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
When you use the mad nd enable command, the system prompts you to enter a domain ID. If you do not want to change the current domain ID, press enter at the prompt.
# Enable ND MAD on VLAN-interface 3.
[Sysname-Vlan-interface3] mad nd enable
irf domain
mad restore
Use mad restore to restore the normal MAD state of the IRF fabric in Recovery state.
mad restore
If the active IRF fabric has failed to work before the IRF split problem is fixed, use this command to restore an IRF fabric in Recovery state. The recovered IRF fabric will take over the active IRF fabric role.
# Restore the normal MAD state of the IRF fabric in Recovery state.
[Sysname] mad restore
This command will restore the device from multi-active conflict state. Continue? [Y/N]:Y
Restoring from multi-active conflict state, please wait...
Use port group interface to bind a physical interface to an IRF port.
Use undo port group interface to remove the binding of a physical interface to an IRF port.
port group interface interface-type interface-number [ mode { enhanced | extended } ]
undo port group interface interface-name
No physical interfaces are bound to an IRF port.
IRF port view
interface-type interface-number: Specifies a physical interface by its type and number.
interface-name: Specifies a physical interface in the interface-typeinterface-number format. No space is allowed between the interface-type and interface-number arguments.
mode: Specifies a binding mode for the IRF physical interface.
enhanced: Sets the binding mode to enhanced.
extended: Sets the binding mode to extended. This keyword is not supported in the current software version.
Execute this command multiple times to bind multiple physical interfaces to an IRF port. You can bind a maximum of 16 physical interfaces to an IRF port.
Use the shutdown command to shut down a physical interface before you bind it to or remove it from an IRF port. To bring up the physical interface after a binding or binding removal operation, use the undo shutdown command.
The system does not dynamically remove IRF port bindings when IRF links are lost, for example, because an expansion interface card is removed. To remove IRF port bindings, you must use the undo port group interface command.
For more information about IRF port binding requirements, see Virtual Technologies Configuration Guide.
# Bind Ten-GigabitEthernet 1/1/1 to IRF-port 1/1 on IRF member 1.
[Sysname-irf-port1/1] port group interface ten-gigabitethernet 1/1/1
[Sysname-irf-port1/1] quit
irf-port
IRF 3 commands
associate
Use associate to assign a virtual slot number to a PEX.
Use undo associate to remove the virtual slot number of a PEX.
associate associated-id
undo associate
A PEX is not assigned a virtual slot number.
PEX port view
associated-id: Specifies a virtual slot number. The value range for this argument is 100 to 159. If S5130-EI PEXs exist, the value range changes to 100 to 129.
You must assign a unique virtual slot number to each PEX.
You cannot change the slot number of a PEX while it is starting up.
An operating PEX will reboot if you change or remove its slot number.
If you execute this command multiple times on a PEX port, the most recent configuration takes effect.
# Assign virtual slot 101 to the PEX attached to PEX port 2.
[Sysname] pex-port 2
[Sysname-pex-port2] associate 101
display pex-port
description
Use description to configure the description of a PEX port.
The description of a PEX port uses the pex-port pex-number format (for example, pex-port 0002).
PEX port view
text: Specifies a description, a case-sensitive string of 1 to 79 characters.
# Configure the description as connettodep2 for PEX port 2.
[Sysname-pex-port2] description connecttodep2
display pex-port
display pex working-mode
Use display pex working-mode to display the operating mode settings of devices in the IRF 3 system.
display pex working-mode { all | slot slot-number1 [ to slot-number2 ] }
all: Specifies all parent devices and PEXs.
slot slot-number1: Specifies a parent device by its IRF member ID or a PEX by its virtual slot number.
slot slot-number1 to slot-number2: Specifies a range of parent devices or PEXs. The slot-number1 argument represents the start IRF member ID or PEX slot number. The slot-number2 argument represents the end IRF member ID or PEX slot number. The value for the slot-number2 argument must be greater than or equal to the value for the slot-number1 argument.
# Display the operating mode settings for all parent devices and PEXs.
<Sysname> display pex working-mode all
Parent device mode Configuration:
Auto mode:
Slots 1 to 3
Switch mode:
None
PEX mode at startup:
None
PEX device mode Configuration:
Switch mode at startup:
None
Slots 100 to 103
Table 7 Command output
Parent device mode Configuration |
Displays the operating mode settings for the parent devices. |
Auto mode |
Displays parent devices that operate in auto mode. |
Switch mode |
Displays parent devices that operate in switch mode. |
PEX mode at startup |
Displays parent devices that will operate in PEX mode after a reboot. |
PEX device mode Configuration |
Displays the operating mode configuration for PEXs. |
Switch mode at startup |
Displays PEXs that will operate in switch mode after a reboot. |
Displays PEXs that will operate in PEX mode after a reboot. |
display pex-port
Use display pex-port to display information about PEX ports.
display pex-port [ pex-port-id ] [ verbose ]
pex-port-id: Specifies the port number of a PEX port. If you do not specify a PEX port, the command displays information about all PEX ports.
verbose: Displays detailed information about PEX ports. If you do not specify this keyword, the command displays brief information about PEX ports.
# Display brief information about all PEX ports.
<Sysname> display pex-port
PEX port 2:
Description: pex-port 0002
Associated slot numbers: 1
Slot PEX status
*100 Online
PEX port 3:
Description: pex-port 0003
Slot PEX status
*101 Offline
# Display detailed information about all PEX ports.
<Sysname> display pex-port verbose
PEX port 2:
Slot PEX status
*100 Online
Member interfaces: 3
Member interface Status Peer interface
XGE1/1/2 Down --
XGE1/1/3 Down --
XGE1/1/4 Forwarding PEX100/0/51
Table 8 Command output
PEX port description. |
Group |
PEX port group to which the PEX port is assigned. This field is displayed if the PEX port is connected to a PEX stack. |
Associated slot numbers |
Number of virtual slots assigned to PEXs on the PEX port. |
Slot |
Virtual slot number of a PEX attached to the PEX port. The virtual slot number of the PEX is prefixed with an asterisk (*). This field displays No associated ID if no virtual slot number has been assigned on the PEX port. |
PEX status |
PEX status: · Online—The PEX is online. · Offline—The PEX is offline. · Loading—The PEX is starting up. |
Member interfaces |
Number of PEX physical interfaces that are assigned to the PEX port. |
Member interface |
Physical interface assigned to the PEX port on the parent fabric. |
Status |
PEX link status: · Forwarding—The PEX link is operating correctly and can forward data traffic. · Down—The PEX link is disconnected and cannot forward any packets. · Blocked—The PEX link cannot forward any packets except for IRF 3 packets. |
Peer interface |
PEX physical interface on the PEX. This field displays two hyphens (--) if the system cannot obtain the interface name. |
No member interfaces. |
No physical interfaces have been assigned to the PEX port. |
irf mode
Use irf mode to configure the IRF mode.
Use undo irf mode to remove the IRF mode configuration.
irf mode { enhanced | normal }
undo irf mode enhanced
The IRF mode is normal.
enhanced: Specifies enhanced IRF mode. In this mode, the device can operate as a parent device in an IRF 3 system. This mode supports a maximum of two parent devices and 30 PEXs.
normal: Specifies normal IRF mode. In this mode, IRF 3 capability is disabled. The device can only form an independent IRF fabric with other devices.
The command setting takes effect on all IRF member devices in an IRF fabric.
For a success IRF merge, make sure all IRF member devices operate in the same IRF mode.
For the mode change to take effect, save the configuration and reboot the device.
# Set the IRF mode to enhanced.
[Sysname] irf mode enhanced
pex-port
Use pex-port to create a PEX port and enter its view, or enter the view of an existing PEX port.
Use undo pex-port to delete a PEX port.
pex-port pex-port-id
undo pex-port pex-port-id
No PEX ports exist.
pex-port-id: Specifies a PEX port number. The value range for the port number is 1 to 120.
PEX ports are logical ports for managing PEXs.
Each PEX must be assigned to a PEX port. All PEX settings for a PEX are configured on its PEX port.
Before you delete a PEX port, check its state. If the PEX port is in Online state, the delete operation will cause the attached PEX to reboot.
# Create PEX port 2.
[Sysname-pex-port2]
display pex-port
pex-port load-sharing mode
Use pex-port load-sharing mode to configure a PEX link load sharing mode for a PEX port to distribute traffic across its physical links.
Use undo pex-port load-sharing mode to restore the default.
pex-port load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
The following are criteria for distributing different types of packets across PEX links:
PEX port view
destination-ip: Distributes traffic across PEX member links based on destination IP address.
destination-mac: Distributes packets across PEX member links based on destination MAC address.
ingress-port: Distributes packets across PEX member links based on incoming port.
source-ip: Distributes packets across PEX member links based on source IP address.
source-mac: Distributes packets across PEX member links based on source MAC address.
To successfully configure a PEX link load sharing mode for a PEX port, make sure you have bound a minimum of one physical interface to the PEX port.
You can configure a PEX link load sharing mode to include a combination of multiple criteria for making traffic distribution decisions. If your device does not support a criterion combination, the system displays an error message.
If you configure the PEX link load sharing mode multiple times on a PEX port, the most recent configuration takes effect.
# Configure a PEX link load sharing mode for PEX port 1 to distribute traffic based on destination MAC address.
[Sysname] pex-port 1
[Sysname-pex-port1] pex-port load-sharing mode destination-mac
Use port group interface to assign a physical interface to a PEX port on the parent fabric.
Use undo port group interface to remove a physical interface from a PEX port.
No physical interfaces are assigned to a PEX port.
PEX port view
Execute this command multiple times to bind multiple physical interfaces to a PEX port. You can bind a maximum of six physical interfaces to a PEX port. The physical interfaces are aggregated automatically for backup and load balancing. The default configuration is automatically restored on the interfaces after the assignment.
You must connect a PEX port's all physical interfaces to the same PEX.
If a physical interface has been assigned to a PEX port, you cannot assign the interface to any other PEX port.
A PEX port must have a minimum of one physical interface in Forwarding state for its PEX to communicate with the parent fabric. If a PEX port has only one physical interface in Forwarding state, the PEX will reboot if any of the following events occur:
· The interface is removed from the PEX port.
· The interface goes down.
For more information about IRF physical interface requirements, see Virtual Technologies Configuration Guide.
# Assign physical interface Ten-GigabitEthernet 1/1/1 to PEX port 3.
[Sysname] pex-port 3
[Sysname-pex-port3] port group interface ten-gigabitethernet 1/1/1
# Assign physical interface Ten-GigabitEthernet 1/1/6 to PEX port 4. In this example, Ten-GigabitEthernet 1/1/5 to Ten-GigabitEthernet1/1/8 are in the same port group.
[Sysname] interface range name pex interface ten-gigabitethernet 1/1/5 to ten-gigabitethernet 1/1/8
[Sysname-if-range-pex] shutdown
[Sysname-if-range-pex] quit
[Sysname] pex-port 4
[Sysname-pex-port4] port group interface ten-gigabitethernet 1/1/6
[Sysname-pex-port4] quit
[Sysname-if-range-pex] undo shutdown
display pex-port
