04-Layer 2 - LAN Switching Configuration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Switch Series Configuration Guides-Release7178-6W10004-Layer 2 - LAN Switching Configuration Guide
04-Spanning tree configuration
04-Spanning tree configuration 594.43 KB
Configuring spanning tree protocols· 1
STP· 1
STP protocol packets· 1
Basic concepts in STP· 1
Calculation process of the STP algorithm·· 2
RSTP· 8
PVST· 9
MSTP· 9
MSTP features· 9
MSTP basic concepts· 10
How MSTP works· 13
MSTP implementation on devices· 14
Protocols and standards· 14
Spanning tree configuration task lists· 14
STP configuration task list 15
RSTP configuration task list 16
PVST configuration task list 16
MSTP configuration task list 17
Setting the spanning tree mode· 18
Configuring an MST region· 18
Configuring the root bridge or a secondary root bridge· 19
Configuring the current device as the root bridge of a specific spanning tree· 20
Configuring the current device as a secondary root bridge of a specific spanning tree· 20
Configuring the device priority· 20
Configuring the maximum hops of an MST region· 21
Configuring the network diameter of a switched network· 21
Setting spanning tree timers· 22
Configuration restrictions and guidelines· 22
Configuration procedure· 23
Setting the timeout factor 23
Setting the BPDU transmission rate· 23
Configuring edge ports· 24
Configuration restrictions and guidelines· 24
Configuration procedure· 24
Configuring path costs of ports· 24
Specifying a standard for the device to use when it calculates the default path cost 25
Configuring path costs of ports· 27
Configuration example· 27
Configuring the port priority· 28
Configuring the port link type· 28
Configuration restrictions and guidelines· 29
Configuration procedure· 29
Configuring the mode a port uses to recognize and send MSTP packets· 29
Enabling outputting port state transition information· 30
Enabling the spanning tree feature· 30
Enabling the spanning tree feature in STP/RSTP/MSTP mode· 30
Enabling the spanning tree feature in PVST mode· 31
Performing mCheck· 31
Performing mCheck globally· 31
Performing mCheck in interface view· 31
Configuring Digest Snooping· 32
Configuration restrictions and guidelines· 32
Configuration procedure· 33
Digest Snooping configuration example· 33
Configuring No Agreement Check· 34
Configuration prerequisites· 35
Configuration procedure· 35
No Agreement Check configuration example· 36
Configuring TC Snooping· 36
Configuration restrictions and guidelines· 37
Configuration procedure· 37
Configuring protection features· 37
Enabling BPDU guard· 37
Enabling root guard· 38
Enabling loop guard· 39
Configuring port role restriction· 39
Configuring TC-BPDU transmission restriction· 40
Enabling TC-BPDU guard· 40
Enabling BPDU drop· 41
Enabling SNMP notifications for new-root election and topology change events· 41
Displaying and maintaining the spanning tree· 42
Spanning tree configuration example· 42
MSTP configuration example· 42
PVST configuration example· 46
Spanning tree protocols eliminate loops in a physical link-redundant network by selectively blocking redundant links and putting them in a standby state.
The recent versions of STP include the Rapid Spanning Tree Protocol (RSTP), the Per-VLAN Spanning Tree (PVST), and the Multiple Spanning Tree Protocol (MSTP).
STP
STP was developed based on the 802.1d standard of IEEE to eliminate loops at the data link layer in a LAN. Networks often have redundant links as backups in case of failures, but loops are a very serious problem. Devices running STP detect loops in the network by exchanging information with one another. They eliminate loops by selectively blocking certain ports to prune the loop structure into a loop-free tree structure. This avoids proliferation and infinite cycling of packets that would occur in a loop network.
In a narrow sense, STP refers to IEEE 802.1d STP. In a broad sense, STP refers to the IEEE 802.1d STP and various enhanced spanning tree protocols derived from that protocol.
STP uses bridge protocol data units (BPDUs), also known as configuration messages, as its protocol packets. This chapter uses BPDUs to represent all types of spanning tree protocol packets.
STP-enabled network devices exchange BPDUs to establish a spanning tree. BPDUs contain sufficient information for the network devices to complete spanning tree calculation.
STP uses the following types of BPDUs:
·     Configuration BPDUs—Used by the network devices to calculate a spanning tree and maintain the spanning tree topology.
·     Topology change notification (TCN) BPDUs—Notify network devices of network topology changes.
Configuration BPDUs contain sufficient information for the network devices to complete spanning tree calculation. Important fields in a configuration BPDU include the following:
·     Root bridge ID—Consisting of the priority and MAC address of the root bridge.
·     Root path cost—Cost of the path to the root bridge denoted by the root identifier from the transmitting bridge.
·     Designated bridge ID—Consisting of the priority and MAC address of the designated bridge.
·     Designated port ID—Consisting of the priority and global port number of the designated port.
·     Message age—Age of the configuration BPDU while it propagates in the network.
·     Max age—Maximum age of the configuration BPDU stored on the switch.
·     Hello time—Configuration BPDU transmission interval.
·     Forward delay—Delay that STP bridges use to transit port state.
Root bridge
A tree network must have a root bridge. The entire network contains only one root bridge, and all the other bridges in the network are called leaf nodes. The root bridge is not permanent, but can change with changes of the network topology.
Upon initialization of a network, each device generates and periodically sends configuration BPDUs, with itself as the root bridge. After network convergence, only the root bridge generates and periodically sends configuration BPDUs. The other devices only forward the BPDUs.
Root port
On a non-root bridge, the port nearest to the root bridge is the root port. The root port communicates with the root bridge. Each non-root bridge has only one root port. The root bridge has no root port.
Designated bridge and designated port
Classification
Designated bridge
Designated port
For a device
Device directly connected to the local device and responsible for forwarding BPDUs to the local device
Port through which the designated bridge forwards BPDUs to this device
For a LAN
Device responsible for forwarding BPDUs to this LAN segment
Port through which the designated bridge forwards BPDUs to this LAN segment
As shown in Figure 1, Device B and Device C are directly connected to a LAN.
If Device A forwards BPDUs to Device B through port A1, the designated bridge and designated port are as follows:
·     The designated bridge for Device B is Device A.
·     The designated port for Device B is port A1 on Device A.
If Device B forwards BPDUs to the LAN, the designated bridge and designated port are as follows:
·     The designated bridge for the LAN is Device B.
·     The designated port for the LAN is port B2 on Device B.
Figure 1 Designated bridges and designated ports
Path cost
Path cost is a reference value used for link selection in STP. To prune the network into a loop-free tree, STP calculates path costs to select the most robust links and block redundant links that are less robust.
The spanning tree calculation process described in the following sections is a simplified process presented only as an example.
Calculation process
The STP algorithm uses the following calculation process:
1.     Network initialization.
Upon initialization of a device, each port generates a BPDU with the following contents:
¡     The port as the designated port.
¡     The device as the root bridge.
¡     0 as the root path cost.
¡     The device ID as the designated bridge ID.
2.     Root bridge selection.
Initially, each STP-enabled device on the network assumes itself to be the root bridge, with its own device ID as the root bridge ID. By exchanging configuration BPDUs, the devices compare their root bridge IDs to elect the device with the smallest root bridge ID as the root bridge.
3.     Root port and designated ports selection on the non-root bridges.
Step
1
A non-root-bridge device regards the port on which it received the optimum configuration BPDU as the root port. Table 1 describes how the optimum configuration BPDU is selected.
2
Based on the configuration BPDU and the path cost of the root port, the device calculates a designated port configuration BPDU for each of the other ports.
·     The root bridge ID is replaced with that of the configuration BPDU of the root port.
·     The root path cost is replaced with that of the configuration BPDU of the root port plus the path cost of the root port.
·     The designated bridge ID is replaced with the ID of this device.
·     The designated port ID is replaced with the ID of this port.
3
The device compares the calculated configuration BPDU with the configuration BPDU on the port whose port role will be determined. Then, the device acts depending on the result of the comparison:
·     If the calculated configuration BPDU is superior, the device performs the following operations:
¡     Considers this port as the designated port.
¡     Replaces the configuration BPDU on the port with the calculated configuration BPDU.
¡     Periodically sends the calculated configuration BPDU.
·     If the configuration BPDU on the port is superior, the device blocks this port without updating its configuration BPDU. The blocked port can receive BPDUs, but cannot send BPDUs or forward data traffic.
When the network topology is stable, only the root port and designated ports forward user traffic. Other ports are all in the blocked state to receive BPDUs but not to forward BPDUs or user traffic.
Table 1 Selecting the optimum configuration BPDU
Step
Actions
1
Upon receiving a configuration BPDU on a port, the device compares the priority of the received configuration BPDU with that of the configuration BPDU generated by the port.
·     If the former priority is lower, the device discards the received configuration BPDU and keeps the configuration BPDU the port generated.
·     If the former priority is higher, the device replaces the content of the configuration BPDU generated by the port with the content of the received configuration BPDU.
2
The device compares the configuration BPDUs of all the ports and chooses the optimum configuration BPDU.
The following are the principles of configuration BPDU comparison:
a.     The configuration BPDU with the lowest root bridge ID has the highest priority.
b.     If configuration BPDUs have the same root bridge ID, their root path costs are compared. For example, the root path cost in a configuration BPDU plus the path cost of a receiving port is S. The configuration BPDU with the smallest S value has the highest priority.
c.     If all configuration BPDUs have the same root bridge ID and S value, the following attributes are compared in sequence:
-     Designated bridge IDs.
-     Designated port IDs.
-     IDs of the receiving ports.
The configuration BPDU that contains a smaller designated bridge ID, designated port ID, or receiving port ID is selected.
A tree-shape topology forms when the root bridge, root ports, and designated ports are selected.
Example of STP calculation
Figure 2 provides an example showing how the STP algorithm works.
Figure 2 The STP algorithm
As shown in Figure 2, the priority values of Device A, Device B, and Device C are 0, 1, and 2, respectively. The path costs of links among the three devices are 5, 10, and 4.
1.     Device state initialization.
In Table 2, each configuration BPDU contains the following fields: root bridge ID, root path cost, designated bridge ID, and designated port ID.
Table 2 Initial state of each device
Device
Port name
Configuration BPDU on the port
Device A
Port A1
{0, 0, 0, Port A1}
Port A2
{0, 0, 0, Port A2}
Device B
Port B1
{1, 0, 1, Port B1}
Port B2
{1, 0, 1, Port B2}
Device C
Port C1
{2, 0, 2, Port C1}
Port C2
{2, 0, 2, Port C2}
2.     Configuration BPDUs comparison on each device.
In Table 3, each configuration BPDU contains the following fields: root bridge ID, root path cost, designated bridge ID, and designated port ID.
Table 3 Comparison process and result on each device
Device
Comparison process
Configuration BPDU on ports after comparison
Device A
Port A1 performs the following operations:
1.     Receives the configuration BPDU of Port B1 {1, 0, 1, Port B1}.
2.     Determines that its existing configuration BPDU {0, 0, 0, Port A1} is superior to the received configuration BPDU.
3.     Discards the received one.
Port A2 performs the following operations:
1.     Receives the configuration BPDU of Port C1 {2, 0, 2, Port C1}.
2.     Determines that its existing configuration BPDU {0, 0, 0, Port A2} is superior to the received configuration BPDU.
Device A determines that it is both the root bridge and designated bridge in the configuration BPDUs of all its ports. It considers itself as the root bridge. It does not change the configuration BPDU of any port and starts to periodically send configuration BPDUs.
·     Port A1: {0, 0, 0, Port A1}
·     Port A2: {0, 0, 0, Port A2}
Device B
Port B1 performs the following operations:
1.     Receives the configuration BPDU of Port A1 {0, 0, 0, Port A1}.
2.     Determines that the received configuration BPDU is superior to its existing configuration BPDU {1, 0, 1, Port B1}.
3.     Updates its configuration BPDU.
Port B2 performs the following operations:
1.     Receives the configuration BPDU of Port C2 {2, 0, 2, Port C2}.
2.     Determines that its existing configuration BPDU {1, 0, 1, Port B2} is superior to the received configuration BPDU.
3.     Discards the received BPDU.
·     Port B1: {0, 0, 0, Port A1}
·     Port B2: {1, 0, 1, Port B2}
Device B performs the following operations:
1.     Compares the configuration BPDUs of all its ports.
2.     Decides that the configuration BPDU of Port B1 is the optimum.
3.     Selects Port B1 as the root port with the configuration BPDU unchanged.
Based on the configuration BPDU and path cost of the root port, Device B calculates a designated port configuration BPDU for Port B2 {0, 5, 1, Port B2}. Device B compares it with the existing configuration BPDU of Port B2 {1, 0, 1, Port B2}. Device B determines that the calculated one is superior, and determines that Port B2 is the designated port. It replaces the configuration BPDU on Port B2 with the calculated one, and periodically sends the calculated configuration BPDU.
·     Root port (Port B1): {0, 0, 0, Port A1}
·     Designated port (Port B2): {0, 5, 1, Port B2}
Device C
Port C1 performs the following operations:
1.     Receives the configuration BPDU of Port A2 {0, 0, 0, Port A2}.
2.     Determines that the received configuration BPDU is superior to its existing configuration BPDU {2, 0, 2, Port C1}.
Port C2 performs the following operations:
1.     Receives the original configuration BPDU of Port B2 {1, 0, 1, Port B2}.
2.     Determines that the received configuration BPDU is superior to the existing configuration BPDU {2, 0, 2, Port C2}.
·     Port C1: {0, 0, 0, Port A2}
·     Port C2: {1, 0, 1, Port B2}
Device C performs the following operations:
2.     Decides that the configuration BPDU of Port C1 is the optimum.
3.     Selects Port C1 as the root port with the configuration BPDU unchanged.
Based on the configuration BPDU and path cost of the root port, Device C calculates the configuration BPDU of Port C2 {0, 10, 2, Port C2}. Device C compares it with the existing configuration BPDU of Port C2 {1, 0, 1, Port B2}. Device C determines that the calculated configuration BPDU is superior to the existing one, selects Port C2 as the designated port, and replaces the configuration BPDU of Port C2 with the calculated one.
·     Root port (Port C1): {0, 0, 0, Port A2}
·     Designated port (Port C2): {0, 10, 2, Port C2}
1.     Receives the updated configuration BPDU of Port B2 {0, 5, 1, Port B2}.
2.     Determines that the received configuration BPDU is superior to its existing configuration BPDU {0, 10, 2, Port C2}.
1.     Receives a periodic configuration BPDU {0, 0, 0, Port A2} from Port A2.
2.     Determines that it is the same as the existing configuration BPDU.
·     Port C2: {0, 5, 1, Port B2}
Device C determines that the root path cost of Port C1 is larger than that of Port C2. The root path cost of Port C1 is 10, root path cost of the received configuration BPDU (0) plus path cost of Port C1 (10). The root path cost of Port C2 is 9, root path cost of the received configuration BPDU (5) plus path cost of Port C2 (4). Device C determines that the configuration BPDU of Port C2 is the optimum, and selects Port C2 as the root port with the configuration BPDU unchanged.
Based on the configuration BPDU and path cost of the root port, Device C performs the following operations:
1.     Calculates a designated port configuration BPDU for Port C1 {0, 9, 2, Port C1}.
2.     Compares it with the existing configuration BPDU of Port C1 {0, 0, 0, Port A2}.
3.     Determines that the existing configuration BPDU is superior to the calculated one and blocks Port C1 with the configuration BPDU unchanged.
Port C1 does not forward data until a new event triggers a spanning tree calculation process: for example, the link between Device B and Device C is down.
·     Blocked port (Port C1): {0, 0, 0, Port A2}
·     Root port (Port C2): {0, 5, 1, Port B2}
After the comparison processes described in Table 3, a spanning tree with Device A as the root bridge is established, as shown in Figure 3.
Figure 3 The final calculated spanning tree
The configuration BPDU forwarding mechanism of STP
The configuration BPDUs of STP are forwarded according to these guidelines:
·     Upon network initiation, every device regards itself as the root bridge and generates configuration BPDUs with itself as the root. Then it sends the configuration BPDUs at a regular hello interval.
·     If the root port receives a configuration BPDU superior to the configuration BPDU of the port, the device performs the following operations:
¡     Increases the message age carried in the configuration BPDU.
¡     Starts a timer to time the configuration BPDU.
¡     Sends this configuration BPDU through the designated port.
·     If a designated port receives a configuration BPDU with a lower priority than its configuration BPDU, the port immediately responds with its configuration BPDU.
·     If a path fails, the root port on this path no longer receives new configuration BPDUs and the old configuration BPDUs will be discarded due to timeout. The device generates a configuration BPDU with itself as the root and sends the BPDUs and TCN BPDUs. This triggers a new spanning tree calculation process to establish a new path to restore the network connectivity.
However, the newly calculated configuration BPDU cannot be propagated throughout the network immediately. As a result, the old root ports and designated ports that have not detected the topology change continue forwarding data along the old path. If the new root ports and designated ports begin to forward data as soon as they are elected, a temporary loop might occur.
STP timers
The most important timing parameters in STP calculation are forward delay, hello time, and max age.
·     Forward delay
Forward delay is the delay time for port state transition.
A path failure can cause spanning tree re-calculation to adapt the spanning tree structure to the change. However, the resulting new configuration BPDU cannot propagate throughout the network immediately. If the newly elected root ports and designated ports start to forward data immediately, a temporary loop will likely occur.
The newly elected root ports or designated ports require twice the forward delay time before they transit to the forwarding state. This allows the new configuration BPDU to propagate throughout the network.
·     Hello time
The device sends hello packets at the hello time interval to the neighboring devices to make sure the paths are fault-free.
·     Max age
The device uses the max age to determine whether a stored configuration BPDU has expired and discards it if the max age is exceeded.
RSTP
RSTP achieves rapid network convergence by allowing a newly elected root port or designated port to enter the forwarding state much faster than STP.
A newly elected RSTP root port rapidly enters the forwarding state when the following conditions exist:
·     The old root port on the device has stopped forwarding data.
·     The upstream designated port has started forwarding data.
A newly elected RSTP designated port rapidly enters the forwarding state if it is an edge port or it connects to a point-to-point link.
·     A port that directly connects to a user terminal can be configured as an edge port. Edge ports directly enter the forwarding state.
·     When a designated port connects to a point-to-point link, it enters the forwarding state immediately after the device receives a handshake response from the directly connected device.
PVST
In an STP- or RSTP-enabled LAN, all bridges share one spanning tree. Traffic from all VLANs is forwarded along the spanning tree, and ports cannot be blocked on a per-VLAN basis to prune loops.
PVST allows every VLAN to have its own spanning tree, which increases usage of links and bandwidth. Because each VLAN runs STP or RSTP independently, a spanning tree only serves its VLAN.
A PVST-enabled H3C device can communicate with a third-party device that is running Rapid PVST or PVST. The PVST-enabled H3C device supports fast network convergence like RSTP when connected to PVST-enabled H3C devices or third-party devices enabled with Rapid PVST.
A port's link type determines the type of BPDUs the port sends.
·     An access port sends STP BPDUs.
·     A trunk or hybrid port sends STP BPDUs in VLAN 1 and sends PVST BPDUs in other VLANs.
MSTP
MSTP overcomes the following STP, RSTP, and PVST limitations:
·     STP limitations—STP does not support rapid state transition of ports. A newly elected port must wait twice the forward delay time before it transits to the forwarding state.
·     RSTP limitations—Although RSTP enables faster network convergence than STP, RSTP fails to provide load balancing among VLANs. As with STP, all RSTP bridges in a LAN share one spanning tree and forward packets from all VLANs along this spanning tree.
·     PVST limitations—Because each VLAN has its spanning tree, the amount of PVST BPDUs is proportional to the number of VLANs on a trunk or hybrid port. When the trunk or hybrid port permits too many VLANs, both resources and calculations for maintaining the VLAN spanning trees increase dramatically. If a status change occurs on the trunk or hybrid port that permits multiple VLANs, the device CPU will be overburdened with recalculating the affected spanning trees. As a result, network performance is degraded.
MSTP features
Developed based on IEEE 802.1s, MSTP overcomes the limitations of STP, RSTP, and PVST. In addition to supporting rapid network convergence, it allows data flows of different VLANs to be forwarded along separate paths. This provides a better load sharing mechanism for redundant links.
MSTP provides the following features:
·     MSTP divides a switched network into multiple regions, each of which contains multiple spanning trees that are independent of one another.
·     MSTP supports mapping VLANs to spanning tree instances by means of a VLAN-to-instance mapping table. MSTP can reduce communication overheads and resource usage by mapping multiple VLANs to one instance.
·     MSTP prunes a loop network into a loop-free tree, which avoids proliferation and endless cycling of packets in a loop network. In addition, it supports load balancing of VLAN data by providing multiple redundant paths for data forwarding.
·     MSTP is compatible with STP and RSTP, and partially compatible with PVST.
MSTP basic concepts
Figure 4 shows a switched network that contains four MST regions, each MST region containing four MSTP devices. Figure 5 shows the networking topology of MST region 3.
Figure 4 Basic concepts in MSTP
Figure 5 Network diagram and topology of MST region 3
MST region
A multiple spanning tree region (MST region) consists of multiple devices in a switched network and the network segments among them. All these devices have the following characteristics:
·     A spanning tree protocol enabled
·     Same region name
·     Same VLAN-to-instance mapping configuration
·     Same MSTP revision level
·     Physically linked together
Multiple MST regions can exist in a switched network. You can assign multiple devices to the same MST region, as shown in Figure 4.
·     The switched network contains four MST regions, MST region 1 through MST region 4.
·     All devices in each MST region have the same MST region configuration.
MSTI
MSTP can generate multiple independent spanning trees in an MST region, and each spanning tree is mapped to the specific VLANs. Each spanning tree is referred to as a multiple spanning tree instance (MSTI).
In Figure 5, MST region 3 contains three MSTIs, MSTI 1, MSTI 2, and MSTI 0.
As an attribute of an MST region, the VLAN-to-instance mapping table describes the mapping relationships between VLANs and MSTIs.
In Figure 5, the VLAN-to-instance mapping table of MST region 3 is as follows:
·     VLAN 1 to MSTI 1.
·     VLAN 2 and VLAN 3 to MSTI 2.
·     Other VLANs to MSTI 0.
MSTP achieves load balancing by means of the VLAN-to-instance mapping table.
CST
The common spanning tree (CST) is a single spanning tree that connects all MST regions in a switched network. If you regard each MST region as a device, the CST is a spanning tree calculated by these devices through STP or RSTP.
The blue lines in Figure 4 represent the CST.
IST
An internal spanning tree (IST) is a spanning tree that runs in an MST region. It is also called MSTI 0, a special MSTI to which all VLANs are mapped by default.
In Figure 4, MSTI 0 is the IST in MST region 3.
CIST
The common and internal spanning tree (CIST) is a single spanning tree that connects all devices in a switched network. It consists of the ISTs in all MST regions and the CST.
In Figure 4, the ISTs (MSTI 0) in all MST regions plus the inter-region CST constitute the CIST of the entire network.
Regional root
The root bridge of the IST or an MSTI within an MST region is the regional root of the IST or MSTI. Based on the topology, different spanning trees in an MST region might have different regional roots, as shown in MST region 3 in Figure 5.
·     The regional root of MSTI 1 is Device B.
·     The regional root of MSTI 2 is Device C.
·     The regional root of MSTI 0 (also known as the IST) is Device A.
Common root bridge
The common root bridge is the root bridge of the CIST.
In Figure 4, the common root bridge is a device in MST region 1.
Port roles
A port can play different roles in different MSTIs. As shown in Figure 6, an MST region contains Device A, Device B, Device C, and Device D. Port A1 and port A2 of Device A connect to the common root bridge. Port B2 and Port B3 of Device B form a loop. Port C3 and Port C4 of Device C connect to other MST regions. Port D3 of Device D directly connects to a host.
Figure 6 Port roles
MSTP calculation involves the following port roles:
·     Root port—Forwards data for a non-root bridge to the root bridge. The root bridge does not have any root port.
·     Designated port—Forwards data to the downstream network segment or device.
·     Alternate port—Acts as the backup port for a root port or master port. When the root port or master port is blocked, the alternate port takes over.
·     Backup port—Acts as the backup port of a designated port. When the designated port is invalid, the backup port becomes the new designated port. A loop occurs when two ports of the same spanning tree device are connected, so the device blocks one of the ports. The blocked port acts as the backup.
·     Edge port—Does not connect to any network device or network segment, but directly connects to a user host.
·     Master port—Acts as a port on the shortest path from the local MST region to the common root bridge. The master port is not always located on the regional root. It is a root port on the IST or CIST and still a master port on the other MSTIs.
·     Boundary port—Connects an MST region to another MST region or to an STP/RSTP-running device. In MSTP calculation, a boundary port's role on an MSTI is consistent with its role on the CIST. However, that is not true with master ports. A master port on MSTIs is a root port on the CIST.
Port states
In MSTP, a port can be in one of the following states:
·     Forwarding—The port receives and sends BPDUs, learns MAC addresses, and forwards user traffic.
·     Learning—The port receives and sends BPDUs, learns MAC addresses, but does not forward user traffic. Learning is an intermediate port state.
·     Discarding—The port receives and sends BPDUs, but does not learn MAC addresses or forward user traffic.
When in different MSTIs, a port can be in different states.
A port state is not exclusively associated with a port role. Table 4 lists the port states that each port role supports. (A check mark [√] indicates that the port supports this state, while a dash [—] indicates that the port does not support this state.)
Table 4 Port states that different port roles support
Port role (right)
Port state (below)
Root port/master port
Designated port
Alternate port
Backup port
Forwarding
Learning
Discarding
How MSTP works
MSTP divides an entire Layer 2 network into multiple MST regions, which are connected by a calculated CST. Inside an MST region, multiple spanning trees, called MSTIs, are calculated. Among these MSTIs, MSTI 0 is the IST.
Like STP, MSTP uses configuration BPDUs to calculate spanning trees. An important difference is that an MSTP BPDU carries the MSTP configuration of the bridge from which the BPDU is sent.
CIST calculation
During the CIST calculation, the following process takes place:
·     The device with the highest priority is elected as the root bridge of the CIST.
·     MSTP generates an IST within each MST region through calculation.
·     MSTP regards each MST region as a single device and generates a CST among these MST regions through calculation.
The CST and ISTs constitute the CIST of the entire network.
MSTI calculation
Within an MST region, MSTP generates different MSTIs for different VLANs based on the VLAN-to-instance mappings. For each spanning tree, MSTP performs a separate calculation process similar to spanning tree calculation in STP. For more information, see "Calculation process of the STP algorithm."
In MSTP, a VLAN packet is forwarded along the following paths:
·     Within an MST region, the packet is forwarded along the corresponding MSTI.
·     Between two MST regions, the packet is forwarded along the CST.
MSTP is compatible with STP and RSTP. Devices that are running MSTP and that are used for spanning tree calculation can identify STP and RSTP protocol packets.
In addition to basic MSTP features, the following features are provided for ease of management:
·     Root bridge hold
·     Root bridge backup
·     Root guard
·     BPDU guard
·     Loop guard
·     TC-BPDU guard
·     Port role restriction
·     TC-BPDU transmission restriction
MSTP is documented in the following protocols and standards:
·     IEEE 802.1d, Media Access Control (MAC) Bridges
·     IEEE 802.1w, Part 3: Media Access Control (MAC) Bridges—Amendment 2: Rapid Reconfiguration
·     IEEE 802.1s, Virtual Bridged Local Area Networks—Amendment 3: Multiple Spanning Trees
·     IEEE 802.1Q-REV/D1.3, Media Access Control (MAC) Bridges and Virtual Bridged Local Area Networks —Clause 13: Spanning tree Protocols
Before configuring a spanning tree, complete the following tasks:
·     Determine the spanning tree protocol to be used (STP, RSTP, PVST, or MSTP).
·     Plan the device roles (the root bridge or leaf node).
When you configure spanning tree protocols, follow these restrictions and guidelines:
·     If both MVRP and a spanning tree protocol are enabled on a device, MVRP packets are forwarded along MSTIs. To advertise a specific VLAN within the network through MVRP, make sure this VLAN is mapped to an MSTI when you configure the VLAN-to-instance mapping table. For more information about MVRP, see "Configuring MVRP."
·     To connect a spanning tree network to a TRILL network, make sure the following requirements are met:
¡     The spanning tree protocol is disabled on the TRILL network.
¡     An edge port is used to connect the spanning tree network to the TRILL network. The edge port can quickly transit to the forwarding state. This prevents network topology changes from influencing the TRILL network.
For more information about TRILL, see TRILL Configuration Guide.
·     The spanning tree configurations are mutually exclusive with any of the following features on a port: service loopback, RRPP, and Smart Link.
·     Configurations made in system view take effect globally. Configurations made in Ethernet interface view or WLAN mesh interface view take effect only on the interface. Configurations made in Layer 2 aggregate interface view take effect only on the aggregate interface. Configurations made on an aggregation member port can take effect only after the port is removed from the aggregation group.
·     After you enable a spanning tree protocol on a Layer 2 aggregate interface, the system performs spanning tree calculation on the Layer 2 aggregate interface. It does not perform spanning tree calculation on the aggregation member ports. The spanning tree protocol enable state and forwarding state of each selected member port is consistent with those of the corresponding Layer 2 aggregate interface.
·     The member ports of an aggregation group do not participate in spanning tree calculation. However, the ports still reserve their spanning tree configurations for participating in spanning tree calculation after leaving the aggregation group.
Tasks at a glance
Configuring the root bridge:
·     (Required.) Setting the spanning tree mode
·     (Optional.) Configuring the root bridge or a secondary root bridge
·     (Optional.) Configuring the device priority
·     (Optional.) Configuring the network diameter of a switched network
·     (Optional.) Setting spanning tree timers
·     (Optional.) Setting the timeout factor
·     (Optional.) Setting the BPDU transmission rate
·     (Optional.) Enabling outputting port state transition information
·     (Required.) Enabling the spanning tree feature
Configuring the leaf nodes:
·     (Optional.) Configuring path costs of ports
·     (Optional.) Configuring the port priority
(Optional.) Configuring TC Snooping
(Optional.) Configuring protection features
(Optional.) Enabling SNMP notifications for new-root election and topology change events
Tasks at a glance
·     (Optional.) Configuring edge ports
·     (Optional.) Configuring the port link type
(Optional.) Performing mCheck
Tasks at a glance
Tasks at a glance
·     (Required.) Configuring an MST region
·     (Optional.) Configuring the maximum hops of an MST region
·     (Optional.) Configuring the mode a port uses to recognize and send MSTP packets
(Optional.) Configuring Digest Snooping
(Optional.) Configuring No Agreement Check
The spanning tree modes include:
·     STP mode—All ports of the device send STP BPDUs. Select this mode when the peer device of a port supports only STP.
·     RSTP mode—All ports of the device send RSTP BPDUs. A port in this mode automatically transits to the STP mode when it receives STP BPDUs from the peer device. A port in this mode does not transit to the MSTP mode when it receives MSTP BPDUs from the peer device.
·     PVST mode—All ports of the device send PVST BPDUs. Each VLAN maintains a spanning tree. In a network, the amount of spanning trees maintained by all devices equals the number of PVST-enabled VLANs multiplied by the number of PVST-enabled ports. If the amount of spanning trees exceeds the capacity of the network, device CPUs will be overloaded. Packet forwarding is interrupted, and the network becomes unstable. The maximum number of spanning trees that a device can maintain is 254.
·     MSTP mode—All ports of the device send MSTP BPDUs. A port in this mode automatically transits to the STP mode when receiving STP BPDUs from the peer device. A port in this mode does not transit to the RSTP mode when receiving RSTP BPDUs from the peer device.
The MSTP mode is compatible with the RSTP mode, and the RSTP mode is compatible with the STP mode.
Compatibility of the PVST mode depends on the link type of a port.
·     On an access port, the PVST mode is compatible with other spanning tree modes in all VLANs.
·     On a trunk port or hybrid port, the PVST mode is compatible with other spanning tree modes only in VLAN 1.
To set the spanning tree mode:
Step
Remarks
N/A
2.     Set the spanning tree mode.
stp mode { mstp | pvst | rstp | stp }
The default setting is the MSTP mode.
Spanning tree devices belong to the same MST region if they are both connected through a physical link and configured with the following details:
·     Format selector (0 by default, not configurable).
·     MST region name.
·     MST region revision level.
·     VLAN-to-instance mapping entries in the MST region.
The configuration of MST region-related parameters (especially the VLAN-to-instance mapping table) might cause MSTP to begin a new spanning tree calculation. To reduce the possibility of topology instability, the MST region configuration takes effect only after you activate it by doing one of the following:
·     Use the active region-configuration command.
·     Enable a spanning tree protocol by using the stp global enable command if the spanning tree protocol is disabled.
In STP, RSTP, or PVST mode, MST region configurations do not take effect.
To configure an MST region:
Step
Remarks
N/A
2.     Enter MST region view.
stp region-configuration
N/A
3.     Configure the MST region name.
region-name name
The default setting is the MAC address.
4.     Configure the VLAN-to-instance mapping table.
·     instance instance-id vlan vlan-id-list
·     vlan-mapping modulo modulo
Use one of the commands.
By default, all VLANs in an MST region are mapped to the CIST (or MSTI 0).
5.     Configure the MSTP revision level of the MST region.
revision-level level
The default setting is 0.
6.     (Optional.) Display the MST region configurations that are not activated yet.
check region-configuration
N/A
7.     Manually activate MST region configuration.
N/A
You can have the spanning tree protocol determine the root bridge of a spanning tree through calculation. You can also specify a device as the root bridge or as a secondary root bridge.
A device has independent roles in different spanning trees. It can act as the root bridge in one spanning tree and as a secondary root bridge in another. However, one device cannot be the root bridge and a secondary root bridge in the same spanning tree.
A spanning tree can have only one root bridge. If multiple devices can be selected as the root bridge in a spanning tree, the device with the lowest MAC address is selected.
When the root bridge of an instance fails or is shut down and no new root bridge is specified, the following events occur:
·     If you specify only one secondary root bridge, it becomes the root bridge.
·     If you specify multiple secondary root bridges for the instance, the secondary root bridge with the lowest MAC address is given priority.
·     If you do not specify a secondary root bridge, a new root bridge is calculated.
You can specify one root bridge for each spanning tree, regardless of the device priority settings. Once you specify a device as the root bridge or a secondary root bridge, you cannot change its priority.
You can configure a device as the root bridge by setting the device priority to 0. For the device priority configuration, see "Configuring the device priority."
Step
Remarks
N/A
2.     Configure the current device as the root bridge.
·     In STP/RSTP mode:
stp root primary
·     In PVST mode:
stp vlan vlan-id-list root primary
·     In MSTP mode:
stp [ instance instance-list ] root primary
By default, a device does not function as the root bridge.
Step
Remarks
N/A
2.     Configure the current device as a secondary root bridge.
·     In STP/RSTP mode:
stp root secondary
·     In PVST mode:
stp vlan vlan-id-list root secondary
·     In MSTP mode:
stp [ instance instance-list ] root secondary
By default, a device does not function as a secondary root bridge.
Device priority is a factor in calculating the spanning tree. The priority of a device determines whether the device can be elected as the root bridge of a spanning tree. A lower value indicates a higher priority. You can set the priority of a device to a low value to specify the device as the root bridge of the spanning tree. A spanning tree device can have different priorities in different spanning trees.
During root bridge selection, if all devices in a spanning tree have the same priority, the one with the lowest MAC address is selected. You cannot change the priority of a device after it is configured as the root bridge or as a secondary root bridge.
To configure the priority of a device in a specified MSTI:
Step
Remarks
N/A
2.     Configure the priority of the current device.
·     In STP/RSTP mode:
stp priority priority
·     In PVST mode:
stp vlan vlan-id-list priority priority
·     In MSTP mode:
stp [ instance instance-list ] priority priority
The default setting is 32768.
Restrict the region size by setting the maximum hops of an MST region. The hop limit configured on the regional root bridge is used as the hop limit for the MST region.
Configuration BPDUs sent by the regional root bridge always have a hop count set to the maximum value. When a device receives this configuration BPDU, it decrements the hop count by one, and uses the new hop count in the BPDUs that it propagates. When the hop count of a BPDU reaches zero, it is discarded by the device that received it. Devices beyond the reach of the maximum hops can no longer participate in spanning tree calculations, so the size of the MST region is limited.
Make this configuration only on the root bridge. All other devices in the MST region use the maximum hop value set for the root bridge.
You can configure the maximum hops of an MST region based on the STP network size. As a best practice, set the maximum hops to a value that is greater than the maximum hops of each edge device to the root bridge.
To configure the maximum number of hops of an MST region:
Step
Remarks
N/A
2.     Configure the maximum hops of the MST region.
stp max-hops hops
The default setting is 20.
Any two terminal devices in a switched network can reach each other through a specific path, and there are a series of devices on the path. The switched network diameter is the maximum number of devices on the path for an edge device to reach another one in the switched network through the root bridge. The network diameter indicates the network size. The bigger the diameter, the larger the network size.
Based on the network diameter you configured, the system automatically sets an optimal hello time, forward delay, and max age for the device.
In STP, RSTP, or MSTP mode, each MST region is considered a device. The configured network diameter takes effect only on the CIST (or the common root bridge) but not on other MSTIs.
In PVST mode, the configured network diameter takes effect only on the root bridges of the specified VLANs.
To configure the network diameter of a switched network:
Step
Remarks
N/A
2.     Configure the network diameter of the switched network.
·     In STP/RSTP/MSTP mode:
stp bridge-diameter diameter
·     In PVST mode:
stp vlan vlan-id-list bridge-diameter diameter
The default setting is 7.
The following timers are used for spanning tree calculation:
·     Forward delay—Delay time for port state transition. To prevent temporary loops on a network, the spanning tree feature sets an intermediate port state (the learning state) before it transits from the discarding state to the forwarding state. The feature also requires that the port transit its state after a forward delay timer to make sure the state transition of the local port stays synchronized with the peer.
·     Hello time—Interval at which the device sends configuration BPDUs to detect link failures. If the device receives no configuration BPDUs within the timeout period, it recalculates the spanning tree. The formula for calculating the timeout period is timeout period = timeout factor × 3 × hello time.
·     Max age—In the CIST of an MSTP network, the device uses the max age timer to determine whether a configuration BPDU received by a port has expired. If it has, a new spanning tree calculation process starts. The max age timer does not take effect on other MSTIs except the CIST.
To ensure a fast topology convergence, make sure the timer settings meet the following formulas:
·     2 × (forward delay – 1 second) ≥ max age
·     Max age ≥ 2 × (hello time + 1 second)
As a best practice, specify the network diameter instead of manually setting the spanning tree timers. The spanning tree protocols will automatically calculate the timers based on the network diameter. If the network diameter uses the default value, the timers also use their default values.
Set the timers only on the root bridge. The timer settings on the root bridge apply to all devices on the entire switched network.
·     The length of the forward delay timer is related to the network diameter of the switched network. The larger the network diameter is, the longer the forward delay time should be. As a best practice, use the automatically calculated value because inappropriate forward delay setting might cause temporary redundant paths or increase the network convergence time.
·     An appropriate hello time setting enables the device to promptly detect link failures on the network without using excessive network resources. If the hello time is too long, the device mistakes packet loss for a link failure and triggers a new spanning tree calculation process. If the hello time is too short, the device frequently sends the same configuration BPDUs, which wastes device and network resources. As a best practice, use the automatically calculated value.
·     If the max age timer is too short, the device frequently begins spanning tree calculations and might mistake network congestion as a link failure. If the max age timer is too long, the device might fail to promptly detect link failures and quickly launch spanning tree calculations, reducing the auto-sensing capability of the network. As a best practice, use the automatically calculated value.
To set the spanning tree timers:
Step
Remarks
N/A
2.     Set the forward delay timer.
stp timer forward-delay time
·     In PVST mode:
stp vlan vlan-id-list timer forward-delay time
The default setting is 15 seconds.
3.     Set the hello timer.
stp timer hello time
·     In PVST mode:
stp vlan vlan-id-list timer hello time
The default setting is 2 seconds.
4.     Set the max age timer.
stp timer max-age time
·     In PVST mode:
stp vlan vlan-id-list timer max-age time
The default setting is 20 seconds.
The timeout factor is a parameter used to decide the timeout period. The formula for calculating the timeout period is: timeout period = timeout factor × 3 × hello time.
On a stable network, each non-root-bridge device forwards configuration BPDUs to the downstream devices at the hello time interval to detect link failures. If a device does not receive a BPDU from the upstream device within nine times the hello time, it assumes that the upstream device has failed. Then, it starts a new spanning tree calculation process.
An upstream device might be too busy to forward configuration BPDUs in time, for example, many Layer 2 interfaces are configured on the upstream device. As a result, the downstream device fails to receive a BPDU within the timeout period and then starts an undesired spanning tree calculation. The calculation might fail, and it also wastes network resources. To prevent undesired spanning tree calculation and save network resources on a stable network, you can set the timeout factor to 5, 6, or 7.
To set the timeout factor:
Step
Remarks
N/A
2.     Set the timeout factor of the device.
stp timer-factor factor
The default setting is 3.
The maximum number of BPDUs a port can send within each hello time equals the BPDU transmission rate plus the hello timer value. Set an appropriate BPDU transmission rate based on the physical status of the port and the network structure.
The higher the BPDU transmission rate, the more BPDUs are sent within each hello time, and the more system resources are used. By setting an appropriate BPDU transmission rate, you can limit the rate at which the port sends BPDUs. Setting an appropriate rate also prevents spanning tree protocols from using excessive network resources when the network topology changes. As a best practice, use the default setting.
To set the BPDU transmission rate:
Step
Remarks
N/A
2.     Enter Layer 2 Ethernet or aggregate interface view.
N/A
3.     Set the BPDU transmission rate of the ports.
stp transmit-limit limit
The default setting is 10.
If a port directly connects to a user terminal rather than another device or a shared LAN segment, this port is regarded as an edge port. When network topology change occurs, an edge port will not cause a temporary loop. Because a device does not determine whether a port is directly connected to a terminal, you must manually configure the port as an edge port. After that, the port can rapidly transit from the blocked state to the forwarding state.
·     If BPDU guard is disabled, a port set as an edge port becomes a non-edge port again if it receives a BPDU from another port. To restore the edge port, re-enable it.
·     If a port directly connects to a user terminal, configure it as an edge port and enable BPDU guard for it. This enables the port to quickly transit to the forwarding state when ensuring network security.
·     On a port, the loop guard feature and the edge port setting are mutually exclusive.
To configure a port as an edge port:
Step
Remarks
N/A
N/A
3.     Configure the current ports as edge ports.
stp edged-port
By default, all ports are non-edge ports.
Path cost is a parameter related to the rate of a port. On a spanning tree device, a port can have different path costs in different MSTIs. Setting appropriate path costs allows VLAN traffic flows to be forwarded along different physical links, achieving VLAN-based load balancing.
You can have the device automatically calculate the default path cost, or you can configure the path cost for ports.
CAUTION
CAUTION:
If you change the standard that the device uses to calculate the default path costs, you restore the path costs to the default.
You can specify a standard for the device to use in automatic calculation for the default path cost. The device supports the following standards:
·     dot1d-1998—The device calculates the default path cost for ports based on IEEE 802.1d-1998.
·     dot1t—The device calculates the default path cost for ports based on IEEE 802.1t.
·     legacy—The device calculates the default path cost for ports based on a private standard.
When you specify a standard for the device to use when it calculates the default path cost, follow these guidelines:
·     When it calculates the path cost for an aggregate interface, IEEE 802.1t takes into account the number of Selected ports in its aggregation group. However, IEEE 802.1d-1998 does not take into account the number of Selected ports. The calculation formula of IEEE 802.1t is: Path cost = 200,000,000/link speed (in 100 kbps). The link speed is the sum of the link speed values of the Selected ports in the aggregation group.
·     IEEE 802.1d-1998 or the private standard always assigns the smallest possible value to a single port or aggregate interface with a speed exceeding 10 Gbps. The forwarding path selected based on this criterion might not be the best one. To solve this problem, perform one of the following tasks:
¡     Use dot1t as the standard for default path cost calculation.
¡     Manually set the path cost for the port (see "Configuring path costs of ports").
To specify a standard for the device to use when it calculates the default path cost:
Step
Remarks
N/A
2.     Specify a standard for the device to use when it calculates the default path costs of its ports.
stp pathcost-standard { dot1d-1998 | dot1t | legacy }
By default, the calculation standard is legacy.
Table 5 Mappings between the link speed and the path cost
Link speed
Port type
Path cost
IEEE 802.1d-1998
IEEE 802.1t
Private standard
0
N/A
65535
200000000
200000
10 Mbps
Single port
100
2000000
2000
Aggregate interface containing two Selected ports
1000000
1800
Aggregate interface containing three Selected ports
666666
1600
Aggregate interface containing four Selected ports
500000
1400
100 Mbps
Single port
19
200000
200
100000
180
66666
160
50000
140
1000 Mbps
Single port
4
20000
20
10000
18
6666
16
5000
14
10 Gbps
Single port
2
2000
2
1000
1
666
1
500
1
20 Gbps
Single port
1
1000
1
500
1
333
1
250
1
40 Gbps
Single port
1
500
1
250
1
166
1
125
1
100 Gbps
Single port
1
200
1
100
1
66
1
50
1
When the path cost of a port changes, the system recalculates the role of the port and initiates a state transition.
To configure the path cost of a port:
Step
Remarks
N/A
N/A
3.     Configure the path cost of the ports.
·     In STP/RSTP mode:
stp cost cost
·     In PVST mode:
stp vlan vlan-id-list cost cost
·     In MSTP mode:
stp [ instance instance-list ] cost cost
By default, the system automatically calculates the path cost of each port.
# In MSTP mode, perform the following tasks:
·     Configure the device to calculate the default path costs of its ports by using IEEE 802.1d-1998.
·     Set the path cost of Ten-GigabitEthernet 1/1/3 to 200 on MSTI 2.
[Sysname] stp pathcost-standard dot1d-1998
Cost of every port will be reset and automatically re-calculated after you change the current pathcost standard. Continue?[Y/N]:y
Cost of every port has been re-calculated.
[Sysname] interface ten-gigabitethernet 1/1/3
[Sysname-Ten-GigabitEthernet1/1/3] stp instance 2 cost 200
# In PVST mode, perform the following tasks:
·     Set the path cost of Ten-GigabitEthernet 1/1/3 to 2000 on VLAN 20 through VLAN 30.
[Sysname-Ten-GigabitEthernet1/1/3] stp vlan 20 to 30 cost 2000
The priority of a port is a factor that determines whether the port can be elected as the root port of a device. If all other conditions are the same, the port with the highest priority is elected as the root port.
On a spanning tree device, a port can have different priorities and play different roles in different spanning trees. As a result, data of different VLANs can be propagated along different physical paths, implementing per-VLAN load balancing. You can set port priority values based on the actual networking requirements.
When the priority of a port changes, the system recalculates the port role and initiates a state transition.
To configure the priority of a port:
Step
Remarks
N/A
N/A
3.     Configure the port priority.
·     In STP/RSTP mode:
stp port priority priority
·     In PVST mode:
stp vlan vlan-id-list port priority priority
·     In MSTP mode:
stp [ instance instance-list ] port priority priority
The default setting is 128 for all ports.
A point-to-point link directly connects two devices. If two root ports or designated ports are connected over a point-to-point link, they can rapidly transit to the forwarding state after a proposal-agreement handshake process.
·     You can configure the link type as point-to-point for a Layer 2 aggregate interface or a port that operates in full duplex mode. As a best practice, use the default setting for the device to automatically detect the port link type.
·     In PVST or MSTP mode, the stp point-to-point force-false or stp point-to-point force-true command configured on a port takes effect on all VLANs or all MSTIs.
·     If you configure a non-point-to-point link as a point-to-point link, a temporary loop might occur.
To configure the link type of a port:
Step
Remarks
N/A
N/A
3.     Configure the port link type.
stp point-to-point { auto | force-false | force-true }
By default, the link type is auto where the port automatically detects the link type.
A port can receive and send MSTP packets in the following formats:
·     dot1s—802.1s-compliant standard format
·     legacy—Compatible format
By default, the packet format recognition mode of a port is auto. The port automatically distinguishes the two MSTP packet formats, and determines the format of packets that it will send based on the recognized format.
You can configure the MSTP packet format on a port. Then, the port sends only MSTP packets of the configured format to communicate with devices that send packets of the same format.
By default, a port in auto mode sends 802.1s MSTP packets. When the port receives an MSTP packet of a legacy format, the port starts to send packets only of the legacy format. This prevents the port from frequently changing the format of sent packets. To configure the port to send 802.1s MSTP packets, shut down and then bring up the port.
When the number of existing MSTIs exceeds 48, the port can send only 802.1s MSTP packets.
To configure the MSTP packet format to be supported on a port:
Step
Remarks
N/A
N/A
3.     Configure the mode that the port uses to recognize/send MSTP packets.
stp compliance { auto | dot1s | legacy }
The default setting is auto.
In a large-scale spanning tree network, you can enable devices to output the port state transition information. Then, you can monitor the port states in real time.
To enable outputting port state transition information:
Step
Remarks
N/A
2.     Enable outputting port state transition information.
·     In STP/RSTP mode:
stp port-log instance 0
·     In PVST mode:
stp port-log vlan vlan-id-list
·     In MSTP mode:
stp port-log { all | instance instance-list }
By default, this feature is enabled.
You must enable the spanning tree feature for the device before any other spanning tree related configurations can take effect. In STP, RSTP, or MSTP mode, make sure the spanning tree feature is enabled globally and on the desired ports. In PVST mode, make sure the spanning tree feature is enabled globally, in the desired VLANs, and on the desired ports.
To exclude specific ports from spanning tree calculation and save CPU resources, disable the spanning tree feature for these ports with the undo stp enable command. Make sure no loops occur in the network after you disable the spanning tree feature on these ports.
Step
Remarks
N/A
2.     Enable the spanning tree feature.
stp global enable
By default, the spanning tree feature is disabled globally.
3.     Enter Layer 2 Ethernet or aggregate interface view.
N/A
4.     (Optional.) Enable the spanning tree feature for the port.
stp enable
By default, the spanning tree feature is enabled on all ports.
Step
Remarks
N/A
stp global enable
3.     Enable the spanning tree feature in VLANs.
stp vlan vlan-id-list enable
By default, the spanning tree feature is enabled in VLANs.
4.     Enter Layer 2 Ethernet or aggregate interface view.
N/A
5.     Enable the spanning tree feature on the port.
stp enable
Performing mCheck
The mCheck feature enables user intervention in the port status transition process.
When a port on an MSTP, RSTP, or PVST device connects to an STP device and receives STP BPDUs, the port automatically transits to the STP mode. However, the port cannot automatically transit back to the original mode when the following conditions exist:
·     The peer STP device is shut down or removed.
·     The port cannot detect the change.
To forcibly transit the port to operate in the original mode, you can perform an mCheck operation.
For example, Device A, Device B, and Device C are connected in sequence. Device A runs STP, Device B does not run any spanning tree protocol, and Device C runs RSTP, PVST, or MSTP. In this case, when Device C receives an STP BPDU transparently transmitted by Device B, the receiving port transits to the STP mode. If you configure Device B to run RSTP, PVST, or MSTP with Device C, you must perform mCheck operations on the ports interconnecting Device B and Device C.
Step
Remarks
N/A
2.     Perform mCheck.
stp global mcheck
The mCheck operation takes effect on devices operating in MSTP, PVST, or RSTP mode.
Step
Remarks
N/A
N/A
3.     Perform mCheck.
stp mcheck
CAUTION
CAUTION:
Use caution with global Digest Snooping in the following situations:
·     When you modify the VLAN-to-instance mappings.
·     When you restore the default MST region configuration.
If the local device has different VLAN-to-instance mappings than its neighboring devices, loops or traffic interruption will occur.
As defined in IEEE 802.1s, connected devices are in the same region only when they have the same MST region-related configurations, including:
·     Region name.
·     Revision level.
·     VLAN-to-instance mappings.
A spanning tree device identifies devices in the same MST region by determining the configuration ID in BPDU packets. The configuration ID includes the region name, revision level, and configuration digest. It is 16-byte long and is the result calculated through the HMAC-MD5 algorithm based on VLAN-to-instance mappings.
Because spanning tree implementations vary by vendor, the configuration digests calculated through private keys are different. The devices of different vendors in the same MST region cannot communicate with each other.
To enable communication between an H3C device and a third-party device in the same MST region, enable Digest Snooping on the H3C device port connecting them.
When you configure Digest Snooping, follow these guidelines:
·     Before you enable Digest Snooping, make sure associated devices of different vendors are connected and run spanning tree protocols.
·     With Digest Snooping enabled, in-the-same-region verification does not require comparison of configuration digest. The VLAN-to-instance mappings must be the same on associated ports.
·     To make Digest Snooping take effect, you must enable Digest Snooping both globally and on associated ports. As a best practice, enable Digest Snooping on all associated ports first and then enable it globally. This will make the configuration take effect on all configured ports and reduce impact on the network.
·     To prevent loops, do not enable Digest Snooping on MST region edge ports.
·     As a best practice, enable Digest Snooping first and then the spanning tree feature. To avoid traffic interruption, do not configure Digest Snooping when the network is already working well.
Use this feature on when your H3C device is connected to a third-party device that uses its private key to calculate the configuration digest.
To configure Digest Snooping:
Step
Remarks
N/A
N/A
3.     Enable Digest Snooping on the interface.
stp config-digest-snooping
By default, Digest Snooping is disabled on ports.
4.     Return to system view.
N/A
5.     Enable Digest Snooping globally.
stp global config-digest-snooping
By default, Digest Snooping is disabled globally.
Digest Snooping configuration example
Network requirements
As shown in Figure 7, Device A and Device B connect to Device C, which is a third-party device. All these devices are in the same region.
Enable Digest Snooping on the ports of Device A and Device B that connect to Device C, so that the three devices can communicate with one another.
Figure 7 Network diagram
Configuration procedure
# Enable Digest Snooping on Ten-GigabitEthernet 1/1/1 of Device A and enable global Digest Snooping on Device A.
[DeviceA] interface ten-gigabitethernet 1/1/1
[DeviceA-Ten-GigabitEthernet1/1/1] stp config-digest-snooping
[DeviceA-Ten-GigabitEthernet1/1/1] quit
[DeviceA] stp global config-digest-snooping
# Enable Digest Snooping on Ten-GigabitEthernet 1/1/1 of Device B and enable global Digest Snooping on Device B.
[DeviceB] interface ten-gigabitethernet 1/1/1
[DeviceB-Ten-GigabitEthernet1/1/1] stp config-digest-snooping
[DeviceB-Ten-GigabitEthernet1/1/1] quit
[DeviceB] stp global config-digest-snooping
In RSTP and MSTP, the following types of messages are used for rapid state transition on designated ports:
·     Proposal—Sent by designated ports to request rapid transition
·     Agreement—Used to acknowledge rapid transition requests
Both RSTP and MSTP devices can perform rapid transition on a designated port only when the port receives an agreement packet from the downstream device. RSTP and MSTP devices have the following differences:
·     For MSTP, the root port of the downstream device sends an agreement packet only after it receives an agreement packet from the upstream device.
·     For RSTP, the downstream device sends an agreement packet whether or not an agreement packet from the upstream device is received.
Figure 8 Rapid state transition of an MSTP designated port
Figure 9 Rapid state transition of an RSTP designated port
If the upstream device is a third-party device, the rapid state transition implementation might be limited as follows:
·     The upstream device uses a rapid transition mechanism similar to that of RSTP.
·     The downstream device runs MSTP and does not operate in RSTP mode.
In this case, the following occurs:
1.     The root port on the downstream device receives no agreement from the upstream device.
2.     It sends no agreement to the upstream device.
As a result, the designated port of the upstream device can transit to the forwarding state only after a period twice the Forward Delay.
To enable the designated port of the upstream device to transit its state rapidly, enable No Agreement Check on the downstream device's port.
Configuration prerequisites
Before you configure the No Agreement Check feature, complete the following tasks:
·     Connect a device to a third-party upstream device that supports spanning tree protocols through a point-to-point link.
·     Configure the same region name, revision level, and VLAN-to-instance mappings on the two devices.
Enable the No Agreement Check feature on the root port.
To configure No Agreement Check:
Step
Remarks
N/A
N/A
3.     Enable No Agreement Check.
stp no-agreement-check
By default, No Agreement Check is disabled.
No Agreement Check configuration example
As shown in Figure 10, Device A connects to a third-party device that has a different spanning tree implementation. Both devices are in the same region.
The third-party device (Device B) is the regional root bridge, and Device A is the downstream device.
Figure 10 Network diagram
# Enable No Agreement Check on Ten-GigabitEthernet 1/1/1 of Device A.
[DeviceA-Ten-GigabitEthernet1/1/1] stp no-agreement-check
As shown in Figure 11, an IRF fabric connects to two user networks through double links.
·     Device A and Device B form the IRF fabric.
·     The spanning tree feature is disabled on Device A and Device B and enabled on all devices in user network 1 and user network 2.
·     The IRF fabric transparently transmits BPDUs for both user networks and is not involved in the calculation of spanning trees.
When the network topology changes, it takes time for the IRF fabric to update its MAC address table and ARP table. During this period, traffic in the network might be interrupted.
Figure 11 TC Snooping application scenario
image14.emf
To avoid traffic interruption, you can enable TC Snooping on the IRF fabric. After receiving a TC-BPDU through a port, the IRF fabric updates MAC address table and ARP table entries associated with the port's VLAN. In this way, TC Snooping prevents topology change from interrupting traffic forwarding in the network. For more information about the MAC address table and the ARP table, see "Configuring the MAC address table" and Layer 3—IP Services Configuration Guide.
When you configure TC Snooping, follow these restrictions and guidelines:
·     TC Snooping and the spanning tree feature are mutually exclusive. You must globally disable the spanning tree feature before enabling TC Snooping.
·     The priority of BPDU tunneling is higher than that of TC Snooping. When BPDU tunneling is enabled on a port, the TC Snooping feature does not take effect on the port.
·     TC Snooping does not support the PVST mode.
To enable TC Snooping:
Step
Remarks
N/A
2.     Globally disable the spanning tree feature.
undo stp global enable
3.     Enable TC Snooping.
stp tc-snooping
By default, TC Snooping is disabled.
A spanning tree device supports the following protection features:
·     BPDU guard
·     Root guard
·     Loop guard
·     TC-BPDU guard
·     BPDU drop
Enabling BPDU guard
For access layer devices, the access ports can directly connect to the user terminals (such as PCs) or file servers. The access ports are configured as edge ports to allow rapid transition. When these ports receive configuration BPDUs, the system automatically sets the ports as non-edge ports and starts a new spanning tree calculation process. This causes a change of network topology. Under normal conditions, these ports should not receive configuration BPDUs. However, if someone uses configuration BPDUs maliciously to attack the devices, the network will become unstable.
The spanning tree protocol provides the BPDU guard feature to protect the system against such attacks. When edge ports receive configuration BPDUs on a device with BPDU guard enabled, the device performs the following operations:
·     Shuts down these ports.
·     Notifies the NMS that these ports have been shut down by the spanning tree protocol.
The device reactivates the shutdown ports after a detection interval. For more information about this detection interval, see Fundamentals Configuration Guide.
BPDU guard does not take effect on loopback-testing-enabled ports. For more information about loopback testing, see Interface Configuration Guide.
Configure BPDU guard on a device with edge ports configured.
To enable BPDU guard:
Step
Remarks
N/A
2.     Enable the BPDU guard feature for the device.
stp bpdu-protection
By default, BPDU guard is disabled.
Enabling root guard
The root bridge and secondary root bridge of a spanning tree should be located in the same MST region. Especially for the CIST, the root bridge and secondary root bridge are put in a high-bandwidth core region during network design. However, due to possible configuration errors or malicious attacks in the network, the legal root bridge might receive a configuration BPDU with a higher priority. Another device supersedes the current legal root bridge, causing an undesired change of the network topology. The traffic that should go over high-speed links is switched to low-speed links, resulting in network congestion.
To prevent this situation, MSTP provides the root guard feature. If root guard is enabled on a port of a root bridge, this port plays the role of designated port on all MSTIs. After this port receives a configuration BPDU with a higher priority from an MSTI, it performs the following operations:
·     Immediately sets that port to the listening state in the MSTI.
·     Does not forward the received configuration BPDU.
This is equivalent to disconnecting the link connected to this port in the MSTI. If the port receives no BPDUs with a higher priority within twice the forwarding delay, it reverts to its original state.
On a port, the loop guard feature and the root guard feature are mutually exclusive.
Configure root guard on a designated port.
To enable root guard:
Step
Remarks
N/A
N/A
3.     Enable the root guard feature.
stp root-protection
By default, root guard is disabled.
Enabling loop guard
By continuing to receive BPDUs from the upstream device, a device can maintain the state of the root port and blocked ports. However, link congestion or unidirectional link failures might cause these ports to fail to receive BPDUs from the upstream devices. In this situation, the device reselects the following port roles:
·     Those ports in forwarding state that failed to receive upstream BPDUs become designated ports.
·     The blocked ports transit to the forwarding state.
As a result, loops occur in the switched network. The loop guard feature can suppress the occurrence of such loops.
The initial state of a loop guard-enabled port is discarding in every MSTI. When the port receives BPDUs, it transits its state. Otherwise, it stays in the discarding state to prevent temporary loops.
Do not enable loop guard on a port that connects user terminals. Otherwise, the port stays in the discarding state in all MSTIs because it cannot receive BPDUs.
On a port, the loop guard feature is mutually exclusive with the root guard feature or the edge port setting.
Configure loop guard on the root port and alternate ports of a device.
To enable loop guard:
Step
Remarks
N/A
N/A
3.     Enable the loop guard feature for the ports.
stp loop-protection
By default, loop guard is disabled.
Configuring port role restriction
CAUTION
CAUTION:
Use this feature with caution, because enabling port role restriction on a port might affect the connectivity of the spanning tree topology.
The bridge ID change of a device in the user access network might cause a change to the spanning tree topology in the core network. To avoid this problem, you can enable port role restriction on a port. With this feature enabled, when the port receives a superior BPDU, it becomes an alternate port rather than a root port.
Make this configuration on the port that connects to the user access network.
To configure port role restriction:
Step
Remarks
N/A
N/A
3.     Enable port role restriction.
stp role-restriction
By default, port role restriction is disabled.
Configuring TC-BPDU transmission restriction
CAUTION
CAUTION:
Enabling TC-BPDU transmission restriction on a port might cause the previous forwarding address table to fail to be updated when the topology changes.
The topology change to the user access network might cause the forwarding address changes to the core network. When the user access network topology is unstable, the user access network might affect the core network. To avoid this problem, you can enable TC-BPDU transmission restriction on a port. With this feature enabled, when the port receives a TC-BPDU, it does not forward the TC-BPDU to other ports.
To configure TC-BPDU transmission restriction:
Step
Remarks
N/A
N/A
3.     Enable TC-BPDU transmission restriction.
stp tc-restriction
By default, TC-BPDU transmission restriction is disabled.
Enabling TC-BPDU guard
When a device receives topology change (TC) BPDUs (the BPDUs that notify devices of topology changes), it flushes its forwarding address entries. If someone uses TC-BPDUs to attack the device, the device will receive a large number of TC-BPDUs within a short time. Then, the device is busy with forwarding address entry flushing. This affects network stability.
TC-BPDU guard allows you to set the maximum number of immediate forwarding address entry flushes performed within 10 seconds after the device receives the first TC-BPDU. For TC-BPDUs received in excess of the limit, the device performs a forwarding address entry flush when the time period expires. This prevents frequent flushing of forwarding address entries. As a best practice, enable TC-BPDU guard.
To enable TC-BPDU guard:
Step
Remarks
N/A
2.     Enable the TC-BPDU guard feature.
stp tc-protection
By default, TC-BPDU guard is enabled.
As a best practice, do not disable this feature.
3.     (Optional.) Configure the maximum number of forwarding address entry flushes that the device can perform every 10 seconds.
stp tc-protection threshold number
The default setting is 6.
Enabling BPDU drop
In a spanning tree network, every BPDU arriving at the device triggers an STP calculation process and is then forwarded to other devices in the network. Malicious attackers might use the vulnerability to attack the network by forging BPDUs. By continuously sending forged BPDUs, they can make all devices in the network continue performing STP calculations. As a result, problems such as CPU overload and BPDU protocol status errors occur.
To avoid this problem, you can enable BPDU drop on ports. A BPDU drop-enabled port does not receive any BPDUs and is invulnerable to forged BPDU attacks.
To enable BPDU drop on an Ethernet interface:
Step
Remarks
N/A
2.     Enter Layer 2 Ethernet interface view.
N/A
3.     Enable BPDU drop on the current interface.
bpdu-drop any
By default, BPDU drop is disabled.
This feature enables the device to generate logs and report new-root election events or spanning tree topology changes to SNMP. For the event notifications to be sent correctly, you must also configure SNMP on the device. For more information about SNMP configuration, see the network management and monitoring configuration guide for the device.
When you use the snmp-agent trap enable stp [ new-root | tc ] command, follow these guidelines:
·     The new-root keyword applies only to STP, MSTP, and RSTP modes.
·     The tc keyword applies only to PVST mode.
·     In STP, MSTP, or RSTP mode, the snmp-agent trap enable stp command enables SNMP notifications for new-root election events.
·     In PVST mode, the snmp-agent trap enable stp enables SNMP notifications for spanning tree topology changes.
To enable SNMP notifications for new-root election and topology change events:
Step
Remarks
N/A
2.     Enable SNMP notifications for new-root election events.
In STP, MSTP, or RSTP mode, execute either of the following commands:
·     snmp-agent trap enable stp new-root
The default settings are as follows:
·     SNMP notifications are disabled for new-root election events.
·     In MSTP mode, SNMP notifications are enabled in MSTI 0 and disabled in other MSTIs for spanning tree topology changes.
·     In PVST mode, SNMP notifications are disabled for spanning tree topology changes in all VLANs.
3.     Enable SNMP notifications for spanning tree topology changes.
In PVST mode, execute either of the following commands:
·     snmp-agent trap enable stp tc
4.     Enable the device to generate a log when it detects or receives a TCN BPDU in PVST mode.
stp log enable tc
By default, the device does not generate a log when it detects or receives a TCN BPDU in PVST mode.
Displaying and maintaining the spanning tree
Execute display commands in any view and reset command in user view.
Display information about ports blocked by spanning tree protection features.
display stp abnormal-port
Display BPDU statistics on ports.
display stp bpdu-statistics [ interface interface-type interface-number [ instance instance-list ] ]
Display information about ports shut down by spanning tree protection features.
display stp down-port
Display the port role calculation history for the specified MSTI or all MSTIs.
display stp [ instance instance-list | vlan vlan-id-list ] history [ slot slot-number ]
Display the incoming and outgoing TC/TCN BPDU statistics by all ports in the specified MSTI or all MSTIs.
display stp [ instance instance-list | vlan vlan-id-list ] tc [ slot slot-number ]
Display the spanning tree status and statistics.
display stp [ instance instance-list | vlan vlan-id-list ] [ interface interface-list | slot slot-number ] [ brief ]
Display the MST region configuration information that has taken effect.
display stp region-configuration
Display the root bridge information of all MSTIs.
display stp root
Clear the spanning tree statistics.
reset stp [ interface interface-list ]
Spanning tree configuration example
MSTP configuration example
As shown in Figure 12, all devices on the network are in the same MST region. Device A and Device B work at the distribution layer. Device C and Device D work at the access layer.
Configure MSTP so that packets of different VLANs are forwarded along different spanning trees.
·     VLAN 10 packets are forwarded along MSTI 1.
·     VLAN 30 packets are forwarded along MSTI 3.
·     VLAN 40 packets are forwarded along MSTI 4.
·     VLAN 20 packets are forwarded along MSTI 0.
VLAN 10 and VLAN 30 are terminated on the distribution layer devices, and VLAN 40 is terminated on the access layer devices. The root bridges of MSTI 1 and MSTI 3 are Device A and Device B, respectively, and the root bridge of MSTI 4 is Device C.
Figure 12 Network diagram
1.     Configure VLANs and VLAN member ports. (Details not shown.)
¡     Create VLAN 10, VLAN 20, and VLAN 30 on both Device A and Device B.
¡     Create VLAN 10, VLAN 20, and VLAN 40 on Device C.
¡     Create VLAN 20, VLAN 30, and VLAN 40 on Device D.
¡     Configure the ports on these devices as trunk ports and assign them to related VLANs.
2.     Configure Device A:
# Enter MST region view, and configure the MST region name as example.
[DeviceA] stp region-configuration
[DeviceA-mst-region] region-name example
# Map VLAN 10, VLAN 30, and VLAN 40 to MSTI 1, MSTI 3, and MSTI 4, respectively.
[DeviceA-mst-region] instance 1 vlan 10
[DeviceA-mst-region] instance 3 vlan 30
[DeviceA-mst-region] instance 4 vlan 40
# Configure the revision level of the MST region as 0.
[DeviceA-mst-region] revision-level 0
# Activate MST region configuration.
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
# Configure the current device as the root bridge of MSTI 1.
[DeviceA] stp instance 1 root primary
# Enable the spanning tree feature globally.
[DeviceA] stp global enable
3.     Configure Device B:
[DeviceB] stp region-configuration
[DeviceB-mst-region] region-name example
[DeviceB-mst-region] instance 1 vlan 10
[DeviceB-mst-region] instance 3 vlan 30
[DeviceB-mst-region] instance 4 vlan 40
[DeviceB-mst-region] revision-level 0
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
# Configure the current device as the root bridge of MSTI 3.
[DeviceB] stp instance 3 root primary
[DeviceB] stp global enable
4.     Configure Device C:
<DeviceC> system-view
[DeviceC-mst-region] region-name example
[DeviceC-mst-region] instance 1 vlan 10
[DeviceC-mst-region] instance 3 vlan 30
[DeviceC-mst-region] instance 4 vlan 40
[DeviceC-mst-region] revision-level 0
[DeviceC-mst-region] quit
# Configure the current device as the root bridge of MSTI 4.
[DeviceC] stp instance 4 root primary
[DeviceC] stp global enable
5.     Configure Device D:
<DeviceD> system-view
[DeviceD-mst-region] region-name example
[DeviceD-mst-region] instance 1 vlan 10
[DeviceD-mst-region] instance 3 vlan 30
[DeviceD-mst-region] instance 4 vlan 40
[DeviceD-mst-region] revision-level 0
[DeviceD-mst-region] quit
[DeviceD] stp global enable
In this example, Device B has the lowest root bridge ID. As a result, Device B is elected as the root bridge in MSTI 0.
When the network is stable, you can use the display stp brief command to display brief spanning tree information on each device.
# Display brief spanning tree information on Device A.
[DeviceA] display stp brief
 MST ID      Port                         Role  STP State     Protection
 0           Ten-GigabitEthernet1/1/1         ALTE  DISCARDING    NONE
 0           Ten-GigabitEthernet1/1/2         DESI  FORWARDING    NONE
 0           Ten-GigabitEthernet1/1/3         ROOT  FORWARDING    NONE
 1           Ten-GigabitEthernet1/1/1         DESI  FORWARDING    NONE
 1           Ten-GigabitEthernet1/1/3         DESI  FORWARDING    NONE
 3           Ten-GigabitEthernet1/1/2         DESI  FORWARDING    NONE
 3           Ten-GigabitEthernet1/1/3         ROOT  FORWARDING    NONE
# Display brief spanning tree information on Device B.
[DeviceB] display stp brief
 0           Ten-GigabitEthernet1/1/1         DESI  FORWARDING    NONE
 0           Ten-GigabitEthernet1/1/3         DESI  FORWARDING    NONE
 1           Ten-GigabitEthernet1/1/2         DESI  FORWARDING    NONE
 1           Ten-GigabitEthernet1/1/3         ROOT  FORWARDING    NONE
 3           Ten-GigabitEthernet1/1/1         DESI  FORWARDING    NONE
 3           Ten-GigabitEthernet1/1/3         DESI  FORWARDING    NONE
# Display brief spanning tree information on Device C.
[DeviceC] display stp brief
 0           Ten-GigabitEthernet1/1/2         ROOT  FORWARDING    NONE
 1           Ten-GigabitEthernet1/1/1         ROOT  FORWARDING    NONE
 1           Ten-GigabitEthernet1/1/2         ALTE  DISCARDING    NONE
 4           Ten-GigabitEthernet1/1/3         DESI  FORWARDING    NONE
# Display brief spanning tree information on Device D.
[DeviceD] display stp brief
 0           Ten-GigabitEthernet1/1/1         ROOT  FORWARDING    NONE
 0           Ten-GigabitEthernet1/1/2         ALTE  DISCARDING    NONE
 0           Ten-GigabitEthernet1/1/3         ALTE  DISCARDING    NONE
 3           Ten-GigabitEthernet1/1/1         ROOT  FORWARDING    NONE
 3           Ten-GigabitEthernet1/1/2         ALTE  DISCARDING    NONE
 4           Ten-GigabitEthernet1/1/3         ROOT  FORWARDING    NONE
Based on the output, you can draw each MSTI mapped to each VLAN, as shown in Figure 13.
Figure 13 MSTIs mapped to different VLANs
PVST configuration example
As shown in Figure 14, Device A and Device B work at the distribution layer, and Device C and Device D work at the access layer.
Configure PVST to meet the following requirements:
·     Packets of a VLAN are forwarded along the spanning trees of the VLAN.
·     VLAN 10, VLAN 20, and VLAN 30 are terminated on the distribution layer devices, and VLAN 40 is terminated on the access layer devices.
·     The root bridge of VLAN 10 and VLAN 20 is Device A.
·     The root bridge of VLAN 30 is Device B.
·     The root bridge of VLAN 40 is Device C.
Figure 14 Network diagram
# Set the spanning tree mode to PVST.
[DeviceA] stp mode pvst
# Configure the device as the root bridge of VLAN 10 and VLAN 20.
[DeviceA] stp vlan 10 20 root primary
# Enable the spanning tree feature globally and in VLAN 10, VLAN 20, and VLAN 30.
[DeviceA] stp vlan 10 20 30 enable
[DeviceB] stp mode pvst
# Configure the device as the root bridge of VLAN 30.
[DeviceB] stp vlan 30 root primary
[DeviceB] stp vlan 10 20 30 enable
[DeviceC] stp mode pvst
# Configure the device as the root bridge of VLAN 40.
[DeviceC] stp vlan 40 root primary
# Enable the spanning tree feature globally and in VLAN 10, VLAN 20, and VLAN 40.
[DeviceC] stp vlan 10 20 40 enable
[DeviceD] stp mode pvst
# Enable the spanning tree feature globally and in VLAN 20, VLAN 30, and VLAN 40.
[DeviceD] stp vlan 20 30 40 enable
 VLAN ID     Port                         Role  STP State     Protection
 10          Ten-GigabitEthernet1/1/1         DESI  FORWARDING    NONE
 10          Ten-GigabitEthernet1/1/3         DESI  FORWARDING    NONE
 20          Ten-GigabitEthernet1/1/1         DESI  FORWARDING    NONE
 20          Ten-GigabitEthernet1/1/2         DESI  FORWARDING    NONE
 20          Ten-GigabitEthernet1/1/3         DESI  FORWARDING    NONE
 30          Ten-GigabitEthernet1/1/2         DESI  FORWARDING    NONE
 30          Ten-GigabitEthernet1/1/3         ROOT  FORWARDING    NONE
 10          Ten-GigabitEthernet1/1/2         DESI  FORWARDING    NONE
 10          Ten-GigabitEthernet1/1/3         ROOT  FORWARDING    NONE
 20          Ten-GigabitEthernet1/1/3         ROOT  FORWARDING    NONE
 30          Ten-GigabitEthernet1/1/1         DESI  FORWARDING    NONE
 30          Ten-GigabitEthernet1/1/3         DESI  FORWARDING    NONE
 10          Ten-GigabitEthernet1/1/1         ROOT  FORWARDING    NONE
 10          Ten-GigabitEthernet1/1/2         ALTE  DISCARDING    NONE
 20          Ten-GigabitEthernet1/1/1         ROOT  FORWARDING    NONE
 20          Ten-GigabitEthernet1/1/2         ALTE  DISCARDING    NONE
 40          Ten-GigabitEthernet1/1/3         DESI  FORWARDING    NONE
 20          Ten-GigabitEthernet1/1/1         ALTE  DISCARDING    NONE
 20          Ten-GigabitEthernet1/1/2         ROOT  FORWARDING    NONE
 20          Ten-GigabitEthernet1/1/3         ALTE  DISCARDING    NONE
 30          Ten-GigabitEthernet1/1/1         ROOT  FORWARDING    NONE
 30          Ten-GigabitEthernet1/1/2         ALTE  DISCARDING    NONE
 40          Ten-GigabitEthernet1/1/3         ROOT  FORWARDING    NONE
Based on the output, you can draw a topology for each VLAN spanning tree, as shown in Figure 15.
Figure 15 VLAN spanning tree topologies
