04-H3C S12500 IPv6 over IPv4 GRE Tunnel Configuration Examples
Chapters Download (116.56 KB)
| 04-H3C S12500 IPv6 over IPv4 GRE Tunnel Configuration Examples | 116.56 KB |
This document provides IPv6 over IPv4 GRE tunnel configuration examples.
This document assumes that you have basic knowledge of GRE.
As shown in Figure 1, Device A, Device B, and Device C are all on an IPv4 network. Dual stack devices Device A and Device B each connect to an IPv6 host.
Configure a GRE/IPv4 tunnel between Device A and Device B, so PC A and PC B can communicate with each other over the IPv4 network.
To enable the IPv6 hosts to communicate over the IPv4 network, specify the GRE tunnel mode as GRE/IPv4 and configure IPv6 addresses for the tunnel interfaces.
To transmit packets between PC A and PC B through the GRE tunnel, configure a route reaching the destination network through the tunnel interface on Device A and Device B. You can configure the routes by using either of the following methods:
· Configure static routes, using the peer tunnel interface as the next hop or using the local tunnel interface as the outgoing interface.
· Enable a dynamic routing protocol on both the tunnel interfaces and the Layer 3 interfaces connected to PC A and PC B.
For both ends of the GRE tunnel to reach each other, configure a static route reaching the remote end on Device A and Device B.
This configuration example was created and verified on S12500-CMW710-R7328P02.
You must configure the tunnel source address and destination address at both ends of the tunnel. The tunnel source or destination address at one end must be the tunnel destination or source address at the other end.
# Configure interface VLAN-interface 10.
[DeviceA] vlan 10
[DeviceA-vlan 10] port gigabitethernet2/0/1
[DeviceA-vlan 10] quit
[DeviceA-Vlan-interface10] ip address 192.13.2.2 24
# Configure other interfaces in the same way VLAN-interface 10 is configured. (Details not shown.)
# Create a tunnel interface Tunnel 0, and specify the tunnel mode as GRE/IPv4.
[DeviceA] interface tunnel 0 mode gre
# Configure an IPv6 address for the tunnel interface Tunnel 0.
[DeviceA-Tunnel0] ipv6 address 3001::1 64
# Configure the source address of the tunnel interface Tunnel 0 as the IP address of VLAN-interface 10.
[DeviceA-Tunnel0] source 192.13.2.2
# Configure the destination address of the tunnel interface Tunnel 0 as the IP address of VLAN-interface 11 on Device B.
[DeviceA-Tunnel0] destination 131.108.5.2
[DeviceA-Tunnel0] quit
# Configure a static route reaching PC B through the tunnel interface Tunnel 0.
[DeviceA] ipv6 route-static 2001:: 64 tunnel 0
# Configure a static route reaching the remote end of the GRE tunnel.
[DeviceA] ip route-static 131.108.5.2 255.255.255.0 192.13.2.1
# Configure interface VLAN-interface 11.
[DeviceB] vlan 11
[DeviceB-vlan 11] port gigabitethernet2/0/2
[DeviceB-vlan 11] quit
[DeviceB] interface vlan-interface 11
[DeviceB-Vlan-interface11] ip address 131.108.5.2 24
[DeviceB-Vlan-interface11] quit
# Configure other interfaces in the same way VLAN-interface 11 is configured. (Details not shown.)
[DeviceB] interface tunnel 0 mode gre
[DeviceB-Tunnel0] ipv6 address 3001::2 64
# Configure the source address of the tunnel interface Tunnel 0 as the IP address of VLAN-interface 11.
[DeviceB-Tunnel0] source 131.108.5.2
# Configure the destination address of the tunnel interface Tunnel 0 as the IP address of VLAN-interface 10 on Device A.
[DeviceB-Tunnel0] destination 192.13.2.2
[DeviceB-Tunnel0] quit
# Configure a static route reaching PC A through the tunnel interface Tunnel 0.
[DeviceB] ipv6 route-static 1001:: 64 Tunnel 0
[DeviceB] ip route-static 192.13.2.2 255.255.255.0 131.108.5.1
<DeviceC> system-view
[DeviceC] vlan 10
[DeviceC-vlan 10] port gigabitethernet2/0/1
[DeviceC-vlan 10] quit
[DeviceC] interface vlan-interface 10
[DeviceC-Vlan-interface10] ip address 192.13.2.1 24
[DeviceC-Vlan-interface10] quit
[DeviceC] vlan 11
[DeviceC-vlan 11] port gigabitethernet2/0/2
[DeviceC-vlan 11] quit
[DeviceC] interface vlan-interface 11
[DeviceC-Vlan-interface11] ip address 131.108.5.1 24
[DeviceC-Vlan-interface11] quit
# Verify that PC A and PC B can ping each other successfully. This example uses PC A to ping PC B.
C:\>ping6 2001::2
Pinging 2001::2
from 1001::1 with 32 bytes of data:
Reply from 2001::2: bytes=32 time<1ms
Ping statistics for 2001::2:
Minimum = 0ms, Maximum = 0ms, Average = 0ms
· Device A:
vlan 10
vlan 20
interface GigabitEthernet2/0/1
port link-mode bridge
port access vlan 10
interface GigabitEthernet3/0/1
port access vlan 20
interface interface Vlan-interface 10
port link-mode route
ip address 192.13.2.2 255.255.255.0
interface interface Vlan-interface 20
ipv6 address 1001::1/64
interface Tunnel0 mode gre
ipv6 address 3001::1/64
source 192.13.2.2
ipv6 route-static 2001:: 64 Tunnel 0
· Device B:
vlan 11
vlan 20
interface GigabitEthernet2/0/2
port access vlan 11
port access vlan 20
interface interface Vlan-interface 11
ip address 131.108.5.2 255.255.255.0
ipv6 address 2001::1/64
ipv6 address 3001::2/64
source 131.108.5.2
· Device C:
vlan 10
vlan 11
port access vlan 10
port access vlan 11
ip address 192.13.2.1 255.255.255.0
ip address 131.108.5.1 255.255.255.0
· H3C S12500 Routing Switch Series Layer 3—IP Services Configuration Guide-Release 7328
· H3C S12500 Routing Switch Series Layer 3—IP Services Command Reference-Release 7328
