09-ACL and QoS Command Reference
HomeSupportSwitchesH3C S10500 Switch SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release7178-6W10009-ACL and QoS Command Reference
02-QoS commands
02-QoS commands 310.37 KB
QoS policy commands· 1
Traffic class commands· 1
display traffic classifier 1
if-match· 2
traffic classifier 7
Traffic behavior commands· 8
accounting· 8
car 8
display traffic behavior 10
filter 12
nest top-most 12
redirect 13
remark customer-vlan-id· 14
remark dot1p· 14
remark drop-precedence· 15
remark dscp· 16
remark ip-precedence· 17
remark local-precedence· 18
remark qos-local-id· 18
remark service-vlan-id· 19
traffic behavior 20
QoS policy commands· 20
classifier behavior 20
control-plane· 21
display qos policy· 22
display qos policy control-plane· 23
display qos policy control-plane pre-defined· 24
display qos policy global 27
display qos policy interface· 28
display qos vlan-policy· 29
qos apply policy· 30
qos apply policy global 32
qos policy· 32
qos vlan-policy· 33
reset qos policy control-plane· 34
reset qos policy global 34
reset qos vlan-policy· 35
Priority mapping commands· 36
Priority map commands· 36
display qos map-table· 36
import 37
qos map-table· 38
Port priority commands· 38
qos priority· 38
Priority trust mode commands· 39
display qos trust interface· 39
qos trust 40
GTS and rate limit commands· 41
GTS commands· 41
display qos gts interface· 41
qos gts· 41
Rate limit commands· 42
display qos lr 42
qos lr 43
Congestion management commands· 45
SP commands· 45
display qos queue sp interface· 45
qos sp· 46
WRR commands· 46
display qos queue wrr interface· 46
qos wrr 47
qos wrr { byte-count | weight } 48
qos wrr group sp· 49
WFQ commands· 50
display qos queue wfq interface· 50
qos bandwidth queue· 51
qos wfq· 52
qos wfq { byte-count | weight } 53
qos wfq group sp· 54
Queue scheduling profile commands· 55
bandwidth queue· 55
display qos qmprofile configuration· 56
display qos qmprofile interface· 57
qos apply qmprofile· 58
qos qmprofile· 58
queue· 59
Congestion avoidance commands· 61
display qos wred interface· 61
display qos wred table· 61
qos wred apply· 63
qos wred queue table· 63
queue· 64
queue ecn· 65
queue weighting-constant 66
Global CAR commands· 68
car name· 68
display qos car name· 69
qos car 70
reset qos car name· 72
Queue-based accounting commands· 73
display qos queue-statistics interface outbound· 73
QoS policy commands
Use display traffic classifier to display traffic classes.
In standalone mode:
In IRF mode:
display traffic classifier user-defined [ classifier-name ] [ chassis chassis-number slot slot-number ]
user-defined: Displays user-defined traffic classes.
classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the traffic classes on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify this option, the command displays traffic classes on the global active MPU. (In IRF mode.)
# Display all user-defined traffic classes.
  User-defined classifier information:
   Classifier: 1 (ID 100)
     Operator: AND
     Rule(s) :
      If-match acl 2000
   Classifier: 2 (ID 101)
     Operator: AND
     Rule(s) :
      If-match not protocol ipv6
   Classifier: 3 (ID 102)
     Operator: AND
     Rule(s) :
      -none-
Classifier
Traffic class name and its match criteria.
Operator
Match operator you set for the traffic class. If the operator is AND, the traffic class matches the packets that match all its match criteria. If the operator is OR, the traffic class matches the packets that match any of its match criteria.
Rule(s)
Match criteria.
if-match
Use if-match to define a match criterion.
Use undo if-match to delete a match criterion.
if-match match-criteria
undo if-match match-criteria
No match criterion is configured.
Traffic class view
match-criteria: Specifies a match criterion. Table 2 shows the available match criteria.
Table 2 Available match criteria
Option
acl [ ipv6 ] { acl-number | name acl-name }
Matches an ACL.
The value range for the acl-number argument is 2000 to 5999 for IPv4 ACLs and 2000 to 5999 for IPv6 ACLs.
The acl-name argument is a case-insensitive string of 1 to 63 characters, which must start with an English letter. To avoid confusion, the argument cannot be all.
any
Matches all packets.
control-plane protocol protocol-name&<1-8>
Matches control plane protocols.
The protocol-name&<1-8> argument specifies a space-separated list of up to eight system-defined control plane protocols. For available system-defined control plane protocols, see Table 3. For the ICMPv6 protocol, the switch supports matching only echo request packets and echo reply packets.
control-plane protocol-group protocol-group-name
Matches a control plane protocol group.
The protocol-group-name argument can be critical, exception, important, management, monitor, normal, or redirect.
customer-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in inner VLAN tags of double-tagged packets.
The dot1p-value&<1-8> argument specifies a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
customer-vlan-id vlan-id-list
Matches VLAN IDs in inner VLAN tags of double-tagged packets.
The vlan-id-list argument specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 to vlan-id2. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
destination-mac mac-address
Matches a destination MAC address.
This option takes effect only on Ethernet interfaces.
dscp dscp-value&<1-8>
Matches DSCP values.
The dscp-value&<1-8> argument specifies a space-separated list of up to eight DSCP values. The value range for the dscp-value argument is 0 to 63 or keywords shown in Table 5.
forwarding-layer route
Matches Layer 3 forwarded packets.
ip-precedence ip-precedence-value&<1-8>
Matches IP precedence values.
The ip-precedence-value&<1-8> argument specifies a space-separated list of up to eight IP precedence values. The value range for the ip-precedence-value argument is 0 to 7.
Matches a protocol.
The protocol-name argument can be ip or ipv6.
qos-local-id local-id-value
Matches a local QoS ID in the range of 1 to 4095.
service-dot1p dot1p-value&<1-8>
Matches 802.1p priority values in outer VLAN tags.
The dot1p-value&<1-8> argument is a space-separated list of up to eight 802.1p priority values. The value range for the dot1p-value argument is 0 to 7.
service-vlan-id vlan-id-list
Matches VLAN IDs in outer VLAN tags.
You can use the VLAN ID in the outer VLAN tag to match single-tagged packets.
source-mac mac-address
Matches a source MAC address.
Table 3 Available system-defined control plane protocols
Protocol
arp
ARP packets
arp-snooping
ARP snooping packets
bgp
BGP packets
bgp4+
IPv6 BGP packets
dhcp
DHCP packets
dhcp-snooping
DHCP snooping packets
dhcp6
DHCPv6 packets
dldp
DLDP packets
dot1x
802.1X packets
icmp
ICMP packets
icmp6
ICMPv6 packets
igmp
IGMP packets
ip-option
IPv4 packets with the Options field
ipv6-option
IPv6 packets with the Options field
isis
IS-IS packets
lacp
LACP packets
lldp
LLDP packets
mvrp
MVRP packets
ospf-multicast
OSPF multicast packets
ospf-unicast
OSPF unicast packets
ospf3-multicast
OSPFv3 multicast packets
ospf3-unicast
OSPFv3 unicast packets
ssh
SSH packets
stp
STP packets
telnet
Telnet packets
vrrp
VRRP packets
vrrp6
IPv6 VRRP packets
Only the following match criteria are supported to match MPLS packets:
·     customer-dot1p.
·     customer-vlan-id.
·     destination-mac.
·     service-dot1p.
·     source-mac.
In a traffic class with the logical OR operator, you can configure multiple if-match commands for any of the available match criteria. You can also configure multiple values in one if-match command for any of the following available match criteria:
·     802.1p priority.
·     Control plane protocol.
·     DSCP.
·     IP precedence.
·     VLAN ID.
To delete a criterion that has multiple values, make sure the specified values in the undo if-match command are the same as those specified in the if-match command. The order of values can be different.
In a traffic class with the logical AND operator, if you configure multiple values for a match criterion, the traffic behavior associated with the traffic class cannot be applied correctly.
When you configure ACL-based match criteria for a traffic class, follow these restrictions and guidelines:
·     If the ACL used as a match criterion does not exist, the traffic class cannot be applied to hardware.
·     You can add two if-match statements that use the same ACL as the match criterion. In one statement, specify the ACL by its name. In the other statement, specify the ACL by its number.
For single-tagged packets, you can use the service-vlan-id criterion to match them.
For the control plane protocol match criterion, you can use the display qos policy control-plane pre-defined command to display predefined control plane protocols.
If a traffic class includes the control-plane protocol or control-plane protocol-group match criterion, the QoS policy that uses this traffic class can be applied only to a control plane.
# Define a match criterion for traffic class class1 to match the packets with a destination MAC address of 0050-ba27-bed3.
# Define a match criterion for traffic class class2 to match the packets with a source MAC address of  0050-ba27-bed2.
# Define a match criterion for traffic class class1 to match the double-tagged packets with 802.1p priority 3 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with 802.1p priority 5 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-dot1p 5
# Define a match criterion for traffic class class1 to match the advanced ACL 3101.
# Define a match criterion for traffic class class1 to match the ACL named flow.
# Define a match criterion for traffic class class1 to match the advanced IPv6 ACL 3101.
# Define a match criterion for traffic class class1 to match the IPv6 ACL named flow.
# Define a match criterion for traffic class class1 to match all packets.
# Define a match criterion for traffic class class1 to match the packets with a DSCP value of 1, 6, or 9.
[Sysname-classifier-class1] if-match dscp 1 6 9
# Define a match criterion for traffic class class1 to match the packets with an IP precedence value of 1 or 6.
[Sysname-classifier-class1] if-match ip-precedence 1 6
# Define a match criterion for traffic class class1 to match IP packets.
# Define a match criterion for traffic class class1 to match double-tagged packets with VLAN ID 1, 6, or 9 in the inner VLAN tag.
# Define a match criterion for traffic class class1 to match the packets with VLAN ID 2, 7, or 10 in the outer VLAN tag.
[Sysname-classifier-class1] if-match service-vlan-id 2 7 10
# Define a match criterion for traffic class class1 to match the packets with a local QoS ID of 3.
[Sysname-classifier-class1] if-match qos-local-id 3
# Define a match criterion for traffic class class1 to match ARP protocol packets.
[Sysname-classifier-class1] if-match control-plane protocol arp
# Define a match criterion for traffic class class1 to match packets of the protocols in protocol group normal.
[Sysname-classifier-class1] if-match control-plane protocol-group normal
traffic classifier
Use traffic classifier to create a traffic class and enter traffic class view.
Use undo traffic classifier to delete a traffic class.
No traffic class exists.
classifier-name: Specifies a traffic class name, a case-sensitive string of 1 to 31 characters.
operator: Sets the operator to logic AND (the default) or OR for the traffic class.
and: Specifies the logic AND operator. The traffic class matches the packets that match all its criteria.
or: Specifies the logic OR operator. The traffic class matches the packets that match any of its criteria.
# Create a traffic class class1.
accounting
Use accounting to configure a traffic accounting action in a traffic behavior.
Use undo accounting to delete the action.
accounting [ byte | packet ]
undo accounting
No traffic accounting action is configured.
Traffic behavior view
byte: Counts traffic in bytes.
packet: Counts traffic in packets.
If you do not specify the byte or packet keyword, the switch counts traffic in packets.
# Configure a traffic accounting action in traffic behavior database to count traffic in bytes.
[Sysname-behavior-database] accounting byte
car
Use car to configure a CAR action in a traffic behavior.
Use undo car to delete the action.
car cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] * [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
car cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] * [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
No CAR action is configured.
cir committed-information-rate: Specifies the committed information rate (CIR) in kbps, which is an average traffic rate. The value range for committed-information-rate is 8 to 160000000. The value must be an integral multiple of 8.
cbs committed-burst-size: Specifies the committed burst size (CBS) in bytes. The value range for the committed-burst-size argument is 512 to 256000000. The value must be an integral multiple of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the excess burst size (EBS) in bytes. The value range for the excess-burst-size argument is 0 to 256000000. The value must be an integral multiple of 512.
pir peak-information-rate: Specifies the peak information rate (PIR) in kbps. The value range for the peak-information-rate argument is 8 to 160000000. The value must be an integral multiple of 8.
green action: Specifies the action to take on packets that conform to the CIR. The default setting is pass.
red action: Specifies the action to take on the packet that conforms to neither the CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to the PIR but not to the CIR. The default setting is pass.
action: Sets the action to take on the packet:
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
·     remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
·     remark-dscp-pass new-dscp: Sets the DSCP value of the packet to new-dscp and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63.
·     remark-lp-pass new-local-precedence: Sets the local precedence value of the packet to new-local-precedence and permits the packet to pass through. The new-local-precedence argument is in the range of 0 to 7.
hierarchy-car-name: Specifies the name of the used hierarchical CAR action.
mode: Specifies the collaborating mode of the hierarchical CAR action and the common CAR action:
·     and: Specifies the AND mode (the default mode). In this mode, the traffic rate of a flow is limited by both the common CAR applied to it and the total traffic rate defined with hierarchical CAR. For example, you can perform the following configurations:
¡     Use common CAR actions to limit the rate of Internet access flow 1 and that of flow 2 to 128 kbps respectively.
¡     Use a hierarchical CAR action to limit their total traffic rate to 192 kbps.
When flow 1 is not present, flow 2 can access the Internet at the maximum rate, 128 kbps. If both flows are present, each flow cannot exceed its own rate limit, and the total rate cannot exceed 192 kbps.
·     or: Specifies the OR mode. In this mode, a flow can perform one of the following tasks:
¡     Pass through at the rate equal to the common CAR applied to it.
¡     Pass through at a higher rate if the total traffic rate of all flows does not exceed the hierarchical CAR.
¡     Use generic CAR actions to limit the rate of video flow 1 and that of flow 2 to 128 kbps respectively.
¡     Use a hierarchical CAR action to limit their total traffic rate to 512 kbps.
As long as the rate of flow 1 does not exceed 128 kbps, flow 2 can pass at a rate up to 384 kbps.
To use two rates for traffic policing, configure the car command with the pir peak-information-rate option. To use one rate for traffic policing, configure the car command without the pir peak-information-rate option.
A CAR action can be applied in the inbound or outbound direction of an interface.
If you configure the car command multiple times in the same traffic behavior, the most recent configuration takes effect.
# Configure a CAR action in traffic behavior database as follows:
·     Set the CIR to 200 kbps, CBS to 51200 bytes, and EBS to 0.
·     Transmit conforming packets, and mark excess packets with DSCP value 0 and transmit them.
[Sysname-behavior-database] car cir 200 cbs 51200 ebs 0 green pass red remark-dscp-pass 0
Use display traffic behavior to display traffic behaviors.
In standalone mode:
In IRF mode:
display traffic behavior user-defined [ behavior-name ] [ chassis chassis-number slot slot-number ]
user-defined: Displays user-defined traffic behaviors.
behavior-name: Specifies a behavior by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic behavior, this command displays all traffic behaviors.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays traffic behaviors on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify this option, the command displays traffic behaviors on the global active MPU. (In IRF mode.)
# Display all user-defined traffic behaviors.
  User-defined behavior information:
    Behavior: 1 (ID 100)
      Marking:
        Remark dscp 3
      Committed Access Rate:
        CIR 200 (kbps), CBS 51200 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Yellow action : pass
        Red action    : remark dscp default and pass
    Behavior: 2 (ID 101)
      Accounting enable: Packet
      Filter enable: Permit
      Marking:
        Remark dot1p 1
    Behavior: 3 (ID 102)
      -none-
Behavior
Name and contents of a traffic behavior.
Marking
Information about priority marking.
Remark dscp
Action of setting the DSCP value for packets.
Information about the CAR action.
Green action
Action to take on green packets.
Yellow action
Action to take on yellow packets.
Red action
Action to take on red packets.
Filter enable
Traffic filtering action.
Remark dot1p
Action of setting the 802.1p value for packets.
none
No other traffic behavior is configured.
filter
Use filter to configure a traffic filtering action in a traffic behavior.
Use undo filter to delete the action.
filter { deny | permit }
undo filter
No traffic filtering action is configured.
deny: Drops packets.
permit: Transmits packets.
# Configure a traffic filtering action as deny in traffic behavior database.
nest top-most
Use nest top-most to configure a VLAN tag adding action in a traffic behavior.
Use undo nest top-most to delete the action.
nest top-most vlan vlan-id
undo nest top-most
No VLAN tag adding action is configured.
vlan-id vlan-id: Specifies the VLAN ID to be added, in the range of 1 to 4094.
A QoS policy that contains a VLAN tag adding action can be applied only to the inbound direction of an interface.
# Configure traffic behavior b1 to add VLAN tag 123.
[Sysname] traffic behavior b1
[Sysname-behavior-b1] nest top-most vlan 123
redirect
Use redirect to configure a traffic redirecting action in a traffic behavior.
Use undo redirect to delete the action.
redirect { cpu | failover-group group-name | interface interface-type interface-number [ track-oap ] }
undo redirect { cpu | failover-group group-name | interface interface-type interface-number }
No traffic redirecting action is configured.
cpu: Redirects traffic to the CPU.
failover-group group-name: Redirects traffic to a failover group specified by its name, a case-sensitive string of 1 to 63 characters. This option is not supported in the current software version.
interface interface-type interface-number: Redirects traffic to a Layer 2 Ethernet interface specified by its type and number.
track-oap: Redirects traffic only when OAP clients are present.
After you configure a traffic redirecting action in a traffic behavior, only a traffic accounting action can be configured in the traffic behavior.
If you specify the track-oap keyword, the switch detects the presence of OAP clients and redirects traffic to the interface only when OAP clients are present.
The switch supports redirecting traffic to only a Layer 2 Ethernet interface for interface QoS policies.
# Configure redirecting traffic to the CPU in the traffic behavior database.
[Sysname-behavior-database] redirect cpu
# Configure redirecting traffic to GigabitEthernet 1/0/1 in the traffic behavior database.
[Sysname-behavior-database] redirect interface gigabitethernet 1/0/1
·     classifier behavior
·     qos policy
·     traffic behavior
Use remark customer-vlan-id to configure a CVLAN marking action in a traffic behavior.
Use undo remark customer-vlan-id to delete the action.
No CVLAN marking action is configured.
vlan-id: Specifies a CVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with CVLAN 111.
[Sysname-behavior-b1] remark customer-vlan-id 111
remark dot1p
Use remark dot1p to configure an 802.1p priority marking action or an inner-to-outer tag priority copying action in a traffic behavior.
Use undo remark dot1p to delete the action.
remark [ green | red | yellow ] dot1p dot1p-value
undo remark [ green | red | yellow ] dot1p
undo remark dot1p
No 802.1p priority marking action or inner-to-outer tag priority copying action is configured.
green: Specifies green packets.
red: Specifies red packets.
yellow: Specifies yellow packets.
dot1p-value: Specifies the 802.1p priority to be marked for packets, in the range of 0 to 7.
customer-dot1p-trust: Copies the 802.1p priority value in the inner VLAN tag to the outer VLAN tag after the QoS policy is applied to an interface.
Using both the remark dot1p dot1p-value and remark dot1p customer-dot1p-trust commands will cause them to override each other. The most recent configuration takes effect.
The remark dot1p customer-dot1p-trust command does not take effect on single-tagged packets.
# Configure traffic behavior database to mark matching traffic with 802.1p 2.
[Sysname-behavior-database] remark dot1p 2
# Configure an inner-to-outer tag priority copying action in traffic behavior database.
[Sysname-behavior-database] remark dot1p customer-dot1p-trust
Use remark drop-precedence to configure a drop priority marking action in a traffic behavior.
Use undo remark drop-precedence to delete the action.
remark drop-precedence drop-precedence-value
No drop priority marking action is configured.
drop-precedence-value: Specifies the drop priority to be marked for packets, in the range of 0 to 2.
The command applies only to incoming traffic.
# Configure traffic behavior database to mark matching traffic with drop priority 2.
[Sysname-behavior-database] remark drop-precedence 2
remark dscp
Use remark dscp to configure a DSCP marking action in a traffic behavior.
Use undo remark dscp to delete the action.
undo [ green | red | yellow ] remark dscp
No DSCP marking action is configured.
dscp-value: Specifies a DSCP value, which can be a number from 0 to 63 or a keyword in Table 5.
Table 5 DSCP keywords and values
Keyword
DSCP value (binary)
DSCP value (decimal)
default
000000
0
af11
001010
10
af12
001100
12
af13
001110
14
af21
010010
18
af22
010100
20
af23
010110
22
af31
011010
26
af32
011100
28
af33
011110
30
af41
100010
34
af42
100100
36
af43
100110
38
cs1
001000
8
cs2
010000
16
cs3
011000
24
cs4
100000
32
cs5
101000
40
cs6
110000
48
cs7
111000
56
ef
101110
46
# Configure traffic behavior database to mark matching traffic with DSCP 6.
Use remark ip-precedence to configure an IP precedence marking action in a traffic behavior.
Use undo remark ip-precedence to delete the action.
remark ip-precedence ip-precedence-value
No IP precedence marking action is configured.
ip-precedence-value: Specifies the IP precedence value to be marked for packets, in the range of 0 to 7.
# Set the IP precedence to 6 for packets.
[Sysname-behavior-database] remark ip-precedence 6
Use remark local-precedence to configure a local precedence marking action in a traffic behavior.
Use undo remark local-precedence to delete the action.
remark [ green | red | yellow ] local-precedence local-precedence-value
undo remark [ green | red | yellow ] local-precedence
No local precedence marking action is configured.
local-precedence-value: Specifies the local precedence to be marked for packets, in the range of 0 to 7.
# Configure traffic behavior database to mark matching traffic with local precedence 2.
remark qos-local-id
Use remark qos-local-id to configure a local QoS ID marking action in a traffic behavior.
Use undo remark qos-local-id to delete the action.
remark qos-local-id local-id-value
No local QoS ID marking action is configured.
local-id-value: Specifies the local QoS ID to be marked for packets. The value range for this argument is 1 to 4095.
Marking a local QoS ID for traffic of multiple classes combines these traffic classes into one new class indicated by the local QoS ID. You can configure a traffic behavior for this new class to implement two levels of actions on these traffic classes.
A local QoS ID marking action can be applied only to incoming traffic.
# Configure the action of marking packets with local QoS ID 2.
[Sysname-behavior-database] remark qos-local-id 2
Use remark service-vlan-id to configure an SVLAN marking action in a traffic behavior.
Use undo remark service-vlan-id to delete the action.
No SVLAN marking action is configured.
vlan-id: Specifies an SVLAN ID in the range of 1 to 4094.
# Configure traffic behavior b1 to mark matching packets with SVLAN 222.
[Sysname-behavior-b1] remark service-vlan-id 222
traffic behavior
Use traffic behavior to create a traffic behavior and enter traffic behavior view.
Use undo traffic behavior to delete a traffic behavior.
No traffic behavior exists.
behavior-name: Specifies the name of the traffic behavior, a case-sensitive string of 1 to 31 characters.
# Create a traffic behavior named behavior1.
[Sysname-behavior-behavior1]
QoS policy commands
classifier behavior
Use classifier behavior to associate a traffic behavior with a traffic class in a QoS policy.
Use undo classifier to delete a class-behavior association from a QoS policy.
classifier classifier-name behavior behavior-name [ insert-before before-classifier-name | mode dcbx ] *
No traffic behavior is associated with a traffic class.
QoS policy view
behavior-name: Specifies a traffic behavior by its name, a case-sensitive string of 1 to 31 characters.
insert-before before-classifier-name: Inserts a new class before an existing class. The before-classifier-name argument specifies an existing class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify the insert-before before-classifier-name option, the new class is placed at the end of the QoS policy.
mode dcbx: Specifies that the class-behavior association applies only to DCBX. For more information about DCBX, see Layer 2—LAN Switching Configuration Guide.
A traffic class can be associated only with one traffic behavior in a QoS policy.
If the specified traffic class or traffic behavior does not exist, the system defines a null traffic class or traffic behavior.
# Associate traffic class database with traffic behavior test in QoS policy user1.
[Sysname] qos policy user1
qos policy
control-plane
Use control-plane to enter control plane view.
In standalone mode:
In IRF mode:
control-plane chassis chassis-number slot slot-number
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. (In IRF mode.)
Do not specify an MPU or switching fabric module by using the slot number. QoS policies cannot be applied to the control planes of MPUs and switching fabric modules.
# (In standalone mode.) Enter the control plane view of card 3.
[Sysname] control-plane slot 3
[Sysname-cp-slot3]
# (In IRF mode.) Enter the control plane view of card 3 on IRF member device 1.
[Sysname] control-plane chassis 1 slot 3
[Sysname-cp-chassis1-slot3]
display qos policy
Use display qos policy to display the configuration of QoS policies.
In standalone mode:
In IRF mode:
display qos policy user-defined [ policy-name [ classifier classifier-name ] ] [ chassis chassis-number slot slot-number ]
user-defined: Specifies user-defined QoS policies.
policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a QoS policy, this command displays the configuration of all user-defined QoS policies.
classifier classifier-name: Specifies a traffic class by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a traffic class, this command displays all traffic classes.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the QoS policies on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify this option, the command displays the configuration of QoS policies on the global active MPU. (In IRF mode.)
# Display the configuration of all user-defined QoS policies.
  User-defined QoS policy information:
  Policy: 1 (ID 100)
     Behavior: 1
      Marking:
        Remark dscp 3
        CIR 112 (kbps), CBS 7000 (Bytes), EBS 512 (Bytes)
        Green action  : pass
        Red action    : discard
     Behavior: 2
      Marking:
        Remark mpls-exp 4
     Behavior: 3
      -none-
For the output description, see Table 1 and Table 4.
Use display qos policy control-plane to display the QoS policy applied to a control plane.
In standalone mode:
In IRF mode:
display qos policy control-plane chassis chassis-number slot slot-number
# Display the QoS policy applied to the control plane of card 3 on IRF member device 1.
<Sysname> display qos policy control-plane chassis 1 slot 3
Control plane chassis 1 slot 3
  Direction: Inbound
  Policy: p1
   Classifier: c1
     Operator: AND
     Rule(s) :
      If-match dscp cs3
     Behavior: b1
        CIR 1000 (kbps), CBS 62976 (Bytes), EBS 0 (Bytes)
        Green action  : pass
        Green packets : 0 (Packets)
        Red packets   : 0 (Packets)
Table 6 Command output
Direction
Inbound direction on the control plane.
Green packets
Statistics about green packets.
Red packets
Statistics about red packets.
For the description of other fields, see Table 1 and Table 4.
Use display qos policy control-plane pre-defined to display predefined QoS policies applied to control planes of cards.
In standalone mode:
In IRF mode:
display qos policy control-plane pre-defined [ chassis chassis-number slot slot-number ]
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the predefined QoS policy applied to the control plane of each in-position card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify this option, the command displays the predefined QoS policy applied to the control plane of each in-position card on each IRF member device. (In IRF mode.)
# (In standalone mode.) Display the predefined QoS policy applied to the control plane of slot 3.
<Sysname> display qos policy control-plane pre-defined slot 3
Pre-defined policy information slot 3
  Protocol          Priority   Bandwidth (kbps)   Group
  IS-IS             29         512                critical
  VRRP              36         512                important
  OSPF Multicast    30         256                critical
  OSPF Unicast      30         256                critical
  PIM Multicast     24         128                critical
  PIM Unicast       24         128                critical
  IGMP              18         512                important
  PIMv6 Multicast   24         64                 critical
  PIMv6 Unicast     24         64                 critical
  OSPFv3 Unicast    30         256                critical
  OSPFv3 Multicast  30         256                critical
  VRRPv6            36         512                important
  ARP               12         768                normal
  DHCP Snooping     18         256                redirect
  DHCP              18         256                normal
  802.1x            12         128                important
  STP               36         256                critical
  LACP              36         64                 critical
  MVRP              18         256                critical
  BGP               24         256                critical
  ICMP              9          512                monitor
  IPOPTION          18         384                normal
  BGPv6             24         256                critical
  IPOPTIONv6        18         64                 normal
  LLDP              24         64                 important
  DLDP              24         64                 critical
  TELNET            8          512                management
  SSH               8          512                management
  HTTP              12         64                 management
  HTTPS             12         64                 management
  TACACS            12         64                 management
  RADIUS            12         64                 management
  ARP Snooping      18         256                redirect
  ICMPv6            8          512                monitor
  DHCPv6            18         256                normal
  BFD               31         2048               critical
# (In IRF mode.) Display the predefined QoS policy applied to the control plane of slot 3 of IRF member device 1.
<Sysname> display qos policy control-plane pre-defined chassis 1 slot 3
Pre-defined control plane policy chassis 1 slot 3
  ARP               12         768                normal
  DHCP              18         256                normal
  STP               36         256                critical
  LACP              36         64                 critical
  BGP               24         256                critical
  ICMP              9          512                monitor
  DLDP              24         64                 critical
Table 7 Command output
Contents of the pre-defined control plane QoS policy.
Group
Protocol group.
Use display qos policy global to display QoS policies applied globally.
In standalone mode:
In IRF mode:
display qos policy global [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
inbound: Specifies the inbound direction.
outbound: Specifies the outbound direction.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays QoS policies applied globally on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify this option, the command displays QoS policies applied globally on the global active MPU. (In IRF mode.)
If you do not specify a direction, this command displays QoS policies globally applied in the inbound direction and QoS policies globally applied in the outbound direction.
# Display the QoS policy applied globally in the inbound direction.
<Sysname> display qos policy global inbound
  Direction: Inbound
  Policy: p1
   Classifier: c1
     Operator: AND
     Rule(s) :
      If-match dscp cs3
     Behavior: b1
        Green action  : pass
Table 8 Command output
Direction
Direction (inbound or outbound ) in which the QoS policy is applied.
Green packets
Red packets
Use display qos policy interface to display QoS policies applied to interfaces.
display qos policy interface [ interface-type interface-number ] [ inbound | outbound ]
inbound: Specifies QoS policies applied in the inbound direction.
outbound: Specifies QoS policies applied in the outbound direction.
If you do not specify a direction, this command displays QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Display the QoS policy applied to the incoming traffic of GigabitEthernet 1/3/0/1.
<Sysname> display qos policy interface gigabitethernet 1/3/0/1 inbound
  Direction: Inbound
  Policy: p1
   Classifier: c1
     Operator: AND
     Rule(s) :
      If-match dscp cs3
     Behavior: b1
        Green action  : pass
Table 9 Command output
Direction
Direction in which the QoS policy is applied to the interface.
Green packets
Traffic statistics for green packets.
Red packets
Traffic statistics for red packets.
Use display qos vlan-policy to display QoS policies applied to VLANs.
In standalone mode:
In IRF mode:
display qos vlan-policy { name policy-name | vlan [ vlan-id ] } [ chassis chassis-number slot slot-number ] [ inbound | outbound ]
name policy-name: Specifies a QoS policy by its name, a case-sensitive string of 1 to 31 characters.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
outbound: Specifies QoS policies applied in the inbound direction.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays QoS policies applied to VLANs on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify this option, the command displays QoS policies applied to VLANs on the global active MPU. (In IRF mode.)
# Display QoS policies applied to VLAN 2.
<Sysname> display qos vlan-policy vlan 2
Vlan 2
  Direction: Inbound
  Policy: p1
   Classifier: c1
     Operator: AND
     Rule(s) :
      If-match dscp cs3
     Behavior: b1
        Green action  : pass
Table 10 Command output
Direction
Direction in which the QoS policy is applied for the VLAN.
Green packets
Red packets
qos apply policy
Use qos apply policy to apply a QoS policy to an interface or control plane.
Use undo qos apply policy to remove an applied QoS policy.
undo qos apply policy policy-name { inbound | outbound }
No QoS policy is applied to an interface or control plane.
Interface view, control plane view
inbound: Applies the QoS policy to incoming traffic.
outbound: Applies the QoS policy to outgoing traffic. This keyword is not supported in control plane view.
Table 11 shows the support of the inbound and outbound keywords for different actions.
Table 11 Support of the inbound and outbound keywords for different actions
Action
inbound
outbound
Class-based accounting
Yes
Yes
Traffic policing
Yes
Yes
Traffic filtering
Yes
Yes
Traffic mirroring
Yes
Yes
Outer VLAN tag encapsulation
Yes
No
Traffic redirecting
Yes
No
CVLAN marking
Yes except on EA, EB, and LSU1TGS16SC0 interface modules
Yes
SVLAN marking
Yes
Yes
Yes
Yes
Drop precedence marking
Yes
No
DSCP marking
Yes
Yes
Yes
Yes
Local precedence marking
Yes
No
Local QoS ID marking
Yes
No
# Apply QoS policy USER1 to the outgoing traffic of GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos apply policy USER1 outbound
# Apply QoS policy aaa to the incoming traffic of the control plane of slot 3.
[Sysname-cp-slot3] qos apply policy aaa inbound
Use qos apply policy global to apply a QoS policy globally.
Use undo qos apply policy global to remove a globally applied QoS policy.
undo qos apply policy policy-name global { inbound | outbound }
No QoS policy is applied globally.
A QoS policy applied globally takes effect on all incoming or outgoing traffic on the switch.
# Globally apply the QoS policy user1 to incoming traffic.
[Sysname] qos apply policy user1 global inbound
qos policy
Use qos policy to create a QoS policy and enter QoS policy view.
Use undo qos policy to delete a QoS policy.
qos policy policy-name
undo qos policy policy-name
No QoS policy exists.
policy-name: Specifies the name of the QoS policy, a case-sensitive string of 1 to 31 characters.
To delete a QoS policy that has been applied to an object, you must first remove the QoS policy from the object.
# Create a QoS policy named user1.
·     qos apply policy
·     qos apply policy global
·     qos vlan-policy
qos vlan-policy
Use qos vlan-policy to apply a QoS policy to the specified VLANs.
Use undo qos vlan-policy to remove a QoS policy from the specified VLANs.
undo qos vlan-policy policy-name vlan vlan-id-list { inbound | outbound }
No QoS policy is applied to a VLAN.
vlan vlan-id-list: Specifies a space-separated list of up to 10 VLAN items. Each item specifies a VLAN or a range of VLANs in the form of vlan-id1 [ to vlan-id2 ]. The value for vlan-id2 must be greater than or equal to the value for vlan-id1. The value range for the vlan-id argument is 1 to 4094.
inbound: Applies the QoS policy to incoming packets.
outbound: Applies the QoS policy to outgoing packets.
# Apply the QoS policy test to the incoming traffic of VLAN 200, VLAN 300, VLAN 400, and VLAN 500.
[Sysname] qos vlan-policy test vlan 200 300 400 500 inbound
Use reset qos policy control-plane to clear statistics for the QoS policy applied to a control plane.
In standalone mode:
In IRF mode:
reset qos policy control-plane chassis chassis-number slot slot-number
# (In standalone mode.) Clear statistics for the QoS policy applied to the control plane of card 3.
<Sysname> reset qos policy control-plane slot 3
# (In IRF mode.) Clear statistics for the QoS policy applied to the control plane of card 3 on IRF member device 1.
<Sysname> reset qos policy control-plane chassis 1 slot 3
Use reset qos policy global to clear statistics for QoS policies applied globally.
inbound: Specifies the QoS policy applied in the inbound direction.
outbound: Specifies the QoS policy applied in the outbound direction.
If you do not specify a direction, this command clears statistics for the QoS policy applied in the inbound direction and the QoS policy applied in the outbound direction.
# Clear statistics for the QoS policy globally applied in the inbound direction.
<Sysname> reset qos policy global inbound
Use reset qos vlan-policy to clear statistics for QoS policies applied to VLANs.
vlan vlan-id: Specifies a VLAN ID in the range of 1 to 4094.
If you do not specify a direction, this command clears statistics for QoS policies applied in the inbound direction and QoS policies applied in the outbound direction.
# Clear statistics for QoS policies applied to VLAN 2.
<Sysname> reset qos vlan-policy vlan 2
Use display qos map-table to display the configuration of priority maps.
display qos map-table [ dot1p-dp | dot1p-exp | dot1p-lp | dot1p-rpr | dscp-dot1p| dscp-dp | dscp-dscp | exp-dot1p | exp-rpr | ippre-rpr ]
The switch provides the following types of priority maps.
Table 12 Priority maps
Priority mapping
dot1p-dp
802.1p-drop priority map.
dot1p-exp
802.1p-EXP priority map.
dot1p-lp
802.1p-local priority map.
dot1p-rpr
802.1p-RPR priority map.
dscp-dot1p
DSCP-802.1p priority map.
dscp-dp
DSCP-drop priority map.
dscp-dscp
DSCP-DSCP priority map.
exp-dot1p
EXP-802.1p priority map.
exp-rpr
EXP-RPR priority map.
ippre-rpr
IP precedence-RPR priority map.
If you do not specify a priority map, this command displays the configuration of all priority maps.
# Display the configuration of the 802.1p-local priority map.
MAP-TABLE NAME: dot1p-lp   TYPE: pre-define
IMPORT  :  EXPORT
   0    :    2
   1    :    0
   2    :    1
   3    :    3
   4    :    4
   5    :    5
   6    :    6
   7    :    7
Table 13 Command output
MAP-TABLE NAME
Name of the priority map.
TYPE
Type of the priority map.
IMPORT
Input values of the priority map.
EXPORT
Output values of the priority map.
import
Use import to configure mappings for a priority map.
Use undo import to restore the specified or all mappings to the default for a priority map.
The default priority maps are used. For more information, see ACL and QoS Configuration Guide.
Priority map view
import-value-list: Specifies a list of input values.
export-value: Specifies the output value.
all: Restores all mappings in the priority map to the default.
# Configure the 802.1p-drop priority map to map 802.1p priority values 4 and 5 to drop priority 1.
[Sysname] qos map-table dot1p-dp
[Sysname-maptbl-dot1p-dp] import 4 5 export 1
qos map-table
Use qos map-table to enter the specified priority map view.
qos map-table { dot1p-dp | dot1p-exp | dot1p-lp | dot1p-rpr | dscp-dot1p| dscp-dp | dscp-dscp | exp-dot1p | exp-rpr | ippre-rpr }
For the description of the keywords, see Table 12.
The dscp-dot1p priority map does not take effect on SF interface modules.
EXP-related priority maps take effect only on MPLS-capable cards. For information about MPLS-capable cards, see MPLS Configuration Guide.
# Enter the 802.1p-drop priority map view.
·     display qos map-table
·     import
qos priority
Use qos priority to change the port priority of an interface.
Use undo qos priority to restore the default.
qos priority priority-value
undo qos priority
The port priority of an interface is 0.
Layer 2 Ethernet interface view, Layer 3 Ethernet interface view
priority-value: Specifies a port priority value in the range of 0 to 7.
# Set the port priority of interface GigabitEthernet 1/0/1 to 2.
[Sysname-GigabitEthernet1/0/1] qos priority 2
Use display qos trust interface to display the priority trust modes and port priorities of interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the priority trust mode and port priorities of all interfaces.
# Display the priority trust mode and port priority of GigabitEthernet 1/0/1.
<Sysname> display qos trust interface gigabitethernet 1/0/1
 Port priority trust information
  Port priority:4
  Port priority trust type: dot1p
Table 14 Command output
Interface type and interface number.
Priority trust mode on the interface: dot1p or dscp.
qos trust
Use qos trust to configure the priority trust mode for an interface.
Use undo qos trust to restore the default.
qos trust { dot1p | dscp }
undo qos trust
The priority trust mode of an interface is 802.1p priority.
dot1p: Uses the 802.1p priority in incoming packets for priority mapping.
dscp: Uses the DSCP value in incoming packets for priority mapping.
The dscp-dot1p priority map does not take effect on SF interface modules. To use the priority carried in packets for priority mapping on an interface of such a card, you must configure the interface to trust the 802.1p priority.
# Set the priority trust mode to 802.1p priority on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos trust dot1p
GTS commands
Use display qos gts interface to display GTS configuration and statistics on interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the GTS configuration and statistics on all interfaces.
# Display the GTS configuration and statistics on all interfaces.
Rule: If-match queue 1
 Rule: If-match queue 4
  CIR 400 (kbps), CBS 25088 (Bytes)
Table 15 Command output
Interface name, including the interface type and interface number.
Rule
Match criteria.
qos gts
Use qos gts to set GTS parameters for a queue on an interface.
Use undo qos gts to delete GTS settings on an interface.
undo qos gts queue queue-id
No GTS parameters are set on an interface.
queue queue-id: Specifies a queue by its ID in the range of 0 to 7.
cir committed-information-rate: Specifies the CIR in kbps. The committed-information-rate argument has the following value ranges:
·     8 to 1000000 for GE interfaces.
·     8 to 10000000 for 10-GE interfaces.
·     8 to 40000000 for 40-GE interfaces.
·     8 to 100000000 for 100-GE interfaces.
The values must be an integral multiple of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for the committed-burst-size argument is 512 to 16000000. The value must be an integral multiple of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 16000000 is converted to 16000000.
# Configure the following GTS parameters for queue 1 on GigabitEthernet 1/0/1:
·     The CIR is 6400 kbps.
·     The CBS is 51200 bytes.
[Sysname-GigabitEthernet1/0/1] qos gts queue 1 cir 6400 cbs 51200
Rate limit commands
display qos lr
Use display qos lr to display the rate limit configuration and statistics for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the rate limit configuration and statistics for all interfaces.
# Display the rate limit configuration and statistics for all interfaces.
 Direction: Inbound
  CIR 10000 (kbps), CBS 625152 (Bytes)
 Direction: Outbound
Table 16 Command output
Direction
Direction to which the rate limit configuration is applied: inbound or outbound.
qos lr
Use qos lr to limit the rate of packets on an interface.
Use undo qos lr to remove a rate limit.
undo qos lr { inbound | outbound }
No rate limit is configured on an interface.
inbound: Limits the rate of incoming packets.
outbound: Limits the rate of outgoing packets.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for the committed-burst-size argument is 512 to 128000000. The value must be an integral multiple of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 128000000 is converted to 128000000.
# Limit the rate of outgoing packets on GigabitEthernet 1/0/1, with CIR 2000 kbps and CBS 51200 bytes.
[Sysname-GigabitEthernet1/0/1] qos lr outbound cir 2000 cbs 51200
SP commands
Use display qos queue sp interface to display the SP queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the SP queuing configuration of all interfaces.
# Display the SP queuing configuration of GigabitEthernet 1/0/1.
<Sysname> display qos queue sp interface gigabitethernet 1/0/1
 Output queue: Strict Priority queuing
Queue ID        Group           Byte-count      Min-Bandwidth
 be              sp              N/A             N/A
 af1             sp              N/A             N/A
 af2             sp              N/A             N/A
 af3             sp              N/A             N/A
 af4             sp              N/A             N/A
 ef              sp              N/A             N/A
 cs6             sp              N/A             N/A
 cs7             sp              N/A             N/A
Table 17 Command output
Output queue
Type of the current output queue.
Byte-count
Number of bytes that are forwarded from a queue during a queue scheduling cycle. N/A is displayed for SP queues.
Min-Bandwidth
Minimum guaranteed bandwidth for a queue.
qos sp
qos sp
Use qos sp to configure SP queuing on an interface.
Use undo qos sp to restore the default.
qos sp
undo qos sp
SP queuing is used on an interface.
# Enable SP queuing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos sp
WRR commands
Use display qos queue wrr interface to display the WRR queuing configuration of an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRR queuing configuration of all interfaces.
# Display the WRR queuing configuration of GigabitEthernet 1/0/1.
<Sysname> display qos queue wrr interface gigabitethernet 1/0/1
 Output queue: Weighted Round Robin queuing
 Queue ID        Group           Weight          Min-Bandwidth
 be              1               1               N/A
 af1             1               2               N/A
 af2             1               3               N/A
 af3             1               4               N/A
 af4             1               5               N/A
 ef              1               6               N/A
 cs6             1               7               N/A
 cs7             1               8               N/A
Table 18 Command output
Output queue
Group
Number of the WRR group to which a queue belongs. By default, all queues belong to WRR group 1. Only SF interface modules support WRR group 2.
Weight
Number of packets that are forwarded from a queue during a queue scheduling cycle. N/A is displayed for SP queues.
Min-Bandwidth
qos wrr
qos wrr
Use qos wrr to enable WRR queuing on an interface.
Use undo qos wrr to disable WRR queuing and restore the default queue scheduling algorithm for an interface.
undo qos wrr { byte-count | weight }
byte-count: Uses the byte as the scheduling unit.
weight: Uses the packet as the scheduling unit.
You must use the qos wrr command to enable WRR queuing before you can configure WRR queuing parameters for a queue on an interface.
# Enable packet-based WRR queuing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wrr weight
# Enable byte-count WRR queuing on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wrr byte-count
Use qos wrr { byte-count | weight } to configure WRR queuing parameters for a queue on an interface.
Use undo qos wrr to restore the default.
qos wrr queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wrr queue-id
All queues of a WRR-enabled interface are in WRR group 1, and the scheduling values of queues 0 through 7 are 1, 2, 3, 4, 5, 6, 7, and 8, respectively.
queue-id: Specifies a queue by its ID, which can be a number in the range of 0 to 7 or a keyword in Table 19.
group { 1 | 2 }: Specifies a WRR group. Only SF interface modules support WRR group 2.
schedule-value: Specifies a scheduling value in the range of 1 to 15.
The queue-id argument can be either a number or a keyword. Table 19 shows the number-keyword map.
Table 19 The number-keyword map for the queue-id argument
Number
Keyword
0
be
1
af1
2
af2
3
af3
4
af4
5
ef
6
cs6
7
cs7
# Enable byte-count WRR queuing on GigabitEthernet 1/0/1, and assign queue 0, with the scheduling value 10, to WRR group 1.
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group 1 byte-count 10
·     display qos queue wrr interface
·     qos wrr
qos wrr group sp
Use qos wrr group sp to assign a queue to the SP group.
Use undo qos wrr group sp to restore the default.
qos wrr queue-id group sp
All queues of a WRR-enabled interface are in WRR group 1.
sp: Assigns a queue to the SP group, which uses the SP queue scheduling algorithm.
This command is available only on a WRR-enabled interface. Queues in the SP group are scheduled with SP. The SP group has higher scheduling priority than the WRR groups. The queues in a WRR group are scheduled based on their scheduling values. The two WRR groups are scheduled in the ratio of 1:1.
You must use the qos wrr command to enable WRR queuing before you can configure this command on an interface.
For this command to take effect on an SG interface module when you use SP+WRR queuing, make sure the queue IDs in the SP group are continuous.
# Enable packet-based WRR queuing on GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-GigabitEthernet1/0/1] qos wrr 0 group sp
·     qos wrr
WFQ commands
display qos queue wfq interface
Use display qos queue wfq interface to display the WFQ configuration on an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WFQ configuration of all interfaces.
# Display the WFQ configuration of GigabitEthernet 1/0/1.
<Sysname> display qos wfq interface gigabitethernet 1/0/1
 Output queue: Hardware Weighted Fair Queuing
 be              1               1               64
 af1             1               1               64
 af2             1               1               64
 af3             1               1               64
 af4             1               1               64
 ef              1               1               64
 cs6             1               1               64
 cs7             1               1               64
Table 20 Command output
Output queue
Group
Number of the WFQ group to which a queue belongs. By default, all queues are in WFQ group 1. Only SF interface modules support WFQ group 2.
Weight
Min-Bandwidth
qos wfq
qos bandwidth queue
Use qos bandwidth queue to set the minimum guaranteed bandwidth for a queue on an interface.
Use undo qos bandwidth queue to restore the default.
undo qos bandwidth queue queue-id
The minimum guaranteed bandwidth of each queue on a WFQ-enabled interface is 64 kbps.
min bandwidth-value: Specifies the minimum guaranteed bandwidth in kbps for a queue. The bandwidth-value argument has the following value ranges:
You must use the qos wfq command to enable WFQ before you can configure this command on an interface.
The minimum guaranteed bandwidth is the minimum bandwidth guaranteed for a queue when the interface is congested.
# Set the minimum guaranteed bandwidth to 100 kbps for queue 0 on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wfq weight
[Sysname-GigabitEthernet1/0/1] qos bandwidth queue 0 min 100
qos wfq
qos wfq
Use qos wfq to enable WFQ on an interface.
Use undo qos wfq to disable WFQ and restore the default queuing algorithm on an interface.
qos wfq { byte-count | weight }
undo qos wfq { byte-count | weight }
You must use the qos wfq command to enable WFQ before you can configure WFQ queuing parameters for a queue on an interface.
# Enable packet-based WFQ on GigabitEthernet 1/0/1.
# Enable byte-count WFQ on GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wfq byte-count
Use qos wfq { byte-count | weight } to configure WFQ queuing parameters for a queue on an interface.
Use undo qos wfq to restore the default.
qos wfq queue-id group { 1 | 2 } { byte-count | weight } schedule-value
undo qos wfq queue-id
All queues of a WFQ-enabled interface are in WFQ group 1 and have a scheduling value of 1.
group { 1 | 2 }: Specifies a WFQ group. Only SF interface modules support WFQ group 2.
You must use the qos wfq command to enable WFQ before you configure this command.
# Enable byte-count WFQ on interface GigabitEthernet 1/0/1, and assign queue 0, with the scheduling value 10, to WFQ group 1.
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group 1 byte-count 10
·     display qos queue wfq interface
·     qos bandwidth queue
·     qos wfq
qos wfq group sp
Use qos wfq group sp to assign a queue to the SP group.
Use undo qos wfq group sp to restore the default.
qos wfq queue-id group sp
All queues of a WFQ-enabled interface are in WFQ group 1.
sp: Assigns a queue to the SP group.
For this command to take effect on an SG interface module when you use SP+WFQ queuing, make sure the queue IDs in the SP group are continuous.
On SF interface modules, SP+WFQ queuing schedules traffic in the following order:
1.      Schedules the queues in the SP group based on their priorities until the SP queues are empty.
2.     Schedules the traffic conforming to the minimum guaranteed bandwidth of each queue in WFQ groups. The two WFQ groups are scheduled in the ratio of 1:1.
3.     Schedules the traffic in each queue of WFQ groups according to the configured scheduling values. The two WFQ groups are scheduled in the ratio of 1:1.
On interface modules other than SF interface modules, SP+WFQ queuing schedules traffic in the following order:
1.     Schedules the traffic conforming to the minimum guaranteed bandwidth of each queue in the WFQ group.
2.     Schedules the queues in the SP group based on their priorities until the SP queues are empty.
3.     Schedules the traffic of queues in the WFQ group according to the configured scheduling values.
# Enable byte-count WFQ on interface GigabitEthernet 1/0/1, and assign queue 0 to the SP group.
[Sysname-GigabitEthernet1/0/1] qos wfq 0 group sp
·     qos wfq
Queue scheduling profile commands
bandwidth queue
Use bandwidth queue to configure the minimum guaranteed bandwidth for a queue.
Use undo bandwidth queue to restore the default.
undo bandwidth queue queue-id
The minimum guaranteed bandwidth for a WFQ queue is 64 kbps.
Queue scheduling profile view
min bandwidth-value: Specifies the minimum guaranteed bandwidth in the range of 8 to 100000000 kbps.
To configure the minimum guaranteed bandwidth for a queue in a queue scheduling profile, you must first configure the queue as a WFQ queue.
# Configure queue 0 in the queue scheduling profile myprofile as a WFQ queue, and configure the minimum guaranteed bandwidth as 100 kbps for queue 0.
[Sysname] qos qmprofile myprofile
[Sysname-qmprofile-myprofile] queue 0 wfq group 1 weight 1
[Sysname-qmprofile-myprofile] bandwidth queue 0 min 100
·     display qos qmprofile interface
·     queue
·     qos qmprofile
display qos qmprofile configuration
Use display qos qmprofile configuration to display the queue scheduling profile configuration.
In standalone mode:
In IRF mode:
display qos qmprofile configuration [ profile-name ] [ chassis chassis-number slot slot-number ]
profile-name: Specifies a queue scheduling profile by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a queue scheduling profile, this command displays the configuration of all queue scheduling profiles.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the configuration of queue scheduling profiles on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify this option, the command displays the configuration of queue scheduling profiles on the global active MPU. (In IRF mode.)
# Display the configuration of the queue scheduling profile myprofile.
<Sysname> display qos qmprofile configuration myprofile
Queue management profile: myprofile (ID 1)
Queue ID    Type    Group    Schedule-unit    Schedule-value    Bandwidth
 be          SP      N/A      N/A              N/A                N/A
 af1         WFQ     1        weight           1                  128
 af2         SP      N/A      N/A              N/A                N/A
 af3         SP      N/A      N/A              N/A                N/A
 af4         SP      N/A      N/A              N/A                N/A
 ef          SP      N/A      N/A              N/A                N/A
 cs6         SP      N/A      N/A              N/A                N/A
 cs7         SP      N/A      N/A              N/A                N/A
Table 21 Command output
Queue scheduling profile name.
Queue scheduling type:
·     SP.
·     WRR.
·     WFQ.
Group
Number of the group to which the queue belongs.
Schedule-unit
Scheduling unit: weight or byte-count.
Schedule-value
Value for the scheduling unit.
Bandwidth
Minimum guaranteed bandwidth for the queue.
Use display qos qmprofile interface to display the queue scheduling profile applied to an interface.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the queue scheduling profiles applied to all interfaces.
# Display the queue scheduling profile applied to GigabitEthernet 1/0/1.
<Sysname> display qos qmprofile interface gigabitethernet 1/0/1
Table 22 Command output
Interface name.
Name of the queue scheduling profile applied to the interface.
qos apply qmprofile
Use qos apply qmprofile to apply a queue scheduling profile to an interface.
Use undo qos apply qmprofile to restore the default.
No queue scheduling profile is applied to an interface.
You can apply only one queue scheduling profile to an interface.
# Apply the queue scheduling profile myprofile to GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos apply qmprofile myprofile
qos qmprofile
Use qos qmprofile to create a queue scheduling profile and enter its view, or enter the view of an existing queue scheduling profile.
Use undo qos qmprofile to delete a queue scheduling profile.
qos qmprofile profile-name
undo qos qmprofile profile-name
No user-created queue scheduling profile exists.
profile-name: Specifies the name of the queue scheduling profile, a case-sensitive string of 1 to 31 characters.
To delete a queue scheduling profile already applied to an interface, first remove it from the interface.
# Create a queue scheduling profile named myprofile and enter queue scheduling profile view.
·     queue
queue
Use queue to configure queue scheduling parameters.
Use undo queue to restore the default.
queue queue-id { sp | wfq group group-id { weight | byte-count } schedule-value | wrr group group-id { weight | byte-count } schedule-value }
undo queue queue-id
All queues in a queue scheduling profile use SP queuing.
sp: Enables SP for the queue.
wfq: Enables WFQ for the queue.
wrr: Enables WRR for the queue.
group group-id: Specifies a WFQ or WRR group by its ID, which can be 1 or 2. If you do not specify this option for WFQ, the default is WFQ group 1. Only SF interface modules support group 2.
byte-count: Allocates bandwidth to queues in terms of bytes.
weight: Allocates bandwidth to queues in terms of packets.
schedule-value: Specifies the scheduling weight, in the range of 1 to 15.
For SP+WRR or SP+WFQ queuing to work correctly on an SG interface module, make sure the queue IDs in the SP group are continuous.
# Create a queue scheduling profile named myprofile, and configure queue 0 to use SP.
[Sysname-qmprofile-myprofile] queue 0 sp
# Create a queue scheduling profile named myprofile and configure queue 1 to meet the following requirements:
·     The packet-based WRR queuing is used.
·     The WRR group is group 1.
·     The scheduling value is 10.
[Sysname-qmprofile-myprofile] queue 1 wrr group 1 weight 10
·     qos qmprofile
Congestion avoidance commands
display qos wred interface
Use display qos wred interface to display the WRED configuration and statistics for interfaces.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the WRED configuration and statistics for all interfaces.
# Display the WRED configuration and statistics for GigabitEthernet 1/0/4.
<Sysname> display qos wred interface
Interface: GigabitEthernet1/0/4
 Current WRED configuration:
Applied WRED table name: wr1
display qos wred table
Use display qos wred table to display the WRED table configuration.
In standalone mode:
In IRF mode:
display qos wred table [ name table-name ] [ chassis chassis-number slot slot-number ]
name table-name: Specifies a WRED table by its name. If you do not specify a WRED table, this command displays the configuration of all WRED tables.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays the configuration of WRED tables on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device or specifies a PEX. The chassis-number argument represents the member ID of the IRF member device or the virtual chassis number of the PEX. The slot-number argument represents the slot number of the card or PEX. If you do not specify this option, the command displays the configuration of WRED tables on the global active MPU. (In IRF mode.)
# Display the configuration of WRED table 1.
<Sysname> display qos wred table name 1
Table name: 1
Table type: Queue based WRED
QID   gmin  gmax  gprob  ymin  ymax  yprob  rmin  rmax  rprob  exponent  ECN
0     100   1000  10     100   1000  10     100   1000  10     9         N
1     100   1000  10     300   600   10     100   1000  10     10        Y
2     100   1000  10     100   1000  10     100   1000  10     9         N
3     100   1000  10     100   1000  10     100   1000  10     9         N
4     100   1000  10     100   1000  10     100   1000  10     9         N
5     100   1000  10     100   1000  10     100   1000  10     9         N
6     100   1000  10     100   1000  10     100   1000  10     9         N
7     100   1000  10     100   1000  10     100   1000  10     9         N
Table 23 Command output
QID
Queue ID.
gmin
Lower limit for green packets.
gmax
Upper limit for green packets.
gprob
Drop probability for green packets.
ymin
Lower limit for yellow packets.
ymax
Upper limit for yellow packets.
yprob
Drop probability for yellow packets.
rmin
Lower limit for red packets.
rmax
Upper limit for red packets.
rprob
Drop probability for red packets.
exponent
Exponent for average queue length calculation.
ECN
Indicates whether ECN is enabled for the queue:
·     Y—Enabled.
·     N—Disabled.
qos wred apply
Use qos wred apply to apply a WRED table on an interface.
Use undo qos wred apply to restore the default.
qos wred apply [ table-name ]
undo qos wred apply
No WRED table is applied to an interface, and tail drop is used on an interface.
table-name: Specifies a WRED table by its name, a case-sensitive string of 1 to 32 characters.
If you do not specify a WRED table, this command applies the default WRED table to the interface.
# Apply the queue-based WRED table table1 to interface GigabitEthernet 1/0/1.
[Sysname-GigabitEthernet1/0/1] qos wred apply table1
·     display qos wred interface
·     display qos wred table
·     qos wred table
qos wred queue table
Use qos wred queue table to create a queue-based WRED table and enter its view, or enter the view of an existing WRED table.
Use undo qos wred queue table to delete a queue-based WRED table.
undo qos wred queue table table-name
No WRED table exists.
table table-name: Specifies the name of the WRED table.
You cannot delete a WRED table applied to an interface. To delete it, first remove it from the interface.
# Create a queue-based WRED table named queue-table1.
[Sysname-wred-table-queue-table1]
queue
Use queue to configure the drop-related parameters for a queue in a WRED table.
queue queue-id [ drop-level drop-level ] low-limit low-limit high-limit high-limit [ discard-probability discard-prob ]
undo queue { queue-id | all }
The low-limit argument is 100, the high-limit argument is 1000, and the discard-prob argument is 10.
WRED table view
drop-level drop-level: Specifies a drop level. The value 0 corresponds to green packets, the value 1 corresponds to yellow packets, and the value 2 corresponds to red packets. If you do not specify a drop level, the subsequent configuration takes effect on the packets in the queue regardless of the drop level.
low limit low-limit: Specifies the lower limit for the average queue length, in the range of 0 to 16383.
high-limit high-limit: Specifies the upper limit for the average queue length, in the range of 0 to 16383. The value for the high-limit argument must be greater than the value for the low-limit argument.
discard-probability discard-prob: Specifies the drop probability in percentage, in the range of 0 to 100.
When the average queue size is smaller than the lower threshold, no packet is dropped. When the average queue size is between the lower threshold and the upper threshold, the packets are dropped randomly according to the configured drop probability. The longer the queue, the higher the drop probability. When the average queue size exceeds the upper threshold, all subsequent packets are dropped.
# In queue-based WRED table queue-table1, configure the following drop-related parameters for packets in queue 1:
·     The drop level is 1.
·     The lower limit for the average queue length is 10.
·     The upper limit for the average queue length is 20.
·     The drop probability is 30%.
[Sysname-wred-table-queue-table1] queue 1 drop-level 1 low-limit 10 high-limit 20 discard-probability 30
·     qos wred table
queue ecn
Use queue ecn to enable ECN for a queue.
Use undo queue ecn to restore the default.
queue queue-id ecn
undo queue queue-id ecn
ECN is not enabled on any queue.
WRED table view
When both the receiver and sender support ECN, the switch can notify the peer end of the congestion status by identifying and setting the ECN flag. ECN avoids deteriorating congestion.
# In WRED table queue-table1, enable ECN for queue 1.
[Sysname-wred-table-queue-table1] queue 1 ecn
·     qos wred table
queue weighting-constant
Use queue weighting-constant to specify an exponent for average queue length calculation for a queue.
Use undo queue weighting-constant to restore the default.
queue queue-id weighting-constant exponent
undo queue queue-id weighting-constant
The exponent for average queue length calculation is 9.
WRED table view
weighting-constant exponent: Specifies the WRED exponent for average queue length calculation, in the range of 1 to 15.
The bigger the exponent is, the less sensitive the average queue size is to real-time queue size changes. The average queue size is calculated using the formula:
Average queue size = previous average queue size × (1-2-n) + current queue size × 2-n,
where n can be configured with the qos wred weighting-constant command.
# In WRED table queue-table1, set the exponent for average queue length calculation to 12 for queue 1.
[Sysname-wred-table-queue-table1] queue 1 weighting-constant 12
·     qos wred table
Global CAR commands
SC, SF, and SG interface modules do not support hierarchical CAR commands.
car name
Use car name to use global CAR actions in a traffic behavior.
Use undo car to remove global CAR actions from a traffic behavior.
car name car-name [ hierarchy-car hierarchy-car-name [ mode { and | or } ] ]
undo car
No global CAR action is used in a traffic behavior.
Traffic behavior view
car-name: Specifies an aggregate CAR action by its name, a case-sensitive string of 1 to 31 characters. This argument must start with a letter.
hierarchy-car hierarchy-car-name: Specifies a hierarchical CAR action by its name, a case-sensitive string of 1 to 31 characters. This argument must start with a letter.
mode: Specifies a collaborating mode between the hierarchical CAR action and the aggregate CAR action, which can be AND (the default) or OR. If you do not specify a collaborating mode, the AND mode applies.
·     and: Specifies the AND mode (the default mode). In this mode, the rate of a flow is limited by both aggregate CAR and the total traffic rate defined with hierarchical CAR.
·     or: Specifies the OR mode. In this mode, a flow can perform one of the following operations:
¡     Pass through at the rate equal to the aggregate CAR applied to it.
¡     Pass through at a higher rate if the total traffic rate of all flows does not exceed the hierarchical CAR.
# Use the aggregate CAR action aggcar-1 in the traffic behavior be1.
# Configure traffic behavior be1 to use aggregate CAR aggcar-1 and hierarchical CAR hcar, with the collaborating mode as or.
[Sysname-behavior-be1] car name aggcar-1 hierarchy-car hcar mode or
·     display qos car name
·     display traffic behavior user-defined
Use display qos car name to display the configuration and statistics for a global CAR action.
car-name: Specifies a global (aggregate or hierarchical) CAR action by its name, a case-sensitive string of 1 to 31 characters. This argument must start with a letter. If you do not specify a global CAR action, this command displays the configuration and statistics for all global CAR actions, including aggregate CAR actions and hierarchical CAR actions.
# (In standalone mode.) Display the configuration and statistics for all global CAR actions.
<Sysname> display qos car name
  Mode: aggregative
   Green action  : pass
   Yellow action : pass
  Slot 3:
  Mode: hierarchy
   CIR 4000 (kbps), CBS 250368 (Bytes), PIR 5120 (kbps), EBS 102400 (Bytes)
# (In IRF mode.) Display the configuration and statistics for all global CAR actions.
  Mode: aggregative
   Green action  : pass
  Chassis 1 Slot 3:
  Mode: hierarchy
Table 24 Command output
Name
Name of the global CAR action.
Mode
Type of the CAR action:
·     aggregative—Aggregate CAR.
·     hierarchy—Hierarchical CAR.
CIR  CBS  PIR  EBS
Parameters for the CAR action.
Green action
Action to take on green packets:
·     discard—Drops the packets.
·     pass—Permits the packets to pass through.
Yellow action
Action to take on yellow packets:
Red action
Action to take on red packets:
Green packet
Red packet
qos car
Use qos car aggregative to configure an aggregate CAR action.
Use qos car hierarchy to configure a hierarchical CAR action.
Use undo qos car to remove an aggregate or hierarchical CAR action.
qos car car-name { aggregative | hierarchy } cir committed-information-rate [ cbs committed-burst-size [ ebs excess-burst-size ] ] [ green action | red action | yellow action ] *
qos car car-name { aggregative | hierarchy } cir committed-information-rate [ cbs committed-burst-size ] pir peak-information-rate [ ebs excess-burst-size ] [ green action | red action | yellow action ] *
undo qos car car-name
No aggregate or hierarchical CAR action is configured.
car-name: Specifies the name of the global CAR action, a case-sensitive string of 1 to 31 characters. This argument must start with a letter.
aggregative: Specifies the global CAR action as an aggregate CAR action.
hierarchy: Specifies the global CAR action as a hierarchical CAR action.
cir committed-information-rate: Specifies the CIR in the range of 8 to 160000000 kbps. The value must be an integral multiple of 8.
cbs committed-burst-size: Specifies the CBS in bytes. The value range for the committed-burst-size argument is 512 to 256000000. The value must be an integral multiple of 512. The default value for this argument is the product of 62.5 and the CIR and must be an integral multiple of 512. When the product is not an integral multiple of 512, it is rounded up to the nearest integral multiple of 512. A default value greater than 256000000 is converted to 256000000.
ebs excess-burst-size: Specifies the EBS in the range of 0 to 256000000 bytes. The value must be an integral multiple of 512. The default value is 512.
pir peak-information-rate: Specifies the PIR in the range of 8 to 160000000 kbps. The value must be an integral multiple of 8
green action: Specifies the action to take on packets that conform to CIR. The default setting is pass.
red action: Specifies the action to take on the packet that conforms to neither CIR nor PIR. The default setting is discard.
yellow action: Specifies the action to take on packets that conform to PIR but not to CIR. The default setting is pass.
action: Specifies the action to take on packets:
·     discard: Drops the packet.
·     pass: Permits the packet to pass through.
·     remark-dot1p-pass new-cos: Sets the 802.1p priority value of the 802.1p packet to new-cos and permits the packet to pass through. The new-cos argument is in the range of 0 to 7.
·     remark-dscp-pass new-dscp: Remarks the packet with a new DSCP value and permits the packet to pass through. The new-dscp argument is in the range of 0 to 63. Alternatively, you can specify the new-dscp argument with af11, af12, af13, af21, af22, af23, af31, af32, af33, af41, af42, af43, cs1, cs2, cs3, cs4, cs5, cs6, cs7, default, or ef.
An aggregate CAR action takes effect only after it is applied to an interface or used in a QoS policy.
An aggregate CAR action is supported only in the inbound direction.
A hierarchical CAR action takes effect only after it is used in a QoS policy.
To use two rates for global CAR, configure the qos car command with the pir peak-information-rate option. To use one rate for global CAR, configure the qos car command without the pir peak-information-rate option.
# Configure the aggregate CAR action aggcar-1 as follows:
·     The CIR is 25600 kbps.
·     The CBS is 512000 bytes.
·     Red packets are dropped.
[Sysname] qos car aggcar-1 aggregative cir 25600 cbs 512000 red discard
# Configure the hierarchical CAR action h-car as follows:
[Sysname] qos car h-car hierarchy cir 25600 cbs 512000
reset qos car name
Use reset qos car name to clear statistics for global CAR actions.
car-name: Specifies a global CAR action by its name, a case-sensitive string of 1 to 31 characters. This argument must start with a letter. If you do not specify a global CAR action, this command clears statistics for all global CAR actions.
# Clear statistics for the global CAR action aggcar-1.
<Sysname> reset qos car name aggcar-1
Queue-based accounting commands
display qos queue-statistics interface outbound
Use display qos queue-statistics interface outbound to display outgoing traffic statistics collected for interfaces on a per-queue basis.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays the outgoing traffic statistics for all interfaces.
# Display queue-based outgoing traffic statistics of GigabitEthernet 1/0/1.
<Sysname> display qos queue-statistics interface gigabitethernet 1/0/1 outbound
Direction: outbound
 Forwarded: 0 packets, 0 bytes
 Dropped: 0 packets, 0 bytes
 Queue 0
  Forwarded: 0 packets, 0 bytes, 0 pps, 0 bps
  Current queue length: 0 packets
 Queue 1
 Queue 2
 Queue 3
 Queue 4
 Queue 5
 Queue 6
 Queue 7
Table 25 Command output
Interface for which queue-based traffic statistics are displayed.
Direction
Direction of traffic for which statistics are collected.
Forwarded
Counts forwarded traffic both in packets and in bytes.
Dropped
Counts dropped traffic both in packets and in bytes.
Current number of packets in the queue.
reset counters interface (Interface Command Reference)
