10-Security Configuration Guide
HomeSupportSwitchesH3C S12500 Switch SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release7374-6W73110-Security Configuration Guide
16-Object group configuration
16-Object group configuration 83.28 KB
Configuring object groups
Overview
An object group is a group of objects that can be referenced by an ACL to identify packets. Object groups are divided into the following types:
·     IPv4 address object group—A group of IPv4 address objects used to match the IPv4 address in a packet.
·     IPv6 address object group—A group of IPv6 address objects used to match the IPv6 address in a packet.
·     Port object group—A group of port objects used to match the protocol port number in a packet.
Configuring an IPv4 address object group
Step
Remarks
N/A
2.     Configure an IPv4 address object group and enter its view.
object-group ip address object-group-name
The system has one default IPv4 address object group.
3.     (Optional.) Configure a description for the IPv4 address object group.
By default, an object group does not have a description.
4.     Configure an IPv4 address object.
[ object-id ] network { host { address ip-address | name host-name } | subnet ip-address { mask-length | mask } }
By default, no object exists.
Configuring an IPv6 address object group
Step
Remarks
N/A
2.     Configure an IPv6 address object group and enter its view.
object-group ipv6 address object-group-name
The system has one default IPv6 address object group.
3.     (Optional.) Configure a description for the IPv6 address object group.
4.     Configure an IPv6 address object.
[ object-id ] network { host { address ipv6-address | name host-name } | subnet ipv6-address prefix-length }
Configuring a port object group
Step
Remarks
N/A
2.     Configure a port object group and enter its view.
object-group port object-group-name
The system has one default port object group.
3.     (Optional.) Configure a description for the port object group.
4.     Configure a port object.
[ object-id ] port { { eq | lt | gt } port | range port1 port2 }
Displaying and maintaining object groups
Display information about object groups.
display object-group [ { { ip | ipv6 } address | port } [ default ] [ name object-group-name ] | name object-group-name ]
