08-MPLS Command Reference
HomeSupportSwitchesS10500 SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release7178-6W10008-MPLS Command Reference
10-VPLS commands
10-VPLS commands 256.78 KB
VPLS commands
address-family l2vpn
Use address-family l2vpn to create the BGP L2VPN address family, and enter BGP L2VPN address family view.
Use undo address-family l2vpn to delete the BGP L2VPN address family, and all settings from BGP L2VPN address family view.
The BGP L2VPN address family is not created.
BGP view
To establish a BGP PW to a remote PE, you must execute the peer enable command in BGP L2VPN address family view to enable the remote PE.
# Create the BGP L2VPN address family and enter BGP L2VPN address family view.
[Sysname] bgp 100
[Sysname-bgp] address-family l2vpn
[Sysname-bgp-l2vpn]
peer enable (Layer 3—IP Routing Command Reference)
auto-discovery
Use auto-discovery to enable a VSI to automatically discover neighbors through BGP and enter auto-discovery VSI view.
Use undo auto-discovery to disable BGP auto-discovery for a VSI.
auto-discovery bgp
undo auto-discovery
A VSI does not use BGP to automatically discover neighbors.
VSI view
bgp: Enables the VSI to automatically discover neighbors through BGP.
You can use the signaling-protocol command to specify the signaling protocol, LDP or BGP, to establish PWs to the remote PEs found by BGP.
# Enable the VSI aaa to automatically discover neighbors through BGP and enter auto-discovery VSI view.
[Sysname] vsi aaa
[Sysname-vsi-aaa] auto-discovery bgp
[Sysname-vsi-aaa-auto]
·     display l2vpn pw
·     display l2vpn vsi
backup-peer
Use backup-peer to configure a backup PW for VPLS, and enter VSI LDP backup PW view or VSI static backup PW view. If the specified backup PW already exists, this command places you in VSI LDP backup PW view or VSI static backup PW view.
Use undo backup-peer to delete a backup PW for VPLS.
VSI LDP PW view:
backup-peer ip-address [ pw-id pw-id ] [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
undo backup-peer ip-address pw-id pw-id
VSI static PW view:
backup-peer ip-address [ pw-id pw-id ] in-label label-value out-label label-value [ pw-class class-name | tunnel-policy tunnel-policy-name ] *
No backup PWs exist for VPLS.
VSI LDP PW view, VSI static PW view
ip-address: Specifies the LSR ID of the peer PE on the backup PW.
pw-id pw-id: Specifies a PW ID for the backup PW, in the range of 1 to 4294967295.
in-label label-value: Specifies the incoming label for the backup PW, in the range of 16 to 1023.
out-label label-value: Specifies the outgoing label for the backup PW, in the range of 16 to 1023.
pw-class class-name: Specifies a PW class by its name, a case-sensitive string of 1 to 19 characters. You can specify a PW class to configure the PW type and control word for the backup PW. If you do not specify a PW class, the PW type of the backup PW is VLAN and the backup PW does not support control word.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a tunnel policy, the backup PW uses the default tunnel policy.
This command configures a backup PW for a PW to implement PW redundancy. The backup PW is used when the primary PW fails.
You must assign the backup PW a different peer LSR ID and PW ID than any existing VPLS PWs or cross-connect PWs.
A backup PW has the same hub and no-split-horizon attributes as its primary PW.
If both the default PW ID in the default-pw-id command and a PW ID in the backup-peer command are configured, the PW ID in the backup-peer command is used. If only the default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the backup-peer command.
A static PW must have a different incoming label than an existing static LSP or static CRLSP. If they are the same, the static PW is not available, even if you change the incoming label of the static LSP or the static CRLSP. To make the static PW available, delete the static PW, and reconfigure it with an unused incoming label.
# Configure a primary and a backup LDP PW for VSI vpn1, and specify the peer PE address and PW ID of the primary PW as 4.4.4.4 and 100, and those of the backup PW as 5.5.5.5 and 200.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling ldp
[Sysname-vsi-vpn1-ldp] peer 4.4.4.4 pw-id 100
[Sysname-vsi-vpn1-ldp-4.4.4.4-100] backup-peer 5.5.5.5 pw-id 200
[Sysname-vsi-vpn1-ldp-4.4.4.4-100-backup]
·     default-pw-id
·     display l2vpn ldp
·     display l2vpn pw
·     peer
control-word enable
Use control-word enable to enable the control word feature.
Use undo control-word enable to restore the default.
control-word enable
Control word is disabled.
PW class view
The control word field is between the MPLS label stack and the Layer 2 data. It carries extra control information about the Layer 2 frame, for example, the sequence number. The control word feature has the following functions:
·     Avoids fragment disorder. In multipath forwarding, fragments received might be disordered. You can configure the control word feature on the device, so the device can reorder the fragments according to the sequence number carried in the control word field.
·     Identifies the original payload length for packets that include padding.
For packets transmitted on a PW to carry the control word field, you must enable the control word feature on both PEs of the PW.
# Enable control word for PW class pw100.
[Sysname] pw-class pw100
[Sysname-pw-pw100] control-word enable
display l2vpn pw-class
default-pw-id
Use default-pw-id to set the default PW ID for a VSI.
Use undo default-pw-id to delete the default PW ID for a VSI.
default-pw-id default-pw-id
undo default-pw-id
No default PW ID is configured for a VSI.
VSI view
default-pw-id: Specifies the default PW ID for the VSI, in the range of 1 to 4294967295.
After you set the default PW ID for a VSI, you do not need to provide a PW ID in the backup-peer and peer commands.
# Set the default PW ID for VSI vpn1 to 200.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] default-pw-id 200
·     backup-peer
·     peer
description
Use description to configure a description for a VSI.
Use undo description to delete the description of a VSI.
No description is configured for a VSI.
VSI view
text: Specifies the VSI description, a case-sensitive string of 1 to 80 characters.
# Configure a description of vsi for vpn1 for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] description vsi for vpn1
display l2vpn vsi
display bgp l2vpn auto-discovery
Use display bgp l2vpn auto-discovery to display VPLS PE information discovered by BGP.
display bgp l2vpn auto-discovery [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ pe-address ip-address [ advertise-info ] ] | statistics ]
peer ip-address: Specifies a BGP peer by its IP address.
advertised: Displays VPLS PE information advertised to the BGP peer.
received: Displays VPLS PE information received from the BGP peer.
statistics: Displays BGP VPLS PE statistics.
route-distinguisher route-distinguisher: Displays BGP VPLS PE information for the route distinguisher (RD), which is a string of 3 to 21 characters. You can specify an RD in one of the following formats:
·     16-bit AS number:32-bit user-defined number. For example, 101:3.
·     32-bit IP address:16-bit user-defined number. For example, 192.168.122.15:1.
·     32-bit AS number:16-bit user-defined number, where the AS number must be equal to or greater than 65536. For example, 65536:1.
pe-address ip-address: Displays BGP VPLS PE information for the specified PE.
advertise-info: Displays BGP VPLS PE advertisement information.
If you do not specify any parameters, this command displays brief information about all VPLS PEs discovered by BGP.
# Display brief information about all VPLS PEs discovered by BGP.
<Sysname> display bgp l2vpn auto-discovery
 BGP local router ID is 192.168.1.140
 Total number of automatically discovered PEs: 3
 Route distinguisher: 2:2
     PE address      Nexthop         VPLS ID
* >  1.1.1.9         0.0.0.0         100:100
* >i 2.2.2.9         2.2.2.9         100:100
* >i 3.3.3.9         3.3.3.9         100:100
Status codes
Status codes:
·     * – valid—Valid route.
·     > – best—Best route.
·     d – damped—Dampened route.
·     h – history—History route.
·     s – suppressed—Suppressed route.
·     S – Stale—Stale route.
·     i – internal—Internal route.
·     e external—External route.
Origin
Origin of the label block:
·     i – IGP—Originated in the AS.
·     e – EGP—Learned through EGP.
·     ? – incomplete—Unknown origin.
# Display detailed information about the VPLS PE that has RD 2:2 and IP address 2.2.2.9.
<Sysname> display bgp l2vpn auto-discovery route-distinguisher 2:2 pe-address 2.2.2.9
 BGP local router ID: 192.168.1.140
 Local AS number: 100
 Total number of automatically discovered PEs: 1
 Paths:   1 available, 1 best
 Original nexthop: 2.2.2.9
 Ext-Community   : <RT: 2:2>, <VPLS ID: 100:100>
 AS-path         : (null)
 Origin          : igp
 Attribute value : localpref 100, pref-val 0
 PE address      : 2.2.2.9
 State           : valid, internal, best
Original nexthop
Original next hop. If the VPLS PE information was obtained from a BGP update, this field displays the next hop address in the received update.
Ext-Community
Extended community attribute:
·     RTRoute Target.
·     VPLS IDVPLS instance identifier.
AS-path
AS path attribute, which records all ASs that the VPLS PE information passed to prevent routing loops.
Origin
·     igp—Originated in the AS.
·     egp—Learned through EGP.
·     incomplete—Unknown origin.
Attribute value
Attribute of the VPLS PE information:
·     MED—Multi-Exit Discriminator attribute.
·     localpref—Local preference value.
·     pref-val—Preferred value.
·     prePreference value.
State of the VPLS PE information:
·     valid.
·     internal.
·     external.
·     local.
·     best.
# Display BGP advertisement information for the specified VPLS PE.
<Sysname> display bgp l2vpn auto-discovery route-distinguisher 2:2 pe-address 1.1.1.9 advertise-info
 Paths:   1 best
 VPLS ID         : 100:100
 PE address      : 1.1.1.9
 Advertised to peers (2 in total):
    2.2.2.9
    3.3.3.9
display bgp l2vpn signaling
Use display bgp l2vpn signaling to display VPLS label block information discovered by BGP.
display bgp l2vpn signaling [ peer ip-address { advertised | received } [ statistics ] | route-distinguisher route-distinguisher [ site-id site-id [ label-offset label-offset [ advertise-info ] ] ] | statistics ]
advertised: Displays VPLS label block information advertised to the BGP peer.
received: Displays VPLS label block information received from the BGP peer.
statistics: Displays VPLS label block statistics.
route-distinguisher route-distinguisher: Displays BGP VPLS label block information for the route distinguisher (RD), which is a string of 3 to 21 characters. You can specify an RD in one of the following formats:
site-id site-id: Displays BGP VPLS label block information for the specified site. The value range for the site ID is 0 to 65535.
label-offset label-offset: Displays information about the BGP VPLS label block with the specified offset in the range of 0 to 65535.
advertise-info: Displays BGP VPLS label block advertisement information.
If you do not specify any parameters, this command displays brief information about all BGP VPLS label blocks.
# Display brief information about all BGP VPLS label blocks.
<Sysname> display bgp l2vpn signaling
 BGP local router ID is 192.168.1.135
 Total number of label blocks: 2
     Site ID  LB offset  LB range  LB base    Nexthop
* >  1        0          10        1034       0.0.0.0
* >i 2        0          10        1162       192.3.3.3
Status codes
Status codes:
·     e – external—External route.
Origin
LB offset
Offset of the label block.
LB range
Size of the label block.
LB base
Initial value of the label block.
# Display detailed information about the BGP VPLS label block that has RD 1:1, site ID 2, and offset 0.
<Sysname> display bgp l2vpn signaling route-distinguisher 1:1 site-id 2 label-offset 0
 Route distinguisher: 1:1
 Total number of label blocks: 1
 Ext-Community   : <RT: 1:1>, <L2VPN info: MTU 1500, Encap type BGP VPLS>
 AS-path         : (null)
 Origin          : igp
 Site ID         : 2
 LB offset       : 0
 LB base         : 1418
 LB range        : 10
Original nexthop
Original next hop. If the label block was obtained from a BGP route update, this field displays the next hop address in that BGP route update.
Ext-Community
·     RT—Route target.
·     L2VPN info—L2VPN information, including the MTU and encapsulation type.
AS-path
AS path attribute, which records all ASs that the label block passed to prevent routing loops.
Origin
Attribute value
Attribute of the label block:
·     pre—Preference value.
LB offset
LB base
LB range
State of the label block:
·     valid.
·     internal.
·     external.
·     local.
·     best.
# Display BGP advertisement information for the specified VPLS label block.
<Sysname> display bgp l2vpn signaling route-distinguisher 1:1 site-id 1 label-offset 0 advertise-info
 Paths:   1 best
 Site ID         : 1
 LB offset       : 0
 LB base         : 1418
 LB range        : 10
    2.2.2.9
    3.3.3.9
Table 5 Command output
LB offset
LB base
LB range
display l2vpn auto-discovery
Use display l2vpn auto-discovery to display information about automatically discovered VPLS PEs.
display l2vpn auto-discovery [ peer ip-address ] [ vsi vsi-name ]
peer ip-address: Displays information about the specified VPLS PE. If you do not specify a PE, this command displays information about all automatically discovered VPLS PEs.
vsi vsi-name: Displays automatically discovered VPLS PEs for the VSI specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays automatically discovered VPLS PEs for all VSIs.
# Display information about all automatically discovered VPLS PEs.
<Sysname> display l2vpn auto-discovery
Total number of automatically discovered peers: 2
VSI Name: bbb
RD                    PE_address      VPLS ID               Nexthop
2:2                   1.1.1.9         100:100               1.1.1.9
2:2                   3.3.3.9         100:100               3.3.3.9
·     route-distinguisher
·     vpls-id
display l2vpn bgp
Use display l2vpn bgp to display VPLS label block information.
display l2vpn bgp [ local | peer ip-address ] [ vsi vsi-name ] [ verbose ]
local: Displays local VPLS label block information.
peer ip-address: Displays VPLS label block information received from the remote peer.
vsi vsi-name: Displays VPLS label block information for the VSI specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays VPLS label block information for all VSIs.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
If you specify a peer, this command displays both the label block received from the peer and the local label block that matches the received label block.
If you do not specify a peer or local, this command displays label blocks received from all peers and local label blocks that match the received ones.
A local label block matches a received label block if the following condition is met: local label block LO ≤ remote site ID ≤ local label block LO + local label block LR – 1.
# Display brief information about label blocks received from all peers.
<Sysname> display l2vpn bgp
Total number of BGP PWs: 2, 2 up, 0 down
VSI Name: aaa
Rmt Site   Offset  RD                    Nexthop          In/Out Label     State
1          0       1:1                   1.1.1.9          1419/1420        Up
3          0       1:1                   3.3.3.9          1421/1282        Up
Table 6 Command output
Rmt Site
ID of the remote site.
Offset
# Display detailed information about label blocks received from all peers.
<Sysname> display l2vpn bgp verbose
VSI Name: aaa
 Remote Site ID     : 1
 Offset             : 0
 RD                 : 1:1
 PW State           : Up
 Encapsulation      : BGP-VPLS
 MTU                : 1500
 Nexthop            : 1.1.1.9
 Local VC Label     : 1419
 Remote VC Label    : 1420
 Link ID            : 9
 Local Label Block  : 1418/10/0
 Remote Label Block : 1418/10/0
 Export Route Target: 1:1
 Remote Site ID     : 3
 Offset             : 0
 RD                 : 1:1
 PW State           : Up
 MTU                : 1500
 Nexthop            : 3.3.3.9
 Local VC Label     : 1421
 Remote VC Label    : 1282
 Link ID            : 10
 Remote Label Block : 1280/10/0
Table 7 Command output
Local VC Label
Incoming label of the PW.
Remote VC Label
Outgoing label of the PW.
Link ID
Link ID of the PW.
Local Label Block
Local label block: label base/label range/Label-block offset.
Remote Label Block
Remote label block: label base/label range/Label-block offset.
Export Route Target
Route target of the remote label block.
# Display brief information about all local label blocks.
<Sysname> display l2vpn bgp local
VSI Name: aaa
Site   Offset  Range  Label Base    RD
2      0       10     1418          1:1
Table 8 Command output
Offset
Range
Range of the label block.
Label Base
RD
RD of the label block. If no RD is configured, this field displays a hyphen (-).
# Display detailed information about all local label blocks.
<Sysname> display l2vpn bgp local verbose
VSI Name: aaa
 Site ID            : 2
 Offset             : 0
 RD                 : 1:1
 Range              : 10
 Label Base         : 1418
 Link ID            : 8,9,10,11,12,13,14,15,16
Table 9 Command output
Offset
RD
Range
Label Base
Link ID
Link IDs of the PWs established using the label block.
display l2vpn pw
display l2vpn forwarding
Use display l2vpn forwarding to display L2VPN forwarding information.
In standalone mode:
display l2vpn forwarding { ac | pw } [ vsi vsi-name ] [ slot slot-number ] [ verbose ]
In IRF mode:
display l2vpn forwarding { ac | pw } [ vsi vsi-name ] [ chassis chassis-number slot slot-number ] [ verbose ]
ac: Displays AC forwarding information.
pw: Displays PW forwarding information.
vsi vsi-name: Displays L2VPN forwarding information for the VSI specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN forwarding information for all VSIs.
slot slot-number: Displays L2VPN forwarding information on a card. The slot-number argument specifies the slot number of the card. If you do not specify a card, this command displays L2VPN forwarding information on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Displays L2VPN forwarding information for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device and the slot-number argument specifies the slot number of the card. If you do not specify this option, the command displays L2VPN forwarding information for the active MPU of the master device. (In IRF mode.)
# Display brief AC forwarding information for all VSIs.
<Sysname> display l2vpn forwarding ac
Total number of VSIs: 1
Total number of ACs: 2
AC                               VSI Name                        Link ID
GE1/0/5 srv1                     test                            3
GE1/0/5 srv2                     test                            4
Table 10 Command output
Total number of VSIs, including VSIs not bound to any AC.
AC
Layer 2 interface and Ethernet service instance, such as GE1/0/5 srv1.
Link ID
Link ID of the AC in the VSI.
# Display detailed AC forwarding information for all VSIs.
<Sysname> display l2vpn forwarding ac verbose
VSI Name: vpls1
  Interface: GE1/0/3  Service Instance: 1
    Link ID      : 1
    Access Mode  : VLAN
    Encapsulation: s-vid 1
Table 11 Command output
Service Instance
Ethernet service instance ID. This field is displayed only when the AC is an Ethernet service instance on a Layer 2 interface.
Link ID
Access Mode
AC access mode:
·     VLAN.
·     Ethernet.
Encapsulation
Match criterion of the Ethernet service instance. This field is displayed only when the AC is an Ethernet service instance on a Layer 2 interface.
# Display brief PW forwarding information for all VSIs.
<Sysname> display l2vpn forwarding pw
Total number of PWs: 2, 2 up, 0 blocked, 0 down
VSI Name                        In/Out Label    NID        Link ID    State
aaa                             1272/1275       1034       8          Up
aaa                             1271/1273       1035       9          Up
Table 12 Command output
Total number of VSIs, including VSIs containing no PW.
NID
NHLFE ID for the public tunnel that carries the PW.
If equal-cost tunnels are available, this field displays multiple NIDs.
If no tunnel is available, this field displays None.
Link ID
Link ID of the PW in the VSI.
PW state: Up, Down, Blocked, or BFD Defect.
Blocked indicates that the PW is blocked. BFD Defect indicates BFD has detected a defect on the PW.
# Display detailed PW forwarding information for all VSIs.
<Sysname> display l2vpn forwarding pw verbose
VSI Name: aaa
  Link ID: 8
    PW Type         : VLAN                  PW State : Up
    In Label        : 1272                  Out Label: 1275
    MTU             : 1500
    PW Attributes   : Main
    VCCV CC         : Router-Alert
    VCCV BFD        : Fault Detection with BFD
    Tunnel Group ID : 0x960000000
    Tunnel NHLFE IDs: 1034
  Link ID: 9
    In Label        : 1271                  Out Label: 1273
    MTU             : 1500
    Tunnel Group ID : 0xa60000001
    Tunnel NHLFE IDs: 1035
Table 13 Command output
Link ID
PW Type
Data encapsulation type of the PW.
PW State
Blocked indicates that the PW is blocked. BFD Defect indicates that BFD has detected a defect on the PW.
PW Attributes
PW attribute:
·     Main—The PW is the primary PW.
·     Backup—The PW is the backup PW.
·     No-split-horizon—Split horizon forwarding is disabled.
VCCV CC
VCCV CC type:
·     Control-Word—Control word.
·     Router-Alert—MPLS router alert label.
·     TTL—TTL timeout.
VCCV BFD
VCCV BFD type:
·     Fault Detection with BFD—BFD packets use IP/UDP encapsulation (with IP/UDP headers).
·     Fault Detection with Raw-BFD—BFD packets use PW-ACH encapsulation (without IP/UDP headers).
Tunnel Group ID
ID of the tunnel group for the PW.
Tunnel NHLFE IDs
NHLFE ID of the public tunnel that carries the PW.
display l2vpn ldp
Use display l2vpn ldp to display LDP PW label information.
display l2vpn ldp [ peer ip-address [ pw-id pw-id | vpls-id vpls-id ] | vsi vsi-name ] [ verbose ]
peer ip-address: Displays information about PW labels advertised by a peer PE through LDP. The ip-address argument specifies the LSR ID of the peer PE. If you do not specify a peer PE, this command displays information about LDP PW labels advertised by all peer PEs.
pw-id pw-id: Displays FEC 128 LDP PW label information for the PW specified by its PW ID. The PW ID is in the range of 1 to 4294967295. If you specify the peer ip-address option without the pw-id pw-id option, this command displays all LDP PW label information advertised by the specified peer PE.
vpls-id vpls-id: Displays FEC 129 LDP PW label information for the VPLS instance specified by its ID, which is a string of 3 to 21 characters. You can specify a VPLS ID in one of the following formats:
vsi vsi-name: Displays LDP PW label information for the VSI specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays LDP PW label information for all VSIs.
LDP advertises FEC-to-PW label bindings in the following ways:
·     After you specify a remote PE with the peer command, LDP advertises an FEC 128-to-PW label binding to the remote PE.
·     After BGP discovers a remote PE, LDP advertises an FEC 129-to-PW label binding to the remote PE.
This command can display PW labels as follows:
·     If you specify the pw-id pw-id option, this command displays PW labels for FEC 128.
·     If you specify the vpls-id vpls-id option, this command displays PW labels for FEC 129.
·     If you do not specify pw-id pw-id or vpls-id vpls-id, this command displays PW labels for both FEC 128 and FEC 129.
# Display brief information about all PW labels advertised by LDP.
<Sysname> display l2vpn ldp
Total number of LDP PWs: 6, 4 up, 2 down
Peer            PW ID/VPLS ID         In/Out Label    State Owner
192.3.3.3       1001                  775125/775126   Up    vpls1
192.3.3.3       1003                  775117/775122   Up    vpls3
192.3.3.3       1004                  775120/775120   Up    vpls4
192.3.3.3       10009                 unknown/775134  Down  vpls5
192.4.4.4       100                   775116/unknown  Down  vpls6
2.2.2.2         99:99                 775135/775125   Up    vplsauto
Table 14 Command output
PW ID/VPLS ID
PW ID for FEC 128, or VPLS ID of the PE for FEC 129.
PW state: Up or Down.
Owner
Name of the VSI to which the PW belongs.
# Display detailed information about all PW labels advertised by LDP.
<Sysname> display l2vpn ldp verbose
Peer: 2.2.2.9          PW ID: 500
  VSI Name: ccc
  PW State: Up
  PW Status Communication: Notification method
  PW ID FEC (Local/Remote):
    PW Type     : VLAN/VLAN
    Group ID    : 0/0
    Label       : 1552/1552
    Control Word: Disabled/Disabled
    VCCV CV Type: -/-
    VCCV CC Type: -/-
    MTU         : 1500/1500
    PW Status   : PW forwarding/PW forwarding
Peer: 2.2.2.9          VPLS ID: 100:100
  VSI Name: bbb
  PW State: Up
    Local AII   : (1.1.1.9, 2.2.2.9)
    Remote AII  : (2.2.2.9, 1.1.1.9)
    PW Type     : VLAN/VLAN
    Group ID    : 0/0
    Label       : 1553/1553
    VCCV CV Type: -/-
    VCCV CC Type: -/-
    MTU         : 1500/1500
Peer: 3.3.3.9          VPLS ID: 100:100
  VSI Name: bbb
  PW State: Up
    Local AII   : (1.1.1.9, 3.3.3.9)
    Remote AII  : (3.3.3.9, 1.1.1.9)
    PW Type     : VLAN/VLAN
    Group ID    : 0/0
    Label       : 1554/1416
    VCCV CV Type: -/-
    VCCV CC Type: -/-
    MTU         : 1500/1500
Table 15 Command output
PW status communication method:
·     Notification method—Notifies the PW status through Notification messages.
·     Label withdraw method—Assigns a PW label to the PW when the state of the AC associated with PW comes up, and withdraws the PW label when the AC state goes down.
PW ID FEC information advertised from the local PE to the peer PE/PW ID FEC information advertised from the peer PE to the local PE.
VCCV CV Type
VCCV CV type:
·     LSP Ping—Uses MPLS LSP ping to verify PW connectivity.
·     BFD—Uses BFD to verify PW connectivity. BFD packets use IP/UDP encapsulation (with IP/UDP headers).
·     Raw-BFD—Uses BFD to verify PW connectivity. BFD packets use PW-ACH encapsulation (without IP/UDP headers).
VCCV CC Type
VCCV control channel (CC) types supported by the local PE:
·     TTL—TTL timeout.
MTU
Maximum transmission unit of the VSI.
PW Status
PW status:
·     PW forwarding—PW is ready for packet forwarding.
·     PW not forwarding—PW is not ready for packet forwarding.
·     AC receive fault—AC cannot receive packets.
·     AC transmit fault—AC cannot send packets.
·     PW receive fault—PW cannot receive packets.
·     PW transmit fault—PW cannot send packets.
VPLS ID
ID of the VPLS instance.
Local AII
Source Attachment Individual Identifier (SAII) and Target Attachment Individual Identifier (TAII) advertised to the remote PE.
Remote AII
SAII and TAII received from the remote PE.
display l2vpn mac-address
Use display l2vpn mac-address to display MAC address table information for VSIs.
display l2vpn mac-address [ vsi vsi-name ] [ dynamic ] [ count ]
vsi vsi-name: Displays MAC address table information for the VSI specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays MAC address table information for all VSIs.
dynamic: Displays dynamically generated MAC address entries. If you do not specify this keyword, the command displays all types of MAC address entries. The device supports only dynamic MAC address entries in the current software version.
count: Displays the number of the MAC address entries. If you do not specify this keyword, the command displays detailed information about the MAC address entries.
# Display MAC address table information for all VSIs.
<Sysname> display l2vpn mac-address
MAC Address      State    VSI Name                         Link ID/Name  Aging
0000-0000-000a   dynamic  vpn1                             1             Aging
0000-0000-0009   dynamic  vpn1                             2             Aging
--- 2 mac address(es) found  ---
# Display the total number of MAC address entries of all VSIs.
<Sysname> display l2vpn mac-address count
Table 16 Command output
MAC address type. The MAC address type can only be dynamic in the current software version, which indicates that the MAC address is dynamically learned.
Link ID/Name
The Link ID field represents the outgoing link ID of the MAC address entry. It is the link ID of the AC or PW in the VSI.
The Name field applies to a VXLAN VSI. VPLS VSIs do not support the Name field.
Aging
Whether the MAC address entry will be aged.
XX mac address(es) found
Total number of MAC address entries of the VSI.
reset l2vpn mac-address
display l2vpn pw
Use display l2vpn pw to display L2VPN PW information.
display l2vpn pw [ vsi vsi-name ] [ protocol { bgp | ldp | static } ] [ verbose ]
vsi vsi-name: Displays L2VPN PW information for the VSI specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays L2VPN PW information for all VSIs.
protocol: Specifies a signaling protocol. If you do not specify a protocol, this command displays PWs created by all protocols.
bgp: Displays BGP PW information.
ldp: Displays LDP PW information, including PWs for FEC 128 (LDP PWs) and FEC 129 (BGP auto-discovery LDP PWs).
static: Displays static PW information.
# Display brief information about all PWs.
<Sysname> display l2vpn pw
Flags: M - main, B - backup, H - hub link, S - spoke link, N - no split horizon
Total number of PWs: 5
5 up, 0 blocked, 0 down, 0 defect, 0 idle, 0 duplicate
VSI Name: aaa
Peer            PW ID/Rmt Site    In/Out Label    Proto   Flag  Link ID  State
2.2.2.9         2                 1420/1419       BGP     M     9        Up
3.3.3.9         3                 1421/1281       BGP     M     10       Up
VSI Name: bbb
2.2.2.9         -                 1553/1553       LDP     M     8        Up
3.3.3.9         -                 1554/1416       LDP     M     9        Up
VSI Name: ccc
2.2.2.9         500               1552/1552       LDP     M     8        Up
Table 17 Command output
PW ID/Rmt Site
This field displays the following:
·     PW ID for an LDP PW (FEC 128) or a static PW.
·     A hyphen (-) for a BGP auto-discovery LDP PW (FEC 129).
·     Remote site ID for a BGP PW.
Proto
Protocol used to establish the PW: LDP, Static, or BGP.
Flag
PW attribute flag:
·     M—Primary PW.
·     B—Backup PW.
·     N—Split horizon forwarding is disabled.
Link ID
PW state:
·     UpThe PW is available.
·     DownThe PW is not available.
·     BlockedThe PW is a backup PW.
·     Defect—BFD has detected a defect on the PW.
·     IdleThe incoming label of the PW is not available.
·     DupThe incoming label of the static PW is occupied by a static LSP or a static CRLSP.
# Display detailed information about all L2VPN PWs.
<Sysname> display l2vpn pw verbose
VSI Name: aaa
  Peer: 2.2.2.9          Remote Site: 2
    Signaling Protocol  : BGP
    Link ID             : 9          PW State : Up
    In Label            : 1420       Out Label: 1419
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x800000960000000
    Tunnel NHLFE IDs    : 1038
  Peer: 3.3.3.9          Remote Site: 3
    Link ID             : 10         PW State : Up
    In Label            : 1421       Out Label: 1281
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    Tunnel Group ID     : 0x800000160000001
    Tunnel NHLFE IDs    : 1030
VSI Name: bbb
    Signaling Protocol  : LDP
    Link ID             : 8          PW State : Up
    In Label            : 1553       Out Label: 1553
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
    In Label            : 1554       Out Label: 1416
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
VSI Name: ccc
    In Label            : 1552       Out Label: 1552
    MTU                 : 1500
    VCCV CC             : -
    VCCV BFD            : -
Table 18 Command output
Peer
IP address of the peer PE to which the PW is destined.
Link ID
PW State
PW state:
·     DuplicateThe incoming label of the static PW is occupied by a static LSP or a static CRLSP.
Wait to Restore Time
Wait time to switch traffic from the backup PW to the primary PW when the primary PW recovers, in seconds. If the switchover is disabled, this field displays Infinite.
This field is available when both primary and backup PW exist, and is displayed only for the primary PW.
Remaining Time
Remaining wait time for traffic switchover, in seconds. This field is displayed after the switchover wait timer is started.
MTU
Negotiated MTU of the PW.
PW Attributes
PW attribute:
VCCV CC
VCCV CC type:
·     TTL—TTL timeout.
VCCV BFD
VCCV BFD type:
Tunnel Group ID
Tunnel NHLFE IDs
VPLS ID
Remote Site
Input statistics
PW forwarding statistics in inbound direction:
·     Octets—Number of received octets.
·     Packets—Number of received packets.
·      Errors—Number of received error packets.
·     Discards—Number of discarded packets.
Output statistics
PW forwarding statistics in outbound direction:
·     Octets—Number of sent octets.
·     Packets—Number of sent packets.
·     Errors—Number of error packets.
statistics enable
Use display l2vpn pw-class to display PW class information.
display l2vpn pw-class [ class-name ]
class-name: Displays information about the PW class specified by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a PW class, this command displays information about all PW classes.
# Display information about all PW classes.
<Sysname> display l2vpn pw-class
Total number of PW classes: 2
PW Class Name       PW Type              Control Word   VCCV CC        VCCV BFD
pw1                 Ethernet             Enabled        Control-Word   Raw-BFD
pw2                 VLAN                 Disabled       Router-Alert   BFD
Table 19 Command output
VCCV CC
VCCV CC type:
·     TTL—TTL timeout.
VCCV BFD
VCCV BFD type:
pw-class
display l2vpn service-instance
Use display l2vpn service-instance to display Ethernet service instance information.
interface interface-type interface-number: Displays Ethernet service instance information for the specified Layer 2 Ethernet interface or Layer 2 aggregate interface. If you do not specify an interface, this command displays Ethernet service instance information for all Layer 2 Ethernet interfaces and Layer 2 aggregate interfaces.
service-instance instance-id: Displays information about the Ethernet service instance specified by its ID. The instance ID is in the range of 1 to 4096. If you specify interface interface-type interface-number without this option, the command displays information about all Ethernet service instances on the specified Layer 2 Ethernet interface or Layer 2 aggregate interface.
# Display brief information about all Ethernet service instances.
<Sysname> display l2vpn service-instance
Total number of service-instances: 8, 8 up, 0 down
Total number of ACs: 4, 4 up, 0 down
Interface                SrvID Owner                           LinkID State Type
GE1/0/3                  1     vpls1                           1      Up    VSI
GE1/0/3                  2     vpls2                           1      Up    VSI
GE1/0/3                  3     vpls3                           1      Up    VSI
GE1/0/3                  4     vpls4                           1      Up    VSI
GE1/0/3                  5                                            Up
Table 20 Command output
SrvID
Owner
Name of the VSI bound to the Ethernet service instance. If no VSI is bound, this field is blank.
LinkID
Ethernet service instance state.
L2VPN type of the Ethernet service instance: VSI or VPWS.
# Display detailed information about all Ethernet service instances on Layer 2 Ethernet interface GigabitEthernet 1/0/3.
<Sysname> display l2vpn service-instance interface gigabitethernet 1/0/3 verbose
Interface: GE1/0/3
  Service Instance: 1
    Encapsulation : s-vid 1 to 16
    VSI Name      : vpls1
    Link ID       : 1
    State         : Up
  Service Instance: 2
    Encapsulation : s-vid 1001 to 1016
                    only-tagged
    VSI Name      : vpls2
    Link ID       : 1
    State         : Up
  Service Instance: 3
    Encapsulation : s-vid 2000
                    c-vid 1001 to 1002 1015 to 1016
    VSI Name      : vpls3
    Link ID       : 1
    State         : Up
Table 21 Command output
Service Instance
Encapsulation
Packet match criterion of the Ethernet service instance. If no packet match criterion is configured, the field is not displayed.
VSI Name
Link ID
Ethernet service instance state: Up and Down.
service-instance
display l2vpn vsi
Use display l2vpn vsi to display VSI information.
display l2vpn vsi [ name vsi-name ] [ verbose ]
name vsi-name: Displays information about the VSI specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command displays information about all VSIs.
# Display brief information about all VSIs.
<Sysname> display l2vpn vsi
Total number of VSIs: 2, 1 up, 1 down, 0 admin down
VSI Name                        VSI Index       MTU    State
vpls1                           0               1500   Up
vpls2                           1               1500   Down
Table 22 Command output
VSI state:
·     Up.
·     Down.
·     Admin down—The VSI is manually brought down by using the shutdown command.
# Display detailed information about all VSIs.
<Sysname> display l2vpn vsi verbose
VSI Name: vpls1
  VSI Index               : 0
  VSI Description         : vsi for vpls1
  VSI State               : Up
  Bandwidth               : -
  Broadcast Restrain      : 5%
  Multicast Restrain      : 100%
  Unknown Unicast Restrain: 100%
  MAC Table Limit         : Unlimited
  Drop Unknown            : Disabled
  LDP PWs:
    Peer            PW ID            Link ID    State
    192.3.3.3       1                8          Up
    192.3.3.3       1001             8          Blocked
  BGP PWs:
    Peer            Remote Site      Link ID    State
    192.4.4.4       1                9          Up
  ACs:
    AC                               Link ID    State
    GE1/0/3 srv1                     1          Up
Table 23 Command output
VSI Description
If no description is configured for the VSI, this field is not displayed.
VSI State
VSI state:
·     Up.
·     Down.
Drop Unknown
Whether the VSI drops packets with unknown source MAC addresses after it has leaned the maximum number of MAC addresses.
·     Enabled—Drops packets with unknown source MAC addresses.
·     Disabled—Forwards packets with unknown source MAC addresses.
AC
Layer 2 interface and Ethernet service instance, such as GE1/0/3 srv1.
vsi
encapsulation
Use encapsulation to configure a packet match criterion for an Ethernet service instance.
Use undo encapsulation to remove a packet match criterion from an Ethernet service instance.
encapsulation s-vid vlan-id [ only-tagged ]
encapsulation s-vid vlan-id c-vid vlan-id
encapsulation { default | tagged | untagged }
undo encapsulation
No packet match criterion is configured for an Ethernet service instance.
Ethernet service instance view
s-vid vlan-id: Matches packets with a specific outer VLAN ID in the range of 1 to 4094.
only-tagged: Matches tagged packets. If the outer VLAN is not the PVID, the matching result does not differ, whether or not you specify the only-tagged keyword. If the outer VLAN is the PVID, the matching result depends on whether or not the only-tagged keyword is specified.
·     To match only PVID-tagged packets, specify the only-tagged keyword.
·     To match both untagged packets and PVID-tagged packets, do not specify the only-tagged keyword.
s-vid vlan-id c-vid vlan-id: Matches packets with a specific outer VLAN ID and a specific inner VLAN ID. The value range for the vlan-id argument is 1 to 4094.
default: Matches packets that do not match any other Ethernet service instances on the interface. On an interface, you can configure this criterion only in one Ethernet service instance. The Ethernet service instance matches any packets if it is the only instance on the interface.
untagged: Matches any packets that do not have a VLAN tag.
An Ethernet service instance can contain only one match criterion. To change the match criterion, you must remove the original criterion first. When you remove the match criterion in an Ethernet service instance, the mapping between the Ethernet service instance and the VSI is removed automatically.
For information about inner and outer VLAN tags, see Layer 2—LAN Switching Configuration Guide.
# Configure Ethernet service instance 1 on Layer 2 Ethernet interface GigabitEthernet 1/0/1 to match packets that have an outer VLAN ID of 111 and an inner VLAN ID of 20.
[Sysname-GigabitEthernet1/0/1] service-instance 1
[Sysname-GigabitEthernet1/0/1-srv1] encapsulation s-vid 111 c-vid 20
l2vpn enable
Use l2vpn enable to enable L2VPN.
Use undo l2vpn enable to disable L2VPN.
l2vpn enable
undo l2vpn enable
L2VPN is disabled.
You must enable L2VPN before configuring other L2VPN settings.
# Enable L2VPN.
[Sysname] l2vpn enable
l2vpn switchover
Use l2vpn switchover to switch traffic from the specified PW to its backup or primary PW.
l2vpn switchover peer ip-address pw-id pw-id
peer ip-address: Specifies the LSR ID of the peer PE.
pw-id pw-id: Specifies a PW by its ID in the range of 1 to 4294967295.
The specified LSR ID and PW ID uniquely identify a PW.
If a PW has a backup PW or primary PW, this command switches traffic from the PW to the backup or primary PW. If the PW does not have a backup or primary PW, this command does not perform the switchover.
# Switch traffic from PW 100 destined for 3.3.3.3 to its backup PW.
<Sysname> l2vpn switchover peer 3.3.3.3 pw-id 100
mac-learning enable
Use mac-learning enable to enable MAC address learning for a VSI.
Use undo mac-learning enable to disable MAC address learning for a VSI.
mac-learning enable
MAC address learning is enabled for a VSI.
VSI view
If MAC address learning is disabled for a VSI, the VSI does not learn the source MAC addresses of received packets.
# Disable MAC address learning for the VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] undo mac-learning enable
display l2vpn vsi
mtu
Use mtu to set an MTU for a VSI.
mtu mtu
undo mtu
A VSI has an MTU of 1500 bytes.
VSI view
mtu: Specifies an MTU value in the range of 300 to 65535, in bytes.
The MTU specifies the maximum length of a packet transmitted on a PW, including the control word, PW label, and network layer packet.
When LDP is used to create PWs, all PEs in a VPLS instance must have the same MTU configured for the VSI.
# Set the MTU to 1400 bytes for VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] mtu 1400
display l2vpn vsi
peer
Use peer to configure a VPLS PW and enter VSI LDP PW view or VSI static PW view. If the specified PW has been created, this command places you in VSI LDP PW view or VSI static PW view.
Use undo peer to delete a VPLS PW.
VSI LDP signaling view:
peer ip-address [ pw-id pw-id ] [ hub | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] *
undo peer ip-address pw-id pw-id
VSI static configuration view:
peer ip-address [ pw-id pw-id ] [ in-label label-value out-label label-value [ hub | no-split-horizon | pw-class class-name | tunnel-policy tunnel-policy-name ] * ]
No PW is configured for VPLS.
VSI LDP signaling view, VSI static configuration view
pw-id pw-id: Specifies a PW ID for the PW, in the range of 1 to 4294967295.
in-label label-value: Specifies the incoming label of the PW, in the range of 16 to 1023.
out-label label-value: Specifies the outgoing label of the PW, in the range of 16 to 1023.
hub: Specifies the PW as the hub link the VSI. After a VSI is enabled with the hub-spoke capability, a PW in the VSI is a spoke link by default. This keyword is not supported in the current software version.
no-split-horizon: Disables split horizon forwarding for the PW. By default, a PW must use the split horizon forwarding scheme to forward packets.
pw-class class-name: Specifies a PW class by its name, a case-sensitive string of 1 to 19 characters. You can specify a PW class to configure the PW type and control word. If you do not specify a PW class, the PW type is VLAN and the PW does not support control word.
tunnel-policy tunnel-policy-name: Specifies a tunnel policy by its name, a case-insensitive string of 1 to 19 characters. If you do not specify a tunnel policy, the PW uses the default tunnel policy.
To create a static PW, you must specify the incoming and outgoing labels. To enter VSI static PW view of an existing static PW, you do not need to specify the incoming and outgoing labels.
The PW ID for a PW must be the same on the PEs at the ends of the PW.
On a PE, the LSR ID of the peer PE and the PW ID uniquely identify a PW. The peer LSR ID and PW ID combination of a PW must be unique among all VPLS PWs and cross-connect PWs.
If both a default PW ID in the default-pw-id command and a PW ID in the peer command are configured, the PW ID in the peer command is used. If only a default PW ID is configured, the default PW ID is used. If no default PW ID is configured, you must provide a PW ID in the peer command.
# Configure an LDP PW for the VSI vpn1 and enter VSI LDP PW view: specify the peer PE address as 4.4.4.4, set the PW ID to 200, and disable split horizon forwarding for the PW.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-ldp] peer 4.4.4.4 pw-id 200 no-split-horizon
[Sysname-vsi-vpn1-ldp-4.4.4.4-200]
# Configure a static PW for the VSI vpn1 and enter VSI static PW view: specify the peer PE address as 5.5.5.5, set the PW ID to 200, incoming label to 100, and outgoing label to 200, and disable split horizon forwarding for the PW.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] pwsignaling static
[Sysname-vsi-vpn1-static] peer 5.5.5.5 pw-id 200 in-label 100 out-label 200 no-split-horizon
[Sysname-vsi-vpn1-static-5.5.5.5-200]
·     default-pw-id
·     display l2vpn ldp
·     display l2vpn pw
·     pw-class
·     tunnel-policy
peer auto-discovery
Use peer auto-discovery to enable BGP to exchange VPLS PE information with the specified peers.
Use undo peer auto-discovery to disable BGP from exchanging VPLS PE information with the specified peers.
peer { group-name | ip-address [ mask-length ] } auto-discovery [ non-standard ]
undo peer { group-name | ip-address [ mask-length ] } auto-discovery
BGP can exchange VPLS PE information with the a BGP L2VPN peer or peer group through RFC 6074 MP_REACH_NLRI.
group-name: Specifies a peer group by its name, a case-sensitive string of 1 to 47 characters. The specified peer group must have been created.
ip-address: Specifies a peer by its IP address. The specified peer must have been created.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to exchange VPLS PE information with all dynamic peers in the subnet.
non-standard: Uses non-standard MP_REACH_NLRI to exchange VPLS PE information. If you do not specify this keyword, RFC 6074 MP_REACH_NLRI is used to exchange VPLS PE information.
L2VPN can use MP-BGP to exchange VPLS PE information and find remote PEs in the same VPLS instance.
To enable BGP to exchange VPLS PE information with the specified peers through RFC 6074 MP_REACH_NLRI, you can also use the peer enable command in BGP L2VPN address family view. To disable the capability, use the undo peer auto-discovery command.
# Enable BGP to exchange VPLS PE information with the peer 3.3.3.9 through RFC 6074 MP_REACH_NLRI.
[Sysname] bgp 100
[Sysname-bgp-l2vpn] peer 3.3.3.9 auto-discovery
# Enable BGP to exchange VPLS PE information with the peer group test  through non-standard MP_REACH_NLRI.
[Sysname] bgp 100
[Sysname-bgp-l2vpn] peer test auto-discovery non-standard
peer signaling
Use peer signaling to enable BGP to exchange label block information with the specified peers.
Use undo peer signaling to disable BGP to exchange label block information with the specified peers.
peer { group-name | ip-address [ mask-length ] } signaling
undo peer { group-name | ip-address [ mask-length ] } signaling
BGP can exchange label block information with a BGP L2VPN peer or peer group.
mask-length: Specifies a mask length in the range of 0 to 32. You can use the ip-address and mask-length arguments together to specify a subnet. If you specify a subnet, this command enables BGP to exchange label block information with all dynamic peers in the subnet.
L2VPN uses MP-BGP to exchange label blocks when creating a BGP PW.
To enable BGP to exchange label block information with the specified peers, you can also use the peer enable command in BGP L2VPN address family view. To disable the capability, use the undo peer signaling command.
# Enable BGP to exchange label block information with the peer 3.3.3.9.
[Sysname] bgp 100
[Sysname-bgp-l2vpn] peer 3.3.3.9 signaling
policy vpn-target
Use policy vpn-target to enable route target-based filtering of incoming BGP L2VPN information.
Use undo policy vpn-target to disable route target-based filtering of incoming BGP L2VPN information.
policy vpn-target
Route target-based filtering of incoming BGP L2VPN information is enabled.
If route target-based filtering is enabled, L2VPN accepts only the incoming BGP L2VPN information whose export route target attribute matches the local import route target attribute.
If route target-based filtering is disabled, L2VPN accepts all incoming BGP L2VPN information.
On an inter-AS VPN option B network, an ASBR-PE needs to store all BGP L2VPN information (VPLS PE and label block information discovered by BGP) and advertises the information to the remote ASBR-PE. To meet this need, execute the undo policy vpn-target command on the ASBR-PE to accept all incoming BGP L2VPN information.
For more information about an inter-AS VPN option B network, see MPLS Configuration Guide.
# Disable route target-based filtering of incoming BGP L2VPN information.
[Sysname] bgp 100
[Sysname-bgp-l2vpn] undo policy vpn-target
pw-class (auto-discovery VSI view)
Use pw-class to specify a PW class for an auto-discovery VSI.
Use undo pw-class to remove the configuration.
pw-class class-name
undo pw-class
No PW class is specified.
Auto-discovery VSI view
The specified PW class will be used to establish all PWs on the auto-discovery VSI.
# Specify a PW class named pw100 for the auto-discovery VSI aaa.
[Sysname-pw-pw100] quit
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] pw-class pw100
·     control-word enable
·     display l2vpn pw-class
·     pw-type
pw-class (system view)
Use pw-class to create a PW class and enter PW class view.
Use undo pw-class to delete a PW class.
pw-class class-name
undo pw-class class-name
No PW class is created.
class-name: Specifies a name for the PW class, a case-sensitive string of 1 to 19 characters.
In PW class view, you can configure PW attributes such as the PW type and whether to enable control word. A PW class simplifies PW attribute configuration for PWs that have the same PW attributes. You can configure the PW attributes in a PW class, and specify the PW class for the PWs.
# Create a PW class named pw100 and enter PW class view.
[Sysname-pw-pw100]
·     pw-type
pwsignaling
Use pwsignaling to specify a PW signaling protocol for a VSI, and enter the VSI signaling protocol view.
Use undo pwsignaling to remove the specified PW signaling protocol for a VSI.
pwsignaling { ldp | static }
undo pwsignaling { ldp | static }
No PW signaling protocol is specified for a VSI.
VSI view
ldp: Establishes PWs through LDP (FEC 128) and enters VSI LDP signaling view.
static: Establishes PWs statically and enters VSI static configuration view.
# Configure the VSI vpn1 to use LDP to establish LDP PWs, and enter VSI LDP signaling view.
[Sysname] vsi vpn1
display l2vpn pw
pw-type
Use pw-type to specify a PW type for a PW class.
Use undo pw-type to restore the default.
pw-type { ethernet | vlan }
undo pw-type
The PW type for a PW class is VLAN.
PW class view
ethernet: Specifies the PW type as Ethernet.
vlan: Specifies the PW type as VLAN.
When the PW type is Ethernet, the PE encapsulates packets forwarded between the AC and PW as follows:
·     Traffic from the AC to the PW cannot carry the P-tag assigned by the service provider.
¡     If traffic from the AC has the P-tag, the PE removes the P-tag, and adds a PW label and an outer tag into the packet before forwarding it.
¡     If traffic from the AC does not have the P-tag, the PE adds a PW label and an outer tag into the packet before forwarding it.
·     For traffic received from the PW:
¡     If the AC access mode (configured by the xconnect vsi command) is VLAN, the PE adds the P-tag and forwards the traffic through the AC.
¡     If the AC access mode is Ethernet, the PE directly forwards the traffic through the AC. The PE cannot modify or delete the P-tag for the traffic from the PW.
When the PW type is VLAN, the PE encapsulates packets forwarded between the AC and PW as follows:
·     Traffic from the AC to the PW must carry the P-tag.
¡     If traffic from the AC has the P-tag, the PE performs one of the following operations:
-     Keeps the P-tag when the peer PE does not require the ingress to modify the P-tag.
-     Changes the P-tag to the expected value (which can be zero) when the peer PE requires the ingress to modify the P-tag. Then, the PE adds a PW label and an outer tag into the packet before forwarding it.
¡     If traffic from the AC does not have the P-tag, the PE performs one of the following operations:
-     Adds a P-tag of 0 when the peer PE does not require the ingress to modify the P-tag.
-     Adds the expected P-tag (which can be zero) when the peer PE requires the ingress to modify the P-tag. Then, the PE adds a PW label and an outer tag into the packet before forwarding it.
¡     If the AC access mode (configured by the xconnect vsi command) is VLAN, the PE modifies or keeps the P-tag and forwards the traffic through the AC.
¡     If the AC access mode is Ethernet, the PE removes the P-tag and forwards the traffic through the AC.
# Configure the PW type as Ethernet.
[Sysname-pw-pw100] pw-type ethernet
Use reset l2vpn mac-address to clear MAC address entries for VSIs.
reset l2vpn mac-address [ vsi vsi-name ]
vsi vsi-name: Clears MAC address entries for the VSI specified by its name, a case-sensitive string of 1 to 31 characters. If you do not specify a VSI, this command clears MAC address entries for all VSIs.
When a VSI learns wrong MAC addresses or has learned the maximum number of MAC addresses, use this command to clear MAC addresses for the VSI. Then, the VSI can learn MAC addresses again.
# Clear MAC address entries for the VSI vpn1.
<Sysname> reset l2vpn mac-address vsi vpn1
display l2vpn mac-address vsi
revertive
Use revertive to specify whether to switch traffic from the backup PW to the primary PW when the primary PW recovers, and set the wait time for the switchover.
Use undo revertive wtr to restore the default wait time of 0 seconds.
Use undo revertive never to restore the default.
revertive { wtr wtr-time | never }
undo revertive { wtr | never }
When the primary PW recovers, traffic is immediately switched back from the backup PW to the primary PW.
wtr wtr-time: Specifies the wait time in the range of 0 to 3600 seconds. When the primary PW recovers, the PE waits for the specified time before switching traffic from the backup PW to the primary PW.
never: Disables switchover to primary.
# Set the switchover wait time to 120 seconds for static PWs in the VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1-static] revertive wtr 120
display l2vpn pw
route-distinguisher
Use route-distinguisher to configure a route distinguisher (RD) for an auto-discovery VSI.
Use undo route-distinguisher to remove the RD for an auto-discovery VSI.
No RD is configured for an auto-discovery VSI.
route-distinguisher: Specifies an RD, a string of 3 to 21 characters. An RD can be in one of the following formats:
VPLS uses RDs to differentiate the sites that reside in different VPNs and have the same site ID.
BGP adds the configured RD before the site ID. The RD and the site ID uniquely identify a VPN site.
The configured RD applies to both BGP neighbor auto-discovery and VPLS label block advertisement.
You cannot configure the same RD for different BGP VSIs.
To change an RD, you must remove the RD and then configure it again.
# Configure the RD 22:1 for the BGP VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] route-distinguisher 22:1
rr-filter
Use rr-filter to create a route reflector (RR) reflection policy so that only the L2VPN information that contains the specified extended community number is reflected.
Use undo rr-filter to restore the default.
rr-filter extended-community-number
undo rr-filter
An RR does not filter reflected L2VPN information.
extended-community-number: Specifies an extended community number in the range of 1 to 199.
By configuring different RR reflection policies on RRs in a cluster, you can implement load balancing among the RRs.
# Configure the RR to reflect only the BGP L2VPN information that contains the extended community number 10.
[Sysname] bgp 100
[Sysname-bgp-l2vpn] rr-filter 10
service-instance
Use service-instance to create an Ethernet service instance on an interface, and enter Ethernet service instance view.
Use undo service-instance to delete an Ethernet service instance on an interface.
undo service-instance instance-id
No Ethernet service instance is created on an interface.
Layer 2 Ethernet interface view, Layer 2 aggregate interface view
instance-id: Specifies the ID of the Ethernet service instance, in the range of 1 to 4096.
# Create Ethernet service instance 1 on Layer 2 Ethernet interface GigabitEthernet 1/0/1, and enter Ethernet service instance 1 view.
shutdown
Use shutdown to disable a VSI.
Use undo shutdown to enable a VSI.
shutdown
A VSI is enabled.
VSI view
After you disable a VSI, the VSI cannot provide VPLS services.
Use the shutdown command when you want to temporarily disable VPLS. When a VSI is disabled, you can still configure the VSI. After the configuration, use the undo shutdown command to enable the VSI. The VSI will provide VPLS services using the new settings.
# Disable VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] shutdown
display l2vpn vsi
signaling-protocol
Use signaling-protocol to specify a signaling protocol used to establish a PW to the remote PE discovered by BGP and enter specified signaling view.
Use undo signaling-protocol to remove the signaling protocol configuration.
signaling-protocol { bgp | ldp }
No signaling protocol is specified.
bgp: Specifies the signaling protocol as BGP and enters auto-discovery VSI BGP signaling view.
ldp: Specifies the signaling protocol as LDP and enters auto-discovery VSI LDP signaling view.
You cannot execute this command multiple times to specify different signaling protocols in the same auto-discovery VSI view.
# Use LDP (FEC 129) to establish a PW to a remote PE discovered by BGP and enter auto-discovery VSI LDP signaling view.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] signaling-protocol ldp
[Sysname-vsi-aaa-auto-ldp]
·     display l2vpn pw
·     display l2vpn vsi
site
Use site to create a local site.
Use undo site to delete a local site.
site site-id [ range range-value ] [ default-offset default-offset ]
undo site site-id
No site is created.
Auto-discovery VSI BGP signaling view
site-id: Specifies a local site ID in the range of 0 to 32.
range range-value: Specifies the maximum number of sites in a VPLS instance, in the range of 2 to 1 + the maximum number of site-id. The default value is 10.
default-offset default-offset: Specifies the start site ID, 0 or 1. The default value is 0.
You can create multiple local sites for a VSI.
You can use the site command to increase the range value for an existing site. You cannot decrease the range value for an existing site with the site command. To decrease the range value, you must delete the site and re-create the site with the new range value.
You cannot modify the default-offset for a site with the site command. To modify it, you must delete the site and re-create the site with the new default-offset.
# Create site 1, configure the VPLS instance to contain a maximum of 30 sites, and set the start site ID to 0 for the VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa] auto-discovery bgp
[Sysname-vsi-aaa-auto] signaling-protocol bgp
[Sysname-vsi-aaa-auto-bgp] site 1 range 30 default-offset 0
·     display l2vpn pw
·     display l2vpn vsi
tunnel-policy (auto-discovery VSI view)
Use tunnel-policy to specify a tunnel policy for an auto-discovery VSI.
Use undo tunnel-policy to remove the configuration.
undo tunnel-policy
No tunnel policy is specified.
The PWs on the auto-discovery VSI use the specified tunnel policy to select public tunnels.
If you do not specify a tunnel policy or specify a nonexistent tunnel policy, the default tunnel policy applies. The default tunnel policy selects only one public tunnel for a PW in this order: LSP tunnel, CRLSP tunnel.
VPLS does not support load balancing among tunnels. If you specify a tunnel policy whose load balancing number is set to a value greater than 1, the setting does not take effect. The tunnel policy selects only one tunnel.
# Specify the tunnel policy policy1 for the auto-discovery VSI aaa.
[Sysname] tunnel-policy policy1
[Sysname-tunnel-policy-policy1] quit
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] tunnel-policy policy1
tunnel-policy
vpls-id
Use vpls-id to set the VPLS ID of a VSI.
Use undo vpls-id to remove the VPLS ID of a VSI.
vpls-id vpls-id
undo vpls-id
No VPLS ID is specified for a VSI.
Auto-discovery VSI LDP signaling view
vpls-id: Specifies a VPLS ID, a string of 3 to 21 characters. You can specify a VPLS ID in one of the following formats:
A VPLS ID uniquely identifies a VPLS instance. Two PEs must have the same VPLS ID to establish a PW.
VPLS IDs are used in the scenario where BGP is used to find remote PEs and FEC 129 LDP is used to establish PWs to the remote PEs.
The local PE advertises a BGP update that includes the configured VPLS ID as an extended community attribute to the remote PE. The remote PE compares the received VPLS ID with its own VPLS ID. If the two VPLS IDs are identical, the two PEs use FEC 129 LDP to establish a PW. If not, the PEs do not establish a PW.
To change a VPLS ID, you must remove the VPLS ID and then configure it again.
# Configure the VPLS ID 100:1 for the VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto-ldp] vpls-id 100:1
·     display l2vpn pw
·     display l2vpn vsi
vpn-target
Use vpn-target to configure route targets for an auto-discovery VSI.
Use undo vpn-target to remove route targets for an auto-discovery VSI.
undo vpn-target { vpn-target&<1-8> | all } [ both | export-extcommunity | import-extcommunity ]
No route targets are configured for an auto-discovery VSI.
Auto-discovery VSI
vpn-target&<1-8>: Specifies a space-separated list of up to eight route targets.
A route target is a string of 3 to 21 characters in one of the following formats:
both: Uses the specified route targets as both import targets and export targets. The both keyword is used when you do not specify any of both, export-extcommunity, and import-extcommunity.
export-extcommunity: Uses the specified route targets as export targets.
import-extcommunity: Uses the specified route targets as import targets.
all: Removes all route targets.
A local PE sets the route targets as export targets in BGP update messages when it advertises L2VPN information through the update messages to a remote peer. The peer uses its import targets to match the received export targets. If a match is found, the peer accepts the L2VPN information.
# Configure import route targets as 10:1 100:1 1000:1 and export route targets as 20:1 200:1 2000:1, for the auto-discovery VSI aaa.
[Sysname] vsi aaa
[Sysname-vsi-aaa-auto] vpn-target 10:1 100:1 1000:1 import-extcommunity
[Sysname-vsi-aaa-auto] vpn-target 20:1 200:1 2000:1 export-extcommunity
vsi
Use vsi to create a VSI or enter VSI view. If the VSI has been created, this command places you in VSI view.
Use undo vsi to delete a VSI.
vsi vsi-name
undo vsi vsi-name
No VSI is created.
vsi-name: Specifies a name for the VSI, a case-sensitive string of 1 to 31 characters.
You can create multiple PWs for a VSI manually, or by using LDP or BGP.
# Create a VSI named vpls1 and enter VSI view.
[Sysname] vsi vpls1
[Sysname-vsi-vpls1]
display l2vpn vsi
xconnect vsi
Use xconnect vsi to bind an Ethernet service instance to a VSI.
Use undo xconnect vsi to remove the binding.
xconnect vsi vsi-name access-mode { ethernet | vlan }
undo xconnect vsi
An Ethernet service instance is not bound to any VSI.
vsi-name: Specifies the name of a VSI, a case-sensitive string of 1 to 31 characters.
access-mode: Specifies the AC access mode. The default access mode is VLAN.
·     ethernet: Specifies the access mode as Ethernet.
·     vlan: Specifies the access mode as VLAN.
The AC access mode determines how the PE considers the VLAN tag in Ethernet frames received from the AC and how the PE forwards Ethernet frames to the AC.
·     VLAN access mode—Ethernet frames received from the AC must carry a VLAN tag in the Ethernet header. The PE considers the VLAN tag as a P-tag assigned by the service provider. Ethernet frames sent to the AC must also carry the P-tag.
·     Ethernet access mode—If Ethernet frames from the AC have a VLAN tag in the header, the PE considers it as a U-tag and ignores it. Ethernet frames sent to the AC do not carry the P-tag.
The Ethernet service instance specified in this command must have match criteria configured by encapsulation.
The switch does not support binding a Layer 3 interface to a VSI.
# Configure Ethernet service instance 200 on GigabitEthernet 1/0/1 to match packets with outer VLAN tag 200, and bind the Ethernet service instance to VSI vpn1.
[Sysname] vsi vpn1
[Sysname-vsi-vpn1] quit
[Sysname-GigabitEthernet1/0/1] service-instance 200
[Sysname-GigabitEthernet1/0/1-srv200] encapsulation s-vid 200
[Sysname-GigabitEthernet1/0/1-srv200] xconnect vsi vpn1
·     display l2vpn interface
·     display l2vpn service-instance
·     encapsulation
·     vsi
