06-Layer 3 - IP Routing Command Reference
HomeSupportSwitchesS10500 SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release7178-6W10006-Layer 3 - IP Routing Command Reference
10-OSPFv3 commands
10-OSPFv3 commands 309.63 KB
OSPFv3 commands· 1
abr-summary (OSPFv3 area view) 1
area· 1
asbr-summary· 2
bandwidth-reference· 3
default tag· 4
default-cost (OSPFv3 area view) 4
default-route-advertise (OSPFv3 view) 5
display ospfv3· 6
display ospfv3 abr-asbr 12
display ospfv3 abr-summary· 13
display ospfv3 asbr-summary· 15
display ospfv3 graceful-restart 17
display ospfv3 interface· 22
display ospfv3 lsdb· 23
display ospfv3 nexthop· 28
display ospfv3 non-stop-routing· 29
display ospfv3 peer 30
display ospfv3 request-queue· 33
display ospfv3 retrans-queue· 34
display ospfv3 routing· 35
display ospfv3 spf-tree· 37
display ospfv3 statistics· 40
display ospfv3 vlink· 43
enable ipsec-profile· 44
filter (OSPFv3 area view) 45
filter-policy export (OSPFv3 view) 46
filter-policy import (OSPFv3 view) 47
graceful-restart enable· 48
graceful-restart helper enable· 49
graceful-restart helper strict-lsa-checking· 50
graceful-restart interval 51
import-route (OSPFv3 view) 51
log-peer-change· 53
lsa-generation-interval 53
maximum load-balancing (OSPFv3 view) 54
non-stop-routing· 55
nssa· 55
ospfv3· 57
ospfv3 area· 57
ospfv3 authentication-mode· 58
ospfv3 bfd enable· 59
ospfv3 cost 60
ospfv3 dr-priority· 60
ospfv3 ipsec-profile· 61
ospfv3 mib-binding· 62
ospfv3 mtu-ignore· 62
ospfv3 network-type· 63
ospfv3 peer 64
ospfv3 prefix-suppression· 64
ospfv3 timer dead· 65
ospfv3 timer hello· 66
ospfv3 timer poll 67
ospfv3 timer retransmit 67
ospfv3 trans-delay· 68
preference· 69
prefix-suppression· 69
reset ospfv3 process· 70
reset ospfv3 redistribution· 71
reset ospfv3 statistics· 71
router-id· 72
silent-interface(OSPFv3 view) 72
snmp-agent trap enable ospfv3· 73
snmp context-name· 74
snmp trap rate-limit 75
spf-schedule-interval 75
stub (OSPFv3 area view) 76
stub-router 77
transmit-pacing· 78
vlink-peer (OSPFv3 area view) 79
OSPFv3 commands
Use abr-summary to configure route summarization on an ABR.
Use undo abr-summary to remove the configuration.
abr-summary ipv6-address prefix-length [ not-advertise ] [ cost value ]
undo abr-summary ipv6-address prefix-length
Route summarization is not configured on an ABR.
OSPFv3 area view
ipv6-address: Specifies the destination IPv6 address of the summary route.
prefix-length: Specifies the prefix length of the destination IPv6 address, in the range of 0 to 128. This argument specifies the number of consecutive 1s of the prefix, which defines the network ID.
not-advertise: Specifies not to advertise the summary IPv6 route. If you do not specify this keyword, the command advertises the IPv6 summary route.
cost value: Specifies the cost of the summary route, in the range of 1 to 16777215. The default cost is the largest cost value among routes that are summarized.
This command applies only to an ABR to summarize multiple contiguous networks into one network.
To enable ABR to advertise specific routes that have been summarized, use the undo abr-summary command.
# Summarize networks 2000:1:1:1::/64 and 2000:1:1:2::/64 in Area 1 into 2000:1:1::/48.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 1
[Sysname-ospfv3-1-area-0.0.0.1] abr-summary 2000:1:1:: 48
area
Use area to create an OSPFv3 area and enter OSPFv3 area view.
Use undo area to remove an OSPFv3 area.
area area-id
undo area area-id
No OSPFv3 area is created.
OSPFv3 view
area-id: Specifies an area by its ID, an IPv4 address or a decimal integer in the range of 0 to 4294967295 that is translated into the IPv4 address format.
# Create OSPFv3 Area 0 and enter its view.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 0
[Sysname-ospfv3-1-area-0.0.0.0]
asbr-summary
Use asbr-summary to configure route summarization on an ASBR.
Use undo asbr-summary to remove the configuration.
asbr-summary ipv6-address prefix-length [ cost cost | not-advertise | nssa-only | tag tag ] *
undo asbr-summary ipv6-address prefix-length
Route summarization is not configured on an ASBR.
OSPFv3 view
prefix-length: Specifies the prefix length in the range of 0 to 128.
cost cost: Specifies the cost of the summary route, in the range of 1 to 16777214. If you do not specify this option, the summary route uses the largest cost among the summarized routes. If the summarized routes are Type-2 external routes described in Type-5 LSAs translated from Type-7 LSAs, the summary route uses the largest cost among the summarized routes plus 1.
not-advertise: Disables advertising the summary route. If you do not specify this keyword, the command advertises the route.
nssa-only: Limits the route advertisement to the NSSA area by setting the P-bit of Type-7 LSAs to 0. By default, the P-bit of Type-7 LSAs is set to 1. If the ASBR is also an ABR and FULL state neighbors exist in the backbone area, the P-bit of Type-7 LSAs originated by the ASBR is set to 0. This keyword applies to the NSSA ASBR.
tag tag: Specifies a tag for the summary route, in the range of 0 to 4294967295.
An ASBR can summarize routes in the following LSAs:
·     Type-5 LSAs.
·     Type-7 LSAs in an NSSA area.
·     Type-5 LSAs translated by the ASBR (also an ABR) from Type-7 LSAs in an NSSA area.
If the ASBR (ABR) is not a translator, it cannot summarize routes in Type-5 LSAs translated from Type-7 LSAs.
To enable ASBR to advertise specific routes that have been summarized, use the undo asbr-summary command.
# Configure a summary route 2000::/16, and specify a cost of 100 and a tag value of 2 for the summary route.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] asbr-summary 2000:: 16 cost 100 tag 2
bandwidth-reference
Use bandwidth-reference to set a reference bandwidth value for link cost calculation.
Use undo bandwidth-reference to restore the default.
bandwidth-reference value
The default value is 100 Mbps.
OSPFv3 view
value: Specifies the bandwidth reference value for link cost calculation, in the range of 1 to 4294967 Mbps.
You can configure an OSPFv3 cost for an interface with one of the following methods:
·     Configure the cost value in interface view.
·     Configure a bandwidth reference value. OSPFv3 computes the cost automatically based on the bandwidth reference value by using the following formula: Interface OSPFv3 cost = Bandwidth reference value / Interface bandwidth.
¡     If the calculated cost is greater than 65535, the value of 65535 is used.
¡     If the calculated cost is smaller than 1, the value of 1 is used.
If no cost value is configured for an interface, OSPFv3 computes the interface cost value automatically.
# Set the reference bandwidth value to 1000 Mbps.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] bandwidth-reference 1000
default tag
Use default tag to set a tag for redistributed routes.
Use undo default tag to restore the default.
default tag tag
undo default tag
The tag of redistributed routes is 1.
OSPFv3 view
tag: Specifies a tag for redistributed routes, in the range of 0 to 4294967295.
If you do not specify a tag for redistributed routes by using the default-route-advertise, import-route, or route-tag command, the tag specified by the default tag command applies.
# Set the tag for redistributed routes to 2.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] default tag 2
·     default-route-advertise (OSPFv3 view)
·     import-route
·     route-tag (MPLS Command Reference)
Use default-cost to set a cost for the default route advertised to the stub area or NSSA area.
Use undo default-cost to restore the default.
default-cost cost
undo default-cost
The cost is 1.
OSPFv3 area view
value: Specifies a cost for the default route advertised to the stub area or NSSA area, in the range of 0 to 16777214.
This command takes effect only on the ABR of a stub area or the ABR/ASBR of an NSSA area.
# Configure Area 1 as a stub area, and set the cost of the default route advertised to the stub area to 60.
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] stub
[Sysname-ospfv3-1-area-0.0.0.1] default-cost 60
·     nssa (OSPFv3 area view)
·     stub (OSPFv3 area view)
Use default-route-advertise to redistribute a default route into the OSPFv3 routing domain.
Use undo default-route-advertise to restore the default.
default-route-advertise [ [ always | permit-calculate-other ] | cost cost | route-policy route-policy-name | tag tag | type type ] *
No default route is redistributed into the OSPFv3 routing domain.
OSPFv3 view
always: Redistributes a default route in an AS-external-LSA into the OSPFv3 routing domain regardless of whether a default route exists in the routing table. If you do not specify this keyword, the router redistributes a default route in an AS-external-LSA into the OSPFv3 routing domain only when the default route exists in the routing table.
permit-calculate-other: Enables OSPFv3 to calculate default routes received from other routers. If you do not specify this keyword, OSPFv3 does not calculate default routes from other routers. If the router does not redistribute any default route in an AS-external-LSA into the OSPFv3 routing domain, the router calculates default routes from other routers. It calculates these routes regardless of whether this keyword is specified.
cost cost: Specifies a cost for the default route, in the range of 0 to 16777214. The default is 1.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. When the routing policy is matched and one of the following conditions is met, the command redistributes a default route in an AS-external-LSA into the OSPFv3 routing domain:
·     A default route exists in the routing table.
·     The always keyword is specified.
The routing policy modifies values in the AS-external-LSA.
tag tag: Specifies a tag for the default route, in the range of 0 to 4294967295.
type type: Specifies a type for the AS-external-LSA, 1 or 2. The default is 2. If you do not specify this option, the tag specified by the default tag command applies.
This command redistributes a default route in an AS-external-LSA, which cannot be redistributed with the import-route command. If the local routing table has no default route, you must provide the always keyword for the command.
# Redistribute a default route into the OSPFv3 routing domain. (The default route does not exist in the local router.)
[Sysname] ospfv3 1
[Sysname-ospfv3-1] default-route-advertise always
display ospfv3
Use display ospfv3 to display OSPFv3 process information.
display ospfv3 [ process-id ] [ verbose ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all OSPFv3 processes.
verbose: Displays detailed OSPFv3 process information. If you do not specify this keyword, the command displays brief OSPFv3 process information.
# Display detailed information about all OSPFv3 processes.
<Sysname> display ospfv3 verbose
               OSPFv3 Process 1 with Router ID 1.1.1.1
 RouterID: 1.1.1.1          Router type:  ABR  ASBR  NSSA
 Route tag: 0
 Route tag check: Disabled
 Multi-VPN-Instance: Disabled
 Type value of extended community attributes:
    Domain ID : 0x0005
    Route type: 0x0306
    Router ID : 0x0107
 Domain-id: 0.0.0.0
 DN-bit check: Enabled
 DN-bit set: Enabled
 SPF-schedule-interval: 5 50 200
 LSA generation interval: 5
 LSA arrival interval: 1000
 Default ASE parameters: Tag: 1
 Route preference: 10
 ASE route preference: 150
 SPF calculation count: 0
 External LSA count: 0
 LSA originated count: 0
 LSA received count: 0
 SNMP trap rate limit interval: 10  Count: 7
 Area count: 2  Stub area Count: 0  NSSA area Count: 1
 ExChange/Loading neighbors: 0
 Max equal cost paths: 32
 Up interfaces: 1
 Full neighbors: 1
 Normal areas with up interfaces: 1
 Calculation trigger type: Full
 Current calculation type: SPF calculation
 Current calculation phase: Calculation area topology
 Redistribute timer: Off
 Redistribute schedule type: RIB
 Redistribute route count: 0
 Process reset state: N/A
 Current reset type: N/A
 Next reset type: N/A
 Reset prepare message replied: -/-/-/-
 Reset process message replied: -/-/-/-
 Reset phase of module:
   M-N/A, P-N/A, S-N/A, C-N/A, R-N/A
 Area: 0.0.0.0
 Area flag: Normal
 SPF scheduled count: 0
 LSA count: 0
 IPsec profile name: Profile000
 Up interfaces: 0
 MTU: 1440
 Default cost: 1
 Created by Vlink
 Area: 0.0.0.2
 Area flag: Normal
 LSA count: 0
 Up interfaces: 1
 MTU: 1500
 Default cost: 1
 Area: 0.0.0.3
 Area flag: NSSA
 SPF Scheduled Count: 0
 LSA Count: 0
 Up interfaces: 0
 MTU: 1440
 Default cost: 1
 Process reset flag: N/A
OSPFv3 process is 1, and router ID is 1.1.1.1.
Router type
Router type:
·     ABR.
·     ASBR.
·     NSSA.
·     Null.
Route tag
Tag of the routes redistributed into the OSPFv3 process.
Route tag check
Whether the check is enabled for the route tag in OSPFv3 LSAs of the OSPFv3 process.
Multi-VPN-Instance
Whether the OSPFv3 process supports PE or multiple VPN instances:
·     Multi-VPN-Instance: Disabled—The process does not support multiple VPN instances.
·     Multi-VPN-Instance: Enabled—The process supports multiple VPN instances.
·     PE Router, Multi-VPN-Instance: Enabled—The local device is a PE.
DN-bit check
Whether the check is enabled for the DN bit in OSPFv3 LSAs of the OSPFv3 process.
DN-bit set
Whether the DN bit is set for OSPFv3 LSAs in the OSPFv3 process.
Condition
Time when the router acts as a stub router:
·     Always.
·     On startup while BGP is converging for xxx seconds, where xxx is specified by the user.
·     On startup for xxx seconds, where xxx is specified by the user.
State of the stub router:
·     Active.
·     Inactive.
Interval for SPF calculations.
Transmit pacing
LSU advertisement rate:
·     Interval—Specifies the interval for sending LSUs.
·     Count—Specifies the maximum number of LSUs sent at each interval.
Default parameters of redistributed routes. Tag represents the route tag of the redistributed routes.
Route preference
Internal route preference.
AS-external route preference.
Number of originated LSAs.
LSA received count
Number of received LSAs.
Area count
Total number of areas.
Stub area Count
Number of stub areas.
NSSA area Count
Number of NSSA areas.
Neighbors in ExChange/Loading state.
Route calculation trigger type:
·     Full—Calculation of all routes is triggered.
·     Area topology change—Topology change in an area.
·     Intra router change—Incremental intra-area route change.
·     ASBR change—Incremental ASBR route change.
·     Full IP prefix—Calculation of all IP prefixes is triggered.
·     Full intra AS—Calculation of all intra-AS prefixes is triggered.
·     Inc intra AS—Calculation of incremental intra-AS prefixes is triggered.
·     Full inter AS—Calculation of all AS-external prefixes is triggered.
·     Inc inter AS—Calculation of incremental AS-external prefixes is triggered.
·     Nexthop calculation—Calculation of next hops is triggered.
·     N/A—Route calculation is not triggered.
Current route calculation type:
·     SPF calculation.
·     Intra router calculation—Intra-area route calculation.
·     ASBR calculation—Inter-area ASBR route calculation.
·     Inc intra router—Incremental intra-area route calculation.
·     Inc ASBR calculation—Incremental inter-area ASBR route calculation.
·     Full intra AS—Calculation of all intra-AS prefixes.
·     Inc intra AS—Calculation of incremental intra-AS prefixes.
·     Full inter AS—Calculation of all AS-external prefixes.
·     Inc inter AS—Calculation of incremental AS-external prefixes.
Current route calculation phase:
·     Calculation area topology—Calculating area topology.
·     Calculation router—Calculating routes on routers.
·     Calculation intra AS—Calculating intra-AS routes.
·     Calculation ASBR—Calculating routes on ASBRs.
·     Calculation inter AS—Calculating AS-external routes.
·     Calculation end—Ending phase of calculation.
Redistribute timer
Route redistribution timer status: on or off.
Route redistribution scheduling type:
·     RIB—Redistribute routes through the RIB table.
·     Self—Redistribute routes through the routing table.
·     N/A—Route redistribution is not triggered.
Number of redistributed routes.
Process reset state
·     N/A—The process is not reset.
·     Under reset—The process is in the reset progress.
·     Under RIB smooth—The process is synchronizing RIB routes.
Current reset type
Current process reset type:
·     GR quit—Normal reset when GR quits abnormally.
·     Delete—Delete OSPFv3 process.
·     Undo router-id—Delete router ID.
·     Set router-id—Set router ID.
Next reset type
Next process reset type:
Modules that reply reset prepare messages:
·     P—Neighbor maintenance module.
·     S—LSDB synchronization module.
·     C—Route calculation module.
·     R—Route redistribution module.
Modules that reply reset process messages:
Reset phase of each module:
·     LSDB synchronization (S) module:
¡     N/A—Not reset.
¡     Delete ASE—Delete all ASE LSAs.
¡     Delete area LSA—Delete LSAs from an area.
¡     Delete area IF—Delete interfaces from an area.
·     Route calculation (C) module:
¡     N/A—Not reset.
¡     Delete topology—Delete area topology.
¡     Delete router—Delete routes of routers.
¡     Delete intra AS—Delete intra-AS routes
¡     Delete inter AS—Delete AS-external routes.
¡     Delete ASBR—Delete ASBR routes.
·     Route redistribution (R) module:
¡     N/A—Not reset.
¡     Delete import—Delete redistributed routes.
IPsec profile name
IPsec profile applied to the interface.
Created by Vlink
The area is created through virtual link.
State of the translator that translates Type-7 LSAs to Type-5 LSAs:
·     Enabled—The translator is specified through commands.
·     Elected—The translator is designated through election.
·     Disabled—The device is not a translator.
Stability interval (in seconds) for Type-7 LSA-to-Type-5 LSA translation.
Use display ospfv3 abr-asbr to display information about the routes to OSPFv3 ABR and ASBR.
display ospfv3 [ process-id ] abr-asbr
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about all the routes to the OSPFv3 ABR and ASBR.
# Display information about all the routes to the OSPFv3 ABR and ASBR.
<Sysname> display ospfv3 abr-asbr
 Destination :1.1.1.2                                   Rtr Type : ABR
 Area        :0.0.0.0                                   Path Type: Intra
 NextHop     :FE80:1:1::1                               Cost     : 1
 Destination :1.1.1.3                                   Rtr Type : ASBR
 NextHop     :FE80:2:1::1                               Cost     : 1
Destination
Router ID of an ABR or ASBR.
Rtr Type
Router type: ABR, or ASBR.
Area
Area ID of the next hop.
Path Type
Type of the route to the ABR or ASBR:
·     Intra—Intra-area route.
·     Inter—Inter-area route.
NextHop
Next hop address.
Cost
Cost from the router to the ABR or ASBR.
Use display ospfv3 abr-summary to display ABR summary route information.
display ospfv3 [ process-id ] [ area area-id ] abr-summary [ ipv6-address prefix-length ] [ verbose ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about ABR summary routes for all OSPFv3 processes.
area area-id: Specifies an OSPFv3 area by its ID. The area ID is an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format. If you do not specify this option, the command displays information about ABR summary routes for all OSPFv3 areas.
ipv6-address prefix-length: Specifies an IPv6 address. The ipv6-address argument specifies an IPv6 prefix. The prefix-length argument specifies a prefix length in the range of 0 to 128. If you do not specify this argument, the command displays information about all summary routes on the ABR.
verbose: Displays detailed ABR summary route information. If you do not specify this keyword, the command displays brief ABR summary route information.
# Display brief ABR summary route information in OSPFv3 process 1.
<Sysname> display ospfv3 1 abr-summary
             OSPFv3 Process 1 with Router ID 2.2.2.2
                     Area: 1.1.1.1
 Total summary addresses: 1
 Prefix      : 1000:4::/32
 Status      : Advertise
 NULL0       : Active
 Cost        : 1 (Configured)
 Routes count: 2
Area
Area to which the summary routes belong.
Total number of summary routes.
Prefix
Prefix of the summary route.
Status
Advertisement status of the summary route.
NULL0
Null 0 route.
Cost
Cost of the summary route.
Routes count
Number of summarized routes.
# Display detailed ABR summary route information in OSPFv3 process 1.
<Sysname> display ospfv3 1 abr-summary verbose
                        Area: 1.1.1.1
 Status      : Advertise
 NULL0       : Active
 Routes count: 2
   Destination                                        Metric
   1000:4:10:3::/96                                   1
   1000:4:11:3::/96                                   1
Destination
Destination address of a summarized route.
Metric
Metric of a summarized route.
Use display ospfv3 asbr-summary to display ASBR summary route information.
display ospfv3 [ process-id ] asbr-summary [ ipv6-address prefix-length ] [ verbose ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays information about ASBR summary routes for all OSPFv3 processes.
ipv6-address prefix-length: Specifies an IPv6 address. The ipv6-address argument specifies an IPv6 prefix. The prefix-length argument specifies a prefix length in the range of 0 to 128. If you do not specify this argument, the command displays information about all ASBR summary routes.
verbose: Displays detailed ASBR summary route information. If you do not specify this keyword, the command displays brief ASBR summary route information.
# Display brief ASBR summary route information in OSPFv3 process 1.
<Sysname> display ospfv3 1 asbr-summary
 Status      : Advertise
 NULL0       : Active
 Tag         : (Not configured)
 Nssa-only   : (Not configured)
 Routes count: 2
Table 5 Command output
Prefix
Prefix and prefix length of the summary route.
Status
Advertisement status of the summary route:
·     Advertise—The summary route has been advertised.
·     Not-advertise—The summary route has not been advertised.
NULL0
Status of the Null 0 route:
·     Active.
·     Inactive.
Cost
Cost of the summary route:
·     Configured.
·     Not configured.
Tag
Tag of the summary route:
·     Configured.
·     Not configured.
Nssa-only
Whether the nssa-only attribute is configured:
·     Configured.
·     Not configured.
Routes count
# Display detailed ASBR summary route information in OSPFv3 process 1.
<Sysname> display ospfv3 1 asbr-summary verbose
 Status      : Advertise
 NULL0       : Active
 Routes count: 2
  Destination                                 Protocol Process Type Metric
  1000:4:10:3::/96                            Static   0       2    1
  1000:4:11:3::/96                            Static   0       2    1
Table 6 Command output
Destination
Prefix and prefix length of the summarized route.
Protocol
Routing protocol from which the route was redistributed.
Process
Process of the routing protocol from which the route was redistributed.
Type of the summarized route.
Metric
Metric of the summarized route.
Use display ospfv3 graceful-restart to display GR information.
display ospfv3 [ process-id ] graceful-restart [ verbose ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays GR information for all processes.
verbose: Displays detailed GR information. If you do not specify this keyword, the command displays brief GR information.
# Display brief GR information for all OSPFv3 processes (GR restarter).
<Sysname> display ospfv3 graceful-restart
               OSPFv3 Process 1 with Router ID 3.3.3.3
 Graceful-restart capability     : Enable
 Graceful-restart support        : Planned and un-planned, Partial
 Helper capability               : Enable
 Helper support                  : Planned and un-planned
 Current GR state                : Normal
 Graceful-restart period         : 120 seconds
 Number of neighbors under helper: 0
 Number of restarting neighbors  : 0
 Last exit reason:
   Restarter: None
   Helper   : None
Table 7 Command output
The GR status of OSPFv3 process 1 with router ID 3.3.3.3 is displayed.
Whether OSPFv3 GR is enabled:
·     Enabled.
·     Disabled.
GR modes that the process supports (displayed only when GR is enabled):
·     Planned and un-planned—Supports both planned and unplanned GR.
·     Planned only—Supports only planned GR.
·     Partial—Supports partial GR.
·     Global—Supports global GR.
Helper capability
Whether OSPFv3 GR helper is enabled:
·     Enabled.
·     Disabled.
Helper support
Policies and GR modes that the GR helper supports (displayed only when GR helper is enabled):
·     Strict LSA check—The GR helper supports strict LSA checking.
·     Planned and un-planned—The GR helper supports both planned and unplanned GR.
·     Planned only—The GR helper supports only planned GR.
Current GR state
GR status:
·     Normal—GR is not in progress or has completed.
·     Under GR—GR is in progress.
·     Under Helper—The process is acting as GR helper.
GR restart interval.
Number of neighbors in GR helper status.
Number of neighbors in GR restarter status.
Last exit reason
Last exit reason:
·     Restarter—Reason that the restarter exited most recently:
¡     None.
¡     Completed—GR is completed.
¡     Interval timer is fired—The GR timer expires.
¡     Interface state change—An interface state change occurs.
¡     Received 1-way hello—The device receives 1-way hello packets from the neighbor.
¡     Reset neighbor—The neighbor is reset.
¡     DR or BDR change—The DR or BDR changes.
·     Helper—Reason that the helper exited most recently:
¡     None.
¡     Grace Period timer is fired—The GR timer expires.
¡     Lsa check failed—An LSA change on the GR helper is detected.
¡     Received MAXAGE gracelsa but neighbor is not full—The device receives Grace-LSAs that reached the maximum age, but the neighbor is not in Full state.
# Display detailed GR information for all OSPFv3 processes (GR restarter).
<Sysname> display ospfv3 graceful-restart verbose
 Last exit reason:
   Restarter: None
   Helper   : None
 Area: 0.0.0.0
 Area flag: Normal
 Area up interface count: 1
 Virtual-link Neighbor-ID: 100.1.1.1, Neighbor-state: Full
 Restarter state: Normal   State: P-2-P    Type: Virtual
 Interface: 6696 (Vlan-interface200), Instance-ID: 0
 Local  IPv6 address: 200:1:FFFF::1
 Remote IPv6 address: 201:FFFF::2
 Transit area: 0.0.0.1
 Last exit reason:
   Restarter: None
   Helper   : None
 Neighbor       GR state       Last helper exit reason
 100.1.1.1      Normal         None
 Area: 0.0.0.1
 Area flag: Transit
 Area up interface count: 3
 Interface: 5506 (Vlan-interface3), Instance-ID: 0
 Restarter state: Normal   State: DR       Type: Broadcast
 Last exit reason:
   Restarter: None
   Helper   : None
 Neighbor count of this interface: 0
 Last exit reason:
   Restarter: None
   Helper   : None
 Neighbor count of this interface: 1
 Sham-link Neighbor-ID: 100.1.1.1, Neighbor-state: Full
 Restarter state: Normal   State: P-2-P    Type: Sham
 Interface-ID: 2147483649, Instance-ID: 0
 Source      : 8000:88::FFFF
 Destination : 7000:77::FFFF
 Last exit reason:
   Restarter: None
   Helper   : None
 Area: 0.0.0.5
 Area flag: NSSANoSummaryNoImportRoute
 Area up interface count: 0
Table 8 Command output
Area
Area ID.
Area flag
Type of the area:
·     Normal.
·     Transit.
·     Stub.
·     StubNoSummary—Totally stub area.
·     NSSA.
·     NSSANoSummary—Totally NSSA area.
·     NSSANoSummaryNoImportRoute—Totally NSSA area with the no-import-route keyword configured.
Number of up interfaces in the area.
Interface in the area, or the output interface of the virtual link.
Restarter state
Restarter state on the interface.
Interface state.
Interface network type.
Number of neighbors on the interface.
Neighbor
Neighbor router ID.
GR state
Neighbor GR state:
·     Under GR—GR is in process.
Reason that the helper exited most recently.
Router ID of the virtual link's neighbor.
Neighbor-State
Neighbor or virtual link state: Down, Init, 2-Way, ExStart, Exchange, Loading, and Full.
Local IPv6 address
Local IPv6 address of the neighbor relationship.
Remote IPv6 address
Peer IPv6 address of the neighbor relationship.
Transit area
Transit area ID.
Router ID of the sham link's neighbor.
Source
Source address of the sham link.
Destination
Destination address of the sham link.
Use display ospfv3 interface to display OSPFv3 interface information.
display ospfv3 [ process-id ] interface [ interface-type interface-number | verbose ]
verbose: Displays detailed information about all OSPFv3 interfaces.
If you do not specify a process, this command displays brief OSPFv3 interface information for all processes.
If you do not specify the interface-type interface-number argument or the verbose keyword, this command displays brief information about all OSPFv3 interfaces.
# Display OSPFv3 information about VLAN-interface 1.
<Sysname> display ospfv3 interface vlan-interface 1
 Area: 0.0.0.0
 Vlan-interface1 is up, line protocol is up
  Interface ID 65697        Instance ID 0
  IPv6 prefixes
    fe80::200:12ff:fe34:1  (Link-Local address)
    2001::1
  Cost: 1       State: BDR       Type: Broadcast    MTU: 1500
  Priority: 1
  Designated router: 2.2.2.2
  Backup designated router: 1.1.1.1
  Timers: Hello 10, Dead 40, Poll 40, Retransmit 5, Transmit delay 1
  Neighbor count is 1, Adjacent neighbor count is 1
  Keychain authentication: Enabled (test)
  Exchanging/Loading neighbors: 0
  Wait timer: Off,  LsAck timer: Off
  Prefix-suppression is enabled
Table 9 Command output
Area
Area ID that the interface belongs to.
Interface ID
Interface ID.
Instance ID
Instance ID.
IPv6 prefixes
IPv6 prefix.
Cost
Cost value of the interface.
Interface state:
·     DOWN—No protocol traffic can be sent or received on the interface.
·     Waiting—The interface starts sending and receiving Hello packets. The router is trying to determine the identity of the (Backup) designated router for the network.
·     P-2-P—The interface will send Hello packets at the interval of HelloInterval, and try to establish an adjacency with the neighbor.
·     DR—The router is the designated router on the network.
·     BDR—The router is the backup designated router on the network.
·     DROther—The router is a DR Other router on the attached network.
Network type of the interface: PTP (P2P), PTMP (P2MP), Broadcast, or NBMA.
MTU
MTU value of the interface.
Priority
DR priority of the interface.
Designated router
DR on this link.
BDR on this link.
Timer interval configured
Time intervals in seconds configured on the interface:
·     Hello—Hello interval.
·     Dead—Dead interval.
·     Poll—Polling interval on an NBMA network.
·     Retransmit—LSA retransmission interval.
·     Transmit delay—Transmission delay of the interface.
Neighbor count
Number of adjacencies on the interface.
IPsec profile name
Keychain authentication is enabled for the interface, and keychain test is used.
display ospfv3 lsdb
Use display ospfv3 lsdb to display the OSPFv3 LSDB.
display ospfv3 [ process-id ] lsdb [ { external | grace | inter-prefix | inter-router | intra-prefix | link | network | nssa | router | unknown [ type ] } [ link-state-id ] [ originate-router router-id | self-originate ] | statistics | total | verbose ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays LSDB information for all processes.
external: Displays AS external LSAs (Type-5 LSAs).
grace: Displays Grace-LSAs (Type-11 LSAs).
inter-prefix: Displays Inter-area-prefix LSAs (Type-3 LSAs).
inter-router: Displays Inter-area-router LSAs (Type-4 LSAs).
intra-prefix: Displays Intra-area-prefix LSAs (Type-9 LSAs).
link: Displays Link-LSAs (Type-8 LSAs).
network: Displays Network-LSAs (Type-2 LSAs).
nssa: Displays NSSA LSAs (Type-7 LSAs).
router: Displays Router-LSAs (Type-1 LSAs).
unknown: Displays unknown LSAs.
type: Specifies an LSA type, a hexadecimal string of 0 to FFFF. If you do not specify this argument, the command displays all unknown LSAs.
link-state-id: Specifies a link state ID in IPv4 address format.
originate-router router-id: Specifies an advertising router by its ID.
self-originate: Displays locally originated LSAs.
statistics: Displays LSA statistics.
total: Displays the total number of LSAs in the LSDB.
verbose: Displays detailed information. If you do not specify this keyword, the command displays brief information.
# Display OSPFv3 LSDB information.
<Sysname> display ospfv3 lsdb
                  Link-LSA (Interface GigabitEthernet1/0/1)
 Link State ID   Origin Router    Age   SeqNumber  Checksum  Prefix
 0.15.0.8        2.2.2.2          0691  0x80000041 0x8315      1
 0.0.0.3         1.1.1.1          0623  0x80000001 0x0fee      1
                  Router-LSA (Area 0.0.0.1)
 Link State ID   Origin Router    Age   SeqNumber  Checksum    Link
 0.0.0.0         1.1.1.1          0013  0x80000068 0x5d5f      2
 0.0.0.0         2.2.2.2          0024  0x800000ea 0x1e22      0
                  Network-LSA (Area 0.0.0.1)
 0.15.0.8        2.2.2.2          0019  0x80000007 0x599e
                  Intra-Area-Prefix-LSA (Area 0.0.0.1)
 Link State ID   Origin Router    Age   SeqNumber  Checksum  Prefix  Reference
 0.0.0.2         2.2.2.2          3600  0x80000002 0x2eed      2 Network-LSA
 0.0.0.1         2.2.2.2          0018  0x80000001 0x1478      1 Network-LSA
Table 10 Command output
Origin Router
Originating router.
Age
Age of LSAs.
SeqNumber
LSA sequence number.
Checksum
LSA checksum.
Prefix
Number of prefixes.
Link
Number of links.
Type-9 LSA.
Reference
Type of referenced LSA.
# Display Link LSA information in the LSDB.
<Sysname> display ospfv3 lsdb link
  LS age            : 833
  LS type           : Link-LSA
  Link state ID     : 0.15.0.8
  Originating router: 2.2.2.2
  LS seq number     : 0x80000041
  Checksum          : 0x8315
  Length            : 56
  Priority          : 1
  Options           : 0x000013 (-|R|-|-|E|V6)
  Link-Local address: fe80::200:5eff:fe00:100
  Number of prefixes: 1
      Prefix        : 1001::/64
      Prefix options: 0 (-|-|-|-)
Table 11 Command output
LS age
Age of LSA.
LS type
Type of LSA.
Link state ID
Link state ID.
Originating router
Originating router.
LS seq number
Checksum
LSA checksum.
Length
LSA length.
Priority
Router priority.
Options
Options.
Link-Local address
Link-local address.
Number of prefixes
Number of prefixes.
Prefix
Address prefix.
Prefix options
Prefix options.
# Display LSA statistics.
<System> display ospfv3 lsdb statistics
 Area ID         Router Network IntePre  InteRou IntraPre NSSA
 0.0.0.1         2      0       0        0       2        0
 0.0.0.3         1      0       0        0       1        1
 Total           2      0       0        0       3        1
                 Link   Grace   ASE
 Total           4      0       0
Table 12 Command output
Area ID
Area ID.
Router
Number of Type-1 LSAs.
Network
Number of Type-2 LSAs.
IntePre
Number of Type-3 LSAs.
InteRou
Number of Type-4 LSAs.
IntraPre
Number of Type-9 LSAs.
NSSA
Number of Type-7 LSAs.
Link
Total number of Type-8 LSAs.
Grace
Number of Type-11 LSAs.
ASE
Total number of Type-5 LSAs.
# Display detailed OSPFv3 LSDB information.
<Sysname> display ospfv3 lsdb verbose
                 SendCnt: 0       RxmtCnt: 0       Status: Stale
Table 13 Command output
SendCnt
Number of interfaces to send the LSA.
RxmtCnt
Number of LSAs in the link state retransmission list.
Status
LSA status:
·     Normal.
·     Delayed.
·     Maxage routed—The LSA has reached its maximum age.
·     Self originated.
·     Stale—A self-originated LSA is received during the GR process.
Use display ospfv3 nexthop to display OSPFv3 next hop information.
display ospfv3 [ process-id ] nexthop
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays next hop information for all OSPFv3 processes.
# Display next hop information for OSPFv3 process 1.
<Sysname> display ospfv3 1 nexthop
 Nexthop : FE80::20C:29FF:FED7:F308                Interface: GE1/0/2
 RefCount: 4                                       Status   : Valid
 NbrID   : 1.1.1.1                                 NbrIntID : 21
 Nexthop : FE80::20C:29FF:FED7:F312                Interface: GE1/0/3
 RefCount: 3                                       Status   : Valid
 NbrID   : 1.1.1.1                                 NbrIntID : 38
Table 14 Command output
Nexthop
Next hop address.
Output interface.
RefCount
Reference count (routes that reference the next hop).
Status
Next hop status: valid or invalid.
NbrId
Neighbor router ID.
NbrIntID
Neighbor interface ID.
Use display ospfv3 non-stop-routing to display OSPFv3 NSR information.
display ospfv3 [ process-id ] non-stop-routing
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPFv3 NSR information for all OSPFv3 processes.
# Display OSPFv3 NSR information.
<Sysname> display ospfv3 non-stop-routing
 Nonstop Routing capability: Enabled
 Upgrade phase             : Normal
Table 15 Command output
NSR status: enabled or disabled.
Upgrade phase
NSR phase:
·     Normal—Normal status.
·     Preparation—Upgrade preparation phase.
·     Smooth—Upgrade phase.
·     Precalculation—Route pre-calculation phase.
·     Calculation—Route calculation phase.
·     Redistribution—Route redistribution phase.
display ospfv3 peer
Use display ospfv3 peer to display information about OSPFv3 neighbors.
display ospfv3 [ process-id ] [ area area-id ] peer [ [ interface-type interface-number ] [ verbose ] | peer-router-id | statistics ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify a process, this command displays neighbor information for all processes.
area area-id: Specifies an area by its ID, an IPv4 address or a decimal integer in the range of 0 to 4294967295 that is translated into the IPv4 address format. If you do not specify an area, this command displays neighbor information for all areas.
verbose: Displays detailed neighbor information.
peer-router-id: Specifies a neighbor.
statistics: Displays OSPFv3 neighbor statistics.
If you do not specify an interface and a neighbor, this command displays neighbor information for all interfaces.
# Display the neighbor information for OSPFv3 process 1 on an interface.
<Sysname> display ospfv3 1 peer vlan-interface 1
 Area: 0.0.0.1
 Router ID       Pri State             Dead-Time InstID Interface
 2.2.2.2         1   Init/ -           00:00:36  0      Vlan1
Table 16 Command output
Router ID
Neighbor router ID.
Pri
Neighboring router priority.
Neighbor state.
Dead-Time
Dead time remained.
Inst ID
Instance ID.
Interface connected to the neighbor.
# Display detailed neighbor information for OSPFv3 process 1 on an interface.
<Sysname> display ospfv3 1 peer vlan-interface 1 verbose
 Area 0.0.0.1 interface Vlan1's neighbors
 Router ID: 2.2.2.2          Address: fe80::200:5eff:fe00:100
   State: ExStart  Mode: None  Priority: 1
   DR: 2.2.2.2  BDR: None   MTU: 1500
   Options is 0x000413 (AT|-|-|-|-|-|R|-|x|E|V6)
   Dead timer due in 00:00:33
   Neighbor is up for 00:24:19
   Authentication sequence: (high) 0, (low) 59755
   Neighbor state change count: 205
   Database Summary List 0
   Link State Request List 0
   Link State Retransmission List 0
   Neighbor interface ID: 8037
   GR state: Normal
   Grace period: 0           Grace period timer: Off
   DD Rxmt timer: Off        LS Rxmt timer: On
Table 17 Command output
Router ID
Neighbor router ID.
Address
Link-local address of the interface.
Neighbor state.
Mode
Neighbor mode for LSDB synchronization.
Priority
DR
DR on the interface's network segment.
BDR
BDR on the interface's network segment.
MTU
Interface MTU.
Options
LSA options:
·     DC—The originating router supports OSPFv3 over on-demand circuits.
·     R—Indicates whether the originating router is an active router.
·     N—Indicates whether the originating router supports NSSA LSAs.
·     x—Reserved.
·     E—Indicates whether the originating router can receive AS External LSAs.
·     V6—Indicates whether the originating router takes part in IPv6 route calculation.
Dead timer due in 33  sec
This dead timer will expire in 33 seconds.
The neighbor has been up for 00:24:19.
Authentication sequence number carried in the received packets. The high 32-bit value is 0, and the low 32-bit value is 59755.
Count of neighbor state changes.
Number of LSAs sent in DD packet.
Number of LSAs in the link state request list.
GR state
GR state:
·     Normal—GR is not in progress.
·     Doing GR—Acting as the GR restarter.
·     Complete GR.
·     Helper—Acting as the GR helper.
Grace period
Grace-LSA sending interval.
Grace period timer
Grace-LSA sending interval timer.
DD Rxmt timer
DD packet retransmission timer.
LS Rxmt timer
LSU retransmission timer.
# Display OSPFv3 neighbor statistics.
<Sysname> display ospfv3 peer statistics
 Area ID         Down Attempt Init 2-Way ExStart Exchange Loading Full Total
 0.0.0.0         0    0       0    0     0       0        0       1    1
 Total           0    0       0    0     0       0        0       1    1
Table 18 Command output
Area ID
Area ID.
Down
In this state, neighbor initial state, the router has not received any information from a neighboring router for a period of time.
Attempt
This state is available only in an NBMA network. In this state, the OSPFv3 router has not received any information from a neighbor for a period. The router can send Hello packets at a longer interval to keep the neighbor relationship.
Init
In this state, the device received a Hello packet from the neighbor but the packet contains no router ID of the neighbor. Mutual communication is not setup.
2-Way
Mutual communication between the router and its neighbor is available. DR/BDR election is finished under this state (or higher).
ExStart
In this state, the router decides on the initial DD sequence number and active/standby relationship of the two parties.
Exchange
In this state, the router exchanges DD packets with the neighbor.
Loading
In this state, the router sends LSRs to request the neighbor for needed LSAs.
Full
LSDB synchronization has been accomplished between neighbors.
Total
Total number of neighbors under the same state.
Use display ospfv3 request-queue to display OSPFv3 request list information.
display ospfv3 [ process-id ] [ area area-id ] request-queue [ interface-type interface-number ] [ neighbor-id ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify an OSPFv3 process, this command displays OSPFv3 request list information for all OSPFv3 processes.
area area-id: Specifies an area by its ID, an IPv4 address or a decimal integer in the range of 0 to 4294967295 that is translated into the IPv4 address format. If you do not specify an OSPFv3 area, this command displays OSPFv3 request list information for all areas.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays OSPFv3 request list information for all interfaces.
neighbor-id: Specifies a neighbor's router ID. If you do not specify a neighbor, this command displays OSPFv3 request list information for all OSPFv3 neighbors.
# Display OSPFv3 request list information.
<Sysname> display ospfv3 request-queue
                   Area: 0.0.0.0
                   Nbr-ID 1.3.3.3 Request List
 Type    LinkState ID    AdvRouter       SeqNumber    Age   Checksum
 0x4005  0.0.34.127      1.3.3.3         0x80000001   0027  0x274d
 0x4005  0.0.34.128      1.3.3.3         0x80000001   0027  0x2d45
 0x4005  0.0.34.129      1.3.3.3         0x80000001   0027  0x333d
 0x4005  0.0.34.130      1.3.3.3         0x80000001   0027  0x3935
Table 19 Command output
Area
Area ID.
Interface type and sequence number.
Nbr-ID
Neighbor ID.
Request list
Request list information.
LSA type.
AdvRouter
Advertising router.
SeqNumber
Age
LSA age.
Checksum
Checksum.
Use display ospfv3 retrans-queue to display retransmission list information.
display ospfv3 [ process-id ] [ area area-id ] retrans-queue [ interface-type interface-number ] [ neighbor-id ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify an OSPFv3 process, this command displays retransmission list information for all OSPFv3 processes.
area area-id: Specifies an area by its ID, an IPv4 address or a decimal integer in the range of 0 to 4294967295 that is translated into the IPv4 address format. If you do not specify an OSPFv3 area, this command displays retransmission list information for all OSPFv3 areas.
interface-type interface-number: Specifies an interface by its type and number. If you do not specify an interface, this command displays retransmission list information for all interfaces.
neighbor-id: Specifies a neighbor's router ID. If you do not specify a neighbor, this command displays retransmission list information for all neighbors.
# Display OSPFv3 retransmission list information.
<Sysname> display ospfv3 retrans-queue
                   Area: 0.0.0.0
                   Nbr-ID 1.2.2.2 Retransmit List
 0x2009  0.0.0.0         1.3.3.3         0x80000001   3600  0x49fb
Table 20 Command output
Area
Area ID.
Nbr-ID
Neighbor ID.
Retransmit List
Retransmission list information.
LSA type.
AdvRouter
Advertising router.
SeqNumber
Age
LSA age.
Checksum
Checksum.
Use display ospfv3 routing to display OSPFv3 route information.
display ospfv3 [ process-id ] routing [ ipv6-address prefix-length ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the OSPFv3 route information for all processes.
# Display OSPFv3 routing information.
<Sysname> display ospfv3 routing
               OSPFv3 Process 1 with Router ID 9.9.9.9
 I  - Intra area route,  E1 - Type 1 external route,  N1 - Type 1 NSSA route
 IA - Inter area route,  E2 - Type 2 external route,  N2 - Type 2 NSSA route
 *  - Selected route
 *Destination: 3::3/128
  Type       : I                                         Cost     : 0
  Nexthop    : ::                                        Interface: Loop1
  AdvRouter  : 9.9.9.9                                   Area     : 0.0.0.0
  Preference : 10
 *Destination: 4::4/128
  Type       : I                                         Cost     : 1
  Nexthop    : FE80::20C:29FF:FED4:7171                  Interface: GE1/0/2
  AdvRouter  : 8.8.8.8                                   Area     : 0.0.0.0
  Preference : 10
 *Destination: 6::/64
  Type       : I                                         Cost     : 1
  Nexthop    : ::                                        Interface: GE1/0/2
  Preference : 10
 Total: 3
 Intra area: 3         Inter area: 0         ASE: 0         NSSA: 0
Table 21 Command output
Destination
Destination network segment.
Route type.
Cost
Route cost value.
Nexthop
Next hop address.
Output interface.
AdvRouter
Advertising router.
Area
Area ID.
Tag
Tag of external routes.
Preference
Route preference.
Total
Total number of routes.
Intra area
Number of intra-area routes.
Inter area
Number of inter-area routes.
ASE
Number of Type-5 external routes.
NSSA
Number of Type-7 external routes.
Use display ospfv3 spf-tree to display OSPFv3 topology information.
display ospfv3 [ process-id ] [ area area-id ] spf-tree [ verbose ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays topology information for all OSPFv3 processes.
area area-id: Specifies an OSPFv3 area by its ID. The area ID is an IP address or a decimal integer in the range of 0 to 4294967295 that is translated into the IP address format. If you do not specify this option, the command displays topology information for all OSPFv3 areas.
verbose: Displays detailed OSPFv3 topology information. If you do not specify this keyword, the command displays brief OSPFv3 topology information.
# Display brief topology information for Area 0 in OSPFv3 process 1.
<Sysname> display ospfv3 1 area 0 spf-tree
 Flags: S-Node is on SPF tree       R-Node is directly reachable
        I-Node or Link is init      D-Node or Link is to be deleted
        P-Neighbor is parent        A-Node is in candidate list
        C-Neighbor is child         H-Nexthop changed
        N-Link is a new path        V-Link is involved
                 Area: 0.0.0.0  Shortest Path Tree
 SPFNode         Type   Flag         SPFLink         Type   Cost  Flag
>1.1.1.1         Router S R
                                  -->2.2.2.2         RT2RT  1     C
                                  -->2.2.2.2         RT2RT  1     P
Table 22 Command output
SPFNode
SPF node, represented by the advertising router ID.
Node type:
·     Network—Network node.
·     Router—Router node.
Node flag:
·     I—The node is in initialization state.
·     A—The node is on the candidate list.
·     S—The node is on the SPF tree.
·     R—The node is directly connected to the root node.
·     D—The node is to be deleted.
SPFLink
SPF link, representing the advertising router ID.
Link type:
·     RT2RT—Router to router.
·     NET2RT—Network to router.
·     RT2NET—Router to network.
Link flag:
·     I—The link is in initialization state.
·     P—The peer is the parent node.
·     C—The peer is the child node.
·     D—The link is to be deleted.
·     H—The next hop is changed.
·     V—When the peer node is deleted or added, the peer node is not on the SPF tree or is deleted.
·     N—The link is newly added, and both end nodes are on the SPF tree.
·     L—The link is on the area change list.
# Display detailed topology information for Area 0 in OSPFv3 process 1.
<Sysname> display ospfv3 1 area 0 spf-tree verbose
>SPFNode[0]
  AdvID        : 1.1.1.1                  LsID       : 0.0.0.0
  NodeType     : Router                   Distance   : 1
  NodeFlag     : S R
  Nexthop count: 1
 -->NbrID      : 1.1.1.1                  NbrIntID   : 21
    Interface  : GE1/0/2                  NhFlag     : Valid
    RefCount   : 4
  SPFLink count: 1
 -->AdvID      : 1.1.1.1                  LsID       : 0.0.0.0
    IntID      : 232                      NbrIntID   : 465
    NbrID      : 2.2.2.2                  LinkType   : RT2RT
    LinkCost   : 1                        LinkNewCost: 1
    LinkFlag   : C                        NexthopCnt : 0
  ParentLink count: 1
    IntID      : 215                      NbrIntID   : 466
    LinkFlag   : P                        NexthopCnt : 0
Table 23 Command output
SPFNode
SPF node.
AdvID
ID of the advertising router.
LsID
Link state ID.
NodeType
Node type.
Distance
Cost to the root node.
NodeFlag
Node flag.
Nexthop count
Number of next hops.
NbrID
Neighbor router ID.
NbrIntID
Output interface.
NhFlag
Next hop flag: valid or invalid.
Nexthop
Next hop.
RefCount
SPFLink count
Number of SPF links.
IntID
Interface ID.
LinkType
Link type:
LinkCost
Link cost.
LinkNewCost
New link cost.
LinkFlag
Link flag:
NexthopCnt
ParentLinkCnt
Number of parent links.
Use display ospfv3 statistics to display OSPFv3 statistics.
display ospfv3 [ process-id ] statistics [ error ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays OSPFv3 statistics for all processes.
error: Displays error statistics. If you do not specify this keyword, the command displays OSPFv3 packet, LSA, and route statistics.
# Display OSPFv3 statistics.
<Sysname> display ospfv3 statistics
                   Packet Statistics
 Type                         Recv                Send
 Hello                        1746                1284
 DB Description               505                 941
 Ls Req                       252                 136
 Ls Upd                       851                 1553
 Ls Ack                       416                 450
             Local Originated LSAs Statistics
 Type                                             Count
 Router-LSA                                       192
 Network-LSA                                      0
 Inter-Area-Prefix-LSA                            0
 Inter-Area-Router-LSA                            0
 AS-external-LSA                                  0
 NSSA-LSA                                         0
 Link-LSA                                         10
 Intra-Area-Prefix-LSA                            112
 Grace-LSA                                        0
 Unknown-LSA                                      0
 Total                                            314
                   Routes Statistics
 Type                                             Count
 Intra Area                                       0
 Inter Area                                       0
 ASE                                              0
 NSSA                                             0
Table 24 Command output
Packet Statistics
Statistics about inbound and outbound packets.
Hello
Hello packet.
DB Description
DB description packet.
Ls Req
Link state request packet.
Ls Upd
Link state update packet.
Ls Ack
Link state acknowledgment packet.
Statistics about generated LSAs.
Router-LSA
Network-LSA
AS-external-LSA
Number of Type-5 LSAs.
NSSA-LSA
Link-LSA
Number of Type-8 LSAs.
Grace-LSA
Unknown-LSA
Number of Unknown-LSAs.
Total
Total number.
Routes Statistics
Number of routes.
Intra Area
Intra-area routes.
Inter Area
Inter-area routes.
ASE
NSSA
# Display OSPFv3 error statistics.
<Sysname> display ospfv3 statistics error
 0         : Transmit error               0         : Neighbor state low
 0         : Packet too small             0         : Bad version
 0         : Bad checksum                 0         : Unknown neighbor
 0         : Bad area ID                  0         : Bad packet
 0         : Packet dest error            0         : Inactive area packet
 0         : Router ID confusion          0         : Bad virtual link
 0         : HELLO: Hello-time mismatch   0         : HELLO: Dead-time mismatch
 0         : HELLO: Ebit option mismatch  0         : DD: Ebit option mismatch
 0         : DD: Unknown LSA type         0         : DD: MTU option mismatch
 0         : REQ: Empty request           0         : REQ: Bad request
 0         : UPD: LSA checksum bad        0         : UPD: Unknown LSA type
 0         : UPD: Less recent LSA         0         : UPD: LSA length bad
 0         : UPD: LSA AdvRtr id bad       0         : ACK: Bad ack packet
 0         : ACK: Invalid ack             0         : Interface down
 0         : Multicast incapable          0         : Authentication failure
 0         : AuthSeqNumber error
Table 25 Command output
Transmit error
Packets with error when being transmitted.
Neighbor state low
Packets received in low neighbor state.
Packet too small
Packets too small in length.
Bad version
Packets with wrong version.
Bad checksum
Packets with wrong checksum.
Unknown neighbor
Packets received from unknown neighbors.
Bad area ID
Packets with invalid area ID.
Bad packet
Packets illegal.
Packet dest error
Packets with wrong destination addresses.
Packets received in inactive areas.
Router ID confusion
Packets with duplicate router ID.
Bad virtual link
Packets on wrong virtual links.
Hello packets with mismatched hello timer.
Hello packets with mismatched dead timer.
Hello packets with mismatched E-bit in the option field.
DD packets with mismatched E-bit in the option field.
DD packets with unknown LSA type.
DD packets with mismatched MTU.
REQ: Empty request
LSR packets with no request information.
REQ: Bad request
Bad LSR packets.
LSU packets with wrong LSA checksum.
LSU packets with unknown LSA type.
LSU packets without the most recent LSA.
UPD: LSA length bad
LSU packets with wrong LSA length.
LSU packets with wrong LSA advertising router.
ACK: Bad ack packet
Bad LSAck packets for LSU packets.
ACK: Invalid ack
Invalid LSAck packets.
Interface down
Shutdown times of the interface.
Multicast incapable
Failures to join the multicast group.
Failures to authenticate the received packets.
AuthSeqNumber error
Authentication sequence number errors in the received packets.
Use display ospfv3 vlink to display OSPFv3 virtual link information.
display ospfv3 [ process-id ] vlink
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command displays the OSPFv3 virtual link information for all OSPFv3 processes.
# Display OSPFv3 virtual link information.
<Sysname> display ospfv3 vlink
 Virtual-link Neighbor-id: 12.2.2.2, Neighbor-state: Full
 Interface: 2348 (Vlan-interface12), Instance-ID: 0
 Local  IPv6 address: 3:3333::12
 Remote IPv6 address: 2:2222::12
 Cost: 1  State: P-2-P  Type: Virtual
Table 26 Command output
ID of the neighbor on the virtual link.
Neighbor-State
Neighbor state: Down, Init, 2-Way, ExStart, Exchange, Loading, or Full.
Number and name of the local interface on the virtual link.
Cost
Interface route cost.
Interface state.
Virtual link.
Transit Area
Transit area ID. This field is displayed when a virtual link is present on the interface.
Timers
Values of OSPFv3 timers (in seconds): hello, dead, and retransmit, and interface transmission delay.
IPsec profile name
Use enable ipsec-profile to apply an IPsec profile to an OSPFv3 area.
Use undo enable ipsec-profile to remove the IPsec profile from the OSPFv3 area.
enable ipsec-profile profile-name
No IPsec profile is applied to an area.
OSPFv3 area view
profile-name: Specifies an IPsec profile by its name, a case-insensitive string of 1 to 63 characters.
To protect routing information and prevent attacks, OSPFv3 can authenticate protocol packets by using an IPsec profile. For more information about IPsec profiles, see Security Configuration Guide.
# Apply the IPsec profile profile001 to Area 0 in OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.0] enable ipsec-profile profile001
Use filter to configure inbound/outbound Inter-Area-Prefix-LSA filtering on an ABR.
Use undo filter to remove the configuration.
filter { acl6-number | prefix-list prefix-list-name | route-policy route-policy-name } { export | import }
Inter-Area-Prefix-LSAs are not filtered.
OSPFv3 area view
acl6-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999 to filter inbound/outbound Inter-Area-Prefix-LSAs.
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter inbound/outbound Inter-Area-Prefix-LSAs.
route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter inbound/outbound Inter-Area-Prefix-LSAs.
export: Filters Inter-Area-Prefix-LSAs advertised to other areas.
import: Filters Inter-Area-Prefix-LSAs advertised into the local area.
This command applies only to an ABR.
# Use IPv6 prefix list my-prefix-list to filter inbound Inter-Area-Prefix-LSAs. Use IPv6 ACL 2000 to filter outbound Inter-Area-Prefix-LSAs in OSPFv3 Area 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] filter prefix-list my-prefix-list import
[Sysname-ospfv3-1-area-0.0.0.1] filter 2000 export
Use filter-policy export to configure OSPFv3 to filter redistributed routes.
Use undo filter-policy export to remove the configuration.
filter-policy { acl6-number | prefix-list prefix-list-name } export [ protocol [ process-id ] ]
Redistributed routes are not filtered.
OSPFv3 view
acl6-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999 to filter redistributed routes by destination address.
prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter redistributed routes by destination address.
protocol: Filters routes redistributed from the specified routing protocol, which can be bgp4+, direct, isisv6, ospfv3, ripng, or static. If you do not specify this argument, the command filters all redistributed routes.
process-id: Specifies a process by its ID in the range of 1 to 65535. This argument is available only when the protocol argument is ripng, ospfv3, or isisv6.
To reference an advanced ACL (with a number from 3000 to 3999) in the command, configure the ACL in one of the following ways:
·     To deny/permit a route with the specified destination, use rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix.
·     To deny/permit a route with the specified destination and prefix, use rule [ rule-id ] { deny | permit } ipv6 source sour sour-prefix destination dest dest-prefix.
The source keyword specifies the destination address of a route, and the destination keyword specifies the prefix of the route. The prefix must be contiguous. Otherwise, the configuration does not take effect.
Using the filter-policy export command filters only routes redistributed by the import-route command. If the import-route command is not configured to redistribute routes from other protocols and other OSPFv3 processes, the filter-policy export command does not take effect.
# Use IPv6 prefix list abc to filter redistributed routes.
[Sysname] ipv6 prefix-list abc permit 2002:1:: 64
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy prefix-list abc export
# Configure IPv6 ACL 3000 to permit only route 2001::1/128. Use ACL 3000 to filter redistributed routes.
[Sysname-acl6-adv-3000] rule 10 permit ipv6 source 2001::1 128 destination ffff:ffff:ffff:ffff:ffff:ffff:ffff:ffff 128
[Sysname-acl6-adv-3000] rule 100 deny ipv6
[Sysname-acl6-adv-3000] quit
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 3000 export
Use filter-policy import to configure OSPFv3 to filter routes calculated using received LSAs.
Use undo filter-policy import to restore the default.
filter-policy { acl6-number [ gateway prefix-list-name ] | prefix-list prefix-list-name [ gateway prefix-list-name ] | gateway prefix-list-name | route-policy route-policy-name } import
Routes calculated using received LSAs are not filtered.
OSPFv3 view
acl6-number: Specifies an IPv6 ACL by its number in the range of 2000 to 3999 to filter routes by destination.
gateway prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes by next hop. If you do not specify this option, the command does not filter routes by next hop.
prefix-list prefix-list-name: Specifies an IPv6 prefix list by its name, a case-sensitive string of 1 to 63 characters, to filter routes by destination.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to filter received routes.
Using the filter-policy import command filters only routes computed by OSPFv3. Routes that fail to pass the filter are not added to the routing table.
# Use IPv6 prefix list abc to filter received routes.
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy prefix-list abc import
# Configure IPv6 ACL 3000 to permit only route 2001::1/128 to pass. Use ACL 3000 to filter received routes.
[Sysname] ospfv3
[Sysname-ospfv3-1] filter-policy 3000 import
graceful-restart enable
Use graceful-restart enable to enable the GR capability for OSPFv3.
Use undo graceful-restart enable to disable the GR capability for OSPFv3.
graceful-restart enable [ global | planned-only ] *
The GR capability for OSPFv3 is disabled.
OSPFv3 view
global: Enables global GR. In global GR mode, a GR process can be completed only when all GR helpers exist. A GR process fails if a GR helper fails (for example, the interface connected to the GR helper goes down). If you do not specify this keyword, the command enables partial GR. In partial GR mode, a GR process can be completed as long as one GR helper exists.
planned-only: Enables planned GR only. If you do not specify this keyword, the command enables both planned GR and unplanned GR.
GR includes planned GR and unplanned GR.
·     Planned GR—Manually restarts OSPFv3 or performs an active/standby switchover. Before OSPFv3 restart or active/standby switchover, the GR restarter sends Grace-LSAs to GR helpers.
·     Unplanned GR—OSPFv3 restarts or an active/standby switchover occurs because of device failure. Before OSPFv3 restart or active/standby switchover, the GR restarter does not send Grace-LSAs to GR helpers.
OSPFv3 GR and OSPFv3 NSR are mutually exclusive. Do not configure the graceful-restart enable command and the non-stop-routing command at the same time.
To prevent service interruption after a master/backup switchover, a GR restarter running OSPFv3 must complete the following tasks:
·     Keep the GR restarter forwarding entries stable during reboot.
·     Establish all adjacencies and obtain complete topology information after reboot.
# Enable the GR capability for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart enable
graceful-restart helper enable
Use graceful-restart helper enable to enable the GR helper capability for OSPFv3.
Use undo graceful-restart helper enable to disable the GR helper capability for OSPFv3.
The GR helper capability for OSPFv3 is enabled.
OSPFv3 view
planned-only: Enables only planned GR for the GR helper. If you do not specify this keyword, the command enables both planned GR and unplanned GR for the GR helper.
Upon receiving the Grace-LSA, the neighbors with the GR helper capability enter the helper mode (and are called GR helpers). Then, the GR restarter retrieves its adjacencies and LSDB with the help of the GR helpers.
# Enable the GR helper capability for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart helper enable
graceful-restart helper strict-lsa-checking
Use graceful-restart helper strict-lsa-checking to enable strict LSA checking for the GR helper.
Use undo graceful-restart helper strict-lsa-checking to disable strict LSA checking for the GR helper.
Strict LSA checking for the GR helper is disabled.
OSPFv3 view
With GR helper enabled, when an LSA change on the GR helper is detected, the GR helper device exits the GR helper mode.
# Enable strict LSA checking for the GR helper in OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart helper strict-lsa-checking
graceful-restart interval
Use graceful-restart interval to set the GR restart interval.
Use undo graceful-restart interval to restore the default.
graceful-restart interval interval-value
The GR restart interval is 120 seconds.
OSPFv3 view
interval-value: Specifies GR restart interval in the range of 40 to 1800 seconds.
The value of the GR restart interval cannot be smaller than the maximum OSPFv3 neighbor dead time of all the OSPFv3 interfaces. Otherwise, GR restart might fail.
# Set the GR restart interval for OSPFv3 process 1 to 100 seconds.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] graceful-restart interval 100
ospfv3 timer dead
import-route (OSPFv3 view)
Use import-route to redistribute routes.
Use undo import-route to disable route redistribution.
import-route protocol [ process-id | all-processes | allow-ibgp ] [ cost cost | nssa-only | route-policy route-policy-name | tag tag | type type ] *
OSPFv3 route redistribution is disabled.
OSPFv3 view
protocol: Redistributes routes from the specified routing protocol, which can be bgp4+, direct, isisv6, ospfv3, ripng, or static.
process-id: Specifies the process ID of a routing protocol, in the range of 1 to 65536. The default is 1. This argument takes effect only when the protocol argument is isisv6, ospfv3, or ripng.
all-processes: Redistributes routes from all the processes of the specified routing protocol. This keyword takes effect only when the protocol argument is ripng, ospfv3, or isisv6.
allow-ibgp: Redistributes IBGP routes. It is available only when the protocol argument is bgp4+.
cost cost: Specifies a cost for redistributed routes, in the range of 1 to 16777214. The default is 1.
nssa-only: Limits the route advertisement to the NSSA area by setting the P-bit of Type-7 LSAs to 0. If you do not specify this keyword, the P-bit of Type-7 LSAs is set to 1. If the router acts as both an ASBR and an ABR and FULL state neighbors exist in the backbone area, the P-bit of Type-7 LSAs originated by the router is set to 0. This keyword applies to NSSA routers.
route-policy route-policy-name: Specifies a routing policy to filter redistributed routes. The route-policy-name argument is a case-sensitive string of 1 to 63 characters.
tag tag: Specifies a tag for external LSAs, in the range of 0 to 4294967295. If you do not specify this option, the tag specified by the default tag command applies.
type type: Specifies the type for redistributed routes, 1 or 2. The default is 2.
An external route is a route to a destination outside the OSPFv3 AS. External routes types are as follows:
·     A Type-1 external route has high reliability. Its cost is comparable with the cost of OSPFv3 internal routes. The cost of a Type-1 external route equals the cost from the router to the ASBR plus the cost from the ASBR to the external route's destination.
·     A Type-2 external route has low credibility. OSPFv3 considers the cost from the ASBR to a Type-2 external route is much bigger than the cost from the ASBR to an OSPFv3 internal router. The cost of a Type-2 external route equals the cost from the ASBR to the Type-2 external route's destination.
The import-route command cannot redistribute default routes.
The import-route bgp4+ command redistributes only EBGP routes. The import-route bgp4+ allow-ibgp command redistributes both EBGP and IBGP routes, and might cause routing loops. Therefore, use it with caution.
The import-route nssa-only command redistributes AS-external routes in Type-7 LSAs only into the NSSA area.
# Configure OSPFv3 process 1 to redistribute routes from RIPng and specify the type as type 2 and cost as 50.
[Sysname] ospfv3
[Sysname-ospfv3-1] import-route ripng 10 type 2 cost 50
# Configure OSPFv3 process 100 to redistribute the routes discovered by OSPFv3 process 160.
[Sysname] ospfv3 100
[Sysname-ospfv3-100] import-route ospfv3 160
default-route-advertise (OSPFv3 view)
log-peer-change
Use log-peer-change to enable logging for neighbor state changes.
Use undo log-peer-change to disable logging for neighbor state changes.
log-peer-change
Logging for neighbor state changes is enabled.
OSPFv3 view
This feature enables the device to deliver logs about neighbor state changes to its information center. The information center processes logs according to user-defined output rules (whether and where to output logs). For more information about the information center, see Network Management and Monitoring Configuration Guide.
# Disable logging for neighbor state changes for OSPFv3 process 100.
[Sysname-ospfv3-100] undo log-peer-change
lsa-generation-interval
Use lsa-generation-interval to set the OSPFv3 LSA generation interval.
Use undo lsa-generation-interval to restore the default.
The maximum interval is 5 seconds, the minimum interval is 0 milliseconds, and the incremental interval is 0 milliseconds.
OSPFv3 view
maximum-interval: Specifies the maximum OSPFv3 LSA generation interval in the range of 1 to 60 seconds.
minimum-interval: Specifies the minimum OSPFv3 LSA generation interval in the range of 10 to 60000 milliseconds. The default is 0, which indicates that the minimum interval can be any value.
incremental-interval: Specifies the OSPFv3 LSA generation incremental interval in the range of 10 to 60000 milliseconds. The value of 0 milliseconds indicates that no OSPFv3 LSA generation incremental interval is set.
When network changes are infrequent, LSAs are generated at the minimum interval. If network changes become frequent, the LSA generation interval is incremented by the incremental interval × 2n-2 for each generation until the maximum interval is reached. The value n is the number of generation times.
The minimum interval and the incremental interval cannot be greater than the maximum interval.
# Set the maximum LSA generation interval to 2 seconds, minimum interval to 100 milliseconds, and incremental interval to 100 milliseconds.
[Sysname-ospfv3-100] lsa-generation-interval 2 100 100
lsa-arrival-interval
maximum load-balancing (OSPFv3 view)
Use maximum load-balancing to set the maximum number of equal-cost multi-path (ECMP) routes.
Use undo maximum load-balancing to restore the default.
maximum load-balancing maximum
The maximum number of OSPFv3 ECMP routes equals the maximum number of ECMP routes supported by the system.
OSPFv3 view
maximum: Specifies the maximum number of ECMP routes. When the maximum number is 1, OSPFv3 does not perform load balancing.
If you use the max-ecmp-num command to configure the maximum number of ECMP routes supported by the system as m:
·     The default setting for the maximum load-balancing command is m.
·     The value range for the maximum argument of the maximum load-balancing command is 1 to m.
# Set the maximum number of ECMP routes to 2.
[Sysname-ospfv3-100] maximum load-balancing 2
max-ecmp-num
non-stop-routing
Use non-stop-routing to enable OSPFv3 NSR.
Use undo non-stop-routing to disable OSPFv3 NSR.
non-stop-routing
OSPFv3 NSR is disabled.
OSPFv3 view
OSPFv3 NSR takes effect on a per-process basis. As a best practice, enable NSR for each OSPFv3 process.
OSPFv3 NSR and OSPFv3 GR are mutually exclusive. Do not configure the non-stop-routing command and the graceful-restart enable command at the same time.
# Enable NSR for OSPFv3 process 100.
[Sysname-ospfv3-100] non-stop-routing
nssa
Use nssa to configure the current area as an NSSA area.
Use undo nssa to restore the default.
nssa [ default-route-advertise [ cost cost | nssa-only | route-policy route-policy-name | tag tag | type type ] * | no-import-route | no-summary | [ translate-always | translate-never ] | suppress-fa | translator-stability-interval value ] *
undo nssa
No area is configured as an NSSA area.
OSPFv3 area view
default-route-advertise: Used on an NSSA ABR or an ASBR only. If it is configured on an NSSA ABR, the ABR redistributes a default route in a Type-7 LSA into the NSSA area. It redistributes a default route regardless of whether a default route exists in the routing table. If it is configured on an ASBR, the ASBR redistributes a default route in a Type-7 LSA only when the default route exists in the routing table.
cost cost: Specifies a cost for the default route, in the range of 0 to 16777214. If you do not specify this option, the default cost specified by the default-cost command applies.
nssa-only: Limits the default route advertisement to the NSSA area by setting the P-bit of Type-7 LSAs to 0. If you do not specify this keyword, the P-bit of Type-7 LSAs is set to 1. If the router acts as both an ASBR and an ABR and FULL state neighbors exist in the backbone area, the P-bit is set to 0.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters. When the specified routing policy is matched, the command redistributes a default route in a Type-7 LSA into the OSPFv3 routing domain. The routing policy modifies values in the Type-7 LSA.
tag tag: Specifies a tag for the default route, in the range of 0 to 4294967295.
type type: Specifies a type for the Type-7 LSA, 1 or 2. The default is 2.
no-import-route: Used on an NSSA ABR to control the import-route command to not redistribute routes into the NSSA area.
no-summary: Used only on an ABR to advertise a default route in a Type-3 summary LSA into the NSSA area and to not advertise other summary LSAs into the area. The area is a totally NSSA area.
translate-always: Always translates Type-7 LSAs to Type-5 LSAs. This keyword takes effect only on an NSSA ABR.
translate-never: Never translates Type-7 LSAs to Type-5 LSAs. This keyword takes effect only on an NSSA ABR.
suppress-fa: Suppresses the forwarding address in the Type-7 LSAs from being placed in the Type-5 LSAs.
translator-stability-interval value: Specifies the stability interval of the translator. During the interval, the translator can maintain its translating capability after another device becomes the new translator. The value argument is the stability interval in the range of 0 to 900 seconds. The default interval is 0. A value of 0 means the translator does not maintain its translating capability when a new translator arises.
All routers attached to an NSSA area must be configured with the nssa command in area view.
# Configure Area 1 as an NSSA area.
[Sysname] ospfv3 120
[Sysname-ospfv3-120] area 1
[Sysname-ospfv3-120-area-0.0.0.1] nssa
default-cost (OSPFv3 area view)
ospfv3
Use ospfv3 to enable an OSPFv3 process and enter OSPFv3 view.
Use undo ospfv3 to disable an OSPFv3 process.
ospfv3 [ process-id | vpn-instance vpn-instance-name ] *
undo ospfv3 [ process-id ]
No OSPFv3 process is enabled.
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. The default process ID is 1.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, the OSPFv3 process runs on the public network.
Specify a router ID for the OSPFv3 process. Otherwise, the OSPFv3 process cannot generate LSAs.
# Enable OSPFv3 process 120 and configure the router ID as 1.1.1.1.
[Sysname-ospfv3-120] router-id 1.1.1.1
ospfv3 area
Use ospfv3 area to enable an OSPFv3 process and specify an area for on an interface.
Use undo ospfv3 area to disable an OSPFv3 process.
ospfv3 process-id area area-id [ instance instance-id ]
undo ospfv3 process-id area area-id [ instance instance-id ]
No OSPFv3 process is enabled on an interface.
Interface view
instance-id: Specifies an instance by its ID in the range of 0 to 255. The default is 0.
# Configure VLAN-interface 10 to run instance 1 of OSPFv3 process 1 in Area 1.
[Sysname-Vlan-interface10] ospfv3 1 area 1 instance 1
ospfv3 authentication-mode
Use ospfv3 authentication-mode to specify an authentication mode for an OSPFv3 interface.
Use undo ospfv3 authentication-mode to remove the configuration.
ospfv3 authentication-mode keychain keychain-name [ instance instance-id ]
undo ospfv3 authentication-mode [ instance instance-id ]
No authentication is performed on an OSPFv3 interface.
Interface view
keychain: Specifies keychain authentication.
keychain-name: Specifies a keychain by its name, a case-sensitive string of 1 to 63 characters.
instance instance-id: Specifies an instance by its ID in the range of 0 to 255. The default is 0.
When keychain authentication is configured for an OSPFv3 interface, OSPFv3 performs the following operations before sending a packet:
1.     Obtains a valid send key from the keychain.
OSPFv3 does not send the packet if it fails to obtain a valid send key.
2.     Uses the key ID, authentication algorithm, and key string to authenticate the packet.
If the key ID is greater than 65535, OSPFv3 does not send the packet.
When keychain authentication is configured for an OSPFv3 interface, OSPFv3 performs the following operations after receiving a packet:
1.     Uses the key ID carried in the packet to obtain a valid accept key from the keychain.
OSPFv3 discards the packet if it fails to obtain a valid accept key.
2.     Uses the authentication algorithm and key string for the valid accept key to authenticate the packet.
If the authentication fails, OSPFv3 discards the packet.
OSPFv3 supports only the HMAC-SHA-256 authentication algorithm.
The ID of keys used for authentication can only be in the range of 0 to 65535.
# Configure GigabitEthernet 3/0/1 to use keychain test for OSPFv3 packet authentication.
[Sysname] interface gigabitethernet 3/0/1
[Sysname-GigabitEthernet3/0/1] ospfv3 authentication-mode keychain test
ospfv3 bfd enable
Use ospfv3 bfd enable to enable BFD on an OSPFv3 interface.
Use undo ospfv3 bfd enable to disable BFD on an OSPFv3 interface.
ospfv3 bfd enable [ instance instance-id ]
undo ospfv3 bfd enable [ instance instance-id ]
BFD for OSPFv3 is disabled.
Interface view
BFD provides a mechanism to quickly detect the connectivity of links between OSPFv3 neighbors, improving the convergence speed of OSPFv3.
OSPFv3 uses BFD to implement bidirectional control detection.
# Enable BFD on VLAN-interface 11 in instance 1.
[Sysname-Vlan-interface11] ospfv3 bfd enable instance 1
ospfv3 cost
Use ospfv3 cost to set an OSPFv3 cost for an interface in an instance.
Use undo ospfv3 cost to restore the default.
ospfv3 cost value [ instance instance-id ]
undo ospfv3 cost [ instance instance-id ]
The cost is 1 for a VLAN interface, is 0 for a loopback interface, and is computed according to the interface bandwidth for other interfaces.
Interface view
value: Specifies an OSPFv3 cost in the range of 0 to 65535 for a loopback interface, and in the range of 1 to 65535 for other interfaces.
# Set the OSPFv3 cost for VLAN-interface 10 in instance 1 to 33.
[Sysname-Vlan-interface10] ospfv3 cost 33 instance 1
ospfv3 dr-priority
Use ospfv3 dr-priority to set the router priority for an interface in an instance.
Use undo ospfv3 dr-priority to restore the default.
ospfv3 dr-priority priority [ instance instance-id ]
undo ospfv3 dr-priority [ instance instance-id ]
An interface has a router ID of 1.
Interface view
priority: Specifies a router priority in the range of 0 to 255.
An interface's router priority determines its privilege in DR/BDR selection.
# Set the router priority for VLAN-interface 10 in instance 1 to 8.
[Sysname-Vlan-interface10] ospfv3 dr-priority 8 instance 1
ospfv3 ipsec-profile
Use ospfv3 ipsec-profile to apply an IPsec profile to an OSPFv3 interface.
Use undo ospfv3 ipsec-profile to remove the IPsec profile from the OSPFv3 interface.
ospfv3 ipsec-profile profile-name [ instance instance-id ]
undo ospfv3 ipsec-profile [ instance instance-id ]
No IPsec profile is applied to an OSPFv3 interface.
Interface view
An IPsec profile must be specified in this command. For more information about IPsec profiles, see Security Configuration Guide.
# Apply the IPsec profile profile001 to the OSPFv3 interface VLAN-interface 10.
[Sysname-Vlan-interface10] ospfv3 ipsec-profile profile001
ospfv3 mib-binding
Use ospfv3 mib-binding to bind MIB to an OSPFv3 process.
Use undo ospfv3 mib-binding to restore the default.
ospfv3 mib-binding process-id
MIB is bound to the OSPFv3 process with the smallest process ID.
If the specified process ID does not exist, the MIB binding configuration fails.
Deleting an OSPFv3 process that has been bound to MIB unbinds the OSPFv3 process from MIB, and re-binds MIB to the OSPFv3 process with the smallest process ID.
# Bind MIB to OSPFv3 process 100.
[Sysname] ospfv3 mib-binding 100
ospfv3 mtu-ignore
Use ospfv3 mtu-ignore to configure an interface to ignore MTU check during DD packet exchange.
Use undo ospfv3 mtu-ignore to restore the default.
ospfv3 mtu-ignore [ instance instance-id ]
undo ospfv3 mtu-ignore [ instance instance-id ]
An interface performs MTU check during DD packet exchange.
Interface view
A neighbor relationship can be established only if the interface's MTU is the same as that of the peer.
# Configure VLAN-interface 10 that belongs to instance 1 to ignore MTU check during DD packet exchange.
[Sysname-Vlan-interface10] ospfv3 mtu-ignore instance 1
ospfv3 network-type
Use ospfv3 network-type to specify the network type for an OSPFv3 interface.
Use undo ospfv3 network-type to restore the default.
ospfv3 network-type { broadcast | nbma | p2mp [ unicast ] | p2p } [ instance instance-id ]
undo ospfv3 network-type [ instance instance-id ]
The network type of an OSPFv3 interface is broadcast.
Interface view
broadcast: Specifies the network type as broadcast.
nbma: Specifies the network type as NBMA.
p2mp: Specifies the network type as P2MP.
unicast: Specifies the P2MP interface to unicast OSPFv3 packets. By default, a P2MP interface multicasts OSPFv3 packets.
p2p: Specifies the network type as P2P.
instance-id: Specifies the instance ID of an interface, in the range of 0 to 255. The default is 0.
If a router on a broadcast network does not support multicast, configure the network type for the connected interfaces as NBMA.
If any two routers on an NBMA network are directly connected through a virtual link, the network is fully meshed. You can configure the network type for the connected interfaces as NBMA. If two routers are not directly connected, configure the P2MP network type so that the two routers can exchange routing information through another router.
When the network type of an interface is NBMA or P2MP unicast, you must use the peer command to specify the neighbor.
When the network type of an interface is P2MP unicast, all OSPFv3 packets are unicast by the interface.
# Specify the OSPFv3 network type for VLAN-interface 20 as NBMA.
[Sysname] interface vlan-interface 20
[Sysname-Vlan-interface20] ospfv3 network-type nbma
ospfv3 dr-priority
ospfv3 peer
Use ospfv3 peer to specify a neighbor and set the DR priority of the neighbor.
Use undo ospfv3 peer to remove the configuration.
ospfv3 peer ipv6-address [ cost value | dr-priority dr-priority ] [ instance instance-id ]
undo ospfv3 peer ipv6-address [ instance instance-id ]
No link-local address is specified for the neighbor interface.
Interface view
ipv6-address: Specifies the link-local IPv6 address of the neighbor.
cost value: Specifies the cost of the neighbor, in the range of 1 to 65535.
dr-priority dr-priority: Specifies the DR priority of the neighbor, in the range of 0 to 255. The default is 1.
For NBMA and P2MP interfaces (only when in unicast mode), you must specify the link-local IPv6 addresses of their neighbors because these interfaces cannot find neighbors through broadcasting hello packets. For NBMA interfaces, you can also specify DR priorities for their neighbors.
# On VLAN-interface 10, specify the link-local address of its neighbor as FE80::1111.
[Sysname-Vlan-interface10] ospfv3 peer fe80::1111
ospfv3 prefix-suppression
Use ospfv3 prefix-suppression to disable an OSPFv3 interface from advertising all its prefixes.
Use undo ospfv3 prefix-suppression to restore the default.
ospfv3 prefix-suppression [ disable ] [ instance instance-id ]
undo ospfv3 prefix-suppression [ instance instance-id ]
Prefix suppression is disabled on an interface.
Interface view
disable: Disables prefix suppression for an interface.
To disable prefix suppression for an interface associated with an OSPFv3 process that has been enabled with prefix suppression, use the ospfv3 prefix-suppression disable command on that interface.
# Enable prefix suppression for VLAN-interface 10.
[Sysname-Vlan-interface10] ospfv3 prefix-suppression
prefix-suppression
ospfv3 timer dead
Use ospfv3 timer dead to set the OSPFv3 neighbor dead time.
Use undo ospfv3 timer dead to restore the default.
ospfv3 timer dead seconds [ instance instance-id ]
undo ospfv3 timer dead [ instance instance-id ]
The OSPFv3 neighbor dead time is 40 seconds for P2P and broadcast interfaces, and is 120 seconds for P2MP and NBMA interfaces.
Interface view
seconds: Specifies the dead time in the range of 1 to 65535 seconds.
If an interface receives no hello packet from a neighbor after dead time elapses, the interface considers the neighbor down.
The dead time must be at least four times the hello time and must be identical on interfaces attached to the same network segment.
# Set the OSPFv3 neighbor dead time to 60 seconds for VLAN-interface 10.
[Sysname-Vlan-interface10] ospfv3 timer dead 60
ospfv3 timer hello
ospfv3 timer hello
Use ospfv3 timer hello to set the hello interval for an interface.
Use undo ospfv3 timer hello to restore the default.
ospfv3 timer hello seconds [ instance instance-id ]
undo ospfv3 timer hello [ instance instance-id ]
The hello interval is 10 seconds for P2P and broadcast interfaces, and is 30 seconds for P2MP or NBMA interfaces.
Interface view
seconds: Specifies the hello interval in the range of 1 to 65535 seconds.
The shorter the hello interval is, the faster the topology converges and the more resources are consumed. Make sure the hello interval on two neighboring interfaces is the same.
# Set the hello interval to 20 seconds for VLAN-interface 10.
[Sysname-Vlan-interface10] ospfv3 timer hello 20
ospfv3 timer dead
ospfv3 timer poll
Use ospfv3 timer poll to set the poll interval on an NBMA interface.
Use undo ospfv3 timer poll to restore the default.
ospfv3 timer poll seconds [ instance instance-id ]
undo ospfv3 timer poll [ instance instance-id ]
The poll interval is 120 seconds on an interface.
Interface view
seconds: Specifies the poll interval in the range of 1 to 65535 seconds.
instance-id: Specifies an interface instance by its ID in the range of 0 to 255. The default is 0.
When an NBMA interface finds its neighbor is down, it sends hello packets at the poll interval.
The poll interval must be at least four times the hello interval.
# Set the poll interval on VLAN-interface 10 to 120 seconds.
[Sysname-Vlan-interface10] ospfv3 timer poll 120
ospfv3 timer hello
ospfv3 timer retransmit
Use ospfv3 timer retransmit to set the LSA retransmission interval for an interface.
Use undo ospfv3 timer retransmit to restore the default.
ospfv3 timer retransmit seconds [ instance instance-id ]
undo ospfv3 timer retransmit [ instance instance-id ]
The interval is 5 seconds.
Interface view
seconds: Specifies the LSA retransmission interval in the range of 1 to 3600 seconds.
After the device sends an LSA to its neighbor, it waits for an acknowledgment. If the device receives no acknowledgment after the LSA retransmission interval elapses, it will retransmit the LSA.
To avoid unnecessary retransmissions, set an appropriate retransmission interval. For example, you can set a large retransmission interval value on a low-speed link.
# Set the LSA retransmission interval on VLAN-interface10 in instance 1 to 12 seconds.
[Sysname-Vlan-interface10] ospfv3 timer retransmit 12 instance 1
ospfv3 trans-delay
Use ospfv3 trans-delay to set the transmission delay for an interface.
Use undo ospfv3 trans-delay to restore the default.
ospfv3 trans-delay seconds [ instance instance-id ]
undo ospfv3 trans-delay [ instance instance-id ]
The transmission delay is 1 second.
Interface view
seconds: Specifies the transmission delay in the range of 1 to 3600 seconds.
Each LSA in the LSDB has an age that is incremented by 1 every second, but the age does not change during transmission. Adding a transmission delay into the age time is important in low speed networks.
# Set the transmission delay to 3 seconds for VLAN-interface 10 in instance 1.
[Sysname-Vlan-interface10] ospfv3 trans-delay 3 instance 1
preference
Use preference to set a preference for OSPFv3 routes.
Use undo preference to restore the default.
undo preference [ ase ]
The preference is 10 for OSPFv3 internal routes and 150 for OSPFv3 external routes.
OSPFv3 view
ase: Specifies a preference for OSPFv3 external routes. If you do not specify this keyword, the command sets a preference for OSPFv3 internal routes.
preference: Specifies the preference value in the range of 1 to 255. The smaller the value, the higher the preference.
route-policy route-policy-name: Specifies a routing policy by its name, a case-sensitive string of 1 to 63 characters, to set a preference for matching routes.
If multiple routing protocols find multiple routes to the same destination, the router uses the route found by the protocol with the highest preference.
# Set a preference of 150 for OSPFv3 routes.
[Sysname] OSPFv3
[Sysname-OSPFv3-1] preference 150
prefix-suppression
Use prefix-suppression to disable an OSPFv3 process from advertising all prefixes except for the prefixes of loopback interfaces and passive interfaces.
Use undo prefix-suppression to restore the default.
prefix-suppression
An OSPFv3 process advertises all prefixes.
OSPFv3 view
To disable an OSPFv3 process from advertising the prefixes of loopback and passive interfaces, configure prefix suppression on the interfaces by using the ospfv3 prefix-suppression command.
When prefix suppression is enabled:
·     OSPFv3 does not advertise the prefixes of suppressed interfaces in Type-8 LSAs.
·     On broadcast and NBMA networks, the DR does not advertise the prefixes of suppressed interfaces in Type-9 LSAs that reference Type-2 LSAs.
·     On P2P and P2MP networks, OSPFv3 does not advertise the prefixes of suppressed interfaces in Type-9 LSAs that reference Type-1 LSAs.
# Enable prefix suppression for OSPFv3 process 100.
[Sysname-ospfv3-100] prefix-suppression
reset ospfv3 process
Use reset ospfv3 process to restart OSPFv3 processes.
reset ospfv3 [ process-id ] process [ graceful-restart ]
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command restarts all OSPFv3 processes.
graceful-restart: Restarts the OSPFv3 process by using GR.
The reset ospfv3 process command performs the following actions:
·     Clears all invalid LSAs without waiting for their timeouts.
·     Starts a new DR/BDR election.
·     Keeps previous OSPFv3 configurations.
The system prompts you to select whether to restart OSPFv3 process upon execution of this command.
# Restart all OSPFv3 processes.
<Sysname> reset ospfv3 process
Reset OSPFv3 process? [Y/N]:y
reset ospfv3 redistribution
Use reset ospfv3 redistribution to restart route redistribution.
reset ospfv3 [ process-id ] redistribution
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command restarts route redistribution for all OSPFv3 processes.
# Restart route redistribution.
<Sysname> reset ospfv3 redistribution
reset ospfv3 statistics
Use reset ospfv3 statistics to clear OSPFv3 statistics.
reset ospfv3 [ process-id ] statistics
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. If you do not specify this argument, the command clears statistics for all OSPFv3 processes.
# Clear statistics for all OSPFv3 processes.
<Sysname> reset ospfv3 statistics
router-id
Use router-id to configure a router ID.
Use undo router-id to remove the configured router ID.
router-id router-id
undo router-id
No router ID is configured.
OSPFv3 view
router-id: Specifies a router ID in IPv4 address format.
The router ID is the unique identifier for the device to run OSPFv3 in the AS. An OSPFv3 process cannot run without a router ID.
Different processes must have different router IDs.
# Configure the router ID 10.1.1.3 for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] router-id 10.1.1.3
ospfv3
silent-interface(OSPFv3 view)
Use silent-interface to disable the specified interface from receiving and sending OSPFv3 packets.
Use undo silent-interface to restore the default.
An interface can receive and send OSPFv3 packets.
OSPFv3 view
all: Specifies all interfaces.
Multiple processes can disable the same interface from receiving and sending OSPFv3 packets. However, the silent-interface command takes effect only on interfaces enabled with the current process.
# Disable VLAN-interface 10 from receiving and sending OSPFv3 packets in OSPFv3 processes 100 and 200.
[Sysname-ospfv3-100] router-id 10.100.1.9
[Sysname-ospfv3-100] silent-interface vlan-interface 10
[Sysname-ospfv3-100] quit
[Sysname] ospfv3 200
[Sysname-ospfv3-200] router-id 20.100.1.9
[Sysname-ospfv3-200] silent-interface vlan-interface 10
snmp-agent trap enable ospfv3
Use snmp-agent trap enable ospfv3 to enable SNMP notifications for OSPFv3.
Use undo snmp-agent trap enable ospfv3 to disable SNMP notifications for OSPFv3.
snmp-agent trap enable ospfv3 [ grrestarter-status-change | grhelper-status-change | if-state-change | if-cfg-error | if-bad-pkt | neighbor-state-change | nssatranslator-status-change | virtif-bad-pkt | virtif-cfg-error | virtif-state-change | virtgrhelper-status-change | virtneighbor-state-change ] *
undo snmp-agent trap enable ospfv3 [ grrestarter-status-change | grhelper-status-change | if-state-change | if-cfg-error | if-bad-pkt | neighbor-state-change | nssatranslator-status-change | virtif-bad-pkt | virtif-cfg-error | virtif-state-change | virtgrhelper-status-change | virtneighbor-state-change ] *
SNMP notifications for OSPFv3 are enabled.
grrestarter-status-change: Specifies notifications about GR restarter state changes.
grhelper-status-change: Specifies notifications about GR helper state changes.
if-state-change: Specifies notifications about interface state changes.
if-cfg-error: Specifies notifications about error configuration of an interface.
if-bad-pkt: Specifies notifications about error messages received on an interface.
neighbor-state-change: Specifies notifications about neighbor state changes.
nssatranslator-status-change: Specifies notifications about NSSA translator state changes.
virtif-bad-pkt: Specifies notifications about error messages received on a virtual interface.
virtif-cfg-error: Specifies notifications about error configuration of a virtual interface.
virtif-state-change: Specifies notifications about virtual interface state changes.
virtgrhelper-status-change: Specifies notifications about neighbor GR helper state changes of a virtual interface.
virtneighbor-state-change: Specifies notifications about the neighbor state changes of a virtual interface.
# Disable SNMP notifications for OSPFv3.
[Sysname] undo snmp-agent trap enable ospfv3
snmp context-name
Use snmp context-name to configure an SNMP context for OSPFv3.
Use undo snmp context-name to restore the default.
No SNMP contexts exist for OSPFv3.
OSPFv3 view
context-name: Specifies a context name, a case-sensitive string of 1 to 32 characters.
The standard OSPFv3 MIB provides only single-instance MIB objects. For SNMP to correctly identify OSPFv3 management information in the standard OSPFv3 MIB, you must configure a unique context name for OSPFv3. If multiple OSPFv3 processes exist, you must assign a unique context to each process.
Context is a method introduced to SNMPv3 for multiple-instance management. For SNMPv1/v2c, you must specify a community name as a context name for protocol identification.
# Configure the SNMP context name as mib for OSPFv3 process 1.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] snmp context-name mib
snmp trap rate-limit
Use snmp trap rate-limit to set the SNMP notification output interval and the maximum number of SNMP notifications that can be output at each interval.
Use undo snmp trap rate-limit to restore the default.
OSPFv3 outputs a maximum of seven SNMP notifications within 10 seconds.
OSPFv3 view
interval trap-interval: Specifies the SNMP notification output interval in the range of 2 to 60 seconds.
count trap-number: Specifies the number of SNMP notifications output by OSPFv3 at each interval, in the range of 0 to 300. The value of 0 indicates that OSPFv3 does not output SNMP notifications.
# Configure OSPFv3 to output a maximum of 10 SNMP notifications within 5 seconds.
[Sysname-ospfv3-100] snmp trap rate-limit interval 5 count 10
spf-schedule-interval
Use spf-schedule-interval to set the OSPFv3 SPF calculation interval.
Use undo spf-schedule-interval to restore the default.
The maximum SPF calculation interval is 5 seconds, the minimum interval is 50 milliseconds, and the incremental interval is 200 milliseconds.
OSPFv3 view
maximum-interval: Specifies the maximum OSPFv3 route calculation interval in the range of 1 to 60 seconds.
minimum-interval: Specifies the minimum OSPFv3 route calculation interval in the range of 10 to 60000 milliseconds.
incremental-interval: Specifies the incremental OSPFv3 route calculation interval in the range of 10 to 60000 milliseconds.
Based on the LSDB, an OSPFv3 router uses SPF to calculate a shortest path tree with itself being the root. OSPFv3 uses the shortest path tree to determine the next hop to a destination. By adjusting the SPF calculation interval, you can prevent overconsumption of bandwidth and router resources due to frequent topology changes.
For a stable network, the minimum interval is used. If network changes become frequent, the SPF calculation interval is incremented by the incremental interval × 2n-2 for each calculation until the maximum interval is reached. The value n is the number of calculation times.
# Set the maximum SPF calculation interval to 10 seconds, minimum interval to 500 milliseconds, and incremental interval to 300 milliseconds.
[Sysname-ospfv3-100] spf-schedule-interval 10 500 300
stub (OSPFv3 area view)
Use stub to configure an area as a stub area.
Use undo stub to restore the default.
undo stub
No area is configured as a stub area.
OSPFv3 area view
default-route-advertise-always: Enables the ABR to always advertise a default route into the stub area.
no-summary: Enables the ABR to advertise only a default route in an Inter-Area-Prefix-LSA into the stub area. No AS-external-LSA, Inter-Area-Prefix-LSA, or other Inter-Area-Router-LSA is advertised in the area. The area is a totally stub area.
To remove the no-summary configuration on an ABR, execute the stub command again to overwrite it.
To configure an area as a stub area, execute the stub command on all routers attached to the area.
# Configure OSPFv3 area 1 as a stub area.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] area 1
[Sysname-ospfv3-1-area-0.0.0.1] stub
stub-router
Use stub-router to configure a router as a stub router.
Use undo stub-router to restore the default.
stub-router r-bit [ include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } ] *
stub-router max-metric [ external-lsa [ max-metric-value ] | summary-lsa [ max-metric-value ] | include-stub | on-startup { seconds | wait-for-bgp [ seconds ] } ] *
undo stub-router
The router is not configured as a stub router.
OSPFv3 view
r-bit: Clears the R-bit of the Option field in Type-1 LSAs.
max-metric: Advertises the locally generated Type-1 LSAs with the maximum cost of 65535.
external-lsa max-metric-value: Specifies a cost for external LSAs, in the range of 1 to 16777215. The default is 16711680.
summary-lsa max-metric-value: Specifies a cost for Type-3 and Type-4 LSAs, in the range of 1 to 16777215. The default is 16711680.
include-stub: Specifies the cost for Type-9 LSAs that reference Type-1 LSAs to the maximum value 65535.
on-startup seconds: Specifies the router as a stub router during reboot, and specifies the timeout time in the range of 5 to 86400 seconds.
wait-for-bgp seconds: Specifies the router as a stub router during BGP route convergence after reboot, and specifies the timeout time in the range of 5 to 86400 seconds. The default timeout time is 600 seconds.
You can use the stub-router r-bit command or stub-router max-metric command to configure a router as a stub router.
·     The stub-router r-bit command clears the R-bit of the Option field in Type-1 LSAs. When the R-bit is clear, the OSPFv3 router can participate in OSPFv3 topology distribution without forwarding traffic.
·     The stub-router max-metric command specifies the OSPFv3 max-metric router LSA feature. This feature enables OSPFv3 to advertise its locally generated Type-1 LSAs with a maximum cost of 65535. Neighbors do not send packets to the stub router as long as they have a route with a smaller cost.
# Configure a stub router.
[Sysname-ospfv3-100] stub-router r-bit
transmit-pacing
Use transmit-pacing to set the LSU transmission interval and the maximum number of LSU packets that can be sent at each interval.
Use undo transmit-pacing to restore the default.
An OSPFv3 interface sends a maximum of three LSU packets every 20 milliseconds.
OSPFv3 view
interval interval: Specifies an interval at which an interface sends LSU packets, in the range of 10 to 1000 milliseconds. If the router has multiple OSPFv3 interfaces, increase the interval to reduce the total number of LSU packets sent by the router every second.
count count: Specifies the maximum number of LSU packets sent by an interface at each interval, in the range of 1 to 200. If the router has multiple OSPFv3 interfaces, decrease the maximum number to reduce the total number of LSU packets sent by the router every second.
# Configure all the interfaces running OSPFv3 process 1 to send a maximum of 10 LSU packets every 30 milliseconds.
[Sysname] ospfv3 1
[Sysname-ospfv3-1] transmit-pacing interval 30 count 10
vlink-peer (OSPFv3 area view)
Use vlink-peer to configure a virtual link.
Use undo vlink-peer to remove a virtual link.
vlink-peer router-id [ dead seconds | hello seconds | instance instance-id | ipsec-profile profile-name | retransmit seconds | trans-delay seconds ] *
undo vlink-peer router-id [ dead | hello | ipsec-profile | retransmit | trans-delay ] *
No virtual link is configured.
OSPFv3 area view
router-id: Specifies the router ID of the neighbor on the virtual link.
dead seconds: Specifies the dead interval in the range of 1 to 32768 seconds. The default is 40. The dead interval must be identical with that on the virtual link neighbor, and must be at least four times the hello interval.
hello seconds: Specifies the hello interval in the range of 1 to 8192 seconds. The default is 10. It must be identical with the hello interval on the virtual link neighbor.
instance instance-id: Specifies the instance ID of a virtual link, in the range of 0 to 255. The default is 0.
ipsec-profile profile-name: Specifies an IPsec profile by its name, a case-insensitive string of 1 to 63 characters. For more information about IPsec profiles, see Security Configuration Guide.
retransmit seconds: Specifies the retransmission interval in the range of 1 to 3600 seconds. The default is 5.
trans-delay seconds: Specifies the transmission delay interval in the range of 1 to 3600 seconds. The default is 1.
For non-backbone areas without direct connections to the backbone area or for a backbone area that cannot maintain connectivity, you can use the vlink-peer command to create logical links. A virtual link is similar to an interface with OSPFv3 enabled, because parameters such as hello, dead, retransmit and trans-delay are configured in the same way.
Both ends of a virtual link are ABRs that are configured with the vlink-peer command.
Parameters include the following guidelines:
·     The smaller the hello interval is, the faster the network converges, and the more network resources are consumed.
·     A retransmission interval that is too small can cause unnecessary retransmissions. A large value is appropriate for a low speed link.
·     Specify an appropriate transmission delay with the trans-delay keyword.
# Configure a virtual link to 10.10.0.3.
[Sysname] ospfv3 1
[Sysname-ospfv3-1-area-0.0.0.1] vlink-peer 10.10.0.3
