01-Fundamentals Command Reference
HomeSupportSwitchesS7500E SeriesReference GuidesCommand ReferencesH3C S7500E Switch Series Command References-Release7178-6W10001-Fundamentals Command Reference
14-License management commands
14-License management commands 62.4 KB
All commands in this chapter are supported only on the default MDC. Features licensed to the default MDC are also licensed to non-default MDCs. For information about MDCs, see Fundamentals Configuration Guide.
display license
Use display license to display detailed license information.
In standalone mode:
display license [ activation-file | activation-key | license-key ] [ slot slot-number ]
In IRF mode:
display license [ activation-file | activation-key | license-key ] [ chassis chassis-number slot slot-number ]
activation-file: Displays information about activation files.
activation-key: Displays information about activation keys. This keyword is not supported in the current software version.
license-key: Displays information about license keys. This keyword is not supported in the current software version.
slot slot-number: Specifies the slot number of an MPU. If you do not specify an MPU, this command displays license information for all MPUs. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU in an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the MPU on the device. If you do not specify an MPU, this command displays license information for all MPUs in the IRF fabric. (In IRF mode.)
The display license command displays detailed information about all licenses if it is used without any keywords.
# (In standalone mode.) Display detailed information about all licenses.
<Sysname> display license
Slot 0:
flash:/license/13.ak
Feature: mdc
Product Description: H3C S7500E Advanced Data Center License
Registered at: 2014-12-08 14:35:47
License Type: Permanent
Current State: In use
# (In IRF mode.) Display detailed license information for each IRF member device.
Chassis 1 slot 0:
Feature: mdc
Slot n
Slot number of the MPU. This field is available in standalone mode.
Chassis n slot m
Slot number of the MPU and member ID of the IRF member device that hosts the MPU. This field is available in IRF mode.
Activation file path.
13.ak represents the activation file name.
Feature
Feature name.
Registered at
Time when the license was installed.
License Type
License type by validity period:
·     NA—The system cannot obtain the license type.
·     Permanent—Purchased license that never expires and is always valid.
·     Days restricted—Purchased license that is valid for a period in days, for example, 30 days.
·     Trial (days restricted)—Free trial license that is valid for a period in days.
Time Left (days)
Remaining days of the license. This field is available for a purchased license.
Trial Time Left (days)
Remaining days of the trial period. This field is available for a trial license.
Validity Period
Start date and end state for a date restricted purchased license. If the start or end date is not limited, this field displays No limit.
Trial Validity Period
Start date and end state for a date restricted trial license. If the start or end date is not limited, this field displays No limit.
Current State
State of the license:
·     In use—The license is being used.
·     Usable—The license is available for use. If multiple days-restricted licenses for one feature are installed, only one license is in In use state and the rest licenses are in Usable state.
·     Expired—The license has expired.
·     Uninstalled—The license has been uninstalled.
·     Unusable—The license cannot be used.
·     Invalid—The license is invalid and cannot be used.
Uninstall Key
This field is available for licenses that have been uninstalled. An Uninstall file that contains an Uninstall key is created when you uninstall the activation file. The Uninstall file is required for transferring the license.
Uninstall Date
Date when the activation file was uninstalled.
display license feature
Use display license feature to display brief license information for features.
Feature license information includes the following information:
·     The total number of licenses that the device supports.
·     The number of installed licenses.
·     Features that must be licensed to run on the device.
# (In standalone mode.) Display brief feature license information.
<Sysname> display license feature
Slot 0:
Total: 8  Usage: 0
Feature                         Licensed        State
LISP                            N               -
EVB                             N               -
evi                             N               -
mdc                             N               -
SPBM                            N               -
TRILL                           N               -
FCoE                            N               -
# (In IRF mode.) Display brief feature license information.
Chassis 1 slot 0:
Total: 8  Usage: 0
LISP                            N               -
EVB                             N               -
evi                             N               -
mdc                             N               -
SPBM                            N               -
TRILL                           N               -
FCoE                            N               -
Slot n
Chassis n slot m
Total
Total number of licenses that can be installed on the MPU.
Usage
Number of installed licenses on the MPU.
Feature
Feature that must be licensed before being used.
The device supports license registration for MDC and EVI only.
Licensed
Licensing state of the feature:
·     N—Not licensed.
·     Y—Licensed.
License type by purchasing state:
·     Trial—Trial license.
·     Formal—Purchased license.
If the feature is not licensed, this field displays a hyphen (-). To use the feature, you must install a valid license file.
display license device-id
Use display license device-id to display SN and DID information.
In standalone mode:
display license device-id slot slot-number
In IRF mode:
display license device-id chassis chassis-number slot slot-number
slot slot-number: Specifies the slot number of an MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies an MPU in an IRF member device. The chassis-number argument represents the member ID of the IRF member device. The slot-number argument represents the slot number of the MPU on the device. (In IRF mode.)
Each MPU has a unique SN and DID. When you register a license for an MPU, you must provide its SN and DID.
The DID changes each time you use the license compress command to compress the license storage. Use the display license device-id command to identify the up-to-date DID each time you register licenses.
The DID can be generated as a string or .id file.
·     If the DID is a string, enter the string when you register the license with the license center.
·     If the DID is contained in an .id file, upload the file when you register the license with the license center.
# (In standalone mode.) Display the SN and DID of the MPU in slot 0.
<Sysname> display license device-id slot 0
SN: XXXXXXXXXXXXXXXXXXXX
Device ID: XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX-XXXX
# (In IRF mode.) Display the SN and DID of the MPU in slot 0 on IRF member device 2.
<Sysname> display license device-id chassis 2 slot 0
license activation-file install
Use license activation-file install to install a license activation file.
In standalone mode:
license activation-file install file-name slot slot-number
In IRF mode:
license activation-file install file-name chassis chassis-number slot slot-number
file-name: Specifies the file path, a case-sensitive string of 1 to 127 characters. The activation file must be valid and stored on an MPU's flash memory.
chassis chassis-number slot slot-number: Specifies an MPU in an IRF member device. The chassis-number argument represents the IRF member ID of the device. The slot-number argument represents the slot number of the MPU on the device. (In IRF mode.)
For a successful license activation file installation, make sure the following requirements are met:
·     The SN and DID used for registering the feature license match the current SN and DID of the specified MPU.
·     No one else is installing an activation file on the device you are working with.
You can install the activation files of multiple licenses for a feature. The feature can be used as long as one of the licenses is valid.
Activation files are MPU locked rather than device locked. A licensed feature can run on the MPU where its activation file is installed even after the MPU is moved between devices.
For a license-based feature package to run correctly, you must install one license on each MPU and make sure the licenses are the same. This requirement is true of an IRF fabric and a device in standalone mode.
# (In standalone mode.) Install the activation file 20110810.ak on the MPU in slot 0.
[Sysname] license activation-file install flash:/license/20110810.ak slot 0
This operation might take some time. Do not perform any other operations until t
he operation is completed or a failure message is displayed. Please wait...
The activation file has been installed.
# (In IRF mode.) Install the activation file 20110813.ak on the MPU in slot 0 of IRF member device 2.
[Sysname] license activation-file install flash:/license/20110813.ak chassis 2 slot 0
·     display license activation-file
·     display license device-id
·     license activation-file uninstall
Use license activation-file uninstall to uninstall an activation file.
In standalone mode:
license activation-file uninstall file-name slot slot-number
In IRF mode:
license activation-file uninstall file-name chassis chassis-number slot slot-number
A feature cannot run on the device after you uninstall all its activation files.
Use this command to revoke an unexpired license if you want to transfer the license from one MPU to another. For a successful uninstallation, make sure no one else is uninstalling an activation file on the device you are working with.
When an activation file is uninstalled, the system creates an Uninstall file. Use this file together with the SN and DID of the transfer destination to register the license for the transfer destination.
Trial licenses are not transferrable. When you uninstall the activation file of a trial license, no Uninstall file is created.
# (In standalone mode.) Uninstall the activation file flash:/license/20110810.ak from the MPU in slot 0.
[Sysname] license activation-file uninstall flash:/license/20110810.ak slot 0
Uninstall file: flash:/license/20110810.uak
# (In IRF mode.) Uninstall the activation file flash:/license/20110813.ak from the MPU in slot 0 on IRF member device 2.
[Sysname] license activation-file uninstall flash:/license/20110813.ak chassis 2 slot 0
Uninstall file: flash:/license/20110813.uak
·     license activation-file install
license compress
Use license compress to compress the license storage.
In standalone mode:
license compress slot slot-number
In IRF mode:
license compress chassis chassis-number slot slot-number
This command clears invalid licenses (expired licenses and uninstalled licenses) and Uninstall files from the license storage area. Back up the Uninstall files before you compress the license storage.
The DID changes each time the license storage is compressed. Before performing a compression, make sure all licenses registered with the old DID have been installed. They cannot be installed after the compression.
For a successful compression, make sure no one else is compressing the license storage on the device you are working with.
# (In standalone mode.) Compress the license storage on the MPU in slot 0.
[Sysname] license compress slot 0
This command will delete all data relevant to uninstalled and expired keys/licen
ses, including Uninstall keys, and create a new device ID for activation keys/fi
les. Make sure you have saved the Uninstall keys so you can apply for a new acti
vation key/file for the unexpired licenses that were covered by the uninstalled
activation keys/files.
Are you sure you want to continue? [Y/N]: y
# (In IRF mode.) Compress the license storage on the MPU in slot 0 of IRF member device 2.
[Sysname] license compress chassis 2 slot 0
