06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS10500 SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release7178-6W10006-Layer 3 - IP Routing Command Reference
12-IPv6 policy-based routing commands
12-IPv6 policy-based routing commands 60.75 KB
apply next-hop
Use apply next-hop to set a next hop.
Use undo apply next-hop to remove the configuration.
apply next-hop [ vpn-instance vpn-instance-name ] { ipv6-address [ direct ] [ track track-entry-number ] } &<1-2>
undo apply next-hop [ [ vpn-instance vpn-instance-name ] ipv6-address&<1-2> ]
No next hop is set.
IPv6 policy node view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist.
ipv6-address: Specifies the IPv6 address of the next hop. If you do not specify the vpn-instance vpn-instance-name option, the next hop belongs to the public network.
direct: Specifies that the next hop must be directly connected to take effect.
track track-entry-number: Specifies a track entry by its number in the range of 1 to 1024.
&<1-2>: Indicates that the argument before it can be entered twice at most.
You can specify two next hops for backup by executing this command twice.
With a next hop specified, the undo apply next-hop command removes the next hop.
Without any next hop specified, the undo apply next-hop command removes all next hops.
# Set a directly-connected next hop of 1::1.
[Sysname] ipv6 policy-based-route aa permit node 11
[Sysname-pbr6-aa-11] apply next-hop 1::1
display ipv6 policy-based-route
Use display ipv6 policy-based-route to display IPv6 PBR policy information.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters.
If no policy is specified, this command displays information about all policies. If a policy name is specified, this command displays information about the specified policy.
# Display all IPv6 policy information.
<Sysname> display ipv6 policy-based-route
Policy name: aaa
  node 1 permit:
    if-match acl 2000
    apply next-hop 1000::1
node 1 permit
The match mode of Node 1 is permit.
if-match acl
Compares IPv6 packets with IPv6 ACL.
apply next-hop
Specifies a next hop for permitted IPv6 packets.
ipv6 policy-based-route (system view)
display ipv6 policy-based-route interface
Use display ipv6 policy-based-route interface to display IPv6 interface PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route interface interface-type interface-number [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route interface interface-type interface-number [ chassis chassis-number slot slot-number ]
slot slot-number: Displays the IPv6 PBR configuration and statistics on a card. The slot-number argument represents the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the IPv6 PBR configuration and statistics for a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. (In IRF mode.)
# Display IPv6 PBR configuration and statistics on GigabitEthernet 1/0/1.
<Sysname> display ipv6 policy-based-route interface gigabitethernet 1/0/1
Policy based routing information for interface GigabitEthernet1/0/1(failed):
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0
Total matched: 0
Policy based routing information for interface GigabitEthernet1/0/1:
Policy name: aaa
  node 0 deny(not support):
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 5 permit:
    if-match acl 3101
  Matched: 0 (no statistics resource)
Total matched: 0
failed indicates the policy (including all its nodes) failed to be assigned to the driver.
For a global interface (with only one-dimensional interface number, for example, VLAN-interface 10), failed can be displayed only when you specify the slot slot-number or chassis chassis-number slot slot-number option for the command.
node 2 permit(no resource)
Match mode of the node, permit or deny.
not support means the device does not support the match criteria configured on the node. no resource means the device has insufficient ACL resources, and failed to assign ACL resources to the node.
For a global interface (with only one-dimensional interface number, for example, VLAN-interface 10), not support and no resource can be displayed only when you specify the slot slot-number or chassis chassis-number slot slot-number option for the command.
if-match acl
Compares IPv6 packets with the IPv6 ACL.
apply next-hop
Number of successful matches on the node (no statistics resource indicates insufficient statistics resources).
For a global interface (with only one-dimensional interface number, for example, VLAN-interface 10), no statistics resource can be displayed only when you specify the slot slot-number or chassis chassis-number slot slot-number option for the command.
Total matched
Total number of successful matches on all nodes.
reset ipv6 policy-based-route statistics
display ipv6 policy-based-route local
Use display ipv6 policy-based-route local to display IPv6 local PBR configuration and statistics.
In standalone mode:
display ipv6 policy-based-route local [ slot slot-number ]
In IRF mode:
display ipv6 policy-based-route local [ chassis chassis-number slot slot-number ]
# Display IPv6 local PBR configuration and statistics.
<Sysname> display ipv6 policy-based-route local
Policy based routing information for local:
Policy name: aaa
  node 0 deny:
  Matched: 0
  node 1 permit:
    if-match acl 3999
  Matched: 0
  node 2 permit:
    if-match acl 2000
    apply next-hop 1::1
  Matched: 0
  node 5 permit:
    if-match acl 3101
    apply next-hop 2::2
  Matched: 0
Total matched: 0
node 0 deny/node 2 permit
if-match acl
Compares packets with the ACL.
apply next-hop
Specifies a next hop for permitted packets.
Matched: 0
Number of successful matches on the node.
Total matched
display ipv6 policy-based-route setup
Use display ipv6 policy-based-route setup to display IPv6 PBR configuration.
# Display IPv6 PBR configuration.
<Sysname> display ipv6 policy-based-route setup
Policy Name              Interface Name
pr01                     GigabitEthernet 1/0/1
policy Name
Policy name.
Interface Name
Interface where the policy is applied.
ipv6 policy-based-route (interface view)
if-match acl
Use if-match acl to set an ACL match criterion.
Use undo if-match acl to remove the ACL match criterion.
if-match acl { acl6-number | name acl6-name }
undo if-match acl
No ACL match criterion is set.
acl6-number: Specifies an ACL by its number in the range of 2000 to 3999. The value range of a basic ACL is 2000 to 2999 and that of an advanced ACL is 3000 to 3999.
name acl6-name: Specifies an ACL by its name, a case-insensitive string of 1 to 63 characters starting with letter a to z or A to Z. The ACL name cannot be all.
# Configure Node 10 of policy aa to permit the packets matching ACL 2000.
[Sysname] ipv6 policy-based-route aa permit node 10
[Sysname-pbr6-aa-10] if-match acl 2000
# Configure Node 10 of policy aa to permit the packets matching ACL aaa.
[Sysname-pbr6-aa-10] if-match acl name aaa
ipv6 local policy-based-route
Use ipv6 local policy-based-route to configure IPv6 local PBR based on a specified policy.
Use undo ipv6 local policy-based-route to remove the configuration.
No policy is referenced for IPv6 local PBR.
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified IPv6 policy must already exist.
You can apply only one policy locally. Before you apply a new policy, you must first remove the current policy.
IPv6 local PBR is used to route locally generated packets. This feature might affect local services, such as ping and Telnet. Do not configure IPv6 local PBR unless doing so is required.
# Configure IPv6 local PBR based on policy aaa.
[Sysname] ipv6 local policy-based-route aaa
·     display ipv6 policy-based-route setup
·     ipv6 policy-based-route (system view)
Use ipv6 policy-based-route to configure IPv6 interface PBR by applying an IPv6 policy to an interface.
Use undo ipv6 policy-based-route to remove the configuration.
ipv6 policy-based-route policy-name
No IPv6 is applied to an interface.
Interface view
policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. The specified policy must already exist.
You can apply only one policy to an interface. Before you apply a new policy, remove the current policy from the interface.
# Apply policy aaa to VLAN-interface 2.
[Sysname] vlan 2
[Sysname-Vlan2] interface vlan-interface 2
[Sysname-Vlan-interface2] ipv6 policy-based-route aaa
Use ipv6 policy-based-route to create an IPv6 policy or policy node and enter IPv6 policy node view. If the specified IPv6 policy node already exists, the command directly places you into IPv6 policy node view.
Use undo ipv6 policy-based-route to remove an IPv6 policy or IPv6 policy node.
undo ipv6 policy-based-route policy-name [ deny | node node-number | permit ]
No IPv6 policy node is created.
policy-name: Specifies a policy name, a case-sensitive string of 1 to 19 characters.
deny: Specifies the match mode for the policy node as deny.
permit: Specifies the match mode for the policy node as permit (default mode).
node node-number: Specifies the number of the IPv6 policy node, in the range of 0 to 255. A smaller number has a higher priority.
To remove an IPv6 policy that has already applied to an interface, you must remove the policy from the interface first.
If a policy node is specified, the undo ipv6 policy-based-route command removes the specified policy node. If a match mode is specified, the command removes all nodes configured with the match mode. If no node is specified, the command removes the whole policy.
# Create permit-mode Node 10 for IPv6 policy aaa and enter IPv6 policy node view.
[Sysname] ipv6 policy-based-route aaa permit node 10
[Sysname-pbr6-aaa-10]
Use reset ipv6 policy-based-route statistics to clear IPv6 PBR statistics.
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters. If you do not specify a policy, this command clears IPv6 PBR statistics for all policies.
# Clear all IPv6 PBR statistics.
<Sysname> reset ipv6 policy-based-route statistics
·     display ipv6 policy-based-route interface
·     display ipv6 policy-based-route local
