- 07-IP Multicast Configuration Guide
- 01-Multicast Overview
- 02-IGMP snooping configuration
- 03-PIM snooping configuration
- 04-Multicast VLAN configuration
- 05-Multicast routing and forwarding configuration
- 06-IGMP configuration
- 07-PIM configuration
- 08-MSDP configuration
- 09-Multicast VPN configuration
- 10-MLD snooping configuration
- 11-IPv6 PIM snooping configuration
- 12-IPv6 multicast VLAN configuration
- 13-IPv6 multicast routing and forwarding configuration
- 14-MLD configuration
- 15-IPv6 PIM configuration
| 00-Preface | 90.8 KB |
Preface
This configuration guide describes IP multicast fundamentals and configuration. It covers the IPv4 multicast configuration and IPv6 multicast configuration. With multicast, you can implement efficient point-to-multipoint data transmission in your network.
· Audience.
· Conventions.
· About the H3C S7500E-X documentation set.
Audience
· Network planners.
· Network administrators working with the S7500E-X switch series.
Conventions
This section describes the conventions used in the documentation.
Port numbering in examples
The port numbers in the documentation are for illustration only and might be unavailable on your device.
Command conventions
Convention |
Boldface |
Italic |
{ x | y | ... } |
[ x | y | ... ] |
{ x | y | ... } * |
Asterisk marked braces enclose a set of required syntax choices separated by vertical bars, from which you select at least one. |
[ x | y | ... ] * |
&<1-n> |
GUI conventions
Convention |
Boldface |
Window names, button names, field names, and menu items are in Boldface. For example, the New User window appears; click OK. |
Symbols
Convention |
NOTE: |
Network topology icons
Convention |
Represents an access point. |
Wireless terminator unit. |
Wireless terminator. |
Represents a security card, such as a firewall, load balancing, NetStream, SSL VPN, IPS, or ACG card. |
The H3C S7500E-X documentation set includes the following categories of documents:
Category |
Documents |
Purposes |
Hardware specifications and installation |
Guides you through initial installation and setup procedures to help you quickly set up and use your device with the minimum configuration. |
Provides a complete guide to hardware installation and hardware specifications. |
H3C Pluggable SFP [SFP+][XFP] Transceiver Modules Installation Guide |
Guides you through installing SFP/SFP+/XFP transceiver modules. |
Guides you through installing CFP transceiver modules. |
Guides you through installing QSFP+ transceiver modules. |
Describes the transceiver modules available for the H3C network products, their external views, and specifications. |
Software configuration |
Describes software features and configuration procedures. |
Provides a quick reference to all available commands. |
Describes typical network scenarios and provide configuration examples and instructions. |
Operations and maintenance |
Provides troubleshooting information for common problems of using the product. |
Covers the most frequently asked questions about the hardware, software and system specifications. |
Provides information about the product release, including the version history, hardware and software compatibility matrix, version upgrade information, technical support information, and software upgrading. |
Explains the system log messages. |
Obtaining documentation
Access the most up-to-date H3C product documentation on the World Wide Web at http://www.h3c.com.
Click the following links to obtain different categories of product documentation:
[Technical Documents]—Provides hardware installation, software upgrading, and software feature configuration and maintenance documentation.
[Products & Solutions]—Provides information about products and technologies, as well as solutions. [Software Download]—Provides the documentation released with the software version.
Technical support
Documentation feedback
We appreciate your comments.
