06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Switch Series Command References-Release7178-6W10006-Layer 3 - IP Routing Command Reference
07-Policy-based routing commands
07-Policy-based routing commands 61.77 KB
apply default-next-hop
Use apply default-next-hop to set a default next hop.
Use undo apply default-next-hop to remove the configuration.
apply default-next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
undo apply default-next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-2> ]
No default next hop is set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist. This option does not take effect.
ip-address: Specifies the IP address of the default next hop.
direct: Specifies a directly connected default next hop.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-2>: Indicates that the argument before it can be entered twice at most.
You can specify multiple default next hops for backup in one command line or by executing this command multiple times.
You can specify a maximum of two default next hops for a node.
With a default next hop specified, the undo apply default-next-hop command removes the default next hop.
Without any default next hop specified, the undo apply default-next-hop command removes all default next hops.
# Set a directly-connected default next hop of 1.1.1.1.
[Sysname] policy-based-route aa permit node 11
[Sysname-pbr-aa-11] apply default-next-hop 1.1.1.1 direct
apply next-hop
Use apply next-hop to set a next hop.
Use undo apply next-hop to remove the configuration.
apply next-hop [ vpn-instance vpn-instance-name ] { ip-address [ direct ] [ track track-entry-number ] }&<1-2>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ip-address&<1-2> ]
No next hop is set.
Policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist. The vpn-instance vpn-instance-name option is not supported in the current software version.
ip-address: Specifies the IP address of the next hop.
direct: Specifies that the next hop must be directly connected to take effect.
You can specify a maximum of two next hops for backup in one command line or by executing this command twice.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1.1.1.1.
[Sysname-pbr-aa-11] apply next-hop 1.1.1.1 direct
display ip policy-based-route
Use display ip policy-based-route to display PBR policy information.
display ip policy-based-route [ policy policy-name ]
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters.
If no policy is specified, this command displays information about all policies.
If a policy name is specified, this command displays information about the specified policy.
# Display all policy information.
<Sysname> display ip policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
policy-based-route
display ip policy-based-route interface
Use display ip policy-based-route interface to display interface PBR configuration and statistics.
display ip policy-based-route interface interface-type interface-number [ slot slot-number ]
slot slot-number: Displays interface PBR configuration and statistics for an IRF member device or a PEX. The slot-number argument represents the member ID of the IRF member device or the virtual slot number of the PEX.
# Display PBR configuration and statistics on Ten-GigabitEthernet 1/1/1.
<Sysname> display ip policy-based-route interface ten-gigabitethernet 1/1/1
Policy based routing information for interface Ten-GigabitEthernet1/1/1(failed):
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
    apply next-hop 2.2.2.2
  Matched: 0
Total matched: 0
Policy based routing information for interface Ten-GigabitEthernet1/1/1:
Policy name: aaa
  node 0 deny(not support):
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0 (no statistics resource)
Total matched: 0
failed indicates that the policy (including all its nodes) failed to be assigned to the driver.
For a global interface (with only a one-dimensional interface number, for example, VLAN-interface 10), failed can be displayed only when you specify the slot slot-number option for the command.
node 2 permit(no resource)
Match mode of the node, permit or deny.
not support means the device does not support match criteria configured on the node. no resource means the device has insufficient ACL resources, and failed to assign ACL resources to the node.
For a global interface (with only a one-dimensional interface number, for example, VLAN-interface 10), not support and no resource can be displayed only when you specify the slot slot-number option for the command.
if-match acl
apply next-hop
Number of successful matches on the node (no statistics resource indicates insufficient statistics resources).
For a global interface (with only a one-dimensional interface number, for example, VLAN-interface 10), no statistics resource can be displayed only when you specify the slot slot-number option for the command.
Total matched
Total number of successful matches on all nodes.
reset ip policy-based-route statistics
display ip policy-based-route local
Use display ip policy-based-route local to display local PBR configuration and statistics.
display ip policy-based-route local [ slot slot-number ]
slot slot-number: Displays local PBR configuration and statistics for an IRF member device or a PEX. The slot-number argument represents the member ID of the IRF member device or the virtual slot number of the PEX.
# Display local PBR configuration and statistics.
<Sysname> display ip policy-based-route local
Policy based routing information for local:
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0
Total matched: 0
Local PBR configuration and statistics.
node 0 deny/node 2 permit
Match mode of the node: permit or deny.
if-match acl
apply next-hop
Matched: 0
Number of successful matches on the node.
Total matched
display ip policy-based-route setup
Use display ip policy-based-route setup to display PBR configuration.
# Display PBR configuration.
<Sysname> display ip policy-based-route setup
Policy Name              Interface Name
pr01                     Ten-GigabitEthernet 1/1/1
Interface Name
Interface where the policy is applied.
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to remove the ACL match criterion.
undo if-match acl
No ACL match criterion is set.
Policy node view
acl-number: Specifies an ACL by its number in the range of 2000 to 2999 for a basic ACL, and in the range of 3000 to 3999 for an advanced ACL.
name acl-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all.
# Configure Node 11 of policy aa to permit the packets matching ACL 2011.
[Sysname-pbr-aa-11] if-match acl 2011
# Configure Node 11 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr-aa-11] if-match acl name aaa
ip local policy-based-route
Use ip local policy-based-route to configure local PBR based on a policy.
Use undo ip local policy-based-route to remove the configuration.
ip local policy-based-route policy-name
No policy is referenced for local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
Local PBR is used to route locally generated packets. This feature might affect local services, such as ping and Telnet. Do not configure local PBR unless doing so is required.
# Configure local PBR based on policy aaa.
[Sysname] ip local policy-based-route aaa
·     display ip policy-based-route setup
·     policy-based-route
Use ip policy-based-route to configure interface PBR by applying a policy to an interface.
Use undo ip policy-based-route to remove the configuration.
ip policy-based-route policy-name
No policy is applied to an interface.
Interface view
You can apply only one policy to an interface. Before you apply a new policy, you must first remove the current policy from the interface.
# Apply policy aaa to VLAN-interface 2.
[Sysname] vlan 2
[Sysname-Vlan2] interface vlan-interface 2
[Sysname-Vlan-interface2] ip policy-based-route aaa
policy-based-route
Use policy-based-route to create a policy node and enter policy node view.
Use undo policy-based-route to remove a policy or policy node.
undo policy-based-route policy-name [ deny | node node-number | permit ]
No policy node is created.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies a policy node by its number in the range of 0 to 255. A smaller number has a higher priority.
A policy that has been applied to an interface or locally cannot be removed. To remove it, you must first cancel the application.
·     If a policy node is specified, the undo policy-based-route command removes the specified policy node.
·     If a match mode is specified, the command removes all nodes configured with the match mode.
·     If no policy node or match mode is specified, the command removes the whole policy.
# Create permit-mode of Node 10 for policy policy1 and enter policy node view.
[Sysname] policy-based-route policy1 permit node 10
[Sysname-pbr-policy1-10]
Use reset ip policy-based-route statistics to clear PBR statistics.
reset ip policy-based-route statistics [ policy policy-name ]
If no policy is specified, the command clears all PBR statistics.
If a policy is specified, the command clears the PBR statistics for the specified policy.
To view PBR statistics, use the display ip policy-based-route interface command.
# Clear all PBR statistics.
<Sysname> reset ip policy-based-route statistics
·     display ip policy-based-route interface
·     display ip policy-based-route local
