10-High Availability Configuration Examples
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration ExamplesH3C S12500 Typical Configuration Example-R7328P02-6W10010-High Availability Configuration Examples
02-H3C S12500 VRRP Configuration Examples
02-H3C S12500 VRRP Configuration Examples 247.9 KB
Introduction
This document provides VRRP configuration examples.
This document is not restricted to specific software or hardware versions.
This document assumes that you have basic knowledge of VRRP and STP.
Example: Configuring a single VRRP group
Network requirements
As shown in Figure 1, configure a VRRP group on Device A and Device B as the gateway for Host A to meet the following requirements:
·     Device A operates as the master to forward packets from Host A to the external network.
·     When Device A or its uplink interface fails, Host A can access the external network through Device B.
Figure 1 Network diagram
Requirements analysis
To meet the network requirements, you must perform the following tasks:
·     For Device A to become the master when it recovers from a failure, configure the preemptive mode for the VRRP group.
·     For Device A to decrease its priority and become a backup when its uplink interface fails, configure VRRP tracking on Device A.
·     To avoid frequent role change in the VRRP group, configure a preemption delay.
Software version used
This configuration example was created and verified on S12500-CMW710-R7328P02.
When you configure a single VRRP group, follow these restrictions and guidelines:
·     The virtual IP address of a VRRP group cannot be any of the following addresses:
¡     All-zero address (0.0.0.0).
¡     Broadcast address (255.255.255.255).
¡     Loopback address.
¡     IP address of other than Class A, Class B, and Class C.
¡     Invalid IP address (for example, 0.0.0.1).
·     IPv4 VRRP can use VRRPv2 or VRRPv3 (default version). For a VRRP group to operate correctly, make sure the VRRP versions on all devices in the VRRP group are the same.
·     Removal of the VRRP group on the IP address owner causes IP address collision. To avoid a collision, change the IP address of the interface on the IP address owner before you remove the VRRP group from the interface.
·     Configure the same virtual IP addresses for each device in the VRRP group.
·     Make sure the decreased priority of the master is lower than the priority of all the other devices in the VRRP group. Another device in the group can then be elected as the master.
Configuration procedures
1.     Configure Device A:
# Configure the interface IP addresses.
[DeviceA] interface ten-gigabitethernet 3/0/1
[DeviceA-Ten-GigabitEthernet3/0/1] undo shutdown
[DeviceA-Ten-GigabitEthernet3/0/1] quit
[DeviceA] vlan 2
[DeviceA-vlan2] port ten-gigabitethernet 3/0/1
[DeviceA-vlan2] quit
[DeviceA] interface vlan-interface 2
[DeviceA-Vlan-interface2] undo shutdown
[DeviceA-Vlan-interface2] ip address 192.168.0.2 24
[DeviceA-Vlan-interface2] quit
[DeviceA] interface ten-gigabitethernet 3/0/2
[DeviceA-Ten-GigabitEthernet3/0/2] undo shutdown
[DeviceA-Ten-GigabitEthernet3/0/2] quit
[DeviceA] vlan 3
[DeviceA-vlan3] port ten-gigabitethernet 3/0/2
[DeviceA-vlan3] quit
[DeviceA] interface vlan-interface 3
[DeviceA-Vlan-interface3] undo shutdown
[DeviceA-Vlan-interface3] quit
# Create VRRP group 1, and set its virtual IP address to 192.168.0.1.
[DeviceA-Vlan-interface2] vrrp vrid 1 virtual-ip 192.168.0.1
# Assign Device A higher priority than Device B in VRRP group 1, so Device A can become the master.
[DeviceA-Vlan-interface2] vrrp vrid 1 priority 110
# Configure Device A to operate in preemptive mode, and set the preemption delay to 5 seconds.
[DeviceA-Vlan-interface2] vrrp vrid 1 preempt-mode delay 5
# Create track entry 1 to monitor the upstream link status of VLAN-interface 3. When the upstream link fails, the track entry transits to Negative.
[DeviceA] track 1 interface vlan-interface 3
# Associate VRRP group 1 with track entry 1 to decrease the weight of Device A by 50 when the track entry transits to Negative.
[DeviceA-Vlan-interface2] vrrp vrid 1 track 1 reduced 50
2.     Configure Device B:
[DeviceB] interface ten-gigabitethernet 3/0/1
[DeviceB-Ten-GigabitEthernet3/0/1] undo shutdown
[DeviceB-Ten-GigabitEthernet3/0/1] quit
[DeviceB] vlan 2
[DeviceB-vlan2] port ten-gigabitethernet 3/0/1
[DeviceB-vlan2] quit
[DeviceB] interface vlan-interface 2
[DeviceB-Vlan-interface2] undo shutdown
[DeviceB-Vlan-interface2] ip address 192.168.0.3 24
[DeviceB-Vlan-interface2] vrrp vrid 1 virtual-ip 192.168.0.1
# Assign a priority of 100 to Device B in VRRP group 1.
[DeviceB-Vlan-interface2] vrrp vrid 1 priority 100
# Configure Device B to operate in preemptive mode, and set the preemption delay to 5 seconds.
[DeviceB-Vlan-interface2] vrrp vrid 1 preempt-mode delay 5
[DeviceB-Vlan-interface2] quit
# Ping Host B from Host A. (Details not shown.)
# Display detailed information about VRRP group 1 on Device A.
[DeviceA-Vlan-interface2] display vrrp verbose
 Running Mode      : Standard
   Interface Vlan-interface2
     VRID           : 1                    Adver Timer  : 100
     Admin Status   : Up                   State        : Master
     Config Pri     : 110                  Running Pri  : 110
     Preempt Mode   : Yes                  Delay Time   : 5
     Auth Type      : None
     Virtual IP     : 192.168.0.1
     Virtual MAC    : 0000-5e00-0101
     Master IP      : 192.168.0.2
   VRRP Track Information:
     Track Object   : 1                   State : Positive   Pri Reduced : 50
# Display detailed information about VRRP group 1 on Device B.
[DeviceB-Vlan-interface2] display vrrp verbose
     Admin Status   : Up                   State        : Backup
     Config Pri     : 100                  Running Pri  : 100
     Become Master  : 401ms left
     Auth Type      : None
The output shows that Device A is operating as the master in VRRP group 1 to forward packets from Host A to Host B.
# Disconnect the link between Host A and Device A, and verify that Host A can still ping Host B. (Details not shown.)
     Auth Type      : None
     Master IP      : 192.168.0.3
The output shows that when Device A fails, Device B takes over to forward packets from Host A to Host B.
# Recover the link between Host A and Device A, and display detailed information about VRRP group 1 on Device A.
     Auth Type      : None
The output shows that after Device A resumes normal operation, it becomes the master to forward packets from Host A to Host B.
Configuration files
·     Device A:
vlan 2
interface Vlan-interface2
 ip address 192.168.0.1 255.255.255.0
 vrrp vrid 1 virtual-ip 192.168.0.2
interface Ten-GigabitEthernet3/0/1
 port link-mode bridge
 port access vlan 2
 track 1 interface ten-gigabitethernet 3/0/2
·     Device B:
vlan 2
 port access vlan 2
Example: Configuring multiple VRRP groups
As shown in Figure 2, configure two VRRP groups on Device A and Device B as gateways for internal hosts to meet the following requirements:
·     Device A operates as the master of VRRP group 1 to forward packets from area A, and Device B operates as the master of VRRP group 2 to forward packets from area B. When one of the devices fails, the other device provides gateway service for both areas.
·     When the uplink interface of one device fails, hosts can access the external network through the other device.
Figure 2 Network diagram
·     To avoid loops between Device A, Device B, and the Layer 2 switches, use the spanning tree feature to block a port in the two VRRP groups.
When you configure multiple VRRP groups, follow these restrictions and guidelines:
¡     Loopback address.
·     Make sure the following configurations are the same on the members of a VRRP group:
¡     Number of virtual IP addresses.
¡     Virtual IP addresses.
¡     Advertisement interval.
# Configure interface IP addresses. (Take one interface as example. Configure other interfaces as shown in Figure 2 in the same way.)
[DeviceA] vlan 101
[DeviceA-vlan101] port ten-gigabitethernet 3/0/1
[DeviceA-vlan101] quit
[DeviceA] interface vlan-interface 101
[DeviceA-Vlan-interface101] undo shutdown
[DeviceA-Vlan-interface101] ip address 10.0.0.2 24
[DeviceA-Vlan-interface101] quit
# Configure Ten-GigabitEthernet 3/0/24 as a trunk port and assign it to VLAN 101 and VLAN 102.
[DeviceA] interface ten-gigabitethernet 3/0/24
[DeviceA-Ten-GigabitEthernet3/0/24] port link-type trunk
[DeviceA-Ten-GigabitEthernet3/0/24] undo port trunk permit vlan 1
[DeviceA-Ten-GigabitEthernet3/0/24] port trunk permit vlan 101 to 102
[DeviceA-Ten-GigabitEthernet3/0/24] port trunk pvid vlan 101
[DeviceA-Ten-GigabitEthernet3/0/24] quit
# Disable the spanning tree feature on Ten-GigabitEthernet 3/0/2.
[DeviceA-Ten-GigabitEthernet3/0/2] undo stp enable
# Create VRRP group 1, and set its virtual IP address to 10.0.0.1. Assign Device A higher priority than Device B in VRRP group 1, so Device A can become the master.
[DeviceA-Vlan-interface101] vrrp vrid 1 virtual-ip 10.0.0.1
[DeviceA-Vlan-interface101] vrrp vrid 1 priority 120
# Create VRRP group 2, and set its virtual IP address to 11.0.0.1.
[DeviceA] interface vlan-interface 102
[DeviceA-Vlan-interface102] vrrp vrid 2 virtual-ip 11.0.0.1
[DeviceA-Vlan-interface102] quit
[DeviceA-Vlan-interface101] vrrp vrid 1 preempt-mode delay 5
# Create track entry 1 to monitor the upstream link status of VLAN-interface 4094. When the upstream link fails, the track entry transits to Negative.
[DeviceA] track 1 interface vlan-interface 4094
[DeviceA-Vlan-interface101] vrrp vrid 1 track 1 reduced 50
# Configure MSTP, and map VLAN 101 to MSTI 1 and VLAN 102 to MSTI 2. Configure Device A as the root bridge of MSTI 1.
[DeviceA] stp region-configuration
[DeviceA-mst-region] region-name vrrp
[DeviceA-mst-region] instance 1 vlan 101
[DeviceA-mst-region] instance 2 vlan 102
[DeviceA-mst-region] active region-configuration
[DeviceA-mst-region] quit
[DeviceA] stp instance 1 root primary
[DeviceA] stp instance 2 root secondary
[DeviceA] stp global enable
[DeviceB] vlan 101
[DeviceB-vlan101] port ten-gigabitethernet 3/0/1
[DeviceB-vlan101] quit
[DeviceB] interface vlan-interface 101
[DeviceB-Vlan-interface101] undo shutdown
[DeviceB-Vlan-interface101] ip address 10.0.0.3 24
[DeviceB-Vlan-interface101] quit
[DeviceB] interface ten-gigabitethernet 3/0/24
[DeviceB-Ten-GigabitEthernet3/0/24] port link-type trunk
[DeviceB-Ten-GigabitEthernet3/0/24] undo port trunk permit vlan 1
[DeviceB-Ten-GigabitEthernet3/0/24] port trunk permit vlan 101 to 102
[DeviceB-Ten-GigabitEthernet3/0/24] port trunk pvid vlan 101
[DeviceB-Ten-GigabitEthernet3/0/24] quit
[DeviceB-Ten-GigabitEthernet3/0/2] undo stp enable
[DeviceB-Ten-GigabitEthernet3/0/2] quit
[DeviceB-Vlan-interface101] vrrp vrid 1 virtual-ip 10.0.0.1
# Create VRRP group 2, and set its virtual IP address to 11.0.0.1. Assign Device B higher priority than Device A in VRRP group 2, so Device B can become the master.
[DeviceB] interface vlan-interface 102
[DeviceB-Vlan-interface102] vrrp vrid 2 virtual-ip 11.0.0.1
[DeviceB-Vlan-interface102] vrrp vrid 2 priority 120
[DeviceB-Vlan-interface102] vrrp vrid 2 preempt-mode delay 5
[DeviceB-Vlan-interface102] quit
# Create track entry 2 to monitor the upstream link status of VLAN-interface 4094. When the upstream link fails, the track entry transits to Negative.
[DeviceB] track 2 interface vlan-interface 4094
# Associate VRRP group 2 with track entry 2 to decrease the weight of Device A by 50 when the track entry transits to Negative.
[DeviceB-Vlan-interface102] vrrp vrid 2 track 2 reduced 50
# Configure MSTP, and map VLAN 101 to MSTI 1 and VLAN 102 to MSTI 2. Configure Device B as the root bridge of MSTI 2.
[DeviceB] stp region-configuration
[DeviceB-mst-region] region-name vrrp
[DeviceB-mst-region] instance 1 vlan 101
[DeviceB-mst-region] instance 2 vlan 102
[DeviceB-mst-region] active region-configuration
[DeviceB-mst-region] quit
[DeviceB] stp instance 2 root primary
[DeviceB] stp instance 1 root secondary
[DeviceB] stp global enable
3.     Configure L2SwitchA:
# Configure MSTP, and map VLAN 101 to MSTI 1. Activate the MST region configuration, and enable the spanning tree feature globally.
<L2SwitchA> system-view
[L2SwitchA] stp region-configuration
[L2SwitchA-mst-region] region-name vrrp
[L2SwitchA-mst-region] instance 1 vlan 101
[L2SwitchA-mst-region] active region-configuration
[L2SwitchA-mst-region] quit
[L2SwitchA] stp global enable
4.     Configure L2SwitchB:
# Configure MSTP, and map VLAN 102 to MSTI 1. Activate the MST region configuration, and enable the spanning tree feature globally.
<L2SwitchB> system-view
[L2SwitchB] stp region-configuration
[L2SwitchB-mst-region] region-name vrrp
[L2SwitchB-mst-region] instance 1 vlan 102
[L2SwitchB-mst-region] active region-configuration
[L2SwitchB-mst-region] quit
[L2SwitchB] stp global enable
1.     Ping the external network to verify the network connectivity:
# Ping 100.0.0.1 from Host A in area A.
<host A> ping 100.0.0.1
PING 100.0.0.1 (100.0.0.1): 56 data bytes
56 bytes from 100.0.0.1: seq=0 ttl=128 time=22.43 ms
56 bytes from 100.0.0.1: seq=1 ttl=128 time=7.17 ms
56 bytes from 100.0.0.1: seq=2 ttl=128 time=8.91 ms
56 bytes from 100.0.0.1: seq=3 ttl=128 time=7.45 ms
56 bytes from 100.0.0.1: seq=4 ttl=128 time=9.11 ms
--- 100.0.0.1 ping statistics ---
5 packets transmitted, 5 packets received, 0% packet loss
round-trip min/avg/max = 7.17/11.01/22.43 ms
The output shows that Host A can ping the external network successfully.
# Ping 100.1.0.1 from Host C in area B.
<host C> ping 100.1.0.1
PING 100.1.0.1 (100.1.0.1): 56 data bytes
56 bytes from 100.1.0.1: seq=0 ttl=128 time=22.43 ms
56 bytes from 100.1.0.1: seq=1 ttl=128 time=7.17 ms
56 bytes from 100.1.0.1: seq=2 ttl=128 time=8.91 ms
56 bytes from 100.1.0.1: seq=3 ttl=128 time=7.45 ms
56 bytes from 100.1.0.1: seq=4 ttl=128 time=9.11 ms
--- 100.1.0.1 ping statistics ---
The output shows that Host C can ping the external network successfully.
2.     Verify the VRRP group configuration:
# Display detailed information about the VRRP groups on Device A.
[DeviceA] display vrrp verbose
   Interface Vlan-interface101
     Config Pri     : 120                  Running Pri  : 120
     Auth Type      : None
     Virtual IP     : 10.0.0.1
     Master IP      : 10.0.0.2
   Interface Vlan-interface102
     VRID           : 2                    Adver Timer  : 100
     Preempt Mode   : Yes                  Delay Time   : 0
     Auth Type      : None
     Virtual IP     : 11.0.0.1
     Master IP      : 11.0.0.3
The output shows that Device A is operating as the master in VRRP group 1 and backup in VRRP group 2.
# Display detailed information about the VRRP groups on Device B.
[DeviceB] display vrrp verbose
     Auth Type      : None
     Auth Type      : None
     Virtual MAC    : 0000-5e00-0102
     Track Object   : 2                   State : Positive   Pri Reduced : 50
The output shows that Device B is operating as the backup in VRRP group 1 and master in VRRP group 2.
# When Device A fails, display detailed information about the VRRP groups on Device B.
     Auth Type      : None
     Master IP      : 10.0.0.3
     Auth Type      : None
The output shows that Device B becomes the master in VRRP group 1. Hosts in area A and area B can still ping the external network successfully.
# When Device A recovers, display detailed information about the VRRP groups on Device A.
     Auth Type      : None
     Become Master  : 3550ms left
     Auth Type      : None
The output shows that after Device A resumes normal operation, it becomes the master in VRRP group 1. Hosts in VLAN 101 access the external network through Device A.
Configuration files
·     Device A:
vlan 101 to 102
vlan 4094
 region-name vrrp
 instance 1 vlan 101
 instance 2 vlan 102
 stp global enable
interface Vlan-interface101
 ip address 10.0.0.2 255.255.255.0
interface Vlan-interface102
 ip address 11.0.0.2 255.255.255.0
interface Vlan-interface4094
 ip address 100.0.0.2 255.255.255.0
 port access vlan 101
interface Ten-GigabitEthernet3/0/2
 port access vlan 4094
 undo stp enable
interface Ten-GigabitEthernet3/0/3
 port access vlan 102
interface Ten-GigabitEthernet3/0/24
·     Device B:
vlan 101 to 102
vlan 4094
 region-name vrrp
 instance 1 vlan 101
 instance 2 vlan 102
 stp global enable
 ip address 10.0.0.3 255.255.255.0
 ip address 11.0.0.3 255.255.255.0
 ip address 100.1.0.2 255.255.255.0
 undo stp enable
 track 2 interface ten-gigabitethernet 3/0/2
Example: Configuring VRRP load balancing
As shown in Figure 3, configure a load-balanced VRRP group on Device A, Device B, and Device C as the gateway for the hosts to meet the following requirements:
·     Packets from the hosts are load balanced among the devices.
·     When one device fails, hosts can access the external network through the other devices.
Figure 3 Network diagram
·     For traffic to be switched to the other two devices when the uplink interface of one device fails, configure VF tracking on Device A, Device B, and Device C. When the uplink interface of one device fails, the weights of the VFs (including the AVF) on the device decrease by a specified value.
·     For the failed device to become the master when it recovers, configure the preemptive mode for the VRRP group.
When you configure VRRP load balancing, follow these restrictions and guidelines:
¡     Loopback address.
·     In load balancing mode, the virtual IP address of a VRRP group cannot be the IP address of any interface in the VRRP group. Otherwise, VRRP load balancing cannot operate correctly.
·     When the upstream link of the VF owner fails, an LVF must take over as the AVF. The switchover occurs when the weight of the VF owner drops below the lower limit of failure. This requires the reduced weight for the VF owner to be higher than 245.
Configuring Device A
1.     Configure interface IP addresses:
[DeviceA] vlan 2
[DeviceA-Vlan-interface2] ip address 10.1.1.2 24
[DeviceA] vlan 3
2.     Configure VRRP:
# Configure VRRP to operate in load balancing mode.
[DeviceA] vrrp mode load-balance
# Create VRRP group 1, and set its virtual IP address to 10.1.1.1.
[DeviceA-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
# Assign Device A the highest priority in VRRP group 1, so Device A can become the master.
[DeviceA-Vlan-interface2] vrrp vrid 1 priority 120
3.     Configure Track:
# Configure the VFs in VRRP group 1 to monitor track entry 1, and decrease their weights by 250 when the track entry transits to Negative.
[DeviceA-Vlan-interface2] vrrp vrid 1 weight track 1 reduced 250
Configuring Device B
[DeviceB] vlan 2
[DeviceB-Vlan-interface2] ip address 10.1.1.3 24
[DeviceB] vlan 3
[DeviceB-vlan3] port ten-gigabitethernet 3/0/2
[DeviceB-vlan3] quit
[DeviceB] interface vlan-interface 3
[DeviceB-Vlan-interface3] quit
2.     Configure VRRP:
[DeviceB] vrrp mode load-balance
[DeviceB-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
# Assign Device B higher priority than Device C in VRRP group 1, so Device B can become the master when Device A fails.
[DeviceB-Vlan-interface2] vrrp vrid 1 priority 110
3.     Configure Track:
[DeviceB] track 1 interface vlan-interface 3
[DeviceB-Vlan-interface2] vrrp vrid 1 weight track 1 reduced 250
Configuring Device C
<DeviceC> system-view
[DeviceC] interface ten-gigabitethernet 3/0/1
[DeviceC-Ten-GigabitEthernet3/0/1] undo shutdown
[DeviceC-Ten-GigabitEthernet3/0/1] quit
[DeviceC] vlan 2
[DeviceC-vlan2] port ten-gigabitethernet 3/0/1
[DeviceC-vlan2] quit
[DeviceC] interface vlan-interface 2
[DeviceC-Vlan-interface2] undo shutdown
[DeviceC-Vlan-interface2] ip address 10.1.1.4 24
[DeviceC-Vlan-interface2] quit
[DeviceC] vlan 3
[DeviceC-vlan3] port ten-gigabitethernet 3/0/2
[DeviceC-vlan3] quit
[DeviceC] interface vlan-interface 3
[DeviceC-Vlan-interface3] quit
2.     Configure VRRP:
[DeviceC] vrrp mode load-balance
[DeviceC-Vlan-interface2] vrrp vrid 1 virtual-ip 10.1.1.1
# Configure Device C to operate in preemptive mode, and set the preemption delay to 5 seconds.
[DeviceC-Vlan-interface2] vrrp vrid 1 preempt-mode delay 5
3.     Configure Track:
[DeviceC] track 1 interface vlan-interface 3
[DeviceC-Vlan-interface2] vrrp vrid 1 weight track 1 reduced 250
# Verify that Host A can ping the external network. (Details not shown.)
IPv4 Virtual Device Information:
 Running Mode      : Load Balance
     Auth Type      : None
     Virtual IP     : 10.1.1.1
     Member IP List : 10.1.1.2 (Local, Master)
                      10.1.1.3 (Backup)
                      10.1.1.4 (Backup)
   Forwarder Information: 3 Forwarders 1 Active
     Config Weight  : 255
     Running Weight : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-0011 (Owner)
     Owner ID       : 0000-5e01-1101
     Priority       : 255
     Active         : local
    Forwarder 02
     State          : Listening
     Virtual MAC    : 000f-e2ff-0012 (Learnt)
     Owner ID       : 0000-5e01-1103
     Priority       : 127
     Active         : 10.1.1.3
    Forwarder 03
     State          : Listening
     Virtual MAC    : 000f-e2ff-0013 (Learnt)
     Owner ID       : 0000-5e01-1105
     Priority       : 127
     Active         : 10.1.1.4
   Forwarder Weight Track Information:
     Track Object   : 1          State : Positive   Weight Reduced : 250
     Auth Type      : None
     Member IP List : 10.1.1.3 (Local, Backup)
                      10.1.1.2 (Master)
                      10.1.1.4 (Backup)
     Config Weight  : 255
    Forwarder 01
     State          : Listening
     Virtual MAC    : 000f-e2ff-0011 (Learnt)
     Priority       : 127
     Active         : 10.1.1.2
    Forwarder 02
     State          : Active
     Virtual MAC    : 000f-e2ff-0012 (Owner)
     Priority       : 255
     Active         : local
    Forwarder 03
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.4
# Display detailed information about VRRP group 1 on Device C.
[DeviceC] display vrrp verbose
     Auth Type      : None
     Member IP List : 10.1.1.4 (Local, Backup)
                      10.1.1.2 (Master)
                      10.1.1.3 (Backup)
     Config Weight  : 255
    Forwarder 01
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.2
    Forwarder 02
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.3
    Forwarder 03
     State          : Active
     Virtual MAC    : 000f-e2ff-0013 (Owner)
     Priority       : 255
     Active         : local
The output shows that Device A is the master in VRRP group 1, and each of the three devices has one AVF and two LVFs.
# Disconnect the link of VLAN-interface 3 on Device A, and display detailed information about VRRP group 1 on Device A.
     Auth Type      : None
                      10.1.1.3 (Backup)
                      10.1.1.4 (Backup)
   Forwarder Information: 3 Forwarders 0 Active
     Config Weight  : 255
     Running Weight : 5
    Forwarder 01
     State          : Initialize
     Priority       : 0
     Active         : 10.1.1.4
    Forwarder 02
     State          : Initialize
     Priority       : 0
     Active         : 10.1.1.3
    Forwarder 03
     State          : Initialize
     Priority       : 0
     Active         : 10.1.1.4
     Track Object   : 1          State : Negative   Weight Reduced : 250
     Auth Type      : None
                      10.1.1.2 (Master)
                      10.1.1.3 (Backup)
   Forwarder Information: 3 Forwarders 2 Active
     Config Weight  : 255
    Forwarder 01
     State          : Active
     Virtual MAC    : 000f-e2ff-0011 (Take Over)
     Priority       : 85
     Active         : local
     Redirect Time  : 93 secs
     Time-out Time  : 1293 secs
    Forwarder 02
     State          : Listening
     Priority       : 85
     Active         : 10.1.1.3
    Forwarder 03
     State          : Active
     Priority       : 255
     Active         : local
The output shows that when the uplink interface of Device A fails, the weights of the VFs on Device A drop below the lower limit of failure. All VFs on Device A transit to Initialized state and cannot forward traffic. The VF for MAC address 000f-e2ff-0011 on Device C becomes the AVF to forward traffic.
# When the timeout timer (about 1800 seconds) expires, display detailed information about VRRP group 1 on Device C.
     Auth Type      : None
                      10.1.1.2 (Master)
                      10.1.1.3 (Backup)
   Forwarder Information: 2 Forwarders 1 Active
     Config Weight  : 255
    Forwarder 02
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.3
    Forwarder 03
     State          : Active
     Priority       : 255
     Active         : local
The output shows that when the timeout timer expires, the VF for virtual MAC address 000f-e2ff-0011 is removed. The VF no longer forwards the packets destined for the MAC address.
# When Device A fails, display detailed information about VRRP group 1 on Device B.
 IPv4 Standby Information:
     Run Mode       : Load Balance
     Run Method     : Virtual MAC
     Auth Type      : None
     Member IP List : 10.1.1.3 (Local, Master)
                      10.1.1.4 (Backup)
     Config Weight  : 255
    Forwarder 02
     State          : Active
     Priority       : 255
     Active         : local
    Forwarder 03
     State          : Listening
     Priority       : 127
     Active         : 10.1.1.4
The output shows that when Device A fails, Device B becomes the master because it has higher priority than Device C.
Configuration files
·     Device A:
 vlan 2 to 3
interface Vlan-interface3
 port access vlan 2
 port access vlan 3
track 1 interface vlan-interface3
·     Device B:
 vlan 2 to 3
 ip address 10.1.1.3 255.255.255.0
 port access vlan 2
 port access vlan 3
·     Device C:
 vlan 2 to 3
 ip address 10.1.1.4 255.255.255.0
 port access vlan 2
 port access vlan 3
Related documentation
·     H3C S12500 Routing Switch Series High Availability Command Reference-Release 7328
·     H3C S12500 Routing Switch Series High Availability Configuration Guide-Release 7328
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Command Reference-Release 7328
·     H3C S12500 Routing Switch Series Layer 2—LAN Switching Configuration Guide-Release 7328
