- 12-Network Management and Monitoring Configuration Guide
- 02-NQA configuration
- 03-NTP configuration
- 04-SNMP configuration
- 05-RMON configuration
- 06-NETCONF configuration
- 07-Mirroring configuration
- 08-Sampler configuration
- 09-sFlow configuration
- 10-Information center configuration
- 11-EAA configuration
- 12-Process monitoring and maintenance configuration
- 13-Packet capture configuration
| 06-NETCONF configuration | 234.35 KB |
NETCONF configuration task list
Establishing a NETCONF session
Subscribing to event notifications
Example for subscribing to event notifications
Locking/unlocking the configuration
Example for locking the configuration
Performing the get/get-bulk operation
Performing the get-config/get-bulk-config operation
Performing the edit-config operation
Example for retrieving the configuration data for all modules
Example for retrieving the configuration data for the Syslog module
Example for retrieving a data entry for the interface table
Example for changing the value of a parameter
Saving, rolling back, and loading the configuration
Rolling back the configuration based on a configuration file
Rolling back the configuration based on a rollback point
Example for saving the configuration
Example for filtering data with regular expression match
Example for filtering data by conditional match
Performing CLI operations through NETCONF
Retrieving NETCONF session information·
Terminating another NETCONF session
Appendix A Supported NETCONF operations
Overview
Network Configuration Protocol (NETCONF) is an XML-based network management protocol with filtering capabilities. It provides programmable mechanisms to manage and configure network devices. Through NETCONF, you can configure device parameters, retrieve parameter values, and get statistics information.
In NETCONF messages, each data item is contained in a fixed element. This enables different devices of the same vendor to provide the same access method and the same result presentation method. For the devices of different vendors, XML mapping in NETCONF messages can achieve the same effect. For a network environment containing different devices regardless of vendors, you can develop a NETCONF-based NMS system to configure and manage devices in a simple and effective way.
NETCONF structure
NETCONF has four layers: content layer, operations layer, RPC layer, and transport protocol layer.
Table 1 NETCONF layers and XML layers
NETCONF layer |
XML layer |
Content |
Configuration data, status data, and statistics information |
The content layer contains a set of managed objects, which can be configuration data, status data, and statistics information. For information about the operable data, see the NETCONF XML API reference for the switch. |
Operations |
<get>,<get-config>,<edit-config>… |
The operations layer defines a set of base operations invoked as RPC methods with XML-encoded parameters. NETCONF base operations include data retrieval operations, configuration operations, lock operations, and session operations. For the device supported operations, see "Appendix A Supported NETCONF operations." |
RPC |
<rpc>,<rpc-reply> |
The RPC layer provides a simple, transport-independent framing mechanism for encoding RPCs. The <rpc> and <rpc-reply> elements are used to enclose NETCONF requests and responses (data at the operations layer and the content layer). |
Transport Protocol |
· In non-FIPS mode: · In FIPS mode: |
The transport protocol layer provides reliable, connection-oriented, and serial data links. In non-FIPS mode, you can log in through Telnet, SSH, or the console port to perform NETCONF operations at the CLI. You can also log in through HTTP or HTTPS to perform NETCONF operations in the Web interface or perform NETCONF-over-SOAP operations. In FIPS mode, all login methods are the same as in non-FIPS mode except that you cannot use Telnet or HTTP. |
NETCONF message format
NETCONF
IMPORTANT: When configuring NETCONF in XML view, you must add the end mark "]]>]]>" at the end of an XML message. Otherwise, the device cannot identify the message. Examples in this chapter do not have this end mark. Do add it in actual operations. |
All NETCONF messages are XML-based and comply with RFC 4741. Any incoming NETCONF messages must pass XML Schema check before it can be processed. If a NETCONF message fails XML Schema check, the device sends an error message to the client.
For information about the NETCONF operations supported by the device and the operable data, see the NETCONF XML API reference for the switch.
The following example shows a NETCONF message, which is used to get all parameters of all interfaces on the device.
<?xml version="1.0" encoding="utf-8"?>
<rpc message-id ="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<get-bulk>
<filter type="subtree">
<top xmlns="http://www.h3c.com/netconf/data:1.0">
<Ifmgr>
<Interfaces>
<Interface/>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get-bulk>
</rpc>
NETCONF over SOAP
All NETCONF-over-SOAP messages are XML-based and comply with RFC 4741. NETCONF messages are contained in the <Body> element of SOAP messages. NETCONF-over-SOAP messages also comply with the following rules:
· SOAP messages must use the SOAP Envelope namespaces.
· SOAP messages must use the SOAP Encoding namespaces.
· SOAP messages cannot contain DTD reference.
· SOAP messages cannot contain XML processing instructions.
The following example shows a NETCONF-over-SOAP message, which is used to get all parameters of all interfaces on the device.
<env:Envelope xmlns:env="http://www.w3.org/2003/05/soap-envelope">
<env:Header>
<auth:Authentication env:mustUnderstand="1" xmlns:auth="http://www.h3c.com/netconf/base:1.0">
<auth:AuthInfo>800207F0120020C</auth:AuthInfo>
</auth:Authentication>
</env:Header>
<env:Body>
<get-bulk>
<Ifmgr>
<Interfaces>
<Interface/>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get-bulk>
</rpc>
</env:Body>
</env:Envelope>
How to use NETCONF
You can use NETCONF to manage and configure the device by using the methods in Table 2.
Table 2 NETCONF methods for configuring the device
Configuration tool |
Login method |
Remarks |
CLI |
· Console port · SSH · Telnet |
To implement NETCONF operations, copy valid NETCONF messages to the CLI in XML view. This method is suitable for R&D and test purposes. |
Standard Web interface for the device |
· In non-FIPS mode: ¡ HTTP ¡ HTTPS · In FIPS mode: |
The system automatically converts the configuration operations on the Web interface to NETCONF messages and sends them to the device to implement NETCONF operations. This method is the most commonly used method. |
Custom Web interface |
N/A |
To use this method, you must enable NETCONF over SOAP. By default, the device cannot interpret Custom Web interfaces' URLs. For the device to interpret these URLs, you must encode the NETCONF messages sent from a custom Web interface in SOAP. |
Protocols and standards
· RFC 3339, Date and Time on the Internet: Timestamps
· RFC 4741, NETCONF Configuration Protocol
· RFC 4742, Using the NETCONF Configuration Protocol over Secure SHell (SSH)
· RFC 4743, Using NETCONF over the Simple Object Access Protocol (SOAP)
· RFC 5277, NETCONF Event Notifications
· RFC 5381, Experience of Implementing NETCONF over SOAP
· RFC 5539, NETCONF over Transport Layer Security (TLS)
· RFC 6241, Network Configuration Protocol
FIPS compliance
The device supports the FIPS mode that complies with NIST FIPS 140-2 requirements. Support for features, commands, and parameters might differ in FIPS mode (see Security Configuration Guide) and non-FIPS mode.
Task at a glance |
(Optional.) Enabling NETCONF over SOAP |
(Optional.) Enabling NETCONF over SSH |
(Required.) Establishing a NETCONF session |
(Optional.) Subscribing to event notifications |
(Optional.) Locking/unlocking the configuration |
(Optional.) Performing the get/get-bulk operation |
(Optional.) Performing the get-config/get-bulk-config operation |
(Optional.) Performing the edit-config operation |
(Optional.) Saving, rolling back, and loading the configuration |
(Optional.) Filtering data |
(Optional.) Performing CLI operations through NETCONF |
(Optional.) Retrieving NETCONF session information |
(Optional.) Terminating another NETCONF session |
(Optional.) Returning to the CLI |
NETCONF messages can be encapsulated into SOAP messages and transmitted over HTTP and HTTPS. After enabling NETCONF over SOAP, you can develop Web configuration interface to perform NETCONF operations.
To enable NETCONF over SOAP:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enable NETCONF over SOAP. |
· Enable NETCONF over SOAP over HTTP (not available
in FIPS mode): · Enable NETCONF over SOAP over HTTPS: |
By default, the NETCONF over SOAP feature is disabled. |
This feature allows users to use a client to perform NETCONF operations on the device through a NETCONF-over-SSH connection.
To enable NETCONF over SSH:
Step |
Command |
Remark |
system-view |
N/A |
2. Specify a port to listen for NETCONF-over-SSH connections. |
netconf ssh server port port-number |
By default, port 830 listens for NETCONF-over-SSH connections. |
3. Enable NETCONF over SSH. |
netconf ssh server enable |
By default, NETCONF over SSH is disabled. |
A client must send a hello message to a device to finish capabilities exchange before the device processes other requests from the client.
You can use the aaa session-limit command (see Security Command Reference) to set the maximum number of NETCONF sessions that the device can support. If the upper limit is reached, new NETCONF users cannot access the device.
Entering XML view
Task |
Command |
Enter XML view. |
xml |
Available in user view. |
Exchanging capabilities
After you enter XML view, the client and the device exchange their capabilities before you can perform subsequent operations. The device automatically advertises its NETCONF capabilities to the client in a hello message as follows:
<?xml version="1.0" encoding="UTF-8"?><hello xmlns="urn:ietf:params:xml:ns:netconf:base:1.0"><capabilities><capability>urn:ietf:params:netconf:base:1.1</capability><capability>urn:ietf:params:netconf:writable-running</capability><capability>urn:ietf:params:netconf:capability:notification:1.0</capability><capability>urn:ietf:params:netconf:capability:validate:1.1</capability><capability>urn:ietf:params:netconf:capability:interleave:1.0</capability><capability>urn:ietf:params:netconf:capability:h3c-netconf-ext:1.0</capability></capabilities><session-id>1</session-id></hello>]]>]]>
Where:
· The <capabilities> parameter represents the capabilities supported by the device.
· The <session-id> parameter represents the ID assigned to the current session. The ID uniquely identifies the session.
After receiving the hello message from the device, copy the following message to notify the device of the capabilities (user-configurable) supported by the client:
<capabilities>
<capability>
capability-set
</capability>
</capabilities>
</hello>
Where, capability-set represents the capabilities supported by the client. Use a pair of <capability> and </capability> tags to enclose a capability.
After you subscribe to event notifications, the device sends event notifications to the NETCONF client when a subscribed event takes place on the device. The notifications include the code, group, severity, start time, and description of the events. The device supports only log subscription. For information about which event notifications you can subscribe to, see the system log messages reference for the switch.
A subscription takes effect only on the current session. If the session is terminated, the subscription is automatically canceled.
You can send multiple subscription messages to subscribe to notification of multiple events.
Subscription procedure
# Copy the following message to the client to complete the subscription:
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<create-subscription xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
<stream>NETCONF</stream>
<filter>
<event xmlns="http://www.h3c.com/netconf/event:1.0">
<Code>code</Code>
<Group>group</Group>
<Severity>severity</Severity>
</event>
</filter>
<startTime>start-time</startTime>
<stopTime>stop-time</stopTime>
</create-subscription>
</rpc>
Where:
· The <stream> parameter represents the event stream type supported by the device. Only NETCONF is supported.
· The <event> parameter represents an event to which you have subscribed.
· The <code> parameter represents a mnemonic symbol.
· The <group> parameter represents the module name.
· The <severity> parameter represents the severity level of the event.
· The <start-time> parameter represents the start time of the subscription.
· The <stop-time> argument represents the end time of the subscription.
After receiving the subscription request from the client, the device returns a response in the following format if the subscription is successful:
<rpc-reply message-id="101" xmlns:netconf="urn:ietf:params:xml:ns:netconf:base:1.0">
<ok/>
</rpc-reply>
If the subscription fails, the device returns an error message in the following format:
<rpc-reply message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<rpc-error>
<error-type>error-type</error-type>
<error-tag>error-tag</error-tag>
<error-severity>error-severity</error-severity>
<error-message xml:lang="en">error-message</error-message>
</rpc-error>
</rpc-reply>
For more information about error messages, see RFC 4741.
Network requirements
Configure a client to subscribe to all events with no time limitation. After the subscription is successful, all events on the device are sent to the client before the session between the device and client is terminated.
Configuration procedure
# Enter XML view.
<Sysname> xml
# Exchange capabilities.
<capabilities>
<capability>
urn:ietf:params:netconf:base:1.0
</capability>
</capabilities>
</hello>
# Subscribe to all events with no time limitation.
<create-subscription xmlns ="urn:ietf:params:xml:ns:netconf:notification:1.0">
</rpc>
# If the client receives the following response, the subscription is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="101">
<ok/>
</rpc-reply>
# If fan 1 on the device encounters problems, the device sends the following text to the client that has subscribed to all events:
<notification xmlns="urn:ietf:params:xml:ns:netconf:notification:1.0">
<eventTime>2011-01-04T12:30:46</eventTime>
<Group>DEV</Group>
<Code>FAN_DIRECTION_NOT_PREFERRED</Code>
<Slot>6</Slot>
<Severity>Alert</Severity>
<context>Fan 1 airflow direction is not preferred on slot 6, please check it.</context>
</event>
</notification>
# When another client (192.168.100.130) logs in to the device, the device sends a notification to the client that has subscribed to all events:
<eventTime>2011-01-04T12:30:52</eventTime>
<Group>SHELL</Group>
<Code>SHELL_LOGIN</Code>
<Slot>6</Slot>
<Severity>Notification</Severity>
<context>VTY logged in from 192.168.100.130.</context>
</event>
</notification>
The device supports up to five NETCONF sessions. Up to five users can simultaneously manage and monitor the device using NETCONF. During device configuration and maintenance or network troubleshooting, a user can lock the configuration to prevent other users from changing it. After that, only the user holding the lock can change the configuration, and other users can only read the configuration.
In addition, only the user holding the lock can release the lock. After the lock is released, other users can change the current configuration or lock the configuration. If the session of the user that holds the lock is terminated, the system automatically releases the lock.
Locking the configuration
# Copy the following text to the client to lock the configuration:
<lock>
<target>
<running/>
</target>
</lock>
</rpc>
After receiving the lock request, the device returns a response in the following format if the lock operation is successful:
<ok/>
</rpc-reply>
Unlocking the configuration
# Copy the following text to the client to unlock the configuration:
<unlock>
<target>
<running/>
</target>
</unlock>
</rpc>
After receiving the unlock request, the device returns a response in the following format if the unlock operation is successful:
<ok/>
</rpc-reply>
Lock the device configuration so that other users cannot change the device configuration.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Lock the configuration.
<lock>
<target>
<running/>
</target>
</lock>
</rpc>
If the client receives the following response, the lock operation is successful:
<ok/>
</rpc-reply>
If another client sends a lock request, the device returns the following response:
<rpc-error>
<error-type>protocol</error-type>
<error-tag>lock-denied</error-tag>
<error-severity>error</error-severity>
<error-message xml:lang="en">Lock failed, lock is already held.</error-message>
<error-info>
</error-info>
</rpc-error>
</rpc-reply>
The output shows that the lock operation failed because the client with session ID 1 held the lock, and only the client holding the lock can release the lock.
Performing service operations
You can use NETCONF to perform service operations on the device, such as retrieving and modifying the specified information. The basic operations include get, get-bulk, get-config, get-bulk-config, and edit-config, which are used to retrieve all data, retrieve configuration data, and edit the data of the specified module. For more information, see NETCONF XML API reference for the switch.
The get operation is used to retrieve device configuration and state information that match the conditions. In some cases, this operation leads to inefficiency.
The get-bulk operation is used to retrieve a number of data entries starting from the data entry next to the one with the specified index. One data entry contains a device configuration entry and a state information entry. The data entry quantity is defined by the count attribute, and the index is specified by the index attribute. The returned output does not include the index information. If you do not specify the index attribute, the index value starts with 1 by default.
If either of the following occurs, the operation retrieves all the rest data entries starting from the data entry next to the one with the specified index:
· You do not specify the count attribute.
· The number of matched data entries is less than the value of the count attribute.
# Copy the following text to the client to perform the get operation.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<getoperation>
<filter>
Specify the module, submodule, table name, and column name
</top>
</filter>
</getoperation>
</rpc>
Where, the <getoperation> parameter can be <get> or <get-bulk>. The <filter> element is used to filter data, and it can contain module name, submodule name, table name, and column name.
· If the module name and the submodule name are not provided, the operation retrieves the data for all modules and submodules. If a module name or a submodule name is provided, the operation retrieves the data for the specified module or submodule.
· If the table name is not provided, the operation retrieves the data for all tables. If a table name is provided, the operation retrieves the data for the specified table.
· If only the index column is provided, the operation retrieves the data for all columns. If the index column and other columns are provided, the operation retrieves the data for the index column and the specified columns.
The <get> and <get-bulk> messages are similar. A <get-bulk> message carries the count and index attributes. The following is a <get-bulk> message example:
<rpc message-id ="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:xc="http://www.h3c.com/netconf/base:1.0">
<get-bulk>
<top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:base="http://www.h3c.com/netconf/base:1.0">
<Syslog>
<Logs xc:count="5">
<Log>
<Index>10</Index>
</Log>
</Logs>
</Syslog>
</top>
</filter>
</get-bulk>
</rpc>
Where, the count attribute complies with the following rules:
· The count attribute can be placed in the module node and table node. In other nodes, it cannot be resolved.
· When the count attribute is placed in the module node, a descendant node inherits this count attribute if the descendant node does not contain the count attribute.
After receiving the get-bulk request, the device returns a response in the following format if the operation is successful:
<?xml version="1.0"?>
<rpc-reply message-id="100"
<data>
Device state and configuration data
</data>
</rpc-reply>
The get-config and get-bulk-config operations are used to retrieve all non-default configurations, which are configured by means of CLI, MIB, and Web. The <get-config> and <get-bulk-config> messages can contain the <filter> element for filtering data.
The <get-config> and <get-bulk-config> messages are similar. The following is a <get-config> message example:
<get-config>
<source>
<running/>
</source>
<filter>
<top xmlns="http://www.h3c.com/netconf/config:1.0">
Specify the module name, submodule name, table name, and column name
</top>
</filter>
</get-config>
</rpc>
After receiving the get-config request, the device returns a response in the following format if the operation is successful:
<rpc-reply message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<data>
All data matching the specified filter
</data>
</rpc-reply>
The edit-config operation supports the following operation attributes: merge, create, replace, remove, delete, default-operation, error-option, and test-option. For more information about these attributes, see "Appendix A Supported NETCONF operations."
# Copy the following text to perform the <edit-config> operation.
<edit-config>
<target><running></running></target>
<error-option>
Default operation when an error occurs
</error-option>
<config>
</top>
</config>
</edit-config>
</rpc>
After receiving the edit-config request, the device returns a response in the following format if the operation is successful:
<?xml version="1.0">
<ok/>
</rpc-reply>
Retrieve configuration data for all modules.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Retrieve configuration data for all modules.
<get-config>
<source>
<running/>
</source>
</get-config>
</rpc>
If the client receives the following text, the get-config operation is successful:
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:web="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="101">
<data>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex>1307</IfIndex>
<Shutdown>1</Shutdown>
</Interface>
<Interface>
<IfIndex>1308</IfIndex>
</Interface>
<Interface>
<IfIndex>1309</IfIndex>
</Interface>
<Interface>
<IfIndex>1311</IfIndex>
<VlanType>2</VlanType>
</Interface>
<Interface>
<IfIndex>1313</IfIndex>
</Interface>
</Interfaces>
</Ifmgr>
<Syslog>
<LogBuffer>
<BufferSize>120</BufferSize>
</LogBuffer>
</Syslog>
<System>
<Device>
<SysName>H3C</SysName>
<TimeZone>
<Zone>+11:44</Zone>
<ZoneName>beijing</ZoneName>
</TimeZone>
</Device>
</System>
<Fundamentals>
<WebUI>
<SessionAgingTime>98</SessionAgingTime>
</WebUI>
</Fundamentals>
</top>
</data>
</rpc-reply>
Retrieve configuration data for the Syslog module.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Retrieve configuration data for the Syslog module.
<get-config>
<source>
<running/>
</source>
<Syslog/>
</top>
</filter>
</get-config>
</rpc>
<data>
<Syslog>
<LogBuffer>
</LogBuffer>
</Syslog>
</top>
</data>
</rpc-reply>
Retrieve a data entry for the interface table.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>urn:ietf:params:netconf:base:1.0</capability>
</capabilities>
</hello>
# Retrieve a data entry for the interface table.
<rpc message-id="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:web="urn:ietf:params:xml:ns:netconf:base:1.0">
<get-bulk>
<top xmlns="http://www.h3c.com/netconf/data:1.0" xmlns:web="http://www.h3c.com/netconf/base:1.0">
<Ifmgr>
<Interfaces web:count="1">
</Interfaces>
</Ifmgr>
</top>
</filter>
</get-bulk>
</rpc>
If the client receives the following text, the get-bulk operation is successful:
<data>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex>1302</IfIndex>
<Name>GigabitEthernet6/0/2</Name>
<AbbreviatedName>GE6/0/2</AbbreviatedName>
<PortIndex>3</PortIndex>
<ifTypeExt>22</ifTypeExt>
<ifType>6</ifType>
<Description>GigabitEthernet6/0/2 Interface</Description>
<AdminStatus>2</AdminStatus>
<OperStatus>2</OperStatus>
<ConfigSpeed>0</ConfigSpeed>
<ActualSpeed>100000</ActualSpeed>
<ConfigDuplex>3</ConfigDuplex>
<ActualDuplex>1</ActualDuplex>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</data>
</rpc-reply>
Change the log buffer size for the Syslog module to 512.
# Enter XML view.
<Sysname> xml
<capabilities>
</capabilities>
</hello>
# Change the log buffer size for the Syslog module to 512.
<edit-config>
<target>
<running/>
</target>
<config>
<top xmlns="http://www.h3c.com/netconf/config:1.0" web:operation="merge">
<Syslog>
<LogBuffer>
<BufferSize>512</BufferSize>
</LogBuffer>
</Syslog>
</top>
</config>
</edit-config>
</rpc>
If the client receives the following text, the edit-config operation is successful:
<ok/>
</rpc-reply>
Use NETCONF to save, roll back, or load the configuration.
Saving the configuration
# Copy the following text to the client to save the device configuration to a specified file:
<save AllMDC="false">
<file>Specify the configuration file name</file>
</save>
</rpc>
The name of the specified configuration file must start with the storage media name and end with the extension (.cfg). If the file name is not specified, the configuration is saved to the main next-startup configuration file by default.
If AllMDC is set to true in the management MDC, the configuration of each MDC is separately saved in the specified file. If AllMDC is not specified, only the configuration of the current MDC is saved. This attribute takes effect on only the management MDC.
After receiving the save request, the device returns a response in the following format if the save operation is successful:
<ok/>
</rpc-reply>
# Copy the following text to the client to roll back the configuration:
<rollback>
</rollback>
</rpc>
After receiving the rollback request, the device returns a response in the following format if the rollback operation is successful:
<ok/>
</rpc-reply>
This feature allows the device to roll back the configuration based on a rollback point when one of the following situations occurs:
· A NETCONF client sends a rollback request.
· A NETCONF client stays idle longer than the rollback idle timeout time.
· A NETCONF client is disconnected from the device.
NOTE: NETCONF uses the save-point operation to configure a rollback point. |
To roll back the configuration based on a rollback point, perform the following tasks:
1. Lock the system.
Multiple users might simultaneously use NETCONF to configure the device. To prevent other users from modifying the running configuration, H3C recommends that you lock the system before rolling back the configuration.
2. Configure a rollback point. For more information, see "Performing the save-point/begin operation."
3. Edit the device configuration. For more information, see "Performing the edit-config operation."
4. Accept the configuration or roll back the configuration based on the rollback point. For more information, see "Performing the save-point/commit operation" or"Performing the save-point/rollback operation."
The configuration can also be rolled back automatically when the NETCONF session idle time exceeds the rollback idle timeout time.
5. Release the lock.
# Copy the following text to the client to configure a rollback point:
<save-point>
<begin>
<confirm-timeout>100</confirm-timeout>
</begin>
</save-point>
</rpc>
Where, the <confirm-timeout> parameter specifies the rollback idle timeout time in the range of 1 to 65536 seconds (the default is 600 seconds). This parameter is optional.
A NETCONF session can have only one rollback point. To change a rollback point for a session, you must perform one of the following tasks:
· Delete the rollback point and reconfigure it.
· Configure a new rollback point after the rollback idle timeout time expires.
After receiving the save-point request, the device returns a response in the following format if the rollback point is successfully configured:
<ok></ok>
</rpc-reply>
<save-point>
<rollback>
</rollback>
</save-point>
</rpc>
<ok></ok>
</rpc-reply>
# Copy the following text to the client to accept the configuration:
<save-point>
<commit>
</commit>
</save-point>
</rpc>
After receiving the commit request, the device returns a response in the following format if the commit operation is successful:
<ok></ok>
</rpc-reply>
Loading the configuration
After you perform the load operation, the loaded configurations are merged into the current configuration:
· New configurations are directly loaded.
· Configurations that already exist in the current configuration are replaced by those loaded from the configuration file.
# Copy the following text to the client to load a configuration file for the device:
<load>
</load>
</rpc>
After receiving the load request, the device returns a response in the following format if the load operation is successful:
<ok/>
</rpc-reply>
Save the current configuration to the configuration file my_config.cfg.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Save the configuration of the device to the configuration file my_config.cfg.
<save>
<file> my_config.cfg</file>
</save>
</rpc>
If the client receives the following response, the save operation is successful:
<ok/>
</rpc-reply>
Filtering data
When you perform a get, get-bulk, get-config, or get-bulk-config operation, you can add the <filter> parameter to define a filter, so you can retrieve only the information of interest. Data filtering mechanisms include full match, regular expression match, and conditional match. The full match has the highest priority and the conditional match has the lowest priority. When more than one filtering criteria is specified, the one with the highest priority takes effect.
· Full match
You can specify an element value in an XML message to implement full match. If multiple element values are provided, the system returns the data matching all the specified values.
# Copy the following text to the client to retrieve the configuration data of all interfaces in UP state.
<rpc message-id ="101" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0">
<get>
<Ifmgr>
<Interfaces>
<Interface>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get>
</rpc>
You can also specify an attribute name that is the same as a column name of the current table at the row to implement full match. The system returns only configuration data that matches this attribute name. The XML message equivalent to the above element-value-based full match is as follows:
<get>
<top xmlns="http://www.h3c.com/netconf/data:1.0"xmlns:data=" http://www.h3c.com/netconf/data:1.0">
<Ifmgr>
<Interfaces>
<Interface data:AdminStatus="2" />
</Interfaces>
</Ifmgr>
</top>
</filter>
</get>
</rpc>
The above examples show that both element-value-based full match and attribute-name-based full match can retrieve the same configuration data for all interfaces in UP state.
· Regular expression match
To implement a complex data filtering with characters, you can add a regExp attribute for a specific element.
# Copy the following text to the client to retrieve the descriptions of interfaces, of which all the characters must be upper-case letters from A to Z.
<rpc message-id="1-0" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0" >
<get-config>
<source>
<running/>
</source>
<Ifmgr>
<Interfaces>
<Interface>
<Description h3c:regExp="^[A-Z]*$" />
</Interface>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get-config>
</rpc>
· Conditional match
To implement a complex data filtering with digits and character strings, you can add a match attribute for a specific element. Table 3 lists the conditional match operators.
Table 3 Conditional match operators
Operation |
Operator |
Remarks |
More than |
match="more:value" |
More than the specified value. The supported data types include date, digit, and character string. |
Less than |
match="less:value" |
Less than the specified value. The supported data types include date, digit, and character string. |
Not less than |
match="notLess:value" |
Not less than the specified value. The supported data types include date, digit, and character string. |
Not more than |
match="notMore:value" |
Not more than the specified value. The supported data types include date, digit, and character string. |
Equal |
match="equal:value" |
Equal to the specified value. The supported data types include date, digit, character string, OID, and BOOL. |
Not equal |
match="notEqual:value" |
Not equal to the specified value. The supported data types include date, digit, character string, OID, and BOOL. |
Include |
match="include:string" |
Includes the specified string. The supported data types include only character string. |
Not include |
match="exclude:string" |
Excludes the specified string. The supported data types include only character string. |
Start with |
match="startWith:string" |
Starts with the specified string. The supported data types include character string and OID. |
End with |
match="endWith:string" |
Ends with the specified string. The supported data types include only character string. |
# Copy the following text to the client to retrieve extension information about the entity whose CPU usage is more than 50%.
<rpc message-id="100" xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:h3c="http://www.h3c.com/netconf/base:1.0" >
<get>
<Device>
<ExtPhysicalEntities>
<Entity>
<CpuUsage h3c:match="more:50"></CpuUsage>
</Entity>
</Device >
</top>
</filter>
</get>
</rpc>
Retrieve all data including colons in the Description column of the Interfaces table under the Ifmgr module.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Retrieve all data including colons in the Description column of the Interfaces table under the Ifmgr module.
xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:reg="http://www.h3c.com/netconf/base:1.0">
<get>
<Ifmgr>
<Interfaces>
<Interface>
<Description reg:regExp=":" />
</Interface>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get>
</rpc>
If the client receives the following text, the operation is successful.
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:reg="http://www.h3c.com/netconf/base:1.0" message-id="100">
<data>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex>2681</IfIndex>
<Description>Ten-GigabitEthernet6/0/49:1 Interface</Description>
</Interface>
<Interface>
<IfIndex>2682</IfIndex>
<Description>Ten-GigabitEthernet6/0/49:2 Interface</Description>
</Interface>
<Interface>
<IfIndex>2683</IfIndex>
<Description>Ten-GigabitEthernet6/0/49:3 Interface</Description>
</Interface>
<Interface>
<IfIndex>2684</IfIndex>
<Description>Ten-GigabitEthernet6/0/49:4 Interface</Description>
</Interface>
<Interface>
<IfIndex>2685</IfIndex>
<Description>Ten-GigabitEthernet6/0/50:1 Interface</Description>
</Interface>
<Interface>
<IfIndex>2686</IfIndex>
<Description>Ten-GigabitEthernet6/0/50:2 Interface</Description>
</Interface>
<Interface>
<IfIndex>2687</IfIndex>
<Description>Ten-GigabitEthernet6/0/50:3 Interface</Description>
</Interface>
<Interface>
<IfIndex>2688</IfIndex>
<Description>Ten-GigabitEthernet6/0/50:4 Interface</Description>
</Interface>
<Interface>
<IfIndex>2689</IfIndex>
<Description>Ten-GigabitEthernet6/0/51:1 Interface</Description>
</Interface>
<Interface>
<IfIndex>2690</IfIndex>
<Description>Ten-GigabitEthernet6/0/51:2 Interface</Description>
</Interface>
<Interface>
<IfIndex>2691</IfIndex>
<Description>Ten-GigabitEthernet6/0/51:3 Interface</Description>
</Interface>
<Interface>
<IfIndex>2692</IfIndex>
<Description>Ten-GigabitEthernet6/0/51:4 Interface</Description>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</data>
</rpc-reply>
Retrieve data in the Name column with the ifindex value not less than 5000 in the Interfaces table under the Ifmgr module.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Retrieve data in the Name column with the ifindex value not less than 5000 in the Interfaces table under the Ifmgr module.
xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="http://www.h3c.com/netconf/base:1.0">
<get>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex nc:match="more:5000"/>
<Name/>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</filter>
</get>
</rpc>
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" xmlns:nc="http://www.h3c.com/netconf/base:1.0" message-id="100">
<data>
<Ifmgr>
<Interfaces>
<Interface>
<IfIndex>7241</IfIndex>
<Name>NULL0</Name>
</Interface>
<Interface>
<IfIndex>7243</IfIndex>
<Name>Register-Tunnel0</Name>
</Interface>
</Interfaces>
</Ifmgr>
</top>
</data>
</rpc-reply>
You can enclose command lines in XML messages to configure the device.
# Copy the following text to the client to execute the commands:
<CLI>
<Execution>
Commands
</Execution>
</CLI>
</rpc>
The <Execution> element can contain multiple commands, with one command on one line.
After receiving the CLI operation request, the device returns a response in the following format if the CLI operation is successful:
<CLI>
<Execution>
<![CDATA[Responses to the commands]]>
</Execution>
</CLI>
</rpc-reply>
CLI operation example
Configuration requirements
Send the display current-configuration command to the device.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Copy the following text to the client to execute the display current-configuration command.
<CLI>
<Execution>
</Execution>
</CLI>
</rpc>
<CLI>
<Execution><![CDATA[
version 7.1.052, Demo 2501005,
sysname ab
ftp server enable
ftp update fast
ftp timeout 2000
irf mac-address persistent timer
irf auto-update enable
undo irf link-delay
domain default enable system
telnet server enable
vlan 1
vlan 1000
radius scheme system
primary authentication 127.0.0.1 1645
</Execution>
</CLI>
</rpc-reply>
You can use the get-sessions operation to retrieve NETCONF session information of the device.
# Copy the following message to the client to retrieve NETCONF session information from the device:
<get-sessions/>
</rpc>
After receiving the get-sessions request, the device returns a response in the following format if the get-sessions operation is successful:
<get-sessions>
<Session>
<SessionID>Configuration session ID </SessionID>
<Line>line information</Line>
<UserName>Name of the use creating the session</UserName>
<Since>Time when the session was created</Since>
<LockHeld>Whether the session holds a lock</LockHeld>
</Session>
</get-sessions>
</rpc-reply>
For example, to get NETCONF session information:
# Enter XML view.
<Sysname> xml
# Copy the following message to the client to exchange capabilities with the device.
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Copy the following message to the client to get the current NETCONF session information on the device.
<get-sessions/>
</rpc>
If the client receives a message as follows, the operation is successful:
<get-sessions>
<Session>
<SessionID>1</SessionID>
<Line>vty0</Line>
<UserName></UserName>
<Since>2011-01-05T00:24:57</Since>
<LockHeld>false</LockHeld>
</Session>
</get-sessions>
</rpc-reply>
· The session ID of an existing NETCONF session is 1.
· The login user type is vty0.
· The login time is 2011-01-05T00:24:57.
· The user does not hold the lock of the configuration.
NETCONF allows one client to terminate the NETCONF session of another client. The client whose session is terminated returns to user view.
# Copy the following message to the client to terminate the specified NETCONF session:
<kill-session>
<session-id>
Specified session-ID
</session-id>
</kill-session>
</rpc>
After receiving the kill-session request, the device returns a response in the following format if the kill-session operation is successful:
<ok/>
</rpc-reply>
Configuration example
The user whose session ID is 1 terminates the session with session ID 2.
# Enter XML view.
<Sysname> xml
<capabilities>
<capability>
</capability>
</capabilities>
</hello>
# Terminate the session with session ID 2.
<kill-session>
<session-id>2</session-id>
</kill-session>
</rpc>
If the client receives the following text, the NETCONF session with session ID 2 has been terminated, and the client with session ID 2 has returned from XML view to user view:
<ok/>
</rpc-reply>
To return from XML view to the CLI, copy the following message to the client:
<close-session/>
</rpc>
After the device receives the close-session request, it sends the following response and returns to CLI's user view:
<ok/>
</rpc-reply>
Comware V7 platform made some modification to the NETCONF protocol: delete some uncommon operations and add some operations. Table 4 lists the supported NETCONF operations.
Operation |
XML example |
get |
Retrieves device configuration and state information. |
To retrieve device configuration and state information for the Syslog module: |
get-config |
Retrieves the non-default configuration data. If non-default configuration data does not exist, the device returns a response with empty data. |
To retrieve non-default configuration data for the interface table: |
get-bulk |
Retrieves a number of data entries (including device configuration and state information) starting from the data entry next to the one with the specified index. |
To retrieve device configuration and state information for all interface: |
get-bulk-config |
Retrieves a number of non-default configuration data entries starting from the data entry next to the one with the specified index. |
To retrieve non-default configuration for all interfaces: |
edit-config: merge |
Changes the running configuration. To use the merge attribute in the edit-config operation, you must specify the operation target (on a specified level): · If the specified target exists, the operation directly changes the configuration for the target. · If the specified target does not exist, the operation creates and configures the target. · If the specified target does not exist and it cannot be created, an error message is returned. |
To change the buffer size to 120: |
edit-config: create |
Creates a specified target. To use the create attribute in the edit-config operation, you must specify the operation target. · If the table supports target creation and the specified target does not exist, the operation creates and then configures the target. · If the specified target exists, a data-exist error message is returned. |
The XML data format is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to create. |
edit-config: replace |
Replaces the specified target. · If the specified target exists, the operation replaces the configuration of the target with the configuration carried in the message. · If the specified target does not exist but is allowed to be created, create the target and then apply the configuration of the target. · If the specified target does not exist and is not allowed to be created, the operation is not conducted and an invalid-value error message is returned. |
The syntax is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to replace. |
edit-config: remove |
Removes the specified configuration. · If the specified target has only the table index, the operation removes all configuration of the specified target, and the target itself. · If the specified target has the table index and configuration data, the operation removes the specified configuration data of this target. · If the specified target does not exist, or the XML message does not specify any target, a success message is returned. |
The syntax is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to remove. |
edit-config: delete |
Deletes the specified configuration. · If the specified target has only the table index, the operation removes all configuration of the specified target, and the target itself. · If the specified target has the table index and configuration data, the operation removes the specified configuration data of this target. · If the specified target does not exist, an error message is returned, showing that the target does not exist. |
The syntax is the same as the edit-config message with the merge attribute. Change the operation attribute from merge to delete. |
edit-config: default-operation |
Modifies the current configuration of the device using the default operation method. If you do not specify an operation attribute for an edit-config message, NETCONF uses one of the following default operation attributes: merge, create, delete, and replace. Your setting of the value for the <default-operation> element takes effect only once. If you do not specify an operation attribute and the default operation method for an <edit-config> message, merge is always applied. · merge—This is the default value for the <default-operation> element. · replace—This value is used when the operation attribute is not specified and the default operation method is specified as replace. · none—This value is used when the operation attribute is not specified and the default operation method is specified as none. If this value is specified, the edit-config operation is used only for schema verification rather than issuing a configuration. If the schema verification is passed, a successful message is returned. Otherwise, an error message is returned. |
To issue an empty operation for schema verification purposes: |
edit-config: error-option |
Determines the action to take in case of a configuration error. The error-option element has one of the following values: · stop-on-error—Stops the operation on error and returns an error message. This is the default error-option value. · continue-on-error—Continues the operation on error and returns an error message. · rollback-on-error—Rolls back the configuration. |
To issue the configuration for two interfaces with the error-option element value as continue-on-error: |
edit-config: test-option |
Determines whether to issue a configuration item in the edit-configure operation. The test-option element has one of the following values: · test-then-set—Performs a validation test before attempting to set. If the validation test fails, the edit-config operation is not performed. This is the default test-option value. · set—Directly performs the set operation without the validation test. · test-only—Performs only a validation test without attempting to set. If the validation test succeeds, a successful message is returned. Otherwise, an error message is returned. |
To issue the configuration for an interface for test purposes: |
action |
Issues actions that are not for configuring data, for example, reset action. |
To clear statistics information for all interfaces: |
lock |
Locks the configuration data that are made through NETCONF sessions. The configuration data can be changed by the edit-config operation. Other configurations are not limited by the lock operation. This lock operation does not lock configuration data made through other protocols, for example, SNMP. |
To lock the configuration: |
unlock |
Unlocks the configuration, so NETCONF sessions can change device configuration. When a NETCONF session is terminated, the related locked configuration is also unlocked. |
To unlock the configuration: |
get-sessions |
Retrieves information about all NETCONF sessions in the system. |
To retrieve information about all NETCONF sessions in the system: |
close-session |
Terminates the NETCONF session for the current user, to unlock the configuration and release the resources (for example, memory) of this session. This operation logs the current user off the XML view. |
To terminate the NETCONF session for the current user: |
kill-session |
Terminates the NETCONF session for another user. This operation cannot terminate the NETCONF session for the current user. |
To terminate the NETCONF session with session-id 1: |
CLI |
Executes CLI operations. A request message encloses commands in the <CLI> element, and a response message encloses the command output in the <CLI> element. NETCONF supports the following views: · Execution—User view · Configuration—System view To execute a command in other views, specify the command for entering the specified view, and then the desired command. |
To execute the display this command in system view: |
save |
Saves the running configuration. You can use the <file> element to specify a file for saving the configuration. If you do not specify a file, the running configuration is saved to the main next-startup configuration file. The AllMDC attribute specifies that all MDC configurations are saved. It applies to only the management MDC. |
To save the running configuration to the file test.cfg: |
load |
Loads the configuration. After the device finishes the load operation, the configuration in the specified file is merged into the current configuration of the device. |
To merge the configuration in the file a1.cfg to the current configuration of the device: |
rollback |
Rolls back the configuration. To do so, you must specify the configuration file in the <file> element. After the device finishes the rollback operation, the current device configuration is totally replaced with the configuration in the specified configuration file. |
To roll back the current configuration to the configuration in the file 1A.cfg: |
