06-Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R7523P01-6W10006-Layer 3 - IP Routing Configuration Guide
11-IPv6 IS-IS configuration
11-IPv6 IS-IS configuration 213.9 KB
Configuring IPv6 IS-IS
Overview
IPv6 IS-IS supports all IPv4 IS-IS features except that it advertises IPv6 routing information. This chapter describes only IPv6 IS-IS specific configuration tasks. For information about IS-IS, see "Configuring IS-IS."
Intermediate System-to-Intermediate System (IS-IS) supports multiple network protocols, including IPv6. To support IPv6, the IETF added two type-length-values (TLVs) and a new network layer protocol identifier (NLPID).
The TLVs are as follows:
·     IPv6 Reachability—Contains routing prefix and metric information to describe network reachability and has a type value of 236 (0xEC).
·     IPv6 Interface Address—Same as the "IP Interface Address" TLV in IPv4 ISIS, except that the 32-bit IPv4 address is translated to the 128-bit IPv6 address.
The new NLPID is an 8-bit field that identifies which network layer protocol is supported. For IPv6, the NLPID is 142 (0x8E), which must be carried in hello packets sent by IPv6 IS-IS.
Configuring basic IPv6 IS-IS
Before you configure basic IPv6 IS-IS, complete the following tasks:
·     Configure IPv6 addresses for interfaces to ensure IPv6 connectivity between neighboring nodes.
·     Enable IS-IS.
Basic IPv6 IS-IS configuration can implement the interconnection of IPv6 networks.
To configure basic IPv6 IS-IS:
Step
Remarks
N/A
2.     Enable an IS-IS process and enter IS-IS view.
By default, no IS-IS process is enabled.
3.     Configure the network entity title (NET) for the IS-IS process.
network-entity net
By default, no NET is configured.
4.     Create the IPv6 address family and enter its view.
By default, no IS-IS IPv6 address family exists.
5.     Return to IS-IS view.
N/A
6.     Return to system view.
N/A
7.     Enter interface view.
N/A
8.     Enable IPv6 for IS-IS on the interface.
isis ipv6 enable [ process-id ]
By default, IPv6 is disabled for IS-IS on an interface.
Configuring IPv6 IS-IS route control
Before you configure IPv6 IS-IS route control, complete basic IPv6 IS-IS configuration.
To configure IPv6 IS-IS route control:
Step
Remarks
N/A
2.     Enter IS-IS view.
N/A
3.     Enter IS-IS IPv6 address family view.
N/A
4.     Specify a preference for IPv6 IS-IS routes.
preference { route-policy route-policy-name | preference } *
By default, the default setting is 15.
5.     Configure an IPv6 IS-IS summary route.
summary ipv6-prefix prefix-length [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
By default, no IPv6 IS-IS summary route is configured.
6.     Configure IPv6 IS-IS to advertise a default route.
default-route-advertise [ avoid-learning | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, IPv6 IS-IS does not advertise Level-1 and Level-2 default routes.
7.     Configure IPv6 IS-IS to filter redistributed routes.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
By default, IPv6 IS-IS does not filter redistributed routes.
This command is usually used together with the import-route command.
8.     Configure IPv6 IS-IS to filter received routes.
filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import
By default, IPv6 IS-IS does not filter received routes.
9.     Configure IPv6 IS-IS to redistribute routes from another routing protocol.
import-route protocol [ as-number | process-id ] [ allow-ibgp ] [ allow-direct | cost cost-value | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, IPv6 IS-IS does not redistribute routes from any other routing protocol.
10.     Configure the maximum number of redistributed Level 1/Level 2 IPv6 routes.
import-route limit number
By default, the maximum number of redistributed Level 1/Level 2 IPv6 routes is not configured.
11.     Configure route advertisement from Level-2 to Level-1.
import-route isisv6 level-2 into level-1 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
By default, IPv6 IS-IS does not advertise routes from Level-2 to Level-1.
12.     Configure route advertisement from Level-1 to Level-2.
import-route isisv6 level-1 into level-2 [ filter-policy { ipv6-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
By default, IPv6 IS-IS advertises routes from Level-1 to Level-2.
13.     Specify the maximum number of ECMP routes for load balancing.
maximum load-balancing number
By default, the maximum number of ECMP routes equals the maximum number of ECMP routes supported by the system.
Configuring IPv6 IS-IS link cost
Configuring an IPv6 IS-IS cost for an interface
Step
Remarks
N/A
N/A
3.     Specify an IS-IS cost style.
By default, the IS-IS cost type is narrow.
4.     Enter IPv6 address family view.
N/A
5.     Enable IPv6 IS-IS MTR.
multi-topology [ compatible ]
By default, IPv6 IS-IS MTR is disabled.
6.     Return to IS-IS view.
N/A
7.     Return to system view.
N/A
8.     Enter interface view.
N/A
9.     Enable IPv6 for IS-IS on the interface.
10.     Specify an IPv6 cost for the IS-IS interface.
isis ipv6 cost
By default, no IPv6 cost is specified for the interface.
Configuring a global IPv6 IS-IS cost
Step
Remarks
N/A
N/A
cost-style { wide | wide-compatible | compatible }
By default, the IS-IS cost style is narrow.
N/A
6.     Specify a global IPv6 IS-IS cost.
circuit-cost cost-value [ level-1 | level-2 ]
By default, no global IPv6 cost is specified.
Enabling automatic link cost calculation
Step
Remarks
N/A
N/A
cost-style { wide | wide-compatible }
N/A
6.     Enable automatic IPv6 IS-IS cost calculation.
auto-cost enable
By default, automatic IPv6 IS-IS cost calculation is disabled.
7.     (Optional.) Configure a bandwidth reference value for automatic IPv6 IS-IS cost calculation.
bandwidth-reference value
The default setting is 100 Mbps.
Tuning and optimizing IPv6 IS-IS networks
Configuration prerequisites
Before you tune and optimize IPv6 IS-IS networks, complete basic IPv6 IS-IS tasks.
Assigning a convergence priority to IPv6 IS-IS routes
A topology change causes IS-IS routing convergence. To improve convergence speed, you can assign convergence priorities to IPv6 IS-IS routes. Convergence priority levels are critical, high, medium, and low. The higher the convergence priority, the faster the convergence speed.
By default, IPv6 IS-IS host routes have medium convergence priority, and other IPv6 IS-IS routes have low convergence priority.
To assign a convergence priority to specific IPv6 IS-IS routes:
Step
Remarks
N/A
N/A
N/A
6.     Assign a convergence priority to specific IPv6 IS-IS routes.
·     Method 1:
prefix-priority
{ critical | high | medium } { prefix-list prefix-list-name | tag tag-value }
·     Method 2:
prefix-priority route-policy
route-policy-name
By default, IPv6 IS-IS routes, except IPv6 IS-IS host routes, have the low convergence priority.
Setting the LSDB overload bit
Step
Remarks
N/A
N/A
N/A
6.     Set the overload bit.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 | wait-for-bgp4+ [ timeout3 ] ] ] [ allow { external | interlevel } * ]
By default, the overload bit is not set.
Configuring a tag value on an interface
When IS-IS advertises an IPv6 prefix with a tag value, it adds the tag to the IPv6 reachability information TLV, regardless of the link cost style.
To configure a tag value on an interface:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Configure a tag value on the interface.
isis ipv6 tag tag
By default, no tag value is configured on an interface.
Controlling SPF calculation interval
Step
Remarks
N/A
N/A
N/A
6.     Set the SPF calculation interval.
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ]
By default:
·     The maximum interval is 5 seconds.
·     The minimum interval is 50 milliseconds.
·     The incremental interval is 200 milliseconds.
Enabling IPv6 IS-IS ISPF
Step
Remarks
N/A
N/A
N/A
6.     Enable IPv6 IS-IS ISPF.
ispf enable
By default, IPv6 IS-IS ISPF is enabled.
Enabling prefix suppression
Perform this task to disable an interface from advertising its prefix in LSPs. This enhances network security by preventing IP routing to the interval nodes and speeds up network convergence.
To enable prefix suppression:
Step
Remarks
N/A
N/A
3.     Enable prefix suppression on the interface.
isis ipv6 prefix-suppression
By default, prefix suppression is disabled on an interface.
Configuring BFD for IPv6 IS-IS
Bidirectional forwarding detection (BFD) can quickly detect faults between IPv6 IS-IS neighbors to improve the convergence speed of IPv6 IS-IS. For more information about BFD, see High Availability Configuration Guide.
To configure BFD for IPv6 IS-IS:
Step
Remarks
N/A
N/A
3.     Configure the NET for the IS-IS process.
network-entity net
N/A
5.     Return to system view.
N/A
6.     Enter interface view.
N/A
7.     Enable IPv6 for IS-IS on the interface.
8.     Enable BFD for IPv6 IS-IS.
isis ipv6 bfd enable
By default, BFD for IPv6 IS-IS is disabled.
Configuring IPv6 IS-IS FRR
IMPORTANT
IMPORTANT:
ECMP routes do not support FRR.
A link or router failure on a path can cause packet loss and routing loop. IPv6 IS-IS FRR enables fast rerouting to minimize the failover time.
Figure 1 Network diagram for IPv6 IS-IS FRR
In Figure 1, after you enable FRR on Router B, IPv6 IS-IS FRR automatically calculates or designates a backup next hop when a link failure is detected. In this way, packets are directed to the backup next hop to reduce traffic recovery time. Meanwhile, IPv6 IS-IS calculates the shortest path based on the new network topology, and forwards packets over the path after network convergence.
You can assign a backup next hop for IPv6 IS-IS FRR in the following ways:
·     Enable IPv6 IS-IS FRR to calculate a backup next hop through Loop Free Alternate (LFA) calculation.
·     Designate a backup next hop with a routing policy for routes matching specific criteria.
Before you configure IPv6 IS-IS FRR, complete the following tasks:
·     Configure IPv6 addresses for interfaces to ensure IP connectivity between neighboring nodes.
·     Enable IPv6 IS-IS.
·     Make sure the backup next hop is reachable.
Configuration procedure
Configuring IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation
Step
Remarks
N/A
N/A
3.     (Optional.) Disable LFA calculation on the interface.
isis ipv6 fast-reroute lfa-backup exclude
By default, the interface participates in LFA calculation and can be elected as a backup interface.
4.     Return to system view.
N/A
5.     Enter IS-IS IPv6 unicast address family view.
N/A
6.     Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation.
fast-reroute lfa
By default, IPv6 IS-IS FRR is disabled.
Configuring IPv6 IS-IS FRR using a routing policy
You can use the apply ipv6 fast-reroute backup-interface command to specify a backup next hop in a routing policy for routes matching specific criteria. You can also perform this task to reference the routing policy for IPv6 IS-IS FRR. For more information about the apply ipv6 fast-reroute backup-interface command and routing policy configurations, see "Configuring routing policies."
To configure IPv6 IS-IS FRR using a routing policy:
Step
Remarks
N/A
N/A
By default, the interface participates in LFA calculation, and can be elected as a backup interface.
N/A
N/A
6.     Enable IPv6 IS-IS FRR using a routing policy.
Enabling BFD for IPv6 IS-IS FRR
By default, IPv6 IS-IS FRR does not use BFD to detect primary link failures. To speed up IPv6 IS-IS convergence, enable BFD for IPv6 IS-IS FRR to detect primary link failures.
To enable BFD control packet mode for IPv6 IS-IS FRR:
Step
Remarks
N/A
N/A
3.     Enable BFD control packet mode for IPv6 IS-IS FRR.
isis ipv6 primary-path-detect bfd ctrl
By default, BFD control packet mode for IPv6 IS-IS FRR is disabled.
To enable BFD echo packet mode for IPv6 IS-IS FRR:
Step
Remarks
N/A
2.     Configure the source IPv6 address of BFD echo packets.
bfd echo-source-ipv6 ip-address
By default, the source IPv6 address of BFD echo packets is not configured.
The source IPv6 address cannot be on the same network segment as any local interface's IP address.
For more information, see High Availability Command Reference.
3.     Enter interface view.
N/A
4.     Enable BFD echo packet mode for IPv6 IS-IS FRR.
isis ipv6 primary-path-detect bfd echo
By default, BFD echo packet mode for IPv6 IS-IS FRR is disabled.
Enabling IPv6 IS-IS MTR
On a network, IPv4 and IPv6 topologies must be consistent so that both IPv6 IS-IS and IPv4 IS-IS can use the SPF algorithm to perform route calculation. If they are different, routers supporting both IPv4 and IPv6 might send IPv6 packets to routers that do not support IPv6, resulting in packet loss.
To resolve this issue, configure IPv6 IS-IS Multi-Topology Routing (MTR) to perform route calculation separately in IPv4 and IPv6 topologies.
Figure 2 Network diagram
As shown in Figure 2, the numbers refer to the link costs. Router A, Router B, and Router D support both IPv4 and IPv6. Router C supports only IPv4 and cannot forward IPv6 packets.
Enable IPv6 IS-IS MTR on Router A, Router B, Router C, and Router D to make them perform route calculation separately in IPv4 and IPv6 topologies. With this configuration, Router A does not forward IPv6 packets destined to Router D through Router B, avoiding packet loss.
Before you configure IPv6 IS-IS MTR, configure basic IPv4 and IPv6 IS-IS functions, and establish IS-IS neighbors.
To enable IPv6 IS-IS MTR:
Step
Remarks
N/A
N/A
N/A
Displaying and maintaining IPv6 IS-IS
Execute display commands in any view. For other display and reset commands, see "Configuring IS-IS."
Display information about routes redistributed by IPv6 IS-IS.
display isis redistribute ipv6 [ ipv6-address mask-length ] [ level-1 | level-2 ] [ process-id ]
Display IPv6 IS-IS routing information.
display isis route ipv6 [ ipv6-address ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IPv6 IS-IS topology information.
display isis spf-tree ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IPv6 IS-IS route calculation log information.
display isis event-log spf ipv6 [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
IPv6 IS-IS configuration examples
IPv6 IS-IS basic configuration example
Network requirements
As shown in Figure 3, Switch A, Switch B, Switch C, and Switch D, all enabled with IPv6, reside in the same AS. Configure IPv6 IS-IS on the switches so that they can reach each other.
Switch A and Switch B are Level-1 switches, Switch D is a Level-2 switch, and Switch C is a Level-1-2 switch.
Figure 3 Network diagram
1.     Configure IPv6 addresses for interfaces. (Details not shown.)
2.     Configure IPv6 IS-IS:
# Configure Switch A.
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.0000.0000.0001.00
[SwitchA-isis-1] address-family ipv6
[SwitchA-isis-1-ipv6] quit
[SwitchA-isis-1] quit
[SwitchA-Vlan-interface100] isis ipv6 enable 1
# Configure Switch B.
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.0000.0000.0002.00
[SwitchB-isis-1] address-family ipv6
[SwitchB-isis-1-ipv6] quit
[SwitchB-isis-1] quit
[SwitchB-Vlan-interface200] isis ipv6 enable 1
# Configure Switch C.
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 10.0000.0000.0003.00
[SwitchC-isis-1] address-family ipv6
[SwitchC-isis-1-ipv6] quit
[SwitchC-isis-1] quit
[SwitchC-Vlan-interface100] isis ipv6 enable 1
[SwitchC-Vlan-interface200] isis ipv6 enable 1
[SwitchC-Vlan-interface300] isis ipv6 enable 1
[SwitchC-Vlan-interface300] quit
# Configure Switch D.
<SwitchD> system-view
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.0000.0000.0004.00
[SwitchD-isis-1] address-family ipv6
[SwitchD-isis-1-ipv6] quit
[SwitchD-isis-1] quit
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] isis ipv6 enable 1
[SwitchD-Vlan-interface300] quit
[SwitchD] interface vlan-interface 301
[SwitchD-Vlan-interface301] isis ipv6 enable 1
[SwitchD-Vlan-interface301] quit
# Display the IPv6 IS-IS routing table on Switch A.
[SwitchA] display isis route ipv6
                         Level-1 IPv6 Forwarding Table
 Destination : ::                                      PrefixLen: 0
 Flag        : R/-/-                                   Cost     : 10
 Next Hop    : FE80::200:FF:FE0F:4                     Interface: Vlan100
 Destination : 2001:1::                                PrefixLen: 64
 Flag        : D/L/-                                   Cost     : 10
 Next Hop    : Direct                                  Interface: Vlan100
 Destination : 2001:2::                                PrefixLen: 64
 Flag        : R/-/-                                   Cost     : 20
 Destination : 2001:3::                                PrefixLen: 64
# Display the IPv6 IS-IS routing table on Switch B.
[SwitchB] display isis route ipv6
 Next Hop    : FE80::200:FF:FE0F:4                     Interface: Vlan200
 Next Hop    : Direct                                  Interface: Vlan200
# Display the IPv6 IS-IS routing table on Switch C.
[SwitchC] display isis route ipv6
 Next Hop    : Direct                                  Interface: Vlan300
                         Level-2 IPv6 Forwarding Table
 Destination : 2001:4::1                               PrefixLen: 128
 Next Hop    : FE80::20F:E2FF:FE3E:FA3D                Interface: Vlan300
# Display the IPv6 IS-IS routing table on Switch D.
[SwitchD] display isis route ipv6
 Next Hop    : FE80::200:FF:FE0F:4                     Interface: Vlan300
 Flag        : D/L/-                                   Cost     : 0
 Next Hop    : Direct                                  Interface: Loop1
BFD for IPv6 IS-IS configuration example
As shown in Figure 4:
·     Configure IPv6 IS-IS on Switch A and Switch B so that they can reach other.
·     Enable BFD on VLAN-interface 10 of Switch A and Switch B.
After the link between Switch B and the Layer-2 switch fails, BFD can quickly detect the failure and notify IPv6 IS-IS of the failure. Then Switch A and Switch B communicate through Switch C.
Figure 4 Network diagram
Device
IPv6 address
Switch A
Vlan-int10
2001::1/64
Switch A
Vlan-int11
2001:2::1/64
Switch B
Vlan-int10
2001::2/64
Switch B
Vlan-int13
2001:3::2/64
Switch C
Vlan-int11
2001:2::2/64
Switch C
Vlan-int13
2001:3::1/64
[SwitchA] isis 1
[SwitchA-Vlan-interface10] isis ipv6 enable 1
[SwitchA-Vlan-interface11] isis ipv6 enable 1
[SwitchB] isis 1
[SwitchB-Vlan-interface10] isis ipv6 enable 1
[SwitchB] interface vlan-interface 13
[SwitchB-Vlan-interface13] isis ipv6 enable 1
[SwitchB-Vlan-interface13] quit
[SwitchC] isis 1
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] isis ipv6 enable 1
[SwitchC-Vlan-interface11] quit
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] isis ipv6 enable 1
[SwitchC-Vlan-interface13] quit
3.     Configure BFD functions:
# Enable BFD and configure BFD parameters on Switch A.
[SwitchA-Vlan-interface10] isis ipv6 bfd enable
[SwitchA-Vlan-interface10] bfd min-transmit-interval 500
[SwitchA-Vlan-interface10] bfd min-receive-interval 500
[SwitchA-Vlan-interface10] bfd detect-multiplier 7
[SwitchA-Vlan-interface10] return
# Enable BFD and configure BFD parameters on Switch B.
[SwitchB] bfd session init-mode active
[SwitchB-Vlan-interface10] isis ipv6 bfd enable
[SwitchB-Vlan-interface10] bfd min-transmit-interval 500
[SwitchB-Vlan-interface10] bfd min-receive-interval 500
[SwitchB-Vlan-interface10] bfd detect-multiplier 6
# Display BFD session information on Switch A.
<SwitchA> display bfd session
 Total Session Num: 1            Init Mode: Active
 IPv6 Session Working Under Ctrl Mode:
     Local Discr: 1441                Remote Discr: 1450
       Source IP: FE80::20F:FF:FE00:1202 (link-local address of VLAN-interface 10 on Switch A)
  Destination IP: FE80::20F:FF:FE00:1200 (link-local address of VLAN-interface 10 on Switch B)
   Session State: Up                     Interface: Vlan10
       Hold Time: 2319ms
# Display routes destined for 2001:4::0/64 on Switch A.
<SwitchA> display ipv6 routing-table 2001:4::0 64
Summary Count : 1
Destination: 2001:4::/64                                 Protocol  : IS_L1
NextHop    : FE80::20F:FF:FE00:1200                      Preference: 15
Interface  : Vlan10                                      Cost      : 10
The output shows that Switch A and Switch B communicate through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
Summary Count : 1
NextHop    : FE80::BAAF:67FF:FE27:DCD0                   Preference: 15
Interface  : Vlan11                                      Cost      : 20
The output shows that Switch A and Switch B communicate through VLAN-interface 11.
IPv6 IS-IS FRR configuration example
As shown in Figure 5, Switch A, Switch B, and Switch C belong to the same IS-IS routing domain. Configure IPv6 IS-IS FRR so that when the Link A fails, traffic can be switched to Link B immediately.
Figure 5 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
1::1/64
Switch B
Vlan-int101
3::1/64
Vlan-int200
2::1/64
Vlan-int200
2::2/64
Loop0
10::1/128
Loop0
20::1/128
Switch C
Vlan-int100
1::2/64
Vlan-int101
3::2/64
1.     Configure IPv6 addresses for interfaces on the switches and enable IPv6 IS-IS. (Details not shown.)
2.     Configure IPv6 IS-IS on the switches to make sure Switch A, Switch B, and Switch C can communicate with each other at Layer 3. (Details not shown.)
3.     Configure IPv6 IS-IS FRR:
Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation, or designate a backup next hop by using a referenced routing policy.
¡     (Method 1.) Enable IPv6 IS-IS FRR to calculate a backup next hop through LFA calculation:
[SwitchA] isis 1
[SwitchA-isis-1-ipv6] fast-reroute lfa
[SwitchB] isis 1
[SwitchB-isis-1-ipv6] fast-reroute lfa
¡     (Method 2.) Enable IPv6 IS-IS FRR to designate a backup next hop by using a routing policy:
[SwitchA] ipv6 prefix-list abc index 10 permit 20:: 128
[SwitchA-route-policy-frr-10] if-match ipv6 address prefix-list abc
[SwitchA-route-policy-frr-10] apply ipv6 fast-reroute backup-interface vlan-interface 100 backup-nexthop 1::2
[SwitchA] isis 1
[SwitchA-isis-1-ipv6] fast-reroute route-policy frr
[SwitchB] ipv6 prefix-list abc index 10 permit 10:: 128
[SwitchB-route-policy-frr-10] if-match ipv6 address prefix-list abc
[SwitchB-route-policy-frr-10] apply ipv6 fast-reroute backup-interface vlan-interface 101 backup-nexthop 3::2
[SwitchB] isis 1
[SwitchB-isis-1-ipv6] fast-reroute route-policy frr
# Display route 20::1/128 on Switch A to view the backup next hop information.
[SwitchA] display ipv6 routing-table 20::1 128 verbose
Summary count : 1
Destination: 20::1/128
   Protocol: IS_L1
 Process ID: 1
  SubProtID: 0x1                    Age: 00h27m45s
       Cost: 10              Preference: 15
      IpPre: N/A             QosLocalID: N/A
        Tag: 0                    State: Active Adv
  OrigTblID: 0xa                OrigVrf: default-vrf
    TableID: 0xa                 OrigAs: 0
      NibID: 0x24000005          LastAs: 0
     AttrID: 0xffffffff        Neighbor: ::
      Flags: 0x10041        OrigNextHop: FE80::34CD:9FF:FE2F:D02
      Label: NULL           RealNextHop: FE80::34CD:9FF:FE2F:D02
    BkLabel: NULL             BkNextHop: FE80::7685:45FF:FEAD:102
  Tunnel ID: Invalid          Interface: Vlan-interface200
BkTunnel ID: Invalid        BkInterface: Vlan-interface100
   FtnIndex: 0x0           TrafficIndex: N/A
  Connector: N/A
# Display route 10::1/128 on Switch B to view the backup next hop information.
[SwitchB] display ipv6 routing-table 10::1 128 verbose
Summary count : 1
Destination: 10::1/128
   Protocol: IS_L1
 Process ID: 1
  SubProtID: 0x1                    Age: 00h33m23s
      NibID: 0x24000006          LastAs: 0
      Flags: 0x10041        OrigNextHop: FE80::34CC:E8FF:FE5B:C02
      Label: NULL           RealNextHop: FE80::34CC:E8FF:FE5B:C02
BkTunnel ID: Invalid        BkInterface: Vlan-interface101
  Connector: N/A
