03-Interface Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guides-Release7374-6W73103-Interface Configuration Guide
01-Bulk interface configuration
01-Bulk interface configuration 69.79 KB
You can enter interface range view to bulk configure multiple interfaces with the same feature instead of configuring them one by one. For example, you can execute the shutdown command in interface range view to shut down a range of interfaces.
When you bulk configure interfaces in interface range view, follow these restrictions and guidelines:
·     In interface range view, only the commands supported by the first interface are available. The first interface is specified with the interface range command.
·     You cannot enter the view of some interfaces by using the interface interface-type { interface-number | interface-number.subnumber } command, for example, BRI 1/1/1:1. Do not configure any of these interfaces as the first interface in the interface range.
·     Do not assign both an aggregate interface and any of its member interfaces to an interface range. Some commands, after being executed on both an aggregate interface and its member interfaces, can break up the aggregation.
·     No limit is set on the maximum number of interfaces in an interface range. The more interfaces in an interface range, the longer the command execution time.
·     The maximum number of interface range names is limited only by the system resources. To guarantee bulk interface configuration performance, H3C recommends that you configure fewer than 1000 interface range names.
·     When a command is executed in interface range view, the system tries to execute the command on all member interfaces in the interface range. One of the following situations might occur:
¡     The system displays an error message and stays in interface range view. It means that the execution failed on member interfaces in the interface range.
-     If the execution failed on the first member interface in the interface range, the command is not executed on any member interfaces.
-     If the execution failed on non-first member interfaces, the command takes effect on member interfaces except the member interfaces where the execution failed.
¡     The system returns to system view. It means the command is supported in both system view and interface view. If the execution failed on a member interface in interface range view and succeeded in system view, the command is not executed on the subsequent member interfaces.
You can use the display this command to verify the configuration in interface view of each member interface. In addition, if the configuration is not needed in system view, use the undo form of the command to remove the configuration.
Configuration procedure
Step
Remarks
N/A
2.     Enter interface range view.
·     interface range { interface-type interface-number [ to interface-type interface-number ] } &<1-24>
·     interface range name name [ interface { interface-type interface-number [ to interface-type interface-number ] } &<1-24> ]
By using the interface range name command, you assign a name to an interface range and can specify this name rather than the interface range to enter the interface range view.
3.     (Optional.) Display commands available for the first interface in the interface range.
Enter a question mark (?) at the interface range prompt.
N/A
4.     Use available commands to configure the interfaces.
Available commands vary by interface.
N/A
5.     (Optional.) Verify the configuration.
display this
N/A
Displaying and maintaining bulk interface configuration
Display information about the specified interface range or all existing interface ranges.
display interface range [ name name ]
