11 Network Management and Monitoring Command Reference
HomeSupportSwitchesS7500E-XS SeriesReference GuidesCommand ReferencesH3C S7500E-XS Command References-R2418P05-6W10011 Network Management and Monitoring Command Reference
03-Information center commands
03-Information center commands 179.69 KB
diagnostic-logfile save
Use diagnostic-logfile save to manually save diagnostic logs from the diagnostic log file buffer to the diagnostic log file.
When this command is executed, the system displays a message that logs in the buffer have been saved to the diagnostic log file even if the diagnostic log file buffer does not contain diagnostic logs.
You can specify the directory to store the diagnostic log file by using the info-center diagnostic-logfile directory command.
The system clears the diagnostic log file buffer after saving the buffered diagnostic logs to the diagnostic log file.
# Manually save diagnostic logs from the diagnostic log file buffer to the diagnostic log file.
<Sysname> diagnostic-logfile save
The contents in the diagnostic log file buffer have been saved to the file flash:/ diagfile/diagfile.log.
·     info-center diagnostic-logfile directory
·     info-center diagnostic-logfile enable
display diagnostic-logfile summary
Use display diagnostic-logfile summary to display the diagnostic log file configuration.
# Display the diagnostic log file configuration.
<Sysname> display diagnostic-logfile summary
  Diagnostic log file: Enabled.
  Diagnostic log file size quota: 10 MB
  Diagnostic log file directory: flash:/diagfile
  Writing frequency: 24 hour 0 min 0 sec
Diagnostic log file
·     EnabledDiagnostic logs can be output to the diagnostic log file.
·     DisabledDiagnostic logs cannot be output to the diagnostic log file.
Maximum size of the diagnostic log file, in MB.
Log file directory
Directory where the diagnostic log file is saved.
Writing frequency
Interval at which the system saves diagnostic logs from the diagnostic log file buffer to the diagnostic log file.
display info-center
Use display info-center to display information center configuration information.
display info-center
# Display information center configuration.
<Sysname> display info-center
Information Center: Enabled
Console: Enabled
Monitor: Enabled
Log host: Enabled
    IP address: 192.168.0.1, port number: 5000, host facility: local7
    IP address: 192.168.0.2, port number: 5001, host facility: local5
Log buffer: Enabled
    Max buffer size 1024, current buffer size 512,
    Current messages 0, dropped messages 0, overwritten messages 0
Log file: Enabled
Security log file: Enabled
Information timestamp format:
    Loghost: Date
    Other output destination: Date
display logbuffer
Use display logbuffer to display the state of the log buffer and the log information in the log buffer.
display logbuffer [ reverse ] [ level severity | size buffersize | slot slot-number ] *
reverse: Displays log entries chronologically, with the most recent entry at the top. If you do not specify this keyword, the command displays log entries chronologically, with the oldest entry at the top.
level severity: Specifies a severity level in the range of 0 to 7. If you do not specify this keyword, the command displays log information for all levels.
Table 2 Log levels
Severity value
Level
Corresponding keyword in commands
0
Emergency
The system is unusable. For example, the system authorization has expired.
emergency
1
Alert
Action must be taken immediately. For example, traffic on an interface exceeds the upper limit.
alert
2
Critical
Critical condition. For example, the device temperature exceeds the upper limit, the power module fails, or the fan tray fails.
critical
3
Error
Error condition. For example, the link state changes.
error
4
Warning
Warning condition. For example, an interface is disconnected, or the memory resources are used up.
warning
5
Notification
Normal but significant condition. For example, a terminal logs in to the device, or the device reboots.
notification
6
Informational
Informational message. For example, a command or a ping operation is executed.
informational
7
Debug
Debugging message.
debugging
size buffersize: Specifies the number of latest log messages to be displayed. The value range is 1 to 1024. If you do not specify this keyword, the command displays all log information.
slot slot-number: Specifies an IRF member ID.
# Display the state and log information of the log buffer.
<Sysname> display logbuffer slot 1
Log buffer: Enabled
Max buffer size: 1024
Actual buffer size: 512
Dropped messages: 0
Overwritten messages: 0
Current messages: 127
%Jun 19 18:03:24:55 2006 Sysname SYSLOG/7/SYS_RESTART:System restarted
Log buffer
·     EnabledLogs can be output to the log buffer.
·     DisabledLogs cannot be output to the buffer.
Max buffer size
Maximum buffer size supported by the device.
Actual buffer size
Maximum buffer size configured by using the info-center logbuffer size command.
Dropped messages
Number of dropped messages.
Number of overwritten messages.
Current messages
Number of current messages.
·     info-center logbuffer
·     reset logbuffer
display logbuffer summary
Use display logbuffer summary to display the summary of the log buffer.
display logbuffer summary [ level severity | slot slot-number ] *
level severity: Specifies a severity level in the range of 0 to 7. If you do not specify this keyword, the command displays log information of all levels in the log buffer. For more information about log levels, see Table 2.
# Display the summary of the log buffer.
<Sysname> display logbuffer summary
Slot EMERG ALERT  CRIT ERROR  WARN NOTIF  INFO DEBUG
     1     0     0     0     5     4    37   123     0
     2     0     0     0     0     0     0     0     0
     3     0     0     0     0     0     0     0     0
     4     0     0     0     0     0     0     0     0
     5     0     0     0     0     0     0     0     0
     6     0     0     0     0     0     0     0     0
     7     0     0     0     0     0     0     0     0
     8     0     0     0     0     0     0     0     0
     9     0     0     0     0     0     0     0     0
    10     0     0     0     0     0     0     0     0
Slot
IRF member ID.
EMERG
Represents emergency. For more information, see Table 2.
ALERT
Represents alert. For more information, see Table 2.
CRIT
Represents critical. For more information, see Table 2.
ERROR
Represents error. For more information, see Table 2.
WARN
Represents warning. For more information, see Table 2.
NOTIF
Represents notification. For more information, see Table 2.
INFO
Represents informational. For more information, see Table 2.
DEBUG
Represents debug. For more information, see Table 2.
display logfile summary
Use display logfile summary to display the log file configuration.
# Display the log file configuration.
<Sysname> display logfile summary
  Log file: Enabled.
  Log file size quota: 10 MB
  Log file directory: flash:/logfile
  Writing frequency: 0 hour 1 min 10 sec
Table 5 Command output
Log file
·     EnabledLogs can be output to the log file.
·     DisabledLogs cannot be output to the log file.
Log file size quota
Maximum storage space reserved for the log file, in MB.
Log file directory
Log file directory.
Writing frequency
Log file writing frequency.
display security-logfile summary
Use display security-logfile summary to display the summary of the security log file.
security-audit
A local user can use this command only after being authorized as the security log administrator by the system administrator through the authorization-attribute user-role security-audit command. For more information about security log administrator, see Security Configuration Guide.
# Display the summary of the security log file.
<Sysname> display security-logfile summary
  Security log file size quota: 10 MB
  Security log file directory: flash:/seclog
  Alarm threshold: 80%
  Current usage: 30%
  Writing frequency: 1 hour 0 min 0 sec
Table 6 Command output
Security log file
·     EnabledSecurity logs can be output to the security log file.
·     DisabledSecurity logs cannot be output to the security log file.
Maximum storage space reserved for the security log file.
Security log file directory.
Alarm-threshold
Alarm threshold of the security log file usage.
Current usage
Current usage of the security log file.
Writing frequency
Security log file writing frequency.
authorization-attribute (Security Command Reference)
enable log updown
Use enable log updown to enable an interface to generate link up or link down logs when the interface state changes.
Use undo enable log updown to disable an interface from generating link up or link down logs when the interface state changes.
enable log updown
All interfaces are allowed to generate link up and link down logs.
Interface view
# Disable port FortyGigE 1/1/1 from generating link up or link down logs.
[Sysname] interface fortygige 1/1/1
[Sysname-FortyGigE1/1/1] undo enable log updown
Use info-center diagnostic-logfile enable to enable saving diagnostic logs to the diagnostic log file.
Use undo info-center diagnostic-logfile enable to disable saving diagnostic logs to the diagnostic log file.
Saving diagnostic logs to the diagnostic log file is enabled.
This command enables the system to save generated diagnostic logs to the diagnostic log file for centralized management. This facilitates users in monitoring device activities and debugging problems by viewing the diagnostic logs.
# Enable saving diagnostic logs to the diagnostic log file.
[Sysname] info-center diagnostic-logfile enable
info-center diagnostic-logfile frequency
Use info-center diagnostic-logfile frequency to configure the interval at which the system saves diagnostic logs from the diagnostic log file buffer to the diagnostic log file.
Use undo info-center diagnostic-logfile frequency to restore the default saving interval.
The diagnostic log file saving interval is 86400 seconds.
freq-sec: Specifies the interval at which the system saves diagnostic logs from the diagnostic log file buffer to the diagnostic log file. The value range is 10 to 86400 seconds, and the default is 86400 seconds.
The system saves diagnostic logs in the diagnostic log file buffer, and outputs the buffered diagnostic logs to the diagnostic log file at the specified interval.
# Configure the system to save diagnostic logs from the diagnostic log file buffer to the diagnostic log file every 600 seconds.
[Sysname] info-center diagnostic-logfile frequency 600
info-center diagnostic-logfile quota
Use info-center diagnostic-logfile quota to set the maximum size of the diagnostic log file.
Use undo info-center diagnostic-logfile quota to restore the default.
The maximum size of the diagnostic log file is 10 MB.
size: Specifies the maximum size of the diagnostic log file, in the range of 1 to 10 MB.
# Set the maximum size to 6 MB for the diagnostic log file.
[Sysname] info-center diagnostic-logfile quota 6
Use info-center diagnostic-logfile directory to configure the directory to save the diagnostic log file.
The diagnostic log file is saved in the diagfile directory under the root directory of the storage device.
dir-name: Specifies a directory by its name, a string of 1 to 511 characters.
The specified directory must have been created.
This command cannot survive an IRF reboot or a master/subordinate switchover.
# Set the diagnostic log file directory to flash:/test.
<Sysname> mkdir test
[Sysname] info-center diagnostic-logfile directory flash:/test
The directory is in primary partition.
info-center logfile overwrite-protection
Use info-center logfile overwrite-protection to enable log file overwrite-protection. When the log file is full or the storage media runs out of space, the device stops saving logs to the log file.
Use undo info-center logfile overwrite-protection to disable log file overwrite-protection. When the log file is full or the storage media runs out of space, the device overwrites old logs with new logs.
info-center logfile overwrite-protection [ all-port-powerdown ]
Log file overwrite-protection is disabled.
all-port-powerdown: Shuts down all the physical ports except for the console port, the management Ethernet port, and IRF ports on the device when the log file is full or the storage media runs out of space.
This command is supported only in FIPS mode.
With log file overwrite-protection enabled, the device stops saving new logs to the log file when the log file is full or the storage media runs out of space.
If the all-port-powerdown keyword is specified, the device shuts down all the physical ports except for the console port, the management Ethernet port, and IRF ports on the device when the log file is full or the storage media runs out of space. When this happens, back up the log file, delete the original file to release the storage space, and then bring up the ports.
# Enable log file overwrite-protection.
[Sysname] info-center logfile overwrite-protection
info-center enable
Use info-center enable to enable the information center.
Use undo info-center enable to disable the information center.
info-center enable
The information center is enabled.
# Enable the information center.
[Sysname] info-center enable
info-center format
Use info-center format to set the format of logs sent to a log host.
Use undo info-center format to restore the default.
info-center format { unicom | cmcc }
Logs are sent to a log host in standard format.
unicom: Specifies the unicom format.
cmcc: Specifies the cmcc format.
Logs can be sent to a log host in standard, unicom, or cmcc format. For more information about log formats, see Network Management and Monitoring Configuration Guide.
# Set the log format to unicom for logs sent to log hosts.
[Sysname] info-center format unicom
Use info-center logbuffer to enable log output to the log buffer.
Use undo info-center logbuffer to disable log output to the log buffer.
Logs are allowed to be output to the log buffer.
# Enable log output to the log buffer.
[Sysname] info-center logbuffer
·     display logbuffer
·     info-center enable
Use info-center logbuffer size to set the maximum number of logs that can be stored in the log buffer.
Use undo info-center logbuffer size to restore the default.
The log buffer can store up to 512 logs.
buffersize: Specifies the maximum number of logs that can be stored in the log buffer. The value range is 0 to 1024, and the default is 512.
# Set the maximum log buffer size to 50.
[Sysname] info-center logbuffer size 50
# Restore the default maximum log buffer size.
[Sysname] undo info-center logbuffer size
·     display logbuffer
info-center logfile enable
Use info-center logfile enable to enable the log file feature.
Use undo info-center logfile enable to disable the log file feature.
The log file feature is enabled.
# Enable log output to the log file.
[Sysname] info-center logfile enable
info-center logfile frequency
Use info-center logfile frequency to configure the interval for saving logs to the log file.
Use undo info-center logfile frequency to restore the default saving interval.
The log file saving interval is 86400 seconds.
freq-sec: Specifies the interval at which the system saves logs to the log file, in seconds. The value range is 1 to 86400, and the default is 86400.
With this command executed, the system saves logs in the log file buffer to the log file at the log file saving interval.
# Set the log file saving interval to 60000 seconds.
[Sysname] info-center logfile frequency 60000
info-center logfile size-quota
Use info-center logfile size-quota to set the maximum size for the log file.
Use undo info-center logfile size-quota to restore the default.
The maximum size of the log file is 10 MB.
size: Specifies the maximum size for the log file, in MB.
When the maximum size of the log file is reached, the system deletes the earliest messages and writes new messages to the log file.
# Set the maximum size to 6 MB for the log file.
[Sysname] info-center logfile size-quota 6
info-center logfile directory
Use info-center logfile directory to configure the directory where the log file is saved.
The directory to save the log file is flash:/logfile.
The suffix of the log file is .log. When the default directory has no enough space for storing the file, you can specify a new directory for the log file.
The configuration made by this command cannot survive an IRF reboot or a master/subordinate switchover.
# Create a directory named test under the flash root directory.
# Set the log file directory to flash:/test.
[Sysname] info-center logfile directory flash:/test
info-center logging suppress duplicates
Use info-center logging suppress duplicates to enable duplicate log suppression.
Use undo info-center logging suppress duplicate to restore the default.
undo info-center logging suppress duplicates
Duplicate log suppression is disabled.
Outputting consecutive duplicate logs at an interval of less than 30 seconds wastes system and network resources.
With this feature enabled, the system starts a suppression period when outputting a new log:
·     During the suppression period, the system does not output logs with the same module name, level, mnemonic, location, and text as the previous log.
·     After the suppression period expires, if the same log continues to appear, the system outputs the suppressed logs and the log number and starts another suppression period. The suppression period is 30 seconds the first time, 2 minutes the second time, and 10 minutes for subsequent times.
·     If a different log is generated during the suppression period, the system aborts the current suppression period, outputs suppressed logs and the log number and then outputs the new log, starting another suppression period.
Suppose the IP address of Vlan-interface 100 on device A conflicts with that of another device on the network, device A will output the following log information repeatedly:
%Jan  1 07:27:48:636 2000 Sysname ARP/6/DUPIFIP:
Duplicate address 172.16.0.1 on interface Vlan-interface100, sourced from 00e0-fc58-123d
# Enable duplicate log suppression on device A.
[Sysname] info-center logging suppress duplicates
Device A continues to output the following log information:
%Jan  1 07:28:19:639 2000 Sysname ARP/6/DUPIFIP:
 This message repeated 4 times in last 30 seconds.
The output shows that after the duplicate log suppression function is enabled, the system outputs another duplicate log and starts the first suppression period for 30 seconds.
%Jan  1 07:30:19:643 2000 Sysname ARP/6/DUPIFIP:
 This message repeated 20 times in last 2 minutes.
The output shows the second suppression period lasts for 2 minutes.
%Jan  1 07:30:20:541 2000 Sysname ARP/6/DUPIFIP:
 This message repeated 1 times in last 1 second.
%Jan  1 07:30:19:542 2000 Sysname CFGMAN/5/CFGMAN_CFGCHANGED: -EventIndex=[12]-CommandSource=[2]-ConfigSource=[4]-ConfigDestination=[2]; Configuration is changed.
The output shows that a different log is generated during the suppression period.
%Jan  1 07:30:24:643 2000 Sysname ARP/6/DUPIFIP:
%Jan  1 07:30:55:645 2000 Sysname ARP/6/DUPIFIP:
The output shows that the system starts another suppression period.
info-center loghost
Use info-center loghost to specify a log host and to configure output parameters.
Use undo info-center loghost to restore the default.
info-center loghost [ vpn-instance vpn-instance-name ] { loghost | ipv4-address | ipv6 ipv6-address } [ port port-number ] [ facility local-number ]
undo info-center loghost [ vpn-instance vpn-instance-name ] { loghost | ipv4-address | ipv6 ipv6-address }
No log host is specified.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If the log host is on the public network, do not specify this option.
loghost: Specifies a log host by its host name, a case insensitive string of 1 to 253 characters.
ipv4-address: Specifies an IPv4 log host by its IPv4 address.
ipv6 ipv6-address: Specifies an IPv6 log host by its IPv6 address
port port-number: Specifies the port number of the log host, in the range of 1 to 65535. The default is 514. It must be the same as the value configured on the log host. Otherwise, the log host cannot receive system information.
facility local-number: Specifies a logging facility from local0 to local7 for the log host. The default value is local7. Logging facilities are used to mark different logging sources, and query and filer logs.
The info-center loghost command takes effect only after information center is enabled with the info-center enable command.
The device supports up to four log hosts.
# Output logs to the log host 1.1.1.1.
[Sysname] info-center loghost 1.1.1.1
info-center loghost source
Use info-center loghost source to specify the source IP address for output logs.
Use undo info-center loghost source to restore the default.
The source IP address of output logs is the primary IP address of the matching route's egress interface.
interface-type interface-number: Specifies the egress interface for logs by the interface type and interface number.
The system uses the primary IP address of the specified egress interface as the source IP address of log information no matter which physical interface is used to output the logs.
The info-center loghost source command takes effect only after the information center is enabled with the info-center enable command.
# Specify the IP address of interface loopback 0 as the source IP address of logs.
[Sysname] interface loopback 0
[Sysname-LoopBack0] ip address 2.2.2.2 32
[Sysname-LoopBack0] quit
[Sysname] info-center loghost source loopback 0
info-center security-logfile alarm-threshold
Use info-center security-logfile alarm-threshold to set the alarm threshold for security log file usage.
Use undo info-center security-logfile alarm-threshold to restore the default.
The alarm threshold for security log file usage is 80. When the usage of the security log file reaches 80%, the system outputs a message to inform the administrator.
usage: Specifies an alarm threshold. The value must be an integer in the range of 1 to 100.
When the security log file is full, the system deletes the oldest logs and then writes new logs to the security log file. This feature helps avoid security log loss by setting an alarm threshold for the security log file usage. When the threshold is reached, the system outputs log information to inform the administrator. The administrator can log in to the device as the security log administrator, and back up the security log file.
# Set the alarm threshold for security log file usage to 90.
[Sysname] info-center security-logfile alarm-threshold 90
info-center security-logfile size-quota
info-center security-logfile enable
Use info-center security-logfile enable to enable saving of security logs to the security log file.
Use undo info-center security-logfile enable to restore the default.
The saving of security logs to the security log file is disabled.
This feature enables the system to output security logs to the security log file buffer, and saves the logs from the buffer to the security log file at a specific interval.
# Enable saving security logs to the security log file.
[Sysname] info-center security-logfile enable
info-center security-logfile frequency
Use info-center security-logfile frequency to configure the interval for saving security logs to the security log file.
Use undo info-center security-logfile frequency to restore the default saving interval.
The security log file saving interval is 86400 seconds.
freq-sec: Specifies a saving interval in the range of 10 to 86400 seconds.
The system first outputs the security logs to the security log file buffer, and then saves the logs in the buffer to the security log file at the specified interval.
# Save security logs to the security log file every 600 seconds.
[Sysname] info-center security-logfile frequency 600
Use info-center security-logfile size-quota to set the maximum size for the security log file.
Use undo info-center security-logfile size-quota to restore the default.
The maximum size of the security log file is 10 MB.
size: Specifies the maximum size for the security log file, in MB. The value range for this argument varies by device model.
# Set the maximum size to 6 MB for the security log file.
[Sysname] info-center security-logfile size-quota 6
info-center security-logfile directory
Use info-center security-logfile directory to configure the directory where the security log file is saved.
The security log file is saved in the seclog directory under the root directory of the storage device.
security-audit
# Set the security log file directory to flash:/test.
[Sysname] info-center security-logfile directory flash:/test
info-center source
Use info-center source to configure a log output rule for a module.
Use undo info-center source to restore the default.
info-center source { module-name | default } { console | logbuffer | logfile | loghost | monitor } { deny | level severity }
undo info-center source { module-name | default } { console | logbuffer | logfile | loghost | monitor }
Table 7 lists the default log output rules.
Table 7 Default output rules
Destination
Source modules
Common log
Security log
Diagnostic log
Hidden log
Console
All supported modules
debugging
Disabled
Disabled
Disabled
Monitor terminal
debugging
Disabled
Disabled
Disabled
Log host
informational
Disabled
Disabled
informational
Log buffer
informational
Disabled
Disabled
informational
Log file
informational
Disabled
Disabled
informational
Security log file
All supported modules, cannot be filtered
Disabled
Debugging, which cannot be filtered
Disabled
Disabled
Diagnostic log file
Disabled
Disabled
Disabled
module-name: Specifies a module by its name. For instance, to output FTP information, set this argument to FTP. You can use the info-center source ? command to view the modules supported by the device.
default: Specifies all modules, which can be displayed by using the info-center source ? command.
console: Outputs logs to the console.
logbuffer: Outputs logs to the log buffer.
logfile: Outputs logs to the log file.
loghost: Outputs logs to the log host.
monitor: Outputs logs to the monitor terminal.
deny: Disables log output.
level severity: Specifies a severity level in the range of 0 to 7. The smaller the severity value, the higher the severity level. See Table 2 for more information. Logs at the specified severity level and higher levels are allowed or denied to be output.
If you do not set an output rule for a module, the module uses the default output rule or the output rule set by using the default keyword.
If you use the command multiple times, only the most recent output rule takes effect for the specified module.
After you set an output rule for a module, you must use the module-name argument to modify or remove the rule. A new output rule configured by using the default keyword does not take effect on the module.
# Output only VLAN module's information with the emergency level to the console.
[Sysname] info-center source default console deny
[Sysname] info-center source vlan console level emergency
# Based on the previous configuration, disable output of VLAN module's information to the console so no system information is output to the console.
[Sysname] undo info-center source vlan console
info-center synchronous
Use info-center synchronous to enable synchronous information output.
Use undo info-center synchronous to disable synchronous information output.
Synchronous information output is disabled.
System log output interrupts ongoing configuration operations, including obscuring previously entered commands. Synchronous information output shows the obscured commands. It also provides a command prompt in command editing mode, or a [Y/N] string in interaction mode so you can continue your operation from where you were stopped.
# Enable synchronous information output, and then issue the display current-configuration command to view the current configuration of the device.
[Sysname] info-center synchronous
Info-center synchronous output is on
[Sysname] display current-
At this time, the system receives log information. It displays the log information first, and then displays your previous input, which is display current- in this example.
%May 21 14:33:19:425 2007 Sysname SHELL/4/LOGIN: VTY login from 192.168.1.44
Enter configuration to complete the display current-configuration command, and press the Enter key to execute the command.
# Enable synchronous information output, and then save the current configuration (enter interactive information).
[Sysname] save
The current configuration will be written to the device. Are you sure? [Y/N]:
At this time, the system receives the log information. It displays the log information first and then displays [Y/N].
[Y/N]:
Enter Y or N to complete your input.
info-center syslog min-age
Use info-center syslog min-age to set the minimum storage period for logs stored in the log buffer and log file.
Use undo info-center syslog min-age to restore the default.
info-center syslog min-age min-age
The log minimum storage period is not set.
min-age: Sets the log minimum storage period in hours. The value range is 1 to 8760.
When the log buffer or log file is full, new logs will automatically overwrite the oldest logs by default. After the minimum storage period is set, the system identifies the storage period of a log to determine whether to delete the log. The system current time minus a log's generation time is the log's storage period.
·     If the storage period of a log is shorter than or equal to the minimum storage period, the system does not delete the log. The new log will not be saved.
·     If the storage period of a log is longer than the minimum storage period, the system deletes the log to save the new log.
# Set the log minimum storage period to 168 hours.
[Sysname] info-center syslog min-age 168
info-center timestamp
Use info-center timestamp to configure the timestamp format for logs sent to the console, monitor terminal, log buffer, and log file.
Use undo info-center timestamp to restore the default.
The timestamp format for logs sent to the console, monitor terminal, log buffer, and log file is date.
boot: Sets the timestamp format to xxx.yyy, where xxx is the most significant 32 bits (in milliseconds) and yyy is the least significant 32 bits. For example, 0.21990989 equals Jun 25 14:09:26:881 2007. The boot time shows the time since system startup.
date: Sets the timestamp format to MMM DD hh:mm:ss:xxx YYYY, such as Dec  8 10:12:21:708 2007. The date time shows the current system time.
·     MMM: Abbreviations of the months in English, which could be Jan, Feb, Mar, Apr, May, Jun, Jul, Aug, Sep, Oct, Nov, or Dec.
·     DD: Date, starting with a space if it is less than 10, for example " 7".
·     hh:mm:ss:xxx: Local time, with hh in the range of 00 to 23, mm and ss in the range of 00 to 59, and xxx in the range of 0 to 999.
·     YYYY: Year.
none: Indicates no time information is provided.
# Set the timestamp format to boot for logs sent to the console, monitor terminal, log buffer, and log file.
[Sysname] info-center timestamp boot
info-center timestamp loghost
Use info-center timestamp loghost to configure the timestamp format for logs sent to a log host.
Use undo info-center timestamp loghost to restore the default.
info-center timestamp loghost { date | iso [ with-timezone ] | no-year-date | none }
The timestamp format for logs sent to a log host is date.
date: Sets the timestamp format to mmm dd hh:mm:ss yyyy, such as Dec  8 10:12:21 2007. The date time shows the current system time.
iso: Sets the ISO 8601 timestamp format, for example, 2009-09-21T15:32:55.
with-timezone: Includes the time zone in the timestamp. The time zone is in the format hh:mm, for example, 2013-04-12T19:20:50-04:00. If the system cannot get the time zone, Z is displayed, for example, 2013-04-12T23:20Z.
no-year-date: Sets the timestamp format to the current system date and time without year.
none: Indicates that no timestamp information is provided.
# Set the timestamp format to no-year-date for logs sent to log hosts.
[Sysname] info-center timestamp loghost no-year-date
info-center trace-logfile quota
Use info-center trace-logfile quota to set the maximum size of the trace log file.
Use undo info-center trace-logfile quota to restore the default.
The maximum size of the trace log file is 1 MB.
size: Specifies the maximum size of the trace log file, in the range of 1 to 10 MB.
# Set the maximum size to 6 MB for the trace log file.
[Sysname] info-center trace-logfile quota 6
logfile save
Use logfile save to manually save logs in the log file buffer to the log file.
logfile save
2: System level
You can specify the directory to save the log file with the info-center logfile directory command.
The system clears the log file buffer after saving logs from the log file buffer to the log file automatically or manually.
# Manually save logs from the log file buffer to the log file.
<Sysname> logfile save
The contents in the log file buffer have been saved to the file flash:/logfile/logfile.log.
·     info-center logfile enable
·     info-center logfile directory
reset logbuffer
Use reset logbuffer to clear the log buffer.
reset logbuffer
# Clear the log buffer.
<Sysname> reset logbuffer
display logbuffer
security-logfile save
Use security-logfile save to manually save security logs from the security log file buffer to the security log file.
security-audit
When this command is executed, the system displays a message that logs in the buffer have been saved to the security log file even if the security log file buffer does not contain security logs.
The system clears the security log file buffer after saving security logs to the security log file.
A local user can use this command only after being authorized as the security log administrator by the system administrator. For more information about security log administrator, see Security Configuration Guide.
# Manually save the security logs in the security log file buffer to the security log file.
<Sysname> security-logfile save
The contents in the security log file buffer have been saved to the file flash:/seclog/seclog.log.
·     info-center security-logfile directory
·     authorization-attribute (Security Command Reference)
terminal debugging
Use terminal debugging to enable the display of debug information on the current terminal.
Use undo terminal debugging to disable the display of debug information on the current terminal.
terminal debugging
The display of debug information is disabled on the current terminal.
To view debug information on the console, perform the following tasks:
1.     Execute the terminal debugging command.
2.     Enable the information center (enabled by default).
3.     Use a debugging command to enable the related debugging.
To view debug information on the monitor terminal, perform the following tasks:
1.     Execute the terminal monitor and terminal debugging commands.
The configuration of this command is only valid for the current connection between the terminal and the device. If a new connection is established, the default is restored.
You can also enable the display of debug information on the current terminal by executing the terminal logging level 7 command. This command has the following differences from the terminal debugging command:
·     The terminal logging level 7 command enables log display for all levels (levels 0 through 7) on the current terminal.
·     The terminal debugging command only enables log display for the debug level (level 7) and the levels that are higher than or equal to the severity level specified with the terminal logging level command.
# Enable the display of debug information on the current terminal.
<Sysname> terminal debugging
The current terminal is enabled to display debugging logs.
·     terminal logging level
·     terminal monitor
Use terminal logging level to set the lowest level of the logs that can be output to the current terminal.
Use undo terminal logging level to restore the default.
The lowest level of the logs that can be output to the current terminal is 6 (informational).
severity: Specifies the lowest level of the logs that can be output to the current terminal, in the range of 0 to 7.
If you specify the lowest level of the logs that can be output to the current terminal, the device outputs the logs with a severity level higher than or equal to the specified level. For example, if you set the lowest level of the logs that can be output to the current terminal to 6 (informational), logs with a severity value from 0 to 6 will be output.
The configuration of this command is valid for only the current connection between the terminal and the device. If a new connection is established, the display of logs on the terminal restores the default.
# Set the lowest level of the logs that can be output on the monitor terminal to 7 (Debug).
<Sysname> terminal logging level 7
terminal monitor
Use terminal monitor to enable the display of logs on the current terminal.
Use undo terminal monitor to disable the display of logs on the current terminal.
terminal monitor
Monitoring of logs is enabled on the console and disabled on the monitor terminal.
The configuration of this command is valid for only the current connection between the terminal and the device. If a new connection is established, the default is restored.
# Enable the display of logs on the current terminal.
<Sysname> terminal monitor
