01-Probe Commands
display hardware internal ipuc adj index
debug hardware internal mpls { error | event }
debugging hardware internal drv_l2 fdb au-message
debugging system internal adj4
debugging system internal arp event
debugging system internal arp features
debugging system internal arp notify
debugging system internal arp sync
debugging system internal fib prefix
debugging system internal fib vn
debugging system internal httpd
debugging system internal igmp-snooping fsm tracing
debugging system internal ip vpn-instance
debugging system internal ipv6 fib prefix
debugging system internal mld-snooping fsm tracing
debugging system internal vlan
display hardware internal devd
display hardware internal device
display hardware internal diag board-check
display hardware internal diag buffer-usage
display hardware internal diag forward-path check
display hardware internal driver boot information
display hardware internal driver diag standby-to-master
display hardware internal driver dstm control stackport
display hardware internal driver dstm hello-packet exceptioninfo
display hardware internal driver dstm hello-packet summary
display hardware internal driver dstm selfmemberinfo
display hardware internal driver dstm stackport
display hardware internal driver dstm topodata
display hardware internal driver dstm topoinfo
display hardware internal driver dstm { diaginfo | exceptioninfo }
display hardware internal driver eth-controller info
display hardware internal driver eth-controller mib
display hardware internal driver eth-controller queue
display hardware internal driver etsec mib
display hardware internal driver ha overtime-task
display hardware internal driver phy-xg register dump
display hardware internal driver register etsec
display hardware internal driver register lsw
display hardware internal driver reserved_memory
display hardware internal driver rxtx high-usage-packet
display hardware internal driver { phy-g | phy-xg } register
display hardware internal drv_l2 fdb hash-info
display hardware internal drv_l2 fdb hw-table
display hardware internal drv_l2 four-irf forward-path
display hardware internal drv_l2 mstp
display hardware internal drv_l2 port global-info
display hardware internal drv_l2 port mac-ctrl-reg
display hardware internal drv_l2 port mib-counters-reg
display hardware internal drv_l2 port port-status-reg
display hardware internal drv_l2 port vlan-qos-config
display hardware internal drv_l2 port { port-peak-rate | port-state-info | port-traffic-state }
display hardware internal drv_l2 trunk
display hardware internal drv_l2 trunk designated-port-entry
display hardware internal drv_l2 vlan vlan-hw-table
display hardware internal drv_l2 vlan vlan-port-tagged
display hardware internal ekdm slot
display hardware internal ekdm-sync
display hardware internal fa flow-control enable slot chip
display hardware internal fa flow-control status slot chip
display hardware internal fa fport-cell-statistic slot chip
display hardware internal fa fport-rx-cell-drop slot chip
display hardware internal fa fport-tx-cell-drop slot chip
display hardware internal fa fport-tx-fifo-status slot chip
display hardware internal fa voq drop slot chip unit
display hardware internal fa voq statistic slot chip unit
display hardware internal fabric connectivity-table
display hardware internal fabric d-function
display hardware internal fabric fap flow-queue-table
display hardware internal fabric fap portqos
display hardware internal fabric fap queue-flow-table
display hardware internal fabric fap queue-flow-table tgtslot
display hardware internal fabric fap queue-size
display hardware internal fabric fap queue-size non-empty
display hardware internal fabric link-status
display hardware internal fabric mc-route
display hardware internal fabric mc-route counter
display hardware internal fabric mc-route mode
display hardware internal fabric mc-route phylist
display hardware internal fabric prbs-mode
display hardware internal fabric register dump
display hardware internal fabric unicast-table
display hardware internal fcoe dit
display hardware internal fcoe interface Vfc
display hardware internal fcoe key-info
display hardware internal fcoe op route
display hardware internal fcoe route
display hardware internal forward counter
display hardware internal forward err-info
display hardware internal fwd egress-resource slot chip txq-port
display hardware internal fwd ingress-buffer slot chip physical-port
display hardware internal fwd pfc key-info slot chip port
display hardware internal ha masterboard-standbyboard
display hardware internal ha switch-info
display hardware internal ibc control-path-check state
display hardware internal ibc lanswitch egresscntr | ingresscntr
display hardware internal ibc lanswitch mactable
display hardware internal ibc lanswitch portmap
display hardware internal ibc lanswitch portmib
display hardware internal ibc lanswitch vlan
display hardware internal ibc rxpkt
display hardware internal ibc rxque
display hardware internal ibc txpkt
display hardware internal ipuc cnt
display hardware internal ipuc fib
display hardware internal ipuc fib number
display hardware internal ipuc op
display hardware internal ipuc op adj
display hardware internal l2mc mac-table { igsp | mldsp | static }
display hardware internal l2mc { igsp | mldsp | static }
display hardware internal l3mc counter
display hardware internal l3mc dit
display hardware internal l3mc ditcnt
display hardware internal l3mc lbp
display hardware internal l3mc localvpninfo vpnid
display hardware internal l3mc lpm bipim ipv4
display hardware internal l3mc lpm ipv4/ipv6
display hardware internal l3mc mroute ipv4/ipv6
display hardware internal l3mc nexthop
display hardware internal l3mc openflow
display hardware internal l3mc openflow trunk-route
display hardware internal l3mc tcam
display hardware internal l3mc tunnel
display hardware internal l3mc vidx
display hardware internal l3mc vrfinfo vrid
display hardware internal mirror
display hardware internal mpls debugging
display hardware internal mpls dit
display hardware internal mpls evi-hashpcl
display hardware internal mpls evi-info globalvar
display hardware internal mpls evi-instance
display hardware internal mpls evi-link
display hardware internal mpls evi-operation
display hardware internal mpls evi-tunnel
display hardware internal mpls evi-vlan
display hardware internal mpls frr dit
display hardware internal mpls infilter
display hardware internal mpls labelinfo inlabel
display hardware internal mpls mpls variable
display hardware internal mpls nhlfe
display hardware internal mpls nhlfecnt
display hardware internal mpls spb bmacinfo
display hardware internal mpls spb bvlan
display hardware internal mpls spb fabricvidx
display hardware internal mpls spb lbpinfo
display hardware internal mpls spb operation
display hardware internal mpls spb pwinfo
display hardware internal mpls spb tunnelinfo
display hardware internal mpls spb variable
display hardware internal mpls spb vidx
display hardware internal mpls tablesize
display hardware internal mpls tticnt
display hardware internal mpls tunnel
display hardware internal mpls vpws
display hardware internal mpls vpws actti
display hardware internal nst packet-statistic
display hardware internal packet-drop
display hardware internal pcl irfdest resource
display hardware internal pcl irfdest tti
display hardware internal pcl pce-entry slot
display hardware internal qos buffer-count
display hardware internal register
display hardware internal register dump
display hardware internal rxtx device-status
display hardware internal rxtx dma
display hardware internal rxtx interrupt
display hardware internal rxtx packet
display hardware internal rxtx rxpkt
display hardware internal rxtx txpkt
display hardware internal sflow interface
display hardware internal temperature-limit
display hardware internal tunnel
display system internal adj4 entry
display system internal adj4 statistics
display system internal adjacent-table
display system internal arp ifcb
display system internal arp ip-address
display system internal arp machash
display system internal arp probe
display system internal arp reload
display system internal arp source-suppression cache
display system internal arp statistics
display system internal arp vlan
display system internal bgp graceful-restart statistics
display system internal bgp instance statistics
display system internal bgp interface
display system internal bgp l2vpn auto-discovery advertise
display system internal bgp l2vpn auto-discovery verbose
display system internal bgp l2vpn signaling advertise
display system internal bgp l2vpn signaling verbose
display system internal bgp nib
display system internal bgp nib log
display system internal bgp peer statistics
display system internal bgp protocol statistics
display system internal bgp routing-table advertise-info
display system internal bgp routing-table verbose
display system internal control-plane management statistics
display system internal ethernet character
display system internal ethernet controlblock
display system internal evi flooding
display system internal evi selective-flooding
display system internal evi statistics
display system internal evi vlan-mapping
display system internal evi vlan-status
display system internal evi-link data
display system internal eviisis status
display system internal fib prefix
display system internal fib prefix entry-status
display system internal fib prefix ip
display system internal fib running-status
display system internal fib statistics
display system internal fib vn
display system internal fib vn entry-status
display system internal fib vn reference
display system internal ha service
display system internal ha service-group
display system internal ha statistics
display system internal httpd service
display system internal ifmgr brief
display system internal ifmgr down
display system internal ifmgr entry
display system internal ifmgr event
display system internal ifmgr hotplug
display system internal ifmgr index
display system internal ifmgr list
display system internal ifmgr mdc
display system internal ifmgr name
display system internal ifmgr type
display system internal ip address
display system internal ip source binding
display system internal ip vpn-binding
display system internal ip vpn-instance
display system internal ip vpn-instance inactive
display system internal ip vpn-instance statistics
display system internal ipv6 address
display system internal ipv6 fib prefix
display system internal ipv6 fib prefix entry-status
display system internal ipv6 fib prefix ipv6
display system internal ipv6 l2-multicast ip forwarding verbose
display system internal ipv6 l2-multicast ip verbose
display system internal ipv6 l2-multicast ipc statistics
display system internal ipv6 l2-multicast mac forwarding verbose
display system internal ipv6 l2-multicast mac verbose
display system internal ipv6 mrib interface statistics
display system internal ipv6 mrib mbr
display system internal ipv6 multicast forwarding vlan reference
display system internal ipv6 multicast forwarding-table dummy
display system internal ipv6 multicast forwarding-table verbose
display system internal ipv6 multicast-vlan forwarding-table verbose
display system internal ipv6 pathmtu
display system internal ipv6 pbr fib
display system internal ipv6 pbr kernel policy
display system internal ipv6 pbr policy
display system internal ipv6 pim interface
display system internal ipv6 pim rp
display system internal ipv6 pim thread
display system internal ipv6 rawip
display system internal ipv6 rib event attribute
display system internal ipv6 rib event policy
display system internal ipv6 rib event prefix
display system internal ipv6 rib event protocol
display system internal ipv6 rib event statistics
display system internal ipv6 rib log
display system internal ipv6 rib memory
display system internal ipv6 rib nib log
display system internal ipv6 rib prefix
display system internal ipv6 rib summary
display system internal ipv6 route-direct interface
display system internal ipv6 route-direct log
display system internal ipv6 route-static nib log
display system internal ipv6 source binding
display system internal ipv6 tcp
display system internal ipv6 udp
display system internal isis import-route
display system internal isis import-route ipv6
display system internal isis interface
display system internal isis interface ipv6
display system internal isis nib
display system internal isis nib ipv6
display system internal isis nib log
display system internal isis prefix
display system internal isis prefix ipv6
display system internal isis status
display system internal kernel memory dump
display system internal kernel memory pool
display system internal l2-multicast ip forwarding verbose
display system internal l2-multicast ip verbose
display system internal l2-multicast ipc statistics
display system internal l2-multicast mac forwarding verbose
display system internal l2-multicast mac verbose
display system internal l2vpn l2vfib record
display system internal l2vpn l2vfib statistics
display system internal link-aggregation global
display system internal link-aggregation interface
display system internal lipc lcmp statistics
display system internal lipc lgmp group
display system internal lipc lgmp group-list
display system internal lipc lgmp physical-group
display system internal lipc lgmp physical-group-list
display system internal lipc lgmp statistics
display system internal lipc lip statistics
display system internal lipc loop statistics
display system internal lipc mtcp group
display system internal lipc mtcp performance
display system internal lipc mtcp statistics
display system internal lipc pcb statistics
display system internal lipc physical
display system internal lipc publish global-cb
display system internal lipc publish statistics
display system internal lipc stcp event
display system internal lipc stcp global-server
display system internal lipc stcp links
display system internal lipc stcp performance
display system internal lipc stcp statistics
display system internal lipc stcp status
display system internal lipc stream
display system internal lipc sudp pcb-info
display system internal lipc sudp statistics
display system internal lipc sudp { global-port | local-port }
display system internal lipc topology history
display system internal lipc topology link
display system internal lipc topology node
display system internal lipc topology process-time
display system internal lipc topology statistics
display system internal lipc topology status
display system internal mac-address configuration
display system internal mac-address statistics
display system internal mbuf relay statistics
display system internal mbuf statistics
display system internal mpls lfib ilm
display system internal mpls lfib nhlfe
display system internal mpls lfib nhlfe reflist
display system internal mpls lfib record
display system internal mpls lfib statistics
display system internal mpls lsp-pending
display system internal mpls statistics
display system internal mrib interface statistics
display system internal mrib mbr
display system internal multicast capability
display system internal multicast forwarding vlan reference
display system internal multicast forwarding-table dummy
display system internal multicast forwarding-table verbose
display system internal multicast record
display system internal multicast-vlan forwarding-table verbose
display system internal mvrp interface
display system internal mvrp map-count
display system internal nd dad
display system internal nd entry
display system internal nd ifcb
display system internal nd machash
display system internal nd probe
display system internal nd reload
display system internal nd static
display system internal nd statistics
display system internal ospf event-log
display system internal ospf interface
display system internal ospf lsdb
display system internal ospf nib
display system internal ospf prefix
display system internal ospf status
display system internal ospfv3 event-log
display system internal ospfv3 interface
display system internal ospfv3 lsdb
display system internal ospfv3 nib
display system internal ospfv3 prefix
display system internal ospfv3 status
display system internal pbr fib
display system internal pbr kernel policy
display system internal pbr policy
display system internal pim interface
display system internal pim rp
display system internal pim thread
display system internal rib event attribute
display system internal rib event policy
display system internal rib event prefix
display system internal rib event protocol
display system internal rib event statistics
display system internal rib log
display system internal rib memory
display system internal rib nib log
display system internal rib prefix
display system internal rib summary
display system internal rip interface
display system internal rip nib
display system internal rip nib log
display system internal rip status
display system internal ripng interface
display system internal ripng nib
display system internal ripng nib log
display system internal ripng status
display system internal route-direct interface
display system internal route-direct log
display system internal route-static nib log
display system internal sflow statistics
display system internal startup cache
display system internal stp bridge-info
display system internal stp port-info
display system internal tunnel data
display system internal zone acl
irf link-status auto-recovery enable
reset hardware internal mpls evi-operation
reset system internal adj4 statistics
reset system internal arp statistics
reset system internal fib statistics
reset system internal ipv6 multicast forwarding-table dummy
reset system internal ipv6 route-static nib log
reset system internal mac-address statistics
reset system internal mbuf relay statistics
reset system internal mpls lfib record
reset system internal multicast forwarding-table dummy
reset system internal multicast record
reset system internal nd statistics
reset system internal sflow statistics
set hardware internal diag monitor-control
set hardware internal driver { phy-g | phy-xg } register
set hardware internal fa fport-rx-cell-cfg slot chip fport
set hardware internal fa fport-tx-cell-cfg slot chip fport
set hardware internal fan low-speed-thresh speed
set hardware internal fcoe op route
set hardware internal ibc lanswitch egresscntr | ingresscntr bind
set hardware internal ipuc cnt
set hardware internal ipuc dropcnt
set hardware internal l3mc counter
set hardware internal l3mc ditcnt
set hardware internal mpls dit_load_balance
set hardware internal mpls nhlfecntbind
set hardware internal mpls nhlfecntunbind
set hardware internal mpls tticntbind
set hardware internal mpls tticntunbind
IPv4 fast forwarding probe commands
display system internal ip fast-forwarding cache verbose
display system internal ip fast-forwarding service-sequence
IPv6 fast forwarding probe commands
display system internal ipv6 fast-forwarding cache verbose
display system internal ipv6 fast-forwarding service-information
display system internal ipv6 fast-forwarding statistics
reset system internal ipv6 fast-forwarding statistics
IPv6 adjacency table probe commands
debugging system internal adj6
display system internal adj6 entry
display system internal adj6 statistics
display system internal ipv6 adjacent-table
reset system internal adj6 statistics
The commands in this book are designed only for developers to debug software.
D
Use display hardware internal ipuc adj index to display MAC addresses stored in hardware for ARP and ND.
display hardware internal ipuc adj index index slot slot-number
In IRF mode:
display hardware internal ipuc adj index index chassis chassis-number slot slot-number
Probe view
index index: Specifies the index of ARP and ND entries in hardware.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
Use debug hardware internal mpls { error | event } to enable a type of MPLS debugging.
debug hardware internal mpls basic-entry slot slot-number
debug hardware internal mpls basic-error slot slot-number
debug hardware internal mpls basic-event slot slot-number
debug hardware internal mpls bfd-error slot slot-number
debug hardware internal mpls bfd-event slot slot-number
debug hardware internal mpls diag-error slot slot-number
debug hardware internal mpls diag-event slot slot-number
debug hardware internal mpls evi-error slot slot-number
debug hardware internal mpls evi-event slot slot-number
debug hardware internal mpls l3vpn-error slot slot-number
debug hardware internal mpls l3vpn -event slot slot-number
debug hardware internal mpls vll-error slot slot-number
debug hardware internal mpls vll-event slot slot-number
debug hardware internal mpls vpls-error slot slot-number
debug hardware internal mpls vpls-event slot slot-number
debug hardware internal mpls spb-error slot slot-number
debug hardware internal mpls spb-event slot slot-number
Probe view
Use debugging hardware internal drv_l2 fdb au-message to display AU messages arriving at the bridge processing flow and the arrival time of each message.
debugging hardware internal drv_l2 fdb au-message { interface { interface-type interface-number | interface-name } | slot slot-number [ chip chip-number ] } [ mac mac-addr ] [ vlan vlan-id ] [ message-type type ] [ max-count count-num ]
Probe view
interface-name: Specifies an interface by its name. The interface can be an aggregate interface.
slot-number: Specifies the number of the slot that houses the interface card.
chip-number: Specifies the chip number of the entries to be displayed. The chip-number argument represents a chip ID of the interface card.
mac-addr: Specifies the MAC address of an entry.
vlan-id: Specifies the VLAN ID of an entry. The value range for this argument is 1 to 4095.
type: Specifies the AU message type. The value can be AA(3) or NA(0).
count-num: Specifies the maximum number of entries displayed. The value range for this argument is 1 to 4294967295.
debugging lipc
Use debugging lipc to enable debugging for LIPC.
debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo } [ lip lip ]
undo debugging lipc { detail | dump port | lgmp | mbuf | mtcp | pub | stcp | stream | topo | stream } [ lip lip ]
detail: Enables detailed debugging.
dump port: Specifies a port number in the range of 0 to 65535.
lgmp: Enables debugging for the LIPC LGMP module.
mbuf: Enables debugging for the LIPC MBUF module.
mtcp: Enables debugging for the LIPC MTCP module.
pub: Enables debugging for the LIPC PUB module.
stcp: Enables debugging for the LIPC STCP module.
stream: Enables debugging for the LIPC STREAM module.
topo: Enables debugging for the LIPC TOPO module.
lip lip: Specifies a remote node by its ID in the range of 0 to 32767.
Use debugging system internal adj4 to enable IPv4 adjacency entry debugging.
Use undo debugging system internal adj4 to remove the configuration.
debugging system internal adj4 { hardware | bind | notify | entry }
undo debugging system internal adj4 { hardware | bind | notify | entry }
IPv4 adjacency debugging is disabled.
Probe view
hardware: Specifies IPv4 adjacency entry hardware debugging.
bind: Specifies debugging for a VN/NHLFE binding.
notify: Specifies debugging for VN/NHLFE binding update when an IPv4 adjacency entry changes.
entry: Specifies debugging for IPv4 adjacency entry update.
Use debugging system internal arp event to enable ARP event debugging.
Use undo debugging system internal arp event to disable ARP event debugging.
ARP event debugging is disabled.
Probe view
Use debugging system internal arp features to enable ARP features debugging.
Use undo debugging system internal arp features to disable ARP features debugging.
debugging system internal arp features { notify | packet }
undo debugging system internal arp features { notify | packet }
ARP features debugging is disabled.
Probe view
notify: Enables notification debugging for ARP features.
packet: Enables packet debugging for ARP features.
Use debugging system internal arp notify to enable ARP notification debugging.
Use undo debugging system internal arp notify to disable ARP notification debugging.
ARP notification debugging is disabled.
Probe view
Use debugging system internal arp sync to enable ARP synchronization debugging.
Use undo debugging system internal arp sync to disable ARP synchronization debugging.
ARP synchronization debugging is disabled.
Probe view
Use debugging system internal fib prefix to enable FIB debugging.
Use undo debugging system internal fib prefix to disable FIB debugging.
In standalone mode:
debugging system internal fib prefix { all | message | hardware } slot slot-number
undo debugging system internal fib prefix { all | message | hardware } slot slot-number
In IRF mode:
debugging system internal fib prefix { all | message | hardware } chassis chassis-number slot slot-number
undo debugging system internal fib prefix { all | message | hardware } chassis chassis-number slot slot-number
FIB debugging is disabled.
Probe view
all: Enables all types of debugging.
message: Enables message debugging. The output displays information about IPv4 FIB prefixes that are distributed by routers and synchronized by cards.
hardware: Enables hardware debugging. The output displays information sent to drivers and returned information by drivers.
Use debugging system internal fib vn to enable VN debugging.
Use undo debugging system internal fib vn to disable VN debugging.
In standalone mode:
debugging system internal fib vn { all | message | hardware | bind | notify } slot slot-number
undo debugging system internal fib vn { all | message | hardware | bind | notify } slot slot-number
In IRF mode:
debugging system internal fib vn { all | message | hardware | bind | notify } chassis chassis-number slot slot-number
undo debugging system internal fib vn { all | message | hardware | bind | notify } chassis chassis-number slot slot-number
VN debugging is disabled.
Probe view
message: Enables message debugging. The output displays VN entries that are sent by routers and synchronized by cards.
hardware: Enables hardware debugging. The output displays information sent to drivers and information returned by drivers.
bind: Enables bind debugging. The output displays information about prefix-bound VN and VN-bound adjacency table/next hop label forwarding entry (NHLFE).
notify: Enables notify debugging. The output displays adjacency table/NHLFE change notification sent to the VN, and VN change notification sent to the prefix table.
Use debugging system internal httpd to enable HTTPD debugging.
Use undo debugging system internal httpd to disable HTTPD debugging.
debugging system internal httpd { all | event | process | error }
undo debugging system internal httpd { all | event | process | error }
Probe view
all: Enables all types of debugging for HTTPD.
event: Enables event debugging for HTTPD.
process: Enables process debugging for HTTPD.
error: Enables error debugging for HTTPD.
Use debugging system internal igmp-snooping fsm tracing to enable trace log debugging for the IGMP snooping state machine.
Use undo debugging system internal igmp-snooping fsm tracing to disable trace log debugging for the IGMP snooping state machine.
In standalone mode:
debugging system internal igmp-snooping fsm tracing [ vlan vlan-id [ group-address source-address ] ] [ slot slot-number ]
In IRF mode:
debugging system internal igmp-snooping fsm tracing [ vlan vlan-id [ group-address source-address ] ] [ chassis chassis-number slot slot-number ]
Trace log debugging for the IGMP snooping state machine is disabled.
Probe view
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command outputs trace logs for all VLANs.
group-address: Specifies a multicast group address. If this argument is not specified, this command outputs trace logs for all multicast groups.
source-address: Specifies a multicast source address. If this argument is not specified, this command outputs trace logs for all multicast sources.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command outputs trace logs for all cards. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command outputs trace logs for all cards in the IRF fabric. (In IRF mode.)
Use debugging system internal ip vpn-instance to enable VPN instance debugging.
Use undo debugging system internal ip vpn-instance to disable VPN instance debugging.
debugging system internal ip vpn-instance slot slot-number
undo debugging system internal ip vpn-instance slot slot-number
debugging system internal ip vpn-instance chassis chassis-number slot slot-number
undo debugging system internal ip vpn-instance chassis chassis-number slot slot-number
VPN instance debugging is disabled.
Probe view
slot slot-number: Specifies a card. The slot-number argument represents the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card of an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that holds the card. (In IRF mode.)
Use debugging system internal ipv6 fib prefix to enable IPv6 FIB prefix debugging.
Use undo debugging system internal ipv6 fib prefix to disable IPv6 FIB prefix debugging.
In standalone mode:
debugging system internal ipv6 fib prefix { all | message | hardware } slot slot-number
undo debugging system internal ipv6 fib prefix { all | message | hardware } slot slot-number
In IRF mode:
debugging system internal ipv6 fib prefix { all | message | hardware } chassis chassis-number slot slot-number
undo debugging system internal ipv6 fib prefix { all | message | hardware } chassis chassis-number slot slot-number
IPv6 FIB prefix debugging is disabled.
Probe view
all: Enables all types of IPv6 FIB prefix debugging.
message: Enables IPv6 FIB prefix message debugging. If you specify this keyword, the system displays the IPv6 FIB prefix obtained from the routing table or synchronized from other cards or devices.
hardware: Enables IPv6 FIB prefix hardware debugging. If you specify this keyword, the system displays the FIB6 information issued to the driver, and the returned FIB6 information from the driver.
slot slot-number: Enables IPv6 FIB prefix debugging for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Enables IPv6 FIB prefix debugging for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
Use debugging system internal mld-snooping fsm tracing to enable trace log debugging for the MLD snooping state machine.
Use undo debugging system internal mld-snooping fsm tracing to disable trace log debugging for the MLD snooping state machine.
In standalone mode:
debugging system internal mld-snooping fsm tracing [ vlan vlan-id [ ipv6-group-address ipv6-source-address ] ] [ slot slot-number ]
In IRF mode:
debugging system internal mld-snooping fsm tracing [ vlan vlan-id [ ipv6-group-address ipv6-source-address ] ] [ chassis chassis-number slot slot-number ]
Trace log debugging for the MLD snooping state machine is disabled.
Probe view
group ipv6-group-address: Specifies an IPv6 multicast group address. If this option is not specified, this command outputs trace logs for all IPv6 multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source address. If this option is not specified, this command outputs trace logs for all IPv6 multicast sources.
debugging system internal nd
Use debugging system internal nd to enable ND debugging.
Use undo debugging system internal nd to disable ND debugging.
debugging system internal nd { notify | sync }
undo debugging system internal nd { notify | sync }
ND debugging is disabled.
Probe view
notify: Enables ND notification debugging.
sync: Enables ND synchronization debugging.
debugging system internal stg
Use debugging system internal stg to enable outputting STG debugging information.
Use undo debugging system internal stg to disable outputting STG debugging information.
debugging system internal stg { all | bind | error | map | state | tc }
undo debugging system internal stg { all | bind | error | map | state | tc }
This function is disabled.
Probe view
all: Specifies all STG debugging information.
bind: Specifies STG VLAN mapping debugging information.
error: Specifies STG error debugging information.
map: Specifies STG-to-STI mapping debugging information.
state: Specifies STG status debugging information.
tc: Specifies TC event debugging information.
debugging system internal stp
Use debugging system internal stp to enable outputting IPC debugging information for STP.
Use undo debugging system internal stp to disable outputting IPC debugging information for STP.
debugging system internal stp ipc
undo debugging system internal stp ipc
Probe view
ipc: Specifies IPC debugging information for STP.
Use debugging system internal vlan to enable debugging for VLANs.
Use undo debugging system internal vlan to disable debugging for VLANs.
debugging system internal vlan { all | error | event | execution | hardware }
undo debugging system internal vlan { all | error | event | execution | hardware }
Debugging for VLANs is disabled.
Probe view
all: Enables all types of debugging for VLANs.
error: Enables error debugging for VLANs.
event: Enables event debugging for VLANs.
execution: Enables execution debugging for VLANs.
hardware: Enables hardware debugging for VLANs.
display fan auto-control-mode
Use display fan auto-control-mode to display the current fan operating mode.
In standalone mode:
In IRF mode:
display fan auto-control-mode chassis chassis-number
Probe view
chassis chassis-number: Specifies a member device by its member ID.
Use display hardware internal devd to display card status change events and global events.
display hardware internal devd global-event slot-number cpu-number
display hardware internal devd board-event slot-number cpu-number
Probe view
global-event: Specifies global events.
board-event: Specifies card status change events.
cpu-number: Specifies a CPU number. The value range is 0 to 1.
Use display hardware internal device to display detailed information about the device.
Probe view
Use display hardware internal diag board-check to display fast diagnosis records for a card.
display hardware internal diag board-check slot slot-number [ oam ]
Probe view
slot-number: Specifies an MPU.
oam: Specifies an auxiliary CPU.
Use display hardware internal diag buffer-usage to display the buffer usage within 24 hours.
display hardware internal diag buffer-usage slot slotid chip chipnum
Probe view
slotid: Specifies a card by its slot number.
chipnum: Specifies a chip by its number.
Use display hardware internal diag forward-path check to verify whether a card can exchange diagnostic packets with other cards when service diagnosis has been enabled.
display hardware internal diag forward-path check slot-number chip-number
Probe view
slot-number: Specifies a slot.
chip-number: Specifies a chip.
After you execute this command, the system prints information if service diagnosis fails or packet loss occurs. If no exception occurs to service detection, the system does not print any information.
Use display hardware internal driver boot information to display the bootstrap records of a card.
display hardware internal driver boot information { previous [ standby ] | current } [ slot slot-number [ cpu cpu-number ] ] [ clear ]
Probe view
previous: Specifies the previous bootstrap.
standby: Specifies the local standby cards.
current: Specifies the current bootstrap.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays the bootstrap records of the MPUs.
cpu cpu-number: Specifies a CPU number. Values include 0 (the host CPU) and 1 (the auxiliary CPU).
clear: Clears the records.
Use display hardware internal driver diag standby-to-master to display standby-to-active switchover records.
display hardware internal driver diag standby-to-master get-num from-num slot slot-number
Probe view
get-num: Specifies the number of records to be displayed.
from-num: Specifies a record offset to display the specified record and all subsequent records.
slot slot-number: Specifies an MPU by its slot number.
Use display hardware internal driver dstm control stackport to display the IRF-port control data that DSTM has on a CPU.
This command is available only in IRF mode.
display hardware internal driver dstm control stackport slot slot-number cpu cpu-number
Probe view
slot slot-number: Specifies a card by its global slot number (the slot number of the card relative to the entire IRF fabric rather than the chassis).
cpu cpu-number: Specifies a CPU by its number. 0 represents the host CPU, and 1 represents the OAM auxiliary CPU.
Use display hardware internal driver dstm hello-packet exceptioninfo to display STM hello packet exception statistics on an MPU.
display hardware internal driver dstm hello-packet exceptioninfo [ clear ] slot Mr-slot-number
Probe view
clear: Clears hello packet exception records.
slot Mr-slot-number: Specifies an MPU by its global slot number (the slot number of the MPU relative to the entire IRF fabric rather than the chassis).
Use display hardware internal driver dstm hello-packet summary to display STM hello packet statistics on an MPU.
display hardware internal driver dstm hello-packet summary slot Mr-slot-number
Probe view
Use display hardware internal driver dstm selfmemberinfo to display IRF member device information that DSTM has on a CPU.
display hardware internal driver dstm selfmemberinfo slot slot-number cpu cpu-number
Probe view
Use display hardware internal driver dstm stackport to display IRF port data and driver information that DSTM has on a CPU for an IRF port.
display hardware internal driver dstm stackport port-number slot slot-number cpu cpu-number [ clear ]
Probe
Probe view
stackport port-number: Specifies the IRF port index, which only can be 1 or 2.
clear: Clears IRF port data and driver information for the specified IRF port.
Use display hardware internal driver dstm topodata to display topology records that DSTM has on a CPU, including forwarding paths, connections, and topology type.
display hardware internal driver dstm topodata slot slot-number cpu cpu-number
Probe view
Use display hardware internal driver dstm topoinfo to display IRF topology information that DSTM has on a CPU. The information includes the chassis numbers, MPU slot numbers, and CPU MAC addresses of its neighbors.
display hardware internal driver dstm topoinfo slot slot-number cpu cpu-number
Probe view
Use display hardware internal driver dstm { diaginfo | exceptioninfo } to display DSTM diagnostic or exception records on a CPU.
display hardware internal driver dstm { diaginfo | exceptioninfo } slot slot-number cpu cpu-number [ clear | { after | before } date time [ reverse ] ]
Probe view
diaginfo: Specifies diagnostic records.
exceptioninfo: Specifies exception records.
clear: Clears diagnostic or exception records.
after: Specifies the records collected since the specified date and time.
before: Specifies the records collected before the specified date and time.
date: Specifies a date in the format MM/DD/YYYY or YYYY/MM/DD. The YYYY value is in the range of 2000 to 2035, the MM value is in the range of 1 to 12, and the value range for DD depends on the month value.
time: Specifies a time in the format hh:mm:ss. The hh value is in the range of 0 to 23, the mm value is in the range of 0 to 59, and the ss value is in the range of 0 to 59. The leading zero in a segment can be omitted. If the seconds segment is 0 (hh:mm:00), you can omit it. If both the minutes and seconds segments are 0 (hh:00:00), you can omit both of the segments. For example, to specify 08:00:00, you can enter 8.
reverse: Displays records in reverse chronological order, with the most recent record at the top.
Use display hardware internal driver eth-controller info to display a DTSEC port's data send/receive information, MAC information, and hardware error information.
display hardware internal driver eth-controller info slot slot-number port port-number
Probe view
slot slot-number: Specifies a slot number.
port port-number: Specifies a port number.
Use display hardware internal driver eth-controller mib to display MIB statistics for a DTSEC port.
display hardware internal driver eth-controller mib slot slot-number port port-number
Probe view
Use display hardware internal driver eth-controller queue to display the queue information of a DTSEC port.
display hardware internal driver eth-controller queue slot slot-number [ { queue queue-number | port port-number } ]
Probe view
queue queue-number: Specifies a queue number.
Use display hardware internal driver etsec mib to display MIB statistics for an ETSEC port.
display hardware internal driver [ oam ] etsec mib slot slot-number port port-number
Probe view
oam: Specifies the OAM CPU.
port port-number: Specifies a port number. Values include:
· For an MPU:
? 0—Network interface.
? 1—Port connected to the peer CPU.
? 2—Port connected to the LAN switch.
· For a line card:
? 0—Port connected to the LAN switch.
? 3—Reserved.
· For an OAM card:
? 0—Port connected to the peer OAM CPU.
? 3—Port connected to the LAN switch.
display hardware internal driver led-alarm-source
Use display hardware internal driver led-alarm-source to display LED alarm reasons.
display hardware internal driver led-alarm-source [ slot slot-number ]
Probe view
Use display hardware internal driver ha overtime-task to display the stack information for overtime tasks.
display hardware internal driver ha overtime-task slot slot-number cpu cpu-number
Probe view
Use display hardware internal driver phy-xg register dump to display the contents of the PHY register of a slot.
display hardware internal driver phy-xg register dump slot slot-number
Probe view
Use display hardware internal driver register etsec to display registers for an ETSEC port.
display hardware internal driver [ oam ] register etsec slot slot-number port port-number
Probe view
Use display hardware internal driver register lsw to display LAN switch chip information.
display hardware internal driver register lsw [ slot slot-number [ chip chip-number [ { port port-number } | reg-addr ] ] ]
Probe view
chip chip-number: Specifies a chip number.
reg-addr: Specifies a register address.
Use display hardware internal driver reserved_memory to display the information in the reserved memory space.
display hardware internal driver reserved_memory [ slot slot-number [ cpu cpu-number ] ] [ clear ]
Probe view
Use display hardware internal driver rxtx high-usage-packet to display packet information recorded when the CPU usage on a line card exceeded the threshold.
display hardware internal driver rxtx high-usage-packet slot slot-number
Probe view
slot slot-number: Specifies a line card by its slot number
Use display hardware internal driver { phy-g | phy-xg } register to display the contents of the PHY register of a port.
display hardware internal driver phy-g register interface { interface-type interface-number | interface-name } { internal | external } address address
display hardware internal driver phy-xg register interface { interface-type interface-number | interface-name } sublayer sub-number address address
Probe view
internal: Displays the internal PHY information.
external: Displays the external PHY information.
address: Specifies the address of a PHY register.
Use display hardware internal drv_l2 fdb hash-info to display the contents of the hash lookup table of a chip.
display hardware internal drv_l2 fdb hash-info { mac mac-addr vlan vlan-id | hash-value value } slot slot-number chip chip-number
display hardware internal drv_l2 fdb hash-info vpls-type mac mac-addr vpn-id vpn-id slot slot-number chip chip-number
Probe view
mac-addr: Specifies an MAC address.
value: Specifies the first hash value of an MAC address entry.
vpn-id: Specifies a VPN ID.
Use display hardware internal drv_l2 fdb hw-table to display the contents of the hardware forwarding database (FDB) and filter the contents by the combination of parameters.
display hardware internal drv_l2 fdb hw-table [ mac-type [ mac mac-addr ] [ vlan vlan-id ] [ static static-status ] [ userdefined define-num ] [ age age-flag ] [ sa-cmd sa-cmd ] [ da-cmd da-cmd ] [ da-route route-flag ] [ sp sp-flag ] [ dev dev-num phy-port phy-port-num ] [ dev dev-num ] [ trunk-id trunk-num ] | vpls-type [ mac mac-addr ] [ static static-status ] [ age age-flag ] [ pw-id pw-num ] [ inlif-id inlif-id ] [ dit-pointer pointer-num ] [ dev dev-num ] [ trunk-id trunk-num ] | slot slot-number chip chip-number [ [ beginning-address address ] [ max-num max-num ] | [ count ] ]
Probe view
IMPORTANT: When the value of a field can be 0 or 1, typically, 0 indicates No or Not Set, and 1 indicates Yes or Set. |
mac-type: Specifies the bridge MAC address entries.
vpls-type: Specifies the VPLS MAC address entries.
vlan-id: Specifies the VLAN ID of an entry. The value range for this argument is 0 to 4095.
static-status: Specifies the static flag of an entry. The value of this argument can be 0 or 1.
define-num: Specifies the user-defined field of an entry. The value range for this argument is 0 to 15.
age-flag: Specifies the aging flag of an entry. The value of this argument can be 0 or 1.
sa-cmd: Specifies the forwarding decision field matching the source MAC address of an entry. The value range for this argument is 0 to 4.
da-cmd: Specifies the forwarding decision field matching the destination MAC address of an entry. The value range for this argument is 0 to 4.
route-flag: Specifies the field that determines whether to forward a packet whose destination address is matched to the Layer 3 engine. The value of this argument is 0 or 1.
sp-flag: Specifies whether the entry is an SP entry. The value of this argument can be 0 or 1.
dev-num: Specifies the device number of an entry. The value range for this argument is 0 to 127.
phy-port-num: Specifies the physical port number of an entry. The value range for this argument is 0 to 63.
trunk-num: Specifies the aggregation group number of an entry. The value range for this argument is 1 to 255.
pw-num: Specifies a PW-ID. This argument takes effect when the entry type is VPLS. The value range for this argument is 0 to 127.
inlif-id: Specifies the InLif ID of an entry. The value range for this argument is 0 to 16383.
pointer-num: Specifies the DIT pointer of a VPLS entry. The value range for this argument is 0 to 65535.
slot-number: Specifies the slot number of the entries to be displayed. The slot-number argument represents the number of the slot that houses the interface card.
address: Specifies the start address of the entries to be displayed. The value range for this argument is the start address of the FDB to the end address of the FDB.
max-num: Specifies the maximum number of entries displayed. The value range for this argument is 1 to 500.
count: Displays only the entry count.
Use display hardware internal drv_l2 four-irf forward-path to display all cross-chassis forwarding paths for an interface card or MPU in a four-chassis IRF fabric.
display hardware internal drv_l2 four-irf forward-path slot slot-number
Probe view
slot slot-number: Specifies an interface card or MPU by its slot number.
Use display hardware internal drv_l2 mstp to display the hardware entry status of the SPT instance or the software entry status of the STP, DLDP, LACP, and ETHOAM instances.
display hardware internal drv_l2 mstp slot slot-number { instance instance-id software | chip chip-number instance instance-id hardware }
Probe view
software: Specifies the software entry status.
hardware: Specifies the hardware entry status.
slot-number: Specifies an interface card by its slot number.
chip-number: Specifies a chip by its slot number.
instance-Id: Specifies an instance by its ID. The value range for this argument is 0 to 255 for software entries and is 0 to 4095 for hardware entries.
Use display hardware internal drv_l2 port global-info to display the global variables of an interface.
display hardware internal drv_l2 port global-info interface interface-name
Probe view
Use display hardware internal drv_l2 port mac-ctrl-reg to display the contents of the MAC control register of a port.
display hardware internal drv_l2 port mac-ctrl-reg interface { interface-type interface-number | interface-name }
Probe view
Use display hardware internal drv_l2 port mib-counters-reg to display the contents of the MIB counters register of a port.
display hardware internal drv_l2 port mib-counters-reg interface { interface-type interface-number | interface-name }
Probe view
Use display hardware internal drv_l2 port mac-ctrl-reg to display the contents of the status register of a port.
display hardware internal drv_l2 port port-status-reg interface { interface-type interface-number | interface-name }
Probe view
Use display hardware internal drv_l2 port vlan-qos-config to display the contents of the port VLAN and QoS configuration table register of a port.
display hardware internal drv_l2 port vlan-qos-config interface { interface-type interface-number | interface-name }
Probe view
Use display hardware internal drv_l2 port { port-peak-rate | port-state-info | port-traffic-state } to display the status, traffic, and history peak rate changes of a port.
display hardware internal drv_l2 port { port-peak-rate | port-state-info | port-traffic-state } { interface interface-name | slot slot-number }
Probe view
Use display hardware internal drv_l2 trunk to display the link aggregation unicast table and the non-trunk table.
display hardware internal drv_l2 trunk trunk-id slot slot-number chip chip-number
Probe view
trunk-id: Specifies an aggregation group by its ID in the range of 1 to 255.
chip-number: Specifies a chip by its chip number.
Use display hardware internal drv_l2 trunk designated-port-entry to display the link aggregation multicast table.
display hardware internal drv_l2 trunk designated-port-entry index slot slot-number chip chip-number
Probe view
index: Specifies the index of the link aggregation multicast table, in the range of 0 to 15.
Use display hardware internal drv_l2 vlan vlan-hw-table to display information about VLAN hardware entries in the specified chip.
display hardware internal drv_l2 vlan vlan-hw-table { start-vlan start-vlan-id [ max-count count-num ] | vlan vlan-id } slot slot-number chip chip-number
Probe view
start-vlan-id: Specifies a start VLAN by its ID in the range of 0 to 4095.
count-num: Specifies the maximum number of VLANs, in the range of 1 to 10.
vlan-id: Specified a VLAN by its ID in the range of 0 to 4095.
Use display hardware internal drv_l2 vlan vlan-port-tagged to display information about VLAN tagged ports.
display hardware internal drv_l2 vlan vlan-port-tagged vlan-id slot slot-number
Probe view
vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
Use display hardware internal ekdm to display the card core information saved on a card.
display hardware internal ekdm slot slot-number cpu cpu-number
Probe view
Use display hardware internal ekdm-sync to display the inter-card core data synchronization information saved on an MPU's primary CPU or secondary CPU.
display hardware internal ekdm-sync [ mr-slot cpu-number ]
Probe view
mr-slot: Specifies an MPU by its slot number. If you do not specify this argument, the command displays the information saved on the active MPU's CPUs.
Use display hardware internal fa flow-control enable slot chip to display the flow-control enable status on an FA port.
display hardware internal fa flow-control enable slot slot-number chip chip-num
Probe view
slot-number: Specifies a destination card by its slot number. The value range depends on the actual chassis.
chip-num: Specifies a PP chip by its number in the range of 0 to 3.
Use display hardware internal fa flow-control status slot chip to display the flow-control status on an FA port.
display hardware internal fa flow-control status slot slot-number chip chip-num
Probe view
Use display hardware internal fa fport-cell-statistic slot chip to display the Tx and Rx cell statistics on an FA port.
display hardware internal fa fport-cell-statistic slot slot-number chip chip-num
Probe view
Use display hardware internal fa fport-rx-cell-drop slot chip to display Rx cell drop statistics on a port.
display hardware internal fa fport-rx-cell-drop slot slot-number chip chip-num
Probe view
Use display hardware internal fa fport-tx-cell-drop slot chip to display the Tx cell drop statistics on a port.
display hardware internal fa fport-tx-cell-drop slot slot-num chip chip-num
Probe view
Use display hardware internal fa fport-tx-fifo-status slot chip to display the FIFO status of a port.
display hardware internal fa fport-tx-fifo-status slot slot-number chip chip-num
Probe view
Use display hardware internal fa voq drop slot chip unit to display VOQ drop statistics.
display hardware internal fa voq drop slot slot-num chip chip-num unit unit-num
Probe view
unit-num: Specifies a VOQ unit by its number, 0 or 1.
Use display hardware internal fa voq statistic slot chip unit to display VOQ statistics.
display hardware internal fa voq statistic slot slot-number chip chip-num unit unit-num
Probe view
Use display hardware internal fabric link-status to display connectivity information.
Probe view
chipnum: Specifies a chip by its number in the range of 0 to 3.
Use display hardware internal fabric d-function to call the dune interface to implement the function of a concrete interface.
display hardware internal fabric d-function d-function-id slot slot-number chip chipnum [ help ] [ param1 [ param2 [ param3 [ param4 [ param5 ] ] ] ] ]
Probe view
d-function-id: Specifies a dune interface by its ID.
slot-num: Specifies a card by its slot number.
chipnum: Specifies a FAP or FE chip by its number in the range of 0 to 3.
param1: Specifies parameter 1.
param2: Specifies parameter 2.
param3: Specifies parameter 3.
param4: Specifies parameter 4.
param5: Specifies parameter 5.
Use display hardware internal fabric fap flow-queue-table to display detailed FQL entry information, including the flow type, flow ID, source queue ID, and source FAP device number.
display hardware internal fabric fap flow-queue-table slot slotid chip chipnum [ flownum [ querylen ] ]
Probe view
flownum: Specifies a flow by its number in the range of 0 to (12K-1). The default is 0.
querylen: Specifies the query length in the range of 1 to 16. The default is 8.
Use display hardware internal fabric fap portqos to display the port hierarchical relationships configured on the FAP chip.
display hardware internal fabric fap portqos slot slotnum chip chipnum port portnum [ wrrgroup [ INTEGER<0-3> ] ] [ tc [ INTEGER<0-7> ] ] [ credit-rate ]
Probe view
portnum: Specifies a port by its number. The port corresponds to the output interface.
creditrate: Displays the credit rate of the corresponding flow.
Use display hardware internal fabric fap queue-flow-table to display detailed QFL entry information, including the queue type, mapped traffic flow, destination FAP device number and port, and queue size.
display hardware internal fabric fap queue-flow-table slot slotid chip chipnum [ queuenum [ querylen ] ]
Probe view
queuenum: Specifies a queue by its ID in the range of 0 to (12K-1). The default is 0.
querylen: Specifies the query length in the range of 1 to 8. The default is 8.
Use display hardware internal fabric fap queue-flow-table tgtslot to display detailed QFL entry information according to destination slot number, destination chip number, and destination port number. Detailed QFL entry information includes the queue type, mapped traffic flow, destination FAP device number and port, and queue size.
display hardware internal fabric fap queue-flow-table slot slotid chip chipnum slot tgt-slotid chip tgt-chipnum port tgt-portnum
Probe view
tgt-slotid: Specifies the destination slot number.
tgt-chipnum: Specifies the destination chip number.
tgt-portnum: Specifies the destination port number (physical port number).
Use display hardware internal fabric fap queue-size to display queue sizes.
display hardware internal fabric fap queue-size slot slotid chip chipnum queuenum [ querylen ]
Probe view
querylen: Specifies the query length in the range of 1 to 100. Without this argument, the command displays the size of the specified queue. With this argument, for example, the argument is set to m, the command displays the sizes of m queues starting with the queue specified with the queuenum argument.
Use display hardware internal fabric fap queue-size non-empty to display the sizes of the most recent 100 non-empty queues.
display hardware internal fabric fap queue-size slot slotid chip chipnum non-empty [ start-queueunum ] [ verbose ]
Probe view
start-queuenum: Specifies the start queue ID in the range of 0 to (12K-1).
verbose: Displays detailed information about each queue.
Use display hardware internal fabric link-status to display the SERDES link status and parameters.
display hardware internal fabric link-status slot slotid chip chipnum [ link linknum ]
Probe view
linknum: Specifies a SERDES link number.
Use display hardware internal fabric mc-route to display fabric VIDX management data and VIDX software entries.
display hardware internal fabric mc-route { physical | virtual | vlan } slot mr-slotnum offset offset
display hardware internal fabric mc-route physical slot sfc-slotnum offset offset
display hardware internal fabric mc-route slot sfc-slotnum chip chip-num offset offset
Probe view
physical: Specifies VIDX multicast software entries set to the hardware. The entries are queried on the MPU and the network card.
vlan: Specifies VLAN multicast entries. The entries are queried only on the MPU.
virtual: Specifies virtual fabric VIDX multicast entries. The entries are queried only on the MPU.
mr-slotnum: Specifies a MPU by its slot number.
sfc-slotnum: Specifies a network card by its slot number.
offset: Specifies the VIDX number.
Use display hardware internal fabric mc-route counter to display the switching network multicast operation statistics.
display hardware internal fabric mc-route counter slot slot-number
Probe view
Use display hardware internal fabric mc-route mode to display the lbi mode.
Probe view
mode: Specifies the lbi mode.
Use display hardware internal fabric mc-route phylist to display the phyvidxnodes of each cursor in a list.
display hardware internal fabric mc-route phylist slot slot-number block block-num list list-num
Probe view
block-num: Specifies a block by its number. A block can be used by only one MDC.
list-num: Specifies a list by its number. The value represents the number of ports.
Use display hardware internal fabric prbs-mode to display the prbs mode.
display hardware internal fabric prbs-mode slot slotid chip chipnum [ lane lanenum ]
Probe view
lanenum: Specifies a link by its number.
Use display hardware internal fabric register dump to display FAP internal register values output from the MPU console.
display hardware internal fabric register slot slotid chip chipnum dump
Probe view
Use display hardware internal fabric unicast-table to display unicast information.
display hardware internal fabric unicast-table slot slotid chip chipnum
Probe view
display hardware internal fcoe dit
Use display hardware internal fcoe dit to display internal information about dit resources for an FC route on a card.
In standalone mode:
display hardware internal fcoe dit dit-id slot slot-number
In IRF mode:
display hardware internal fcoe dit dit-id chassis chassis-number slot slot-number
Probe view
dit dit-id: Specifies an FC route by its dit ID.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
display hardware internal fcoe interface Vfc
Use display hardware internal fcoe interface Vfc to display internal information about a VFC interface on a card.
In standalone mode:
display hardware internal fcoe interface Vfc interface-number vlan-id slot slot-number
In IRF mode:
display hardware internal fcoe interface Vfc interface-number vlan-id chassis chassis-number slot slot-number
Probe view
interface Vfc interface-number: Specifies a VFC interface by its number.
vlan-id: Specifies a VLAN by its ID to which the specified VFC interface belongs.
display hardware internal fcoe key-info
Use display hardware internal fcoe key-info to display internal key information about FCoE on a card.
In standalone mode:
display hardware internal fcoe key-info [ vsan vsan-id ] slot slot-number
In IRF mode:
display hardware internal fcoe key-info [ vsan vsan-id ] chassis chassis-number slot slot-number
Probe view
vsan vsan-id: Specifies a VSAN by its ID.
display hardware internal fcoe op route
Use display hardware internal fcoe op route to display internal information about route operation records on a card.
In standalone mode:
display hardware internal fcoe op route [ clear ] [ error ] slot slot-number
In IRF mode:
display hardware internal fcoe op route [ clear ] [ error ] chassis chassis-number slot slot-number
Probe view
clear: Deletes existing route operation records.
error: Displays the route operation records that fail to be issued.
display hardware internal fcoe route
Use display hardware internal fcoe route to display internal information about an FC route on a card.
In standalone mode:
display hardware internal fcoe route route-id slot slot-number
In IRF mode:
display hardware internal fcoe route route-id chassis chassis-number slot slot-number
Probe view
route route-id: Specifies an FC route by its route ID.
display hardware internal forward counter
Use display hardware internal forward counter to display key forwarding path statistics of PP, XBAR, FAP, DX (cascade chips, BV48, and XP32 cards), and FE chips.
In standalone mode:
display hardware internal forward counter [ slot slot-number ] [ drop | hgl | clear ]
display hardware internal forward counter { pp | fap | fe | dx } [ slot slot-number [ chip chip-num ] ] [ drop | hgl | clear ]
In IRF mode:
display hardware internal forward counter [ chassis chassis-num slot slot-number ] [ drop | hgl | clear ]
display hardware internal forward counter { pp | fap | fe | dx } [ chassis chassis-num slot slot-number ] [ chip chip-num ] [ drop | hgl | clear ]
Probe view
chassis-num: Specifies the ID of the IRF member device, 1 to 2.
slotid: Specifies the destination slot number. The slot number depends on the chassis.
chipnum: Specifies a chip by its number. The value range varies by chip:
· XBAR: 0 to 1.
· PP: 0 to 3.
· FAP: 0 to 3.
· DX: 4 to 7.
· FE: 0 to 1.
pp: Specifies the PP chip, which is on the interface card.
fap: Specifies the FAP chip, which is on the S12500 interface card.
fe: Specifies the FE chip, which is on the S12500 network card.
dx: Specifies the DX chip, which is on the cascade interface card.
drop: Displays only the drop or error statistics. Without this keyword, the command displays statistics of all types.
hgl: Displays HGL error related statistics.
clear: Clears all statistics.
display hardware internal forward err-info
Use display hardware internal forward err-info to display key interrupts of the system, including the interrupts on PP, XBAR, FAP, DX (cascade chip on GV48 and XP32 cards), and FE chips.
In standalone mode:
display hardware internal forward err-info [ slot slot-number ] [severity | hgl | clear ]
display hardware internal forward err-info { pp | fap | fe | dx } [ slot slot-number [ chip chip-num ] ] [severity | hgl | clear ]
In IRF mode:
display hardware internal forward err-info [ chassis chassis-num slot slot-number ] [severity | hgl | clear ]
display hardware internal forward err-info { pp | fap | fe | dx } [ chassis chassis-num slot slot-number ] [ chip chip-num ] [severity | hgl | clear ]
Probe view
· XBAR: 0 to 1.
· PP: 0 to 3.
· FAP: 0 to 3.
· DX: 4 to 7.
· FE: 0 to 1.
severity: Displays only the drop or error interrupts. Without this keyword, the command displays all interrupts.
hgl: Displays HGL error related interrupts.
clear: Clears all interrupts.
display hardware internal fwd egress-resource slot chip txq-port
Use display hardware internal fwd egress-resource slot chip txq-port to display the buffer statistics on a txp port.
display hardware internal fwd egress-resource slot slot-number chip chip-num txq-port txq-port-num
Probe view
slot-num: Specifies a card by its slot number. The value range depends on the chassis.
chip-num: Specifies a PP chip by its number. The value range depends on the card type.
txq-port-num: Specifies a txq port by its number in the range of 0 to 69.
display hardware internal fwd ingress-buffer slot chip physical-port
Use display hardware internal fwd ingress-buffer slot chip physical-port to display the buffer statistics on a physical port.
display hardware internal fwd ingress-buffer slot slot-number chip chip-num physical-port physical-port-num
Probe view
physical-port-num: Specifies a physical port by its number in the range of 0 to 63.
display hardware internal fwd pfc key-info slot chip port
Use display hardware internal fwd pfc key-info slot chip port to display key PFC information, including Bank and PFC ports to which virtual ports map, configured profiles, txq ports, count of each priority, and the threshold configurations.
display hardware internal fwd pfc key-info slot slot-number chip chip-num port port-num
Probe view
chip-num: Specifies a chip by its number.
port-num: Specifies a virtual port by its number.
display hardware internal ha masterboard-standbyboard
Use display hardware internal ha masterboard-standbyboard to display active/standby switchover information.
display hardware internal ha masterboard-standbyboard slot slot-number [ cpu cpu-number ]
Probe view
cpu cpu-number: Specifies a CPU by its chip number, 0 or 1.
display hardware internal ha switch-info
Use display hardware internal ha switch-info to display the active/standby switchover interruption records.
display hardware internal ha switch-info slot slot-number cpu cpu-number [ clear ]
Probe view
clear: Clears the active/standby switchover interruption records.
display hardware internal ibc control-path-check state
Use display hardware internal ibc control-path-check state to display the control path check state, including the card state, whether the check is enabled, whether the check is ongoing, and the check failures.
display hardware internal ibc control-path-check state slot slot-number
Probe view
slot slot-number: Specifies a slot by its number.
display hardware internal ibc lanswitch egresscntr | ingresscntr
Use display hardware internal ibc lanswitch egresscntr | ingresscntr to display bridge counter information on an LSW chip in a slot.
display hardware internal ibc lanswitch slot slot-number lsw lsw-number { egresscntr | ingresscntr }
Probe view
ingresscntr: Specifies an ingress bridge counter.
egresscntr: Specifies an egress bridge counter.
lsw-number: Specifies an LSW chip by its number in the range of 0 to 1.
display hardware internal ibc lanswitch mactable
Use display hardware internal ibc lanswitch mactable to display MAC table information on an LSW chip in a slot.
display hardware internal ibc lanswitch slot slot-number lsw lsw-number mactable
Probe view
display hardware internal ibc lanswitch portmap
Use display hardware internal ibc lanswitch portmap to display port mappings between the ports on an LSW chip in the specified slot and the peer ports. Information about the peer ports includes CPU IDs, PP IDs, physical port numbers, LSW chip numbers, and slot numbers. The information provides the transmission path of inter-card packets.
display hardware internal ibc lanswitch slot slot-number lsw lsw-number portmap
Probe view
lsw-number: Specifies an LSW chip by its number.
display hardware internal ibc lanswitch portmib
Use display hardware internal ibc lanswitch portmib to display MIB counters for a port on an LSW chip in the specified slot, including the PVID, link status of the port, and incoming and outgoing packet statistics since last configuration.
display hardware internal ibc lanswitch slot slot-number lsw lsw-number portmib phyport-number
Probe view
phyport-number: Specifies a physical port by its number.
display hardware internal ibc lanswitch vlan
Use display hardware internal ibc lanswitch vlan to display port information for the specified VLAN on an LSW chip in the specified slot.
display hardware internal ibc lanswitch slot slot-number lsw lsw-number vlan vlanId
Probe view
vlanId: Specifies a VLAN by its ID.
display hardware internal ibc rxpkt
Use display hardware internal ibc rxpkt to display specified contents of the specified packets that are received by a CPU in a slot.
display hardware internal ibc rxpkt slot slot-number cpu cpu-number [ number number | length length | frametype type | srcmac mac | vlan vlanID | queid queid | [ match matchPosition matchLength matchData | missmatch missmatchPosition matchLength matchData ] ]
Probe view
cpu-number: Specifies a CPU by its number in the range of 0 to 1.
number: Specifies the number of packets, in the range of 1 to 1000.
length: Specifies the length of a packet, in the range of 64 to 600 bytes.
type: Specifies the packet type.
mac: Specifies the source MAC address for the specified packets, in the format of H-H-H.
vlanID: Specifies a VLAN by its ID in the range of 0 to 4095.
queid: Specifies a receive queue by its ID in the range of 0 to 7.
matchPosition: Specifies the starting position to match the packet.
matchLength: Specifies the length of the matched packet, in the range of 1 to 8 fields.
matchData: Specifies the matched data, in the range of 2 to 16 hexadecimal characters.
missmatchPosition: Specifies the starting position for a missmatch of the packet.
missmatchLength: Specifies the length of a missmatch of the packet, in the range of 1 to 8 fields.
missmatchData: Specifies a missmatch of data, in the range of 2 to 16 hexadecimal characters.
display hardware internal ibc rxque
Use display hardware internal ibc rxque to display or clear information about the receive queue of inter-card packets on a CPU in the specified slot.
display hardware internal ibc rxque slot slot-number cpu cpu-number [clear]
Probe view
cpu cpu-number: Specifies a CPU by its number in the range of 0 to 1.
clear: Clears the receive queue information.
display hardware internal ibc txpkt
Use display hardware internal ibc txpkt to display specified contents of the specified packets that are sent by a CPU in a slot.
display hardware internal ibc txpkt slot slot-number cpu cpu-number [number number | length length | frametype type | dstmac mac | vlan vlanID | [ match matchPosition matchLength matchData | missmatch missmatchPosition matchLength matchData ] ]
Probe view
mac: Specifies the destination MAC address for the specified packets, in the format of H-H-H.
display hardware internal ipuc cnt
Use display hardware internal ipuc cnt to display routing engine counters. By default, all next hops are bound to counter 0.
In standalone mode:
display hardware internal ipuc cnt index slot slot-number
In IRF mode:
display hardware internal ipuc cnt index chassis chassis-number slot slot-number
Probe view
cnt: Specifies IP unicast engine counters.
index: Specifies a counter by its index in the range of 0 to 3.
display hardware internal ipuc fib
Use display hardware internal ipuc fib to display NH information found by exact matching or longest matching in the CPSS layer. When no mask is specified, the device uses exact matching. If no prefix is found, the device displays "The prefix not found."
In standalone mode:
display hardware internal ipuc fib { [ vrid ] ipv4-addr | ipv6-addr } [ mask-length ] slot slot-number
In IRF mode:
display hardware internal ipuc fib { [ vrid ] ipv4-addr | ipv6-addr } [ mask-length ] chassis chassis-number slot slot-number
Probe view
vrid: Specifies a VPN by its ID. The value range varies by system operating mode.
ipv4-addr: Specifies an IPv4 address.
ipv6-addr: Specifies an IPv6 address.
mask-length: Specifies the mask length in the range of 0 to 32 for an IPv4 address and 0 to 128 for an IPv6 address.
display hardware internal ipuc fib number
Use display hardware internal ipuc fib number to display unicast entry statistics.
In standalone mode:
display hardware internal ipuc fib number [ vrid ] slot slot-number
In IRF mode:
display hardware internal ipuc fib number [ vrid ] chassis chassis-number slot slot-number
Probe view
fib: Specifies unicast entry statistics.
vrid: Specifies a VPN by its ID. The value range varies by system operating mode. Without the vrid argument, the command displays the FIB entry statistics for all VPNs.
display hardware internal ipuc op
Use display hardware internal ipuc op to display the operation records of route entries for all MDCs on a card. By default, the device stores the most recent 200 records. The records are displayed in reverse chronological order.
In standalone mode:
display hardware internal ipuc op { ipv4 | ipv6 | vn } [ error ] [ clear ] slot slot-number
In IRF mode:
display hardware internal ipuc op { ipv4 | ipv6 | vn } [ error ] [ clear ] chassis chassis-number slot slot-number
Probe view
op: Specifies operation records.
ipv4: Specifies the operation records of IPv4 route entries.
ipv6: Specifies the operation records of IPv6 route entries.
vn: Specifies the operation records of VN route entries.
error: Specifies unsuccessful operation records.
clear: Clears operation records.
display hardware internal ipuc op adj
Use display hardware internal ipuc op adj to display operation information for ARP and ND.
display hardware internal ipuc op adj [ error ] [ clear ] slot slot-number
In IRF mode:
display hardware internal ipuc op adj [ error ] [ clear ] chassis chassis-number slot slot-number
Probe view
error: Displays error operation information for ARP and ND.
clear: Clears operation information for ARP and ND.
display hardware internal l2mc mac-table { igsp | mldsp | static }
Use display hardware internal l2mc mac-table { igsp | mldsp | static } to display information about a Layer 2 multicast MAC shadow table of the driver. This command is available for interface cards.
In standalone mode:
display hardware internal l2mc mac-table { igsp | mldsp | static } [ mac-address ] vlan vlan-id slot slot-number chip chip-number
In IRF mode:
display hardware internal l2mc mac-table { igsp | mldsp | static } [ mac-address ] vlan vlan-id chassis chassis-number slot slot-number chip chip-number
Probe view
igsp: Specifies a MAC-IPv4 shadow table.
mldsp: Specifies a MAC-IPv6 shadow table.
static: Specifies a multicast multiport MAC address.
mac-address: Specifies a multicast MAC address.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. (In IRF mode.)
chip chip-number: Specifies a chip by its chip number.
display hardware internal l2mc { igsp | mldsp | static }
Use display hardware internal l2mc { igsp | mldsp | static } to display information about a Layer 2 multicast MAC shadow table of the driver. This command is available for MPUs.
display hardware internal l2mc { igsp | mldsp | static } [mac-address] vlan vlan-id slot slot-number
In IRF mode:
display hardware internal l2mc { igsp | mldsp | static } [mac-address] vlan vlan-id chassis chassis-number slot slot-number
Probe view
display hardware internal l3mc counter
Use display hardware internal l3mc counter to display statistics for a counter on an interface card. For an interface card with multiple PP chips, this command displays statistics for the counter on each PP chip.
In standalone mode:
display hardware internal l3mc counter cnt-id slot slot-number clear ]
In IRF mode:
display hardware internal l3mc counter cnt-id chassis chassis-number slot slot-number [ clear ]
Probe view
counter cnt-id: Specifies a counter by its ID in the range of 2 or 3.
clear: Clears the history statistics.
You can use the display hardware internal ipuc cnt cnt-number chassis chassis-number slot slot-number command to display statistics for Counter 0.
display hardware internal l3mc dit
Use display hardware internal l3mc dit to display information about a DIT entry and the DIT link that begins with the DIT entry on an interface card.
display hardware internal l3mc dit dit-id [ verbose ] slot slot-number chip chip-number
In IRF mode:
display hardware internal l3mc dit dit-id [ verbose ] chassis chassis-number slot slot-number chip chip-number
Probe view
chip chip-number: Specifies a chip by its chip number in the range of 0 to 3.
dit dit-id: Specifies a DIT by its ID.
verbose: Displays detailed information about a specific DIT entry. If this keyword is not specified, this command displays the DIT IDs of the specified DIT entry and the nexthop.
This command stops displaying the output when the "IsLast" flag is yes.
This command stops displaying the output and prompts "More DITs need to display." when 64 DIT nodes are displayed. To display information about more DIT nodes, use this command again and specify the value for dit dit-id argument as the "Next ID" value in the last displayed DIT entry.
You must specify the dit dit-id argument as a multicast DIT ID. Otherwise, this command displays incorrect information.
display hardware internal l3mc ditcnt
Use display hardware internal l3mc ditcnt to display information about a counter. The counter records the number of multicast packets forwarded by the DIT entry that is bound to the counter.
In standalone mode:
display hardware internal l3mc ditcnt cnt-id slot slot-number
In IRF mode:
display hardware internal l3mc ditcnt cnt-id chassis chassis-number slot slot-number
Probe view
ditcnt cnt-id: Specifies a counter by its ID in the range of is 0 or 1.
display hardware internal l3mc lbp
Use display hardware internal l3mc lbp to display software multicast entries for the aggregate loopback interface on an MPU or interface card.
In standalone mode:
display hardware internal l3mc lbp slot slot-number
In IRF mode:
display hardware internal l3mc lbp chassis chassis-number slot slot-number
Probe view
display hardware internal l3mc localvpninfo vpnid
Use display hardware internal l3mc localvpninfo vpnid to display the platform VRF index corresponding to a driver VPN ID and information about the VPN instance.
In standalone mode:
display hardware internal l3mc localvpninfo vpnid vpnid slot slot-number
In IRF mode:
display hardware internal l3mc localvpninfo vpnid vpnid chassis chassis-number slot slot-number
Probe view
vpnid vpn-id: Specifies a VPN instance by its ID in the range of 0 to 1023.
display hardware internal l3mc lpm bipim ipv4
Use display hardware internal l3mc lpm bipim ipv4 to display information about the prefix list for Layer 3 multicast.
In standalone mode:
display hardware internal l3mc lpm bipim ipv4 vpn-id source-address group-address slot slot-number chip chip-id
In IRF mode:
display hardware internal l3mc lpm bipim ipv4 vpn-id source-address group-address chassis chassis-number slot slot-number chip chip-id
Probe view
source-address: Specifies a multicast source by its IP address.
group-address: Specifies a multicast group by its IP address.
chip chip-id: Specifies a chip by its chip ID.
display hardware internal l3mc lpm ipv4/ipv6
Use display hardware internal l3mc lpm ipv4/ipv6 to display hardware multicast entries on an interface card. For IPv4, this command displays (V, S, G) entries. For IPv6, this command displays (S, G) entries.
In standalone mode:
display hardware internal l3mc lpm ipv4 [ vpn-id ] sip gip slot slot-number chip chip-number
display hardware internal l3mc lpm ipv6 sip gip slot slot-number chip chip-number
In IRF mode:
display hardware internal l3mc lpm ipv4 [ vpn-id ] sip gip chassis chassis-number slot slot-number chip chip-number
display hardware internal l3mc lpm ipv6 sip gip chassis chassis-number slot slot-number chip chip-number
Probe view
vpn-id: Specifies a VPN instance. The value of 0 represents the public network.
sip: Specifies a source IPv4 or IPv6 address.
gip: Specifies an IPv4 or IPv6 multicast group address.
display hardware internal l3mc mroute ipv4/ipv6
Use display hardware internal l3mc mroute ipv4/ipv6 to display information about CPSS entries and related next hops on an interface card.
display hardware internal l3mc mroute ipv4 vpn-id sip gip [ verbose ] slot slot-number
display hardware internal l3mc mroute ipv6 vpn-id sip gip [ verbose ] slot slot-number
In IRF mode:
display hardware internal l3mc mroute ipv4 vpn-id sip gip [ verbose ] chassis chassis-number slot slot-number
display hardware internal l3mc mroute ipv6 vpn-id sip gip [ verbose ] chassis chassis-number slot slot-number
Probe view
sip: Specifies a source IP address.
gip: Specifies a multicast group address.
verbose: Display detailed information. If this keyword is not specified, this command displays information about (VPN, SIP, GIP) entries and related next hops.
If you specify the sip argument as 0.0.0.0, this command displays information about (*, G) entries.
If you specify the sip argument and gip argument both as 0.0.0.0, this command displays information about the default routing entry (0.0.0.0, 0.0.0.0).
display hardware internal l3mc nexthop
Use display hardware internal l3mc nexthop to display information about the specified multicast next hop ID and the DIT link under the next hop ID.
In standalone mode:
display hardware internal l3mc nexthop nexthop-id [ verbose ] slot slot-number chip chip-number
In IRF mode:
display hardware internal l3mc nexthop nexthop-id [ verbose ] chassis chassis-number slot slot-number chip chip-number
Probe view
nexthop nexthop-id: Specifies a next hop by its ID.
verbose: Displays detailed DIT information.
This command displays up to eight DIT nodes in a DIT link. To display a DIT link that has more than eight DIT nodes (for example, DIT links for the multicast VLAN plus service), use the display hardware internal l3mc dit command.
You must specify the nexthop nexthop-id argument as a Layer 3 next hop ID, including that of the default multicast routing entry. Otherwise, this command displays "The nexthop is not used."
display hardware internal l3mc openflow
Use display hardware internal l3mc openflow to display information about the DIT, Fabric Didx, VIDX, and TTI that correspond to an OpenFlow group on a specified card.
display hardware internal l3mc openflow group group-number slot slot-number chip chip-number
probe view
group group-number: Specifies a broadcast group ID.
chip chip-number: Specifies a chip bumber.
display hardware internal l3mc openflow trunk-route
Use display hardware internal l3mc openflow trunk-route to display the offset trunk routes.
display hardware internal l3mc openflow trunk-route trunk-number [ trunkoffset offset1 ][ oifoffset offset2 ] slot slot-number
probe view
trunk-number: Specifies the trunk ID you want to query.
trunkoffset offset1: Specifies the Trunk-Oif offset.
slot slot-number: Specifies Trunk-Oif-Node offset..
display hardware internal l3mc tcam
Use display hardware internal l3mc tcam to display information about IPv6 multicast TCAM hardware entries on an interface card.
In standalone mode:
display hardware internal l3mc tcam tcam-id slot slot-number
In IRF mode:
display hardware internal l3mc tcam tcam-id chassis chassis-number slot slot-number
Probe view
tcam tcam-id: Specifies a TCAM software resource by its ID.
You must specify the tcam tcam-id option as a valid tcam-id. The value range for the argument might vary with different system operating modes.
display hardware internal l3mc tunnel
Use display hardware internal l3mc tunnel to display information about hardware entries for a multicast VPN tunnel.
In standalone mode:
display hardware internal l3mc tunnel tunnel-id slot slot-number chip chip-number
In IRF mode:
display hardware internal l3mc tunnel tunnel-id chassis chassis-number slot slot-number chip chip-number
Probe view
chip chip-number: Specifies a chip by its ID.
tunnel tunnel-id: Specifies a multicast VPN tunnel by its Mtunnel ID.
display hardware internal l3mc vidx
Use display hardware internal l3mc vidx to display information about software and hardware of a VIDX on all chips of an interface card.
display hardware internal l3mc vidx vidx-id slot slot-number
In IRF mode:
display hardware internal l3mc vidx vidx-id chassis chassis-number slot slot-number
Probe view
vidx vidx-id: Specifies a VIDX by its ID in the range of 2049 to 4089.
You must specify the vidx vidx-id argument as a local multicast VIDX ID. Otherwise, this command displays incorrect information.
display hardware internal l3mc vrfinfo vrid
Use display hardware internal l3mc vrfinfo vrid to display the dirver VPN ID corresponding to a platform VRF index and information about the VPN instance.
In standalone mode:
In IRF mode:
Probe view
vrid vrf-id: Specifies a VRF index by its index number in the range of 0 to 1023.
display hardware internal mirror
Use display hardware internal mirror to display the mirroring configuration for a chip on a card.
display hardware internal mirror { ingress | egress } slot slot-number chip chip-number [ hardware ]
display hardware internal mirror { ingress | egress } slot slot-number chip mdc_chip
Probe view
ingress: Specifies the ingress direction.
egress: Specifies the egress direction.
slot slot-number: Specifies a card by its slot number. The card must be in place.
chip chip-number: Specifies a chip by its number in the range of 0 to 7.
chip mdc_chip: Specifies the virtual chip.
hardware: Displays the mirroring configuration in hardware. If you do not specify this keyword, the command displays the mirroring configuration in software.
display hardware internal mpls debugging
Use display hardware internal mpls debugging to display the MPLS debugging state.
display hardware internal mpls debugging slot slot-number
Probe view
slot slot-number: Specifies a card. The slot-number argument represents the number of the slot that holds the card.
display hardware internal mpls dit
Use display hardware internal mpls dit to display DIT entries.
display hardware internal mpls dit mpls dit-index slot slot-number
display hardware internal mpls dit vpls dit-index slot slot-number
Probe view
dit dit-index: Specifies a DIT entry by its index.
display hardware internal mpls evi-hashpcl
Use display hardware internal mpls evi-hashpcl to display the ACL rules that conflict with the EVI MAC hash table.
display hardware internal mpls evi-hashpclslot slot-number
Probe view
display hardware internal mpls evi-info globalvar
Use display hardware internal mpls evi-info globalvar to display EVI global variables.
display hardware internal mpls evi-info globalvar slot slot-number
Probe view
display hardware internal mpls evi-instance
Use display hardware internal mpls evi-instance to display software entries for an EVI network.
display hardware internal mpls evi-instance slot slot-number tunnel interface-number
Probe view
interface tunnel interface-number: Specifies an EVI tunnel interface by its number.
display hardware internal mpls evi-link
Use display hardware internal mpls evi-link to display software entries for an EVI-link interface.
In standalone mode:
display hardware internal mpls evi-link slot slot-number tunnel interface-number evi-link interface-number
In IRF mode:
display hardware internal mpls evi-link chassis chassis-number slot slot-number tunnel interface-number evi-link interface-number
Probe view
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. (In IRF mode.)
evi-link interface-number: Specifies an EVI-link interface by its number.
display hardware internal mpls evi-operation
Use display hardware internal mpls evi-operation to display EVI operation records.
display hardware internal mpls evi-operation slot slot-number
Probe view
display hardware internal mpls evi-tunnel
Use display hardware internal mpls evi-tunnel to display information about an EVI tunnel.
display hardware internal mpls evi-tunnel slot slot-number tunnel interface-number
Probe view
interface tunnel interface-number: Specifies an EVI tunnel by its index.
display hardware internal mpls evi-vlan
Use display hardware internal mpls evi-vlan to display information about extended VLANs.
display hardware internal mpls evi-vlan slot slot-number vlan vlan-id-list
Probe view
vlan vlan-id-list: Specifies a list of extended VLANs.
display hardware internal mpls frr dit
Use display hardware internal mpls frr dit to display Fast Reroute DIT entries.
display hardware internal mpls frr dit dit-index slot slot-number
Probe view
display hardware internal mpls infilter
Use display hardware internal mpls infilter to display the filtering function state on interfaces.
display hardware internal mpls infilter slot slot-number
Probe view
display hardware internal mpls labelinfo inlabel
Use display hardware internal mpls mpls labelinfo inlabel to display MPLS labels.
display hardware internal mpls labelinfo inlabel label-value slot slot-number
display hardware internal mpls labelinfo hardware inlabel label-value slot slot-number
Probe view
inlabel label-value: Specifies an incoming label. The label range depends on system operating modes.
display hardware internal mpls mpls variable
Use display hardware internal mpls mpls variable to display global variable information for MPLS.
display hardware internal mpls mpls variable slot slot-number
Probe view
display hardware internal mpls nhlfe
Use display hardware internal mpls nhlfe to display NHLFE entries.
display hardware internal mpls nhlfe nhlfe-value slot slot-number
Probe view
nhlfe nhlfe-value: Specifies an NHLFE entry.
display hardware internal mpls nhlfecnt
Use display hardware internal mpls nhlfcnt to display NHLFE entry counter information. Bind an NHLFE entry to a counter before you execute this command.
display hardware internal mpls nhlfecnt slot slot-number chip chip-number count-id
Probe view
chip chip-number: Specifies a chip by its number.
count-id: Specifies a counter by its ID.
display hardware internal mpls spb bmacinfo
Use display hardware internal mpls spb bmacinfo to display software entries for a B-MAC.
display hardware internal mpls spb bmacinfo vlan vlanid mac-address H-H-H slot slot-number
Probe view
vlan vlanid: Specifies a B-VLAN by its ID.
mac-address H-H-H: Specifies a B-MAC in the format of H-H-H.
display hardware internal mpls spb bvlan
Use display hardware internal mpls spb bvlan to verify whether or not a VLAN is a B-VLAN.
display hardware internal mpls spb bvlan vlanid slot slot-number
Probe view
vlan vlanid: Specifies a VLAN by its ID.
display hardware internal mpls spb fabricvidx
Use display hardware internal mpls spb fabircvidx to display fabric VIDX software entries for a chip on a card.
display hardware internal mpls spb fabircvidx slot slot-number chip chip-number mrboard mr-slot-number
Probe view
chip chip-number: Specifies a chip on the card by its number.
mrboard slot-number: Specifies an MPU by its slot number.
display hardware internal mpls spb lbpinfo
Use display hardware internal mpls spb lbpinfo to display lbpinfo software entries.
display hardware internal mpls spb lbpinfo slot slot-number frame frameid
Probe view
frame frameid: Specifies the ID of the chassis that contains the card.
display hardware internal mpls spb operation
Use display hardware internal mpls spb operation to display SPB operation records.
display hardware internal mpls spb operation slot slot-number optype optype
display hardware internal mpls spb operation slot slot-number clear
Probe view
optype optype: Specifies an operation type.
display hardware internal mpls spb pwinfo
Use display hardware internal mpls spb pwinfo to display software entries for a PW.
display hardware internal mpls spb pwinfo vsiindex vsiindex linkid pwid slot slot-number
Probe view
vsiindex vsiindex: Specifies an SPB VSI by its index.
linkid pwid: Specifies a PW by its ID.
display hardware internal mpls spb tunnelinfo
Use display hardware internal mpls spb tunnelinfo to display SPB hash node software entries.
display hardware internal mpls spb tunnelinfo i-sid isid vlan vlanid mac-address H-H-H slot slot-number
Probe view
i-sid isid: Specifies an SPB VSI by its I-SID.
mac-address H-H-H: Specifies a B-MAC in H-H-H format.
display hardware internal mpls spb variable
Use display hardware internal mpls spb variable to display software entries for SPB global variables.
display hardware internal mpls spb variable slot slot-number
Probe view
slot slot-number: Specifies a card by its number.
display hardware internal mpls spb vidx
Use display hardware internal mpls spb vidx to display information about a VIDX of an interface card.
display hardware internal mpls spb vidx vidxid slot slot-number
Probe view
vidx vidxid: Specifies a VIDX by its ID.
display hardware internal mpls tablesize
Use display hardware internal mpls tablesize to display the number of entries for each hardware parameter.
Probe view
display hardware internal mpls tticnt
Use display hardware internal mpls tticnt to display the packet counts for a bound Tunnel Terminate Interface (TTI).
display hardware internal mpls tticnt mpls slot slot-number tti-index
display hardware internal mpls tticnt ipv4 slot slot-number tti-index
display hardware internal mpls tticnt Ethernet { Bridge-Aggregation | GigabitEthernet | InLoopBack | LoopBack | M-Ethernet | NULL | Register-Tunnel | EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
display hardware internal mpls tticnt minm { Bridge-Aggregation | GigabitEthernet | InLoopBack | LoopBack | M-Ethernet | NULL | Register-Tunnel | EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
Probe view
mpls: Specifies an MPLS TTI.
Ethernet: Specifies an Ethernet TTI.
ipv4: Specifies an IPv4 TTI.
minm: Specifies an MINM TTI.
tti-index: Specifies a TTI index.
display hardware internal mpls tunnel
Use display hardware internal mpls tunnel to display tunnel entries.
display hardware internal mpls tunnel tunnel-id slot slot-number
Probe view
tunnel tunnel-id: Specifies a tunnel by its tunnel ID.
display hardware internal mpls vpws
Use display hardware internal mpls vpws to display VLL software entries.
display hardware internal mpls vpws slot slot-number inlabel label-value
Probe view
inlabel label-value: Specifies an incoming label. The label range depends on the system operating mode.
display hardware internal mpls vpws actti
Use display hardware internal mpls vpws actti to display AC TTI indexes.
display hardware internal mpls vpws actti slot slot-number inlabel label-value
Probe view
display hardware internal nh
Use display hardware internal nh to display hardware next hop entries of a VPN.
In standalone mode:
display hardware internal ipuc nh nh-id [ number show-number [ urpf ] ] slot slot-number chip ppid
display hardware internal ipuc nh { x.x.x.x | x:x::x:x } mask-length slot slot-number chip ppid
display hardware internal ipuc nh vrid vrid { x.x.x.x | x:x::x:x } mask-length slot slot-number chip ppid
In IRF mode:
display hardware internal ipuc nh nh-id [ number show-number [ urpf ] ] chassis chassis-number slot slot-number chip ppid
display hardware internal ipuc nh { x.x.x.x | x:x::x:x } mask-length chassis chassis-number slot slot-number chip ppid
display hardware internal ipuc nh vrid vrid { x.x.x.x | x:x::x:x } mask-length chassis chassis-number slot slot-number chip ppid
Probe view
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
nh: Specifies next hop entries.
nh-id nh-id: Specifies a next hop by its ID.
number show-number: Specifies the number of next hop entries to display, in the range of 1 to 32.
urpf: Displays the ECMP URPF route entry.
chip ppid: Specifies a PP chip by its ID. The value range varies by card.
x.x.x.x: Specifies an IPv4 address in dotted decimal notation.
x:x:x:x: Specifies an IPv6 address.
vrid vrid: Specifies a VPN by its ID. The value range varies by system operating mode.
display hardware internal nst packet-statistic
Use display hardware internal nst packet-statistic to display packet statistics by CPU code for the specified card on the specified device.
display hardware internal nst packet-statistic chassis chassis-number slot slot-number [ clear ]
Probe view
chassis chassis-number: Specifies a chassis by its number. (In IRF mode.)
clear: Clears packet statistics.
display hardware internal packet-drop
Use display hardware internal packet-drop to display dropped packet statistics on a card.
In standalone mode:
display hardware internal packet-drop slot slot-number [ verbose ]
In IRF mode:
display hardware internal packet-drop chassis chassis-number slot slot-number [ verbose ]
Probe view
verbose: Displays detailed information. Without this keyword, the command displays non-zero statistics.
display hardware internal pcl irfdest resource
Use display hardware internal pcl irfdest resource to display the index and resource number information about the DIT, tunnel, and MPLS label.
probe view
display hardware internal pcl irfdest tti
Use display hardware internal pcl irfdest tti to display the TTI index information about the specified trunk.
display hardware internal pcl irfdest tti slot slot-number trunk trunk-number
probe view
trunk trunk-number Specifies a trunk ID in the range of 1 to 255.
display hardware internal pcl pce-entry slot
Use display hardware internal pcl pce-entry slot to display the contents and action of a specific entry for a chip on a card.
display hardware internal pcl pce-entry slot slot-number chip chip-number portgroup portgroup-number pce { pclid pceid pcltype | drvindex drvindex-number } [ hardware ]
display hardware internal pcl pce-entry slot slot-number chip mdc_chip portgroup portgroup-number pce { pclid pceid pcltype | drvindex drvindex-number }
display hardware internal pcl pce-entry slot slot-number chip chip-number portgroup portgroup-number tti { pclid pceid pcltype | drvindex drvindex-number } [ hardware ]
display hardware internal pcl pce-entry slot slot-number chip mdc_chip portgroup portgroup-number tti { pclid pceid pcltype | drvindex drvindex-number }
Probe view
portgroup portgroup-number: Specifies a core by its number, which can be 0 or 1.
pce: Specifies a PCL by PCE ID.
tti: Specifies a TTI entry by PCE ID.
pclid: PCL ID in the range of 0 to 4294967295.
pceid: PCE ID in the range of 0 to 65535.
pcltype: PCL type for the PCE or TTI entry. The value range is 0 to 56.
drvindex drvindex-number: Specifies a global driver index for the PCE or TTI entry. The value range for drvindex-number is 0 to 106496 for standard cards and 0 to 401407 for enhanced cards.
hardware: Displays the entries in hardware. If you do not specify this keyword, the command displays the entries in software.
display hardware internal qos buffer-count
Use display hardware internal qos buffer-count to display the number of used buffers in hardware.
display hardware internal qos buffer-count { ingress | egress } slot slot-number chip chip-number
Probe view
ingress: Specifies ingress buffers.
egress: Specifies egress buffers.
chip chip-number: Specifies a chip by its number. The value range for chip-number is 0 to 3 for PP chips and 4 to 7 for Layer 2 chips.
display hardware internal register
Use display hardware internal register to display the register in an interface card chip.
display hardware internal register slot slot-number chip chipnum [ portgroup portgroupnum ] address [ length ]
Probe view
portgroupnum: Specifies a chip port group number.
address: Specifies the register address.
length: Specifies the query length.
display hardware internal register dump
Use display hardware internal register dump to display the dump results in the interface card chip register.
display hardware internal register dump slot slot-number chip chipnum
Probe view
slotid: Specifies a card by its slot number.
display hardware internal rxtx device-status
Use display hardware internal rxtx device-status to display the status of PP chips for a CPU on a card.
display hardware internal rxtx device-status slot slot-number cpu cpu-number [ clear ]
Probe view
cpu cpu-number: Specifies a CPU by its number, which can be 0 or 1.
clear: Clears a counter after displaying the contents of the counter.
display hardware internal rxtx dma
Use display hardware internal rxtx dma to display the DMA packet drop counter for a PP card.
display hardware internal rxtx dma statistic slot slot-number
Probe view
slot slot-number: Specifies a PP card by its slot number.
display hardware internal rxtx interrupt
Use display hardware internal rxtx interrupt to display the statistics of the interrupt handling module on a card.
display hardware internal rxtx interrupt statistic slot slot-number [ clear ]
Probe view
display hardware internal rxtx packet
Use display hardware internal rxtx packet to display the statistics of the packet TxRx module for a CPU on a card.
display hardware internal rxtx packet statistic slot slot-number cpu cpu-number [ clear ]
Probe view
display hardware internal rxtx rxpkt
Use display hardware internal rxtx txpkt to display the contents of specific incoming packets on a card.
display hardware internal rxtx rxpkt slot slotnum [ cpucode cpu-code ] [ queue queueid ] [ number num ] [ length len ] [ vlan vlanid ] [ port portid ] [ dev dev-num ]
Probe view
slot slotnum: Displays the incoming packets from a card specified by its slot number. Only the MPU and the PP card can be specified.
cpucode cpu-code: Displays the incoming packets with a specific CPU code.
queue queueid: Displays the incoming packets of a queue specified by its ID.
number num: Specifies the number of packets to be displayed. The value range for num is 1 to 10000.
length len: Specifies the number of bytes to be displayed for each packet. The value range for len is 1 to 1536 bytes.
vlan vlanid: Displays the incoming packets from a VLAN specified by its ID.
port portid: Displays the incoming packets from a port specified by its ID.
dev dev-num: Displays the incoming packets from a chip specified by its number.
Use display hardware internal rxtx txpkt to display the contents of specific outgoing packets.
display hardware internal rxtx txpkt [ dit-tx dit-transmit | ingress-tx ingress-transmit | port-tx port-transmit | vidx-tx vidx-transmit | vlan-tx vlan-transmit | slot slotnum ] [ number num ] [ length len ] [ vlan vlanid ]
Probe view
dit-tx dit-transmit: Displays the packets sent out in transmit mode.
ingress-tx ingress-transmit: Displays the packets sent out in ingress mode.
port-tx port-transmit: Displays the packets sent out in port mode.
vidx-tx vidx-transmit: Displays the packets sent out in VIDX mode.
vlan-tx vidx-transmit: Displays the packets sent out in VLAN mode.
slot slotnum: Displays the outgoing packets on a card specified by its slot number. Only the MPU and the PP card can be specified.
number num: Specifies the number of packets to be displayed. The value range for num is 1 to 10000, and the default is 20.
length len: Specifies the number of bytes to be displayed for each packet. The value range for len is 1 to 1536 bytes, and the default is 48 bytes.
vlan vlanid: Displays the outgoing packets of a VLAN specified by its ID.
display hardware internal sflow interface
Use display hardware internal sflow interface to display the configured sampling rate for hardware sFlow and packet statistics on a specific interface.
display hardware internal sflow interface { interface-type interface-number | interface-name }
Probe view
interface-name: Specifies an interface by its name.
display hardware internal temperature-limit
Use display hardware internal temperature-limit to display the high-temperature shutdown thresholds of all line cards.
Probe view
display hardware internal tunnel
Use display hardware internal tunnel to display tunnel software and hardware entries based on a software index or a Comware tunnel ID.
display hardware internal tunnel { index indexid | interface Tunnel tunnelld } [ hardware ] slot slot-number
In IRF mode:
display hardware internal tunnel { index indexid | interface Tunnel tunnelld } [ hardware ] chassis chassis-number slot slot-number
Probe view
index indexid: Specifies a tunnel index. The value range depends on the system operating mode.
interface: Specifies a tunnel interface.
Tunnel tunnelId: Specifies a global tunnel ID, which is identical with a Comware tunnel ID.
hardware: Displays hardware information.
slot slot-number: Specifies a card. The slot-number argument represents the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card of an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that holds the card. (In IRF mode.)
display psr status
Use display psr status to display power supply status information.
display psr slot-number psr-id status
Probe view
slot-number: Specifies an MPU by its global slot number.
psr-id: Specifies the power supply ID. The value ranges are as follows:
· 1 to 6 for an S12504.
· 1 to 8 for an S12508.
· 1 to 16 for an S12518.
Power supply status information includes the following items:
· Runtime.
· Version numbers of the internal sub-modules.
· Voltage and current.
· Temperature.
· Operating status.
· Alarming status.
display system internal acl
Use display system internal acl to display ACL configuration and match statistics.
display system internal acl [ ipv6 ] { acl-number | name acl-name } { slot slot-number }
display system internal acl [ ipv6 ] { acl-number | name acl-name } { chassis chassis-number slot slot-number }
Probe view
acl-number: Specifies the number of an ACL:
· 2000 to 2999 for the following ACLs:
? IPv4 basic ACLs if the ipv6 keyword is not specified.
? IPv6 basic ACLs if the ipv6 keyword is specified.
· 3000 to 3999 for the following ACLs:
? IPv4 advanced ACLs if the ipv6 keyword is not specified.
? IPv6 advanced ACLs if the ipv6 keyword is specified.
· 4000 to 4999 for Lay-2 ACLs. This entry is not displayed if the ipv6 keyword is specified.
· 5000 to 5999 for user-defined ACLs. This entry is not displayed if the ipv6 keyword is specified.
name acl-name: Assigns a name to the ACL for easy identification. The acl-name argument is a case-insensitive string of 1 to 63 characters. It must start with an English letter. For basic ACLs or advanced ACLs:
· If the ipv6 keyword is not specified, it is the name of an IPv4 basic ACL or an IPv4 advanced ACL.
· If the ipv6 keyword is specified, it is the name of an IPv6 basic ACL or an IPv6 advanced ACL.
slot slot-number: Displays ACL configuration and match statistics for a specified card. The slot-number argument specifies the card by its slot number. By default, the command displays ACL configuration and match statistics on the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ACL configuration and match statistics for a card of an IRF member device. The chassis-number argument represents the IRF member ID of the device. The slot-number argument represents the slot number of the card on the device. By default, the command displays ACL configuration and match statistics on all MPUs of the IRF device.(In IRF mode.)
display system internal adj4 entry
Use display system internal adj4 entry to display detailed information about an IPv4 adjacency entry.
In standalone mode:
display system internal adj4 entry ip-address interface interface-type interface-number slot slot-number
In IRF mode:
display system internal adj4 entry ip-address interface interface-type interface-number chassis chassis-number slot slot-number
Probe view
ip-address: Displays the IPv4 adjacency entry about the specified IP address.
interface interface-type interface-number: Displays the IPv4 adjacency entry for the interface specified by its interface type and interface number.
slot slot-number: Displays IPv4 adjacency entries for the specified card. The slot-number argument specifies the card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays IPv4 adjacency entries for the specified card of the specified IRF member device. The chassis-number argument represents the IRF member ID of the device. The slot-number argument represents the slot number of the card on the device. (In IRF mode.)
display system internal adj4 statistics
Use display system internal adj4 statistics to display IPv4 adjacency entry statistics.
In standalone mode:
display system internal adj4 statistics slot slot-number
In IRF mode:
display system internal adj4 statistics chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays IPv4 adjacency entry statistics on a card. The slot-number argument specifies the card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays IPv4 adjacency entry statistics on a card of an IRF member device. The chassis-number argument represents the IRF member ID of the device. The slot-number argument represents the slot number of the card on the device. (In IRF mode.)
display system internal adjacent-table
Use display system internal adjacent-table to display IPv4 adjacency entries.
In standalone mode:
display system internal adjacent-table slot slot-number [ count | verbose ]
In IRF mode:
display system internal adjacent-table chassis chassis-number slot slot-number [ count | verbose ]
Probe view
slot slot-number: Displays IPv4 adjacency entries on a card. The slot-number argument specifies the card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays IPv4 adjacency entries on a card of an IRF member device. The chassis-number argument represents the IRF member ID of the device. The slot-number argument represents the slot number of the card on the device. (In IRF mode.)
count: Displays the number of IPv4 adjacency entries.
verbose: Displays detailed IPv4 adjacency entry information.
display system internal arp
Use display system internal arp to display ARP entries that are not synchronized from other cards or devices.
In standalone mode:
display system internal arp { all | static | dynamic | multiport } slot slot-number [ count ]
In IRF mode:
display system internal arp { all | static | dynamic | multiport } chassis chassis-number slot slot-number [ count ]
Probe view
all: Displays all ARP entries that are not synchronized from other cards or devices.
static: Displays static ARP entries that are not synchronized from other cards or devices.
dynamic: Displays dynamic ARP entries that are not synchronized from other cards or devices.
multiport: Displays multiport ARP entries that are not synchronized from other cards or devices.
slot slot-number: Displays ARP entries that are not synchronized from other cards for the card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ARP entries that are not synchronized from other cards for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
count: Displays the total number of ARP entries that are not synchronized from other cards or devices.
display system internal arp ifcb
Use display system internal arp ifcb to display ARP control block information for a Layer 2 or Layer 3 interface.
In standalone mode:
display system internal arp ifcb interface interface-type interface-number slot slot-number
In IRF mode:
display system internal arp ifcb interface interface-type interface-number chassis chassis-number slot slot-number
Probe view
interface interface-type interface-number: Displays ARP control block information for the specified Layer 2 or Layer 3 interface.
slot slot-number: Displays ARP control block information for a specific interface on the card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ARP control block information for a specific interface on a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal arp ip-address
Use display system internal arp ip-address to display the ARP entry for a specific IP address.
In standalone mode:
display system internal arp ip-address slot slot-number
In IRF mode:
display system internal arp ip-address chassis chassis-number slot slot-number
Prove view
ip-address: Displays the ARP entry for the specified IP address.
slot slot-number: Displays the ARP entry for a specific IP address of the card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the ARP entry for a specific IP address of a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal arp machash
Use display system internal arp machash to display machash entries.
In standalone mode:
display system internal arp machash vlan vlan-id ip ip-address slot slot-number
In IRF mode:
display system internal arp machash vlan vlan-id ip ip-address chassis chassis-number slot slot-number
Probe view
vlan vlan-id: Displays machash entries for the specified VLAN.
ip ip-address: Displays machash entries for the specified IP address.
slot slot-number: Displays machash entries for the card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays machash entries for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal arp probe
Use display system internal arp probe to display ARP probe link entries.
In standalone mode:
display system internal arp probe slot slot-number
In IRF mode:
display system internal arp probe chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays ARP probe link entries for the card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ARP probe link entries for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal arp reload
Use display system internal arp reload to display ARP reload link entries.
In standalone mode:
display system internal arp reload slot slot-number
In IRF mode:
display system internal arp reload chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays ARP reload link entries for the card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ARP reload link entries for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal arp source-suppression cache
Use display system internal arp source-suppression cache to display ARP source suppression entries.
In standalone mode:
display system internal arp source-suppression cache slot slot-number
In IRF mode:
display system internal arp source-suppression cache chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays ARP source suppression entries for the card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ARP source suppression entries for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal arp statistics
Use display system internal arp statistics to display ARP statistics.
In standalone mode:
display system internal arp statistics slot slot-number
In IRF mode:
display system internal arp statistics chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays ARP statistics for the card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ARP statistics for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal arp vlan
Use display system internal arp vlan to display ARP entries for a specific VLAN.
In standalone mode:
display system internal arp vlan vlan-id slot slot-number [ count ]
In IRF mode:
display system internal arp vlan vlan-id chassis chassis-number slot slot-number [ count ]
Probe view
vlan vlan-id: Displays ARP entries for the specified VLAN.
slot slot-number: Displays ARP entries for a specific VLAN on the card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ARP entries for a specific VLAN on a card of an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
count: Displays the total number of ARP entries.
display system internal bgp graceful-restart statistics
Use display system internal bgp graceful-restart statistics to display BGP GR statistics.
Probe view
display system internal bgp instance statistics
Use display system internal bgp instance statistics to display BGP instance statistics.
display system internal bgp instance { ipv4 | ipv6 | vpnv4 } [ vpn-instance vpn-instance-name ] [ rib | send ] statistics
display system internal bgp instance { l2vpn | vpnv6 } [ rib | send ] statistics
Probe view
ipv4: Displays BGP instance statistics for IPv4 address family.
ipv6: Displays BGP instance statistics for IPv6 address family.
vpnv4: Displays BGP instance statistics for VPNv4 address family.
l2vpn: Displays BGP instance statistics for L2VPN address family.
vpnv6: Displays BGP instance statistics for VPNv6 address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command displays BGP instance statistics for the public network.
rib: Displays statistics for the BGP instance route module.
send: Displays statistics for the BGP instance sending module.
display system internal bgp interface
Use display system internal bgp interface to display BGP interface information.
display system internal bgp interface ipv4 [ vpn-instance vpn-instance-name] [ interface-type interface-number | ipv4-address { mask | mask-length } ]
display system internal bgp interface ipv6 [ vpn-instance vpn-instance-name] [ interface-type interface-number | ipv6-address prefix-length ]
Probe view
ipv4: Displays BGP interface information for IPv4 address family.
ipv6: Displays BGP interface information for IPv6 address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command displays BGP interface information for the public network.
interface-type interface-number: Specifies a BGP interface by its type and number.
ipv4-address { mask | mask-length }: Specifies a BGP interface by its IPv4 address and mask. The mask-length argument specifies the mask length in the range of 0 to 32.
ipv6-address prefix-length: Specifies a BGP interface by its IPv6 address. The prefix-length argument specifies the prefix length in the range of 0 to 128.
display system internal bgp l2vpn auto-discovery advertise
Use display system internal bgp l2vpn auto-discovery advertise to display advertisement information for a VPLS PE discovered by BGP.
display system internal bgp l2vpn auto-discovery route-distinguisher route-distinguisher pe-address ip-address advertise
Probe view
route-distinguisher route-distinguisher: Specifies a route distinguisher (RD), a string of 3 to 21 characters. You can specify an RD in one of the following formats:
· 16-bit AS number:32-bit user-defined number, such as 101:3.
· 32-bit IP address:16-bit user-defined number, such as 192.168.122.15:1.
· 32-bit AS number:16-bit user-defined number, such as 65536:1. In this format, the minimum value for the AS number is 65536.
pe-address ip-address: Specifies a PE by its IP address.
display system internal bgp l2vpn auto-discovery verbose
Use display system internal bgp l2vpn auto-discovery verbose to display detailed information about a VPLS PE discovered by BGP.
display system internal bgp l2vpn auto-discovery route-distinguisher route-distinguisher pe-address ip-address verbose
Probe view
display system internal bgp l2vpn signaling advertise
Use display system internal bgp l2vpn signaling advertise to display BGP L2VPN label block advertisement information.
display system internal bgp l2vpn signaling route-distinguisher route-distinguisher site-id site-id label-offset label-offset advertise
Probe view
site-id site-id: Specifies a site by its ID in the range of 0 to 65535.
label-offset label-offset: Specifies an offset in the range of 0 to 65535.
display system internal bgp l2vpn signaling verbose
Use display system internal bgp l2vpn signaling verbose to display detailed BGP L2VPN label block information.
display system internal bgp l2vpn signaling route-distinguisher route-distinguisher site-id site-id label-offset label-offset verbose
Probe view
display system internal bgp nib
Use display system internal bgp nib to display next hop information for BGP routes.
display system internal bgp nib { ipv4 | ipv6 } [ nib-id ] [ verbose ]
Probe view
ipv4: Displays BGP next hop information for IPv4 address family.
ipv6: Displays BGP next hop information for IPv6 address family.
nib-id: Specifies a next hop by its ID in the range of 1 to FFFFFFFF. If you do not specify a next hop, this commands displays information about all BGP next hops.
verbose: Displays detailed next hop information. If you do not specify this keyword, this command displays brief next hop information.
display system internal bgp nib log
Use display system internal bgp nib log to display log information for all BGP next hops.
Probe view
display system internal bgp peer statistics
Use display system internal bgp peer statistics to display BGP peer statistics.
display system internal bgp peer { ipv4 | vpnv4 } [ vpn-instance vpn-instance-name ] ipv4-address [ rib | send | session ] statistics
display system internal bgp peer ipv6 { ipv4-address | [ vpn-instance vpn-instance-name ] ipv6-address } [ rib | send | session ] statistics
display system internal bgp peer vpnv6 ipv4-address [ rib | send | session ] statistics
display system internal bgp peer l2vpn ipv4-address [ rib | send | session ] statistics
Probe view
ipv4: Displays BGP peer statistics for IPv4 address family.
ipv6: Displays BGP peer statistics for IPv6 address family.
vpnv4: Displays BGP peer statistics for VPNv4 address family.
vpnv6: Displays BGP peer statistics for VPNv6 address family.
l2vpn: Displays BGP peer statistics for L2VPN address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command displays BGP peer statistics for the public network.
ipv4-address: Specifies a BGP peer by its IPv4 address.
ipv6-address: Specifies a BGP peer by its IPv6 address.
rib: Displays BGP route module information.
send: Displays BGP sending module information.
session: Displays BGP session module information.
display system internal bgp protocol statistics
Use display system internal bgp protocol statistics to display statistics for a BGP module.
display system internal bgp protocol [ calc | rib | send | session ] statistics
Probe view
calc: Displays statistics for the BGP route comparison module.
rib: Displays statistics for the BGP route module.
send: Displays statistics for the BGP sending module.
session: Displays statistics for the BGP session module.
display system internal bgp routing-table advertise-info
Use display system internal bgp routing-table advertise-info to display BGP route advertisement information.
display system internal bgp routing-table ipv4 [ vpn-instance vpn-instance-name ] network-address { mask | mask-length } advertise-info
display system internal bgp routing-table ipv6 [ vpn-instance vpn-instance-name ] network-address prefix-length advertise-info
display system internal bgp routing-table vpnv4 network-address { mask | mask-length } advertise-info
display system internal bgp routing-table vpnv6 network-address prefix-length advertise-info
Probe view
ipv4: Displays BGP route advertisement information for IPv4 address family.
ipv6: Displays BGP route advertisement information for IPv6 address family.
vpnv4: Displays BGP route advertisement information for VPNv4 address family.
vpnv6: Displays BGP route advertisement information for VPNv6 address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command displays BGP route advertisement information for the public network.
network-address: Specifies a destination network.
mask: Specifies the mask of the destination network, in dotted decimal notation.
mask-length: Specifies the mask length of the destination network, in the range of 0 to 32.
prefix-length: Specifies the prefix length of the destination network, in the range of 0 to 128.
display system internal bgp routing-table verbose
Use display system internal bgp routing-table verbose to display detailed BGP routing information.
display system internal bgp routing-table ipv4 [ vpn-instance vpn-instance-name ] network-address { mask | mask-length } verbose
display system internal bgp routing-table ipv6 [ vpn-instance vpn-instance-name ] network-address prefix-length verbose
display system internal bgp routing-table vpnv4 network-address { mask | mask-length } verbose
display system internal bgp routing-table vpnv6 network-address prefix-length verbose
Probe view
ipv4: Displays detailed BGP routing information for IPv4 address family.
ipv6: Displays detailed BGP routing information for IPv6 address family.
vpnv4: Displays detailed BGP routing information for VPNv4 address family.
vpnv6: Displays detailed BGP routing information for VPNv6 address family.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If you do not specify this option, this command displays detailed BGP routing information for the public network.
display system internal control-plane management statistics
Use display system internal control-plane management statistics to display the statistics for the control plane of the management interface.
Probe view
display system internal ethernet character
Use display system internal ethernet character to display the statistics and details of characteristics monitored by the Ethernet module.
In standalone mode:
display system internal ethernet character { global | interface { interface-type interface-number } } slot slot-number
In IRF mode:
display system internal ethernet character { global | interface { interface-type interface-number } } chassis chassis-number slot slot-number
Probe view
global: Displays the global Ethernet characteristics. The global Ethernet characteristics match all packets on a device.
interface interface-type interface-number: Displays the Ethernet characteristics on an interface specified by its type and number. The interface-specific characteristics match the packets received and sent by an Ethernet interface.
slot slot-number: Specifies a card. The slot-number argument represents the number of the slot that houses the card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card of an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that houses the card. (In IRF mode.)
The Ethernet module receives, decapsulates, sends, and encapsulates link layer packets. When an upper-layer application module (for example, STP or LLDP) needs to monitor and process protocol packets, the module performs the following operations:
· Specifies the monitoring scope (for example, packets on the specified interface or all packets on the device).
· Specifies the characteristics (for example, the specified Ethernet protocol type and the specified MAC) of the protocol packets to be monitored.
· Applies the characteristics to the Ethernet module.
The Ethernet module can match packets against the registered characteristics base during the specified phase. The phases include RCV-MAC phase, RCV-LLC phase, and SND-L3IF phase. Packets matching the characteristics are processed by the current phase. Packets not matching the characteristics are processed by the next phase.
display system internal ethernet controlblock
Use display system internal ethernet controlblock to display the control block information of an interface, including the link layer parameter values.
In standalone mode:
display system internal ethernet controlblock interface { interface-type interface-number } slot slot-number
In IRF mode:
display system internal ethernet controlblock interface { interface-type interface-number } chassis chassis-number slot slot-number
Probe view
interface interface-type interface-number: Displays the link control information of an interface specified by its type and number.
slot slot-number: Displays the link control information on the specified card. The slot-number argument represents the number of the slot that houses the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the link control information on the specified card of the specified IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that houses the card. (In IRF mode.)
display system internal evi flooding
Use display system internal evi flooding to display EVI flooding information.
In standalone mode:
display system internal evi flooding interface interface-type interface-number slot slot-number
In IRF mode:
display system internal evi flooding interface interface-type interface-number chassis chassis-number slot slot-number
Probe view
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
display system internal evi selective-flooding
Use display system internal evi selective-flooding to display driver information for the MAC address that is used for selective flooding in the specified VLAN of an EVI tunnel interface.
In standalone mode:
display system internal evi selective-flooding interface tunnel interface-number mac-address mac-address vlan vlan-id slot slot-number
In IRF mode:
display system internal evi selective-flooding interface tunnel interface-number mac-address mac-address vlan vlan-id chassis chassis-number slot slot-number
Probe view
interface tunnel interface-number: Specifies an EVI tunnel interface.
mac-address mac-address: Specifies the MAC address used for selective flooding.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
display system internal evi statistics
Use display system internal evi statistics to display EVI statistics.
In standalone mode:
display system internal evi statistics slot slot-number
In IRF mode:
display system internal evi statistics chassis chassis-number slot slot-number
Probe view
display system internal evi vlan-mapping
Use display system internal evi vlan-mapping to display EVI VLAN-mapping information.
In standalone mode:
display system internal evi vlan-mapping vlan vlan-id interface interface-type interface-number slot slot-number
In IRF mode:
display system internal evi vlan-mapping vlan vlan-id interface interface-type interface-number chassis chassis-number slot slot-number
Probe view
vlan vlan-id: Specifies a local VLAN by its ID in the range of 1 to 4094.
display system internal evi vlan-status
Use display system internal evi vlan-status to display driver information for a VLAN on an EVI tunnel interface.
In standalone mode:
display system internal evi vlan-status interface tunnel interface-number vlan vlan-id slot slot-number
In IRF mode:
display system internal evi vlan-status interface tunnel interface-number vlan vlan-id chassis chassis-number slot slot-number
Probe view
display system internal evi-link data
Use display system internal evi-link data to display kernel data for an EVI-Link interface.
In standalone mode:
display system internal evi-link data interface evi-link number [ slot slot-number ]
In IRF mode:
display system internal evi-link data interface evi-link number [ chassis chassis-number slot slot-number ]
Probe view
interface evi-link number: Specifies an EVI-Link interface by its interface number. The EVI-Link interface must exist on the device.
slot slot-number: Specifies a card by its slot number. If you do not specify a card, this command displays kernel data for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. If you do not specify a card, this command displays kernel data for the global active MPU. (In IRF mode.)
display system internal eviisis status
Use display system internal eviisis status to display EVI IS-IS process state.
Probe view
display system internal fib prefix
Use display system internal fib prefix to display brief information about IPv4 FIB prefixes.
In standalone mode:
display system internal fib prefix [ vpn-instance vpn-instance-name ] slot slot-number
In IRF mode:
display system internal fib prefix [ vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
Probe view
vpn-instance vpn-instance-name: Displays brief information about IPv4 FIB prefix for the specified VPN instance. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify any VPN, the command displays brief information about IPv4 FIB prefix for the public network.
display system internal fib prefix entry-status
Use display system internal fib prefix entry-status to display the IPv4 FIB prefixes that fail to be set to the driver or are aging.
In standalone mode:
display system internal fib prefix [ vpn-instance vpn-instance-name] entry-status status slot slot-number
In IRF mode:
display system internal fib prefix [ vpn-instance vpn-instance-name] entry-status status chassis chassis-number slot slot-number
Probe view
vpn-instance vpn-instance-name: Displays the IPv4 FIB prefixes that fail to be set to the driver or are aging for the specified VPN instance. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify any VPN, the command displays brief information about IPv4 FIB prefix for the public network.
entry-status status: Displays the IPv4 FIB prefixes in the specified status. The value for the status argument can be A or F.
· A indicates aging IPv4 FIB entries.
· F indicates the IPv4 FIB entries that fail to be set to the driver.
display system internal fib prefix ip
Use display system internal fib prefix ip to display IPv4 FIB prefix information for an IP address.
In standalone mode:
display system internal fib prefix [ vpn-instance vpn-instance-name ] ip [ mask | mask-length ] slot slot-number
In IRF mode:
display system internal fib prefix [ vpn-instance vpn-instance-name ] ip [ mask | mask-length ] chassis chassis-number slot slot-number
Probe view
vpn-instance vpn-instance-name: Displays the IPv4 FIB prefix information for the specified VPN instance. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify any VPN, the command displays brief information about IPv4 FIB prefix for the public network.
ip: Specifies an IP address.
mask: Specifies the mask for the IP address.
mask-length: Specifies the mask length for the IP address, the number of consecutive ones in the mask.
display system internal fib running-status
Use display system internal fib running-status to display the running status information for IPv4 FIB, IPv6 FIB, and virtual next hops (VN).
In standalone mode:
display system internal fib running-status slot slot-number
In IRF mode:
display system internal fib running-status chassis chassis-number slot slot-number
Probe view
display system internal fib statistics
Use display system internal fib statistics to display statistics about the IPv4 FIB, IPv6 FIB, and VN.
In standalone mode:
display system internal fib statistics slot slot-number
In IRF mode:
display system internal fib statistics chassis chassis-number slot slot-number
Probe view
display system internal fib vn
Use display system internal fib vn to display VN entry information.
In standalone mode:
display system internal fib vn [ next-hop next-hop ] slot slot-number
display system internal fib vn { id id | index index } slot slot-number
In IRF mode:
display system internal fib vn [ next-hop next-hop ] chassis chassis-number slot slot-number
display system internal fib vn { id id | index index } chassis chassis-number slot slot-number
Probe view
id id: Displays VN entry information for the specified VN ID.
index index: Displays VN entry information for the specified VN index.
next-hop next-hop: Displays VN entry information for the specified next hop. An IPv4 or IPv6 address can be entered in this parameter.
display system internal fib vn entry-status
Use display system internal fib vn entry-status to display VN entry information in the specified status.
In standalone mode:
display system internal fib vn entry-status status slot slot-number
In IRF mode:
display system internal fib vn entry-status status chassis chassis-number slot slot-number
Probe view
entry-status status: Displays VN entry information in the specified status. The value for the status argument can be A, F, or R.
· A indicates aging VN entries.
· F indicates the VN entries that fail to be set to the driver.
· R indicates the VN entries that are not deleted due to the reference.
display system internal fib vn reference
Use display system internal fib vn reference to display information about VN references.
In standalone mode:
display system internal fib vn { id id | index index } reference slot slot-number
In IRF mode:
display system internal fib vn { id id | index index } reference chassis chassis-number slot slot-number
Probe view
id id: Displays information about VN references for the specified VN ID.
index index: Displays information about VN references for the specified VN index.
reference: Displays information about the prefix of the VN reference.
display system internal ha service
Use display system internal ha service to display HA statistics of the specified service process, including basic service registration information, control message processing statistics, and data sending and receiving statistics.
display system internal ha service socket
Probe view
socket: Specifies a service process by its socket. You can use the display system internal ha service-group sg-name command to query sockets.
Use display system internal ha service-group to display information about SGs registered with the HA module, including SG name, SG status, and number of SUs.
display system internal ha service-group [ name [ instance ] ]
Probe view
name: Specifies an SG by its name. If this argument is not specified, the command displays information about all SGs.
instance: Specifies an SG instance (if any).
display system internal ha statistics
Use display system internal ha statistics to display HA submodule statistics.
display system internal ha statistics { submodule { fsm | service } | summary }
Probe view
submodule: Specifies an HA submodule.
fsm: Specifies the FSM submodule.
service: Specifies the service submodule.
summary: Displays the global statistics.
display system internal httpd service
Use display system internal httpd service to display HTTPD service information.
Probe view
display system internal ifmgr brief
Use display system internal ifmgr brief to display brief information about an interface.
In standalone mode:
display system internal ifmgr brief { para slot slot-number | help }
In IRF mode:
display system internal ifmgr brief { para chassis chassis-number slot slot-number | help }
Probe view
para: Specifies an interface index.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. (In IRF mode.)
help: Displays help information for valid parameters that you can specify.
display system internal ifmgr down
Use display system internal ifmgr down to display the down types that have been registered.
In standalone mode:
display system internal ifmgr down [ slot slot-number ]
In IRF mode:
display system internal ifmgr down [ chassis chassis-number slot slot-number ]
Probe view
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays the registered down types on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the registered down types on the global active MPU in the IRF fabric. (In IRF mode.)
display system internal ifmgr entry
Use display system internal ifmgr entry to display data structure information for an interface.
In standalone mode:
display system internal ifmgr entry { para [ slot slot-number ] | help }
In IRF mode:
display system internal ifmgr entry { para [ chassis chassis-number slot slot-number ] | help }
Probe view
para: Specifies an interface name or index in the format of 1*Interface index or 2*Interface name.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays data structure information for the interfaces on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays data structure information for the interfaces on the global active MPU in the IRF fabric. (In IRF mode.)
display system internal ifmgr event
Use display system internal ifmgr event to display register information for an interface event, including the modules that have registered the event, and the types of the interfaces on which the modules have registered the event.
In standalone mode:
display system internal ifmgr event { para [ slot slot-number ] | help }
In IRF mode:
display system internal ifmgr event { para [ chassis chassis-number slot slot-number ] | help }
Probe view
para: Specifies an event type or interface type. If you specify both an event type and an interface type, connect them by using an asterisk (*) in the form of event*type.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays interface event register information on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays interface event register information on the global active MPU in the IRF fabric. (In IRF mode.)
display system internal ifmgr hotplug
Use display system internal ifmgr hotplug to display hotplug information for a card or subcard.
In standalone mode:
display system internal ifmgr hotplug [ para [ slot slot-number ] | help ]
In IRF mode:
display system internal ifmgr hotplug [ para [ chassis chassis-number slot slot-number ] | help ]
Probe view
para: Specifies a slot number. If you do not specify this argument, the command displays hotplug information for all cards.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays card hotplug information on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays card hotplug information on the global active MPU in the IRF fabric. (In IRF mode.)
display system internal ifmgr index
Use display system internal ifmgr index to display interface index information.
In standalone mode:
display system internal ifmgr index { para [ slot slot-number ] | help }
In IRF mode:
display system internal ifmgr index { para [ chassis chassis-number slot slot-number ] | help }
Probe view
para: Specifies an interface index in decimal format.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays interface index information for the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays interface index information for the global active MPU in the IRF fabric. (In IRF mode.)
display system internal ifmgr list
Use display system internal ifmgr list to display the name and index of each interface.
In standalone mode:
display system internal ifmgr list [ para [ slot slot-number ] | help ]
In IRF mode:
display system internal ifmgr list [ para [ chassis chassis-number slot slot-number ] | help ]
Probe view
para: Specifies an interface type. If you do not specify an interface type, the command displays names and indexes of all interfaces.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays names and indexes of the interfaces on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays names and indexes of the interfaces on the global active MPU in the IRF fabric. (In IRF mode.)
display system internal ifmgr mdc
Use display system internal ifmgr mdc to display information about the interfaces assigned to MDCs.
In standalone mode:
display system internal ifmgr mdc { para [ slot slot-number ] | help }
In IRF mode:
display system internal ifmgr mdc { para [ chassis chassis-number slot slot-number ] | help }
Probe view
para: Specifies a parameter for the command. Valid formats for this argument include:
· 1*ID of the group to which the interface belongs.
· 2*Interface name.
· 3*MDC ID.
· 4*Slot number.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays the interfaces assigned to MDCs on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays the interfaces assigned to MDCs on the global active MPU in the IRF fabric. (In IRF mode.)
display system internal ifmgr name
Use display system internal ifmgr name to display a tree structure such as interface index, interface number, and help information to parse an interface name.
In standalone mode:
display system internal ifmgr name { para [ slot slot-number ] | help }
In IRF mode:
display system internal ifmgr name { para [ chassis chassis-number slot slot-number ] | help
Probe view
para: Specifies the full name or abbreviated name of an interface.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays tree structures such as interface indexes, interface numbers, and help information for the interfaces on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays tree structures such as interface indexes, interface numbers, and help information for the interfaces on the global active MPU in the IRF fabric. (In IRF mode.)
display system internal ifmgr type
Use display system internal ifmgr type to display interface type information.
In standalone mode:
display system internal ifmgr type { para [ slot slot-number ] | help }
In IRF mode:
display system internal ifmgr type { para [ chassis chassis-number slot slot-number ] | help }
Probe view
para: Specifies an interface type, a string of 1 to 127 characters.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the command displays interface type information for the interfaces on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. If you do not specify this option, the command displays interface type information for the interfaces on the global active MPU in the IRF fabric. (In IRF mode.)
display system internal ip address
Use display system internal ip address to display detailed information about an IP address.
In standalone mode:
display system internal ip address [ vpn-instance vpn-instance-name ] [ interface interface-type interface-number ] [ ip-address ] slot slot-number
In IRF mode:
display system internal ip address [ vpn-instance vpn-instance-name ] [ interface interface-type interface-number ] [ ip-address ] chassis chassis-number slot slot-number
Probe view
ip-address ip-address: Specifies an IP address.
vpn-instance vpn-instance-name: Specifies the VPN to which an IP address belongs.
slot slot-number: Displays IP addresses on a card. The slot-number argument specifies the card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Displays IP addresses on a card of an IRF member device. The chassis-number argument represents the IRF member ID of the device. The slot-number argument represents the slot number of card on the device. (In IRF mode.)
If you do not specify any parameters, this command displays detailed information about all IPv4 addresses for the public network.
ip address
display system internal ip source binding
Use display system internal ip source binding to display detailed information about IPv4 source guard bindings.
In standalone mode:
display system internal ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dot1x | dhcp-relay | dhcp-server | dhcp-snooping ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] slot slot-number
In IRF mode:
display system internal ip source binding [ static | [ vpn-instance vpn-instance-name ] [ dot1x | dhcp-relay | dhcp-server | dhcp-snooping ] ] [ ip-address ip-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
Probe view
static: Specifies static IPv4 source guard binding entries.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance, a case-sensitive string of 1 to 31 characters.
dhcp-relay: Displays dynamic IPv4 source guard binding entries created by DHCP relay.
dhcp-server: Displays dynamic IPv4 source guard binding entries created by DHCP server.
dhcp-snooping: Displays dynamic IPv4 source guard binding entries created by DHCP snooping.
dot1x: Displays dynamic IPv4 source guard binding entries created by 802.1X.
ip-address ip-address: Displays the IPv4 source guard binding entry for an IPv4 address.
mac-address mac-address: Displays the IPv4 source guard binding entry for a MAC address. The MAC address must be specified in H-H-H format.
vlan vlan-id: Specifies a VLAN. The vlan-id argument represents the bound VLAN ID in the range of 1 to 4094.
interface interface-type interface-number: Displays IPv4 source guard binding entries on an interface.
slot slot-number: Displays IPv4 source guard binding entries on a card. The slot-number argument represents the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays IPv4 source guard binding entries on a card in an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that holds the card. (In IRF mode.)
ip source binding
display system internal ip vpn-binding
Use display system internal ip vpn-binding to display VPN instance binding information for the system kernel.
display system internal ip vpn-binding slot slot-number
In IRF mode:
display system internal ip vpn-binding chassis chassis-number slot slot-number
Probe view
display system internal ip vpn-instance
Use display system internal ip vpn-instance to display VPN instance information for the system kernel.
In standalone mode:
display system internal ip vpn-instance [ instance-name vpn-instance-name ] slot slot-number
In IRF mode:
display system internal ip vpn-instance [ instance-name vpn-instance-name ] chassis chassis-number slot slot-number
Probe view
instance-name vpn-instance-name: Specifies a VPN instance by its name. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters.
display system internal ip vpn-instance inactive
Use display system internal ip vpn-instance inactive to display information about VPN instances that are being deleted.
Probe view
display system internal ip vpn-instance statistics
Use display system internal ip vpn-instance statistics to display VPN instance statistics for the system kernel.
In standalone mode:
display system internal ip vpn-instance statistics slot slot-number
In IRF mode:
display system internal ip vpn-instance statistics chassis chassis-number slot slot-number
Probe view
display system internal ipv6 address
Use display system internal ipv6 address to display IPv6 address detailed information.
In standalone mode:
display system internal ipv6 address [ vpn-instance vpn-instance-name ] [ interface interface-type interface-number ] [ ipv6-address ] slot slot-number
In IRF mode:
display system internal ipv6 address [ vpn-instance vpn-instance-name ] [ interface interface-type interface-number ] [ ipv6-address ] chassis chassis-number slot slot-number
Probe view
ipv6-address: Displays detailed information about the specified IPv6 address.
vpn-instance vpn-instance-name: Displays detailed information about a specific IPv6 address of the specified VPN instance.
interface interface-type interface-number: Displays detailed information about a specific IPv6 address of the specified interface.
slot slot-number: Displays detailed information about a specific IPv6 address for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays detailed information about a specific IPv6 address for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
If you do not specify any parameters, the command displays detailed information about all IPv6 addresses on the public network.
display system internal ipv6 fib prefix
Use display system internal ipv6 fib prefix to display basic information about IPv6 FIB prefixes.
In standalone mode:
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] slot slot-number
In IRF mode:
display system internal ipv6 fib prefix [vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
Probe view
vpn-instance vpn-instance-name: Displays basic information about the IPv6 FIB prefix for the specified MPLS L3VPN. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays basic information about the IPv6 FIB prefix for the public network.
slot slot-number: Displays basic information about the IPv6 FIB prefix for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays basic information about the IPv6 FIB prefix for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal ipv6 fib prefix entry-status
Use display system internal ipv6 fib prefix entry-status to display IPv6 FIB entries that fail to be set to the driver or that are aging.
In standalone mode:
display system internal ipv6 fib prefix entry-status status [ vpn-instance vpn-instance-name ] slot slot-number
In IRF mode:
display system internal ipv6 fib prefix entry-status status [ vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
Probe view
vpn-instance vpn-instance-name: Displays the IPv6 FIB prefixes that fail to be set to the driver or that are aging for the specified VPN instance. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify any VPN, the command displays information about IPv6 FIB entries for the public network.
entry-status status: Specifies the status of IPv6 FIB entries. The value of the status argument can be A or F. A indicates aging FIB entries, and F indicates the FIB entries that fail to be set to the driver.
slot slot-number: Displays IPv6 FIB prefixes that fail to be set to the driver or that are aging for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the IPv6 FIB prefixes that fail to be set to the driver or that are aging for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal ipv6 fib prefix ipv6
Use display system internal ipv6 fib prefix to display detailed information the IPv6 FIB prefix for a specific IPv6 address.
In standalone mode:
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] ipv6 [ prefix-length ] slot slot-number
In IRF mode:
display system internal ipv6 fib prefix [ vpn-instance vpn-instance-name ] ipv6 [ prefix-length ] chassis chassis-number slot slot-number
Probe view
vpn-instance vpn-instance-name: Displays detailed information about a specific IPv6 FIB prefix for the specified MPLS L3VPN. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays detailed information about the IPv6 FIB prefix for the public network.
ipv6: Displays detailed information about the IPv6 FIB prefix for the specified IPv6 address.
prefix-length: Specifies the length of an IPv6 FIB prefix, in the range of 0 to 128.
slot slot-number: Displays detailed information about a specific IPv6 FIB prefix for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays detailed information about a specific IPv6 FIB prefix for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal ipv6 l2-multicast ip forwarding verbose
Use display system internal ipv6 l2-multicast ip forwarding verbose to display detailed information about IPv6 forwarding entries for IPv6 Layer 2 multicast.
In standalone mode:
display system internal ipv6 l2-multicast ip forwarding verbose [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display system internal ipv6 l2-multicast ip forwarding verbose [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe view
group ipv6-group-address: Specifies an IPv6 multicast group. If this option is not specified, this command displays detailed information about the IPv6 forwarding entries for all IPv6 multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source. If this option is not specified, this command displays detailed information about the IPv6 forwarding entries for all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command displays detailed information about the IPv6 forwarding entries for all VLANs.
slot slot-numbe: Specifies a card by its slot number. If no card is specified, this command displays detailed information about the IPv6 forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays detailed information about the IPv6 forwarding entries for all MPUs in the IRF fabric. (In IRF mode.)
display system internal ipv6 l2-multicast ip verbose
Use display system internal ipv6 l2-multicast ip verbose to display detailed information about IPv6 multicast groups in IPv6 Layer 2 multicast.
In standalone mode:
display system internal ipv6 l2-multicast ip verbose [ group ipv6-group-address | source ipv6-source-address] * [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display system internal ipv6 l2-multicast ip verbose [ group ipv6-group-address | source ipv6-source-address] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe view
group ipv6-group-address: Specifies an IPv6 multicast group. If this option is not specified, this command displays detailed information about all IPv6 multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source. If this option is not specified, , this command displays detailed information about IPv6 multicast groups with all IPv6 multicast sources.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command displays detailed information about the IPv6 multicast groups for all VLANs.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays detailed information about the IPv6 multicast groups for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays detailed information about the IPv6 multicast groups for all MPUs in the IRF fabric. (In IRF mode.)
display system internal ipv6 l2-multicast ipc statistics
Use display system internal ipv6 l2-multicast ipc statistics to display inter-process communication (IPC) statistics for IPv6 Layer 2 multicast.
In standalone mode:
display system internal ipv6 l2-multicast ipc statistics [ slot slot-number ]
In IRF mode:
display system internal ipv6 l2-multicast ipc statistics [ chassis chassis-number slot slot-number ]
Probe view
slot slot-numbe: Specifies a card by its slot number. If no card is specified, this command displays IPC statistics for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays IPC statistics for all MPUs in the IRF fabric. (Distributed devices–In IRF mode.)
display system internal ipv6 l2-multicast mac forwarding verbose
Use display system internal ipv6 l2-multicast mac forwarding verbose to display detailed information about the MAC forwarding entries for IPv6 Layer 2 multicast.
In standalone mode:
display system internal ipv6 l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display system internal ipv6 l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe view
mac-address: Specifies a MAC multicast group. If this argument is not specified, this command displays detailed information about the MAC forwarding entries for all MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command displays detailed information about the MAC forwarding entries for all VLANs.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays detailed information about the MAC forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays detailed information about the MAC forwarding entries for all MPUs in the IRF fabric. (In IRF mode.)
display system internal ipv6 l2-multicast mac verbose
Use display system internal ipv6 l2-multicast mac verbose to display detailed information about MAC multicast groups for IPv6 Layer 2 multicast.
In standalone mode:
display system internal ipv6 l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display system internal ipv6 l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe view
mac-address: Specifies a MAC multicast group. If this argument is not specified, this command displays detailed information about all MAC multicast groups.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command displays detailed information about the MAC multicast groups for all VLANs.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays detailed information about the MAC multicast groups for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays detailed information about the MAC multicast groups for all MPUs in the IRF fabric. (In IRF mode.)
display system internal ipv6 mrib interface statistics
Use display system internal ipv6 mrib interface statistics display statistics for the interfaces that are maintained by the IPv6 MRIB, including interfaces that are configured with IPv6 multicast protocols, register interfaces, InLoopBack0 interfaces, and null0 interfaces.
display system internal ipv6 mrib [ vpn-instance vpn-instance-name ] interface statistics
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays statistics for the interfaces that are maintained by the IPv6 MRIB on the public network.
display system internal ipv6 mrib mbr
Use display system internal ipv6 mrib mbr interface to display join/prune information maintained by the multicast border router (MBR) in the IPv6 MRIB process.
display system internal ipv6 mrib [ vpn-instance vpn-instance-name ] mbr interface interface-type interface-number [ source ipv6-source-address group ipv6-group-address ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays join/prune information maintained by the MBR in the IPv6 MRIB process on the public network.
source ipv6-source-address: Specifies an IPv6 source address. If this option is not specified, this command does not display IPv6 MBR entries.
group ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16, where x and y represent any hexadecimal numbers from 0 to F. The IPv6 multicast group address cannot be FFx0::/16, FFx1::/16, FFx2::/16, or FF0y::. If this option is not specified, this command does not display IPv6 MBR entries.
display system internal ipv6 multicast forwarding vlan reference
Use display system internal ipv6 multicast forwarding vlan reference to display mappings between outgoing VLAN interfaces and IPv6 Layer 2 multicast entries.
In standalone mode:
display system internal ipv6 multicast forwarding vlan reference [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display system internal ipv6 multicast forwarding vlan reference [ group ipv6-group-address | source ipv6-source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe view
group ipv6-group-address: Specifies an IPv6 multicast group address. If this option is not specified, this command displays mappings between outgoing VLAN interfaces and IPv6 Layer 2 multicast entries for all multicast groups.
source ipv6-source-address: Specifies an IPv6 multicast source address. If this option is not specified, this command displays mappings between outgoing VLAN interfaces and IPv6 Layer 2 multicast entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command displays mappings between outgoing VLAN interfaces and IPv6 Layer 2 multicast entries for all VLANs.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays mappings between outgoing VLAN interfaces and IPv6 Layer 2 multicast entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays mappings between outgoing VLAN interfaces and IPv6 Layer 2 multicast entries for all MPUs in the IRF fabric. (In IRF mode.)
display system internal ipv6 multicast forwarding-table dummy
Use display system internal ipv6 multicast forwarding-table dummy to display temporary IPv6 multicast forwarding entries.
In standalone mode:
display system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | statistics | slot slot-number ] *
In IRF mode:
display system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | chassis chassis-number slot slot-number | statistics ] *
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays temporary IPv6 multicast forwarding entries on the public network.
ipv6-source-address: Specifies an IPv6 multicast source address. If this argument is not specified, this command displays the temporary IPv6 multicast forwarding entries for all IPv6 multicast sources.
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16, where x and y represent any hexadecimal numbers from 0 to F. If this argument is not specified, this command displays the temporary IPv6 multicast forwarding entries for all IPv6 multicast groups.
prefix-length: Specifies the address prefix length. The default value is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays the temporary IPv6 multicast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays the temporary IPv6 multicast forwarding entries for all MPUs in the IRF fabric. (In IRF mode.)
statistics: Displays statistics.
display system internal ipv6 multicast forwarding-table verbose
Use display system internal ipv6 multicast forwarding-table verbose to display detailed information about the IPv6 multicast forwarding table.
In standalone mode:
display system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table verbose [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number ] *
In IRF mode:
display system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table verbose [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | chassis chassis-number slot slot-number | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays detailed information about the IPv6 multicast forwarding table on the public network.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays detailed information about the IPv6 multicast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-numbe: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays detailed information about the IPv6 multicast forwarding entries for all MPUs in the IRF fabric.( In IRF mode.)
incoming-interface: Specifies the IPv6 multicast forwarding entries that include the specified incoming interface.
interface-type interface-number: Specifies an incoming interface by its type and number.
outgoing-interface: Specifies the IPv6 multicast forwarding entries that include the specified outgoing interface.
exclude: Specifies the IPv6 multicast forwarding entries that do not include the specified interface in the outgoing interface list.
include: Specifies the IPv6 multicast forwarding entries that include the specified interface in the outgoing interface list.
match: Specifies the IPv6 multicast forwarding entries that include only the specified interface in the outgoing interface list.
display system internal ipv6 multicast-vlan forwarding-table verbose
Use display system internal ipv6 multicast-vlan forwarding-table verbose to display detailed information about the IPv6 multicast VLAN forwarding table.
In standalone mode:
display system internal ipv6 multicast-vlan forwarding-table verbose [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | slot slot-number | subvlan vlan-id | vlan vlan-id ] *
In IRF mode:
display system internal ipv6 multicast-vlan forwarding-table verbose [ ipv6-source-address [ prefix-length ] | ipv6-group-address [ prefix-length ] | chassis chassis-number slot slot-number | subvlan vlan-id | vlan vlan-id ] *
Probe view
ipv6-source-address: Specifies an IPv6 multicast source address. If this argument is not specified, this commands displays detailed information about the IPv6 multicast VLAN forwarding entries for all IPv6 multicast sources.
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16, where x and y represent any hexadecimal numbers from 0 to F. If this argument is not specified, this commands displays detailed information about the IPv6 multicast VLAN forwarding entries for all IPv6 multicast groups.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays detailed information about the IPv6 multicast VLAN forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays detailed information about the IPv6 multicast VLAN forwarding entries for all MPUs in the IRF fabric. (In IRF mode.)
subvlan vlan-id: Specifies a sub-VLAN by its ID. If this option is not specified, this command displays detailed information about the IPv6 multicast VLAN forwarding entries for all sub-VLANs.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command displays detailed information about the IPv6 multicast VLAN forwarding entries for all VLANs.
display system internal ipv6 pathmtu
Use display system internal ipv6 pathmtu to display IPv6 Path MTU information.
In standalone mode:
display system internal ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | { all | dynamic | static } [ count ] } slot slot-number
In IRF mode:
display system internal ipv6 pathmtu [ vpn-instance vpn-instance-name ] { ipv6-address | { all | dynamic | static } [ count ] } chassis chassis-number slot slot-number
Probe view
vpn-instance vpn-instance-name: Displays IPv6 Path MTU information for the specified MPLS L3VPN. The vpn-instance-name argument is a case-sensitive string of 1 to 31 characters. If you do not specify this option, the command displays the IPv6 Path MTU information for the public network.
all: Displays all Path MTU information for the public network.
dynamic: Displays all dynamic Path MTU information.
static: Displays all static Path MTU information.
count: Displays the total number of Path MTU entries.
slot slot-number: Displays Path MTU entries for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays Path MTU entries for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
If you do not specify any parameters, the command displays all Path MTU information for the public network.
display system internal ipv6 pbr fib
Use display system internal ipv6 pbr fib to display next hop information in user mode.
In standalone mode:
display system internal ipv6 pbr fib [ vpn-instance vpn-instance-name ] slot slot-number
In IRF mode:
display system internal ipv6 pbr fib [ vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
The system does not display next hop information in user mode.
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist. If no VPN is specified, the command displays information about next hops belonging to the public network.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal ipv6 pbr kernel policy
Use display system internal ipv6 pbr kernel policy to display IPv6 PBR policy information in kernel mode.
In standalone mode:
display system internal ipv6 pbr kernel policy [ policy-name [ setup ] ] slot slot-number
In IRF mode:
display system internal ipv6 pbr kernel policy [ policy-name [ setup ] ] chassis chassis-number slot slot-number
The system does not display IPv6 PBR policy information in kernel mode.
Probe view
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters.
setup: Displays information about the specified IPv6 PBR policy applied to an interface.
display system internal ipv6 pbr policy
Use display system internal ipv6 pbr policy to display IPv6 PBR policy information in user mode.
In standalone mode:
display system internal ipv6 pbr policy [ policy-name [ setup ] ] slot slot-number
In IRF mode:
display system internal ipv6 pbr policy [ policy-name [ setup ] ] chassis chassis-number slot slot-number
The system does not display IPv6 PBR policy information in user mode.
Probe view
display system internal ipv6 pim interface
Use display system internal ipv6 pim interface to display interface information maintained by the label information base (LIB) in the IPv6 PIM process.
display system internal ipv6 pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number [ address | gateway | prefix] ] | ipv6-address prefix-length ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays interface information maintained by the LIB in the IPv6 PIM process on the public network.
address: Specifies an IPv6 address.
gateway: Specifies an IPv6 gateway address.
prefix: Specifies an IPv6 address prefix.
ipv6-address: Specifies an IPv6 address except ::. If this argument is not specified, this command displays the interface information for all IPv6 addresses.
prefix-length: Specifies the address prefix length in the range of 0 to 128.
display system internal ipv6 pim rp
Use display system internal ipv6 pim rp to display IPv6 PIM RP statistics.
display system internal ipv6 pim [ vpn-instance vpn-instance-name ] rp
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays IPv6 PIM RP statistics on the public network.
display system internal ipv6 pim thread
Use display system internal ipv6 pim thread to display statistics for the IPv6 PIM threads.
display system internal ipv6 pim thread { event | main | route }
Probe view
event: Specifies the IPv6 PIM event thread.
main: Specifies the IPv6 PIM main thread.
route: Specifies the IPv6 PIM routing thread.
display system internal ipv6 rawip
Use display system internal ipv6 rawip to display brief information about IPv6 RawIP connections.
In standalone mode:
display system internal ipv6 rawip slot slot-number
In IRF mode:
display system internal ipv6 rawip chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays brief information about IPv6 RawIP connections for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief information about IPv6 RawIP connections for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal ipv6 rib event attribute
Use display system internal ipv6 rib event attribute to display IPv6 RIB attribute events.
Probe view
display system internal ipv6 rib event policy
Use display system internal ipv6 rib event policy to display IPv6 RIB policy events.
Probe view
display system internal ipv6 rib event prefix
Use display system internal ipv6 rib event prefix to display IPv6 RIB prefix events.
Probe view
display system internal ipv6 rib event protocol
Use display system internal ipv6 rib event protocol to display IPv6 RIB protocol events.
display system internal ipv6 rib event protocol [ vpn-instance vpn-instance-name ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Without this option, the command displays the information for the public network.
display system internal ipv6 rib event statistics
Use display system internal ipv6 rib event statistics to display IPv6 RIB event statistics.
display system internal ipv6 rib event statistics [ vpn-instance vpn-instance-name ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Without this option, the command displays the statistics for the public network.
display system internal ipv6 rib log
Use display system internal ipv6 rib log to display IPv6 RIB logs.
display system internal ipv6 rib log [ reverse ]
display system internal ipv6 rib event log
Probe view
rib: Displays IPv6 RIB logs.
event: Displays logs about IPv6 RIB rouging changes.
reverse: Displays logs in reverse chronological order.
display system internal ipv6 rib memory
Use display system internal ipv6 rib memory to display IPv6 RIB memory information.
Probe view
display system internal ipv6 rib nib log
Use display system internal ipv6 rib nib log to display IPv6 next hop logs.
display system internal ipv6 rib nib log [ reverse ]
Probe view
nib: Displays IPv6 next hop logs.
display system internal ipv6 rib prefix
Use display system internal ipv6 rib prefix to display IPv6 RIB prefix information.
display system internal ipv6 rib prefix ipv6-address prefix-length [ vpn-instance vpn-instance-name ]
Probe view
ipv6-address: Specifies the destination IPv6 address.
prefix-length: Specifies the prefix length of the destination IPv6 address, in the range of 0 to 128.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Without this option, the command displays the IPv6 RIB prefix information for the public network.
display system internal ipv6 rib summary
Use display system internal ipv6 rib summary to display IPv6 RIB statistics.
Probe view
display system internal ipv6 route-direct interface
Use display system internal ipv6 route-direct interface to display IPv6 interface information.
display system internal ipv6 route-direct interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Without this option, the command displays the IPv6 interface information for the public network.
ipv6-address: Specifies an IPv6 address.
prefix-length: Specifies the prefix length of the IPv6 address, in the range of 0 to 128.
display system internal ipv6 route-direct log
Use display system internal ipv6 route-direct log to display IPv6 direct route logs.
display system internal ipv6 route-direct { event | notify | nib } log [ reverse ]
Probe view
event: Displays interface event logs.
notify: Displays interface event notification logs.
nib: Displays logs for IPv6 direct route next hops.
display system internal ipv6 route-static nib log
Use display system internal ipv6 route-static nib log to display IPv6 static route NIB logs.
display system internal ipv6 route-static nib log [ reverse ]
Probe view
display system internal ipv6 source binding
Use display system internal ipv6 source binding to display detailed information about IPv6 source guard bindings.
In standalone mode:
display system internal ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [dhcpv6-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] slot slot-number
In IRF mode:
display system internal ipv6 source binding [ static | [ vpn-instance vpn-instance-name ] [dhcpv6-snooping ] ] [ ip-address ipv6-address ] [ mac-address mac-address ] [ vlan vlan-id ] [ interface interface-type interface-number ] [ chassis chassis-number slot slot-number ]
Probe view
static: Specifies static IPv6 source guard binding entries.
dhcpv6-snooping: Displays dynamic IPv6 source guard binding entries created by DHCPv6 snooping.
ip-address ipv6-address: Displays the IPv6 source guard binding entry for an IPv6 address.
mac-address mac-address: Displays the IPv6 source guard binding entry for a MAC address. The MAC address must be specified in H-H-H format.
interface interface-type interface-number: Displays IPv6 source guard binding entries on an interface.
slot slot-number: Displays Ipv6 source guard binding entries on a card. The slot-number argument represents the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays IPv6 source guard binding entries on a card in an IRF member device. The chassis-number argument represents the ID of the IRF member device and the slot-number argument represents the number of the slot that holds the card. (In IRF mode.)
display system internal ipv6 tcp
Use display system internal ipv6 tcp to display brief information about IPv6 TCP connections.
In standalone mode:
display system internal ipv6 tcp slot slot-number
In IRF mode:
display system internal ipv6 tcp chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays brief information about IPv6 TCP connections for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief information about IPv6 TCP connections for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal ipv6 udp
Use display system internal ipv6 udp to display brief information about IPv6 UDP connections.
In standalone mode:
display system internal ipv6 udp slot slot-number
In IRF mode:
display system internal ipv6 udp chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays brief information about IPv6 UDP connections for the specified card. The slot-number argument specifies the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief information about IPv6 UDP connections for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal isis import-route
Use display system internal isis import-route to display routes redistributed by IS-IS.
In standalone mode:
display system internal isis import-route [ ipv4 ] [ process-id ] [ standby slot slot-number ]
In IRF mode:
display system internal isis import-route [ ipv4 ] [ process-id ] [ standby chassis chassis-number slot slot-number ]
Probe view
ipv4: Displays routes redistributed by IS-IS.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. Without this argument, the command displays routes redistributed by all IS-IS processes.
standby slot slot-number: Displays backup routes redistributed by IS-IS for a card. The slot-number argument specifies the slot number of the card. Without this option, the command displays routes redistributed by IS-IS. (In standalone mode.)
standby chassis chassis-number slot slot-number: Displays backup routes redistributed by IS-IS for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. Without this option, the command displays routes redistributed by IS-IS. (In IRF mode.)
display system internal isis import-route ipv6
Use display system internal isis import-route ipv6 to display routes redistributed by IPv6 IS-IS.
In standalone mode:
display system internal isis import-route ipv6 [ process-id ] [ standby slot slot-number ]
In IRF mode:
display system internal isis import-route ipv6 [ process-id ] [ standby chassis chassis-number slot slot-number ]
Probe view
process-id: Specifies an IS-IS process by its ID in the range of 1 to 635535. Without this argument, the command displays routes redistributed by all IS-IS processes.
standby slot slot-number: Displays backup routes redistributed by IPv6 IS-IS for a card. Without this option, the command displays routes redistributed by IPv6 IS-IS. (In standalone mode.)
standby chassis chassis-number slot slot-number: Displays backup routes redistributed by IPv6 IS-IS for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. Without this option, the command displays routes redistributed by IPv6 IS-IS. (In IRF mode.)
display system internal isis interface
Use display system internal isis interface to display IS-IS interface information.
display system internal isis interface [ ipv4 ] [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe view
ipv4: Displays information about IS-IS interfaces.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Without this option, the command displays interface information for the public network.
ip-address: Specifies an IP address in dotted decimal notation.
mask: Specifies the IP address mask in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
display system internal isis interface ipv6
Use display system internal isis interface ipv6 to display IPv6 IS-IS interface information.
display system internal isis interface ipv6 [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe view
prefix-length: Specifies the prefix length, an integer in the range of 0 to 128.
display system internal isis nib
Use display system internal isis nib to display IS-IS next hop information.
display system internal isis nib [ ipv4 ] [ nib-id ] [ verbose ]
Probe view
ipv4: Displays IS-IS next hop information.
nib-id: Specifies a next hop by its ID in the range of 1 to FFFFFFFF. Without this argument, the command displays information about all next hops.
verbose: Displays detailed IS-IS next hop information.
display system internal isis nib ipv6
Use display system internal isis nib ipv6 to display IPv6 IS-IS next hop information.
display system internal isis nib ipv6 [ nib-id ] [ verbose ]
Probe view
verbose: Displays detailed IPv6 IS-IS next hop information. Without this keyword, the command displays brief IPv6 IS-IS next hop information.
display system internal isis nib log
Use display system internal isis nib log to display IS-IS next hop log information.
Probe view
display system internal isis prefix
Use display system internal isis prefix to display IS-IS prefix information.
In standalone mode:
display system internal isis prefix [ ipv4 ] [ [ level-1 | level-2 ] | [ prefix mask-length ] ] * [ process-id ] [ standby slot slot-number ]
In IRF mode:
display system internal isis prefix [ ipv4 ] [ [ level-1 | level-2 ] | [ prefix mask-length ] ] * [ process-id ] [ standby chassis chassis-number slot slot-number ]
Probe view
ipv4: Displays IS-IS prefix information.
level-1: Displays IS-IS Level-1 prefix information. If no level is specified, the command displays both Level-1 and Level-2 prefix information.
level-2: Displays IS-IS Level-2 prefix information. If no level is specified, the command displays both Level-1 and Level-2 prefix information.
prefix mask-length: Specifies a prefix and the mask length.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 65535. Without this argument, the command displays prefix information for all IS-IS processes.
standby slot slot-number: Displays backup IS-IS prefix information for a card. The slot-number argument specifies the slot number of the card. Without this option, the command displays IS-IS prefix information. (In standalone mode.)
standby chassis chassis-number slot slot-number: Displays backup IS-IS prefix information for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. Without this option, the command displays IS-IS prefix information. (In IRF mode.)
display system internal isis prefix ipv6
Use display system internal isis prefix ipv6 to display IPv6 IS-IS prefix information.
In standalone mode:
display system internal isis prefix ipv6 [ [ level-1 | level-2 ] | [ prefix mask-length ] ] * [ process-id ] [ standby slot slot-number ]
In IRF mode:
display system internal isis prefix ipv6 [ [ level-1 | level-2 ] | [ prefix mask-length ] ] * [ process-id ] [ standby chassis chassis-number slot slot-number ]
Probe view
level-1: Displays IS-IS Level 1 prefix information. If no level is specified, the command displays both Level 1 and Level 2 prefix information.
level-2: Displays IS-IS Level 2 prefix information. If no level is specified, the command displays both Level 1 and Level 2 prefix information.
process-id: Specifies an IS-IS process by its ID in the range of 1 to 635535. Without this argument, the command displays prefix information for all IS-IS processes.
standby slot slot-number: Displays backup IPv6 IS-IS prefix information for a card. Without this option, the command displays IPv6 IS-IS prefix information. (In standalone mode.)
standby chassis chassis-number slot slot-number: Displays backup IPv6 IS-IS prefix information for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. Without this option, the command displays IPv6 IS-IS prefix information. (In IRF mode.)
display system internal isis status
Use display system internal isis status to display global IS-IS status information.
Probe view
display system internal kernel memory dump
Use display system internal kernel memory dump to display kernel memory contents with the specified length starting from a specific kernel memory address.
In standalone mode:
display system internal kernel memory dump address address-hex length memory-length [ slot slot-number ]
In IRF mode:
display system internal kernel memory dump address address-hex length memory-length [ chassis chassis-number slot slot-number ]
Probe view
address address-hex: Specifies the start address.
length memory-length: Specifies the memory length in bytes from the start address. The value range is 1 to 1024.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the active MPU is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. If you do not specify this option, the global active MPU is specified. (In IRF mode.)
display system internal kernel memory pool
Use display system internal kernel memory pool to display the statistics of kernel memory pools being used.
In standalone mode:
display system internal kernel memory pool [ name name-string ] [ slot slot-number ]
display system internal kernel memory pool tag [ tag-value ] [ slot slot-number ]
display system internal kernel memory pool name name-string tag tag-value [ slot slot-number ]
In IRF mode:
display system internal kernel memory pool [ name name-string ] [ chassis chassis-number slot slot-number ]
display system internal kernel memory pool tag [ tag-value ] [ chassis chassis-number slot slot-number ]
display system internal kernel memory pool name name-string tag tag-value [ chassis chassis-number slot slot-number ]
Probe view
name name-string: Specifies a kernel memory pool by its name. If you specify only this option, the command displays brief usage information for the specified kernel memory pool.
tag tag-value: Specifies a kernel memory pool or kernel memory pools by a tag. If you specify only the tag keyword, the command displays brief usage information for all tagged kernel memory pools. If you specify only the tag tag-value option, the command displays brief usage information for the kernel memory pools with the specified tag.
If you specify neither the name option nor the tag option, the command displays brief usage information for all kernel memory pools.
If you specify both the name name-string option and the tag tag-value option, the command displays usage information for the specified kernel memory pool with the specified tag.
display system internal l2-multicast ip forwarding verbose
Use display system internal l2-multicast ip forwarding verbose to display detailed information about IP forwarding entries for Layer 2 multicast.
In standalone mode:
display system internal l2-multicast ip forwarding verbose [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display system internal l2-multicast ip forwarding verbose [ group group-address | source source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe view
group group-address: Specifies a multicast group address. If this option is not specified, this command displays detailed information about IP multicast forwarding entries for all multicast groups.
source source-address: Specifies a multicast source address. If this option is not specified, this command displays detailed information about IP multicast forwarding entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command displays detailed information about IP multicast forwarding entries for all VLANs.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays detailed information about IP multicast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays detailed information about IP multicast forwarding entries for all MPUs in the IRF fabric. (In IRF mode.)
display system internal l2-multicast ip verbose
Use display system internal l2-multicast ip verbose to display detailed information about IP multicast groups for Layer 2 multicast.
In standalone mode:
display system internal l2-multicast ip verbose [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display system internal l2-multicast ip verbose [ group group-address | source source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe view
group group-address: Specifies a multicast group address. If this option is not specified, this command displays detailed information about all multicast groups.
source source-address: Specifies a multicast source address. If this option is not specified, this command displays detailed information about the multicast groups with all multicast sources.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command displays detailed information about the multicast groups for all VLANs.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays detailed information about the multicast groups for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays detailed information about the multicast groups for all MPUs in the IRF fabric. (In IRF mode.)
display system internal l2-multicast ipc statistics
Use display system internal l2-multicast ipc statistics to display IPC statistics for Layer 2 multicast.
In standalone mode:
display system internal l2-multicast ipc statistics [ slot slot-number ]
In IRF mode:
display system internal l2-multicast ipc statistics [ chassis chassis-number slot slot-number ]
Probe view
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays IPC statistics for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays IPC statistics for all MPUs in the IRF fabric. (In IRF mode.)
display system internal l2-multicast mac forwarding verbose
Use display system internal l2-multicast mac forwarding verbose to display detailed information about the MAC forwarding entries for Layer 2 multicast.
In standalone mode:
display system internal l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display system internal l2-multicast mac forwarding verbose [ mac-address ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe view
display system internal l2-multicast mac verbose
Use display system internal l2-multicast mac verbose to display detailed information about MAC multicast groups for Layer 2 multicast.
In standalone mode:
display system internal l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display system internal l2-multicast mac verbose [ mac-address ] [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe view
display system internal l2vpn l2vfib record
Use display system internal l2vpn l2vfib record to display information recorded by the L2VPN L2VFIB module, including the following:
· Information received by L2VPN L2VFIB.
· Information L2VFIB sent to the driver.
· Information returned from the driver.
In standalone mode:
display system internal l2vpn l2vfib record [ start start-number ] slot slot-number
In IRF mode:
display system internal l2vpn l2vfib record [ start start-number ] chassis chassis-number slot slot-number
Probe view
start start-number: Specifies the number of a record, in the range of 0 to 10000. This command displays the specified record and all records that follow. If you do not specify this keyword, this command displays all records.
slot slot-number: Specifies a card. The slot-number argument represents the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card of an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that holds the card. (In IRF mode.)
reset system internal l2vpn l2vfib record
display system internal l2vpn l2vfib statistics
Use display system internal l2vpn l2vfib statistics to display L2VPN L2VFIB statistics.
In standalone mode:
display system internal l2vpn l2vfib statistics slot slot-number
In IRF mode:
display system internal l2vpn l2vfib statistics chassis chassis-number slot slot-number
Probe view
display system internal link-aggregation global
Use display system internal link-aggregation global to display the global information about the Ethernet link aggregation module.
In standalone mode:
display system internal link-aggregation slot slot-number global
In IRF mode:
display system internal link-aggregation chassis chassis-number slot slot-number global
Probe view
slot-number: Specifies a card by its slot number. (In standalone mode.)
display system internal link-aggregation interface
Use display system internal link-aggregation interface to display aggregate interface information.
In standalone mode:
display system internal link-aggregation slot slot-number interface { bridge-aggregation | route-aggregation } interface-number [ kernel | statistics ]
display system internal link-aggregation slot slot-number interface interface-type interface-number [ kernel | lacp | lacppdu | statistics ]
In IRF mode:
display system internal link-aggregation chassis chassis-number slot slot-number interface { bridge-aggregation | route-aggregation } interface-number [ kernel | statistics ]
display system internal link-aggregation chassis chassis-number slot slot-number interface interface-type interface-number [ kernel | lacp | lacppdu | statistics ]
Probe view
bridge-aggregation: Displays information about Layer 2 aggregate interfaces.
route-aggregation: Displays information about Layer 3 aggregate interfaces.
interface-number: Specifies an existing aggregate interface number.
interface-type interface-number: Specifies the interface type and interface number.
kernel: Displays kernel information.
statistics: Displays statistic information.
lacp: Displays dynamic aggregation information.
lacppdu: Displays statistics for LACPDUs.
If none of the kernel, lacp, lacppdu, and statistics keywords are specified, this command displays the interface information in the main thread.
Part of the information that is displayed overlaps because the information is saved in separate threads. You can use the overlapping information for problem location and analysis.
display system internal lipc lcmp statistics
Use display system internal lipc lcmp statistics to display global statistics for LIPC LCMP modules, including the number of sent and received packets and the number of errors.
display system internal lipc lcmp statistics [ lip lip ]
This command displays global statistics for the LIPC LCMP module at the local node.
Probe view
lip lip: Specifies a remote node by its ID in the range of 0 to 32767.
display system internal lipc lgmp group
Use display system internal lipc lgmp group to display information about a multicast group, including member host information and related statistics.
display system internal lipc lgmp group groupID [ lip lip ]
This command displays information about a multicast group at the local node.
Probe view
group groupID: Specifies a multicast group by its ID in the range of 0 to 4294967295.
display system internal lipc lgmp group-list
Use display system internal lipc lgmp group-list to display the number of created multicast groups, the number of multicast member ports, and HASH information.
display system internal lipc lgmp group-list [ lip lip ]
This command displays the number of created multicast groups, the number of multicast member ports, and HASH information at the local node.
Probe view
display system internal lipc lgmp physical-group
Use display system internal lipc lgmp physical-group to display information about a hardware multicast group.
display system internal lipc lgmp physical-group phyID [ lip lip ]
This command displays information about a hardware multicast group at the local node.
Probe view
physical-group phyID: Specifies a hardware multicast group by its ID in the range of 0 to 4294967295.
display system internal lipc lgmp physical-group-list
Use display system internal lipc lgmp physical-group-list to display information about all hardware multicast groups.
display system internal lipc lgmp physical-group-list [ lip lip ]
This command displays information about all hardware multicast groups at the local node.
Probe view
display system internal lipc lgmp statistics
Use display system internal lipc lgmp statistics to display statistics for LIPC LGMP modules.
display system internal lipc lgmp statistics [ lip lip ]
This command displays statistics for the LIPC LGMP module at the local node.
Probe view
display system internal lipc lip statistics
Use display system internal lipc lip statistics to display global statistics for LIPC LIP modules, including the number of sent and received LIP packets and the number of errors.
display system internal lipc lip statistics [ lip lip ]
This command displays global statistics for the LIPC LIP module at the local node.
Probe view
display system internal lipc loop statistics
Use display system internal lipc loop statistics to display statistics for local loops.
display system internal lipc loop statistics [ lip lip ]
This command display statistics for local loops.
Probe view
display system internal lipc mtcp group
Use display system internal lipc mtcp group to display member information, statistics, or state machine history for an LIPC multicast group.
display system internal lipc mtcp group portID { history | member | statistics } [ lip lip ]
This command displays member information, statistics, or state machine history for an LIPC multicast group at the local node.
Probe view
portID: Specifies a port ID in the range of 0 to 4294967295.
history: Specifies state machine history.
member: Specifies member information.
statistics: Specifies statistics information.
display system internal lipc mtcp performance
Use display system internal lipc mtcp performance to display information about LIPC multicast performance.
display system internal lipc mtcp performance [ lip lip ]
This command displays information about LIPC multicast performance at the local node.
Probe view
Before you use this command to display information about LIPC multicast performance, first enable performance statistics for LIPC multicast connections by using the lipc performance command.
display system internal lipc mtcp statistics
Use display system internal lipc mtcp statistics to display information about LIPC multicast connections.
display system internal lipc mtcp statistics [ lip lip ]
This command displays global statistics for LIPC multicast connections at the local node.
Probe view
display system internal lipc pcb statistics
Use display system internal lipc pcb statistics to display global statistics for LIPC PCB modules.
display system internal lipc pcb statistics [ lip lip ]
This command displays global statistics for the LIPC PCB module at the local node.
Probe view
display system internal lipc physical
Use display system internal lipc physical to display global statistics for the driver adaptation layer.
display system internal lipc physical [ lip lip ]
This command displays global statistics for the driver adaptation layer at the local node.
Probe view
Usage guideline
The statistics includes information exchanged between the LIPC module and the driver, including the number of sent and received packets, the number of errors of the driver, and the number of events reported by the driver.
display system internal lipc publish global-cb
Use display system internal lipc publish global-cb to display information about the global control block of LIPC PUBLISH modules.
display system internal lipc publish global-cb [ lip lip ]
This command displays information about the global control block of the LIPC PUBLISH module at the local node.
Probe view
This command is used for examine whether the PUBLISH module at a node encounters an out-of-order problem.
display system internal lipc publish statistics
Use display system internal lipc publish statistics to display statistics for LIPC PUBLISH modules.
display system internal lipc publish statistics [ lip lip ]
This command displays statistics for the LIPC PUBLISH module at the local node.
Probe view
display system internal lipc stcp event
Use display system internal lipc stcp event to display information about LIPC unicast events.
display system internal lipc stcp event { sync | trans } [ lip lip ]
This command displays information about LIPC unicast events for the local node.
Probe view
sync: Specifies LIPC unicast control packet events.
trans: Specifies LIPC unicast data packet events.
This command displays information about LIPC unicast events, including connection, DACK, destruction, and time sequence exchange. H3C recommends that you use this command for troubleshooting when you find any problem with LIPC unicast. Use this command before the system resources are used up. When the system resources are used up, old information is replaced by new information.
display system internal lipc stcp global-server
Use display system internal lipc stcp global-server to display information about the global well-known ports for LIPC unicast.
display system internal lipc stcp global-server [ lip lip ]
This command displays information about the global well-known ports for LIPC unicast at the local node.
Probe view
display system internal lipc stcp links
Use display system internal lipc stcp links to display information about LIPC unicast connections, including received and transmitted packet information, state information, and buffer information.
display system internal lipc stcp links { all | detail port | global gport | listening | local lport | singledetail lport rport } [ lip lip ]
This command displays information about LIPC unicast connections at the local node.
Probe view
all: Specifies all unicast connections at the local node.
detail port: Specifies a port by its number in the range of 0 to 65535.
global gport: Specifies a global well-known port by its number in the range of 100 to 8100.
listening: Specifies the connections in listening state at the local node.
local lport: Specifies a local port by its number in the range of 10100 to 65535.
singledetail lport rport: Specifies a local port number and a remote port number. The value range for the port numbers is 0 to 65535.
display system internal lipc stcp performance
Use display system internal lipc stcp performance to display information about LIPC unicast performance.
display system internal lipc stcp performance [ lip lip ]
This command displays information about LIPC unicast performance for the local node.
Probe view
To display information about LIPC unicast performance, you must have enabled performance statistics for LIPC unicast or multicast by using the lipc performance command.
lipc performance
display system internal lipc stcp statistics
Use display system internal lipc stcp statistics to display global statistics for LIPC unicast connections, which can be used for analyzing LIPC unicast operations.
display system internal lipc stcp statistics [ lip lip ]
This command displays statistics for LIPC unicast at the local node.
Probe view
display system internal lipc stcp status
Use display system internal lipc stcp status to display unicast transmission state information, including sequence number, ACK sequence number, send flag, and receive flag of the unicast packets.
display system internal lipc stcp status { recv | send } [ lip lip ]
Probe view
recv: Specifies the receiving end.
send: Specifies the sending end.
This command is used for analyzing transmission reliability of unicast packets.
display system internal lipc stream
Use display system internal lipc stream to display information about LIPC unicast streams.
display system internal lipc stream { ack | reass | send } port portID [ lip lip ]
This command displays information about LIPC unicast streams at the local node.
Probe view
ack: Specifies the received ACK messages on the specified port.
reass: Specifies the reassembled streams on the specified port.
send: Specifies the sent streams on the specified port.
port portID: Specifies a port by its port number in the range of 0 to 65535.
display system internal lipc sudp pcb-info
Use display system internal lipc sudp pcb-info to display the detailed PCB information of SUDP modules.
display system internal lipc sudp pcb-info { all-port | global-port | local-port | specific-port portID } [ lip lip ]
This command displays the detailed PCB information of the SUDP module at the local node.
Probe view
all-port: Specifies all ports.
global-port: Specifies all global well-known ports.
local-port: Specifies the local well-known ports.
specific-port portID: Specifies a port number in the range of 0 to 65535.
display system internal lipc sudp statistics
Use display system internal lipc sudp statistics to display global statistics for LIPC SUDP modules.
display system internal lipc sudp statistics [ lip lip ]
This command displays global statistics for the LIPC SUDP module at the local node.
Probe view
display system internal lipc sudp { global-port | local-port }
Use display system internal lipc sudp to display information about all SUDP global well-known ports or local ports.
display system internal lipc sudp { global-port | local-port } [ lip lip ]
This command display information about all SUDP global well-known ports or local ports at the local node.
Probe view
display system internal lipc topology history
Use display system internal lipc topology history to display the change history of topology links.
display system internal lipc topology history [ lip lip ]
This command displays the change history of topology links at the local node.
Probe view
display system internal lipc topology link
Use display system internal lipc topology link to display information about LIPC topology links.
display system internal lipc topology link [ lip lip ]
This command displays information about LIPC topology links at the local node.
Probe view
display system internal lipc topology node
Use display system internal lipc topology node to display statistics for topology nodes.
display system internal lipc topology node nodeID [ lip lip ]
This command displays statistics for topology nodes related to the local node.
Probe view
node nodeID: Specifies a node by its ID in the range of 0 to 32767.
The statistics includes the number events that occurred on the local node, and the latest six time records (with a precision to 0.1 milliseconds) of each event.
display system internal lipc topology process-time
Use display system internal lipc topology process-time to display the time spent in notifying each module when topology events occur.
display system internal lipc topology process-time [ lip lip ]
This command displays the time spent in notifying each module when topology events occur at the local node.
Probe view
display system internal lipc topology statistics
Use display system internal lipc topology statistics to display global statistics about topology, including the number global events, and the latest six time records (with a precision to 0.1 milliseconds) of each event.
display system internal lipc topology statistics [ lip lip ]
This command displays global statistics about topology at the local node.
Probe view
display system internal lipc topology status
Use display system internal lipc topology status to display topology status.
display system internal lipc topology status [ lip lip ]
This command displays topology status at the local node.
Probe view
display system internal mac-address configuration
Use display system internal mac-address configuration to display MAC address table configuration information.
In standalone mode:
display system internal mac-address configuration { blackhole | multiport | multicast | static } [ count ] slot slot-number
In IRF mode:
display system internal mac-address configuration { blackhole | multiport | multicast | static } [ count ] chassis chassis-number slot slot-number
Probe view
blackhole: Displays blackhole MAC address entries.
multiport: Displays multiport unicast MAC address entries.
multicast: Displays multicast MAC address entries.
static: Displays static MAC address entries.
count: Displays the total number of MAC address entries that match all entry attributes you specify in the command. If no entry attribute is specified, the command displays the total number of entries in the MAC address table. If this keyword is not specified, the command displays detailed information about specified MAC address entries.
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
display system internal mac-address statistics
Use display system internal mac-address statistics to display MAC address table statistics.
In standalone mode:
display system internal mac-address statistics slot slot-number
In IRF mode:
display system internal mac-address statistics chassis chassis-number slot slot-number
Probe view
display system internal mbuf relay statistics
Use display system internal mbuf relay statistics to display MBUF Relay statistics.
In standalone mode:
display system internal mbuf relay statistics slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
In IRF mode:
display system internal mbuf relay statistics chassis chassis-number slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
Probe view
slot slot-number: Displays MBUF Relay statistics on a card. The slot-number argument represents the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays MBUF Relay statistics of a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that holds the card. (In IRF mode.)
cpu cpu-id: Specifies the CPU that MBUF Relay uses. If no CPU is specified, the command displays MBUF Relay statistics for all CPUs.
rcv received-id: Specifies the MBUF Relay receiver by its ID. If no MBUF Relay receiver is specified, the command displays MBUF Relay statistics for all the receivers on the CPU.
display system internal mbuf statistics
Use display system internal mbuf to display MBUF statistics.
In standalone mode:
display system internal mbuf statistics slot slot-number
In IRF mode:
display system internal mbuf statistics chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays MBUF statistics on a card. The slot-number argument represents the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays MBUF statistics of a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that holds the card. (In IRF mode.)
display system internal mpls lfib ilm
Use display system internal mpls lfib ilm to display detailed MPLS ILM information.
In standalone mode:
display system internal mpls lfib ilm label slot slot-number
In IRF mode:
display system internal mpls lfib ilm label chassis chassis-number slot slot-number
Probe view
label: Specifies an incoming label in the range of 16 to 1048575.
display system internal mpls lfib nhlfe
Use display system internal mpls lfib nhlfe to display detailed MPLS NHLFE information.
In standalone mode:
display system internal mpls lfib nhlfe nid slot slot-number
In IRF mode:
display system internal mpls lfib nhlfe nid chassis chassis-number slot slot-number
Probe view
nid: Specifies an NHLFE entry index in the range of 0 to 4294967294.
display system internal mpls lfib nhlfe reflist
Use display system internal mpls lfib nhlfe reflist to display MPLS NHLFE reverse mapping information.
In standalone mode:
display system internal mpls lfib nhlfe nid reflist slot slot-number
In IRF mode:
display system internal mpls lfib nhlfe nid reflist chassis chassis-number slot slot-number
Probe view
display system internal mpls lfib record
Use display system internal mpls lfib record to display information recorded by the MPLS LFIB module, including information received by MPLS LFIB, information LFIB set to the driver, and information returned from the driver.
In standalone mode:
display system internal mpls lfib record [ start start-number ] slot slot-number
In IRF mode:
display system internal mpls lfib record [ start start-number ] chassis chassis-number slot slot-number
Probe view
start start-number: Specifies the number of a record, in the range of 0 to 4096. This command displays the specified record and all records that follow. If you do not specify this keyword, this command displays all records.
reset system internal mpls lfib record
display system internal mpls lfib statistics
Use display system internal mpls lfib statistics to display MPLS LFIB statistics.
In standalone mode:
display system internal mpls lfib statistics slot slot-number
In IRF mode:
display system internal mpls lfib statistics chassis chassis-number slot slot-number
Probe view
display system internal mpls lsp-pending
Use display system internal mpls lsp-pending to display information about LSPs not deployed to the forwarding plane during the GR process of LDP, BGP, or RSVP.
Probe view
display system internal mpls statistics
Use display system internal mpls statistics to display internal statistics for MPLS.
Probe view
display system internal mrib interface statistics
Use display system internal mrib interface statistics to display statistics for the interfaces that are maintained by the MRIB. The MRIB maintained interfaces include register interfaces, InLoopBack0 interfaces, null0 interfaces, and the interfaces that are configured with multicast protocols.
display system internal mrib [ vpn-instance vpn-instance-name ] interface statistics
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays statistics for the interfaces that are maintained by the MRIB on the public network.
display system internal mrib mbr
Use display system internal mrib mbr to display join/prune information maintained by the MBR in the MRIB process.
display system internal mrib [ vpn-instance vpn-instance-name ] mbr interface interface-type interface-number [ source source-address group group-address ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays join/prune information maintained by the MBR in the MRIB process on the public network.
source source-address: Specifies a multicast source address. If this option is not specified, this command does not display MBR entries.
group group-address: Specifies a multicast group address in the range of 224.0.0.0 to 239.255.255.255. If this option is not specified, this command does not display MBR entries.
display system internal multicast capability
Use display system internal multicast capability to display multicast capability.
In standalone mode:
display system internal multicast capability [ slot slot-number ]
In IRF mode:
display system internal multicast capability [ chassis chassis-number slot slot-number ]
Probe view
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays multicast capability for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays multicast capability for all MPUs in the IRF fabric. (In IRF mode.)
display system internal multicast forwarding vlan reference
Use display system internal multicast forwarding vlan reference to display mappings between outgoing VLAN interfaces and Layer 2 multicast entries.
In standalone mode:
display system internal multicast forwarding vlan reference [ group group-address | source source-address ] * [ vlan vlan-id ] [ slot slot-number ]
In IRF mode:
display system internal multicast forwarding vlan reference [ group group-address | source source-address ] * [ vlan vlan-id ] [ chassis chassis-number slot slot-number ]
Probe view
group group-address: Specifies a multicast group address. If this option is not specified, this command displays mappings between outgoing VLAN interfaces and Layer 2 multicast entries for all multicast groups.
source source-address: Specifies a multicast source address. If this option is not specified, this command displays mappings between outgoing VLAN interfaces and Layer 2 multicast entries for all multicast sources.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command displays mappings between outgoing VLAN interfaces and all multicast groups for all VLANs.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays mappings between outgoing VLAN interfaces and Layer 2 multicast entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays mappings between outgoing VLAN interfaces and Layer 2 multicast entries for all MPUs in the IRF fabric. (In IRF mode.)
display system internal multicast forwarding-table dummy
Use display system internal multicast forwarding-table dummy to display temporary multicast forwarding entries.
In standalone mode:
display system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | statistics | slot slot-number ] *
In IRF mode:
display system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | chassis chassis-number slot slot-number | statistics ] *
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays temporary multicast forwarding entries on the public network.
group-address: Specifies a multicast group address in the range of 224.0.0.0 to 239.255.255.255. If this argument is not specified, this command displays the temporary multicast forwarding entries for all multicast groups.
source-address: Specifies a multicast source address. If this argument is not specified, this command displays the temporary multicast forwarding entries for all multicast sources.
mask-length: Specifies the address mask length. The default value is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
mask: Specifies the address mask. The default value is 255.255.255.255.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays the temporary multicast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays the temporary multicast forwarding entries for all MPUs in the IRF fabric. (In IRF mode.)
statistics: Displays statistics.
display system internal multicast forwarding-table verbose
Use display system internal multicast forwarding-table verbose to display detailed information about the multicast forwarding table.
In standalone mode:
display system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table verbose [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number | slot slot-number ] *
In IRF mode:
display system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table verbose [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | chassis chassis-number slot slot-number | incoming-interface interface-type interface-number | outgoing-interface { exclude | include | match } interface-type interface-number ] *
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays detailed information about the multicast forwarding table on the public network.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays detailed information about the multicast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays detailed information about the multicast forwarding entries for all MPUs in the IRF fabric. (In IRF mode.)
incoming-interface: Specifies the multicast forwarding entries that include the specified incoming interface.
interface-type interface-number: Specifies an incoming interface by its type and number.
outgoing-interface: Specifies the multicast forwarding entries that include the specified outgoing interface.
exclude: Specifies the multicast forwarding entries that do not include the specified interface in the outgoing interface list.
include: Specifies the multicast forwarding entries that include the specified interface in the outgoing interface list.
match: Specifies the multicast forwarding entries that include only the specified interface in the outgoing interface list.
display system internal multicast record
Use display system internal multicast record to display operation records about multicast entries.
In standalone mode:
display system internal multicast record { statistics | { { all | fail } [ { group [ group-address | ipv6-group-address ] | source [ source-address | ipv6-source-address ] } * | item item-list | filter { exclude | include } { { add-l2-ip | add-l2-ip-port | add-l2-ip-slot | add-l2-mac | add-l2-mac-port | add-l2-mac-slot | add-l3-ipm | add-l3-oif | add-l3-port | add-l3-slot | del-l2-ip | del-l2-ip-port | del-l2-ip-slot | del-l2-mac | del-l2-mac-port | del-l2-mac-slot | del-l3-ipm | del-l3-oif | del-l3-port | del-l3-slot | set-l3-iif } * | ipmc-type-all } ] [ verbose ] } } [ slot slot-number ]
In IRF mode:
display system internal multicast record { statistics | { { all | fail } [ { group [ group-address | ipv6-group-address ] | source [ source-address | ipv6-source-address ] } * | item item-list | filter { exclude | include } { { add-l2-ip | add-l2-ip-port | add-l2-ip-slot | add-l2-mac | add-l2-mac-port | add-l2-mac-slot | add-l3-ipm | add-l3-oif | add-l3-port | add-l3-slot | del-l2-ip | del-l2-ip-port | del-l2-ip-slot | del-l2-mac | del-l2-mac-port | del-l2-mac-slot | del-l3-ipm | del-l3-oif | del-l3-port | del-l3-slot | set-l3-iif } * | ipmc-type-all } ] [ verbose ] } } [ chassis chassis-number slot slot-number ]
Probe view
statistics: Displays statistics for operation records.
all: Specifies all operation records.
fail: Specifies failed operation records.
ipv6-group-address: Specifies an IPv6 multicast group address.
ipv6-source-address: Specifies an IPv6 multicast source address.
item item-list: Specifies one or more records. To display one record, set the value of the item-list argument to 1. To display more records, use the form start-item [ to end-item ]. The value ranges for the start-item argument and the end-item argument are 1 to 500000.
filter: Specifies to filter operation records.
exclude: Specifies to display operation records that do not meet the specified criteria.
include: Specifies to display operation records that meet the specified criteria.
add-l2-ip: Specifies the operation to add Layer 2 IP multicast entries.
add-l2-ip-port: Specifies the operation to add ports to Layer 2 IP multicast entries.
add-l2-ip-slot: Specifies the operation to install a card. Card information is then added to Layer 2 IP multicast entries.
add-l2-mac: Specifies the operation to add Layer 2 MAC multicast entries.
add-l2-mac-port: Specifies the operation to add ports to Layer 2 MAC multicast entries.
add-l2-mac-slot: Specifies the operation to install a card. Card information is then added to Layer 2 MAC multicast entries.
add-l3-ipm: Specifies the operation to add Layer 3 multicast entries.
add-l3-oif: Specifies the operation to add outgoing interfaces to Layer 3 multicast entries.
add-l3-port: Specifies the operation to add outgoing ports to Layer 3 multicast entries.
add-l3-slot: Specifies the operation to install a card. The card provides outgoing interfaces for Layer 3 distributed forwarding.
del-l2-ip: Specifies the operation to remove Layer 2 IP multicast entries.
del-l2-ip-port: Specifies the operation to remove ports from Layer 2 IP multicast entries.
del-l2-ip-slot: Specifies the operation to remove a card. Card information is then deleted from Layer 2 IP entries.
del-l2-mac: Specifies the operation to remove Layer 2 MAC multicast entries.
del-l2-mac-port: Specifies the operation to remove ports from Layer 2 MAC multicast entries.
del-l2-mac-slot: Specifies the operation to remove a card. Card information is then deleted from Layer 2 MAC entries.
del-l3-ipm: Specifies the operation to remove Layer 3 IP multicast entries.
del-l3-oif: Specifies the operation to remove outgoing interfaces from Layer 3 multicast entries.
del-l3-port: Specifies the operation to remove outgoing ports from Layer 3 multicast entries.
del-l3-slot: Specifies the operation to remove a card. The card provided outgoing interfaces for Layer 3 distributed forwarding before being removed.
set-l3-iif: Specifies the operation to set incoming interfaces for Layer 3 multicast entries.
ipmc-type-all: Specifies all types of operations.
verbose: Specifies to display detailed information. If the outgoing interface and outgoing port in the record are not complete, you need to specify this keyword.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays operation records about multicast entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays operation records about multicast entries for all MPUs in the IRF fabric. (In IRF mode.)
display system internal multicast-vlan forwarding-table verbose
Use display system internal multicast-vlan forwarding-table verbose to display detailed information about the multicast VLAN forwarding table.
In standalone mode:
display system internal multicast-vlan forwarding-table verbose [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | slot slot-number | subvlan vlan-id | vlan vlan-id ] *
In IRF mode:
display system internal multicast-vlan forwarding-table verbose [ group-address [ mask { mask-length | mask } ] | source-address [ mask { mask-length | mask } ] | chassis chassis-number slot slot-number | subvlan vlan-id | vlan vlan-id ] *
Probe view
Predefined user role
group-address: Specifies a multicast group address in the range of 224.0.0.0 to 239.255.255.255. If this argument is not specified, this commands displays detailed information about the multicast VLAN forwarding entries for all multicast groups.
mask { mask-length | mask }: Specifies the mask length or mask for the multicast group address. The value range for the mask-length argument is 4 to 32 and the default is 32. The default value for the mask argument is 255.255.255.255.
source-address: Specifies a multicast source address. If this argument is not specified, this command displays detailed information about the multicast VLAN forwarding entries for all multicast sources.
mask { mask-length | mask }: Specifies the mask length or mask for the multicast source address. The value range for the mask-length argument is 0 to 32 and the default is 32. The default value for the mask argument is 255.255.255.255.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command displays detailed information about the multicast VLAN forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays detailed information about the multicast VLAN forwarding entries for all MPUs in the IRF fabric. (In IRF mode.)
subvlan vlan-id: Specifies a sub-VLAN. If this option is not specified, this command displays detailed information about the multicast VLAN forwarding entries for all sub-VLANs.
vlan vlan-id: Specifies a VLAN by its ID. The value range for the vlan-id argument is 1 to 4094. If you do not specify any VLAN, this command displays detailed information about the multicast VLAN forwarding entries in all VLANs.
display system internal mvrp interface
Use display system internal mvrp interface to display MVRP operation information of an interface in a VLAN.
display system internal mvrp interface interface-type interface-number vlan vlan-id
Probe view
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
display system internal mvrp map-count
Use display system internal mvrp map-count to display the propagation count of a VLAN.
display system internal mvrp map-count vlan vlan-id
Probe view
This command displays the total number of interfaces in STP forwarding state that have registered the specified VLAN through MVRP.
display system internal nd dad
Use display system internal nd dad to display DAD link information.
In standalone mode:
display system internal nd dad slot slot-number
In IRF mode:
display system internal nd dad chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays DAD link information for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays DAD link information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal nd entry
Use display system internal nd entry to display ND entries.
In standalone mode:
display system internal nd entry slot slot-number
In IRF mode:
display system internal nd entry chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays ND entries for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ND entries for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal nd ifcb
Use display system internal nd ifcb to display ND control block information for an interface.
In standalone mode:
display system internal nd ifcb interface interface-type interface-number slot slot-number
In IRF mode:
display system internal nd ifcb interface interface-type interface-number chassis chassis-number slot slot-number
Probe view
interface interface-type interface-number: Displays ND control block information for the specified interface.
slot slot-number: Displays ND control block information for a specific interface on the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ND control block information for a specific interface on the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal nd machash
Use display system internal nd machash to display ND machash entries.
In standalone mode:
display system internal nd machash vlan vlan-id ipv6-address slot slot-number
In IRF mode:
display system internal nd machash vlan vlan-id ipv6-address chassis chassis-number slot slot-number
Probe view
vlan vlan-id: Displays ND machash entries for the specified VLAN.
ip-address: Displays ND machash entries for the specified IP address.
slot slot-number: Displays machash entries for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ND machash entries for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal nd probe
Use display system internal nd probe to display ND probe link information.
In standalone mode:
display system internal nd probe slot slot-number
In IRF mode:
display system internal nd probe chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays ND probe link information for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ND probe link information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal nd reload
Use display system internal nd reload to display ND reload link information.
In standalone mode:
display system internal nd reload slot slot-number
In IRF mode:
display system internal nd reload chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays ND reload link information for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ND reload link information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal nd static
Use display system internal nd static to display static ND entries.
display system internal nd static ipv6-address interface interface-type interface-number
Probe view
ipv6-address: Displays static ND entries for a specified IPv6 address.
interface interface-type interface-number: Displays static ND entries for the specified interface.
display system internal nd statistics
Use display system internal nd statistics to display ND statistics.
In standalone mode:
display system internal nd statistics slot slot-number
In IRF mode:
display system internal nd statistics chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays ND statistics for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays ND statistics for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
display system internal ospf event-log
Use display system internal ospf event-log to display OSPF logs.
display system internal ospf event-log { gr | ha | interface | nib | notify | upgrade }
Probe view
gr: Displays GR logs.
ha: Displays HA event processing logs.
interface: Displays interface event logs.
nib: Displays NIB logs.
notify: Displays interface notification logs.
upgrade: Displays smooth upgrade logs.
display system internal ospf interface
Use display system internal ospf interface to display OSPF interface information.
display system internal ospf interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Without this option, the command displays interface information for the public network.
ip-address: Specifies an IP address in dotted decimal notation.
mask: Specifies the IP address mask in dotted decimal notation.
mask-length: Specifies the mask length, an integer in the range of 0 to 32.
display system internal ospf lsdb
Use display system internal ospf lsdb to display OSPF LSA information in the LSDB.
display system internal ospf [ process-id ] lsdb { asbr | ase | nssa | summary }
Probe view
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. Without this argument, the command displays LSA information for all OSPF processes.
asbr: Displays Type-4 LSA (ASBR Summary LSA) information in the LSDB.
ase: Displays Type-5 LSA (AS External LSA) information in the LSDB.
nssa: Displays Type-7 LSA (NSSA External LSA) information in the LSDB.
summary: Displays Type-3 LSA (Network Summary LSA) information in the LSDB.
display system internal ospf nib
Use display system internal ospf nib to display OSPF next hop information.
display system internal ospf nib [ nib-id ] [ verbose ]
Probe view
nib-id: Specifies a next hop by its ID in the range of 1 to FFFFFFFF.
verbose: Displays detailed OSPF next hop information.
display system internal ospf prefix
Use display system internal ospf prefix to display OSPF prefix information.
display system internal ospf [ process-id ] prefix [ ip-address { mask | mask-length } ]
Probe view
process-id: Specifies an OSPF process by its ID in the range of 1 to 65535. Without this argument, the command displays prefix information for all OSPF processes.
ip-address: Specifies the destination IP address. Without this argument, the command displays all prefix information.
display system internal ospf status
Use display system internal ospf status to display OSPF status, including memory threshold status, and information about each module.
Probe view
display system internal ospfv3 event-log
Use display system internal ospfv3 event-log to display OSPFv3 log information.
display system internal ospfv3 event-log { gr | nib | rib }
Probe view
gr: Displays GR log information.
nib: Displays NIB log information.
rib: Displays RIB log information.
display system internal ospfv3 interface
Use display system internal ospfv3 interface to display OSPFv3 interface information.
display system internal ospfv3 interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe view
ipv6-address: Specifies an IPv6 address prefix.
prefix-length: Specifies the prefix length, an integer in the range of 0 to 128.
display system internal ospfv3 lsdb
Use display system internal ospfv3 lsdb to display OSPFv3 LSA information in the LSDB.
display system internal ospfv3 [ process-id ] lsdb { inter-prefix | inter-router | intra-prefix { reference type-1 | reference type-2 } | router }
Probe view
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. Without this argument, the command displays LSA information for all OSPFv3 processes.
inter-prefix: Displays Inter-Area-Prefix LSA information in the LSDB.
inter-router: Displays Inter-Area-Router LSA information in the LSDB.
intra-prefix: Displays Intra-Area-Prefix LSA information in the LSDB.
reference type-1: Displays information about Intra-Area-Prefix LSAs that reference Router LSAs.
reference type-2: Displays information about Intra-Area-Prefix LSAs that reference Network LSAs.
router: Displays Router LSA information in the LSDB.
display system internal ospfv3 nib
Use display system internal ospfv3 nib to display OSPFv3 next hop information.
display system internal ospfv3 nib [ nib-id ] [ verbose ]
Probe view
verbose: Displays detailed OSPFv3 next hop information.
display system internal ospfv3 prefix
Use display system internal ospfv3 prefix to display OSPFv3 prefix information.
display system internal ospfv3 [ process-id ] prefix { inter | intra } [ ipv6-address prefix-length ]
Probe view
process-id: Specifies an OSPFv3 process by its ID in the range of 1 to 65535. Without this argument, the command displays prefix information for all OSPFv3 processes.
inter: Displays inter-AS prefix information.
intra: Displays intra-AS prefix information.
ipv6-address prefix-length: Specifies an IPv6 address. The ipv6-address argument specifies an IPv6 prefix. The prefix-length argument specifies a prefix length in the range of 0 to 128. Without this argument, the command displays all OSPFv3 prefix information.
display system internal ospfv3 status
Use display system internal ospfv3 status to display OSPFv3 status, including memory threshold status, and information about each module.
Probe view
display system internal pbr fib
Use display system internal pbr fib to display next hop information in user mode.
In standalone mode:
display system internal pbr fib [ vpn-instance vpn-instance-name ] slot slot-number
In IRF mode:
display system internal pbr fib [ vpn-instance vpn-instance-name ] chassis chassis-number slot slot-number
The system does not display next hop information in user mode.
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. The specified VPN must already exist. If no VPN is specified, the command displays information about next hops belonging to the public network.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal pbr kernel policy
Use display system internal pbr kernel policy to display PBR policy information in kernel mode.
In standalone mode:
display system internal pbr kernel policy [ policy-name [ setup ] ] slot slot-number
In IRF mode:
display system internal pbr kernel policy [ policy-name [ setup ] ] chassis chassis-number slot slot-number
The system does not display PBR policy information in kernel mode.
Probe view
policy policy-name: Specifies a policy by its name, a case-sensitive string of 1 to 19 characters.
setup: Displays information about the specified PBR policy applied to an interface.
display system internal pbr policy
Use display system internal pbr policy to display PBR policy information in user mode.
In standalone mode:
display system internal pbr policy [ policy-name [ setup ] ] slot slot-number
In IRF mode:
display system internal pbr policy [ policy-name [ setup ] ] chassis chassis-number slot slot-number
The system does not display PBR policy information in user mode.
Probe view
display system internal pim interface
Use display system internal pim interface to display interface information maintained by LIB in the PIM process.
display system internal pim [ vpn-instance vpn-instance-name ] interface [ interface-type interface-number | ip-address { mask-length | mask } ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays interface information maintained by LIB in the PIM process on the public network.
interface-type interface-number: Specifies an interface by its type and number. If this argument is not specified, this command displays information about all interfaces.
ip-address: Specifies an IP address except 0.0.0.0. If this argument is not specified, this command displays the interface information for all IP addresses.
mask-length: Specifies the mask length in the range of 0 to 32.
mask: Specifies the mask.
display system internal pim rp
Use display system internal pim rp to display PIM RP statistics.
display system internal pim [ vpn-instance vpn-instance-name ] rp
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command displays PIM RP statistics on the public network.
display system internal pim thread
Use display system internal pim thread to display statistics for the PIM threads.
display system internal pim thread { event | main | route }
Probe view
event: Specifies the PIM event thread.
main: Specifies the PIM main thread.
route: Specifies the PIM routing thread.
display system internal rawip
Use display system internal rawip to display brief information about RawIP connections.
In standalone mode:
display system internal rawip slot slot-number
In IRF mode:
display system internal rawip chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays brief RawIP connection information for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief RawIP connection information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal rib event attribute
Use display system internal rib event attribute to display IPv4 RIB attribute events.
Probe view
display system internal rib event policy
Use display system internal rib event policy to display IPv4 RIB policy events.
Probe view
display system internal rib event prefix
Use display system internal rib event prefix to display IPv4 RIB prefix events.
Probe view
display system internal rib event protocol
Use display system internal rib event protocol to display IPv4 RIB protocol events.
display system internal rib event protocol [ vpn-instance vpn-instance-name ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Without this option, the command displays the information for the public network.
display system internal rib event statistics
Use display system internal rib event statistics to display RIB event statistics.
display system internal rib event statistics [ vpn-instance vpn-instance-name ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Without this option, the command displays the statistics for the public network.
display system internal rib log
Use display system internal rib log to display RIB logs.
display system internal rib log [ reverse ]
display system internal rib event log
Probe view
rib: Displays RIB logs.
event: Displays logs about RIB rouging changes.
reverse: Displays logs in reverse chronological order.
display system internal rib memory
Use display system internal rib memory to display RIB memory information.
Probe view
display system internal rib nib log
Use display system internal rib nib log to display next hop logs.
display system internal rib nib log [ reverse ]
Probe view
nib: Displays next hop logs.
display system internal rib prefix
Use display system internal rib prefix to display RIB prefix information.
display system internal rib prefix ip-address mask-length [ vpn-instance vpn-instance-name ]
Probe view
mask-length: Specifies the mask length of the IP address, in the range of 0 to 32.
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Without this option, the command displays RIB prefix information for the public network.
display system internal rib summary
Use display system internal rib summary to display RIB statistics.
Probe view
display system internal rip interface
Use display system internal rip interface to display interface information.
display system internal rip interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If no VPN is specified, the command displays information about the public network.
ip-address: Specifies an IP address, in dotted decimal notation.
mask: Specifies the subnet mask of the IP address, in dotted decimal notation.
display system internal rip nib
Use display system internal rip nib to display next hop information of RIP routes.
display system internal rip nib [ nib-id ] [ verbose ]
Probe view
nib-id: Specifies a next hop by its ID in the range of 1 to FFFFFFFF. If no next hop is specified, the command displays information about all next hops.
verbose: Displays the detailed next hop information.
display system internal rip nib log
Use display system internal rip nib log to display logs of next hops for RIP routes.
Probe view
display system internal rip status
Use display system internal rip status to display global RIP status information.
Probe view
display system internal ripng interface
Use display system internal ripng interface to display interface information.
display system internal ripng interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ipv6-address prefix-length ]
Probe view
ipv6-address: Specifies an IPv6 address.
mask-length: Specifies the prefix length in the range of 0 to 128.
display system internal ripng nib
Use display system internal ripng nib to display next hop information of RIPng routes.
display system internal ripng nib [ nib-id ] [ verbose ]
Probe view
display system internal ripng nib log
Use display system internal ripng nib log to display logs of next hops for RIPng routes.
Probe view
display system internal ripng status
Use display system internal ripng status to display global RIPng status information.
Probe view
display system internal route-direct interface
Use display system internal route-direct interface to display interface information.
display system internal route-direct interface [ vpn-instance vpn-instance-name ] [ interface-type interface-number | ip-address { mask | mask-length } ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. Without this option, the command displays the interface information for the public network.
display system internal route-direct log
Use display system internal route-direct log to display direct route logs.
display system internal route-direct { event | notify | nib } log [ reverse ]
Probe view
event: Displays interface event logs.
notify: Displays interface event notification logs.
nib: Displays logs for direct routes next hops.
display system internal route-static nib log
Use display system internal route-static nib log to display static route NIB logs.
display system internal route-static nib log [ reverse ]
Probe view
display system internal sflow statistics
Use display system internal sflow statistics to display the sFlow statistics.
In standalone mode:
display system internal sflow statistics [ slot slot-number ]
In IRF mode:
display system internal sflow statistics [ chassis chassis-number slot slot-number ]
probe view
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the IRF member ID of the device that holds the card. The slot-number argument represents the slot number of the card. (In IRF mode.)
display system internal startup cache
Use display system internal startup cache to display the file path of the .mdb binary configuration file used at the current startup.
Probe view
When you use the save command (without specifying the file-url option) to save the running configuration, the device automatically saves the running configuration to both an .mdb binary file and a .cfg text file. The two files use the same file name.
At startup, the device uses the following workflow to identify and load a configuration file:
1. The device searches for a valid .cfg next-startup configuration file.
2. If one is found, the device searches for an .mdb file that has the same name and content as the .cfg file.
3. If an .mdb file has the same name and content as the .cfg file, the device starts up with the .mdb file. If this file does not exist, the device starts up with the .cfg file.
The device loads an .mdb file faster than it loads a .cfg file.
This command displays None if the loaded configuration file is a .cfg file.
display system internal stp bridge-info
Use display system internal stp bridge-info to display bridge configuration for an instance.
In standalone mode:
display system internal stp bridge-info instance instance-id slot slot-number
In IRF mode:
display system internal stp bridge-info instance instance-id chassis chassis-number slot slot-number
Probe view
instance instance-id: Specifies an MSTI ID in the range of 0 to 4094, where 0 represents the common root bridge (CIST).
slot slot-number: Specifies a card by its slot number. The slot-number argument represents the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the slot number of the card. (In IRF mode.)
display system internal stp port-info
Use display system internal stp port-info to display the configuration and running status of an interface in the specified instance.
display system internal stp port-info instance instance-id interface interface-type interface-number
Probe view
instance instance-id: Specifies an MSTI ID in the range of 0 to 4094, where 0 represents the CIST.
interface interface-type interface-number: Specifies an interface. The interface-type argument represents the interface type. The interface-number argument represents the interface number.
display system internal tcp
Use display system internal tcp to display brief information about TCP connections.
In standalone mode:
display system internal tcp slot slot-number
In IRF mode:
display system internal tcp chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays brief TCP connection information for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief TCP connection information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal tunnel data
Use display system internal tunnel data to display kernel data for a tunnel interface.
In standalone mode:
display system internal tunnel data interface tunnel number [ slot slot-number ]
In IRF mode:
display system internal tunnel data interface tunnel number [ chassis chassis-number slot slot-number ]
Probe view
interface tunnel number: Specifies a tunnel interface by interface number. The specified tunnel interface must already exist.
slot slot-number: Specifies a card. The slot-number argument represents the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card of an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that holds the card. (In IRF mode.)
display system internal udp
Use display system internal udp to display brief information about UDP connections.
In standalone mode:
display system internal udp slot slot-number
In IRF mode:
display system internal udp chassis chassis-number slot slot-number
Probe view
slot slot-number: Displays brief UDP connection information for the specified card. The slot-number argument specifies the slot number of the card. (In standalone mode.)
chassis chassis-number slot slot-number: Displays brief UDP connection information for the specified card on the specified IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
display system internal vlan
Use display system internal vlan to display the internal information of the VLAN module.
In standalone mode:
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary } slot slot-number
In IRF mode:
display system internal vlan { instance vlan-id | interface interface-type interface-number | summary } chassis chassis-number slot slot-number
Probe view
instance vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
interface interface-type interface-number: Specifies an interface specified by its type and number.
summary: Displays summary information about the VLAN module.
slot slot-number: Specifies a card. The slot-number argument represents the number of the slot that houses the card. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card of an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the number of the slot that houses the card. (In IRF mode.)
display system internal zone acl
Use display system internal zone acl to display information about issued zone ACLs in a VSAN.
In standalone mode:
display system internal zone acl vsan vsan-id [ slot slot-number ]
In IRF mode:
display system internal zone acl vsan vsan-id [ chassis chassis-number slot slot-number ]
Probe view
vsan vsan-id: Specifies a VSAN by its ID.
slot slot-number: Displays information about issued zone ACLs in a VSAN on a card specified by its slot number. If no card is specified, the command displays information about issued zone ACLs in a VSAN on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Displays information about issued zone ACLs in a VSAN on a card on an IRF member device. The chassis-number argument represents the IRF member ID. The slot-number argument represents the slot number of the card. If no card is specified, the command displays information about issued zone ACLs in a VSAN on the global active MPU. (In IRF mode.)
F
follow
Use follow to display the stack information for a process or a thread.
In standalone mode:
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ] [ slot slot-number ]
In IRF mode:
follow { job job-id | process pid } [ thread thread-id ] [ delay seconds ] [ iteration count ] [ chassis chassis-number slot slot-number ]
Probe view
job job-id: Specifies a job by its ID in the range of 1 to 2147483647. A job ID uniquely identifies a process, and it does not change after the process restarts.
process pid: Specifies a process by its ID in the range of 1 to 2147483647. The process ID might change after the process restarts.
thread thread-id: Specifies a thread by its ID in the range of 1 to 2147483647. If you do not specify this option, all threads for the specified process are specified.
delay seconds: Specifies the interval between follow operations in seconds, in the range of 0 to 255. The default value is 5.
iteration count: Specifies the number of follow operations, in the range of 0 to 255. The default value is 5.
slot slot-number: Specifies a card by its slot number. If you do not specify this option, the active MPU is specified. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. If you do not specify this option, the global active MPU is specified. (In IRF mode.)
For a user process, this command displays the following information:
· The user stack information (starting from the user stack prompt).
· The kernel stack information (starting from the kernel stack prompt).
For a kernel process, this command displays only the kernel stack information.
I
irf link-status auto-recovery enable
Use irf link-status auto-recovery enable to enable IRF link-down auto recovery.
Use undo irf link-status auto-recovery enable to disable IRF link-down auto recovery.
IRF link-down auto recovery is enabled.
IRF link-down auto recovery does not take effect when IRF link status detection is disabled.
This command is available in IRF mode. When you change the operating mode from IRF to standalone, the command configuration is lost, regardless of whether you have saved the configuration.
You can enable this function on an IRF fabric with failed links (links that can be recovered by this function) to test whether this function is operating correctly.
irf link-status detect enable
Use irf link-status detect enable to enable IRF link status detection.
Use undo irf link-status detect enable to disable IRF link status detection.
The IRF link status detection is enabled.
For detecting IRF link-down events in time, make sure you have enabled IRF link status detection. When this function is enabled, the system automatically examines the status of each IRF physical link to detect IRF link-down events.
When the IRF link status detection function is enabled on an IRF fabric, you can remove an IRF physical link on the IRF fabric to test whether this function is operating correctly.
L
l2vpn l2vfib record size
Use l2vpn l2vfib record size to set the maximum number of entries that the L2VPN L2VFIB module records.
In standalone mode:
l2vpn l2vfib record size size slot slot-number
In IRF mode:
l2vpn l2vfib record size size chassis chassis-number slot slot-number
The L2VPN L2VFIB module can record a maximum of 4096 entries.
Probe view
size: Specifies the maximum number of entries, in the range of 0 to 10000.
lipc dump-port
Use lipc dump-port to enable dumping for a unicast port.
lipc dump-port port &<1-5> [ lip lip ]
undo lipc dump-port [ lip lip ]
Dumping is disabled on unicast ports.
Probe view
dump-port port &<1-5>: Specifies one or multiple unicast ports, where the value range for the port argument is 1 to 65535 and &<1-5> means that you can specify up to five ports.
lip lip: Specifies a remote node by its ID in the range of 0 to 32767.
After you enable dumping on a unicast port, the system records information about all received and transmitted packets through the port in the file /proc/lipc/dumpinfo.
lipc performance
Use lipc performance to configure performance statistics for LIPC unicast or multicast connections.
lipc performance { mtcp | stcp } { clear | off | on } [ lip lip ]
Performance statistics is disabled.
Probe view
mtcp: Specifies the LIPC MTCP module.
stcp: Specifies the LIPC STCP module.
clear: Clears performance statistics.
off: Disables performance statistics.
on: Enables performance statistics.
lipc ping
Use lipc ping to ping a node to examine whether the LIPC connection with the specified node is operating correctly.
lipc ping lip [ length len times num ]
The device sends a ping packet with 100 bytes up to 10 times if it does not receive any reply.
Probe view
lip: Specifies a node ID in the range of 0 to 32767.
length len: Specifies the length of the ping packet, in the range of 0 to 32767.
times num: Specifies the number of times for retransmitting the ping packet, in the range of 0 to 32767.
You can use the display system internal lipc topology link command to view the valid node IDs in the system. When you specify the node ID in this command, make sure the ID is valid.
lipc timeout
Use lipc timeout to set the timeout time for LIPC topology links.
lipc timeout time [ lip lip ]
The setting is 60 seconds.
Probe view
timeout time: Specifies a timeout time in the range of 3 to 65535.
If the topology module of the local node does not receive the heartbeat packets from a node in up state when the timeout time expires, it tears down all unicast and multicast connections with the node.
The timeout time needs to be modified only when you use the KDB or KGDB to debug the kernel. H3C recommends that you set a larger timeout time to avoid the other nodes from tearing down the connections with the node whose kernel is being debugged.
list
Use list to view subdirectory or file information in the /proc/, /sys/, or /var/ directory.
In standalone mode:
list file-path [ slot slot-number ]
In IRF mode:
list file-path [ chassis chassis-number slot slot-number ]
Probe view
file-path: Specifies a subdirectory path or file path, which is case sensitive.
slot slot-number: Displays the subdirectory or file information on a card specified by its slot number. If no card is specified, the command displays the subdirectory or file information on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the subdirectory or file information on a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the slot number of the card. If no card is specified, the command displays the subdirectory or file information on the global active MPU. (In IRF mode.)
The file or subdirectory path specified cannot contain file links.
M
memory boundary-check enable
Use memory boundary-check enable to enable memory boundary check.
Use undo memory boundary-check enable to restore the default.
In standalone mode:
memory boundary-check enable job job-id [ slot slot-number ]
undo memory boundary-check enable job job-id [ slot slot-number ]
In IRF mode:
memory boundary-check enable job job-id [ chassis chassis-number slot slot-number ]
undo memory boundary-check enable job job-id [ chassis chassis-number slot slot-number ]
Memory boundary check is disabled.
Probe view
This command enables the system to perform memory boundary check before each memory deallocation to ensure the correct memory allocation and deallocation.
If a memory overwrite occurs, the system stores the memory overwrite information in a memory file. The system stores all memory overwrite information in the same memory file.
memory boundary-check scan
Use memory boundary-check scan to trigger a memory boundary check and display the check result.
In standalone mode:
memory boundary-check scan job job-id [ slot slot-number ]
In IRF mode:
memory boundary-check scan job job-id [ chassis chassis-number slot slot-number ]
Probe view
job job-id: Specifies a job by its job ID in the range of 1 to 2147483647. A job ID uniquely identifies a process, and it does not change after the process restarts.
This command takes effect only when memory boundary check has been enabled.
If a memory overwrite is detected, the system displays 128-byte memory contents starting from the 16th byte preceding the detected memory address.
When more than one memory overwrite is detected, the system only records and displays 128-byte memory contents with the lowest memory address detected.
mpls lfib record size
Use mpls lfib record size to set the maximum number of entries that the MPLS LFIB module records.
In standalone mode:
mpls lfib record size size slot slot-number
In IRF mode:
mpls lfib record size size chassis chassis-number slot slot-number
The MPLS LFIB module can record a maximum of 4096 entries.
Probe view
size: Specifies the maximum number of entries, in the range of 0 to 4096.
multicast record
Use multicast record to set the maximum number of operation records for multicast entries.
Use undo multicast record to restore the default.
multicast record [ fail ] limit limit-value
undo multicast record [ fail ] limit
The maximum number is 0. The device does not keep operation records for multicast entries.
Probe view
fail: Specifies to record failed operations on multicast entries.
limit-value: Specifies the maximum number of operation records for multicast entries, in the range of 0 to 500000.
P
probe
Use probe to enter probe view.
probe
In probe view, you can use commands to view system status and information and diagnose system faults.
R
reset hardware internal mpls evi-operation
Use reset hardware internal mpls evi-operation to clear EVI operation records.
reset hardware internal mpls evi-operation slot slot-number
Probe view
reset system internal adj4 statistics
Use reset system internal adj4 statistics to clear IPv4 adjacency entry statistics.
In standalone mode:
reset system internal adj4 statistics slot slot-number
In IRF mode:
reset system internal adj4 statistics chassis chassis-number slot slot-number
Probe view
slot slot-number: Clears IPv4 adjacency entry statistics on a card. The slot-number argument specifies the card by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Clears IPv4 adjacency entry statistics on a card of an IRF member device. The chassis-number argument represents the IRF member ID of the device. The slot-number argument represents the slot number of the card on the device. (In IRF mode.)
reset system internal arp statistics
Use reset system internal arp statistics to clear ARP statistics.
In standalone mode:
reset system internal arp statistics slot slot-number
In IRF mode:
reset system internal arp statistics chassis chassis-number slot slot-number
Probe view
slot slot-number: Clears ARP statistics for the card specified by its slot number. (In standalone mode.)
chassis chassis-number slot slot-number: Clears ARP statistics for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the slot number of the card. (In IRF mode.)
reset system internal fib statistics
Use reset system internal fib statistics to clear FIB statistics.
In standalone mode:
reset system internal fib statistics slot slot-number
In IRF mode:
reset system internal fib statistics chassis chassis-number slot slot-number
Probe view
slot slot-number: Specifies a card by its slot number. (In standalone mode.)
reset system internal ipv6 multicast forwarding-table dummy
Use reset system internal ipv6 multicast forwarding-table dummy to remove the temporary IPv6 multicast forwarding entries.
In standalone mode:
reset system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy { { ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] } * | all } [ slot slot-number ]
In IRF mode:
reset system internal ipv6 multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy { { ipv6-group-address [ prefix-length ] | ipv6-source-address [ prefix-length ] } * | all } [ chassis chassis-number slot slot-number ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command removes the temporary IPv6 multicast forwarding entries on the public network.
ipv6-group-address: Specifies an IPv6 multicast group address in the range of FFxy::/16, where x and y represent any hexadecimal numbers from 0 to F. If this argument is not specified, this command removes the temporary IPv6 multicast forwarding entries for all IPv6 multicast groups.
ipv6-source-address: Specifies an IPv6 multicast source address. If this argument is not specified, this command removes the temporary IPv6 multicast forwarding entries for all IPv6 multicast sources.
prefix-length: Specifies the address prefix length. The default value is 128. For an IPv6 multicast group address, the value range for this argument is 8 to 128. For an IPv6 multicast source address, the value range for this argument is 0 to 128.
all: Specifies all entries.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command removes the temporary IPv6 multicast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command displays removes the temporary IPv6 multicast forwarding entries for all MPUs in the IRF fabric. (In IRF mode.)
reset system internal ipv6 route-static nib log
Use reset system internal ipv6 route-static nib log to clear IPv6 static route NIB logs.
Probe view
reset system internal mac-address statistics
Use reset system internal mac-address statistics to clear MAC address table statistics.
In standalone mode:
reset system internal mac-address statistics slot slot-number
In IRF mode:
reset system internal mac-address statistics chassis chassis-number slot slot-number
Probe view
reset system internal mbuf relay statistics
Use reset system internal mbuf relay statistics to clear MBUF Relay statistics.
In standalone mode:
reset system internal mbuf relay statistics slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
In IRF mode:
reset system internal mbuf relay statistics chassis chassis-number slot slot-number [ cpu cpu-id [ rcv receiver-id ] ]
Probe view
slot slot-number: Clears MBUF Relay statistics on a card. The slot-number argument represents the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Clears MBUF Relay statistics of a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device and. The slot-number argument represents the number of the slot that holds the card. (In IRF mode.)
cpu cpu-id: Specifies the CPU that MBUF Relay uses. If no CPU is specified, the command clears MBUF Relay statistics for all CPUs.
rcv received-id: Specifies the MBUF Relay receiver by its ID. If no MBUF Relay receiver is specified, the command clears MBUF Relay statistics for all the receivers on the CPU.
reset system internal mpls lfib record
Use reset system internal mpls lfib record to clear information recorded by the MPLS LFIB module.
In standalone mode:
reset system internal mpls lfib record slot slot-number
In IRF mode:
reset system internal mpls lfib record chassis chassis-number slot slot-number
Probe view
display system internal mpls lfib record
reset system internal multicast forwarding-table dummy
Use reset system internal multicast forwarding-table dummy to remove temporary multicast forwarding entries.
In standalone mode:
reset system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] } * | all } [ slot slot-number ]
In IRF mode:
reset system internal multicast [ vpn-instance vpn-instance-name ] forwarding-table dummy { { source-address [ mask { mask-length | mask } ] | group-address [ mask { mask-length | mask } ] } * | all } [ chassis chassis-number slot slot-number ]
Probe view
vpn-instance vpn-instance-name: Specifies an MPLS L3VPN instance by its name, a case-sensitive string of 1 to 31 characters. If this option is not specified, the command removes temporary multicast forwarding entries on the public network.
source-address: Specifies a multicast source address. If this argument is not specified, this command removes the temporary multicast forwarding entries for all multicast sources.
group-address: Specifies a multicast group address in the range of 224.0.0.0 to 239.255.255.255. If this argument is not specified, this command removes the temporary multicast forwarding entries for all multicast groups.
mask-length: Specifies the address mask length. The default value is 32. For a multicast group address, the value range for this argument is 4 to 32. For a multicast source address, the value range for this argument is 0 to 32.
mask: Specifies the address mask. The default is 255.255.255.255.
all: Specifies all routing entries.
slot slot-number: Specifies a card by its slot number. If no card is specified, this command removes the temporary multicast forwarding entries for the MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. If this option is not specified, this command removes the temporary multicast forwarding entries for all MPUs in the IRF fabric. (In IRF mode.)
reset system internal multicast record
Use reset system internal multicast record to clear operation records for multicast entries.
Probe view
reset system internal nd statistics
Use reset system internal nd statistics to clear ND statistics.
In standalone mode:
reset system internal nd statistics slot slot-number
In IRF mode:
reset system internal nd statistics chassis chassis-number slot slot-number
Probe view
slot slot-number: Clears ND statistics for the specified card. The slot-number argument specifies the number of the slot that holds the card. (In standalone mode.)
chassis chassis-number slot slot-number: Clears ND statistics for a card on an IRF member device. The chassis-number argument specifies the ID of the IRF member device. The slot-number argument specifies the number of the slot that holds the card. (In IRF mode.)
reset system internal sflow statistics
Use reset system internal sflow statistics to clear the sFlow statistics.
In standalone mode:
reset system internal sflow statistics [ slot slot-number ]
In IRF mode:
reset system internal sflow statistics [ chassis chassis-number slot slot-number ]
probe view
S
set hardware internal diag monitor-control
Use set hardware internal diag monitor-control to enable or disable periodic diagnosis items for one or all cards.
Use the undo set hardware internal diag monitor-control to restore the periodic diagnosis items before the set operation is performed.
To view the periodic diagnosis items for a card, execute display hardware internal diag content slot slotid [ oam ].
[ undo ] set hardware internal diag monitor-control { on | off } [ slot slotid [ oam ] ]
Probe view
undo: Restores the periodic diagnosis items.
on: Enables periodic diagnosis items.
off: Disables periodic diagnosis items.
slot-number: Specifies a slot.
oam: Specifies an auxiliary CPU.
set hardware internal driver { phy-g | phy-xg } register
Use set hardware internal driver { phy-g | phy-xg } register to set the PHY register of a port.
set hardware internal driver phy-g register interface { interface-type interface-number | interface-name } { internal | external } address address data
set hardware internal driver phy-xg register interface { interface-type interface-number | interface-name } sublayer sub-number address address data
Probe view
internal: Displays the internal PHY information.
external: Displays the external PHY information.
interface-name: Specifies an interface by its name.
address: Specifies the address of a PHY register.
sub-number: Specifies a sublayer of a PHY register. The value range for this argument is 0 to 1F (hexadecimal).
data: Specifies the data.
This command might cause service failures. Use this command with caution.
set hardware internal fa fport-rx-cell-cfg slot chip fport
Use set hardware internal fa fport-rx-cell-cfg slot chip fport to set the Rx cell type on a port.
set hardware internal fa fport-rx-cell-cfg slot slot-number chip chip-num fport port-num [ bc-cell ] [ diagnostic-cell ] [ mc-cell ] [ uc-cell ]
Probe view
slot-number: Specifies a destination card by its slot number. The value range depends on the actual chassis.
chip-num: Specifies a PP chip by its number in the range of 0 to 3.
port-num: Specifies an FA port by its number in the range of 0 to 5.
bc-cell: Specifies broadcast cells.
diagnostic-cell: Specifies diagnostic cells.
mc-cell: Specifies multicast cells.
uc-cell: Specifies unicast cells.
set hardware internal fa fport-tx-cell-cfg slot chip fport
Use set hardware internal fa fport-tx-cell-cfg slot chip fport to set the Tx cell type on a port. When no cell type is specified, the command sets all cell types.
set hardware internal fa fport-tx-cell-cfg slot slot-number chip chip-num fport port-num [bc-cell ] [ diagnostic-cell ] [ mc-cell ] [ uc-cell ]
Probe view
set hardware internal fa voq statistic-cfg slot chip unit set/display hardware internal fa voq statistic-cfg slot chip
Use set hardware internal fa voq statistic-cfg slot chip unit set to set the VOQ statistics type. When no parameter is specified, the command sets all descriptors.
Use display hardware internal fa voq statistic-cfg slot chip to display the VOQ statistics type.
set hardware internal fa voq statistic-cfg slot slot-number chip chip-num unit unit-num set set-num [ descriptor ] [ { descriptor-dp | fabric-dp } dp-num ] [ { descriptor-tc | fabric-tc } tc-num ] [ tgt-fport fport-num ] [ tgt-device dev-num ]
display hardware internal fa voq statistic-cfg slot slot-number chip chip-num
Probe view
unit-num: Specifies a VOQ unit by its number, 0 or 1.
set-num: Specifies a counter by its number in the range of 0 to 3.
descriptor-dp: Specifies the DP assigned by the ingress.
fabric-dp: Specifies the DP mapped by FA.
dp-num: Specifies the DP in the range of 0 to 2.
descriptor-tc: Specifies the TC assigned by the ingress.
fabric-tc: Specifies the TC mapped by FA.
tc-num: Specifies a TC by its number. When descriptor-tc is specified, the value range for the TC-num argument is 0 to 7. When fabric-tc is specified, the value range for the TC-num argument is 0 to 3.
tgt-fport: Specifies the destination FA port of the specified cell. The fport argument specifies the Fport of the source device.
fport-num: Specifies an FA port number in the range of 0 to 5.
tgt-device: Specifies the destination device.
dev-num: Specifies the destination by its number in the range of 0 to 63.
set hardware internal fan low-speed-thresh speed
Use set hardware internal fan low-speed-thresh to set fan speed alarm thresholds.
Use undo set hardware internal fan low-speed-thresh to restore the default.
In standalone mode:
set hardware internal fan [ fan-tray-id ] low-speed-thresh speed
undo set hardware internal fan [ fan-tray-id ] low-speed-thresh
In IRF mode:
set hardware internal fan chassis chassis-number [ fan-tray-id ] low-speed-thresh speed
undo set hardware internal fan chassis chassis-number [ fan-tray-id ] low-speed-thresh
Probe view
fan-tray-id: Specifies a fan tray by its ID. Values include 1 (the top fan tray) and 2 (the bottom fan tray).
speed: Specifies the low-speed threshold. The value ranges and defaults are as follows:
· S12518—11450 to 6000 rpm, 1450 rpm by default.
· S12508—750 to 3200 rpm, 750 rpm by default.
· S12504—750 to 6000 rpm, 750 rpm by default.
chassis chassis-number: Specifies a member device by its member ID.
set hardware internal fcoe op route
Use set hardware internal fcoe op route to set the number of FC route operation records for a card.
In standalone mode:
set hardware internal fcoe op route record-num slot slot-number
In IRF mode:
set hardware internal fcoe op route record-num chassis chassis-number slot slot-number
Probe view
route record-num: Specifies the number of FC route operation records.
set hardware internal ibc lanswitch egresscntr | ingresscntr bind
Use set hardware internal ibc lanswitch egresscntr | ingresscntr bind to bind counter information for a port on an LSW chip in a slot or counter information for the specified VLAN to a bridge counter set.
set hardware internal ibc lanswitch slot slot-number lsw lsw-number { egresscntr | ingresscntr } set set-number bind { vlan vlanID | port phyport-number }
Probe view
ingresscntr: Specifies an ingress bridge counter.
egresscntr: Specifies an egress bridge counter.
slot-number: Specifies a slot by its number.
lsw-number: Specifies an LSW chip by its number in the range of 0 to 1.
VlanID: Specifies a VLAN by its ID in the range of 0 to 4095.
phyport-number: Specifies a physical port by its number in the range of 0 to 23.
set-number: Specifies a bridge counter set by its number in the range of 0 to 1.
set hardware internal ipuc cnt
Use set hardware internal ipuc cnt to bind a next hop to a counter. By default, all next hops are bound to counter 0.
In standalone mode:
set hardware internal ipuc cnt index nh nexthop-id slot slot-number
In IRF mode:
set hardware internal ipuc cnt index nh nexthop-id chassis chassis-number slot slot-number
Probe view
cnt index: Specifies a counter by its index in the range of 0 to 3.
nh nexthop-id: Specifies a next hop by its ID.
set hardware internal ipuc dropcnt
Use set hardware internal ipuc dropcnt to set the operating mode of a drop counter. By default, all counters operate in mode 0, which means the system records statistics of packets dropped by the routing engine.
In standalone mode:
set hardware internal ipuc dropcnt { 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 } slot slot-number
In IRF mode:
set hardware internal ipuc dropcnt { 0 | 1 | 2 | 3 | 4 | 5 | 6 | 7 | 8 | 9 | 10 | 11 | 12 | 13 | 14 | 15 } chassis chassis-number slot slot-number
Probe view
dropcnt mode: Specifies an operating mode for the drop counter.
set hardware internal ipuc op
Use set hardware internal ipuc op to set the number of operation records of IPv4 or IPv6 route entries.
In standalone mode:
set hardware internal ipuc op { ipv4 | ipv6 } number slot slot-number
In IRF mode:
set hardware internal ipuc op { ipv4 | ipv6 } number chassis chassis-number slot slot-number
Probe view
op { ipv4 | ipv6 }: Specifies operation records of IPv4 or IPv6 route entries.
number: Specifies the number of operation records, in the range of 0 to 20000. The default is 200. When the value is set to 0, the device does not record operations.
set hardware internal l3mc counter
Use set hardware internal l3mc counter to bind a counter to a next hop. This configuration takes effect on all PP chips of an interface card.
Use undo set hardware internal l3mc counter to unbind a counter from a next hop.
In standalone mode:
set hardware internal l3mc counter cnt-id nexthop nexthop-id slot slot-number
undo set hardware internal l3mc counter cnt-id slot slot-number
In IRF mode:
set hardware internal l3mc counter cnt-id nexthop nexthop-id chassis chassis-number slot slot-number
undo set hardware internal l3mc counter cnt-id chassis chassis-number slot slot-number
Probe view
counter cnt-id: Specifies a counter by its ID. The value for the argument is 2 or 3.
nexthop nexthop-id: Specifies a next hop by its ID. The ID must be a Layer 3 multicast next hop ID.
chassis chassis-number slot slot-number: Specifies a card on an IRF member device. The chassis-number argument specifies the IRF member device ID, and the slot-number argument specifies the number of the slot where the card resides. (In IRF mode.)
This command takes effect on only next hops for multicast.
The undo set command can be used on only bound counters. After a counter is unbound from a multicast next hop, the multicast next hop is bound to Counter 0.
set hardware internal l3mc ditcnt
Use set hardware internal l3mc ditcnt to bind a counter to an interface on an interface card.
Use undo set hardware internal l3mc ditcnt to unbind a counter from an interface.
In standalone mode:
set hardware internal l3mc ditcnt cnt-id [ vlan vlan-id ] [trunk trunk-id ] slot slot-number
undo set hardware internal l3mc ditcnt cnt-id slot slot-number
In IRF mode:
set hardware internal l3mc ditcnt cnt-id [ vlan vlan-id ] [trunk trunk-id ] chassis chassis-number slot slot-number
undo set hardware internal l3mc ditcnt cnt-id chassis chassis-number slot slot-number
Probe view
ditcnt cnt-id: Specifies a counter by its ID in the range of 0 or 1.
vlan vlan-id: Specifies a VLAN by its ID in the range of 1 to 4094.
trunk trunk-id: Specifies a trunk interface by its ID in the range of 1 to 255.
set hardware internal mpls dit_load_balance
Use set hardware internal mpls dit_load_balance to set a DIT load balancing timer.
set hardware internal mpls dit_load_balance slot slot-number time time-space
Probe view
time time-spacer: Specifies a timer interval.
set hardware internal mpls nhlfecntbind
Use set hardware internal mpls nhlfcntbind to bind an NHLFE entry with a specific incoming label to a specific counter.
set hardware internal mpls nhlfecntbind slot slot-number chip chip-number inlabel label-value count-id
Probe view
chip chip-number: Specifies a chip by its number.
label label-value: Specifies an incoming label.
count-id: Specifies a counter by its ID.
set hardware internal mpls nhlfecntunbind
Use set hardware internal mpls nhlfcntunbind to unbind an NHLFE entry with a specific incoming label from a specific counter.
set hardware internal mpls nhlfecntunbind slot slot-number chip chip-number inlabel label-value count-id
Probe view
label label-value: Specifies an incoming label by its label value.
set hardware internal mpls tticntbind
Use set hardware internal mpls tticntbind to bind a TTI to a counter.
set hardware internal mpls tticntbind mpls slot slot-number tti-index
set hardware internal mpls tticntbind ipv4 slot slot-number tti-index
set hardware internal mpls tticntbind Ethernet { Bridge-Aggregation | GigabitEthernet | InLoopBack | LoopBack | M-Ethernet | NULL | Register-Tunnel | EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
set hardware internal mpls tticntbind minm { Bridge-Aggregation | GigabitEthernet | InLoopBack | LoopBack | M-Ethernet | NULL | Register-Tunnel | EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
Probe view
mpls: Specifies an MPLS TTI.
Ethernet: Specifies an Ethernet TTI.
ipv4: Specifies an IPv4 TTI.
minm: Specifies a MINM TTI.
tti-index: Specifies a TTI index.
set hardware internal mpls tticntunbind
Use set hardware internal mpls tticntunbind to unbind a TTI from a counter.
set hardware internal mpls tticntunbind mpls slot slot-number tti-index
set hardware internal mpls tticntunbind ipv4 slot slot-number tti-index
set hardware internal mpls tticntunbind ethernet { Bridge-Aggregation | GigabitEthernet | InLoopBack | LoopBack | M-Ethernet | NULL | Register-Tunnel | EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
set hardware internal mpls tticntunbind minm { Bridge-Aggregation | GigabitEthernet | InLoopBack | LoopBack | M-Ethernet | NULL | Register-Tunnel | EVI-Link | Route-Aggregation | Ten-GigabitEthernet | Tunnel | Vlan-interface } slot slot-number tti-index
Probe view
minm: Specifies an MINM TTI.
T
test diag-offline
Use test diag-offline to diagnose the problem of an isolated card.
In standalone mode:
test diag-offline slot slot-number
In IRF mode:
test diag-offline chassis chassis-number slot slot-number
Probe view
After you execute this command, the system tests the card and displays the diagnostic result. The system also saves the diagnostic result as a log to a file in the root directory of the flash memory and displays the file name on your configuration terminal. The file is named in this format: diag_chassis-numberslot-number_YYMMDD_hhmmss, for example, /mnt/flash:/ diag_c3slot7_20130426_103159.txt.
Send the diagnostic result to H3C support for analysis.
V
view
Use view to view the contents of a specific file in the /proc/, /sys/, or /var/ directory.
In standalone mode:
view file-path [ slot slot-number ]
In IRF mode:
view file-path [ chassis chassis-number slot slot-number ]
Probe view
file-path: Specifies a file path, which is case sensitive.
slot slot-number: Displays the file contents on a card specified by its slot number. If no card is specified, the command displays the file contents on the active MPU. (In standalone mode.)
chassis chassis-number slot slot-number: Displays the file contents on a card on an IRF member device. The chassis-number argument represents the ID of the IRF member device. The slot-number argument represents the slot number of the card. If no card is specified, the command displays the file contents on the global active MPU. (In IRF mode.)
The specified file path cannot contain file links. A file link is similar to a file shortcut and points to a file or directory. You can access a file or directory through a file link.
Commands listed in this chapter can be executed, but they do not take effect.
IPv4 fast forwarding probe commands
display system internal ip fast-forwarding cache verbose
Use display system internal ip fast-forwarding cache verbose to display detailed information about the IPv4 fast forwarding table.
In standalone mode:
display system internal ip fast-forwarding cache [ ip-address ] [ slot slot-number ] verbose
In IRF mode:
display system internal ip fast-forwarding cache [ ip-address ] [ chassis chassis-number slot slot-number ] verbose
Probe view
display system internal ip fast-forwarding service-sequence
Use display system internal ip fast-forwarding service-sequence to display service module registration information in the fast forwarding module.
Probe view
IPv6 fast forwarding probe commands
display system internal ipv6 fast-forwarding cache verbose
Use display system internal ipv6 fast-forwarding cache [ ipv6-address ] verbose to display detailed information about the IPv6 fast forwarding table.
In standalone mode:
display system internal ipv6 fast-forwarding cache [ ipv6-address ] [ slot slot-number ] verbose
In IRF mode:
display system internal ipv6 fast-forwarding cache [ ipv6-address ] [ chassis chassis-number slot slot-number ] verbose
Probe view
display system internal ipv6 fast-forwarding service-information
Use display system internal ipv6 fast-forwarding service-information to display service module IPv6 registration information in the fast forwarding module.
Probe view
display system internal ipv6 fast-forwarding statistics
Use display system internal ipv6 fast-forwarding statistics to display IPv6 fast forwarding statistics.
In standalone mode:
display system internal ipv6 fast-forwarding statistics [ slot slot-number ]
In IRF mode:
display system internal ipv6 fast-forwarding statistics [ chassis chassis-number slot slot-number ]
Probe view
reset system internal ipv6 fast-forwarding statistics
Use reset system internal ipv6 fast-forwarding statistics to clear IPv6 fast forwarding statistics.
In standalone mode:
reset system internal ipv6 fast-forwarding statistics [ slot slot-number ]
In IRF mode:
reset system internal ipv6 fast-forwarding statistics [ chassis chassis-number slot slot-number ]
Probe view
IPv6 adjacency table probe commands
debugging system internal adj6
Use debugging system internal adj6 to enable IPv6 adjacency entry debugging.
Use undo debugging system internal adj6 to remove the configuration.
debugging system internal adj6 { hardware | bind | notify | entry }
undo debugging system internal adj6 { hardware | bind | notify | entry }
Probe view
display system internal adj6 entry
Use display system internal adj6 entry to display detailed information about an IPv6 adjacency entry.
In standalone mode:
display system internal adj6 entry ipv6-address interface interface-type interface-number slot slot-number
In IRF mode:
display system internal adj6 entry ipv6-address interface interface-type interface-number chassis chassis-number slot slot-number
Probe view
display system internal adj6 statistics
Use display system internal adj6 statistics to display IPv6 adjacency entry statistics.
In standalone mode:
display system internal adj6 statistics slot slot-number
In IRF mode:
display system internal adj6 statistics chassis chassis-number slot slot-number
Probe view
display system internal ipv6 adjacent-table
Use display system internal ipv6 adjacent-table to display IPv6 adjacency entries.
In standalone mode:
display system internal ipv6 adjacent-table slot slot-number [ count | verbose ]
In IRF mode:
display system internal ipv6 adjacent-table chassis chassis-number slot slot-number [ count | verbose ]
Probe view
reset system internal adj6 statistics
Use reset system internal adj6 statistics to clear IPv6 adjacency entry statistics.
In standalone mode:
reset system internal adj6 statistics slot slot-number
In IRF mode:
reset system internal adj6 statistics chassis chassis-number slot slot-number
Probe view
