12-Network Management and Monitoring Command Reference
HomeSupportSwitchesH3C S7500E-X Switch SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release7178-6W10012-Network Management and Monitoring Command Reference
05-SNMP commands
05-SNMP commands 199.21 KB
SNMP commands
By default, the device provides low encryption. To obtain high encryption, you must install the Strong Cryptography feature license. This feature provides stronger cryptography, additional IPsec tunnels, and higher encryption performance. For more information about obtaining the Strong Cryptography feature license, see the release notes or contact your H3C sales representative.
Support for features, commands, and parameters differs with the cryptography capability.
The SNMP agent sends notifications (traps and informs) to inform the NMS of significant events, such as link state changes and user logins or logouts. Unless otherwise stated, the trap keyword in the command line includes both traps and informs.
display snmp-agent community
Use display snmp-agent community to display SNMPv1 or SNMPv2c community information.
read: Displays information about SNMP read-only communities.
write: Displays information about SNMP read and write communities.
This command is supported only for high encryption in non-FIPS mode.
If no keyword is specified, this command displays information about all SNMPv1 and SNMPv2c communities that have been created.
The communities include:
·     Those configured with the snmp-agent community command.
·     Those automatically created by the system for SNMPv1 and SNMPv2c users that have been assigned to an existing SNMP group.
# Display information about all SNMPv1 and SNMPv2c communities.
<Sysname> display snmp-agent community
   Community name: aa
       Group name: aa
       ACL:2001
       Storage-type: nonVolatile
       Context name: con1
   Community name: bb
       Role name: bb
   Community name: userv1
       Group name: testv1
       Storage type: nonVolatile
Community name
Community name created by using the snmp-agent community command or username created by using the snmp-agent usm-user { v1 | v2c } command.
Group name
SNMP group name.
·     If the community is created by using the snmp-agent community command in VACM mode, the group name is the same as the community name.
·     If the community is created by using the snmp-agent usm-user { v1 | v2c } command, the name of the group that has the user is displayed.
Role name
User role name for the community.
If the community is created by using the snmp-agent community command in RBAC mode, a user role can be bound to the community name.
ACL
Number of the ACL that controls the access of the NMSs in the community to the device.
Only the NMSs with the IP addresses permitted in the ACL can access the device with the community name.
This field appears only when an SNMPv1 or SNMPv2c user is associated with an ACL rule.
Storage type
Storage type:
·     volatile—Settings are lost when the system reboots.
·     nonVolatile—Settings remain after the system reboots.
·     permanent—Settings remain after the system reboots and can be modified but not deleted.
·     readOnlySettings remain after the system reboots and cannot be modified or deleted.
·     other—Any other storage type.
Context name
SNMP context:
·     If a mapping between an SNMP community and an SNMP context is configured, the SNMP context is displayed.
·     If no mapping between an SNMP community and an SNMP context exists, this field is not displayed.
·     snmp-agent community
·     snmp-agent usm-user { v1 | v2c }
display snmp-agent context
Use display snmp-agent context to display an SNMP context.
display snmp-agent context [ context-name ]
context-name: Specifies an SNMP context by its name, a case-sensitive string of 1 to 32 characters. If no SNMP context is specified, this command displays all SNMP contexts created on the device.
# Display all SNMP contexts created on the device.
<Sysname> display snmp-agent context
   ospfcontext
   isiscontext
snmp-agent context
display snmp-agent group
Use display snmp-agent group to display SNMP group information, including the group name, security model, MIB view, and storage-type.
display snmp-agent group [ group-name ]
group-name: Specifies an SNMPv1, SNMPv2c, or SNMPv3 group name for high encryption in non-FIPS mode, and an SNMPv3 group name for high encryption in FIPS mode. It is a case-sensitive string of 1 to 32 characters. If no group is specified, this command displays information about all SNMP groups.
# Display information about all SNMP groups.
<Sysname> display snmp-agent group
   Group name: groupv3
       Security model: v3 noAuthnoPriv
       Readview: ViewDefault
       Writeview: <no specified>
       Notifyview: <no specified>
Group name
SNMP group name.
Security model
Security model of the SNMP group:
·     authPriv—authentication with privacy.
·     authNoPriv—authentication without privacy.
·     noAuthNoPriv—no authentication, no privacy.
Security model of an SNMPv1 or SNMPv2c group can only be noAuthNoPriv.
Readview
Read-only MIB view accessible to the SNMP group.
Writeview
Write MIB view accessible to the SNMP group.
Notifyview
Notify MIB view for the SNMP group. The SNMP users in the group can send notifications only for the nodes in the notify MIB view.
Storage-type
Storage type, including volatile, nonvolatile, permanent, readOnly, and other (see Table 1).
ACL
Number of the ACL that controls the access of the NMSs in the SNMP group to the device.
This field appears only when an ACL is assigned to the SNMP group.
snmp-agent group
display snmp-agent local-engineid
Use display snmp-agent local-engineid to display the local SNMP engine ID.
Every SNMP agent has one SNMP engine to provide services for sending and receiving messages, authenticating and encrypting messages, and controlling access to managed objects.
The local SNMP engine ID uniquely identifies the SNMP engine of the SNMP agent in an SNMP domain.
# Display the local engine ID.
<Sysname> display snmp-agent local-engineid
SNMP local engine ID: 800007DB7F0000013859
display snmp-agent mib-node
Use display snmp-agent mib-node to display SNMP MIB node information.
display snmp-agent mib-node [ details | index-node | trap-node | verbose ]
details: Specifies detailed MIB node information, including node name, last octet of an OID string, and name of the next leaf node.
index-node: Specifies SNMP MIB tables, and node names and OIDs of MIB index nodes.
trap-node: Specifies node names and OIDs of MIB notification nodes, and node names and OIDs of notification objects.
verbose: Specifies detailed information about SNMP MIB nodes, including node names, OIDs, node types, permissions to MIB nodes, data types, MORs, and parent, child, and sibling nodes.
If no keywords are specified, this command displays information about all SNMP MIB nodes, including node name, OID, and permissions to MIB nodes.
The SNMP software package includes different MIB files. Support for MIBs varies by SNMP software versions.
# Display SNMP MIB node information.
<Sysname> display snmp-agent mib-node
iso<1>(NA)
  |-std<1.0>(NA)
   |-iso8802<1.0.8802>(NA)
    |-ieee802dot1<1.0.8802.1>(NA)
     |-ieee802dot1mibs<1.0.8802.1.1>(NA)
      |-lldpMIB<1.0.8802.1.1.2>(NA)
       |-lldpNotifications<1.0.8802.1.1.2.0>(NA)
        |-lldpNotificationPrefix<1.0.8802.1.1.2.0.0>(NA)
         |-lldpRemTablesChange<1.0.8802.1.1.2.0.0.1>(NA)
       |-lldpObjects<1.0.8802.1.1.2.1>(NA)
        |-lldpConfiguration<1.0.8802.1.1.2.1.1>(NA)
         |-*lldpMessageTxInterval<1.0.8802.1.1.2.1.1.1>(RW)
         |-*lldpMessageTxHoldMultiplier<1.0.8802.1.1.2.1.1.2>(RW)
         |-*lldpReinitDelay<1.0.8802.1.1.2.1.1.3>(RW)
-std
MIB node name.
<1.0>
OID of a MIB node.
(NA)
Permissions to MIB nodes:
·     NA—Not accessible.
·     NF—Supports notifications.
·     RO—Supports read-only access.
·     RW—Supports read and write access.
·     RC—Supports read-write-create access.
·     WO—Supports write-only access.
Leaf node or MIB table node.
# Display detailed MIB node information.
<Sysname> display snmp-agent mib-node details
iso(1)(lldpMessageTxInterval)
  |-std(0)(lldpMessageTxInterval)
   |-iso8802(8802)(lldpMessageTxInterval)
    |-ieee802dot1(1)(lldpMessageTxInterval)
     |-ieee802dot1mibs(1)(lldpMessageTxInterval)
      |-lldpMIB(2)(lldpMessageTxInterval)
       |-lldpNotifications(0)(lldpMessageTxInterval)
        |-lldpNotificationPrefix(0)(lldpMessageTxInterval)
         |-lldpRemTablesChange(1)(NULL)
       |-lldpObjects(1)(lldpMessageTxInterval)
        |-lldpConfiguration(1)(lldpMessageTxInterval)
         |-*lldpMessageTxInterval(1)(lldpMessageTxHoldMultiplier)
         |-*lldpMessageTxHoldMultiplier(2)(lldpReinitDelay)
         |-*lldpReinitDelay(3)(lldpTxDelay)
         |-*lldpTxDelay(4)(lldpNotificationInterval)
         |-*lldpNotificationInterval(5)(lldpPortConfigPortNum)
         |-lldpPortConfigTable(6)(lldpPortConfigPortNum)
          |-lldpPortConfigEntry(1)(lldpPortConfigPortNum)
           |-*lldpPortConfigPortNum(1)(lldpPortConfigAdminStatus)
           |-*lldpPortConfigAdminStatus(2)(lldpPortConfigNotificationEnable)
           |-*lldpPortConfigNotificationEnable(3)(lldpPortConfigTLVsTxEnable)
           |-*lldpPortConfigTLVsTxEnable(4)(lldpConfigManAddrPortsTxEnable)
-std
MIB node name.
(0)
Last bit of a MIB OID string.
Name of a leaf node.
# Display MIB table names, and node names and OIDs of MIB index nodes.
<Sysname> display snmp-agent mib-node index-node
Table          |lldpPortConfigTable
Index          ||lldpPortConfigPortNum
OID            |||  1.0.8802.1.1.2.1.1.6.1.1
Table          |lldpConfigManAddrTable
Index          ||lldpLocManAddrSubtype
OID            |||  1.0.8802.1.1.2.1.3.8.1.1
OID            |||  1.0.8802.1.1.2.1.3.8.1.2
Table          |lldpStatsTxPortTable
Index          ||lldpStatsTxPortNum
OID            |||  1.0.8802.1.1.2.1.2.6.1.1
Table          |lldpStatsRxPortTable
Index          ||lldpStatsRxPortNum
OID            |||  1.0.8802.1.1.2.1.2.7.1.1
Table          |lldpLocPortTable
Index          ||lldpLocPortNum
OID            |||  1.0.8802.1.1.2.1.3.7.1.1
Table 5 Command output
Table
MIB table name.
Index
Name of a MIB index node.
OID
OID of a MIB index node.
# Display names and OIDs of MIB notification nodes, and names and OIDs of notification objects.
<Sysname> display snmp-agent mib-node trap-node
Name          |lldpRemTablesChange
OID           ||1.0.8802.1.1.2.0.0.1
Trap Object
Name          |||lldpStatsRemTablesInserts
OID           ||||1.0.8802.1.1.2.1.2.2
Name          |||lldpStatsRemTablesDeletes
OID           ||||1.0.8802.1.1.2.1.2.3
Name          |||lldpStatsRemTablesDrops
OID           ||||1.0.8802.1.1.2.1.2.4
Name          |||lldpStatsRemTablesAgeouts
OID           ||||1.0.8802.1.1.2.1.2.5
Name          |lldpXMedTopologyChangeDetected
OID           ||1.0.8802.1.1.2.1.5.4795.0.1
Trap Object
Name          |||lldpRemChassisIdSubtype
OID           ||||1.0.8802.1.1.2.1.4.1.1.4
OID           ||||1.0.8802.1.1.2.1.4.1.1.5
Name          |||lldpXMedRemDeviceClass
OID           ||||1.0.8802.1.1.2.1.5.4795.1.3.1.1.3
Name          |mplsL3VpnVrfUp
OID           ||1.3.6.1.2.1.10.166.11.0.1
Trap Object
Name          |||mplsL3VpnIfConfRowStatus
OID           ||||1.3.6.1.2.1.10.166.11.1.2.1.1.5
Name          |||mplsL3VpnVrfOperStatus
OID           ||||1.3.6.1.2.1.10.166.11.1.2.2.1.6
Table 6 Command output
Name
Name of a MIB notification node.
OID
OID of a MIB notification node.
Trap Object
Name and OID of a notification object.
# Display detailed information about SNMP MIB nodes, including node names, OIDs, node types, permissions to MIB nodes, data types, MORs, and parent, child, and sibling nodes.
<Sysname> display snmp-agent mib-node verbose
Name          |lldpNotificationInterval
OID           ||1.0.8802.1.1.2.1.1.5
Properties    ||NodeType:   Leaf
              ||AccessType: RW
              ||DataType:   Integer32
              ||MOR:        0x020c1105
Parent        ||lldpConfiguration
First child   ||
Next leaf     ||lldpPortConfigPortNum
Next sibling  ||lldpPortConfigTable
Allow         ||get/set/getnext
Value range   ||  [5..3600]
Name          |lldpPortConfigTable
OID           ||1.0.8802.1.1.2.1.1.6
Properties    ||NodeType:   Table
              ||AccessType: NA
              ||DataType:   NA
              ||MOR:        0x00000000
First child   ||lldpPortConfigEntry
Next sibling  ||lldpConfigManAddrTable
Name          |lldpPortConfigEntry
OID           ||1.0.8802.1.1.2.1.1.6.1
Properties    ||NodeType:   Row
              ||AccessType: NA
              ||DataType:   NA
              ||MOR:        0x00000000
Parent        ||lldpPortConfigTable
First child   ||lldpPortConfigPortNum
Next sibling  ||
Index         ||[indexImplied:0, indexLength:1]:
Name          |lldpPortConfigPortNum
OID           ||1.0.8802.1.1.2.1.1.6.1.1
Properties    ||NodeType:   Column
              ||AccessType: NA
              ||MOR:        0x020c1201
Parent        ||lldpPortConfigEntry
First child   ||
Next leaf     ||lldpPortConfigAdminStatus
Next sibling  ||lldpPortConfigAdminStatus
Value range   ||  [1..4096]
Name          |lldpPortConfigAdminStatus
OID           ||1.0.8802.1.1.2.1.1.6.1.2
              ||AccessType: RW
              ||DataType:   Integer
              ||MOR:        0x020c1202
First child   ||
Next leaf     ||lldpPortConfigNotificationEnable
Next sibling  ||lldpPortConfigNotificationEnable
Value range   ||
              ||  ['txOnly', 1]
              ||  ['rxOnly', 2]
              ||  ['txAndRx', 3]
              ||  ['disabled', 4]
Table 7 Command output
Name
MIB node name.
OID
OID of a MIB node.
NodeType
MIB node types:
·     Table—Table node.
·     Row—Row node in a MIB table.
·     Column—Column node in a MIB table.
·     Leaf—Leaf node.
·     Group—Group node (parent node of a leaf node).
·     Trapnode—Notification node.
·     Other—Other node types.
AccessType
DataType
Data types of MIB nodes:
·     Integer—An integer.
·     Integer32—A 32-bit integer.
·     Unsigned32—A 32-bit integer with no mathematical sign.
·     Gauge—A non-negative integer that might increase or decrease.
·     Gauge32—A 32-bit non-negative integer that might increase or decrease.
·     Counter—A non-negative integer that might increase but not decrease.
·     Counter32—A 32-bit non-negative integer that might increase but not decrease.
·     Counter64—A 64-bit non-negative integer that might increase but not decrease.
·     Timeticks—A non-negative integer for time keeping.
·     Octstring—An octal string.
·     OID—Object identifier.
·     IPaddress—A 32-bit IP address.
·     Networkaddress—A network IP address.
·     Opaque—Any data.
·     Userdefined—User-defined data.
·     BITS—Bit enumeration.
MOR
MOR for a MIB node.
Parent
Name of a parent node.
First child
Name of the first leaf node.
Next leaf
Name of the next leaf node.
Next sibling
Name of the next sibling node.
Allow
Operation types allowed:
·     get/set/getnext—All operations.
·     get—Get operation.
·     set—Set operation.
·     getnext—GetNext operation.
Value range
Value range of a MIB node.
Index
Table index. This field appears only for a table node.
display snmp-agent mib-view
Use display snmp-agent mib-view to display MIB views.
display snmp-agent mib-view [ exclude | include | viewname view-name ]
exclude: Displays the subtrees excluded from any MIB view.
include: Displays the subtrees included in any MIB view.
viewname view-name: Displays information about the specified MIB view.
If you do not specify any parameters, this command displays all MIB views.
# Display all MIB views.
<Sysname> display snmp-agent mib-view
   View name: ViewDefault
       MIB Subtree: iso
       Subtree mask:
       View Type: included
       View status: active
       MIB Subtree: snmpUsmMIB
       Subtree mask:
       View Type: excluded
       View status: active
       MIB Subtree: snmpVacmMIB
       Subtree mask:
       View Type: excluded
       View status: active
       MIB Subtree: snmpModules.18
       Subtree mask:
       View Type: excluded
       View status: active
ViewDefault is the default MIB view. The output shows that except for the MIB objects in the snmpUsmMIB, snmpVacmMIB, and snmpModules.18 subtrees, all the MIB objects in the iso subtree are accessible.
Table 8 Command output
View name
MIB view name.
MIB Subtree
MIB subtree covered by the MIB view.
Subtree mask
MIB subtree mask.
Storage-type
Type of the medium (see Table 1) where the subtree view is stored.
View Type
Access privilege for the MIB subtree in the MIB view:
·     Included—All objects in the MIB subtree are accessible in the MIB view.
·     Excluded—None of the objects in the MIB subtree is accessible in the MIB view.
View status
Status of the MIB view:
·     active—MIB view is effective.
·     inactive—MIB view is ineffective.
MIB views are active upon their creation at the CLI. To temporarily disable a MIB view without deleting it, you can perform an SNMP set operation to set its status to inactive.
snmp-agent mib-view
display snmp-agent remote
Use display snmp-agent remote to display remote SNMP engine IDs configured by using the snmp-agent remote command.
display snmp-agent remote [ ip-address [ vpn-instance vpn-instance-name ] | ipv6 ipv6-address [ vpn-instance vpn-instance-name ] ]
ip-address: Specifies the IP address of a remote SNMP entity to display its SNMP engine ID.
ipv6 ipv6-address: Specifies the IPv6 address of a remote SNMP entity to display its SNMP engine ID.
vpn-instance vpn-instance-name: Specifies the VPN for a remote SNMP entity. The vpn-instance-name argument specifies the name of the MPLS L3VPN, a case-sensitive string of 1 to 31 characters. If this parameter is not specified, the remote SNMP entity is in the public network.
If no IP address is specified, this command displays all remote SNMP engine IDs you have configured.
# Display all remote SNMP engine IDs.
<Sysname> display snmp-agent remote
   Remote engineID: 800063A28000A0FC00580400000001
       IPv4 address: 1.1.1.1
       VPN instance: vpn1
Table 9 Command output
Remote engineID
Remote SNMP engine ID you have configured using the snmp-agent remote command.
IPv4 address
IPv4 address of the remote SNMP entity.
For remote SNMP entities that are configured with an IPv6 address, the field name is "IPv6 address."
VPN instance
This field is available only if a VPN has been specified for the remote SNMP entity in the snmp-agent remote command.
snmp-agent remote
display snmp-agent statistics
Use display snmp-agent statistics to display SNMP message statistics.
# Display SNMP message statistics.
<Sysname> display snmp-agent statistics
  1684 messages delivered to the SNMP entity.
  5 messages were for an unsupported version.
  0 messages used an unknown SNMP community name.
  0 messages represented an illegal operation for the community supplied.
  0 ASN.1 or BER errors in the process of decoding.
  1679 messages passed from the SNMP entity.
  0 SNMP PDUs had badValue error-status.
  0 SNMP PDUs had genErr error-status.
  0 SNMP PDUs had noSuchName error-status.
  0 SNMP PDUs had tooBig error-status (Maximum packet size 1500).
  16544 MIB objects retrieved successfully.
  2 MIB objects altered successfully.
  7 GetRequest-PDU accepted and processed.
  7 GetNextRequest-PDU accepted and processed.
  1653 GetBulkRequest-PDU accepted and processed.
  1669 GetResponse-PDU accepted and processed.
  2 SetRequest-PDU accepted and processed.
  0 Trap PDUs accepted and processed.
  0 alternate Response Class PDUs dropped silently.
  0 forwarded Confirmed Class PDUs dropped silently.
Table 10 Command output
Number of messages that the SNMP agent has received.
Number of messages that had an SNMP version not configured on the SNMP agent.
Number of messages that used an unknown SNMP community name.
Number of messages carrying an operation that the community has no right to perform.
Number of messages that had ASN.1 or BER errors during decoding.
Number of messages sent by the SNMP agent.
Number of PDUs with a BadValue error.
Number of PDUs with a genErr error.
Number of PDUs with a NoSuchName error.
Number of PDUs with a TooBig error (the maximum packet size is 1500 bytes).
Number of MIB objects that have been successfully retrieved.
Number of MIB objects that have been successfully modified.
Number of GetRequest requests that have been received and processed.
Number of getNext requests that have been received and processed.
Number of getBulk requests that have been received and processed.
Number of get responses that have been received and processed.
Number of set requests that have been received and processed.
Number of notifications that have been received and processed.
Number of dropped response packets.
Number of forwarded packets that have been dropped.
display snmp-agent sys-info
Use display snmp-agent sys-info to display SNMP agent system information.
display snmp-agent sys-info [ contact | location | version ] *
contact: Displays the system contact.
location: Displays the physical location of the device.
version: Displays the SNMP agent version.
If none of the parameters is specified, this command displays all SNMP agent system information.
# Display all SNMP agent system information.
<Sysname> display snmp-agent sys-info
   The contact information of the agent:
           Hangzhou H3C Technologies Co., Ltd.
   The location information of the agent:
           Hangzhou, China
   The SNMP version of the agent:
     SNMPv3
snmp-agent sys-info
display snmp-agent trap queue
Use display snmp-agent trap queue to display basic information about the trap queue, including the queue size and number of traps in the queue.
# Display the trap queue configuration and usage status.
<Sysname> display snmp-agent trap queue
   Queue size: 100
   Message number: 6
·     snmp-agent trap life
·     snmp-agent trap queue-size
display snmp-agent trap-list
Use display snmp-agent trap-list to display modules that can generate SNMP notifications and their notification function status (enable or disable).
You can use the snmp-agent trap enable command to enable or disable the notification function of a module. For a module that has sub-modules, the notification function status is enable if the trap function of any of its sub-modules is enabled.
# Display the modules that can generate notification and their notification function status.
<Sysname> display snmp-agent trap-list
arp notification is disabled.
   configuration notification is enabled.
   isis notification is enabled.
   l3vpn notification is enabled.
   mac-address notification is enabled.
   mpls notification is disabled.
   ospf notification is enabled.
   radius notification is disabled.
   standard notification is enabled.
   system notification is enabled.
   Enabled notifications: 7; Disabled notifications: 3
display snmp-agent usm-user
Use display snmp-agent usm-user to display SNMPv3 user information.
display snmp-agent usm-user [ engineid engineid | group group-name | username user-name ] *
engineid engineid: Displays SNMPv3 user information for the SNMP engine ID identified by engineid. When an SNMPv3 user is created, the system records the local SNMP entity engine ID. The user becomes invalid when the engine ID changes, and it becomes valid again when the recorded engine ID is restored.
group group-name: Displays SNMPv3 user information for a specified SNMP group name. The group name is case sensitive.
username user-name: Displays information about the specified SNMPv3 user. The username is case sensitive.
This command displays only SNMPv3 users that you have created by using the snmp-agent usm-user v3 command. To display SNMPv1 or SNMPv2c users created by using the snmp-agent usm-user { v1 | v2c } command, use the display snmp-agent community command.
# Display information about all SNMPv3 users.
<Sysname> display snmp-agent usm-user
   Username: userv3
   Group name: mygroupv3
       Engine ID: 800063A203000FE240A1A6
       User status: active
   Username: userv3
       Engine ID: 8000259503000BB3100A508
       User status: active
   Username: userv3code
   Role name: groupv3code
       User status: active
   Role name: snmprole
       Engine ID: 800063A280000002BB0001
       User status: active
Table 11 Command output
Username
SNMP username.
Group name
SNMP group name.
Role name
SNMP user role name.
Engine ID
Engine ID that the SNMP agent used when the SNMP user was created.
Storage type
Storage type:
·     volatile.
·     nonvolatile.
·     permanent.
·     readOnly.
·     other.
For more information about these storage types, see Table 1.
User status
SNMP user status:
·     active—The SNMP user is effective.
·     notInService—The SNMP user is correctly configured but not activated.
·     notReady—The SNMP user configuration is incomplete.
·     other—Any other status.
SNMP users are active upon their creation at the CLI. To temporarily disable an SNMP user without deleting it, you can perform an SNMP set operation to change its status.
ACL
Number of the ACL that controls the access of the SNMP user (the NMS) to the device.
To access the device, the IP address of the NMS must be permitted in the ACL.
This field appears only when an SNMPv3 user is associated with an ACL rule.
enable snmp trap updown
Use enable snmp trap updown to enable link state notifications on an interface.
Use undo enable snmp trap updown to disable link state notifications on an interface.
Link state notifications are enabled.
Interface view
For an interface to generate linkUp/linkDown notifications when its state changes, you must also enable the linkUp/linkDown notification function globally by using the snmp-agent trap enable standard [ linkdown | linkup ] * command.
# Enable GigabitEthernet 1/0/1 to send linkUp/linkDown SNMP traps to 10.1.1.1 in the community public.
[Sysname] snmp-agent target-host trap address udp-domain 10.1.1.1 params securityname public
[Sysname-GigabitEthernet1/0/1] enable snmp trap updown
·     snmp-agent target-host
·     snmp-agent trap enable
snmp-agent
Use snmp-agent to enable the SNMP agent.
Use undo snmp-agent to disable the SNMP agent.
snmp-agent
undo snmp-agent
SNMP agent is disabled.
The snmp-agent command is optional for an SNMP configuration task. The SNMP agent is automatically enabled when you execute any command that begins with snmp-agent except for the snmp-agent calculate-password command.
# Enable the SNMP agent.
Use snmp-agent calculate-password to calculate a digest for the ciphertext authentication or privacy key converted from a plaintext key in SNMPv3.
High encryption in non-FIPS mode:
snmp-agent calculate-password plain-password mode { 3desmd5 | 3dessha | md5 | sha } { local-engineid | specified-engineid engineid }
High encryption in FIPS mode:
snmp-agent calculate-password plain-password mode sha { local-engineid | specified-engineid engineid }
plain-password: Specifies a plaintext authentication or privacy key.
mode: Specifies the same authentication mode and privacy mode as configured in the snmp-agent usm-user v3 command. The encryption algorithms AES, 3DES, and DES are in descending order of security strength. DES is enough to meet general security requirements. The MD5 authentication algorithm is faster than SHA-1, while SHA-1 provides higher security than MD5.
·     3desmd5: Converts the plaintext privacy key to an encrypted key for 3DES encryption used in conjunction with MD5 authentication.
·     3dessha: Converts the plaintext privacy key to an encrypted key for 3DES encryption used in conjunction with SHA-1 authentication.
·     md5: Converts the plaintext authentication key to a ciphertext key for MD5 authentication, or converts the plaintext privacy key to a ciphertext key for AES or DES encryption used in conjunction with MD5.
·     sha: Converts the plaintext authentication key to a ciphertext key for SHA-1 authentication, or converts the plaintext privacy key to a ciphertext key for AES or DES encryption used in conjunction with SHA-1 authentication.
local-engineid: Uses the local engine ID to calculate the ciphertext key. You can configure the local engine ID by using the snmp-agent local-engineid command.
specified-engineid engineid: Uses a user-defined engine ID to calculate the ciphertext key. The engineid argument specifies an SNMP engine ID as a hexadecimal string. It must contain an even number of hexadecimal characters, in the range of 10 to 64. All-zero and all-F strings are invalid.
Make sure the SNMP agent is enabled before you execute the snmp-agent calculate-password command.
For security purposes, use this command to calculate digests for ciphertext authentication and privacy keys when you create SNMPv3 users by using the snmp-agent usm-user v3 command.
The converted key is valid only under the engine ID specified for key conversion.
# Use the local engine and the SHA-1 algorithm to calculate a digest for the ciphertext key converted from the plaintext key authkey.
[Sysname] snmp-agent calculate-password authkey mode sha local-engineid
The encrypted key is: 09659EC5A9AE91BA189E5845E1DDE0CC
·     snmp-agent local-engineid
·     snmp-agent usm-user v3
Use snmp-agent community to configure an SNMP community.
Use undo snmp-agent community to delete an SNMP community.
In VACM mode:
snmp-agent community { read | write } [ simple | cipher ] community-name [ mib-view view-name ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent community { read | write } [ cipher ] community-name
In RBAC mode:
snmp-agent community [ simple | cipher ] community-name user-role role-name [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent community [ cipher ] community-name
No SNMP community exists.
read: Assigns the specified community read-only access to MIB objects. A read-only community can only inquire MIB information.
write: Assigns the specified community read and write access to MIB objects. A read and write community can configure MIB information.
simple: Sets a community name in plain text. For security purposes, this community name is saved in cipher text.
cipher: Sets and saves the community name in cipher text.
community-name: Sets a case-sensitive community name. In plain text, the community name must be a string of 1 to 32 characters. In cipher text, the community name must be a string of 33 to 73 characters. Input a string as escape characters after a backslash (\).
mib-view view-name: Specifies the MIB view available for the community. The view-name argument represents a MIB view name, a string of 1 to 32 characters. A MIB view represents a set of accessible MIB objects. If no MIB view is specified, the specified community can access the MIB objects in the default MIB view ViewDefault.
user-role role-name: Specifies a user role name for the community, a case-sensitive string of 1 to 63 characters.
acl acl-number: Specifies a basic IPv4 ACL to filter NMSs by source IPv4 address. The acl-number argument represents an ACL number in the range of 2000 to 2999. In the specified community, only NMSs with an IPv4 address permitted in the ACL can access the SNMP agent. If no ACL is specified, or the specified ACL does not exist, all NMSs in the SNMP community can access the SNMP agent. If the specified ACL does not have any rules, no NMS in the SNMP community can access the SNMP agent. For detailed information about ACL, see ACL and QoS Configuration Guide.
acl ipv6 ipv6-acl-number: Specifies a basic IPv6 ACL to filter NMSs by source IPv6 address. The ipv6-acl-number argument represents an ACL number in the range of 2000 to 2999. In the specified community, only NMSs with an IPv6 address permitted in the IPv6 ACL can access the SNMP agent. If no ACL is specified, or the specified ACL does not exist, all NMSs in the SNMP community can access the SNMP agent. If the specified ACL does not have any rules, no NMS in the SNMP community can access the SNMP agent.
This command is for SNMPv1 and SNMPv2c, and is supported only for high encryption in non-FIPS mode.
To set and save a community name in plain text, do not specify the simple or cipher keyword.
You can create up to 10 SNMP communities by using the snmp-agent community command. To create more SNMP communities, use the snmp-agent usm-user { v1 | v2c } command.
An SNMPv1 or SNMPv2c community contains a set of NMSs and SNMP agents, and is identified by a community name. An NMS and an SNMP agent must use the same community name to authenticate each other.
Typically, public is used as the read-only community name and private is used as the read and write community name. To improve security, assign your SNMP communities a name other than public and private.
You can use the following modes to control access to MIB objects for an SNMP community:
·     View-based Access Control ModelThe VACM mode controls access to MIB objects by assigning MIB views to SNMP communities.
·     Role based access controlThe RBAC mode controls access to MIB objects by assigning user roles to SNMP communities.
¡     An SNMP community with a predefined user role network-admin, mdc-admin, or level-15 has the read and write access to all MIB objects.
¡     An SNMP community with a predefined user role network-operator or mdc-operator has the read-only access to all MIB objects.
¡     An SNMP community with a user role specified by the role command accesses MIB objects through the user role rules specified by the rule command.
For more information about user roles, see Fundamentals Configuration Guide.
If you create the same SNMP community with both modes multiple times, the most recent configuration takes effect.
For an NMS to access an agent:
·     The RBAC mode requires the user role bound to the community name to have the same access right to MIB objects as the NMS.
·     The VACM mode requires only the access right from the NMS to MIB objects.
The RBAC mode is more secure. As a best practice, use the RBAC mode to create an SNMP community.
# Create the read-only community readaccess in plain text so an SNMPv1 or SNMPv2c NMS can use the community name readaccess to read the MIB objects in the default view ViewDefault.
[Sysname] snmp-agent sys-info version v1 v2c
[Sysname] snmp-agent community read simple readaccess
# Create the read and write community writeaccess in plain text so only the SNMPv2c NMS at 1.1.1.1 can use the community name writeaccess to read or set the MIB objects in the default view ViewDefault.
[Sysname] acl number 2001
[Sysname-acl-basic-2001] rule permit source 1.1.1.1 0.0.0.0
[Sysname-acl-basic-2001] rule deny source any
[Sysname-acl-basic-2001] quit
[Sysname] snmp-agent sys-info version v2c
[Sysname] snmp-agent community write simple writeaccess acl 2001
# Create the read and write community wr-sys-acc in plain text so an SNMPv1 or SNMPv2c NMS can use the community name wr-sys-acc to read or set the MIB objects in the system subtree (OID 1.3.6.1.2.1.1).
[Sysname] undo snmp-agent mib-view ViewDefault
[Sysname] snmp-agent mib-view included test system
[Sysname] snmp-agent community write simple wr-sys-acc mib-view test
·     display snmp-agent community
·     snmp-agent mib-view
snmp-agent community-map
Use snmp-agent community-map to map an SNMP community to an SNMP context.
Use undo snmp-agent community-map to delete the mapping between an SNMP community and an SNMP context.
snmp-agent community-map community-name context context-name
undo snmp-agent community-map community-name context context-name
No mapping between an SNMP community and an SNMP context exists on the device.
community-name: Specifies an SNMP community, a case-sensitive string of 1 to 32 characters.
context-name: Specifies an SNMP context, a case-sensitive string of 1 to 32 characters.
This command enables a module on an agent to obtain the context mapped to a community name when an NMS accesses the agent by using SNMPv1 or SNMPv2c.
You can configure a maximum of 10 community-context mappings on the device.
# Map SNMP community private to SNMP context trillcontext.
[Sysname] snmp-agent community-map private context ospfcontext
snmp-agent context
Use snmp-agent context to create an SNMP context.
Use undo snmp-agent context to delete an SNMP context.
snmp-agent context context-name
undo snmp-agent context context-name
No SNMP context is configured on the device.
Predefined use roles
An NMS and an SNMP agent can communicate with each other if the following conditions exist:
·     No SNMP context is configured on the NMS and the SNMP agent.
·     The NMS and the SNMP agent use the same SNMP context.
Otherwise, a timeout message appears, indicating a communication failure between the NMS and SNMP agent.
You can create a maximum of 20 SNMP contexts.
# Create SNMP context trillcontext.
[Sysname] snmp-agent context ospfcontext
snmp-agent group
Use snmp-agent group to create an SNMP group and specify its access right.
Use undo snmp-agent group to delete an SNMP group.
SNMPv1 and SNMP v2c:
snmp-agent group { v1 | v2c } group-name [ read-view view-name ] [ write-view view-name ] [ notify-view view-name ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent group { v1 | v2c } group-name
SNMPv3 (high encryption in non-FIPS mode):
snmp-agent group v3 group-name [ authentication | privacy ] [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
SNMPv3 (high encryption in FIPS mode):
snmp-agent group v3 group-name { authentication | privacy } [ read-view read-view ] [ write-view write-view ] [ notify-view notify-view ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent group v3 group-name [ authentication | privacy ]
No SNMP group exists.
v1: Specifies SNMPv1.
v2c: Specifies SNMPv2c.
v3: Specifies SNMPv3.
group-name: Specifies an SNMP group name, a string of 1 to 32 case-sensitive characters.
authentication: Specifies the authentication without privacy security model for the SNMPv3 group.
privacy: Specifies the authentication with privacy security model for the SNMPv3 group.
read-view view-name: Specifies a read-only MIB view. The view-name represents a MIB view name, a string of 1 to 32 characters. If no read-only MIB view is specified, the SNMP group has read access to the default view ViewDefault.
write-view view-name: Specifies a read and write MIB view. The view-name represents a MIB view name, a string of 1 to 32 characters. If no read and write view is specified, the SNMP group cannot set any MIB object on the SNMP agent.
notify-view view-name: Specifies a notify MIB view. The view-name represents a MIB view name, a string of 1 to 32 characters. The SNMP agent sends notifications to the users in the specified group only for the MIB objects included in the notify view. If no notify view is specified, the SNMP agent does not send any notification to the users in the specified group.
acl acl-number: Specifies a basic IPv4 ACL to filter NMSs by source IPv4 address. The acl-number argument represents an ACL number in the range of 2000 to 2999. In the specified SNMP group, only NMSs with an IPv4 address permitted in the ACL can access the SNMP agent. If no ACL is specified, or the specified ACL does not exist, all NMSs in the SNMP group can access the SNMP agent. If the specified ACL does not have any rules, no NMS in the SNMP community can access the SNMP agent.
acl ipv6 ipv6-acl-number: Specifies a basic IPv6 ACL to filter NMSs by source IPv6 address. The ipv6-acl-number argument represents an ACL number in the range of 2000 to 2999. In the specified SNMP group, only NMSs with an IPv6 address permitted in the IPv6 ACL can access the SNMP agent. If no ACL is specified, or the specified ACL does not exist, all NMSs in the SNMP group can access the SNMP agent. If the specified ACL does not have any rules, no NMS in the SNMP community can access the SNMP agent.
SNMPv1 and SNMPv2c settings in this command are supported only for high encryption in non-FIPS mode.
All users in an SNMP group share the security model and access rights of the group.
You can create up to 20 SNMP groups, including SNMPv1, SNMPv2c, and SNMPv3 groups.
All SNMPv3 users in a group share the same security model, but can use different authentication and privacy key settings. To implement a security model for a user and avoid SNMP communication failures, make sure the security model configuration for the group and the security key settings for the user are compliant with Table 12 and match the settings on the NMS.
Table 12 Basic security setting requirements for different security models
Security model
Security model keyword for the group
Security key settings for the user
Remarks
Authentication with privacy
privacy
Authentication key, privacy key
If the authentication key or the privacy key is not configured, SNMP communication will fail.
Authentication without privacy
authentication
Authentication key
If no authentication key is configured, SNMP communication will fail.
The privacy key (if any) for the user does not take effect.
No authentication, no privacy
Neither authentication nor privacy
None
The authentication and privacy keys, if configured, do not take effect.
# Create the SNMPv3 group group1, and assign the no authentication, no privacy security model to the group.
[Sysname] snmp-agent group v3 group1
·     display snmp-agent group
Use snmp-agent local-engineid to change the SNMP engine ID of the local SNMP agent.
Use undo snmp-agent local-engineid to restore the default local SNMP engine ID.
The local engine ID is the combination of the company ID and the device ID. Device ID varies by product and might be an IP address, a MAC address, or any user-defined hexadecimal string.
engineid: Specifies an SNMP engine ID as a hexadecimal string. It must contain an even number of hexadecimal characters, in the range of 10 to 64. All-zero and all-F strings are invalid.
An SNMP engine ID uniquely identifies an SNMP entity in an SNMP managed network. Make sure the local SNMP engine ID is unique within your SNMP managed network to avoid communication problems.
If you have configured SNMPv3 users, change the local SNMP engine ID only when necessary. The change can void the SNMPv3 usernames and encrypted keys you have configured.
# Change the local engine ID to 123456789A.
[Sysname] snmp-agent local-engineid 123456789A
·     display snmp-agent local-engineid
snmp-agent log
Use snmp-agent log to enable logging SNMP operations.
Use undo snmp-agent log to disable logging SNMP operations.
snmp-agent log { all | get-operation | set-operation | authfail }
undo snmp-agent log { all | get-operation | set-operation | authfail }
SNMP logging is disabled.
all: Enables logging SNMP authentication failures, Get operations, and Set operations.
authfail: Enables logging SNMP authentication failures.
get-operation: Enables logging SNMP Get operations.
set-operation: Enables logging SNMP Set operations.
Use SNMP logging to record the SNMP operations performed on the SNMP agent or authentication failures from the NMS to the agent for auditing NMS behaviors. The SNMP agent sends log data to the information center. You can configure the information center to output the data to a destination as needed.
# Enable logging SNMP Get operations.
[Sysname] snmp-agent log get-operation
# Enable logging SNMP Set operations.
[Sysname] snmp-agent log set-operation
# Enable logging SNMP authentication failures.
[Sysname] snmp-agent log authfail
snmp-agent mib-view
Use snmp-agent mib-view to create or update a MIB view.
Use undo snmp-agent mib-view to delete a MIB view.
undo snmp-agent mib-view view-name
The system creates the ViewDefault view when the SNMP agent is enabled. In this default MIB view, all MIB objects in the iso subtree but the snmpUsmMIB, snmpVacmMIB, and snmpModules.18 subtrees are accessible.
excluded: Denies access to any node in the specified MIB subtree.
included: Permits access to all the nodes in the specified MIB subtree.
view-name: Specifies a view name, a string of 1 to 32 characters.
oid-tree: Specifies a MIB subtree by its root node's OID (for example, 1.3.6.1.2.1.1) or object name (for example, system). An OID is a dotted numeric string that uniquely identifies an object in the MIB tree.
mask mask-value: Sets a MIB subtree mask, a hexadecimal string. Its length must be an even number in the range of 2 to 32.
A MIB view represents a set of MIB objects (or MIB object hierarchies) with certain access privilege. The MIB objects included in the MIB view are accessible while those excluded from the MIB view are inaccessible.
Each view-name oid-tree pair represents a view record. If you specify the same record with different MIB subtree masks multiple times, the most recent configuration takes effect.
The system can store entries for up to 20 unique MIB view records. In addition to the four default MIB view records, you can create up to 16 unique MIB view records. After you delete the default view with the undo snmp-agent mib-view command, you can create up to 20 unique MIB view records.
Be cautious with deleting the default MIB view. The operation blocks the access to any MIB object on the device from NMSs that use the default view.
# Include the mib-2 (OID 1.3.6.1) subtree in the mibtest view and exclude the system subtree from this view.
[Sysname] snmp-agent mib-view included mibtest 1.3.6.1
[Sysname] snmp-agent mib-view excluded mibtest system
[Sysname] snmp-agent community read public mib-view mibtest
An SNMPv1 NMS in the public community can query the objects in the mib-2 subtree but not any object (for example, the sysDescr or sysObjectID node) in the system subtree.
·     display snmp-agent mib-view
·     snmp-agent group
snmp-agent packet max-size
Use snmp-agent packet max-size to set the maximum size (in bytes) of SNMP packets that the SNMP agent can receive or send.
Use undo snmp-agent packet max-size to restore the default packet size.
The maximum size of SNMP packets that the SNMP agent can receive or send is 1500 bytes.
byte-count: Sets the maximum size (in bytes) of SNMP packets that the SNMP agent can receive or send. The value range is 484 to 17940.
If any device on the path to the NMS does not support packet fragmentation, limit the SNMP packet size to prevent large-sized packets from being discarded. For most networks, the default value is sufficient.
# Set the maximum SNMP packet size to 1024 bytes.
[Sysname] snmp-agent packet max-size 1024
snmp-agent port
Use snmp-agent port to specify the UDP port for receiving SNMP packets.
Use undo snmp-agent port to restore the default.
snmp-agent port port-num
The device uses UDP port 161 for receiving SNMP packets.
port-num: Specifies the UDP port for receiving SNMP packets, in the range of 1 to 65535. The default is 161.
After changing the port number for receiving SNMP packets, reconnect the device by using the port number for SNMP get and set operations.
To display UDP port information, use the display current-configuration command.
# Specify the UDP port for receiving SNMP packets as 5555.
[Sysname] snmp-agent port 5555
# Restore the default UDP port.
[Sysname] undo snmp-agent port
snmp-agent remote
Use snmp-agent remote to configure the SNMP engine ID of a remote SNMP entity.
Use undo snmp-agent remote to delete a remote SNMP engine ID.
snmp-agent remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] engineid engineid
undo snmp-agent remote ip-address
No remote SNMP engine ID has been configured.
ip-address: Specifies the IP address of a remote SNMP entity.
ipv6 ipv6-address: Specifies the IPv6 address of a remote SNMP entity.
vpn-instance vpn-instance-name: Specifies the VPN for a remote SNMP entity. The vpn-instance-name argument specifies the name of the MPLS L3VPN, a case-sensitive string of 1 to 31 characters. If this option is not specified, the remote SNMP entity is in the public network.
engineid: Specifies the SNMP engine ID of the remote SNMP entity. This argument must be a hexadecimal string that contains an even number of characters, in the range of 10 to 64. All-zero and all-F strings are invalid.
To send informs to an NMS, you must configure the SNMP engine ID of the NMS on the SNMP agent.
The NMS accepts the SNMPv3 informs from the SNMP agent only if the engine ID in the informs is the same as its local engine ID.
You can configure up to 20 remote SNMP engine IDs.
# Configure the SNMP engine ID (123456789A) of the SNMP manager (10.1.1.1).
[Sysname] snmp-agent remote 10.1.1.1 engineid 123456789A
snmp-agent { inform | trap } source
Use snmp-agent { inform | trap } source to specify a source IP address for the informs or traps sent by the SNMP agent.
Use undo snmp-agent { inform | trap } source to restore the default.
snmp-agent { inform | trap } source interface-type { interface-number | interface-number.subnumber }
The SNMP agent uses the IP address of the outgoing routed interface as the source IP address of notifications.
inform: Specifies informs.
trap: Specifies traps.
interface-type { interface-number | interface-number.subnumber }: Specifies an interface by its type and number. The interface-number argument specifies a main interface number. The subnumber argument specifies a subinterface number in the range of 1 to 4094.
The snmp-agent source command enables the SNMP agent to use the primary IP address of an interface or subinterface as the source IP address in all its SNMP informs or traps, regardless of their outgoing interfaces. An NMS can use this IP address to filter all the informs or traps sent by the SNMP agent.
Make sure the specified interface has been created and assigned a valid IP address. The configuration will fail if the interface has not been created and will take effect only after a valid IP address is assigned to the specified interface.
# Configure the primary IP address of GigabitEthernet 1/0/1 as the source address of SNMP traps.
[Sysname] snmp-agent trap source gigabitethernet 1/0/1
# Configure the primary IP address of GigabitEthernet 1/0/2 as the source address of SNMP informs.
[Sysname] snmp-agent inform source gigabitethernet 1/0/2
snmp-agent sys-info contact
Use snmp-agent sys-info contact to configure the system contact.
Use undo snmp-agent sys-info contact to restore the default contact.
snmp-agent sys-info contact sys-contact
The system contact is Hangzhou H3C Tech. Co., Ltd.
sys-contact: Specifies the system contact, a string of 1 to 255 characters.
Configure the system contact for system maintenance and management.
# Configure the system contact as Dial System Operator # 27345.
[Sysname] snmp-agent sys-info contact Dial System Operator # 27345
snmp-agent sys-info location
Use snmp-agent sys-info location to configure the system location.
Use undo snmp-agent sys-info location to restore the default location.
snmp-agent sys-info location sys-location
The system location is Hangzhou, China.
sys-location: Specifies the system location, a string of 1 to 255 characters.
Configure the location of the device for system maintenance and management.
# Configure the system location as Room524-row1-3.
[Sysname] snmp-agent sys-info location Room524-row1-3
Use snmp-agent sys-info version to enable SNMP versions.
Use undo snmp-agent sys-info version to disable SNMP versions.
snmp-agent sys-info contact version { all | { v1 | v2c | v3 } * }
undo snmp-agent sys-info version { all | { v1 | v2c | v3 } * }
snmp-agent sys-info version v3
undo snmp-agent sys-info version v3
No SNMP version is enabled.
all: Specifies SNMPv1, SNMPv2c, and SNMPv3.
Configure the SNMP agent with the same SNMP version as the NMS for successful communications between them.
# Enable SNMPv3.
[Sysname] snmp-agent sys-info version v3
Use snmp-agent target-host to configure the SNMP agent to send SNMP notifications (informs or traps) to a host.
Use undo snmp-agent target-host to remove an SNMP notification target host.
snmp-agent target-host inform address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string { v2c | v3 [ authentication | privacy ] }
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string [ v1 | v2c | v3 [ authentication | privacy ] ]
undo snmp-agent target-host { trap | inform } address udp-domain { ip-address | ipv6 ipv6-address } params securityname security-string [ vpn-instance vpn-instance-name ]
snmp-agent target-host inform address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string v3 { authentication | privacy }
snmp-agent target-host trap address udp-domain { ip-address | ipv6 ipv6-address } [ udp-port port-number ] [ vpn-instance vpn-instance-name ] params securityname security-string v3 { authentication | privacy }
No SNMP notification target host has been configured.
inform: Sends notifications as informs.
trap: Sends notifications as traps.
address: Specifies the destination address of SNMP notifications.
udp-domain: Specifies UDP as the transport protocol.
ip-address: Specifies the IPv4 address or host name of the target host as the destination of SNMP notifications. The host name is a case-insensitive string of 1 to 253 characters. The string can only contain letters, numbers, hyphens (-), underscores (_), and dots (.). If you specify a host name, the IPv4 address of the target host can be obtained.
ipv6 ipv6-address: Specifies the IPv6 address or host name of the target host as the destination of SNMP notifications. The host name is a case-insensitive string of 1 to 253 characters, which only contains letters, numbers, hyphens (-), underscores (_), and dots (.). If you specify a host name, the IPv6 address of the target host can be obtained.
udp-port port-number: Specifies the UDP port for SNMP notifications. If no UDP port is specified, UDP port 162 is used.
vpn-instance vpn-instance-name: Specifies the VPN for the target host. The vpn-instance-name argument specifies the name of the MPLS L3VPN, a case-sensitive string of 1 to 31 characters. If this parameter is not specified, the target host is in the public network.
params securityname security-string: Specifies the authentication parameter. The security-string argument specifies an SNMPv1 or SNMPv2c community name or an SNMPv3 username, a string of 1 to 32 characters.
·     authentication: Specifies the security model to be authentication without privacy. You must specify the authentication key when you create the SNMPv3 user.
·     privacy: Specifies the security model to be authentication with privacy. You must specify the authentication key and privacy key when you create the SNMPv3 user.
You can specify multiple SNMP notification target hosts.
Make sure the SNMP agent uses the same UDP port for SNMP notifications as the target host. Typically, NMSs, for example, IMC and MIB Browser, use port 162 for SNMP notifications as defined in the SNMP protocols.
If none of the keywords v1, v2c, or v3 is specified, SNMPv1 is used. Make sure the SNMP agent uses the same SNMP version as the target host so the host can receive the notification.
If neither authentication nor privacy is specified, the security model is no authentication, no privacy.
# Configure the SNMP agent to send SNMPv3 traps to 10.1.1.1 in the user public.
[Sysname] snmp-agent trap enable standard
[Sysname] snmp-agent target-host trap address udp-domain 10.1.1.1 params securityname public v3
·     snmp-agent { inform | trap } source
Use snmp-agent trap enable to enable SNMP notifications globally.
Use undo snmp-agent trap enable to disable SNMP notifications globally.
snmp-agent trap enable [ configuration | protocol | standard [ authentication | coldstart | linkdown | linkup | warmstart ] * | system ]
undo snmp-agent trap enable [ configuration | protocol | standard [ authentication | coldstart | linkdown | linkup | warmstart ] * | system ]
SNMP configuration notifications, standard notifications, and system notifications are enabled. Whether other SNMP notifications are enabled varies by modules.
configuration: Specifies configuration notifications. If configuration notifications are enabled, the system checks the running configuration and the startup configuration every 10 minutes for any change and generates a notification for the most recent change.
protocol: Specifies a module for enabling SNMP notifications. For more information about this argument, see the command reference for each module.
standard: Specifies SNMP standard notifications.
Table 13 Standard SNMP notifications
Keyword
Definition
authentication
Authentication failure notification sent when an NMS fails to authenticate to the SNMP agent.
coldstart
Notification sent when the device restarts.
linkdown
Notification sent when the link of a port goes down.
linkup
Notification sent when the link of a port comes up.
warmstart
Notification sent when the SNMP agent restarts.
system: Specifies system notifications sent when the system time is modified, the system reboots, or the main system software image is not available.
The snmp-agent trap enable command enables the device to generate notifications, including both informs and traps, even though the keyword trap is used in this command.
You can use the snmp-agent target-host command to enable the device to send the notifications as informs or traps to a host.
If no optional parameters are specified, this command or its undo form enables or disables all SNMP notifications supported by the device.
# Enable the SNMP agent to send SNMP authentication failure traps to 10.1.1.1 in the community public.
[Sysname] snmp-agent trap enable standard authentication
snmp-agent trap if-mib link extended
Use snmp-agent trap if-mib link extended to configure the SNMP agent to send extended linkUp/linkDown notifications.
Use undo snmp-agent trap if-mib link extended to restore the default.
The SNMP agent sends standard linkUp/linkDown notifications.
Extended linkUp and linkDown notifications add interface description and interface type to the standard linkUp/linkDown notifications for fast failure point identification.
When you use this command, make sure the NMS supports the extended linkup and linkDown notifications.
# Enable extended linkUp/linkDown notifications.
[Sysname] snmp-agent trap if-mib link extended
Use snmp-agent trap life to configure the lifetime of notifications in the SNMP notification queue.
Use undo snmp-agent trap life to restore the default notification lifetime.
snmp-agent trap life seconds
The SNMP notification lifetime is 120 seconds.
seconds: Sets a lifetime in seconds, in the range of 1 to 2592000.
When congestion occurs, the SNMP agent buffers notifications in a queue. The notification lifetime sets how long a notification can stay in the queue. A notification is deleted when its lifetime expires.
# Set the SNMP notification lifetime to 60 seconds.
[Sysname] snmp-agent trap life 60
snmp-agent trap log
Use snmp-agent trap log to enable SNMP notification logging.
Use undo snmp-agent trap log to disable SNMP notification logging.
snmp-agent trap log
SNMP notification logging is disabled.
Use SNMP notification logging to record SNMP notifications sent by the SNMP agent for notification tracking. The SNMP agent sends logs to the information center. You can configure the information center to output the logs to a destination as needed.
# Enable SNMP notification logging.
[Sysname] snmp-agent trap log
Use snmp-agent trap queue-size to set the SNMP notification queue size.
Use undo snmp-agent trap queue-size to restore the default queue size.
The SNMP notification queue can store up to 100 notifications.
size: Sets the maximum number of notifications that the SNMP notification queue can hold. The value range is 1 to 1000.
When congestion occurs, the SNMP agent buffers notifications in a queue. SNMP notification queue size sets the maximum number of notifications that this queue can hold. When the queue size is reached, the oldest notifications are dropped for new notifications.
# Set the SNMP notification queue size to 200.
[Sysname] snmp-agent trap queue-size 200
Use snmp-agent usm-user { v1 | v2c } to add a user to an SNMPv1 or SNMPv2c group.
Use undo snmp-agent usm-user { v1 | v2c } to delete a user from an SNMPv1 or SNMPv2c group.
snmp-agent usm-user { v1 | v2c } user-name group-name [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent usm-user { v1 | v2c } user-name
No SNMP users have been configured.
user-name: Specifies an SNMP username, a case-sensitive string of 1 to 32 characters.
group-name: Specifies an SNMPv1 or SNMPv2c group name, a case-sensitive string of 1 to 32 characters. The group can be one that has been created or not. If the group has not been created, the user takes effect after you create the group.
acl acl-number: Specifies a basic IPv4 ACL to filter NMSs by source IPv4 address. The acl-number argument represents an ACL number in the range of 2000 to 2999. Only NMSs with an IPv4 address permitted in the ACL can use the specified username (community name) to access the SNMP agent. If no ACL is specified, or the specified ACL does not exist, any NMS can use the specified username to access the SNMP agent. If the specified ACL does not have any rules, no NMS in the SNMP community can access the SNMP agent.
acl ipv6 ipv6-acl-number: Specifies a basic IPv6 ACL to filter NMSs by source IPv6 address. The ipv6-acl-number argument represents an ACL number in the range of 2000 to 2999. Only NMSs with an IPv6 address permitted in the IPv6 ACL can access the SNMP agent. If no ACL is specified, or the specified ACL does not exist, any NMS can use the specified username to access the SNMP agent. If the specified ACL does not have any rules, no NMS in the SNMP community can access the SNMP agent.
This command is supported only for high encryption in non-FIPS mode.
When you create an SNMPv1 or SNMPv2c user, the system automatically creates a community that has the same name as the SNMPv1 or SNMPv2c username. This community has the same access right as the SNMPv1 or SNMPv2c group. To display the SNMPv1 and SNMPv2c communities created in this way, use the display snmp-agent community command.
To change the access right of the SNMPv1 or SNMPv2c user, use the snmp-agent community command or the snmp-agent group { v1 | v2c } command. If the snmp-agent community command is used, the SNMPv1 or SNMPv2c is removed from the SNMP group.
The snmp-agent usm-user { v1 | v2c } command enables managing SNMPv1 and SNMPv2c communities in the same way as managing SNMPv3 users. It does not affect the way of configuring SNMPv1 and SNMPv2c communities on the NMS.
# Add the user userv2c to the SNMPv2c group readCom so an NMS can use the protocol SNMPv2c and the read-only community name userv2c to access the device.
[Sysname] snmp-agent group v2c readCom
[Sysname] snmp-agent usm-user v2c userv2c readCom
# Add the user userv2c in the SNMPv2c group readCom so only the NMS at 1.1.1.1 can use the protocol SNMPv2c and read-only community name userv2c to access the device.
[Sysname] snmp-agent usm-user v2c userv2c readCom acl 2001
·     snmp-agent community
·     snmp-agent group
Use snmp-agent usm-user v3 to add a user to an SNMPv3 group or create an SNMPv3 user.
Use undo snmp-agent usm-user v3 to delete a user from an SNMPv3 group or remove an SNMPv3 user.
High encryption in non-FIPS mode (in VACM mode):
snmp-agent usm-user v3 user-name group-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | 3des | des56 } priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
undo snmp-agent usm-user v3 user-name { local | engineid engineid-string | remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] }
High encryption in non-FIPS mode (in RBAC mode):
snmp-agent usm-user v3 user-name user-role role-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode { aes128 | 3des | des56 } priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
High encryption in FIPS mode (in VACM mode):
snmp-agent usm-user v3 user-name group-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] { cipher | simple } authentication-mode sha auth-password [ privacy-mode aes128 priv-password ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
High encryption in FIPS mode (in RBAC mode):
snmp-agent usm-user v3 user-name user-role role-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode sha auth-password [ privacy-mode aes128 priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
Low encryption (in VACM mode):
snmp-agent usm-user v3 user-name group-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode des56 priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ] *
Low encryption (in RBAC mode):
snmp-agent usm-user v3 user-name user-role role-name [ remote { ip-address | ipv6 ipv6-address } [ vpn-instance vpn-instance-name ] ] [ { cipher | simple } authentication-mode { md5 | sha } auth-password [ privacy-mode des56 priv-password ] ] [ acl acl-number | acl ipv6 ipv6-acl-number ]
No SNMPv3 users have been configured.
user-name: Specifies an SNMPv3 username, a case-sensitive string of 1 to 32 characters.
group-name: Specifies an SNMPv3 group name, a case-sensitive string of 1 to 32 characters.
user-role role-name: Specifies a user role name, a case-sensitive string of 1 to 63 characters.
remote { ip-address | ipv6 ipv6-address }: Specifies the IPv4 or IPv6 address of the remote SNMP entity. vpn-instance vpn-instance-name: Specifies the VPN for the target host receiving SNMP notifications. The vpn-instance-name argument specifies the name of the MPLS L3VPN, a case-sensitive string of 1 to 31 characters. If this parameter is not specified, the target host is in the public network.
cipher: Specifies auth-password and priv-password as encrypted keys, which can be calculated to a hexadecimal string by using the snmp-agent calculate-password command.
simple: Specifies auth-password and priv-password as plaintext keys.
authentication-mode: Specifies an authentication algorithm. MD5 is faster but less secure than SHA. For more information about these algorithms, see Security Configuration Guide.
·     md5: Specifies the MD5 authentication algorithm.
·     sha: Specifies the SHA-1 authentication algorithm.
auth-password: Specifies a case-sensitive plaintext or encrypted authentication key. For high encryption in non-FIPS mode, a plaintext key is a string of 1 to 64 visible characters. For high encryption in FIPS mode, a plaintext key is a string of 15 to 64 visible characters, which must contain numbers, uppercase letters, lowercase letters, and special characters. If the cipher keyword is specified, the encrypted authentication key length requirements differ by authentication algorithm and key string format, as shown in Table 14.
Table 14 Encrypted authentication key length requirements
Authentication algorithm
Hexadecimal string
Non-hexadecimal string
MD5
32 characters
53 characters
SHA
40 characters
57 characters
privacy-mode: Specifies an encryption algorithm for privacy. The encryption algorithms AES, 3DES, and DES are in descending order of security strength. DES is enough to meet general security requirements.
·     aes128: Specifies the AES algorithm.
·     3des: Specifies the 3DES algorithm.
·     des56: Specifies the DES algorithm.
priv-password: Specifies a case-sensitive plaintext or encrypted privacy key. For high encryption in non-FIPS mode, a plaintext key is a string of 1 to 64 characters. For high encryption in FIPS mode, a plaintext key is a string of 15 to 64 visible characters, which must contain numbers, uppercase letters, lowercase letters, and special characters. If the cipher keyword is specified, the encrypted privacy key length requirements differ by authentication algorithm and key string format, as shown in Table 15.
Table 15 Encrypted privacy key length requirements
Encryption algorithm
Hexadecimal string
MD5
3DES
64 characters
73 characters
MD5
AES128 or DES-56
32 characters
53 characters
SHA
3DES
80 characters
73 characters
SHA
AES128 or DES-56
40 characters
53 characters
acl acl-number: Specifies a basic IPv4 ACL to filter NMSs by source IPv4 address. The acl-number argument represents an ACL number in the range of 2000 to 2999. Only NMSs with an IPv4 address permitted in the ACL can use the specified username to access the SNMP agent. If no ACL is specified, or the specified ACL does not exist, any NMS can use the specified username to access the SNMP agent. If the specified ACL does not have any rules, no NMS in the SNMP community can access the SNMP agent.
acl ipv6 ipv6-acl-number: Specifies a basic IPv6 ACL to filter NMSs by source IPv6 address. The ipv6-acl-number argument represents an ACL number in the range of 2000 to 2999. Only NMSs with an IPv6 address permitted in the IPv6 ACL can use the specified username to access the SNMP agent. If no ACL is specified, or the specified ACL does not exist, any NMS can use the specified username to access the SNMP agent. If the specified ACL does not have any rules, no NMS in the SNMP community can access the SNMP agent.
local: Specifies the local SNMP engine.
engineid engineid-string: Specifies an SNMP engine. The engineid-string argument represents the engine ID and must contain an even number of hexadecimal characters, in the range of 10 to 64. All-zero and all-F strings are invalid. After you change the local engine ID, the existing SNMPv3 users and encrypted keys become invalid, and you must reconfigure them.
SNMPv3 users are valid only on the SNMP engine that creates them. By default, SNMPv3 users are created on the local SNMP engine. When you create an SNMPv3 user for sending SNMP inform messages, you must associate it with the remote SNMP engine.
To send SNMPv3 informs to an NMS, perform the following tasks:
·     Specify the IPv4 or IPv6 address of the NMS in the snmp-agent usm-user v3 command.
·     Map the IPv4 or IPv6 address to the SNMP engine ID of the NMS by using the snmp-agent remote command.
You can use the following modes to control access to MIB objects for an SNMPv3 user:
·     View-based Access Control ModelIn VACM mode, you must create an SNMPv3 group before you assign an SNMPv3 user to the group. Otherwise, the user cannot take effect after it is created. An SNMP group contains one or multiple users and specifies the MIB views and security model for the group of users. The authentication and encryption algorithms for each user are specified when they are created.
·     Role based access controlThe RBAC mode controls access to MIB objects by assigning user roles to SNMP users.
¡     An SNMP user with a predefined user role network-admin, mdc-admin, or level-15 has the read and write access to all MIB objects.
¡     An SNMP user with a predefined user role network-operator or mdc-operator has the read-only access to all MIB objects.
¡     An SNMP user with a user role specified by the role command accesses MIB objects through the user role rules specified by the rule command.
After creating an SNMPv3 user in this mode, you can use the snmp-agent usm-user v3 user-role command to assign a maximum of 64 user roles to the SNMPv3 user.
In VACM mode, if you configure an SNMPv3 user multiple times, the most recent configuration takes effect.
In RBAC mode, you can assign different user roles to an SNMPv3 user:
·     If you specify only user roles but do not change any other settings, the snmp-agent usm-user v3 command assigns different user roles to the user. Other settings remain unchanged.
·     If you specify user roles and also change other settings, the snmp-agent usm-user v3 command assigns different user roles to the user. The most recent configuration for other settings takes effect.
·     The RBAC mode requires the user role bound to the username to have the same access right to MIB objects as the NMS.
The RBAC mode is more secure. As a best practice, use the RBAC mode to create an SNMPv3 user.
For security purposes, all keys, including keys configured in plain text, are saved in cipher text.
Make sure you remember the username and the plain text of the keys. When you access the device from an NMS, you must provide this information.
In VACM mode:
# Add the user testUser to the SNMPv3 group testGroup, and enable the authentication without privacy security model for the group. Specify the authentication algorithm SHA-1 and the authentication key 123456TESTplat&! in plain text for the user.
[Sysname] snmp-agent group v3 testGroup authentication
[Sysname] snmp-agent usm-user v3 testUser testGroup simple authentication-mode sha 123456TESTplat&!
# For an NMS to access the MIB objects in the default view ViewDefault, make sure the following configurations on the NMS are the same as the SNMP agent:
·     SNMPv3 username.
·     SNMP protocol version.
·     Authentication algorithm and key.
# Add the user testUser to the SNMPv3 group testGroup, and enable the authentication and privacy security model for the group. Specify the authentication algorithm SHA-1, the privacy algorithm AES, the plaintext authentication key 123456TESTauth&!, and the plaintext privacy key 123456TESTencr&! for the user.
[Sysname] snmp-agent group v3 testGroup privacy
[Sysname] snmp-agent usm-user v3 testUser testGroup simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
·     SNMPv3 username.
·     Authentication algorithm.
·     Privacy algorithm.
·     Plaintext authentication and privacy keys.
# Add the user remoteUser for the SNMP remote engine at 10.1.1.1 to the SNMPv3 group testGroup, and enable the authentication and privacy security model for the group. Specify the authentication algorithm SHA-1, the privacy algorithm AES, the plaintext authentication key 123456TESTauth&!, and the plaintext privacy key 123456TESTencr&! for the user.
[Sysname] snmp-agent usm-user v3 remoteUser testGroup remote 10.1.1.1 simple authentication-mode sha 123456TESTauth&! privacy-mode aes128 123456TESTencr&!
In RBAC mode:
# Create the SNMPv3 user testUser with the user role network-operator and enable the authentication without privacy security model for the user. Specify the authentication algorithm SHA-1 and the authentication key 123456TESTplat&! in plain text for the user.
[Sysname] snmp-agent usm-user v3 testUser user-role network-operator simple authentication-mode sha 123456TESTplat&!
# For an NMS to have read-only access to all MIB objects, make sure the following configurations on the NMS are the same as the SNMP agent:
·     SNMPv3 username.
·     display snmp-agent usm-user
·     snmp-agent calculate-password
·     snmp-agent group
·     snmp-agent remote
·     snmp-agent usm-user v3 user-role
Use snmp-agent usm-user v3 user-role to assign a user role to an SNMPv3 user created in RBAC mode.
Use undo snmp-agent usm-user user-role to remove a user role.
undo snmp-agent usm-user v3 user-name user-role role-name
No SNMPv3 users have been configured in RBAC mode.
You can assign a maximum of 64 user roles to an SNMPv3 user.
An SNMPv3 user must have a minimum of one user role.
# Assign the user role network-admin to the SNMPv3 user testUser.
[Sysname] snmp-agent usm-user v3 testUser user-role network-admin
