13-SPB Configuration Examples
HomeSupportSwitchesH3C S12500 Switch SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Typical Configuration Example-R7328P02-6W10013-SPB Configuration Examples
00-H3C S12500 SPBM Configuration Examples
00-H3C S12500 SPBM Configuration Examples 217.8 KB
Introduction
This document provides examples for configuring SPBM.
This document assumes that you have basic knowledge of SPBM.
General configuration restrictions and guidelines
When you configure SPBM, follow the restrictions and guidelines in this section.
Feature compatibility requirements
When you use SPBM in conjunction with other features, follow the restrictions and guidelines in Table 1.
Table 1 SPBM and other features compatibility
Feature
System operating mode
The system operating mode must be advanced, enhanced Layer 2, or enhanced Layer 3 mode. For more information about system operating modes, see device management in Fundamentals Configuration Guide.
IRF
You must configure the irf mac-address persistent always command to prevent the IRF bridge MAC address from changing after a master re-election.
Spanning tree
The spanning tree mode must be set to MSTP (the default).
For SPBM neighbors to establish adjacencies, you must map all B-VLANs to MSTI 4092 and make sure their in-between links have connectivity. To forward traffic on an SPBM network, you must assign all SPBM nodes to one MST region. For more information about MST region configuration, see Layer 2—LAN Switching Configuration Guide.
Static MAC
If a B-MAC is the same as a static MAC in the MAC address table, remove the static MAC. The device can forward SPBM packets to the B-MAC only after the conflict is removed.
VLAN
ISIS-SPB protocol frames are transmitted untagged on links. To prevent SPBM-enabled interfaces from dropping these frames, assign each SPBM-enabled interface to the port VLAN (PVID) as an untagged member.
You must configure the provider network ports on BEBs and BCBs as trunk or hybrid ports, and assign the ports to all B-VLANs as tagged VLAN members.
Hardware restrictions
In an MDC on an SPBM node, a provider network port cannot be in the same port group as an IRF physical port, EVI tunnel source interface, or Layer 3 Ethernet interface.
Table 2 Port groups on interface cards
Card type
Port groups
Port assignment
48-port 1000 Mbps Ethernet fiber interface card
48-port 1000 Mbps Ethernet copper interface card
2
Group 1—Lowest numbered 24 ports.
Group 2—Highest numbered 24 ports.
4-port 10-Gigabit Ethernet fiber interface card
2
Group 1—Lowest numbered 2 ports.
Group 2—Highest numbered 2 ports.
8-port 10-Gigabit Ethernet fiber interface card
4
Group 1—Ports 1 and 2.
Group 2—Ports 3 and 4.
Group 3—Ports 5 and 6.
Group 4—Ports 7 and 8.
16-port 10-Gigabit Ethernet fiber interface card
8
Group 1—Ports 1 and 3.
Group 2—Ports 2 and 4.
Group 3—Ports 5 and 7.
Group 4—Ports 6 and 8.
Group 5—Ports 9 and 11.
Group 6—Ports 10 and 12.
Group 7—Ports 13 and 15.
Group 8—Ports 14 and 16.
20-port 10-Gigabit Ethernet interface card
1
All ports are in one group.
32-port 10-Gigabit Ethernet fiber interface card
4
Group 1—Ports 1, 3, 5, 7, 9, 11, 13, 15.
Group 2—Ports 2, 4, 6, 8, 10, 12, 14, 16.
Group 3—Ports 17, 19, 21, 23, 25, 27, 29, 31.
Group 4—Ports 18, 20, 22, 24, 26, 28, 30, 32.
40-port 10-Gigabit Ethernet fiber interface card
2
Group 1—Lowest numbered 20 ports.
Group 2—Highest numbered 20 ports.
48-port 10-Gigabit Ethernet fiber interface card
4
Group 1—Ports 1 to 12.
Group 2—Ports 13 to 24.
Group 3—Ports 25 to 36.
Group 4—Ports 37 to 48.
16-port 40-Gigabit Ethernet fiber interface card
4
Group 1—Ports 1 to 4.
Group 2—Ports 5 to 8.
Group 3—Ports 9 to 12.
Group 4—Ports 13 to 16.
4-port 100-Gigabit Ethernet fiber interface card
2
Example: Configuring SPBM with tandem replication
Network requirements
As shown in Figure 1, deploy an SPBM network to meet the following requirements:
·     Use I-SID 3001 to extend VLAN 100 across customer sites 1, 2, 3, and 4.
·     Assign B-VLAN 3001 to I-SID 3001.
·     Use tandem replication for multicast in the SPBM network.
Figure 1 Network diagram
BCB 2 uses the same port numbering scheme as BCB 1. BEB 2, BEB 3, and BEB 4 use the same port numbering scheme as BEB 1.
When you configure SPBM, follow these restrictions and guidelines:
·     The following MST region parameters must be the same across all SPBM nodes:
?     Region name.
?     Revision level.
?     All B-VLANs mapped to MSTI 4092.
·     Multicast replication mode must be the same across all BEBs.
·     You must enable the multicast B-VLAN feature on all nodes in the SPBM network if the following requirements are met:
?     Tandem replication is used.
?     A BEB uses interfaces on an EC or EF interface card as provider network ports.
An EC or EF interface card is an interface card suffixed with EC or EF. For more information about the multicast B-VLAN feature, see SPB Configuration Guide.
Software version used
This configuration example was created and verified on S12500-CMW710-R7328P02.
Configuration procedures
Configuring BEB 1
# Create C-VLAN 100 and B-VLAN 3001.
<BEB1> system-view
[BEB1] vlan 100
[BEB1-vlan100] quit
[BEB1] vlan 3001
[BEB1-vlan3001] quit
# Configure MST region parameters. This example uses the default (0) for the revision level.
[BEB1] stp region-configuration
[BEB1-mst-region] region-name spb
[BEB1-mst-region] instance 4092 vlan 3001
[BEB1-mst-region] active region-configuration
[BEB1-mst-region] quit
# Enable SPBM both globally and on provider network ports. Assign the provider network ports to B-VLAN 3001.
[BEB1] spbm
[BEB1-spbm] quit
[BEB1] interface range Ten-GigabitEthernet 1/0/2 to Ten-GigabitEthernet 1/0/3
[BEB1-if-range] undo shutdown
[BEB1-if-range] port link-type trunk
[BEB1-if-range] port trunk permit vlan 3001
[BEB1-if-range] spbm enable
[BEB1-if-range] quit
# Enable L2VPN.
[BEB1] l2vpn enable
# Configure an SPB VSI (I-SID 3001).
[BEB1] vsi test
[BEB1-vsi-test] spb i-sid 3001
# Assign B-VLAN 3001 to the SPB VSI.
[BEB1-vsi-test-3001] b-vlan 3001
# Enable tandem multicast replication for the SPB VSI.
[BEB1-vsi-test-3001] multicast replicate-mode tandem
[BEB1-vsi-test-3001] quit
[BEB1-vsi-test] quit
# Assign the customer network port Ten-GigabitEthernet 1/0/1 to C-VLAN 100.
[BEB1] interface Ten-GigabitEthernet1/0/1
[BEB1-Ten-GigabitEthernet1/0/1] undo shutdown
[BEB1-Ten-GigabitEthernet1/0/1] port link-type trunk
[BEB1-Ten-GigabitEthernet1/0/1] port trunk permit vlan 100
# Configure Ethernet service instance 1 to match C-VLAN 100, and map the service instance to the SPB VSI.
[BEB1-Ten-GigabitEthernet1/0/1] service-instance 1
[BEB1-Ten-GigabitEthernet1/0/1-srv1] encapsulation s-vid 100
[BEB1-Ten-GigabitEthernet1/0/1-srv1] xconnect vsi test
[BEB1-Ten-GigabitEthernet1/0/1-srv1] quit
[BEB1-Ten-GigabitEthernet1/0/1] quit
Configuring BEB 2, BEB 3, and BEB 4
# Configure the BEBs in the same way you configure BEB 1. (Details not shown.)
Configuring BCB 1
# Create B-VLAN 3001.
<BCB1> system-view
[BCB1] vlan 3001
[BCB1-vlan3001] quit
[BCB1] stp region-configuration
[BCB1-mst-region] region-name spb
[BCB1-mst-region] instance 4092 vlan 3001
[BCB1-mst-region] active region-configuration
[BCB1-mst-region] quit
[BCB1] spbm
[BCB1-spbm] quit
[BCB1] interface range Ten-GigabitEthernet 2/0/1 to Ten-GigabitEthernet 2/0/4
[BCB1-if-range] undo shutdown
[BCB1-if-range] port link-type trunk
[BCB1-if-range] port trunk permit vlan 3001
[BCB1-if-range] spbm enable
[BCB1-if-range] quit
Configuring BCB 2
# Configure BCB 2 in the same way you configure BCB 1. (Details not shown.)
Verify the configuration on BEBs (for example, BEB 1):
# Verify that the BEB has ISIS-SPB adjacency with its neighbors.
[BEB1] display spbm peer
                           Peer information for SPBM
 System ID         Port                        Circuit ID    State    Holdtime
 0011.2200.1501    XGE1/0/2                    2             Up       29s
 0011.2200.1601    XGE1/0/3                    3             Up       29s
# Verify that the BEB has established tunnels to other BEBs.
[BEB1] display l2vpn vsi name test verbose
VSI Name: test
  VSI Index               : 0
  VSI State               : Up
  Bandwidth               : 102400 kbps
  Broadcast Restrain      : 5%
  Multicast Restrain      : -
  Unknown Unicast Restrain: -
  MAC Table Limit         : Unlimited
  Drop Unknown            : -
  SPB I-SID               : 3001
  SPB Connections:
    BMAC            BVLAN            Link ID    Type
    0011-2200-1201  3001             64         Unicast
    0011-2200-1301  3001             65         Unicast
    0011-2200-1401  3001             66         Unicast
    6380-ff00-0bb9  3001             -          Multicast
  ACs:
    AC                               Link ID    State
    XGE1/0/1 srv1                    0          Up
Configuration files
·     BEB 1, BEB 2, BEB 3, and BEB 4:
vlan 100
vlan 3001
 region-name spb
spbm
l2vpn enable
vsi test
 spb i-sid 3001
  b-vlan 3001
 port link-mode bridge
 port trunk permit vlan 1 100
 service-instance 1
  xconnect vsi test
 port trunk permit vlan 1 3001
 spbm enable
 spbm enable
·     BCB 1 and BCB 2:
vlan 3001
 region-name spb
spbm
interface Ten-GigabitEthernet2/0/1
 spbm enable
interface Ten-GigabitEthernet2/0/2
 spbm enable
interface Ten-GigabitEthernet2/0/3
 spbm enable
interface Ten-GigabitEthernet2/0/4
 spbm enable
Example: Configuring SPBM with head-end replication
As shown in Figure 2, deploy an SPBM network to meet the following requirements:
·     Use I-SID 3001 to extend VLAN 100 across customer sites 1, 2, and 3.
·     Use head-end replication for multicast in the SPBM network.
Figure 2 Network diagram
?     Region name.
?     Revision level.
Configuring BEB 1
<BEB1> system-view
[BEB1] vlan 100
[BEB1-vlan100] quit
[BEB1] vlan 3001
# Enable SPBM both globally and on the provider network port Ten-GigabitEthernet 1/0/2. Assign the provider network port to B-VLAN 3001.
[BEB1] spbm
[BEB1-spbm] quit
[BEB1] interface Ten-GigabitEthernet1/0/2
[BEB1-Ten-GigabitEthernet1/0/2] undo shutdown
[BEB1-Ten-GigabitEthernet1/0/2] port link-type trunk
[BEB1-Ten-GigabitEthernet1/0/2] port trunk permit vlan 3001
[BEB1-Ten-GigabitEthernet1/0/2] spbm enable
[BEB1-Ten-GigabitEthernet1/0/2] quit
# Enable L2VPN.
[BEB1] l2vpn enable
[BEB1] vsi test
Configuring BEB 2 and BEB 3
Configuring the BCB
<BCB> system-view
[BCB] vlan 3001
[BCB-vlan3001] quit
[BCB] stp region-configuration
[BCB-mst-region] region-name spb
[BCB-mst-region] instance 4092 vlan 3001
[BCB-mst-region] active region-configuration
[BCB-mst-region] quit
[BCB] spbm
[BCB-spbm] quit
[BCB] interface range Ten-GigabitEthernet 2/0/1 to Ten-GigabitEthernet 2/0/3
[BCB-if-range] undo shutdown
[BCB-if-range] port link-type trunk
[BCB-if-range] port trunk permit vlan 3001
[BCB-if-range] spbm enable
[BCB-if-range] quit
# Verify that the BEB has ISIS-SPB adjacency with its neighbor.
 0000.eeee.0101    XGE1/0/2                    2             Up       29s
VSI Name: test
  VSI Index               : 0
  VSI State               : Up
  Drop Unknown            : -
  SPB I-SID               : 3001
  SPB Connections:
    0000-eeee-0141  3001             64         Unicast
    0000-9999-0141  3001             65         Unicast
  ACs:
    AC                               Link ID    State
    XGE1/0/1 srv1                    0          Up
Configuration files
·     BEB 1, BEB 2, and BEB 3:
vlan 100
vlan 3001
 region-name spb
spbm
l2vpn enable
vsi test
 spb i-sid 3001
  b-vlan 3001
 service-instance 1
  xconnect vsi test
 spbm enable
·     BCB:
vlan 3001
 region-name spb
spbm
 spbm enable
 spbm enable
 spbm enable
Example: Performing SPBM ECT migration by changing the B-VLAN
As shown in Figure 3, perform ECT migration for the SPBM network (I-SID 3001) in "Example: Configuring SPBM with tandem replication."
Move I-SID 3001 from the original ECT algorithm to ECT algorithm 9. Change the B-VLAN from 3001 to 3003 for I-SID 3001.
Figure 3 Network diagram
Requirements analysis
To perform the ECT migration, you must perform the following tasks:
·     Create B-VLAN 3003, and map B-VLAN 3003 to MSTI 4092 on all SPBM nodes.
·     Map B-VLAN 3003 to ECT algorithm 9 on all SPBM nodes.
·     Change the B-VLAN from 3001 to 3003 for I-SID 3001 on BEBs.
Adding B-VLAN 3003
Configuring BEB 1
# Create B-VLAN 3003.
<BEB1> system-view
[BEB1] vlan 3003
[BEB1-vlan3003] quit
[BEB1-mst-region] instance 4092 vlan 3003
# Assign provider network ports to B-VLAN 3003.
[BEB1-if-range] port trunk permit vlan 3003
# Map B-VLAN 3003 to ECT algorithm 9.
[BEB1] spbm
[BEB1-spbm] ect 9 b-vlan 3003
[BEB1-spbm] quit
Configuring BCB 1
<BCB1> system-view
[BCB1] vlan 3003
[BCB1-vlan3003] quit
# Configure MST region parameters. Map B-VLAN 3003 to MSTI 4092.
[BCB1-mst-region] instance 4092 vlan 3003
[BCB1-if-range] port trunk permit vlan 3003
[BCB1] spbm
[BCB1-spbm] ect 9 b-vlan 3003
[BCB1-spbm] quit
Configuring BCB 2
Performing ECT migration
Configuring BEB 1
# Change the B-VLAN to 3003 for the SPB VSI test.
[BEB1] vsi test
[BEB1-vsi-test] spbm i-sid 3001
[BEB1-vsi-test-3001] b-vlan 3003
Before ECT migration
# Before the ECT migration, verify that I-SID 3001 uses B-VLAN 3001 to transmit customer traffic on BEBs (for example BEB 1).
[BEB1] display spbm ect-migration i-sid 3001
ECT            B-VLAN    T    R
00-80-c2-01    3001      1    1
After ECT migration
# Approximately 2 minutes later after the ECT migration, verify that I-SID 3001 uses B-VLAN 3003 to transmit customer traffic on BEBs (for example BEB 1).
[BEB1-spbm] display spbm ect-migration i-sid 3001
ECT            B-VLAN    T    R
00-80-c2-09    3003      1    1
Configuration files (before ECT migration)
vlan 100
vlan 3001
vlan 3003
 region-name spb
 instance 4092 vlan 3001 3003
spbm
ect 9 b-vlan 3003
l2vpn enable
vsi test
 spb i-sid 3001
  b-vlan 3001
 service-instance 1
  xconnect vsi test
 port trunk permit vlan 1 3001 3003
 spbm enable
 spbm enable
·     BCB 1 and BCB 2:
vlan 3001
vlan 3003
 region-name spb
spbm
ect 9 b-vlan 3003
 spbm enable
 spbm enable
 spbm enable
 spbm enable
Related documentation
·     H3C S12500 Routing Switch Series SPB Configuration Guide
·     H3C S12500 Routing Switch Series SPB Command Reference
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Configuration Guide
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Command Reference
·     H3C S12500 Routing Switch Series MPLS Configuration Guide
·     H3C S12500 Routing Switch Series MPLS Command Reference
