02-Virtual Technologies Configuration Guide
HomeSupportSwitchesS7500E SeriesConfigure & DeployConfiguration GuidesH3C S7500E Switch Series Configuration Guides-Release7178-6W10002-Virtual Technologies Configuration Guide
01-IRF configuration
01-IRF configuration 1000.4 KB
Setting up an IRF fabric· 1
Overview· 1
Network topology· 3
Basic concepts· 3
Configuration synchronization· 6
Master election· 6
Multi-active handling procedure· 7
MAD mechanisms· 8
General restrictions and configuration guidelines· 13
IRF fabric size· 13
Hardware compatibility· 14
Software requirements· 14
MPU requirements· 14
OAP module requirements· 14
IRF physical interface requirements· 14
Connecting IRF ports· 15
Feature compatibility and configuration restrictions· 16
Licensing requirements· 16
Configuration backup· 17
Setup and configuration task list 17
Planning the IRF fabric setup· 17
Preconfiguring IRF member devices in standalone mode· 18
Assigning a member ID to each IRF member device· 18
Specifying a priority for each member device· 18
Binding physical interfaces to IRF ports· 18
Saving configuration to the next-startup configuration file· 19
Connecting IRF physical interfaces· 19
Setting the operating mode to IRF mode· 20
Accessing the IRF fabric· 21
Configuring IRF member devices in IRF mode· 21
Changing the member ID of a device· 21
Changing the priority of a member device· 22
Adding physical interfaces to an IRF port 22
Enabling IRF auto-merge· 24
Configuring a member device description· 25
Configuring IRF link load sharing mode· 25
Configuring IRF bridge MAC persistence· 26
Enabling software auto-update for software image synchronization· 27
Setting the IRF link down report delay· 28
Isolating an unused IRF member ID· 28
Configuring MAD· 29
Recovering an IRF fabric· 37
Displaying and maintaining an IRF fabric· 38
Configuration examples· 39
LACP MAD-enabled IRF configuration example for a two-chassis IRF fabric· 39
BFD MAD-enabled IRF configuration example for a two-chassis IRF fabric· 41
ARP MAD-enabled IRF configuration example for a two-chassis IRF fabric· 44
ND MAD-enabled IRF configuration example for a two-chassis IRF fabric· 46
Configuration example for restoring standalone mode· 49
Four-chassis IRF fabric configuration example· 51
Setting up an IRF 3 system·· 56
Overview· 56
Network topology· 58
Basic concepts· 60
IRF 3 operating mechanisms· 62
IRF fabric split handling· 63
Hardware compatibility· 64
Configuration restrictions and guidelines· 64
Parent fabric size restrictions· 64
PEX physical interface requirements· 64
PEX cabling for one tier of PEXs· 66
PEX cabling for PEX stack· 66
IRF member ID restrictions· 67
sFlow compatibility· 67
Cross-PEX link aggregation· 67
Feature availability of PEXs· 67
IRF 3 system setup and configuration task list 67
Planning the IRF 3 system setup· 68
Setting up the parent fabric· 68
Enabling IRF 3 capability on the parent device· 69
Configuring IRF 3 settings on the parent fabric for PEXs· 70
Creating PEX ports· 70
Assigning virtual chassis numbers to one tier of PEXs· 70
Assigning virtual chassis numbers to a PEX stack· 70
Creating a PEX port group and assigning the PEX ports of a PEX stack to the group· 71
Assigning physical interfaces to PEX ports· 71
Configuring PEX link load sharing mode· 72
Specifying startup software images for PEXs· 74
Connecting the PEXs to the parent fabric· 74
Removing PEXs from an IRF 3 system·· 74
Displaying and maintaining PEXs· 76
IRF 3 system configuration examples· 76
IRF 3 system with one tier of PEXs configuration example· 76
IRF 3 system with a PEX stack configuration example· 83
Overview
H3C Intelligent Resilient Framework (IRF) technology virtualizes multiple physical devices at the same layer into one virtual fabric to provide data center class availability and scalability. IRF virtualization technology offers processing power, interaction, unified management, and uninterrupted maintenance of multiple devices.
Figure 1 shows an IRF fabric that has two member devices, which appear as a single node to the upper-layer and lower-layer devices.
Figure 1 IRF application scenario
IRF provides the following benefits:
·     Simplified topology and easy management—An IRF fabric appears as one node and is accessible at a single IP address on the network. You can use this IP address to log in at any member device to manage all the members of the IRF fabric. In addition, you do not need to run the spanning tree feature among the IRF members.
·     1:N redundancy—In an IRF fabric, one member acts as the master to manage and control the entire IRF fabric. All the other members process services while backing up the master. When the master fails, all the other member devices elect a new master from among them to take over without interrupting services.
·     IRF link aggregation—You can assign several physical links between neighboring members to their IRF ports to create a load-balanced aggregate IRF connection with redundancy.
·     Multichassis link aggregation—You can use the Ethernet link aggregation feature to aggregate the physical links between the IRF fabric and its upstream or downstream devices across the IRF members.
·     Network scalability and resiliency—Processing capacity of an IRF fabric equals the total processing capacities of all the members. You can increase ports, network bandwidth, and processing capacity of an IRF fabric simply by adding member devices without changing the network topology.
As shown in Figure 2, Device A and Device B form a two-chassis IRF fabric. The fabric has four MPUs (one active and three standbys), and two times the number of interface cards that a single device provides. The IRF fabric manages the physical and software resources of Device A and Device B in a centralized manner.
Figure 2 Two-chassis IRF fabric implementation schematic diagram
You can scale this two-chassis IRF fabric to a four-chassis IRF fabric for higher port density and availability, as shown in Figure 3.
Figure 3 Four-chassis IRF fabric implementation schematic diagram
Network topology
The device supports daisy-chain or ring topology for IRF fabrics. IRF does not support the full mesh topology. For information about connecting IRF member devices, see "Connecting IRF physical interfaces."
Basic concepts
Operating mode
The device operates in one of the following modes:
·     Standalone mode—The device cannot form an IRF fabric with other devices.
·     IRF mode—The device can form an IRF fabric with other devices.
IRF member roles
IRF uses two member roles: master and standby (called subordinate throughout the documentation).
When devices form an IRF fabric, they elect a master to manage and control the IRF fabric, and all the other devices back up the master. When the master device fails, the other devices elect a new master automatically. For more information about master election, see "Master election."
IRF member ID
An IRF fabric uses member IDs to uniquely identify and manage its members. This member ID information is included as the first part of interface numbers and file paths to uniquely identify interfaces and files in an IRF fabric. Two devices cannot form an IRF fabric if they use the same member ID. A device cannot join an IRF fabric if its member ID has been used in the fabric.
For example, after you assign a device with a member ID of 2 to an IRF fabric, the name of interface GigabitEthernet 3/0/1 changes to GigabitEthernet 2/3/0/1. The file path changes from slot1#flash:/test.cfg to chassis2#slot1#flash:/test.cfg.
By default, the standby MPU of a device is automatically assigned the same ID as the active MPU.
MPU roles
Each IRF member device has one or two MPUs. The following are MPU roles:
Role
Master MPU
Active MPU of the master device. It is also called the global active MPU. You configure and manage the entire IRF fabric at the CLI of the global active MPU.
Active MPU
Active MPU on each member device. An active MPU performs the following operations:
·     Manages the local device, including synchronizing configuration with the local standby MPU, processing protocol packets, and creating and maintaining route entries.
·     Processes IRF-related events, such as master election and topology collection.
Standby MPU
For the master MPU, all other MPUs are standby MPUs, including active MPUs on subordinate devices.
If a member device has two MPUs, the MPU backing up the local active MPU is the local standby MPU from the perspective of the member device.
IRF port
An IRF port is a logical interface that connects IRF member devices. Every IRF-capable device has two IRF ports.
In standalone mode, the IRF ports are named IRF-port 1 and IRF-port 2.
In IRF mode, the IRF ports are named IRF-port n/1 and IRF-port n/2, where n is the member ID of the device. The two IRF ports are referred to as IRF-port 1 and IRF-port 2 in this book.
To use an IRF port, you must bind a minimum of one physical interface to it. The physical interfaces assigned to an IRF port automatically form an aggregate IRF link. An IRF port goes down when all its IRF physical interfaces are down.
IRF physical interfaces connect IRF member devices and must be bound to an IRF port. They forward traffic between member devices, including IRF protocol packets and data packets that must travel across IRF member devices.
For more information about physical interfaces that can be used for IRF links, see "IRF physical interface requirements."
MAD
An IRF link failure causes an IRF fabric to split in two IRF fabrics operating with the same Layer 3 configurations, including the same IP address. To avoid IP address collision and network problems, IRF uses multi-active detection (MAD) mechanisms to detect the presence of multiple identical IRF fabrics, handle collisions, and recover from faults.
IRF domain ID
One IRF fabric forms one IRF domain. IRF uses IRF domain IDs to uniquely identify IRF fabrics and prevent IRF fabrics from interfering with one another.
As shown in Figure 4, IRF fabric 1 contains Device A and Device B, and IRF fabric 2 contains Device C and Device D. Both fabrics use the LACP aggregate links between them for MAD. When a member device receives an extended LACPDU for MAD, it checks the domain ID to see whether the packet is from the local IRF fabric. Then, the device can handle the packet correctly.
Figure 4 A network that contains two IRF domains
IRF split
IRF split occurs when an IRF fabric breaks up into multiple IRF fabrics because of IRF link failures, as shown in Figure 5. The split IRF fabrics operate with the same IP address. IRF split causes routing and forwarding problems on the network. To quickly detect a multi-active collision, configure a minimum of one MAD mechanism (see "Configuring MAD").
Figure 5 IRF split
IRF merge
IRF merge occurs when two split IRF fabrics reunite or when two independent IRF fabrics are united, as shown in Figure 6.
Figure 6 IRF merge
Member priority
Member priority determines the possibility of a member device to be elected the master. A member with higher priority is more likely to be elected the master.
IRF uses a strict running-configuration synchronization mechanism. In an IRF fabric, all devices obtain and run the running configuration of the master. Any configuration changes are automatically propagated from the master to the remaining devices. The configuration files of these devices are retained, but the files do not take effect. The devices use their own startup configuration files only after they are removed from the IRF fabric.
For more information about configuration management, see Fundamentals Configuration Guide.
Master election
Master election occurs each time the IRF fabric topology changes in the following situations:
·     The IRF fabric is established.
·     The master device fails or is removed.
·     The IRF fabric splits.
·     Independent IRF fabrics merge.
Master election does not occur when two split IRF fabrics merge.
Master election selects a master in descending order:
1.     Current master, even if a new member has higher priority.
When an IRF fabric is being formed, all members consider themselves as the master. This rule is skipped.
2.     Member with higher priority.
3.     Member with the longest system uptime.
Two members are considered to start up at the same time if the difference between their startup times is equal to or less than 10 minutes. For these members, the next tiebreaker applies.
4.     Member with the lowest CPU MAC address.
For the setup of a new IRF fabric, the subordinate devices must reboot to complete the setup after the master election.
For an IRF merge, devices must reboot if they are in the IRF fabric that fails the master election. The reboot can be performed automatically or manually.
The multi-active handling procedure includes detection, collision handling, and failure recovery.
Detection
MAD identifies each IRF fabric with a domain ID and an active ID (the member ID of the master). If multiple active IDs are detected in a domain, MAD determines that an IRF collision or split has occurred.
For more information about the MAD mechanisms and their application scenarios, see "MAD mechanisms."
Collision handling
When MAD detects a multi-active collision, it sets all IRF fabrics except one to the Recovery state. The fabric that is not placed in Recovery state can continue to forward traffic. The Recovery-state IRF fabrics are inactive and cannot forward traffic.
LACP MAD uses the following process to handle a multi-active collision:
1.     Compares the number of members in each fabric.
2.     Sets all fabrics to the Recovery state except the one that has the most members.
3.     Compares the member IDs of their masters if all IRF fabrics have the same number of members.
4.     Sets all fabrics to the Recovery state except the one that has the lowest numbered master.
5.     Shuts down all physical network ports in the Recovery-state fabrics except for the following ports:
¡     IRF physical interfaces.
¡     Ports you have specified with the mad exclude interface command.
In contrast, BFD MAD, ARP MAD, and ND MAD do not compare the number of members in fabrics. These MAD mechanisms use the following process to handle a multi-active collision:
1.     Compare the member IDs of the masters in the IRF fabrics.
2.     Set all fabrics to the Recovery state except the one that has the lowest numbered master.
3.     Take the same action on the network ports in Recovery-state fabrics as LACP MAD.
Failure recovery
To merge two split IRF fabrics, first repair the failed IRF link and remove the IRF link failure.
·     If the IRF fabric in Recovery state fails before the failure is recovered, repair the failed IRF fabric and the failed IRF link.
·     If the active IRF fabric fails before the failure is recovered, enable the inactive IRF fabric to take over the active IRF fabric. Then, recover the MAD failure.
MAD mechanisms
IRF provides MAD mechanisms by extending LACP, BFD, ARP, and IPv6 ND. You can configure ARP MAD and ND MAD together in an IRF fabric for prompt IRF split detection.
IMPORTANT
IMPORTANT:
·     Do not configure LACP MAD together with BFD MAD, ARP MAD, or ND MAD, because they handle collisions differently.
·     Do not configure BFD MAD together with ARP MAD or ND MAD. BFD MAD is exclusive with the spanning tree feature, but ARP MAD and ND MAD require the spanning tree feature.
Table 1 compares the MAD mechanisms and their application scenarios.
Table 1 Comparison of MAD mechanisms
MAD mechanism
Advantages
Disadvantages
Application scenario
LACP MAD
·     Detection speed is fast.
·     Does not require MAD-dedicated physical links or Layer 3 interfaces.
Requires an intermediate device that supports extended LACP for MAD.
Link aggregation is used between the IRF fabric and its upstream or downstream device.
For information about LACP, see Layer 2—LAN Switching Configuration Guide.
BFD MAD
·     No intermediate device is required for two-chassis IRF fabrics.
·     Intermediate device, if used, can come from any vendor.
·     Requires MAD dedicated physical links and Layer 3 interfaces, which cannot be used for transmitting user traffic.
·     If no intermediate device is used, the IRF members must be fully meshed.
·     If an intermediate device is used, every IRF member must connect to the intermediate device.
·     No special requirements for network scenarios.
·     If no intermediate device is used, this mechanism is only suitable for two-chassis IRF fabrics that have members that are geographically close to one another.
For information about BFD, see High Availability Configuration Guide.
ARP MAD
·     No intermediate device is required.
·     Does not require MAD dedicated ports.
·     Detection speed is slower than BFD MAD and LACP MAD.
·     The spanning tree feature must be enabled.
Spanning tree-enabled non-link aggregation IPv4 network scenario.
For information about ARP, see Layer 3—IP Services Configuration Guide.
ND MAD
Spanning tree-enabled non-link aggregation IPv6 network scenario.
LACP MAD
As shown in Figure 7, LACP MAD has the following requirements:
·     Every IRF member must have a link with an intermediate device.
·     All the links form a dynamic link aggregation group.
·     The intermediate device must be a device that supports extended LACP for MAD.
The IRF member devices send extended LACPDUs that convey a domain ID and an active ID. The intermediate device transparently forwards the extended LACPDUs received from one member device to all the other member devices.
·     If the domain IDs and active IDs sent by all the member devices are the same, the IRF fabric is integrated.
·     If the extended LACPDUs convey the same domain ID but different active IDs, a split has occurred. LACP MAD handles this situation as described in "Collision handling."
Figure 7 LACP MAD scenario
BFD MAD
On a two-chassis IRF fabric, BFD MAD can work with or without intermediate devices. On a three- or four-chassis IRF fabric, BFD MAD must work with an intermediate device.
BFD MAD can be used on common Ethernet ports or management Ethernet ports. If management Ethernet ports are used, you must select the first management Ethernet port on the active MPU of each member device for BFD MAD links.
Figure 8 shows a typical BFD MAD application scenario on common Ethernet ports. Figure 9 shows a typical BFD MAD application scenario on management Ethernet ports.
To use BFD MAD:
·     Set up dedicated BFD MAD link between each pair of IRF members or between each IRF member and the intermediate device. Do not use the BFD MAD links for any other purposes.
·     If common Ethernet ports are used for BFD MAD links, you must configure BFD MAD on a VLAN interface. Perform the following tasks:
¡     Assign the ports connected by BFD MAD links to the same VLAN. The VLAN must be unique across MDCs and the network.
¡     Create a VLAN interface for the VLAN, and assign a MAD IP address to each member on the VLAN interface.
On the intermediate device (if any), you must create the VLAN and assign the ports on the BFD MAD links to the VLAN.
·     If management Ethernet ports are used for BFD MAD, assign a MAD IP address to the management Ethernet port on each member. On the intermediate device (if any), assign the ports on the BFD links to the same VLAN.
The MAD addresses identify the member devices and must belong to the same subnet.
Figure 8 BFD MAD scenario for common Ethernet ports
Figure 9 BFD MAD scenario for management Ethernet ports
With BFD MAD, the master attempts to establish BFD sessions with other member devices by using its MAD IP address as the source IP address.
·     If the IRF fabric is integrated, only the MAD IP address of the master takes effect. The master cannot establish a BFD session with any other member. If you execute the display bfd session command, the state of the BFD sessions is Down.
·     When the IRF fabric splits, the IP addresses of the masters in the split IRF fabrics take effect. The masters can establish a BFD session. If you execute the display bfd session command, the state of the BFD session between the two devices is Up.
ARP MAD
ARP MAD detects multi-active collisions by using extended ARP packets that convey the IRF domain ID and the active ID.
You can set up ARP MAD links between neighbor IRF member devices, or between each IRF member device and an intermediate device (see Figure 10). If an intermediate device is used, you must also run the spanning tree feature between the IRF fabric and the intermediate device.
Figure 10 ARP MAD scenario
Each IRF member compares the domain ID and the active ID in incoming extended ARP packets with its domain ID and active ID.
·     If the domain IDs are different, the extended ARP packet is from a different IRF fabric. The device does not continue to process the packet with the MAD mechanism.
·     If the domain IDs are the same, the device compares the active IDs:
¡     If the active IDs are different, the IRF fabric has split.
¡     If the active IDs are the same, the IRF fabric is integrated.
ND MAD
ND MAD detects multi-active collisions by using NS packets to transmit the IRF domain ID and the active ID.
You can set up ND MAD links between neighbor IRF member devices or between each IRF member device and an intermediate device (see Figure 11). If an intermediate device is used, you must also run the spanning tree protocol between the IRF fabric and the intermediate device.
Figure 11 ND MAD scenario
Each IRF member device compares the domain ID and the active ID in incoming NS packets with its domain ID and active ID:
·     If the domain IDs are different, the NS packet is from a different IRF fabric. The device does not continue to process the packet with the MAD mechanism.
For a successful IRF setup, follow the restrictions and guidelines in this section and the setup procedure in "Setup and configuration task list."
IRF fabric size
An S7500E IRF fabric can contain a maximum of two chassis in the following situations:
·     You use the 10-GE or 40-GE ports on the LSQM2MPUD0 or LSQM1SRP8X2QE0 MPU as IRF physical interfaces.
·     You use the ports on any of the following modules as IRF physical interfaces:
¡     SA modules.
¡     SC modules:
-     LSQM2GP24TSSC0.
-     LSQM2GP44TSSC0.
-     LSQM2GT24PTSSC0.
-     LSQM2GT24TSSC0.
In other situations, an S7500E IRF fabric can contain a maximum of four chassis.
All S7500E switches are IRF capable except for the S7502E switch. An H3C S7500E switch can form an IRF fabric only with devices in the same series.
All IRF member devices must run the same software image version. Make sure the software auto-update feature is enabled on all member devices.
MPU requirements
To operate correctly, an IRF fabric must meet the following MPU requirements:
·     Every IRF member has a minimum of one MPU.
·     Every IRF member must use the same model of MPUs.
When you set up an IRF fabric, follow these restrictions and guidelines for OAP modules:
·     You cannot use OAP modules in a three- or four-chassis IRF fabric.
·     If OAP modules are used in a two-chassis IRF fabric, you must assign member IDs 1 and 2 to the member devices.
Use the following physical interfaces for IRF links:
·     10-GE fiber ports.
·     40-GE fiber ports.
Selecting transceiver modules and cables
When you select transceiver modules and cables, follow these restrictions and guidelines:
·     Use XFP, SFP+, QSFP+, or CFP transceiver modules and fibers for a long-distance connection.
·     Use SFP+, QSFP+, or QSFP+ to SFP+ DAC cables for a short-distance connection.
·     Make sure the transceiver modules at the two ends of an IRF link are the same type. For more information about transceiver modules, see the device installation guide.
Restrictions on grouped 10-GE ports on interface modules
The 10-GE ports on the LSQM1TGS12EC0 interface module are grouped by port number in order, starting from 1. Each group contains four ports.
The ports on the LSQM2TGS16SF0 interface module are divided into the following groups:
·     Ports 1, 2, 15, and 16.
·     Ports 3 through 5.
·     Ports 6 through 8.
·     Ports 9 through 11.
·     Ports 12 through 14.
If you use the ports in a group for IRF links, follow these restrictions and guidelines:
·     You must use all or none of the ports for IRF links. The ports can be bound to different IRF ports.
·     Before you bind one 10-GE port to an IRF port or remove it from the IRF port, you must shut down all the ports in the group. If any of the ports are in up state, the bind or remove action will fail.
·     Bring up the ports after you complete the operations.
Restrictions on 40-GE QSFP+ ports on interface modules
Port split (the using tengige command) and combination (the using fortygige command) require a card reboot. As a best practice to avoid topology change, complete these operations before you add the device to an IRF fabric. When you perform these operations in an IRF fabric, make sure you understand the impact on the IRF fabric topology. For more information about 40-GE port split and combination operations, see Interface Configuration Guide.
If you use the 40-GE QSFP+ ports on interface modules for IRF links, follow these restrictions and guidelines:
·     You can use a 40-GE QSFP+ port for IRF links, or use the breakout SFP+ ports of the QSFP+ port for IRF links.
·     If you use the 10-GE breakout ports of a 40-GE port for IRF links, follow these restrictions and guidelines:
¡     You must use all or none of the four 10-GE breakout ports for IRF links. The four breakout ports can be bound to different IRF ports.
¡     Before you bind one 10-GE breakout port to an IRF port or remove it from the IRF port, you must shut down all the 10-GE breakout ports. If any of the breakout ports are in up state, the bind or remove action will fail.
¡     Bring up the breakout ports after you complete the operations.
Restrictions on 10-GE and 40-GE ports on MPUs
If you use 10-GE or 40-GE ports on the LSQM2MPUD0 or LSQM1SRP8X2QE0 MPU for IRF links, follow these restrictions and guidelines:
·     Ports on interface modules cannot be used for IRF links.
·     Ports bound to all IRF ports in an IRF fabric must be located on the same type of MPU.
·     Ports at the ends of an IRF link must operate at the same rate.
When you connect two neighboring IRF members, follow these restrictions and guidelines:
·     You must connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other.
·     Do not connect physical interfaces of both IRF ports on one member device to the physical interfaces of both IRF ports on the other device.
·     Make sure the two ends of an aggregate IRF link have the same number of IRF physical interfaces.
ECMP
To form an IRF fabric, all member devices in the IRF fabric must support the same maximum number of ECMP routes. For more information about ECMP, see Layer 3—IP Routing Configuration Guide.
IRF mode
To form an IRF fabric, all member devices must use the same IRF mode setting.
To add a new MPU or replace an MPU, make sure the added MPU or replacement MPU is operating in the same IRF mode as the IRF fabric.
For more information about IRF modes, see "Setting up an IRF 3 system."
MDC
When you configure MDC on an IRF fabric, follow these restrictions and guidelines:
·     If the IRF fabric splits, do not change the MDC settings on any IRF member devices before they reunite.
·     Except for the commands in Table 2, all IRF commands are available only on the default MDC.
Table 2 IRF commands available on both default and non-default MDCs
Command category
Commands
Display commands
display irf link
MAD commands
mad arp enable
mad bfd enable
mad enable
mad nd enable
mad ip address
For more information about MDC, see "Configuring MDC."
System operating mode
All member devices in the IRF fabric must work in the same system operating mode (set by using the system-working-mode command). For more information about the system operating mode, see Fundamentals Configuration Guide.
TRILL
If TRILL is used, configure the irf mac-address persistent always command to retain the IRF bridge MAC address permanently. The persistence setting avoids unnecessary traffic disruption caused by IRF bridge MAC address changes on the TRILL network.
For a license-based feature to run correctly on an IRF fabric, make sure the licenses installed for the feature on all member devices are the same. For more information about feature licensing, see Fundamentals Configuration Guide.
As a best practice, back up the next-startup configuration file on a device before adding the device to an IRF fabric as a subordinate.
A subordinate device's next-startup configuration file might be overwritten if the master and the subordinate use the same file name for their next-startup configuration files. You can use the backup file to restore the original configuration after removing the subordinate from the IRF fabric.
To set up an IRF fabric, perform the following tasks:
Tasks at a glance
Remarks
1.     (Required.) Planning the IRF fabric setup
N/A
2.     (Required.) Preconfiguring IRF member devices in standalone mode:
¡     Assigning a member ID to each IRF member device
¡     Specifying a priority for each member device
¡     Binding physical interfaces to IRF ports
You can configure member IDs, member priority, and IRF port bindings in standalone or IRF mode.
As a best practice, perform these tasks in standalone mode to reduce the number of reboots.
3.     (Required.) Saving configuration to the next-startup configuration file
N/A
4.     (Required.) Connecting IRF physical interfaces
N/A
5.     (Required.) Setting the operating mode to IRF mode
N/A
6.     (Required.) Accessing the IRF fabric
N/A
7.     (Optional.) Configuring IRF member devices in IRF mode:
¡     Changing the member ID of a device
¡     Changing the priority of a member device
¡     Adding physical interfaces to an IRF port
¡     Enabling IRF auto-merge
¡     Configuring a member device description
¡     Configuring IRF link load sharing mode
¡     Configuring IRF bridge MAC persistence
¡     Enabling software auto-update for software image synchronization
¡     Setting the IRF link down report delay
¡     Isolating an unused IRF member ID
¡     Configuring MAD
¡     Recovering an IRF fabric
CAUTION CAUTION:
Changing member IDs in an IRF fabric can void member ID-related configuration and cause unexpected problems. Make sure you understand the impact on your live network before you change member IDs.
Adding physical interfaces to an IRF port is required if you did not configure IRF port bindings in standalone mode.
Consider the following items when you plan an IRF fabric:
·     Hardware compatibility and restrictions.
·     IRF fabric size.
·     Master switch.
·     IRF physical interfaces.
·     Member ID and priority assignment scheme.
·     Fabric topology and cabling scheme.
For more information about hardware and cabling, see the switch installation guide.
Perform the preconfiguration tasks on every IRF member device. These settings take effect on each member device after their operating mode changes to IRF.
Assign a unique IRF member ID to a device before changing the device's operating mode to IRF. If you do not specify an IRF member ID in standalone mode, the device uses a member ID of 1 after its operating mode changes to IRF.
The member ID is saved in both active and standby MPUs. The standby MPU might store a different member ID than the active MPU after an MPU replacement. For consistency, the system updates the member ID in the active MPU automatically to the standby MPU when the difference is detected.
To assign a member ID to the device in standalone mode:
Step
Remarks
N/A
2.     Assign an IRF member ID to the device.
irf member member-id
By default, the device does not have an IRF member ID.
IRF member priority represents the possibility for a device to be elected the master in an IRF fabric. The higher the priority, the higher the possibility.
To specify a priority for the device in standalone mode:
Step
Remarks
N/A
2.     Specify a priority for the device.
irf priority priority
The default IRF member priority is 1.
To establish an IRF connection between two devices, you must bind a minimum of one physical interface to IRF-port 1 on one device and to IRF-port 2 on the other.
You must configure IRF physical interfaces as Layer 2 interfaces. Layer 3 interfaces cannot be bound to IRF ports. To configure a physical interface as a Layer 2 interface, use the port link-mode bridge command. For more information about this command, see Interface Configuration Guide.
In standalone mode, IRF port binding operations do not affect the current configuration of the interface. However, when the operating mode changes to IRF mode, the default configuration is restored on the physical interface. You can only execute the following commands on the physical interface:
·     description.
·     flow-interval.
·     priority-flow-control { auto | enable }.
·     priority-flow-control no-drop dot1p dot1p-list.
·     shutdown.
For more information about these commands, see Interface Command Reference.
To bind physical interfaces to IRF ports:
Step
Remarks
N/A
2.     Enter IRF port view.
irf-port port-number
N/A
3.     Bind a physical interface to the IRF port.
port group interface interface-type interface-number [ mode { enhanced | extended } ]
By default, no physical interfaces are bound to any IRF port.
Repeat this step to assign multiple physical interfaces to the IRF port.
You can bind physical interfaces on different modules to the same IRF port.
Each IRF port can have a maximum of eight physical interfaces.
The extended keyword is reserved for future support. An IRF physical interface operates in enhanced mode after the IRF binding takes effect, regardless of whether you have specified the mode enhanced keywords.
Save the running configuration before converting to the IRF mode. The mode change requires a reboot, which causes all unsaved settings to be lost.
Perform the following task in any view:
Save the running configuration to the next-startup configuration file.
save [ safely ] [ backup | main ] [ force ]
When you connect two neighboring IRF members, connect the physical interfaces of IRF-port 1 on one member to the physical interfaces of IRF-port 2 on the other (see Figure 12).
For example, you have four chassis: A, B, C, and D. IRF-port 1 and IRF-port 2 are represented by A1 and A2 on chassis A, represented by B1 and B2 on chassis B, and so on. To connect the four chassis into a ring topology of A-B-C-D(A), the IRF link cabling scheme must be one of the following:
·     A1-B2, B1-C2, C1-D2, and D1-A2.
·     A2-B1, B2-C1, C2-D1, and D2-A1.
Figure 12 Connecting IRF physical interfaces
Connect the devices into a daisy-chain topology or a ring topology. A ring topology is more reliable (see Figure 13). In ring topology, the failure of one IRF link does not cause the IRF fabric to split as in daisy-chain topology. Rather, the IRF fabric changes to a daisy-chain topology without interrupting network services.
To use the ring topology, you must have a minimum of three member devices.
Figure 13 Daisy-chain topology vs. ring topology
By default, the device operates in standalone mode. To assign the device to an IRF fabric, you must change its operating mode to IRF mode.
To set the operating mode of a device to IRF mode:
Step
Remarks
1.     (Optional.) Verify that a unique IRF member ID has been assigned to the device.
display irf configuration
Check the MemberID field. If the device does not have an IRF member ID, the field displays two hyphens (--).
2.     Enter system view.
N/A
3.     Set the operating mode to IRF mode.
chassis convert mode irf
The default operating mode is standalone mode.
After you change the operating mode, the device automatically reboots for the change to take effect.
During the reboot, you may choose to have the system automatically convert the startup configuration file. Automatic configuration conversion prevents slot- or interface-related settings from becoming invalid. For example, the system adds member ID information to interface numbers and file paths in IRF mode.
To restore the standalone mode, use the undo chassis convert mode command.
TIP
TIP:
IRF generates packets on a device in IRF mode even if the device does not form an IRF fabric with any other devices. To conserve system resources, set a device to standalone mode after removing it from an IRF fabric.
The IRF fabric appears as one device after it is formed. You configure and manage all IRF members at the CLI of the master. All settings you have made are automatically propagated to the IRF members.
The following methods are available for accessing an IRF fabric:
·     Local login—Log in through the console port of any member device.
·     Remote login—Log in at a Layer 3 interface on any member device by using methods including Telnet and SNMP.
When you log in to an IRF fabric, you are placed at the CLI of the master, regardless of at which member device you are logged in.
For more information, see login configuration in Fundamentals Configuration Guide.
After you access the master's CLI, you can perform the tasks in this section or configure features in all other configuration guides for the device.
CAUTION
CAUTION:
In IRF mode, an IRF member ID change can invalidate member ID-related settings and cause data loss. Make sure you fully understand its impact on your live network.
The new member ID takes effect at reboot. After the device reboots, the settings on all member ID-related physical resources (including common physical network ports) are removed, regardless of whether you have saved the configuration.
For a successful IRF merge, you must place a device in standalone mode before renumbering it in one of the following situations:
·     The IRF physical interfaces of the device are 10-GE breakout ports of a 40-GE QSFP+ port.
·     You are exchanging the member IDs of two devices. In this case, place both devices in standalone mode.
To change the member ID of a member device:
Step
Remarks
N/A
2.     Change the member ID of a member device.
irf member member-id renumber new-member-id
By default, the device uses the member ID that is set in standalone mode. If no member ID is assigned to the device in standalone mode, the device automatically uses the member ID of 1 after its operating mode changes to IRF.
3.     Save the running configuration.
save [ safely ] [ force ]
N/A
4.     Reboot the member device.
reboot chassis chassis-number
The chassis-number must be the same as the member-id specified in the irf member member-id renumber new-member-id command.
You can change the priority of a member device so it can be elected the master in the next master election.
A change to member priority can affect the master re-election result. However, it does not cause an immediate master re-election.
To change the priority of a member device:
Step
Remarks
N/A
2.     Specify a priority for a member of an IRF fabric.
irf member member-id priority priority
An IRF port can have a maximum of eight physical interfaces.
In IRF mode, you can add physical interfaces to an IRF port without traffic interruption on the IRF port.
Before you perform this task, disable IRF auto-merge.
When you perform this task, follow the IRF port binding restrictions and configuration guidelines in these sections:
·     IRF physical interface requirements.
·     Binding physical interfaces to IRF ports.
To configure IRF ports:
Step
Remarks
N/A
2.     Enter Ethernet interface view or interface range view.
·     Enter interface range view:
¡     Method 1:
interface range { interface-type interface-number [ to interface-type interface-number ] } &<1-
24>
¡     Method 2:
interface range name name [ interface { interface-type interface-number [ to interface-type interface-number ] } &<1-24> ]
·     Enter interface view:
To shut down a range of IRF physical interfaces, enter interface range view.
To shut down one IRF physical interface, enter its interface view.
3.     Shut down the physical interfaces.
shutdown
If you cannot shut down a physical interface, follow the system instruction to shut down its peer interface.
4.     Return to system view.
N/A
5.     Enter IRF port view.
irf-port member-id/port-number
N/A
6.     Bind each physical interface to the IRF port.
port group [ mdc mdc-name ] interface interface-type interface-number [ mode { enhanced | extended } ]
You can bind a maximum of eight physical interfaces to an IRF port.
7.     Return to system view.
N/A
8.     Enter Ethernet interface view or interface range view.
¡     Method 1:
24>
¡     Method 2:
N/A
9.     Bring up the physical interfaces.
N/A
10.     Return to system view.
N/A
11.     Save the running configuration.
save
Activating IRF port settings causes IRF merge and reboot. To avoid data loss, save the running configuration to the startup configuration file before you perform the operation.
12.     Activate the configuration on the IRF port.
irf-port-configuration active
After this step is performed, the state of the IRF port changes to UP. The member devices elect a master, and the subordinate device reboots automatically.
After the IRF fabric is formed, you can add physical interfaces to an IRF port (in UP state) without repeating this step.
When two IRF fabrics merge, you must reboot the member devices in the IRF fabric that fails in the master election. The auto-merge feature enables the IRF fabric to automatically reboot all its member devices to complete the merge.
If this feature is disabled or does not take effect, you must manually reboot the devices that failed the master election to complete the merge.
To enable IRF auto-merge:
Step
Remarks
N/A
2.     Enable IRF auto-merge.
irf auto-merge enable
By default, this feature is enabled.
Step
Remarks
N/A
2.     Configure a description for a member device.
irf member member-id description text
By default, no member device description is configured.
On an IRF port, traffic is balanced across its physical links.
You can configure the IRF port to distribute traffic based on any combination of the following criteria:
·     IP addresses.
·     MAC addresses.
·     Ingress ports.
The system displays an error message if a criteria combination is not supported.
Configure the IRF link load sharing mode for IRF links in system view or IRF port view:
·     In system view, the configuration is global and takes effect on all IRF ports.
·     In IRF port view, the configuration is port specific and takes effect only on the specified IRF port.
An IRF port preferentially uses the port-specific load sharing mode. If no port-specific load sharing mode is available, the IRF port uses the global load sharing mode.
Configuring the global load sharing mode
Step
Remarks
3.     Enter system view.
N/A
4.     Configure the global IRF link load sharing mode.
irf-port global load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
The following are the default load sharing mode:
·     Non-IP traffic—Source and destination MAC addresses.
·     Non-TCP/-UDP IP traffic—Source and destination IP addresses.
·     TCP/UDP IP traffic—Source and destination service ports.
The ingress-port keyword is not supported in the current software version.
Configuring a port-specific load sharing mode
Before you configure a port-specific load sharing mode, make sure you have bound a minimum of one physical interface to the IRF port.
To configure a port-specific load sharing mode for an IRF port:
Step
Remarks
N/A
irf-port member-id/irf-port-number
N/A
3.     Configure the port-specific load sharing mode.
irf-port load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
By default, an IRF fabric uses the bridge MAC address of the master device as its bridge MAC address. Layer 2 protocols, such as LACP, use this bridge MAC address to identify the IRF fabric. On a switched LAN, the bridge MAC address must be unique.
To avoid duplicate bridge MAC addresses, an IRF fabric can change its bridge MAC address automatically after its bridge MAC owner leaves. However, the change causes temporary traffic disruption.
Depending on the network condition, enable the IRF fabric to preserve or change its bridge MAC address after the address owner leaves. Available options include:
·     irf mac-address persistent timerBridge MAC address of the IRF fabric is retained for 6 minutes after the address owner leaves. If the owner does not return before the timer expires, the IRF fabric uses the bridge MAC address of the current master as its bridge MAC address. This option avoids unnecessary bridge MAC address changes caused by device reboot, transient link failure, or purposeful link disconnection.
·     irf mac-address persistent alwaysBridge MAC address of the IRF fabric does not change after the address owner leaves.
IRF fabrics cannot merge if they have the same bridge MAC address. If you use the removed bridge MAC owner as the master device in a new fabric, the bridge MAC of the new fabric is the same as the old fabric. For the two IRF fabrics to merge, you must change the bridge MAC address of the old IRF fabric.
·     undo irf mac-address persistent—Bridge MAC address of the current master replaces the original one as soon as the owner of the original bridge MAC address leaves.
IMPORTANT
IMPORTANT:
You must configure the undo irf mac-address persistent command if ARP MAD or ND MAD is used.
To configure the IRF bridge MAC persistence setting:
Step
Remarks
N/A
2.     Configure IRF bridge MAC persistence.
·     Retain the bridge MAC address permanently even if the address owner has left the fabric:
·     Retain the bridge MAC address for 6 minutes after the address owner leaves the fabric:
·     Change the bridge MAC address as soon as the address owner leaves the fabric:
By default, the IRF bridge MAC address does not change after the address owner has left the fabric.
IMPORTANT
IMPORTANT:
To ensure a successful software auto-update in a multi-user environment, prevent anyone from rebooting or swapping member devices or MPUs during the auto-update process. To inform administrators of the auto-update status, configure the information center to output the status message to configuration terminals (see Network Management and Monitoring Configuration Guide).
The software auto-update feature automatically propagates the software images of the global active MPU to all other MPUs in the IRF fabric.
To join an IRF fabric, an MPU must use the same software images as the global active MPU in the fabric.
When you add an MPU to the IRF fabric, software auto-update compares the startup software images of the MPU with the current software images of the IRF global active MPU. If the two sets of images are different, the MPU automatically performs the following operations:
1.     Downloads the current software images of the global active MPU.
2.     Sets the downloaded images as the main startup software images.
3.     Reboots with the new software images to rejoin the IRF fabric.
You must manually update the new MPU with the software images running on the IRF fabric in the following situations:
·     Software auto-update is disabled.
·     Software auto-update fails to update software. This situation might occur if the IRF fabric cannot identify the software version used on the new MPU.
Configuration prerequisites
Make sure the MPU you are adding to the IRF fabric has sufficient storage space for the new software images.
If sufficient storage space is not available, the MPU automatically deletes the current software images. If the reclaimed space is still insufficient, the MPU cannot complete the auto-update. You must reboot the device that holds the MPU, and then access the BootWare menus to delete files.
Configuration procedure
To enable software image synchronization:
Step
Remarks
N/A
2.     Enable software auto-update.
irf auto-update enable
By default, software auto-update is enabled.
To prevent frequent IRF splits and merges during link flapping, configure the IRF ports to delay reporting link down events.
An IRF port does not report a link down event to the IRF fabric immediately after its link changes from up to down. If the IRF link state is still down when the delay is reached, the port reports the change to the IRF fabric.
IRF ports do not delay link up events. They report the link up event immediately after the IRF link comes up.
When you configure the IRF link down report delay, follow these restrictions and guidelines:
·     Make sure the IRF link down report delay is shorter than the maximum CCM lifetime and BFD session lifetime. For more information about CFD and BFD, see High Availability Configuration Guide.
·     As a best practice, set the delay to 0 seconds in the following situations:
¡     The IRF fabric requires a fast master/subordinate or IRF link switchover.
¡     The BFD, BFD MAD, GR, or RRPP feature is used.
To set the IRF link down report delay:
Step
Remarks
N/A
2.     Set the IRF link down report delay.
irf link-delay interval
The default IRF link down report delay is 1 second.
The greater the interval, the slower the service recovery.
This feature prevents an IRF fabric from creating CRC errors or traffic storms.
CRC errors or traffic storms occur if an IRF member device tags inter-chassis packets with a valid unused member ID. This issue is typically caused by poor-quality fiber modules, fibers, or cables on IRF links.
To avoid CRC errors or traffic storms, isolate the unused member IDs in the valid member ID range. When an unused member ID is isolated, the member devices will drop all packets that are tagged with the member ID.
IMPORTANT
IMPORTANT:
Before you assign an isolated ID to a new member device, remove the isolation setting for the member ID.
To isolate an unused IRF member ID:
Step
Remarks
N/A
2.     Isolate an unused IRF member ID.
irf isolate member member-id
By default, no member IDs are isolated.
This command is supported only in IRF mode.
Configuring MAD
When you configure MAD, follow these restrictions and guidelines:
·     You can configure ARP MAD and ND MAD together in an IRF fabric for prompt IRF split detection.
¡     Do not configure LACP MAD together with BFD MAD, ARP MAD, or ND MAD, because they handle collisions differently.
¡     Do not configure BFD MAD together with ARP MAD or ND MAD. BFD MAD is exclusive with the spanning tree feature, but ARP MAD and ND MAD require the spanning tree feature.
·     If LACP MAD, ARP MAD, or ND MAD runs between two IRF fabrics, assign each fabric a unique IRF domain ID. (For BFD MAD, this task is optional.)
·     An IRF fabric has only one IRF domain ID.
¡     You can change the IRF domain ID by using the following commands: irf domain, mad enable, mad arp enable, or mad nd enable. The IRF domain IDs configured by using these commands overwrite each other.
¡     In an MDC environment, if you change the IRF domain ID in one MDC, the IRF domain IDs in all other MDCs change automatically. The irf domain command is available only on the default MDC. The mad enable, mad arp enable, and mad nd enable commands are available on any MDCs.
·     To prevent a port from being shut down when the IRF fabric transits to the Recovery state, use the mad exclude interface command. To bring up ports in a Recovery-state IRF fabric, use the mad restore command instead of the undo shutdown command. The mad restore command activates the Recovery-state IRF fabric.
Configuring LACP MAD
When you use LACP MAD, follow these guidelines:
·     If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection.
·     Use dynamic link aggregation mode. MAD is LACP dependent. Even though LACP MAD can be configured on both static and dynamic aggregate interfaces, it takes effect only on dynamic aggregate interfaces.
·     Configure link aggregation settings on the intermediate device.
To configure LACP MAD:
Step
Remarks
N/A
2.     Assign a domain ID to the IRF fabric.
irf domain domain-id
The default IRF domain ID is 0.
3.     Create an aggregate interface and enter aggregate interface view.
·     Enter Layer 2 aggregate interface view:
·     Enter Layer 3 aggregate interface view:
Perform this step also on the intermediate device.
4.     Configure the aggregation group to operate in dynamic aggregation mode.
link-aggregation mode dynamic
By default, an aggregation group operates in static aggregation mode.
5.     Enable LACP MAD.
mad enable
By default, LACP MAD is disabled.
6.     Return to system view.
N/A
7.     Enter Ethernet interface view or interface range view.
¡     Method 1:
24>
¡     Method 2:
24> ]
·     Enter Ethernet interface view:
To assign a range of ports to the aggregation group, enter interface range view.
To assign one port to the aggregation group, enter Ethernet interface view.
8.     Assign the Ethernet port or the range of Ethernet ports to the specified aggregation group.
port link-aggregation group number
Multichassis link aggregation is allowed.
Also perform this step on the intermediate device.
Configuring BFD MAD on a VLAN interface
Configure BFD MAD on a VLAN interface if you use common Ethernet ports for BFD MAD.
When you use BFD MAD on a VLAN interface, follow these restrictions and guidelines:
Category
BFD MAD VLAN
·     Do not enable BFD MAD on VLAN-interface 1.
·     If you are using an intermediate device, perform the following tasks on both the IRF fabric and the intermediate device:
¡     Create a VLAN and VLAN interface for BFD MAD.
¡     Assign the ports of BFD MAD links to the BFD MAD VLAN.
·     Make sure the BFD MAD VLAN belongs to only one MDC. The VLAN ID is unique across MDCs.
·     Make sure the IRF fabrics on the network use different BFD MAD VLANs.
·     Make sure the BFD MAD VLAN contains only ports on the BFD MAD links.
BFD MAD VLAN and feature compatibility
Do not use the BFD MAD VLAN for any purpose other than configuring BFD MAD.
·     Configure only the mad bfd enable and mad ip address commands on the BFD MAD-enabled VLAN interface. If you configure other features, both BFD MAD and other features on the interface might run incorrectly.
·     Disable the spanning tree feature on any Layer 2 Ethernet ports in the BFD MAD VLAN. The MAD feature is mutually exclusive with the spanning tree feature.
·     Do not bind a BFD MAD-enabled VLAN interface to a VPN instance. The MAD feature is mutually exclusive with VPN.
MAD IP address
·     To avoid problems, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled VLAN interface. Do not configure an IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled VLAN interface.
·     Make sure all the MAD IP addresses are on the same subnet.
·     MAD IP addresses must be unique among all IP addresses on the IRF fabric.
BFD MAD and IRF link down report delay restrictions
Set the IRF link down report delay to 0 seconds to avoid unnecessary recalculations.
To configure BFD MAD on a VLAN interface:
Step
Remarks
N/A
2.     (Optional.) Assign a domain ID to the IRF fabric.
By default, the domain ID of an IRF fabric is 0.
3.     Create a VLAN dedicated to BFD MAD.
vlan vlan-id
The default VLAN on the device is VLAN 1.
N/A
5.     Enter interface view or interface range view.
¡     Method 1:
24>
¡     Method 2:
24> ]
To assign a range of ports to the BFD MAD VLAN, enter interface range view.
To assign one port to the BFD MAD VLAN, enter Ethernet interface view.
6.     Assign the port or the range of ports to the BFD MAD VLAN.
·     Assign the port to the VLAN as an access port:
port access vlan vlan-id
·     Assign the port to the VLAN as a trunk port:
port trunk permit vlan
vlan-id
·     Assign the port to the VLAN as a hybrid port:
port hybrid vlan
vlan-id { tagged | untagged }
The link type of BFD MAD ports can be access, trunk, or hybrid.
The default link type of a port is access.
N/A
8.     Enter VLAN interface view.
interface vlan-interface vlan-interface-id
N/A
9.     Enable BFD MAD.
mad bfd enable
By default, BFD MAD is disabled.
10.     Assign a MAD IP address to a member device on the VLAN interface.
mad ip address ip-address { mask | mask-length } member member-id
By default, no MAD IP addresses are configured on any VLAN interface.
Repeat this step to assign a MAD IP address to each member device on the VLAN interface.
Configuring BFD MAD on management Ethernet ports
When you use BFD MAD on management Ethernet ports, follow these restrictions and guidelines:
Category
Management Ethernet ports for BFD MAD
Use the first management Ethernet port on the active MPU of each member device to set up BFD MAD links.
Ports on the intermediate device for BFD MAD
If you are using an intermediate device, use common Ethernet ports on the intermediate device to set up BFD MAD links.
BFD MAD VLAN
·     On the intermediate device (if any), create a VLAN for BFD MAD, and assign the ports used for BFD MAD to the VLAN. On the IRF fabric, you do not need to assign the BFD MAD-enabled management Ethernet ports to the VLAN.
·     As a best practice, do not configure other features on the VLAN used for BFD MAD.
·     Make sure the BFD MAD VLAN on the intermediate device contains only ports on the BFD MAD links.
BFD MAD-enabled management Ethernet port and feature compatibility
Do not bind a BFD MAD-enabled management Ethernet port to a VPN instance. The MAD feature is mutually exclusive with VPN.
MAD IP address
·     Use the mad ip address command instead of the ip address command to configure MAD IP addresses on the BFD MAD-enabled management Ethernet ports.
To configure BFD MAD on management Ethernet ports:
Step
Remarks
N/A
3.     Enter management Ethernet interface view.
interface m-gigabitethernet interface-number
Enter the view of the first management Ethernet port on each member device's active MPU to perform the subsequent steps.
4.     Enable BFD MAD.
mad bfd enable
5.     Assign a MAD IP address to each member device.
By default, no MAD IP addresses are configured.
Configuring ARP MAD
When you use ARP MAD, follow these guidelines:
·     Do not configure ARP MAD on VLAN-interface 1.
·     Do not use the VLAN configured for ARP MAD for any other purposes.
·     If an intermediate device is used, you can use common data links as ARP MAD links. If no intermediate device is used, set up dedicated ARP MAD links between IRF member devices.
·     If an intermediate device is used, make sure the following requirements are met:
¡     Run the spanning tree feature between the IRF fabric and the intermediate device. Make sure there is only one ARP MAD link in forwarding state. For more information about the spanning tree feature and its configuration, see Layer 2—LAN Switching Configuration Guide.
¡     Enable the IRF fabric to change its bridge MAC address as soon as the bridge MAC owner leaves.
¡     Create an ARP MAD VLAN and assign the ports on the ARP MAD links to the VLAN.
¡     If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection.
To configure ARP MAD:
Step
Remarks
N/A
3.     Configure the IRF bridge MAC address to change as soon as the address owner leaves.
By default, the IRF fabric's bridge MAC address does not change after the address owner leaves.
4.     Create a VLAN dedicated to ARP MAD.
vlan vlan-id
5.     Return to system view.
N/A
6.     Enter Ethernet interface view or interface range view.
¡     Method 1:
24>
¡     Method 2:
24> ]
To assign a range of ports to the ARP MAD VLAN, enter interface range view.
To assign one port to the ARP MAD VLAN, enter Ethernet interface view.
7.     Assign the port or the range of ports to the ARP MAD VLAN.
vlan-id
port hybrid vlan
The link type of ARP MAD ports can be access, trunk, or hybrid.
8.     Return to system view.
N/A
9.     Enter VLAN interface view.
N/A
10.     Assign the interface an IP address.
By default, no IP addresses are assigned to any VLAN interfaces.
11.     Enable ARP MAD.
mad arp enable
By default, ARP MAD is disabled.
Configuring ND MAD
When you use ND MAD, follow these guidelines:
·     Do not configure ND MAD on VLAN-interface 1.
·     Do not use the VLAN configured for ND MAD for any other purposes.
·     If an intermediate device is used, you can use common data links as ND MAD links. If no intermediate device is used, set up dedicated ND MAD links between IRF member devices.
¡     Run the spanning tree feature between the IRF fabric and the intermediate device. Make sure there is only one ND MAD link in forwarding state. For more information about the spanning tree feature and its configuration, see Layer 2—LAN Switching Configuration Guide.
¡     Create an ND MAD VLAN and assign the ports on the ND MAD links to the VLAN.
To configure ND MAD:
Step
Remarks
N/A
4.     Create a VLAN dedicated to ND MAD.
vlan vlan-id
N/A
¡     Method 1:
24>
¡     Method 2:
24> ]
To assign a range of ports to the ND MAD VLAN, enter interface range view.
To assign one port to the ND MAD VLAN, enter Ethernet interface view.
7.     Assign the port or the range of ports to the ND MAD VLAN.
vlan-id
port hybrid vlan
The link type of ND MAD ports can be access, trunk, or hybrid.
N/A
N/A
ipv6 address { ipv6-address/pre-length | ipv6 address pre-length }
By default, no IPv6 addresses are assigned to any VLAN interfaces.
11.     Enable ND MAD.
mad nd enable
By default, ND MAD is disabled.
Excluding a port from the shutdown action upon detection of multi-active collision
CAUTION
CAUTION:
·     Excluding a VLAN interface and its Layer 2 ports from the shutdown action introduces IP collision risks because the VLAN interface might be active on both the active and inactive IRF fabrics.
·     Do not exclude the VLAN interface used for BFD MAD and its Layer 2 member ports from the shutdown action. A violation causes BFD MAD link flapping.
By default, all ports except the console and IRF physical interfaces shut down automatically when the IRF fabric transits to the Recovery state.
You can exclude a network port from the shutdown action for management or other special purposes. For example:
·     Exclude a port from the shutdown action so you can Telnet to the port for managing the device.
·     Exclude a VLAN interface and its Layer 2 ports from the shutdown action so you can log in through the VLAN interface.
To configure a port to not shut down when the IRF fabric transits to the Recovery state:
Step
Remarks
N/A
2.     Configure a network port to not shut down when the IRF fabric transits to the Recovery state.
mad exclude interface interface-type interface-number
By default, all network ports on a Recovery-state IRF fabric are shut down, except for the IRF physical interfaces and console port.
After the failed IRF link between two split IRF fabrics is recovered, log in to the inactive IRF fabric, and use the reboot command to reboot all its members. If the irf auto-merge enable command has been configured, the inactive IRF member devices automatically reboot after the failed link is recovered. After these member devices join the active IRF fabric as subordinates, IRF merge is complete, as shown in Figure 14.
Figure 14 Recovering the IRF fabric
If the active IRF fabric fails before the IRF link is recovered (see Figure 15), use the mad restore command on the inactive IRF fabric to recover the inactive IRF fabric. The command also brings up all network ports that were shut down by MAD. After you repair the IRF link, the two parts merge into a unified IRF fabric.
Figure 15 Active IRF fabric fails before the IRF link is recovered
To manually recover an inactive IRF fabric:
Step
2.     Recover the inactive IRF fabric.
mad restore
After the IRF fabric is recovered, all ports that have been shut down by MAD come up automatically.
Displaying and maintaining an IRF fabric
Display information about all IRF members.
display irf
Display the IRF fabric topology.
display irf topology
Display IRF link information.
display irf link
Display IRF configuration.
Display load sharing mode for IRF links.
display irf-port load-sharing mode [ irf-port [ member-id/irf-port-number ] ]
Display MAD configuration.
display mad [ verbose ]
Configuration examples
This section provides IRF configuration examples for IRF fabrics that use different MAD mechanisms.
LACP MAD-enabled IRF configuration example for a two-chassis IRF fabric
Network requirements
As shown in Figure 16, set up a two-chassis IRF fabric at the access layer of the enterprise network.
Configure LACP MAD on the multichassis aggregation to Device C, an H3C device that supports extended LACP.
Figure 16 Network diagram
IMPORTANT
IMPORTANT:
Between two neighboring IRF members, IRF links must be bound to IRF-port 1 on one member and to IRF-port 2 on the other.
1.     Configure Device A:
# Assign member ID 1 to Device A, and bind Ten-GigabitEthernet 3/0/1 to IRF-port 2.
[Sysname] irf member 1
[Sysname] irf-port 2
[Sysname-irf-port2] port group interface ten-gigabitethernet 3/0/1
[Sysname-irf-port2] quit
# Save the configuration.
[Sysname] quit
<Sysname> save
# Enable IRF mode.
[Sysname] chassis convert mode irf
The device will switch to IRF mode and reboot. You are recommended to save the current running configuration and specify the configuration file for the next startup. Continue? [Y/N]:y
 Do you want to convert the content of the next startup configuration file flash:/startup.cfg to make it available in IRF mode? [Y/N]:y
 Please wait...
 Saving the converted configuration file to the main board succeeded.
Slot 1:
 Saving the converted configuration file succeeded.
 Now rebooting, please wait...
2.     Configure Device B:
# Assign member ID 2 to Device B, and bind Ten-GigabitEthernet 3/0/1 to IRF-port 1.
[Sysname] irf member 2
[Sysname] irf-port 1
[Sysname-irf-port1] port group interface ten-gigabitethernet 3/0/1
[Sysname-irf-port1] quit
[Sysname] quit
<Sysname> save
# Connect the two devices as shown in Figure 16.
# Enable IRF mode on Device B.
 Please wait...
Slot 1:
Device B and Device A form an IRF fabric after Device B reboots.
3.     Configure LACP MAD:
# Assign domain ID 1 to the IRF fabric.
[Sysname] irf domain 1
# Create a dynamic aggregate interface and enable LACP MAD.
[Sysname] interface bridge-aggregation 2
[Sysname-Bridge-Aggregation2] link-aggregation mode dynamic
[Sysname-Bridge-Aggregation2] mad enable
 [Current domain is: 1]:
 The assigned  domain ID is: 1
 MAD LACP only enable on dynamic aggregation interface.
[Sysname-Bridge-Aggregation2] quit
# Assign GigabitEthernet 1/4/0/2 and GigabitEthernet 2/4/0/2 to the aggregate interface.
[Sysname] interface gigabitethernet 1/4/0/2
[Sysname-GigabitEthernet1/4/0/2] port link-aggregation group 2
[Sysname-GigabitEthernet1/4/0/2] quit
[Sysname] interface gigabitethernet 2/4/0/2
[Sysname-GigabitEthernet2/4/0/2] port link-aggregation group 2
4.     Configure Device C as the intermediate device:
CAUTION
CAUTION:
If the intermediate device is also an IRF fabric, assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
# Create a dynamic aggregate interface.
# Assign GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2 to the aggregate interface.
[Sysname] interface gigabitethernet 4/0/1
[Sysname-GigabitEthernet4/0/1] port link-aggregation group 2
[Sysname-GigabitEthernet4/0/1] quit
[Sysname] interface gigabitethernet 4/0/2
[Sysname-GigabitEthernet4/0/2] port link-aggregation group 2
BFD MAD-enabled IRF configuration example for a two-chassis IRF fabric
As shown in Figure 17, set up an IRF fabric at the distribution layer of the network.
·     Configure BFD MAD in the IRF fabric and set up BFD MAD links between the member devices.
·     Disable the spanning tree feature on the ports used for BFD MAD, because the two features conflict with each other.
Figure 17 Network diagram
[Sysname] quit
<Sysname> save
# Enable IRF mode.
 Please wait...
Slot 1:
[Sysname] quit
<Sysname> save
# Connect the two devices as shown in Figure 17.
 Please wait...
Slot 1:
Device B and Device A form an IRF after Device B reboots.
3.     Configure BFD MAD:
# Set the IRF link down report delay to 0 seconds.
[Sysname] irf link-delay 0
# Create VLAN 3, and add GigabitEthernet 1/4/0/1 and GigabitEthernet 2/4/0/1 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] port gigabitethernet 1/4/0/1 gigabitethernet 2/4/0/1
[Sysname-vlan3] quit
# Create VLAN-interface 3, and configure a MAD IP address for each member device on the VLAN interface.
[Sysname] interface vlan-interface 3
[Sysname-Vlan-interface3] mad bfd enable
[Sysname-Vlan-interface3] mad ip address 192.168.2.1 24 member 1
[Sysname-Vlan-interface3] mad ip address 192.168.2.2 24 member 2
[Sysname-Vlan-interface3] quit
# Disable the spanning tree feature on GigabitEthernet 1/4/0/1 and GigabitEthernet 2/4/0/1.
[Sysname] interface gigabitethernet 1/4/0/1
[Sysname-gigabitethernet1/4/0/1] undo stp enable
[Sysname-gigabitethernet1/4/0/1] quit
[Sysname] interface gigabitethernet 2/4/0/1
[Sysname-gigabitethernet2/4/0/1] undo stp enable
ARP MAD-enabled IRF configuration example for a two-chassis IRF fabric
As shown in Figure 18, set up a two-chassis IRF fabric at the distribution layer of the enterprise network.
·     Configure ARP MAD for the IRF fabric and use Device C as an intermediate device. Device C can come from any vendor.
·     To prevent loops, enable the spanning tree feature between the IRF fabric and Device C.
Figure 18 Network diagram
[Sysname] quit
<Sysname> save
# Enable IRF mode.
 Please wait...
Slot 1:
[Sysname] quit
<Sysname> save
# Connect the two devices as shown in Figure 18.
 Please wait...
Slot 1:
3.     Configure ARP MAD on the IRF fabric:
# Enable the spanning tree feature globally, and map the ARP MAD VLAN to MSTI 1 in the MST region.
[Sysname] stp global enable
[Sysname-mst-region] region-name arpmad
[Sysname-mst-region] instance 1 vlan 3
[Sysname-mst-region] quit
# Configure the bridge MAC address of the IRF fabric to change as soon as the bridge MAC owner leaves.
[Sysname] undo irf mac-address persistent
# Set the domain ID of the IRF fabric to 1.
# Create VLAN 3, and add GigabitEthernet 1/4/0/2 and GigabitEthernet 2/4/0/2 to VLAN 3.
[Sysname] vlan 3
[Sysname-vlan3] port gigabitethernet 1/4/0/2 gigabitethernet 2/4/0/2
# Create VLAN-interface 3, assign it an IP address, and enable ARP MAD on the interface.
[Sysname-Vlan-interface3] mad arp enable
[Sysname-Vlan-interface3] ip address 192.168.2.1 24
CAUTION
CAUTION:
<DeviceC> system-view
[DeviceC] stp global enable
[DeviceC-mst-region] region-name arpmad
[DeviceC-mst-region] instance 1 vlan 3
[DeviceC-mst-region] quit
# Create VLAN 3, and add GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2 to VLAN 3.
[DeviceC] vlan 3
[DeviceC-vlan3] port gigabitethernet 4/0/1 gigabitethernet 4/0/2
[DeviceC-vlan3] quit
ND MAD-enabled IRF configuration example for a two-chassis IRF fabric
As shown in Figure 19, set up a two-chassis IRF fabric at the distribution layer of the enterprise network.
·     Configure ND MAD for the IRF fabric and use Device C as an intermediate device. Device C can come from any vendor.
Figure 19 Network diagram
[Sysname] quit
<Sysname> save
# Enable IRF mode.
 Please wait...
Slot 1:
[Sysname] quit
<Sysname> save
# Connect the two devices as shown in Figure 19.
 Please wait...
Slot 1:
3.     Configure ND MAD on the IRF fabric:
# Enable the spanning tree feature globally, and map the ND MAD VLAN to MSTI 1 in the MST region.
[Sysname-mst-region] region-name ndmad
[Sysname] vlan 3
# Create VLAN-interface 3, assign it an IP address, and enable ND MAD on the interface.
[Sysname-Vlan-interface3] ipv6 address 2001::1 64
[Sysname-Vlan-interface3] mad nd enable
CAUTION
CAUTION:
[DeviceC-mst-region] region-name ndmad
[DeviceC] vlan 3
Configuration example for restoring standalone mode
Break the IRF fabric in Figure 20, and change the operating mode of Device A and Device B from IRF to standalone.
Figure 20 Network diagram
1.     Identify the master.
<IRF> display irf
MemberID  Slot  Role   Priority   CPU-Mac         Description
 *+1      0     Master  1         00e0-fc0f-8C01  DeviceA
   1      1     Standby 1         00e0-fc0f-8c02  DeviceA
   2      0     Standby 1         00e0-fc0f-15e1  DeviceB
   2      1     Standby 1         00e0-fc0f-15e2  DeviceB
 The Bridge MAC of the IRF is: 0000-fc00-313e
 Auto upgrade                : no
 Mac persistent              : always
 Domain ID                   : 0
 Auto merge                  : yes
 IRF mode                    : normal
The output shows that Device A is the master.
2.     Examine the configuration for VLAN interfaces.
If a VLAN interface has member ports on different member devices, change the IP address for the interface on each device to be unique.
3.     Shut down IRF physical interfaces to disconnect all IRF links. In this example, shut down Ten-GigabitEthernet 1/3/0/1.
<IRF> system-view
[IRF] interface ten-gigabitethernet 1/3/0/1
[IRF-Ten-GigabitEthernet1/3/0/1] shutdown
[IRF-Ten-GigabitEthernet1/3/0/1] quit
4.     Save the configuration.
[IRF] save
 Validating file. Please wait.....................................
 The current configuration is saved to the active main board successfully.
 Configuration is saved to device successfully.
5.     Change the operating mode of Device A to standalone.
[IRF] undo chassis convert mode
 The device will switch to stand-alone mode and reboot. You are recommended to save the current running configuration and specify the configuration file for the next startup. Continue? [Y/N]:y
 Do you want to convert the content of the next startup configuration file flash:/startup.cfg to make it available in stand-alone mode? [Y/N]:y
 Saving the converted configuration file to main board succeeded.
Chassis 1 Slot 1:
Device A automatically reboots to complete the operating mode change.
6.     Log in to Device B and change its operating mode to standalone.
<IRF> system-view
Chassis 2 Slot 1:
Device B automatically reboots to complete the operating mode change.
Four-chassis IRF fabric configuration example
As shown in Figure 22, set up a four-chassis IRF fabric at the access layer of the enterprise network.
Figure 21 Network diagram before IRF deployment
Figure 22 Network diagram after IRF deployment
IMPORTANT
IMPORTANT:
# Assign member ID 1 and priority 12 to Device A.
[Sysname] irf priority 12
# Bind Ten-GigabitEthernet 3/0/2 and Ten-GigabitEthernet 3/0/1 to IRF-port 1 and IRF-port 2, respectively.
[Sysname-irf-port1] port group interface ten-gigabitethernet 3/0/2
[Sysname] save
# Enable IRF mode.
 Please wait...
Slot 1:
# Assign member ID 2 and member priority 26 to Device B.
[Sysname] irf priority 26
# Bind Ten-GigabitEthernet 3/0/1 and Ten-GigabitEthernet 3/0/2 to IRF-port 1 and IRF-port 2, respectively.
[Sysname-irf-port2] port group interface ten-gigabitethernet 3/0/2
[Sysname] save
# Connect Device B to Device A, as shown in Figure 22.
 Please wait...
Slot 1:
3.     Configure Device C:
# Assign member ID 3 and member priority 6 to Device C.
[Sysname] irf member 3
[Sysname] irf priority 6
[Sysname] save
# Connect Device C to Device B, as shown in Figure 22.
# Enable IRF mode on Device C.
 Please wait...
Slot 1:
Device C reboots to join the IRF fabric.
4.     Configure Device D:
# Assign member ID 4 and member priority 2 to Device D.
[Sysname] irf member 4
[Sysname] save
# Connect Device D to Device A and Device C, as shown in Figure 22.
# Enable IRF mode on Device D.
 Please wait...
Slot 1:
Device D reboots to join the IRF fabric. A four-chassis IRF fabric is formed.
5.     Configure LACP MAD, BFD MAD, ARP MAD, or ND MAD in the IRF fabric, as described in the previous configuration examples. (Details not shown.)
Overview
IRF 3 integrates multiple lower-layer devices with a higher-layer IRF fabric to provide high-density, low-cost connectivity at the access layer.
In an IRF 3 system, the higher-layer IRF fabric is called the parent fabric and the lower-layer devices are called port extenders (PEXs). You can manage and configure the PEXs from the parent fabric as if they were interface cards on the parent fabric.
Typically, IRF 3 works at the access layer of data centers. As shown in Figure 23, the access layer of a network is virtualized into an IRF 3 system. The system contains one parent fabric (a two-chassis IRF fabric) and multiple PEXs to provide connectivity for servers and hosts.
Figure 23 IRF 3 application scenario
IRF 3 provides the following benefits:
·     Simplified topologyDevices in an IRF 3 system appear as one node. For redundancy and load balancing, a downstream or upstream device can connect to the IRF 3 system through multichassis link aggregation. Together with link aggregation, IRF 3 creates a loop-free Layer 2 network. The spanning tree feature is not needed among devices in the IRF 3 system or on the link aggregations. IRF 3 also simplifies the Layer 3 network topology because it reduces the number of routing peers. The network topology does not change when a device is added to or removed from the IRF 3 system.
·     Single point of managementAn IRF 3 system is accessible at a single IP address on the network. You can use this IP address to log in through any network port to manage all the devices in the system. For an SNMP NMS, an IRF 3 system is one managed network node.
·     Network scalability and resiliency—You can increase the number of ports in an IRF 3 system by adding PEXs without changing network topology.
·     High availability—PEXs have multiple high-speed physical interfaces for uplink connectivity to the parent fabric. The links on these ports are aggregated and load balanced automatically.
·     Decreased TCO—IRF 3 decreases hardware investments and management costs. In an IRF 3 system, the parent fabric performs all the management and routing functions, and the PEXs only forwards traffic. You can add low-performance devices as PEXs to an IRF 3 system for network scalability. In addition, PEXs can load software and synchronize configuration from the parent fabric without administrative intervention.
Network topology
The following are the methods to connect PEXs to the parent fabric:
·     One tier of PEXs—Each PEX is directly connected to the parent fabric. PEXs cannot be connected to each other, as shown in Figure 24.
·     Two-tier PEX stack—One tier of PEXs (tier-2 PEXs) are attached to the tier-1 PEXs (the PEXs that are directly connected to the parent fabric). The two tiers of PEXs are connected and configured to form a PEX stack. Figure 25 shows a typical PEX stack access topology.
Figure 24 IRF 3 network topology with one tier of PEXs
Figure 25 IRF 3 network topology (PEX stack)
Basic concepts
IRF 3 includes IRF concepts and adds the concepts in this section. For more information about IRF concepts, see "Setting up an IRF fabric."
IRF 3 roles
The devices in an IRF 3 system have the following roles:
·     Parent fabric—Higher-layer single-chassis or multichassis IRF fabric that controls the entire IRF 3 system, including PEXs. Each IRF 3 system has one parent fabric.
·     Parent deviceMember devices in the parent fabric.
·     Master deviceControls and manages the entire IRF 3 system, including all parent devices and PEXs. The master device in the IRF fabric is also the master device for the IRF 3 system. You configure all devices (including PEXs and parent devices) from the master device.
·     PEX—Operates as I/O modules of the parent fabric to receive and transmit traffic. All forwarding decisions are made on the parent fabric. Table 3 shows the operating states of PEXs.
Table 3 PEX operating states
Loading
The PEX is starting up. To avoid problems, do not reboot a PEX while it is in Loading state.
Online
The PEX has started up and registered with the parent fabric. You can configure and manage the PEX from the parent fabric.
Offline
Any of the following conditions exist:
·     The PEX has not started up.
·     The PEX has lost its uplink connectivity to the parent fabric.
·     The PEX configuration on the parent fabric is incomplete.
PEX port
A PEX port is a logical port created on the parent fabric for managing PEXs attached to the port.
In PEX independent access mode, you must create a unique PEX port for each PEX, and assign all physical interfaces connected to the PEX to the PEX port.
In PEX stack access mode, you must create a unique PEX port for each tier-1 PEX and its tier-2 PEX.
PEX port group
A PEX port group represents a PEX stack. The PEX ports that connect to the same PEX stack must be assigned to the same PEX port group. For example, the physical network topology of a PEX stack is parent device (PEX port 1)—PEX 100—PEX 101—PEX 102—PEX 103—(PEX port 2) parent device. To build this PEX stack, you must assign PEX port 1 and PEX port 2 to the same PEX port group.
PEX physical interface
PEX physical interfaces connect PEXs and the parent fabric.
You can set up multiple PEX links between the parent fabric and a PEX. These links aggregate automatically for backup and load balancing.
On the parent fabric, you must assign the PEX physical interfaces for one PEX to the same PEX port. On a PEX, you must connect all its PEX physical interfaces to the physical interfaces in the same PEX port.
Table 4 describes the states of PEX physical interfaces.
Table 4 PEX physical interface states
Forwarding
The PEX physical interface is operating correctly and can forward data traffic.
Down
The physical link is disconnected. The PEX physical interface cannot forward any packets.
Blocked
The PEX physical interface cannot forward any packets except for IRF 3 packets. The Blocked state is a transitional state between Forwarding and Down. A PEX physical interface changes to the Blocked state in the following situations:
·     Incorrect physical connection:
¡     The PEX has PEX links to more than one PEX port on the parent fabric.
¡     The PEX port on the parent fabric contains physical links to more than one PEX.
·     The data link is forced to the Blocked state. In the startup phase, the PEX blocks a PEX physical interface if the interface's physical link is up, but it is not used for loading startup software.
·     The physical state of the interface is up, but the PEX link to the parent fabric has been disconnected. The PEX and the parent fabric cannot receive IRF 3 heartbeat packets from each other.
Virtual slot number and virtual chassis
For management purposes, each PEX is assigned to a unique virtual chassis on the parent fabric. A PEX is managed as an interface card on its virtual chassis. The slot number for the PEX is fixed at 0.
The virtual chassis number and slot number are included as the first two segments of the interface numbers on the PEX. For example, a PEX has an interface numbered 1/0/1 before it is added to an IRF 3 system. The interface number changes to 100/0/0/1 after the PEX is added to chassis 100 in an IRF 3 system.
IRF 3 operating mechanisms
IRF 3 membership establishment
After you complete PEX configuration for a PEX, the master device monitors the PEX physical interfaces for the chassis number request from the PEX. The PEX uses the following process to join the IRF 3 system:
1.     Virtual chassis assignment:
a.     At startup, the PEX sends a chassis number request to the master device.
b.     The master device assigns the user-configured chassis number to the PEX.
2.     Software loading and PEX registration:
a.     The PEX checks the local storage medium for valid startup images.
b.     If the local startup images are valid, the PEX verifies their compatibility with the running software images on the master device:
-     If all the images are compatible, the PEX starts up with the local startup images.
-     If any incompatibility exists, the PEX goes to step c.
Steps a and b apply only to the S5130-EI, S5130-HI, and S6300 switches. For the switches to start up, you must make sure they have valid local startup images.
The S5120-28SC-HI and S5120-52SC-HI PEXs always request startup images from the master device.
c.     The PEX sends a startup software request to the master device.
d.     The master device provides the correct Boot ROM and startup software images to the PEX.
e.     The PEX loads the software images, and then automatically reboots to register with the master device.
-     An S5120-28SC-HI or S5120-52SC-HI PEX loads the software images without downloading the images to the local.
-     An S5130-EI, S5130-HI, or S6300 PEX downloads the software images to the local storage medium, and then loads the software images.
3.     Configuration synchronization:
a.     The parent device issues its running configuration to the PEX.
b.     The PEX runs with the configuration received from the master device instead of reading the configuration from its local startup configuration file.
4.     PEX link maintenance:
The master device and the PEX send heartbeat packets on the PEX links to detect link failure. You can determine whether a PEX link is available by checking the state of its physical interfaces.
Configuration management
An IRF 3 system manages all its settings (including settings for PEXs) on the master device. You can configure and manage PEXs only from the master device. The running configuration on the master device has all settings in the IRF 3 system, including settings for PEXs. When a PEX reboots or is added, the master device issues its running configuration to the PEX.
Data forwarding
The PEXs do not have local forwarding capability.
The PEXs send any incoming traffic to the parent fabric. The parent fabric makes the forwarding decisions and sends the traffic to the outgoing interfaces. Figure 26 shows the data forwarding model.
Figure 26 Data forwarding model
IRF fabric split handling
A PEX uses an independent mechanism to regularly detect the IRF split on the parent fabric. When the parent fabric splits into multiple IRF fabrics, a PEX selects one IRF fabric as its parent fabric, as follows:
1.     The PEX selects the IRF fabric that has the most members as the parent fabric.
2.     If the IRF fabrics have the same number of members, the PEX compares the member IDs of their masters. Then, the PEX selects the IRF fabric that has the lowest numbered master.
After selecting one IRF fabric as the parent fabric, the PEX blocks all PEX links to other IRF fabrics.
These conflict handling rules are the same as LACP MAD. As a best practice, use LACP MAD on the parent fabric to ensure that the PEX selects the same IRF fabric to forward traffic as IRF. If any other MAD mechanisms are used, the parent fabric selected by the PEX might be placed in Recovery state.
Ports on a PEX cannot be used for IRF MAD. When you configure MAD mechanisms, use ports on the parent fabric and devices that are not in the IRF 3 system.
H3C S7500E switches can only operate as parent devices. The following PEXs are available:
·     S5130-EI.
·     S5130-HI.
·     S6300.
·     S5120-28SC-HI.
·     S5120-52SC-HI.
IMPORTANT
IMPORTANT:
You can stack only the S5130-EI PEXs.
To connect to PEXs, you must purchase any of the following modules:
·     EC interface module: LSQM1TGS12EC0.
·     SC interface modules:
¡     LSQM2GP24TSSC0.
¡     LSQM2GP44TSSC0.
¡     LSQM2GT24PTSSC0.
¡     LSQM2GT24TSSC0.
·     SF interface module: LSQM2TGS16SF0.
For a successful IRF 3 system setup, read the configuration restrictions and guidelines carefully before you connect and set up a PEX.
Parent fabric size restrictions
Number of member devices cannot exceed two for the parent fabric.
PEX physical interface requirements
PEX physical interface selection
Make sure the PEX physical interfaces at the two ends of a PEX link are at the same rate.
Use Table 5 to identify physical interfaces for PEX links.
Table 5 Candidate PEX physical interfaces
Switch model
Remarks
S7500E
Use the SFP+ and QSFP+ ports on the interface modules listed in "Hardware compatibility" for PEX links.
If you use the SFP+ ports in a group (see "SFP+ port grouping rules") for PEX links, follow these restrictions and guidelines:
·     You must use all or none of the ports for PEX links. The SFP+ ports can be assigned to different PEX ports.
·     To shut down or bring up any SFP+ ports in the group, you must make sure all the SFP+ ports have been assigned to or removed from PEX ports.
·     S5120-28SC-HI
·     S5120-52SC-HI
Use the SFP+ ports on the front panel for PEX links.
If you use an S5120-28SC-HI or S5120-52SC-HI switch as a PEX, follow these restrictions and guidelines:
·     Do not install any expansion interface cards except the 2-port SFP+ expansion interface cards (LSWM2SP2PM).
·     Do not connect the switch with SFP+ DAC cables.
·     Do not use SFP-XG-LX220-MM1310 transceiver modules.
·     Do not connect ports on an expansion interface card to the parent fabric.
S6300 series switches
Use the following physical interfaces for PEX links:
·     The highest numbered four SFP+ ports on the front panel.
·     QSFP+ ports on the front panel.
Do not use both SFP+ and QSFP+ ports for PEX links.
S5130-EI series switches
Use SFP+ ports on the front panel for PEX links.
N/A
·     S5130-54C-HI
·     S5130-54C-PWR-HI
·     S5130-34C-HI
·     S5130-30F-HI
·     S5130-30C-PWR-HI
·     S5130-30C-HI
If you use an S5130-HI switch as a PEX, follow these restrictions and guidelines:
·     Do not install any expansion interface cards except for expansion interface cards LSWM2SP2PM and LSWM2XGT2PM.
The SFP+ ports on the LSQM1TGS12EC0 interface module are grouped by port number in order, starting from 1. Each group contains four ports.
The SFP+ ports on the LSQM2TGS16SF0 interface module are divided into the following groups:
·     Ports 1, 2, 15, and 16.
·     Ports 3 through 5.
·     Ports 6 through 8.
·     Ports 9 through 11.
·     Ports 12 through 14.
PEX physical interface shutdown restrictions on PEXs
The shutdown command cannot be executed on any ports of PEXs for PEX links.
PEX cabling for one tier of PEXs
When you connect one tier of PEXs to the parent fabric, follow these cabling restrictions and guidelines:
·     On the parent fabric side, connect a PEX port's all physical interfaces to the same PEX.
·     On the PEX side, connect all its PEX physical interfaces to the physical interfaces in the same PEX port.
·     Do not connect PEXs to each other.
·     IRF 3 only supports one layer of PEXs. You cannot attach a lower-layer PEX to a higher-layer PEX.
·     Do not attach a lower-layer network device to a PEX.
PEX cabling for PEX stack
When you connect the parent fabric and a PEX stack, follow these cabling restrictions and guidelines:
·     PEXs and PEX stacks can coexist. However, PEXs of the same PEX port must use the same connection method.
·     A PEX stack can contain a maximum of two tiers of PEXs. Each tier-1 PEX can be connected to a maximum of one tier-2 PEX.
·     Connect PEXs in the same stack in daisy-chain topology. Do not connect PEXs of different stacks to each other.
·     On the parent fabric side, connect a PEX port's all physical interfaces to the same tier-1 PEX.
·     On the tier-1 PEX side, connect all its PEX physical interfaces to the physical interfaces in the same PEX port.
IRF member ID restrictions
In an IRF 3 system, change the member IDs of parent devices with caution. If the member ID of a parent device is changed, you must reconfigure the PEX port bindings on the parent device.
sFlow compatibility
sFlow is not available on PEX physical interfaces.
Cross-PEX link aggregation
Ports on PEXs of different switch series cannot be aggregated into one aggregation group.
Feature availability of PEXs
Some software features supported on the parent devices are not available for PEXs. For more information about these features, see the software release notes for the parent devices.
IRF 3 system setup and configuration task list
To set up an IRF 3 system with one tier of PEXs, use the following procedure:
Tasks at a glance
Remarks
1.     (Required.) Planning the IRF 3 system setup
N/A
2.     (Required.) Setting up the parent fabric
The parent fabric must be a single-chassis or multichassis IRF fabric.
3.     (Required.) Enabling IRF 3 capability on the parent device
N/A
4.     (Required.) Configuring IRF 3 settings on the parent fabric for PEXs:
a.     Creating PEX ports
b.     Assigning virtual chassis numbers to one tier of PEXs
c.     Assigning physical interfaces to PEX ports
d.     Configuring PEX link load sharing mode
e.     Specifying startup software images for PEXs
Specifying startup software images for PEXs is optional if the PEXs have storage media and can load PEX-capable startup software images locally.
Configuring PEX link load sharing mode is optional.
5.     (Required.) Connecting the PEXs to the parent fabric
Make sure the PEX cabling is consistent with the PEX physical interface assignment on the parent fabric.
PEXs join the IRF 3 system when PEX links come up.
To remove PEXs from the IRF 3 system, see "Removing PEXs from an IRF 3 system."
To set up an IRF 3 system with PEX stacks, use the following procedure:
Tasks at a glance
Remarks
N/A
2.     (Optional.) Setting up the parent fabric
N/A
b.     Assigning virtual chassis numbers to a PEX stack
c.     Creating a PEX port group and assigning the PEX ports of a PEX stack to the group
d.     Assigning physical interfaces to PEX ports
e.     Configuring PEX link load sharing mode
f.     Specifying startup software images for PEXs
Make sure the PEX cabling is consistent with the PEX physical interface assignment on the parent fabric. Connect PEXs to each other for the PEX stack.
Consider the following items when you plan an IRF 3 system:
·     Hardware compatibility and restrictions.
·     IRF 3 system size. (See "Enabling IRF 3 capability on the parent device.")
·     Parent devices and PEXs.
·     PEX access mode.
·     PEX physical interfaces and cabling scheme.
·     Virtual chassis assignment for PEXs.
The plan must meet the requirements described in "Hardware compatibility" and "Configuration restrictions and guidelines."
For more information about hardware and cabling, see the installation guide for the device.
To set up an H3C S7500E parent fabric, use the procedure described in "Setting up an IRF fabric."
For a device to operate as a parent device, you must enable its IRF 3 capability by setting the IRF mode to enhanced or light. The IRF mode determines the number of PEXs that an IRF 3 system can contain, as shown in Table 6.
Table 6 Comparison of enhanced-mode and light-mode IRF 3 systems
Mode
Maximum PEXs
Remarks
Enhanced
60, in which the number of S5120-28SC-HI and S5120-52SC-HI PEXs cannot exceed 30.
In the current software version, the total number of PEXs cannot exceed 30.
To use this mode, the interface modules on the parent fabric can only be any of the following modules:
·     EC interface modules.
¡     LSQ1QGS4SC0.
¡     LSQM2GP24TSSC0.
¡     LSQM2GP44TSSC0.
¡     LSQM2GT24PTSSC0.
¡     LSQM2GT24TSSC0.
¡     LSQM2GT48SC0.
¡     LSQM4GV48SC0.
·     SF interface modules.
·     OAP module: LSU1WCME0.
Other interface modules cannot start up correctly when the parent fabric is operating in enhanced IRF mode.
Light
30
Make sure the parent fabric does not have member devices that are assigned the member ID 3 or 4.
To use PEX stacks, you must set the IRF mode to light.
The parent devices must operate in the same IRF mode.
To enable IRF 3 capability:
Step
Remarks
N/A
2.     Enable enhanced or light IRF mode.
irf mode { enhanced | light }
The default IRF mode is normal. IRF capability is enabled, and IRF 3 capability is disabled.
If PEX stack access will be used, you must set the IRF operating mode to light.
To disable IRF 3 capability, use the following commands:
·     irf mode normal.
·     undo irf mode { enhanced | light }.
3.     Return to user view.
N/A
4.     Save the running configuration.
save
N/A
5.     Reboot the system for the setting to take effect.
reboot
N/A
Creating PEX ports
To connect one tier of PEXs, you must create a PEX port for each PEX. To connect a PEX stack, you must create a PEX port for each tier-1 PEX and its attached tier-2 PEX.
To create a PEX port:
Step
Remarks
N/A
2.     Create a PEX port and enter PEX port view.
pex-port pex-port-id
By default, no PEX ports have been created.
You can create a maximum of 120 PEX ports.
3.     (Optional.) Configure a port description.
The default PEX port description is pex-port pex-number, for example, pex-port 0002.
Perform this task if you are connecting one tier of PEXs to the parent fabric.
You must assign a unique virtual chassis number to each PEX.
You cannot change the chassis number of a PEX while it is starting up.
An operating PEX will reboot if you change or remove its chassis number.
To assign a virtual chassis number to a PEX:
Step
Remarks
N/A
2.     Enter PEX port view.
N/A
3.     Assign a virtual chassis number to the PEX.
associate chassis-number
By default, no virtual chassis numbers are assigned to PEXs.
If the PEX is already assigned a chassis number, the new chassis number replaces the old number.
On each PEX port, you can configure one tier-1 PEX and one tier-2 PEX.
The PEX will reboot if you change or delete its virtual chassis number after the PEX has started up.
Step
Remarks
N/A
N/A
3.     Assign a virtual chassis number to the tier-1 PEX.
4.     Assign a virtual chassis number to the tier-2 PEX.
associate order chassis-number
To change the assigned number, you must first remove the old number.
To set up a PEX stack, you must assign all its PEX ports to the same PEX port group. For example, the physical topology of a PEX stack is (PEX port 1)—PEX 100—PEX 101—PEX 102—PEX 103—(PEX port 2). To set up the PEX stack, you must assign PEX port 1 and PEX port 2 to the same PEX port group.
When you assign PEX ports to a PEX port group, follow these restrictions and guidelines:
·     The PEX ports must exist.
·     A PEX port can be assigned only to one PEX port group.
·     The assignment fails if the number of PEX ports has reached the upper limit for the PEX port group.
To create a PEX port group and assign PEX ports to the group:
Step
Remarks
N/A
2.     Create a PEX port group and enter PEX port group view.
pex-port-group group-id
By default, no PEX port groups exist.
The device supports a maximum of 60 PEX port groups.
3.     Assign a PEX port to the PEX port group.
member pex-port pex-port-id
By default, a PEX port group does not contain PEX ports.
Repeat this step to assign multiple PEX ports to the PEX port group.
A PEX port must have a minimum of one physical interface in Forwarding state for its PEXs to communicate with the parent fabric correctly. If a PEX port has only one physical interface in Forwarding state, the attached PEXs will reboot when any of the following events occur:
·     The interface is removed from the PEX port.
·     The interface goes down.
For more information about physical interfaces that can be used for PEX links, see "PEX physical interface requirements."
To assign physical interfaces to a PEX port:
Step
Remarks
N/A
2.     Enter interface view or interface range view.
24>
To configure one interface, enter interface view.
To configure a range of interfaces, enter interface range view.
3.     Shut down the physical interface or interfaces.
shutdown
By default, all physical interfaces are up.
N/A
5.     Enter PEX port view.
N/A
6.     Assign a physical interface to the PEX port.
port group interface interface-type interface-number
By default, a PEX port does not contain physical interfaces.
Repeat this step to assign multiple physical interfaces to the PEX port. A physical interface's configuration is automatically restored to the default after you assign the interface to a PEX port.
Each PEX port can have a maximum of six physical interfaces.
N/A
8.     Enter interface view or interface range view.
24>
N/A
9.     Bring up the physical interface or interfaces.
N/A
On a PEX port, traffic is balanced across its physical links.
You can configure the PEX port to distribute traffic based on any combination of the following criteria:
·     Source IP address.
·     Source MAC address.
·     Destination IP address.
·     Destination MAC address.
·     Ingress port.
Configure the PEX link load sharing mode for PEX links in system view or PEX port view:
·     In system view, the configuration is global and takes effect on all PEX ports.
·     In PEX port view, the configuration is port specific and takes effect only on the specified PEX port.
A PEX port preferentially uses the port-specific load sharing mode. If no port-specific load sharing mode is available, the PEX port uses the global load sharing mode.
Step
Remarks
N/A
2.     Configure the global PEX link load sharing mode.
pex-port global load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
Before you configure a port-specific load sharing mode, make sure you have bound a minimum of one physical interface to the PEX port.
To configure a port-specific load sharing mode for a PEX port:
Step
Remarks
N/A
N/A
pex-port load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
PEXs must load startup software images from the parent fabric when they join the IRF 3 system for the first time.
To specify startup software images for PEXs to load from the parent fabric:
Remarks
Specify startup software images for PEXs.
·     Specify .bin image files:
boot-loader pex pex-model file boot boot-package system system-package [ feature feature-package&<1-30> ]
·     Specify an .ipe image files:
boot-loader pex pex-model file ipe ipe-filename
To upgrade software for PEXs in the IRF 3 system, see Fundamentals Configuration Guide.
Connect all the PEX physical interfaces to the physical interfaces assigned to the same PEX port on the parent fabric.
For more information about connection restrictions and guidelines, see "PEX cabling for one tier of PEXs" and "PEX cabling for PEX stack."
Step
Remarks
N/A
2.     Change PEXs to switch mode.
pex working-mode switch { all | chassis chassis-number slot slot-number1 [ to slot-number2 ] }
PEXs operate in PEX mode in the IRF 3 system.
The switch mode change will take effect at reboot.
To cancel the change, configure the undo pex working-mode switch { all | chassis chassis-number slot slot-number1 [ to slot-number2 ] } command before the reboot.
In switch mode, PEXs operate independently from the parent fabric and cannot be managed from the parent fabric.
N/A
4.     Reboot each PEX that is placed in switch mode.
reboot chassis chassis-number
Repeat this step to reboot all PEXs that are placed in switch mode. The devices will be removed from the IRF 3 system and operate as independent switches.
IMPORTANT IMPORTANT:
After the removed devices reboot, the mode change is included in their running configuration but not in their startup configuration files. To prevent the original mode from being restored when another reboot occurs, you must save the configuration on each removed device.
5.     Enter system view.
N/A
6.     Enter interface view or interface range view.
·     Enter interface view:
·     Enter interface range view:
interface range { interface-type interface-number [ to interface-type interface-number ] } &<1-24>
Specify all physical interfaces that are connected to the removed PEXs.
7.     Shut down the physical interfaces.
shutdown
N/A
9.     Remove the PEX settings for a removed PEX.
a.     Enter PEX port view.
b.     Remove each physical interface from the PEX port.
undo port group interface interface-type interface-number
c.     Return to system view.
d.     Remove the PEX port.
undo pex-port pex-port-id
Repeat this step to remove the PEX settings for each removed PEX.
10.     Enter interface view or interface range view.
N/A
11.     Bring up the physical interfaces.
N/A
Displaying and maintaining PEXs
Display PEX port information.
display pex-port [ pex-id ] [ verbose ]
Display the operating mode settings for PEXs in the IRF 3 system.
display pex working-mode { all | chassis chassis-number slot slot-number1 [ to slot-number2 ] }
Display the PEX startup software images stored on the parent fabric.
display boot-loader pex [ pex-model ]
Display PEX topology information.
display pex-port [ pex-port-id ] topology
For more information about the display boot-loader pex command, see Fundamentals Command Reference.
IRF 3 system configuration examples
IRF 3 system with one tier of PEXs configuration example
As shown in Figure 27, set up an IRF 3 system that contains a two-chassis H3C S7500E parent fabric and one tier of two S6300-52QF PEXs.
Figure 27 Network diagram
1.     Configure the parent fabric:
# Set up a two-chassis S7500E IRF fabric, as described in "Setting up an IRF fabric." (Details not shown.)
# Enable enhanced IRF mode on the IRF fabric.
[Sysname] irf mode enhanced
[Sysname] quit
<Sysname> reboot
# Create PEX port 1 for PEX 1.
[Sysname] pex-port 1
# Assign virtual chassis number 100 to PEX 1.
[Sysname-pex-port1] associate 100
[Sysname-pex-port1] quit
# Shut down two ranges of ports: Ten-GigabitEthernet 1/2/0/1 through Ten-GigabitEthernet 1/2/0/4, and Ten-GigabitEthernet 2/2/0/1 through Ten-GigabitEthernet 2/2/0/4.
[Sysname] interface range ten-gigabitethernet 1/2/0/1 to ten-gigabitethernet 1/2/0/4 ten-gigabitethernet 2/2/0/1 to ten-gigabitethernet 2/2/0/4
[Sysname-if-range] shutdown
[Sysname-if-range] quit
# Assign Ten-GigabitEthernet 1/2/0/1 and Ten-GigabitEthernet 2/2/0/1 to PEX port 1.
[Sysname-pex-port1] port group interface ten-gigabitethernet 1/2/0/1
[Sysname-pex-port1] port group interface ten-gigabitethernet 2/2/0/1
# Configure the description of PEX port 1 as connect-to-pex1.
[Sysname-pex-port1] description connect-to-pex1
# Create PEX port 2 for PEX 2.
[Sysname] pex-port 2
# Assign virtual chassis number 101 to PEX 2.
[Sysname-pex-port2] associate 101
# Assign Ten-GigabitEthernet 1/2/0/2 and Ten-GigabitEthernet 2/2/0/2 to PEX port 2.
[Sysname-pex-port2] port group interface ten-gigabitethernet 1/2/0/2
[Sysname-pex-port2] port group interface ten-gigabitethernet 2/2/0/2
# Configure the description of PEX port 2 as connect-to-pex2.
[Sysname-pex-port2] description connect-to-pex2
[Sysname-pex-port2] quit
# Bind all idle physical interfaces in the same group as the PEX physical interfaces to PEX port 1 and PEX port 2.
[Sysname-pex-port1] port group interface ten-gigabitethernet 1/2/0/3
[Sysname-pex-port1] port group interface ten-gigabitethernet 1/2/0/4
[Sysname-pex-port2] port group interface ten-gigabitethernet 2/2/0/3
[Sysname-pex-port2] port group interface ten-gigabitethernet 2/2/0/4
To shut down or bring up any SFP+ ports in a group, you must make sure all the SFP+ ports have been assigned to or removed from PEX ports.
# Bring up the ports Ten-GigabitEthernet 1/2/0/1 through Ten-GigabitEthernet 1/2/0/4 and Ten-GigabitEthernet 2/2/0/1 through Ten-GigabitEthernet 2/2/0/4.
[Sysname-if-range] undo shutdown
[Sysname-if-range] return
<Sysname> save
# Use FTP or TFTP to transfer PEX startup software image file to the parent device. (Details not shown.)
You must store the image file in the root directory of a file system on the parent fabric.
# Specify the file as the startup image file for S6300-52QF switches.
<Sysname> boot-loader pex PEX-S6300 file ipe flash:/S6300PEX.ipe main
Verifying the IPE file and the images....Done.
Decompressing file S6300PEX-CMW710-BOOT-A0045P57.bin to flash:/S6300PEX-CMW710-BOOT-A0045P57.bin.....................Done.
Decompressing file S6300PEX-CMW710-SYSTEM-A0045P57.bin to flash:/S6300PEX-CMW710-SYSTEM-A0045P57.bin............................................................................................................Done.
The system reads the images from the file after they pass verification.
2.     Connect the PEXs to the parent fabric, as shown in Figure 27. (Details not shown.)
3.     Run PEX-capable Boot ROM and Comware images on the switches to be used as PEXs. For software versions that support PEX, see the release notes for the switches. (Details not shown.)
4.     Use one of the following methods to change the operating mode to PEX for the switches to be used as PEXs:
¡     Change the operating mode to PEX from the EXTENDED BOOT MENU:
# Reboot PEX 1 and press Ctrl+B at the prompt. If you have set a password, you must enter the correct password to access the EXTENDED BOOT MENU.
Starting......
Press Ctrl+D to access BASIC BOOT MENU
*                     H3C S6300-52QF BOOTROM, Version 135                      *
Copyright (c) 2004-2014 Hangzhou H3C Technologies Co., Ltd.
Creation Date   : Jul 15 2014,19:17:00
CPU Clock Speed : 1000MHz
Memory Size     : 2048MB
Flash Size      : 512MB
CPLD Version    : 002/002
PCB Version     : Ver.B
Mac Address     : 70F96D3DBB2B
PEX mode is disabled.
Press Ctrl+B to access EXTENDED BOOT MENU...0
Password recovery capability is enabled.
# In the EXTENDED BOOT MENU, press Ctrl+Y to change the operating mode to PEX.
   EXTENDED BOOT MENU
1. Download image to flash
2. Select image to boot
3. Display all files in flash
4. Delete file from flash
5. Restore to factory default configuration
6. Enter BootRom upgrade menu
7. Skip current system configuration
8. Set switch startup mode
0. Reboot
Ctrl+Z: Access EXTENDED ASSISTANT MENU
Ctrl+F: Format file system
Ctrl+P: Change authentication for console login
Ctrl+Y: Change Work Mode
Ctrl+R: Download image to SDRAM and run
Enter your choice(0-8):
# Enter Y to confirm the operating mode change.
PEX mode is disabled. Are you sure you want to enable PEX mode? [Y/N]Y
Mode changed successfully
# Enter 0 in the EXTENDED BOOT MENU to reboot PEX 1.
¡     Change the operating mode to PEX from the CLI:
# Enter system view.
# Change the operating mode to PEX.
[Sysname] pex working-mode pex slot 1
Are you sure you want to change to the PEX mode? [Y/N]: y
If you want to change parent device to PEX mode or change PEX device to switch mode, you must reboot the device.
Reboot PEX 1 for the change to take effect.
At startup, PEX 1 loads the startup images from the parent fabric.
Flash Size      : 512MB
PCB Version     : Ver.B
Mac Address     : 70BAEF5CA028
PEX mode is enabled.
Loading the main image files...
Loading file flash:/s5800v2_s6300pex-cmw710-system-e2130l15.bin..........................................................................................................................................................................................................................................................................Done.
Loading file flash:/s5800v2_s6300pex-cmw710-boot-e2130l15.bin........................................................................Done.
Image file flash:/s5800v2_s6300pex-cmw710-boot-e2130l15.bin is
self-decompressing...........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Done.
System is starting...
Started downloading S6300PEX-CMW710-SYSTEM-A0045P57.bin
Writing to flash
Started downloading S6300PEX-CMW710-BOOT-A0045P57.bin
Writing to flash
Starting......
Flash Size      : 512MB
PCB Version     : Ver.B
Loading file flash:/S6300PEX-CMW710-SYSTEM-A0045P57.bin..................................................................................................................................................................................................................................................................................Done.
Loading file flash:/S6300PEX-CMW710-BOOT-A0045P57.bin..............................................................................Done.
Image file flash:/S6300PEX-CMW710-BOOT-A0045P57.bin is self-decompressing.........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Done.
Cryptographic algorithms tests passed.
Done.
While the PEX is starting up, the parent fabric displays messages about PEX port state changes, PEX registration, and PEX startup.
%Nov 12 10:32:43:326 2014 H3C PEX/4/PEX_LINK_BLOCK: -MDC=1-Chassis=1-Slot=2; Status of Ten-GigabitEthernet1/2/0/1 changed from down to blocked.
%Nov 12 10:32:43:326 2014 H3C PEX/4/PEX_LINK_BLOCK: -MDC=1-Chassis=2-Slot=2; Status of Ten-GigabitEthernet2/2/0/1 changed from down to blocked.
%Nov 12 10:32:43:352 2014 H3C IFNET/3/PHY_UPDOWN: -MDC=1; Ten-GigabitEthernet1/2/0/1 link status is up.
%Nov 12 10:32:43:352 2014 H3C IFNET/3/PHY_UPDOWN: -MDC=1; Ten-GigabitEthernet2/2/0/1 link status is up.
%Nov 12 10:32:43:353 2014 H3C IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol on the interface Ten-GigabitEthernet1/2/0/1 is up.
%Nov 12 10:32:43:353 2014 H3C IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol on the interface Ten-GigabitEthernet2/2/0/1 is up.
%Nov 12 10:32:52:753 2014 H3C PEX/5/PEX_REG_REQUEST: -MDC=1; Received a REGISTER request on PEX port 1 from PEX (chassis 100).
%Nov 12 10:32:52:766 2014 H3C DEV/4/BOARD_LOADING: -MDC=1; Board in chassis 100 slot 0 is loading software images.
%Nov 12 10:32:52:742 2014 H3C PEX/5/PEX_LINK_FORWARD: -MDC=1-Chassis=1-Slot=2; Status of Ten-GigabitEthernet1/2/0/1 changed from blocked to forwarding.
%Nov 12 10:32:52:742 2014 H3C PEX/5/PEX_LINK_FORWARD: -MDC=1-Chassis=2-Slot=2; Status of Ten-GigabitEthernet2/2/0/1 changed from blocked to forwarding.
%Nov 12 10:33:09:127 2014 H3C DEV/2/BOARD_STATE_FAULT: -MDC=1; Board state changed to Fault on chassis 100 slot 0, type is unknown.
%Nov 12 10:33:21:290 2014 H3C DEV/5/BOARD_STATE_NORMAL: -MDC=1; Board state changed to Normal on chassis 100 slot 0, type is S6300-52QF.
%Nov 12 10:33:27:754 2014 H3C PEX/5/PEX_REG_JOININ: -MDC=1; PEX (chassis 100) registered successfully on PEX port 1.
%Nov 12 10:33:28:645 2014 H3C IFNET/3/PHY_UPDOWN: -MDC=1; Pex100/0/0/51 link status is up.
%Nov 12 10:33:28:645 2014 H3C IFNET/3/PHY_UPDOWN: -MDC=1; Pex100/0/0/52 link status is up.
%Nov 12 10:33:28:647 2014 H3C IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol on the interface Pex100/0/0/51 is up.
%Nov 12 10:33:28:647 2014 H3C IFNET/5/LINK_UPDOWN: -MDC=1; Line protocol on the interface Pex100/0/0/52 is up.
5.     Configure PEX 2 in the same way PEX 1 is configured. (Details not shown.)
# Verify that the IRF 3 system has been set up. You can configure the PEXs from the parent fabric if the PEXs are in Online state and each have a minimum of one PEX link in Forwarding state.
<Sysname> display pex-port verbose
PEX port 1:
  Description: connnect-to-pex1
  Associated ID: Chassis 100
    Chassis       PEX status
    *100          Online
  Member interfaces: 4
    Member interface        Status               Peer interface
    XGE1/2/0/1              Forwarding           PEX100/0/0/51
    XGE1/2/0/3              Down                 --
    XGE1/2/0/4              Down                 --
    XGE2/2/0/1              Forwarding           PEX100/0/0/52
PEX port 2:
  Description: connnect-to-pex2
  Associated ID: Chassis 101
    Chassis       PEX status
    *101          Online
    XGE1/2/0/2              Forwarding           PEX101/0/0/52
    XGE2/2/0/2              Forwarding           PEX101/0/0/51
    XGE2/2/0/3              Down                 --
    XGE2/2/0/4              Down                 --
IRF 3 system with a PEX stack configuration example
As shown in Figure 28, set up an IRF 3 system that contains a two-chassis parent fabric and a stack of four S5130-EI PEXs.
Figure 28 Network diagram
Configuration procedure
# Set up a two-chassis IRF fabric, as described in "Setting up an IRF fabric." (Details not shown.)
# Create PEX port 1.
# Assign virtual chassis number 100 to PEX 1 at tier 1.
# Assign virtual chassis number 101 to PEX 2 (the tier-2 PEX attached to PEX 1).
[Sysname-pex-port1] associate order 101
# Shut down two ranges of ports: Ten-GigabitEthernet 1/1/0/1 through Ten-GigabitEthernet 1/1/0/4, and Ten-GigabitEthernet 2/1/0/1 through Ten-GigabitEthernet 2/1/0/4.
[Sysname] interface range ten-gigabitethernet 1/1/0/1 to ten-gigabitethernet 1/1/0/4 ten-gigabitethernet 2/1/0/1 to ten-gigabitethernet 2/1/0/4
# Assign Ten-GigabitEthernet 1/1/0/1 and Ten-GigabitEthernet 2/1/0/1 to PEX port 1.
[Sysname-pex-port1] port group interface ten-gigabitethernet 1/1/0/1
[Sysname-pex-port1] port group interface ten-gigabitethernet 2/1/0/1
# Create PEX port 2.
# Assign virtual chassis number 103 to PEX 4 at tier 1.
[Sysname-pex-port2] associate 103
# Assign virtual chassis number 102 to PEX 3 (the tier-2 PEX attached to PEX 4).
[Sysname-pex-port2] associate order 102
# Assign Ten-GigabitEthernet 1/1/0/2 and Ten-GigabitEthernet 2/1/0/2 to PEX port 2.
[Sysname-pex-port2] port group interface ten-gigabitethernet 1/1/0/2
[Sysname-pex-port2] port group interface ten-gigabitethernet 2/1/0/2
# Bind all idle physical interfaces in the same group to PEX port 1 and PEX port 2.
[Sysname-pex-port1] port group interface ten-gigabitethernet 1/1/0/3
[Sysname-pex-port1] port group interface ten-gigabitethernet 1/1/0/4
[Sysname-pex-port2] port group interface ten-gigabitethernet 2/1/0/3
[Sysname-pex-port2] port group interface ten-gigabitethernet 2/1/0/4
# Bring up the ports Ten-GigabitEthernet 1/1/0/1 through Ten-GigabitEthernet 1/1/0/4 and Ten-GigabitEthernet 2/1/0/1 through Ten-GigabitEthernet 2/1/0/4.
# Create PEX port group 1.
[Sysname] pex-port-group 1
# Assign PEX port 1 and PEX port 2 to PEX port group 1.
[Sysname-pex-port-group1] member pex-port 1
[Sysname-pex-port-group1] member pex-port 2
[Sysname-pex-port1] return
<Sysname> save
# Specify the file as the startup image file for S5130-EI switches.
<Syanme> boot-loader pex PEX-S5130EI file ipe flash:/s5130EI.ipe
Verifying the IPE file and the images.........................Done.
Decompressing file pex-s5130EI-boot.bin to flash:/pex-s5130EI-boot.bin................................Done.
Decompressing file pex-s5130EI-system.bin to flash:/pex-s5130EI-system.bin...........................................................................................................................................................Done.
2.     Connect the PEXs and the parent fabric, as shown in Figure 28. (Details not shown.)
4.     Use one of the following methods to change the operating mode to PEX for the candidate PEXs:
¡     Change the operating mode to PEX from the BOOT MENU:
# Reboot PEX 1 and press Ctrl+B at the prompt. If you have set a password, you must enter the correct password to access the BOOT MENU.
Starting......
Press Ctrl+T to start memory test
Press Ctrl+E to start heavy memory test
*                    H3C S5130-52S-EI BOOTROM, Version 130                     *
Copyright (c) 2004-2015 Hangzhou H3C Technologies Co., Ltd.
Creation Date       : Jun 26 2015, 09:31:44
Memory Size         : 1024MB
Flash Size          : 512MB
CPLD Version        : 002
PCB Version         : Ver.B
Mac Address         : 586ab10acdef
Press Ctrl+B to access EXTENDED BOOT MENU...0BootRom password: Not required. Please press Enter to continue.
# In the BOOT MENU, press Ctrl+Y to change the operating mode to PEX. By default, PEX mode is disabled for the S5130-EI switch.
BOOT MENU
1. Download application file to flash
2. Select application file to boot
8. Reserved
9. Set switch startup mode
0. Reboot
Ctrl+F: Format File System
Ctrl+P: Skip Super Password
Ctrl+R: Download application to SDRAM and Run
Ctrl+Z: Access EXTEND-ASSISTANT MENU
Enter your choice(0-9):
PEX mode is disabled. Are you sure you want to enable PEX mode? [Y/N]YDone!
# Enter 0 in the BOOT MENU to reboot PEX 1.
[Sysname] quit
# Reboot the PEX.
<Sysname> reboot
Press Ctrl-B to enter Extended Boot menu...0......Done!
Request File: flash:/pex-s5130EI-system.bin......Done.
Loading...Done!
Loading file pex_s5130EI.cpio.gz...Done!
Request File: flash:/pex-s5130EI-boot.bin...Done.
Loading...Done!...............................................................................................................................................................................................................................Done!
%Jan  1 11:44:04:850 2015 Sysname PEX/4/PEX_LINK_BLOCK: Status of Ten-GigabitEthernet1/1/0/1 changed from down to blocked.
%Jan  1 11:44:04:850 2015 Sysname PEX/4/PEX_LINK_BLOCK: Status of Ten-GigabitEthernet2/1/0/1 changed from down to blocked.
%Jan  1 11:44:13:483 2015 Sysname PEX/5/PEX_LINK_FORWARD: Status of Ten-GigabitEthernet1/1/0/1 changed from blocked to forwarding.
%Jan  1 11:44:13:483 2015 Sysname PEX/5/PEX_LINK_FORWARD: Status of Ten-GigabitEthernet2/1/0/1 changed from blocked to forwarding.
%Jan  1 11:44:13:518 2015 Sysname PEX/5/PEX_REG_REQUEST: Received a REGISTER request on PEX port 1 from PEX (chassis 100).
%Jan  1 11:44:14:363 2015 Sysname DEV/4/BOARD_LOADING: Board in chassis 100 is loading software images.
%Jan  1 11:44:14:365 2015 Sysname DEV/5/LOAD_FINISHED: Board in chassis 100 has finished loading software images.
%Jan  1 11:44:42:136 2015 Sysname DEV/4/BOARD_LOADING: Board in chassis 100 is loading software images.
%Jan  1 11:45:32:097 2015 Sysname DEV/5/LOAD_FINISHED: Board in chassis 100 has finished loading software images.
%Jan  1 11:48:24:339 2015 Sysname DEV/5/BOARD_STATE_NORMAL: Board state changes to NORMAL on Chassis 100, type is MAIN_BOARD_TYPE_50.
%Jan  1 11:48:29:061 2015 Sysname OPTMOD/4/MODULE_IN: -Chassis=100; Pex100/0/0/1: The transceiver is STACK_SFP_PLUS.
%Jan  1 11:48:29:061 2015 Sysname OPTMOD/4/MODULE_IN: -Chassis=100; Pex100/0/0/2: The transceiver is STACK_SFP_PLUS.
%Jan  1 11:48:37:455 2015 Sysname PEX/5/PEX_REG_JOININ: PEX (chassis 100) registered successfully on PEX port 1.
%Jan  1 11:48:42:422 2015 Sysname IFNET/3/PHY_UPDOWN: Pex100/0/0/1 link status is up.
%Jan  1 11:48:42:422 2015 Sysname IFNET/3/PHY_UPDOWN: Pex100/0/0/2 link status is up.
%Jan  1 11:48:42:430 2015 Sysname IFNET/5/LINK_UPDOWN: Line protocol on the interface Pex100/0/0/1 is up.
%Jan  1 11:48:42:430 2015 Sysname IFNET/5/LINK_UPDOWN: Line protocol on the interface Pex100/0/0/2 is up.
5.     Configure PEX 2, PEX 3, and PEX 4 in the same way PEX 1 is configured. As a best practice, first configure the tier-1 PEXs and then the tier-2 PEXs. (Details not shown.)
<Sysname>dis pex-port verbose
PEX port 1:
  Description: pex-port 0001
  Group: 1
  Associated chassis numbers: 2
    Chassis             PEX status
    *100                Online
     101                Online
  Member interfaces: 2
    XGE1/1/0/1              Forwarding      PEX100/0/0/1
    XGE2/1/0/1              Forwarding      PEX100/0/0/2
PEX port 2:
  Description: pex-port 0002
  Group: 1
    Chassis             PEX status
    *103                Online
     102                Online
    XGE1/1/0/2              Forwarding      PEX103/0/0/1
    XGE2/1/0/2              Forwarding      PEX103/0/0/2
# Verify that the PEX stack topology is correct on PEX port 1.
<Sysname> display pex-port 1 topology
PEX port 1:
PEX            Neighbors       Local interfaces     Peer interfaces
Chassis 100    PEX port 1      PEX100/0/0/1         XGE1/1/0/1
                               PEX100/0/0/2         XGE2/1/0/1
               Chassis 101     PEX100/0/0/3         PEX101/0/0/1
Chassis 101    Chassis 100     PEX101/0/0/1         PEX100/0/0/3
               Chassis 102     PEX101/0/0/2         PEX102/0/0/1
Chassis 102    Chassis 101     PEX102/0/0/1         PEX101/0/0/2
               Chassis 103     PEX102/0/0/2         PEX103/0/0/1
Chassis 103    Chassis 102     PEX103/0/0/3         PEX102/0/0/2
               PEX port 2      PEX103/0/0/1         XGE1/1/0/2
                               PEX103/0/0/2         XGE2/1/0/2
# Verify that the PEX stack topology is correct on PEX port 2. (Details not shown.)
