13-EVI Configuration Guide
HomeSupportSwitchesS12500 SeriesConfigure & DeployConfiguration GuidesH3C S12500 Configuration Guide-Release7128-6W71013-EVI Configuration Guide
Table of Contents
Related Documents
01-EVI configuration
01-EVI configuration 603.99 KB
Configuring EVI
Overview
Ethernet Virtualization Interconnect (EVI) is a MAC-in-IP technology that provides Layer 2 connectivity between distant Layer 2 network sites across an IP routed network. It is used for connecting geographically dispersed sites of a virtualized large-scale data center that requires Layer 2 adjacency (see Figure 1).
EVI enables long-distance virtual machine workload mobility and data mobility, disaster recovery and business continuity. For example, virtual machines can move between data center sites without changing their IP addresses, so their movements are transparent to users and do not interrupt traffic.
Figure 1 Virtual machine migration
Layer 2 connectivity extension issues
EVI resolves the following Layer 2 connectivity extension issues:
·           Site independence—EVI keeps protocol failures, such as broadcast storms, from propagating across sites.
·           Transport independence—EVI has no special requirements for site location or transport network type, except that the transport network can forward IP packets.
·           High availability—EVI supports redundant edge devices and has a loop-free mechanism to prevent loops for a multihomed network site.
·           Link efficiency—EVI optimizes the inter-site multicast and broadcast transmission mechanism and implements load-sharing on redundant links.
·           Site and transport transparency—EVI is both site and transport network transparent. It has no special site or transport network topology requirements.
·           Easy management and maintenance—EVI requires deployment only on edge devices and does not introduce any topology change or configuration within sites or the transport network.
Network topologies
As shown in Figure 2, an EVI network comprises one or multiple edge devices at each site. These sites are connected through virtual links across an IP-based transport network and run the EVI IS-IS protocol to advertise their MAC address entries to each other. EVI maintains MAC routing information on the edge devices without changing the forwarding or routing information within the sites or the transport network.
Figure 2 EVI network
EVI supports multiple EVI networks on an edge device for extending different VLANs across the Layer 3 network. One EVI network can convey multiple VLANs, but one VLAN can map to only one EVI network. Each EVI network has separate network parameters and independently forwards traffic.
As shown in Figure 3, EVI network 1 extends VLAN 100 and VLAN 101 to Site 2, Site 3, and Site 4 for Web access traffic. EVI network 2 extends VLAN 4000 (the management VLAN) to all sites, and EVI network 3 extends VLANs 50 to 80 between Site 1 and Site 4 for database traffic.
Figure 3 Multiple EVI networks
Terminology
Edge device
An edge device performs typical Layer 2 learning and forwarding on the site-facing interfaces (internal interfaces) and performs tunneling and routing on the transport-facing interfaces.
EVI network ID
An edge device can belong to multiple EVI networks. Each EVI network is uniquely identified by a network ID.
EVI link
An EVI link is a bidirectional virtual Ethernet channel between a pair of edge devices in an EVI network. EVI links are conveyed on EVI tunnels. Each EVI link is uniquely identified by a pair of source and destination EVI tunnel IP addresses.
EVI tunnel
An EVI tunnel is a point-to-many automatic GRE tunnel that conveys EVI links for an EVI network. One EVI tunnel can serve only one EVI network.
EVI neighbor
All edge devices in an EVI network are EVI neighbors to one other.
ENDP
EVI Neighbor Discovery Protocol uses the client/server model to dynamically discover sites and edge devices, establish and maintain EVI links, and exchange network membership information in an EVI network.
ENDS
An EVI neighbor discovery server maintains all neighbor information in an EVI network. An EVI network can have up to two ENDSs.
ENDC
An EVI neighbor discovery client works with an ENDS to learn neighbor information and triggers EVI link setup between neighbors.
EVI IS-IS
EVI IS-IS establishes adjacencies and advertises MAC reachability information among edge devices at different sites in an EVI network.
EVI IS-IS runs independently of the Layer 3 routing protocols on the transport network and sites.
DED
Designated edge devices (DEDs) include inter-site DEDs and site DED.
An inter-site DED is elected from between the edge devices on each EVI link to send CSNP packets for LSDB synchronization.
A site DED is elected from among the redundant edge devices at a multihomed site to distribute extended VLANs among them so the traffic of a VLAN always enters or leaves the site from the same edge device.
The current software version does not support multihoming. In this document, DEDs only refer to inter-site DEDs.
Internal interface
Internal interfaces are site-facing Layer 2 interfaces that connect an edge device to switches or routers in the site.
Working mechanism
An edge device uses the following process to set up an EVI network and forward traffic at Layer 2 to remote sites:
1.      Runs ENDP to discover EVI neighbors and set up EVI links between neighbors.
2.      Runs EVI IS-IS to advertise MAC reachability information over EVI links in the EVI network.
3.      Forwards traffic based on MAC reachability information that has been advertised from other sites.
This section describes these phases in detail.
Neighbor discovery
An EVI network runs ENDP to discover all its edge devices and establishes adjacencies between edge devices in the following process:
1.      ENDS is enabled on one edge device and ENDC is enabled on all other edge devices.
2.      The ENDCs register their IP addresses and other data with the ENDS.
3.      The ENDS updates its ENDC database with received data and sends the updated database to each ENDC.
4.      After receiving the register reply, the ENDCs establish an EVI link with each other.
For high availability, you can configure up to two ENDSs for an EVI network.
MAC address learning
MAC reachability information on an EVI edge device comes from the following sources:
·           MAC entries configured or learned in the data plane—The edge devices use the typical source-MAC-based learning mechanism to learn unicast MAC addresses in their local sites (called "local MAC addresses").
·           MAC entries learned through EVI IS-IS—After completing neighbor discovery, the edge devices run EVI IS-IS in the control plane to establish adjacencies and advertise MAC reachability information that has been learned or configured in the data plane to each other over EVI links.
The mac-address max-mac-count command and the mac-address mac-learning enable command take effect only on local MAC addresses, which are learned in the data plane. They do not take effect on remote MAC addresses, which are learned in the control plane.
Unicast flow
For intra-site unicast flows, an edge device performs the typical MAC address table lookup, as shown in Figure 4.
Figure 4 Layer 2 forwarding in a site
The following forwarding process (see Figure 5) takes place for unicast flows between sites:
1.      The source edge device learns the source MAC address of the incoming Ethernet frame, and looks up the destination MAC address in its MAC table for the outgoing interface.
2.      If the outgoing interface is an EVI-Link interface rather than an internal physical port, the source edge device encapsulates the frame in a GRE header, and then adds an IP header and a link layer protocol header.
In the outer IP header, the source IP address is the source edge device's tunnel source IP address, and the destination IP address is the destination edge device's tunnel source IP address.
3.      The source edge device forwards the encapsulated packet out of the EVI link to the destination edge device across the IP transport network.
4.      The destination edge device removes the headers of the original Ethernet frame, looks up the destination MAC address in the MAC address table, and sends the frame out of the matching outgoing interface.
Figure 5 Layer 2 forwarding between sites
Multicast flow
Edge devices run IPv4 IGMP snooping or IPv6 MLD snooping on each extended VLAN and learn multicast router port and multicast member port information on EVI-Link interfaces for Layer 2 multicast forwarding as if they were Ethernet interfaces. In an extended VLAN, each edge device tunnels IGMP, MLD, and PIM protocol packets to all its remote edge devices, and the remote edge devices flood the packets in the VLAN.
For a site-to-site multicast data frame in an extended VLAN, the following process (see Figure 6) takes place:
1.      The DR in a site sends out a multicast frame.
2.      The source edge device copies the frame and encapsulates one copy on each multicast member EVI-Link interface.
3.      The source edge device unicasts the encapsulated frames to the destination edge devices over the EVI links.
4.      Each destination edge device removes the headers of the multicast frame and copies the multicast frame on each multicast member interface.
5.      Each destination edge device sends the multicast frame out of all member interfaces to the destination hosts.
Figure 6 Multicast data frame forwarding process
Flooding flow
An edge device handles floodings by frame type, as follows:
·           Broadcast frame—Floods the frame out of all interfaces in the VLAN where the frame has been received, including internal interfaces and EVI-link interfaces. For ARP packets, you can use the ARP flooding suppression feature (see "ARP flooding suppression") to reduce ARP broadcasts.
·           Destination-unknown unicast or multicast frame—Floods the frame out of all internal interfaces in the VLAN where the frame has been received. The edge device typically does not propagate destination unknown frames to other sites. If a site-to-site flooding is desirable for a special MAC address, use the selective flooding feature (see "Selective flooding").
If a frame must be flooded to remote sites, the EVI edge device replicates the frame on each EVI link, encapsulates each replica in a unicast frame, and sends the unicast frames to their respective destination sites.
Placement of Layer 3 gateways
For the hosts in an extended VLAN at a site, their Layer 3 gateway must be on the edge device at the local site rather than a remote site.
ARP flooding suppression reduces ARP request broadcasts on the EVI network by enabling edge devices to reply to ARP requests on behalf of remote-site hosts. As shown in Figure 7, this feature snoops ARP replies on an EVI tunnel interface to cache ARP entries for remote MAC addresses. If an ARP request has a matching ARP entry, the local edge device replies to the request on behalf of the remote-site host. If no matching ARP entry is found, the edge device floods the request to the EVI network.
ARP flooding suppression uses the following workflow:
1.      Host IP1 in site A sends an ARP request to obtain the MAC address of IP2.
2.      Site A's edge device floods the ARP requests out of all interfaces, including the EVI tunnel interfaces.
3.      Site B's edge device de-encapsulates the ARP request and broadcasts the request.
4.      IP2 sends an ARP reply back to site A's edge device over the EVI link.
5.      Site A's edge device creates an ARP cache entry for the remote MAC address and forwards the reply to the requesting host.
6.      Site A's edge device replies to all subsequent requests for the MAC address of IP2.
Figure 7 ARP flooding suppression
Selective flooding
Selective flooding enables an edge device to send an unknown unicast or multicast frame out of an EVI tunnel interface.
This feature is designed for special multicast addresses that require flooding across sites and cannot be added to a multicast forwarding table by IGMP snooping.
For example, you must configure selective flooding for PIM hellos, IGMP general query packets, and Microsoft NLBS cluster traffic to be sent out of an EVI tunnel interface.
Path MTU
When encapsulating an Ethernet frame in EVI, the edge device does not modify the Ethernet frame, but sets the DF bit in the IP header. For an Ethernet transport network, the total packet size increases by up to 46 bytes. Because EVI does not support path MTU discovery, your EVI deployment must make sure the path MTU of the transport network is higher than the maximum size of EVI tunneled frames.
EVI configuration task list
Tasks at a glance
Remarks
Configuring EVI basic functions:
·       (Required.) Configuring an IPv4 EVI tunnel
·       (Required.) Assigning a network ID to the EVI tunnel
·       (Required.) Specifying extended VLANs on the EVI tunnel
·       (Required.) Configuring ENDP
·       (Required.) Enabling EVI on transport-facing physical interfaces
All edge devices in an EVI network must have the same network ID.
An extended VLAN can be assigned only to one EVI network.
(Optional.) Tuning EVI IS-IS parameters
EVI IS-IS automatically runs on an EVI tunnel interface immediately after the interface is created.
You can tune EVI IS-IS parameters for optimizing network performance.
(Optional.) Enabling EVI ARP flooding suppression
Perform this task to reduce ARP request broadcasts on an EVI network.
(Optional.) Enabling selective flooding for a MAC address
Perform this task for special multicast MAC addresses that require Layer 2 inter-site forwarding but cannot be learned into the MAC address table.
All tasks in this section are required for setting up an EVI network.
Step
Remarks
1.     Enter system view.
N/A
2.     Create an EVI tunnel interface and enter tunnel interface view.
interface tunnel number mode evi
By default, no tunnel interface exists.
The endpoints of a tunnel must use the same tunnel mode.
3.     Specify a source IPv4 address or interface for the tunnel.
source { ipv4-address | interface-type interface-number }
By default, no source IP address or source interface is specified for any tunnel.
EVI uses the specified address or the primary IP address of the specified source interface as the source IP address of tunneled packets on the transport network.
The source interface can be a Layer 3 Ethernet interface, Layer 3 aggregate interface, VLAN interface, or Layer 3 loopback interface.
EVI networks can share a tunnel source IP address or interface.
* IMPORTANT:
To avoid forwarding failure, do not use a GRE tunnel interface or its IP address (configure with the ip address command in tunnel interface view) as the source interface or IP address of an EVI tunnel.
4.     Configure the EVI link keepalive interval and the maximum number of keepalive transmissions.
keepalive [ seconds [ times ] ]
By default, a keepalive packet is sent every five seconds and the maximum number of transmissions is two.
If no reply is received from the remote end on an EVI link after the maximum number of keepalive transmissions is reached, the local end considers the EVI link as having failed.
Assign the same network ID to the EVI tunnels of all edge devices in an EVI network.
On an edge device, the network ID assigned to an EVI tunnel must be unique among all EVI tunnels.
To assign a network ID to an EVI tunnel:
Step
Remarks
N/A
2.     Enter EVI tunnel interface view.
interface tunnel number [ mode evi ]
N/A
3.     Specify a network ID.
evi network-id number
By default, no network ID is specified.
When configuring extended VLANs, follow these guidelines:
·           An extended VLAN can be specified only on one EVI tunnel.
·           To avoid loops, do not assign transport-facing ports to extended VLANs.
·           To avoid data breach, make sure all edge devices in an EVI network maintain the same list of extended VLANs.
To assign extended VLANs to an EVI tunnel:
Step
Remarks
N/A
N/A
3.     Specify a list of extended VLANs.
evi-isis extend-vlan vlan-list
By default, no VLANs are specified on any EVI tunnel.
To specify more extended VLANs, repeat this step.
Configuring ENDP
ENDP enables the edge devices in an EVI network to discovery each other.
Configure an edge device as an ENDS to provide registration services or as an ENDC to register with an ENDS.
Configuration guidelines
·           You can configure up to two ENDSs on an EVI tunnel interface for redundancy. These two ENDSs work separately. The failure of one ENDS does not affect the neighbor discovery and EVI link maintenance in the EVI network.
·           To guarantee that each edge device can get the addresses of all its EVI neighbors, make sure the ENDSs are the same across the EVI network.
·           To improve security, enable ENDP authentication.
?  Make sure all authentication-enabled ENDCs and ENDSs in an EVI network use the same authentication key.
?  If authentication is disabled on an ENDS, all ENDCs, including authentication-enabled ENDCs, can register with the ENDS without authentication.
?  If authentication is enabled on an ENDS, only authentication-enabled ENDCs that use the same authentication key as the ENDS can register with the ENDS.
Configuring the edge device as an ENDS on the EVI tunnel
Step
Remarks
N/A
N/A
3.     Enable ENDS.
evi neighbor-discovery server enable
By default, ENDS is disabled.
An ENDS is always an ENDC of itself. You can use the evi neighbor-discovery client enable command to add one more ENDS, and use the evi neighbor-discovery client register-interval command to modify the ENDC registration interval.
4.     (Optional.) Enable ENDP authentication.
evi neighbor-discovery authentication simple-password
By default, ENDP authentication is disabled.
Configuring the edge device as an ENDC on the EVI tunnel
Step
Remarks
N/A
N/A
3.     Configure the edge device as the ENDC of an ENDS.
evi neighbor-discovery client enable server-ip
By default, ENDC is disabled.
If ENDS is enabled on the EVI tunnel interface, you can use this command to specify only one more ENDS.
If ENDS is disabled, you can repeat this command to specify up to two ENDSs.
ENDS address is the tunnel source address configured on an ENDS-enabled EVI tunnel interface.
All ENDSs and ENDCs in an EVI network must use the same authentication password.
5.     Configure the interval at which the ENDC updates its registration with ENDSs.
evi neighbor-discovery client register-interval time-value
By default, an ENDC update its registration with an ENDS every 15 seconds.
Enable EVI on all transport-facing physical interfaces that provide transport network access for EVI tunnels.
To avoid forwarding failure, do not enable the spanning tree feature on these interfaces.
To enable EVI on an interface:
Step
Remarks
N/A
2.     Enter Layer 2 or Layer 3 Ethernet interface view.
N/A
3.     Enable EVI on the interface.
evi enable
By default, EVI function is disabled on all interfaces.
EVI IS-IS automatically runs on an EVI link immediately after the link is set up. You can tune EVI IS-IS parameters to optimize the protocol performance.
EVI IS-IS configuration task list
All EVI IS-IS configuration tasks are optional.
Tasks at a glance
Remarks
Configuring an EVI IS-IS process
N/A
Optimizing an EVI IS-IS network:
·       Configuring the EVI IS-IS hello interval
·       Configuring the hello multiplier for calculating the adjacency hold time
·       Configuring the DED priority
·       Configuring the CSNP packet sending interval
·       Configuring the minimum LSP sending interval and the maximum number of LSPs sent at each interval
·       Configuring the maximum LSP lifetime
·       Configuring the LSP refresh interval
·       Enabling adjacency change logging
Perform the EVI IS-IS network optimization tasks to enable fast EVI link failure detection, set appropriate MAC reachability information update interval, and control the volume of LSP and CSNP traffic on an EVI network.
Configuring graceful restart for an EVI IS-IS process
Perform this task for providing nonstop services.
Increasing the maximum number of MAC entries in an LSP for an EVI IS-IS process
Perform this task depending on the MAC address table size on the edge device.
When you create an EVI tunnel interface, the system automatically creates an EVI IS-IS process that has the same number as the interface. You can access the EVI IS-IS process view to change EVI IS-IS process-specific settings.
Alternatively, you can create an EVI IS-IS process before creating an EVI tunnel interface and configure the process-specific settings, but the process and its settings take effect only after the interface is created.
An automatically created EVI IS-IS process can be manually deleted by using the undo evi-isis command or automatically deleted when you delete its EVI tunnel interface. In contrast, to delete a manually created EVI IS-IS process, you must use the undo evi-isis command. Deleting its EVI tunnel interface can only invalidate the process.
If the EVI tunnel interface has been deleted, the undo evi-isis command deletes the EVI IS-IS process and clears the settings made in EVI IS-IS process view. If the EVI tunnel interface still exists, the undo evi-isis command only clears the settings made in EVI IS-IS process view.
To create an EVI IS-IS process or enter its view:
Step
Remarks
N/A
2.     Create an EVI IS-IS process and enter EVI IS-IS view.
evi-isis process-id
By default, no EVI IS-IS process is configured.
Perform the tasks in this section to optimize an EVI IS-IS network for bandwidth efficiency and high performance.
EVI edge devices send EVI IS-IS hellos over EVI links to establish and maintain adjacencies, and elect the DED on each EVI link.
A short interval increases the speed of network convergence but requires more system resources.
To configure the EVI IS-IS hello interval on an EVI tunnel interface:
Step
Remarks
N/A
2.     Enter tunnel interface view.
N/A
3.     Configure the EVI IS-IS hello interval.
evi-isis timer hello seconds
The default hello interval is 10 seconds.
If the edge device is the DED on an EVI link, its hello interval on the link is one-third of the hello interval set with this command.
Adjacency hold time sets how long one edge device retains the adjacency with another. It determines how long an edge device can detect a failed EVI link.
If the graceful restart function is disabled, the adjacency hold time equals the EVI IS-IS hello interval multiplied by the hello multiplier set in this section.
If graceful restart is enabled, the adjacency hold time equals the restart interval or the EVI IS-IS hello interval multiplied by the hello multiplier, whichever is greater.
The hello interval of a DED is one-third of the hello interval set with the evi-isis timer hello command.
An edge device sends its adjacency hold time in hello packets to update the adjacencies with its neighbor edge devices. A neighbor edge device removes the adjacency with the advertising edge device and recalculates routes if it does not receive an EVI IS-IS hello packet from the advertising edge device before the time value expires.
To configure the multiplier for calculating the adjacency hold time on an EVI tunnel interface:
Step
Remarks
N/A
N/A
3.     Configure the multiplier for calculating the adjacency hold time.
evi-isis timer holding-multiplier value
The default multiplier is 3.
The maximum adjacency hold time is 65535 seconds. If this value is exceeded, the actual adjacency hold time is set to 65535 seconds.
The edge devices on an EVI link exchange their DED priority in EVI IS-IS hello packets to elect a DED for periodic LSDB synchronization. You can use the evi-isis timer csnp command to change the synchronization interval.
The edge device with higher DED priority is more likely to be elected as the DED. If two edge devices have the same DED priority, the device with the highest MAC address is elected.
To configure the DED priority of the edge device on an EVI tunnel interface:
Step
Remarks
N/A
N/A
3.     Configure the DED priority.
evi-isis ded-priority value
The default DED priority is 64.
This configuration takes effect only on DEDs.
The DEDs in an EVI network regularly send CSNP packets to advertise LSP summaries for LSDB synchronization.
To configure the CSNP packet sending interval on a DED:
Step
Remarks
N/A
N/A
3.     Configure the CSNP packet sending interval.
evi-isis timer csnp seconds
By default, a DED sends CSNP packets every 10 seconds.
When MAC reachability information changes, an edge device sends LSP updates to notify its adjacent EVI neighbors.
To control EVI IS-IS LSP traffic on the EVI network:
Step
Remarks
N/A
N/A
3.     Configure the minimum LSP sending interval and the maximum number of LSP segments sent at each interval.
evi-isis timer lsp time [ count count ]
By default, the minimum LSP sending interval is 100 milliseconds, and a maximum of five LSP segments can be sent at each interval.
Before the minimum sending interval is reached, the EVI tunnel interface cannot send LSP segments.
EVI edge devices add a lifetime in each LSP they have advertised, and update LSPs regularly or when MAC reachability information changes. If an edge device does not receive an update for an LSP before it expires, the edge device removes the LSP from the LSDB and removes the MAC addresses advertised through the LSP from the data plane.
To specify the maximum lifetime of the LSPs generated by an EVI IS-IS process:
Step
Remarks
N/A
2.     Enter EVI IS-IS process view.
evi-isis process-id
N/A
3.     Configure the maximum LSP lifetime.
timer lsp-max-age seconds
The default maximum LSP lifetime is 1200 seconds.
An edge device regularly sends LSP updates to remote edge devices for updating MAC reachability information.
To change the LSP refresh interval:
Step
Remarks
N/A
evi-isis process-id
N/A
3.     Configure the LSP refresh interval.
timer lsp-refresh seconds
The default LSP refresh interval is 900 seconds.
The minimum LSP sending interval and the maximum number of LSPs sent at each interval can affect the actual LSP refresh interval.
To avoid unnecessary age-outs, appropriately set the LSP refresh interval and the LSP lifetime.
Adjacency change logging enables an EVI IS-IS process to send a log message to the information center when an adjacency change occurs. With the information center, you can set log message filtering and output rules, including output destinations. For more information about using the information center, see Network Management and Monitoring Configuration Guide.
To enable adjacency change logging:
Step
Remarks
N/A
2.     Enter EVI IS-IS view.
evi-isis process-id
N/A
3.     Enable adjacency change logging.
log-peer-change enable
By default, adjacency change logging is enabled.
Enable graceful restart for the peer EVI IS-IS processes at two ends of an EVI tunnel to guarantee nonstop forwarding while the peer EVI IS-IS processes are re-establishing their adjacency after a process restart or active/standby switchover occurs.
If graceful restart is enabled, the adjacency hold time equals the restart interval or the EVI IS-IS hello interval multiplied by the holding-multiplier, whichever is greater. (For a DED, the hello interval is one-third of the hello interval set with the evi-isis timer hello command.)
To configure graceful restart for an EVI IS-IS process:
Step
Remarks
N/A
evi-isis process-id
N/A
3.     Enable graceful restart.
graceful-restart
By default, EVI IS-IS graceful restart is disabled.
4.     Configure the restart interval.
graceful-restart interval interval-value
The default restart interval is 300 seconds.
If the restarting EVI process fails to complete re-establishing the adjacency with the peer EVI process, the EVI link goes down.
An EVI IS-IS process advertises all local MAC reachability information in one LSP. By default, an LSP can convey up to 55 x 210 MAC address entries.
To increase this number to accommodate all local MAC address entries, create virtual systems. Each virtual system represents an increase of 55 x 210 MAC reachability information entries. If n virtual systems are created, the maximum number of MAC address entries in an LSP is (n+1) x 55 x 210.
To configure EVI IS-IS virtual system:
Step
Remarks
N/A
evi-isis process-id
N/A
3.     Create an EVI IS-IS virtual system.
virtual-system systemid
By default, no EVI IS-IS virtual systems are created.
* IMPORTANT:
The virtual system ID must be unique in the EVI network.
Step
Remarks
N/A
N/A
3.     Enable EVI ARP flooding suppression.
evi arp-suppression enable
By default, EVI ARP flooding suppression is disabled.
4.     (Optional.) Display EVI ARP flooding suppression entries.
·       In standalone mode:
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ slot slot-number ] [ count ]
·       In IRF mode:
display evi arp-suppression interface tunnel interface-number [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
The display commands are available in any view.
CAUTION
CAUTION:
Do not configure selective flooding for a unicast MAC address that might be learned at an edge device's data plane. The configuration can cause packets destined for the MAC address to be dropped on remote devices after they get the MAC address through EVI IS-IS.
An edge device by default floods unknown unicast and multicast frames only to internal interfaces.
If an application uses a special multicast address that requires flooding across sites and cannot be added to a multicast forwarding table by IGMP snooping, enable selective flooding for it.
To enable selective flooding for a MAC address:
Step
Remarks
N/A
N/A
3.     Enable selective flooding for the MAC address in a set of VLANs.
evi selective-flooding mac-address mac-address vlan vlan-id-list
By default, selective flooding is disabled for all MAC addresses.
Displaying and maintaining EVI
On an ENDS, display IPv4 ENDS information (on an ENDS).
display evi neighbor-discovery server summary
On an ENDS, display IPv4 neighbors that have registered with the ENDS.
display evi neighbor-discovery server member [ interface tunnel interface-number | local local-ip | remote client-ip ]
On an ENDS, display ENDS statistics.
display evi neighbor-discovery server statistics interface tunnel interface-number
Display IPv4 ENDC information.
display evi neighbor-discovery client summary
Display IPv4 neighbors that an ENDC has discovered.
display evi neighbor-discovery client member [ interface tunnel interface-number | local local-ip | remote client-ip | server server-ip ]
Display ENDC statistics.
display evi neighbor-discovery client statistics interface tunnel interface-number
Display EVI-Link interface information for an EVI tunnel.
display evi link interface tunnel interface-number
Display information about EVI-Link interfaces.
display interface [ evi-link [ interface-number ] ] [ brief [ description ] ]
Display brief EVI IS-IS process information.
display evi-isis brief [ process-id ]
Display the MAC address database of EVI IS-IS.
display evi-isis { local | remote } mac-info [ interface tunnel interface-number [ vlan vlan-id ] [ count ] ]
Display EVI IS-IS link state database.
display evi-isis lsdb [ local | lsp-id lspid | verbose ] * [ process-id ]
Display EVI IS-IS neighbors.
display evi-isis peer [ process-id ]
Display EVI IS-IS information for a tunnel interface.
display evi-isis tunnel [ tunnel-number ]
Display EVI IS-IS GR state.
display evi-isis graceful-restart status [ process-id ]
Display remote MAC addresses (in standalone mode).
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ slot slot-number ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id [ slot slot-number ]
Display remote MAC addresses (in IRF mode).
display evi mac-address interface tunnel interface-number [ vlan vlan-id ] [ chassis chassis-number slot slot-number ] [ count ]
display evi mac-address interface tunnel interface-number mac-address mac-address vlan vlan-id [ chassis chassis-number slot slot-number ]
Display EVI ARP flooding suppression entries (in standalone mode).
Display EVI ARP flooding suppression entries (in IRF mode).
Clear data for EVI IS-IS processes.
reset evi-isis all [ process-id ]
Clear EVI ARP flooding suppression entries.
reset evi arp-suppression interface tunnel interface-number [ vlan vlan-id ]
EVI configuration examples
By default, Ethernet interfaces, VLAN interfaces, and aggregate interfaces are down. To configure these interfaces, use the undo shutdown command to bring them up.
Single-homed EVI network configuration example
Network requirements
As shown in Figure 8, use EVI to connect site 1, site 2, and site 3 across an IP network into a large Layer 2 network, and extend VLAN 21 to VLAN 100 across the sites.
Use network ID 1 to identify the EVI network.
Use Switch A as an ENDS and all other edge switches as ENDCs for neighbor discovery.
Figure 8 Network diagram
Configuration procedure
This example assumes that routes have been configured for the sites to reach each other.
1.      Configure Switch A:
# Configure the EVI tunnel source interface (VLAN-interface 10 in this example), and assign the transport-facing physical interface GigabitEthernet 3/0/1 to the VLAN.
[SwitchA] vlan 10
[SwitchA-vlan10] port gigabitethernet 3/0/1
[SwitchA-vlan10] quit
[SwitchA-Vlan-interface10] ip address 1.1.1.1 24
# Create an IPv4 EVI tunnel interface.
[SwitchA] interface tunnel 0 mode evi
# Set the network ID of the EVI tunnel interface to 1.
[SwitchA-Tunnel0] evi network-id 1
# Specify the IP address of VLAN-interface 10 as the source IP of the EVI tunnel.
[SwitchA-Tunnel0] source 1.1.1.1
# Set the tunnel keepalive interval to 20 seconds and the maximum number of transmissions to 2.
[SwitchA-Tunnel0] keepalive 20 2
# Specify extended VLANs on the EVI tunnel interface.
[SwitchA-Tunnel0] evi-isis extend-vlan 21 to 100
# Configure Switch A as an ENDS on the tunnel interface.
[SwitchA-Tunnel0] evi neighbor-discovery server enable
[SwitchA-Tunnel0] quit
# Enable EVI on GigabitEthernet 3/0/1.
[SwitchA] interface gigabitethernet 3/0/1
[SwitchA-GigabitEthernet3/0/1] evi enable
[SwitchA-GigabitEthernet3/0/1] quit
2.      Configure Switch B:
[SwitchB] vlan 10
[SwitchB-vlan10] port gigabitethernet 3/0/1
[SwitchB-vlan10] quit
[SwitchB-Vlan-interface10] ip address 1.1.2.1 24
[SwitchB] interface tunnel 0 mode evi
[SwitchB-Tunnel0] evi network-id 1
[SwitchB-Tunnel0] source 1.1.2.1
[SwitchB-Tunnel0] keepalive 20 2
[SwitchB-Tunnel0] evi-isis extend-vlan 21 to 100
# Configure Switch B as an ENDC of Switch A.
[SwitchB-Tunnel0] evi neighbor-discovery client enable 1.1.1.1
[SwitchB-Tunnel0] quit
[SwitchB] interface gigabitethernet 3/0/1
[SwitchB-GigabitEthernet3/0/1] evi enable
[SwitchB-GigabitEthernet3/0/1] quit
3.      Configure Switch C:
[SwitchC] vlan 10
[SwitchC-vlan10] port gigabitethernet 3/0/1
[SwitchC-vlan10] quit
[SwitchC] interface vlan-interface 10
[SwitchC-Vlan-interface10] ip address 1.1.3.1 24
[SwitchC-Vlan-interface10] quit
[SwitchC] interface tunnel 0 mode evi
[SwitchC-Tunnel0] evi network-id 1
[SwitchC-Tunnel0] source 1.1.3.1
[SwitchC-Tunnel0] keepalive 20 2
[SwitchC-Tunnel0] evi-isis extend-vlan 21 to 100
# Configure Switch C as an ENDC of Switch A.
[SwitchC-Tunnel0] evi neighbor-discovery client enable 1.1.1.1
[SwitchC-Tunnel0] quit
[SwitchC] interface gigabitethernet 3/0/1
[SwitchC-GigabitEthernet3/0/1] evi enable
[SwitchC-GigabitEthernet3/0/1] quit
1.      Verify the configuration on Switch A:
# Display information about the EVI tunnel interface.
[SwitchA] display interface tunnel 0
Tunnel0
Current state: UP
Line protocol state: UP
Maximum Transmit Unit: 64000
Internet protocol processing: disabled
Tunnel source 1.1.1.1
Tunnel keepalive enabled, Period(20 s), Retries(2)
Network ID 1
Tunnel protocol/transport GRE_EVI/IP
Last clearing of counters:  Never
# Display information about EVI-Link interfaces.
[SwitchA] display evi link interface tunnel 0
Interface     Status Source          Destination
Evi-Link1     UP     1.1.1.1         1.1.2.1
Evi-Link2     UP     1.1.1.1         1.1.3.1
# Display ENDS information.
[SwitchA] display evi neighbor-discovery server summary
Interface      Local Address   Network ID    Auth        Members
Tunnel0        1.1.1.1         1             disabled    3
# Display ENDC information.
[SwitchA] display evi neighbor-discovery client summary
                         Status: I-Init  E-Establish  P-Probe
Interface      Local Address   Server Address  Network ID    Auth        Status
Tunnel0        1.1.1.1         1.1.1.1         1             disabled    E
# Display EVI neighbors registered with the ENDS.
[SwitchA] display evi neighbor-discovery server member
Interface: Tunnel0    Network ID: 1
IP Address: 1.1.1.1
Client Address  System ID         Expire    Created Time
1.1.1.1         000F-0001-0001    25        2012/01/01 00:00:43
1.1.2.1         000F-0001-0002    15        2012/01/01 01:00:46
1.1.3.1         000F-0001-0003    20        2012/01/01 01:02:13
# Display neighbor entries that Switch A has learned.
[SwitchA] display evi neighbor-discovery client member
Local Address: 1.1.1.1
Server Address: 1.1.1.1
Neighbor        System ID         Created Time           Expire    Status
1.1.2.1         000F-0001-0002    2012/01/01 12:12:12    13        Up
1.1.3.1         000F-0001-0003    2012/01/01 12:12:12    12        Up
2.      Verify the configuration on Switch B:
[SwitchB] display interface tunnel 0
Tunnel0
Current state: UP
Tunnel source 1.1.2.1
Network ID 1
[SwitchB] display evi link interface tunnel 0
Evi-Link1     UP     1.1.2.1         1.1.1.1
Evi-Link2     UP     1.1.2.1         1.1.3.1
[SwitchB] display evi neighbor-discovery client summary
Tunnel0        1.1.2.1         1.1.1.1         1             disabled    E
# Display neighbor entries that Switch B has learned.
[SwitchB] display evi neighbor-discovery client member
Local Address: 1.1.3.1
1.1.1.1        000F-0001-0001    2012/01/01 12:12:12    13        Up
1.1.3.1        000F-0001-0003    2012/01/01 12:12:12    13        Up
3.      Verify the configuration on Switch C:
[SwitchC] display interface tunnel 0
Tunnel0
Current state: UP
Tunnel source 1.1.3.1
Network ID 1
# Display information about EVI-Link interfaces on Switch C.
[SwitchC] display evi link interface tunnel 0
Evi-Link1     UP     1.1.3.1         1.1.1.1
Evi-Link2     UP     1.1.3.1         1.1.2.1
[SwitchC] display evi neighbor-discovery client summary
Tunnel0        1.1.3.1         1.1.1.1         1             disabled    E
# Display neighbor entries that Switch C has learned.
[SwitchC] display evi neighbor-discovery client member
1.1.2.1        000F-0000-0002    2012/01/01 12:12:12    13        Up
4.      Verify that hosts in different sites can ping one another in the same VLAN.
Multiple-EVI-networks configuration example
Use EVI to connect the sites of the data center in Figure 9. To isolate different types of traffic and extend their VLANs to different sites, set up the following EVI networks:
·           Database EVI network (network ID 1)—Extends VLANs 100 and 101 across sites 2, 3, and 4.
·           Network management EVI network (network ID 2)—Extends VLAN 4000 across all the sites.
·           Web service EVI network (network ID 3)—Extends VLANs 50 to 80 across sites 1 and 4.
In each EVI network, use the edge device at site 4 as an ENDS and all other edge devices as its ENDCs.
Figure 9 Network diagram
1.      Configure site 4:
# Configure the EVI tunnel source interface for all EVI tunnels (VLAN-interface 10 in this example), and assign the transport-facing physical interface GigabitEthernet 3/0/1 to the VLAN.
<Site4> system-view
[Site4] vlan 10
[Site4-vlan10] port gigabitethernet 3/0/1
[Site4-vlan10] quit
[Site4] interface vlan-interface 10
[Site4-Vlan-interface10] ip address 172.16.4.1 16
[Site4-Vlan-interface10] quit
# Configure the database EVI network.
[Site4] interface tunnel 101 mode evi
[Site4-Tunnel101] source 172.16.4.1
[Site4-Tunnel101] evi network-id 1
[Site4-Tunnel101] evi-isis extend-vlan 100 101
[Site4-Tunnel101] evi neighbor-discovery server enable
[Site4-Tunnel101] quit
# Configure the network management EVI network.
[Site4] interface tunnel 102 mode evi
[Site4-Tunnel102] source 172.16.4.1
[Site4-Tunnel102] evi network-id 2
[Site4-Tunnel102] evi-isis extend-vlan 4000
[Site4-Tunnel102] evi neighbor-discovery server enable
[Site4-Tunnel102] quit
# Configure the Web service EVI network.
[Site4] interface tunnel 103 mode evi
[Site4-Tunnel103] source 172.16.4.1
[Site4-Tunnel103] evi network-id 3
[Site4-Tunnel103] evi-isis extend-vlan 50 to 80
[Site4-Tunnel103] evi neighbor-discovery server enable
[Site4-Tunnel103] quit
[Site4] interface gigabitethernet 3/0/1
[Site4-GigabitEthernet3/0/1] evi enable
[Site4-GigabitEthernet3/0/1] quit
2.      Configure site 1:
<Site1> system-view
[Site1] vlan 10
[Site1-vlan10] port gigabitethernet 3/0/1
[Site1-vlan10] quit
[Site1] interface vlan-interface 10
[Site1-Vlan-interface10] ip address 172.16.1.1 16
[Site1-Vlan-interface10] quit
[Site1] interface tunnel 102 mode evi
[Site1-Tunnel102] source 172.16.1.1
[Site1-Tunnel102] evi network-id 2
[Site1-Tunnel102] evi-isis extend-vlan 4000
[Site1-Tunnel102] evi neighbor-discovery client enable 172.16.4.1
[Site1-Tunnel102] quit
[Site1] interface tunnel 103 mode evi
[Site1-Tunnel103] source 172.16.1.1
[Site1-Tunnel103] evi network-id 3
[Site1-Tunnel103] evi-isis extend-vlan 50 to 80
[Site1-Tunnel103] evi neighbor-discovery client enable 172.16.4.1
[Site1-Tunnel103] quit
# Enable EVI on GigabitEthernet 3/0/1, the physical interface for the EVI tunnel.
[Site1] interface gigabitethernet 3/0/1
[Site1-GigabitEthernet3/0/1] evi enable
[Site1-GigabitEthernet3/0/1] quit
3.      Configure all the other sites in the same way that site 1 is configured. Make sure extended VLANs are correctly configured at each site.
# Display neighbors registered with the ENDS in each EVI network.
[Site4] display evi neighbor-discovery server member
Interface: Tunnel101    Network ID: 1
IP Address: 172.16.4.1
172.16.2.1      000F-0001-0002    25        2011/01/01 00:00:43
172.16.3.1      000F-0001-0003    15        2011/01/01 01:00:46
172.16.4.1      000F-0001-0004    20        2011/01/01 01:02:13
Interface: Tunnel102    Network ID: 2
172.16.1.1      000F-0001-0001    19        2011/01/01 00:19:31
172.16.5.1      000F-0001-0005    18        2011/01/01 01:04:32
Interface: Tunnel103    Network ID: 3
EVI Layer 2 multicast configuration example
Configure the EVI network (network ID 1) in Figure 10 to transmit multicast traffic for the multicast group at 228.8.8.8 in VLAN 100. The multicast source is connected to Switch A in Site 1, and a receiver host is attached to Switch B in Site 2.
In the EVI network, Switch A is the ENDS, and Switch B is the ENDC.
Figure 10 Network diagram
1.      Configure the Router:
# Enable IP multicast routing, and enable IGMP on VLAN-interface 100.
<Router> system-view
[Router] multicast routing-enable
[Router] vlan 100
[Router-vlan100] quit
[Router] interface vlan-interface 100
[Router-Vlan-interface100] ip address 100.100.1.1 24
[Router-Vlan-interface100] igmp enable
2.      Configure Switch A:
[SwitchA] vlan 10
# Configure Switch A as an ENDS on the EVI tunnel interface.
# Enable selective flooding for PIM hellos (destination MAC 0100-5e00-0001, and destination IP 224.0.0.1) and IGMP general query packets (destination MAC 0100-5e00-000D, and destination IP 224.0.0.13). These destination MAC addresses cannot be learned in the data plane. Selective flooding enables these packets to be sent between sites.
[SwitchA-Tunnel0] evi selective-flooding mac-address 0100-5e00-0001 vlan 100
[SwitchA-Tunnel0] evi selective-flooding mac-address 0100-5e00-000D vlan 100
# Enable global IGMP snooping.
[SwitchA] igmp-snooping
[SwitchA-igmp-snooping] quit
# Create VLAN 100, assign GigabitEthernet 3/0/2 and GigabitEthernet 3/0/3 to the VLAN, and enable IGMP snooping in the VLAN.
[SwitchA] vlan 100
[SwitchA-vlan100] port gigabitethernet 3/0/2 to gigabitethernet 3/0/3
[SwitchA-vlan100] igmp-snooping enable
[SwitchA-vlan100] quit
3.      Configure Switch B:
[SwitchB] vlan 10
[SwitchB] igmp-snooping
[SwitchB-igmp-snooping] quit
# Create VLAN 100, assign GigabitEthernet 3/0/2 to the VLAN, and enable IGMP snooping in the VLAN.
[SwitchA] vlan 100
1.      On Switch A:
# Display EVI-Link interface information.
Evi-Link0     UP     1.1.1.1         1.1.2.1
# Display dynamic IGMP snooping forwarding entries.
[SwitchA] display igmp-snooping group
Total 1 entries.
VLAN 100: Total 1 entries.
  (0.0.0.0, 228.8.8.8)
    Host slots (0 in total):
    Host ports (1 in total):
      ELNK0                   (00:04:01)
2.      On Switch B:
Evi-Link0     UP     1.1.2.1         1.1.1.1
# Display Router port information.
[SwitchB] display igmp-snooping router-port
VLAN 100:
  Router slots (0 in total):
  Router ports (1 in total):
    ELNK0                   (00:02:35)
[SwitchB] display igmp-snooping group
Total 1 entries.
    Host slots (1 in total):
      chassis 1 slot 3
      GE3/0/2
