- 11-High Availability Configuration Guide
- 01-High Availability Overview
- 02-Ethernet OAM configuration
- 03-DLDP configuration
- 04-RRPP configuration
- 05-Smart Link configuration
- 06-Monitor Link configuration
- 07-VRRP configuration
- 08-BFD configuration
- 09-Track configuration
- 10-Process placement configuration
| 05-Smart Link configuration | 232.12 KB |
Smart Link collaboration mechanisms
Smart Link configuration task list
Configuring a Smart Link device
Configuring protected VLANs for a smart link group
Configuring member ports for a smart link group
Configuring role preemption for a smart link group
Enabling the sending of flush messages
Configuring an associated device
Enabling the receiving of flush messages
Displaying and maintaining Smart Link
Smart Link configuration examples
Single smart link group configuration example
Multiple smart link groups load sharing configuration example
Overview
To avoid single-point failures and guarantee network reliability, downstream devices are usually dual-homed to upstream devices, as shown in Figure 1.
Figure 1 Dual uplink network diagram
To remove network loops on a dual-homed network, you can use a spanning tree protocol. However, convergence time is long with spanning tree protocols, which makes it unsuitable for users who have high demand on convergence speed.
For more information about spanning tree protocols, see Layer 2—LAN Switching Configuration Guide. Smart Link is a feature developed to address the slow convergence issue with STP. It provides link redundancy as well as fast convergence in a dual uplink network, allowing the backup link to take over quickly when the primary link fails. Smart Link features subsecond convergence time.
A Smart Link device is configured with a smart link group and a transmit control VLAN to transmit flush messages. For example, Device C and Device D in Figure 1 are Smart Link devices.
An associated device supports Smart Link, and receives flush messages sent from the specified control VLAN. For example, Device A, Device B, and Device E in Figure 1 are associated devices.
Terminology
Smart link group
A smart link group consists of only two member ports: the primary and the secondary ports. Only one port is active for forwarding at a time, and the other port is blocked and in standby state. When link failure occurs on the active port due to port shutdown or the presence of unidirectional link, the standby port becomes active and takes over, and the original active port transits to the blocked state.
As shown in Figure 1, Port 1 and Port 2 of Device C form a smart link group and those of Device D form another, with Port 1 being active and Port 2 being standby.
Primary/secondary port
Primary port and secondary port are two port types in a smart link group. When both ports in a smart link group are up, the primary port preferentially transits to the forwarding state, and the secondary port stays in standby state. Once the primary port fails, the secondary port takes over to forward traffic. As shown in Figure 1, you can configure Port 1 of Device C and that of Device D as primary ports, and Port 2 of Device C and that of Device D secondary ports.
Primary/secondary link
Flush message
Flush messages are used by a smart link group to notify other devices to refresh their MAC address forwarding entries and ARP/ND entries when link switchover occurs in the smart link group. Flush messages are common multicast data packets, and will be dropped by a blocked receiving port.
Protected VLAN
A smart link group controls the forwarding state of protected VLANs. Each smart link group on a port controls a different protected VLAN. The state of the port in a protected VLAN is determined by the state of the port in the smart link group.
Transmit control VLAN
The transmit control VLAN is used for transmitting flush messages. When link switchover occurs, the devices (such as Device C and Device D in Figure 1) send flush messages within the transmit control VLAN.
Receive control VLAN
The receive control VLAN is used for receiving and processing flush messages. When link switchover occurs, the devices (such as Device A, Device B, and Device E in Figure 1) receive and process flush messages in the receive control VLAN and refresh their MAC address forwarding entries and ARP/ND entries.
How Smart Link works
Link backup
As shown in Figure 1, the link on Port 1 of Device C is the primary link, and the link on Port 2 of Device C is the secondary link. Typically, Port 1 is in forwarding state, and Port 2 is in standby state. When the primary link fails, Port 2 takes over to forward traffic and Port 1 is blocked and placed in standby state.
When a port switches to the forwarding state, the system outputs log information to notify the user of the port state change.
Topology change
Link switchover can outdate the MAC address forwarding entries and ARP/ND entries on all devices, so a forwarding entry update mechanism is required to ensure proper transmission. The following update mechanisms are provided:
· Uplink traffic-triggered MAC address learning—Update is triggered by uplink traffic. This mechanism is applicable to environments with devices that do not support Smart Link, including devices from other vendors.
· Flush update—A Smart Link-enabled device updates its information by transmitting flush messages over the backup link to its upstream devices. This mechanism requires the upstream devices to be capable of recognizing Smart Link flush messages to update their MAC address forwarding entries and ARP/ND entries.
Role preemption
As shown in Figure 1, the link on Port 1 of Device C is the primary link. The link on Port 2 of Device C is the secondary link. Once the primary link fails, Port 1 is automatically blocked and placed in standby state, and Port 2 takes over to forward traffic. When the primary link recovers, one of the following actions occurs:
· To keep traffic forwarding stable if the smart link group is not configured with role preemption, Port 1 does not immediately take over to forward traffic. It stays blocked until the next link switchover.
· If the smart link group is configured with role preemption, Port 1 takes over to forward traffic as soon as its link recovers, and Port 2 is automatically blocked and placed in standby state.
Load sharing
A ring network might carry traffic of multiple VLANs. Smart Link can forward traffic from different VLANs in different smart link groups for load sharing.
To implement load sharing, you can assign a port to multiple smart link groups. Configure each group with a different protected VLAN. Make sure the state of the port is different in these smart link groups, so traffic from different VLANs can be forwarded along different paths.
You can configure protected VLANs for a smart link group by referencing Multiple Spanning Tree Instances (MSTIs). For more information about MSTIs, see Layer 2—LAN Switching Configuration Guide.
Smart Link cannot detect when faults occur on the uplink of the upstream devices or when faults are cleared. You can configure the Monitor Link function to monitor the status of the uplink ports of the upstream devices. Monitor Link adapts the up/down state of downlink ports to uplink ports, and triggers Smart Link to perform link switchover on the downstream device. For more information about Monitor Link, see "Configuring Monitor Link."
Tasks at a glance |
Configuring a Smart Link device: · Configuring protected VLANs for a smart link group · (Required.) Configuring member ports for a smart link group · (Optional.) Configuring role preemption for a smart link group · (Optional.) Enabling the sending of flush messages |
Configuring an associated device · (Required.) Enabling the receiving of flush messages |
Configuration prerequisites
Before configuring a Smart Link device, complete the following tasks:
· To prevent loops, shut down a port before configuring it as a smart link group member. You can bring up the port only after completing the smart link group configuration.
· Disable the spanning tree feature and RRPP on the ports you want to add to the smart link group.
NOTE: · A loop might occur on the network during the time when the spanning tree feature is disabled but Smart Link has not yet taken effect on a port. · Do not configure a port as a member of a Layer 2 aggregation group and a smart link group at the same time. Otherwise, the port cannot become the smart link group member, and you cannot view the port by using the display smart-link group command. |
Protected VLANs are configured by referencing MSTIs. The protected VLAN configuration method varies by the spanning tree mode:
· In STP, RSTP, or MSTP mode, you must manually configure the mappings between VLANs and MSTIs.
· In PVST mode, the device automatically maps each VLAN to an MSTI. When the spanning tree protocol is disabled globally, all VLANs are automatically mapped to MSTI 0.
To configure the protected VLANs for a smart link group:
Step |
Command |
Remarks |
1. Enter system view. |
system-view |
N/A |
2. Enter MST region view. |
stp region-configuration |
Skip this step if the device is operating in PVST mode. For more information about the command, see Layer 2—LAN Switching Command Reference. |
3. Configure the VLAN-to-instance mapping table. |
· Method 1: · Method 2: |
Skip this step if the device is operating in PVST mode. All VLANs in an MST region are mapped to CIST (MSTI 0) by default. For more information about the commands, see Layer 2—LAN Switching Command Reference. |
4. Manually activate MST region configuration. |
active region-configuration |
5. (Optional.) Display the currently activated configuration information of the MST region. |
display stp region-configuration |
Available in any view. The output of the command includes VLAN-to-instance mappings. For more information about the command, see Layer 2—LAN Switching Command Reference. |
6. Return to system view. |
quit |
Skip this step if the device is operating in PVST mode. |
7. Create a smart link group and enter smart link group view. |
smart-link group group-id |
N/A |
8. Configure protected VLANs for the smart link group. |
protected-vlan reference-instance instance-id-list |
By default, no protected VLAN is configured for a smart link group. |
You can configure member ports for a smart link group either in smart link group view or in interface view. The configurations made in these two views have the same effect.
In smart link group view
To configure member ports for a smart link group in smart link group view:
Step |
Command |
Remarks |
system-view |
N/A |
2. Create a smart link group and enter smart link group view. |
N/A |
3. Configure member ports for a smart link group. |
port interface-type interface-number { primary | secondary } |
By default, no member port is configured for a smart link group. |
In interface view
To configure member ports for a smart link group in interface view:
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter Layer 2 Ethernet interface view or Layer 2 aggregate interface view. |
N/A |
port smart-link group group-id { primary | secondary } |
By default, an interface is not a smart link group member. |
Step |
Command |
Remarks |
system-view |
N/A |
2. Enter smart link group view. |
N/A |
3. Enable role preemption. |
preemption mode role |
By default, role preemption is disabled. |
4. Configure the preemption delay. |
preemption delay delay |
By default, the preemption delay is 1 second. The preemption delay configuration takes effect only after role preemption is enabled. |
Follow these guidelines when you enable the sending of flush messages:
· The control VLAN configured for a smart link group must be different from the control VLAN configured for any other smart link group.
· Make sure the configured control VLAN already exists, and assign the smart link group member ports to the control VLAN.
· The control VLAN of a smart link group must also be one of its protected VLANs. Do not remove the control VLAN. Otherwise, flush messages cannot be sent correctly.
To enable the sending of flush messages:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Enable flush update. |
flush enable [ control-vlan vlan-id ] |
By default, flush update is enabled, and VLAN 1 is the control VLAN. |
Disable the spanning tree feature on the associated device's ports that connect to the member ports of the smart link group. Otherwise, the ports will discard flush messages when they are not in forwarding state if a topology change occurs.
You do not need to enable all ports on the associated devices to receive flush messages. Enable the feature only on all control VLANs of ports on the primary and secondary links between the Smart Link device and the destination device.
Follow these guidelines when you enable the receiving of flush messages:
· If no control VLAN is specified for processing flush messages, the device forwards the received flush messages without any processing.
· Make sure the receive control VLAN is the same as the transmit control VLAN configured on the Smart Link device. If they are not the same, the associated device will forward the received flush messages directly without any processing.
· Do not remove the control VLANs. Otherwise, flush messages cannot be sent correctly.
· Make sure the control VLANs are existing VLANs, and assign the ports capable of receiving flush messages to the control VLANs.
To enable the receiving of flush messages:
Step |
Command |
Remarks |
system-view |
N/A |
N/A |
3. Configure the control VLANs for receiving flush messages. |
smart-link flush enable [ control-vlan vlan-id-list ] |
By default, no control VLAN receives flush messages. |
Perform display commands in any view and the reset command in user view:
Task |
Command |
Display information about the received flush messages. |
display smart-link flush |
Display smart link group information. |
display smart-link group { group-id | all } |
Clear the statistics about flush messages. |
reset smart-link statistics |
By default, Ethernet, VLAN, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up.
Network requirements
As shown in Figure 2:
· Switch C and Switch D are Smart Link devices. Switch A, Switch B, and Switch E are associated devices. Traffic of VLANs 1 through 30 on Switch C and Switch D is dually uplinked to Switch A.
· Configure Smart Link on Switch C and Switch D for dual uplink backup.
Configuration procedure
1. Configure Switch C:
# Create VLANs 1 through 30, map these VLANs to MSTI 1, and activate the MST region configuration.
[SwitchC] vlan 1 to 30
[SwitchC] stp region-configuration
[SwitchC-mst-region] instance 1 vlan 1 to 30
[SwitchC-mst-region] active region-configuration
[SwitchC-mst-region] quit
# Shut down GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2, disable the spanning tree feature on GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2 separately, configure them as trunk ports, and assign them to VLANs 1 through 30.
[SwitchC] interface gigabitEthernet 4/0/1
[SwitchC-GigabitEthernet4/0/1] shutdown
[SwitchC-GigabitEthernet4/0/1] undo stp enable
[SwitchC-GigabitEthernet4/0/1] port link-type trunk
[SwitchC-GigabitEthernet4/0/1] port trunk permit vlan 1 to 30
[SwitchC-GigabitEthernet4/0/1] quit
[SwitchC] interface gigabitEthernet 4/0/2
[SwitchC-GigabitEthernet4/0/2] shutdown
[SwitchC-GigabitEthernet4/0/2] undo stp enable
[SwitchC-GigabitEthernet4/0/2] port link-type trunk
[SwitchC-GigabitEthernet4/0/2] port trunk permit vlan 1 to 30
[SwitchC-GigabitEthernet4/0/2] quit
# Create smart link group 1, and configure all VLANs mapped to MSTI 1 as the protected VLANs.
[SwitchC-smlk-group1] protected-vlan reference-instance 1
# Configure GigabitEthernet 4/0/1 as the primary port and GigabitEthernet 4/0/2 as the secondary port for smart link group 1.
[SwitchC-smlk-group1] port gigabitEthernet4/0/1 primary
[SwitchC-smlk-group1] port gigabitEthernet4/0/2 secondary
# Enable flush message sending in smart link group 1, and configure VLAN 10 as the transmit control VLAN.
[SwitchC-smlk-group1] flush enable control-vlan 10
[SwitchC-smlk-group1] quit
# Bring up GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2 again.
[SwitchC-GigabitEthernet4/0/1] undo shutdown
[SwitchC-GigabitEthernet4/0/2] undo shutdown
2. Configure Switch D:
[SwitchD] vlan 1 to 30
[SwitchD] stp region-configuration
[SwitchD-mst-region] instance 1 vlan 1 to 30
[SwitchD-mst-region] active region-configuration
[SwitchD-mst-region] quit
[SwitchD] interface gigabitEthernet 4/0/1
[SwitchD-GigabitEthernet4/0/1] shutdown
[SwitchD-GigabitEthernet4/0/1] undo stp enable
[SwitchD-GigabitEthernet4/0/1] port link-type trunk
[SwitchD-GigabitEthernet4/0/1] port trunk permit vlan 1 to 30
[SwitchD-GigabitEthernet4/0/1] quit
[SwitchD] interface gigabitEthernet 4/0/2
[SwitchD-GigabitEthernet4/0/2] shutdown
[SwitchD-GigabitEthernet4/0/2] undo stp enable
[SwitchD-GigabitEthernet4/0/2] port link-type trunk
[SwitchD-GigabitEthernet4/0/2] port trunk permit vlan 1 to 30
[SwitchD-GigabitEthernet4/0/2] quit
[SwitchD-smlk-group1] protected-vlan reference-instance 1
[SwitchD-smlk-group1] port gigabitEthernet4/0/1 primary
[SwitchD-smlk-group1] port gigabitEthernet4/0/2 secondary
# Enable flush message sending in smart link group 1, and configure VLAN 20 as the transmit control VLAN.
[SwitchD-smlk-group1] flush enable control-vlan 20
[SwitchD-smlk-group1] quit
[SwitchD-GigabitEthernet4/0/1] undo shutdown
[SwitchD-GigabitEthernet4/0/2] undo shutdown
3. Configure Switch B:
# Create VLANs 1 through 30.
[SwitchB] vlan 1 to 30
# Configure GigabitEthernet 4/0/1 as a trunk port, and assign it to VLANs 1 through 30. Enable flush message receiving on it, and configure VLAN 10 and VLAN 20 as the receive control VLANs.
[SwitchB] interface gigabitEthernet 4/0/1
[SwitchB-GigabitEthernet4/0/1] port link-type trunk
[SwitchB-GigabitEthernet4/0/1] port trunk permit vlan 1 to 30
[SwitchB-GigabitEthernet4/0/1] smart-link flush enable control-vlan 10 20
[SwitchB-GigabitEthernet4/0/1] quit
# Configure GigabitEthernet 4/0/2 as a trunk port, and assign it to VLANs 1 through 30. Disable the spanning tree feature and enable flush message receiving on it, and configure VLAN 20 as the receive control VLAN.
[SwitchB] interface gigabitEthernet 4/0/2
[SwitchB-GigabitEthernet4/0/2] port link-type trunk
[SwitchB-GigabitEthernet4/0/2] port trunk permit vlan 1 to 30
[SwitchB-GigabitEthernet4/0/2] undo stp enable
[SwitchB-GigabitEthernet4/0/2] smart-link flush enable control-vlan 20
[SwitchB-GigabitEthernet4/0/2] quit
# Configure GigabitEthernet 4/0/3 as a trunk port, and assign it to VLANs 1 through 30. Disable the spanning tree feature and enable flush message receiving on it, and configure VLAN 10 as the receive control VLAN.
[SwitchB] interface gigabitEthernet 4/0/3
[SwitchB-GigabitEthernet4/0/3] port link-type trunk
[SwitchB-GigabitEthernet4/0/3] port trunk permit vlan 1 to 30
[SwitchB-GigabitEthernet4/0/3] undo stp enable
[SwitchB-GigabitEthernet4/0/3] smart-link flush enable control-vlan 10
[SwitchB-GigabitEthernet4/0/3] quit
4. Configure Switch E:
[SwitchE] vlan 1 to 30
[SwitchE] interface gigabitEthernet 4/0/1
[SwitchE-GigabitEthernet4/0/1] port link-type trunk
[SwitchE-GigabitEthernet4/0/1] port trunk permit vlan 1 to 30
[SwitchE-GigabitEthernet4/0/1] smart-link flush enable control-vlan 10 20
[SwitchE-GigabitEthernet4/0/1] quit
# Configure GigabitEthernet 4/0/2 as a trunk port, and assign it to VLANs 1 through 30. Disable the spanning tree feature and enable flush message receiving on it, and configure VLAN 10 as the receive control VLAN.
[SwitchE] interface gigabitEthernet 4/0/2
[SwitchE-GigabitEthernet4/0/2] port link-type trunk
[SwitchE-GigabitEthernet4/0/2] port trunk permit vlan 1 to 30
[SwitchE-GigabitEthernet4/0/2] undo stp enable
[SwitchE-GigabitEthernet4/0/2] smart-link flush enable control-vlan 10
[SwitchE-GigabitEthernet4/0/2] quit
# Configure GigabitEthernet 4/0/3 as a trunk port, and assign it to VLANs 1 through 30. Disable the spanning tree feature and enable flush message receiving on it, and configure VLAN 20 as the receive control VLAN.
[SwitchE] interface gigabitEthernet 4/0/3
[SwitchE-GigabitEthernet4/0/3] port link-type trunk
[SwitchE-GigabitEthernet4/0/3] port trunk permit vlan 1 to 30
[SwitchE-GigabitEthernet4/0/3] undo stp enable
[SwitchE-GigabitEthernet4/0/3] smart-link flush enable control-vlan 20
[SwitchE-GigabitEthernet4/0/3] quit
5. Configure Switch A:
[SwitchA] vlan 1 to 30
# Configure GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2 as trunk ports, assign them to VLANs 1 through 30, enable flush message receiving on them, and configure VLAN 10 and VLAN 20 as the receive control VLANs.
[SwitchA] interface gigabitEthernet 4/0/1
[SwitchA-GigabitEthernet4/0/1] port link-type trunk
[SwitchA-GigabitEthernet4/0/1] port trunk permit vlan 1 to 30
[SwitchA-GigabitEthernet4/0/1] smart-link flush enable control-vlan 10 20
[SwitchA-GigabitEthernet4/0/1] quit
[SwitchA] interface gigabitEthernet 4/0/2
[SwitchA-GigabitEthernet4/0/2] port link-type trunk
[SwitchA-GigabitEthernet4/0/2] port trunk permit vlan 1 to 30
[SwitchA-GigabitEthernet4/0/2] smart-link flush enable control-vlan 10 20
[SwitchA-GigabitEthernet4/0/2] quit
Use the display smart-link group command to display the smart link group configuration on a device.
# Display the smart link group configuration on Switch C.
[SwitchC] display smart-link group 1
Smart link group 1 information:
Device ID : 000f-e23d-5af0
Preemption mode : NONE
Preemption delay: 1(s)
Control VLAN : 10
Protected VLAN : Reference Instance 1
Member Role State Flush-count Last-flush-time
GE4/0/1 PRIMARY ACTIVE 5 16:45:20 2012/04/21
GE4/0/2 SECONDARY STANDBY 1 16:37:20 2012/04/21
Use the display smart-link flush command to display the flush messages received on a device.
# Display the flush messages received on Switch B.
[SwitchB] display smart-link flush
Received flush packets : 5
Receiving interface of the last flush packet : GigabitEthernet4/0/3
Receiving time of the last flush packet : 16:50:21 2012/04/21
Device ID of the last flush packet : 000f-e23d-5af0
Control VLAN of the last flush packet : 10
As shown in Figure 3:
· Switch C is a Smart Link device. Switch A, Switch B, and Switch D are associated devices. Traffic of VLANs 1 through 200 on Switch C is dually uplinked to Switch A by Switch B and Switch D.
· Implement dual uplink backup and load sharing on Switch C: Traffic of VLANs 1 through 100 is uplinked to Switch A by Switch B. Traffic of VLANs 101 through 200 is uplinked to Switch A by Switch D.
# Create VLAN 1 through VLAN 200, map VLANs 1 through 100 to MSTI 1, and VLANs 101 through 200 to MSTI 2, and activate MST region configuration.
[SwitchC] vlan 1 to 200
[SwitchC-mst-region] instance 1 vlan 1 to 100
[SwitchC-mst-region] instance 2 vlan 101 to 200
# Shut down GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2, disable the spanning tree feature on them, configure them as trunk ports, and assign them to VLAN 1 through VLAN 200.
[SwitchC-GigabitEthernet4/0/1] port trunk permit vlan 1 to 200
[SwitchC-GigabitEthernet4/0/2] port trunk permit vlan 1 to 200
# Create smart link group 1, and configure all VLANs mapped to MSTI 1 as the protected VLANs for smart link group 1.
# Enable role preemption in smart link group 1, enable flush message sending, and configure VLAN 10 as the transmit control VLAN.
[SwitchC-smlk-group1] preemption mode role
# Create smart link group 2, and configure all VLANs mapped to MSTI 2 as the protected VLANs for smart link group 2.
[SwitchC-smlk-group2] protected-vlan reference-instance 2
# Configure GigabitEthernet 4/0/1 as the secondary port and GigabitEthernet 4/0/2 as the primary port for smart link group 2.
[SwitchC-smlk-group2] port gigabitEthernet4/0/2 primary
[SwitchC-smlk-group2] port gigabitEthernet4/0/1 secondary
# Enable role preemption in smart link group 2, enable flush message sending, and configure VLAN 110 as the transmit control VLAN.
[SwitchC-smlk-group2] preemption mode role
[SwitchC-smlk-group2] flush enable control-vlan 110
[SwitchC-smlk-group2] quit
# Bring up GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2.
2. Configure Switch B:
# Create VLAN 1 through VLAN 200.
[SwitchB] vlan 1 to 200
# Configure GigabitEthernet 4/0/1 as a trunk port, assign it to VLANs 1 through 200, enable flush message receiving, and configure VLAN 10 and VLAN 110 as the receive control VLANs on the port.
[SwitchB-GigabitEthernet4/0/1] port trunk permit vlan 1 to 200
[SwitchB-GigabitEthernet4/0/1] smart-link flush enable control-vlan 10 110
# Configure GigabitEthernet 4/0/2 as a trunk port, assign it to VLANs 1 through 200, disable the spanning tree feature and enable flush message receiving on it, and configure VLAN 10 and VLAN 110 as the receive control VLANs.
[SwitchB-GigabitEthernet4/0/2] port trunk permit vlan 1 to 200
[SwitchB-GigabitEthernet4/0/2] smart-link flush enable control-vlan 10 110
3. Configure Switch D:
[SwitchD] vlan 1 to 200
[SwitchD-GigabitEthernet4/0/1] port trunk permit vlan 1 to 200
[SwitchD-GigabitEthernet4/0/1] smart-link flush enable control-vlan 10 110
# Configure GigabitEthernet 4/0/2 as a trunk port and assign it to VLANs 1 through 200, disable the spanning tree feature and enable flush message receiving, and configure VLAN 10 and VLAN 110 as the receive control VLANs on the port.
[SwitchD-GigabitEthernet4/0/2] port trunk permit vlan 1 to 200
[SwitchD-GigabitEthernet4/0/2] smart-link flush enable control-vlan 10 110
4. Configure Switch A:
[SwitchA] vlan 1 to 200
# Configure GigabitEthernet 4/0/1 and GigabitEthernet 4/0/2 as trunk ports, assign them to VLANs 1 through 200, enable flush message receiving, and configure VLAN 10 and VLAN 110 as the receive control VLANs on the ports.
[SwitchA-GigabitEthernet4/0/1] port trunk permit vlan 1 to 200
[SwitchA-GigabitEthernet4/0/1] smart-link flush enable control-vlan 10 110
[SwitchA-GigabitEthernet4/0/2] port trunk permit vlan 1 to 200
[SwitchA-GigabitEthernet4/0/2] smart-link flush enable control-vlan 10 110
[SwitchC] display smart-link group all
Preemption mode : ROLE
Control VLAN : 10
Smart link group 2 information:
Control VLAN : 110
Protected VLAN : Reference Instance 2
GE4/0/2 PRIMARY ACTIVE 5 16:45:20 2012/04/21
GE4/0/1 SECONDARY STANDBY 1 16:37:20 2012/04/21
Receiving interface of the last flush packet : GigabitEthernet4/0/2
Receiving time of the last flush packet : 16:25:21 2012/04/21
