02-Virtual Technologies Command Reference
HomeSupportSwitchesS7500E-X SeriesReference GuidesCommand ReferencesH3C S7500E-X Switch Series Command References-Release7178-6W10002-Virtual Technologies Command Reference
01-IRF commands
01-IRF commands 211.46 KB
IRF commands
All IRF commands are available only on the default MDC, except for the commands in Table 1.
Table 1 IRF commands available on both default and non-default MDCs
Command category
Commands
Display commands
display irf link
MAD commands
mad arp enable
mad bfd enable
mad enable
mad nd enable
mad exclude interface
mad ip address
For more information about MDCs, see Virtual Technologies Configuration Guide.
chassis convert mode irf
Use chassis convert mode irf to enable IRF mode.
Use undo chassis convert mode to restore standalone mode.
The device operates in standalone mode.
To set up an IRF fabric, place all member devices in IRF mode after you configure member IDs, priorities, and IRF port settings for the member devices. In standalone mode, a device cannot form an IRF fabric with other devices.
IRF generates packets on a device in IRF mode even if the device does not form an IRF fabric with any other devices. To conserve system resources, set a device to standalone mode after you remove the device from an IRF fabric.
The device automatically reboots for the mode change to take effect. During the reboot, you may choose to have the system automatically convert the startup configuration file. Automatic configuration conversion prevents chassis-, slot- or interface-related settings from becoming invalid. For example, the system adds member ID information to interface numbers and file paths in IRF mode.
# Enable IRF mode.
[Sysname] chassis convert mode irf
The device will switch to IRF mode and reboot.
You are recommended to save the current running configuration and specify the configuration file for the next startup. Continue? [Y/N]:y
Do you want to convert the content of the next startup configuration file flash:/startup.cfg to make it available in IRF mode? [Y/N]:y
Now rebooting, please wait...
# Restore standalone mode.
[Sysname] undo chassis convert mode
The device will switch to stand-alone mode and reboot.
Do you want to convert the content of the next startup configuration file flash:/startup.cfg to make it available in stand-alone mode? [Y/N]:y
display irf
Use display irf to display IRF fabric information, including the member ID, role, priority, bridge MAC address, and description of each IRF member.
display irf
# Display IRF fabric information.
<Sysname> display irf
MemberID  Slot  Role   Priority  CPU-Mac         Description
 *+1      0     Master 1         00e0-fc0f-8c08  ---
 The Bridge MAC of the IRF is: 0000-fc00-2500
 Auto upgrade                : yes
 Mac persistent              : always
 Domain ID                   : 0
 Auto merge                  : yes
 IRF mode                    : normal
MemberID
IRF member ID:
·     ID of the master is prefixed with an asterisk (*) sign.
·     ID of the device where you are logged in is prefixed with a plus (+) sign.
Slot
MPU slot number.
Role
Role of the MPU in the IRF fabric:
·     Standby—Standby MPU for the global active MPU.
·     Master—Global active MPU.
·     Loading—Standby MPU for the global active MPU. The standby MPU is loading software images.
Priority
IRF member priority.
CPU-MAC
MAC address of the CPU on the MPU.
Description you have configured for the member device.
·     If no description is configured, this field displays a dashed line (---).
·     If the description exceeds the maximum number of characters that can be displayed, an ellipsis (…) is displayed in place of the exceeding text. To display the complete description, use the display current-configuration command.
Auto upgrade
Status of the software auto-update feature:
·     yes—Enabled. The global active MPU automatically pushes its software images to the MPUs you are adding to the IRF fabric.
·     no—Disabled. You must manually make sure the joining MPUs use the same software images as the global active MPU. If the software images are different, the joining MPUs cannot be added to the IRF fabric.
MAC persistent
IRF bridge MAC persistence setting:
·     6 minBridge MAC address of the IRF fabric remains unchanged for 6 minutes after the address owner leaves.
·     alwaysBridge MAC address of the IRF fabric does not change after the address owner leaves.
·     no—Bridge MAC address of the current master replaces the original bridge MAC address as soon as the owner of the original address leaves.
Auto merge
State of the auto-merge feature:
·     yesEnabled. The IRF fabric automatically reboots its member devices when it fails in the master election during an IRF fabric merge.
·     noDisabled. Manual reboot is required to complete an IRF fabric merge.
IRF mode
IRF mode:
·     enhanced.
·     light.
·     normal.
display irf configuration
Use display irf configuration to display basic IRF settings, including each member's current member ID, new member ID, and physical interfaces bound to the IRF ports. The new member IDs take effect at reboot.
# (In standalone mode.) Display the basic IRF settings of the device.
<Sysname> display irf configuration
 MemberID Priority IRF-Port1                   IRF-Port2
 --         1         disable                  disable
# (In IRF mode.) Display all members' basic IRF settings.
 MemberID  NewID  IRF-Port1                     IRF-Port2
  1        1      Ten-GigabitEthernet1/1/0/1    disable
                  Ten-GigabitEthernet1/1/0/2
  2        2      disable                       Ten-GigabitEthernet2/1/0/1
                                                Ten-GigabitEthernet2/1/0/2
MemberID
Current member ID of the device.
This field displays two hyphens (--) if no member ID is assigned.
Priority
Member priority.
This field is available when the device is operating in standalone mode.
NewID
Member ID assigned to the device. This member ID takes effect at reboot.
This field is available when the device is operating in IRF mode.
IRF-Port1
Physical interfaces bound to IRF-port 1. The bindings take effect at reboot.
This field displays disable if no physical interfaces are bound to the IRF port.
IRF-Port2
Physical interfaces bound to IRF-port 2. The bindings take effect at reboot.
display irf link
Use display irf link to display IRF link information, including IRF ports, IRF physical interfaces, and IRF link status.
display irf link
# Display IRF link information.
<Sysname> display irf link
Member 1
 IRF Port    Interface                       Status
 1           disable                            --
 2           GigabitEthernet1/3/0/1          UP
             GigabitEthernet1/5/0/1          ADM
             GigabitEthernet1/6/0/1          DOWN
Member 2
 1           GigabitEthernet2/3/0/1          UP
             GigabitEthernet2/5/0/1          DOWN
             GigabitEthernet2/6/0/1          ADM
 2           disable                            --
Member ID
IRF member ID.
IRF Port
IRF port number:
·     1IRF-port 1.
·     2IRF-port 2.
Physical interfaces bound to the IRF port. This field displays disable if no physical interfaces have been bound to the IRF port.
Status
Link state of the IRF physical interface:
·     UP—The link is up.
·     DOWN—The link is down.
·     ADM—The interface has been manually shut down by using the shutdown command.
·     ABSENT—Module that hosts the interface is not present.
display irf topology
Use display irf topology to display IRF fabric topology information, including the member IDs, IRF port state, adjacencies of IRF ports, and CPU MAC address of the master.
# Display the IRF fabric topology.
<Sysname> display irf topology
                           Topology Info
               IRF-Port1                IRF-Port2
 MemberID    Link       neighbor      Link       neighbor    Belong To
 3           DIS        ---           DOWN       ---         00e0-fc0f-8c08
Table 5 Command output
IRF-Port 1
Information about IRF-port 1, including its link state and neighbor.
IRF-Port 2
Information about IRF-port 2, including its link state and neighbor.
Link
Link state of the IRF port:
·     UPThe IRF link is up.
·     DOWNThe IRF link is down.
·     DISNo physical interfaces have been bound to the IRF port. To bind a physical interface to the IRF port, use the port group interface command.
·     TIMEOUTIRF hello interval has timed out.
·     ISOLATE—The device is isolated from the IRF fabric. This issue might be caused by the following reasons:
¡     The IRF fabric does not support the device model.
¡     The maximum number of member devices has exceeded the upper limit.
neighbor
IRF member ID of the device connected to the IRF port.
If no device is connected to the IRF port, this field displays three hyphens (---).
Belong To
IRF fabric that has the device, represented by the CPU MAC address of the master in the IRF fabric.
display irf-port load-sharing mode
Use display irf-port load-sharing mode to display load sharing mode for IRF links.
display irf-port load-sharing mode [ irf-port [ member-id/irf-port-number ] ]
irf-port: Displays IRF port-specific load sharing modes. If you do not specify this keyword, the command displays the global load sharing mode for IRF links.
member-id/irf-port-number: Specifies an IRF port number. The member-id argument represents an IRF member ID. The irf-port-number argument represents the index number (1 or 2) of the IRF port on the member device. If you do not specify the member-id and irf-port-number arguments, this command displays the load sharing mode used on each IRF port in the IRF fabric. If no IRF ports are in up state, this command displays No IRF link exists.
# Display the global load sharing mode for IRF links. In this example, because no user-defined global load sharing mode has been configured, the default global load sharing mode applies.
<Sysname> display irf-port load-sharing mode
irf-port Load-Sharing Mode:
Layer 2 traffic: destination-mac address  source-mac address
Layer 3 traffic: destination-ip address   source-ip address
Layer 4 traffic: destination-port         source-port
# Display the load sharing mode of IRF-port 1/1. In this example, because neither port-specific load sharing mode nor user-defined global load sharing mode has been configured, the default global load sharing mode applies.
<Sysname> display irf-port load-sharing mode irf-port 1/1
irf-port1/1 Load-Sharing Mode:
Layer 2 traffic: destination-mac address, source-mac address
Layer 3 traffic: destination-ip address,  source-ip address
Layer 4 traffic: destination-port,        source-port
# Display the load sharing mode used on each IRF port.
irf-port 1/1 Load-Sharing Mode:
Table 6 Command output
Global load sharing mode for IRF links:
·     If no global IRF link load sharing mode has been configured, the default global load sharing mode applies.
·     If a user-defined global load sharing mode has been configured, the configured mode applies.
Link load sharing mode of IRF-port 1/1:
·     If you have not configured a port-specific load sharing mode, the global IRF link load sharing mode applies.
·     If you have configured a port-specific load sharing mode, the configured mode applies.
Default load sharing mode for traffic that has no IP header. By default, this type of traffic is distributed based on source and destination MAC addresses.
Default load sharing mode for non-TCP/-UDP IP packets. By default, this type of traffic is distributed based on source and destination IP addresses.
Default load sharing mode for TCP/UDP packets. By default, this type of traffic is distributed based on source and destination port numbers.
Configured load sharing mode of IRF-port 1/1. Packets are distributed based on their destination MAC addresses.
display mad
Use display mad to display MAD status and settings.
display mad [ verbose ]
verbose: Displays detailed MAD information. If you do not specify this keyword, the command only displays whether a MAD mechanism is enabled or disabled.
# Display brief MAD information.
<Sysname> display mad
MAD ARP disabled.
MAD ND disabled.
MAD LACP disabled.
MAD BFD disabled.
# Display detailed MAD information.
<Sysname> display mad verbose
Multi-active recovery state: No
Excluded ports (user-configured):
Excluded ports (system-configured):
  FortyGigE1/0/0/1
  FortyGigE1/0/0/2
  Ten-GigabitEthernet1/2/0/47
  Ten-GigabitEthernet1/7/0/45
  Ten-GigabitEthernet2/3/0/25
  Ten-GigabitEthernet2/7/0/45
MAD ARP enabled interface:
  Vlan-interface4
MAD ND disabled.
MAD LACP disabled.
MAD BFD enabled interface: Vlan-interface3
  MAD status                 : Faulty
  Member ID   MAD IP address       Neighbor   MAD status
  1           88.1.1.1/24          2          Faulty
  2           88.1.1.2/24          1          Faulty
Table 7 Command output
Whether the IRF fabric is in Recovery state.
·     Yes—The IRF fabric is in Recovery state. When MAD detects that an IRF fabric has split into multiple IRF fabrics, it allows one fabric to forward traffic. All the other IRF fabrics are set to the Recovery state. In Recovery state, MAD shuts down all physical ports in the fabric except for the IRF physical interfaces and ports configured to not shut down.
·     No—The IRF fabric is not in Recovery state. The fabric is active and can forward traffic.
Ports manually configured to not shut down when the IRF fabric transits to the Recovery state.
Ports set to not shut down by default when the IRF fabric transits to the Recovery state.
MAD status
MAD link status:
·     Normal—The MAD link is operating correctly.
·     Faulty—The MAD link is faulty. Check the interface or port for connectivity or configuration problems.
·     N/A—MAD link status cannot be detected. This field always displays N/A if BFD MAD is enabled on a management Ethernet port.
Member ID
IRF member ID of the local device.
Port
Member ports of the aggregate interface used for LACP MAD.
Neighbor
IRF member ID of the neighbor member device.
irf auto-merge enable
Use irf auto-merge enable to enable IRF auto-merge.
Use undo irf auto-merge enable to disable IRF auto-merge.
IRF auto-merge is enabled. The IRF fabric that has failed in the master election reboots automatically to complete the IRF fabric merge.
If the IRF auto-merge feature is disabled, you must follow the system instructions to manually reboot member devices in the IRF fabric that fails master election.
For a successful merge, make sure IRF auto-merge is enabled on both IRF fabrics that are merging.
This command is supported only in IRF mode. When you change the operating mode from IRF to standalone, the setting for this command is lost, regardless of whether you have saved the configuration. To disable IRF auto-merge after you change the operating mode from standalone to IRF, use the undo form of this command.
IRF auto-merge takes effect on merges caused by the following events:
·     The IRF link recovers from a link failure.
·     The IRF physical interfaces of the member devices are connected after the interfaces are bound to IRF ports.
The feature does not take effect on a merge that occurs in the following conditions:
·     You bind a physical interface to an IRF port.
·     The interface has been connected to the peer IRF physical interface before the binding operation.
# Enable IRF auto-merge.
[Sysname] irf auto-merge enable
irf auto-update enable
Use irf auto-update enable to enable the software auto-update feature.
Use undo irf auto-update enable to disable the software auto-update feature.
The software auto-update feature is enabled.
This command is supported only in IRF mode. When you change the operating mode from IRF to standalone, the setting for this command is lost, regardless of whether you have saved the configuration. To disable software auto-update after you change the operating mode from standalone to IRF, use the undo form of this command.
This command automatically propagates the current software images of the master MPU in the IRF fabric to any MPUs you are adding to the IRF fabric.
To ensure a successful software update, verify that the new MPU you are adding to the IRF fabric has sufficient storage space for the new software images. If sufficient storage space is not available, the MPU automatically deletes the current software images. If the reclaimed space is still insufficient, the MPU cannot complete the auto-update. You must reboot the device that holds the MPU, and then access the BootWare menus to delete files.
You must manually update the new MPU with the software images running on the IRF fabric in the following situations:
·     Software auto-update is disabled.
·     Software auto-update fails to update software. This situation might occur if the IRF fabric cannot identify the software version used on the new MPU.
# Enable the software auto-update feature.
[Sysname] irf auto-update enable
irf domain
Use irf domain to assign a domain ID to an IRF fabric.
Use undo irf domain to restore the default IRF domain setting.
irf domain domain-id
undo irf domain
The IRF domain ID is 0.
domain-id: Specifies a domain ID for the IRF fabric. The value range is 0 to 4294967295.
This command is supported only in IRF mode. When you change the operating mode from IRF to standalone, the IRF domain setting is lost, regardless of whether you have saved the configuration.
One IRF fabric forms one IRF domain. IRF uses IRF domain IDs to uniquely identify IRF fabrics and prevent IRF fabrics from interfering with one another.
If one IRF fabric uses another IRF fabric as the intermediate device for LACP MAD, ARP MAD or ND MAD, you must assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
An IRF fabric has only one IRF domain ID. You can change the IRF domain ID by using the following commands: irf domain, mad enable, mad arp enable, or mad nd enable. The IRF domain IDs configured by using these commands overwrite each other.
In an MDC environment, the irf domain command is available only on the default MDC. The mad enable, mad arp enable, and mad nd enable commands are available on all MDCs. If you change the IRF domain ID in one MDC, the IRF domain IDs in all other MDCs change automatically.
# Set the IRF domain ID to 30.
[Sysname] irf domain 30
irf isolate member
Use irf isolate member to isolate an unused IRF member ID.
Use undo irf isolate member to remove the isolation setting for an IRF member ID.
irf isolate member member-id
undo irf isolate member member-id
No IRF member IDs are isolated.
member-id: Specifies an IRF member ID. Available values are IDs that have not been assigned.
CRC errors or traffic storms occur if an IRF member device tags inter-chassis packets with a valid unused member ID. This issue is typically caused by poor-quality fiber modules, fibers, or cables on IRF links.
To avoid CRC errors or traffic storms, isolate the unused member IDs in the valid member ID range. When an unused member ID is isolated, the member devices will drop all packets that are tagged with the member ID.
Before you assign an isolated member ID to a new member device, you must remove the isolation setting for the member ID by using the undo irf isolate member command.
# Isolate IRF member ID 3.
[Sysname] irf isolate member 3
irf link-delay
Use irf link-delay to set a delay for the IRF ports to report a link down event.
Use undo irf link-delay to restore the default.
irf link-delay interval
undo irf link-delay
The IRF link down event report delay is 1 second.
interval: Sets the IRF link down report delay in the range of 0 to 10000 milliseconds. If the interval is set to 0, link down events are reported without any delay. The greater the interval, the slower the service recovery.
This command is supported only in IRF mode. When you change the operating mode from IRF to standalone, the command configuration is lost, regardless of whether you have saved the configuration.
If the CFD or BFD feature is used in the IRF fabric, make sure the delay interval is shorter than the maximum CCM lifetime and BFD session lifetime. For more information about CFD and BFD, see High Availability Configuration Guide.
As a best practice, set the delay to 0 seconds in the following situations:
·     The IRF fabric requires a quick master/subordinate or IRF link switchover.
·     The BFD, BFD MAD, GR, or RRPP feature is used.
# Set the IRF link down report delay to 300 milliseconds.
[Sysname] irf link-delay 300
irf mac-address persistent
Use irf mac-address persistent to configure IRF bridge MAC persistence.
Use undo irf mac-address persistent to enable the IRF fabric to change its bridge MAC address as soon as the address owner leaves.
irf mac-address persistent { always | timer }
always: Enables the IRF bridge MAC address to be permanent. The IRF bridge MAC address does not change after the address owner leaves.
timer: Enables the IRF bridge MAC address to remain unchanged for 6 minutes after the address owner leaves. If the address owner rejoins the IRF fabric within the time limit, the IRF bridge MAC address does not change. If the address owner does not rejoin within the time limit, the IRF fabric uses the bridge MAC address of the current master as the bridge MAC address.
Bridge MAC persistence is supported only in IRF mode. When you change the operating mode from IRF to standalone, the bridge MAC persistence setting is lost, regardless of whether you have saved the configuration.
If the undo form of this command is configured, bridge MAC address of the current master replaces the original IRF bridge MAC as soon as the original address owner leaves.
If ARP MAD or ND MAD is used, execute the undo irf mac-address persistent command to disable IRF bridge MAC persistence.
If two IRF fabrics have the same bridge MAC address, they cannot merge.
# Enable the IRF bridge MAC address to be permanent.
[Sysname] irf mac-address persistent always
irf member
Use irf member to assign a member ID to the device in standalone mode.
Use undo irf member to restore the default.
irf member member-id
undo irf member
The device operates in standalone mode and does not have a member ID.
member-id: Assigns an IRF member ID to the device. The value range is 1 to 4.
Assign an IRF member ID to a device before enabling IRF mode. The member ID takes effect after IRF mode is enabled. This member ID must be unique among all IRF member devices.
If no member ID is assigned to the device in standalone mode, the device uses a member ID of 1 after its operating mode changes to IRF.
To change the member ID of a device in IRF mode, use the irf member member-id renumber new-member-id command. The new member ID takes effect at reboot.
# (In standalone mode.) Assign member ID 2 to the device.
[Sysname] irf member 2
irf member renumber
irf member description
Use irf member description to configure a description for an IRF member.
Use undo irf member description to restore the default.
irf member member-id description text
undo irf member member-id description
No description is configured for an IRF member device.
member-id: Specifies the ID of an IRF member, in the range of 1 to 4.
text: Configures the IRF member description, a string of 1 to 127 characters.
Configure a description to describe the location or purpose of a member device.
This command is supported only in IRF mode. When you change the operating mode from IRF to standalone, the IRF member description is lost, regardless of whether you have saved the configuration.
# Configure a description for IRF member 1.
[Sysname] irf member 1 description F1Num001
irf member priority
Use irf member priority to change the priority of an IRF member.
Use undo irf member priority to restore the default.
irf member member-id priority priority
undo irf member member-id priority
The IRF member priority is 1.
member-id: Specifies an IRF member ID in the range of 1 to 4.
priority: Sets priority in the range of 1 to 32. The greater the priority value, the higher the priority. A member with higher priority is more likely to be the master.
This command is available in IRF mode. The new priority setting takes effect at the next master election, but it does not trigger a master election.
To assign an IRF priority to a device in standalone mode, use the irf priority command.
# (In IRF mode.) Set the priority of IRF member 2 to 32.
[Sysname] irf member 2 priority 32
irf priority
irf member renumber
Use irf member renumber to change the member ID of a device in the IRF fabric.
Use undo irf member renumber to restore the previous IRF member ID of the device.
undo irf member member-id renumber
In IRF mode, the device uses the member ID that is set in standalone mode. If no member ID is assigned to the device in standalone mode, the device uses a member ID of 1 after its operating mode changes to IRF.
member-id: Specifies the ID of an IRF member device, in the range of 1 to 4.
new-member-id: Assigns a new ID to the IRF member device, in the range of 1 to 4.
CAUTION
CAUTION:
In IRF mode, an IRF member ID change can invalidate member ID-related settings, including interface and file path settings, and cause data loss. Make sure you fully understand its impact on your live network.
The new IRF member ID, including the one set by using the undo irf member renumber command, takes effect after you reboot the member device.
To cancel the change before you reboot the member device, use the undo irf member renumber command. In the command, set the new member ID to be the same as the old member ID.
When adding a device into an IRF fabric, you must assign a unique IRF member ID to the device. If its IRF member ID has been used in the IRF fabric, the device cannot join the IRF fabric.
Interchanging member IDs between IRF member devices might cause undesirable configuration changes and data loss. For example, the IRF member IDs of Device A and Device B are 2 and 3, respectively. After you interchange their member IDs, their port settings also interchange.
To set the member ID of a device in standalone mode, use the irf member command.
# (In IRF mode.) Change the member ID of an IRF member from 2 to 4.
[Sysname] irf member 2 renumber 4
Renumbering the member ID may result in configuration change or loss. Continue?[Y/N]y
# (In IRF mode.) Before rebooting the device, cancel the change in the preceding example.
[Sysname] undo irf member 2 renumber
If you reboot the device after executing the irf member 2 renumber 4 command, the device member ID changes to 4 at system reboot. Using undo irf member 2 renumber cannot restore the member ID to 2.
irf member
irf priority
Use irf priority to assign an IRF member priority to a device in standalone mode.
Use undo irf priority to restore the default.
irf priority priority
undo irf priority
priority: Specifies an IRF member priority value in the range of 1 to 32. The greater the priority value, the higher the priority. A member with higher priority is more likely to be the master.
The member priority configured in standalone mode takes effect after you enable IRF mode.
To change the member priority of a device in IRF mode, use the irf member member-id priority priority command. The new priority setting takes effect at the next master election, but it does not trigger a master election.
# (In standalone mode.) Assign IRF member priority 32 to the device.
[Sysname] system-view
[Sysname] irf priority 32
irf member priority
irf-port global load-sharing mode
Use irf-port global load-sharing mode to set the global load sharing mode for IRF links.
Use undo irf-port global load-sharing mode to restore the default.
irf-port global load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
The following are criteria for distributing different types of packets across IRF links:
·     TCP/UDP packets—Source and destination TCP/UDP port numbers.
·     Non-TCP/-UDP IP packets—Source and destination IP addresses.
·     Non-IP packets (packets without an IP header)—Source and destination MAC addresses.
destination-ip: Distributes traffic across IRF member links based on destination IP address.
destination-mac: Distributes packets across IRF member links based on destination MAC address.
ingress-port: Distributes packets across IRF member links based on incoming port. This keyword is not supported in the current software version.
source-ip: Distributes packets across IRF member links based on source IP address.
source-mac: Distributes packets across IRF member links based on source MAC address.
The global IRF link load sharing mode applies to all IRF ports in the IRF fabric. You can configure the sharing mode to include a combination of multiple criteria for making traffic distribution decisions. If your device does not support a criterion combination, the system displays an error message.
If you configure the global load sharing mode multiple times, the most recent configuration takes effect.
You can also configure a port-specific load sharing mode for an IRF port in IRF port view by using the irf-port load-sharing mode command.
An IRF port preferentially uses the port-specific load sharing mode. If no port-specific load sharing mode is available, the port uses the global load sharing mode.
# Configure the global IRF link load sharing mode to distribute traffic based on destination MAC address.
[Sysname] irf-port global load-sharing mode destination-mac
Use irf-port load-sharing mode to configure a port-specific load sharing mode for an IRF port to distribute traffic across its physical links.
Use undo irf-port load-sharing mode to restore the default.
irf-port load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
IRF port view
To successfully configure a port-specific load sharing mode for an IRF port, make sure you have bound a minimum of one physical interface to the IRF port.
You can configure an IRF port-specific load sharing mode to include a combination of multiple criteria for making traffic distribution decisions. If your device does not support a criterion combination, the system displays an error message.
If you configure the port-specific load sharing mode multiple times on an IRF port, the most recent configuration takes effect.
# Configure a port-specific load sharing mode for IRF-port 1/1 to distribute traffic based on destination MAC address.
[Sysname] irf-port 1/1
[Sysname-irf-port1/1] irf-port load-sharing mode destination-mac
irf-port member-id/port-number
Use irf-port member-id/port-number to enter IRF port view in IRF mode.
Use undo irf-port member-id/port-number to removing all port bindings on an IRF port in IRF mode.
member-id/port-number: Specifies an IRF port on an IRF member. The member-id argument represents the ID of the IRF member. The port-number argument represents the IRF port index and must be 1 or 2.
To bind physical interfaces to an IRF port, you must enter IRF port view.
Before you remove all port bindings on an IRF port, shut down all its physical interfaces.
# (In IRF mode.) Enter the view of IRF-port 1 on member 1.
irf-port port-number
Use irf-port port-number to enter IRF port view in standalone mode.
Use undo irf-port port-number to remove all port bindings on an IRF port in standalone mode.
port-number: Specifies an IRF port number, which must be 1 or 2.
Before removing all port bindings on an IRF port, shut down all its physical interfaces.
# (In standalone mode.) Enter IRF-port 1 view.
[Sysname-irf-port1]
irf-port-configuration active
Use irf-port-configuration active to activate IRF port settings.
After connecting the physical interfaces between two devices and binding them to the correct IRF ports, you must use this command to activate the settings on the IRF ports. This command merges the two devices into one IRF fabric.
The system activates the IRF port settings automatically in the following situations:
·     The configuration file that the device starts with contains IRF port bindings.
·     You are binding physical interfaces to an IRF port after an IRF fabric is formed.
To configure and activate IRF-port 1/2:
# Bind Ten-GigabitEthernet 1/1/0/27 to IRF-port 1/2.
[Sysname] interface ten-gigabitEthernet 1/1/0/27
[Sysname-Ten-GigabitEthernet1/1/0/27] shutdown
[Sysname-Ten-GigabitEthernet1/1/0/27] quit
[Sysname] irf-port 1/2
[Sysname-irf-port1/2] port group interface Ten-GigabitEthernet 1/1/0/27
You must perform the following tasks for a successful IRF setup:
Save the configuration after completing IRF configuration.
Execute the "irf-port-configuration active" command to activate the IRF ports.
[Sysname-irf-port1/2] quit
[Sysname-Ten-GigabitEthernet1/1/0/27] undo shutdown
# Save the configuration so the IRF port settings can take effect after the device reboots.
[Sysname] save
 Validating file. Please wait............................
Chassis 1 Slot 1:
 Save next configuration file successfully.
 Configuration is saved to device successfully.
# Activate the IRF port settings.
[Sysname] irf-port-configuration active
mad arp enable
Use mad arp enable to enable ARP MAD.
Use undo mad arp enable to disable ARP MAD.
mad arp enable
undo mad arp enable
ARP MAD is disabled.
Layer 3 interface view
ARP MAD detects multi-active collisions by using extended ARP packets.
Do not configure ARP MAD on VLAN-interface 1.
You can use ARP MAD with ND MAD, but not with LACP MAD or BFD MAD.
·     ARP MAD handles collisions differently than LACP MAD.
·     ARP MAD requires the spanning tree feature, but BFD MAD is exclusive with the spanning tree feature.
You can set up ARP MAD links between neighbor IRF members or between each IRF member device and an intermediate device.
If one IRF fabric uses another IRF fabric as the intermediate device for ARP MAD, you must assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
When you use the mad arp enable command, the system prompts you to enter a domain ID. If you do not want to change the current domain ID, press enter at the prompt.
·     An IRF fabric has only one IRF domain ID. You can change the IRF domain ID by using the following commands: irf domain, mad enable, mad arp enable, or mad nd enable. The IRF domain IDs configured by using these commands overwrite each other.
·     You can execute the mad arp enable command on any MDCs. If you change the IRF domain ID in one MDC, the new IRF domain ID takes effect immediately on all MDCs.
# Enable ARP MAD on VLAN-interface 3.
[Sysname] interface vlan-interface 3
[Sysname-Vlan-interface3] mad arp enable
 [Current domain is: 0]: 1
 The assigned  domain ID is: 1
irf domain
mad bfd enable
Use mad bfd enable to enable BFD MAD.
Use undo mad bfd enable to disable BFD MAD.
mad bfd enable
undo mad bfd enable
BFD MAD is disabled.
Management Ethernet interface view, VLAN interface view
BFD MAD uses the BFD protocol to detect multi-active collisions. This MAD mechanism can work with or without intermediate devices.
You cannot use BFD MAD with LACP MAD, because BFD MAD handles collisions differently than LACP MAD.
You cannot use BFD MAD with ARP MAD or ND MAD. BFD MAD is exclusive with the spanning tree feature, but ARP MAD and ND MAD require the spanning tree feature.
When you configure BFD MAD on a VLAN interface, follow these guidelines:
Category
BFD MAD VLAN
·     Do not enable BFD MAD on VLAN-interface 1.
·     If you are using an intermediate device, perform the following tasks both on the IRF fabric and the intermediate device:
¡     Create a VLAN and VLAN interface for BFD MAD.
¡     Assign the ports of BFD MAD links to the BFD MAD VLAN.
·     Make sure the BFD MAD VLAN belongs to only one MDC. The VLAN ID is unique across MDCs.
·     Make sure the IRF fabrics on the network use different BFD MAD VLANs.
·     Make sure the BFD MAD VLAN contains only ports on the BFD MAD links.
BFD MAD VLAN and feature compatibility
Do not use the BFD MAD VLAN for any purpose other than configuring BFD MAD.
·     Configure only the mad bfd enable and mad ip address commands on the BFD MAD-enabled VLAN interface. If you configure other features, both BFD MAD and other features on the interface might run incorrectly.
·     Disable the spanning tree feature on any Layer 2 Ethernet ports in the BFD MAD VLAN. The MAD feature is mutually exclusive with the spanning tree feature.
·     Do not bind a BFD MAD-enabled VLAN interface to a VPN instance. The MAD feature is mutually exclusive with VPN.
MAD IP address
·     To avoid problems, only use the mad ip address command to configure IP addresses on the BFD MAD-enabled VLAN interface. Do not configure an IP address by using the ip address command or configure a VRRP virtual address on the BFD MAD-enabled VLAN interface.
·     Make sure all the MAD IP addresses are on the same subnet.
·     MAD IP addresses must be unique among all IP addresses on the IRF fabric.
BFD MAD and IRF link down report delay restrictions
Set the IRF link down report delay to 0 seconds to avoid unnecessary recalculations.
When you use BFD MAD on management Ethernet ports, follow these restrictions and guidelines:
Category
Management Ethernet ports for BFD MAD
Use the first management Ethernet port on the active MPU of each member device to set up BFD MAD links.
Ports on the intermediate device for BFD MAD
If you are using an intermediate device, use common Ethernet ports on the intermediate device to set up BFD MAD links.
BFD MAD VLAN
·     On the intermediate device (if any), create a VLAN for BFD MAD, and assign the ports used for BFD MAD to the VLAN. On the IRF fabric, you do not need to assign the BFD MAD-enabled management Ethernet ports to the VLAN.
·     As a best practice, do not configure other features on the VLAN used for BFD MAD.
·     Make sure the BFD MAD VLAN on the intermediate device contains only ports on the BFD MAD links.
BFD MAD-enabled management Ethernet port and feature compatibility
Do not bind a BFD MAD-enabled management Ethernet port to a VPN instance. The MAD feature is mutually exclusive with VPN.
MAD IP address
·     Use the mad ip address command instead of the ip address command to configure MAD IP addresses on the BFD MAD-enabled management Ethernet ports.
# Enable BFD MAD on VLAN-interface 3.
[Sysname-Vlan-interface3] mad bfd enable
mad enable
Use mad enable to enable LACP MAD.
Use undo mad enable to disable LACP MAD.
mad enable
undo mad enable
LACP MAD is disabled.
Aggregate interface view
LACP MAD uses extended LACP packets to detect multi-active collisions. This MAD mechanism requires an intermediate H3C device that supports extended LACPDUs.
LACP MAD handles collisions differently than BFD MAD, ARP MAD, and ND MAD. To avoid conflicts, do not enable LACP MAD together with any of those mechanisms in an IRF fabric.
You must set up a dynamic link aggregation group that spans all IRF member devices between the IRF fabric and the intermediate device. To enable dynamic link aggregation, configure the link-aggregation mode dynamic command on the aggregate interface.
If one IRF fabric uses another IRF fabric as the intermediate device for LACP MAD, you must assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
When you use the mad enable command, the system prompts you to enter a domain ID. If you do not want to change the current domain ID, press enter at the prompt.
·     You can execute the mad enable command on any MDCs. If you change the IRF domain ID in one MDC, the new IRF domain ID takes effect immediately on all MDCs.
# Enable LACP MAD on Bridge-Aggregation 1, a Layer 2 dynamic aggregate interface.
[Sysname-Bridge-Aggregation1] mad enable
MAD LACP only enable on dynamic aggregation interface.
# Enable LACP MAD on Route-Aggregation 1, a Layer 3 dynamic aggregate interface.
[Sysname-Route-Aggregation1] link-aggregation mode dynamic
[Sysname-Route-Aggregation1] mad enable
Use mad exclude interface to exclude a physical network port from being shut down when the IRF fabric transits to the Recovery state upon detection of a multi-active collision.
Use undo mad exclude interface to restore the default MAD action on a physical network port.
mad exclude interface interface-type interface-number
undo mad exclude interface interface-type interface-number
All physical network ports but the IRF physical interfaces and console port shut down when the IRF fabric transits to the Recovery state.
interface-type interface-number: Specifies a port by its type and number.
MAD action is not configurable for IRF physical interfaces.
When MAD detects a multi-active collision, it sets all IRF fabrics except one to the Recovery state. The fabric that is not placed in Recovery state can continue to forward traffic. The Recovery-state IRF fabrics are inactive. MAD shuts down all their physical ports except the IRF physical interfaces and the ports manually configured to not shut down.
If a port must be kept in up state for special purposes such as Telnet connection, exclude the port from the shutdown action. As a best practice to avoid incorrect traffic forwarding, do not exclude any ports except for the ports used for Telnet and MAD. However, do not exclude the VLAN interface of BFD MAD and its Layer 2 member ports from being shut down.
The ports that have shut down by MAD come up when the member devices reboot to join the recovered IRF fabric. If auto recovery fails because the current master fails or any other exception occurs, use the mad restore command to manually recover the member devices and bring up the ports.
# Exclude GigabitEthernet 1/1/0/1 from being shut down when the MAD status transits to Recovery.
[Sysname] mad exclude interface gigabitethernet 1/1/0/1
mad ip address
Use mad ip address to assign a MAD IP address to an IRF member device for BFD MAD.
Use undo mad ip address to delete the MAD IP address for an IRF member device.
mad ip address ip-address { mask | mask-length } member member-id
undo mad ip address ip-address { mask | mask-length } member member-id
No MAD IP address is configured for an IRF member device.
ip-address: Specifies an IP address in dotted decimal notation. This IP address is bound to an IRF member for BFD detection and is called a MAD IP address.
mask: Specifies a subnet mask in dotted decimal notation.
mask-length: Specifies a subnet mask in length, in the range of 0 to 32.
member member-id: Specifies an IRF member ID.
To use BFD MAD, configure a MAD IP address for each IRF member. Make sure all the MAD IP addresses are on the same subnet and are unique among all IP addresses on the IRF fabric.
To avoid problems, only use the mad ip address command to configure MAD IP addresses. Do not configure a MAD IP address by using the ip address command or configure a VRRP virtual address.
The master attempts to establish BFD sessions with other members by using its MAD IP address as the source IP address.
·     When the IRF fabric is integrated, only the MAD IP address of the master takes effect. The master cannot establish a BFD session with any other member. If you execute the display bfd session command, the state of the BFD sessions is Down.
·     When the IRF fabric splits, the IP addresses of the masters in the partitioned IRF fabrics take effect. The masters can establish a BFD session. If you execute the display bfd session command, the state of the BFD session between the two devices is Up.
# Assign a MAD IP address to IRF member 1 on VLAN-interface 3.
[Sysname-Vlan-interface3] mad ip address 192.168.0.1 255.255.255.0 member 1
# Assign a MAD IP address to IRF member 2 on VLAN-interface 3.
[Sysname-Vlan-interface3] mad ip address 192.168.0.2 255.255.255.0 member 2
mad bfd enable
mad nd enable
Use mad nd enable to enable ND MAD.
Use undo mad nd enable to disable ND MAD.
mad nd enable
undo mad nd enable
ND MAD is disabled.
VLAN interface view
ND MAD uses extended NS packets of the IPv6 ND protocol to detect multi-active collisions.
You can use ND MAD with ARP MAD, but not with LACP MAD or BFD MAD.
·     ND MAD handles collisions differently than LACP MAD.
·     ND MAD requires the spanning tree feature, but BFD MAD is exclusive with the spanning tree feature.
Do not configure ND MAD on VLAN-interface 1.
You can set up ND MAD links between neighbor IRF member devices, or between each IRF member device and an intermediate device.
If one IRF fabric uses another IRF fabric as the intermediate device for ND MAD, you must assign the two IRF fabrics different domain IDs for correct split detection. False detection causes IRF split.
When you use the mad nd enable command, the system prompts you to enter a domain ID. If you do not want to change the current domain ID, press enter at the prompt.
·     You can execute the mad nd enable command on any MDCs. If you change the IRF domain ID in one MDC, the new IRF domain ID takes effect immediately on all MDCs.
# Enable ND MAD on VLAN-interface 3.
[Sysname-Vlan-interface3] mad nd enable
irf domain
mad restore
Use mad restore to restore the normal MAD state of the IRF fabric in Recovery state.
mad restore
If the active IRF fabric has failed to work before the IRF split problem is fixed, use this command to restore an IRF fabric in Recovery state. The recovered IRF fabric will take over the active IRF fabric role.
# Restore the normal MAD state of the IRF fabric in Recovery state.
[Sysname] mad restore
   This command will restore the device from multi-active conflict state. Continue? [Y/N]:Y
Restoring from multi-active conflict state, please wait...
Use port group interface to bind a physical interface to an IRF port.
Use undo port group interface to remove the binding of a physical interface and an IRF port.
port group [ mdc mdc-name ] interface interface-type interface-number [ mode { enhanced | extended } ]
undo port group [ mdc mdc-name ] interface interface-name
No physical interfaces are bound to any IRF port. A physical interface operates in enhanced mode after it is bound to an IRF port.
IRF port view
mdc mdc-name: Specifies an MDC name, a case-sensitive string of 1 to 15 characters. If the IRF physical interface belongs to a non-default MDC, you must specify this option. If the IRF physical interface belongs to the default MDC, you do not need to specify this option.
interface-type interface-number: Specifies a physical interface by its type and number.
interface-name: Specifies a physical interface in the interface-typeinterface-number format. No space is allowed between the interface-type and interface-number arguments.
mode: Specifies a binding mode for the IRF physical interface.
·     enhanced: Sets the binding mode to enhanced.
·     extended: Sets the binding mode to extended. Specify this binding mode if optical transmission devices are deployed on the IRF link. This keyword is reserved for future support.
The MDC settings might lose effect after the device reboots to join an IRF fabric. As a best practice, create MDCs and bind the physical interfaces on non-default MDCs to an IRF port only after the IRF fabric is formed. For more information about MDCs, see Virtual Technologies Configuration Guide.
In IRF mode, use the shutdown command to shut down a physical interface before you bind it to or remove it from an IRF port. To bring up the physical interface after a binding or binding removal operation, use the undo shutdown command.
In standalone mode, the shutdown and undo shutdown operations are not required.
Repeat the port group interface command to bind a maximum of eight physical interfaces to an IRF port for link redundancy.
The binding mode takes effect only after the IRF binding takes effect.
The system does not dynamically remove IRF port bindings when IRF links are lost, for example, because an interface module is removed. To remove IRF port bindings, you must use the undo port group interface command.
For more information about IRF port binding requirements, see Virtual Technologies Configuration Guide.
# (In standalone mode.) Bind Ten-GigabitEthernet 1/0/1 to IRF-port 1.
[Sysname-irf-port1] port group interface ten-gigabitethernet 1/0/1
# (In IRF mode.) Bind Ten-GigabitEthernet 1/1/0/1 to IRF-port 1 of member 1.
[Sysname] interface ten-gigabitethernet 1/1/0/1
[Sysname-Ten-GigabitEthernet1/1/0/1] shutdown
[Sysname-Ten-GigabitEthernet1/1/0/1] quit
[Sysname-irf-port1/1] port group interface ten-gigabitethernet 1/1/0/1
[Sysname-irf-port1/1] quit
[Sysname-Ten-GigabitEthernet1/1/0/1] undo shutdown
irf-port
IRF 3 commands
For information about displaying and specifying PEX startup software images, see software upgrade in Fundamentals Command Reference.
associate
Use associate to assign a virtual chassis number to a tier-1 PEX.
Use undo associate to remove the virtual chassis number of a tier-1 PEX.
associate chassis-number
undo associate
A tier-1 PEX is not assigned a virtual chassis number.
PEX port view
chassis-number: Specifies a virtual chassis number in the range of 100 to 219.
A tier-1 PEX is directly connected to the parent fabric. You must assign a unique virtual chassis number to each tier-1 PEX.
You cannot change the chassis number of a tier-1 PEX while it is starting up.
An operating tier-1 PEX will reboot if you change or remove its chassis number.
If you execute this command multiple times for a PEX port, the most recent configuration takes effect.
# Assign chassis number 100 to the tier-1 PEX attached to PEX port 2.
[Sysname] pex-port 2
[Sysname-pex-port2] associate 100
associate order
Use associate order to assign a virtual chassis number to a tier-2 PEX.
Use undo associate order to remove the virtual chassis number of a tier-2 PEX.
associate order chassis-number
undo associate order chassis-number
A tier-2 PEX is not assigned a virtual chassis number.
PEX port view
Use this command in conjunction with the associate command to set up a two-tier PEX stack.
A tier-2 PEX is directly connected to a tier-1 PEX. On the PEX port for a tier-1 PEX, you can assign a virtual chassis number only to its directly connected tier-2 PEX.
For example, the physical topology of a PEX stack is PEX port 1---PEX 100---PEX 101---PEX 102---PEX 103---(PEX port 2). To configure this PEX stack, you must perform the following tasks:
·     On PEX port 1, execute the associate 100 command and the associate order 101 command.
·     On PEX port 2, execute the associate 103 command and the associate order 102 command.
If a tier-2 PEX is directly connected to two tier-1 PEXs as in a three-member PEX stack, you can make the assignment for the tier-2 PEX on either of their PEX ports.
You must make sure the virtual chassis number assigned to a tier-2 PEX is unique.
You cannot change the virtual chassis number of a tier-2 PEX while it is starting up.
To change the assigned number, you must first remove the old number.
An operating tier-2 PEX will reboot if you change or remove its virtual chassis number.
# Assign virtual chassis number 101 to the tier-2 PEX attached to PEX port 1.
[Sysname] pex-port 1
[Sysname-pex-port1] associate order 101
·     associate
·     pex-port
·     pex-port-group
description
Use description to configure the description of a PEX port.
PEX port description uses the pex-port pex-number format (for example, pex-port 0002).
PEX port view
text: Specifies a description, a case-sensitive string of 1 to 79 characters.
# Configure the description as connecttodep2 for PEX port 2.
[Sysname-pex-port2] description connecttodep2
display pex working-mode
Use display pex working-mode to display the operating mode configuration of PEXs in the IRF 3 system.
display pex working-mode { all | chassis chassis-number slot slot-number1 [ to slot-number2 ] }
all: Specifies all PEXs.
chassis chassis-number: Specifies a PEX by its virtual chassis number. Available values are the virtual chassis numbers of all PEXs.
slot slot-number1: Specifies a PEX in the virtual chassis. In the current software version, a virtual chassis can contain only one PEX.
slot slot-number1 to slot-number2: Specifies a range of PEXs in the virtual chassis. In the current software version, a virtual chassis can contain only one PEX.
# Display the operating mode configuration of all PEXs.
<Sysname> display pex working-mode all
PEX device mode Configuration:
  Switch mode at startup:
    None
  PEX mode at startup:
    Chassis 100 slots 0
    Chassis 101 slots 0
    Chassis 102 slots 0
Table 8 Command output
Displays the operating mode configuration for PEXs.
Displays the virtual chassis number and slot number information for PEXs that will operate in switch mode after a reboot.
PEX mode at startup
Displays the virtual chassis number and slot number information for PEXs that will operate in PEX mode after a reboot.
Chassis 100 slots 0
PEX in slot 0 of chassis 100.
display pex-port
Use display pex-port to display information about PEX ports.
display pex-port [ pex-port-id ] [ verbose ]
pex-port-id: Specifies the port number of a PEX port. If you do not specify a PEX port, the command displays information about all PEX ports.
verbose: Displays detailed information about PEX ports. If you do not specify this keyword, the command displays brief information about PEX ports.
# Display brief information about all PEX ports.
<Sysname> display pex-port
PEX port 1:
  Description: pex-port 0001
  Associated chassis numbers: 2
    Chassis       PEX status
    *100          Online
     101          Online
PEX port 5:
  Description: pex-port 0005
  Associated chassis numbers: 1
    Chassis       PEX status
    *105          Online
PEX port 8:
  Description: pex-port 0008
  Group: 1
    Chassis       PEX status
    *122          Offline
# Display detailed information about all PEX ports. In this example, PEX ports have member physical interfaces.
<Sysname> display pex-port verbose
PEX port 1:
    Chassis       PEX status
    *100          Online
     101          Online
  Member interfaces: 2
    Member interface        Status               Peer interface
    XGE1/5/0/1              Forwarding           PEX100/0/0/27
    XGE2/7/0/24             Forwarding           PEX100/0/0/26
PEX port 5:
    Chassis       PEX status
    *105          Online
    XGE1/2/0/46             Forwarding           PEX105/0/0/51
    XGE1/3/0/11             Forwarding           PEX105/0/0/52
PEX port 8:
    Chassis       PEX status
    *122          Offline
  Member interfaces: 1
    FGE2/3/0/12             Down                 --
Table 9 Command output
PEX port description.
Group
PEX port group to which the PEX port belongs.
This field appears if the PEX port is assigned to a PEX port group.
Number of virtual chassis numbers for the PEX port.
Chassis
ID of the virtual chassis that contains a PEX.
This field displays No associated ID if no virtual chassis numbers are associated with the PEX port.
An asterisk (*) indicates that the PEX is directly connected to the parent fabric.
PEX status
PEX status:
·     Online—The PEX is online.
·     Offline—The PEX is offline.
·     Loading—The PEX is starting up.
Member interfaces
Number of physical interfaces assigned to the PEX port on the parent fabric.
Member interface
Physical interfaces assigned to the PEX port on the parent fabric.
Status
PEX link status:
·     ForwardingThe PEX link is operating correctly and can forward data traffic.
·     DownThe PEX link is disconnected and cannot forward any packets.
·     BlockedThe PEX link cannot forward any packets except for IRF 3 packets.
Peer interface
PEX physical interface on the PEX. This field displays two hyphens (--) if the system cannot obtain the interface name.
No member interface.
No physical interfaces have been assigned to the PEX port.
display pex-port topology
Use display pex-port topology to display PEX topology information.
display pex-port [ pex-port-id ] topology
pex-port-id: Specifies a PEX port by its ID. The value range is the PEX port IDs used on the device. If you do not specify a PEX port ID, this command displays PEX topology information for all existing PEX ports.
# Display PEX topology information for PEX port 1.
<Sysname> display pex-port 1 topology
PEX port 1:
PEX           Neighbors      Local interfaces   Peer interfaces
Chassis 100   PEX port 1     PEX100/0/0/27      XGE1/5/0/1
                             PEX100/0/0/26      XGE2/7/0/24
              Chassis 101    PEX100/0/0/28      PEX101/0/0/25
                             PEX100/0/0/25      PEX101/0/0/26
Chassis 101   Chassis 100    PEX101/0/0/25      PEX100/0/0/28
                             PEX101/0/0/26      PEX100/0/0/25
              Chassis 117    PEX101/0/0/28      PEX117/0/0/49
Chassis 117   Chassis 101    PEX117/0/0/49      PEX101/0/0/28
              Chassis 111    PEX117/0/0/50      PEX111/0/0/49
Chassis 111   PEX port 120   PEX111/0/0/50      XGE1/4/0/1
                             PEX111/0/0/52      XGE1/3/0/1
              Chassis 117    PEX111/0/0/49      PEX117/0/0/50
Table 10 Command output
PEX
Virtual chassis number of a PEX.
Neighbors
Virtual chassis number of each neighbor device. This field displays the PEX port ID if the neighbor device is a parent device.
Local interfaces
Local interface that connects to a neighbor device.
Peer interfaces
Interface that connects the neighbor device to the local interface.
irf mode
Use irf mode to configure the IRF mode.
Use undo irf mode to restore the default.
irf mode { enhanced | light | normal }
undo irf mode { enhanced | light }
The device operates in normal IRF mode to provide IRF capability.
enhanced: Specifies enhanced IRF mode. In this mode, the device can operate as a parent device in an IRF 3 system. This mode supports more PEXs than light mode.
light: Specifies light IRF mode. In this mode, the device can operate as a parent device in an IRF 3 system. This mode supports fewer PEXs than enhanced mode.
normal: Specifies normal IRF mode. In this mode, IRF 3 capability is disabled. The device can only form an independent IRF fabric with other devices.
For a device to operate as a parent device, you must enable its IRF 3 capability by setting the IRF mode to enhanced or light. The IRF mode determines the number of PEXs that an IRF 3 system can contain. Use Table 11 to choose a mode depending on feature and port-density requirements.
Table 11 Comparison of enhanced-mode and light-mode IRF 3 systems
Mode
Maximum PEXs
Remarks
Enhanced
60, in which the number of S5120-28SC-HI and S5120-52SC-HI PEXs cannot exceed 30.
In the current software version, the total number of PEXs cannot exceed 30.
To use this mode, the interface modules on the parent fabric can only be any of the following modules:
·     EC interface modules.
·     SC interface modules:
¡     LSQ1QGS4SC0.
¡     LSQM2GP24TSSC0.
¡     LSQM2GP44TSSC0.
¡     LSQM2GT24PTSSC0.
¡     LSQM2GT24TSSC0.
¡     LSQM2GT48SC0.
¡     LSQM4GV48SC0.
·     SF interface modules.
·     SG interface modules.
·     OAP module: LSU1WCME0.
·     Other interface modules cannot start up correctly when the parent fabric is operating in enhanced IRF mode.
If the parent fabric contains an LSUM1SPMAEC0 base card, the parent fabric must operate in light IRF mode for the card to start up correctly.
Light
30
Make sure the parent fabric does not have member devices that are assigned the member ID 3 or 4.
The parent devices must operate in the same IRF mode.
For the mode change to take effect, you must reboot the device.
If PEX stack is used, you must set the IRF operating mode to light.
# Enable enhanced IRF mode.
[Sysname] irf mode enhanced
Do you want to change the IRF capability? [Y/N]:y
IRF capability changed. For the setting to take effect, save the configuration,
and then reboot the device.
member pex-port
Use member pex-port to assign a PEX port to a PEX port group.
Use undo member pex-port to remove a PEX port from a PEX port group.
member pex-port pex-port-id
undo member pex-port pex-port-id
A PEX port group does not contain PEX ports.
PEX port group view
pex-port-id: Specifies a PEX port by its ID, in the range of 1 to 120.
To set up a PEX stack, you must assign all its PEX ports to the same PEX port group. For example, the physical topology of a PEX stack is (PEX port 1)—PEX 100—PEX 101—PEX 102—PEX 103—(PEX port 2). To set up the PEX stack, you must assign PEX port 1 and PEX port 2 to the same PEX port group.
# Assign PEX port 1 and PEX port 2 to PEX port group 1.
[Sysname] pex-port group 1
[Sysname-pex-port-group-1] member pex-port 1
[Sysname-pex-port-group-1] member pex-port 2
·     associate order
·     pex-port-group
·     pex-port
pex working-mode
Use pex working-mode to set the operating mode of PEXs.
Use undo pex working-mode to restore the default.
pex working-mode switch { all | chassis chassis-number slot slot-number1 [ to slot-number2 ] }
undo pex working-mode { all | chassis chassis-number slot slot-number1 [ to slot-number2 ] }
A PEX operates in PEX mode.
switch: Specifies the switch operating mode. In this mode, the specified devices operate independently. It is not part of an IRF 3 system, whether or not it has connections to the parent fabric.
This command does not change the current operating mode of specified PEXs. For the mode change to take effect, you must reboot the PEXs. After the PEXs reboot, you must save the configuration for the configuration to survive a reboot.
To cancel the mode change configuration, use the undo form of this command before you reboot the device. However, the undo command takes effect after the PEXs reboot.
# Set the operating mode to switch for the PEX in virtual chassis 100.
[Sysname] pex working-mode switch chassis 100 slot 0
Are you sure you want to force a change to switch mode?[Y/N]: y
If you want to change PEX device to switch mode, you must reboot the device.
[Sysname] quit
<Sysname> reboot chassis 100
pex-port
Use pex-port to create a PEX port and enter PEX port view. If the port has been created, the command only places you in PEX port view.
Use undo pex-port to delete a PEX port.
undo pex-port pex-port-id
No PEX ports exist.
pex-port-id: Specifies a PEX port number in the range of 1 to 120.
PEX ports are logical ports for managing PEXs.
Each PEX must be assigned to a PEX port. All PEX settings for a PEX are configured on its PEX port.
Before you delete a PEX port, check its state. If the PEX port is in Online state, the delete operation will cause the attached PEXs to reboot.
# Create PEX port 2.
[Sysname-pex-port2]
pex-port global load-sharing mode
Use pex-port global load-sharing mode to set the global load sharing mode for PEX links.
Use undo pex-port global load-sharing mode to restore the default.
pex-port global load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
The following are criteria for distributing different types of packets across PEX links:
destination-ip: Distributes traffic across PEX member links based on destination IP address.
destination-mac: Distributes packets across PEX member links based on destination MAC address.
ingress-port: Distributes packets across PEX member links based on incoming port. This keyword is not supported in the current software version.
source-ip: Distributes packets across PEX member links based on source IP address.
source-mac: Distributes packets across PEX member links based on source MAC address.
The global PEX link load sharing mode applies to all PEX ports on the parent fabric. You can configure the sharing mode to include a combination of multiple criteria for making traffic distribution decisions. If your device does not support a criterion combination, the system displays an error message.
You can also configure a port-specific load sharing mode for a PEX port in PEX port view by using the pex-port load-sharing mode command.
A PEX port preferentially uses the port-specific load sharing mode. If no port-specific load sharing mode is available, the port uses the global load sharing mode.
# Configure the global PEX link load sharing mode to distribute traffic based on destination MAC address.
[Sysname] pex-port global load-sharing mode destination-mac
Use pex-port load-sharing mode to configure a port-specific load sharing mode for a PEX port to distribute traffic across its physical links.
Use undo pex-port load-sharing mode to restore the default.
pex-port load-sharing mode { destination-ip | destination-mac | ingress-port | source-ip | source-mac } *
PEX port view
To successfully configure a port-specific load sharing mode for a PEX port, make sure you have bound a minimum of one physical interface to the PEX port.
You can configure a PEX port-specific load sharing mode to include a combination of multiple criteria for making traffic distribution decisions. If your device does not support a criterion combination, the system displays an error message.
If you configure the port-specific load sharing mode multiple times on a PEX port, the most recent configuration takes effect.
# Configure a port-specific load sharing mode for PEX port 1 to distribute traffic based on destination MAC address.
[Sysname-pex-port1] pex-port load-sharing mode destination-mac
pex-port-group
Use pex-port-group to create a PEX port group and enter its view, or enter the view of an existing PEX port group.
Use undo pex-port-group to delete a PEX port group.
pex-port-group group-id
undo pex-port-group group-id
No PEX port groups exist.
group-id: Specifies a PEX port group ID in the range of 1 to 60.
# Create PEX port group 1, and assign PEX port 1 and PEX port 2 to the PEX port group.
[Sysname] pex-port-group 1
member pex-port
Use port group interface to assign a physical interface to a PEX port on the parent fabric.
Use undo port group interface to remove a physical interface from a PEX port.
port group interface interface-type interface-number
undo port group interface interface-name
No physical interfaces are assigned to a PEX port.
PEX port view
interface-type interface-number: Specifies a physical interface by its type and number. Available interfaces include SFP+ and QSFP+ ports.
You can assign a maximum of six physical interfaces to the PEX port for a PEX. The physical interfaces are aggregated automatically for backup and load balancing. The default configuration is automatically restored on the interfaces after the assignment.
You must connect a PEX port's all physical interfaces to the same PEX.
If a physical interface has been assigned to a PEX port, you cannot assign the interface to any other PEX port.
Make sure the PEX physical interfaces at the two ends of a PEX link are at the same rate.
The SFP+ ports on the LSUM1TGS24EC0 module are grouped by port number in order, starting from 1. Each group contains four ports.
The SFP+ ports on the LSQM2TGS16SF0 module are divided into the following groups:
·     Ports 1, 2, 15, and 16.
·     Ports 3 through 5.
·     Ports 6 through 8.
·     Ports 9 through 11.
·     Ports 12 through 14.
If you use the SFP+ ports in a group for PEX links, follow these restrictions and guidelines:
·     You must use all or none of the ports for PEX links. The SFP+ ports can be assigned to different PEX ports.
·     To shut down or bring up any SFP+ ports in the group, you must make sure all the SFP+ ports have been assigned to or removed from PEX ports.
A PEX port must have a minimum of one physical interface in Forwarding state for its PEXs to communicate with the parent device correctly. If a PEX port has only one physical interface in Forwarding state, the attached PEXs will reboot when any of the following events occur:
·     The interface is removed from the PEX port.
·     The interface goes down.
# Assign the physical interfaces Ten-GigabitEthernet 1/2/0/1 through Ten-GigabitEthernet 1/2/0/4 to PEX port 3.
[Sysname] interface range ten-gigabitethernet 1/2/0/1 to ten-gigabitethernet 1/2/0/4
[Sysname-if-range] shutdown
[Sysname] pex-port 3
[Sysname-pex-port3] port group interface ten-gigabitethernet 1/2/0/1
[Sysname-pex-port3] port group interface ten-gigabitethernet 1/2/0/2
[Sysname-pex-port3] port group interface ten-gigabitethernet 1/2/0/3
[Sysname-pex-port3] port group interface ten-gigabitethernet 1/2/0/4
[Sysname-pex-port3] quit
[Sysname-if-range] undo shutdown
