06-Layer 3 - IP Routing Configuration Guide
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release7178-6W10006-Layer 3 - IP Routing Configuration Guide
05-IS-IS configuration
05-IS-IS configuration 614.77 KB
Configuring IS-IS·· 1
Overview· 1
Terminology· 1
IS-IS address format 1
NET· 2
IS-IS area· 3
IS-IS network types· 4
IS-IS PDUs· 5
Protocols and standards· 7
IS-IS configuration task list 7
Configuring basic IS-IS· 8
Configuration prerequisites· 8
Enabling IS-IS· 9
Configuring the IS level and circuit level 9
Configuring P2P network type for an interface· 9
Configuring IS-IS route control 10
Configuration prerequisites· 10
Configuring IS-IS link cost 10
Specifying a preference for IS-IS· 11
Configuring the maximum number of ECMP routes· 12
Configuring IS-IS route summarization· 12
Advertising a default route· 12
Configuring IS-IS route redistribution· 13
Configuring IS-IS route filtering· 13
Configuring IS-IS route leaking· 14
Tuning and optimizing IS-IS networks· 14
Configuration prerequisites· 14
Specifying the interval for sending IS-IS hello packets· 15
Specifying the IS-IS hello multiplier 15
Specifying the interval for sending IS-IS CSNP packets· 15
Configuring a DIS priority for an interface· 16
Disabling an interface from sending/receiving IS-IS packets· 16
Enabling an interface to send small hello packets· 16
Configuring LSP parameters· 17
Controlling SPF calculation interval 20
Configuring convergence priorities for specific routes· 21
Setting the LSDB overload bit 21
Configuring the ATT bit 22
Configuring the tag value for an interface· 22
Configuring system ID to host name mappings· 22
Enabling the logging of neighbor state changes· 24
Enabling IS-IS ISPF· 24
Enabling prefix suppression· 24
Configuring IS-IS network management 25
Enhancing IS-IS network security· 26
Configuration prerequisites· 26
Configuring neighbor relationship authentication· 26
Configuring area authentication· 26
Configuring routing domain authentication· 27
Configuring IS-IS GR· 27
Configuring IS-IS NSR· 28
Configuring BFD for IS-IS· 29
Configuring IS-IS FRR· 29
Configuration prerequisites· 29
Configuration guidelines· 30
Configuration procedure· 30
Displaying and maintaining IS-IS· 31
IS-IS configuration examples· 32
Basic IS-IS configuration example· 32
DIS election configuration example· 37
IS-IS route redistribution configuration example· 41
IS-IS authentication configuration example· 44
IS-IS GR configuration example· 47
IS-IS NSR configuration example· 48
BFD for IS-IS configuration example· 51
IS-IS FRR configuration example· 54
Configuring IS-IS
Overview
Intermediate System-to-Intermediate System (IS-IS) is a dynamic routing protocol designed by the ISO to operate on the connectionless network protocol (CLNP).
IS-IS was modified and extended in RFC 1195 by the IETF for application in both TCP/IP and OSI reference models, called "Integrated IS-IS" or "Dual IS-IS."
IS-IS is an IGP used within an AS. It uses the SPF algorithm for route calculation.
Terminology
·     Intermediate system—Similar to a router in TCP/IP, IS is the basic unit used in an IS-IS routing domain to generate and propagate routing information. Throughout this chapter, an IS refers to a router.
·     End systemSimilar to a host in TCP/IP, an ES does not run IS-IS. ISO defines the ES-IS protocol for communication between an ES and an IS.
·     Routing domain—An RD comprises a group of ISs that exchange routing information with each other by using the same routing protocol.
·     Area—An IS-IS routing domain can be split into multiple areas.
·     Link State Database—All link states in the network form the LSDB. Each IS has at least one LSDB. An IS uses the SPF algorithm and LSDB to generate IS-IS routes.
·     Link State Protocol Data Unit or Link State Packet An IS advertises link state information in an LSP.
·     Network Protocol Data Unit—An NPDU is a network layer protocol packet in OSI, similar to an IP packet in TCP/IP.
·     Designated ISA DIS is elected on a broadcast network.
·     Network service access point—An NSAP is an OSI network layer address. The NSAP identifies an abstract network service access point and describes the network address format in the OSI reference model.
NSAP
As shown in Figure 1, an NSAP address comprises the Initial Domain Part (IDP) and the Domain Specific Part (DSP). The IDP is analogous to the network ID of an IP address, and the DSP is analogous to the subnet and host ID.
The IDP includes the Authority and Format Identifier (AFI) and the Initial Domain Identifier (IDI).
The DSP includes:
·     High Order Part of DSP (HO-DSP)Identifies the area.
·     System IDIdentifies the host.
·     SEL—Identifies the type of service.
The IDP and DSP are variable in length. The length of an NSAP address ranges from 8 bytes to 20 bytes.
Figure 1 NSAP address format
Area address
The area address comprises the IDP and the HO-DSP of the DSP, which identify the area and the routing domain. Different routing domains cannot have the same area address.
Typically, a router only needs one area address, and all nodes in the same area must have the same area address. To support smooth area merging, partitioning, and switching, a router can have a maximum of three area addresses.
System ID
A system ID uniquely identifies a host or router. It has a fixed length of 48 bits (6 bytes).
The system ID of a device can be generated from the router ID. For example, suppose a router uses the IP address 168.10.1.1 of Loopback 0 as the router ID. The system ID can be obtained in the following steps:
1.     Extend each decimal number of the IP address to three digits by adding 0s from the left, such as 168.010.001.001.
2.     Divide the extended IP address into three sections that each has four digits to get the system ID 1680.1000.1001.
If you use other methods to define a system ID, make sure that it can uniquely identify the host or router.
SEL
The N-SEL, or the NSAP selector (SEL), is similar to the protocol identifier in IP. Different transport layer protocols correspond to different SELs. All SELs in IP are 00.
Routing method
The IS-IS address format identifies the area, so a Level-1 router can easily identify packets destined to other areas. IS-IS routers perform routing as follows:
·     A Level-1 router performs intra-area routing according to the system ID. If the destination address of a packet does not belong to the local area, the Level-1 router forwards it to the nearest Level-1-2 router.
·     A Level-2 router performs inter-area routing according to the area address.
NET
A network entity title (NET) identifies the network layer information of an IS. It does not include transport layer information. A NET is a special NSAP address with the SEL being 0. The length of a NET ranges from 8 bytes to 20 bytes, same as a NSAP address.
A NET includes the following parts:
·     Area IDHas a length of 1 to 13 bytes.
·     System ID—A system ID uniquely identifies a host or router in the area and has a fixed length of 6 bytes.
·     SEL—Has a value of 0 and a fixed length of 1 byte.
For example, for a NET ab.cdef.1234.5678.9abc.00, the area ID is ab.cdef, the system ID is 1234.5678.9abc, and the SEL is 00.
Typically, a router only needs one NET, but it can have a maximum of three NETs for smooth area merging and partitioning. When you configure multiple NETs, make sure the system IDs are the same.
IS-IS area
IS-IS has a 2-level hierarchy to support large-scale networks. A large-scale routing domain is divided into multiple areas. Typically, a Level-1 router is deployed within an area. A Level-2 router is deployed between areas. A Level-1-2 router is deployed between Level-1 and Level-2 routers.
Level-1 and Level-2
·     Level-1 router—A Level-1 router establishes neighbor relationships with Level-1 and Level-1-2 routers in the same area. It maintains an LSDB comprising intra-area routing information. A Level-1 router forwards packets destined for external areas to the nearest Level-1-2 router. Level-1 routers in different areas cannot establish neighbor relationships.
·     Level-2 router—A Level-2 router establishes neighbor relationships with Level-2 and Level-1-2 routers in the same area or in different areas. It maintains a Level-2 LSDB containing inter-area routing information. All the Level-2 and Level-1-2 routers must be contiguous to form the backbone of the IS-IS routing domain. Level-2 routers can establish neighbor relationships even if they are in different areas.
·     Level-1-2 router—A router with both Level-1 and Level-2 router functions is a Level-1-2 router. It can establish Level-1 neighbor relationships with Level-1 and Level-1-2 routers in the same area. It can establish Level-2 neighbor relationships with Level-2 and Level-1-2 routers in different areas. A Level-1 router can reach other areas only through a Level-1-2 router. The Level-1-2 router maintains two LSDBs, a Level-1 LSDB for intra-area routing and a Level-2 LSDB for inter-area routing.
Figure 2 shows one IS-IS network topology. Area 1 is the backbone that comprises a set of Level-2 routers. The other four areas are non-backbone areas connected to the backbone through Level-1-2 routers.
Figure 2 IS-IS topology 1
Figure 3 shows another IS-IS topology. The Level-1-2 routers connect to the Level-1 and Level-2 routers, and form the IS-IS backbone together with the Level-2 routers. No area is defined as the backbone in this topology. The backbone comprises all contiguous Level-2 and Level-1-2 routers in different areas. The IS-IS backbone does not need to be a specific area.
Figure 3 IS-IS topology 2
Both the Level-1 and Level-2 routers use the SPF algorithm to generate the shortest path tree.
Route leaking
Level-2 and Level-1-2 routers form a Level-2 area. An IS-IS routing domain comprises only one Level-2 area and multiple Level-1 areas. A Level-1 area must connect to the Level-2 area rather than another Level-1 area.
Level-1-2 routers send the routing information of Level-1 areas to the Level-2 area. Level-2 routers know the routing information of the entire IS-IS routing domain. By default, a Level-2 router does not advertise the routing information of other areas to a Level-1 area. A Level-1 router simply sends packets destined for other areas to the nearest Level-1-2 router. The path passing through the Level-1-2 router might not be the best. To solve this problem, IS-IS provides the route leaking feature.
Route leaking enables a Level-1-2 router to advertise the routes of other areas to the connected Level-1 area so that the Level-1 routers can select the optimal routes.
IS-IS network types
Network types
IS-IS supports only broadcast networks such as Ethernet and Token Ring.
DIS and pseudonodes
IS-IS routers on a broadcast network must elect a DIS.
The Level-1 and Level-2 DISs are elected separately. You can assign different priorities to a router for different level DIS elections. The higher the router priority, the more likely the router becomes the DIS. If multiple routers with the same highest DIS priority exist, the one with the highest Subnetwork Point of Attachment (SNPA) address will be elected. On a broadcast network, the SNPA address is the MAC address. A router can be the DIS for different levels.
IS-IS DIS election differs from OSPF DIS election in the following ways:
·     A router with priority 0 can also participate in the DIS election.
·     When a router with a higher priority is added to the network, an LSP flooding process is performed to elect the router as the new DIS.
As shown in Figure 4, the same level routers on a network, including non-DIS routers, establish adjacency with each other.
Figure 4 DIS in the IS-IS broadcast network
The DIS creates and updates pseudonodes, and generates LSPs for the pseudonodes, to describe all routers on the network.
A pseudonode represents a virtual node on the broadcast network. It is not a real router. In IS-IS, it is identified by the system ID of the DIS and a 1-byte Circuit ID (a non-zero value).
Using pseudonodes simplifies network topology and can reduce the amount of resources consumed by SPF.
On an IS-IS broadcast network, all routers establish adjacency relationships, but they synchronize their LSDBs through the DIS.
IS-IS PDUs
PDU
IS-IS PDUs are encapsulated into link layer frames. An IS-IS PDU has two parts, the headers and the variable length fields. The headers comprise the PDU common header and the PDU specific header. All PDUs have the same PDU common header. The specific headers vary by PDU type.
Figure 5 PDU format
Table 1 PDU types
PDU Type
Acronym
15
Level-1 LAN IS-IS hello PDU
L1 LAN IIH
16
Level-2 LAN IS-IS hello PDU
L2 LAN IIH
17
Point-to-Point IS-IS hello PDU
P2P IIH
18
Level-1 Link State PDU
L1 LSP
20
Level-2 Link State PDU
L2 LSP
24
Level-1 Complete Sequence Numbers PDU
L1 CSNP
25
Level-2 Complete Sequence Numbers PDU
L2 CSNP
26
Level-1 Partial Sequence Numbers PDU
L1 PSNP
27
Level-2 Partial Sequence Numbers PDU
L2 PSNP
Hello PDU
IS-to-IS hello (IIH) PDUs are used by routers to establish and maintain neighbor relationships. On broadcast networks, Level-1 routers use Level-1 LAN IIHs, and Level-2 routers use Level-2 LAN IIHs. The P2P IIHs are used on point-to-point networks.
LSP
The LSPs carry link state information. LSPs include Level-1 LSPs and Level-2 LSPs. The Level-2 LSPs are sent by the Level-2 routers, and the Level-1 LSPs are sent by the Level-1 routers. The Level-1-2 router can send both types of LSPs.
SNP
A sequence number PDU (SNP) describes the complete or partial LSPs for LSDB synchronization.
SNPs include CSNP and PSNP, which are further divided into Level-1 CSNP, Level-2 CSNP, Level-1 PSNP, and Level-2 PSNP.
A CSNP describes the summary of all LSPs for LSDB synchronization between neighboring routers. On broadcast networks, CSNPs are sent by the DIS periodically (every 10 seconds by default). On point-to-point networks, CSNPs are sent only during the first adjacency establishment.
A PSNP only contains the sequence numbers of one or multiple latest received LSPs. It can acknowledge multiple LSPs at one time. When LSDBs are not synchronized, a PSNP is used to request missing LSPs from a neighbor.
CLV
The variable fields of PDU comprise multiple Code-Length-Value (CLV) triplets.
Figure 6 CLV format
Table 2 shows that different PDUs contain different CLVs. Codes 1 through 10 are defined in ISO 10589 (code 3 and 5 are not shown in the table). Codes 128 through 132 are defined in RFC 1195. Codes 222 through 237 are defined in RFC 5120.
Table 2 CLV codes and PDU types
CLV Code
Name
PDU Type
1
Area Addresses
IIH, LSP
2
IS Neighbors (LSP)
LSP
4
Partition Designated Level 2 IS
L2 LSP
6
IS Neighbors (MAC Address)
LAN IIH
7
IS Neighbors (SNPA Address)
LAN IIH
8
Padding
IIH
9
LSP Entries
SNP
10
Authentication Information
IIH, LSP, SNP
128
IP Internal Reachability Information
LSP
129
Protocols Supported
IIH, LSP
130
IP External Reachability Information
L2 LSP
131
Inter-Domain Routing Protocol Information
L2 LSP
132
IP Interface Address
IIH, LSP
222
MT-ISN
LSP
229
M-Topologies
IIH, LSP
235
MT IP. Reach
LSP
237
MT IPv6 IP. Reach
LSP
·     ISO 10589 ISO IS-IS Routing Protocol
·     ISO 9542 ES-IS Routing Protocol
·     ISO 8348/Ad2 Network Services Access Points
·     RFC 1195, Use of OSI IS-IS for Routing in TCP/IP and Dual Environments
·     RFC 2763, Dynamic Hostname Exchange Mechanism for IS-IS
·     RFC 2966, Domain-wide Prefix Distribution with Two-Level IS-IS
·     RFC 2973, IS-IS Mesh Groups
·     RFC 3277, IS-IS Transient Blackhole Avoidance
·     RFC 3358, Optional Checksums in ISIS
·     RFC 3373, Three-Way Handshake for IS-IS Point-to-Point Adjacencies
·     RFC 3567, Intermediate System to Intermediate System (IS-IS) Cryptographic Authentication
·     RFC 3719, Recommendations for Interoperable Networks using IS-IS
·     RFC 3786, Extending the Number of IS-IS LSP Fragments Beyond the 256 Limit
·     RFC 3787, Recommendations for Interoperable IP Networks using IS-IS
·     RFC 3847, Restart Signaling for IS-IS
·     RFC 4444, Management Information Base for Intermediate System to Intermediate System (IS-IS)
·     RFC 5303, Three-Way Handshake for IS-IS Point-to-Point Adjacencies
·     RFC 5310, IS-IS Generic Cryptographic Authentication
Tasks at a glance
Configuring basic IS-IS:
·     (Required.) Enabling IS-IS
·     (Optional.) Configuring the IS level and circuit level
·     (Optional.) Configuring P2P network type for an interface
(Optional.) Configuring IS-IS route control:
·     Configuring IS-IS link cost
·     Specifying a preference for IS-IS
·     Configuring the maximum number of ECMP routes
·     Configuring IS-IS route summarization
·     Advertising a default route
·     Configuring IS-IS route redistribution
·     Configuring IS-IS route filtering
·     Configuring IS-IS route leaking
(Optional.) Tuning and optimizing IS-IS networks:
·     Specifying the interval for sending IS-IS hello packets
·     Specifying the IS-IS hello multiplier
·     Specifying the interval for sending IS-IS CSNP packets
·     Disabling an interface from sending/receiving IS-IS packets
·     Enabling an interface to send small hello packets
·     Configuring LSP parameters
·     Controlling SPF calculation interval
·     Configuring convergence priorities for specific routes
·     Setting the LSDB overload bit
·     Configuring the ATT bit
·     Configuring the tag value for an interface
·     Configuring system ID to host name mappings
·     Enabling the logging of neighbor state changes
·     Enabling IS-IS ISPF
·     Enabling prefix suppression
(Optional.) Enhancing IS-IS network security:
·     Configuring neighbor relationship authentication
·     Configuring area authentication
·     Configuring routing domain authentication
(Optional.) Configuring IS-IS GR
(Optional.) Configuring IS-IS NSR
(Optional.) Configuring BFD for IS-IS
(Optional.) Configuring IS-IS FRR
Before the configuration, complete the following tasks:
·     Configure the link layer protocol.
·     Configure IP addresses for interfaces to ensure IP connectivity between neighboring nodes.
Enabling IS-IS
Step
Remarks
N/A
1.     Create an IS-IS process and enter its view.
By default, the IS-IS process is disabled.
2.     Assign a NET.
network-entity net
By default, NET is not assigned.
3.     Return to system view.
N/A
4.     Enter interface view.
N/A
5.     Enable an IS-IS process on the interface.
isis enable [ process-id ]
By default, no IS-IS process is enabled.
Follow these guidelines when you configure the IS level for routers in only one area:
·     Configure the IS level of all routers as Level-1 or Level-2 rather than different levels because the routers do not need to maintain two identical LSDBs.
·     Configure the IS level as Level-2 on all routers in an IP network for good scalability.
For an interface of a Level-1 or Level-2 router, the circuit level can only be Level-1 or Level-2. For an interface of a Level-1-2 router, the default circuit level is Level-1-2. If the router only needs to form Level-1 or Level-2 neighbor relationships, configure the circuit level for its interfaces as Level-1 or Level-2. This will limit neighbor relationship establishment.
To configure the IS level and circuit level:
Step
Remarks
N/A
2.     Enter IS-IS view.
N/A
3.     Specify the IS level.
is-level { level-1 | level-1-2 | level-2 }
By default, the IS level is Level-1-2.
4.     Return to system view.
N/A
5.     Enter interface view.
N/A
6.     Specify the circuit level.
isis circuit-level [ level-1 | level-1-2 | level-2 ]
By default, an interface can establish either the Level-1 or Level-2 adjacency.
Perform this task only for a broadcast network that has up to two attached routers.
Interfaces with different network types operate differently. For example, broadcast interfaces on a network must elect the DIS and flood CSNP packets to synchronize the LSDBs. However, P2P interfaces on a network do not need to elect the DIS, and have a different LSDB synchronization mechanism.
If only two routers exist on a broadcast network, configure the network type of attached interfaces as P2P. This avoids DIS election and CSNP flooding, saving network bandwidth and speeding up network convergence.
To configure P2P network type for an interface:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Configure P2P network type for an interface.
isis circuit-type p2p
By default, the network type of an interface varies by physical media. The network type of a VLAN interface is broadcast.
·     Enable IS-IS.
The IS-IS cost of an interface is determined in the following order:
1.     IS-IS cost specified in interface view.
2.     IS-IS cost specified in system view.
The cost is applied to the interfaces associated with the IS-IS process.
3.     Automatically calculated cost.
If the cost style is wide or wide-compatible, IS-IS automatically calculates the cost using the formula: Interface cost = (Bandwidth reference value / Expected interface bandwidth) × 10, in the range of 1 to 16777214. For other cost styles, Table 3 applies.
Configure the expected bandwidth of an interface by using the bandwidth command. For more information, see Interface Command Reference.
Table 3 Automatic cost calculation scheme for cost styles other than wide and wide-compatible
Interface bandwidth
Interface cost
≤ 10 Mbps
60
≤ 100 Mbps
50
≤ 155 Mbps
40
≤ 622 Mbps
30
≤ 2500 Mbps
20
> 2500 Mbps
10
4.     If none of the above costs is used, a default cost of 10 applies.
Configuring an IS-IS cost for an interface
Step
Remarks
4.     Enter system view.
N/A
5.     Enter IS-IS view.
N/A
6.     (Optional.) Specify an IS-IS cost style.
By default, the IS-IS cost type is narrow.
7.     Return to system view.
N/A
8.     Enter interface view.
N/A
9.     (Optional.) Specify a cost for the IS-IS interface.
isis cost value [ level-1 | level-2 ]
By default, no cost for the interface is specified.
Configuring a global IS-IS cost
Step
Remarks
N/A
N/A
3.     (Optional.) Specify an IS-IS cost style.
By default, the IS-IS cost style is narrow.
4.     Specify a global IS-IS cost.
circuit-cost value [ level-1 | level-2 ]
By default, no global cost is specified.
Enabling automatic IS-IS cost calculation
Step
Remarks
N/A
N/A
3.     Specify an IS-IS cost style.
cost-style { wide | wide-compatible }
By default, the IS-IS cost is narrow.
4.     Enable automatic IS-IS cost calculation.
auto-cost enable
By default, automatic IS-IS cost calculation is disabled.
5.     (Optional.) Configure a bandwidth reference value for automatic IS-IS cost calculation.
bandwidth-reference value
The default setting is 100 Mbps.
If multiple routing protocols find routes to the same destination, the route found by the routing protocol that has the highest preference is selected as the optimal route.
Perform this task to assign a preference to IS-IS directly or by using a routing policy. For more information about the routing policy, see "Configuring routing policies."
To configure a preference for IS-IS:
Step
Remarks
N/A
N/A
3.     Configure a preference for IS-IS.
The default setting is 15.
Perform this task to implement load sharing over ECMP routes.
To configure the maximum number of ECMP routes:
Step
Remarks
N/A
N/A
3.     Specify the maximum number of ECMP routes.
maximum load-balancing number
By default, the maximum number of ECMP routes supported by IS-IS equals to the maximum number of ECMP routes supported by the system.
Perform this task to summarize specific routes, including IS-IS routes and redistributed routes, into a single route. Route summarization can reduce the routing table size and the LSDB scale.
Route summarization applies only to locally generated LSPs. The cost of the summary route is the lowest one among the costs of the more-specific routes.
To configure route summarization:
Step
Remarks
N/A
N/A
3.     Configure IS-IS route summarization.
summary ip-address { mask-length | mask } [ avoid-feedback | generate_null0_route | [ level-1 | level-1-2 | level-2 ] | tag tag ] *
By default, route summarization is not configured.
IS-IS cannot redistribute a default route to its neighbors. This task enables IS-IS to advertise a default route of 0.0.0.0/0 in an LSP to the same-level neighbors. Upon receiving the default route, the neighbors add it into their routing table.
To advertise a default route:
Step
Remarks
N/A
N/A
3.     Advertise a default route.
default-route-advertise [ [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name ] *
By default, IS-IS does not advertise a default route.
Perform this task to redistribute routes from other routing protocols into IS-IS. You can specify a cost for redistributed routes and specify the maximum number of redistributed routes.
To configure IS-IS route redistribution from other routing protocols:
Step
Remarks
N/A
N/A
3.     Redistribute routes from other routing protocols or other IS-IS processes.
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | cost-type { external | internal } | [ level-1 | level-1-2 | level-2 ] | route-policy route-policy-name | tag tag ] *
By default, no route is redistributed.
By default, if no level is specified, this command redistributes routes into the Level-2 routing table.
This command redistributes only active routes. To display active routes, use the display ip routing-table protocol command.
4.     (Optional.) Configure the maximum number of redistributed Level 1/Level 2 IPv4 routes.
import-route limit number
By default, the maximum number of redistributed Level 1/Level 2 IPv4 routes is 524288.
You can use an ACL, IP prefix list, or routing policy to filter routes calculated using received LSPs and routes redistributed from other routing protocols.
Filtering routes calculated from received LSPs
IS-IS saves LSPs received from neighbors in the LSDB, uses the SPF algorithm to calculate the shortest path tree with itself as the root, and installs the routes to the IS-IS routing table. IS-IS installs the optimal routes to the IP routing table.
Perform this task to filter calculated routes. Only routes that are not filtered can be added to the IP routing table. The filtered routes retain in the IS-IS routing table and can be advertised to neighbors.
To filter routes calculated using received LSPs:
Step
Remarks
N/A
N/A
3.     Filter routes calculated using received LSPs.
filter-policy { acl-number | prefix-list prefix-list-name | route-policy route-policy-name } import
By default, IS-IS route filtering is not configured.
Filtering redistributed routes
IS-IS can redistribute routes from other routing protocols or other IS-IS processes, add them to the IS-IS routing table, and advertise them in LSPs.
Perform this task to filter redistributed routes. Only routes that are not filtered can be added to the IS-IS routing table and advertised to neighbors.
To filter redistributed routes:
Step
Remarks
N/A
N/A
3.     Filter routes redistributed from other routing protocols or IS-IS processes.
filter-policy { acl-number | prefix-list prefix-list-name | route-policy route-policy-name } export [ protocol [ process-id ] ]
Perform this task to control route advertisement (route leaking) between Level-1 and Level-2.
You can configure IS-IS to advertise routes from Level-2 to Level-1, and to not advertise routes from Level-1 to Level-2.
To configure IS-IS route leaking:
Step
Remarks
N/A
N/A
3.     Configure route leaking from Level-1 to Level-2.
import-route isis level-1 into level-2 [ filter-policy { acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
By default, IS-IS advertises routes from Level-1 to Level-2.
4.     Configure route leaking from Level-2 to Level-1.
import-route isis level-2 into level-1 [ filter-policy { acl-number | prefix-list prefix-list-name | route-policy route-policy-name } | tag tag ] *
By default, IS-IS does not advertise routes from Level-2 to Level-1.
Before you tune and optimize IS-IS networks, complete the following tasks:
·     Enable IS-IS.
If a neighbor does not receive any hello packets from the router within the advertised hold time, it considers the router down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval.
To specify the interval for sending hello packets:
Step
Remarks
N/A
N/A
3.     Specify the interval for sending hello packets.
isis timer hello seconds [ level-1 | level-2 ]
The default setting is 10 seconds.
The interval between hello packets sent by the DIS is 1/3 the hello interval set with the isis timer hello command.
The hello multiplier is the number of hello packets a neighbor must miss before it declares that the router is down.
If a neighbor receives no hello packets from the router within the advertised hold time, it considers the router down and recalculates the routes. The hold time is the hello multiplier multiplied by the hello interval.
On a broadcast link, Level-1 and Level-2 hello packets are advertised separately. You must set a hello multiplier for each level.
On a P2P link, Level-1 and Level-2 hello packets are advertised in P2P hello packets. You do not need to specify Level-1 or Level-2.
To specify the IS-IS hello multiplier:
Step
Remarks
N/A
N/A
3.     Specify the hello multiplier.
isis timer holding-multiplier value [ level-1 | level-2 ]
The default setting is 3.
On a broadcast network, perform this task on the DIS that uses CSNP packets to synchronize LSDBs.
To specify the interval for sending IS-IS CSNP packets:
Step
Remarks
N/A
N/A
3.     Specify the interval for sending CSNP packets on the DIS of a broadcast network.
isis timer csnp seconds [ level-1 | level-2 ]
On a broadcast network, IS-IS must elect a router as the DIS at a routing level. You can specify a DIS priority at a level for an interface. The greater the interface's priority, the more likely it becomes the DIS. If multiple routers in the broadcast network have the same highest DIS priority, the router with the highest MAC address becomes the DIS.
To configure a DIS priority for an interface:
Step
Remarks
N/A
N/A
3.     Configure a DIS priority for the interface.
isis dis-priority value [ level-1 | level-2 ]
The default setting is 64.
After being disabled from sending and receiving hello packets, an interface cannot form any neighbor relationship, but can advertise directly connected networks in LSPs through other interfaces. This can save bandwidth and CPU resources, and ensures that other routers know networks directly connected to the interface.
To disable an interface from sending and receiving IS-IS packets:
Step
Remarks
N/A
N/A
3.     Disable the interface from sending and receiving IS-IS packets.
isis silent
By default, the interface can send and receive IS-IS packets.
IS-IS messages cannot be fragmented at the IP layer because they are directly encapsulated in frames. Any two IS-IS neighboring routers must negotiate a common MTU. To avoid sending big hellos to save bandwidth, enable the interface to send small hello packets without CLVs.
To enable an interface to send small hello packets:
Step
Remarks
N/A
N/A
3.     Enable the interface to send small hello packets without CLVs.
isis small-hello
By default, the interface can send standard hello packets.
Configuring LSP timers
1.     Specify the maximum age of LSPs.
Each LSP has an age that decreases in the LSDB. Any LSP with an age of 0 is deleted from the LSDB. You can adjust the age value based on the scale of a network.
To specify the maximum age of LSPs:
Step
Remarks
N/A
N/A
3.     Specify the maximum LSP age.
timer lsp-max-age seconds
The default setting is 1200 seconds.
2.     Specify the LSP refresh interval and generation interval.
Each router needs to refresh its LSPs at a configurable interval and send them to other routers to prevent valid routes from aging out. A smaller refresh interval speeds up network convergence but consumes more bandwidth.
When network topology changes such as neighbor state, interface metric, system ID, or area ID changes occur, the router generates an LSP after a configurable interval. If such a change occurs frequently, excessive LSPs are generated, consuming a large amount of router resources and bandwidth. To solve the problem, you can adjust the LSP generation interval.
When network changes are not frequent, the minimum-interval is adopted. If network changes become frequent, the LSP generation interval is incremented by incremental-interval × 2n-2 (n is the number of calculation times) each time a generation occurs until the maximum-interval is reached.
To specify the LSP refresh interval and generation interval:
Step
Remarks
N/A
N/A
3.     Specify the LSP refresh interval.
timer lsp-refresh seconds
By default, the LSP refresh interval is 900 seconds.
4.     Specify the LSP generation interval.
timer lsp-generation maximum-interval [ minimum-interval [ incremental-interval ] ] [ level-1 | level-2 ]
By default:
·     The maximum interval is 5 seconds.
·     The minimum interval is 50 milliseconds.
·     The incremental interval is 200 milliseconds.
3.     Specify LSP sending intervals.
If a change occurs in the LSDB, IS-IS advertises the changed LSP to neighbors. You can specify the minimum interval for sending these LSPs to control the amount of LSPs on the network.
On a P2P link, IS-IS requires an advertised LSP be acknowledged. If no acknowledgment is received within a configurable interval, IS-IS will retransmit the LSP.
To configure LSP sending intervals:
Step
Remarks
N/A
N/A
3.     Specify the minimum interval for sending LSPs and the maximum LSP number that can be sent at a time.
isis timer lsp time [ count count ]
By default, the minimum interval is 33 milliseconds, and the maximum LSP number that can be sent at a time is 5.
4.     Specify the LSP retransmission interval on a P2P link.
isis timer retransmit seconds
By default, the LSP retransmission interval on a P2P link is 5 seconds.
Specifying LSP lengths
IS-IS messages cannot be fragmented at the IP layer because they are directly encapsulated in frames. IS-IS routers in an area must send LSPs smaller than the smallest interface MTU in the area.
If the IS-IS routers have different interface MTUs, configure the maximum size of generated LSP packets to be smaller than the smallest interface MTU in the area. Otherwise, the routers must dynamically adjust the LSP packet size to fit the smallest interface MTU, which takes time and affects other services.
To specify LSP lengths:
Step
Remarks
N/A
N/A
3.     Specify the maximum length of generated Level-1 LSPs or Level-2 LSPs.
lsp-length originate size [ level-1 | level-2 ]
By default, the maximum length of generated Level-1 LSPs or Level-2 LSPs is 1497 bytes.
4.     Specify the maximum length of received LSPs.
lsp-length receive size
By default, the maximum length of received LSPs is 1497 bytes.
Enabling LSP flash flooding
Changed LSPs can trigger SPF recalculation. To advertise the changed LSPs before the router recalculates routes for faster network convergence, enable LSP flash flooding.
To enable LSP flash flooding:
Step
Remarks
N/A
N/A
3.     Enable LSP flash flooding.
flash-flood [ flood-count flooding-count | max-timer-interval flooding-interval | [ level-1 | level-2 ] ] *
By default, LSP flash flooding is disabled.
Enabling LSP fragment extension
Perform this task to enable IS-IS fragment extension for an IS-IS process. The MTUs of all interfaces running the IS-IS process must not be less than 512. Otherwise, LSP fragment extension does not take effect.
To enable LSP fragment extension:
Step
Remarks
N/A
N/A
3.     Enable LSP fragment extension.
lsp-fragments-extend [ level-1 | level-1-2 | level-2 ]
4.     Configure a virtual system ID.
virtual-system virtual-system-id
By default, no virtual system ID is configured.
Configure at least one virtual system to generate extended LSP fragments.
Limiting LSP flooding
As shown in Figure 7, Routers A, B, C and D run IS-IS. When Router A generates an LSP, it floods the LSP out of GigabitEthernet 1/0/1, GigabitEthernet 1/0/2, and GigabitEthernet 1/0/3. After Router D receives the LSP from GigabitEthernet 1/0/3, it floods it out of GigabitEthernet 1/0/1 and GigabitEthernet 1/0/2 to Router B and Router C. However, Router B and Router C have already received the LSP from Router A. Repeated LSP flooding consumes extra bandwidth.
Figure 7 Network diagram of a fully meshed network
To avoid this problem, you can add interfaces to a mesh group or block some interfaces.
·     An interface in a mesh group floods a received LSP only to interfaces not in the mesh group.
·     A blocked interface sends LSPs only after receiving LSP requests.
Before you configure this task, you must consider redundancy for interfaces in case LSP packets cannot be flooded because of link failures.
To add an interface to a mesh group or block an interface:
Step
Remarks
N/A
N/A
3.     Add the interface to a mesh group or block the interface.
·     Add the interface to a mesh group:
isis mesh-group mesh-group-number
·     Block the interface:
isis mesh-group mesh-blocked
By default, the interface does not belong to any mesh group and is not blocked.
The mesh group feature takes effect only on P2P interfaces.
Based on the LSDB, an IS-IS router uses the SPF algorithm to calculate the shortest path tree with itself being the root, and uses the shortest path tree to determine the next hop to a destination network. By adjusting the SPF calculation interval, you can prevent bandwidth and router resources from being over consumed due to frequent topology changes.
When network changes are not frequent, the minimum-interval is adopted. If network changes become frequent, the SPF calculation interval is incremented by incremental-interval × 2n-2 (n is the number of calculation times) each time a calculation occurs until the maximum-interval is reached.
To control SPF calculation interval:
Step
Remarks
N/A
N/A
3.     Configure the SPF calculation interval.
timer spf maximum-interval [ minimum-interval [ incremental-interval ] ]
By default:
A topology change causes IS-IS routing convergence. To improve convergence speed, you can assign convergence priorities to IS-IS routes. Convergence priority levels are critical, high, medium, and low. The higher the convergence priority, the faster the convergence speed.
By default, IS-IS host routes have medium convergence priority, and other IS-IS routes have low convergence priority.
To assign convergence priorities to specific IS-IS routes:
Step
Remarks
N/A
N/A
3.     Assign convergence priorities to specific IS-IS routes.
priority { critical | high | medium } { prefix-list prefix-list-name | tag tag-value }
By default, IS-IS routes have the low convergence priority.
By setting the overload bit in sent LSPs, a router informs other routers of failures that make it unable to select routes and forward packets.
When an IS-IS router cannot record the complete LSDB, for example, because of memory insufficiency, it will calculate wrong routes. To make troubleshooting easier, temporarily isolate the router from the IS-IS network by setting the overload bit.
To set the LSDB overload bit:
Step
Remarks
N/A
N/A
3.     Set the overload bit.
set-overload [ on-startup [ [ start-from-nbr system-id [ timeout1 [ nbr-timeout ] ] ] | timeout2 ] [ allow { external | interlevel } * ]
By default, the overload bit is not set.
A Level-1-2 router sends Level-1 LSPs with an ATT bit to inform the Level-1 routers that it can reach other areas.
Configuring IS-IS not to calculate the default route through the ATT bit
Step
Remarks
N/A
N/A
3.     Configure IS-IS not to calculate the default route through the ATT bit.
ignore-att
By default, IS-IS uses the ATT bit to calculate the default route.
Setting the ATT bit of Level-1 LSPs
Step
Remarks
N/A
2.     Enter IS-IS view
N/A
3.     Set the ATT bit of Level-1 LSPs.
set-att { always | never }
By default, the ATT bit is not set for Level-1 LSPs.
Perform this task when the link cost style is wide, wide-compatible, or compatible.
When IS-IS advertises a prefix with a tag value, IS-IS adds the tag to the IP reachability information TLV of the prefix.
To configure the tag value for an interface:
Step
Remarks
N/A
2.     Enter interface view or IPv4 unicast topology view of the interface.
·     Enter interface view:
·     Enter IPv4 unicast topology view of the interface:
a.     interface interface-type interface-number
b.     topology ipv4 [ unicast ] topo-name
N/A
3.     Configure the tag value for the interface.
isis tag tag
By default, the tag value of the interface is not configured.
A 6-byte system ID in hexadecimal notation uniquely identifies a router or host in an IS-IS network. To make a system ID easy to read, the system allows you to use host names to identify devices. It also provides mappings between system IDs and host names.
The mappings can be configured manually or dynamically. Follow these guidelines when you configure the mappings:
·     To view host names rather than system IDs by using the display isis lsdb command, you must enable dynamic system ID to host name mapping.
·     If you configure both dynamic mapping and static mapping on a router, the host name specified for dynamic mapping applies.
Configuring a static system ID to host name mapping
Step
Remarks
N/A
N/A
3.     Configure a system ID to host name mapping for a remote IS.
is-name map sys-id map-sys-name
A system ID can correspond to only one host name.
Configuring dynamic system ID to host name mapping
Static system ID to host name mapping requires you to manually configure a mapping for each router in the network. When a new router is added to the network or a mapping must be modified, you must configure all routers manually.
When you use dynamic system ID to host name mapping, you only need to configure a host name for each router in the network. Each router advertises the host name in a dynamic host name CLV to other routers so all routers in the network can have all mappings.
To help check the origin of LSPs in the LSDB, you can configure a name for the DIS in a broadcast network.
To configure dynamic system ID to host name mapping:
Step
Remarks
N/A
N/A
3.     Specify a host name for the IS and enable dynamic system ID to host name mapping.
is-name sys-name
By default, no host name is specified for the router.
N/A
N/A
6.     Configure a DIS name.
isis dis-name symbolic-name
By default, no DIS name is configured.
This command takes effect only on a router enabled with dynamic system ID to host name mapping.
This command is not available on P2P interfaces.
With this feature enabled, the router delivers logs about neighbor state changes to its information center. The information center processes the logs according to user-defined output rules (whether to output logs and where to output). For more information about the information center, see Network Management and Monitoring Configuration Guide.
To enable the logging of neighbor state changes:
Step
Remarks
N/A
N/A
3.     Enable the logging of neighbor state changes.
log-peer-change
By default, the logging of neighbor state changes is enabled.
Enabling IS-IS ISPF
When the network topology changes, Incremental Shortest Path First (ISPF) computes only the affected part of the SPT, instead of the entire SPT.
To enable IS-IS ISPF:
Step
Remarks
N/A
N/A
3.     Enable IS-IS ISPF.
ispf enable
By default, IS-IS ISPF is enabled.
Perform this task to disable an interface from advertising its prefix in LSPs. This enhances network security by preventing IP routing to the interval nodes and speeds up network convergence.
To enable prefix suppression:
Step
Remarks
N/A
N/A
3.     Enable prefix suppression on the interface.
isis prefix-suppression
By default, prefix suppression is disabled on the interface.
This command is also applicable to the secondary IP address of the interface.
This task includes the following configurations:
·     Bind an IS-IS process to MIB so that you can use network management software to manage the specified IS-IS process.
·     Enable IS-IS notifications to report important events.
Notifications are delivered to the SNMP module, which outputs the notifications according to the configured output rules. For more information about SNMP notifications, see Network Management and Monitoring Configuration Guide.
TRILL uses the IS-IS MIB to provide the TRILL object management function for NMS. Because the MIB objects defined in the IS-IS MIB are single-instance management objects, NMS cannot manage IS-IS and TRILL at the same time. According to the management for multiple OSPF instances defined in RFC 4750, you can set a context name for the SNMP object for managing TRILL. In this way, the SNMP requests for managing IS-IS and the SNMP requests for managing TRILL from NMS can be distinguished. Because the context name is a concept specific to SNMPv3, the community names are mapped to context names for distinguishing different protocols in SNMPv1/v2c.
To configure IS-IS network management:
Step
Remarks
N/A
2.     Bind MIB to an IS-IS process.
isis mib-binding process-id
By default, MIB is bound to the IS-IS process with the smallest process ID.
3.     Enable IS-IS notification sending.
snmp-agent trap enable isis [ adjacency-state-change | area-mismatch | authentication | authentication-type | buffsize-mismatch | id-length-mismatch | lsdboverload-state-change | lsp-corrupt | lsp-parse-error | lsp-size-exceeded | manual-address-drop | max-seq-exceeded | maxarea-mismatch | own-lsp-purge | protocol-support  | rejected-adjacency | skip-sequence-number | version-skew ] *
By default, IS-IS notification sending is enabled.
4.     Enter IS-IS view.
N/A
5.     Configure the context name for the SNMP object for managing IS-IS.
By default, no context name is set for the SNMP object for managing IS-IS.
To enhance the security of an IS-IS network, you can configure IS-IS authentication. IS-IS authentication involves neighbor relationship authentication, area authentication, and routing domain authentication.
·     Enable IS-IS.
With neighbor relationship authentication configured, an interface adds the password in the specified mode into hello packets to the peer and checks the password in the received hello packets. If the authentication succeeds, it forms the neighbor relationship with the peer.
The authentication mode and password at both ends must be identical.
To prevent packet exchange failure in case of an authentication password change, configure the interface not to check the authentication information in the received packets.
To configure neighbor relationship authentication:
Step
Remarks
N/A
N/A
3.     Specify the authentication mode and password.
isis authentication-mode { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } | md5 | simple } { cipher cipher-string | plain plain-string } [ level-1 | level-2 ] [ ip | osi ]
By default, no authentication is configured.
Area authentication prevents the router from installing routing information from untrusted routers into the Level-1 LSDB. The router encapsulates the authentication password in the specified mode in Level-1 packets (LSP, CSNP, and PSNP). It also checks the password in received Level-1 packets.
Routers in a common area must have the same authentication mode and password.
To prevent packet exchange failure in case of an authentication password change, configure IS-IS not to check the authentication information in the received packets.
To configure area authentication:
Step
Remarks
N/A
N/A
3.     Specify the area authentication mode and password.
area-authentication-mode { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } | md5 | simple } { cipher cipher-string | plain plain-string } [ ip | osi ]
By default, no area authentication is configured.
Routing domain authentication prevents untrusted routing information from entering into a routing domain. A router with the authentication configured encapsulates the password in the specified mode into Level-2 packets (LSP, CSNP, and PSNP) and check the password in received Level-2 packets.
All the routers in the backbone must have the same authentication mode and password.
To configure routing domain authentication:
Step
Remarks
N/A
N/A
3.     Specify the routing domain authentication mode and password.
domain-authentication-mode { gca key-id { hmac-sha-1 | hmac-sha-224 | hmac-sha-256 | hmac-sha-384 | hmac-sha-512 } | md5 | simple } { cipher cipher-string | plain plain-string } [ ip | osi ]
By default, no routing domain authentication is configured.
IMPORTANT
IMPORTANT:
IS-IS GR and IS-IS NSR are mutually exclusive. Do not configure them at the same time.
GR ensures forwarding continuity when a routing protocol restarts or an active/standby switchover occurs.
Two routers are required to complete a GR process. The following are router roles in a GR process.
·     GR restarter—Graceful restarting router. It must have GR capability.
·     GR helper—A neighbor of the GR restarter. It assists the GR restarter to complete the GR process. By default, the device acts as the GR helper.
Configure IS-IS GR on the GR restarter.
GR restarter uses the following timers:
·     T1 timer—Specifies the times that GR restarter can send a Restart TLV with the RR bit set. When rebooted, the GR restarter sends a Restart TLV with the RR bit set to its neighbor. If the GR restarter receives a Restart TLV with the RA set from its neighbor before the T1 timer expires, the GR process starts. Otherwise, the GR process fails.
·     T2 timer—Specifies the LSDB synchronization interval. Each LSDB has a T2 timer. The Level-1-2 router has a Level-1 timer and a Level-2 timer. If the LSDBs have not synchronized before the two timers expire, the GR process fails.
·     T3 timer—Specifies the GR interval. The GR interval is set as the holdtime in hello PDUs. Within the interval, the neighbors maintain their adjacency with the GR restarter. If the GR process has not completed within the holdtime, the neighbors tear down the neighbor relationship and the GR process fails.
To configure GR on the GR restarter:
Step
Remarks
N/A
2.     Enable IS-IS and enter IS-IS view.
N/A
3.     Enable IS-IS GR.
graceful-restart
By default, the GR capability for IS-IS is disabled.
4.     (Optional.) Suppress the SA bit during restart.
graceful-restart suppress-sa
By default, the SA bit is not suppressed.
By enabling the GR restarter to suppress the Suppress-Advertisement (SA) bit in the hello PDUs, the neighbors will still advertise their adjacency with the GR restarter.
5.     (Optional.) Configure the T1 timer.
graceful-restart t1 seconds count count
By default, the T1 timer is 3 seconds and can expire 10 times.
6.     (Optional.) Configure the T2 timer.
graceful-restart t2 seconds
By default, the T2 timer is 60 seconds.
7.     (Optional.) Configure the T3 timer.
graceful-restart t3 seconds
By default, the T2 timer is 300 seconds.
IMPORTANT
IMPORTANT:
IS-IS NSR and IS-IS GR are mutually exclusive. Do not configure them at the same time.
After an active/standby switchover, the GR restarter obtains routing information from its neighbors, and the IS-IS process must learn all the routes. If the network topology changes during the switchover, removed routes cannot be updated to the device, which can result in blackhole routes.
NSR solves the problem by backing up IS-IS link state information from the active process to the standby process. After an active/standby switchover, NSR can complete link state recovery and route regeneration without requiring the cooperation of other devices.
To configure IS-IS NSR:
Step
Remarks
N/A
N/A
3.     Enable IS-IS NSR.
non-stop-routing
By default, IS-IS NSR is disabled.
IS-IS NSR takes effect on a per-process basis. As a best practice, enable NSR for each IS-IS process.
BFD provides a single mechanism to quickly detect and monitor the connectivity of links between IS-IS neighbors, reducing network convergence time. For more information about BFD, see High Availability Configuration Guide.
To configure BFD for IS-IS:
Step
Remarks
N/A
N/A
3.     Enable IS-IS on an interface.
N/A
4.     Enable BFD on an IS-IS interface.
isis bfd enable
By default, an IS-IS interface is not enabled with BFD.
A link or router failure on a path can cause packet loss and routing loop. IS-IS FRR enables fast rerouting to minimize the failover time.
Figure 8 Network diagram for IS-IS FRR
In Figure 8, after you enable FRR on Router B, IS-IS automatically calculates or designates a backup next hop when a link failure is detected. In this way, packets are directed to the backup next hop to reduce traffic recovery time. Meanwhile, IS-IS calculates the shortest path based on the new network topology, and forwards packets over the path after network convergence.
You can either enable IS-IS FRR to calculate a backup next hop automatically, or designate a backup next hop with a routing policy for routes matching specific criteria.
Before you configure IS-IS FRR, complete the following tasks:
·     Enable IS-IS.
·     Do not use FRR and BFD at the same time. Otherwise, FRR might fail to take effect.
·     The automatic backup next hop calculation of FRR and that of TE are mutually exclusive.
Configuring IS-IS FRR to automatically calculate a backup next hop
To configuring IS-IS FRR to automatically calculate a backup next hop:
Step
Remarks
N/A
2.     Configure the source address of echo packets.
bfd echo-source-ip ip-address
By default, the source address of echo packets is not configured.
3.     Enter IS-IS view.
N/A
4.     Enable IS-IS FRR to automatically calculate a backup next hop.
fast-reroute auto
By default, IS-IS FRR is disabled.
Configuring IS-IS FRR using a routing policy
You can use the apply fast-reroute backup-interface command to specify a backup next hop in a routing policy for routes matching specific criteria. You can also perform this task to reference the routing policy for IS-IS FRR. For more information about the apply fast-reroute backup-interface command and routing policy configurations, see "Configuring routing policies."
To configure IS-IS FRR using a routing policy:
Step
Remarks
N/A
N/A
4.     Enable IS-IS FRR using a routing policy.
Configuring BFD for IS-IS FRR
By default, IS-IS FRR does not use BFD to detect primary link failures. To speed up IS-IS convergence, enable BFD single-hop echo detection for IS-IS FRR to detect primary link failures.
To configure BFD for IS-IS FRR:
Step
Remarks
N/A
2.     Configure the source IP address of BFD echo packets.
By default, the source IP address of BFD echo packets is not configured.
For more information, see High Availability Command Reference.
3.     Enter interface view.
N/A
4.     Enable BFD for IS-IS FRR.
isis primary-path-detect bfd echo
By default, BFD for IS-IS FRR is disabled.
Display brief IS-IS information (in standalone mode).
display isis brief [ process-id ] [ standby slot slot-number ]
Display brief IS-IS information (in IRF mode).
display isis brief [ process-id ] [ standby chassis chassis-number slot slot-number ]
Display IS-IS GR log information (in standalone mode).
display isis graceful-restart event-log slot slot-number
Display IS-IS GR log information (in IRF mode).
display isis graceful-restart event-log chassis chassis-number slot slot-number
Display the IS-IS GR status.
display isis graceful-restart status [ level-1 | level-2 ] [ process-id ]
Display IS-IS interface information (in standalone mode).
display isis interface [ [ interface-type interface-number ] [ verbose ] | statistics ] [ process-id ] [ standby slot slot-number ]
Display IS-IS interface information (in IRF mode).
display isis interface [ [ interface-type interface-number ] [ verbose ] | statistics ] [ process-id ] [ standby chassis chassis-number slot slot-number ]
Display IS-IS LSDB information (in standalone mode).
display isis lsdb [ [ level-1 | level-2 ] | local | [ lsp-id lspid | lsp-name lspname ] | verbose ] * [ process-id ] [ standby slot slot-number ]
Display IS-IS LSDB information (in IRF mode).
display isis lsdb [ [ level-1 | level-2 ] | local | [ lsp-id lspid | lsp-name lspname ] | verbose ] * [ process-id ] [ standby chassis chassis-number slot slot-number ]
Display IS-IS mesh group information.
display isis mesh-group [ process-id ]
Display the host name to system ID mapping table.
display isis name-table [ process-id ]
Display IS-IS NSR log information (in standalone mode).
display isis non-stop-routing event-log slot slot-number
Display IS-IS NSR log information (in IRF mode).
display isis non-stop-routing event-log chassis chassis-number slot slot-number
Display the IS-IS NSR status.
display isis non-stop-routing status
Display IS-IS neighbor information (in standalone mode).
display isis peer [ statistics | verbose ] [ process-id ] [ standby slot slot-number ]
Display IS-IS neighbor information (in IRF mode).
display isis peer [ statistics | verbose ] [ process-id ] [ standby chassis chassis-number slot slot-number ]
Display IS-IS redistributed route information.
display isis redistribute [ ipv4 [ ip-address mask-length ] ] [ level-1 | level-2 ] [ process-id ]
Display IS-IS IPv4 routing information.
display isis route [ ipv4 [ ip-address mask-length ] ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IS-IS IPv4 topology information.
display isis spf-tree [ ipv4 ] [ [ level-1 | level-2 ] | verbose ] * [ process-id ]
Display IS-IS statistics.
display isis statistics [ ipv4 ] [ level-1 | level-1-2 | level-2 ] [ process-id ]
Display OSI connection information (in standalone mode).
display osi [ slot slot-number ]
Display OSI connection information (in IRF mode).
display osi [ chassis chassis-number slot slot-number ]
Display OSI connection statistics (in standalone mode).
display osi statistics [ slot slot-number ]
Display OSI connection statistics (in IRF mode).
display osi statistics [ chassis chassis-number slot slot-number ]
Clear IS-IS process data structure information.
reset isis all [ process-id ] [ graceful-restart ]
Clear IS-IS GR log information (in standalone mode).
reset isis graceful-restart event-log slot slot-number
Clear IS-IS GR log information (in IRF mode).
reset isis graceful-restart event-log chassis chassis-number slot slot-number
Clear IS-IS NSR log information (in standalone mode).
reset isis non-stop-routing event-log slot slot-number
Clear IS-IS NSR log information (in IRF mode).
reset isis non-stop-routing event-log chassis chassis-number slot slot-number
Clear the data structure information of an IS-IS neighbor.
reset isis peer system-id [ process-id ]
Clear OSI connection statistics.
reset osi statistics
Network requirements
As shown in Figure 9, Switch A, Switch B, Switch C, and Switch D reside in an IS-IS AS.
Switch A and B are Level-1 switches, Switch D is a Level-2 switch, and Switch C is a Level-1-2 switch. Switch A, Switch B, and Switch C are in Area 10, and Switch D is in Area 20.
Figure 9 Network diagram
1.     Configure IP addresses for interfaces. (Details not shown.)
2.     Configure IS-IS:
# Configure Switch A.
[SwitchA] isis 1
[SwitchA-isis-1] is-level level-1
[SwitchA-isis-1] network-entity 10.0000.0000.0001.00
[SwitchA-isis-1] quit
[SwitchA-Vlan-interface100] isis enable 1
# Configure Switch B.
[SwitchB] isis 1
[SwitchB-isis-1] is-level level-1
[SwitchB-isis-1] network-entity 10.0000.0000.0002.00
[SwitchB-isis-1] quit
[SwitchB-Vlan-interface200] isis enable 1
# Configure Switch C.
[SwitchC] isis 1
[SwitchC-isis-1] network-entity 10.0000.0000.0003.00
[SwitchC-isis-1] quit
[SwitchC-Vlan-interface100] isis enable 1
[SwitchC-Vlan-interface200] isis enable 1
[SwitchC-Vlan-interface300] isis enable 1
[SwitchC-Vlan-interface300] quit
# Configure Switch D.
<SwitchD> system-view
[SwitchD] isis 1
[SwitchD-isis-1] is-level level-2
[SwitchD-isis-1] network-entity 20.0000.0000.0004.00
[SwitchD-isis-1] quit
[SwitchD] interface vlan-interface 100
[SwitchD-Vlan-interface100] isis enable 1
[SwitchD-Vlan-interface100] quit
[SwitchD] interface vlan-interface 300
[SwitchD-Vlan-interface300] isis enable 1
[SwitchD-Vlan-interface300] quit
# Display the IS-IS LSDB on each switch to verify the LSPs.
[SwitchA] display isis lsdb
                       Database information for IS-IS(1)
                          Level-1 Link State Database
LSPID                 Seq Num      Checksum   Holdtime   Length  ATT/P/OL
0000.0000.0001.00-00* 0x00000004   0xdf5e     1096       68      0/0/0
0000.0000.0002.00-00  0x00000004   0xee4d     1102       68      0/0/0
0000.0000.0002.01-00  0x00000001   0xdaaf     1102       55      0/0/0
0000.0000.0003.00-00  0x00000009   0xcaa3     1161       111     1/0/0
0000.0000.0003.01-00  0x00000001   0xadda     1112       55      0/0/0
[SwitchB] display isis lsdb
0000.0000.0001.00-00  0x00000006   0xdb60     988         68      0/0/0
0000.0000.0002.00-00* 0x00000008   0xe651     1189        68      0/0/0
0000.0000.0002.01-00* 0x00000005   0xd2b3     1188        55      0/0/0
0000.0000.0003.00-00  0x00000014   0x194a     1190        111     1/0/0
0000.0000.0003.01-00  0x00000002   0xabdb     995         55      0/0/0
[SwitchC] display isis lsdb
0000.0000.0001.00-00  0x00000006   0xdb60     847         68      0/0/0
0000.0000.0002.00-00  0x00000008   0xe651     1053        68      0/0/0
0000.0000.0002.01-00  0x00000005   0xd2b3     1052        55      0/0/0
0000.0000.0003.00-00* 0x00000014   0x194a     1051        111     1/0/0
0000.0000.0003.01-00* 0x00000002   0xabdb     854         55      0/0/0
                          Level-2 Link State Database
0000.0000.0003.00-00* 0x00000012   0xc93c     842         100     0/0/0
0000.0000.0004.00-00  0x00000026   0x331      1173        84      0/0/0
0000.0000.0004.01-00  0x00000001   0xee95     668         55      0/0/0
[SwitchD] display isis lsdb
0000.0000.0003.00-00  0x00000013   0xc73d        1003          100     0/0/0
0000.0000.0004.00-00* 0x0000003c   0xd647        1194          84      0/0/0
0000.0000.0004.01-00* 0x00000002   0xec96        1007          55      0/0/0
# Display the IS-IS routing information on each switch.
[SwitchA] display isis route
                         Level-1 IPv4 Forwarding Table
 IPv4 Destination     IntCost    ExtCost ExitInterface   NextHop         Flags
 10.1.1.0/24          10         NULL    Vlan100         Direct          D/L/-
 10.1.2.0/24          20         NULL    Vlan100         10.1.1.1        R/-/-
 192.168.0.0/24       20         NULL    Vlan100         10.1.1.1        R/-/-
 0.0.0.0/0            10         NULL    Vlan100         10.1.1.1        R/-/-
[SwitchC] display isis route
 192.168.0.0/24       10         NULL    Vlan300         Direct          D/L/-
 10.1.2.0/24          10         NULL    Vlan200         Direct          D/L/-
                         Level-2 IPv4 Forwarding Table
 192.168.0.0/24       10         NULL                                    D/L/-
 10.1.1.0/24          10         NULL                                    D/L/-
 10.1.2.0/24          10         NULL                                    D/L/-
 172.16.0.0/16        20         NULL    Vlan300         192.168.0.2     R/-/-
[SwitchD] display isis route
 10.1.1.0/24          20         NULL    Vlan300         192.168.0.1     R/-/-
 10.1.2.0/24          20         NULL    Vlan300         192.168.0.1     R/-/-
 172.16.0.0/16        10         NULL    Vlan100         Direct          D/L/-
The output shows that the routing table of Level-1 switches contains a default route with the next hop as the Level-1-2 switch. The routing table of Level-2 switch contains both routing information of Level-1 and Level-2.
DIS election configuration example
As shown in Figure 10, Switches A, B, C, and D reside in IS-IS area 10 on a broadcast network (Ethernet). Switch A and Switch B are Level-1-2 switches, Switch C is a Level-1 switch, and Switch D is a Level-2 switch.
Change the DIS priority of Switch A to make it elected as the Level-1-2 DIS router.
Figure 10 Network diagram
Configuration procedure
2.     Enable IS-IS:
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchB-Vlan-interface100] isis enable 1
[SwitchC] isis 1
[SwitchC-isis-1] is-level level-1
[SwitchD] isis 1
[SwitchD-isis-1] network-entity 10.0000.0000.0004.00
# Display information about IS-IS neighbors on Switch A.
[SwitchA] display isis peer
                          Peer information for IS-IS(1)
  System Id: 0000.0000.0002
  Interface: Vlan-interface100       Circuit Id: 0000.0000.0003.01
  State: Up     HoldTime: 21s        Type: L1(L1L2)     PRI: 64
  System Id: 0000.0000.0003
  State: Up     HoldTime: 27s        Type: L1           PRI: 64
  Interface: Vlan-interface100       Circuit Id: 0000.0000.0004.01
  State: Up     HoldTime: 28s        Type: L2(L1L2)     PRI: 64
  System Id: 0000.0000.0004
  State: Up     HoldTime: 30s        Type: L2          PRI: 64
# Display information about IS-IS interfaces on Switch A.
[SwitchA] display isis interface
  Index     IPv4.State      IPv6.State     CircuitID   MTU   Type   DIS
  00001     Up              Down           1           1497  L1/L2  No/No
# Display information about IS-IS interfaces on Switch C.
[SwitchC] display isis interface
  00001     Up              Down           1           1497  L1/L2  Yes/No
# Display information about IS-IS interfaces on Switch D.
[SwitchD] display isis interface
  00001     Up              Down           1           1497  L1/L2  No/Yes
The output shows that when the default DIS priority is used, Switch C is the DIS for Level-1, and Switch D is the DIS for Level-2. The pseudonodes of Level-1 and Level-2 are 0000.0000.0003.01 and 0000.0000.0004.01.
#Configure the DIS priority of Switch A.
[SwitchA-Vlan-interface100] isis dis-priority 100
# Display IS-IS neighbors on Switch A.
  Interface: Vlan-interface100       Circuit Id: 0000.0000.0001.01
  00001     Up              Down           1           1497  L1/L2  Yes/Yes
The output shows that after the DIS priority configuration, Switch A becomes the DIS for Level-1-2, and the pseudonode is 0000.0000.0001.01.
# Display information about IS-IS neighbors and interfaces on Switch C.
[SwitchC] display isis peer
  State: Up     HoldTime: 25s        Type: L1           PRI: 64
  System Id: 0000.0000.0001
  State: Up     HoldTime: 7s         Type: L1           PRI: 100
# Display information about IS-IS neighbors and interfaces on Switch D.
[SwitchD] display isis peer
  State: Up     HoldTime: 9s         Type: L2           PRI: 100
  State: Up     HoldTime: 28s        Type: L2           PRI: 64
IS-IS route redistribution configuration example
As shown in Figure 11, Switch A, Switch B, Switch C, and Switch D reside in the same AS. They use IS-IS to interconnect. Switch A and Switch B are Level-1 routers, Switch D is a Level-2 router, and Switch C is a Level-1-2 router.
Redistribute RIP routes into IS-IS on Switch D.
Figure 11 Network diagram
2.     Configure basic IS-IS:
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchC] isis 1
[SwitchD] isis 1
[SwitchD] interface interface vlan-interface 300
# Display IS-IS routing information on each switch.
 10.1.1.0/24          10         NULL    VLAN100         Direct          D/L/-
 10.1.2.0/24          20         NULL    VLAN100         10.1.1.1        R/-/-
 192.168.0.0/24       20         NULL    VLAN100         10.1.1.1        R/-/-
 0.0.0.0/0            10         NULL    VLAN100         10.1.1.1        R/-/-
 10.1.2.0/24          10         NULL    VLAN200         Direct          D/L/-
 192.168.0.0/24       10         NULL    VLAN300         Direct          D/L/-
 10.1.1.0/24          20         NULL    VLAN300         192.168.0.1     R/-/-
 10.1.2.0/24          20         NULL    VLAN300         192.168.0.1     R/-/-
3.     Run RIPv2 between Switch D and Switch E, and configure IS-IS to redistribute RIP routes on Switch D:
# Configure RIPv2 on Switch D.
[SwitchD] rip 1
[SwitchD-rip-1] network 10.0.0.0
[SwitchD-rip-1] version 2
[SwitchD-rip-1] undo summary
# Configure RIPv2 on Switch E.
[SwitchE] rip 1
[SwitchE-rip-1] network 10.0.0.0
[SwitchE-rip-1] version 2
[SwitchE-rip-1] undo summary
# Configure IS-IS to redistribute RIP routes on Switch D.
[SwitchD-rip-1] quit
[SwitchD] isis 1
[SwitchD–isis-1] import-route rip level-2
# Display IS-IS routing information on Switch C.
 10.1.4.0/24          10         NULL    VLAN300         192.168.0.2     R/L/-
 10.1.5.0/24          20         NULL    VLAN300         192.168.0.2     R/L/-
 10.1.6.0/24          20         NULL    VLAN300         192.168.0.2     R/L/-
IS-IS authentication configuration example
As shown in Figure 12, Switch A, Switch B, Switch C, and Switch D reside in the same IS-IS routing domain. Run IS-IS among them.
Switch A, Switch B, and Switch C belong to Area 10, and Switch D belongs to Area 20.
·     Configure neighbor relationship authentication between neighbors.
·     Configure area authentication in Area 10 to prevent untrusted routes from entering into the area.
·     Configure routing domain authentication on Switch C and Switch D to prevent untrusted routes from entering the routing domain.
Figure 12 Network diagram
[SwitchA] isis 1
[SwitchB] isis 1
[SwitchC] isis 1
[SwitchD] isis 1
[SwitchD-isis-1] network-entity 20.0000.0000.0001.00
3.     Configure neighbor relationship authentication between neighbors:
# Configure the authentication mode as MD5 and set the plaintext password to eRq on VLAN-interface 100 of Switch A and on VLAN-interface 100 of Switch C.
[SwitchA-Vlan-interface100] isis authentication-mode md5 plain eRg
[SwitchC-Vlan-interface100] isis authentication-mode md5 plain eRg
# Configure the authentication mode as MD5 and set the plaintext password to t5Hr on VLAN-interface 200 of Switch B and on VLAN-interface 200 of Switch C.
[SwitchB-Vlan-interface200] isis authentication-mode md5 plain t5Hr
[SwitchC-Vlan-interface200] isis authentication-mode md5 plain t5Hr
# Configure the authentication mode as MD5 and set the plaintext password to hSec on VLAN-interface 300 of Switch D and on VLAN-interface 300 of Switch C.
[SwitchC-Vlan-interface300] isis authentication-mode md5 plain hSec
[SwitchD-Vlan-interface300] isis authentication-mode md5 plain hSec
4.     Configure the area authentication mode as MD5 and set the plaintext password to 10Sec on Switch A, Switch B, and Switch C.
[SwitchA] isis 1
[SwitchA-isis-1] area-authentication-mode md5 plain 10Sec
[SwitchB] isis 1
[SwitchB-isis-1] area-authentication-mode md5 plain 10Sec
[SwitchC] isis 1
[SwitchC-isis-1] area-authentication-mode md5 plain 10Sec
5.     Configure routing domain authentication mode as MD5 and set the plaintext password to 1020Sec on Switch C and Switch D.
[SwitchC] isis 1
[SwitchC-isis-1] domain-authentication-mode md5 plain 1020Sec
[SwitchD] isis 1
[SwitchD-isis-1] domain-authentication-mode md5 plain 1020Sec
IS-IS GR configuration example
As shown in Figure 13, Switch A, Switch B, and Switch C belong to the same IS-IS routing domain.
Figure 13 Network diagram
1.     Configure IP addresses and subnet masks for interfaces. (Details not shown.)
2.     Configure IS-IS on the switches to make sure Switch A, Switch B, and Switch C can communicate with each other at layer 3 and dynamic route update can be implemented among them with IS-IS. (Details not shown.)
3.     Enable IS-IS GR on Switch A.
[SwitchA] isis 1
[SwitchA-isis-1] graceful-restart
[SwitchA-isis-1] return
# Restart the IS-IS process on Switch A.
<SwitchA> reset isis all 1 graceful-restart
Reset IS-IS process? [Y/N]:y
# Display the IS-IS GR status on Switch A.
<SwitchA> display isis graceful-restart status
Restart status: COMPLETE
Restart phase: Finish
SA Bit: supported
                          Level-1 restart information
Total number of interfaces: 1
Number of waiting LSPs: 0
                          Level-2 restart information
IS-IS NSR configuration example
As shown in Figure 14, Switch S, Switch A, and Switch B belong to the same IS-IS routing domain.
·     Run IS-IS on all the switches to interconnect them with each other.
·     Enable IS-IS NSR on Switch S to ensure forwarding continuity between Switch A and Switch B when an active/standby switchover occurs on Switch S.
Figure 14 Network diagram
1.     Configure the IP addresses and subnet masks for interfaces on the switches. (Details not shown.)
2.     Configure IS-IS on the switches to make sure Switch S, Switch A, and Switch B can communicate with each other at Layer 3 and dynamic route update can be implemented among them with IS-IS. (Details not shown.)
3.     Enable IS-IS NSR on Switch S.
<SwitchS> system-view
[SwitchS] isis 1
[SwitchS-isis-1] non-stop-routing
[SwitchS-isis-1] return
# Reoptimize process placement on Switch S to trigger an active/standby switchover.
[SwitchS] placement reoptimize
Program                           Current location       New location
syslog                            0/0                    0/0
diagusageratio                    0/0                    0/0
l3vpn                             0/0                    0/0
fc                                0/0                    0/0
dns                               0/0                    0/0
lauth                             0/0                    0/0
aaa                               0/0                    0/0
lsm                               0/0                    0/0
rm                                0/0                    0/0
rm6                               0/0                    0/0
track                             0/0                    0/0
ip6addr                           0/0                    0/0
ipaddr                            0/0                    0/0
rpm                               0/0                    0/0
trange                            0/0                    0/0
tunnel                            0/0                    0/0
lagg                              0/0                    0/0
bfd                               0/0                    0/0
acl                               0/0                    0/0
slsp                              0/0                    0/0
usr6                              0/0                    0/0
usr                               0/0                    0/0
qos                               0/0                    0/0
fczone                            0/0                    0/0
ethbase                           0/0                    0/0
ipcim                             0/0                    0/0
ip6base                           0/0                    0/0
ipbase                            0/0                    0/0
eth                               0/0                    0/0
eviisis                           0/0                    0/0
ifnet                             NA                     NA
isis                              0/0                    1/0
Continue? [y/n]:y
Re-optimization of the placement start. You will be notified on completion
Re-optimization of the placement complete. Use 'display placement' to view the new placement
# During the switchover period, display IS-IS neighbor information on Switch A to verify the neighborship between Switch A and Switch S.
<SwitchA> display isis peer
 Interface: vlan100                 Circuit Id: 0000.0000.0001.01
 State: Up     HoldTime:  25s       Type: L1(L1L2)     PRI: 64
 State: Up     HoldTime:  27s       Type: L2(L1L2)     PRI: 64
# Display IS-IS routing information on Switch A to verify that Switch A has a route to the loopback interface of Switch B.
<SwitchA> display isis route
 12.12.12.0/24        10         NULL    vlan100         Direct          D/L/-
 22.22.22.22/32       10         NULL    Loop0           Direct          D/-/-
 14.14.14.0/32        10         NULL    vlan100         12.12.12.2      R/L/-
 44.44.44.44/32       10         NULL    vlan100         12.12.12.2      R/L/-
# Display IS-IS neighbor information on Switch B to verify the neighborship between Switch B and Switch S.
<SwitchB> display isis peer
 Interface: vlan200                 Circuit Id: 0000.0000.0001.01
# Display IS-IS routing information on Switch B to verify that Switch B has a route to the loopback interface of Switch A.
<SwitchB> display isis route
 14.14.14.0/24        10         NULL    vlan200         Direct          D/L/-
 44.44.44.44/32       10         NULL    Loop0           Direct          D/-/-
 12.12.12.0/32        10         NULL    vlan200         14.14.14.4      R/L/-
 22.22.22.22/32       10         NULL    vlan20       14.14.14.4      R/L/-
The output shows that the neighbor information and routing information on Switch A and Switch B have not changed during the active/standby switchover on Switch S. The neighbors are unaware of the switchover.
BFD for IS-IS configuration example
·     As shown in Figure 15, run IS-IS on Switch A, Switch B and Switch C so that can reach each other at the network layer.
·     After the link over which Switch A and Switch B communicate through the Layer-2 switch fails, BFD can quickly detect the failure and notify IS-IS of the failure. Switch A and Switch B then communicate through Switch C.
Figure 15 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int10
10.1.0.102/24
Switch B
Vlan-int10
10.1.0.100/24
Vlan-int11
11.1.1.1/24
Vlan-int13
13.1.1.1/24
Loop0
121.1.1.1/32
Loop0
120.1.1.1/32
Switch C
Vlan-int11
11.1.1.2/24
Vlan-int13
13.1.1.2/24
[SwitchA] isis
[SwitchA-LoopBack0] isis enable
[SwitchA-LoopBack0] quit
[SwitchA-Vlan-interface10] isis enable
[SwitchA-Vlan-interface11] isis enable
[SwitchB] isis
[SwitchB-LoopBack0] isis enable
[SwitchB-LoopBack0] quit
[SwitchB-Vlan-interface10] isis enable
[SwitchB] interface vlan-interface 13
[SwitchB-Vlan-interface13] isis enable
[SwitchB-Vlan-interface13] quit
[SwitchC] isis
[SwitchC] interface vlan-interface 11
[SwitchC-Vlan-interface11] isis enable
[SwitchC-Vlan-interface11] quit
[SwitchC] interface vlan-interface 13
[SwitchC-Vlan-interface13] isis enable
[SwitchC-Vlan-interface13] quit
3.     Configure BFD functions:
# Enable BFD and configure BFD parameters on Switch A.
[SwitchA] bfd session init-mode passive
[SwitchA-Vlan-interface10] isis bfd enable
[SwitchA-Vlan-interface10] bfd min-receive-interval 500
[SwitchA-Vlan-interface10] bfd min-transmit-interval 500
[SwitchA-Vlan-interface10] bfd detect-multiplier 7
# Enable BFD and configure BFD parameters on Switch B.
[SwitchB] bfd session init-mode active
[SwitchB-Vlan-interface10] isis bfd enable
[SwitchB-Vlan-interface10] bfd min-receive-interval 500
[SwitchB-Vlan-interface10] bfd min-transmit-interval 500
[SwitchB-Vlan-interface10] bfd detect-multiplier 8
[SwitchB-Vlan-interface10] return
# Display the BFD session information on Switch A.
<SwitchA> display bfd session
 LD/RD          SourceAddr      DestAddr        State    Holdtime    Interface
 3/1            192.168.0.102   192.168.0.100   Up       1700ms      Vlan10
# Display routes destined for 120.1.1.0/24 on Switch A.
<SwitchA> display ip routing-table 120.1.1.0 verbose
Summary Count : 1
Destination: 120.1.1.0/24
   Protocol: ISIS             Process ID: 1
  SubProtID: 0x1                     Age: 04h20m37s
       Cost: 10               Preference: 10
        Tag: 0                     State: Active Adv
  OrigTblID: 0x0                 OrigVrf: default-vrf
    TableID: 0x2                  OrigAs: 0
      NibID: 0x26000002           LastAs: 0
     AttrID: 0xffffffff         Neighbor: 0.0.0.0
      Flags: 0x1008c         OrigNextHop: 192.168.0.100
      Label: NULL            RealNextHop: 192.168.0.100
    BkLabel: NULL              BkNextHop: N/A
  Tunnel ID: Invalid           Interface: Vlan-interface10
BkTunnel ID: Invalid         BkInterface: N/A
The output shows that Switch A and Switch B communicate through VLAN-interface 10. Then the link over VLAN-interface 10 fails.
Summary Count : 1
       Cost: 20               Preference: 10
      Flags: 0x1008c         OrigNextHop: 10.1.1.100
      Label: NULL            RealNextHop: 10.1.1.100
  Tunnel ID: Invalid           Interface: Vlan-interface11
The output shows that Switch A and Switch B communicate through VLAN-interface 11.
IS-IS FRR configuration example
As shown in Figure 16, Switch A, Switch B, and Switch C belong to the same IS-IS routing domain. Configure IS-IS FRR so that when the Link A fails, traffic can be switched to Link B immediately.
Figure 16 Network diagram
Device
IP address
Device
IP address
Switch A
Vlan-int100
12.12.12.1/24
Switch B
Vlan-int101
24.24.24.4/24
Vlan-int200
13.13.13.1/24
Vlan-int200
13.13.13.2/24
Loop0
1.1.1.1/32
Loop0
4.4.4.4/32
Switch C
Vlan-int100
12.12.12.2/24
Vlan-int101
24.24.24.2/24
1.     Configure IP addresses and subnet masks for interfaces on the switches. (Details not shown.)
2.     Configure IS-IS on the switches to make sure Switch A, Switch B, and Switch C can communicate with each other at Layer 3. (Details not shown.)
3.     Configure IS-IS FRR:
Enable IS-IS FRR to automatically calculate a backup next hop, or designate a backup next hop by using a referenced routing policy.
¡     (Method 1.) Enable IS-IS FRR to automatically calculate a backup next hop:
[SwitchA] isis 1
[SwitchA-isis-1] fast-reroute auto
[SwitchB] isis 1
[SwitchB-isis-1] fast-reroute auto
¡     (Method 2.) Enable IS-IS FRR to designate a backup next hop by using a referenced routing policy:
[SwitchA-route-policy-frr-10] if-match ip address prefix-list abc
[SwitchA-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface 100 backup-nexthop 12.12.12.2
[SwitchA] isis 1
[SwitchA-isis-1] fast-reroute route-policy frr
[SwitchB] ip prefix-list abc index 10 permit 1.1.1.1 32
[SwitchB-route-policy-frr-10] if-match ip address prefix-list abc
[SwitchB-route-policy-frr-10] apply fast-reroute backup-interface vlan-interface 101 backup-nexthop 24.24.24.2
[SwitchB] isis 1
[SwitchB-isis-1] fast-reroute route-policy frr
# Display route 4.4.4.4/32 on Switch A to view the backup next hop information.
[SwitchA] display ip routing-table 4.4.4.4 verbose
Summary Count : 1
Destination: 4.4.4.4/32
      Flags: 0x1008c         OrigNextHop: 13.13.13.2
      Label: NULL            RealNextHop: 13.13.13.2
    BkLabel: NULL              BkNextHop: 12.12.12.2
  Tunnel ID: Invalid           Interface: Vlan-interface200
BkTunnel ID: Invalid         BkInterface: Vlan-interface100
# Display route 1.1.1.1/32 on Switch B to view the backup next hop information.
[SwitchB] display ip routing-table 1.1.1.1 verbose
Summary Count : 1
Destination: 1.1.1.1/32
      Flags: 0x1008c         OrigNextHop: 13.13.13.1
      Label: NULL            RealNextHop: 13.13.13.1
    BkLabel: NULL              BkNextHop: 24.24.24.2
BkTunnel ID: Invalid         BkInterface: Vlan-interface101
