09-ACL and QoS Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release7374-6W73109-ACL and QoS Configuration Guide
01-ACL configuration
01-ACL configuration 211.26 KB
In this document, EB cards refer to the interface cards suffixed with EB, EC1 cards refer to the interface cards suffixed with EC1, EC2 cards refer to the interface cards suffixed with EC2, EF cards refer to the interface cards suffixed with EF, FD cards refer to the interface cards suffixed with FD, and FG cards refer to the cards suffixed with FG.
Overview
An access control list (ACL) is a set of rules (or permit or deny statements) for identifying traffic based on criteria such as source IP address, destination IP address, and port number.
ACLs are primarily used for packet filtering. "Configuring packet filtering with ACLs" provides an example. You can use ACLs in QoS, security, routing, and other feature modules for identifying traffic. The packet drop or forwarding decisions depend on the modules that use ACLs.
ACL categories
Category
ACL number
IP version
Match criteria
Basic ACLs
2000 to 2999
IPv4
Source IPv4 address.
IPv6
Source IPv6 address.
Advanced ACLs
3000 to 3999
IPv4
Source IPv4 address, destination IPv4 address, packet priority, protocol number, and other Layer 3 and Layer 4 header fields.
IPv6
Source IPv6 address, destination IPv6 address, packet priority, protocol number, and other Layer 3 and Layer 4 header fields.
Ethernet frame header ACLs
4000 to 4999
IPv4 and IPv6
Layer 2 header fields, such as source and destination MAC addresses, 802.1p priority, and link layer protocol type.
User-defined ACLs
5000 to 5999
IPv4 and IPv6
User specified matching patterns in protocol headers.
Numbering and naming ACLs
Each ACL category has a unique range of ACL numbers. When creating an ACL, you must assign it a number. In addition, you can assign the ACL a name for ease of identification. After creating an ACL with a name, you cannot rename it or delete its name.
For an IPv4 basic or advanced ACLs, its ACL number and name must be unique in IPv4. For an IPv6 basic or advanced ACL, its ACL number and name must be unique in IPv6.
Match order
The rules in an ACL are sorted in a specific order. When a packet matches a rule, the device stops the match process and performs the action defined in the rule. If an ACL contains overlapping or conflicting rules, the matching result and action to take depend on the rule order.
The following ACL match orders are available:
·     config—Sorts ACL rules in ascending order of rule ID. A rule with a lower ID is matched before a rule with a higher ID. If you use this approach, carefully check the rules and their order.
The match order of user-defined ACLs can only be config.
·     auto—Sorts ACL rules in depth-first order. Depth-first ordering makes sure any subset of a rule is always matched before the rule. Table 1 lists the sequence of tie breakers that depth-first ordering uses to sort rules for each type of ACL.
Table 1 Sort ACL rules in depth-first order
ACL category
Sequence of tie breakers
IPv4 basic ACL
1.     VPN instance.
2.     More 0s in the source IPv4 address wildcard (more 0s means a narrower IPv4 address range).
3.     Rule configured earlier.
IPv4 advanced ACL
1.     VPN instance.
2.     Specific protocol number.
3.     More 0s in the source IPv4 address wildcard mask.
4.     More 0s in the destination IPv4 address wildcard.
5.     Narrower TCP/UDP service port number range.
6.     Rule configured earlier.
IPv6 basic ACL
1.     VPN instance.
2.     Longer prefix for the source IPv6 address (a longer prefix means a narrower IPv6 address range).
IPv6 advanced ACL
1.     VPN instance.
3.     Longer prefix for the source IPv6 address.
4.     Longer prefix for the destination IPv6 address.
1.     More 1s in the source MAC address mask (more 1s means a smaller MAC address).
2.     More 1s in the destination MAC address mask.
A wildcard mask, also called an inverse mask, is a 32-bit binary number represented in dotted decimal notation. In contrast to a network mask, the 0 bits in a wildcard mask represent "do care" bits, and the 1 bits represent "don't care" bits. If the "do care" bits in an IP address are identical to the "do care" bits in an IP address criterion, the IP address matches the criterion. All "don't care" bits are ignored. The 0s and 1s in a wildcard mask can be noncontiguous. For example, 0.255.0.255 is a valid wildcard mask.
Rule numbering
ACL rules can be manually numbered or automatically numbered. This section describes how automatic ACL rule numbering works.
Rule numbering step
If you do not assign an ID to the rule you are creating, the system automatically assigns it a rule ID. The rule numbering step sets the increment by which the system automatically numbers rules. For example, the default ACL rule numbering step is 5. If you do not assign IDs to rules you are creating, they are automatically numbered 0, 5, 10, 15, and so on. The wider the numbering step, the more rules you can insert between two rules.
By introducing a gap between rules rather than contiguously numbering rules, you have the flexibility of inserting rules in an ACL. This feature is important for a config-order ACL, where ACL rules are matched in ascending order of rule ID.
Automatic rule numbering and renumbering
The ID automatically assigned to an ACL rule takes the nearest higher multiple of the numbering step to the current highest rule ID, starting with 0.
For example, if the numbering step is 5 (the default), and there are five ACL rules numbered 0, 5, 9, 10, and 12, the newly defined rule is numbered 15. If the ACL does not contain a rule, the first rule is numbered 0.
Whenever the step changes, the rules are renumbered, starting from 0. For example, if there are five rules numbered 5, 10, 13, 15, and 20, changing the step from 5 to 2 causes the rules to be renumbered 0, 2, 4, 6, and 8.
Fragments filtering with ACLs
Traditional packet filtering matches only first fragments of packets, and allows all subsequent non-first fragments to pass through. Attackers can fabricate non-first fragments to attack networks.
To avoid the risks, the H3C ACL implementation does the following:
·     Filters all fragments by default, including non-first fragments.
·     Allows for matching criteria modification for efficiency. For example, you can configure the ACL to filter only non-first fragments.
Configuration task list
Tasks at a glance
(Required.) Perform at least one of the following tasks:
·     Configuring a basic ACL
¡ Configuring an IPv4 basic ACL
¡ Configuring an IPv6 basic ACL
·     Configuring an advanced ACL
¡ Configuring an IPv4 advanced ACL
¡ Configuring an IPv6 advanced ACL
·     Configuring an Ethernet frame header ACL
·     Configuring a user-defined ACL
(Optional.) Copying an ACL
(Optional.) Configuring the ACL hardware mode
(Optional.) Configuring packet filtering with ACLs
This section describes procedures for configuring IPv4 and IPv6 basic ACLs.
IPv4 basic ACLs match packets based only on source IP addresses.
To configure an IPv4 basic ACL:
Step
Remarks
N/A
2.     Create an IPv4 basic ACL and enter its view.
acl number acl-number [ name acl-name ] [ match-order { auto | config } ]
By default, no ACL exists.
IPv4 basic ACLs are numbered in the range of 2000 to 2999.
You can use the acl name acl-name command to enter the view of a named ACL.
3.     (Optional.) Configure a description for the IPv4 basic ACL.
By default, an IPv4 basic ACL has no ACL description.
4.     (Optional.) Set the rule numbering step.
step step-value
The default setting is 5.
5.     Create or edit a rule.
rule [ rule-id ] { deny | permit } [ counting | fragment | logging | source { object-group addr-group-name | source-address source-wildcard | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
By default, an IPv4 basic ACL does not contain any rule.
The logging keyword takes effect only when the module (for example, packet filtering) that uses the ACL supports logging.
On a PE or MCE, rules with the vpn-instance keyword do not apply to packets received from a VPN site. For more information about PE and MCE, see MPLS Configuration Guide.
6.     (Optional.) Add or edit a rule comment.
rule rule-id comment text
By default, no rule comments are configured.
IPv6 basic ACLs match packets based only on source IP addresses.
To configure an IPv6 basic ACL:
Step
Remarks
N/A
2.     Create an IPv6 basic ACL view and enter its view.
acl ipv6 number acl-number [ name acl-name ] [ match-order { auto | config } ]
IPv6 basic ACLs are numbered in the range of 2000 to 2999.
You can use the acl ipv6 name acl-name command to enter the view of a named ACL.
3.     (Optional.) Configure a description for the IPv6 basic ACL.
By default, an IPv6 basic ACL has no ACL description.
step step-value
rule [ rule-id ] { deny | permit } [ counting | fragment | logging | routing [ type routing-type ] | source { object-group addr-group-name | source-address source-prefix | source-address/source-prefix | any } | time-range time-range-name | vpn-instance vpn-instance-name ] *
By default, an IPv6 basic ACL does not contain any rule.
The vpn-instance keyword is not supported in the current software version. It is reversed for future support.
This section describes procedures for configuring IPv4 and IPv6 advanced ACLs.
IPv4 advanced ACLs match packets based on the following criteria:
·     Source IP addresses.
·     Destination IP addresses.
·     Packet priorities.
·     Protocol numbers.
·     Other protocol header information, such as TCP/UDP source and destination port numbers, TCP flags, ICMP message types, and ICMP message codes.
Compared to IPv4 basic ACLs, IPv4 advanced ACLs allow more flexible and accurate filtering.
To configure an IPv4 advanced ACL:
Step
Remarks
N/A
2.     Create an IPv4 advanced ACL and enter its view.
IPv4 advanced ACLs are numbered in the range of 3000 to 3999.
3.     (Optional.) Configure a description for the IPv4 advanced ACL.
By default, an IPv4 advanced ACL has no ACL description.
step step-value
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { object-group addr-group-name | dest-address dest-wildcard | any } | destination-port { object-group port-group-name | operator port1 [ port2 ] } | { dscp dscp | { precedence precedence | tos tos } * } | fragment | icmp-type { icmp-type [ icmp-code ] | icmp-message } | logging | source { object-group addr-group-name | source-address source-wildcard | any } | source-port { object-group port-group-name | operator port1 [ port2 ] } | time-range time-range-name | vpn-instance vpn-instance-name ] *
By default, an IPv4 advanced ACL does not contain any rule.
If the ACL is used on an EB, EC2, or FD card in basic ACL hardware mode, the vpn-instance keyword (even if specified,) does not take effect.
IPv6 advanced ACLs match packets based on the following criteria:
·     Source IPv6 addresses.
·     Destination IPv6 addresses.
·     Protocol numbers.
·     Other protocol header fields such as the TCP/UDP source port number, TCP/UDP destination port number, ICMPv6 message type, and ICMPv6 message code.
Compared to IPv6 basic ACLs, IPv6 advanced ACLs allow more flexible and accurate filtering.
To configure an IPv6 advanced ACL:
Step
Remarks
N/A
2.     Create an IPv6 advanced ACL and enter its view.
IPv6 advanced ACLs are numbered in the range of 3000 to 3999.
3.     (Optional.) Configure a description for the IPv6 advanced ACL.
By default, an IPv6 advanced ACL has no ACL description.
step step-value
rule [ rule-id ] { deny | permit } protocol [ { { ack ack-value | fin fin-value | psh psh-value | rst rst-value | syn syn-value | urg urg-value } * | established } | counting | destination { object-group addr-group-name | dest-address dest-prefix | dest-address/dest-prefix | any } | destination-port { object-group port-group-name | operator port1 [ port2 ] } | dscp dscp | flow-label flow-label-value | fragment | icmp6-type { icmp6-type icmp6-code | icmp6-message } | logging | routing [ type routing-type ] | hop-by-hop [ type hop-type ] | source { object-group addr-group-name | source-address source-prefix | source-address/source-prefix | any } | source-port { object-group port-group-name | operator port1 [ port2 ] } | time-range time-range-name | vpn-instance vpn-instance-name ] *
By default, IPv6 advanced ACL does not contain any rule.
Ethernet frame header ACLs, also called "Layer 2 ACLs," match packets based on Layer 2 protocol header fields, such as:
·     Source MAC address.
·     Destination MAC address.
·     802.1p priority (VLAN priority).
·     Link layer protocol type.
To configure an Ethernet frame header ACL:
Step
Remarks
N/A
2.     Create an Ethernet frame header ACL and enter its view.
Ethernet frame header ACLs are numbered in the range of 4000 to 4999.
3.     (Optional.) Configure a description for the Ethernet frame header ACL.
By default, an Ethernet frame header ACL has no ACL description.
step step-value
rule [ rule-id ] { deny | permit } [ cos vlan-pri | counting | dest-mac dest-address dest-mask | { lsap lsap-type lsap-type-mask | type protocol-type protocol-type-mask } | source-mac source-address source-mask | time-range time-range-name ] *
By default, an Ethernet frame header ACL does not contain any rule.
The lsap keyword is not supported in the current software version. It is reversed for future support.
On an EB, EC2, or FD card that is in basic ACL hardware mode, the protocol-type protocol-type-mask argument cannot be set to 0x86DD 0xFFFF, which matches IPv6 packets.
User-defined ACLs allow you to customize rules based on information in protocol headers. You can define a user-defined ACL to match packets. A specific number of bytes after an offset (relative to the specified header) are compared against a match pattern after being ANDed with a match pattern mask.
To configure a user-defined ACL:
Step
Remarks
N/A
2.     Create a user-defined ACL and enter its view.
User-defined ACLs are numbered in the range of 5000 to 5999.
3.     (Optional.) Configure a description for the user-defined ACL.
By default, a user-defined ACL has no ACL description.
4.     Create or edit a rule.
rule [ rule-id ] { deny | permit } [ { { ipv4 | ipv6 | l2 | l4 } rule-string rule-mask offset }&<1-8> ] [ counting | time-range time-range-name ] *
By default, a user-defined ACL does not contain any rule.
5.     (Optional.) Add or edit a rule comment.
Copying an ACL
You can create an ACL by copying an existing ACL (source ACL). The new ACL (destination ACL) has the same properties and content as the source ACL, but not the same ACL number and name.
To successfully copy an ACL, make sure:
·     The destination ACL number is from the same category as the source ACL number.
·     The source ACL already exists, but the destination ACL does not.
To copy an ACL:
Step
2.     Copy an existing ACL to create a new ACL.
acl [ ipv6 ] copy { source-acl-number | name source-acl-name } to { dest-acl-number | name dest-acl-name }
IMPORTANT:
After configuring this feature, to make the configuration take effect, you must save it and then restart the device.
Devices with different ACL hardware modes cannot form an IRF fabric. For more information about IRF, see Virtual Technologies Configuration Guide.
The ACL hardware mode is supported only by the default MDC. For more information about MDC, see Virtual Technologies Configuration Guide.
Specifying an ACL hardware mode
CAUTION
CAUTION:
Use caution to switch the ACL hardware mode. The switching might cause ACL configurations to go invalid.
This operation applies to EB, EC2, or FD cards.
·     In basic ACL hardware mode, the cards support only IPv4 basic, IPv4 advanced, and Ethernet frame header ACLs.
·     In advanced ACL hardware mode, the cards support IPv4 basic, IPv4 advanced, Ethernet frame header, IPv6 basic, IPv6 advanced, and user-defined ACLs.
To specify an ACL hardware mode:
Step
Remarks
N/A
2.     Specify an ACL hardware mode.
acl hardware-mode { advanced | basic }
By default, the ACL hardware mode is advanced.
Enabling or disabling IPv6 for the ACL hardware mode
IMPORTANT:
Use caution to enable or disable IPv6 for ACL hardware mode. The operation might cause ACL configuration to go invalid.
This operation applies to only EC1, EF, and FG cards.
·     When IPv6 is disabled for the ACL hardware mode, the cards support only IPv4 basic, IPv4 advanced, and Ethernet frame header ACLs.
·     When IPv6 is enabled for the ACL hardware mode, the cards support IPv4 basic, IPv4 advanced, Ethernet frame header, IPv6 basic, IPv6 advanced, and user-defined ACLs.
To enable or disable IPv6 for the ACL hardware mode:
Step
Remarks
N/A
2.     Enable or disable IPv6 for the ACL hardware mode.
acl hardware-mode ipv6 { disable | enable }
By default, IPv6 is disabled for the ACL hardware mode.
This section describes procedures for applying an ACL to filter incoming or outgoing IPv4 or IPv6 packets on the specified interface. When ACLs are applied to filter packets, the ACL applied globally, the ACL applied to an interface, and the ACL applied to a VLAN are in the descending priority order.
User-defined ACLs cannot be used to filter outgoing packets.
Applying an ACL to filter packets globally
Step
Remarks
N/A
2.     Apply an ACL to all physical interfaces to filter packets.
packet-filter [ ipv6 ] { acl-number | name acl-name } global { inbound | outbound } [ hardware-count ]
By default, physical interfaces do not filter packets.
You can apply up to 32 ACLs to the same direction of all physical interfaces.
Applying an ACL to an interface for packet filtering
When you use the packet-filter command in VLAN interface view to filter the outgoing IPv4 packets, the command takes effect on only Layer 3 unicast packets.
When an EB, EC2, or FD card operates in basic ACL hardware mode, it does not support packet filtering for outgoing IPv4 packets on VLAN interfaces.
To apply an ACL to an interface for packet filtering:
Step
Remarks
N/A
2.     Enter interface view.
N/A
3.     Apply an ACL to the interface to filter packets.
packet-filter [ ipv6 ] { acl-number | name acl-name } { inbound | outbound } [ hardware-count ]
By default, an interface does not filter packets.
You can apply up to 32 ACLs to the same direction of an interface.
Applying an ACL to a VLAN for packet filtering
Step
Remarks
N/A
2.     Apply an ACL to a VLAN to filter packets.
packet-filter [ ipv6 ] { acl-number | name acl-name } vlan vlan-list { inbound | outbound } [ hardware-count ]
By default, the system does not filter packets in a VLAN.
You can apply up to 32 ACLs to the same direction of a VLAN.
Setting the interval for generating and outputting packet filtering logs
After you set the interval, the device periodically generates and outputs the packet filtering logs to the information center, including the number of matching packets and the matched ACL rules. For more information about information center, see Network Management and Monitoring Configuration Guide.
To set the interval for generating and outputting packet filtering logs:
Step
Remarks
N/A
2.     Set the interval for generating and outputting packet filtering logs.
acl [ ipv6 ] logging interval interval
The default setting is 0 minutes, which mean that no packet filtering logs are generated.
Setting the packet filtering default action
Step
Remarks
N/A
2.     Set the packet filtering default action to deny.
packet-filter default deny
By default, the packet filter permits packets that do not match any ACL rule to pass.
Enabling hardware-count for the packet filtering default action
When you enable the hardware-count feature for the packet filtering default action on an interface, the interface counts how many times the packet filtering default action has been performed.
To enable the hardware-count feature for the packet filtering default action on an interface, make sure you have applied ACLs to the interface for packet filtering.
To enable hardware-count for the packet filtering default action:
Step
Remarks
N/A
N/A
3.     Enable hardware-count for the packet filtering default action on the interface.
packet-filter default { inbound | outbound } hardware-count
By default, hardware-count is disabled for the packet filtering default action.
Displaying and maintaining ACLs
Display ACL configuration and match statistics.
display acl [ ipv6 ] { acl-number | all | name acl-name }
Display information about the ACL hardware mode and the IPv6 status for the mode.
display acl hardware-mode
Display whether an ACL has been successfully applied to an interface for packet filtering (in standalone mode).
display packet-filter { interface [ interface-type interface-number ] [ inbound | outbound ] | { global | interface vlan-interface vlan-interface-number | vlan [ vlan-id ] } [ inbound | outbound ] [ slot slot-number ] }
Display whether an ACL has been successfully applied to an interface for packet filtering (In IRF mode).
display packet-filter { interface [ interface-type interface-number ] [ inbound | outbound ] | { global | interface vlan-interface vlan-interface-number | vlan [ vlan-id ] } [ inbound | outbound ] [ chassis chassis-number slot slot-number ] }
Display match statistics and default action statistics for packet filtering ACLs.
display packet-filter statistics { global | interface interface-type interface-number | vlan vlan-id } { inbound | outbound } [ default | [ ipv6 ] { acl-number | name acl-name } ] [ brief ]
Display the accumulated statistics for packet filtering ACLs.
display packet-filter statistics sum { inbound | outbound } [ ipv6 ] { acl-number | name acl-name } [ brief ]
Display detailed ACL packet filtering information (in standalone mode).
display packet-filter verbose { global | interface interface-type interface-number | vlan vlan-id } { inbound | outbound } [ [ ipv6 ] { acl-number | name acl-name } ] [ slot slot-number ]
Display detailed ACL packet filtering information (in IRF mode).
display packet-filter verbose { global | interface interface-type interface-number | vlan vlan-id } { inbound | outbound } [ [ ipv6 ] { acl-number | name acl-name } ] [ chassis chassis-number slot slot-number ]
Display QoS and ACL resource usage (in standalone mode).
display qos-acl resource [ slot slot-number ]
Display QoS and ACL resource usage (in IRF mode).
display qos-acl resource [ chassis chassis-number slot slot-number ]
Clear ACL statistics.
reset acl [ ipv6 ] counter { acl-number | all | name acl-name }
Clear match statistics (including the accumulated statistics) and default action statistics for packet filtering ACLs.
reset packet-filter statistics { global | interface [ interface-type interface-number ] | vlan [ vlan-id ] } { inbound | outbound } [ default | [ ipv6 ] { acl-number | name acl-name } ]
ACL configuration examples
By default, Ethernet, VLAN, and aggregate interfaces are shut down. You must use the undo shutdown command to bring them up. The examples assume that all these interfaces are already up.
IPv4 ACL configuration example
Network requirements
A company interconnects its departments through a switch A. Configure an ACL to:
·     Permit access from the President's office at any time to the salary server.
·     Deny access from any other department to the salary server during office hours (from 8:00 to 18:00) on working days.
Figure 1 Network diagram
Configuration procedure
1.     Create a periodic time range from 8:00 to 18:00 on working days.
<Switch> system-view
[Switch] time-range trname 8:00 to 18:00 working-day
2.     Define ACLs:
# Create ACL 3000, and configure an ACL rule for it.
[Switch] acl number 3000
[Switch-acl-adv-3000] rule 1 permit ip source 129.111.1.2 0.0.0.0 destination 129.110.1.2 0.0.0.0
[Switch-acl-adv-3000] quit
# Create ACL 3001, and configure an ACL rule for it.
[Switch] acl number 3001
[Switch-acl-adv-3001] rule 1 permit ip source any destination 129.110.1.2 0.0.0.0 time-range trname
[Switch-acl-adv-3001] quit
3.     Define a QoS policy and apply the policy to ports:
# Create traffic classes and define traffic behaviors.
[Switch] traffic classifier test_permit
[Switch-classifier-test_permit] if-match acl 3000
[Switch-classifier-test_permit] quit
[Switch] traffic behavior test_permit
[Switch-behavior-test_permit] filter permit
[Switch-behavior-test_permit] quit
[Switch] traffic classifier test_deny
[Switch-classifier-test_deny] if-match acl 3001
[Switch-classifier-test_deny] quit
[Switch] traffic behavior test_deny
[Switch-behavior-test_deny] filter deny
[Switch-behavior-test_deny] quit
# Create a QoS policy.
[Switch] qos policy test
[Switch-qospolicy-test] classifier test_permit behavior test_permit
[Switch-qospolicy-test] classifier test_deny behavior test_deny
[Switch-qospolicy-test] quit
# Apply the QoS policy to ports GigabitEthernet 4/0/1 through GigabitEthernet 4/0/3 in the inbound direction.
[Switch] interface gigabitethernet 4/0/1
[Switch-GigabitEthernet4/0/1] qos apply policy test inbound
[Switch-GigabitEthernet4/0/1] quit
[Switch] interface gigabitethernet 4/0/2
[Switch-GigabitEthernet4/0/2] qos apply policy test inbound
[Switch-GigabitEthernet4/0/2] quit
[Switch] interface gigabitethernet 4/0/3
[Switch-GigabitEthernet4/0/3] qos apply policy test inbound
[Switch-GigabitEthernet4/0/3] quit
IPv6 ACL configuration example
Perform packet filtering in the inbound direction of interface GigabitEthernet 4/0/1 to deny all IPv6 packets but those with source addresses in the range 4050::9000 to 4050::90FF.
# Create ACL 2000, and define an ACL rule for it.
[Switch] acl ipv6 number 2000
[Switch-acl6-basic-2000] rule permit source 4050::9000/120
[Switch-acl6-basic-2000] quit
# Create ACL 2001, and define an ACL rule for it.
[Switch] acl ipv6 number 2001
[Switch-acl6-basic-2001] rule permit source any
[Switch-acl6-basic-2001] quit
# Define a class and a traffic behavior to permit packets with source addresses in the range 4050::9000 to 4050::90FF.
[Switch] traffic classifier c_permit
[Switch-classifier-c_permit] if-match acl ipv6 2000
[Switch-classifier-c_permit] quit
[Switch] traffic behavior b_permit
[Switch-behavior-b_permit] filter permit
[Switch-behavior-b_permit] quit
# Define a class and a traffic behavior to deny other packets.
[Switch] traffic classifier c_deny
[Switch-classifier-c_deny] if-match acl ipv6 2001
[Switch-classifier-c_deny] quit
[Switch] traffic behavior b_deny
[Switch-behavior-b_deny] filter deny
[Switch-behavior-b_deny] quit
# Configure a QoS policy.
[Switch-qospolicy-test] classifier c_permit behavior b_permit
[Switch-qospolicy-test] classifier c_deny behavior b_deny
# Apply the QoS policy to port GigabitEthernet 4/0/1 in the inbound direction.
IPv4 packet filtering configuration example
As shown in Figure 2, Host A and Host B connect to the switch to access the Internet.
Configure packet filtering on the VLAN interface of the switch so that every day from 8:00 to 18:00, the VLAN-interface denies only IPv4 packets sourced from Host A. Configure the switch to output IPv4 packet filtering logs to the console at 10-minute intervals.
As actual requirements change, edit the ACL so that the VLAN interface denies only IPv4 packets sourced from Host B.
Figure 2 Network diagram
# Create a time range named study; set it to be active from 08:00 to 18:00 every day.
[Switch] time-range study 8:00 to 18:00 daily
# Configure VLAN 2, and assign interface GigabitEthernet 3/0/1 to this VLAN.
[Switch] vlan 2
[Switch-vlan2] port GigabitEthernet 3/0/1
[Switch-vlan2] quit
# Configure a basic IPv4 ACL 2009.
[Switch] acl number 2009
# Create an ACL rule to deny IPv4 packets sourced from 192.168.1.2/32, and configure the rule to log packet filtering events and count rule matches.
[Switch-acl-basic-2009] rule 5 deny source 192.168.1.2 0 time-range study logging counting
[Switch-acl-basic-2009] quit
# Enable the switch to generate and output IPv4 packet filtering logs at 10-minute intervals.
[Switch] acl logging frequence 10
# Apply ACL 2009 to filter incoming packets on VLAN-interface 2.
[Switch-Vlan-interface2] ip address 192.168.1.1 24
[Switch-Vlan-interface2] packet-filter 2009 inbound
[Switch-Vlan-interface2] quit
# Configure the switch to output informational log messages to the console.
[Switch] info-center source default channel 0 log level informational
# Edit ACL rule 5 in ACL 2009 to deny IPv4 packets sourced from 192.168.1.3/32. The rule takes effect on VLAN-interface 2 immediately after the modification. (The switch supports dynamic modification of ACLs in use.)
[Switch-acl-basic-2009] rule 5 deny source 192.168.1.3 0
