07 MPLS Configration Guide
HomeSupportSwitchesS7500E-XS SeriesConfigure & DeployConfiguration GuidesH3C S7500E-XS Configuration Guides-R2418P05-6W10007 MPLS Configration Guide
07-Tunnel policy configuration
07-Tunnel policy configuration 111.49 KB
Overview
Tunnel policies enable a PE to forward traffic for each MPLS VPN over a preferred tunnel or over multiple tunnels. The tunnels supported by MPLS VPN include MPLS LSPs and MPLS TE tunnels.
For more information about MPLS TE, see "Configuring MPLS TE." For more information about MPLS VPNs, see "Configuring MPLS L3VPN," "Configuring MPLS L2VPN," and "Configuring VPLS."
Configuring a tunnel policy
Configuration guidelines
Follow these guidelines when you configure a tunnel policy:
·     To select a preferred tunnel, create a tunnel policy and specify the preferred tunnel with the preferred-path command. The destination address of the preferred tunnel identifies a peer PE so the PE will forward traffic destined for that peer PE over the preferred tunnel.
¡     If you specify multiple preferred tunnels that have the same destination address in a tunnel policy, only the first configured tunnel takes effect.
¡     If the first tunnel is not available, the second tunnel is used, and so forth. No load balancing will be performed on these tunnels.
This method explicitly specifies an MPLS TE tunnel for an MPLS VPN, facilitating traffic planning. H3C recommends that you use this method.
·     To select multiple tunnels for load sharing, create a tunnel policy and specify the tunnel selection order and the number of tunnels by using the select-seq load-balance-number command. A tunnel type closer to the select-seq keyword has a higher priority. For example, the select-seq lsp cr-lsp load-balance-number 3 command gives LSP higher priority. If no LSP is available or the number of LSPs is less than 3, VPN uses CRLSP tunnels. The tunnels selected by this method are not fixed, complicating traffic planning. H3C recommends not using this method.
If you configure both methods for a tunnel policy, the tunnel policy selects tunnels in the following steps:
1.     If the destination address of a preferred tunnel identifies a peer PE, the tunnel policy uses the preferred tunnel to forward traffic destined for the peer PE without using any other tunnels.
2.     If not, the tunnel policy selects tunnels as configured by the select-seq load-balance-number command.
Figure 1 MPLS VPN tunnel selection diagram
As shown in Figure 1, PE 1 and PE 2 have multiple tunnels in between and they are connected to multiple MPLS VPNs. You can control the paths for VPN traffic by using one of the following methods:
·     Configure multiple tunnel policies, and specify a preferred tunnel for each policy by using the preferred-path command. Apply these policies to different MPLS VPNs to forward the traffic of each VPN over a specific tunnel.
·     Configure one tunnel policy, and use the select-seq load-balance-number command to specify the tunnel selection order and the number of tunnels for load balancing. Apply the tunnel policy to MPLS VPNs to forward the traffic of every VPN over multiple tunnels.
The second method distributes traffic of a single VPN to multiple tunnels. The transmission delays on different tunnels can greatly vary. Therefore, the destination device or the upper layer application might take a great time to sequence the packets. H3C recommends not using the second method.
Configuration procedure
To configure a tunnel policy:
Step
Remarks
N/A
2.     Create a tunnel policy, and enter tunnel policy view.
tunnel-policy tunnel-policy-name
By default, no tunnel policy is configured.
3.     Configure tunnel selection methods.
·     (Method 1) Specify a preferred tunnel:
preferred-path tunnel number
·     (Method 2) Configure the tunnel selection order and the number of tunnels for load balancing:
select-seq { cr-lsp | lsp } * load-balance-number number
Configure one or both methods.
By default, no preferred tunnel is specified.
By default, only one tunnel is selected in LSP—CRLSP order.
For a VPN to exclusively use a tunnel, you can specify the tunnel as the preferred tunnel in a tunnel policy, and apply the policy only to that VPN.
Displaying tunnel information
Display tunnel information.
display mpls tunnel { all | statistics | [ vpn-instance vpn-instance-name ] destination { tunnel-ipv4-dest | tunnel-ipv6-dest } }
Tunnel policy configuration examples
Preferred tunnel configuration example
Network requirements
PE 1 has multiple tunnels to reach PE 2: one MPLS TE tunnel on the interface Tunnel 1, and one LDP LSP tunnel.
Two MPLS VPN instances, vpna and vpnb, exist on PE 1. Configure PE 1 to use the MPLS TE tunnel to forward traffic for both VPNs.
1.     Create a tunnel policy named preferredte1, and configure tunnel 1 as the preferred tunnel.
<PE1> system-view
[PE1] tunnel-policy preferredte1
[PE1-tunnel-policy-preferredte1] preferred-path tunnel 1
[PE1-tunnel-policy-preferredte1] quit
2.     Configure MPLS VPN instances and apply the tunnel policy to the VPN instances:
# Create MPLS VPN instance vpna, and apply tunnel policy preferredte1 to it.
[PE1] ip vpn-instance vpna
[PE1-vpn-instance-vpna] route-distinguisher 100:1
[PE1-vpn-instance-vpna] vpn-target 100:1
[PE1-vpn-instance-vpna] tnl-policy preferredte1
[PE1-vpn-instance-vpna] quit
# Create MPLS VPN instance vpnb, and apply tunnel policy preferredte1 to it.
[PE1] ip vpn-instance vpnb
[PE1-vpn-instance-vpnb] route-distinguisher 100:2
[PE1-vpn-instance-vpnb] vpn-target 100:2
[PE1-vpn-instance-vpnb] tnl-policy preferredte1
Exclusive tunnel configuration example
One MPLS VPN vpna exists on PE 1. The VPN exclusively uses the MPLS TE tunnel.
1.     Create tunnel policy preferredte1, and configure tunnel 1 as the preferred tunnel.
<PE1> system-view
2.     Create MPLS VPN instance vpna, and apply tunnel policy preferredte1 to it.
Tunnel selection order configuration example
Only one MPLS VPN, vpna, exists on PE 1. Select only one tunnel in LDP LSP-MPLS TE order for this VPN.
# Create tunnel policy seq-lsp-te.
<PE1> system-view
[PE1] tunnel-policy seq-lsp-te
# Specify the tunnel selection order and set the number of tunnels for load balancing to 1—no load balancing.
[PE1-tunnel-policy-seq-lsp-te] select-seq lsp cr-lsp load-balance-number 1
[PE1-tunnel-policy-seq-lsp-te] quit
# Create MPLS VPN instance vpna, and apply tunnel policy seq-lsp-te to it.
[PE1-vpn-instance-vpna] tnl-policy seq-lsp-te
Preferred tunnel and tunnel selection order configuration example
PE 1 has multiple tunnels to reach PE 2: two MPLS TE tunnels on the interface Tunnel 1 and Tunnel 3, and one LDP LSP tunnel.
PE 1 has multiple MPLS VPN instances: vpna, vpnb, vpnc, vpnd, and vpne. Table 1 shows the tunnel policy that PE 1 uses for each VPN instance.
Table 1 Tunnel policies used for VPN instances
VPN instance
Tunnel policy
vpna, vpnb
Use MPLS TE tunnel Tunnel1 as the preferred tunnel.
vpnc, vpnd
Use MPLS TE tunnel Tunnel3 as the preferred tunnel.
vpne
Uses one tunnel selected in LDP LSP-MPLS TE order.
1.     Configure tunnel policies on PE 1:
# Create tunnel policy preferredte1, and configure tunnel 1 as the preferred tunnel.
<PE1> system-view
# Create tunnel policy preferredte2, and configure tunnel 3 as the preferred tunnel.
[PE1] tunnel-policy preferredte2
[PE1-tunnel-policy-preferredte2] preferred-path tunnel 3
[PE1-tunnel-policy-preferredte2] quit
# Create tunnel policy select-lsp.
[PE1] tunnel-policy select-lsp
# Configure the policy to select only one tunnel in LDP LSP-MPLS TE order.
[PE1-tunnel-policy-select-lsp] select-seq lsp cr-lsp load-balance-number 1
[PE1-tunnel-policy-select-lsp] quit
2.     Configure MPLS VPN instances and apply tunnel policies to the VPN instances:
# Create MPLS VPN instances vpna and vpnb, and apply tunnel policy preferredte1 to them.
[PE1-vpn-instance-vpnb] quit
# Create MPLS VPN instances vpnc and vpnd, and apply tunnel policy preferredte2 to them.
[PE1] ip vpn-instance vpnc
[PE1-vpn-instance-vpnc] route-distinguisher 100:3
[PE1-vpn-instance-vpnc] vpn-target 100:3
[PE1-vpn-instance-vpnc] tnl-policy preferredte2
[PE1-vpn-instance-vpnc] quit
[PE1] ip vpn-instance vpnd
[PE1-vpn-instance-vpnd] route-distinguisher 100:4
[PE1-vpn-instance-vpnd] vpn-target 100:4
[PE1-vpn-instance-vpnd] tnl-policy preferredte2
[PE1-vpn-instance-vpnd] quit
# Create MPLS VPN instance vpne and apply tunnel policy select-lsp to it.
[PE1] ip vpn-instance vpne
[PE1-vpn-instance-vpne] route-distinguisher 100:5
[PE1-vpn-instance-vpne] vpn-target 100:5
[PE1-vpn-instance-vpne] tnl-policy select-lsp
