06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS10500 SeriesReference GuidesCommand ReferencesH3C S10500 Command References-R7523P01-6W10006-Layer 3 - IP Routing Command Reference
05-IS-IS commands
05-IS-IS commands 403.02 KB
IS-IS commands· 1
address-family ipv4· 1
area-authentication send-only· 1
area-authentication-mode· 2
auto-cost enable· 4
bandwidth-reference· 5
circuit-cost 6
cost-style· 7
default-route-advertise· 8
display isis· 9
display isis event-log graceful-restart 11
display isis event-log lsp· 12
display isis event-log non-stop-routing· 13
display isis event-log spf 15
display isis graceful-restart status· 21
display isis interface· 23
display isis lsdb· 26
display isis mesh-group· 31
display isis name-table· 32
display isis non-stop-routing status· 33
display isis packet 34
display isis peer 42
display isis redistribute· 45
display isis route· 46
display isis spf-tree· 49
display isis statistics· 55
display osi 57
display osi statistics· 59
domain-authentication send-only· 61
domain-authentication-mode· 62
fast-reroute· 64
filter-policy export 65
filter-policy import 66
flash-flood· 68
graceful-restart 69
graceful-restart suppress-sa· 69
graceful-restart t1· 70
graceful-restart t2· 71
graceful-restart t3· 72
ignore-att 73
import-route· 73
import-route isis level-1 into level-2· 75
import-route isis level-2 into level-1· 76
import-route limit 77
isis· 78
isis authentication send-only· 79
isis authentication-mode· 80
isis bfd enable· 82
isis circuit-level 83
isis circuit-type p2p· 84
isis cost 84
isis dis-name· 85
isis dis-priority· 86
isis enable· 87
isis fast-reroute lfa-backup exclude· 88
isis mesh-group· 89
isis mib-binding· 89
isis prefix-suppression· 90
isis primary-path-detect bfd· 91
isis silent 92
isis small-hello· 92
isis tag· 93
isis timer csnp· 94
isis timer hello· 95
isis timer holding-multiplier 96
isis timer lsp· 97
isis timer retransmit 98
is-level 99
is-name· 99
is-name map· 100
ispf enable· 101
log-peer-change· 102
lsp-fragments-extend· 102
lsp-length originate· 103
lsp-length receive· 104
maximum load-balancing· 104
network-entity· 105
non-stop-routing· 106
pic· 107
preference· 108
prefix-priority· 109
reset isis all 110
reset isis event-log graceful-restart 110
reset isis event-log non-stop-routing· 111
reset isis event-log spf 112
reset isis packet 112
reset isis peer 113
reset osi statistics· 113
set-att 114
set-overload· 115
snmp context-name· 116
snmp-agent trap enable isis· 117
summary· 118
timer lsp-generation· 119
timer lsp-max-age· 120
timer lsp-refresh· 121
timer spf 122
virtual-system·· 123
IS-IS commands
address-family ipv4
Use address-family ipv4 to create the IS-IS IPv4 address family and enter its view.
Use undo address-family ipv4 to delete the IS-IS IPv4 address family and all configurations in the view.
undo address-family ipv4 [ unicast ]
No IS-IS IPv4 address family exists.
IS-IS view
unicast: Specifies the unicast address family (the default).
# Create the IS-IS IPv4 address family and enter its view.
[Sysname] isis 100
[Sysname-isis-100] address-family ipv4
[Sysname-isis-100-ipv4]
Use area-authentication send-only to configure IS-IS not to check the authentication information in the received Level-1 packets, including LSPs, CSNPs, and PSNPs.
Use undo area-authentication send-only to restore the default.
When area authentication mode and key are configured, a Level-1 or Level-1-2 router checks the authentication information in the received packets.
IS-IS view
When area authentication mode and key are configured, a Level-1 or Level-1-2 router adds the key in the specified mode into transmitted Level-1 packets (including LSPs, CSNPs, and PSNPs). It also checks the key in the received Level-1 packets.
To prevent packet exchange failure in case of an authentication key change, configure IS-IS not to check the authentication information in the received packets.
# Configure IS-IS not to check the authentication information in the received packets.
[Sysname] isis 1
[Sysname-isis-1] area-authentication send-only
Use area-authentication-mode to specify an area authentication mode and a key.
Use undo area-authentication-mode to restore the default.
area-authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ ip | osi ]
No area authentication mode or key is configured.
IS-IS view
gca: Specifies the Generic Cryptographic Authentication (GCA) mode.
key-id: Uniquely identifies an SA in the range of 1 to 65535. The sender inserts the Key ID into the authentication TLV, and the receiver authenticates the packet by using the SA that is selected based on the Key ID.
hmac-sha-1: Specifies the HMAC-SHA-1 algorithm.
hmac-sha-224: Specifies the HMAC-SHA-224 algorithm.
hmac-sha-256: Specifies the HMAC-SHA-256 algorithm.
hmac-sha-384: Specifies the HMAC-SHA-384 algorithm.
hmac-sha-512: Specifies the HMAC-SHA-512 algorithm.
nonstandard: Specifies the nonstandard GCA mode.
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
keychain: Specifies the keychain authentication mode.
keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters.
ip: Checks IP-related fields in LSPs.
osi: Checks OSI-related fields in LSPs.
Area authentication enables IS-IS to discard routes from untrusted routers.
The key in the specified mode is inserted into all outbound Level-1 packets (LSP, CSNP, and PSNP) and is used to authenticate inbound Level-1 packets.
IS-IS keychain authentication can operate correctly only when the keys in the keychain use the HMAC-MD5 authentication algorithm.
·     Before IS-IS sends a Level-1 packet, it uses the valid send key obtained from the keychain to authenticate the packet. If no valid send key exists or the valid send key does not use the HMAC-MD5 algorithm, the authentication fails and the packet does not contain authentication information.
·     After IS-IS receives a Level-1 packet, it uses a valid accept key obtained from the keychain to authenticate the packet. If no valid accept key exists or all valid accept keys fail to authenticate the packet, the authentication fails and the packet is discarded.
Routers in an area must have the same authentication mode and key.
If neither ip nor osi is specified, OSI-related fields are checked.
When you specify the GCA mode, follow these guidelines:
·     If you do not specify the nonstandard keyword, the device can communicate only with devices that use the GCA mode.
·     If you specify the nonstandard keyword, the device can communicate only with devices that use the nonstandard GCA mode.
# Set the area authentication mode to simple, and set the plaintext key to 123456.
[Sysname] isis 1
[Sysname-isis-1] area-authentication-mode simple plain 123456
auto-cost enable
Use auto-cost enable to enable automatic link cost calculation.
Use undo auto-cost enable to disable automatic link cost calculation.
auto-cost enable
Automatic link cost calculation is disabled.
IS-IS view
After automatic link cost calculation is enabled, the link cost is automatically calculated based on the bandwidth reference value of an interface. When the cost-style is wide or wide-compatible, the cost value of an interface is calculated by using the following formula: Cost = (Reference bandwidth value / Link bandwidth) × 10. For other cost styles, Table 1 applies.
Table 1 Automatic cost calculation scheme for cost styles other than wide and wide-compatible
Interface bandwidth
Cost
≤10 Mbps
60
≤100 Mbps
50
≤155 Mbps
40
≤622 Mbps
30
≤2500 Mbps
20
>2500 Mbps
10
# Enable automatic link cost calculation for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] auto-cost enable
bandwidth-reference
cost-style
isis cost
bandwidth-reference
Use bandwidth-reference to set the bandwidth reference value for automatic link cost calculation.
Use undo bandwidth-reference to restore the default.
bandwidth-reference value
The bandwidth reference value is 100 Mbps.
IS-IS view
value: Specifies the bandwidth reference value in the range of 1 to 2147483648 Mbps.
# Set the bandwidth reference of IS-IS process 1 to 200 Mbps.
[Sysname] isis 1
[Sysname-isis-1] bandwidth-reference 200
auto-cost enable
isis cost
circuit-cost
Use circuit-cost to set a global IS-IS link cost.
Use undo circuit-cost to remove the configuration.
circuit-cost cost-value [ level-1 | level-2 ]
undo circuit-cost [ level-1 | level-2 ]
No global link cost is configured.
IS-IS view
cost-value: Specifies the link cost value. The value range varies by cost style.
·     For styles narrow, narrow-compatible, and compatible, the cost value is in the range of 0 to 63.
·     For styles wide and wide-compatible, the cost value is in the range of 0 to 16777215.
level-1: Applies the link cost to Level-1.
level-2: Applies the link cost to Level-2.
If no level is specified, the specified cost applies to both Level-1 and Level-2.
# Set the global Level-1 link cost to 11 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] circuit-cost 11 level-1
cost-style
isis cost
cost-style
Use cost-style to set a cost style.
Use undo cost-style to restore the default.
undo cost-style
The IS-IS cost style is narrow.
IS-IS view
narrow: Receives and sends only narrow cost style packets. The narrow cost is in the range of 0 to 63.
wide: Receives and sends only wide cost style packets. The wide cost is in the range of 0 to 16777215.
compatible: Receives and sends both wide and narrow cost style packets.
narrow-compatible: Receives both narrow and wide cost style packets, but sends only narrow cost style packets.
wide-compatible: Receives both narrow and wide cost style packets, but sends only wide cost style packets.
relax-spf-limit: Allows receiving routes with a cost greater than 1023. If you do not specify this keyword, routes with a cost bigger than 1023 will be discarded. This keyword is available only when compatible or narrow-compatible is used.
# Configure the router to send only narrow cost style packets, but receive both narrow and wide cost style packets.
[Sysname] isis 1
[Sysname-isis-1] cost-style narrow-compatible
circuit-cost
isis cost
Use default-route-advertise to advertise a default route of 0.0.0.0/0.
Use undo default-route-advertise to restore the default.
default-route-advertise [ avoid-learning | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
Default route advertisement is disabled.
IS-IS IPv4 unicast address family view
avoid-learning: Avoids learning the default route received in LSPs or generated by using the ATT bit to avoid routing loops.
level-1: Advertises a Level-1 default route.
level-1-2: Advertises both Level-1 and Level-2 default routes.
level-2: Advertises a Level-2 default route.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
tag tag: Specifies the tag value for the default route, in the range of 1 to 4294967295.
If no level is specified, a Level-2 default route is advertised.
The Level-1 default route is advertised to other routers in the same area, and the Level-2 default route is advertised to all the Level-2 and Level-1-2 routers.
You can use a routing policy to specify a level for the default route. The apply isis level-1 command in routing policy view can generate a Level-1 default route. The apply isis level-2 command in routing policy view can generate a Level-2 default route. The apply isis level-1-2 command in routing policy view can generate both a Level-1 default route and Level-2 default route.
The tag value specified in the routing policy takes precedence over the tag value specified in this command.
# Configure IS-IS process 1 to advertise a Level-2 default route.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] default-route-advertise
display isis
Use display isis to display configuration information for an IS-IS process.
display isis [ process-id ]
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays configuration information for all IS-IS processes.
# Display IS-IS configuration information.
<Sysname> display isis
          IS-IS(1) Protocol Information
Network-entity                 : 10.0000.0000.0001.00
IS-level                       : level-1-2
Cost-style                     : Wide
Fast reroute                   : Disabled
Preference                     : 15
LSP-length receive             : 1497
LSP-length originate
    level-1                    : 1497
    level-2                    : 1497
Maximum imported routes        : 1000
Timers
    LSP-max-age                : 1200
    LSP-refresh                : 900
    SPF intervals              : 5 50 200
IPv6 enabled
    Preference                 : 15
Network-entity
Network entity name.
IS-level
IS-IS routing level.
Cost-style
Cost style.
Fast-reroute
IS-IS FRR status:
·     Disabled—IS-IS FRR is disabled.
·     LFA—IS-IS FRR automatically calculates a backup next hop.
·     Route-policy—IS-IS FRR specifies a backup next hop by using a routing policy.
Preference
IS-IS route preference.
LSP-length receive
Maximum LSP that can be received.
Maximum LSP that can be generated.
Maximum number of redistributed Level-1/Level-2 IPv4/IPv6 routes.
Timers
Timers:
·     LSP-max-age—Maximum life period of LSPs.
·     LSP-refresh—Refresh interval of LSPs.
·     SPF intervals—Interval between SPF calculations.
IPv6 enabled
IPv6 is enabled.
Use display isis event-log graceful-restart to display IS-IS GR log information.
In standalone mode:
display isis event-log graceful-restart slot slot-number
In IRF mode:
display isis event-log graceful-restart chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
# (In standalone mode.) Display IS-IS GR log information for the specified slot.
<Sysname> display isis event-log graceful-restart slot 1
IS-IS loginfo :
Sep 18 08:48:24 2015 slot 1 Process 1 enter GR restarting phase(Initialization).
Sep 18 08:48:24 2015 slot 1 Process 1 enter GR phase (LSDB synchronization).
Sep 18 08:48:24 2015 slot 1 Process 1 enter GR phase (TE tunnel prepare).
Sep 18 08:48:24 2015 slot 1 Process 1 enter GR phase (First SPF computation).
Sep 18 08:48:25 2015 slot 1 Process 1 enter GR phase (Redistribution).
Sep 18 08:48:25 2015 slot 1 Process 1 enter GR phase (Second SPF computation).
Sep 18 08:48:25 2015 slot 1 Process 1 enter GR phase (LSP stability).
Sep 18 08:48:25 2015 slot 1 Process 1 enter GR phase (LSP generation).
Sep 18 08:48:25 2015 slot 1 Process 1 enter GR phase (Finish).
Sep 18 08:48:25 2015 slot 1 Process 1 GR complete.
GR phase
GR phase:
·     Initialization.
·     LSDB synchronization.
·     TE tunnel prepare—Preparing for TE tunnel computation.
·     First SPF computation.
·     Redistribution.
·     Second SPF computation.
·     LSP stability—Ready to generate LSPs.
·     LSP generation.
·     Finish.
Use display isis event-log lsp to display IS-IS LSP log information.
display isis event-log lsp [ level-1 | level-2 ] * [ process-id ]
level-1: Displays Level-1 LSP log information.
level-2: Displays Level-2 LSP log information.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays LSP log information for all IS-IS processes.
If you do not specify a level, the command displays both Level-1 and Level-2 LSP log information.
# Display IS-IS LSP log information.
<Sysname> display isis event-log lsp
                              LSP Log for IS-IS(1)
                                Level-1 LSP Log
Date       Time     LSPID                Seq Num    Event
2015-11-06 11:10:45 1111.1111.1111.00-00 0x0000019c LSP received
2015-11-06 09:26:40 1111.1111.1111.01-00 0x00000111 Purged LSP received
2015-11-06 09:26:28 2222.2222.2222.00-00 0x00000181 LSP generated
2015-11-06 09:26:21 2222.2222.2222.00-00 0x00000180 Purged LSP generated
                                Level-2 SPF Log
2015-11-06 11:10:45 1111.1111.1111.00-00 0x0000090d LSP received
2015-11-06 09:26:41 1111.1111.1111.01-00 0x00000101 Purged LSP received
2015-11-06 09:26:27 2222.2222.2222.00-00 0x00000171 LSP generated
2015-11-06 09:26:20 2222.2222.2222.00-00 0x00000170 Purged LSP generated
Date
Date of the LSP change.
Time
Time of the LSP change.
LSPID
LSP ID.
Seq Num
LSP sequence number.
Event
LSP change event:
·     LSP received.
·     Purged LSP received.
·     LSP generated.
·     Purged LSP generated.
reset isis event-log lsp
Use display isis event-log non-stop-routing to display IS-IS NSR log information.
In standalone mode:
display isis event-log non-stop-routing slot slot-number
In IRF mode:
display isis event-log non-stop-routing chassis chassis-number slot slot-number
# (In standalone mode.) Display IS-IS NSR log information for the specified slot.
<Sysname> display isis event-log non-stop-routing slot 1
IS-IS loginfo :
Sep 18 10:20:44 2015 slot 1 Enter HA Block status
Sep 18 10:20:44 2015 slot 1 Exit HA Block status
Sep 18 10:24:00 2015 slot 1 Process 100 enter NSR phase (Initialization).
Sep 18 10:24:00 2015 slot 1 Process 100 enter NSR phase (Smooth).
Sep 18 10:24:00 2015 slot 1 Process 100 enter NSR phase (TE tunnel prepare).
Sep 18 10:24:00 2015 slot 1 Process 100 enter NSR phase (First SPF computation).
Sep 18 10:24:00 2015 slot 1 Process 100 enter NSR phase (Redistribution).
Sep 18 10:24:00 2015 slot 1 Process 100 enter NSR phase (Second SPF computation).
Sep 18 10:24:00 2015 slot 1 Process 100 enter NSR phase (LSP stability).
Sep 18 10:24:00 2015 slot 1 Process 100 enter NSR phase (LSP generation).
Sep 18 10:24:00 2015 slot 1 Process 100 enter NSR phase (Finish).
Sep 18 10:24:00 2015 slot 1 Process 100 NSR complete.
Table 5 Command output
NSR phase
NSR phase:
·     Initialization.
·     Smooth.
·     Redistribution.
·     LSP generation.
·     Finish.
Use display isis event-log spf to display IS-IS route calculation log information.
display isis event-log spf [ ipv4 ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv4: Displays IS-IS IPv4 route calculation log information. If you do not specify this keyword, the command displays IS-IS IPv4 route calculation log information for the public network.
level-1: Displays Level-1 route calculation log information.
level-2: Displays Level-2 route calculation log information.
verbose: Displays detailed route calculation log information. If you do not specify this keyword, the command displays brief route calculation log information.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays route calculation log information for all IS-IS processes.
If you do not specify a level, the command displays both Level-1 and Level-2 route calculation log information.
# Display brief IS-IS route calculation log information.
<Sysname> display isis event-log spf
                              SPF Log for IS-IS(1)
                                Level-1 SPF Log
Date       Time     Duration   Count      Trigger event
2015-09-07 11:10:45 0          4          Interface metric changed
2015-09-07 09:26:40 0          4          LSP updated
2015-09-07 09:26:28 0          2          DIS changed
2015-09-07 09:26:21 0.001      2          LSP updated
2015-09-07 09:26:07 0.001      3          Direct route changed
                                Level-2 SPF Log
2015-09-07 09:26:21 0          2          LSP updated
2015-09-07 09:26:07 0          3          Direct route changed
# Display detailed IS-IS route calculation log information.
<Sysname> display isis event-log spf verbose
                                Level-1 SPF Log
 Log date      : 2015-09-07 11:10:45
 Log key       : 5
 Trigger count : 4
 Trigger event : Interface metric changed
 SPF details   :
   Phase          Duration     Description
   TE tunnel ADJ  0            TE SPF nodes: 0
   Topology       0            SPF nodes: 3
   BSPF           0            Candidate NBRs: 1
   LFA            0            LFA SPF nodes: 1
   Area           0            Area addresses: 1
   PRC            0            Add: 0 modify: 1 delete: 0
                               Last 10 routes:
                               1.1.1.0/24
   Route summary  0            Summary route nodes: 0
   Total          0
 Log date      : 2015-09-07 09:26:40
 Log key       : 4
 Trigger count : 4
 Trigger event : LSP updated
 SPF details   :
   PRC            0            Add: 0 modify: 0 delete: 0
   Total          0
 Log date      : 2015-09-07 09:26:28
 Log key       : 3
 Trigger count : 2
 Trigger event : DIS changed
 SPF details   :
   Topology       0            SPF links changed: 1
   BSPF           0            Candidate NBRs: 0
   LFA            0            LFA SPF nodes: 0
   Area           0            Area addresses: 0
   Total          0
 Log date      : 2015-09-07 09:26:21
 Log key       : 2
 Trigger count : 2
 SPF details   :
   Topology       0            SPF nodes: 0
   PRC            0.001        Add: 0 modify: 0 delete: 0
   Total          0.001
 Log date      : 2015-09-07 09:26:07
 Log key       : 1
 Trigger count : 3
 Trigger event : Direct route changed
 SPF details   :
   PRC            0.001        Add: 1 modify: 0 delete: 0
                               Last 10 routes:
                               1.1.1.0/24
   Total          0.001
                                Level-2 SPF Log
 Log key       : 5
 Trigger count : 4
 SPF details   :
   Total          0
 Log key       : 4
 Trigger count : 4
 SPF details   :
   Total          0
 Log key       : 3
 Trigger count : 2
 SPF details   :
   Total          0
 Log key       : 2
 Trigger count : 2
 SPF details   :
   Total          0
 Log key       : 1
 Trigger count : 3
 SPF details   :
   Total          0
Table 6 Command output
Date
Start date of route calculation.
Time
Start time of route calculation.
Duration
Route calculation duration in seconds. The value is accurate to six decimal places.
Count
Number of events that trigger the current route calculation.
Trigger event
Type of the most recent event that triggers route calculation:
·     NextHop changed.
·     DIS changed.
·     Interface metric changed.
·     SPF link changed.
·     Default route changed.
·     Summary route changed.
·     TE tunnel updated.
·     TE tunnel metric changed.
·     IPv6 mode changed.
·     FRR configuration changed.
·     Prefix priority configuration changed.
·     Route preference changed.
·     ISPF configuration changed.
·     Import filter policy changed.
·     ECMP configuration changed.
·     PIC configuration changed.
·     Interface LFA exclude changed.
·     ATT configuration changed.
·     GR/NSR first SPF.
·     GR over.
·     T3 timeout.
·     Direct route changed.
·     Logic interface changed.
·     Route leakage configuration changed.
·     NSR over.
·     Entered overload state.
·     Exited overload state.
·     Area address changed.
·     Route policy changed.
·     Redistributed route updated.
·     LSP updated.
·     MT disabled.
·     MT enabled.
·     TE tunnel configuration changed.
·     TE tunnel destination changed.
·     RIB smooth.
Log date
Generation time of the route calculation logs.
Log key
Route calculation log key.
Trigger count
SPF details
Detailed information about the route calculation phases.
Phase
Route calculation phase:
·     TE tunnel ADJ—TE tunnel adjacency calculation.
·     Topology—Topology calculation.
·     BSPF—Backup SPF calculation.
·     LFA—LFA calculation.
·     Area—Area calculation.
·     PRC—Prefix calculation.
·     Route summary—Route summarization calculation.
Route calculation phase description:
·     TE SPF nodes—Number of SPF nodes for TE tunnel adjacency calculation.
·     SPF nodes—Number of SPF nodes for topology calculation.
·     Candidate NBRs—Number of candidate neighbors.
·     LFA SPF nodes—Number of SPF nodes for LFA calculation.
·     Area addresses—Number of area addresses.
·     Add, modify, and delete—Prefix calculation summary.
·     Last 10 routes—10 routes that are most recently calculated.
·     Summary route nodes—Number of summarized routes.
Total
Total duration time of all route calculation phases.
Use display isis graceful-restart status to display IS-IS GR state.
display isis graceful-restart status [ level-1 | level-2 ] [ process-id ]
level-1: Displays the IS-IS Level-1 GR state.
level-2: Displays the IS-IS Level-2 GR state.
process-id: Specifies a process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays GR state of all IS-IS processes.
# Display IS-IS GR state.
<Sysname> display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
                          Level-1 restart information
Total number of interfaces: 1
Number of waiting LSPs: 0
                          Level-2 restart information
Table 7 Command output
Restart status
Current GR state:
·     RESTARTING—In this state, forwarding can be ensured.
·     STARTING—In this state, forwarding cannot be ensured.
·     COMPLETE—GR is completed.
Restart phase
Current Restart phase:
·     Initialization.
·     Redistribution.
·     LSP generation.
·     Finish.
Restart t1
T1 timer, in seconds.
count
Number of T1 timer expirations.
Restart t2
T2 timer, in seconds.
Restart t3
T3 timer, in seconds.
SA Bit
Whether SA is supported.
Total number of IS-IS interfaces.
Number of LSPs not obtained by the GR restarter from GR helpers during LSDB synchronization.
Use display isis interface to display IS-IS interface information.
display isis interface [ [ interface-type interface-number ] [ verbose ] | statistics ] [ process-id ]
interface-type interface-number: Displays information for a specified IS-IS interface. If you do not specify this argument, the command displays information about all interfaces.
verbose: Displays detailed information about an interface. If you do not specify this keyword, the command displays brief information about an interface.
statistics: Displays IS-IS interface statistics.
process-id: Displays IS-IS interface information for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays interface information for all IS-IS processes.
# Display brief IS-IS interface information.
<Sysname> display isis interface
  Interface:  Vlan-interface100
  Index     IPv4 state      IPv6 state     CircuitID   MTU   Type   DIS
  00001     Up              Down           1           1497  L1/L2  No/No
# Display detailed IS-IS interface information.
<Sysname> display isis interface verbose
  SNPA address                     : 000c-29e8-1bd5
  IP address                       : 192.168.220.10
  Secondary IP address(es)         :
  IPv6 link-local address          :
  Extended circuit ID              : 1
  CSNP timer value                 : L1        10   L2        10
  Hello timer value                :           10
  Hello multiplier value           :            3
  LSP timer value                  : L12       33
  LSP transmit-throttle count      : L12        5
  Cost                             : L1       100   L2        100
  IPv6 cost                        : L1        10   L2        10
  Priority                         : L1        64   L2        64
  Retransmit timer value           : L12        5
  LDP state                        : L1      Init   L2      No-LDP
  LDP sync state                   : L1      Init   L2    Achieved
  MPLS TE status                   : L1  Disabled   L2    Disabled
  IPv4 BFD                         : Disabled
  IPv6 BFD                         : Disabled
  IPv4 FRR LFA backup              : Enabled
  IPv6 FRR LFA backup              : Enabled
  IPv4 prefix-suppression          : Disabled
  IPv6 prefix-suppression          : Disabled
  IPv4 tag                         : 1
  IPv6 tag                         : 4294967295
  IPv4 primary path detection mode: BFD ctrl
  IPv6 primary path detection mode: BFD ctrl
Table 8 Command output
Interface type and number.
Index
Interface index.
IPv4 state
IPv4 state.
IPv6 state
IPv6 state.
CircuitID
Circuit ID.
MTU
Interface MTU.
Interface link adjacency type.
DIS
Indicates whether the interface is elected as the DIS. In a P2P network, this field displays a hyphen (-) because DIS election is not performed.
SNPA address
Subnet access point address.
IP address
Primary IP address.
Secondary IP addresses.
IPv6 link local address.
Extended circuit ID
Extended circuit ID for a P2P link.
CSNP timer value
Interval for sending CSNP packets.
Hello timer value
Interval for sending Hello packets.
Number of invalid Hello packets.
LSP timer value
Minimum interval for sending LSP packets.
Number of LSP packets sent each time.
Cost
Cost of the interface.
IPv6 cost
IPv6 link cost of the interface.
Priority
DIS priority.
Retransmission interval for LSPs on a P2P link.
MPLS TE status
MPLS TE status: Enabled or Disabled.
LDP state
LDP state:
·     Init—LDP is not reported.
·     No-LDP—LDP is not configured.
·     Not ready—LDP session is not established.
·     Ready—LDP session is established.
LDP sync state
LDP synchronization state:
·     Init—Initialized.
·     Achieved—Synchronized.
·     Max cost—Maintain the maximum cost.
IPv4 BFD
Whether BFD for IS-IS is enabled:
·     Disabled.
·     Enabled.
IPv6 BFD
Whether BFD for IPv6 IS-IS is enabled:
·     Disabled.
·     Enabled.
IPv4 FRR LFA backup
Whether LFA calculation is enabled for IPv4 FRR:
·     Disabled.
·     Enabled.
IPv6 FRR LFA backup
Whether LFA calculation is enabled for IPv6 FRR:
·     Disabled.
·     Enabled.
Whether IPv4 IS-IS prefix suppression is enabled:
·     Disabled.
·     Enabled.
Whether IPv6 IS-IS prefix suppression is enabled:
·     Disabled.
·     Enabled.
IPv4 tag
IPv4 tag value of the interface.
IPv6 tag
IPv6 tag value of the interface.
·     BFD ctrl—BFD control packet mode.
·     BFD echo—BFD echo packet mode.
# Display IS-IS interface statistics.
<Sysname> display isis interface statistics
                  Interface statistics information for IS-IS(1)
  Type            IPv4 up/down           IPv6 up/down
  LAN                   1/0                    0/0
  P2P                   0/0                    0/0
Table 9 Command output
Network type of the interface:
·     LAN—Broadcast network.
·     P2P—Point-to-point network.
IPv4 up
Number of IS-IS interfaces in up state.
IPv4 down
Number of IS-IS interfaces in down state.
IPv6 up
Number of IS-ISv6 interfaces in up state.
IPv6 down
Number of IS-ISv6 interfaces in down state.
display isis lsdb
Use display isis lsdb to display IS-IS LSDB information.
display isis lsdb [ [ level-1 | level-2 ] | local | [ lsp-id lspid | lsp-name lspname ] | verbose ] * [ process-id ]
level-1: Displays the level-1 LSDB.
level-2: Displays the level-2 LSDB.
local: Displays LSP information generated locally.
lsp-id lspid: Specifies an LSP ID, in the form of sysID. Pseudo ID-fragment num, where sysID represents the originating node or pseudo node. Pseudo ID is separated by a dot from sysID and by a hyphen from fragment num.
lsp-name lspname: Specifies the LSP name, in the form of Symbolic name.Pseudo ID-fragment num, where Pseudo ID is separated by a dot from Symbolic name and by a hyphen from fragment num. If the Pseudo ID is 0, specify the LSP name in the form Symbolic name-fragment num.
verbose: Displays LSDB detailed information. If you do not specify this keyword, the command displays brief information about LSDB.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays LSDBs for all IS-IS processes.
If no level is specified, the command displays both Level-1 and Level-2 LSDB information.
# Display brief Level-1 LSDB information.
<Sysname> display isis lsdb level-1
                        Database information for IS-IS(1)
                          Level-1 Link State Database
LSPID                 Seq Num      Checksum      Holdtime      Length  ATT/P/OL
0000.0000.0001.00-00* 0x00000087   0xf846        1152          183     0/0/0
0000.0000.0003.00-00  0x00000005   0x4bee        520           177     0/0/0
0000.0000.0003.00-01  0x00000004   0x7245        520           45      0/0/0
0000.0000.0011.00-00  0x0000000b   0xcdf6        815           183     0/0/0
# Display detailed Level-1 LSDB information.
<Sysname> display isis lsdb level-1 verbose
0000.0000.0001.00-00* 0x00000080   0x73f         1185          183     0/0/0
 Source       0000.0000.0001.00
 NLPID        IPv4
 Area address 10
 IPv4 address 192.168.220.10
 MT ID        0000   (-/-)
 MT ID        0002   (-/-)
 MT ID        0006   (-/-)
 +NBR  ID
     0000.0000.0011.00                Cost: 100
     Admin group: 0x00000000
     Physical bandwidth: 12500000 bytes/sec
     Reservable bandwidth: 0 bytes/sec
     Unreserved bandwidth for each TE class:
       TE class  0: 0 bytes/sec             TE class  1: 0 bytes/sec
       TE class  2: 0 bytes/sec             TE class  3: 0 bytes/sec
       TE class  4: 0 bytes/sec             TE class  5: 0 bytes/sec
       TE class  6: 0 bytes/sec             TE class  7: 0 bytes/sec
       TE class  8: 0 bytes/sec             TE class  9: 0 bytes/sec
       TE class 10: 0 bytes/sec             TE class 11: 0 bytes/sec
       TE class 12: 0 bytes/sec             TE class 13: 0 bytes/sec
       TE class 14: 0 bytes/sec             TE class 15: 0 bytes/sec
     TE cost: 10
     Bandwidth constraint model: Prestandard DS-TE RDM
     Bandwidth constraints:
       BC[0]      : 0 bytes/sec             BC[1]      : 0 bytes/sec
     Neighbor IP address: 192.168.220.30
     Interface IP address: 192.168.220.10
 IPv6 unicast NBR ID
     6464.6464.6464.01                Cost: 10         MT ID: 2
 MT NBR ID
     6464.6464.6464.01                Cost: 10         MT ID: 6
 +IP-Extended
     192.168.220.0   255.255.255.0    Cost: 100
 IPv4 unicast
     1.1.1.1         255.255.255.255  Cost: 0          MT ID: 6
 IPv4 unicast
     10.10.10.0      255.255.255.0    Cost: 10         MT ID: 6
 IPv6 unicast
     1:1:1::1/128                     Cost: 0          MT ID: 2
 IPv6 unicast
     10:10:10::/64                    Cost: 10         MT ID: 2
 Router ID    1.1.1.1
0000.0000.0003.00-00  0x00000005   0x4bee        887           177     0/0/0
 Source       0000.0000.0003.00
 NLPID        IPv4
 Area address 10
 IPv4 address 10.10.10.10
 IPv4 address 192.168.220.20
 +NBR  ID
     0000.0000.0001.00                Cost: 10
     TE cost: 10
       BC[0]: 0 bytes/sec                   BC[1]: 0 bytes/sec
     Interface IP address: 192.168.220.20
     Neighbor IP address: 192.168.220.10
 Router ID    3.3.3.3
0000.0000.0003.00-01  0x00000004   0x7245        887           45      0/0/0
 +IP-Extended
 +IP-Extended
Table 10 Command output
LSPID
LSP ID.
Seq Num
Checksum
LSP checksum.
Holdtime
LSP lifetime, which decreases as time elapses.
Length
LSP length.
ATT/P/OL
·     ATT—Attach bit.
·     P—Partition bit.
·     OL—Overload bit.
1 means the LSP bit is set and 0 means the LSP bit is not set.
Source
System ID of the originating router.
HOST NAME
Dynamic host name of the originating router.
ORG ID
Original system ID of the virtual system of the originating router.
NLPID
Network layer protocol the originating router runs.
Area address
Area address of the originating router.
IPv4 address
IP address of the originating router's IS-IS interface.
IPv6 address
IPv6 address of the originating router's IS-ISv6 interface.
MT ID        0000     (-/-)
MT ID        0002     (-/-)
MT ID        0006     (-/-)
Topology supported by the originating router (0/0/0 indicates ATT/P/OL):
·     0000—Base topology.
·      (-/-)—Attach bit/overload bit.
IPv6 unicast NBR ID
IPv6 unicast neighbor information about the originating router.
Admin group
Link management group attribute.
IP address of the interface connected to the remote end.
Neighbor IP address
Neighbor interface IP address.
Physical bandwidth
Physical bandwidth.
Reserved bandwidth.
Available bandwidth reserved for each TE class.
TE class
Available bandwidth for each of the 8 or 16 TE classes.
TE cost
TE cost.
·     Prestandard DS-TE RDM.
·     IETF DS-TE RDM.
·     IETF DS-TE MAM.
BC
Bandwidth constraint value. The Prestandard model supports 2 BCs, and the IETF modes support a maximum of 8 BCs.
Router ID
Router ID.
IP-Internal
Internal IP address and mask of the originating router.
IP-External
External IP address and mask of the originating router.
IP-Extended
Extended IP address and mask of the originating router.
Cost
Cost.
Auth
Authentication information of the originating router.
IPV6
Internal IPv6 address and prefix of the originating router.
IPV6-Ext
External IPv6 address and prefix of the originating router.
IPv4 unicast
IPv4 unicast reachability information about the originating router.
IPv6 unicast
Internal IPv6 unicast reachability information about the originating router.
IPv6 unicast-ext
External IPv6 unicast reachability information about the originating router.
Use display isis mesh-group to display IS-IS mesh group configuration information.
display isis mesh-group [ process-id ]
process-id: Displays IS-IS mesh-group configuration for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays IS-IS mesh group configuration information for all IS-IS processes.
# Add VLAN-interface 10 and VLAN-interface 20 to mesh group 100.
[Sysname-Vlan-interface10] isis mesh-group 100
[Sysname-Vlan-interface10] interface vlan-interface 20
[Sysname-Vlan-interface20] isis mesh-group 100
# Display IS-IS mesh-group configuration information.
[Sysname-Vlan-interface20] display isis mesh-group
               Mesh Group information for IS-IS(1)
 Interface          Status
 Vlan10              Blocked
 Vlan20              100
Table 11 Command output
Interface name.
Status
Mesh group the interface belongs to/whether a blocked interface is configured.
Use display isis name-table to display the host name-to-system ID mapping table.
display isis name-table [ process-id ]
process-id: Displays the host name to system ID mapping table for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the host name to system ID mapping table for all IS-IS processes.
# Display the IS-IS host name to system ID mapping table.
<Sysname> display isis name-table
                      Name table information for IS-IS(1)
 System ID           Hostname                            Type       Level
 6789.0000.0001      RUTA                                DYNAMIC    Level-1
 6789.0000.0001      RUTA                                DYNAMIC    Level-2
 0000.0000.0041      RUTB                                STATIC     Level-1
 0000.0000.0041      RUTB                                STATIC     Level-2
 6789.0000.0001.01   DIS-A                               DYNAMIC    Level-1
 0000.0000.0041.01   DIS-B                               DYNAMIC    Level-2
Table 12 Command output
System ID
System ID.
Hostname
Host name.
Mapping type:
·     STATIC.
·     DYNAMIC.
Level
Level on which the system ID-to-host name mapping takes effect: Level-1 or Level-2.
Use display isis non-stop-routing status to display IS-IS NSR status.
# Display IS-IS NSR status.
<Sysname> display isis non-stop-routing status
                        Nonstop Routing information for IS-IS(1)
NSR phase: Finish
Table 13 Command output
NSR phase
NSR phase:
·     Initialization.
·     Smooth.
·     Redistribution.
·     LSP generation.
·     Finish.
display isis packet
Use display isis packet to display IS-IS packet statistics.
display isis packet { csnp | hello | lsp | psnp } by-interface [ verbose ] [ interface-type interface-number ] [ process-id ]
display isis packet { csnp | hello | lsp | psnp } [ verbose ] [ process-id ]
csnp: Displays CSNP packet statistics.
hello: Displays hello packet statistics.
lsp: Displays LSP packet statistics.
psnp: Displays PSNP packet statistics.
by-interface: Displays packet statistics on a per-interface basis.
verbose: Displays detailed packet statistics.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command displays IS-IS packet statistics for all interfaces.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays packet statistics for all IS-IS processes.
# Display detailed hello packet statistics on a per-interface basis.
<Sysname> display isis packet hello by-interface verbose
                     Hello packet information for IS-IS(1)
  Total output packets : 0          Total output error packets : 0
  Total input packets  : 0          Total input error packets  : 0
  Input packets with errors
    Bad packet length     : 0          Bad header length          : 0
    Jumbo packet          : 0          Bad protocol description   : 0
    Bad protocol ID       : 0          Bad protocol version       : 0
    Unknown packet type   : 0          Bad max area count         : 0
    Bad system ID length  : 0          Bad circuit type           : 0
    Bad auth TLV: 0                    Bad area address TLV       : 0
    Auth failure          : 0          Excessive area addresses   : 0
    Bad NBR TLV           : 0          Excessive auth TLVs        : 0
    Excessive IF Addr TLVs: 0          Excessive IF addresses     : 0
    Bad IF address TLV    : 0          Duplicate system ID        : 0
    Bad TLV length        : 0          Bad IP address             : 0
    Duplicate IP address  : 0          Mismatched area address    : 0
    Mismatched protocol   : 0          Mismatched network type    : 0
    Bad IPv6 address TLV  : 0          Bad IPv6 address           : 0
    Duplicate IPv6 address: 0          Bad MT ID TLV              : 0
    SNPA conflict (LAN)   : 0          Excessive NBR SNPAs (LAN)  : 0
    Mismatched level (LAN): 0          Bad 3-Way option TLV (P2P) : 0
    No common MT ID (P2P) : 0          Bad circuit ID (P2P)       : 0
# Display detailed hello packet statistics.
<Sysname> display isis packet hello verbose
    Bad auth TLV           : 0          Bad area address TLV       : 0
    Excessive IF Addr TLVs : 0          Excessive IF addresses     : 0
    Duplicate IPv6 address : 0          Bad MT ID TLV              : 0
    Mismatched level (LAN) : 0          Bad 3-Way option TLV (P2P) : 0
Table 14 Command output
Statistics for packets with the following errors:
·     Bad packet length—Invalid packet length.
·     Bad header length—Invalid header length.
·     Jumbo packet—The packet length exceeds the buffer size or the interface MTU.
·     Bad protocol description—Invalid protocol description.
·     Bad protocol ID—Invalid protocol identifier.
·     Bad protocol version—Invalid protocol version.
·     Unknown packet type—Unknown packet type.
·     Bad max area count—Invalid maximum number of area addresses.
·     Bad system ID length—Invalid system ID length.
·     Bad circuit type—Invalid interface type.
·     Bad auth TLV—Invalid authentication TLV.
·     Bad area address TLV—Invalid area address TLV.
·     Auth failure—Authentication failure.
·     Excessive area addresses—Excessive area addresses.
·     Bad NBR TLV—Invalid neighbor TLV.
·     Excessive auth TLVs—Excessive authentication TLVs.
·     Excessive IF Addr TLVs—Excessive interface address TLVs.
·     Excessive IF addresses—Excessive interface addresses.
·     Bad IF address TLV—Invalid interface address TLV.
·     Duplicate system ID—Duplicate system IDs.
·     Bad TLV length—Invalid TLV length.
·     Bad IP address—The IP address does not belong to the same network as the local interface address.
·     Duplicate IP address—Duplicate IP addresses.
·     Mismatched area address—Mismatched area addresses.
·     Mismatched protocol—Mismatched protocols.
·     Mismatched network type—Mismatched network types.
·     Bad IPv6 address TLV—Invalid IPv6 address TLV.
·     Bad IPv6 address—Invalid IPv6 address.
·     Duplicate IPv6 address—Duplicate IPv6 addresses.
·     SNPA conflict (LAN)—SNPA conflict.
·     Excessive NBR SNPAs (LAN)—Excessive neighbor SNPAs.
·     Mismatched level (LAN)—Mismatched levels.
·     Bad 3-Way option TLV (P2P)—Invalid three-way handshake information.
·     Bad circuit ID (P2P)—Invalid circuit ID.
# Display detailed LSP packet statistics on a per-interface basis.
<Sysname> display isis packet lsp by-interface verbose
                      LSP packet information for IS-IS(1)
    Jumbo packet        : 0          SNPA conflict (LAN)      : 0
    Smaller than header : 0          Bad protocol description : 0
    No active NBR       : 0          Bad system ID length     : 0
    Mismatched level    : 0          Illegal IS type          : 0
    Sequence number is 0: 0          Checksum is 0            : 0
    Incorrect checksum  : 0          Bad TLV length           : 0
    Mismatched protocol : 0          Bad auth TLV   : 0
    Auth failure        : 0          Excessive auth TLVs      : 0
    Bad NBR TLV         : 0          Bad extended IS TLV      : 0
    Bad IF address TLV  : 0          Bad IPv6 IF address TLV  : 0
    Bad alias TLV       : 0          Bad IP reachability TLV  : 0
    Bad MT IS TLV       : 0          Bad area address TLV     : 0
    Bad MT ID TLV       : 0          Bad MT IP TLV            : 0
    Bad MT IPv6 TLV     : 0          Bad IPv6 reachability TLV: 0
    Bad router ID TLV   : 0
# Display detailed LSP packet statistics.
<Sysname> display isis packet lsp verbose
    Sequence number is 0 : 0          Checksum is 0             : 0
    Bad MT IPv6 TLV      : 0          Bad IPv6 reachability TLV : 0
Table 15 Command output
·     Jumbo packet—The packet length exceeds the maximum length of packets that can be received.
·     Smaller than header—The packet length is smaller than the fixed header length.
·     No active NBR—The packet is from an unknown neighbor.
·     Mismatched level—Mismatched levels.
·     Illegal IS type—Invalid IS type.
·     Sequence number is 0—The sequence number is 0.
·     Checksum is 0—The checksum is 0.
·     Incorrect checksum—Incorrect checksum.
·     Bad extended IS TLV—Invalid extended IS TLV.
·     Bad IPv6 IF address TLV—Invalid IPv6 interface address TLV.
·     Bad alias TLV—Invalid alias TLV.
·     Bad IP reachability TLV—Invalid IP reachability TLV.
·     Bad MT IPv6 TLV—Invalid IPv6 topology TLV.
·     Bad IPv6 reachability TLV—Invalid IPv6 reachability TLV.
·     Bad router ID TLV—Invalid router ID TLV.
# Display detailed CSNP packet statistics on a per-interface basis.
<Sysname> display isis packet csnp by-interface verbose
                      CSNP packet information for IS-IS(1)
    Smaller than header: 0          Bad protocol description: 0
    Unknown packet type: 0          Bad max area count      : 0
    Mismatched level   : 0          Bad TLV length          : 0
    Auth failure       : 0          Bad auth TLV            : 0
    Bad LSP TLV length : 0          Excessive auth TLVs     : 0
    Excessive LSPs     : 0          Bad LSP ID              : 0
# Display detailed CSNP packet statistics.
<Sysname> display isis packet csnp verbose
Table 16 Command output
·     Bad LSP TLV length—Invalid LSP TLV length.
·     Excessive LSPs—Excessive LSPs.
·     Bad LSP ID—Invalid LSP ID.
# Display detailed PSNP packet statistics on a per-interface basis.
<Sysname> display isis packet psnp by-interface verbose
                      PSNP packet information for IS-IS(1)
# Display detailed PSNP packet statistics.
<Sysname> display isis packet psnp verbose
Table 17 Command output
reset isis packet
display isis peer
Use display isis peer to display IS-IS neighbor information.
display isis peer [ statistics | verbose ] [ process-id ]
statistics: Displays IS-IS neighbor statistics.
verbose: Displays detailed IS-IS neighbor information. If you do not specify this keyword, the command displays brief IS-IS neighbor information.
process-id: Displays IS-IS neighbor information for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays neighbor information for all IS-IS processes.
# Display brief IS-IS neighbor information.
<Sysname> display isis peer
                         Peer information for IS-IS(1)
 System Id: 0000.0000.0001
 Interface: Vlan100                 Circuit Id:  0000.0000.0001.01
 State: Up     HoldTime:  27s       Type: L1(L1L2)     PRI: 64
 State: Up     HoldTime:  27s       Type: L2(L1L2)     PRI: 64
# Display detailed IS-IS neighbor information.
<Sysname> display isis peer verbose
 System ID: 0000.1111.2222
 Interface: Vlan100                 Circuit Id:  0000.1111.2222.01
 State: Up     Holdtime:   6s       Type: L1(L1L2)     PRI: 64
 Area address(es): 49
 Peer IP address(es): 12.0.0.2
 Peer local circuit ID: 1
 Peer circuit SNPA address: 000c-293b-c4be
 Uptime: 00:05:07
 Adj protocol:  IPv4
 Adj P2P three-way handshake: No
Graceful Restart capable
   Restarting signal: No
   Suppress adjacency advertisement: No
 Local topology:
   0
 Remote topology:
   0    2
 System ID: 0000.0000.0002
 Interface: Vlan101                 Circuit Id:  001
 State: Up     HoldTime: 27s        Type: L1L2         PRI: --
 Peer IP address(es): 192.168.220.30
 Peer circuit SNPA address: 000c-29fd-ed69
 Uptime: 00:05:07
 Adj protocol:  IPv4
 Adj P2P three-way handshake: Yes
   Peer extended circuit ID: 2
Table 18 Command output
System Id
System ID of the neighbor.
Interface connecting to the neighbor.
Circuit Id
Circuit ID.
Circuit state.
HoldTime
Within the holdtime, if no hellos are received from the neighbor, the neighbor is considered down. If a hello is received, the holdtime is reset to the initial value.
Circuit type:
·     L1—Means the circuit type is Level-1 and the neighbor is a Level-1 router.
·     L2—Means the circuit type is Level-2 and the neighbor is a Level-2 router.
·     L1(L1L2)—Means the circuit type is Level-1 and the neighbor is a Level-1-2 router.
·     L2(L1L2)—Means the circuit type is Level-2 and the neighbor is a Level-1-2 router.
PRI
DIS priority of the neighbor.
Area Address(es)
Area address of the neighbor.
Peer IP Address(es)
IP address of the neighbor.
Uptime
Time elapsed since the neighbor relationship was formed.
Adj Protocol
Adjacency protocol: IPv4 or IPv6.
Circuit ID of the neighbor.
SNPA address of the neighbor.
Indicates whether the neighbor supports P2P three-way handshake.
Extended circuit ID of the neighbor interface. This field is available when the neighbor supports three-way handshake.
The neighbor has the GR helper capability.
Restarting signal
RR flag.
SA flag.
Local topology
List of topologies supported by the local interface.
Remote topology
List of topologies supported by the neighbor interface.
# Display IS-IS neighbor statistics.
<Sysname> display isis peer statistics
                    Peer Statistics information for IS-IS(1)
  Type              IPv4 Up/Init              IPv6 Up/Init
  LAN Level-1             1/0                       0/0
  LAN Level-2             1/0                       0/0
  P2P                     0/0                       0/0
Table 19 Command output
Neighbor type:
·     LAN Level-1—Number of Level-1 neighbors whose network type is broadcast.
·     LAN Level-2—Number of Level-2 neighbors whose network type is broadcast.
·     P2P—Number of neighbors whose network type is P2P.
IPv4 Up
Number of IPv4 neighbors in up state.
IPv4 Init
Number of IPv4 neighbors in init state.
IPv6 Up
Number of IPv6 neighbors in up state.
IPv6 Init
Number of IPv6 neighbors in init state.
Use display isis redistribute to display the redistributed IS-IS routing information.
display isis redistribute [ ipv4 [ ip-address mask-length ] ] [ level-1 | level-2 ] [ process-id ]
ipv4: Displays the redistributed IPv4 routing information (the default).
ip-address mask-length: Specifies the destination IP address and mask length.
process-id: Specifies the IS-IS process by its ID in the range of 1 to 65535.
level-1: Displays the IS-IS Level-1 routing information.
level-2: Displays the IS-IS Level-2 routing information.
If you do not specify an IS-IS level, this command displays both Level-1 and Level-2 routing information.
# Display redistributed IPv4 routing information.
<Sysname> display isis redistribute 1
                        Level-1 IPv4 Redistribute Table
 Type IPv4 Destination     IntCost    ExtCost    Tag        State
 D    192.168.30.0/24      0          0                     Active
 D    11.11.11.11/32       0          0
 D    10.10.10.0/24        0          0
Table 20 Command output
IS-IS process of the redistributed routing information.
Redistributed IPv4 routing information of IS-IS Level-1.
Level-2 IPv4 Redistribute Table
Redistributed IPv4 routing information of IS-IS Level-2.
Redistributed route type.
IPV4 Destination
IPv4 destination address.
IntCost
Internal cost of the route.
ExtCost
External cost of the route.
Tag
Tag value.
Indicates whether the route is valid.
display isis route
Use display isis route to display IS-IS IPv4 routing information.
display isis route [ ipv4 [ ip-address mask-length ] ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv4: Displays IS-IS IPv4 routing information (the default).
ip-address mask-length: Displays IS-IS IPv4 routing information for the specified IP address. The mask-length argument is in the range of 0 to 32.
verbose: Displays detailed IS-IS IPv4 routing information. If you do not specify this keyword, the command displays brief IS-IS IPv4 routing information
process-id: Displays IS-IS IPv4 routing information for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays routing information for all IS-IS processes.
level-1: Displays Level-1 IS-IS routes.
level-2: Displays Level-2 IS-IS routes.
If you do not specify a level, this command displays both Level-1 and Level-2 routing information.
# Display brief IS-IS IPv4 routing information.
<Sysname> display isis route
                         Level-1 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 8.8.8.0/24           10         NULL    Vlan100         Direct          D/L/-
 9.9.9.0/24           20         NULL    Vlan100         8.8.8.5         R/L/-
                         Level-2 IPv4 Forwarding Table
 8.8.8.0/24           10         NULL                                    D/L/-
Table 21 Command output
Route information for IS-IS process 1.
IS-IS IPv4 routing information for Level-1.
IS-IS IPv4 routing information for Level-2.
IPv4 Destination
IntCost
Internal cost.
ExtCost
External cost.
ExitInterface
Output interface.
NextHop
Next hop.
Flags
Routing state flag:
·     D—Direct route.
·     R—The route has been added into the routing table.
·     L—The route has been advertised in an LSP.
·     U—Penetration flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
# Display detailed IS-IS IPv4 routing information.
<Sysname> display isis route verbose
 IPV4 Dest : 8.8.8.0/24          Int. Cost : 10               Ext. Cost : NULL
 Admin Tag : -                   Src Count : 2                Flag      : D/L/-
 NextHop   :                     Interface :                  ExitIndex :
    Direct                             Vlan100                    0x00000000
 Nib ID    : 0x0
 IPV4 Dest : 9.9.9.0/24          Int. Cost : 20               Ext. Cost : NULL
 Admin Tag : -                   Src Count : 1                Flag      : R/L/-
    8.8.8.5                            Vlan100                    0x00000003
 Nib ID    : 0x0
Table 22 Command output
IPV4 Dest
IPv4 destination.
Int. Cost
Internal cost.
Ext. Cost
External cost.
Admin Tag
Tag.
Src Count
Count of advertising sources.
Flag
Route state flag:
·     R—The route has been installed into the routing table.
·     L—The route has been flooded in an LSP.
·     U—Route leaking flag. Setting it to UP can prevent an LSP sent from L2 to L1 from being sent back to L2.
Next Hop
Next hop.
Output interface.
ExitIndex
Index of the output interface.
Nib ID
ID assigned by the routing management module (next hop index).
Use display isis spf-tree to display IS-IS IPv4 SPF tree information.
display isis spf-tree [ ipv4 ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
ipv4: Displays IS-IS IPv4 SPF tree information. If you do not specify this keyword, the command displays IS-IS IPv4 SPF tree information.
level-1: Displays Level-1 IS-IS SPF tree information. If you do not specify a level, the command displays both Level-1 and Level-2 SPF tree information.
level-2: Displays Level-2 SPF tree information. If you do not specify a level, the command displays both Level-1 and Level-2 SPF tree information.
verbose: Displays detailed IS-IS SPF tree information. If you do not specify this keyword, the command displays brief IS-IS SPF tree information.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays SPF tree information for all IS-IS processes.
# Display brief IS-IS IPv4 SPF tree information.
<Sysname> display isis spf-tree
                        Shortest Path Tree for IS-IS(1)
      Flags: S-Node is on SPF tree       T-Node is on tent list
             O-Node is overload          R-Node is directly reachable
             I-Node or Link is isolated  D-Node or Link is to be deleted
             C-Neighbor is child         P-Neighbor is parent
             V-Link is involved          N-Link is a new path
             L-Link is on change list    U-Protocol usage is changed
             H-Nexthop is changed
                           Level-1 Shortest Path Tree
SpfNode            NodeFlag       SpfLink            LinkCost LinkFlag
0000.0000.0032.00  S/-/-/-/-/-
                               -->0000.0000.0032.01  10       -/-/C/-/-/-/-/-/-
                               -->0000.0000.0064.00  10       -/-/C/-/-/-/-/-/-
0000.0000.0032.01  S/-/-/R/-/-
                               -->0000.0000.0064.00  0        -/-/C/-/-/-/-/-/-
                               -->0000.0000.0032.00  0        -/-/-/P/-/-/-/-/-
0000.0000.0064.00  S/-/-/R/-/-
                               -->0000.0000.0032.00  10       -/-/-/P/-/-/-/-/-
                               -->0000.0000.0032.01  10       -/-/-/P/-/-/-/-/-
                           Level-2 Shortest Path Tree
# Display detailed IS-IS IPv4 SPF tree information.
<Sysname> display isis spf-tree verbose
 SpfNode        : 0000.0000.0001.00
 Distance       : 0
 TE distance    : 0
 NodeFlag       : S/-/-/-/-/-
 RelayNibID     : 0x0
 TE tunnel count: 0
 Nexthop count  : 0
 SpfLink count  : 1
 -->0000.0000.0004.04
    LinkCost    : 10
    LinkNewCost : 10
    LinkFlag    : -/-/C/-/-/-/-/-/-
    LinkSrcCnt  : 1
        Type: Adjacent       Interface: N/A
        Cost: 10             Nexthop  : N/A
 SpfNode        : 0000.0000.0004.00
 Distance       : 10
 Te Distance    : 10
 RelayNibID     : 0x14000000
 TE tunnel count: 1
     Destination: 4.4.4.4                  Interface  : Tun0
     TE cost    : 10                       Final cost : 10
     Add nexthop: YES                      Add TLV    : YES
 Nexthop count  : 2
     Neighbor   : 0000.0000.0004.00        Interface  : Tun0
     Nexthop    : 4.4.4.4
     BkNeighbor : N/A                      BkInterface: N/A
     BkNexthop  : N/A
     Neighbor   : 0000.0000.0004.00        Interface  : Vlan50
     Nexthop    : 1.1.1.3
     BkNexthop  : N/A
 SpfLink count  : 1
    LinkCost    : 10
    LinkNewCost : 10
    LinkFlag    : -/-/-/P/-/-/-/-/-
    LinkSrcCnt  : 1
        Type: Remote         Interface: N/A
        AdvMtID: 0
 SpfNode        : 0000.0000.0004.04
 Distance       : 10
 TE distance    : 10
 NodeFlag       : S/-/-/R/-/-
 RelayNibID     : 0x14000001
 TE tunnel count: 0
 Nexthop count  : 0
 SpfLink count  : 2
 -->0000.0000.0001.00
    LinkCost    : 0
    LinkNewCost : 0
    LinkSrcCnt  : 1
        Cost: 0              Nexthop  : N/A
 -->0000.0000.0004.00
    LinkCost    : 0
    LinkNewCost : 0
    LinkSrcCnt  : 1
        Type: Remote         Interface: Vlan50
        Cost: 0              Nexthop  : 1.1.1.3
 Distance       : 0
 TE distance    : 0
 RelayNibID     : 0x0
 TE tunnel count: 0
 Nexthop count  : 0
 SpfLink count  : 1
    LinkCost    : 10
    LinkNewCost : 10
    LinkSrcCnt  : 1
 Distance       : 10
 TE distance    : 10
 RelayNibID     : 0x0
 TE tunnel count: 1
 Nexthop count  : 2
     Nexthop    : 4.4.4.4
     BkNexthop  : N/A
     Nexthop    : 1.1.1.3
     BkNexthop  : N/A
 SpfLink count  : 1
    LinkCost    : 10
    LinkNewCost : 10
    LinkSrcCnt  : 1
        AdvMtID: 0
 Distance       : 10
 TE distance    : 10
 RelayNibID     : 0x0
 TE tunnel count: 0
 Nexthop count  : 0
 SpfLink count  : 2
    LinkCost    : 0
    LinkNewCost : 0
    LinkSrcCnt  : 1
    LinkCost    : 0
    LinkNewCost : 0
    LinkSrcCnt  : 1
Table 23 Command output
SpfNode
ID of the topology node.
Distance
Shortest distance from the root node to the local node.
TE distance
Shortest distance from the root node to the local node (including tunnel links). If tunnel is not configured, TE distance equals to Distance.
NodeFlag
Node flag:
·     S—The node is on the SPF tree.
·     T—The node is on the tent list.
·     O—The node is overloaded.
·     R—The node is directly connected.
·     I—The node is isolated.
·     D—The node is to be deleted.
RelayNibID
Next hop ID of the node after route recursion.
TE tunnel count
Number of tunnels destined to this node.
Destination
Destination router.
TE cost
IGP cost of the TE tunnel.
Final cost
Final cost of the TE tunnel.
Nexthop count
Next hop count.
Nexthop
Primary next hop of the node or the link advertising source.
AdvMtID
Topology from which the routing information is learned:
·     0—Base topology.
·     6-4094—Other topologies.
Primary output interface of the node or the link advertising source.
BkNexthop
Backup next hop.
BkInterface
Backup output interface.
Neighbor
ID of the primary next hop neighbor.
BkNeighbor
ID of the backup next hop neighbor.
SpfLink
Topology link.
SpfLink count
Number of topology links.
LinkCost
Link cost.
LinkNewCost
New link cost.
LinkFlag
Link flag:
·     I—The link is isolated.
·     D—The link is to be deleted.
·     C—The neighbor is a child node.
·     P—The neighbor is the parent node.
·     V—The link is involved.
·     N—The link is a new path.
·     L—The link is on the change list.
·     U—The protocol usage of the link is changed.
·     H—The next hop of the link is changed.
LinkSrcCnt
Number of link advertising sources.
Type of the link advertising source:
·     Adjacent—The link advertising source is a local neighbor.
·     Remote—The link advertising source is advertised by a remote node in an LSP.
Cost
Cost of the link advertising source.
Use display isis statistics to display IS-IS statistics.
display isis statistics [ ipv4 ] [ level-1 | level-1-2 | level-2 ] [ process-id ]
ipv4: Displays IS-IS IPv4 statistics. If you do not specify this option, the command displays both IPv4 and IPv6 statistics.
level-1: Displays IS-IS Level-1 statistics.
level-1-2: Displays IS-IS Level-1-2 statistics.
level-2: Displays IS-IS Level-2 statistics.
process-id: Displays statistics for an IS-IS process specified by its ID in the range of 1 to 65535. If you do not specify an IS-IS process, this command displays the statistics for all IS-IS processes.
# Display IS-IS statistics.
<Sysname> display isis statistics
                               Level-1 Statistics
MTR(base)
Learnt routes information:
         Total IPv4 Learnt Routes in IPv4 Routing Table: 1
Imported routes information:
         IPv4 Imported Routes:
                         Static: 0       Direct: 0
                         ISIS:   0       BGP:    0
                         RIP:    0       OSPF:   0
                         Total Number:   0
MTR(base)
         Total IPv6 Learnt Routes in IPv6 Routing Table: 0
         IPv6 Imported Routes:
                         Static: 0       Direct: 0
                         ISISv6: 0       BGP4+:  0
                         RIPng:  0       OSPFv3: 0
                         Total Number:   0
Lsp information:
                  LSP Source ID:          No. of used LSPs
                  7777.8888.1111                  001
                               Level-2 Statistics
MTR(base)
         Total IPv4 Learnt Routes in IPv4 Routing Table: 0
                         Static: 0       Direct: 0
                         ISIS:   0       BGP:    0
                         RIP:    0       OSPF:   0
                         Total Number:   0
MTR(base)
                         Static: 0       Direct: 0
                         ISISv6: 0       BGP4+:  0
                         RIPng:  0       OSPFv3: 0
                         Total Number:   0
Lsp information:
                  7777.8888.1111                  001
Table 24 Command output
Statistics information for IS-IS(processid)
Statistics for the IS-IS process.
Level-1 Statistics
Level-1 statistics.
Level-2 Statistics
Level-2 statistics.
MTR(topo-name)
MTR topology. base represents the base topology.
·     Total IPv4 Learnt Routes in IPv4 Routing Table—Number of learned IPv4 routes.
·     Total IPv6 Learnt Routes in IPv6 Routing Table—Number of learned IPv6 routes.
Numbers of different types of redistributed IPv4 routes, including static, direct, IS-IS, BGP, RIP, and OSPF routes.
Numbers of different types of redistributed IPv6 routes, including static, direct, IS-ISv6, BGP4+, RIPng, and OSPFv3 routes.
Lsp information
LSP information:
·     LSP Source ID—ID of the source system.
·     No. of used LSPs—Number of used LSPs.
display osi
Use display osi to display OSI connection information.
In standalone mode:
display osi [ slot slot-number ]
In IRF mode:
display osi [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays OSI connection information for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. On an IRF fabric, this command displays OSI connection information for all cards if you do not specify a card. On an IRF 3 system, this command displays OSI connection information for all cards and PEXs if you do not specify a card or PEX. (In IRF mode.)
# (In standalone mode.) Display OSI connection information.
<Sysname> display osi
Total OSI socket number: 2
 Creator: isisd[1539]
 State: N/A
 Options: SO_FILTER
 Error: 0
 Receiving buffer(cc/hiwat/lowat/drop/state): 0 / 1048576 / 1 / 0 / N/A
 Sending buffer(cc/hiwat/lowat/state): 0 / 262144 / 512 / N/A
 Type: 2
 Enabled interfaces:
  Vlan-interface100
   MAC address: 0180-c200-0014
 State: N/A
 Options: SO_FILTER
 Error: 0
 Type: 2
 Enabled interfaces:
  Vlan-interface100
Table 25 Command output
Total number of OSI sockets.
Creator
Name of the socket creator. The process ID of the creator is displayed in the square brackets.
This field always displays N/A.
Options
Socket options:
·     SO_FILTER—Filter option is configured.
·     N/A—No option is configured.
Error
Number of errors that affect the socket session.
Receiving buffer information, including the current used space, maximum space, minimum space, number of dropped packets, and status.
Sending buffer information, including the current used space, maximum space, minimum space, and status.
Type 2 socket, corresponding to unreliable connectionless-oriented transport layer protocols.
Enabled interfaces
Input interfaces and matched multicast MAC addresses. Only packets received from Ethernet link-layer interfaces need to match the multicast MAC addresses.
display osi statistics
Use display osi statistics to display OSI packet statistics.
In standalone mode:
display osi statistics [ slot slot-number ]
In IRF mode:
display osi statistics [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays OSI packet statistics for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. On an IRF fabric, this command displays OSI packet statistics for all cards if you do not specify a card. On an IRF 3 system, this command displays OSI packet statistics for all cards and PEXs if you do not specify a card or PEX. (In IRF mode.)
# Display OSI packet statistics.
<Sysname> display osi statistics
Received packets:
     Total: 35
     Relay received: 35
     Relay forwarded: 35
     Invalid service slot: 0
     No matched socket: 0
     Not delivered, input socket full: 0
Sent packets:
     Total: 19
     Relay forwarded: 19
     Relay received: 19
     Failed: 0
Table 26 Command output
Received packets
Statistics of received packets:
·     Total—Total number of received link layer packets.
·     Relay received—Number of inbound packets on LPUs relayed from other cards. This count is not included in the total count of received packets.
·     Relay forwarded—Number of inbound packets relayed to LPUs.
·     Invalid service slot—Number of discarded packets due to unavailable LPUs.
·     No matched socket—Number of discarded packets due to mismatches in input interfaces, MAC addresses, or connection filter criteria.
·     Not delivered, input socket full—Number of undelivered packets due to a socket receiving buffer overflow.
Sent packets
Statistics of sent packets:
·     Total—Total number of packets that IS-IS sent over OSI connections.
·     Relay forwarded—Number of outbound packets relayed to the cards that hosts the output interfaces. This count is not included in the total count of sent packets.
·     Relay received—Number of outbound packets on the cards that hosts the output interfaces. These packets are relayed from other cards.
·     Failed—Number of packets failed to be sent.
reset osi statistics
domain-authentication send-only
Use domain-authentication send-only to configure IS-IS not to check the authentication information in the received Level-2 packets, including LSPs, CSNPs, and PSNPs.
Use undo domain-authentication send-only to restore the default.
When domain authentication mode and key are configured, a Level-2 or Level-1-2 router checks the authentication information in the received packets.
IS-IS view
When domain authentication mode and key are configured, a Level-2 or Level-1-2 router adds the key in the specified mode into transmitted Level-2 packets (including LSPs, CSNPs, and PSNPs). It also checks the key in the received Level-2 packets.
To prevent packet exchange failure in case of an authentication key change, configure IS-IS not to check the authentication information in the received packets.
# Configure IS-IS not to check the authentication information in the received packets.
[Sysname] isis 1
[Sysname-isis-1] domain-authentication send-only
area-authentication send-only
domain-authentication-mode
isis authentication send-only
Use domain-authentication-mode to specify the routing domain authentication mode and a key.
Use undo domain-authentication-mode to restore the default.
domain-authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ ip | osi ]
No routing domain authentication mode or key is configured.
IS-IS view
gca: Specifies the GCA mode.
key-id: Uniquely identifies an SA in the range of 1 to 65535. The sender inserts the Key ID into the authentication TLV, and the receiver authenticates the packet by using the SA that is selected based on the Key ID.
hmac-sha-1: Specifies the HMAC-SHA-1 algorithm.
hmac-sha-224: Specifies the HMAC-SHA-224 algorithm.
hmac-sha-256: Specifies the HMAC-SHA-256 algorithm.
hmac-sha-384: Specifies the HMAC-SHA-384 algorithm.
hmac-sha-512: Specifies the HMAC-SHA-512 algorithm.
nonstandard: Specifies the nonstandard GCA authentication mode.
md5: Specifies the MD5 authentication mode.
simple: Specifies the simple authentication mode.
plain: Specifies a key in plaintext form. For security purposes, the key specified in plaintext form will be stored in encrypted form.
string: Specifies the key. Its plaintext form is a case-sensitive string of 1 to 16 characters. Its encrypted form is a case-sensitive string of 33 to 53 characters.
keychain: Specifies the keychain authentication mode.
keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters.
ip: Checks IP-related fields in LSPs.
osi: Checks OSI-related fields in LSPs.
The configured key in the specified mode is inserted into all outgoing Level-2 packets (LSP, CSNP, and PSNP) and is used for authenticating the incoming Level-2 packets.
IS-IS keychain authentication can operate correctly only when the keys in the keychain use the HMAC-MD5 authentication algorithm.
·     Before IS-IS sends a Level-2 packet, it uses the valid send key obtained from the keychain to authenticate the packet. If no valid send key exists or the valid send key does not use the HMAC-MD5 algorithm, the authentication fails and the packet does not contain the authentication information.
·     After IS-IS receives a Level-2 packet, it uses a valid accept key obtained from the keychain to authenticate the packet. If no valid accept key exists or all valid accept keys fail to authenticate the packet, the authentication fails and the packet is discarded.
All the backbone routers must have the same authentication mode and key.
If neither ip nor osi is specified, the OSI-related fields in LSPs are checked.
When you specify the GCA mode, follow these guidelines:
·     If you do not specify the nonstandard keyword, the device can communicate only with devices that use the GCA mode.
·     If you specify the nonstandard keyword, the device can communicate only with devices that use the nonstandard GCA mode.
# Set the routing domain authentication mode to simple, and set the plaintext key to 123456.
[Sysname] isis 1
[Sysname-isis-1] domain-authentication-mode plain 123456
area-authentication-mode
isis authentication-mode
fast-reroute
Use fast-reroute to configure IS-IS FRR.
Use undo fast-reroute to disable IS-IS FRR.
fast-reroute { lfa | route-policy route-policy-name }
undo fast-reroute
lfa: Calculates a backup next hop through Loop Free Alternate (LFA) calculation for all routes.
route-policy route-policy-name: Uses the specified routing policy to designate a backup next hop. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
The LFA calculation of FRR and IS-IS TE are mutually exclusive.
Example
# Enable FRR for IS-IS process 1 and configure IS-IS FRR to calculate a backup next hop through LFA calculation for all routes.
[Sysname] isis 1
[Sysname-isis-1-ipv4] fast-reroute lfa
filter-policy export
Use filter-policy export to configure IS-IS to filter redistributed routes.
Use undo filter-policy export to remove the configuration.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
IS-IS does not filter redistributed routes.
IS-IS IPv4 unicast address family view
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter redistributed routes.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes by destination address.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes.
protocol: Filters routes redistributed from the specified routing protocol. If no protocol is specified, the command filters all redistributed routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. This argument is available only when the protocol is isis, ospf, or rip. The default process ID is 1.
To use an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL using one of the following methods:
·     To deny/permit a route with the specified destination, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard command.
·     To deny/permit a route with the specified destination and mask, use the rule [ rule-id ] { deny | permit } ip source sour-addr sour-wildcard destination dest-addr dest-wildcard command.
The source keyword specifies the destination address of a route and the destination keyword specifies the subnet mask of the route. For the configuration to take effect, specify a contiguous subnet mask.
# Use basic ACL 2000 to filter redistributed routes.
[Sysname] acl basic 2000
[Sysname-acl-ipv4-basic-2000] rule deny source 192.168.10.0 0.0.0.255
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] filter-policy 2000 export
# Configure advanced ACL 3000 to permit only route 113.0.0.0/16 to pass. Use advanced ACL 3000 to filter redistributed routes.
[Sysname] acl advanced 3000
[Sysname-acl-ipv4-adv-3000] rule 10 permit ip source 113.0.0.0 0 destination 255.255.0.0 0
[Sysname-acl-ipv4-adv-3000] rule 100 deny ip
[Sysname] isis 1
[Sysname-isis 1] address-family ipv4
[Sysname-isis-1-ipv4] filter-policy 3000 export
display isis route
filter-policy import
Use filter-policy import to configure IS-IS to filter routes calculated using received LSPs.
Use undo filter-policy import to restore the default.
filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import
IS-IS does not filter routes calculated using received LSPs.
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter routes calculated using received LSPs.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes calculated using received LSPs by destination address.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter received routes.
# Use basic ACL 2000 to filter routes calculated using received LSPs.
[Sysname] isis 1
[Sysname-isis-1-ipv4] filter-policy 2000 import
# Use advanced ACL 3000 to filter routes calculated using received LSPs and install only route 113.0.0.0/16 to the IP routing table.
[Sysname] isis 1
[Sysname-isis-1-ipv4] filter-policy 3000 import
display ip routing-table
flash-flood
Use flash-flood to enable IS-IS LSP flash flooding.
Use undo flash-flood to disable IS-IS LSP flash flooding.
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval | [ level-1 | level-2 ] ] *
undo flash-flood [ level-1 | level-2 ]
IS-IS LSP flash flooding is disabled.
IS-IS view
flood-count flooding-count: Specifies the maximum number of LSPs to be flooded before the next SPF calculation, in the range of 1 to 15. The default is 5.
max-timer-interval flooding-interval: Specifies the delay of the flash flooding, in the range of 10 to 50000 milliseconds. The default is 10.
level-1: Enables flash flooding for level-1.
level-2: Enables flash flooding for level-2.
If no level is specified, the command enables IS-IS LSP flash flooding for both Level-1 and Level-2.
# Enable fast flooding, and set the maximum LSPs to be sent to 10 and the delay time to 100 milliseconds.
[Sysname] isis 1
[Sysname-isis-1] flash-flood flood-count 10 max-timer-interval 100
graceful-restart
Use graceful-restart to enable IS-IS GR.
Use undo graceful-restart to disable IS-IS GR.
graceful-restart
IS-IS GR is disabled.
IS-IS view
IS-IS GR and IS-IS NSR are mutually exclusive. Therefore, do not configure the graceful-restart command and the non-stop-routing command at the same time.
# Enable GR for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart
graceful-restart suppress-sa
Use graceful-restart suppress-sa to suppress the Suppress-Advertisement (SA) bit during restart.
Use undo graceful-restart suppress-sa to restore the default.
The SA bit is set during restart.
IS-IS view
Suppressing the SA bit is mainly for avoiding black hole route. If a router starts or reboots without keeping the local forwarding table, sending packets to the router might result in severe packet loss. To avoid this, you can set the SA bit of the hello packet sent by the GR restarter to 1. Upon receiving such hello packets, the GR helpers will not advertise the GR restarter through LSP.
# Suppress the SA bit during graceful restart.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart suppress-sa
graceful-restart
graceful-restart t1
Use graceful-restart t1 to set the T1 timer.
Use undo graceful-restart t1 to restore the default.
graceful-restart t1 seconds count count
The T1 timer is 3 seconds and can expire 10 times.
IS-IS view
seconds: Specifies the T1 timer in the range of 3 to 10 seconds.
count: Specifies the number of times that the T1 timer can expire, in the range of 1 to 20.
The T1 timer specifies the number of times that GR restarter can send a Restart TLV with the RR bit set. After restart, the GR restarter sends a Restart TLV with the RR bit set to its neighbor. If the restarting router receives a Restart TLV with the RA set from its neighbor before the T1 timer expires, the GR process starts. Otherwise, the GR process fails.
# Set the T1 timer of IS-IS process 1 to 5 seconds, and the expiration times to 5.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart t1 5 count 5
graceful-restart
graceful-restart t2
graceful-restart t3
graceful-restart t2
Use graceful-restart t2 to set the T2 timer.
Use undo graceful-restart t2 to restore the default.
graceful-restart t2 seconds
The T2 timer is 60 seconds.
IS-IS view
seconds: Specifies the T2 timer in the range of 30 to 65535 seconds.
The T2 timer specifies the LSDB synchronization interval. Each LSDB has a T2 timer. The Level-1-2 router has two T2 timers: a Level-1 timer and a Level-2 timer. If the LSDBs have not achieved synchronization before the two timers expire, the GR process fails.
# Set the T2 timer of IS-IS process 1 to 50 seconds.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart t2 50
graceful-restart
graceful-restart t1
graceful-restart t3
graceful-restart t3
Use graceful-restart t3 to set the T3 timer.
Use undo graceful-restart t3 to restore the default.
graceful-restart t3 seconds
The T3 timer is 300 seconds.
IS-IS view
seconds: Specifies the T3 timer in the range of 300 to 65535 seconds.
The T3 timer specifies the GR interval. The GR interval is set as the holdtime in hello PDUs. Within the interval, the neighbors maintain their adjacency with the GR restarter. If the GR process has not completed within the holdtime, the neighbors tear down the neighbor relationship and the GR process fails.
# Set the T3 timer of IS-IS process 1 to 500 seconds.
[Sysname] isis 1
[Sysname-isis-1] graceful-restart t3 500
graceful-restart
graceful-restart t1
graceful-restart t2
ignore-att
Use ignore-att to configure IS-IS not to calculate the default route through the ATT bit.
Use undo ignore-att to restore the default.
ignore-att
undo ignore-att
IS-IS calculates the default route through the ATT bit.
IS-IS view
# Configure IS-IS not to calculate the default route through the ATT bit.
[Sysname] isis 1
[Sysname-isis-1] ignore-att
import-route
Use import-route to redistribute routes from another routing protocol or another IS-IS process.
Use undo import-route to remove the redistribution.
import-route protocol [ as-number ] [ process-id | all-processes | allow-ibgp ] [ allow-direct | cost cost-value | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
IS-IS does not redistribute routes from other routing protocols or processes.
protocol: Redistributes routes from a routing protocol.
as-number: Specifies an AS by its number in the range of 1 to 4294967295. This argument applies only to the BGP protocol. If you do not specify this argument, the command redistributes all IPv4 EBGP routes. As a best practice, specify an AS to prevent the system from redistributing excessive routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. It is available only when the protocol is isis, ospf, or rip.
all-processes: Redistributes routes from all the processes of the specified routing protocol. This keyword takes effect only when the protocol is rip, ospf, or isis.
allow-ibgp: Allows redistribution of IBGP routes. It is available when the protocol is BGP.
allow-direct: Redistributes the networks of the local interfaces enabled with the specified routing protocol. By default, the networks of the local interfaces are not redistributed. If you specify both the allow-direct keyword and the route-policy route-policy-name option, make sure the if-match rule defined in the routing policy does not conflict with the allow-direct keyword. For example, if you specify the allow-direct keyword, do not configure the if-match route-type rule for the routing policy. Otherwise, the allow-direct keyword does not take effect.
cost cost-value: Specifies a cost for redistributed routes, which is in the range of 0 to 4261412864.
·     For the styles of narrow, narrow-compatible, and compatible, the cost is in the range of 0 to 63.
·     For the styles of wide and wide-compatible, the cost is in the range of 0 to 4261412864.
cost-type { external | internal }: Specifies the cost type. The internal type indicates internal routes, and the external type indicates external routes. If external is specified, the cost of a redistributed route is added by 64 to make internal routes take priority over external routes. The type is external by default. The keywords are available only when the cost type is narrow, narrow-compatible, or compatible.
level-1: Redistributes routes into the Level-1 routing table.
level-1-2: Redistributes routes into both Level-1 and Level-2 routing tables.
level-2: Redistributes routes into the Level-2 routing table. If no level is specified, the routes are redistributed into the Level-2 routing table by default.
route-policy route-policy-name: Redistributes only routes matching the specified routing policy. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag value for marking redistributed routes, in the range of 1 to 4294967295.
IS-IS takes all the redistributed routes as external routes to destinations outside the IS-IS routing domain.
The effective cost varies by cost style. For the styles of narrow, narrow-compatible, and compatible, the cost is in the range of 0 to 63. If the cost is more than 63, 63 is used. For the style of wide or wide-compatible, the configured value is the effective value.
This import-route command cannot redistribute default routes. The command redistributes only active routes. To display route state information, use the display ip routing-table protocol command.
The import-route bgp command redistributes only EBGP routes.
The import-route bgp allow-ibgp command redistributes both EBGP and IBGP routes. Because this command might cause routing loops, use it with caution.
The undo import-route protocol all-processes command removes only the configuration made by the import-route protocol all-processes command, instead of the configuration made by the import-route protocol process-id command.
# Redistribute static routes into IS-IS, and set the cost for redistributed routes to 15.
[Sysname] isis 1
[Sysname-isis-1-ipv4] import-route static cost 15
import-route limit
import-route isis level-1 into level-2
Use import-route isis level-1 into level-2 to enable route advertisement from Level-1 to Level-2.
Use undo import-route isis level-1 into level-2 to disable route advertisement from Level-1 to Level-2.
import-route isis level-1 into level-2 [ filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
Route advertisement from Level-1 to Level-2 is enabled.
filter-policy: Specifies a filtering policy.
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter routes from Level-1 to Level-2.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes from Level-1 to Level-2 by destination address.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter routes from Level-1 to Level-2.
tag tag: Specifies a tag for marking redistributed routes, in the range of 1 to 4294967295.
If a routing policy is used, the routing policy must be specified in the import-route isis level-1 into level-2 command to filter routes from Level-1 to Level-2. Other routing policies specified for route reception and redistribution do not affect the route leaking.
If a filtering policy is configured, only Level-1 routes not filtered out can be advertised into the Level-2 area.
# Enable route advertisement from Level-1 to Level-2.
[Sysname] isis 1
[Sysname-isis-1-ipv4] import-route isis level-1 into level-2
import-route
import-route isis level-2 into level-1
Use import-route isis level-2 into level-1 to enable route advertisement from Level-2 to Level-1.
Use undo import-route isis level-2 into level-1 to restore the default.
import-route isis level-2 into level-1 [ filter-policy { ipv4-acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
Route advertisement from Level-2 to Level-1 is disabled.
ipv4-acl-number: Specifies an ACL by its number in the range of 2000 to 3999 to filter routes from Level-2 to Level-1.
prefix-list prefix-list-name: Specifies an IPv4 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes from Level-2 to Level-1 by destination address.
route-policy route-policy-name: Uses the specified routing policy to filter routes from Level-2 to Level-1. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
If a routing policy is used, the routing policy must be specified in the import-route isis level-2 into level-1 command to filter routes from Level-2 to Level-1. Other routing policies specified for route reception and redistribution does not affect the route leaking.
If a filtering policy is configured, only Level-2 routes not filtered out can be advertised into the Level-1 area.
# Enable route advertisement from Level-2 to Level-1.
[Sysname] isis 1
[Sysname-isis-1-ipv4] import-route isis level-2 into level-1
import-route
import-route limit
Use import-route limit to configure the maximum number of redistributed Level 1/Level 2 IPv4 routes.
Use undo import-route limit to restore the default.
import-route limit number
The maximum number of redistributed Level 1/Level 2 IPv4 routes is not configured.
number: Specifies the maximum number of redistributed Level 1/Level 2 IPv4 routes. The value range for this argument is 1 to 1048576.
# Configure IS-IS process 1 to redistribute up to 1000 Level 1/Level 2 IPv4 routes.
[Sysname] isis 1
[Sysname-isis-1-ipv4] import-route limit 1000
import-route
isis
Use isis to enable IS-IS and enter IS-IS view.
Use undo isis to disable IS-IS.
undo isis [ process-id ]
IS-IS is disabled.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. The default is 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If no VPN instance is specified, the IS-IS process runs on the public network.
# Enable IS-IS process 1 and set the system ID to 0000.0000.0002 and area ID to 01.0001.
[Sysname] isis 1
[Sysname-isis-1] network-entity 01.0001.0000.0000.0002.00
isis enable
network-entity
Use isis authentication send-only to configure an IS-IS interface not to check the authentication information in the received hello packets.
Use undo isis authentication send-only to remove the configuration.
isis authentication send-only [ level-1 | level-2 ]
undo isis authentication send-only [ level-1 | level-2 ]
When interface authentication mode and key are configured, an IS-IS interface checks the authentication information in the received packets.
Interface view
level-1: Configures IS-IS not to check the authentication information in the received Level-1 hello packets.
level-2: Configures IS-IS not to check the authentication information in the received Level-2 hello packets.
When peer authentication mode and key are configured, an IS-IS interface adds the key in the specified mode into transmitted hello packets. It also checks the key in the received hello packets.
To prevent packet exchange failure in case of an authentication key change, configure the IS-IS interface not to check the authentication information in the received packets.
# Configure VLAN-interface 10 not to check the authentication information in the received Level-1 hello packets.
[Sysname-Vlan-interface10] isis authentication send-only level-1
Use isis authentication-mode to specify the neighbor relationship authentication mode and a key.
Use undo isis authentication-mode to remove the configuration.
isis authentication-mode { { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } [ nonstandard ] | md5 | simple } { cipher | plain } string | keychain keychain-name } [ level-1 | level-2 ] [ ip | osi ]
undo isis authentication-mode [ level-1 | level-2 ]
No neighbor relationship authentication mode or key is configured.
Interface view
nonstandard: Specifies the nonstandard GCA mode.
level-1: Configures the key for Level-1.
level-2: Configures the key for Level-2.
ip: Checks IP-related fields in LSPs and SNPs.
osi: Checks OSI-related fields in LSPs and SNPs.
The key in the specified mode is inserted into all outbound hello packets and is used for authenticating inbound hello packets. Only if the authentication succeeds can the neighbor relationship be formed.
·     Before IS-IS sends a Hello packet, it uses the valid send key obtained from the keychain to authenticate the packet. If no valid send key exists or the valid send key does not use the HMAC-MD5 algorithm, the authentication fails and the packet does not contain the authentication information.
·     After IS-IS receives a Hello packet, it uses a valid accept key obtained from the keychain to authenticate the packet. If no valid accept key exists or all valid accept keys fail to authenticate the packet, the authentication fails and the packet is discarded.
The level-1 and level-2 keywords are configurable on an interface that has had IS-IS enabled with the isis enable command.
If you configure a key without specifying a level, the key applies to both Level-1 and Level-2.
For two routers to become neighbors, the authentication mode and key at both ends must be identical.
# On VLAN-interface 10, set the authentication mode to simple, and set the plaintext key to 123456.
[Sysname-Vlan-interface10] isis authentication-mode simple plain 123456
domain authentication-mode
isis bfd enable
Use isis bfd enable to enable BFD.
Use undo isis bfd enable to disable BFD.
isis bfd enable
IS-IS BFD is disabled.
Interface view
# Enable BFD for IS-IS on VLAN-interface 11.
[Sysname-Vlan-interface11] isis enable
[Sysname-Vlan-interface11] isis bfd enable
isis circuit-level
Use isis circuit-level to set the circuit level for the interface.
Use undo isis circuit-level to restore the default.
isis circuit-level [ level-1 | level-1-2 | level-2 ]
An interface can establish either the Level-1 or Level-2 adjacency.
Interface view
level-1: Sets the circuit level to Level-1.
level-1-2: Sets the circuit level to Level-1-2.
level-2: Sets the circuit level to Level-2.
For a Level-1 (Level-2) router, the circuit level can only be Level-1 (Level-2). For a Level-1-2 router, you must specify a circuit level for a specific interface to form only the specified level neighbor relationship.
# VLAN-interface 10 is connected to a non-backbone router in the same area. Set the circuit level of VLAN-interface 10 to Level-1 to prevent sending and receiving Level-2 Hello packets.
[Sysname-Vlan-interface10] isis enable
[Sysname-Vlan-interface10] isis circuit-level level-1
is-level
isis circuit-type p2p
Use isis circuit-type p2p to set the network type of an interface to P2P.
Use undo isis circuit-type to restore the default.
The network type of an interface varies by physical media. (The network type of a VLAN interface is broadcast.)
Interface view
Use this command only on a broadcast network with two attached routers.
Interfaces with different network types operate differently. For example, broadcast interfaces must elect a DIS and flood CSNP packets to synchronize the LSDBs. P2P interfaces do not need to elect a DIS, and use a different LSDB synchronization mechanism.
If only two routers exist on a broadcast network, set the network type of attached interfaces to P2P to avoid DIS election and CSNP flooding. This saves network bandwidth and speeds up network convergence.
# Set the network type of VLAN-interface 10 to P2P.
[Sysname-Vlan-interface10] isis circuit-type p2p
isis cost
Use isis cost to set the IS-IS cost for an interface.
Use undo isis cost to remove the configuration.
isis cost cost-value [ level-1 | level-2 ]
undo isis cost [ level-1 | level-2 ]
No IS-IS cost is configured for an interface.
Interface view
cost-value: Specifies an IS-IS cost in the range of 1 to 16777215.
level-1: Applies the cost to Level-1.
level-2: Applies the cost to Level-2.
If neither level-1 nor level-2 is included, the cost applies to both level-1 and level-2.
# Set the Level-2 IS-IS cost to 5 for VLAN-interface 10.
[Sysname-Vlan-interface10] isis cost 5 level-2
auto-cost enable
bandwidth-reference
isis dis-name
Use isis dis-name to configure a name for a DIS to represent the pseudo node on a broadcast network.
Use undo isis dis-name to restore the default.
isis dis-name symbolic-name
undo isis dis-name
No name is configured for the DIS.
Interface view
symbolic-name: Specifies a DIS name, a case-insensitive string of 1 to 64 characters.
This command takes effect only on routers that have dynamic system ID to host name mapping enabled. This command does not take effect on Point-to-Point interfaces.
# Set the DIS name to LOCALAREA.
[Sysname-Vlan-interface10] isis dis-name LOCALAREA
is-name
isis dis-priority
Use isis dis-priority to specify a DIS priority at a specified level for an interface.
Use undo isis dis-priority to remove the configuration.
isis dis-priority priority [ level-1 | level-2 ]
undo isis dis-priority [ level-1 | level-2 ]
The priority of Level-1 and Level-2 is 64.
Interface view
priority: Specifies a DIS priority in the range of 0 to 127.
level-1: Applies the DIS priority to Level-1.
level-2: Applies the DIS priority to Level-2.
On an IS-IS broadcast network, a router must be elected as the DIS at each routing level. Specify a DIS priority at a level for an interface. The greater the interface's priority is, the more likelihood it becomes the DIS. If multiple routers in the broadcast network have the same highest DIS priority, the router with the highest Subnetwork Point of Attachment (SNPA) address becomes the DIS. SNPA addresses are MAC addresses on a broadcast network.
IS-IS has no backup DIS. The router with a priority of 0 can also participate in DIS election.
If neither level-1 nor level-2 is specified, the DIS priority applies to both Level-1 and Level-2.
# Set the Level-2 DIS priority to 127 for VLAN-interface 10.
[Sysname-Vlan-interface10] isis dis-priority 127 level-2
isis enable
Use isis enable to enable an IS-IS process on an interface.
Use undo isis enable to disable IS-IS.
isis enable [ process-id ]
undo isis enable
No IS-IS process is enabled on an interface.
Interface view
# Enable IS-IS process 1 globally and enable it on VLAN-interface 10.
[Sysname] isis 1
[Sysname-isis-1] network-entity 10.0001.1010.1020.1030.00
[Sysname-isis-1] quit
[Sysname-Vlan-interface10] isis enable 1
isis
network-entity
isis fast-reroute lfa-backup exclude
Use isis fast-reroute lfa-backup exclude to disable LFA calculation on an interface.
Use undo isis fast-reroute lfa-backup exclude to restore the default.
LFA calculation is enabled on an interface, and the interface can be elected as a backup interface.
Interface view
When this command is configured, the interface does not participate in the LFA calculation, and cannot be elected as a backup interface.
# Disable LFA calculation on VLAN-interface 10.
[Sysname] isis 1
[Sysname-Vlan-interface10] isis fast-reroute lfa-backup exclude
fast-reroute
isis mesh-group
Use isis mesh-group to add an interface into a mesh group or block the interface.
Use undo isis mesh-group to restore the default.
isis mesh-group { mesh-group-number | mesh-blocked }
An interface does not belong to any mesh group and is not blocked.
Interface view
mesh-group-number: Specifies a mesh group by its number in the range of 1 to 4294967295.
mesh-blocked: Configures the interface to send LSPs only after receiving LSP requests.
An interface not in a mesh group floods received LSPs to other interfaces. For an NBMA network with multiple point-to-point links, this mechanism causes repeated LSP flooding and bandwidth waste.
To solve this problem, use this command to add relevant interfaces to a mesh group. An interface in a mesh group only floods a received LSP to interfaces not in the same mesh group.
You can also use this command to block an interface. A blocked interface sends LSPs only after receiving LSP requests.
The mesh-group feature takes effect only on point-to-point links.
# Add VLAN interface VLAN-interface 10 to mesh group 3.
[Sysname-Vlan-interface10] isis mesh-group 3
isis mib-binding
Use isis mib-binding to bind an IS-IS process to MIB.
Use undo  isis mib-binding to restore the default.
isis mib-binding process-id
MIB operation is bound to the IS-IS process with the smallest process ID.
If the specified the process ID does not exist, the MIB binding configuration fails.
Deleting an IS-IS process bound to MIB operation deletes the MIB binding configuration. MIB operation is bound to the IS-IS process with the smallest process ID.
# Bind IS-IS process 100 to MIB.
[Sysname] isis mib-binding 100
isis prefix-suppression
Use isis prefix-suppression to enable prefix suppression on an interface.
Use undo isis prefix-suppression to disable prefix suppression on an interface.
Prefix suppression is disabled on an interface.
Interface view
Use this command to disable an interface from advertising its prefix in LSPs. This enhances network security by preventing IP routing to the interval nodes and speeds up network convergence.
This command is also applicable to the secondary IP address of the interface.
# Enable prefix suppression on VLAN-interface 10.
[Sysname-Vlan-interface10] isis prefix-suppression
isis primary-path-detect bfd
Use isis primary-path-detect bfd echo to enable BFD for IS-IS FRR or IS-IS PIC.
Use undo isis primary-path-detect bfd to disable BFD for IS-IS FRR or IS-IS PIC.
isis primary-path-detect bfd { ctrl | echo }
BFD is disabled for IS-IS FRR or IS-IS PIC.
Interface view
ctrl: Specifies the BFD control packet mode.
echo: Specifies the BFD echo packet mode.
This command enables IS-IS FRR or IS-IS PIC to use BFD to detect primary link failures.
# Enable BFD control packet mode for IS-IS FRR on VLAN-interface 10.
[Sysname] isis 1
[Sysname-isis-1-ipv4] quit
[Sysname-Vlan-interface10] isis primary-path-detect bfd ctrl
# Enable BFD echo packet mode for IS-IS PIC on VLAN-interface 11.
[Sysname] isis 1
[Sysname-isis-1] pic additional-path-always
[Sysname-Vlan-interface11] isis primary-path-detect bfd echo
isis silent
Use isis silent to disable the interface from sending and receiving IS-IS packets.
Use undo isis silent to restore the default.
isis silent
undo isis silent
An interface can send and receive IS-IS packets.
Interface view
This command is not available in loopback interface view.
# Disable VLAN-interface 10 from sending and receiving IS-IS packets.
[Sysname-Vlan-interface10] isis silent
isis small-hello
Use isis small-hello to configure the interface to send small hello packets without CLVs.
Use undo isis small-hello to restore the default.
isis small-hello
An interface sends standard hello packets.
Interface view
# Configure VLAN-interface 10 to send small Hello packets.
[Sysname-Vlan-interface10] isis small-hello
isis tag
Use isis tag to configure the tag value for an interface.
Use undo isis tag to restore the default.
isis tag tag
undo isis tag
The interface is not configured with a tag value.
Interface view
tag: Specifies the tag value in the range of 1 to 4294967295.
When IS-IS advertises an IP prefix with a tag value, it adds the tag to the IP reachability information TLV if the link cost style is wide, wide-compatible, or compatible.
# Configure the tag value for VLAN-interface 10.
[Sysname-Vlan-interface10] isis tag 4294967295
isis timer csnp
Use isis timer csnp to set on the DIS of a broadcast network the interval for sending CSNP packets.
Use undo isis timer csnp to remove the configuration.
isis timer csnp seconds [ level-1 | level-2 ]
undo isis timer csnp [ level-1 | level-2 ]
The default CSNP interval is 10 seconds.
Interface view
seconds: Specifies on the DIS of a broadcast network the interval for sending CSNP packets. The value range is 1 to 600 seconds.
level-1: Applies the interval to Level-1.
level-2: Applies the interval to Level-2.
On a broadcast network, this command only applies to the DIS, because the DIS sends CSNP packets periodically for LSDB synchronization.
If no level is specified, the CSNP interval applies to both Level-1 and Level-2.
# Configure Level-2 CSNP packets to be sent every 15 seconds over VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer csnp 15 level-2
isis timer hello
Use isis timer hello to set the interval for sending hello packets.
Use undo isis timer hello to remove the configuration.
isis timer hello seconds [ level-1 | level-2 ]
undo isis timer hello [ level-1 | level-2 ]
The hello interval is 10 seconds.
Interface view
seconds: Specifies the interval for sending hello packets, in the range of 3 to 255 seconds.
level-1: Specifies the interval for sending Level-1 hello packets.
level-2: Specifies the interval for sending Level-2 hello packets.
If a neighbor does not receive any hello packets from the router within the advertised hold time, it considers the router down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval.
Level-1 and Level-2 hello packets are sent independently on a broadcast network, so you need to specify an interval for each level. On a P2P link, Level-1 and Level-2 packets are both sent in P2P hello packets, and you need not specify an interval for each level.
You can configure the level-1 and level-2 keywords only on broadcast interfaces. Before you configure the level-1 or level-2 keyword, enable IS-IS on the interface.
The shorter the interval, the more system resources will be occupied.
If no level is specified, the hello interval applies to both Level-1 and Level-2.
# Configure Level-2 hello packets to be sent every 20 seconds over VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer hello 20 level-2
isis timer holding-multiplier
Use isis timer holding-multiplier to set the IS-IS hello multiplier.
Use undo isis timer holding-multiplier to remove the configuration.
isis timer holding-multiplier value [ level-1 | level-2 ]
undo isis timer holding-multiplier [ level-1 | level-2 ]
The default IS-IS hello multiplier is 3.
Interface view
value: Specifies the number of hello intervals, in the range of 3 to 1000.
level-1: Applies the number to the Level-1 IS-IS neighbor.
level-2: Applies the number to the Level-2 IS-IS neighbor.
The hello multiplier is the number of hello packets a neighbor must miss before declaring the router is down.
Level-1 and Level-2 hello packets are sent independently on a broadcast network, so you need to specify a hello multiplier for each level. On a P2P link, Level-1 and Level-2 packets are both sent in P2P hello packets, and you need not specify Level-1 or Level-2.
If no level is specified, the hello multiplier applies to both Level-1 and Level-2.
The value of hello multiplier multiplied by hello interval cannot be more than 65535.
# Set the hello multiplier to 6 for VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer holding-multiplier 6
isis timer hello
isis timer lsp
Use isis timer lsp to set the minimum interval for sending LSPs on the interface and specify the maximum number of LSPs that can be sent per time.
Use undo isis timer lsp to restore the default.
isis timer lsp time [ count count ]
undo isis timer lsp
The minimum interval for sending LSPs on the interface is 33 milliseconds, and the maximum number of LSPs that can be sent at a time is 5.
Interface view
time: Specifies the minimum interval for sending link-state packets, in the range of 1 to 1000 milliseconds.
count: Specifies the maximum number of link-state packets to be sent at one time, in the range of 1 to 1000.
If a change occurs in the LSDB, IS-IS advertises the changed LSP to neighbors. You can specify the minimum interval for sending these LSPs to control the amount of LSPs on the network.
# Set the interval to 500 milliseconds for sending LSPs on VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer lsp 500
isis timer retransmit
Use isis timer retransmit to configure the interval for retransmitting LSP packets over a point-to-point link.
Use undo isis timer retransmit to restore the default.
isis timer retransmit seconds
The retransmission interval on a P2P link is 5 seconds.
Interface view
seconds: Specifies the interval for retransmitting LSP packets, in the range of 1 to 300 seconds.
On a P2P link, IS-IS requires an advertised LSP be acknowledged. If no acknowledgment is received within a configurable interval, IS-IS will retransmit the LSP.
You do not need to use this command over a broadcast link where CSNPs are periodically broadcast to implement LSDB synchronization.
# Set the LSP retransmission interval on a P2P link to 50 seconds for VLAN-interface 10.
[Sysname-Vlan-interface10] isis timer retransmit 50
isis timer lsp
is-level
Use is-level to specify the IS level.
Use undo is-level to restore the default.
is-level { level-1 | level-1-2 | level-2 }
undo is-level
The IS level is level-1-2.
IS-IS view
level-1: Specifies Level-1, which means IS-IS only calculates intra-area routes and maintains the Level-1 LSDB.
level-1-2: Specifies Level-1-2, which means IS-IS calculates routes and maintains the LSDBs for both Level-1 and Level-2.
level-2: Specifies Level-2, which means IS-IS calculates routes and maintains the LSDB for Level-2 only.
If only one area exists, configure all the routers as either Level-1 or Level-2, because the routers do not need to maintain two identical LSDBs at the same time.
If the only area is an IP network, configure all the routers as Level-2 for scalability.
# Set the IS level to Level-1 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] is-level level-1
is-name
Use is-name to specify a host name for the IS and enable dynamic system ID to hostname mapping.
Use undo is-name to disable dynamic system ID to hostname mapping.
is-name sys-name
undo is-name
Dynamic system ID to hostname mapping is disabled, and no host name is configured for the IS.
IS-IS view
sys-name: Specifies a host name for the local IS, a case-insensitive string of 1 to 64 characters.
To display the host name rather than the system ID of an IS by using the display isis lsdb command, first enable dynamic system ID to hostname mapping.
# Configure a host name for the local IS.
[Sysname] isis 1
[Sysname-isis-1] is-name RUTA
display isis name-table
is-name map
Use is-name map to configure a system ID to host name mapping for a remote IS.
Use undo is-name map to remove the mapping.
is-name map sys-id map-sys-name
undo is-name map sys-id
No system ID to host name mapping is configured for a remote IS.
IS-IS view
sys-id: Specifies the system ID or pseudonode ID of a remote IS.
map-sys-name: Specifies a host name for the remote IS, a case-insensitive string of 1 to 64 characters.
Each remote IS system ID corresponds to only one name.
# Map the host name RUTB to the system ID 0000.0000.0041 of the remote IS.
[Sysname] isis 1
[Sysname-isis-1] is-name map 0000.0000.0041 RUTB
ispf enable
Use ispf enable to enable IS-IS incremental SPF (ISPF).
Use undo ispf enable to disable IS-IS ISPF.
ispf enable
undo ispf enable
IS-IS ISPF is enabled.
IS-IS view
When a network topology is changed, ISPF recomputes only the affected part of the SPT, instead of the entire SPT.
# Enable IS-IS ISPF.
[Sysname] isis 1
[Sysname-isis-1] ispf enable
log-peer-change
Use log-peer-change to enable the logging of neighbor state changes.
Use undo log-peer-change to disable the logging.
log-peer-change
The logging of IS-IS neighbor state changes is enabled.
IS-IS view
This command enables sending logs about IS-IS neighbor state changes to the information center. For IS-IS neighbor state change logs to be sent correctly, you must also configure the information center parameters on the device. For more information about information center, see the network management and monitoring configuration guide for the device.
# Disable the logging of IS-IS neighbor state changes.
[Sysname] isis 1
[Sysname-isis-1] undo log-peer-change
lsp-fragments-extend
Use lsp-fragments–extend to enable LSP fragment extension for a level.
Use undo lsp-fragments–extend to restore the default.
lsp-fragments-extend [ level-1 | level-1-2 | level-2 ]
undo lsp-fragments-extend
LSP fragment extension is disabled.
IS-IS view
level-1: Applies the fragment extension to Level-1 LSPs.
level-1-2: Applies the fragment extension to both Level-1 and Level-2 LSPs.
level-2: Applies the fragment extension to Level-2 LSPs.
If no level is specified, the command enables LSP fragment extension for both Level-1 and Level-2.
# Enable LSP fragment extension for Level-2.
[Sysname] isis 1
[Sysname-isis-1] lsp-fragments-extend level-2
lsp-length originate
Use lsp-length originate to configure the maximum size of generated Level-1 or Level-2 LSPs.
Use undo lsp-length originate to remove the configuration.
lsp-length originate size [ level-1 | level-2 ]
undo lsp-length originate [ level-1 | level-2 ]
The maximum size of generated Level-1 and Level-2 LSPs is 1497 bytes.
IS-IS view
size: Specifies the maximum size of LSP packets, in the range of 512 to 16384 bytes.
level-1: Applies the size to Level-1 LSP packets.
level-2: Applies the size to Level-2 LSP packets.
If neither Level-1 nor Level-2 is specified in the command, the configured maximum size applies to the current IS-IS level.
# Set the maximum size of the generated Level-2 LSPs to 1024 bytes.
[Sysname] isis 1
[Sysname-isis-1] lsp-length originate 1024 level-2
lsp-length receive
Use lsp-length receive to configure the maximum size of received LSPs.
Use undo lsp-length receive to restore the default.
lsp-length receive size
The maximum size of received LSPs is 1497 bytes.
IS-IS view
size: Specifies the maximum size of received LSPs, in the range of 512 to 16384 bytes.
# Configure the maximum size of received LSPs to 1024 bytes.
[Sysname] isis 1
[Sysname-isis-1] lsp-length receive 1024
maximum load-balancing
Use maximum load-balancing to configure the maximum number of ECMP routes for load balancing.
Use undo maximum load-balancing to restore the default.
maximum load-balancing number
The maximum number of IS-IS ECMP routes equals the maximum number of ECMP routes supported by the system.
number: Specifies the maximum number of ECMP routes. The value of 1 indicates that IS-IS does not perform load balancing. The value range for this argument is 1 to 32.
If you use the max-ecmp-num command to configure the maximum number of ECMP routes supported by the system as m:
·     The default setting for the maximum load-balancing command is m.
·     The value range for the number argument of the maximum load-balancing command is 1 to m.
# Set the maximum number of ECMP routes to 2.
[Sysname] isis 100
[Sysname-isis-100] address-family ipv4
[Sysname-isis-100-ipv4] maximum load-balancing 2
max-ecmp-num
network-entity
Use network-entity to configure the Network Entity Title (NET) for an IS-IS process.
Use undo network-entity to delete a NET.
network-entity net
undo network-entity net
No NET is configured.
IS-IS view
net: Specifies a NET as a dotted hexadecimal string in the X…X.XXXX....XXXX.00 format. The X…X segment represents the area address, the XXXX....XXXX segment represents the system ID, and the 00 segment is the SEL.
A NET is a special NSAP address with the SEL being 0. The length of the NET is in the range of 8 to 20 bytes.
A NET comprises the following parts:
·     Area ID—With a length of 1 to 13 bytes.
·     System ID—A system ID uniquely identifies a host or router in the area and has a fixed 6-byte length.
·     SEL—It has a value of 0 and a fixed 1-byte length.
For example, a NET of ab.cdef.1234.5678.9abc.00 specifies the area ID ab.cdef, the system ID 1234.5678.9abc, and the SEL 00.
# Set the NET to 10.0001.1010.1020.1030.00, of which 10.0001 is the area ID and 1010.1020.1030 is the system ID.
[Sysname] isis 1
isis
isis enable
non-stop-routing
Use non-stop-routing to enable IS-IS NSR.
Use undo non-stop-routing to disable IS-IS NSR.
non-stop-routing
IS-IS NSR is disabled.
IS-IS view
IS-IS NSR takes effect on a per-process basis. As a best practice, enable NSR for each IS-IS process.
IS-IS NSR and IS-IS GR are mutually exclusive. Therefore, do not configure the non-stop-routing command and the graceful-restart command at the same time.
# Enable NSR for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] non-stop-routing
pic
Use pic to enable IS-IS PIC.
Use undo pic to disable IS-IS PIC.
undo pic
IS-IS PIC is enabled.
IS-IS view
additional-path-always: Allows the indirect suboptimal route as the backup route.
Prefix Independent Convergence (PIC) enables the device to speed up network convergence by ignoring the number of prefixes. PIC applies only to indirect routes.
When both IS-IS PIC and IS-IS FRR are configured, only IS-IS FRR takes effect.
# Configure IS-IS PIC to support the indirect suboptimal route as the backup route.
[Sysname] isis 1
preference
Use preference to configure the preference for IS-IS.
Use undo preference to restore the default.
undo preference
IS-IS preference is 15.
preference: Specifies an IS-IS protocol preference in the range of 1 to 255.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to assign a priority to the matching routes.
If multiple routing protocols find routes to the same destination, the route found by the routing protocol with the highest preference is selected as the optimal route.
If a routing policy is specified in this command, the preference set by the routing policy applies to the matching routes. Other routes use the preference set by the preference command.
# Set the preference for IS-IS to 25.
[Sysname] isis 1
[Sysname-isis-1-ipv4] preference 25
prefix-priority
Use prefix-priority to assign convergence priorities to specific IS-IS routes.
Use undo prefix-priority to remove the configuration.
prefix-priority { critical | high | medium } { prefix-list prefix-list-name | tag tag-value }
undo prefix-priority { critical | high | medium } [ prefix-list | tag ]
undo prefix-priority route-policy
IS-IS routes have the lowest convergence priority.
critical: Specifies the highest convergence priority.
high: Specifies the high convergence priority.
medium: Specifies the medium convergence priority.
prefix-list prefix-list-name: Specifies an IP prefix list by its name, a case-sensitive string of 1 to 63 characters.
tag tag-value: Specifies a tag value in the range of 1 to 4294967295.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters.
The higher the convergence priority, the faster the convergence speed.
IS-IS host routes have a medium convergence priority.
# Assign the high convergence priority to IS-IS routes permitted by IP prefix list standtest.
[Sysname] isis 1
[Sysname-isis-1-ipv4] prefix-priority high prefix-list standtest
reset isis all
Use reset isis all to clear all IS-IS data structure information.
reset isis all [ process-id ] [ graceful-restart ]
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535 to clear the data structure information for an IS-IS process.
graceful-restart: Recovers the data through graceful restart after the data is cleared.
If no IS-IS process is specified, the command clears data structure information for all IS-IS processes.
Use this command when LSPs must be updated immediately.
# Clear all IS-IS data structure information.
<Sysname> reset isis all
reset isis event-log graceful-restart
Use reset isis event-log graceful-restart to clear IS-IS GR log information.
In standalone mode:
reset isis event-log graceful-restart slot slot-number
In IRF mode:
reset isis event-log graceful-restart chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
# Clear IS-IS GR log information.
<Sysname> reset isis event-log graceful-restart
# (In standalone mode.) Clear IS-IS GR log information for the specified slot.
<Sysname> reset isis event-log graceful-restart slot 1
reset isis event-log non-stop-routing
Use reset isis event-log non-stop-routing to clear IS-IS NSR log information.
In standalone mode:
reset isis event-log non-stop-routing slot slot-number
In IRF mode:
reset isis event-log non-stop-routing chassis chassis-number slot slot-number
# (In standalone mode.) Clear IS-IS NSR log information for the specified slot.
<Sysname> reset isis event-log non-stop-routing slot 1
reset isis event-log spf
Use reset isis event-log spf to clear IS-IS route calculation log information.
reset isis event-log spf [ process-id ]
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears route calculation log information for all IS-IS processes.
# Clear route calculation log information for IS-IS process 1.
<Sysname> reset isis event-log spf 1
display isis event-log spf
reset isis packet
Use reset isis packet to clear IS-IS packet statistics.
reset isis packet [ csnp | hello | lsp | psnp ] [ interface-type interface-number ] [ process-id ]
csnp: Clears CSNP packet statistics.
hello: Clears hello packet statistics.
lsp: Clears LSP packet statistics.
psnp: Clears PSNP packet statistics.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify this option, the command clears IS-IS packet statistics for all interfaces.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears IS-IS packet statistics for all IS-IS processes.
# Clear IS-IS packet statistics for all IS-IS processes.
<Sysname> reset isis packet
display isis packet
reset isis peer
Use reset isis peer to clear data structure information for a specified IS-IS neighbor.
reset isis peer system-id [ process-id ]
system-id: Specifies an IS-IS neighbor by its system ID.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535 to clear data structure information for the neighbor in the specified IS-IS process.
Use this command when you re-establish an IS-IS neighbor relationship.
# Clear the data structure information of the neighbor with the system ID 0000.0c11.1111.
<Sysname> reset isis peer 0000.0c11.1111
Use reset osi statistics to clear OSI packet statistics.
To obtain OSI packet statistics from the specified time point, first clear the existing statistics.
# Clear OSI packet statistics.
<Sysname> reset osi statistics
display osi statistics
set-att
Use set-att to set the ATT bit of Level-1 LSPs.
Use undo set-att to restore the default.
set-att { always | never }
undo set-att
The ATT bit is not set for Level-1 LSPs.
IS-IS view
always: Sets the ATT bit of Level-1 LSPs.
never: Keeps the ATT bit of Level-1 LSPs not set.
# Set the ATT bit of Level-1 LSPs.
[Sysname] isis 1
[Sysname-isis-1] set-att always
set-overload
Use set-overload to set the overload bit.
Use undo set-overload to restore the default.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 | wait-for-bgp [ timeout3 ] ] ] [ allow { external | interlevel } * ]
undo set-overload
The overload bit is not set.
IS-IS view
on-startup: Sets the overload bit upon system startup.
start-from-nbr system-id [ timeout1 [ nbr-timeout ] ]: Starts the nbr-timeout timer when the router begins to establish the neighbor relationship with the neighbor after system startup. If the neighbor relationship is formed within the nbr-timeout interval, IS-IS keeps the overload bit set. If not, the bit is cleared. IS-IS keeps the overload bit set within the timeout1 interval after the neighbor relationship is formed within the nbr-timeout interval.
·     system-id—Specifies the neighbor.
·     timeout1—The timeout1 interval is in the range of 5 to 86400 seconds, and the default is 600 seconds.
·     nbr-timeout—The timer has an interval from 5 to 86400 seconds. The default is 1200 seconds.
timeout2: Sets the overload bit within the timeout2 interval after system startup. The interval is in the range of 5 to 86400 seconds, and the default is 600 seconds.
wait-for-bgp [ timeout3 ]: Starts the timeout3 timer for BGP convergence after system startup. If BGP is not converged within the timeout3 interval, IS-IS clears the overload bit. The value range for the timeout3 argument is 5 to 86400 seconds, and the default is 600 seconds.
allow: Allows advertising address prefixes. By default, no address prefixes are allowed to be advertised when the overload bit is set.
external: Allows advertising IP address prefixes redistributed from other routing protocols with the allow keyword specified.
interlevel: Allows advertising IP address prefixes learned from different IS-IS levels with the allow keyword specified.
If the on-startup keyword is not specified, the command sets the overload bit immediately until the undo set-overload command is executed.
If the on-startup keyword is specified, IS-IS sets the overload bit upon system startup and keeps it set within the timeout2 interval.
# Set overload flag on the current router.
[Sysname] isis 1
[Sysname-isis-1] set-overload
snmp context-name
Use snmp context-name to set the context name for the SNMP object for managing IS-IS.
Use undo snmp context-name to restore the default.
No context name is set for the SNMP object for managing IS-IS.
IS-IS view
context-name: Specifies a context name, a case-sensitive string of 1 to 32 characters.
TRILL shares the standard IS-IS MIB with IS-IS. The standard IS-IS MIB provides only single-instance MIB objects. For SNMP to correctly identify TRILL's management information in the standard IS-IS MIB, you must configure a unique context for TRILL.
Context is a method introduced to SNMPv3 for multiple-instance management. For SNMPv1/v2c, you must specify a community name as a context name for protocol identification.
# Configure the context name as isis for the SNMP object for managing IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] snmp context-name isis
snmp-agent trap enable isis
Use snmp-agent trap enable isis to enable IS-IS SNMP notifications.
Use undo snmp-agent trap enable isis to disable IS-IS SNMP notifications.
snmp-agent trap enable isis [ adjacency-state-change | area-mismatch | authentication | authentication-type | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-corrupt | lsp-parse-error | lsp-size-exceeded | manual-address-drop | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support  | rejected-adjacency | skip-sequence-number | version-skew ] *
undo snmp-agent trap enable isis [ adjacency-state-change | area-mismatch | authentication | authentication-type | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-corrupt | lsp-parse-error | lsp-size-exceeded | manual-address-drop | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support  | rejected-adjacency | skip-sequence-number | version-skew ] *
IS-IS SNMP notifications are enabled.
adjacency-state-change: Specifies notifications about IS-IS adjacency status changes.
area-mismatch: Specifies notifications about area address mismatches between hello packets.
authentication: Specifies notifications about authentication failures of IS-IS packets.
authentication-type: Specifies notifications about authentication type errors of IS-IS packets.
buffsize-mismatch: Specifies notifications about buffer size mismatches for LSPs.
id-length-mismatch: Specifies notifications about system ID length mismatches of IS-IS packets.
lsdboverload-state-change: Specifies notifications about LSDB overload state changes.
lsp-corrupt: Specifies notifications about LSP checksum errors in the LSDB.
lsp-parse-error: Specifies notifications about LSP packet parse failures.
lsp-size-exceeded: Specifies notifications about propagation failures caused by oversized LSPs.
manual-address-drop: Specifies notifications about manually configured area addresses that have been dropped.
max-seq-exceeded: Specifies notifications about attempts to exceed the maximum LSP sequence number.
maxarea-mismatch: Specifies notifications about maximum area address mismatches of hello packets.
own-lsp-purge: Specifies notifications about attempts to remove the local LSP.
protocol-support: Specifies notifications about supported-protocol mismatches.
rejected-adjacency: Specifies notifications about adjacency creation failures.
skip-sequence-number: Specifies notifications about LSP sequence number duplications.
version-skew: Specifies notifications about hello packet version mismatches.
If you do not specify a notification, this command enables all IS-IS SNMP notifications.
If no IS-IS process exists, the configuration is not allowed.
This function does not take effect if all configured IS-IS processes are deleted.
# Disable IS-IS SNMP notifications.
[Sysname] undo snmp-agent trap enable isis
summary
Use summary to configure a summary route.
Use undo summary to remove a summary route.
summary ip-address { mask-length | mask } [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
undo summary ip-address { mask-length | mask } [ level-1 | level-1-2 | level-2 ]
No summary route is configured.
IS-IS IPv4 unicast address family view
ip-address: Specifies the destination IP address of the summary route.
mask-length: Specifies the mask length of the summary route, in the range of 0 to 32.
mask: Specifies the mask of the destination IP address, in dotted decimal notation.
avoid-feedback: Avoids learning summary routes by route calculation.
generate_null0_route: Generates the Null 0 route to avoid routing loops.
level-1: Summarizes only the routes redistributed to Level-1.
level-1-2: Summarizes the routes redistributed to both Level-1 and Level-2.
level-2: Summarizes only the routes redistributed to Level-2.
tag tag: Specifies a management tag in the range of 1 to 4294967295.
To reduce the size of the routing table, as well as the size of LSP and LSDB generated by the router, summarize multiple contiguous networks into a single network. You can summarize native IS-IS routes and redistributed routes. After summarization, the cost of the summary route is the smallest cost of the summarized routes.
If no level is specified, only level-2 routes are summarized.
The router summarizes only routes generated from local LSPs.
# Configure a summary route of 202.0.0.0/8.
[Sysname] isis 1
[Sysname-isis-1] address-family ipv4
[Sysname-isis-1-ipv4] summary 202.0.0.0 255.0.0.0
timer lsp-generation
Use timer lsp-generation to set the LSP generation interval.
Use undo timer lsp-generation to remove the configuration.
timer lsp-generation maximum-interval [ minimum-interval [ incremental-interval ] ] [ level-1 | level-2 ]
undo timer lsp-generation [ level-1 | level-2 ]
The maximum interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
IS-IS view
maximum-interval: Specifies the maximum interval in the range of 1 to 120 seconds.
minimum-interval: Specifies the minimum interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental interval in the range of 10 to 60000 milliseconds.
level-1: Applies the intervals to Level-1.
level-2: Applies the intervals to Level-2. If no level is specified, the specified intervals apply to both Level-1 and Level-2.
By adjusting the LSP generation interval, you can prevent bandwidth and router resources from being over consumed due to frequent topology changes.
When network changes are not frequent, the minimum-interval is adopted. If network changes become frequent, the LSP generation interval is incremented by the incremental-interval each time a generation occurs until the maximum-interval is reached.
The minimum interval and the incremental interval cannot be greater than the maximum interval.
# Set the maximum interval, minimum interval, and incremental interval to 10 seconds, 100 milliseconds, and 200 milliseconds, respectively.
[Sysname] isis 1
[Sysname-isis-1]timer lsp-generation 10 100 200
timer lsp-max-age
Use timer lsp-max-age to set the LSP maximum age in the LSDB.
Use undo timer lsp-max-age to restore the default.
timer lsp-max-age seconds
The LSP maximum age is 1200 seconds.
IS-IS view
seconds: Specifies the LSP maximum aging time in the range of 1 to 65535 seconds.
Each LSP has an age that decreases in the LSDB. Any LSP with an age of 0 is deleted from the LSDB. You can adjust the age value based on the scale of a network.
# Set the maximum LSP age to 1500 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-max-age 1500
timer lsp-refresh
timer lsp-refresh
Use timer lsp-refresh to set the LSP refresh interval.
Use undo timer lsp-refresh to restore the default.
timer lsp-refresh seconds
The default LSP refresh interval is 900 seconds.
IS-IS view
seconds: Specifies the LSP refresh interval in the range of 1 to 65534 seconds.
Each router refreshes its LSPs at a configurable interval and sends them to other routers to achieve the following purposes:
·     Prevent valid routes from aging out.
·     Synchronize LSPs in the network.
A smaller refresh interval speeds up network convergence but consumes more bandwidth.
To refresh LSPs before they are aged out, the interval configured by the timer lsp-refresh command must be smaller than that configured by the timer lsp-max-age command.
# Set the LSP refresh interval to 1500 seconds.
[Sysname] isis 1
[Sysname-isis-1] timer lsp-refresh 1500
timer lsp-max-age
timer spf
Use timer spf to set the SPF calculation interval.
Use undo timer spf to restore the default.
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ]
undo timer spf
IS-IS view
maximum-interval: Specifies the maximum SPF calculation interval in the range of 1 to 120 seconds.
minimum-interval: Specifies the minimum SPF calculation interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental SPF calculation interval in the range of 10 to 60000 milliseconds.
Based on the LSDB, an IS-IS router uses the SPF algorithm to calculate a shortest path tree with itself being the root, and uses the shortest path tree to determine the next hop to a destination network. By adjusting the SPF calculation interval, you can prevent bandwidth and router resources from being overused due to frequent topology changes.
When network changes are not frequent, the minimum-interval is adopted. If network changes become frequent, the SPF calculation interval is incremented by the incremental-interval each time a generation happens until the maximum-interval is reached.
# Set the maximum interval to 10 seconds, the minimum interval to 100 milliseconds, and the incremental interval to 300 milliseconds, respectively.
[Sysname] isis 1
[Sysname-isis-1] timer spf 10 100 300
virtual-system
Use virtual-system to configure a virtual system ID for the IS-IS process.
Use undo virtual-system to remove a virtual system ID.
virtual-system virtual-system-id
undo virtual-system virtual-system-id
No virtual system ID is configured.
IS-IS view
virtual-system-id: Specifies a virtual system ID for the IS-IS process.
# Set a virtual system ID of 2222.2222.2222 for IS-IS process 1.
[Sysname] isis 1
[Sysname-isis-1] virtual-system 2222.2222.2222
