05-Layer 3 - IP Services Command Reference
HomeSupportSwitchesH3C S10500 Switch SeriesReference GuidesCommand ReferencesH3C S10500 Switch Series Command References-Release7178-6W10005-Layer 3 - IP Services Command Reference
13-GRE commands
13-GRE commands 28.45 KB
GRE commands
keepalive
Use keepalive to enable the GRE keepalive function and set the keepalive interval and the keepalive number.
Use undo keepalive to disable the GRE keepalive function.
keepalive [ interval [ times ] ]
undo keepalive
The GRE keepalive function is disabled.
Tunnel interface view
interval: Specifies the keepalive interval in the range of 1 to 32767 seconds. The default value is 10.
times: Specifies the keepalive number in the range of 1 to 255. The default value is 3.
This command enables the tunnel interface to send keepalive packets at the specified interval. If the device receives no response from the peer within the timeout time, it shuts down the local tunnel interface. The device brings the local tunnel interface up if it receives a keepalive acknowledgment packet from the peer. The timeout time is the result of multiplying the keepalive interval by the keepalive number.
The device always acknowledges the keepalive packets it receives whether or not GRE keepalive is enabled.
GRE/IPv6 mode tunnel interfaces do not support this command.
# Enable GRE keepalive, set the keepalive interval to 20 seconds, and set the keepalive number to 5.
[Sysname] interface tunnel 2 mode gre
[Sysname-Tunnel2] keepalive 20 5
