06-Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesS10500 SeriesConfigure & DeployConfiguration GuidesH3C S10500 Configuration Guides-R7523P01-6W10006-Layer 3 - IP Routing Configuration Guide
07-Policy-based routing configuration
07-Policy-based routing configuration 103.66 KB
Configuring PBR
Overview
Policy-based routing (PBR) uses user-defined policies to route packets. A policy can specify the next hop and default next hop for packets that match specific criteria such as ACLs.
A device forwards received packets using the following process:
1.     The device uses PBR to forward matching packets.
2.     If the packets do not match the PBR policy or the PBR-based forwarding fails, the device uses the routing table, excluding the default route, to forward the packets.
3.     If the routing table-based forwarding fails, the device uses the default next hop defined in PBR to forward packets.
4.     If the default next hop-based forwarding fails, the device uses the default route to forward packets.
PBR includes local PBR and interface PBR.
·     Local PBR guides the forwarding of locally generated packets, such as the ICMP packets generated by using the ping command.
·     Interface PBR guides the forwarding of packets received on an interface only.
Policy
A policy includes match criteria and actions to be taken on the matching packets. A policy can have one or multiple nodes as follows:
·     Each node is identified by a node number. A smaller node number has a higher priority.
·     A node contains if-match and apply clauses. An if-match clause specifies a match criterion, and an apply clause specifies an action.
·     A node has a match mode of permit or deny.
A policy compares packets with nodes in priority order. If a packet matches the criteria on a node, it is processed by the action on the node. Otherwise, it goes to the next node for a match. If the packet does not match the criteria on any node, it is forwarded according to the routing table.
if-match clause
PBR supports the following types of if-match clauses:
·     if-match acl—Sets an ACL match criterion.
·     if-match qos-local-id—Sets a local QoS ID match criterion. For more information about QoS, see ACL and QoS Configuration Guide.
On a node, you can specify multiple if-match clauses but only one if-match clause for each type. To match a node, a packet must match all types of the if-match clauses for the node but only one if-match clause for each type.
apply clause
PBR supports the types of apply clauses shown in Table 1. You can specify multiple apply clauses for a node.
Table 1 Priorities and meanings of apply clauses
Clause
Meaning
Priority
apply next-hop
Sets the next hop.
N/A
apply default-next-hop
Sets the default next hop.
This clause takes effect only when no next hop is set or the next hop is invalid, and the packet does not match any route in the routing table.
Relationship between the match mode and clauses on the node
Does a packet match all the if-match clauses on the node?
Match mode
Permit
Deny
Yes.
·     If the node is configured with apply clauses, PBR executes the apply clauses on the node.
¡     If the PBR-based forwarding succeeds, PBR does not compare the packet with the next node.
¡     If the PBR-based forwarding fails, PBR does not compare the packet with the next node.
·     If the node is configured with no apply clauses, the packet is forwarded according to the routing table.
The packet is forwarded according to the routing table.
No.
PBR compares the packet with the next node.
A node that has no if-match clauses matches any packet.
PBR and Track
PBR can work with the Track feature to dynamically adapt the availability status of an apply clause to the link status of a tracked next hop or default next hop.
·     When the track entry associated with an object changes to Negative, the apply clause is invalid.
·     When the track entry changes to Positive or NotReady, the apply clause is valid.
For more information about Track-PBR collaboration, see High Availability Configuration Guide.
PBR configuration task list
Tasks at a glance
(Required.) Configuring a policy:
·     Creating a node
·     Setting match criteria for a node
·     Configuring actions for a node
(Required.) Configuring PBR:
·     Configuring local PBR
·     Configuring interface PBR
Creating a node
Step
Remarks
N/A
2.     Create a node for a policy, and enter policy node view.
By default, no policy node is created.
Step
Remarks
N/A
2.     Enter policy node view.
N/A
3.     Set an ACL match criterion.
By default, no ACL match criterion is set.
4.     Set a local QoS ID match criterion.
if-match qos-local-id local-id-value
By default, no local QoS ID match criterion is set.
If an ACL match criterion is defined, packets are compared with the ACL rules, and the permit or deny action and the time range of the specified ACL are ignored. If the specified ACL does not exist, no packet is matched.
Step
Remarks
N/A
N/A
3.     Set next hops.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
By default, no next hop is specified.
You can specify two next hops for backup in one command line or by executing this command twice.
You can specify a maximum of two next hops for a node.
4.     Set default next hops.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
By default, no default next hop is specified.
You can specify two default next hops for backup in one command line or by executing this command twice.
You can specify a maximum of two default next hops for a node.
The vpn-instance vpn-instance-name option does not take effect.
This command is not supported on the following modules:
·     EA interface modules.
·     EB interface modules.
·     SE interface modules:
¡     LSU1GP24TXSE0.
¡     LSU1GT48SE0.
¡     LSU1GP48SE0.
¡     LSU1TGX4SE0.
¡     LSU1TGS8SE0.
¡     LSU1GP24TSE0.
·     SC interface module: LSU1TGS16SC0.
Configuring PBR
Configure PBR by applying a policy locally. PBR uses the policy to guide the forwarding of locally generated packets. The specified policy must already exist. Otherwise, the local PBR configuration fails.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
Local PBR might affect local services, such as ping and Telnet. Do not configure local PBR unless doing so is required.
To configure local PBR:
Step
Remarks
N/A
2.     Apply a policy locally.
ip local policy-based-route policy-name
By default, no policy is locally applied.
Configure PBR by applying a policy to an interface. PBR uses the policy to guide the forwarding of packets received on the interface. The specified policy must already exist. Otherwise, the interface PBR configuration fails.
You can apply only one policy to an interface. Before you apply a new policy, you must first remove the current policy from the interface.
You can apply a policy to multiple interfaces.
To configure interface PBR:
Step
Remarks
3.     Enter system view.
N/A
4.     Enter interface view.
N/A
5.     Apply a policy to the interface.
ip policy-based-route policy-name
By default, no policy is applied to the interface.
Displaying and maintaining PBR
Display PBR policy information.
display ip policy-based-route [ policy policy-name ]
Display PBR configuration.
display ip policy-based-route setup
(In standalone mode.) Display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
(In IRF mode.) Display local PBR configuration and statistics.
display ip policy-based-route local [ chassis chassis-number slot slot-number ]
(In standalone mode.) Display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
(In IRF mode.) Display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ]
Clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
PBR configuration examples
Packet type-based local PBR configuration example
Network requirements
As shown in Figure 1, configure PBR on Switch A to forward all TCP packets to the next hop 1.1.2.2. Switch A forwards other packets according to the routing table.
Figure 1 Network diagram
Configuration procedure
1.     Configure Switch A:
# Create VLAN 10 and VLAN 20.
[SwitchA] vlan 10
[SwitchA-vlan10] quit
[SwitchA] vlan 20
[SwitchA-vlan20] quit
# Configure the IP addresses of VLAN-interface 10 and VLAN-interface 20.
[SwitchA-Vlan-interface10] ip address 1.1.2.1 24
[SwitchA-Vlan-interface20] ip address 1.1.3.1 24
# Configure ACL 3101 to match TCP packets.
[SwitchA] acl advanced 3101
[SwitchA-acl-adv-3101] rule permit tcp
[SwitchA-acl-adv-3101] quit
# Configure Node 5 for policy aaa to forward TCP packets to next hop 1.1.2.2.
[SwitchA] policy-based-route aaa permit node 5
[SwitchA-pbr-aaa-5] if-match acl 3101
[SwitchA-pbr-aaa-5] apply next-hop 1.1.2.2
[SwitchA-pbr-aaa-5] quit
# Configure local PBR by applying policy aaa to Switch A.
[SwitchA] ip local policy-based-route aaa
2.     Configure Switch B:
# Create VLAN 10.
[SwitchB] vlan 10
[SwitchB-vlan10] quit
# Configure the IP address of VLAN-interface 10.
[SwitchB-Vlan-interface10] ip address 1.1.2.2 24
3.     Configure Switch C:
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-vlan20] quit
# Configure the IP address of VLAN-interface 20.
[SwitchC] interface vlan-interface 20
[SwitchC-Vlan-interface20] ip address 1.1.3.2 24
# Telnet to Switch B on Switch A. The operation succeeds.
# Telnet to Switch C on Switch A. The operation fails.
# Ping Switch C from Switch A. The operation succeeds.
Telnet uses TCP, and ping uses ICMP. The results show the following:
·     All TCP packets sent from Switch A are forwarded to the next hop 1.1.2.2.
·     Other packets are forwarded through VLAN-interface 20.
·     The local PBR configuration is effective.
Packet type-based interface PBR configuration example
As shown in Figure 2, configure PBR on Switch A to forward all TCP packets received on VLAN-interface 11 to the next hop 1.1.2.2. Switch A forwards other packets according to the routing table.
Figure 2 Network diagram
[SwitchA] vlan 10
[SwitchA] vlan 20
# Configure interface PBR by applying policy aaa to VLAN-interface 11.
[SwitchA-Vlan-interface11] ip address 10.110.0.10 24
[SwitchA-Vlan-interface11] ip policy-based-route aaa
# Create VLAN 10.
[SwitchB] vlan 10
# Configure a static route to subnet 10.110.0.0/24.
[SwitchB] ip route-static 10.110.0.0 24 1.1.2.1
# Create VLAN 20.
[SwitchC] vlan 20
[SwitchC-Vlan-interface20] quit
[SwitchC] ip route-static 10.110.0.0 24 1.1.3.1
# Configure the IP address 10.110.0.20/24 for Host A, and specify its gateway address as 10.110.0.10.
# On Host A, Telnet to Switch B that is directly connected to Switch A. The operation succeeds.
# On Host A, Telnet to Switch C that is directly connected to Switch A. The operation fails.
# Ping Switch C from Host A. The operation succeeds.
·     All TCP packets arriving on VLAN-interface 11 of Switch A are forwarded to next hop 1.1.2.2.
·     The interface PBR configuration is effective.
