12-Network Management and Monitoring Configuration Guide
HomeSupportSwitchesS7500E-X SeriesConfigure & DeployConfiguration GuidesH3C S7500E-X Switch Series Configuration Guides-Release7178-6W10012-Network Management and Monitoring Configuration Guide
09-Process monitoring and maintenance configuration
Monitoring and maintaining processes
H3C Comware 7 is a full-featured, modular, and scalable network operating system based on the Linux kernel. Comware 7 software features run the following types of independent processes:
·     User process—Runs in user space. Most Comware 7 software features run user processes. Each process runs in an independent space so the failure of a process does not affect other processes. The system automatically monitors user processes. Comware 7 supports preemptive multithreading. A process can run multiple threads to support multiple activities. Whether a process supports multithreading depends on the software implementation.
·     Kernel thread—Runs in kernel space. A kernel thread executes kernel code. It has a higher security level than a user process. If a kernel thread fails, the system breaks down. You can monitor the running status of kernel threads.
Displaying and maintaining processes
Commands described in this section apply to both user processes and kernel threads. You can execute these commands in any view.
The system identifies a process that consumes excessive memory or CPU resources as an anomaly source.
To display and maintain processes (in standalone mode):
Display memory usage.
display memory [ slot slot-number [ cpu cpu-number ] ]
Display process state information.
display process [ all | job job-id | name process-name ] [ slot slot-number [ cpu cpu-number ] ]
Display CPU usage for all processes.
display process cpu [ slot slot-number [ cpu cpu-number ] ]
Monitor process running state.
monitor process [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
Monitor thread running state.
monitor thread [ dumbtty ] [ iteration number ] [ slot slot-number [ cpu cpu-number ] ]
For more information about the display memory [ slot slot-number ] command, see Fundamentals Command Reference.
To display and maintain processes (in IRF mode):
display memory [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display process [ all | job job-id | name process-name ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display process cpu [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
monitor process [ dumbtty ] [ iteration number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
monitor thread [ dumbtty ] [ iteration number ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
For more information about the display memory [ chassis chassis-number slot slot-number ] command, see Fundamentals Command Reference.
Displaying and maintaining user processes
Execute display commands in any view and other commands in user view.
In standalone mode:
Display log information for all user processes.
display process log [ slot slot-number [ cpu cpu-number ] ]
Display memory usage for all user processes.
display process memory [ slot slot-number [ cpu cpu-number ] ]
Display heap memory usage for a user process.
display process memory heap job job-id [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Display the addresses of memory blocks with a specified size used by a user process.
display process memory heap job job-id size memory-size [ offset offset-size ] [ slot slot-number [ cpu cpu-number ] ]
Display memory content starting from a specified memory block for a user process.
display process memory heap job job-id address starting-address length memory-length [ slot slot-number [ cpu cpu-number ] ]
Display context information for process exceptions.
display exception context [ count value ] [ slot slot-number [ cpu cpu-number ] ]
Display the core file directory.
display exception filepath [ slot slot-number [ cpu cpu-number ] ]
Enable or disable a process to generate core files for exceptions and set the maximum number of core files (which defaults to 1).
process core { maxcore value | off } { job job-id | name process-name } [ slot slot-number [ cpu cpu-number ] ]
Specify the directory for saving core files (the default directory is the root directory of the Flash memory on the active MPU).
exception filepath directory
Clear context information for process exceptions.
reset exception context [ slot slot-number [ cpu cpu-number ] ]
In IRF mode:
display process log [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display process memory [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display process memory heap job job-id [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display process memory heap job job-id size memory-size [ offset offset-size ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display process memory heap job job-id address starting-address length memory-length [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display exception context [ count value ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display exception filepath [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
process core { maxcore value | off } { job job-id | name process-name } [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Specify the directory for saving core files (the default directory is the root directory of the Flash memory on the global active MPU).
reset exception context [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Monitoring kernel threads
Tasks in this section help you quickly identify thread deadloop and starvation problems and their causes.
Configuring kernel thread deadloop detection
CAUTION
CAUTION:
As a best practice, use the default settings. Inappropriate configuration of kernel thread deadloop detection can cause service problems or system breakdown. Make sure you understand the impact of this configuration on your network before you configure kernel thread deadloop detection.
Kernel threads share resources. If a kernel thread monopolizes the CPU, other threads cannot run, resulting in a deadloop.
This feature enables the device to detect deadloops. If a thread occupies the CPU for a specific interval, the device considers that a deadloop has occurred. It generates a deadloop message and reboots to remove the deadloop.
To configure kernel thread deadloop detection (in standalone mode):
Step
Remarks
N/A
1.     Enable kernel thread deadloop detection.
monitor kernel deadloop enable [ slot slot-number [ cpu cpu-number ] ]
By default, kernel thread deadloop detection is disabled.
2.     (Optional.) Set the interval for identifying a kernel thread deadloop.
monitor kernel deadloop time interval [ slot slot-number [ cpu cpu-number ] ]
The default is 8 seconds.
3.     (Optional.) Disable kernel thread deadloop detection for a kernel thread.
monitor kernel deadloop exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
After enabled, kernel thread deadloop detection monitors all kernel threads by default.
To configure kernel thread deadloop detection (in IRF mode):
Step
Remarks
N/A
2.     Enable kernel thread deadloop detection.
monitor kernel deadloop enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
3.     (Optional.) Set the interval for identifying a kernel thread deadloop.
monitor kernel deadloop time interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
4.     (Optional.) Disable kernel thread deadloop detection for a kernel thread.
monitor kernel deadloop exclude-thread tid [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Configuring kernel thread starvation detection
CAUTION
CAUTION:
The system detects whether or not kernel thread starvation occurs after the device is powered up. Inappropriate configuration of kernel thread starvation detection can cause service problems or system breakdown. Make sure you understand the impact of this configuration on your network before you configure kernel thread starvation detection.
Starvation occurs when a thread is unable to access shared resources.
Kernel thread starvation detection enables the system to detect and report thread starvation. If a thread is not executed within a specific interval, the system considers that a starvation has occurred, and generates a starvation message.
Thread starvation does not impact system operation. A starved thread can automatically run when certain conditions are met.
To configure kernel thread starvation detection (in standalone mode):
Step
Remarks
N/A
2.     Enable kernel thread starvation detection.
monitor kernel starvation enable [ slot slot-number [ cpu cpu-number ] ]
By default, the function is disabled.
3.     (Optional.) Set the interval for identifying a kernel thread starvation.
monitor kernel starvation time interval [ slot slot-number [ cpu cpu-number ] ]
The default is 120 seconds.
4.     (Optional.) Disable kernel thread starvation detection for a kernel thread.
monitor kernel starvation exclude-thread tid [ slot slot-number [ cpu cpu-number ] ]
After enabled, kernel thread starvation detection monitors all kernel threads by default.
To configure kernel thread starvation detection (in IRF mode):
Step
Remarks
N/A
monitor kernel starvation enable [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
monitor kernel starvation time interval [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
monitor kernel starvation exclude-thread tid  [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
Displaying and maintaining kernel threads
Execute display commands in any view and reset commands in user view (in standalone mode).
Display kernel thread deadloop information.
display kernel deadloop show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Display kernel thread deadloop detection configuration.
display kernel deadloop configuration [ slot slot-number [ cpu cpu-number ] ]
Display kernel thread exception information.
display kernel exception show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Display kernel thread reboot information.
display kernel reboot show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Display kernel thread starvation information.
display kernel starvation show-number [ offset ] [ verbose ] [ slot slot-number [ cpu cpu-number ] ]
Display kernel thread starvation detection configuration.
display kernel starvation configuration [ slot slot-number [ cpu cpu-number ] ]
Clear kernel thread deadloop information.
reset kernel deadloop [ slot slot-number [ cpu cpu-number ] ]
Clear kernel thread exception information.
reset kernel exception [ slot slot-number [ cpu cpu-number ] ]
Clear kernel thread reboot information.
reset kernel reboot [ slot slot-number [ cpu cpu-number ] ]
Clear kernel thread starvation information.
reset kernel starvation [ slot slot-number [ cpu cpu-number ] ]
Execute display commands in any view and reset commands in user view (in IRF mode).
display kernel deadloop show-number [ offset ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display kernel deadloop configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display kernel exception show-number [ offset ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display kernel reboot show-number [ offset ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display kernel starvation show-number [ offset ] [ verbose ] [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
display kernel starvation configuration [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
reset kernel deadloop [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
reset kernel exception [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
reset kernel reboot [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
reset kernel starvation [ chassis chassis-number slot slot-number [ cpu cpu-number ] ]
